[mapguide-commits] r10151 - in branches/4.0/MgDev/Server/RepositoryAdmin/app: . Commands
    svn_mapguide at osgeo.org
    Thu Jun 12 07:54:41 PDT 2025
Author: jng
Date: 2025-06-12 07:54:40 -0700 (Thu, 12 Jun 2025)
New Revision: 10151
Added:
   branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/RootCommand.cs
   branches/4.0/MgDev/Server/RepositoryAdmin/app/nuget.config
   branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/App.cs
   branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/BackupCommand.cs
   branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/BaseCommand.cs
   branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/CommandException.cs
   branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/RestoreCommand.cs
   branches/4.0/MgDev/Server/RepositoryAdmin/app/MapGuide.RepositoryAdmin.csproj
   branches/4.0/MgDev/Server/RepositoryAdmin/app/Program.cs
   branches/4.0/MgDev/Server/RepositoryAdmin/app/Strings.Designer.cs
   branches/4.0/MgDev/Server/RepositoryAdmin/app/Strings.resx
#2879: Migrate from CommandLine to DotMake.CommandLine as that supports trimming, which is a hard requirement as we intend to publish a trimmed, single-file, self-contained binary
Modified: branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/App.cs
--- branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/App.cs	2025-06-12 12:58:58 UTC (rev 10150)
+++ branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/App.cs	2025-06-12 14:54:40 UTC (rev 10151)
@@ -7,7 +7,6 @@
                  TextWriter stdout,
                  TextWriter stderr,
                  FileInfo dbArchive,
-                 FileInfo dbCheckpoint,
                  FileInfo dbRecover)
     public void Stdout(string msg) => stdout.WriteLine(msg);
@@ -130,7 +129,7 @@
                     logFiles = this.GetLogFiles(cmd.InputPath.FullName, false).ToList();
                     numUnusedFiles = unusedFiles.Count;
-                    if (bk.IncrementalLevel != BackupCommand.MIN_INCREMENTAL_LEVEL && numUnusedFiles > 0)
+                    if (bk.Level != BackupCommand.MIN_INCREMENTAL_LEVEL && numUnusedFiles > 0)
                         this.TransferFiles(outDir, unusedFiles, 0, true);
Modified: branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/BackupCommand.cs
--- branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/BackupCommand.cs	2025-06-12 12:58:58 UTC (rev 10150)
+++ branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/BackupCommand.cs	2025-06-12 14:54:40 UTC (rev 10151)
@@ -1,17 +1,22 @@
-using CommandLine;
+using DotMake.CommandLine;
 namespace MapGuide.RepositoryAdmin.Commands;
-[Verb("backup", HelpText = "VerbHelp_Backup", ResourceType = typeof(Strings))]
+[CliCommand(Name = "backup", Description = nameof(Strings.VerbHelp_Backup))]
 public class BackupCommand : BaseCommand
-    [Option('l', "incremental-level", Required = true)]
-    public required int IncrementalLevel { get; set; }
+    // HACK: Source generator won't generate if attribute placed on base property, so that has been made
+    // abstract and we're decorating here
+    [CliOption(Required = false, Description = nameof(Strings.ArgHelp_Common_BinPath))]
+    public override DirectoryInfo? BinPath { get; set; }
-    [Option('i', "input-path", Required = true, HelpText = "ArgHelp_Backup_InputPath", ResourceType = typeof(Strings))]
+    [CliOption(Description = nameof(Strings.ArgHelp_Backup_Level))]
+    public required int Level { get; set; }
+    [CliOption(Description = nameof(Strings.ArgHelp_Backup_InputPath))]
     public override required DirectoryInfo InputPath { get; set; }
-    [Option('o', "output-path", Required = true, HelpText = "ArgHelp_Backup_OutputPath", ResourceType = typeof(Strings))]
+    [CliOption(Description = nameof(Strings.ArgHelp_Backup_OutputPath))]
     public override required DirectoryInfo OutputPath { get; set; }
     public const int MIN_INCREMENTAL_LEVEL = 0;
@@ -28,9 +33,9 @@
