[mapguide-commits] r10135 - branches/4.0/MgDev/Bindings/src/ApiDump
svn_mapguide at osgeo.org
Mon May 5 03:45:54 PDT 2025
Author: jng
Date: 2025-05-05 03:45:53 -0700 (Mon, 05 May 2025)
New Revision: 10135
Added:
branches/4.0/MgDev/Bindings/src/ApiDump/README.txt
branches/4.0/MgDev/Bindings/src/ApiDump/filelist.csmap.windows.txt
branches/4.0/MgDev/Bindings/src/ApiDump/filelist.server.windows.txt
branches/4.0/MgDev/Bindings/src/ApiDump/filelist.web.windows.txt
branches/4.0/MgDev/Bindings/src/ApiDump/snapshot_all.bat
branches/4.0/MgDev/Bindings/src/ApiDump/api.dotnet.txt
branches/4.0/MgDev/Bindings/src/ApiDump/api.java.txt
branches/4.0/MgDev/Bindings/src/ApiDump/api.php.txt
branches/4.0/MgDev/Bindings/src/ApiDump/dotnet-dump.ps1
branches/4.0/MgDev/Bindings/src/ApiDump/java-dump.ps1
branches/4.0/MgDev/Bindings/src/ApiDump/php_dump.php
- Implement PHP API snapshotter script
- Add snapshot_all.bat that runs all 3 API snapshotter scripts and generates file listing snapshots
- Check in generated snapshots as the new baseline
Added: branches/4.0/MgDev/Bindings/src/ApiDump/README.txt
--- branches/4.0/MgDev/Bindings/src/ApiDump/README.txt (rev 0)
+++ branches/4.0/MgDev/Bindings/src/ApiDump/README.txt 2025-05-05 10:45:53 UTC (rev 10135)
@@ -0,0 +1,5 @@
+Usage:
+1. Run snapshot_all.txt against a MapGuide installation after the MgInstantSetup tool has been run against it
+2. Copy the snapshot .txt files back into SOURCE_DIR/Bindings/src/ApiDump
+3. Review the svn diffs in the .txt files to verify if the snapshot changes are as intended
\ No newline at end of file
Modified: branches/4.0/MgDev/Bindings/src/ApiDump/api.dotnet.txt
--- branches/4.0/MgDev/Bindings/src/ApiDump/api.dotnet.txt 2025-05-01 11:50:30 UTC (rev 10134)
+++ branches/4.0/MgDev/Bindings/src/ApiDump/api.dotnet.txt 2025-05-05 10:45:53 UTC (rev 10135)
@@ -1,5190 +1,10375 @@
-Assembly: OSGeo.MapGuide.Foundation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null
-type OSGeo.MapGuide.MgFeaturePropertyType : System.Object
- [Constructor] Void .ctor()
- [Field] Int32 AssociationProperty
- [Field] Int32 DataProperty
- [Field] Int32 GeometricProperty
- [Field] Int32 ObjectProperty
- [Field] Int32 RasterProperty
-type OSGeo.MapGuide.MgMimeType : System.Object
- [Field] System.String Agf
- [Field] System.String Binary
- [Field] System.String Dwf
- [Field] System.String Gif
- [Field] System.String Html
- [Field] System.String Jpeg
- [Field] System.String Json
- [Field] System.String Kml
- [Field] System.String Kmz
- [Field] System.String Meta
- [Field] System.String Png
- [Field] System.String Text
- [Field] System.String Tiff
- [Field] System.String Xml
-type OSGeo.MapGuide.MgPropertyType : System.Object
- [Field] Int32 Blob
- [Field] Int32 Boolean
- [Field] Int32 Byte
- [Field] Int32 Clob
- [Field] Int32 DateTime
- [Field] Int32 Decimal
- [Field] Int32 Double
- [Field] Int32 Feature
- [Field] Int32 Geometry
- [Field] Int32 Int16
- [Field] Int32 Int32
- [Field] Int32 Int64
- [Field] Int32 Null
- [Field] Int32 Single
- [Field] Int32 String
-type OSGeo.MapGuide.MgExceptionCodes : System.Object
- [Field] System.String MgAllProviderConnectionsUsedException
- [Field] System.String MgArgumentOutOfRangeException
- [Field] System.String MgArrayTypeMismatchException
- [Field] System.String MgAuthenticationFailedException
- [Field] System.String MgClassNotFoundException
- [Field] System.String MgConfigurationException
- [Field] System.String MgConfigurationLoadFailedException
- [Field] System.String MgConfigurationSaveFailedException
- [Field] System.String MgConnectionFailedException
- [Field] System.String MgConnectionNotOpenException
- [Field] System.String MgCoordinateSystemComputationFailedException
- [Field] System.String MgCoordinateSystemConversionFailedException
- [Field] System.String MgCoordinateSystemInitializationFailedException
- [Field] System.String MgCoordinateSystemLoadFailedException
- [Field] System.String MgCoordinateSystemMeasureFailedException
- [Field] System.String MgCoordinateSystemTransformFailedException
- [Field] System.String MgDateTimeException
- [Field] System.String MgDbException
- [Field] System.String MgDbXmlException
- [Field] System.String MgDecryptionException
- [Field] System.String MgDirectoryNotFoundException
- [Field] System.String MgDivideByZeroException
- [Field] System.String MgDomainException
- [Field] System.String MgDuplicateDirectoryException
- [Field] System.String MgDuplicateFileException
- [Field] System.String MgDuplicateGroupException
- [Field] System.String MgDuplicateNameException
- [Field] System.String MgDuplicateObjectException
- [Field] System.String MgDuplicateParameterException
- [Field] System.String MgDuplicateRepositoryException
- [Field] System.String MgDuplicateResourceDataException
- [Field] System.String MgDuplicateResourceException
- [Field] System.String MgDuplicateRoleException
- [Field] System.String MgDuplicateServerException
- [Field] System.String MgDuplicateSessionException
- [Field] System.String MgDuplicateUserException
- [Field] System.String MgDwfException
- [Field] System.String MgDwfSectionNotFoundException
- [Field] System.String MgDwfSectionResourceNotFoundException
- [Field] System.String MgEmptyFeatureSetException
- [Field] System.String MgEncryptionException
- [Field] System.String MgEndOfStreamException
- [Field] System.String MgEvaluationExpiredException
- [Field] System.String MgFdoException
- [Field] System.String MgFeatureServiceException
- [Field] System.String MgFileIoException
- [Field] System.String MgFileNotFoundException
- [Field] System.String MgGeometryException
- [Field] System.String MgGridDensityException
- [Field] System.String MgGroupNotFoundException
- [Field] System.String MgIndexOutOfRangeException
- [Field] System.String MgInvalidArgumentException
- [Field] System.String MgInvalidCastException
- [Field] System.String MgInvalidCoordinateSystemException
- [Field] System.String MgInvalidCoordinateSystemTypeException
- [Field] System.String MgInvalidCoordinateSystemUnitsException
- [Field] System.String MgInvalidDwfPackageException
- [Field] System.String MgInvalidDwfSectionException
- [Field] System.String MgInvalidFeatureSourceException
- [Field] System.String MgInvalidIpAddressException
- [Field] System.String MgInvalidLayerDefinitionException
- [Field] System.String MgInvalidLicenseException
- [Field] System.String MgInvalidLogEntryException
- [Field] System.String MgInvalidMapDefinitionException
- [Field] System.String MgInvalidMimeTypeException
- [Field] System.String MgInvalidOperationException
- [Field] System.String MgInvalidOperationVersionException
- [Field] System.String MgInvalidPasswordException
- [Field] System.String MgInvalidPrintLayoutFontSizeUnitsException
- [Field] System.String MgInvalidPrintLayoutPositionUnitsException
- [Field] System.String MgInvalidPrintLayoutSizeUnitsException
- [Field] System.String MgInvalidPropertyTypeException
- [Field] System.String MgInvalidRepositoryNameException
- [Field] System.String MgInvalidRepositoryTypeException
- [Field] System.String MgInvalidResourceDataNameException
- [Field] System.String MgInvalidResourceDataTypeException
- [Field] System.String MgInvalidResourceNameException
- [Field] System.String MgInvalidResourcePathException
- [Field] System.String MgInvalidResourcePreProcessingTypeException
- [Field] System.String MgInvalidResourceTypeException
- [Field] System.String MgInvalidSerialNumberException
- [Field] System.String MgInvalidServerNameException
- [Field] System.String MgInvalidStreamHeaderException
- [Field] System.String MgInvalidWatermarkDefinitionException
- [Field] System.String MgIoException
- [Field] System.String MgLayerNotFoundException
- [Field] System.String MgLengthException
- [Field] System.String MgLicenseException
- [Field] System.String MgLicenseExpiredException
- [Field] System.String MgLogicException
- [Field] System.String MgLogOpenFailedException
- [Field] System.String MgNotFiniteNumberException
- [Field] System.String MgNotImplementedException
- [Field] System.String MgNullArgumentException
- [Field] System.String MgNullPropertyValueException
- [Field] System.String MgNullReferenceException
- [Field] System.String MgObjectNotFoundException
- [Field] System.String MgOperationProcessingException
- [Field] System.String MgOutOfMemoryException
- [Field] System.String MgOutOfRangeException
- [Field] System.String MgOverflowException
- [Field] System.String MgParameterNotFoundException
- [Field] System.String MgPathTooLongException
- [Field] System.String MgPermissionDeniedException
- [Field] System.String MgPlatformNotSupportedException
- [Field] System.String MgPortNotAvailableException
- [Field] System.String MgPrintToScaleModeNotSelectedException
- [Field] System.String MgRasterTransformationNotSupportedException
- [Field] System.String MgRepositoryCreationFailedException
- [Field] System.String MgRepositoryNotFoundException
- [Field] System.String MgRepositoryNotOpenException
- [Field] System.String MgRepositoryOpenFailedException
- [Field] System.String MgResourceBusyException
- [Field] System.String MgResourceDataNotFoundException
- [Field] System.String MgResourceNotFoundException
- [Field] System.String MgResourcesException
- [Field] System.String MgResourcesLoadFailedException
- [Field] System.String MgResourceTagNotFoundException
- [Field] System.String MgRoleNotFoundException
- [Field] System.String MgRuntimeException
- [Field] System.String MgServerNotFoundException
- [Field] System.String MgServerNotOnlineException
- [Field] System.String MgServiceNotAvailableException
- [Field] System.String MgServiceNotSupportedException
- [Field] System.String MgSessionExpiredException
- [Field] System.String MgSessionNotFoundException
- [Field] System.String MgStreamIoException
- [Field] System.String MgStylizeLayerFailedException
- [Field] System.String MgTemporaryFileNotAvailableException
- [Field] System.String MgUnauthorizedAccessException
- [Field] System.String MgUnclassifiedException
- [Field] System.String MgUnderflowException
- [Field] System.String MgUnknownTileProviderException
- [Field] System.String MgUnsupportedProviderThreadModelException
- [Field] System.String MgUnsupportedTileProviderException
- [Field] System.String MgUriFormatException
- [Field] System.String MgUserNotFoundException
- [Field] System.String MgXmlException
- [Field] System.String MgXmlParserException
-type OSGeo.MapGuide.ManagedException : System.Exception
- implements System.Runtime.Serialization.ISerializable
- [Method] System.String get_Message()
- [Method] System.String get_StackTrace()
- [Method] System.String ToString()
-[System.Reflection.DefaultMemberAttribute]
-type OSGeo.MapGuide.MgStringCollection : OSGeo.MapGuide.MgCollection
- implements System.IDisposable
- implements System.Collections.Generic.IList`1[[System.String, System.Private.CoreLib, Version=8.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e]]
- implements System.Collections.Generic.ICollection`1[[System.String, System.Private.CoreLib, Version=8.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e]]
- implements System.Collections.Generic.IEnumerable`1[[System.String, System.Private.CoreLib, Version=8.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e]]
- implements System.Collections.IEnumerable
- [Constructor] Void .ctor(System.Collections.Generic.IEnumerable`1[System.String])
- [Method] Void Add(System.String)
- [Method] Void Clear()
- [Method] Boolean Contains(System.String)
- [Method] Void CopyTo(System.String[], Int32)
- [Method] Int32 get_Count()
- [Method] Boolean get_IsReadOnly()
- [Method] System.String get_Item(Int32)
- [Method] Int32 GetCount()
- [Method] System.Collections.Generic.IEnumerator`1[System.String] GetEnumerator()
- [Method] System.String GetItem(Int32)
- [Method] Int32 IndexOf(System.String)
- [Method] Void Insert(Int32, System.String)
- [Method] Boolean Remove(System.String)
- [Method] Void RemoveAt(Int32)
- [Method] Void set_Item(Int32, System.String)
- [Method] Void SetItem(Int32, System.String)
- [Method] OSGeo.MapGuide.MgByteReader ToXml()
-type OSGeo.MapGuide.ReadOnlyRewindableStream : System.IO.Stream
- implements System.IAsyncDisposable
- [Method] Boolean get_CanRead()
- [Method] Boolean get_CanRewind()
- [Method] Boolean get_CanSeek()
- [Method] Boolean get_CanWrite()
- [Method] Int64 get_Position()
- [Method] Void Rewind()
- [Method] Int64 Seek(Int64, System.IO.SeekOrigin)
- [Method] Void set_Position(Int64)
- [Method] Void SetLength(Int64)
- [Method] Void Write(Byte[], Int32, Int32)
-type OSGeo.MapGuide.GetByteReaderMethod : System.MulticastDelegate
- implements System.ICloneable
- [Constructor] Void .ctor(System.Object, IntPtr)
- [Method] System.IAsyncResult BeginInvoke(System.AsyncCallback, System.Object)
- [Method] OSGeo.MapGuide.MgByteReader EndInvoke(System.IAsyncResult)
- [Method] OSGeo.MapGuide.MgByteReader Invoke()
-type OSGeo.MapGuide.MgReadOnlyStream : OSGeo.MapGuide.ReadOnlyRewindableStream
- [Constructor] Void .ctor(OSGeo.MapGuide.GetByteReaderMethod)
- [Constructor] Void .ctor(OSGeo.MapGuide.MgByteReader)
- [Method] Void Flush()
- [Method] Int64 get_Length()
- [Method] Int32 Read(Byte[], Int32, Int32)
-type OSGeo.MapGuide.MgBatchPropertyCollection : OSGeo.MapGuide.MgCollection
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgPropertyCollection, OSGeo.MapGuide.Foundation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgPropertyCollection, OSGeo.MapGuide.Foundation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgPropertyCollection, OSGeo.MapGuide.Foundation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgPropertyCollection)
- [Method] Boolean Contains(OSGeo.MapGuide.MgPropertyDefinition)
- [Method] Void CopyTo(OSGeo.MapGuide.MgPropertyCollection[], Int32)
- [Method] OSGeo.MapGuide.MgPropertyCollection get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgPropertyCollection] GetEnumerator()
- [Method] OSGeo.MapGuide.MgPropertyCollection GetItem(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgPropertyDefinition)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgPropertyCollection)
- [Method] Boolean Remove(OSGeo.MapGuide.MgPropertyCollection)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgPropertyCollection)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgPropertyCollection)
-type OSGeo.MapGuide.MgByteReader : OSGeo.MapGuide.MgSerializable
- [Constructor] Void .ctor(Byte[], Int32, System.String)
- [Constructor] Void .ctor(System.String, System.String)
- [Constructor] Void .ctor(System.String, System.String, Boolean)
- [Method] System.String get_MimeType()
- [Method] System.Runtime.InteropServices.HandleRef getCPtr(OSGeo.MapGuide.MgByteReader)
- [Method] Int64 GetLength()
- [Method] System.String GetMimeType()
- [Method] Boolean IsRewindable()
- [Method] Int32 Read(Byte[], Int32)
- [Method] System.Runtime.InteropServices.HandleRef swigRelease(OSGeo.MapGuide.MgByteReader)
- [Method] Void ToFile(System.String)
-type OSGeo.MapGuide.MgByteSink : OSGeo.MapGuide.MgGuardDisposable
-type OSGeo.MapGuide.MgByteSource : OSGeo.MapGuide.MgGuardDisposable
- [Constructor] Void .ctor(System.String)
- [Constructor] Void .ctor(Byte[], Int32)
- [Method] OSGeo.MapGuide.MgByteReader GetReader()
- [Method] Void set_MimeType(System.String)
- [Method] Void SetMimeType(System.String)
-type OSGeo.MapGuide.MgCollection : OSGeo.MapGuide.MgSerializable
- [Method] System.Runtime.InteropServices.HandleRef getCPtr(OSGeo.MapGuide.MgCollection)
- [Method] System.Runtime.InteropServices.HandleRef swigRelease(OSGeo.MapGuide.MgCollection)
-type OSGeo.MapGuide.MgDateTime : OSGeo.MapGuide.MgSerializable
- [Constructor] Void .ctor(Int16, Int16, Int16)
- [Constructor] Void .ctor(Int16, Int16, Int16, Int32)
- [Constructor] Void .ctor(Int16, Int16, Int16, Int16, Int16, Int16, Int32)
- [Method] Int16 get_Day()
- [Method] Int16 get_Hour()
- [Method] Int32 get_Microsecond()
- [Method] Int16 get_Minute()
- [Method] Int16 get_Month()
- [Method] Int16 get_Second()
- [Method] Int16 get_Year()
- [Method] Int16 GetDay()
- [Method] Int16 GetHour()
- [Method] Int32 GetMicrosecond()
- [Method] Int16 GetMinute()
- [Method] Int16 GetMonth()
- [Method] Int16 GetSecond()
- [Method] Int16 GetYear()
- [Method] Boolean IsDate()
- [Method] Boolean IsDateTime()
- [Method] Boolean IsTime()
- [Method] Void set_Day(Int16)
- [Method] Void set_Hour(Int16)
- [Method] Void set_Microsecond(Int32)
- [Method] Void set_Minute(Int16)
- [Method] Void set_Month(Int16)
- [Method] Void set_Second(Int16)
- [Method] Void set_Year(Int16)
- [Method] Void SetDay(Int16)
- [Method] Void SetHour(Int16)
- [Method] Void SetMicrosecond(Int32)
- [Method] Void SetMinute(Int16)
- [Method] Void SetMonth(Int16)
- [Method] Void SetSecond(Int16)
- [Method] Void SetYear(Int16)
- [Method] Void Validate()
-type OSGeo.MapGuide.MgDisposable : OSGeo.MapGuide.MgObject
- [Method] System.Runtime.InteropServices.HandleRef getCPtr(OSGeo.MapGuide.MgDisposable)
- [Method] System.Runtime.InteropServices.HandleRef swigRelease(OSGeo.MapGuide.MgDisposable)
-type OSGeo.MapGuide.MgDisposableCollection : OSGeo.MapGuide.MgCollection
- [Method] Void Add(OSGeo.MapGuide.MgDisposable)
- [Method] Boolean Contains(OSGeo.MapGuide.MgDisposable)
- [Method] OSGeo.MapGuide.MgDisposable GetItem(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgDisposable)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgDisposable)
- [Method] Boolean Remove(OSGeo.MapGuide.MgDisposable)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgDisposable)
-type OSGeo.MapGuide.MgException : OSGeo.MapGuide.ManagedException
- [Method] Void AddStackTraceInfo(System.String, System.String, Int32, System.String)
- [Method] Void AddStackTraceInfo(System.String, Int32, System.String)
- [Method] Void Dispose()
- [Method] System.String GetDetails()
- [Method] System.String GetDetails(System.String)
- [Method] System.String GetExceptionCode()
- [Method] System.String GetExceptionMessage()
- [Method] System.String GetExceptionMessage(System.String)
- [Method] Int64 GetNativeErrorCode()
- [Method] System.String GetStackTrace()
- [Method] System.String GetStackTrace(System.String)
-type OSGeo.MapGuide.MgGuardDisposable : OSGeo.MapGuide.MgDisposable
- [Method] System.Runtime.InteropServices.HandleRef getCPtr(OSGeo.MapGuide.MgGuardDisposable)
- [Method] System.Runtime.InteropServices.HandleRef swigRelease(OSGeo.MapGuide.MgGuardDisposable)
-type OSGeo.MapGuide.MgNamedSerializable : OSGeo.MapGuide.MgSerializable
- [Method] System.Runtime.InteropServices.HandleRef getCPtr(OSGeo.MapGuide.MgNamedSerializable)
- [Method] System.Runtime.InteropServices.HandleRef swigRelease(OSGeo.MapGuide.MgNamedSerializable)
-type OSGeo.MapGuide.MgNullableProperty : OSGeo.MapGuide.MgProperty
- [Method] System.Runtime.InteropServices.HandleRef getCPtr(OSGeo.MapGuide.MgNullableProperty)
- [Method] Boolean IsNull()
- [Method] Void SetNull(Boolean)
- [Method] System.Runtime.InteropServices.HandleRef swigRelease(OSGeo.MapGuide.MgNullableProperty)
-type OSGeo.MapGuide.MgObject : System.Object
-type OSGeo.MapGuide.MgProperty : OSGeo.MapGuide.MgNamedSerializable
- [Method] System.String get_Name()
- [Method] Int16 get_PropertyType()
- [Method] System.String GetName()
- [Method] Int16 GetPropertyType()
- [Method] Void set_Name(System.String)
- [Method] Void SetName(System.String)
-type OSGeo.MapGuide.MgPropertyCollection : OSGeo.MapGuide.MgCollection
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgProperty, OSGeo.MapGuide.Foundation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgProperty, OSGeo.MapGuide.Foundation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgProperty, OSGeo.MapGuide.Foundation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgProperty)
- [Method] Boolean Contains(OSGeo.MapGuide.MgProperty)
- [Method] Void CopyTo(OSGeo.MapGuide.MgProperty[], Int32)
- [Method] OSGeo.MapGuide.MgProperty get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgProperty] GetEnumerator()
- [Method] OSGeo.MapGuide.MgProperty GetItem(Int32)
- [Method] OSGeo.MapGuide.MgProperty GetItem(System.String)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgProperty)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgProperty)
- [Method] Boolean Remove(OSGeo.MapGuide.MgProperty)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgProperty)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgProperty)
-type OSGeo.MapGuide.MgPropertyDefinition : OSGeo.MapGuide.MgProperty
- [Constructor] Void .ctor(System.String, Int16)
- [Method] Void Delete()
- [Method] System.String get_Description()
- [Method] System.String get_QualifiedName()
- [Method] System.Runtime.InteropServices.HandleRef getCPtr(OSGeo.MapGuide.MgPropertyDefinition)
- [Method] System.String GetDescription()
- [Method] System.String GetQualifiedName()
- [Method] Void set_Description(System.String)
- [Method] Void set_QualifiedName(System.String)
- [Method] Void SetDescription(System.String)
- [Method] Void SetQualifiedName(System.String)
- [Method] System.Runtime.InteropServices.HandleRef swigRelease(OSGeo.MapGuide.MgPropertyDefinition)
-type OSGeo.MapGuide.MgSerializable : OSGeo.MapGuide.MgGuardDisposable
- [Method] System.Runtime.InteropServices.HandleRef getCPtr(OSGeo.MapGuide.MgSerializable)
- [Method] System.Runtime.InteropServices.HandleRef swigRelease(OSGeo.MapGuide.MgSerializable)
-type OSGeo.MapGuide.MgStringProperty : OSGeo.MapGuide.MgNullableProperty
- [Method] System.String get_Value()
- [Method] System.String GetValue()
- [Method] Void SetValue(System.String)
-Assembly: OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null
-type OSGeo.MapGuide.MgCoordinateDimension : System.Object
- [Field] Int32 M
- [Field] Int32 XY
- [Field] Int32 XYZ
-type OSGeo.MapGuide.MgGeometryEntityType : System.Object
- [Field] Int32 GeometryComponent
-type OSGeo.MapGuide.MgGeometricPathInstructionType : System.Object
- [Field] Int32 Close
- [Field] Int32 LineTo
- [Field] Int32 MoveTo
- [Field] Int32 QuadTo
-type OSGeo.MapGuide.MgGeometryComponentType : System.Object
- [Field] Int32 ArcSegment
- [Field] Int32 CurveRing
- [Field] Int32 LinearRing
- [Field] Int32 LinearSegment
-type OSGeo.MapGuide.MgGeometryType : System.Object
- [Field] Int32 CurvePolygon
- [Field] Int32 CurveString
- [Field] Int32 LineString
- [Field] Int32 MultiCurvePolygon
- [Field] Int32 MultiCurveString
- [Field] Int32 MultiGeometry
- [Field] Int32 MultiLineString
- [Field] Int32 MultiPoint
- [Field] Int32 MultiPolygon
- [Field] Int32 Point
- [Field] Int32 Polygon
-type OSGeo.MapGuide.MgGeometrySimplificationAlgorithmType : System.Object
- [Field] Int32 DouglasPeucker
- [Field] Int32 TopologyPreserving
-type OSGeo.MapGuide.MgCoordinateSystemCodeFormat : System.Object
- [Field] Int32 Epsg
- [Field] Int32 Mentor
-type OSGeo.MapGuide.MgCoordinateSystemErrorCode : System.Object
- [Field] Int32 AFFZERO
- [Field] Int32 AZM
- [Field] Int32 AZMTH
- [Field] Int32 ConversionFailed
- [Field] Int32 CRTMM
- [Field] Int32 DENRGN
- [Field] Int32 ELEVEL
- [Field] Int32 GEOMM
- [Field] Int32 HMISPHR
- [Field] Int32 InitializationFailed
- [Field] Int32 InvalidArgument
- [Field] Int32 INVDTM
- [Field] Int32 INVELP
- [Field] Int32 INVPRJ
- [Field] Int32 INVQUAD
- [Field] Int32 LAT
- [Field] Int32 LATEQU
- [Field] Int32 LLRNG
- [Field] Int32 LNG
- [Field] Int32 LNGEQU
- [Field] Int32 MAPSCL
- [Field] Int32 MAX15
- [Field] Int32 MEREQU
- [Field] Int32 MRCAT
- [Field] Int32 MSCOEF
- [Field] Int32 NOREF
- [Field] Int32 NOTNRTH
- [Field] Int32 NRDATUM
- [Field] Int32 NRTHLAT
- [Field] Int32 NRTHPNT
- [Field] Int32 NullArgument
- [Field] Int32 OBLQPOLE
- [Field] Int32 Ok
- [Field] Int32 ORGLAT
- [Field] Int32 ORGLNG
- [Field] Int32 OSTN02
- [Field] Int32 OSTN97
- [Field] Int32 OutOfMemory
- [Field] Int32 PLL90
- [Field] Int32 PLLED
- [Field] Int32 PLLEQU
- [Field] Int32 PLLLRG
- [Field] Int32 PLLREV
- [Field] Int32 PLLZERO
- [Field] Int32 PLRLAT
- [Field] Int32 POLDD
- [Field] Int32 POLDUP
- [Field] Int32 POLLAT
- [Field] Int32 POLLNG
- [Field] Int32 QUAD
- [Field] Int32 RNGORD
- [Field] Int32 SCLRED
- [Field] Int32 SOTHLAT
- [Field] Int32 STDLAT
- [Field] Int32 STDLNG
- [Field] Int32 STDPLL
- [Field] Int32 STDSOU
- [Field] Int32 STDWEST
- [Field] Int32 TMKRG0
- [Field] Int32 UNIT
- [Field] Int32 USEPLR
- [Field] Int32 USESW
- [Field] Int32 UTMZON
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformationMethod : System.Object
- [Field] Int32 AGD66
- [Field] Int32 AGD84
- [Field] Int32 ATS77
- [Field] Int32 Bursa
- [Field] Int32 CHENYX
- [Field] Int32 CSRS
- [Field] Int32 DHDN
- [Field] Int32 ED50
- [Field] Int32 ETRF89
- [Field] Int32 FourParameter
- [Field] Int32 GDA94
- [Field] Int32 Geocentric
- [Field] Int32 HPGN
- [Field] Int32 Lclgrf
- [Field] Int32 Molodensky
- [Field] Int32 MReg
- [Field] Int32 NAD27
- [Field] Int32 NAD83
- [Field] Int32 None
- [Field] Int32 NZGD2K
- [Field] Int32 NZGD49
- [Field] Int32 RGF93
- [Field] Int32 SevenParameter
- [Field] Int32 SixParameter
- [Field] Int32 ThreeParameter
- [Field] Int32 TOKYO
- [Field] Int32 WGS72
- [Field] Int32 WGS84
-type OSGeo.MapGuide.MgCoordinateSystemGridOrientation : System.Object
- [Field] Byte EastWest
- [Field] Byte None
- [Field] Byte NorthSouth
- [Field] Byte Unknown
-type OSGeo.MapGuide.MgCoordinateSystemGridSpecializationType : System.Object
- [Field] Int32 Generic
- [Field] Int32 MGRS
- [Field] Int32 Unknown
- [Field] Int32 USNG
-type OSGeo.MapGuide.MgCoordinateSystemMgrsGridLevel : System.Object
- [Field] Int32 Mgrs100Km
- [Field] Int32 Mgrs100m
- [Field] Int32 Mgrs10Km
- [Field] Int32 Mgrs10m
- [Field] Int32 Mgrs1Km
- [Field] Int32 Mgrs1m
- [Field] Int32 MgrsNone
- [Field] Int32 MgrsUnknown
- [Field] Int32 MgrsUps
- [Field] Int32 MgrsUtm
-type OSGeo.MapGuide.MgCoordinateSystemMgrsLetteringScheme : System.Object
- [Field] Byte Alternative
- [Field] Byte Normal
-type OSGeo.MapGuide.MgCoordinateSystemMgrsGridSquarePosition : System.Object
- [Field] Int32 Center
- [Field] Int32 East
- [Field] Int32 North
- [Field] Int32 NorthEast
- [Field] Int32 NorthWest
- [Field] Int32 South
- [Field] Int32 SouthEast
- [Field] Int32 SouthWest
- [Field] Int32 West
-type OSGeo.MapGuide.MgCoordinateSystemProjectionCode : System.Object
- [Field] Int32 Alber
- [Field] Int32 Azede
- [Field] Int32 Azmea
- [Field] Int32 Azmed
- [Field] Int32 Bipolar
- [Field] Int32 Bonne
- [Field] Int32 Cassini
- [Field] Int32 Eckert4
- [Field] Int32 Eckert6
- [Field] Int32 Edcnc
- [Field] Int32 Edcyl
- [Field] Int32 EdcylE
- [Field] Int32 GaussK
- [Field] Int32 Gnomonic
- [Field] Int32 Goode
- [Field] Int32 Hom1uv
- [Field] Int32 Hom1xy
- [Field] Int32 Hom2uv
- [Field] Int32 Hom2xy
- [Field] Int32 Krovak
- [Field] Int32 Krvk95
- [Field] Int32 LL
- [Field] Int32 Lm1sp
- [Field] Int32 Lm2sp
- [Field] Int32 Lmblg
- [Field] Int32 Lmbrtaf
- [Field] Int32 LmMich
- [Field] Int32 Lmtan
- [Field] Int32 Miller
- [Field] Int32 Mndotl
- [Field] Int32 Mndott
- [Field] Int32 Modpc
- [Field] Int32 Mollweid
- [Field] Int32 Mrcat
- [Field] Int32 MrcatK
- [Field] Int32 Mstero
- [Field] Int32 Neacyl
- [Field] Int32 Nerth
- [Field] Int32 Nrthsrt
- [Field] Int32 Nzealand
- [Field] Int32 OblqM
- [Field] Int32 Obqcyl
- [Field] Int32 Ortho
- [Field] Int32 Ostn02
- [Field] Int32 Ostn97
- [Field] Int32 Ostro
- [Field] Int32 PlateCarree
- [Field] Int32 Plycn
- [Field] Int32 Pstro
- [Field] Int32 Pstrosl
- [Field] Int32 PvMercator
- [Field] Int32 Robinson
- [Field] Int32 Rskew
- [Field] Int32 Rskewc
- [Field] Int32 Rskewo
- [Field] Int32 Sinus
- [Field] Int32 Sotrm
- [Field] Int32 Sstro
- [Field] Int32 Swiss
- [Field] Int32 Sys34
- [Field] Int32 Sys34_01
- [Field] Int32 Sys34_99
- [Field] Int32 Teacyl
- [Field] Int32 Tm
- [Field] Int32 Trmeraf
- [Field] Int32 Trmrkrg
- [Field] Int32 Trmrs
- [Field] Int32 Utm
- [Field] Int32 Vdgrntn
- [Field] Int32 Wccsl
- [Field] Int32 Wccst
- [Field] Int32 Winkl
-type OSGeo.MapGuide.MgCoordinateSystemProjectionFormatType : System.Object
- [Field] Int32 Angd
- [Field] Int32 Coef
- [Field] Int32 Lat
- [Field] Int32 Lng
- [Field] Int32 Rot
- [Field] Int32 Scl
- [Field] Int32 Xxx
- [Field] Int32 Yyy
-type OSGeo.MapGuide.MgCoordinateSystemProjectionLogicalType : System.Object
- [Field] Int32 AffineCoefficient
- [Field] Int32 AngularDistance
- [Field] Int32 Azimuth
- [Field] Int32 ComplexCoefficient
- [Field] Int32 Elevation
- [Field] Int32 GeoidHeight
- [Field] Int32 HemisphereSelection
- [Field] Int32 Latitude
- [Field] Int32 Longitude
- [Field] Int32 Scale
- [Field] Int32 UTMZoneNumber
- [Field] Int32 XYCoordinate
-type OSGeo.MapGuide.MgCoordinateSystemProjectionParameterType : System.Object
- [Field] Int32 Adp1p2
- [Field] Int32 Adsp1
- [Field] Int32 Adsp2
- [Field] Int32 Aelev
- [Field] Int32 Afa0
- [Field] Int32 Afa1
- [Field] Int32 Afa2
- [Field] Int32 Afb0
- [Field] Int32 Afb1
- [Field] Int32 Afb2
- [Field] Int32 Cmplxan
- [Field] Int32 Cmplxbn
- [Field] Int32 Cntmer
- [Field] Int32 Denrgn
- [Field] Int32 Eastll
- [Field] Int32 EllipsoidScale
- [Field] Int32 Estdmer
- [Field] Int32 Gcazm
- [Field] Int32 Gcp1lat
- [Field] Int32 Gcp1lng
- [Field] Int32 Gcp2lat
- [Field] Int32 Gcp2lng
- [Field] Int32 Gcplat
- [Field] Int32 Gcplng
- [Field] Int32 Ghgt
- [Field] Int32 Hsns
- [Field] Int32 NotUsed
- [Field] Int32 Nparall
- [Field] Int32 Nrmlpll
- [Field] Int32 Nrthrot
- [Field] Int32 Nrthscl
- [Field] Int32 Nstdpll
- [Field] Int32 Ostdpll
- [Field] Int32 P1lat
- [Field] Int32 P1lng
- [Field] Int32 P2lat
- [Field] Int32 P2lng
- [Field] Int32 Polelat
- [Field] Int32 Polelng
- [Field] Int32 Sclrotorgx
- [Field] Int32 Sclrotorgy
- [Field] Int32 Skwazm
- [Field] Int32 Sparall
- [Field] Int32 Sstdpll
- [Field] Int32 Stdcir
- [Field] Int32 Stdpll
- [Field] Int32 Utmzn
- [Field] Int32 Westll
- [Field] Int32 Yaxisaz
-type OSGeo.MapGuide.MgCoordinateSystemType : System.Object
- [Field] Int32 Arbitrary
- [Field] Int32 Geographic
- [Field] Int32 Projected
-type OSGeo.MapGuide.MgCoordinateSystemUnitCode : System.Object
- [Field] Int32 BenoitChain
- [Field] Int32 BenoitLink
- [Field] Int32 BrChainTrunc
- [Field] Int32 Brealey
- [Field] Int32 BrFootTrunc
- [Field] Int32 BrLinkTrunc
- [Field] Int32 CaGrid
- [Field] Int32 CapeFoot
- [Field] Int32 Centimeter
- [Field] Int32 Centisec
- [Field] Int32 ClarkeChain
- [Field] Int32 ClarkeFoot
- [Field] Int32 ClarkeLink
- [Field] Int32 Decameter
- [Field] Int32 Decimeter
- [Field] Int32 Decisec
- [Field] Int32 Degree
- [Field] Int32 Dekameter
- [Field] Int32 Foot
- [Field] Int32 Furlong
- [Field] Int32 GermanMeter
- [Field] Int32 GoldCoastFoot
- [Field] Int32 Grad
- [Field] Int32 Grade
- [Field] Int32 GunterChain
- [Field] Int32 GunterLink
- [Field] Int32 Hectometer
- [Field] Int32 IFoot
- [Field] Int32 IInch
- [Field] Int32 IMile
- [Field] Int32 Inch
- [Field] Int32 IndianFoot
- [Field] Int32 IndianFt37
- [Field] Int32 IndianFt62
- [Field] Int32 IndianFt75
- [Field] Int32 IndianYard
- [Field] Int32 IndianYd37
- [Field] Int32 InternationalChain
- [Field] Int32 InternationalLink
- [Field] Int32 IYard
- [Field] Int32 Kilometer
- [Field] Int32 Knot
- [Field] Int32 Lat66
- [Field] Int32 Lat83
- [Field] Int32 MapInfo
- [Field] Int32 Meter
- [Field] Int32 MicroInch
- [Field] Int32 Mil
- [Field] Int32 Mile
- [Field] Int32 Millimeter
- [Field] Int32 Millisec
- [Field] Int32 Minute
- [Field] Int32 NautM
- [Field] Int32 Perch
- [Field] Int32 Radian
- [Field] Int32 Rod
- [Field] Int32 Rood
- [Field] Int32 SearsChain
- [Field] Int32 SearsFoot
- [Field] Int32 SearsLink
- [Field] Int32 SearsYard
- [Field] Int32 Second
- [Field] Int32 Yard
-type OSGeo.MapGuide.MgCoordinateSystemUnitType : System.Object
-type OSGeo.MapGuide.MgCoordinateSystemWktFlavor : System.Object
- [Field] Int32 Esri
- [Field] Int32 Geotiff
- [Field] Int32 Geotools
- [Field] Int32 Ogc
- [Field] Int32 Oracle
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDefType : System.Object
- [Field] Int32 Analytical
- [Field] Int32 Interpolation
- [Field] Int32 MultipleRegression
- [Field] Int32 Standalone
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticDirection : System.Object
- [Field] Int32 GeodeticDirectionError
- [Field] Int32 GeodeticDirectionForward
- [Field] Int32 GeodeticDirectionInverse
- [Field] Int32 GeodeticDirectionNone
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticAnalyticalTransformationMethod : System.Object
- [Field] Int32 AbridgedMolodensky
- [Field] Int32 Frame
- [Field] Int32 MolodenskyBadekas
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod : System.Object
- [Field] Int32 GeneralPolynomialEpsg
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticStandaloneTransformationMethod : System.Object
- [Field] Int32 NullX
- [Field] Int32 Wgs72
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformGridFileFormat : System.Object
- [Field] Int32 GEOCON
- [Field] Int32 NADCON
- [Field] Int32 NTv1
- [Field] Int32 NTv2
- [Field] Int32 OST02
- [Field] Int32 OST15
- [Field] Int32 OST97
- [Field] Int32 PAR
- [Field] Int32 RGF
-type OSGeo.MapGuide.MgAgfReaderWriter : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgGeometry Read(OSGeo.MapGuide.MgByteReader)
- [Method] OSGeo.MapGuide.MgGeometry Read(OSGeo.MapGuide.MgByteReader, OSGeo.MapGuide.MgTransform)
- [Method] OSGeo.MapGuide.MgByteReader Write(OSGeo.MapGuide.MgGeometry)
- [Method] OSGeo.MapGuide.MgByteReader Write(OSGeo.MapGuide.MgGeometry, OSGeo.MapGuide.MgTransform)
-type OSGeo.MapGuide.MgAggregateGeometry : OSGeo.MapGuide.MgGeometry
-type OSGeo.MapGuide.MgArcSegment : OSGeo.MapGuide.MgCurveSegment
- [Method] OSGeo.MapGuide.MgGeometricEntity Copy()
- [Method] Int32 get_ComponentType()
- [Method] OSGeo.MapGuide.MgCoordinate get_ControlCoordinate()
- [Method] Int32 get_Dimension()
- [Method] OSGeo.MapGuide.MgCoordinate get_EndCoordinate()
- [Method] OSGeo.MapGuide.MgCoordinate get_StartCoordinate()
- [Method] Int32 GetComponentType()
- [Method] OSGeo.MapGuide.MgCoordinate GetControlCoordinate()
- [Method] Int32 GetDimension()
- [Method] OSGeo.MapGuide.MgCoordinate GetEndCoordinate()
- [Method] OSGeo.MapGuide.MgCoordinate GetStartCoordinate()
- [Method] Boolean IsClosed()
- [Method] Boolean IsEmpty()
- [Method] OSGeo.MapGuide.MgGeometricEntity Transform(OSGeo.MapGuide.MgTransform)
-type OSGeo.MapGuide.MgCoordinate : OSGeo.MapGuide.MgSerializable
- [Method] Double get_M()
- [Method] Double get_NoM()
- [Method] Double get_NoZ()
- [Method] Double get_X()
- [Method] Double get_Y()
- [Method] Double get_Z()
- [Method] Double GetM()
- [Method] Double GetX()
- [Method] Double GetY()
- [Method] Double GetZ()
-type OSGeo.MapGuide.MgCoordinateCollection : OSGeo.MapGuide.MgGuardDisposable
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgCoordinate, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgCoordinate, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgCoordinate, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgCoordinate)
- [Method] Boolean Contains(OSGeo.MapGuide.MgCoordinate)
- [Method] Void CopyTo(OSGeo.MapGuide.MgCoordinate[], Int32)
- [Method] OSGeo.MapGuide.MgCoordinate get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgCoordinate] GetEnumerator()
- [Method] OSGeo.MapGuide.MgCoordinate GetItem(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgCoordinate)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgCoordinate)
- [Method] Boolean Remove(OSGeo.MapGuide.MgCoordinate)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgCoordinate)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgCoordinate)
-type OSGeo.MapGuide.MgCoordinateIterator : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgCoordinate GetCurrent()
- [Method] Boolean MoveNext()
- [Method] Void Reset()
-type OSGeo.MapGuide.MgCoordinateSystem : OSGeo.MapGuide.MgGuardDisposable
- [Method] Void CancelLonLatBounds()
- [Method] Void CancelXYBounds()
- [Method] Void ConvertCoordinateFromLonLat(OSGeo.MapGuide.MgCoordinate)
- [Method] Double ConvertCoordinateSystemUnitsToMeters(Double)
- [Method] Void ConvertCoordinateToLonLat(OSGeo.MapGuide.MgCoordinate)
- [Method] OSGeo.MapGuide.MgCoordinate ConvertFromLonLat(Double, Double)
- [Method] OSGeo.MapGuide.MgCoordinate ConvertFromLonLat(Double, Double, Double)
- [Method] OSGeo.MapGuide.MgCoordinate ConvertFromLonLat(OSGeo.MapGuide.MgCoordinate)
- [Method] Double ConvertMetersToCoordinateSystemUnits(Double)
- [Method] OSGeo.MapGuide.MgCoordinate ConvertToLonLat(Double, Double)
- [Method] OSGeo.MapGuide.MgCoordinate ConvertToLonLat(Double, Double, Double)
- [Method] OSGeo.MapGuide.MgCoordinate ConvertToLonLat(OSGeo.MapGuide.MgCoordinate)
- [Method] OSGeo.MapGuide.MgCoordinateSystem CreateClone()
- [Method] System.String get_CsCode()
- [Method] System.String get_Datum()
- [Method] System.String get_DatumDescription()
- [Method] System.String get_Ellipsoid()
- [Method] System.String get_EllipsoidDescription()
- [Method] Int32 get_EpsgCode()
- [Method] Int16 get_EpsgQuadrant()
- [Method] Double get_MaxX()
- [Method] Double get_MaxY()
- [Method] Double get_MinX()
- [Method] Double get_MinY()
- [Method] System.String get_Projection()
- [Method] System.String get_ProjectionDescription()
- [Method] Int32 get_SridCode()
- [Method] Int32 get_Type()
- [Method] System.String get_Units()
- [Method] Double get_UnitScale()
- [Method] Int16 GetAge()
- [Method] Double GetAzimuth(OSGeo.MapGuide.MgCoordinate, OSGeo.MapGuide.MgCoordinate)
- [Method] Double GetAzimuth(Double, Double, Double, Double)
- [Method] OSGeo.MapGuide.MgCoordinateSystemCatalog GetCatalog()
- [Method] OSGeo.MapGuide.MgStringCollection GetCategories()
- [Method] Double GetConvergence(Double, Double)
- [Method] OSGeo.MapGuide.MgCoordinate GetCoordinate(OSGeo.MapGuide.MgCoordinate, Double, Double)
- [Method] OSGeo.MapGuide.MgCoordinate GetCoordinate(Double, Double, Double, Double)
- [Method] System.String GetCountryOrState()
- [Method] System.String GetCsCode()
- [Method] System.String GetDatum()
- [Method] OSGeo.MapGuide.MgCoordinateSystemDatum GetDatumDefinition()
- [Method] System.String GetDatumDescription()
- [Method] System.String GetEllipsoid()
- [Method] OSGeo.MapGuide.MgCoordinateSystemEllipsoid GetEllipsoidDefinition()
- [Method] System.String GetEllipsoidDescription()
- [Method] Int32 GetEpsgCode()
- [Method] Int16 GetEpsgQuadrant()
- [Method] OSGeo.MapGuide.MgCoordinateSystemEnumInteger32 GetErrors()
- [Method] System.String GetGroup()
- [Method] Double GetLatMax()
- [Method] Double GetLatMin()
- [Method] System.String GetLocation()
- [Method] Double GetLonMax()
- [Method] Double GetLonMin()
- [Method] Double GetMapScale()
- [Method] Double GetMaxX()
- [Method] Double GetMaxY()
- [Method] OSGeo.MapGuide.MgCoordinateSystemMeasure GetMeasure()
- [Method] Double GetMinX()
- [Method] Double GetMinY()
- [Method] Double GetOffsetX()
- [Method] Double GetOffsetY()
- [Method] Double GetOriginLatitude()
- [Method] Double GetOriginLongitude()
- [Method] System.String GetProjection()
- [Method] Int32 GetProjectionCode()
- [Method] System.String GetProjectionDescription()
- [Method] Double GetProjectionParameter(Int32)
- [Method] Int32 GetProjectionParameterCount()
- [Method] Int16 GetQuadrant()
- [Method] Double GetScale(Double, Double)
- [Method] Double GetScaleH(Double, Double)
- [Method] Double GetScaleK(Double, Double)
- [Method] Double GetScaleReduction()
- [Method] System.String GetSource()
- [Method] Int32 GetSridCode()
- [Method] Int32 GetType()
- [Method] Int32 GetUnitCode()
- [Method] System.String GetUnits()
- [Method] Double GetUnitScale()
- [Method] Double GetZeroX()
- [Method] Double GetZeroY()
- [Method] Boolean IsEncrypted()
- [Method] Boolean IsGeodetic()
- [Method] Boolean IsLegalCountryOrState(System.String)
- [Method] Boolean IsLegalCsCode(System.String)
- [Method] Boolean IsLegalDescription(System.String)
- [Method] Boolean IsLegalGroup(System.String)
- [Method] Boolean IsLegalLocation(System.String)
- [Method] Boolean IsLegalSource(System.String)
- [Method] Boolean IsProtected()
- [Method] Boolean IsSameAs(OSGeo.MapGuide.MgGuardDisposable)
- [Method] Boolean IsUsable(OSGeo.MapGuide.MgCoordinateSystemCatalog)
- [Method] Boolean IsValid()
- [Method] Boolean IsValidLonLat(Double, Double)
- [Method] Boolean IsValidXY(Double, Double)
- [Method] Double MeasureEuclideanDistance(OSGeo.MapGuide.MgCoordinate, OSGeo.MapGuide.MgCoordinate)
- [Method] Double MeasureEuclideanDistance(Double, Double, Double, Double)
- [Method] Double MeasureGreatCircleDistance(Double, Double, Double, Double)
- [Method] Double MeasureGreatCircleDistance(OSGeo.MapGuide.MgCoordinate, OSGeo.MapGuide.MgCoordinate)
- [Method] Void SetCountryOrState(System.String)
- [Method] Void SetCsCode(System.String)
- [Method] Void SetDatumDefinition(OSGeo.MapGuide.MgCoordinateSystemDatum)
- [Method] Void SetEllipsoidDefinition(OSGeo.MapGuide.MgCoordinateSystemEllipsoid)
- [Method] Void SetEncryptMode(Boolean)
- [Method] Void SetGroup(System.String)
- [Method] Void SetLocation(System.String)
- [Method] Void SetLonLatBounds(Double, Double, Double, Double)
- [Method] Void SetMapScale(Double)
- [Method] Void SetOffsets(Double, Double)
- [Method] Void SetOriginLatitude(Double)
- [Method] Void SetOriginLongitude(Double)
- [Method] Void SetProjectionCode(Int32)
- [Method] Void SetProjectionParameter(Int32, Double)
- [Method] Void SetProtectMode(Boolean)
- [Method] Void SetQuadrant(Int16)
- [Method] Void SetScaleReduction(Double)
- [Method] Void SetSource(System.String)
- [Method] Void SetUnitCode(Int32)
- [Method] Void SetXYBounds(Double, Double, Double, Double)
- [Method] Void SetZeroes(Double, Double)
-type OSGeo.MapGuide.MgCoordinateSystemCatalog : OSGeo.MapGuide.MgGuardDisposable
- [Method] Boolean AreDictionaryFilesWritable()
- [Method] OSGeo.MapGuide.MgCoordinateSystemCategoryDictionary GetCategoryDictionary()
- [Method] OSGeo.MapGuide.MgCoordinateSystemDictionary GetCoordinateSystemDictionary()
- [Method] OSGeo.MapGuide.MgCoordinateSystemDatumDictionary GetDatumDictionary()
- [Method] System.String GetDefaultDictionaryDir()
- [Method] System.String GetDefaultUserDictionaryDir()
- [Method] System.String GetDictionaryDir()
- [Method] OSGeo.MapGuide.MgCoordinateSystemDictionaryUtility GetDictionaryUtility()
- [Method] OSGeo.MapGuide.MgCoordinateSystemEllipsoidDictionary GetEllipsoidDictionary()
- [Method] OSGeo.MapGuide.MgCoordinateSystemFormatConverter GetFormatConverter()
- [Method] OSGeo.MapGuide.MgCoordinateSystemGeodeticPathDictionary GetGeodeticPathDictionary()
- [Method] OSGeo.MapGuide.MgDisposableCollection GetGeodeticTransformations(OSGeo.MapGuide.MgCoordinateSystemDatum, OSGeo.MapGuide.MgCoordinateSystemDatum)
- [Method] OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDefDictionary GetGeodeticTransformDefDictionary()
- [Method] OSGeo.MapGuide.MgCoordinateSystemMathComparator GetMathComparator()
- [Method] OSGeo.MapGuide.MgCoordinateSystemProjectionInformation GetProjectionInformation()
- [Method] Int16 GetProtectionMode()
- [Method] OSGeo.MapGuide.MgCoordinateSystemUnitInformation GetUnitInformation()
- [Method] System.String GetUserDictionaryDir()
- [Method] Void SetDefaultDictionaryDirAndFileNames()
- [Method] Void SetDictionaryDir(System.String)
- [Method] Void SetProtectionMode(Int16)
- [Method] Void SetUserDictionaryDir(System.String)
-type OSGeo.MapGuide.MgCoordinateSystemCategory : OSGeo.MapGuide.MgGuardDisposable
- [Method] Void AddCoordinateSystem(System.String)
- [Method] OSGeo.MapGuide.MgCoordinateSystemCategory CreateClone()
- [Method] OSGeo.MapGuide.MgStringCollection GetCoordinateSystems()
- [Method] OSGeo.MapGuide.MgCoordinateSystemEnum GetEnum()
- [Method] Int32 GetSize()
- [Method] Boolean HasCoordinateSystem(System.String)
- [Method] Boolean IsLegalName(System.String)
- [Method] Void RemoveCoordinateSystem(System.String)
-type OSGeo.MapGuide.MgCoordinateSystemCategoryDictionary : OSGeo.MapGuide.MgCoordinateSystemDictionaryBase
- [Method] OSGeo.MapGuide.MgCoordinateSystemCategory GetCategory(System.String)
- [Method] OSGeo.MapGuide.MgCoordinateSystemCategory NewCategory()
- [Method] Void Rename(System.String, System.String)
-type OSGeo.MapGuide.MgCoordinateSystemDatum : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgCoordinateSystemDatum CreateClone()
- [Method] System.String GetDtCode()
- [Method] Int16 GetEpsgCode()
- [Method] OSGeo.MapGuide.MgDisposableCollection GetGeodeticTransformations(OSGeo.MapGuide.MgCoordinateSystemDatum)
- [Method] Boolean IsLegalDtCode(System.String)
- [Method] Void SetDtCode(System.String)
- [Method] Void SetEllipsoid(System.String)
- [Method] Void SetEpsgCode(Int16)
-type OSGeo.MapGuide.MgCoordinateSystemDatumDictionary : OSGeo.MapGuide.MgCoordinateSystemDictionaryBase
- [Method] OSGeo.MapGuide.MgCoordinateSystemDatum GetDatum(System.String)
- [Method] OSGeo.MapGuide.MgCoordinateSystemDatum NewDatum()
-type OSGeo.MapGuide.MgCoordinateSystemDictionary : OSGeo.MapGuide.MgCoordinateSystemDictionaryBase
- [Method] OSGeo.MapGuide.MgCoordinateSystem GetCoordinateSystem(System.String)
- [Method] OSGeo.MapGuide.MgCoordinateSystem NewCoordinateSystem()
-type OSGeo.MapGuide.MgCoordinateSystemDictionaryBase : OSGeo.MapGuide.MgGuardDisposable
- [Method] Void Add(OSGeo.MapGuide.MgGuardDisposable)
- [Method] OSGeo.MapGuide.MgGuardDisposable Get(System.String)
- [Method] System.String GetDefaultFileName()
- [Method] System.String GetFileName()
- [Method] System.String GetPath()
- [Method] Boolean Has(System.String)
- [Method] Void Modify(OSGeo.MapGuide.MgGuardDisposable)
- [Method] Void Remove(System.String)
- [Method] Void SetFileName(System.String)
-type OSGeo.MapGuide.MgCoordinateSystemDictionaryUtility : OSGeo.MapGuide.MgGuardDisposable
- [Method] Void CreateCategoryDictionary(System.String)
- [Method] Void CreateCoordsysDictionary(System.String)
- [Method] Void CreateDatumDictionary(System.String)
- [Method] Void CreateEllipsoidDictionary(System.String)
-type OSGeo.MapGuide.MgCoordinateSystemEllipsoid : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgCoordinateSystemEllipsoid CreateClone()
- [Method] Double EccentricityToFlatteningRatio(Double)
- [Method] Double EquatorialRadiusFromPolarRadiusFlatteningRatio(Double, Double)
- [Method] Double FlatteningRatioFromRadii(Double, Double)
- [Method] Double FlatteningRatioToEccentricity(Double)
- [Method] System.String get_ElCode()
- [Method] Double GetEccentricity()
- [Method] System.String GetElCode()
- [Method] Double GetEquatorialRadius()
- [Method] Double GetFlatteningRatio()
- [Method] Double GetFlatteningRatioMax()
- [Method] Double GetFlatteningRatioMin()
- [Method] Double GetGreatCircleAzimuth(Double, Double, Double, Double)
- [Method] Double GetGreatCircleDistance(Double, Double, Double, Double)
- [Method] Double GetPolarRadius()
- [Method] Double GetRadiusMax()
- [Method] Double GetRadiusMin()
- [Method] Boolean IsLegalElCode(System.String)
- [Method] Boolean IsLegalFlatteningRatio(Double)
- [Method] Boolean IsLegalRadius(Double)
- [Method] Boolean IsUsable()
- [Method] Double PolarRadiusFromEquatorialRadiusFlatteningRatio(Double, Double)
- [Method] Void SetElCode(System.String)
- [Method] Void SetRadii(Double, Double)
-type OSGeo.MapGuide.MgCoordinateSystemEllipsoidDictionary : OSGeo.MapGuide.MgCoordinateSystemDictionaryBase
- [Method] OSGeo.MapGuide.MgCoordinateSystemEllipsoid GetEllipsoid(System.String)
- [Method] OSGeo.MapGuide.MgCoordinateSystemEllipsoid NewEllipsoid()
-type OSGeo.MapGuide.MgCoordinateSystemEnum : OSGeo.MapGuide.MgGuardDisposable
- [Method] Void AddFilter(OSGeo.MapGuide.MgCoordinateSystemFilter)
- [Method] OSGeo.MapGuide.MgCoordinateSystemEnum CreateClone()
- [Method] OSGeo.MapGuide.MgDisposableCollection Next(Int32)
- [Method] OSGeo.MapGuide.MgStringCollection NextDescription(Int32)
- [Method] OSGeo.MapGuide.MgStringCollection NextName(Int32)
- [Method] Void Skip(Int32)
-type OSGeo.MapGuide.MgCoordinateSystemEnumInteger32 : OSGeo.MapGuide.MgGuardDisposable
- [Method] Void AddFilter(OSGeo.MapGuide.MgCoordinateSystemFilterInteger32)
- [Method] OSGeo.MapGuide.MgCoordinateSystemEnumInteger32 CreateClone()
- [Method] OSGeo.MapGuide.MgStringCollection Next(Int32)
-type OSGeo.MapGuide.MgCoordinateSystemFactory : OSGeo.MapGuide.MgGuardDisposable
- [Method] System.String ConvertCoordinateSystemCodeToWkt(System.String)
- [Method] System.String ConvertEpsgCodeToWkt(Int32)
- [Method] System.String ConvertWktToCoordinateSystemCode(System.String)
- [Method] Int32 ConvertWktToEpsgCode(System.String)
- [Method] OSGeo.MapGuide.MgCoordinateSystem Create(System.String)
- [Method] OSGeo.MapGuide.MgCoordinateSystem CreateFromCode(System.String)
- [Method] OSGeo.MapGuide.MgStringCollection EnumerateCategories()
- [Method] OSGeo.MapGuide.MgBatchPropertyCollection EnumerateCoordinateSystems(System.String)
- [Method] OSGeo.MapGuide.MgCoordinateSystemGridBase GenericGrid(OSGeo.MapGuide.MgCoordinateSystem, OSGeo.MapGuide.MgCoordinateSystem, Boolean)
- [Method] OSGeo.MapGuide.MgCoordinateSystemGridBase GenericGrid(System.String, System.String, Boolean)
- [Method] System.String GetBaseLibrary()
- [Method] OSGeo.MapGuide.MgCoordinateSystemMgrs GetMgrs(Double, Double, Int16, Boolean)
- [Method] OSGeo.MapGuide.MgCoordinateSystemMgrs GetMgrsDatum(System.String, Int16, Boolean)
- [Method] OSGeo.MapGuide.MgCoordinateSystemMgrs GetMgrsEllipsoid(System.String, Int16, Boolean)
- [Method] OSGeo.MapGuide.MgCoordinateSystemTransform GetTransform(OSGeo.MapGuide.MgCoordinateSystem, OSGeo.MapGuide.MgCoordinateSystem)
- [Method] OSGeo.MapGuide.MgCoordinateSystemGridBoundary GridBoundary(OSGeo.MapGuide.MgPolygon)
- [Method] OSGeo.MapGuide.MgCoordinateSystemGridBoundary GridBoundary(OSGeo.MapGuide.MgCoordinate, OSGeo.MapGuide.MgCoordinate)
- [Method] OSGeo.MapGuide.MgCoordinateSystemGridSpecification GridSpecification()
- [Method] OSGeo.MapGuide.MgCoordinateSystemGridSpecification GridSpecification(Double, Double, Int32, Double)
- [Method] OSGeo.MapGuide.MgCoordinateSystemGridSpecification GridSpecification(Int32, Int32)
- [Method] Boolean IsValid(System.String)
- [Method] OSGeo.MapGuide.MgCoordinateSystemGridBase MgrsGrid(System.String, Boolean, Int16, Boolean)
- [Method] OSGeo.MapGuide.MgCoordinateSystemGridBase MgrsGrid(OSGeo.MapGuide.MgCoordinateSystem, Boolean, Int16, Boolean)
-type OSGeo.MapGuide.MgCoordinateSystemFilter : OSGeo.MapGuide.MgGuardDisposable
- [Method] Boolean IsFilteredOut(OSGeo.MapGuide.MgGuardDisposable)
-type OSGeo.MapGuide.MgCoordinateSystemFilterInteger32 : OSGeo.MapGuide.MgGuardDisposable
- [Method] Boolean IsFilteredOut(Int32)
-type OSGeo.MapGuide.MgCoordinateSystemFormatConverter : OSGeo.MapGuide.MgGuardDisposable
- [Method] System.String CodeToCode(Int32, System.String, Int32)
- [Method] OSGeo.MapGuide.MgCoordinateSystem CodeToDefinition(Int32, System.String)
- [Method] System.String CodeToWkt(Int32, System.String, Int32)
- [Method] System.String DefinitionToCode(OSGeo.MapGuide.MgCoordinateSystem, Int32)
- [Method] System.String DefinitionToWkt(OSGeo.MapGuide.MgCoordinateSystem, Int32)
- [Method] Boolean IsCodeInDictionary(Int32, System.String)
- [Method] System.String WktToCode(Int32, System.String, Int32)
- [Method] OSGeo.MapGuide.MgCoordinateSystem WktToDefinition(Int32, System.String)
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticAnalyticalTransformDefParams : OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDefParams
- [Method] Double GetDeltaX()
- [Method] Double GetDeltaY()
- [Method] Double GetDeltaZ()
- [Method] Double GetRotateX()
- [Method] Double GetRotateY()
- [Method] Double GetRotateZ()
- [Method] Double GetScale()
- [Method] Int32 GetTransformationMethod()
- [Method] Double GetTranslateX()
- [Method] Double GetTranslateY()
- [Method] Double GetTranslateZ()
- [Method] Void SetDeltaX(Double)
- [Method] Void SetDeltaY(Double)
- [Method] Void SetDeltaZ(Double)
- [Method] Void SetRotateX(Double)
- [Method] Void SetRotateY(Double)
- [Method] Void SetRotateZ(Double)
- [Method] Void SetScale(Double)
- [Method] Void SetTransformationMethod(Int32)
- [Method] Void SetTranslateX(Double)
- [Method] Void SetTranslateY(Double)
- [Method] Void SetTranslateZ(Double)
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticInterpolationTransformDefParams : OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDefParams
- [Method] System.String GetFallback()
- [Method] OSGeo.MapGuide.MgDisposableCollection GetGridFiles()
- [Method] OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformGridFile NewGridFile()
- [Method] Void SetFallback(System.String)
- [Method] Void SetGridFiles(OSGeo.MapGuide.MgDisposableCollection)
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams : OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDefParams
- [Method] Double GetCoefficientHeight(Int32)
- [Method] Double GetCoefficientLambda(Int32)
- [Method] Double GetCoefficientPhi(Int32)
- [Method] Double GetDeltaHeight()
- [Method] Double GetDeltaLambda()
- [Method] Double GetDeltaPhi()
- [Method] Double GetLambdaOffset()
- [Method] Double GetNormalizationScale()
- [Method] Double GetPhiOffset()
- [Method] Double GetTestLambda()
- [Method] Double GetTestPhi()
- [Method] Double GetValidation()
- [Method] Void SetCoefficientHeight(Int32, Double)
- [Method] Void SetCoefficientLambda(Int32, Double)
- [Method] Void SetCoefficientPhi(Int32, Double)
- [Method] Void SetDeltaHeight(Double)
- [Method] Void SetDeltaLambda(Double)
- [Method] Void SetDeltaPhi(Double)
- [Method] Void SetLambdaOffset(Double)
- [Method] Void SetNormalizationScale(Double)
- [Method] Void SetPhiOffset(Double)
- [Method] Void SetTestLambda(Double)
- [Method] Void SetTestPhi(Double)
- [Method] Void SetValidation(Double)
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticPath : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgCoordinateSystemGeodeticPath CreateClone()
- [Method] Double get_Accuracy()
- [Method] System.String get_Group()
- [Method] System.String get_Source()
- [Method] System.String get_SourceDatum()
- [Method] System.String get_TargetDatum()
- [Method] Double GetAccuracy()
- [Method] Int32 GetEpsgVariant()
- [Method] Boolean GetIsReversible()
- [Method] OSGeo.MapGuide.MgDisposableCollection GetPathElements()
- [Method] System.String GetPathName()
- [Method] System.String GetSourceDatum()
- [Method] System.String GetTargetDatum()
- [Method] OSGeo.MapGuide.MgCoordinateSystemGeodeticPathElement NewPathElement()
- [Method] Void SetAccuracy(Double)
- [Method] Void SetEpsgCode(Int32)
- [Method] Void SetEpsgVariant(Int32)
- [Method] Void SetIsReversible(Boolean)
- [Method] Void SetPathElements(OSGeo.MapGuide.MgDisposableCollection)
- [Method] Void SetPathName(System.String)
- [Method] Void SetSourceDatum(System.String)
- [Method] Void SetTargetDatum(System.String)
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticPathDictionary : OSGeo.MapGuide.MgCoordinateSystemDictionaryBase
- [Method] OSGeo.MapGuide.MgCoordinateSystemGeodeticPath GetGeodeticPath(System.String)
- [Method] OSGeo.MapGuide.MgCoordinateSystemGeodeticPath NewGeodeticPath()
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticPathElement : OSGeo.MapGuide.MgGuardDisposable
- [Method] Boolean GetIsInversed()
- [Method] System.String GetTransformName()
- [Method] Void SetIsInversed(Boolean)
- [Method] Void SetTransformName(System.String)
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticStandaloneTransformDefParams : OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDefParams
- [Method] Int32 get_TransformationMethod()
- [Method] Void set_TransformationMethod(Int32)
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformation : OSGeo.MapGuide.MgGuardDisposable
- [Method] Double GetBursaWolfeTransformBwScale()
- [Method] Double GetBursaWolfeTransformRotationX()
- [Method] Double GetBursaWolfeTransformRotationY()
- [Method] Double GetBursaWolfeTransformRotationZ()
- [Method] Double GetBwScaleMax()
- [Method] Double GetBwScaleMin()
- [Method] Int32 GetGeodeticTransformationMethod()
- [Method] Double GetMaxOffset()
- [Method] Double GetMaxRotation()
- [Method] Double GetOffsetZ()
- [Method] OSGeo.MapGuide.MgCoordinateSystemDatum GetSource()
- [Method] OSGeo.MapGuide.MgCoordinateSystemDatum GetTarget()
- [Method] Boolean IsLegalBwScale(Double)
- [Method] Boolean IsLegalOffset(Double)
- [Method] Boolean IsLegalRotation(Double)
- [Method] Void SetBursaWolfeTransform(Double, Double, Double, Double)
- [Method] Void SetGeodeticTransformationMethod(Int32)
- [Method] Void SetOffset(Double, Double, Double)
- [Method] Void SetSourceAndTarget(OSGeo.MapGuide.MgCoordinateSystemDatum, OSGeo.MapGuide.MgCoordinateSystemDatum)
- [Method] OSGeo.MapGuide.MgCoordinate Shift(Double, Double)
- [Method] Void Shift(OSGeo.MapGuide.MgCoordinate)
- [Method] OSGeo.MapGuide.MgCoordinate Shift(Double, Double, Double)
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDef : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDef CreateClone()
- [Method] OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformation CreateTransformation(Boolean)
- [Method] Double GetConvergenceValue()
- [Method] Int32 GetEpsgVariation()
- [Method] Double GetErrorValue()
- [Method] Boolean GetInverseSupported()
- [Method] Int32 GetMaxIterations()
- [Method] OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDefParams GetParameters()
- [Method] Double GetRangeMaxLatitude()
- [Method] Double GetRangeMaxLongitude()
- [Method] Double GetRangeMinLatitude()
- [Method] Double GetRangeMinLongitude()
- [Method] Int32 GetTransformDefType()
- [Method] Void SetConvergenceValue(Double)
- [Method] Void SetEpsgVariation(Int32)
- [Method] Void SetErrorValue(Double)
- [Method] Void SetInverseSupported(Boolean)
- [Method] Void SetMaxIterations(Int32)
- [Method] Void SetParameters(OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDefParams)
- [Method] Void SetRangeMaxLatitude(Double)
- [Method] Void SetRangeMaxLongitude(Double)
- [Method] Void SetRangeMinLatitude(Double)
- [Method] Void SetRangeMinLongitude(Double)
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDefDictionary : OSGeo.MapGuide.MgCoordinateSystemDictionaryBase
- [Method] OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDef GetGeodeticTransformationDef(System.String)
- [Method] OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDef NewGeodeticTransformationDef(Int32)
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDefParams : OSGeo.MapGuide.MgGuardDisposable
-type OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformGridFile : OSGeo.MapGuide.MgGuardDisposable
- [Method] Int32 GetFileFormat()
- [Method] Boolean GetIsInverseDirection()
- [Method] Void SetFileFormat(Int32)
- [Method] Void SetIsInverseDirection(Boolean)
-type OSGeo.MapGuide.MgCoordinateSystemGridBase : OSGeo.MapGuide.MgGuardDisposable
- [Method] Int32 ApproxGridLineMemoryUsage(OSGeo.MapGuide.MgCoordinateSystemGridSpecification)
- [Method] Int32 ApproxGridRegionMemoryUsage(OSGeo.MapGuide.MgCoordinateSystemGridSpecification)
- [Method] Int32 ApproxGridTickMemoryUsage(OSGeo.MapGuide.MgCoordinateSystemGridSpecification)
- [Method] Boolean AreExceptionsOn()
- [Method] OSGeo.MapGuide.MgCoordinateSystemGridBoundary GetBoundary()
- [Method] Double GetConvergenceAngle(OSGeo.MapGuide.MgCoordinate)
- [Method] OSGeo.MapGuide.MgCoordinateSystemGridLineCollection GetGridLines(OSGeo.MapGuide.MgCoordinateSystemGridSpecification)
- [Method] OSGeo.MapGuide.MgCoordinateSystemGridRegionCollection GetGridRegions(OSGeo.MapGuide.MgCoordinateSystemGridSpecification)
- [Method] OSGeo.MapGuide.MgCoordinateSystemGridTickCollection GetGridTicks(OSGeo.MapGuide.MgCoordinateSystemGridSpecification)
- [Method] Int32 GetLastError()
- [Method] Double GetProjectiveGridScale(OSGeo.MapGuide.MgCoordinate)
- [Method] Int32 GetSpecializationType()
- [Method] Void ResetLastError()
- [Method] Void SetBoundary(OSGeo.MapGuide.MgCoordinateSystemGridBoundary)
- [Method] Void SetExceptionsOn(Boolean)
- [Method] Int32 SetGridLineExceptionLevel(Int32)
- [Method] Int32 SetGridRegionExceptionLevel(Int32)
- [Method] Int32 SetGridTickExceptionLevel(Int32)
-type OSGeo.MapGuide.MgCoordinateSystemGridBoundary : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgPolygon GetBoundary()
- [Method] Void SetBoundaryExtents(OSGeo.MapGuide.MgCoordinate, OSGeo.MapGuide.MgCoordinate)
- [Method] Void SetBoundaryExtents(OSGeo.MapGuide.MgPolygon)
-type OSGeo.MapGuide.MgCoordinateSystemGridLine : OSGeo.MapGuide.MgGuardDisposable
- [Method] Int32 GetGridOrientation()
- [Method] Double GetRealValue()
- [Method] OSGeo.MapGuide.MgLineString GetSegment(Int32)
- [Method] OSGeo.MapGuide.MgLineStringCollection GetSegmentCollection()
- [Method] Void SetSegmentCollection(OSGeo.MapGuide.MgLineStringCollection)
-type OSGeo.MapGuide.MgCoordinateSystemGridLineCollection : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgCoordinateSystemGridLine GetItem(Int32)
- [Method] Int32 IndexOf(Int32, Double)
-type OSGeo.MapGuide.MgCoordinateSystemGridRegion : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgLineStringCollection GetEastLine()
- [Method] System.String GetLabel()
- [Method] OSGeo.MapGuide.MgLineStringCollection GetNorthLine()
- [Method] OSGeo.MapGuide.MgPolygon GetRegionBoundary()
- [Method] OSGeo.MapGuide.MgCoordinate GetRegionCenter()
- [Method] OSGeo.MapGuide.MgLineStringCollection GetSouthLine()
- [Method] OSGeo.MapGuide.MgLineStringCollection GetWestLine()
-type OSGeo.MapGuide.MgCoordinateSystemGridRegionCollection : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgCoordinateSystemGridRegion GetItem(Int32)
-type OSGeo.MapGuide.MgCoordinateSystemGridSpecification : OSGeo.MapGuide.MgGuardDisposable
- [Method] Double GetCurvePrecision()
- [Method] Double GetEastingBase()
- [Method] Double GetEastingIncrement()
- [Method] Double GetNorthingBase()
- [Method] Double GetNorthingIncrement()
- [Method] Double GetTickEastingIncrement()
- [Method] Double GetTickNorthingIncrement()
- [Method] Int32 GetUnitType()
- [Method] Boolean IsConsistent()
- [Method] Boolean IsSameAs(OSGeo.MapGuide.MgCoordinateSystemGridSpecification)
- [Method] Void SetCurvePrecision(Double)
- [Method] Void SetGridBase(Double, Double)
- [Method] Void SetGridIncrement(Double, Double)
- [Method] Void SetMaxCurvePoints(Int32)
- [Method] Void SetTickIncrements(Double, Double)
- [Method] Void SetUnits(Int32, Int32)
-type OSGeo.MapGuide.MgCoordinateSystemGridTick : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgCoordinate GetDirectionVector()
- [Method] Boolean GetIsOnGridLine()
- [Method] OSGeo.MapGuide.MgCoordinate GetPosition()
- [Method] Int32 GetTickOrientation()
- [Method] Double GetValue()
-type OSGeo.MapGuide.MgCoordinateSystemGridTickCollection : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgCoordinateSystemGridTick GetItem(Int32)
-type OSGeo.MapGuide.MgCoordinateSystemMathComparator : OSGeo.MapGuide.MgGuardDisposable
- [Method] Boolean GetCompareInternalDatumOldParameters()
- [Method] Boolean Same(OSGeo.MapGuide.MgGuardDisposable, OSGeo.MapGuide.MgGuardDisposable)
- [Method] Boolean SameCoordinateSystem(OSGeo.MapGuide.MgCoordinateSystem, OSGeo.MapGuide.MgCoordinateSystem)
- [Method] Boolean SameDatum(OSGeo.MapGuide.MgCoordinateSystemDatum, OSGeo.MapGuide.MgCoordinateSystemDatum)
- [Method] Boolean SameEllipsoid(OSGeo.MapGuide.MgCoordinateSystemEllipsoid, OSGeo.MapGuide.MgCoordinateSystemEllipsoid)
- [Method] Void SetCompareInternalDatumOldParameters(Boolean)
-type OSGeo.MapGuide.MgCoordinateSystemMeasure : OSGeo.MapGuide.MgMeasure
- [Method] OSGeo.MapGuide.MgEnvelope get_Envelope()
- [Method] Double GetDistance(OSGeo.MapGuide.MgCoordinate, OSGeo.MapGuide.MgCoordinate)
- [Method] Double GetDistance(Double, Double, Double, Double)
- [Method] OSGeo.MapGuide.MgEnvelope GetEnvelope()
-type OSGeo.MapGuide.MgCoordinateSystemMgrs : OSGeo.MapGuide.MgCoordinateSystemGridBase
- [Method] System.String ConvertFromLonLat(Double, Double, Int32)
- [Method] System.String ConvertFromLonLat(OSGeo.MapGuide.MgCoordinate, Int32)
- [Method] OSGeo.MapGuide.MgCoordinate ConvertToLonLat(System.String)
- [Method] OSGeo.MapGuide.MgCoordinate ConvertToLonLat(System.String, Int32)
- [Method] Int16 GetLetteringScheme()
-type OSGeo.MapGuide.MgCoordinateSystemProjectionInformation : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgCoordinateSystemEnumInteger32 GetEnumProjections()
- [Method] Int32 GetParameterCount(Int32)
- [Method] Double GetParameterDefault(Int32, Int32)
- [Method] Int32 GetParameterFormatType(Int32, Int32)
- [Method] Int32 GetParameterLogicalType(Int32, Int32)
- [Method] Double GetParameterMax(Int32, Int32)
- [Method] Double GetParameterMin(Int32, Int32)
- [Method] Int32 GetParameterType(Int32, Int32)
- [Method] System.String GetTagString(Int32)
- [Method] Int32 GetUnitType(Int32)
- [Method] Boolean IsUsingOffset(Int32)
- [Method] Boolean IsUsingOriginLatitude(Int32)
- [Method] Boolean IsUsingOriginLongitude(Int32)
- [Method] Boolean IsUsingParameter(Int32, Int32)
- [Method] Boolean IsUsingQuadrant(Int32)
- [Method] Boolean IsUsingScaleReduction(Int32)
-type OSGeo.MapGuide.MgCoordinateSystemTransform : OSGeo.MapGuide.MgTransform
- [Field] Int32 DatumShiftError
- [Field] Int32 DatumShiftFallback
- [Method] Int32 GetdatumWarningCount()
- [Method] OSGeo.MapGuide.MgCoordinateSystemGeodeticPath GetExplicitGeodeticPath()
- [Method] OSGeo.MapGuide.MgCoordinateSystemGeodeticTransformDef GetGeodeticTransformation(Int32)
- [Method] Int32 GetGeodeticTransformationCount()
- [Method] Int32 GetGeodeticTransformationDirection(Int32)
- [Method] Int32 GetLastTransformStatus()
- [Method] OSGeo.MapGuide.MgCoordinateSystem GetSource()
- [Method] Int32 GetSourceWarningCount()
- [Method] OSGeo.MapGuide.MgCoordinateSystem GetTarget()
- [Method] Int32 GetTargetWarningCount()
- [Method] OSGeo.MapGuide.MgLineString GridLine(OSGeo.MapGuide.MgCoordinate, OSGeo.MapGuide.MgCoordinate, Double, Int32)
- [Method] Void IgnoreDatumShiftWarning(Boolean)
- [Method] Void IgnoreOutsideDomainWarning(Boolean)
- [Method] Boolean IsIgnoreDatumShiftWarning()
- [Method] Boolean IsIgnoreOutsideDomainWarning()
- [Method] Boolean IsValidSourcePoint(Double, Double)
- [Method] Boolean IsValidSourcePoint(Double, Double, Double)
- [Method] Boolean IsValidTargetPoint(Double, Double, Double)
- [Method] Boolean IsValidTargetPoint(Double, Double)
- [Method] Void ResetLastTransformStatus()
- [Method] Void SetSourceAndTarget(OSGeo.MapGuide.MgCoordinateSystem, OSGeo.MapGuide.MgCoordinateSystem)
- [Field] Int32 SourceCrsError
- [Field] Int32 TargetCrsError
- [Method] OSGeo.MapGuide.MgCoordinate Transform(Double, Double)
- [Method] OSGeo.MapGuide.MgCoordinate Transform(OSGeo.MapGuide.MgCoordinate)
- [Method] OSGeo.MapGuide.MgCoordinate Transform(Double, Double, Double)
- [Method] OSGeo.MapGuide.MgEnvelope Transform(OSGeo.MapGuide.MgEnvelope)
- [Method] Void TransformCoordinate(OSGeo.MapGuide.MgCoordinate)
- [Field] Int32 TransformDatumShiftWarning
- [Method] OSGeo.MapGuide.MgCoordinate TransformM(Double, Double, Double, Double)
- [Method] OSGeo.MapGuide.MgCoordinate TransformM(Double, Double, Double)
- [Field] Int32 TransformOk
- [Field] Int32 TransformOutsideDomainWarning
- [Field] Int32 TransformTotalFailure
-type OSGeo.MapGuide.MgCoordinateSystemUnitInformation : OSGeo.MapGuide.MgGuardDisposable
- [Method] System.String GetAbbreviation(Int32)
- [Method] Double GetAngularUnitScale(Int32)
- [Method] OSGeo.MapGuide.MgCoordinateSystemEnumInteger32 GetEnumAngularUnits()
- [Method] OSGeo.MapGuide.MgCoordinateSystemEnumInteger32 GetEnumLinearUnits()
- [Method] Double GetLinearUnitScale(Int32)
-type OSGeo.MapGuide.MgCoordinateXY : OSGeo.MapGuide.MgCoordinate
-type OSGeo.MapGuide.MgCoordinateXYM : OSGeo.MapGuide.MgCoordinate
-type OSGeo.MapGuide.MgCoordinateXYZ : OSGeo.MapGuide.MgCoordinate
-type OSGeo.MapGuide.MgCoordinateXYZM : OSGeo.MapGuide.MgCoordinate
-type OSGeo.MapGuide.MgCurve : OSGeo.MapGuide.MgGeometry
-type OSGeo.MapGuide.MgCurvePolygon : OSGeo.MapGuide.MgRegion
- [Method] OSGeo.MapGuide.MgCurveRing get_ExteriorRing()
- [Method] Int32 get_GeometryType()
- [Method] Int32 get_InteriorRingCount()
- [Method] OSGeo.MapGuide.MgCurveRing GetExteriorRing()
- [Method] Int32 GetGeometryType()
- [Method] OSGeo.MapGuide.MgCurveRing GetInteriorRing(Int32)
- [Method] Int32 GetInteriorRingCount()
-type OSGeo.MapGuide.MgCurvePolygonCollection : OSGeo.MapGuide.MgGuardDisposable
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgCurvePolygon, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgCurvePolygon, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgCurvePolygon, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Constructor] Void .ctor()
- [Method] Void Add(OSGeo.MapGuide.MgCurvePolygon)
- [Method] Boolean Contains(OSGeo.MapGuide.MgCurvePolygon)
- [Method] Void CopyTo(OSGeo.MapGuide.MgCurvePolygon[], Int32)
- [Method] OSGeo.MapGuide.MgCurvePolygon get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgCurvePolygon] GetEnumerator()
- [Method] OSGeo.MapGuide.MgCurvePolygon GetItem(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgCurvePolygon)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgCurvePolygon)
- [Method] Boolean Remove(OSGeo.MapGuide.MgCurvePolygon)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgCurvePolygon)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgCurvePolygon)
-type OSGeo.MapGuide.MgCurveRing : OSGeo.MapGuide.MgRing
- [Method] OSGeo.MapGuide.MgCurveSegment GetSegment(Int32)
-type OSGeo.MapGuide.MgCurveRingCollection : OSGeo.MapGuide.MgGuardDisposable
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgCurveRing, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgCurveRing, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgCurveRing, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgCurveRing)
- [Method] Boolean Contains(OSGeo.MapGuide.MgCurveRing)
- [Method] Void CopyTo(OSGeo.MapGuide.MgCurveRing[], Int32)
- [Method] OSGeo.MapGuide.MgCurveRing get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgCurveRing] GetEnumerator()
- [Method] OSGeo.MapGuide.MgCurveRing GetItem(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgCurveRing)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgCurveRing)
- [Method] Boolean Remove(OSGeo.MapGuide.MgCurveRing)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgCurveRing)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgCurveRing)
-type OSGeo.MapGuide.MgCurveSegment : OSGeo.MapGuide.MgGeometryComponent
- implements System.IDisposable
-[System.Reflection.DefaultMemberAttribute]
-type OSGeo.MapGuide.MgCurveSegmentCollection : OSGeo.MapGuide.MgGuardDisposable
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgCurveSegment, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgCurveSegment, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgCurveSegment, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.IEnumerable
- [Method] Void Add(OSGeo.MapGuide.MgCurveSegment)
- [Method] Void Clear()
- [Method] Boolean Contains(OSGeo.MapGuide.MgCurveSegment)
- [Method] Void CopyTo(OSGeo.MapGuide.MgCurveSegment[], Int32)
- [Method] Int32 get_Count()