             OutputPath.Create();
-        if (IncrementalLevel < MIN_INCREMENTAL_LEVEL || IncrementalLevel > MAX_INCREMENTAL_LEVEL)
+        if (Level < MIN_INCREMENTAL_LEVEL || Level > MAX_INCREMENTAL_LEVEL)
-            app.Stderr(string.Format(Strings.IDS_ERR_ARGUMENT_OUT_OF_RANGE, IncrementalLevel));
+            app.Stderr(string.Format(Strings.IDS_ERR_ARGUMENT_OUT_OF_RANGE, Level));
             return 1;
@@ -38,7 +43,7 @@
         //tools.Stdout($"Input path: {InputPath}");
         //tools.Stdout($"Output path: {OutputPath}");
-        if (IncrementalLevel == 0)
+        if (Level == 0)
             return app.BackupOfflineRepositories();
Modified: branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/BaseCommand.cs
--- branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/BaseCommand.cs	2025-06-12 12:58:58 UTC (rev 10150)
+++ branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/BaseCommand.cs	2025-06-12 14:54:40 UTC (rev 10151)
@@ -1,16 +1,15 @@
-using CommandLine;
 public abstract class BaseCommand : ICommonCommand
-    [Option('b', "bin-path", Required = false, HelpText = "ArgHelp_Common_BinPath", ResourceType = typeof(Strings))]
-    public DirectoryInfo? BinPath { get; set; }
+    public abstract DirectoryInfo? BinPath { get; set; }
     public abstract required DirectoryInfo InputPath { get; set; }
     public abstract required DirectoryInfo OutputPath { get; set; }
+    public int Run() => Execute(Console.Out, Console.Error);
     public int Execute(TextWriter stdout, TextWriter stderr)
         var dir = BinPath ?? new DirectoryInfo("../bin");
@@ -21,7 +20,6 @@
         FileInfo? dbArchive = null;
-        FileInfo? dbCheckpoint = null;
         FileInfo? dbRecover = null;
         foreach (var f in dir.EnumerateFiles())
@@ -31,9 +29,6 @@
                 case string s when s.StartsWith("db_archive"):
                     dbArchive = f;
                     break;
-                case string s when s.StartsWith("db_checkpoint"):
-                    dbCheckpoint = f;
-                    break;
                 case string s when s.StartsWith("db_recover"):
                     dbRecover = f;
                     break;
@@ -47,11 +42,6 @@
             stderr.WriteLine(string.Format(Strings.IDS_ERR_FILE_NOT_FOUND, "db_archive"));
             return 1;
-        if (dbCheckpoint == null || !dbCheckpoint.Exists)
-            stderr.WriteLine(string.Format(Strings.IDS_ERR_FILE_NOT_FOUND, "db_checkpoint"));
-            return 1;
         if (dbRecover == null || !dbRecover.Exists)
             stderr.WriteLine(string.Format(Strings.IDS_ERR_FILE_NOT_FOUND, "db_recover"));
@@ -60,7 +50,7 @@
         try
-            var app = new App(this, stdout, stderr, dbArchive, dbCheckpoint, dbRecover);
+            var app = new App(this, stdout, stderr, dbArchive, dbRecover);
             var res = ExecuteCore(app);
             stdout.WriteLine(Strings.IDS_PROGRESS_OPERATION_SUCCEEDED);
             return res;
Modified: branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/CommandException.cs
--- branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/CommandException.cs	2025-06-12 12:58:58 UTC (rev 10150)
+++ branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/CommandException.cs	2025-06-12 14:54:40 UTC (rev 10151)
@@ -7,7 +7,4 @@
 	public CommandException() { }
 	public CommandException(string message) : base(message) { }
 	public CommandException(string message, Exception inner) : base(message, inner) { }
-	protected CommandException(
-	  System.Runtime.Serialization.SerializationInfo info,
-	  System.Runtime.Serialization.StreamingContext context) : base(info, context) { }
Modified: branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/RestoreCommand.cs
--- branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/RestoreCommand.cs	2025-06-12 12:58:58 UTC (rev 10150)
+++ branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/RestoreCommand.cs	2025-06-12 14:54:40 UTC (rev 10151)