- [Method] Boolean get_IsReadOnly()
- [Method] OSGeo.MapGuide.MgCurveSegment get_Item(Int32)
- [Method] Int32 GetCount()
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgCurveSegment] GetEnumerator()
- [Method] OSGeo.MapGuide.MgCurveSegment GetItem(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgCurveSegment)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgCurveSegment)
- [Method] Boolean Remove(OSGeo.MapGuide.MgCurveSegment)
- [Method] Void RemoveAt(Int32)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgCurveSegment)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgCurveSegment)
-type OSGeo.MapGuide.MgCurveString : OSGeo.MapGuide.MgCurve
-type OSGeo.MapGuide.MgCurveStringCollection : OSGeo.MapGuide.MgGuardDisposable
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgCurveString, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgCurveString, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgCurveString, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgCurveString)
- [Method] Boolean Contains(OSGeo.MapGuide.MgCurveString)
- [Method] Void CopyTo(OSGeo.MapGuide.MgCurveString[], Int32)
- [Method] OSGeo.MapGuide.MgCurveString get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgCurveString] GetEnumerator()
- [Method] OSGeo.MapGuide.MgCurveString GetItem(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgCurveString)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgCurveString)
- [Method] Boolean Remove(OSGeo.MapGuide.MgCurveString)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgCurveString)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgCurveString)
-type OSGeo.MapGuide.MgEnvelope : OSGeo.MapGuide.MgSerializable
- [Constructor] Void .ctor(Double, Double, Double, Double)
- [Constructor] Void .ctor(OSGeo.MapGuide.MgEnvelope)
- [Constructor] Void .ctor(OSGeo.MapGuide.MgCoordinate)
- [Constructor] Void .ctor(OSGeo.MapGuide.MgCoordinate, OSGeo.MapGuide.MgCoordinate)
- [Method] Boolean Contains(OSGeo.MapGuide.MgEnvelope)
- [Method] Void ExpandToInclude(OSGeo.MapGuide.MgCoordinate)
- [Method] Void ExpandToInclude(OSGeo.MapGuide.MgEnvelope)
- [Method] Double get_Depth()
- [Method] Double get_Height()
- [Method] OSGeo.MapGuide.MgCoordinate get_LowerLeftCoordinate()
- [Method] OSGeo.MapGuide.MgCoordinate get_UpperRightCoordinate()
- [Method] Double get_Width()
- [Method] Double GetDepth()
- [Method] Double GetHeight()
- [Method] OSGeo.MapGuide.MgCoordinate GetLowerLeftCoordinate()
- [Method] OSGeo.MapGuide.MgCoordinate GetUpperRightCoordinate()
- [Method] Double GetWidth()
- [Method] Boolean Intersects(OSGeo.MapGuide.MgEnvelope)
- [Method] Void MakeNull()
- [Method] OSGeo.MapGuide.MgEnvelope Transform(OSGeo.MapGuide.MgTransform)
-type OSGeo.MapGuide.MgGeometricEntity : OSGeo.MapGuide.MgSerializable
- [Method] OSGeo.MapGuide.MgEnvelope Envelope()
- [Method] Double get_Area()
- [Method] OSGeo.MapGuide.MgPoint get_Centroid()
- [Method] Double get_Length()
- [Method] Double GetArea()
- [Method] OSGeo.MapGuide.MgPoint GetCentroid()
- [Method] Double GetLength()
- [Method] Boolean IsSimple()
-type OSGeo.MapGuide.MgGeometry : OSGeo.MapGuide.MgGeometricEntity
- [Method] OSGeo.MapGuide.MgGeometry Boundary()
- [Method] OSGeo.MapGuide.MgGeometry Buffer(Double, OSGeo.MapGuide.MgMeasure)
- [Method] Boolean Contains(OSGeo.MapGuide.MgGeometry)
- [Method] OSGeo.MapGuide.MgGeometry ConvexHull()
- [Method] Boolean Crosses(OSGeo.MapGuide.MgGeometry)
- [Method] OSGeo.MapGuide.MgGeometry Difference(OSGeo.MapGuide.MgGeometry)
- [Method] Boolean Disjoint(OSGeo.MapGuide.MgGeometry)
- [Method] Double Distance(OSGeo.MapGuide.MgGeometry, OSGeo.MapGuide.MgMeasure)
- [Method] Boolean Equals(OSGeo.MapGuide.MgGeometry)
- [Method] OSGeo.MapGuide.MgGeometry Intersection(OSGeo.MapGuide.MgGeometry)
- [Method] Boolean Intersects(OSGeo.MapGuide.MgGeometry)
- [Method] Boolean Overlaps(OSGeo.MapGuide.MgGeometry)
- [Method] OSGeo.MapGuide.MgPreparedGeometry Prepare()
- [Method] OSGeo.MapGuide.MgGeometry SymetricDifference(OSGeo.MapGuide.MgGeometry)
- [Method] OSGeo.MapGuide.MgGeometry Tessellate()
- [Method] Boolean Touches(OSGeo.MapGuide.MgGeometry)
- [Method] OSGeo.MapGuide.MgGeometry Union(OSGeo.MapGuide.MgGeometry)
- [Method] Boolean Within(OSGeo.MapGuide.MgGeometry)
-type OSGeo.MapGuide.MgGeometryCollection : OSGeo.MapGuide.MgGuardDisposable
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgGeometry, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgGeometry, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgGeometry, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgGeometry)
- [Method] Void CopyTo(OSGeo.MapGuide.MgGeometry[], Int32)
- [Method] OSGeo.MapGuide.MgGeometry get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgGeometry] GetEnumerator()
- [Method] OSGeo.MapGuide.MgGeometry GetItem(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgGeometry)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgGeometry)
- [Method] Boolean Remove(OSGeo.MapGuide.MgGeometry)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgGeometry)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgGeometry)
-type OSGeo.MapGuide.MgGeometryComponent : OSGeo.MapGuide.MgGeometricEntity
-type OSGeo.MapGuide.MgGeometryFactory : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgArcSegment CreateArcSegment(OSGeo.MapGuide.MgCoordinate, OSGeo.MapGuide.MgCoordinate, OSGeo.MapGuide.MgCoordinate)
- [Method] OSGeo.MapGuide.MgCoordinate CreateCoordinateXY(Double, Double)
- [Method] OSGeo.MapGuide.MgCoordinate CreateCoordinateXYM(Double, Double, Double)
- [Method] OSGeo.MapGuide.MgCoordinate CreateCoordinateXYZ(Double, Double, Double)
- [Method] OSGeo.MapGuide.MgCoordinate CreateCoordinateXYZM(Double, Double, Double, Double)
- [Method] OSGeo.MapGuide.MgCurvePolygon CreateCurvePolygon(OSGeo.MapGuide.MgCurveRing, OSGeo.MapGuide.MgCurveRingCollection)
- [Method] OSGeo.MapGuide.MgCurveRing CreateCurveRing(OSGeo.MapGuide.MgCurveSegmentCollection)
- [Method] OSGeo.MapGuide.MgCurveString CreateCurveString(OSGeo.MapGuide.MgCurveSegmentCollection)
- [Method] OSGeo.MapGuide.MgLinearRing CreateLinearRing(OSGeo.MapGuide.MgCoordinateCollection)
- [Method] OSGeo.MapGuide.MgLinearSegment CreateLinearSegment(OSGeo.MapGuide.MgCoordinateCollection)
- [Method] OSGeo.MapGuide.MgLineString CreateLineString(OSGeo.MapGuide.MgCoordinateCollection)
- [Method] OSGeo.MapGuide.MgMultiCurvePolygon CreateMultiCurvePolygon(OSGeo.MapGuide.MgCurvePolygonCollection)
- [Method] OSGeo.MapGuide.MgMultiCurveString CreateMultiCurveString(OSGeo.MapGuide.MgCurveStringCollection)
- [Method] OSGeo.MapGuide.MgMultiGeometry CreateMultiGeometry(OSGeo.MapGuide.MgGeometryCollection)
- [Method] OSGeo.MapGuide.MgMultiLineString CreateMultiLineString(OSGeo.MapGuide.MgLineStringCollection)
- [Method] OSGeo.MapGuide.MgMultiPoint CreateMultiPoint(OSGeo.MapGuide.MgPointCollection)
- [Method] OSGeo.MapGuide.MgMultiPolygon CreateMultiPolygon(OSGeo.MapGuide.MgPolygonCollection)
- [Method] OSGeo.MapGuide.MgPoint CreatePoint(OSGeo.MapGuide.MgCoordinate)
- [Method] OSGeo.MapGuide.MgPolygon CreatePolygon(OSGeo.MapGuide.MgLinearRing, OSGeo.MapGuide.MgLinearRingCollection)
-type OSGeo.MapGuide.MgGeometrySimplifier : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgGeometry Simplify(OSGeo.MapGuide.MgGeometry, Double, Int32)
-type OSGeo.MapGuide.MgLinearRing : OSGeo.MapGuide.MgRing
- [Method] OSGeo.MapGuide.MgCoordinateIterator GetCoordinates()
-type OSGeo.MapGuide.MgLinearRingCollection : OSGeo.MapGuide.MgGuardDisposable
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgLinearRing, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgLinearRing, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgLinearRing, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgLinearRing)
- [Method] Boolean Contains(OSGeo.MapGuide.MgLinearRing)
- [Method] Void CopyTo(OSGeo.MapGuide.MgLinearRing[], Int32)
- [Method] OSGeo.MapGuide.MgLinearRing get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgLinearRing] GetEnumerator()
- [Method] OSGeo.MapGuide.MgLinearRing GetItem(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgLinearRing)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgLinearRing)
- [Method] Boolean Remove(OSGeo.MapGuide.MgLinearRing)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgLinearRing)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgLinearRing)
-type OSGeo.MapGuide.MgLinearSegment : OSGeo.MapGuide.MgCurveSegment
-type OSGeo.MapGuide.MgLineString : OSGeo.MapGuide.MgCurve
-type OSGeo.MapGuide.MgLineStringCollection : OSGeo.MapGuide.MgGuardDisposable
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgLineString, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgLineString, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgLineString, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgLineString)
- [Method] Boolean Contains(OSGeo.MapGuide.MgLineString)
- [Method] Void CopyTo(OSGeo.MapGuide.MgLineString[], Int32)
- [Method] OSGeo.MapGuide.MgLineString get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgLineString] GetEnumerator()
- [Method] OSGeo.MapGuide.MgLineString GetItem(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgLineString)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgLineString)
- [Method] Boolean Remove(OSGeo.MapGuide.MgLineString)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgLineString)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgLineString)
-type OSGeo.MapGuide.MgMeasure : OSGeo.MapGuide.MgGuardDisposable
-type OSGeo.MapGuide.MgMultiCurvePolygon : OSGeo.MapGuide.MgAggregateGeometry
- [Method] OSGeo.MapGuide.MgCurvePolygon GetCurvePolygon(Int32)
-type OSGeo.MapGuide.MgMultiCurveString : OSGeo.MapGuide.MgAggregateGeometry
- [Method] OSGeo.MapGuide.MgCurveString GetCurveString(Int32)
-type OSGeo.MapGuide.MgMultiGeometry : OSGeo.MapGuide.MgAggregateGeometry
- [Method] OSGeo.MapGuide.MgGeometry GetGeometry(Int32)
-type OSGeo.MapGuide.MgMultiLineString : OSGeo.MapGuide.MgAggregateGeometry
- [Method] OSGeo.MapGuide.MgLineString GetLineString(Int32)
-type OSGeo.MapGuide.MgMultiPoint : OSGeo.MapGuide.MgAggregateGeometry
- [Method] OSGeo.MapGuide.MgPoint GetPoint(Int32)
-type OSGeo.MapGuide.MgMultiPolygon : OSGeo.MapGuide.MgAggregateGeometry
- [Method] OSGeo.MapGuide.MgCoordinateIterator get_Coordinates()
- [Method] OSGeo.MapGuide.MgPolygon GetPolygon(Int32)
-type OSGeo.MapGuide.MgPoint : OSGeo.MapGuide.MgGeometry
- [Method] OSGeo.MapGuide.MgCoordinate get_Coordinate()
- [Method] OSGeo.MapGuide.MgCoordinate GetCoordinate()
-type OSGeo.MapGuide.MgPointCollection : OSGeo.MapGuide.MgGuardDisposable
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgPoint, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgPoint, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgPoint, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgPoint)
- [Method] Boolean Contains(OSGeo.MapGuide.MgPoint)
- [Method] Void CopyTo(OSGeo.MapGuide.MgPoint[], Int32)
- [Method] OSGeo.MapGuide.MgPoint get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgPoint] GetEnumerator()
- [Method] OSGeo.MapGuide.MgPoint GetItem(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgPoint)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgPoint)
- [Method] Boolean Remove(OSGeo.MapGuide.MgPoint)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgPoint)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgPoint)
-type OSGeo.MapGuide.MgPolygon : OSGeo.MapGuide.MgRegion
- [Method] OSGeo.MapGuide.MgLinearRing get_ExteriorRing()
- [Method] OSGeo.MapGuide.MgLinearRing GetExteriorRing()
- [Method] OSGeo.MapGuide.MgLinearRing GetInteriorRing(Int32)
-type OSGeo.MapGuide.MgPolygonCollection : OSGeo.MapGuide.MgGuardDisposable
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgPolygon, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgPolygon, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgPolygon, OSGeo.MapGuide.Geometry, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgPolygon)
- [Method] Boolean Contains(OSGeo.MapGuide.MgPolygon)
- [Method] Void CopyTo(OSGeo.MapGuide.MgPolygon[], Int32)
- [Method] OSGeo.MapGuide.MgPolygon get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgPolygon] GetEnumerator()
- [Method] OSGeo.MapGuide.MgPolygon GetItem(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgPolygon)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgPolygon)
- [Method] Boolean Remove(OSGeo.MapGuide.MgPolygon)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgPolygon)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgPolygon)
-type OSGeo.MapGuide.MgPreparedGeometry : OSGeo.MapGuide.MgGuardDisposable
-type OSGeo.MapGuide.MgRegion : OSGeo.MapGuide.MgGeometry
- [Method] OSGeo.MapGuide.MgPoint get_PointInRegion()
- [Method] OSGeo.MapGuide.MgPoint GetPointInRegion()
-type OSGeo.MapGuide.MgRing : OSGeo.MapGuide.MgGeometryComponent
- [Method] OSGeo.MapGuide.MgPoint get_PointInRing()
- [Method] OSGeo.MapGuide.MgPoint GetPointInRing()
-type OSGeo.MapGuide.MgTransform : OSGeo.MapGuide.MgGuardDisposable
-type OSGeo.MapGuide.MgWktReaderWriter : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgGeometry Read(System.String)
- [Method] OSGeo.MapGuide.MgGeometry Read(System.String, OSGeo.MapGuide.MgTransform)
- [Method] System.String Write(OSGeo.MapGuide.MgGeometry)
- [Method] System.String Write(OSGeo.MapGuide.MgGeometry, OSGeo.MapGuide.MgTransform)
-Assembly: OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null
-type OSGeo.MapGuide.MgLayerGroupType : System.Object
- [Field] Int32 BaseMap
- [Field] Int32 BaseMapFromTileSet
- [Field] Int32 Normal
-type OSGeo.MapGuide.MgLayerType : System.Object
- [Field] Int32 Dynamic
-type OSGeo.MapGuide.MgServiceType : System.Object
- [Field] Int16 DrawingService
- [Field] Int16 FeatureService
- [Field] Int16 KmlService
- [Field] Int16 MappingService
- [Field] Int16 ProfilingService
- [Field] Int16 RenderingService
- [Field] Int16 ResourceService
- [Field] Int16 TileService
-type OSGeo.MapGuide.MgUser : System.Object
- [Field] System.String Administrator
- [Field] System.String Anonymous
- [Field] System.String Author
- [Field] System.String WfsUser
- [Field] System.String WmsUser
-type OSGeo.MapGuide.MgGroup : System.Object
- [Field] System.String Everyone
-type OSGeo.MapGuide.MgRole : System.Object
- [Field] System.String Viewer
-type OSGeo.MapGuide.MgFeatureCommandType : System.Object
- [Field] Int32 DeleteFeatures
- [Field] Int32 InsertFeatures
- [Field] Int32 LockFeatures
- [Field] Int32 UnlockFeatures
- [Field] Int32 UpdateFeatures
-type OSGeo.MapGuide.MgFeatureGeometricType : System.Object
- [Field] Int32 Curve
- [Field] Int32 Point
- [Field] Int32 Solid
- [Field] Int32 Surface
-type OSGeo.MapGuide.MgFeatureSpatialOperations : System.Object
- [Field] Int32 Contains
- [Field] Int32 CoveredBy
- [Field] Int32 Crosses
- [Field] Int32 Disjoint
- [Field] Int32 EnvelopeIntersects
- [Field] Int32 Equals
- [Field] Int32 Inside
- [Field] Int32 Intersects
- [Field] Int32 Overlaps
- [Field] Int32 Touches
- [Field] Int32 Within
-type OSGeo.MapGuide.MgObjectPropertyType : System.Object
- [Field] Int32 Collection
- [Field] Int32 OrderedCollection
- [Field] Int32 Value
-type OSGeo.MapGuide.MgOrderingOption : System.Object
- [Field] Int32 Ascending
- [Field] Int32 Descending
-type OSGeo.MapGuide.MgParameterDirection : System.Object
- [Field] Int32 Input
- [Field] Int32 InputOutput
- [Field] Int32 Output
- [Field] Int32 Ret
-type OSGeo.MapGuide.MgRasterDataModelType : System.Object
- [Field] Int32 Bitonal
- [Field] Int32 Data
- [Field] Int32 Gray
- [Field] Int32 Palette
- [Field] Int32 RGB
- [Field] Int32 RGBA
- [Field] Int32 Unknown
-type OSGeo.MapGuide.MgReaderType : System.Object
- [Field] Int32 DataReader
- [Field] Int32 FeatureReader
- [Field] Int32 SqlDataReader
-type OSGeo.MapGuide.MgRepositoryType : System.Object
- [Field] System.String Library
- [Field] System.String Session
-type OSGeo.MapGuide.MgResourceType : System.Object
- [Field] System.String ApplicationDefinition
- [Field] System.String DrawingSource
- [Field] System.String FeatureSource
- [Field] System.String Folder
- [Field] System.String LayerDefinition
- [Field] System.String LoadProcedure
- [Field] System.String Map
- [Field] System.String MapDefinition
- [Field] System.String PrintLayout
- [Field] System.String Selection
- [Field] System.String SymbolDefinition
- [Field] System.String SymbolLibrary
- [Field] System.String TileSetDefinition
- [Field] System.String WatermarkDefinition
- [Field] System.String WebLayout
-type OSGeo.MapGuide.MgResourceTag : System.Object
- [Field] System.String DataFilePath
- [Field] System.String DataPathAliasBegin
- [Field] System.String DataPathAliasEnd
- [Field] System.String LoginPassword
- [Field] System.String LoginUsername
- [Field] System.String Password
- [Field] System.String ProxyPassword
- [Field] System.String ProxyPort
- [Field] System.String ProxyServer
- [Field] System.String ProxyUsername
- [Field] System.String TileCachePath
- [Field] System.String Username
-type OSGeo.MapGuide.MgResourceDataName : System.Object
- [Field] System.String ProxyCredentials
- [Field] System.String ProxyServerName
- [Field] System.String ProxyServerPort
- [Field] System.String UserCredentials
-type OSGeo.MapGuide.MgResourceDataType : System.Object
- [Field] System.String File
- [Field] System.String Stream
- [Field] System.String String
-type OSGeo.MapGuide.MgResourcePermission : System.Object
- [Field] System.String PermissionNoAccess
- [Field] System.String PermissionReadOnly
- [Field] System.String PermissionReadWrite
-type OSGeo.MapGuide.MgResourceHeaderProperties : System.Object
- [Field] Int32 Metadata
- [Field] Int32 Security
-type OSGeo.MapGuide.MgSpatialContextExtentType : System.Object
- [Field] Int32 scDynamic
- [Field] Int32 scStatic
-type OSGeo.MapGuide.MgColor : OSGeo.MapGuide.MgSerializable
- [Constructor] Void .ctor(Int16, Int16, Int16, Int16)
- [Constructor] Void .ctor(Int16, Int16, Int16)
- [Constructor] Void .ctor(System.Drawing.Color)
- [Constructor] Void .ctor(System.String)
- [Method] Int16 get_Alpha()
- [Method] Int16 get_Blue()
- [Method] System.String get_Color()
- [Method] Int16 get_Green()
- [Method] Int16 get_Red()
- [Method] Int16 GetAlpha()
- [Method] Int16 GetBlue()
- [Method] System.String GetColor()
- [Method] Int16 GetGreen()
- [Method] Int16 GetRed()
-type OSGeo.MapGuide.MgBlobProperty : OSGeo.MapGuide.MgNullableProperty
- [Constructor] Void .ctor(System.String, OSGeo.MapGuide.MgByteReader)
- [Method] Int16 get_PropertyType()
- [Method] OSGeo.MapGuide.MgByteReader get_Value()
- [Method] Int16 GetPropertyType()
- [Method] OSGeo.MapGuide.MgByteReader GetValue()
- [Method] Void set_Value(OSGeo.MapGuide.MgByteReader)
- [Method] Void SetValue(OSGeo.MapGuide.MgByteReader)
-type OSGeo.MapGuide.MgBooleanProperty : OSGeo.MapGuide.MgNullableProperty
- [Constructor] Void .ctor(System.String, Boolean)
- [Method] Boolean get_Value()
- [Method] Boolean GetValue()
- [Method] Void set_Value(Boolean)
- [Method] Void SetValue(Boolean)
-type OSGeo.MapGuide.MgByteProperty : OSGeo.MapGuide.MgNullableProperty
- [Constructor] Void .ctor(System.String, Byte)
- [Method] Byte get_Value()
- [Method] Byte GetValue()
- [Method] Void set_Value(Byte)
- [Method] Void SetValue(Byte)
-type OSGeo.MapGuide.MgClassDefinition : OSGeo.MapGuide.MgNamedSerializable
- [Method] Void Delete()
- [Method] OSGeo.MapGuide.MgClassDefinition get_BaseClassDefinition()
- [Method] System.String get_DefaultGeometryPropertyName()
- [Method] System.String get_Description()
- [Method] System.String get_Name()
- [Method] OSGeo.MapGuide.MgClassDefinition GetBaseClassDefinition()
- [Method] System.String GetDefaultGeometryPropertyName()
- [Method] System.String GetDescription()
- [Method] OSGeo.MapGuide.MgPropertyDefinitionCollection GetIdentityProperties()
- [Method] System.String GetName()
- [Method] OSGeo.MapGuide.MgPropertyDefinitionCollection GetProperties()
- [Method] Boolean IsAbstract()
- [Method] Boolean IsComputed()
- [Method] Void set_DefaultGeometryPropertyName(System.String)
- [Method] Void set_Description(System.String)
- [Method] Void set_Name(System.String)
- [Method] Void SetDefaultGeometryPropertyName(System.String)
- [Method] Void SetDescription(System.String)
- [Method] Void SetName(System.String)
-type OSGeo.MapGuide.MgClassDefinitionCollection : OSGeo.MapGuide.MgCollection
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgClassDefinition, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgClassDefinition, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgClassDefinition, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgClassDefinition)
- [Method] Boolean Contains(OSGeo.MapGuide.MgClassDefinition)
- [Method] Void CopyTo(OSGeo.MapGuide.MgClassDefinition[], Int32)
- [Method] OSGeo.MapGuide.MgClassDefinition get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgClassDefinition] GetEnumerator()
- [Method] OSGeo.MapGuide.MgClassDefinition GetItem(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgClassDefinition)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgClassDefinition)
- [Method] Boolean Remove(OSGeo.MapGuide.MgClassDefinition)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgClassDefinition)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgClassDefinition)
- [Method] OSGeo.MapGuide.MgByteReader ToXml()
-type OSGeo.MapGuide.MgClobProperty : OSGeo.MapGuide.MgNullableProperty
-type OSGeo.MapGuide.MgDataPropertyDefinition : OSGeo.MapGuide.MgPropertyDefinition
- [Method] Int32 get_DataType()
- [Method] System.String get_DefaultValue()
- [Method] Int32 get_Length()
- [Method] Boolean get_Nullable()
- [Method] Int32 get_Precision()
- [Method] Boolean get_ReadOnly()
- [Method] Int32 get_Scale()
- [Method] Int32 GetDataType()
- [Method] System.String GetDefaultValue()
- [Method] Int32 GetLength()
- [Method] Boolean GetNullable()
- [Method] Int32 GetPrecision()
- [Method] Boolean GetReadOnly()
- [Method] Int32 GetScale()
- [Method] Boolean IsAutoGenerated()
- [Method] Void set_DataType(Int32)
- [Method] Void set_DefaultValue(System.String)
- [Method] Void set_Length(Int32)
- [Method] Void set_Nullable(Boolean)
- [Method] Void set_Precision(Int32)
- [Method] Void set_ReadOnly(Boolean)
- [Method] Void set_Scale(Int32)
- [Method] Void SetAutoGeneration(Boolean)
- [Method] Void SetDataType(Int32)
- [Method] Void SetDefaultValue(System.String)
- [Method] Void SetLength(Int32)
- [Method] Void SetNullable(Boolean)
- [Method] Void SetPrecision(Int32)
- [Method] Void SetReadOnly(Boolean)
- [Method] Void SetScale(Int32)
-type OSGeo.MapGuide.MgDataReader : OSGeo.MapGuide.MgReader
-type OSGeo.MapGuide.MgDateTimeProperty : OSGeo.MapGuide.MgNullableProperty
- [Constructor] Void .ctor(System.String, OSGeo.MapGuide.MgDateTime)
- [Method] OSGeo.MapGuide.MgDateTime get_Value()
- [Method] OSGeo.MapGuide.MgDateTime GetValue()
- [Method] Void set_Value(OSGeo.MapGuide.MgDateTime)
- [Method] Void SetValue(OSGeo.MapGuide.MgDateTime)
-type OSGeo.MapGuide.MgDeleteFeatures : OSGeo.MapGuide.MgFeatureCommand
- [Constructor] Void .ctor(System.String, System.String)
- [Method] Int32 get_CommandType()
- [Method] System.String get_FeatureClassName()
- [Method] System.String get_FilterText()
- [Method] Int32 GetCommandType()
- [Method] System.String GetFeatureClassName()
- [Method] System.String GetFilterText()
-type OSGeo.MapGuide.MgDoubleProperty : OSGeo.MapGuide.MgNullableProperty
- [Constructor] Void .ctor(System.String, Double)
- [Method] Double get_Value()
- [Method] Void set_Value(Double)
- [Method] Void SetValue(Double)
-type OSGeo.MapGuide.MgFeatureAggregateOptions : OSGeo.MapGuide.MgFeatureQueryOptions
- [Method] Void SelectDistinct(Boolean)
- [Method] Void SetGroupingFilter(OSGeo.MapGuide.MgStringCollection, System.String)
-type OSGeo.MapGuide.MgFeatureCommand : OSGeo.MapGuide.MgSerializable
-type OSGeo.MapGuide.MgFeatureCommandCollection : OSGeo.MapGuide.MgSerializable
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgFeatureCommand, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgFeatureCommand, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgFeatureCommand, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgFeatureCommand)
- [Method] Boolean Contains(OSGeo.MapGuide.MgFeatureCommand)
- [Method] Void CopyTo(OSGeo.MapGuide.MgFeatureCommand[], Int32)
- [Method] OSGeo.MapGuide.MgFeatureCommand get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgFeatureCommand] GetEnumerator()
- [Method] OSGeo.MapGuide.MgFeatureCommand GetItem(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgFeatureCommand)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgFeatureCommand)
- [Method] Boolean Remove(OSGeo.MapGuide.MgFeatureCommand)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgFeatureCommand)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgFeatureCommand)
-type OSGeo.MapGuide.MgFeatureProperty : OSGeo.MapGuide.MgNullableProperty
- [Constructor] Void .ctor(System.String, OSGeo.MapGuide.MgFeatureReader)
- [Method] OSGeo.MapGuide.MgFeatureReader get_Value()
- [Method] OSGeo.MapGuide.MgFeatureReader GetValue()
- [Method] Void set_Value(OSGeo.MapGuide.MgFeatureReader)
- [Method] Void SetValue(OSGeo.MapGuide.MgFeatureReader)
-type OSGeo.MapGuide.MgFeatureQueryOptions : OSGeo.MapGuide.MgSerializable
- [Method] Int32 AddComputedProperty(System.String, System.String)
- [Method] Int32 AddFeatureProperty(System.String)
- [Method] Void RemoveComputedProperty(System.String)
- [Method] Void RemoveFeatureProperty(System.String)
- [Method] Void SetBinaryOperator(Boolean)
- [Method] Void SetFetchSize(Int32)
- [Method] Void SetFilter(System.String)
- [Method] Void SetOrderingFilter(OSGeo.MapGuide.MgStringCollection, Int32)
- [Method] Void SetSpatialFilter(System.String, OSGeo.MapGuide.MgGeometry, Int32)
-type OSGeo.MapGuide.MgFeatureReader : OSGeo.MapGuide.MgReader
- [Method] OSGeo.MapGuide.MgClassDefinition GetClassDefinition()
- [Method] OSGeo.MapGuide.MgFeatureReader GetFeatureObject(System.String)
- [Method] OSGeo.MapGuide.MgFeatureReader GetFeatureObject(Int32)
-type OSGeo.MapGuide.MgFeatureSchema : OSGeo.MapGuide.MgNamedSerializable
- [Method] OSGeo.MapGuide.MgClassDefinitionCollection GetClasses()
-type OSGeo.MapGuide.MgFeatureSchemaCollection : OSGeo.MapGuide.MgCollection
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgFeatureSchema, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgFeatureSchema, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgFeatureSchema, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgFeatureSchema)
- [Method] Boolean Contains(OSGeo.MapGuide.MgFeatureSchema)
- [Method] Void CopyTo(OSGeo.MapGuide.MgFeatureSchema[], Int32)
- [Method] OSGeo.MapGuide.MgFeatureSchema get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgFeatureSchema] GetEnumerator()
- [Method] OSGeo.MapGuide.MgFeatureSchema GetItem(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgFeatureSchema)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgFeatureSchema)
- [Method] Boolean Remove(OSGeo.MapGuide.MgFeatureSchema)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgFeatureSchema)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgFeatureSchema)
-type OSGeo.MapGuide.MgFeatureService : OSGeo.MapGuide.MgService
- [Method] Void ApplySchema(OSGeo.MapGuide.MgResourceIdentifier, OSGeo.MapGuide.MgFeatureSchema)
- [Method] OSGeo.MapGuide.MgTransaction BeginTransaction(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] Void CreateFeatureSource(OSGeo.MapGuide.MgResourceIdentifier, OSGeo.MapGuide.MgFeatureSourceParams)
- [Method] Int32 DeleteFeatures(OSGeo.MapGuide.MgResourceIdentifier, System.String, System.String, OSGeo.MapGuide.MgTransaction)
- [Method] Int32 DeleteFeatures(OSGeo.MapGuide.MgResourceIdentifier, System.String, System.String)
- [System.ObsoleteAttribute]
- [Method] OSGeo.MapGuide.MgFeatureSchemaCollection DescribeSchema(OSGeo.MapGuide.MgResourceIdentifier, System.String)
- [Method] OSGeo.MapGuide.MgFeatureSchemaCollection DescribeSchema(OSGeo.MapGuide.MgResourceIdentifier, System.String, OSGeo.MapGuide.MgStringCollection)
- [Method] System.String DescribeSchemaAsXml(OSGeo.MapGuide.MgResourceIdentifier, System.String)
- [Method] System.String DescribeSchemaAsXml(OSGeo.MapGuide.MgResourceIdentifier, System.String, OSGeo.MapGuide.MgStringCollection)
- [Method] OSGeo.MapGuide.MgByteReader DescribeWfsFeatureType(OSGeo.MapGuide.MgResourceIdentifier, OSGeo.MapGuide.MgStringCollection)
- [Method] OSGeo.MapGuide.MgByteReader DescribeWfsFeatureType(OSGeo.MapGuide.MgResourceIdentifier, OSGeo.MapGuide.MgStringCollection, System.String, System.String)
- [Method] OSGeo.MapGuide.MgByteReader EnumerateDataStores(System.String, System.String)
- [Method] Int32 ExecuteSqlNonQuery(OSGeo.MapGuide.MgResourceIdentifier, System.String, OSGeo.MapGuide.MgParameterCollection, OSGeo.MapGuide.MgTransaction)
- [Method] Int32 ExecuteSqlNonQuery(OSGeo.MapGuide.MgResourceIdentifier, System.String)
- [Method] OSGeo.MapGuide.MgSqlDataReader ExecuteSqlQuery(OSGeo.MapGuide.MgResourceIdentifier, System.String, OSGeo.MapGuide.MgParameterCollection, OSGeo.MapGuide.MgTransaction)
- [Method] OSGeo.MapGuide.MgSqlDataReader ExecuteSqlQuery(OSGeo.MapGuide.MgResourceIdentifier, System.String)
- [Method] OSGeo.MapGuide.MgByteReader GetCapabilities(System.String)
- [Method] OSGeo.MapGuide.MgByteReader GetCapabilities(System.String, System.String)
- [Method] OSGeo.MapGuide.MgClassDefinition GetClassDefinition(OSGeo.MapGuide.MgResourceIdentifier, System.String, System.String)
- [Method] OSGeo.MapGuide.MgStringCollection GetClasses(OSGeo.MapGuide.MgResourceIdentifier, System.String)
- [Method] OSGeo.MapGuide.MgStringCollection GetConnectionPropertyValues(System.String, System.String, System.String)
- [Method] OSGeo.MapGuide.MgByteReader GetFeatureProviders()
- [Method] OSGeo.MapGuide.MgFeatureReader GetLockedFeatures(OSGeo.MapGuide.MgResourceIdentifier, System.String, OSGeo.MapGuide.MgFeatureQueryOptions)
- [Method] OSGeo.MapGuide.MgLongTransactionReader GetLongTransactions(OSGeo.MapGuide.MgResourceIdentifier, Boolean)
- [Method] OSGeo.MapGuide.MgByteReader GetSchemaMapping(System.String, System.String)
- [Method] OSGeo.MapGuide.MgStringCollection GetSchemas(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] OSGeo.MapGuide.MgSpatialContextReader GetSpatialContexts(OSGeo.MapGuide.MgResourceIdentifier, Boolean)
- [Method] OSGeo.MapGuide.MgByteReader GetWfsFeature(OSGeo.MapGuide.MgResourceIdentifier, System.String, OSGeo.MapGuide.MgStringCollection, System.String, System.String, Int32)
- [Method] OSGeo.MapGuide.MgByteReader GetWfsFeature(OSGeo.MapGuide.MgResourceIdentifier, System.String, OSGeo.MapGuide.MgStringCollection, System.String, System.String, Int32, System.String, System.String, System.String, System.String, System.String)
- [Method] OSGeo.MapGuide.MgFeatureReader GetWfsReader(OSGeo.MapGuide.MgResourceIdentifier, System.String, OSGeo.MapGuide.MgStringCollection, System.String, System.String, System.String)
- [Method] OSGeo.MapGuide.MgFeatureReader InsertFeatures(OSGeo.MapGuide.MgResourceIdentifier, System.String, OSGeo.MapGuide.MgBatchPropertyCollection)
- [Method] OSGeo.MapGuide.MgFeatureReader InsertFeatures(OSGeo.MapGuide.MgResourceIdentifier, System.String, OSGeo.MapGuide.MgPropertyCollection)
- [Method] OSGeo.MapGuide.MgFeatureReader InsertFeatures(OSGeo.MapGuide.MgResourceIdentifier, System.String, OSGeo.MapGuide.MgBatchPropertyCollection, OSGeo.MapGuide.MgTransaction)
- [Method] OSGeo.MapGuide.MgFeatureReader InsertFeatures(OSGeo.MapGuide.MgResourceIdentifier, System.String, OSGeo.MapGuide.MgPropertyCollection, OSGeo.MapGuide.MgTransaction)
- [Method] System.String SchemaToXml(OSGeo.MapGuide.MgFeatureSchemaCollection)
- [Method] OSGeo.MapGuide.MgDataReader SelectAggregate(OSGeo.MapGuide.MgResourceIdentifier, System.String, OSGeo.MapGuide.MgFeatureAggregateOptions)
- [Method] OSGeo.MapGuide.MgFeatureReader SelectFeatures(OSGeo.MapGuide.MgResourceIdentifier, System.String, OSGeo.MapGuide.MgFeatureQueryOptions, System.String)
- [Method] OSGeo.MapGuide.MgFeatureReader SelectFeatures(OSGeo.MapGuide.MgResourceIdentifier, System.String, OSGeo.MapGuide.MgFeatureQueryOptions)
- [Method] Boolean SetLongTransaction(OSGeo.MapGuide.MgResourceIdentifier, System.String)
- [Method] Boolean TestConnection(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] Boolean TestConnection(System.String, System.String)
- [Method] OSGeo.MapGuide.MgPropertyCollection UpdateFeatures(OSGeo.MapGuide.MgResourceIdentifier, OSGeo.MapGuide.MgFeatureCommandCollection, OSGeo.MapGuide.MgTransaction)
- [Method] OSGeo.MapGuide.MgPropertyCollection UpdateFeatures(OSGeo.MapGuide.MgResourceIdentifier, OSGeo.MapGuide.MgFeatureCommandCollection, Boolean)
- [Method] Int32 UpdateMatchingFeatures(OSGeo.MapGuide.MgResourceIdentifier, System.String, OSGeo.MapGuide.MgPropertyCollection, System.String, OSGeo.MapGuide.MgTransaction)
- [Method] Int32 UpdateMatchingFeatures(OSGeo.MapGuide.MgResourceIdentifier, System.String, OSGeo.MapGuide.MgPropertyCollection, System.String)
- [Method] OSGeo.MapGuide.MgFeatureSchemaCollection XmlToSchema(System.String)
-type OSGeo.MapGuide.MgFeatureSourceParams : OSGeo.MapGuide.MgSerializable
-type OSGeo.MapGuide.MgFileFeatureSourceParams : OSGeo.MapGuide.MgFeatureSourceParams
- [Constructor] Void .ctor(System.String, System.String, System.String, OSGeo.MapGuide.MgFeatureSchema)
- [Method] System.String get_CoordinateSystemWkt()
- [Method] OSGeo.MapGuide.MgFeatureSchema get_FeatureSchema()
- [Method] System.String get_FileName()
- [Method] System.String get_ProviderName()
- [Method] System.String get_SpatialContextDescription()
- [Method] System.String get_SpatialContextName()
- [Method] Double get_XYTolerance()
- [Method] Double get_ZTolerance()
- [Method] System.String GetCoordinateSystemWkt()
- [Method] OSGeo.MapGuide.MgFeatureSchema GetFeatureSchema()
- [Method] System.String GetFileName()
- [Method] System.String GetProviderName()
- [Method] System.String GetSpatialContextDescription()
- [Method] System.String GetSpatialContextName()
- [Method] Double GetXYTolerance()
- [Method] Double GetZTolerance()
- [Method] Void set_CoordinateSystemWkt(System.String)
- [Method] Void set_FeatureSchema(OSGeo.MapGuide.MgFeatureSchema)
- [Method] Void set_FileName(System.String)
- [Method] Void set_ProviderName(System.String)
- [Method] Void set_SpatialContextDescription(System.String)
- [Method] Void set_SpatialContextName(System.String)
- [Method] Void set_XYTolerance(Double)
- [Method] Void set_ZTolerance(Double)
- [Method] Void SetCoordinateSystemWkt(System.String)
- [Method] Void SetFeatureSchema(OSGeo.MapGuide.MgFeatureSchema)
- [Method] Void SetFileName(System.String)
- [Method] Void SetProviderName(System.String)
- [Method] Void SetSpatialContextDescription(System.String)
- [Method] Void SetSpatialContextName(System.String)
- [Method] Void SetXYTolerance(Double)
- [Method] Void SetZTolerance(Double)
-type OSGeo.MapGuide.MgGeoJsonWriter : OSGeo.MapGuide.MgGuardDisposable
- [Method] System.String FeatureToGeoJson(OSGeo.MapGuide.MgFeatureReader, OSGeo.MapGuide.MgTransform)
- [Method] System.String FeatureToGeoJson(OSGeo.MapGuide.MgReader, OSGeo.MapGuide.MgTransform, System.String, System.String)
- [Method] Boolean IsPrecisionEnabled()
- [Method] Void SetPrecisionEnabled(Boolean)
-type OSGeo.MapGuide.MgGeometricPropertyDefinition : OSGeo.MapGuide.MgPropertyDefinition
- [Method] Int32 get_GeometryTypes()
- [Method] Boolean get_HasElevation()
- [Method] Boolean get_HasMeasure()
- [Method] System.String get_SpatialContextAssociation()
- [Method] OSGeo.MapGuide.MgGeometryTypeInfo get_SpecificGeometryTypes()
- [Method] Int32 GetGeometryTypes()
- [Method] Boolean GetHasElevation()
- [Method] Boolean GetHasMeasure()
- [Method] System.String GetSpatialContextAssociation()
- [Method] OSGeo.MapGuide.MgGeometryTypeInfo GetSpecificGeometryTypes()
- [Method] Void set_GeometryTypes(Int32)
- [Method] Void set_HasElevation(Boolean)
- [Method] Void set_HasMeasure(Boolean)
- [Method] Void set_SpatialContextAssociation(System.String)
- [Method] Void set_SpecificGeometryTypes(OSGeo.MapGuide.MgGeometryTypeInfo)
- [Method] Void SetGeometryTypes(Int32)
- [Method] Void SetHasElevation(Boolean)
- [Method] Void SetHasMeasure(Boolean)
- [Method] Void SetSpatialContextAssociation(System.String)
- [Method] Void SetSpecificGeometryTypes(OSGeo.MapGuide.MgGeometryTypeInfo)
-type OSGeo.MapGuide.MgGeometryProperty : OSGeo.MapGuide.MgNullableProperty
-type OSGeo.MapGuide.MgGeometryTypeInfo : OSGeo.MapGuide.MgSerializable
- [Method] Int32 GetType(Int32)
- [Method] Void SetTypes(OSGeo.MapGuide.MgIntCollection)
-type OSGeo.MapGuide.MgGwsFeatureReader : OSGeo.MapGuide.MgFeatureReader
-type OSGeo.MapGuide.MgInsertFeatures : OSGeo.MapGuide.MgFeatureCommand
- [Constructor] Void .ctor(System.String, OSGeo.MapGuide.MgPropertyCollection)
- [Constructor] Void .ctor(System.String, OSGeo.MapGuide.MgBatchPropertyCollection)
- [Method] OSGeo.MapGuide.MgPropertyCollection get_PropertyValues()
- [Method] OSGeo.MapGuide.MgPropertyCollection GetPropertyValues()
-type OSGeo.MapGuide.MgInt16Property : OSGeo.MapGuide.MgNullableProperty
- [Constructor] Void .ctor(System.String, Int16)
- [Method] Int16 get_Value()
- [Method] Int16 GetValue()
- [Method] Void set_Value(Int16)
- [Method] Void SetValue(Int16)
-type OSGeo.MapGuide.MgInt32Property : OSGeo.MapGuide.MgNullableProperty
- [Constructor] Void .ctor(System.String, Int32)
- [Method] Int32 get_Value()
- [Method] Int32 GetValue()
- [Method] Void set_Value(Int32)
- [Method] Void SetValue(Int32)
-type OSGeo.MapGuide.MgInt64Property : OSGeo.MapGuide.MgNullableProperty
- [Constructor] Void .ctor(System.String, Int64)
- [Method] Int64 get_Value()
- [Method] Int64 GetValue()
- [Method] Void set_Value(Int64)
- [Method] Void SetValue(Int64)
-type OSGeo.MapGuide.MgIntCollection : OSGeo.MapGuide.MgCollection
- implements System.Collections.Generic.IList`1[[System.Int32, System.Private.CoreLib, Version=8.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e]]
- implements System.Collections.Generic.ICollection`1[[System.Int32, System.Private.CoreLib, Version=8.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e]]
- implements System.Collections.Generic.IEnumerable`1[[System.Int32, System.Private.CoreLib, Version=8.0.0.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e]]
- [Method] Void Add(Int32)
- [Method] Boolean Contains(Int32)
- [Method] Void CopyTo(Int32[], Int32)
- [Method] Int32 get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[System.Int32] GetEnumerator()
- [Method] Int32 GetItem(Int32)
- [Method] Int32 IndexOf(Int32)
- [Method] Void Insert(Int32, Int32)
- [Method] Boolean Remove(Int32)
- [Method] Void set_Item(Int32, Int32)
- [Method] Void SetItem(Int32, Int32)
-type OSGeo.MapGuide.MgLayerBase : OSGeo.MapGuide.MgNamedSerializable
- [Constructor] Void .ctor(OSGeo.MapGuide.MgResourceIdentifier, OSGeo.MapGuide.MgResourceService)
- [Method] OSGeo.MapGuide.MgTransaction BeginTransaction()
- [Method] Int32 DeleteFeatures(System.String, OSGeo.MapGuide.MgTransaction)
- [Method] Void ForceRefresh()
- [Method] Boolean get_DisplayInLegend()
- [Method] Boolean get_ExpandInLegend()
- [Method] System.String get_FeatureGeometryName()
- [Method] System.String get_FeatureSourceId()
- [Method] System.String get_Filter()
- [Method] OSGeo.MapGuide.MgLayerGroup get_Group()
- [Method] OSGeo.MapGuide.MgResourceIdentifier get_LayerDefinition()
- [Method] Int32 get_LayerType()
- [Method] System.String get_LegendLabel()
- [Method] Boolean get_Selectable()
- [Method] Boolean get_Visible()
- [Method] Boolean GetDisplayInLegend()
- [Method] Boolean GetExpandInLegend()
- [Method] System.String GetFeatureGeometryName()
- [Method] System.String GetFeatureSourceId()
- [Method] System.String GetFilter()
- [Method] OSGeo.MapGuide.MgLayerGroup GetGroup()
- [Method] OSGeo.MapGuide.MgResourceIdentifier GetLayerDefinition()
- [Method] Int32 GetLayerType()
- [Method] System.String GetLegendLabel()
- [Method] System.String GetObjectId()
- [Method] Boolean GetSelectable()
- [Method] OSGeo.MapGuide.MgSpatialContextReader GetSpatialContexts(Boolean)
- [Method] Boolean GetVisible()
- [Method] OSGeo.MapGuide.MgFeatureReader InsertFeatures(OSGeo.MapGuide.MgBatchPropertyCollection, OSGeo.MapGuide.MgTransaction)
- [Method] OSGeo.MapGuide.MgFeatureReader InsertFeatures(OSGeo.MapGuide.MgPropertyCollection, OSGeo.MapGuide.MgTransaction)
- [Method] Boolean IsVisible()
- [Method] Boolean NeedsRefresh()
- [Method] OSGeo.MapGuide.MgDataReader SelectAggregate(OSGeo.MapGuide.MgFeatureAggregateOptions)
- [Method] OSGeo.MapGuide.MgFeatureReader SelectFeatures(OSGeo.MapGuide.MgFeatureQueryOptions)
- [Method] OSGeo.MapGuide.MgFeatureReader SelectFeatures(OSGeo.MapGuide.MgFeatureQueryOptions, System.String)
- [Method] Void set_DisplayInLegend(Boolean)
- [Method] Void set_Group(OSGeo.MapGuide.MgLayerGroup)
- [Method] Void set_LegendLabel(System.String)
- [Method] Void set_Selectable(Boolean)
- [Method] Void set_Visible(Boolean)
- [Method] Void SetDisplayInLegend(Boolean)
- [Method] Void SetGroup(OSGeo.MapGuide.MgLayerGroup)
- [Method] Void SetLayerDefinition(OSGeo.MapGuide.MgResourceIdentifier, OSGeo.MapGuide.MgResourceService)
- [Method] Void SetLegendLabel(System.String)
- [Method] Void SetSelectable(Boolean)
- [Method] Void SetVisible(Boolean)
- [Method] OSGeo.MapGuide.MgPropertyCollection UpdateFeatures(OSGeo.MapGuide.MgFeatureCommandCollection, OSGeo.MapGuide.MgTransaction)
- [Method] OSGeo.MapGuide.MgPropertyCollection UpdateFeatures(OSGeo.MapGuide.MgFeatureCommandCollection)
- [Method] Int32 UpdateMatchingFeatures(OSGeo.MapGuide.MgPropertyCollection, System.String, OSGeo.MapGuide.MgTransaction)
-type OSGeo.MapGuide.MgLayerCollection : OSGeo.MapGuide.MgGuardDisposable
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgLayerBase, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgLayerBase, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgLayerBase, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgLayerBase)
- [Method] Boolean Contains(OSGeo.MapGuide.MgLayerBase)
- [Method] Boolean Contains(System.String)
- [Method] Void CopyTo(OSGeo.MapGuide.MgLayerBase[], Int32)
- [Method] OSGeo.MapGuide.MgLayerBase get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgLayerBase] GetEnumerator()
- [Method] OSGeo.MapGuide.MgLayerBase GetItem(Int32)
- [Method] OSGeo.MapGuide.MgLayerBase GetItem(System.String)
- [Method] Int32 IndexOf(System.String)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgLayerBase)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgLayerBase)
- [Method] Boolean Remove(OSGeo.MapGuide.MgLayerBase)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgLayerBase)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgLayerBase)
-type OSGeo.MapGuide.MgLayerGroup : OSGeo.MapGuide.MgNamedSerializable
- [Method] Int32 get_LayerGroupType()
- [Method] Int32 GetLayerGroupType()
- [Method] Void SetExpandInLegend(Boolean)
-type OSGeo.MapGuide.MgLayerGroupCollection : OSGeo.MapGuide.MgGuardDisposable
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgLayerGroup, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgLayerGroup, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgLayerGroup, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgLayerGroup)
- [Method] Boolean Contains(OSGeo.MapGuide.MgLayerGroup)
- [Method] Void CopyTo(OSGeo.MapGuide.MgLayerGroup[], Int32)
- [Method] OSGeo.MapGuide.MgLayerGroup get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgLayerGroup] GetEnumerator()
- [Method] OSGeo.MapGuide.MgLayerGroup GetItem(Int32)
- [Method] OSGeo.MapGuide.MgLayerGroup GetItem(System.String)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgLayerGroup)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgLayerGroup)
- [Method] Boolean Remove(OSGeo.MapGuide.MgLayerGroup)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgLayerGroup)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgLayerGroup)
-type OSGeo.MapGuide.MgLongTransactionReader : OSGeo.MapGuide.MgSerializable
- [Method] Void Close()
- [Method] OSGeo.MapGuide.MgLongTransactionReader get_Children()
- [Method] OSGeo.MapGuide.MgDateTime get_CreationDate()
- [Method] System.String get_Owner()
- [Method] OSGeo.MapGuide.MgLongTransactionReader get_Parents()
- [Method] OSGeo.MapGuide.MgLongTransactionReader GetChildren()
- [Method] OSGeo.MapGuide.MgDateTime GetCreationDate()
- [Method] System.String GetOwner()
- [Method] OSGeo.MapGuide.MgLongTransactionReader GetParents()
- [Method] Boolean IsActive()
- [Method] Boolean IsFrozen()
- [Method] Boolean ReadNext()
-type OSGeo.MapGuide.MgMapBase : OSGeo.MapGuide.MgResource
- [Method] Void Create(System.String, OSGeo.MapGuide.MgEnvelope, System.String)
- [Method] Void Create(OSGeo.MapGuide.MgResourceService, OSGeo.MapGuide.MgResourceIdentifier, System.String)
- [Method] OSGeo.MapGuide.MgEnvelope get_DataExtent()
- [Method] Int32 get_DisplayDpi()
- [Method] Int32 get_DisplayHeight()
- [Method] Int32 get_DisplayWidth()
- [Method] Int32 get_FiniteDisplayScaleCount()
- [Method] OSGeo.MapGuide.MgResourceIdentifier get_MapDefinition()
- [Method] OSGeo.MapGuide.MgEnvelope get_MapExtent()
- [Method] System.String get_MapSRS()
- [Method] System.String get_SessionId()
- [Method] OSGeo.MapGuide.MgPoint get_ViewCenter()
- [Method] Double get_ViewScale()
- [Method] System.String GetBackgroundColor()
- [Method] OSGeo.MapGuide.MgEnvelope GetDataExtent()
- [Method] Int32 GetDisplayDpi()
- [Method] Int32 GetDisplayHeight()
- [Method] Int32 GetDisplayWidth()
- [Method] Double GetFiniteDisplayScaleAt(Int32)
- [Method] Int32 GetFiniteDisplayScaleCount()
- [Method] OSGeo.MapGuide.MgLayerGroupCollection GetLayerGroups()
- [Method] OSGeo.MapGuide.MgLayerCollection GetLayers()
- [Method] OSGeo.MapGuide.MgResourceIdentifier GetMapDefinition()
- [Method] OSGeo.MapGuide.MgEnvelope GetMapExtent()
- [Method] System.String GetMapSRS()
- [Method] System.String GetSessionId()
- [Method] OSGeo.MapGuide.MgPoint GetViewCenter()
- [Method] Double GetViewScale()
- [Method] Void Open(OSGeo.MapGuide.MgResourceService, System.String)
- [Method] Void set_DisplayDpi(Int32)
- [Method] Void SetDisplayDpi(Int32)
-type OSGeo.MapGuide.MgMapCollection : OSGeo.MapGuide.MgGuardDisposable
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgMapBase, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgMapBase, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgMapBase, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgMapBase)
- [Method] Boolean Contains(OSGeo.MapGuide.MgMapBase)
- [Method] Void CopyTo(OSGeo.MapGuide.MgMapBase[], Int32)
- [Method] OSGeo.MapGuide.MgMapBase get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgMapBase] GetEnumerator()
- [Method] OSGeo.MapGuide.MgMapBase GetItem(Int32)
- [Method] OSGeo.MapGuide.MgMapBase GetItem(System.String)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgMapBase)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgMapBase)
- [Method] Boolean Remove(OSGeo.MapGuide.MgMapBase)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgMapBase)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgMapBase)
-type OSGeo.MapGuide.MgObjectPropertyDefinition : OSGeo.MapGuide.MgPropertyDefinition
- [Method] OSGeo.MapGuide.MgClassDefinition get_ClassDefinition()
- [Method] OSGeo.MapGuide.MgDataPropertyDefinition get_IdentityProperty()
- [Method] Int32 get_ObjectType()
- [Method] Int32 get_OrderType()
- [Method] OSGeo.MapGuide.MgDataPropertyDefinition GetIdentityProperty()
- [Method] Int32 GetObjectType()
- [Method] Int32 GetOrderType()
- [Method] Void set_ClassDefinition(OSGeo.MapGuide.MgClassDefinition)
- [Method] Void set_IdentityProperty(OSGeo.MapGuide.MgDataPropertyDefinition)
- [Method] Void set_ObjectType(Int32)
- [Method] Void set_OrderType(Int32)
- [Method] Void SetClassDefinition(OSGeo.MapGuide.MgClassDefinition)
- [Method] Void SetIdentityProperty(OSGeo.MapGuide.MgDataPropertyDefinition)
- [Method] Void SetObjectType(Int32)
- [Method] Void SetOrderType(Int32)
-type OSGeo.MapGuide.MgParameter : OSGeo.MapGuide.MgNamedSerializable
- [Constructor] Void .ctor(OSGeo.MapGuide.MgNullableProperty)
- [Constructor] Void .ctor(OSGeo.MapGuide.MgNullableProperty, Int32)
- [Method] Int32 GetDirection()
- [Method] OSGeo.MapGuide.MgNullableProperty GetProperty()
- [Method] Void SetDirection(Int32)
- [Method] Void SetProperty(OSGeo.MapGuide.MgNullableProperty)
-type OSGeo.MapGuide.MgParameterCollection : OSGeo.MapGuide.MgCollection
- [Method] Void Add(OSGeo.MapGuide.MgParameter)
- [Method] Boolean Contains(OSGeo.MapGuide.MgParameter)
- [Method] OSGeo.MapGuide.MgParameter GetItem(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgParameter)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgParameter)
- [Method] Boolean Remove(OSGeo.MapGuide.MgParameter)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgParameter)
-type OSGeo.MapGuide.MgPropertyDefinitionCollection : OSGeo.MapGuide.MgCollection
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgPropertyDefinition, OSGeo.MapGuide.Foundation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgPropertyDefinition, OSGeo.MapGuide.Foundation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgPropertyDefinition, OSGeo.MapGuide.Foundation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgPropertyDefinition)
- [Method] Boolean Contains(OSGeo.MapGuide.MgPropertyDefinition)
- [Method] Void CopyTo(OSGeo.MapGuide.MgPropertyDefinition[], Int32)
- [Method] OSGeo.MapGuide.MgPropertyDefinition get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgPropertyDefinition] GetEnumerator()
- [Method] OSGeo.MapGuide.MgPropertyDefinition GetItem(Int32)
- [Method] OSGeo.MapGuide.MgPropertyDefinition GetItem(System.String)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgPropertyDefinition)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgPropertyDefinition)
- [Method] Boolean Remove(OSGeo.MapGuide.MgPropertyDefinition)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgPropertyDefinition)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgPropertyDefinition)
-type OSGeo.MapGuide.MgRaster : OSGeo.MapGuide.MgSerializable
- [Method] Int32 get_BitsPerPixel()
- [Method] OSGeo.MapGuide.MgEnvelope get_Bounds()
- [Method] Int32 get_DataModelType()
- [Method] Int32 get_ImageXSize()
- [Method] Int32 get_ImageYSize()
- [Method] Int32 GetBitsPerPixel()
- [Method] OSGeo.MapGuide.MgEnvelope GetBounds()
- [Method] Int32 GetCurrentBand()
- [Method] Int32 GetDataModelType()
- [Method] Int16 GetDataType()
- [Method] Int32 GetImageXSize()
- [Method] Int32 GetImageYSize()
- [Method] Int64 GetNullValue()
- [Method] Int32 GetNullValueType()
- [Method] Int32 GetNumberOfBands()
- [Method] OSGeo.MapGuide.MgByteReader GetStream()
- [Method] System.String GetVerticalUnits()
- [Method] Boolean IsNull()
- [Method] Void set_ImageXSize(Int32)
- [Method] Void set_ImageYSize(Int32)
- [Method] Void SetImageXSize(Int32)
- [Method] Void SetImageYSize(Int32)
- [Method] Void SetNull()
-type OSGeo.MapGuide.MgRasterProperty : OSGeo.MapGuide.MgNullableProperty
- [Constructor] Void .ctor(System.String, OSGeo.MapGuide.MgRaster)
- [Method] OSGeo.MapGuide.MgRaster get_Value()
- [Method] OSGeo.MapGuide.MgRaster GetValue()
- [Method] Void set_Value(OSGeo.MapGuide.MgRaster)
- [Method] Void SetValue(OSGeo.MapGuide.MgRaster)
-type OSGeo.MapGuide.MgRasterPropertyDefinition : OSGeo.MapGuide.MgPropertyDefinition
- [Method] Int32 get_DefaultImageXSize()
- [Method] Int32 get_DefaultImageYSize()
- [Method] Int32 GetDefaultImageXSize()
- [Method] Int32 GetDefaultImageYSize()
- [Method] Void set_DefaultImageXSize(Int32)
- [Method] Void set_DefaultImageYSize(Int32)
- [Method] Void SetDefaultImageXSize(Int32)
- [Method] Void SetDefaultImageYSize(Int32)
-type OSGeo.MapGuide.MgReader : OSGeo.MapGuide.MgSerializable
- [Method] OSGeo.MapGuide.MgByteReader GetBLOB(System.String)
- [Method] OSGeo.MapGuide.MgByteReader GetBLOB(Int32)
- [Method] Boolean GetBoolean(Int32)
- [Method] Boolean GetBoolean(System.String)
- [Method] Byte GetByte(System.String)
- [Method] Byte GetByte(Int32)
- [Method] OSGeo.MapGuide.MgByteReader GetCLOB(Int32)
- [Method] OSGeo.MapGuide.MgByteReader GetCLOB(System.String)
- [Method] OSGeo.MapGuide.MgDateTime GetDateTime(Int32)
- [Method] OSGeo.MapGuide.MgDateTime GetDateTime(System.String)
- [Method] Double GetDouble(Int32)
- [Method] Double GetDouble(System.String)
- [Method] OSGeo.MapGuide.MgByteReader GetGeometry(Int32)
- [Method] OSGeo.MapGuide.MgByteReader GetGeometry(System.String)
- [Method] Int16 GetInt16(Int32)
- [Method] Int16 GetInt16(System.String)
- [Method] Int32 GetInt32(System.String)
- [Method] Int32 GetInt32(Int32)
- [Method] Int64 GetInt64(Int32)
- [Method] Int64 GetInt64(System.String)
- [Method] Int32 GetPropertyCount()
- [Method] Int32 GetPropertyIndex(System.String)
- [Method] System.String GetPropertyName(Int32)
- [Method] Int32 GetPropertyType(Int32)
- [Method] Int32 GetPropertyType(System.String)
- [Method] OSGeo.MapGuide.MgRaster GetRaster(Int32)
- [Method] OSGeo.MapGuide.MgRaster GetRaster(System.String)
- [Method] Int32 GetReaderType()
- [Method] Single GetSingle(System.String)
- [Method] Single GetSingle(Int32)
- [Method] System.String GetString(Int32)
- [Method] System.String GetString(System.String)
- [Method] Boolean IsNull(System.String)
- [Method] Boolean IsNull(Int32)
-type OSGeo.MapGuide.MgReadOnlyLayerCollection : OSGeo.MapGuide.MgGuardDisposable
- implements System.Collections.Generic.IReadOnlyList`1[[OSGeo.MapGuide.MgLayerBase, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IReadOnlyCollection`1[[OSGeo.MapGuide.MgLayerBase, OSGeo.MapGuide.PlatformBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
-type OSGeo.MapGuide.MgResource : OSGeo.MapGuide.MgNamedSerializable
- [Method] OSGeo.MapGuide.MgResourceIdentifier GetResourceId()
- [Method] Void Open(OSGeo.MapGuide.MgResourceService, OSGeo.MapGuide.MgResourceIdentifier)
- [Method] Void Save(OSGeo.MapGuide.MgResourceService)
- [Method] Void Save(OSGeo.MapGuide.MgResourceService, OSGeo.MapGuide.MgResourceIdentifier)
-type OSGeo.MapGuide.MgResourceIdentifier : OSGeo.MapGuide.MgSerializable
- [Method] System.String get_Path()
- [Method] System.String get_RepositoryName()
- [Method] System.String get_RepositoryType()
- [Method] System.String get_ResourceType()
- [Method] System.String GetPath()
- [Method] System.String GetRepositoryName()
- [Method] System.String GetRepositoryType()
- [Method] System.String GetResourceType()
- [Method] Void set_Path(System.String)
- [Method] Void set_RepositoryName(System.String)
- [Method] Void set_RepositoryType(System.String)
- [Method] Void set_ResourceType(System.String)
- [Method] Void SetPath(System.String)
- [Method] Void SetRepositoryName(System.String)
- [Method] Void SetRepositoryType(System.String)
- [Method] Void SetResourceType(System.String)
- [Method] System.String ToString()
- [Method] Void Validate()
-type OSGeo.MapGuide.MgResourceService : OSGeo.MapGuide.MgService
- [Method] Void ApplyResourcePackage(OSGeo.MapGuide.MgByteReader)
- [Method] Void ChangeResourceOwner(OSGeo.MapGuide.MgResourceIdentifier, System.String, Boolean)
- [Method] Void CopyResource(OSGeo.MapGuide.MgResourceIdentifier, OSGeo.MapGuide.MgResourceIdentifier, Boolean)
- [Method] Void DeleteResource(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] Void DeleteResourceData(OSGeo.MapGuide.MgResourceIdentifier, System.String)
- [Method] OSGeo.MapGuide.MgByteReader EnumerateReferences(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] OSGeo.MapGuide.MgByteReader EnumerateResourceData(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] System.String EnumerateResourceDocuments(OSGeo.MapGuide.MgStringCollection, System.String, Int32)
- [Method] OSGeo.MapGuide.MgByteReader EnumerateResources(OSGeo.MapGuide.MgResourceIdentifier, Int32, System.String, Boolean)
- [Method] OSGeo.MapGuide.MgByteReader EnumerateResources(OSGeo.MapGuide.MgResourceIdentifier, Int32, System.String)
- [Method] OSGeo.MapGuide.MgByteReader EnumerateUnmanagedData(System.String, Boolean, System.String, System.String)
- [Method] OSGeo.MapGuide.MgByteReader GetRepositoryContent(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] OSGeo.MapGuide.MgByteReader GetRepositoryHeader(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] OSGeo.MapGuide.MgByteReader GetResourceContent(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] OSGeo.MapGuide.MgStringCollection GetResourceContents(OSGeo.MapGuide.MgStringCollection, OSGeo.MapGuide.MgStringCollection)
- [Method] OSGeo.MapGuide.MgByteReader GetResourceData(OSGeo.MapGuide.MgResourceIdentifier, System.String)
- [Method] OSGeo.MapGuide.MgByteReader GetResourceHeader(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] OSGeo.MapGuide.MgByteReader GetResourceMetadata(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] OSGeo.MapGuide.MgDateTime GetResourceModifiedDate(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] Void InheritPermissionsFrom(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] Void MoveResource(OSGeo.MapGuide.MgResourceIdentifier, OSGeo.MapGuide.MgResourceIdentifier, Boolean, Boolean)
- [Method] Void MoveResource(OSGeo.MapGuide.MgResourceIdentifier, OSGeo.MapGuide.MgResourceIdentifier, Boolean)
- [Method] Void RenameResourceData(OSGeo.MapGuide.MgResourceIdentifier, System.String, System.String, Boolean)
- [Method] Boolean ResourceExists(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] Void SetResource(OSGeo.MapGuide.MgResourceIdentifier, OSGeo.MapGuide.MgByteReader, OSGeo.MapGuide.MgByteReader)
- [Method] Void SetResourceData(OSGeo.MapGuide.MgResourceIdentifier, System.String, System.String, OSGeo.MapGuide.MgByteReader)
- [Method] Void SetResourceMetadata(OSGeo.MapGuide.MgResourceIdentifier, OSGeo.MapGuide.MgByteReader)
- [Method] Void UpdateRepository(OSGeo.MapGuide.MgResourceIdentifier, OSGeo.MapGuide.MgByteReader, OSGeo.MapGuide.MgByteReader)
-type OSGeo.MapGuide.MgSelectionBase : OSGeo.MapGuide.MgResource
- implements System.IDisposable
- [Constructor] Void .ctor(OSGeo.MapGuide.MgMapBase)
- [Constructor] Void .ctor(OSGeo.MapGuide.MgMapBase, System.String)
- [Method] Void Add(System.String, System.String, System.String)
- [Method] Void AddFeatureIdDouble(OSGeo.MapGuide.MgLayerBase, System.String, Double)
- [Method] Void AddFeatureIdInt16(OSGeo.MapGuide.MgLayerBase, System.String, Int16)
- [Method] Void AddFeatureIdInt32(OSGeo.MapGuide.MgLayerBase, System.String, Int32)
- [Method] Void AddFeatureIdInt64(OSGeo.MapGuide.MgLayerBase, System.String, Int64)
- [Method] Void AddFeatureIds(OSGeo.MapGuide.MgLayerBase, System.String, OSGeo.MapGuide.MgPropertyCollection)
- [Method] Void AddFeatureIdString(OSGeo.MapGuide.MgLayerBase, System.String, System.String)
- [Method] Void AddFeatures(OSGeo.MapGuide.MgLayerBase, OSGeo.MapGuide.MgFeatureReader, Int32)
- [Method] Boolean Contains(OSGeo.MapGuide.MgLayerBase, System.String)
- [Method] Void FromXml(System.String)
- [Method] System.String GenerateFilter(OSGeo.MapGuide.MgLayerBase, System.String)
- [Method] OSGeo.MapGuide.MgStringCollection GenerateFilters(OSGeo.MapGuide.MgLayerBase, System.String, Int32)
- [Method] System.String GetClass(System.String)
- [Method] OSGeo.MapGuide.MgStringCollection GetClasses(System.String)
- [Method] OSGeo.MapGuide.MgEnvelope GetExtents(OSGeo.MapGuide.MgFeatureService)
- [Method] OSGeo.MapGuide.MgReadOnlyLayerCollection GetLayers()
- [Method] System.String GetResourceName(System.String, System.String)
- [Method] OSGeo.MapGuide.MgFeatureReader GetSelectedFeatures(OSGeo.MapGuide.MgLayerBase, System.String, OSGeo.MapGuide.MgStringCollection)
- [Method] OSGeo.MapGuide.MgFeatureReader GetSelectedFeatures(OSGeo.MapGuide.MgLayerBase, System.String, Boolean)
- [Method] Int32 GetSelectedFeaturesCount(OSGeo.MapGuide.MgLayerBase, System.String)
- [Method] Void Save(OSGeo.MapGuide.MgResourceService, System.String)
- [Method] Void SetMap(OSGeo.MapGuide.MgMapBase)
- [Method] System.String ToXml()
-type OSGeo.MapGuide.MgService : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgWarnings GetWarningsObject()
- [Method] Boolean HasWarnings()
-type OSGeo.MapGuide.MgSingleProperty : OSGeo.MapGuide.MgNullableProperty
- [Constructor] Void .ctor(System.String, Single)
- [Method] Single get_Value()
- [Method] Single GetValue()
- [Method] Void set_Value(Single)
- [Method] Void SetValue(Single)
-type OSGeo.MapGuide.MgSpatialContextReader : OSGeo.MapGuide.MgSerializable
- [Method] System.String get_CoordinateSystem()
- [Method] OSGeo.MapGuide.MgByteReader get_Extent()
- [Method] Int32 get_ExtentType()
- [Method] System.String GetCoordinateSystem()
- [Method] OSGeo.MapGuide.MgByteReader GetExtent()
- [Method] Int32 GetExtentType()
- [Method] Void Reset()
-type OSGeo.MapGuide.MgSqlDataReader : OSGeo.MapGuide.MgReader
-[System.Reflection.DefaultMemberAttribute]
-type OSGeo.MapGuide.MgStringPropertyCollection : OSGeo.MapGuide.MgCollection
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgStringProperty, OSGeo.MapGuide.Foundation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgStringProperty, OSGeo.MapGuide.Foundation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgStringProperty, OSGeo.MapGuide.Foundation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.IEnumerable
- [Constructor] Void .ctor()
- [Method] Void Add(OSGeo.MapGuide.MgStringProperty)
- [Method] Void Add(System.String, System.String)
- [Method] Void Clear()
- [Method] Boolean Contains(OSGeo.MapGuide.MgStringProperty)
- [Method] Void CopyTo(OSGeo.MapGuide.MgStringProperty[], Int32)
- [Method] Int32 get_Count()
- [Method] Boolean get_IsReadOnly()
- [Method] OSGeo.MapGuide.MgStringProperty get_Item(Int32)
- [Method] Int32 GetCount()
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgStringProperty] GetEnumerator()
- [Method] OSGeo.MapGuide.MgStringProperty GetItem(Int32)
- [Method] System.String GetName(Int32)
- [Method] System.String GetValue(System.String)
- [Method] System.String GetValue(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgStringProperty)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgStringProperty)
- [Method] Void Insert(Int32, System.String, System.String)
- [Method] Boolean Remove(System.String)
- [Method] Boolean Remove(OSGeo.MapGuide.MgStringProperty)
- [Method] Void RemoveAt(Int32)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgStringProperty)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgStringProperty)
- [Method] Void SetValue(System.String, System.String)
-type OSGeo.MapGuide.MgTransaction : OSGeo.MapGuide.MgSerializable
- [Method] System.String AddSavePoint(System.String)
- [Method] Void Commit()
- [Method] OSGeo.MapGuide.MgResourceIdentifier GetFeatureSource()
- [Method] Void ReleaseSavePoint(System.String)
- [Method] Void Rollback()
- [Method] Void Rollback(System.String)
-type OSGeo.MapGuide.MgUpdateFeatures : OSGeo.MapGuide.MgFeatureCommand
- [Constructor] Void .ctor(System.String, OSGeo.MapGuide.MgPropertyCollection, System.String)
-type OSGeo.MapGuide.MgWarnings : OSGeo.MapGuide.MgSerializable
- [Method] OSGeo.MapGuide.MgStringCollection GetMessages()
-Assembly: OSGeo.MapGuide.MapGuideCommon, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null
-type OSGeo.MapGuide.MgImageFormats : System.Object
- [Field] System.String Gif
- [Field] System.String Jpeg
- [Field] System.String Meta
- [Field] System.String Png
- [Field] System.String Png8
- [Field] System.String Raw
- [Field] System.String Tiff
-type OSGeo.MapGuide.MgPageUnitsType : System.Object
- [Field] System.String Inches
- [Field] System.String Millimeters
-type OSGeo.MapGuide.MgCoordinateSpace : System.Object
- [Field] System.String Display
- [Field] System.String None
-type OSGeo.MapGuide.MgMapPlotInstruction : System.Object
- [Field] Int32 UseMapCenterAndScale
- [Field] Int32 UseOverriddenCenterAndScale
- [Field] Int32 UseOverriddenExtent
-type OSGeo.MapGuide.MgLogFileType : System.Object
- [Field] System.String Access
- [Field] System.String Authentication
- [Field] System.String Error
- [Field] System.String Trace
-type OSGeo.MapGuide.MgServerInformationProperties : System.Object
- [Field] System.String AdminOperationsQueueCount
- [Field] System.String ApiVersion
- [Field] System.String AvailablePhysicalMemory
- [Field] System.String AvailableVirtualMemory
- [Field] System.String AverageOperationTime
- [Field] System.String CacheDroppedEntries
- [Field] System.String CacheSize
- [Field] System.String ClientOperationsQueueCount
- [Field] System.String CpuUtilization
- [Field] System.String DisplayName
- [Field] System.String MachineIp
- [Field] System.String OperatingSystemVersion
- [Field] System.String ServerVersion
- [Field] System.String SiteOperationsQueueCount
- [Field] System.String Status
- [Field] System.String TotalActiveConnections
- [Field] System.String TotalConnections
- [Field] System.String TotalOperationTime
- [Field] System.String TotalPhysicalMemory
- [Field] System.String TotalProcessedOperations
- [Field] System.String TotalReceivedOperations
- [Field] System.String TotalVirtualMemory
- [Field] System.String Uptime
- [Field] System.String VirtualMemory
- [Field] System.String WorkingSet
-type OSGeo.MapGuide.MgUnitType : System.Object
- [Field] System.String Metric
- [Field] System.String USEnglish
-type OSGeo.MapGuide.MgConfigProperties : System.Object
- [Field] System.String AccessLogPropertiesSection
- [Field] System.String AccessLogPropertyEnabled
- [Field] System.String AccessLogPropertyFilename
- [Field] System.String AccessLogPropertyParameters
- [Field] System.String AdministrativeConnectionPropertiesSection
- [Field] System.String AdministrativeConnectionPropertyEmail
- [Field] System.String AdministrativeConnectionPropertyMaxConnections
- [Field] System.String AdministrativeConnectionPropertyPort
- [Field] System.String AdministrativeConnectionPropertyQueueSize
- [Field] System.String AdministrativeConnectionPropertyThreadPoolSize
- [Field] System.String AdminLogPropertiesSection
- [Field] System.String AdminLogPropertyEnabled
- [Field] System.String AdminLogPropertyFilename
- [Field] System.String AdminLogPropertyParameters
- [Field] System.String AgentAnonymousDenyGetResourceContent
- [Field] System.String AgentAnonymousDenyGetResourceData
- [Field] System.String AgentAnonymousDenyGetResourceHeader
- [Field] System.String AgentDebugPause
- [Field] System.String AgentDisableAuthoring
- [Field] System.String AgentDisableWfs
- [Field] System.String AgentDisableWms
- [Field] System.String AgentErrorLogEnabled
- [Field] System.String AgentErrorLogFilename
- [Field] System.String AgentGlobalGetWfsFeaturesLimit
- [Field] System.String AgentGlobalGetWmsFeatureInfoLimit
- [Field] System.String AgentGlobalMaxFeatureQueryLimit
- [Field] System.String AgentGlobalMaxMapFeatureQueryLimit
- [Field] System.String AgentPropertiesSection
- [Field] System.String AgentRequestLogEnabled
- [Field] System.String AgentRequestLogFilename
- [Field] System.String AuthenticationLogPropertiesSection
- [Field] System.String AuthenticationLogPropertyEnabled
- [Field] System.String AuthenticationLogPropertyFilename
- [Field] System.String AuthenticationLogPropertyParameters
- [Field] System.String CITEWfsEnabled
- [Field] System.String CITEWmsEnabled
- [Field] System.String ClientConnectionPropertiesSection
- [Field] System.String ClientConnectionPropertyMaxConnections
- [Field] System.String ClientConnectionPropertyPort
- [Field] System.String ClientConnectionPropertyQueueSize
- [Field] System.String ClientConnectionPropertyThreadPoolSize
- [Field] System.String ContainerInfoFolder
- [Field] System.String DBEnvironmentPropertiesSection
- [Field] System.String DBMaxLockersParameters
- [Field] System.String DBMaxTransactionsParamters
- [Field] System.String DBPageSizeParameters
- [Field] System.String DBTimeoutParameters
- [Field] System.String DBXMLPageSizeParameters
- [Field] Boolean DefaultAccessLogPropertyEnabled
- [Field] System.String DefaultAccessLogPropertyFilename
- [Field] System.String DefaultAccessLogPropertyParameters
- [Field] System.String DefaultAdministrativeConnectionPropertyEmail
- [Field] Int32 DefaultAdministrativeConnectionPropertyMaxConnections
- [Field] Int32 DefaultAdministrativeConnectionPropertyPort
- [Field] Int32 DefaultAdministrativeConnectionPropertyQueueSize
- [Field] Int32 DefaultAdministrativeConnectionPropertyThreadPoolSize
- [Field] Boolean DefaultAdminLogPropertyEnabled
- [Field] System.String DefaultAdminLogPropertyFilename
- [Field] System.String DefaultAdminLogPropertyParameters
- [Field] System.String DefaultAgentAnonymousDenyGetResourceContent
- [Field] System.String DefaultAgentAnonymousDenyGetResourceData
- [Field] System.String DefaultAgentAnonymousDenyGetResourceHeader
- [Field] Int32 DefaultAgentDebugPause
- [Field] Boolean DefaultAgentErrorLogEnabled
- [Field] System.String DefaultAgentErrorLogFilename
- [Field] Int32 DefaultAgentGlobalGetWfsFeaturesLimit
- [Field] Int32 DefaultAgentGlobalGetWmsFeatureInfoLimit
- [Field] Int32 DefaultAgentGlobalMaxFeatureQueryLimit
- [Field] Int32 DefaultAgentGlobalMaxMapFeatureQueryLimit
- [Field] Boolean DefaultAgentRequestLogEnabled
- [Field] System.String DefaultAgentRequestLogFilename
- [Field] Boolean DefaultAuthenticationLogPropertyEnabled
- [Field] System.String DefaultAuthenticationLogPropertyFilename
- [Field] System.String DefaultAuthenticationLogPropertyParameters
- [Field] Boolean DefaultCITEWfsEnabled
- [Field] Boolean DefaultCITEWmsEnabled
- [Field] Int32 DefaultClientConnectionPropertyMaxConnections
- [Field] Int32 DefaultClientConnectionPropertyPort
- [Field] Int32 DefaultClientConnectionPropertyQueueSize
- [Field] Int32 DefaultClientConnectionPropertyThreadPoolSize
- [Field] System.String DefaultConfigurationFilename
- [Field] Int32 DefaultDBMaxLockersParameters
- [Field] Int32 DefaultDBMaxTransactionsParamters
- [Field] Int32 DefaultDBPageSizeParameters
- [Field] Double DefaultDBTimeoutParameters
- [Field] Int32 DefaultDBXMLPageSizeParameters
- [Field] Boolean DefaultErrorLogPropertyEnabled
- [Field] System.String DefaultErrorLogPropertyFilename
- [Field] System.String DefaultErrorLogPropertyParameters
- [Field] Int32 DefaultFeatureServicePropertyCacheSize
- [Field] Int32 DefaultFeatureServicePropertyCacheTimeLimit
- [Field] Int32 DefaultFeatureServicePropertyCacheTimerInterval
- [Field] Int32 DefaultFeatureServicePropertyDataCacheSize
- [Field] Boolean DefaultFeatureServicePropertyDataConnectionPoolEnabled
- [Field] System.String DefaultFeatureServicePropertyDataConnectionPoolExcludedProviders
- [Field] Int32 DefaultFeatureServicePropertyDataConnectionPoolSize
- [Field] System.String DefaultFeatureServicePropertyDataConnectionPoolSizeCustom
- [Field] Int32 DefaultFeatureServicePropertyDataConnectionTimeout