@@ -1,14 +1,19 @@
-using CommandLine;
-[Verb("restore", HelpText = "VerbHelp_Restore", ResourceType = typeof(Strings))]
+[CliCommand(Name = "restore", Description = nameof(Strings.VerbHelp_Restore))]
 public class RestoreCommand : BaseCommand, ICommonCommand
-    [Option('i', "input-path", Required = true, HelpText = "ArgHelp_Restore_InputPath", ResourceType = typeof(Strings))]
+    [CliOption(Description = nameof(Strings.ArgHelp_Restore_InputPath))]
-    [Option('o', "output-path", Required = true, HelpText = "ArgHelp_Restore_OutputPath", ResourceType = typeof(Strings))]
+    [CliOption(Description = nameof(Strings.ArgHelp_Restore_OutputPath))]
     protected override int ExecuteCore(App app)
Added: branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/RootCommand.cs
--- branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/RootCommand.cs	                        (rev 0)
+++ branches/4.0/MgDev/Server/RepositoryAdmin/app/Commands/RootCommand.cs	2025-06-12 14:54:40 UTC (rev 10151)
@@ -0,0 +1,8 @@
+namespace MapGuide.RepositoryAdmin.Commands;
+[CliCommand(Children = [ typeof(BackupCommand), typeof(RestoreCommand) ])]
+public class RootCommand
Modified: branches/4.0/MgDev/Server/RepositoryAdmin/app/MapGuide.RepositoryAdmin.csproj
--- branches/4.0/MgDev/Server/RepositoryAdmin/app/MapGuide.RepositoryAdmin.csproj	2025-06-12 12:58:58 UTC (rev 10150)
+++ branches/4.0/MgDev/Server/RepositoryAdmin/app/MapGuide.RepositoryAdmin.csproj	2025-06-12 14:54:40 UTC (rev 10151)
@@ -5,10 +5,24 @@
     <TargetFramework>net9.0</TargetFramework>
     <ImplicitUsings>enable</ImplicitUsings>
     <Nullable>enable</Nullable>
+	<EnableTrimAnalyzer>true</EnableTrimAnalyzer>
+	<PublishSingleFile>true</PublishSingleFile>
+	<PublishTrimmed>true</PublishTrimmed>
+	<EnableCompressionInSingleFile>true</EnableCompressionInSingleFile>
+	<SelfContained>true</SelfContained>
+	  <!-- Disabled features to maximize trimming -->
+	<HttpActivityPropagationSupport>false</HttpActivityPropagationSupport>
+	<XmlResolverIsNetworkingEnabledByDefault >false</XmlResolverIsNetworkingEnabledByDefault>
+	<EventSourceSupport>false</EventSourceSupport>
+	<EnableUnsafeBinaryFormatterSerialization>false</EnableUnsafeBinaryFormatterSerialization>
+	<EnableUnsafeUTF7Encoding>false</EnableUnsafeUTF7Encoding>
+	<MetricsSupport>false</MetricsSupport>
+	<MetadataUpdaterSupport>false</MetadataUpdaterSupport>
+	<TrimmerRemoveSymbols>true</TrimmerRemoveSymbols>
   </PropertyGroup>
   <ItemGroup>
-    <PackageReference Include="CommandLineParser" Version="2.9.1" />
+	<PackageReference Include="DotMake.CommandLine" Version="2.4.2" />
   </ItemGroup>
   <ItemGroup>
Modified: branches/4.0/MgDev/Server/RepositoryAdmin/app/Program.cs
--- branches/4.0/MgDev/Server/RepositoryAdmin/app/Program.cs	2025-06-12 12:58:58 UTC (rev 10150)
+++ branches/4.0/MgDev/Server/RepositoryAdmin/app/Program.cs	2025-06-12 14:54:40 UTC (rev 10151)
@@ -1,19 +1,5 @@
-using CommandLine;
 using MapGuide.RepositoryAdmin.Commands;
-using System.Reflection;
-var commandTypes = Assembly.GetExecutingAssembly()
-    .GetTypes()
-    .Where(t => typeof(BaseCommand).IsAssignableFrom(t) && t.GetCustomAttribute<VerbAttribute>() != null && !t.IsAbstract)
-    .ToArray();
-Parser.Default
-    .ParseArguments(args, commandTypes)
-    .WithParsed(opts =>
-        Environment.ExitCode = ((BaseCommand)opts).Execute(Console.Out, Console.Error);
-    .WithNotParsed(err =>
-        Environment.ExitCode = 1;
\ No newline at end of file
+return Cli.Run<RootCommand>(args);
Modified: branches/4.0/MgDev/Server/RepositoryAdmin/app/Strings.Designer.cs
--- branches/4.0/MgDev/Server/RepositoryAdmin/app/Strings.Designer.cs	2025-06-12 12:58:58 UTC (rev 10150)
+++ branches/4.0/MgDev/Server/RepositoryAdmin/app/Strings.Designer.cs	2025-06-12 14:54:40 UTC (rev 10151)
@@ -70,6 +70,20 @@
         /// <summary>
+        ///   Looks up a localized string similar to Incremental level (from 0 to 10).