- [Field] Int32 DefaultFeatureServicePropertyDataConnectionTimerInterval
- [Field] System.String DefaultFeatureServicePropertyDataConnectionUseLimit
- [Field] Int32 DefaultFeatureServicePropertyDataTransactionTimeout
- [Field] Int32 DefaultFeatureServicePropertyDataTransactionTimerInterval
- [Field] System.String DefaultFeatureServicePropertyFDOConnectionTimeoutCustom
- [Field] Int32 DefaultFeatureServicePropertyJoinQueryBatchSize
- [Field] Boolean DefaultFeatureServicePropertyUseFdoJoinOptimization
- [Field] Int32 DefaultGeneralPropertyConnectionTimeout
- [Field] Int32 DefaultGeneralPropertyConnectionTimerInterval
- [Field] System.String DefaultGeneralPropertyDefaultMessageLocale
- [Field] System.String DefaultGeneralPropertyDisplayName
- [Field] System.String DefaultGeneralPropertyFdoPath
- [Field] System.String DefaultGeneralPropertyLicenseServerPath
- [Field] System.String DefaultGeneralPropertyLinuxFontDirectories
- [Field] Boolean DefaultGeneralPropertyLinuxMemDebug
- [Field] System.String DefaultGeneralPropertyLocale
- [Field] System.String DefaultGeneralPropertyLogsDelimiter
- [Field] System.String DefaultGeneralPropertyLogsDetail
- [Field] System.String DefaultGeneralPropertyLogsPath
- [Field] System.String DefaultGeneralPropertyMachineIp
- [Field] Int32 DefaultGeneralPropertyMaxLogFileSize
- [Field] Boolean DefaultGeneralPropertyMaxLogFileSizeEnabled
- [Field] System.String DefaultGeneralPropertyMentorDictionaryPath
- [Field] System.String DefaultGeneralPropertyMentorUserDictionaryPath
- [Field] System.String DefaultGeneralPropertyPreCacheMaps
- [Field] System.String DefaultGeneralPropertyResourcesPath
- [Field] System.String DefaultGeneralPropertySerialNumber
- [Field] Int32 DefaultGeneralPropertyServiceRegistrationTimerInterval
- [Field] Int32 DefaultGeneralPropertyTcpIpMtu
- [Field] System.String DefaultGeneralPropertyTempPath
- [Field] System.String DefaultGeneralPropertyWfsDocumentPath
- [Field] System.String DefaultGeneralPropertyWmsDocumentPath
- [Field] Boolean DefaultHostPropertyDrawingService
- [Field] Boolean DefaultHostPropertyFeatureService
- [Field] Boolean DefaultHostPropertyKmlService
- [Field] Boolean DefaultHostPropertyMappingService
- [Field] Boolean DefaultHostPropertyProfilingService
- [Field] Boolean DefaultHostPropertyRenderingService
- [Field] Boolean DefaultHostPropertyResourceService
- [Field] Boolean DefaultHostPropertySiteService
- [Field] Boolean DefaultHostPropertyTileService
- [Field] Int32 DefaultLibraryCacheSizeParameters
- [Field] Int32 DefaultLibraryLogBufferSizeParameters
- [Field] System.String DefaultMappingServicePropertyLegendFont
- [Field] Boolean DefaultPerformanceLogPropertyEnabled
- [Field] System.String DefaultPerformanceLogPropertyFilename
- [Field] Int32 DefaultPerformanceLogPropertyInterval
- [Field] System.String DefaultPerformanceLogPropertyParameters
- [Field] Boolean DefaultRenderingServicePropertiesGlobalRasterStylizationLockEnabled
- [Field] Boolean DefaultRenderingServicePropertyClampPoints
- [Field] Boolean DefaultRenderingServicePropertyGeneralizeData
- [Field] Int32 DefaultRenderingServicePropertyMaxRasterImageHeight
- [Field] Int32 DefaultRenderingServicePropertyMaxRasterImageWidth
- [Field] Int32 DefaultRenderingServicePropertyMaxRenderImageHeight
- [Field] Int32 DefaultRenderingServicePropertyMaxRenderImageWidth
- [Field] Int32 DefaultRenderingServicePropertyMinRasterGridSize
- [Field] Int32 DefaultRenderingServicePropertyMinRasterGridSizeForPlot
- [Field] Int32 DefaultRenderingServicePropertyRasterGridSize
- [Field] Int32 DefaultRenderingServicePropertyRasterGridSizeForPlot
- [Field] Double DefaultRenderingServicePropertyRasterGridSizeOverrideRatio
- [Field] Double DefaultRenderingServicePropertyRasterGridSizeOverrideRatioForPlot
- [Field] Int32 DefaultRenderingServicePropertyRenderSelectionBatchSize
- [Field] Double DefaultRenderingServicePropertyTileExtentOffset
- [Field] System.String DefaultResourceServicePropertyLibraryRepositoryPath
- [Field] System.String DefaultResourceServicePropertyLibraryResourceDataFilePath
- [Field] System.String DefaultResourceServicePropertyPackagesPath
- [Field] Int32 DefaultResourceServicePropertyRepositoryCheckpointsTimerInterval
- [Field] Int32 DefaultResourceServicePropertyResourceChangeTimerInterval
- [Field] System.String DefaultResourceServicePropertyResourceDataFileTrashFolderName
- [Field] Int32 DefaultResourceServicePropertyResourcePermissionCacheSize
- [Field] System.String DefaultResourceServicePropertyResourceSchemaFilePath
- [Field] System.String DefaultResourceServicePropertySessionRepositoryPath
- [Field] System.String DefaultResourceServicePropertySessionResourceDataFilePath
- [Field] System.String DefaultResourceServicePropertySiteRepositoryPath
- [Field] Int32 DefaultSessionCacheSizeParamters
- [Field] Int32 DefaultSessionDBPageSizeParameters
- [Field] Double DefaultSessionDBXMLPageSizeParameters
- [Field] Int32 DefaultSessionLogBufferSizeParameters
- [Field] Boolean DefaultSessionLogPropertyEnabled
- [Field] System.String DefaultSessionLogPropertyFilename
- [Field] System.String DefaultSessionLogPropertyParameters
- [Field] System.String DefaultSiteConnectionPropertyIpAddress
- [Field] Int32 DefaultSiteConnectionPropertyMaxConnections
- [Field] Int32 DefaultSiteConnectionPropertyPort
- [Field] Int32 DefaultSiteConnectionPropertyQueueSize
- [Field] Int32 DefaultSiteConnectionPropertyThreadPoolSize
- [Field] Int32 DefaultSiteServicePropertySessionTimeout
- [Field] Int32 DefaultSiteServicePropertySessionTimerInterval
- [Field] System.String DefaultTileServicePropertyImageFormat
- [Field] Boolean DefaultTileServicePropertyRenderOnly
- [Field] System.String DefaultTileServicePropertyTileCachePath
- [Field] Int32 DefaultTileServicePropertyTileColumnsPerFolder
- [Field] Int32 DefaultTileServicePropertyTileRowsPerFolder
- [Field] Int32 DefaultTileServicePropertyTileSizeX
- [Field] Int32 DefaultTileServicePropertyTileSizeY
- [Field] Boolean DefaultTraceLogPropertyEnabled
- [Field] System.String DefaultTraceLogPropertyFilename
- [Field] System.String DefaultTraceLogPropertyParameters
- [Field] System.String DrawingServicePropertiesSection
- [Field] System.String ErrorLogPropertiesSection
- [Field] System.String ErrorLogPropertyEnabled
- [Field] System.String ErrorLogPropertyFilename
- [Field] System.String ErrorLogPropertyParameters
- [Field] System.String FeatureServicePropertiesSection
- [Field] System.String FeatureServicePropertyCacheSize
- [Field] System.String FeatureServicePropertyCacheTimeLimit
- [Field] System.String FeatureServicePropertyCacheTimerInterval
- [Field] System.String FeatureServicePropertyDataCacheSize
- [Field] System.String FeatureServicePropertyDataConnectionPoolEnabled
- [Field] System.String FeatureServicePropertyDataConnectionPoolExcludedProviders
- [Field] System.String FeatureServicePropertyDataConnectionPoolSize
- [Field] System.String FeatureServicePropertyDataConnectionPoolSizeCustom
- [Field] System.String FeatureServicePropertyDataConnectionTimeout
- [Field] System.String FeatureServicePropertyDataConnectionTimerInterval
- [Field] System.String FeatureServicePropertyDataConnectionUseLimit
- [Field] System.String FeatureServicePropertyDataTransactionTimeout
- [Field] System.String FeatureServicePropertyDataTransactionTimerInterval
- [Field] System.String FeatureServicePropertyFDOConnectionTimeoutCustom
- [Field] System.String FeatureServicePropertyJoinQueryBatchSize
- [Field] System.String FeatureServicePropertyUseFdoJoinOptimization
- [Field] System.String FontAliasMappingSection
- [Field] System.String GeneralPropertiesSection
- [Field] System.String GeneralPropertyConnectionTimeout
- [Field] System.String GeneralPropertyConnectionTimerInterval
- [Field] System.String GeneralPropertyDefaultMessageLocale
- [Field] System.String GeneralPropertyDisplayName
- [Field] System.String GeneralPropertyFdoPath
- [Field] System.String GeneralPropertyLicenseServerPath
- [Field] System.String GeneralPropertyLinuxFontDirectories
- [Field] System.String GeneralPropertyLinuxMemDebug
- [Field] System.String GeneralPropertyLocale
- [Field] System.String GeneralPropertyLogsDelimiter
- [Field] System.String GeneralPropertyLogsDetail
- [Field] System.String GeneralPropertyLogsPath
- [Field] System.String GeneralPropertyMachineIp
- [Field] System.String GeneralPropertyMaxLogFileSize
- [Field] System.String GeneralPropertyMaxLogFileSizeEnabled
- [Field] System.String GeneralPropertyMentorDictionaryPath
- [Field] System.String GeneralPropertyMentorUserDictionaryPath
- [Field] System.String GeneralPropertyPreCacheMaps
- [Field] System.String GeneralPropertyResourcesPath
- [Field] System.String GeneralPropertySerialNumber
- [Field] System.String GeneralPropertyServiceRegistrationTimerInterval
- [Field] System.String GeneralPropertyTcpIpMtu
- [Field] System.String GeneralPropertyTempPath
- [Field] System.String GeneralPropertyWfsDocumentPath
- [Field] System.String GeneralPropertyWmsDocumentPath
- [Field] System.String HostPropertiesSection
- [Field] System.String HostPropertyDrawingService
- [Field] System.String HostPropertyFeatureService
- [Field] System.String HostPropertyKmlService
- [Field] System.String HostPropertyMappingService
- [Field] System.String HostPropertyProfilingService
- [Field] System.String HostPropertyRenderingService
- [Field] System.String HostPropertyResourceService
- [Field] System.String HostPropertySiteService
- [Field] System.String HostPropertyTileService
- [Field] System.String LibraryCacheSizeParameters
- [Field] System.String LibraryLogBufferSizeParameters
- [Field] System.String MappingServicePropertiesSection
- [Field] System.String MappingServicePropertyLegendFont
- [Field] System.String OgcPropertiesSection
- [Field] System.String PerformanceLogPropertiesSection
- [Field] System.String PerformanceLogPropertyEnabled
- [Field] System.String PerformanceLogPropertyFilename
- [Field] System.String PerformanceLogPropertyInterval
- [Field] System.String PerformanceLogPropertyParameters
- [Field] System.String RenderingServicePropertiesGlobalRasterStylizationLockEnabled
- [Field] System.String RenderingServicePropertiesSection
- [Field] System.String RenderingServicePropertyClampPoints
- [Field] System.String RenderingServicePropertyGeneralizeData
- [Field] System.String RenderingServicePropertyMaxRasterImageHeight
- [Field] System.String RenderingServicePropertyMaxRasterImageWidth
- [Field] System.String RenderingServicePropertyMaxRenderImageHeight
- [Field] System.String RenderingServicePropertyMaxRenderImageWidth
- [Field] System.String RenderingServicePropertyMinRasterGridSize
- [Field] System.String RenderingServicePropertyMinRasterGridSizeForPlot
- [Field] System.String RenderingServicePropertyRasterGridSize
- [Field] System.String RenderingServicePropertyRasterGridSizeForPlot
- [Field] System.String RenderingServicePropertyRasterGridSizeOverrideRatio
- [Field] System.String RenderingServicePropertyRasterGridSizeOverrideRatioForPlot
- [Field] System.String RenderingServicePropertyRenderSelectionBatchSize
- [Field] System.String RenderingServicePropertyTileExtentOffset
- [Field] System.String ResourceServicePropertiesSection
- [Field] System.String ResourceServicePropertyLibraryRepositoryPath
- [Field] System.String ResourceServicePropertyLibraryResourceDataFilePath
- [Field] System.String ResourceServicePropertyPackagesPath
- [Field] System.String ResourceServicePropertyRepositoryCheckpointsTimerInterval
- [Field] System.String ResourceServicePropertyResourceChangeTimerInterval
- [Field] System.String ResourceServicePropertyResourceDataFileTrashFolderName
- [Field] System.String ResourceServicePropertyResourcePermissionCacheSize
- [Field] System.String ResourceServicePropertyResourceSchemaFilePath
- [Field] System.String ResourceServicePropertySessionRepositoryPath
- [Field] System.String ResourceServicePropertySessionResourceDataFilePath
- [Field] System.String ResourceServicePropertySiteRepositoryPath
- [Field] System.String ServerConfigurationFilename
- [Field] System.String SessionCacheSizeParamters
- [Field] System.String SessionDBPageSizeParameters
- [Field] System.String SessionDBXMLPageSizeParameters
- [Field] System.String SessionLogBufferSizeParameters
- [Field] System.String SessionLogPropertiesSection
- [Field] System.String SessionLogPropertyEnabled
- [Field] System.String SessionLogPropertyFilename
- [Field] System.String SessionLogPropertyParameters
- [Field] System.String SiteConnectionPropertiesSection
- [Field] System.String SiteConnectionPropertyIpAddress
- [Field] System.String SiteConnectionPropertyMaxConnections
- [Field] System.String SiteConnectionPropertyPort
- [Field] System.String SiteConnectionPropertyQueueSize
- [Field] System.String SiteConnectionPropertyThreadPoolSize
- [Field] System.String SiteServicePropertiesSection
- [Field] System.String SiteServicePropertySessionTimeout
- [Field] System.String SiteServicePropertySessionTimerInterval
- [Field] System.String TemplateRootFolder
- [Field] System.String TileServicePropertiesSection
- [Field] System.String TileServicePropertyImageFormat
- [Field] System.String TileServicePropertyRenderOnly
- [Field] System.String TileServicePropertyTileCachePath
- [Field] System.String TileServicePropertyTileColumnsPerFolder
- [Field] System.String TileServicePropertyTileRowsPerFolder
- [Field] System.String TileServicePropertyTileSizeX
- [Field] System.String TileServicePropertyTileSizeY
- [Field] System.String TraceLogPropertiesSection
- [Field] System.String TraceLogPropertyEnabled
- [Field] System.String TraceLogPropertyFilename
- [Field] System.String TraceLogPropertyParameters
- [Field] System.String UnmanagedDataMappingsSection
- [Field] System.String WebApplicationPropertiesSection
- [Field] System.String WfsPassword
- [Field] System.String WidgetInfoFolder
- [Field] System.String WmsPassword
-type OSGeo.MapGuide.MgLocalizer : System.Object
- [Method] System.String GetString(System.String, System.String)
- [Method] System.String Localize(System.String, System.String, Int32)
- [Method] Void SetLocalizedFilesPath(System.String)
-type OSGeo.MapGuide.MgDrawingService : OSGeo.MapGuide.MgService
- [Method] OSGeo.MapGuide.MgByteReader DescribeDrawing(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] OSGeo.MapGuide.MgStringCollection EnumerateLayers(OSGeo.MapGuide.MgResourceIdentifier, System.String)
- [Method] OSGeo.MapGuide.MgByteReader EnumerateSectionResources(OSGeo.MapGuide.MgResourceIdentifier, System.String)
- [Method] OSGeo.MapGuide.MgByteReader EnumerateSections(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] System.String GetCoordinateSpace(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] OSGeo.MapGuide.MgByteReader GetDrawing(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] OSGeo.MapGuide.MgByteReader GetLayer(OSGeo.MapGuide.MgResourceIdentifier, System.String, System.String)
- [Method] OSGeo.MapGuide.MgByteReader GetSection(OSGeo.MapGuide.MgResourceIdentifier, System.String)
- [Method] OSGeo.MapGuide.MgByteReader GetSectionResource(OSGeo.MapGuide.MgResourceIdentifier, System.String)
-type OSGeo.MapGuide.MgDwfVersion : OSGeo.MapGuide.MgSerializable
- [Constructor] Void .ctor(System.String, System.String)
- [Method] System.String GetFileVersion()
- [Method] System.String GetSchemaVersion()
- [Method] Void SetFileVersion(System.String)
- [Method] Void SetSchemaVersion(System.String)
-type OSGeo.MapGuide.MgFeatureInformation : OSGeo.MapGuide.MgSerializable
- [Method] System.String GetHyperlink()
- [Method] OSGeo.MapGuide.MgPropertyCollection GetProperties()
- [Method] OSGeo.MapGuide.MgSelection GetSelection()
- [Method] System.String GetTooltip()
- [Method] OSGeo.MapGuide.MgByteReader ToXml()
-type OSGeo.MapGuide.MgKmlService : OSGeo.MapGuide.MgService
- [Method] OSGeo.MapGuide.MgByteReader GetFeaturesKml(OSGeo.MapGuide.MgLayer, OSGeo.MapGuide.MgEnvelope, Int32, Int32, Double, Int32, System.String)
- [Method] OSGeo.MapGuide.MgByteReader GetFeaturesKml(OSGeo.MapGuide.MgLayer, OSGeo.MapGuide.MgEnvelope, Int32, Int32, Double, Int32, System.String, System.String)
- [Method] OSGeo.MapGuide.MgByteReader GetLayerKml(OSGeo.MapGuide.MgLayer, OSGeo.MapGuide.MgEnvelope, Int32, Int32, Double, Int32, System.String, System.String)
- [Method] OSGeo.MapGuide.MgByteReader GetMapKml(OSGeo.MapGuide.MgMap, Double, System.String, System.String)
-type OSGeo.MapGuide.MgLayer : OSGeo.MapGuide.MgLayerBase
- [Method] OSGeo.MapGuide.MgByteReader GenerateLegendImage(Int32, Int32, System.String, Int32, Int32)
- [Method] OSGeo.MapGuide.MgByteReader GenerateLegendImage(Double, Int32, Int32, System.String, Int32, Int32)
- [Method] OSGeo.MapGuide.MgClassDefinition GetClassDefinition()
- [Method] Int32 GetCompositeThemeCategoryCount(Double, Int32)
- [Method] Int32 GetCompositeThemeCategoryCount(Int32)
- [Method] OSGeo.MapGuide.MgIntCollection GetGeometryTypeStyles()
- [Method] OSGeo.MapGuide.MgIntCollection GetGeometryTypeStyles(Double)
- [Method] Int32 GetThemeCategoryCount(Int32)
- [Method] Int32 GetThemeCategoryCount(Double, Int32)
-type OSGeo.MapGuide.MgLayout : OSGeo.MapGuide.MgSerializable
- [Constructor] Void .ctor(OSGeo.MapGuide.MgResourceIdentifier, System.String, System.String)
- [Method] OSGeo.MapGuide.MgResourceIdentifier GetLayout()
- [Method] System.String GetTitle()
- [Method] System.String GetUnitType()
- [Method] Void SetLayout(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] Void SetTitle(System.String)
- [Method] Void SetUnitType(System.String)
-type OSGeo.MapGuide.MgMap : OSGeo.MapGuide.MgMapBase
- [Constructor] Void .ctor(OSGeo.MapGuide.MgSiteConnection)
- [Method] Void Create(OSGeo.MapGuide.MgResourceIdentifier, System.String)
- [Method] Void Create(OSGeo.MapGuide.MgResourceIdentifier, System.String, Int32, Int32, Double, Double, Double, Int32)
- [Method] System.String GetTileFormat()
- [Method] Int32 GetTilePixelRatio()
- [Method] OSGeo.MapGuide.MgResourceIdentifier GetTileSetDefinition()
- [Method] System.String GetTileSetProvider()
- [Method] Int32 GetWatermarkUsage()
- [Method] Void Open(System.String)
- [Method] Void Save()
-type OSGeo.MapGuide.MgMappingService : OSGeo.MapGuide.MgService
- [Method] OSGeo.MapGuide.MgByteReader CreateRuntimeMap(OSGeo.MapGuide.MgResourceIdentifier, System.String, Int32, Int32)
- [Method] OSGeo.MapGuide.MgByteReader CreateRuntimeMap(OSGeo.MapGuide.MgResourceIdentifier, System.String, System.String, System.String, Int32, Int32, Int32, Int32)
- [Method] OSGeo.MapGuide.MgByteReader DescribeRuntimeMap(OSGeo.MapGuide.MgMap, Int32, Int32)
- [Method] OSGeo.MapGuide.MgByteReader DescribeRuntimeMap(OSGeo.MapGuide.MgMap, System.String, Int32, Int32, Int32, Int32)
- [Method] OSGeo.MapGuide.MgByteReader GenerateLegendImage(OSGeo.MapGuide.MgResourceIdentifier, Double, Int32, Int32, System.String, Int32, Int32)
- [Method] OSGeo.MapGuide.MgByteReader GenerateMultiPlot(OSGeo.MapGuide.MgMapPlotCollection, OSGeo.MapGuide.MgDwfVersion)
- [Method] OSGeo.MapGuide.MgByteReader GeneratePlot(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgPlotSpecification, OSGeo.MapGuide.MgLayout, OSGeo.MapGuide.MgDwfVersion)
- [Method] OSGeo.MapGuide.MgByteReader GeneratePlot(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgCoordinate, Double, OSGeo.MapGuide.MgPlotSpecification, OSGeo.MapGuide.MgLayout, OSGeo.MapGuide.MgDwfVersion)
- [Method] OSGeo.MapGuide.MgByteReader GeneratePlot(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgEnvelope, Boolean, OSGeo.MapGuide.MgPlotSpecification, OSGeo.MapGuide.MgLayout, OSGeo.MapGuide.MgDwfVersion)
- [Method] OSGeo.MapGuide.MgByteReader QueryFeatures(OSGeo.MapGuide.MgMap, System.String, System.String)
- [Method] OSGeo.MapGuide.MgByteReader QueryFeatures(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgStringCollection, Int32, Int32, Int32, System.String)
-type OSGeo.MapGuide.MgMapPlot : OSGeo.MapGuide.MgNamedSerializable
- [Constructor] Void .ctor(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgCoordinate, Double, OSGeo.MapGuide.MgPlotSpecification, OSGeo.MapGuide.MgLayout)
- [Constructor] Void .ctor(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgPlotSpecification, OSGeo.MapGuide.MgLayout)
- [Constructor] Void .ctor(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgEnvelope, Boolean, OSGeo.MapGuide.MgPlotSpecification, OSGeo.MapGuide.MgLayout)
- [Method] OSGeo.MapGuide.MgCoordinate GetCenter()
- [Method] Boolean GetExpandToFit()
- [Method] OSGeo.MapGuide.MgEnvelope GetExtent()
- [Method] OSGeo.MapGuide.MgLayout GetLayout()
- [Method] OSGeo.MapGuide.MgMap GetMap()
- [Method] Int32 GetMapPlotInstruction()
- [Method] OSGeo.MapGuide.MgPlotSpecification GetPlotSpecification()
- [Method] Double GetScale()
- [Method] Void SetCenterAndScale(OSGeo.MapGuide.MgCoordinate, Double)
- [Method] Void SetExtent(OSGeo.MapGuide.MgEnvelope, Boolean)
- [Method] Void SetLayout(OSGeo.MapGuide.MgLayout)
- [Method] Void SetMap(OSGeo.MapGuide.MgMap)
- [Method] Void SetMapPlotInstruction(Int32)
- [Method] Void SetPlotSpecification(OSGeo.MapGuide.MgPlotSpecification)
-type OSGeo.MapGuide.MgMapPlotCollection : OSGeo.MapGuide.MgSerializable
- implements System.Collections.Generic.IList`1[[OSGeo.MapGuide.MgMapPlot, OSGeo.MapGuide.MapGuideCommon, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.ICollection`1[[OSGeo.MapGuide.MgMapPlot, OSGeo.MapGuide.MapGuideCommon, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- implements System.Collections.Generic.IEnumerable`1[[OSGeo.MapGuide.MgMapPlot, OSGeo.MapGuide.MapGuideCommon, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null]]
- [Method] Void Add(OSGeo.MapGuide.MgMapPlot)
- [Method] Boolean Contains(OSGeo.MapGuide.MgMapPlot)
- [Method] Void CopyTo(OSGeo.MapGuide.MgMapPlot[], Int32)
- [Method] OSGeo.MapGuide.MgMapPlot get_Item(Int32)
- [Method] System.Collections.Generic.IEnumerator`1[OSGeo.MapGuide.MgMapPlot] GetEnumerator()
- [Method] OSGeo.MapGuide.MgMapPlot GetItem(Int32)
- [Method] OSGeo.MapGuide.MgMapPlot GetItem(System.String)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgMapPlot)
- [Method] Void Insert(Int32, OSGeo.MapGuide.MgMapPlot)
- [Method] Boolean Remove(OSGeo.MapGuide.MgMapPlot)
- [Method] Void set_Item(Int32, OSGeo.MapGuide.MgMapPlot)
- [Method] Void SetItem(Int32, OSGeo.MapGuide.MgMapPlot)
-type OSGeo.MapGuide.MgMetatile : OSGeo.MapGuide.MgSerializable
- [Method] Int32 GetHeight()
- [Method] OSGeo.MapGuide.MgByteReader GetImage()
- [Method] Int32 GetMetaTilingFactor()
- [Method] Int32 GetRequestedHeight()
- [Method] Int32 GetRequestedWidth()
- [Method] System.String GetTileImageFormat()
- [Method] Int32 GetWidth()
-type OSGeo.MapGuide.MgPackageStatusInformation : OSGeo.MapGuide.MgSerializable
- [Method] System.String GetApiName()
- [Method] Double GetAverageOperationTime()
- [Method] OSGeo.MapGuide.MgDateTime GetEndTime()
- [Method] System.String GetErrorMessage()
- [Method] Int32 GetOperationsFailed()
- [Method] Int32 GetOperationsReceived()
- [Method] OSGeo.MapGuide.MgDateTime GetPackageDate()
- [Method] System.String GetPackageDescription()
- [Method] System.String GetPackageName()
- [Method] Int64 GetPackageSize()
- [Method] System.String GetServerAddress()
- [Method] System.String GetServerName()
- [Method] System.String GetStackTrace()
- [Method] OSGeo.MapGuide.MgDateTime GetStartTime()
- [Method] System.String GetStatusCode()
- [Method] System.String GetStatusMessage()
- [Method] System.String GetUserName()
- [Method] Void SetApiName(System.String)
- [Method] Void SetEndTime(OSGeo.MapGuide.MgDateTime)
- [Method] Void SetErrorMessage(System.String)
- [Method] Void SetOperationsFailed(Int32)
- [Method] Void SetOperationsReceived(Int32)
- [Method] Void SetPackageDate(OSGeo.MapGuide.MgDateTime)
- [Method] Void SetPackageDescription(System.String)
- [Method] Void SetPackageName(System.String)
- [Method] Void SetPackageSize(Int64)
- [Method] Void SetServerAddress(System.String)
- [Method] Void SetServerName(System.String)
- [Method] Void SetStackTrace(System.String)
- [Method] Void SetStartTime(OSGeo.MapGuide.MgDateTime)
- [Method] Void SetStatusCode(System.String)
- [Method] Void SetUserName(System.String)
-type OSGeo.MapGuide.MgPlotSpecification : OSGeo.MapGuide.MgSerializable
- [Constructor] Void .ctor(Single, Single, System.String, Single)
- [Constructor] Void .ctor(Single, Single, System.String, Single, Single)
- [Constructor] Void .ctor(Single, Single, System.String, Single, Single, Single)
- [Constructor] Void .ctor(Single, Single, System.String, Single, Single, Single, Single)
- [Constructor] Void .ctor(Single, Single, System.String)
- [Method] Single GetMarginBottom()
- [Method] Single GetMarginLeft()
- [Method] Single GetMarginRight()
- [Method] Single GetMarginTop()
- [Method] System.String GetPageSizeUnits()
- [Method] Single GetPaperHeight()
- [Method] Single GetPaperWidth()
- [Method] Void SetMargins(Single, Single, Single, Single)
- [Method] Void SetPageSizeUnits(System.String)
- [Method] Void SetPaperHeight(Single)
- [Method] Void SetPaperWidth(Single)
-type OSGeo.MapGuide.MgProfilingService : OSGeo.MapGuide.MgService
- [Method] OSGeo.MapGuide.MgByteReader ProfileRenderDynamicOverlay(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgSelection, OSGeo.MapGuide.MgRenderingOptions)
- [Method] OSGeo.MapGuide.MgByteReader ProfileRenderMap(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgSelection, OSGeo.MapGuide.MgCoordinate, Double, Int32, Int32, OSGeo.MapGuide.MgColor, System.String, Boolean)
-type OSGeo.MapGuide.MgRenderingOptions : OSGeo.MapGuide.MgSerializable
- [Constructor] Void .ctor(System.String, Int32, OSGeo.MapGuide.MgColor)
- [Method] Int32 GetBehavior()
- [Method] System.String GetImageFormat()
- [Method] OSGeo.MapGuide.MgColor GetSelectionColor()
- [Field] Int32 KeepSelection
- [Field] Int32 RenderBaseLayers
- [Field] Int32 RenderLayers
- [Field] Int32 RenderSelection
-type OSGeo.MapGuide.MgRenderingService : OSGeo.MapGuide.MgService
- [Method] OSGeo.MapGuide.MgBatchPropertyCollection QueryFeatureProperties(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgStringCollection, OSGeo.MapGuide.MgGeometry, Int32, System.String, Int32, Int32)
- [Method] OSGeo.MapGuide.MgBatchPropertyCollection QueryFeatureProperties(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgStringCollection, OSGeo.MapGuide.MgGeometry, Int32, Int32)
- [Method] OSGeo.MapGuide.MgFeatureInformation QueryFeatures(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgStringCollection, OSGeo.MapGuide.MgGeometry, Int32, System.String, Int32, Int32)
- [Method] OSGeo.MapGuide.MgFeatureInformation QueryFeatures(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgStringCollection, OSGeo.MapGuide.MgGeometry, Int32, Int32)
- [Method] OSGeo.MapGuide.MgByteReader RenderDynamicOverlay(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgSelection, System.String)
- [Method] OSGeo.MapGuide.MgByteReader RenderDynamicOverlay(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgSelection, System.String, Boolean)
- [Method] OSGeo.MapGuide.MgByteReader RenderDynamicOverlay(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgSelection, OSGeo.MapGuide.MgRenderingOptions)
- [Method] OSGeo.MapGuide.MgByteReader RenderMap(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgSelection, OSGeo.MapGuide.MgCoordinate, Double, Int32, Int32, OSGeo.MapGuide.MgColor, System.String, Boolean, OSGeo.MapGuide.MgColor)
- [Method] OSGeo.MapGuide.MgByteReader RenderMap(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgSelection, OSGeo.MapGuide.MgCoordinate, Double, Int32, Int32, OSGeo.MapGuide.MgColor, System.String, Boolean)
- [Method] OSGeo.MapGuide.MgByteReader RenderMap(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgSelection, OSGeo.MapGuide.MgCoordinate, Double, Int32, Int32, OSGeo.MapGuide.MgColor, System.String)
- [Method] OSGeo.MapGuide.MgByteReader RenderMap(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgSelection, OSGeo.MapGuide.MgEnvelope, Int32, Int32, OSGeo.MapGuide.MgColor, System.String, Boolean)
- [Method] OSGeo.MapGuide.MgByteReader RenderMap(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgSelection, OSGeo.MapGuide.MgEnvelope, Int32, Int32, OSGeo.MapGuide.MgColor, System.String)
- [Method] OSGeo.MapGuide.MgByteReader RenderMap(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgSelection, System.String, Boolean, Boolean, OSGeo.MapGuide.MgColor)
- [Method] OSGeo.MapGuide.MgByteReader RenderMap(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgSelection, System.String, Boolean, Boolean)
- [Method] OSGeo.MapGuide.MgByteReader RenderMap(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgSelection, System.String)
- [Method] OSGeo.MapGuide.MgByteReader RenderMap(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgSelection, System.String, Boolean)
- [Method] OSGeo.MapGuide.MgByteReader RenderMapLegend(OSGeo.MapGuide.MgMap, Int32, Int32, OSGeo.MapGuide.MgColor, System.String)
- [Method] OSGeo.MapGuide.MgMetatile RenderMetatile(OSGeo.MapGuide.MgMap, System.String, Int32, Int32, Int32, Int32, Int32, System.String, Double, Int32)
- [Method] OSGeo.MapGuide.MgMetatile RenderMetatileXYZ(OSGeo.MapGuide.MgMap, System.String, Int32, Int32, Int32, Int32, System.String, Double, Int32, Int32)
- [Method] OSGeo.MapGuide.MgByteReader RenderTile(OSGeo.MapGuide.MgMap, System.String, Int32, Int32, Int32, Int32, Int32, System.String, Double)
- [Method] OSGeo.MapGuide.MgByteReader RenderTile(OSGeo.MapGuide.MgMap, System.String, Int32, Int32, Int32, Int32, Int32, System.String)
- [System.ObsoleteAttribute]
- [Method] OSGeo.MapGuide.MgByteReader RenderTile(OSGeo.MapGuide.MgMap, System.String, Int32, Int32)
- [Method] OSGeo.MapGuide.MgByteReader RenderTileFromMetaTile(OSGeo.MapGuide.MgMap, OSGeo.MapGuide.MgMetatile, Int32, Int32)
- [Method] OSGeo.MapGuide.MgByteReader RenderTileUTFGrid(OSGeo.MapGuide.MgMap, System.String, Int32, Int32, Int32, Int32)
- [Method] OSGeo.MapGuide.MgByteReader RenderTileXYZ(OSGeo.MapGuide.MgMap, System.String, Int32, Int32, Int32, Int32, System.String, Double, Int32)
- [Method] OSGeo.MapGuide.MgByteReader RenderTileXYZ(OSGeo.MapGuide.MgMap, System.String, Int32, Int32, Int32, Int32, System.String)
- [Method] OSGeo.MapGuide.MgByteReader RenderTileXYZ(OSGeo.MapGuide.MgMap, System.String, Int32, Int32, Int32)
-type OSGeo.MapGuide.MgSelection : OSGeo.MapGuide.MgSelectionBase
- [Constructor] Void .ctor(OSGeo.MapGuide.MgMap)
- [Constructor] Void .ctor(OSGeo.MapGuide.MgMap, System.String)
-type OSGeo.MapGuide.MgServerAdmin : OSGeo.MapGuide.MgGuardDisposable
- [Method] Void BringOnline()
- [Method] Boolean ClearLog(System.String)
- [Method] Void DeleteLog(System.String)
- [Method] Void DeletePackage(System.String)
- [Method] Void EnableMaximumLogSize(Boolean)
- [Method] OSGeo.MapGuide.MgPropertyCollection EnumerateLogs()
- [Method] OSGeo.MapGuide.MgStringCollection EnumeratePackages()
- [Method] OSGeo.MapGuide.MgPropertyCollection GetConfigurationProperties(System.String)
- [Method] OSGeo.MapGuide.MgByteReader GetDocument(System.String)
- [Method] OSGeo.MapGuide.MgPropertyCollection GetInformationProperties()
- [Method] OSGeo.MapGuide.MgByteReader GetLog(System.String)
- [Method] OSGeo.MapGuide.MgByteReader GetLog(System.String, Int32)
- [Method] OSGeo.MapGuide.MgByteReader GetLog(System.String, OSGeo.MapGuide.MgDateTime, OSGeo.MapGuide.MgDateTime)
- [Method] OSGeo.MapGuide.MgByteReader GetLogFile(System.String)
- [Method] OSGeo.MapGuide.MgByteReader GetPackageLog(System.String)
- [Method] OSGeo.MapGuide.MgPackageStatusInformation GetPackageStatus(System.String)
- [Method] OSGeo.MapGuide.MgPropertyCollection GetSiteStatus()
- [Method] System.String GetSiteVersion()
- [Method] Boolean HasWarning()
- [Method] Boolean IsMaximumLogSizeEnabled()
- [Method] Boolean IsOnline()
- [Method] Void LoadPackage(System.String)
- [Method] Void MakePackage(OSGeo.MapGuide.MgResourceIdentifier, System.String, System.String)
- [Method] Void Open(OSGeo.MapGuide.MgUserInformation)
- [Method] Void Open(System.String, OSGeo.MapGuide.MgUserInformation)
- [Method] Void RemoveConfigurationProperties(System.String, OSGeo.MapGuide.MgPropertyCollection)
- [Method] Void RenameLog(System.String, System.String)
- [Method] Void SetConfigurationProperties(System.String, OSGeo.MapGuide.MgPropertyCollection)
- [Method] Void SetDocument(System.String, OSGeo.MapGuide.MgByteReader)
- [Method] Void SetLogDelimiter(System.String)
- [Method] Void SetMaximumLogSize(Int32)
- [Method] Void TakeOffline()
-type OSGeo.MapGuide.MgSite : OSGeo.MapGuide.MgGuardDisposable
- [Method] Void AddGroup(System.String, System.String)
- [Method] Void AddServer(System.String, System.String, System.String)
- [Method] Void AddUser(System.String, System.String, System.String, System.String)
- [Method] System.String CreateSession()
- [Method] Void DeleteGroups(OSGeo.MapGuide.MgStringCollection)
- [Method] Void DeleteUsers(OSGeo.MapGuide.MgStringCollection)
- [Method] Void DestroySession(System.String)
- [Method] OSGeo.MapGuide.MgByteReader EnumerateGroups(System.String)
- [Method] OSGeo.MapGuide.MgByteReader EnumerateGroups()
- [Method] OSGeo.MapGuide.MgByteReader EnumerateGroups(System.String, System.String)
- [Method] OSGeo.MapGuide.MgStringCollection EnumerateRoles(System.String)
- [Method] OSGeo.MapGuide.MgStringCollection EnumerateRoles(System.String, System.String)
- [Method] OSGeo.MapGuide.MgByteReader EnumerateServers()
- [Method] OSGeo.MapGuide.MgByteReader EnumerateUsers(System.String, System.String, Boolean)
- [Method] OSGeo.MapGuide.MgByteReader EnumerateUsers(System.String)
- [Method] System.String GetCurrentSession()
- [Method] System.String GetCurrentSiteAddress()
- [Method] Int32 GetSessionTimeout()
- [Method] Int32 GetSiteServerCount()
- [Method] OSGeo.MapGuide.MgSiteInfo GetSiteServerInfo(Int32)
- [Method] System.String GetUserForSession()
- [Method] OSGeo.MapGuide.MgWarnings GetWarning()
- [Method] Void GrantGroupMembershipsToUsers(OSGeo.MapGuide.MgStringCollection, OSGeo.MapGuide.MgStringCollection)
- [Method] Void GrantRoleMembershipsToGroups(OSGeo.MapGuide.MgStringCollection, OSGeo.MapGuide.MgStringCollection)
- [Method] Void GrantRoleMembershipsToUsers(OSGeo.MapGuide.MgStringCollection, OSGeo.MapGuide.MgStringCollection)
- [Method] Void Open(OSGeo.MapGuide.MgUserInformation, OSGeo.MapGuide.MgSiteInfo)
- [Method] Void RemoveServer(System.String)
- [Method] Void RevokeGroupMembershipsFromUsers(OSGeo.MapGuide.MgStringCollection, OSGeo.MapGuide.MgStringCollection)
- [Method] Void RevokeRoleMembershipsFromGroups(OSGeo.MapGuide.MgStringCollection, OSGeo.MapGuide.MgStringCollection)
- [Method] Void RevokeRoleMembershipsFromUsers(OSGeo.MapGuide.MgStringCollection, OSGeo.MapGuide.MgStringCollection)
- [Method] Void UpdateGroup(System.String, System.String, System.String)
- [Method] Void UpdateServer(System.String, System.String, System.String, System.String)
- [Method] Void UpdateUser(System.String, System.String, System.String, System.String, System.String)
-type OSGeo.MapGuide.MgSiteConnection : OSGeo.MapGuide.MgGuardDisposable
- [Constructor] Void .ctor(System.String)
- [Method] OSGeo.MapGuide.MgService CreateService(Int32)
- [Method] OSGeo.MapGuide.MgSite GetSite()
-type OSGeo.MapGuide.MgSiteInfo : OSGeo.MapGuide.MgSerializable
- [Constructor] Void .ctor(System.String, Int32, Int32, Int32)
- [Method] Int32 GetPort(MgPortType)
- [Method] MgSiteStatus GetStatus()
- [Method] System.String GetTarget()
- [Method] Void SetStatus(MgSiteStatus)
-type OSGeo.MapGuide.MgTileService : OSGeo.MapGuide.MgService
- [Method] Void ClearCache(OSGeo.MapGuide.MgMap)
- [Method] Void ClearCache(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] Int32 GetDefaultTileSizeX()
- [Method] Int32 GetDefaultTileSizeX(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] Int32 GetDefaultTileSizeY()
- [Method] Int32 GetDefaultTileSizeY(OSGeo.MapGuide.MgResourceIdentifier)
- [Method] OSGeo.MapGuide.MgByteReader GetTile(OSGeo.MapGuide.MgMap, System.String, Int32, Int32)
- [Method] OSGeo.MapGuide.MgByteReader GetTile(OSGeo.MapGuide.MgResourceIdentifier, System.String, Int32, Int32, Int32)
- [Method] OSGeo.MapGuide.MgByteReader GetTileProviders()
-type OSGeo.MapGuide.MgUserInformation : OSGeo.MapGuide.MgSerializable
- [Method] System.String GetClientAgent()
- [Method] System.String GetClientIp()
- [Method] System.String GetLocale()
- [Method] OSGeo.MapGuide.MgByteReader GetReader()
- [Method] Void SetClientAgent(System.String)
- [Method] Void SetClientIp(System.String)
- [Method] Void SetLocale(System.String)
- [Method] Void SetMgSessionId(System.String)
- [Method] Void SetMgUsernamePassword(System.String, System.String)
-type OSGeo.MapGuide.MgMap+WatermarkUsageType : System.Enum
- implements System.IComparable
- implements System.ISpanFormattable
- implements System.IFormattable
- implements System.IConvertible
- [Field] Int32 value__
- [Field] WatermarkUsageType Viewer
- [Field] WatermarkUsageType WMS
-type OSGeo.MapGuide.MgSiteInfo+MgSiteStatus : System.Enum
- [Field] MgSiteStatus Ok
- [Field] MgSiteStatus TimedOut
- [Field] MgSiteStatus UnableToConnect
- [Field] MgSiteStatus Uninitialized
-type OSGeo.MapGuide.MgSiteInfo+MgPortType : System.Enum
- [Field] MgPortType Admin
- [Field] MgPortType Client
- [Field] MgPortType Site
-Assembly: OSGeo.MapGuide.Web, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null
-type OSGeo.MapGuide.MgWebActions : System.Object
- [Field] Int32 About
- [Field] Int32 Buffer
- [Field] Int32 Copy
- [Field] Int32 FitWindow
- [Field] Int32 GetPrintablePage
- [Field] Int32 Help
- [Field] Int32 InvokeScript
- [Field] Int32 InvokeUrl
- [Field] Int32 MapTip
- [Field] Int32 Measure
- [Field] Int32 Pan
- [Field] Int32 PanDown
- [Field] Int32 PanLeft
- [Field] Int32 PanRight
- [Field] Int32 PanUp
- [Field] Int32 PrintMap
- [Field] Int32 Refresh
- [Field] Int32 Search
- [Field] Int32 Select
- [Field] Int32 SelectClear
- [Field] Int32 SelectPolygon
- [Field] Int32 SelectRadius
- [Field] Int32 SelectWithin
- [Field] Int32 ViewNext
- [Field] Int32 ViewOptions
- [Field] Int32 ViewPrevious
- [Field] Int32 ViewRestore
- [Field] Int32 Zoom
- [Field] Int32 ZoomIn
- [Field] Int32 ZoomOut
- [Field] Int32 ZoomRectangle
- [Field] Int32 ZoomSelection
-type OSGeo.MapGuide.MgWebTargetType : System.Object
- [Field] Int32 NewWindow
- [Field] Int32 SpecifiedFrame
- [Field] Int32 TaskPane
-type OSGeo.MapGuide.MgWebTargetViewerType : System.Object
- [Field] Int32 Ajax
- [Field] Int32 All
- [Field] Int32 Dwf
-type OSGeo.MapGuide.MgWebTaskButtonType : System.Object
- [Field] Int32 Back
- [Field] Int32 Forward
- [Field] Int32 Home
- [Field] Int32 Tasks
-type OSGeo.MapGuide.MgWebWidgetType : System.Object
- [Field] Int32 Command
- [Field] Int32 Flyout
- [Field] Int32 Separator
- [Field] Int32 TaskButton
-type OSGeo.MapGuide.MapGuideApi : System.Object
- [Method] Void MgInitializeWebTier(System.String)
-type OSGeo.MapGuide.MgHttpHeader : OSGeo.MapGuide.MgGuardDisposable
- [Method] Boolean AddHeader(System.String, System.String)
- [Method] Int32 GetDateHeader(System.String)
- [Method] OSGeo.MapGuide.MgStringCollection GetHeaderNames()
- [Method] OSGeo.MapGuide.MgStringCollection GetHeaders(System.String)
- [Method] System.String GetHeaderValue(System.String)
- [Method] Int32 GetIntHeader(System.String)
- [Method] Boolean RemoveHeader(System.String)
- [Method] Boolean SetHeaderValue(System.String, System.String)
-type OSGeo.MapGuide.MgHttpPrimitiveValue : OSGeo.MapGuide.MgGuardDisposable
- [Constructor] Void .ctor(Boolean)
- [Constructor] Void .ctor(Int32)
- [Method] Boolean GetBoolValue()
- [Method] Int32 GetIntegerValue()
- [Method] System.String GetStringValue()
- [Method] Int32 GetType()
-type OSGeo.MapGuide.MgHttpRequest : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgHttpResponse Execute()
- [Method] System.String GetAgentUri()
- [Method] OSGeo.MapGuide.MgHttpHeader GetHeader()
- [Method] OSGeo.MapGuide.MgHttpRequestMetadata GetRequestMetadata()
- [Method] OSGeo.MapGuide.MgHttpRequestParam GetRequestParam()
-type OSGeo.MapGuide.MgHttpRequestMetadata : OSGeo.MapGuide.MgGuardDisposable
- [Method] Boolean AddProperty(System.String, System.String)
- [Method] OSGeo.MapGuide.MgStringCollection GetPropertyNames()
- [Method] System.String GetPropertyValue(System.String)
- [Method] Boolean RemoveProperty(System.String)
- [Method] Boolean SetPropertyValue(System.String, System.String)
-type OSGeo.MapGuide.MgHttpRequestParam : OSGeo.MapGuide.MgGuardDisposable
- [Method] Boolean AddParameter(System.String, System.String)
- [Method] Boolean ContainsParameter(System.String)
- [Method] OSGeo.MapGuide.MgStringCollection GetParameterNames()
- [Method] System.String GetParameterType(System.String)
- [Method] System.String GetParameterValue(System.String)
- [Method] Boolean RemoveParameter(System.String)
- [Method] Boolean SetParameterType(System.String, System.String)
- [Method] Boolean SetParameterValue(System.String, System.String)
-type OSGeo.MapGuide.MgHttpResponse : OSGeo.MapGuide.MgGuardDisposable
- [Method] OSGeo.MapGuide.MgHttpResult GetResult()
-type OSGeo.MapGuide.MgHttpResult : OSGeo.MapGuide.MgGuardDisposable
- [Method] System.String GetDetailedErrorMessage()
- [Method] System.String GetHttpStatusMessage()
- [Method] System.String GetResultContentType()
- [Method] OSGeo.MapGuide.MgDisposable GetResultObject()
- [Method] Int32 GetStatusCode()
- [Method] Void SetDetailedErrorMessage(System.String)
- [Method] Void SetHttpStatusMessage(System.String)
- [Method] Void SetResultObject(OSGeo.MapGuide.MgDisposable, System.String)
- [Method] Void SetStatusCode(Int32)
-type OSGeo.MapGuide.MgWebBufferCommand : OSGeo.MapGuide.MgWebUiTargetCommand
-type OSGeo.MapGuide.MgWebCommand : OSGeo.MapGuide.MgNamedSerializable
- [Method] Int32 GetAction()
- [Method] System.String GetDescription()
- [Method] System.String GetDisabledIconUrl()
- [Method] System.String GetIconUrl()
- [Method] System.String GetLabel()
- [Method] System.String GetName()
- [Method] Int32 GetTargetViewerType()
- [Method] Boolean IsUsed()
-type OSGeo.MapGuide.MgWebCommandCollection : OSGeo.MapGuide.MgGuardDisposable
- [Method] Boolean Contains(System.String)
- [Method] Boolean Contains(OSGeo.MapGuide.MgWebCommand)
- [Method] OSGeo.MapGuide.MgWebCommand GetItem(Int32)
- [Method] OSGeo.MapGuide.MgWebCommand GetItem(System.String)
- [Method] Int32 IndexOf(System.String)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgWebCommand)
-type OSGeo.MapGuide.MgWebCommandWidget : OSGeo.MapGuide.MgWebWidget
- [Method] OSGeo.MapGuide.MgWebCommand GetCommand()
-type OSGeo.MapGuide.MgWebContextMenu : OSGeo.MapGuide.MgWebWidgetCollection
- [Method] Boolean IsVisible()
-type OSGeo.MapGuide.MgWebFlyoutWidget : OSGeo.MapGuide.MgWebWidget
- [Method] OSGeo.MapGuide.MgWebWidgetCollection GetSubItems()
-type OSGeo.MapGuide.MgWebGetPrintablePageCommand : OSGeo.MapGuide.MgWebUiTargetCommand
-type OSGeo.MapGuide.MgWebHelpCommand : OSGeo.MapGuide.MgWebUiTargetCommand
- [Method] System.String GetUrl()
-type OSGeo.MapGuide.MgWebInformationPane : OSGeo.MapGuide.MgWebUiSizablePane
- [Method] Boolean IsLegendBandVisible()
- [Method] Boolean IsPropertiesBandVisible()
-type OSGeo.MapGuide.MgWebInvokeScriptCommand : OSGeo.MapGuide.MgWebUiTargetCommand
- [Method] System.String GetScriptCode()
-type OSGeo.MapGuide.MgWebInvokeUrlCommand : OSGeo.MapGuide.MgWebUiTargetCommand
- [Method] Boolean DisabledIfSelectionEmpty()
- [Method] Int32 GetLayerCount()
- [Method] System.String GetLayerNameAt(Int32)
- [Method] Int32 GetParameterCount()
- [Method] System.String GetParameterNameAt(Int32)
- [Method] System.String GetParameterValueAt(Int32)
-type OSGeo.MapGuide.MgWebLayout : OSGeo.MapGuide.MgGuardDisposable
- [Constructor] Void .ctor(OSGeo.MapGuide.MgResourceService, OSGeo.MapGuide.MgResourceIdentifier)
- [Method] System.String GetAjaxPreviewUrl()
- [Method] OSGeo.MapGuide.MgPoint GetCenter()
- [Method] OSGeo.MapGuide.MgWebCommandCollection GetCommands()
- [Method] OSGeo.MapGuide.MgWebContextMenu GetContextMenu()
- [Method] System.String GetDwfPreviewUrl()
- [Method] Boolean GetEnablePingServer()
- [Method] Int32 GetHyperlinkTarget()
- [Method] System.String GetHyperlinkTargetFrame()
- [Method] OSGeo.MapGuide.MgWebInformationPane GetInformationPane()
- [Method] System.String GetMapDefinition()
- [Method] System.String GetMapImageFormat()
- [Method] Int32 GetPointSelectionBuffer()
- [Method] System.String GetSelectionColor()
- [Method] System.String GetSelectionImageFormat()
- [Method] System.String GetStartupScript()
- [Method] OSGeo.MapGuide.MgWebUiPane GetStatusBar()
- [Method] OSGeo.MapGuide.MgWebTaskPane GetTaskPane()
- [Method] OSGeo.MapGuide.MgWebToolBar GetToolBar()
- [Method] Boolean IsZoomControlVisible()
- [Method] OSGeo.MapGuide.MgByteReader ProcessGettingStartedPage(OSGeo.MapGuide.MgByteReader, Boolean)
-type OSGeo.MapGuide.MgWebMeasureCommand : OSGeo.MapGuide.MgWebUiTargetCommand
-type OSGeo.MapGuide.MgWebPrintCommand : OSGeo.MapGuide.MgWebCommand
- [Method] System.String GetPrintLayoutAt(Int32)
- [Method] Int32 GetPrintLayoutCount()
-type OSGeo.MapGuide.MgWebSearchCommand : OSGeo.MapGuide.MgWebUiTargetCommand
- [Method] System.String GetColumnDisplayNameAt(Int32)
- [Method] System.String GetColumnPropertyNameAt(Int32)
- [Method] System.String GetFilter()
- [Method] System.String GetLayer()
- [Method] Int32 GetMatchLimit()
- [Method] System.String GetPrompt()
- [Method] Int32 GetResultColumnCount()
-type OSGeo.MapGuide.MgWebSelectWithinCommand : OSGeo.MapGuide.MgWebUiTargetCommand
-type OSGeo.MapGuide.MgWebSeparatorWidget : OSGeo.MapGuide.MgWebWidget
-type OSGeo.MapGuide.MgWebTaskBar : OSGeo.MapGuide.MgWebUiPane
- [Method] OSGeo.MapGuide.MgWebWidgetCollection GetTaskButtons()
- [Method] OSGeo.MapGuide.MgWebWidgetCollection GetTaskList()
-type OSGeo.MapGuide.MgWebTaskBarWidget : OSGeo.MapGuide.MgWebWidget
-type OSGeo.MapGuide.MgWebTaskPane : OSGeo.MapGuide.MgWebUiSizablePane
- [Method] System.String GetInitialTaskUrl()
- [Method] OSGeo.MapGuide.MgWebTaskBar GetTaskBar()
-type OSGeo.MapGuide.MgWebToolBar : OSGeo.MapGuide.MgWebUiPane
- [Method] OSGeo.MapGuide.MgWebWidgetCollection GetWidgets()
-type OSGeo.MapGuide.MgWebUiPane : OSGeo.MapGuide.MgGuardDisposable
-type OSGeo.MapGuide.MgWebUiSizablePane : OSGeo.MapGuide.MgWebUiPane
-type OSGeo.MapGuide.MgWebUiTargetCommand : OSGeo.MapGuide.MgWebCommand
- [Method] Int32 GetTarget()
- [Method] System.String GetTargetName()
-type OSGeo.MapGuide.MgWebViewOptionsCommand : OSGeo.MapGuide.MgWebUiTargetCommand
-type OSGeo.MapGuide.MgWebWidget : OSGeo.MapGuide.MgGuardDisposable
-type OSGeo.MapGuide.MgWebWidgetCollection : OSGeo.MapGuide.MgGuardDisposable
- [Method] Boolean Contains(OSGeo.MapGuide.MgWebWidget)
- [Method] OSGeo.MapGuide.MgWebWidget GetWidget(Int32)
- [Method] Int32 IndexOf(OSGeo.MapGuide.MgWebWidget)
+ÿþA s s e m b l y : O S G e o . M a p G u i d e . F o u n d a t i o n , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l +
+ t y p e O S G e o . M a p G u i d e . M g F e a t u r e P r o p e r t y T y p e : S y s t e m . O b j e c t +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( ) +
+ [ F i e l d ] I n t 3 2 A s s o c i a t i o n P r o p e r t y +
+ [ F i e l d ] I n t 3 2 D a t a P r o p e r t y +
+ [ F i e l d ] I n t 3 2 G e o m e t r i c P r o p e r t y +
+ [ F i e l d ] I n t 3 2 O b j e c t P r o p e r t y +
+ [ F i e l d ] I n t 3 2 R a s t e r P r o p e r t y +
+ t y p e O S G e o . M a p G u i d e . M g M i m e T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g A g f +
+ [ F i e l d ] S y s t e m . S t r i n g B i n a r y +
+ [ F i e l d ] S y s t e m . S t r i n g D w f +
+ [ F i e l d ] S y s t e m . S t r i n g G i f +
+ [ F i e l d ] S y s t e m . S t r i n g H t m l +
+ [ F i e l d ] S y s t e m . S t r i n g J p e g +
+ [ F i e l d ] S y s t e m . S t r i n g J s o n +
+ [ F i e l d ] S y s t e m . S t r i n g K m l +
+ [ F i e l d ] S y s t e m . S t r i n g K m z +
+ [ F i e l d ] S y s t e m . S t r i n g M e t a +
+ [ F i e l d ] S y s t e m . S t r i n g P n g +
+ [ F i e l d ] S y s t e m . S t r i n g T e x t +
+ [ F i e l d ] S y s t e m . S t r i n g T i f f +
+ [ F i e l d ] S y s t e m . S t r i n g X m l +
+ t y p e O S G e o . M a p G u i d e . M g P r o p e r t y T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 B l o b +
+ [ F i e l d ] I n t 3 2 B o o l e a n +
+ [ F i e l d ] I n t 3 2 B y t e +
+ [ F i e l d ] I n t 3 2 C l o b +
+ [ F i e l d ] I n t 3 2 D a t e T i m e +
+ [ F i e l d ] I n t 3 2 D e c i m a l +
+ [ F i e l d ] I n t 3 2 D o u b l e +
+ [ F i e l d ] I n t 3 2 F e a t u r e +
+ [ F i e l d ] I n t 3 2 G e o m e t r y +
+ [ F i e l d ] I n t 3 2 I n t 1 6 +
+ [ F i e l d ] I n t 3 2 I n t 3 2 +
+ [ F i e l d ] I n t 3 2 I n t 6 4 +
+ [ F i e l d ] I n t 3 2 N u l l +
+ [ F i e l d ] I n t 3 2 R a s t e r +
+ [ F i e l d ] I n t 3 2 S i n g l e +
+ [ F i e l d ] I n t 3 2 S t r i n g +
+ t y p e O S G e o . M a p G u i d e . M g E x c e p t i o n C o d e s : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g M g A l l P r o v i d e r C o n n e c t i o n s U s e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g A r g u m e n t O u t O f R a n g e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g A r r a y T y p e M i s m a t c h E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g A u t h e n t i c a t i o n F a i l e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g C l a s s N o t F o u n d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g C o n f i g u r a t i o n E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g C o n f i g u r a t i o n L o a d F a i l e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g C o n f i g u r a t i o n S a v e F a i l e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g C o n n e c t i o n F a i l e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g C o n n e c t i o n N o t O p e n E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g C o o r d i n a t e S y s t e m C o m p u t a t i o n F a i l e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g C o o r d i n a t e S y s t e m C o n v e r s i o n F a i l e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g C o o r d i n a t e S y s t e m I n i t i a l i z a t i o n F a i l e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g C o o r d i n a t e S y s t e m L o a d F a i l e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g C o o r d i n a t e S y s t e m M e a s u r e F a i l e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g C o o r d i n a t e S y s t e m T r a n s f o r m F a i l e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D a t e T i m e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D b E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D b X m l E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D e c r y p t i o n E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D i r e c t o r y N o t F o u n d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D i v i d e B y Z e r o E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D o m a i n E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D u p l i c a t e D i r e c t o r y E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D u p l i c a t e F i l e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D u p l i c a t e G r o u p E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D u p l i c a t e N a m e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D u p l i c a t e O b j e c t E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D u p l i c a t e P a r a m e t e r E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D u p l i c a t e R e p o s i t o r y E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D u p l i c a t e R e s o u r c e D a t a E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D u p l i c a t e R e s o u r c e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D u p l i c a t e R o l e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D u p l i c a t e S e r v e r E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D u p l i c a t e S e s s i o n E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D u p l i c a t e U s e r E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D w f E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D w f S e c t i o n N o t F o u n d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g D w f S e c t i o n R e s o u r c e N o t F o u n d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g E m p t y F e a t u r e S e t E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g E n c r y p t i o n E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g E n d O f S t r e a m E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g E v a l u a t i o n E x p i r e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g F d o E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g F e a t u r e S e r v i c e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g F i l e I o E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g F i l e N o t F o u n d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g G e o m e t r y E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g G r i d D e n s i t y E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g G r o u p N o t F o u n d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n d e x O u t O f R a n g e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d A r g u m e n t E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d C a s t E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d C o o r d i n a t e S y s t e m E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d C o o r d i n a t e S y s t e m T y p e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d C o o r d i n a t e S y s t e m U n i t s E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d D w f P a c k a g e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d D w f S e c t i o n E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d F e a t u r e S o u r c e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d I p A d d r e s s E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d L a y e r D e f i n i t i o n E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d L i c e n s e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d L o g E n t r y E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d M a p D e f i n i t i o n E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d M i m e T y p e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d O p e r a t i o n E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d O p e r a t i o n V e r s i o n E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d P a s s w o r d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d P r i n t L a y o u t F o n t S i z e U n i t s E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d P r i n t L a y o u t P o s i t i o n U n i t s E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d P r i n t L a y o u t S i z e U n i t s E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d P r o p e r t y T y p e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d R e p o s i t o r y N a m e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d R e p o s i t o r y T y p e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d R e s o u r c e D a t a N a m e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d R e s o u r c e D a t a T y p e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d R e s o u r c e N a m e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d R e s o u r c e P a t h E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d R e s o u r c e P r e P r o c e s s i n g T y p e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d R e s o u r c e T y p e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d S e r i a l N u m b e r E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d S e r v e r N a m e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d S t r e a m H e a d e r E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I n v a l i d W a t e r m a r k D e f i n i t i o n E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g I o E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g L a y e r N o t F o u n d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g L e n g t h E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g L i c e n s e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g L i c e n s e E x p i r e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g L o g i c E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g L o g O p e n F a i l e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g N o t F i n i t e N u m b e r E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g N o t I m p l e m e n t e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g N u l l A r g u m e n t E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g N u l l P r o p e r t y V a l u e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g N u l l R e f e r e n c e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g O b j e c t N o t F o u n d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g O p e r a t i o n P r o c e s s i n g E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g O u t O f M e m o r y E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g O u t O f R a n g e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g O v e r f l o w E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g P a r a m e t e r N o t F o u n d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g P a t h T o o L o n g E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g P e r m i s s i o n D e n i e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g P l a t f o r m N o t S u p p o r t e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g P o r t N o t A v a i l a b l e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g P r i n t T o S c a l e M o d e N o t S e l e c t e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g R a s t e r T r a n s f o r m a t i o n N o t S u p p o r t e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g R e p o s i t o r y C r e a t i o n F a i l e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g R e p o s i t o r y N o t F o u n d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g R e p o s i t o r y N o t O p e n E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g R e p o s i t o r y O p e n F a i l e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g R e s o u r c e B u s y E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g R e s o u r c e D a t a N o t F o u n d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g R e s o u r c e N o t F o u n d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g R e s o u r c e s E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g R e s o u r c e s L o a d F a i l e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g R e s o u r c e T a g N o t F o u n d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g R o l e N o t F o u n d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g R u n t i m e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g S e r v e r N o t F o u n d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g S e r v e r N o t O n l i n e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g S e r v i c e N o t A v a i l a b l e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g S e r v i c e N o t S u p p o r t e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g S e s s i o n E x p i r e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g S e s s i o n N o t F o u n d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g S t r e a m I o E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g S t y l i z e L a y e r F a i l e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g T e m p o r a r y F i l e N o t A v a i l a b l e E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g U n a u t h o r i z e d A c c e s s E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g U n c l a s s i f i e d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g U n d e r f l o w E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g U n k n o w n T i l e P r o v i d e r E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g U n s u p p o r t e d P r o v i d e r T h r e a d M o d e l E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g U n s u p p o r t e d T i l e P r o v i d e r E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g U r i F o r m a t E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g U s e r N o t F o u n d E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g X m l E x c e p t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M g X m l P a r s e r E x c e p t i o n +
+ t y p e O S G e o . M a p G u i d e . M a n a g e d E x c e p t i o n : S y s t e m . E x c e p t i o n +
+ i m p l e m e n t s S y s t e m . R u n t i m e . S e r i a l i z a t i o n . I S e r i a l i z a b l e +
+ i m p l e m e n t s S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . _ E x c e p t i o n +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ M e s s a g e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ S t a c k T r a c e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g T o S t r i n g ( ) +
+ [ S y s t e m . R e f l e c t i o n . D e f a u l t M e m b e r A t t r i b u t e ] +
+ t y p e O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n : O S G e o . M a p G u i d e . M g C o l l e c t i o n +
+ i m p l e m e n t s S y s t e m . I D i s p o s a b l e +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ S y s t e m . S t r i n g , m s c o r l i b , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = b 7 7 a 5 c 5 6 1 9 3 4 e 0 8 9 ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ S y s t e m . S t r i n g , m s c o r l i b , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = b 7 7 a 5 c 5 6 1 9 3 4 e 0 8 9 ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ S y s t e m . S t r i n g , m s c o r l i b , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = b 7 7 a 5 c 5 6 1 9 3 4 e 0 8 9 ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . I E n u m e r a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ S y s t e m . S t r i n g ] ) +
+ [ M e t h o d ] V o i d A d d ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d C l e a r ( ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d C o p y T o ( S y s t e m . S t r i n g [ ] , I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 g e t _ C o u n t ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ I s R e a d O n l y ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t C o u n t ( ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ S y s t e m . S t r i n g ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d R e m o v e A t ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r T o X m l ( ) +
+ t y p e O S G e o . M a p G u i d e . R e a d O n l y R e w i n d a b l e S t r e a m : S y s t e m . I O . S t r e a m +
+ [ M e t h o d ] B o o l e a n g e t _ C a n R e a d ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ C a n R e w i n d ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ C a n S e e k ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ C a n W r i t e ( ) +
+ [ M e t h o d ] I n t 6 4 g e t _ P o s i t i o n ( ) +
+ [ M e t h o d ] V o i d R e w i n d ( ) +
+ [ M e t h o d ] I n t 6 4 S e e k ( I n t 6 4 , S y s t e m . I O . S e e k O r i g i n ) +
+ [ M e t h o d ] V o i d s e t _ P o s i t i o n ( I n t 6 4 ) +
+ [ M e t h o d ] V o i d S e t L e n g t h ( I n t 6 4 ) +
+ [ M e t h o d ] V o i d W r i t e ( B y t e [ ] , I n t 3 2 , I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . G e t B y t e R e a d e r M e t h o d : S y s t e m . M u l t i c a s t D e l e g a t e +
+ i m p l e m e n t s S y s t e m . I C l o n e a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . O b j e c t , I n t P t r ) +
+ [ M e t h o d ] S y s t e m . I A s y n c R e s u l t B e g i n I n v o k e ( S y s t e m . A s y n c C a l l b a c k , S y s t e m . O b j e c t ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r E n d I n v o k e ( S y s t e m . I A s y n c R e s u l t ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r I n v o k e ( ) +
+ t y p e O S G e o . M a p G u i d e . M g R e a d O n l y S t r e a m : O S G e o . M a p G u i d e . R e a d O n l y R e w i n d a b l e S t r e a m +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g B y t e R e a d e r ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . G e t B y t e R e a d e r M e t h o d ) +
+ [ M e t h o d ] V o i d F l u s h ( ) +
+ [ M e t h o d ] I n t 6 4 g e t _ L e n g t h ( ) +
+ [ M e t h o d ] I n t 3 2 R e a d ( B y t e [ ] , I n t 3 2 , I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n : O S G e o . M a p G u i d e . M g C o l l e c t i o n +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n , O S G e o . M a p G u i d e . F o u n d a t i o n , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n , O S G e o . M a p G u i d e . F o u n d a t i o n , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n , O S G e o . M a p G u i d e . F o u n d a t i o n , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n [ ] , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ) +
+ t y p e O S G e o . M a p G u i d e . M g B y t e R e a d e r : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , S y s t e m . S t r i n g , B o o l e a n ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( B y t e [ ] , I n t 3 2 , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ M i m e T y p e ( ) +
+ [ M e t h o d ] S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f g e t C P t r ( O S G e o . M a p G u i d e . M g B y t e R e a d e r ) +
+ [ M e t h o d ] I n t 6 4 G e t L e n g t h ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t M i m e T y p e ( ) +
+ [ M e t h o d ] B o o l e a n I s R e w i n d a b l e ( ) +
+ [ M e t h o d ] I n t 3 2 R e a d ( B y t e [ ] , I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f s w i g R e l e a s e ( O S G e o . M a p G u i d e . M g B y t e R e a d e r ) +
+ [ M e t h o d ] V o i d T o F i l e ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g B y t e S i n k : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ t y p e O S G e o . M a p G u i d e . M g B y t e S o u r c e : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( B y t e [ ] , I n t 3 2 ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t R e a d e r ( ) +
+ [ M e t h o d ] V o i d s e t _ M i m e T y p e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t M i m e T y p e ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g C o l l e c t i o n : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ M e t h o d ] S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f g e t C P t r ( O S G e o . M a p G u i d e . M g C o l l e c t i o n ) +
+ [ M e t h o d ] S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f s w i g R e l e a s e ( O S G e o . M a p G u i d e . M g C o l l e c t i o n ) +
+ t y p e O S G e o . M a p G u i d e . M g D a t e T i m e : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( I n t 1 6 , I n t 1 6 , I n t 1 6 ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( I n t 1 6 , I n t 1 6 , I n t 1 6 , I n t 3 2 ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( I n t 1 6 , I n t 1 6 , I n t 1 6 , I n t 1 6 , I n t 1 6 , I n t 1 6 , I n t 3 2 ) +
+ [ M e t h o d ] I n t 1 6 g e t _ D a y ( ) +
+ [ M e t h o d ] I n t 1 6 g e t _ H o u r ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ M i c r o s e c o n d ( ) +
+ [ M e t h o d ] I n t 1 6 g e t _ M i n u t e ( ) +
+ [ M e t h o d ] I n t 1 6 g e t _ M o n t h ( ) +
+ [ M e t h o d ] I n t 1 6 g e t _ S e c o n d ( ) +
+ [ M e t h o d ] I n t 1 6 g e t _ Y e a r ( ) +
+ [ M e t h o d ] I n t 1 6 G e t D a y ( ) +
+ [ M e t h o d ] I n t 1 6 G e t H o u r ( ) +
+ [ M e t h o d ] I n t 3 2 G e t M i c r o s e c o n d ( ) +
+ [ M e t h o d ] I n t 1 6 G e t M i n u t e ( ) +
+ [ M e t h o d ] I n t 1 6 G e t M o n t h ( ) +
+ [ M e t h o d ] I n t 1 6 G e t S e c o n d ( ) +
+ [ M e t h o d ] I n t 1 6 G e t Y e a r ( ) +
+ [ M e t h o d ] B o o l e a n I s D a t e ( ) +
+ [ M e t h o d ] B o o l e a n I s D a t e T i m e ( ) +
+ [ M e t h o d ] B o o l e a n I s T i m e ( ) +
+ [ M e t h o d ] V o i d s e t _ D a y ( I n t 1 6 ) +
+ [ M e t h o d ] V o i d s e t _ H o u r ( I n t 1 6 ) +
+ [ M e t h o d ] V o i d s e t _ M i c r o s e c o n d ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d s e t _ M i n u t e ( I n t 1 6 ) +
+ [ M e t h o d ] V o i d s e t _ M o n t h ( I n t 1 6 ) +
+ [ M e t h o d ] V o i d s e t _ S e c o n d ( I n t 1 6 ) +
+ [ M e t h o d ] V o i d s e t _ Y e a r ( I n t 1 6 ) +
+ [ M e t h o d ] V o i d S e t D a y ( I n t 1 6 ) +
+ [ M e t h o d ] V o i d S e t H o u r ( I n t 1 6 ) +
+ [ M e t h o d ] V o i d S e t M i c r o s e c o n d ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t M i n u t e ( I n t 1 6 ) +
+ [ M e t h o d ] V o i d S e t M o n t h ( I n t 1 6 ) +
+ [ M e t h o d ] V o i d S e t S e c o n d ( I n t 1 6 ) +
+ [ M e t h o d ] V o i d S e t Y e a r ( I n t 1 6 ) +
+ [ M e t h o d ] V o i d V a l i d a t e ( ) +
+ t y p e O S G e o . M a p G u i d e . M g D i s p o s a b l e : O S G e o . M a p G u i d e . M g O b j e c t +
+ [ M e t h o d ] S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f g e t C P t r ( O S G e o . M a p G u i d e . M g D i s p o s a b l e ) +
+ [ M e t h o d ] S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f s w i g R e l e a s e ( O S G e o . M a p G u i d e . M g D i s p o s a b l e ) +
+ t y p e O S G e o . M a p G u i d e . M g D i s p o s a b l e C o l l e c t i o n : O S G e o . M a p G u i d e . M g C o l l e c t i o n +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g D i s p o s a b l e ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g D i s p o s a b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D i s p o s a b l e G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g D i s p o s a b l e ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g D i s p o s a b l e ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g D i s p o s a b l e ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g D i s p o s a b l e ) +
+ t y p e O S G e o . M a p G u i d e . M g E x c e p t i o n : O S G e o . M a p G u i d e . M a n a g e d E x c e p t i o n +
+ [ M e t h o d ] V o i d A d d S t a c k T r a c e I n f o ( S y s t e m . S t r i n g , S y s t e m . S t r i n g , I n t 3 2 , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d A d d S t a c k T r a c e I n f o ( S y s t e m . S t r i n g , I n t 3 2 , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d D i s p o s e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D e t a i l s ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D e t a i l s ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t E x c e p t i o n C o d e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t E x c e p t i o n M e s s a g e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t E x c e p t i o n M e s s a g e ( ) +