+        ///= 0, Offline (cold) backup (A full snapshot is always taken)
+        ///> 0, Online (hot) backup. For example, for an incremental level value of 2:
+        ///    - If the number of active log files in the previous snapshot is less than or equal to 2, an incremental snapshot is taken.
+        ///    - If the number of active log files in the previous snapshot is greater than 2, a full snapshot is taken.
+        ///Note that active log files are files containing data that has NOT been saved to the database (by de [rest of string was truncated]";.
+        /// </summary>
+        public static string ArgHelp_Backup_Level {
+            get {
+                return ResourceManager.GetString("ArgHelp_Backup_Level", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Path to the destination location to where the repository is backed up. For offline (cold) backups, repositories are archived to a time-stamped sub-directory. For online (hot) backups, repositories are acrhived to the 'CurrentHotBackup' or a time-stamped sub-directory when taking an incremental or full snapshot respectively.
         /// </summary>
         public static string ArgHelp_Backup_OutputPath {
Modified: branches/4.0/MgDev/Server/RepositoryAdmin/app/Strings.resx
--- branches/4.0/MgDev/Server/RepositoryAdmin/app/Strings.resx	2025-06-12 12:58:58 UTC (rev 10150)
+++ branches/4.0/MgDev/Server/RepositoryAdmin/app/Strings.resx	2025-06-12 14:54:40 UTC (rev 10151)
@@ -120,6 +120,14 @@
   <data name="ArgHelp_Backup_InputPath" xml:space="preserve">
     <value>Path to the source location from where the repository is backed up</value>
   </data>
+  <data name="ArgHelp_Backup_Level" xml:space="preserve">
+    <value>Incremental level (from 0 to 10).
+= 0, Offline (cold) backup (A full snapshot is always taken)
+> 0, Online (hot) backup. For example, for an incremental level value of 2:
+    - If the number of active log files in the previous snapshot is less than or equal to 2, an incremental snapshot is taken.
+    - If the number of active log files in the previous snapshot is greater than 2, a full snapshot is taken.
+Note that active log files are files containing data that has NOT been saved to the database (by default, the size of a log file is about 10MB)</value>
+  </data>
   <data name="ArgHelp_Backup_OutputPath" xml:space="preserve">
     <value>Path to the destination location to where the repository is backed up. For offline (cold) backups, repositories are archived to a time-stamped sub-directory. For online (hot) backups, repositories are acrhived to the 'CurrentHotBackup' or a time-stamped sub-directory when taking an incremental or full snapshot respectively</value>
   </data>
Added: branches/4.0/MgDev/Server/RepositoryAdmin/app/nuget.config
--- branches/4.0/MgDev/Server/RepositoryAdmin/app/nuget.config	                        (rev 0)
+++ branches/4.0/MgDev/Server/RepositoryAdmin/app/nuget.config	2025-06-12 14:54:40 UTC (rev 10151)
@@ -0,0 +1,7 @@
+<?xml version="1.0" encoding="utf-8" ?>
+<configuration>
+	<packageSources>
+		<clear />
+		<add key="nuget.org" value="https://api.nuget.org/v3/index.json" protocolVersion="3" />
+	</packageSources>
+</configuration>
More information about the mapguide-commits