+ [ M e t h o d ] I n t 6 4 G e t N a t i v e E r r o r C o d e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S t a c k T r a c e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S t a c k T r a c e ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e : O S G e o . M a p G u i d e . M g D i s p o s a b l e +
+ [ M e t h o d ] S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f g e t C P t r ( O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e ) +
+ [ M e t h o d ] S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f s w i g R e l e a s e ( O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e ) +
+ t y p e O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ M e t h o d ] S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f g e t C P t r ( O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e ) +
+ [ M e t h o d ] S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f s w i g R e l e a s e ( O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e ) +
+ t y p e O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y : O S G e o . M a p G u i d e . M g P r o p e r t y +
+ [ M e t h o d ] S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f g e t C P t r ( O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y ) +
+ [ M e t h o d ] B o o l e a n I s N u l l ( ) +
+ [ M e t h o d ] V o i d S e t N u l l ( B o o l e a n ) +
+ [ M e t h o d ] S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f s w i g R e l e a s e ( O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y ) +
+ t y p e O S G e o . M a p G u i d e . M g O b j e c t : S y s t e m . O b j e c t +
+ t y p e O S G e o . M a p G u i d e . M g P r o p e r t y : O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ N a m e ( ) +
+ [ M e t h o d ] I n t 1 6 g e t _ P r o p e r t y T y p e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t N a m e ( ) +
+ [ M e t h o d ] I n t 1 6 G e t P r o p e r t y T y p e ( ) +
+ [ M e t h o d ] V o i d s e t _ N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t N a m e ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n : O S G e o . M a p G u i d e . M g C o l l e c t i o n +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y , O S G e o . M a p G u i d e . F o u n d a t i o n , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y , O S G e o . M a p G u i d e . F o u n d a t i o n , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y , O S G e o . M a p G u i d e . F o u n d a t i o n , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g P r o p e r t y ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g P r o p e r t y ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g P r o p e r t y [ ] , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g P r o p e r t y ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y G e t I t e m ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g P r o p e r t y ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g P r o p e r t y ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g P r o p e r t y ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g P r o p e r t y ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g P r o p e r t y ) +
+ t y p e O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n : O S G e o . M a p G u i d e . M g P r o p e r t y +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , I n t 1 6 ) +
+ [ M e t h o d ] V o i d D e l e t e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ D e s c r i p t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ Q u a l i f i e d N a m e ( ) +
+ [ M e t h o d ] S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f g e t C P t r ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D e s c r i p t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t Q u a l i f i e d N a m e ( ) +
+ [ M e t h o d ] V o i d s e t _ D e s c r i p t i o n ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ Q u a l i f i e d N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t D e s c r i p t i o n ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t Q u a l i f i e d N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f s w i g R e l e a s e ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n ) +
+ t y p e O S G e o . M a p G u i d e . M g S e r i a l i z a b l e : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f g e t C P t r ( O S G e o . M a p G u i d e . M g S e r i a l i z a b l e ) +
+ [ M e t h o d ] S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f s w i g R e l e a s e ( O S G e o . M a p G u i d e . M g S e r i a l i z a b l e ) +
+ t y p e O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y : O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ V a l u e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t V a l u e ( ) +
+ [ M e t h o d ] V o i d S e t V a l u e ( S y s t e m . S t r i n g ) +
+ A s s e m b l y : O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e D i m e n s i o n : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 M +
+ [ F i e l d ] I n t 3 2 X Y +
+ [ F i e l d ] I n t 3 2 X Y Z +
+ t y p e O S G e o . M a p G u i d e . M g G e o m e t r y E n t i t y T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 G e o m e t r y C o m p o n e n t +
+ t y p e O S G e o . M a p G u i d e . M g G e o m e t r i c P a t h I n s t r u c t i o n T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 C l o s e +
+ [ F i e l d ] I n t 3 2 L i n e T o +
+ [ F i e l d ] I n t 3 2 M o v e T o +
+ [ F i e l d ] I n t 3 2 Q u a d T o +
+ t y p e O S G e o . M a p G u i d e . M g G e o m e t r y C o m p o n e n t T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 A r c S e g m e n t +
+ [ F i e l d ] I n t 3 2 C u r v e R i n g +
+ [ F i e l d ] I n t 3 2 L i n e a r R i n g +
+ [ F i e l d ] I n t 3 2 L i n e a r S e g m e n t +
+ t y p e O S G e o . M a p G u i d e . M g G e o m e t r y T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 C u r v e P o l y g o n +
+ [ F i e l d ] I n t 3 2 C u r v e S t r i n g +
+ [ F i e l d ] I n t 3 2 L i n e S t r i n g +
+ [ F i e l d ] I n t 3 2 M u l t i C u r v e P o l y g o n +
+ [ F i e l d ] I n t 3 2 M u l t i C u r v e S t r i n g +
+ [ F i e l d ] I n t 3 2 M u l t i G e o m e t r y +
+ [ F i e l d ] I n t 3 2 M u l t i L i n e S t r i n g +
+ [ F i e l d ] I n t 3 2 M u l t i P o i n t +
+ [ F i e l d ] I n t 3 2 M u l t i P o l y g o n +
+ [ F i e l d ] I n t 3 2 P o i n t +
+ [ F i e l d ] I n t 3 2 P o l y g o n +
+ t y p e O S G e o . M a p G u i d e . M g G e o m e t r y S i m p l i f i c a t i o n A l g o r i t h m T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 D o u g l a s P e u c k e r +
+ [ F i e l d ] I n t 3 2 T o p o l o g y P r e s e r v i n g +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C o d e F o r m a t : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 E p s g +
+ [ F i e l d ] I n t 3 2 M e n t o r +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E r r o r C o d e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 A F F Z E R O +
+ [ F i e l d ] I n t 3 2 A Z M +
+ [ F i e l d ] I n t 3 2 A Z M T H +
+ [ F i e l d ] I n t 3 2 C o n v e r s i o n F a i l e d +
+ [ F i e l d ] I n t 3 2 C R T M M +
+ [ F i e l d ] I n t 3 2 D E N R G N +
+ [ F i e l d ] I n t 3 2 E L E V E L +
+ [ F i e l d ] I n t 3 2 G E O M M +
+ [ F i e l d ] I n t 3 2 H M I S P H R +
+ [ F i e l d ] I n t 3 2 I n i t i a l i z a t i o n F a i l e d +
+ [ F i e l d ] I n t 3 2 I n v a l i d A r g u m e n t +
+ [ F i e l d ] I n t 3 2 I N V D T M +
+ [ F i e l d ] I n t 3 2 I N V E L P +
+ [ F i e l d ] I n t 3 2 I N V P R J +
+ [ F i e l d ] I n t 3 2 I N V Q U A D +
+ [ F i e l d ] I n t 3 2 L A T +
+ [ F i e l d ] I n t 3 2 L A T E Q U +
+ [ F i e l d ] I n t 3 2 L L R N G +
+ [ F i e l d ] I n t 3 2 L N G +
+ [ F i e l d ] I n t 3 2 L N G E Q U +
+ [ F i e l d ] I n t 3 2 M A P S C L +
+ [ F i e l d ] I n t 3 2 M A X 1 5 +
+ [ F i e l d ] I n t 3 2 M E R E Q U +
+ [ F i e l d ] I n t 3 2 M R C A T +
+ [ F i e l d ] I n t 3 2 M S C O E F +
+ [ F i e l d ] I n t 3 2 N O R E F +
+ [ F i e l d ] I n t 3 2 N O T N R T H +
+ [ F i e l d ] I n t 3 2 N R D A T U M +
+ [ F i e l d ] I n t 3 2 N R T H L A T +
+ [ F i e l d ] I n t 3 2 N R T H P N T +
+ [ F i e l d ] I n t 3 2 N u l l A r g u m e n t +
+ [ F i e l d ] I n t 3 2 O B L Q P O L E +
+ [ F i e l d ] I n t 3 2 O k +
+ [ F i e l d ] I n t 3 2 O R G L A T +
+ [ F i e l d ] I n t 3 2 O R G L N G +
+ [ F i e l d ] I n t 3 2 O S T N 0 2 +
+ [ F i e l d ] I n t 3 2 O S T N 9 7 +
+ [ F i e l d ] I n t 3 2 O u t O f M e m o r y +
+ [ F i e l d ] I n t 3 2 P L L 9 0 +
+ [ F i e l d ] I n t 3 2 P L L E D +
+ [ F i e l d ] I n t 3 2 P L L E Q U +
+ [ F i e l d ] I n t 3 2 P L L L R G +
+ [ F i e l d ] I n t 3 2 P L L R E V +
+ [ F i e l d ] I n t 3 2 P L L Z E R O +
+ [ F i e l d ] I n t 3 2 P L R L A T +
+ [ F i e l d ] I n t 3 2 P O L D D +
+ [ F i e l d ] I n t 3 2 P O L D U P +
+ [ F i e l d ] I n t 3 2 P O L L A T +
+ [ F i e l d ] I n t 3 2 P O L L N G +
+ [ F i e l d ] I n t 3 2 Q U A D +
+ [ F i e l d ] I n t 3 2 R N G O R D +
+ [ F i e l d ] I n t 3 2 S C L R E D +
+ [ F i e l d ] I n t 3 2 S O T H L A T +
+ [ F i e l d ] I n t 3 2 S T D L A T +
+ [ F i e l d ] I n t 3 2 S T D L N G +
+ [ F i e l d ] I n t 3 2 S T D P L L +
+ [ F i e l d ] I n t 3 2 S T D S O U +
+ [ F i e l d ] I n t 3 2 S T D W E S T +
+ [ F i e l d ] I n t 3 2 T M K R G 0 +
+ [ F i e l d ] I n t 3 2 U N I T +
+ [ F i e l d ] I n t 3 2 U S E P L R +
+ [ F i e l d ] I n t 3 2 U S E S W +
+ [ F i e l d ] I n t 3 2 U T M Z O N +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n M e t h o d : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 A G D 6 6 +
+ [ F i e l d ] I n t 3 2 A G D 8 4 +
+ [ F i e l d ] I n t 3 2 A T S 7 7 +
+ [ F i e l d ] I n t 3 2 B u r s a +
+ [ F i e l d ] I n t 3 2 C H E N Y X +
+ [ F i e l d ] I n t 3 2 C S R S +
+ [ F i e l d ] I n t 3 2 D H D N +
+ [ F i e l d ] I n t 3 2 E D 5 0 +
+ [ F i e l d ] I n t 3 2 E T R F 8 9 +
+ [ F i e l d ] I n t 3 2 F o u r P a r a m e t e r +
+ [ F i e l d ] I n t 3 2 G D A 9 4 +
+ [ F i e l d ] I n t 3 2 G e o c e n t r i c +
+ [ F i e l d ] I n t 3 2 H P G N +
+ [ F i e l d ] I n t 3 2 L c l g r f +
+ [ F i e l d ] I n t 3 2 M o l o d e n s k y +
+ [ F i e l d ] I n t 3 2 M R e g +
+ [ F i e l d ] I n t 3 2 N A D 2 7 +
+ [ F i e l d ] I n t 3 2 N A D 8 3 +
+ [ F i e l d ] I n t 3 2 N o n e +
+ [ F i e l d ] I n t 3 2 N Z G D 2 K +
+ [ F i e l d ] I n t 3 2 N Z G D 4 9 +
+ [ F i e l d ] I n t 3 2 R G F 9 3 +
+ [ F i e l d ] I n t 3 2 S e v e n P a r a m e t e r +
+ [ F i e l d ] I n t 3 2 S i x P a r a m e t e r +
+ [ F i e l d ] I n t 3 2 T h r e e P a r a m e t e r +
+ [ F i e l d ] I n t 3 2 T O K Y O +
+ [ F i e l d ] I n t 3 2 W G S 7 2 +
+ [ F i e l d ] I n t 3 2 W G S 8 4 +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d O r i e n t a t i o n : S y s t e m . O b j e c t +
+ [ F i e l d ] B y t e E a s t W e s t +
+ [ F i e l d ] B y t e N o n e +
+ [ F i e l d ] B y t e N o r t h S o u t h +
+ [ F i e l d ] B y t e U n k n o w n +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i a l i z a t i o n T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 G e n e r i c +
+ [ F i e l d ] I n t 3 2 M G R S +
+ [ F i e l d ] I n t 3 2 U n k n o w n +
+ [ F i e l d ] I n t 3 2 U S N G +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M g r s G r i d L e v e l : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 M g r s 1 0 0 K m +
+ [ F i e l d ] I n t 3 2 M g r s 1 0 0 m +
+ [ F i e l d ] I n t 3 2 M g r s 1 0 K m +
+ [ F i e l d ] I n t 3 2 M g r s 1 0 m +
+ [ F i e l d ] I n t 3 2 M g r s 1 K m +
+ [ F i e l d ] I n t 3 2 M g r s 1 m +
+ [ F i e l d ] I n t 3 2 M g r s N o n e +
+ [ F i e l d ] I n t 3 2 M g r s U n k n o w n +
+ [ F i e l d ] I n t 3 2 M g r s U p s +
+ [ F i e l d ] I n t 3 2 M g r s U t m +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M g r s L e t t e r i n g S c h e m e : S y s t e m . O b j e c t +
+ [ F i e l d ] B y t e A l t e r n a t i v e +
+ [ F i e l d ] B y t e N o r m a l +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M g r s G r i d S q u a r e P o s i t i o n : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 C e n t e r +
+ [ F i e l d ] I n t 3 2 E a s t +
+ [ F i e l d ] I n t 3 2 N o r t h +
+ [ F i e l d ] I n t 3 2 N o r t h E a s t +
+ [ F i e l d ] I n t 3 2 N o r t h W e s t +
+ [ F i e l d ] I n t 3 2 S o u t h +
+ [ F i e l d ] I n t 3 2 S o u t h E a s t +
+ [ F i e l d ] I n t 3 2 S o u t h W e s t +
+ [ F i e l d ] I n t 3 2 W e s t +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n C o d e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 A l b e r +
+ [ F i e l d ] I n t 3 2 A z e d e +
+ [ F i e l d ] I n t 3 2 A z m e a +
+ [ F i e l d ] I n t 3 2 A z m e d +
+ [ F i e l d ] I n t 3 2 B i p o l a r +
+ [ F i e l d ] I n t 3 2 B o n n e +
+ [ F i e l d ] I n t 3 2 C a s s i n i +
+ [ F i e l d ] I n t 3 2 E c k e r t 4 +
+ [ F i e l d ] I n t 3 2 E c k e r t 6 +
+ [ F i e l d ] I n t 3 2 E d c n c +
+ [ F i e l d ] I n t 3 2 E d c y l +
+ [ F i e l d ] I n t 3 2 E d c y l E +
+ [ F i e l d ] I n t 3 2 G a u s s K +
+ [ F i e l d ] I n t 3 2 G n o m o n i c +
+ [ F i e l d ] I n t 3 2 G o o d e +
+ [ F i e l d ] I n t 3 2 H o m 1 u v +
+ [ F i e l d ] I n t 3 2 H o m 1 x y +
+ [ F i e l d ] I n t 3 2 H o m 2 u v +
+ [ F i e l d ] I n t 3 2 H o m 2 x y +
+ [ F i e l d ] I n t 3 2 K r o v a k +
+ [ F i e l d ] I n t 3 2 K r v k 9 5 +
+ [ F i e l d ] I n t 3 2 L L +
+ [ F i e l d ] I n t 3 2 L m 1 s p +
+ [ F i e l d ] I n t 3 2 L m 2 s p +
+ [ F i e l d ] I n t 3 2 L m b l g +
+ [ F i e l d ] I n t 3 2 L m b r t a f +
+ [ F i e l d ] I n t 3 2 L m M i c h +
+ [ F i e l d ] I n t 3 2 L m t a n +
+ [ F i e l d ] I n t 3 2 M i l l e r +
+ [ F i e l d ] I n t 3 2 M n d o t l +
+ [ F i e l d ] I n t 3 2 M n d o t t +
+ [ F i e l d ] I n t 3 2 M o d p c +
+ [ F i e l d ] I n t 3 2 M o l l w e i d +
+ [ F i e l d ] I n t 3 2 M r c a t +
+ [ F i e l d ] I n t 3 2 M r c a t K +
+ [ F i e l d ] I n t 3 2 M s t e r o +
+ [ F i e l d ] I n t 3 2 N e a c y l +
+ [ F i e l d ] I n t 3 2 N e r t h +
+ [ F i e l d ] I n t 3 2 N r t h s r t +
+ [ F i e l d ] I n t 3 2 N z e a l a n d +
+ [ F i e l d ] I n t 3 2 O b l q M +
+ [ F i e l d ] I n t 3 2 O b q c y l +
+ [ F i e l d ] I n t 3 2 O r t h o +
+ [ F i e l d ] I n t 3 2 O s t n 0 2 +
+ [ F i e l d ] I n t 3 2 O s t n 9 7 +
+ [ F i e l d ] I n t 3 2 O s t r o +
+ [ F i e l d ] I n t 3 2 P l a t e C a r r e e +
+ [ F i e l d ] I n t 3 2 P l y c n +
+ [ F i e l d ] I n t 3 2 P s t r o +
+ [ F i e l d ] I n t 3 2 P s t r o s l +
+ [ F i e l d ] I n t 3 2 P v M e r c a t o r +
+ [ F i e l d ] I n t 3 2 R o b i n s o n +
+ [ F i e l d ] I n t 3 2 R s k e w +
+ [ F i e l d ] I n t 3 2 R s k e w c +
+ [ F i e l d ] I n t 3 2 R s k e w o +
+ [ F i e l d ] I n t 3 2 S i n u s +
+ [ F i e l d ] I n t 3 2 S o t r m +
+ [ F i e l d ] I n t 3 2 S s t r o +
+ [ F i e l d ] I n t 3 2 S w i s s +
+ [ F i e l d ] I n t 3 2 S y s 3 4 +
+ [ F i e l d ] I n t 3 2 S y s 3 4 _ 0 1 +
+ [ F i e l d ] I n t 3 2 S y s 3 4 _ 9 9 +
+ [ F i e l d ] I n t 3 2 T e a c y l +
+ [ F i e l d ] I n t 3 2 T m +
+ [ F i e l d ] I n t 3 2 T r m e r a f +
+ [ F i e l d ] I n t 3 2 T r m r k r g +
+ [ F i e l d ] I n t 3 2 T r m r s +
+ [ F i e l d ] I n t 3 2 U t m +
+ [ F i e l d ] I n t 3 2 V d g r n t n +
+ [ F i e l d ] I n t 3 2 W c c s l +
+ [ F i e l d ] I n t 3 2 W c c s t +
+ [ F i e l d ] I n t 3 2 W i n k l +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n F o r m a t T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 A n g d +
+ [ F i e l d ] I n t 3 2 C o e f +
+ [ F i e l d ] I n t 3 2 L a t +
+ [ F i e l d ] I n t 3 2 L n g +
+ [ F i e l d ] I n t 3 2 R o t +
+ [ F i e l d ] I n t 3 2 S c l +
+ [ F i e l d ] I n t 3 2 X x x +
+ [ F i e l d ] I n t 3 2 Y y y +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n L o g i c a l T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 A f f i n e C o e f f i c i e n t +
+ [ F i e l d ] I n t 3 2 A n g u l a r D i s t a n c e +
+ [ F i e l d ] I n t 3 2 A z i m u t h +
+ [ F i e l d ] I n t 3 2 C o m p l e x C o e f f i c i e n t +
+ [ F i e l d ] I n t 3 2 E l e v a t i o n +
+ [ F i e l d ] I n t 3 2 G e o i d H e i g h t +
+ [ F i e l d ] I n t 3 2 H e m i s p h e r e S e l e c t i o n +
+ [ F i e l d ] I n t 3 2 L a t i t u d e +
+ [ F i e l d ] I n t 3 2 L o n g i t u d e +
+ [ F i e l d ] I n t 3 2 S c a l e +
+ [ F i e l d ] I n t 3 2 U T M Z o n e N u m b e r +
+ [ F i e l d ] I n t 3 2 X Y C o o r d i n a t e +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n P a r a m e t e r T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 A d p 1 p 2 +
+ [ F i e l d ] I n t 3 2 A d s p 1 +
+ [ F i e l d ] I n t 3 2 A d s p 2 +
+ [ F i e l d ] I n t 3 2 A e l e v +
+ [ F i e l d ] I n t 3 2 A f a 0 +
+ [ F i e l d ] I n t 3 2 A f a 1 +
+ [ F i e l d ] I n t 3 2 A f a 2 +
+ [ F i e l d ] I n t 3 2 A f b 0 +
+ [ F i e l d ] I n t 3 2 A f b 1 +
+ [ F i e l d ] I n t 3 2 A f b 2 +
+ [ F i e l d ] I n t 3 2 C m p l x a n +
+ [ F i e l d ] I n t 3 2 C m p l x b n +
+ [ F i e l d ] I n t 3 2 C n t m e r +
+ [ F i e l d ] I n t 3 2 D e n r g n +
+ [ F i e l d ] I n t 3 2 E a s t l l +
+ [ F i e l d ] I n t 3 2 E l l i p s o i d S c a l e +
+ [ F i e l d ] I n t 3 2 E s t d m e r +
+ [ F i e l d ] I n t 3 2 G c a z m +
+ [ F i e l d ] I n t 3 2 G c p 1 l a t +
+ [ F i e l d ] I n t 3 2 G c p 1 l n g +
+ [ F i e l d ] I n t 3 2 G c p 2 l a t +
+ [ F i e l d ] I n t 3 2 G c p 2 l n g +
+ [ F i e l d ] I n t 3 2 G c p l a t +
+ [ F i e l d ] I n t 3 2 G c p l n g +
+ [ F i e l d ] I n t 3 2 G h g t +
+ [ F i e l d ] I n t 3 2 H s n s +
+ [ F i e l d ] I n t 3 2 N o t U s e d +
+ [ F i e l d ] I n t 3 2 N p a r a l l +
+ [ F i e l d ] I n t 3 2 N r m l p l l +
+ [ F i e l d ] I n t 3 2 N r t h r o t +
+ [ F i e l d ] I n t 3 2 N r t h s c l +
+ [ F i e l d ] I n t 3 2 N s t d p l l +
+ [ F i e l d ] I n t 3 2 O s t d p l l +
+ [ F i e l d ] I n t 3 2 P 1 l a t +
+ [ F i e l d ] I n t 3 2 P 1 l n g +
+ [ F i e l d ] I n t 3 2 P 2 l a t +
+ [ F i e l d ] I n t 3 2 P 2 l n g +
+ [ F i e l d ] I n t 3 2 P o l e l a t +
+ [ F i e l d ] I n t 3 2 P o l e l n g +
+ [ F i e l d ] I n t 3 2 S c l r o t o r g x +
+ [ F i e l d ] I n t 3 2 S c l r o t o r g y +
+ [ F i e l d ] I n t 3 2 S k w a z m +
+ [ F i e l d ] I n t 3 2 S p a r a l l +
+ [ F i e l d ] I n t 3 2 S s t d p l l +
+ [ F i e l d ] I n t 3 2 S t d c i r +
+ [ F i e l d ] I n t 3 2 S t d p l l +
+ [ F i e l d ] I n t 3 2 U t m z n +
+ [ F i e l d ] I n t 3 2 W e s t l l +
+ [ F i e l d ] I n t 3 2 Y a x i s a z +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 A r b i t r a r y +
+ [ F i e l d ] I n t 3 2 G e o g r a p h i c +
+ [ F i e l d ] I n t 3 2 P r o j e c t e d +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m U n i t C o d e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 B e n o i t C h a i n +
+ [ F i e l d ] I n t 3 2 B e n o i t L i n k +
+ [ F i e l d ] I n t 3 2 B r C h a i n T r u n c +
+ [ F i e l d ] I n t 3 2 B r e a l e y +
+ [ F i e l d ] I n t 3 2 B r F o o t T r u n c +
+ [ F i e l d ] I n t 3 2 B r L i n k T r u n c +
+ [ F i e l d ] I n t 3 2 C a G r i d +
+ [ F i e l d ] I n t 3 2 C a p e F o o t +
+ [ F i e l d ] I n t 3 2 C e n t i m e t e r +
+ [ F i e l d ] I n t 3 2 C e n t i s e c +
+ [ F i e l d ] I n t 3 2 C l a r k e C h a i n +
+ [ F i e l d ] I n t 3 2 C l a r k e F o o t +
+ [ F i e l d ] I n t 3 2 C l a r k e L i n k +
+ [ F i e l d ] I n t 3 2 D e c a m e t e r +
+ [ F i e l d ] I n t 3 2 D e c i m e t e r +
+ [ F i e l d ] I n t 3 2 D e c i s e c +
+ [ F i e l d ] I n t 3 2 D e g r e e +
+ [ F i e l d ] I n t 3 2 D e k a m e t e r +
+ [ F i e l d ] I n t 3 2 F o o t +
+ [ F i e l d ] I n t 3 2 F u r l o n g +
+ [ F i e l d ] I n t 3 2 G e r m a n M e t e r +
+ [ F i e l d ] I n t 3 2 G o l d C o a s t F o o t +
+ [ F i e l d ] I n t 3 2 G r a d +
+ [ F i e l d ] I n t 3 2 G r a d e +
+ [ F i e l d ] I n t 3 2 G u n t e r C h a i n +
+ [ F i e l d ] I n t 3 2 G u n t e r L i n k +
+ [ F i e l d ] I n t 3 2 H e c t o m e t e r +
+ [ F i e l d ] I n t 3 2 I F o o t +
+ [ F i e l d ] I n t 3 2 I I n c h +
+ [ F i e l d ] I n t 3 2 I M i l e +
+ [ F i e l d ] I n t 3 2 I n c h +
+ [ F i e l d ] I n t 3 2 I n d i a n F o o t +
+ [ F i e l d ] I n t 3 2 I n d i a n F t 3 7 +
+ [ F i e l d ] I n t 3 2 I n d i a n F t 6 2 +
+ [ F i e l d ] I n t 3 2 I n d i a n F t 7 5 +
+ [ F i e l d ] I n t 3 2 I n d i a n Y a r d +
+ [ F i e l d ] I n t 3 2 I n d i a n Y d 3 7 +
+ [ F i e l d ] I n t 3 2 I n t e r n a t i o n a l C h a i n +
+ [ F i e l d ] I n t 3 2 I n t e r n a t i o n a l L i n k +
+ [ F i e l d ] I n t 3 2 I Y a r d +
+ [ F i e l d ] I n t 3 2 K i l o m e t e r +
+ [ F i e l d ] I n t 3 2 K n o t +
+ [ F i e l d ] I n t 3 2 L a t 6 6 +
+ [ F i e l d ] I n t 3 2 L a t 8 3 +
+ [ F i e l d ] I n t 3 2 M a p I n f o +
+ [ F i e l d ] I n t 3 2 M e t e r +
+ [ F i e l d ] I n t 3 2 M i c r o I n c h +
+ [ F i e l d ] I n t 3 2 M i l +
+ [ F i e l d ] I n t 3 2 M i l e +
+ [ F i e l d ] I n t 3 2 M i l l i m e t e r +
+ [ F i e l d ] I n t 3 2 M i l l i s e c +
+ [ F i e l d ] I n t 3 2 M i n u t e +
+ [ F i e l d ] I n t 3 2 N a u t M +
+ [ F i e l d ] I n t 3 2 P e r c h +
+ [ F i e l d ] I n t 3 2 P o l e +
+ [ F i e l d ] I n t 3 2 R a d i a n +
+ [ F i e l d ] I n t 3 2 R o d +
+ [ F i e l d ] I n t 3 2 R o o d +
+ [ F i e l d ] I n t 3 2 S e a r s C h a i n +
+ [ F i e l d ] I n t 3 2 S e a r s F o o t +
+ [ F i e l d ] I n t 3 2 S e a r s L i n k +
+ [ F i e l d ] I n t 3 2 S e a r s Y a r d +
+ [ F i e l d ] I n t 3 2 S e c o n d +
+ [ F i e l d ] I n t 3 2 Y a r d +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m U n i t T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 A n g u l a r +
+ [ F i e l d ] I n t 3 2 L i n e a r +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m W k t F l a v o r : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 E s r i +
+ [ F i e l d ] I n t 3 2 G e o t i f f +
+ [ F i e l d ] I n t 3 2 G e o t o o l s +
+ [ F i e l d ] I n t 3 2 O g c +
+ [ F i e l d ] I n t 3 2 O r a c l e +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 A n a l y t i c a l +
+ [ F i e l d ] I n t 3 2 I n t e r p o l a t i o n +
+ [ F i e l d ] I n t 3 2 M u l t i p l e R e g r e s s i o n +
+ [ F i e l d ] I n t 3 2 S t a n d a l o n e +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c D i r e c t i o n : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 G e o d e t i c D i r e c t i o n E r r o r +
+ [ F i e l d ] I n t 3 2 G e o d e t i c D i r e c t i o n F o r w a r d +
+ [ F i e l d ] I n t 3 2 G e o d e t i c D i r e c t i o n I n v e r s e +
+ [ F i e l d ] I n t 3 2 G e o d e t i c D i r e c t i o n N o n e +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c A n a l y t i c a l T r a n s f o r m a t i o n M e t h o d : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 A b r i d g e d M o l o d e n s k y +
+ [ F i e l d ] I n t 3 2 F r a m e +
+ [ F i e l d ] I n t 3 2 M o l o d e n s k y B a d e k a s +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c M u l t i p l e R e g r e s s i o n T r a n s f o r m a t i o n M e t h o d : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 G e n e r a l P o l y n o m i a l E p s g +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c S t a n d a l o n e T r a n s f o r m a t i o n M e t h o d : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 N u l l X +
+ [ F i e l d ] I n t 3 2 W g s 7 2 +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e F o r m a t : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 G E O C O N +
+ [ F i e l d ] I n t 3 2 N A D C O N +
+ [ F i e l d ] I n t 3 2 N T v 1 +
+ [ F i e l d ] I n t 3 2 N T v 2 +
+ [ F i e l d ] I n t 3 2 O S T 0 2 +
+ [ F i e l d ] I n t 3 2 O S T 1 5 +
+ [ F i e l d ] I n t 3 2 O S T 9 7 +
+ [ F i e l d ] I n t 3 2 P A R +
+ [ F i e l d ] I n t 3 2 R G F +
+ t y p e O S G e o . M a p G u i d e . M g A g f R e a d e r W r i t e r : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y R e a d ( O S G e o . M a p G u i d e . M g B y t e R e a d e r , O S G e o . M a p G u i d e . M g T r a n s f o r m ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y R e a d ( O S G e o . M a p G u i d e . M g B y t e R e a d e r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r W r i t e ( O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r W r i t e ( O S G e o . M a p G u i d e . M g G e o m e t r y , O S G e o . M a p G u i d e . M g T r a n s f o r m ) +
+ t y p e O S G e o . M a p G u i d e . M g A g g r e g a t e G e o m e t r y : O S G e o . M a p G u i d e . M g G e o m e t r y +
+ t y p e O S G e o . M a p G u i d e . M g A r c S e g m e n t : O S G e o . M a p G u i d e . M g C u r v e S e g m e n t +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r i c E n t i t y C o p y ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ C o m p o n e n t T y p e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e g e t _ C o n t r o l C o o r d i n a t e ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ D i m e n s i o n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e g e t _ E n d C o o r d i n a t e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e g e t _ S t a r t C o o r d i n a t e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t C o m p o n e n t T y p e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e G e t C o n t r o l C o o r d i n a t e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t D i m e n s i o n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e G e t E n d C o o r d i n a t e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e G e t S t a r t C o o r d i n a t e ( ) +
+ [ M e t h o d ] B o o l e a n I s C l o s e d ( ) +
+ [ M e t h o d ] B o o l e a n I s E m p t y ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r i c E n t i t y T r a n s f o r m ( O S G e o . M a p G u i d e . M g T r a n s f o r m ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ M e t h o d ] D o u b l e g e t _ M ( ) +
+ [ M e t h o d ] D o u b l e g e t _ N o M ( ) +
+ [ M e t h o d ] D o u b l e g e t _ N o Z ( ) +
+ [ M e t h o d ] D o u b l e g e t _ X ( ) +
+ [ M e t h o d ] D o u b l e g e t _ Y ( ) +
+ [ M e t h o d ] D o u b l e g e t _ Z ( ) +
+ [ M e t h o d ] D o u b l e G e t M ( ) +
+ [ M e t h o d ] D o u b l e G e t X ( ) +
+ [ M e t h o d ] D o u b l e G e t Y ( ) +
+ [ M e t h o d ] D o u b l e G e t Z ( ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g C o o r d i n a t e , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g C o o r d i n a t e , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g C o o r d i n a t e , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( ) +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g C o o r d i n a t e [ ] , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g C o o r d i n a t e ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e I t e r a t o r : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e G e t C u r r e n t ( ) +
+ [ M e t h o d ] B o o l e a n M o v e N e x t ( ) +
+ [ M e t h o d ] V o i d R e s e t ( ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] V o i d C a n c e l L o n L a t B o u n d s ( ) +
+ [ M e t h o d ] V o i d C a n c e l X Y B o u n d s ( ) +
+ [ M e t h o d ] V o i d C o n v e r t C o o r d i n a t e F r o m L o n L a t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] D o u b l e C o n v e r t C o o r d i n a t e S y s t e m U n i t s T o M e t e r s ( D o u b l e ) +
+ [ M e t h o d ] V o i d C o n v e r t C o o r d i n a t e T o L o n L a t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e C o n v e r t F r o m L o n L a t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e C o n v e r t F r o m L o n L a t ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e C o n v e r t F r o m L o n L a t ( D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] D o u b l e C o n v e r t M e t e r s T o C o o r d i n a t e S y s t e m U n i t s ( D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e C o n v e r t T o L o n L a t ( D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e C o n v e r t T o L o n L a t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e C o n v e r t T o L o n L a t ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C r e a t e C l o n e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ C s C o d e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ D a t u m ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ D a t u m D e s c r i p t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ E l l i p s o i d ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ E l l i p s o i d D e s c r i p t i o n ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ E p s g C o d e ( ) +
+ [ M e t h o d ] I n t 1 6 g e t _ E p s g Q u a d r a n t ( ) +
+ [ M e t h o d ] D o u b l e g e t _ M a x X ( ) +
+ [ M e t h o d ] D o u b l e g e t _ M a x Y ( ) +
+ [ M e t h o d ] D o u b l e g e t _ M i n X ( ) +
+ [ M e t h o d ] D o u b l e g e t _ M i n Y ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ P r o j e c t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ P r o j e c t i o n D e s c r i p t i o n ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ S r i d C o d e ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ T y p e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ U n i t s ( ) +
+ [ M e t h o d ] D o u b l e g e t _ U n i t S c a l e ( ) +
+ [ M e t h o d ] I n t 1 6 G e t A g e ( ) +
+ [ M e t h o d ] D o u b l e G e t A z i m u t h ( O S G e o . M a p G u i d e . M g C o o r d i n a t e , O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] D o u b l e G e t A z i m u t h ( D o u b l e , D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t a l o g G e t C a t a l o g ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n G e t C a t e g o r i e s ( ) +
+ [ M e t h o d ] D o u b l e G e t C o n v e r g e n c e ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e G e t C o o r d i n a t e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e G e t C o o r d i n a t e ( D o u b l e , D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t C o u n t r y O r S t a t e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t C s C o d e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D a t u m ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m G e t D a t u m D e f i n i t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D a t u m D e s c r i p t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t E l l i p s o i d ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d G e t E l l i p s o i d D e f i n i t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t E l l i p s o i d D e s c r i p t i o n ( ) +
+ [ M e t h o d ] I n t 3 2 G e t E p s g C o d e ( ) +
+ [ M e t h o d ] I n t 1 6 G e t E p s g Q u a d r a n t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2 G e t E r r o r s ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t G r o u p ( ) +
+ [ M e t h o d ] D o u b l e G e t L a t M a x ( ) +
+ [ M e t h o d ] D o u b l e G e t L a t M i n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t L o c a t i o n ( ) +
+ [ M e t h o d ] D o u b l e G e t L o n M a x ( ) +
+ [ M e t h o d ] D o u b l e G e t L o n M i n ( ) +
+ [ M e t h o d ] D o u b l e G e t M a p S c a l e ( ) +
+ [ M e t h o d ] D o u b l e G e t M a x X ( ) +
+ [ M e t h o d ] D o u b l e G e t M a x Y ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M e a s u r e G e t M e a s u r e ( ) +
+ [ M e t h o d ] D o u b l e G e t M i n X ( ) +
+ [ M e t h o d ] D o u b l e G e t M i n Y ( ) +
+ [ M e t h o d ] D o u b l e G e t O f f s e t X ( ) +
+ [ M e t h o d ] D o u b l e G e t O f f s e t Y ( ) +
+ [ M e t h o d ] D o u b l e G e t O r i g i n L a t i t u d e ( ) +
+ [ M e t h o d ] D o u b l e G e t O r i g i n L o n g i t u d e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t P r o j e c t i o n ( ) +
+ [ M e t h o d ] I n t 3 2 G e t P r o j e c t i o n C o d e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t P r o j e c t i o n D e s c r i p t i o n ( ) +
+ [ M e t h o d ] D o u b l e G e t P r o j e c t i o n P a r a m e t e r ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t P r o j e c t i o n P a r a m e t e r C o u n t ( ) +
+ [ M e t h o d ] I n t 1 6 G e t Q u a d r a n t ( ) +
+ [ M e t h o d ] D o u b l e G e t S c a l e ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] D o u b l e G e t S c a l e H ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] D o u b l e G e t S c a l e K ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] D o u b l e G e t S c a l e R e d u c t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S o u r c e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t S r i d C o d e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t T y p e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t U n i t C o d e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t U n i t s ( ) +
+ [ M e t h o d ] D o u b l e G e t U n i t S c a l e ( ) +
+ [ M e t h o d ] D o u b l e G e t Z e r o X ( ) +
+ [ M e t h o d ] D o u b l e G e t Z e r o Y ( ) +
+ [ M e t h o d ] B o o l e a n I s E n c r y p t e d ( ) +
+ [ M e t h o d ] B o o l e a n I s G e o d e t i c ( ) +
+ [ M e t h o d ] B o o l e a n I s L e g a l C o u n t r y O r S t a t e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n I s L e g a l C s C o d e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n I s L e g a l D e s c r i p t i o n ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n I s L e g a l G r o u p ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n I s L e g a l L o c a t i o n ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n I s L e g a l S o u r c e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n I s P r o t e c t e d ( ) +
+ [ M e t h o d ] B o o l e a n I s S a m e A s ( O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e ) +
+ [ M e t h o d ] B o o l e a n I s U s a b l e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t a l o g ) +
+ [ M e t h o d ] B o o l e a n I s V a l i d ( ) +
+ [ M e t h o d ] B o o l e a n I s V a l i d L o n L a t ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] B o o l e a n I s V a l i d X Y ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] D o u b l e M e a s u r e E u c l i d e a n D i s t a n c e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e , O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] D o u b l e M e a s u r e E u c l i d e a n D i s t a n c e ( D o u b l e , D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] D o u b l e M e a s u r e G r e a t C i r c l e D i s t a n c e ( D o u b l e , D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] D o u b l e M e a s u r e G r e a t C i r c l e D i s t a n c e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e , O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] V o i d S e t C o u n t r y O r S t a t e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t C s C o d e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t D a t u m D e f i n i t i o n ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m ) +
+ [ M e t h o d ] V o i d S e t E l l i p s o i d D e f i n i t i o n ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d ) +
+ [ M e t h o d ] V o i d S e t E n c r y p t M o d e ( B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t G r o u p ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t L o c a t i o n ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t L o n L a t B o u n d s ( D o u b l e , D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] V o i d S e t M a p S c a l e ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t O f f s e t s ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] V o i d S e t O r i g i n L a t i t u d e ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t O r i g i n L o n g i t u d e ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t P r o j e c t i o n C o d e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t P r o j e c t i o n P a r a m e t e r ( I n t 3 2 , D o u b l e ) +
+ [ M e t h o d ] V o i d S e t P r o t e c t M o d e ( B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t Q u a d r a n t ( I n t 1 6 ) +
+ [ M e t h o d ] V o i d S e t S c a l e R e d u c t i o n ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t S o u r c e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t U n i t C o d e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t X Y B o u n d s ( D o u b l e , D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] V o i d S e t Z e r o e s ( D o u b l e , D o u b l e ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t a l o g : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] B o o l e a n A r e D i c t i o n a r y F i l e s W r i t a b l e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y D i c t i o n a r y G e t C a t e g o r y D i c t i o n a r y ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y G e t C o o r d i n a t e S y s t e m D i c t i o n a r y ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m D i c t i o n a r y G e t D a t u m D i c t i o n a r y ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D e f a u l t D i c t i o n a r y D i r ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D e f a u l t U s e r D i c t i o n a r y D i r ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D i c t i o n a r y D i r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y U t i l i t y G e t D i c t i o n a r y U t i l i t y ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d D i c t i o n a r y G e t E l l i p s o i d D i c t i o n a r y ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m F o r m a t C o n v e r t e r G e t F o r m a t C o n v e r t e r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h D i c t i o n a r y G e t G e o d e t i c P a t h D i c t i o n a r y ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D i s p o s a b l e C o l l e c t i o n G e t G e o d e t i c T r a n s f o r m a t i o n s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m , O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f D i c t i o n a r y G e t G e o d e t i c T r a n s f o r m D e f D i c t i o n a r y ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M a t h C o m p a r a t o r G e t M a t h C o m p a r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n I n f o r m a t i o n G e t P r o j e c t i o n I n f o r m a t i o n ( ) +
+ [ M e t h o d ] I n t 1 6 G e t P r o t e c t i o n M o d e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m U n i t I n f o r m a t i o n G e t U n i t I n f o r m a t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t U s e r D i c t i o n a r y D i r ( ) +
+ [ M e t h o d ] V o i d S e t D e f a u l t D i c t i o n a r y D i r A n d F i l e N a m e s ( ) +
+ [ M e t h o d ] V o i d S e t D i c t i o n a r y D i r ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t P r o t e c t i o n M o d e ( I n t 1 6 ) +
+ [ M e t h o d ] V o i d S e t U s e r D i c t i o n a r y D i r ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ i m p l e m e n t s S y s t e m . I D i s p o s a b l e +
+ [ M e t h o d ] V o i d A d d C o o r d i n a t e S y s t e m ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d C l e a r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y C r e a t e C l o n e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n G e t C o o r d i n a t e S y s t e m s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m G e t E n u m ( ) +
+ [ M e t h o d ] I n t 3 2 G e t S i z e ( ) +
+ [ M e t h o d ] B o o l e a n H a s C o o r d i n a t e S y s t e m ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n I s L e g a l N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d R e m o v e C o o r d i n a t e S y s t e m ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y D i c t i o n a r y : O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y G e t C a t e g o r y ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y N e w C a t e g o r y ( ) +
+ [ M e t h o d ] V o i d R e n a m e ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m C r e a t e C l o n e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D t C o d e ( ) +
+ [ M e t h o d ] I n t 1 6 G e t E p s g C o d e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D i s p o s a b l e C o l l e c t i o n G e t G e o d e t i c T r a n s f o r m a t i o n s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m ) +
+ [ M e t h o d ] B o o l e a n I s L e g a l D t C o d e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t D t C o d e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t E l l i p s o i d ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t E p s g C o d e ( I n t 1 6 ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m D i c t i o n a r y : O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m G e t D a t u m ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m N e w D a t u m ( ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y : O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e t C o o r d i n a t e S y s t e m ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m N e w C o o r d i n a t e S y s t e m ( ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e G e t ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D e f a u l t F i l e N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t F i l e N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t P a t h ( ) +
+ [ M e t h o d ] B o o l e a n H a s ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d M o d i f y ( O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e ) +
+ [ M e t h o d ] V o i d R e m o v e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t F i l e N a m e ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y U t i l i t y : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] V o i d C r e a t e C a t e g o r y D i c t i o n a r y ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d C r e a t e C o o r d s y s D i c t i o n a r y ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d C r e a t e D a t u m D i c t i o n a r y ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d C r e a t e E l l i p s o i d D i c t i o n a r y ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d C r e a t e C l o n e ( ) +
+ [ M e t h o d ] D o u b l e E c c e n t r i c i t y T o F l a t t e n i n g R a t i o ( D o u b l e ) +
+ [ M e t h o d ] D o u b l e E q u a t o r i a l R a d i u s F r o m P o l a r R a d i u s F l a t t e n i n g R a t i o ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] D o u b l e F l a t t e n i n g R a t i o F r o m R a d i i ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] D o u b l e F l a t t e n i n g R a t i o T o E c c e n t r i c i t y ( D o u b l e ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ E l C o d e ( ) +
+ [ M e t h o d ] D o u b l e G e t E c c e n t r i c i t y ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t E l C o d e ( ) +
+ [ M e t h o d ] D o u b l e G e t E q u a t o r i a l R a d i u s ( ) +
+ [ M e t h o d ] D o u b l e G e t F l a t t e n i n g R a t i o ( ) +
+ [ M e t h o d ] D o u b l e G e t F l a t t e n i n g R a t i o M a x ( ) +
+ [ M e t h o d ] D o u b l e G e t F l a t t e n i n g R a t i o M i n ( ) +
+ [ M e t h o d ] D o u b l e G e t G r e a t C i r c l e A z i m u t h ( D o u b l e , D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] D o u b l e G e t G r e a t C i r c l e D i s t a n c e ( D o u b l e , D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] D o u b l e G e t P o l a r R a d i u s ( ) +
+ [ M e t h o d ] D o u b l e G e t R a d i u s M a x ( ) +
+ [ M e t h o d ] D o u b l e G e t R a d i u s M i n ( ) +
+ [ M e t h o d ] B o o l e a n I s L e g a l E l C o d e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n I s L e g a l F l a t t e n i n g R a t i o ( D o u b l e ) +
+ [ M e t h o d ] B o o l e a n I s L e g a l R a d i u s ( D o u b l e ) +
+ [ M e t h o d ] B o o l e a n I s U s a b l e ( ) +
+ [ M e t h o d ] D o u b l e P o l a r R a d i u s F r o m E q u a t o r i a l R a d i u s F l a t t e n i n g R a t i o ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] V o i d S e t E l C o d e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t R a d i i ( D o u b l e , D o u b l e ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d D i c t i o n a r y : O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d G e t E l l i p s o i d ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d N e w E l l i p s o i d ( ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] V o i d A d d F i l t e r ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m F i l t e r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m C r e a t e C l o n e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D i s p o s a b l e C o l l e c t i o n N e x t ( I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n N e x t D e s c r i p t i o n ( I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n N e x t N a m e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S k i p ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2 : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] V o i d A d d F i l t e r ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m F i l t e r I n t e g e r 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2 C r e a t e C l o n e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n N e x t ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m F a c t o r y : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] S y s t e m . S t r i n g C o n v e r t C o o r d i n a t e S y s t e m C o d e T o W k t ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g C o n v e r t E p s g C o d e T o W k t ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . S t r i n g C o n v e r t W k t T o C o o r d i n a t e S y s t e m C o d e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 3 2 C o n v e r t W k t T o E p s g C o d e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C r e a t e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C r e a t e F r o m C o d e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n E n u m e r a t e C a t e g o r i e s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n E n u m e r a t e C o o r d i n a t e S y s t e m s ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e G e n e r i c G r i d ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m , O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m , B o o l e a n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e G e n e r i c G r i d ( S y s t e m . S t r i n g , S y s t e m . S t r i n g , B o o l e a n ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t B a s e L i b r a r y ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M g r s G e t M g r s ( D o u b l e , D o u b l e , I n t 1 6 , B o o l e a n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M g r s G e t M g r s D a t u m ( S y s t e m . S t r i n g , I n t 1 6 , B o o l e a n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M g r s G e t M g r s E l l i p s o i d ( S y s t e m . S t r i n g , I n t 1 6 , B o o l e a n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m T r a n s f o r m G e t T r a n s f o r m ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m , O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y G r i d B o u n d a r y ( O S G e o . M a p G u i d e . M g P o l y g o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y G r i d B o u n d a r y ( O S G e o . M a p G u i d e . M g C o o r d i n a t e , O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n G r i d S p e c i f i c a t i o n ( I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n G r i d S p e c i f i c a t i o n ( D o u b l e , D o u b l e , I n t 3 2 , D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n G r i d S p e c i f i c a t i o n ( ) +
+ [ M e t h o d ] B o o l e a n I s V a l i d ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e M g r s G r i d ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m , B o o l e a n , I n t 1 6 , B o o l e a n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e M g r s G r i d ( S y s t e m . S t r i n g , B o o l e a n , I n t 1 6 , B o o l e a n ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m F i l t e r : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] B o o l e a n I s F i l t e r e d O u t ( O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m F i l t e r I n t e g e r 3 2 : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] B o o l e a n I s F i l t e r e d O u t ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m F o r m a t C o n v e r t e r : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] S y s t e m . S t r i n g C o d e T o C o d e ( I n t 3 2 , S y s t e m . S t r i n g , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C o d e T o D e f i n i t i o n ( I n t 3 2 , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g C o d e T o W k t ( I n t 3 2 , S y s t e m . S t r i n g , I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . S t r i n g D e f i n i t i o n T o C o d e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m , I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . S t r i n g D e f i n i t i o n T o W k t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m , I n t 3 2 ) +
+ [ M e t h o d ] B o o l e a n I s C o d e I n D i c t i o n a r y ( I n t 3 2 , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g W k t T o C o d e ( I n t 3 2 , S y s t e m . S t r i n g , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m W k t T o D e f i n i t i o n ( I n t 3 2 , S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c A n a l y t i c a l T r a n s f o r m D e f P a r a m s : O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s +
+ [ M e t h o d ] D o u b l e G e t D e l t a X ( ) +
+ [ M e t h o d ] D o u b l e G e t D e l t a Y ( ) +
+ [ M e t h o d ] D o u b l e G e t D e l t a Z ( ) +
+ [ M e t h o d ] D o u b l e G e t R o t a t e X ( ) +
+ [ M e t h o d ] D o u b l e G e t R o t a t e Y ( ) +
+ [ M e t h o d ] D o u b l e G e t R o t a t e Z ( ) +
+ [ M e t h o d ] D o u b l e G e t S c a l e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t T r a n s f o r m a t i o n M e t h o d ( ) +
+ [ M e t h o d ] D o u b l e G e t T r a n s l a t e X ( ) +
+ [ M e t h o d ] D o u b l e G e t T r a n s l a t e Y ( ) +
+ [ M e t h o d ] D o u b l e G e t T r a n s l a t e Z ( ) +
+ [ M e t h o d ] V o i d S e t D e l t a X ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t D e l t a Y ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t D e l t a Z ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t R o t a t e X ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t R o t a t e Y ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t R o t a t e Z ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t S c a l e ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t T r a n s f o r m a t i o n M e t h o d ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t T r a n s l a t e X ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t T r a n s l a t e Y ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t T r a n s l a t e Z ( D o u b l e ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c I n t e r p o l a t i o n T r a n s f o r m D e f P a r a m s : O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t F a l l b a c k ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D i s p o s a b l e C o l l e c t i o n G e t G r i d F i l e s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e N e w G r i d F i l e ( ) +
+ [ M e t h o d ] V o i d S e t F a l l b a c k ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t G r i d F i l e s ( O S G e o . M a p G u i d e . M g D i s p o s a b l e C o l l e c t i o n ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c M u l t i p l e R e g r e s s i o n T r a n s f o r m D e f P a r a m s : O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s +
+ [ M e t h o d ] D o u b l e G e t C o e f f i c i e n t H e i g h t ( I n t 3 2 ) +
+ [ M e t h o d ] D o u b l e G e t C o e f f i c i e n t L a m b d a ( I n t 3 2 ) +
+ [ M e t h o d ] D o u b l e G e t C o e f f i c i e n t P h i ( I n t 3 2 ) +
+ [ M e t h o d ] D o u b l e G e t D e l t a H e i g h t ( ) +
+ [ M e t h o d ] D o u b l e G e t D e l t a L a m b d a ( ) +
+ [ M e t h o d ] D o u b l e G e t D e l t a P h i ( ) +
+ [ M e t h o d ] D o u b l e G e t L a m b d a O f f s e t ( ) +
+ [ M e t h o d ] D o u b l e G e t N o r m a l i z a t i o n S c a l e ( ) +
+ [ M e t h o d ] D o u b l e G e t P h i O f f s e t ( ) +
+ [ M e t h o d ] D o u b l e G e t T e s t L a m b d a ( ) +
+ [ M e t h o d ] D o u b l e G e t T e s t P h i ( ) +
+ [ M e t h o d ] D o u b l e G e t V a l i d a t i o n ( ) +
+ [ M e t h o d ] V o i d S e t C o e f f i c i e n t H e i g h t ( I n t 3 2 , D o u b l e ) +
+ [ M e t h o d ] V o i d S e t C o e f f i c i e n t L a m b d a ( I n t 3 2 , D o u b l e ) +
+ [ M e t h o d ] V o i d S e t C o e f f i c i e n t P h i ( I n t 3 2 , D o u b l e ) +
+ [ M e t h o d ] V o i d S e t D e l t a H e i g h t ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t D e l t a L a m b d a ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t D e l t a P h i ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t L a m b d a O f f s e t ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t N o r m a l i z a t i o n S c a l e ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t P h i O f f s e t ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t T e s t L a m b d a ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t T e s t P h i ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t V a l i d a t i o n ( D o u b l e ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h C r e a t e C l o n e ( ) +
+ [ M e t h o d ] D o u b l e g e t _ A c c u r a c y ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ D e s c r i p t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ G r o u p ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ S o u r c e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ S o u r c e D a t u m ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ T a r g e t D a t u m ( ) +
+ [ M e t h o d ] D o u b l e G e t A c c u r a c y ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D e s c r i p t i o n ( ) +
+ [ M e t h o d ] I n t 3 2 G e t E p s g V a r i a n t ( ) +
+ [ M e t h o d ] B o o l e a n G e t I s R e v e r s i b l e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D i s p o s a b l e C o l l e c t i o n G e t P a t h E l e m e n t s ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t P a t h N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S o u r c e D a t u m ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t T a r g e t D a t u m ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h E l e m e n t N e w P a t h E l e m e n t ( ) +
+ [ M e t h o d ] V o i d S e t A c c u r a c y ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t D e s c r i p t i o n ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t E p s g C o d e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t E p s g V a r i a n t ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t I s R e v e r s i b l e ( B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t P a t h E l e m e n t s ( O S G e o . M a p G u i d e . M g D i s p o s a b l e C o l l e c t i o n ) +
+ [ M e t h o d ] V o i d S e t P a t h N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t S o u r c e D a t u m ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t T a r g e t D a t u m ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h D i c t i o n a r y : O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h G e t G e o d e t i c P a t h ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h N e w G e o d e t i c P a t h ( ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h E l e m e n t : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] B o o l e a n G e t I s I n v e r s e d ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t T r a n s f o r m N a m e ( ) +
+ [ M e t h o d ] V o i d S e t I s I n v e r s e d ( B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t T r a n s f o r m N a m e ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c S t a n d a l o n e T r a n s f o r m D e f P a r a m s : O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s +
+ [ M e t h o d ] I n t 3 2 g e t _ T r a n s f o r m a t i o n M e t h o d ( ) +
+ [ M e t h o d ] V o i d s e t _ T r a n s f o r m a t i o n M e t h o d ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] D o u b l e G e t B u r s a W o l f e T r a n s f o r m B w S c a l e ( ) +
+ [ M e t h o d ] D o u b l e G e t B u r s a W o l f e T r a n s f o r m R o t a t i o n X ( ) +
+ [ M e t h o d ] D o u b l e G e t B u r s a W o l f e T r a n s f o r m R o t a t i o n Y ( ) +
+ [ M e t h o d ] D o u b l e G e t B u r s a W o l f e T r a n s f o r m R o t a t i o n Z ( ) +
+ [ M e t h o d ] D o u b l e G e t B w S c a l e M a x ( ) +
+ [ M e t h o d ] D o u b l e G e t B w S c a l e M i n ( ) +
+ [ M e t h o d ] I n t 3 2 G e t G e o d e t i c T r a n s f o r m a t i o n M e t h o d ( ) +
+ [ M e t h o d ] D o u b l e G e t M a x O f f s e t ( ) +
+ [ M e t h o d ] D o u b l e G e t M a x R o t a t i o n ( ) +
+ [ M e t h o d ] D o u b l e G e t O f f s e t Z ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m G e t S o u r c e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m G e t T a r g e t ( ) +
+ [ M e t h o d ] B o o l e a n I s L e g a l B w S c a l e ( D o u b l e ) +
+ [ M e t h o d ] B o o l e a n I s L e g a l O f f s e t ( D o u b l e ) +
+ [ M e t h o d ] B o o l e a n I s L e g a l R o t a t i o n ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t B u r s a W o l f e T r a n s f o r m ( D o u b l e , D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] V o i d S e t G e o d e t i c T r a n s f o r m a t i o n M e t h o d ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t O f f s e t ( D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] V o i d S e t S o u r c e A n d T a r g e t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m , O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S h i f t ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] V o i d S h i f t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S h i f t ( D o u b l e , D o u b l e , D o u b l e ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f C r e a t e C l o n e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n C r e a t e T r a n s f o r m a t i o n ( B o o l e a n ) +
+ [ M e t h o d ] D o u b l e G e t C o n v e r g e n c e V a l u e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t E p s g V a r i a t i o n ( ) +
+ [ M e t h o d ] D o u b l e G e t E r r o r V a l u e ( ) +
+ [ M e t h o d ] B o o l e a n G e t I n v e r s e S u p p o r t e d ( ) +
+ [ M e t h o d ] I n t 3 2 G e t M a x I t e r a t i o n s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s G e t P a r a m e t e r s ( ) +
+ [ M e t h o d ] D o u b l e G e t R a n g e M a x L a t i t u d e ( ) +
+ [ M e t h o d ] D o u b l e G e t R a n g e M a x L o n g i t u d e ( ) +
+ [ M e t h o d ] D o u b l e G e t R a n g e M i n L a t i t u d e ( ) +
+ [ M e t h o d ] D o u b l e G e t R a n g e M i n L o n g i t u d e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t T r a n s f o r m D e f T y p e ( ) +
+ [ M e t h o d ] V o i d S e t C o n v e r g e n c e V a l u e ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t E p s g V a r i a t i o n ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t E r r o r V a l u e ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t I n v e r s e S u p p o r t e d ( B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t M a x I t e r a t i o n s ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t P a r a m e t e r s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s ) +
+ [ M e t h o d ] V o i d S e t R a n g e M a x L a t i t u d e ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t R a n g e M a x L o n g i t u d e ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t R a n g e M i n L a t i t u d e ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t R a n g e M i n L o n g i t u d e ( D o u b l e ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f D i c t i o n a r y : O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f G e t G e o d e t i c T r a n s f o r m a t i o n D e f ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f N e w G e o d e t i c T r a n s f o r m a t i o n D e f ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] I n t 3 2 G e t F i l e F o r m a t ( ) +
+ [ M e t h o d ] B o o l e a n G e t I s I n v e r s e D i r e c t i o n ( ) +
+ [ M e t h o d ] V o i d S e t F i l e F o r m a t ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t I s I n v e r s e D i r e c t i o n ( B o o l e a n ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] I n t 3 2 A p p r o x G r i d L i n e M e m o r y U s a g e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) +
+ [ M e t h o d ] I n t 3 2 A p p r o x G r i d R e g i o n M e m o r y U s a g e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) +
+ [ M e t h o d ] I n t 3 2 A p p r o x G r i d T i c k M e m o r y U s a g e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) +
+ [ M e t h o d ] B o o l e a n A r e E x c e p t i o n s O n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y G e t B o u n d a r y ( ) +
+ [ M e t h o d ] D o u b l e G e t C o n v e r g e n c e A n g l e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d L i n e C o l l e c t i o n G e t G r i d L i n e s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d R e g i o n C o l l e c t i o n G e t G r i d R e g i o n s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d T i c k C o l l e c t i o n G e t G r i d T i c k s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) +
+ [ M e t h o d ] I n t 3 2 G e t L a s t E r r o r ( ) +
+ [ M e t h o d ] D o u b l e G e t P r o j e c t i v e G r i d S c a l e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] I n t 3 2 G e t S p e c i a l i z a t i o n T y p e ( ) +
+ [ M e t h o d ] V o i d R e s e t L a s t E r r o r ( ) +
+ [ M e t h o d ] V o i d S e t B o u n d a r y ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y ) +
+ [ M e t h o d ] V o i d S e t E x c e p t i o n s O n ( B o o l e a n ) +
+ [ M e t h o d ] I n t 3 2 S e t G r i d L i n e E x c e p t i o n L e v e l ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 S e t G r i d R e g i o n E x c e p t i o n L e v e l ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 S e t G r i d T i c k E x c e p t i o n L e v e l ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o l y g o n G e t B o u n d a r y ( ) +
+ [ M e t h o d ] V o i d S e t B o u n d a r y E x t e n t s ( O S G e o . M a p G u i d e . M g P o l y g o n ) +
+ [ M e t h o d ] V o i d S e t B o u n d a r y E x t e n t s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e , O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d L i n e : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] I n t 3 2 G e t C o u n t ( ) +
+ [ M e t h o d ] I n t 3 2 G e t G r i d O r i e n t a t i o n ( ) +
+ [ M e t h o d ] D o u b l e G e t R e a l V a l u e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e S t r i n g G e t S e g m e n t ( I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e S t r i n g C o l l e c t i o n G e t S e g m e n t C o l l e c t i o n ( ) +
+ [ M e t h o d ] V o i d S e t S e g m e n t C o l l e c t i o n ( O S G e o . M a p G u i d e . M g L i n e S t r i n g C o l l e c t i o n ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d L i n e C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d L i n e G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( I n t 3 2 , D o u b l e ) +
+ [ M e t h o d ] V o i d R e m o v e A t ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d R e g i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e S t r i n g C o l l e c t i o n G e t E a s t L i n e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t L a b e l ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e S t r i n g C o l l e c t i o n G e t N o r t h L i n e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o l y g o n G e t R e g i o n B o u n d a r y ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e G e t R e g i o n C e n t e r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e S t r i n g C o l l e c t i o n G e t S o u t h L i n e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e S t r i n g C o l l e c t i o n G e t W e s t L i n e ( ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d R e g i o n C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d R e g i o n G e t I t e m ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] D o u b l e G e t C u r v e P r e c i s i o n ( ) +
+ [ M e t h o d ] D o u b l e G e t E a s t i n g B a s e ( ) +
+ [ M e t h o d ] D o u b l e G e t E a s t i n g I n c r e m e n t ( ) +
+ [ M e t h o d ] D o u b l e G e t N o r t h i n g B a s e ( ) +
+ [ M e t h o d ] D o u b l e G e t N o r t h i n g I n c r e m e n t ( ) +
+ [ M e t h o d ] D o u b l e G e t T i c k E a s t i n g I n c r e m e n t ( ) +
+ [ M e t h o d ] D o u b l e G e t T i c k N o r t h i n g I n c r e m e n t ( ) +
+ [ M e t h o d ] I n t 3 2 G e t U n i t T y p e ( ) +
+ [ M e t h o d ] B o o l e a n I s C o n s i s t e n t ( ) +
+ [ M e t h o d ] B o o l e a n I s S a m e A s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) +
+ [ M e t h o d ] V o i d S e t C u r v e P r e c i s i o n ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t G r i d B a s e ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] V o i d S e t G r i d I n c r e m e n t ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] V o i d S e t M a x C u r v e P o i n t s ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t T i c k I n c r e m e n t s ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] V o i d S e t U n i t s ( I n t 3 2 , I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d T i c k : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e G e t D i r e c t i o n V e c t o r ( ) +
+ [ M e t h o d ] B o o l e a n G e t I s O n G r i d L i n e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e G e t P o s i t i o n ( ) +
+ [ M e t h o d ] I n t 3 2 G e t T i c k O r i e n t a t i o n ( ) +
+ [ M e t h o d ] D o u b l e G e t V a l u e ( ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d T i c k C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d T i c k G e t I t e m ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M a t h C o m p a r a t o r : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] B o o l e a n G e t C o m p a r e I n t e r n a l D a t u m O l d P a r a m e t e r s ( ) +
+ [ M e t h o d ] B o o l e a n S a m e ( O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e , O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e ) +
+ [ M e t h o d ] B o o l e a n S a m e C o o r d i n a t e S y s t e m ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m , O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m ) +
+ [ M e t h o d ] B o o l e a n S a m e D a t u m ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m , O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m ) +
+ [ M e t h o d ] B o o l e a n S a m e E l l i p s o i d ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d , O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d ) +
+ [ M e t h o d ] V o i d S e t C o m p a r e I n t e r n a l D a t u m O l d P a r a m e t e r s ( B o o l e a n ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M e a s u r e : O S G e o . M a p G u i d e . M g M e a s u r e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g E n v e l o p e g e t _ E n v e l o p e ( ) +
+ [ M e t h o d ] D o u b l e G e t D i s t a n c e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e , O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] D o u b l e G e t D i s t a n c e ( D o u b l e , D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g E n v e l o p e G e t E n v e l o p e ( ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M g r s : O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e +
+ [ M e t h o d ] S y s t e m . S t r i n g C o n v e r t F r o m L o n L a t ( D o u b l e , D o u b l e , I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . S t r i n g C o n v e r t F r o m L o n L a t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e C o n v e r t T o L o n L a t ( S y s t e m . S t r i n g , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e C o n v e r t T o L o n L a t ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 1 6 G e t L e t t e r i n g S c h e m e ( ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n I n f o r m a t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2 G e t E n u m P r o j e c t i o n s ( ) +
+ [ M e t h o d ] I n t 3 2 G e t P a r a m e t e r C o u n t ( I n t 3 2 ) +
+ [ M e t h o d ] D o u b l e G e t P a r a m e t e r D e f a u l t ( I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t P a r a m e t e r F o r m a t T y p e ( I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t P a r a m e t e r L o g i c a l T y p e ( I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] D o u b l e G e t P a r a m e t e r M a x ( I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] D o u b l e G e t P a r a m e t e r M i n ( I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t P a r a m e t e r T y p e ( I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t T a g S t r i n g ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t U n i t T y p e ( I n t 3 2 ) +
+ [ M e t h o d ] B o o l e a n I s U s i n g O f f s e t ( I n t 3 2 ) +
+ [ M e t h o d ] B o o l e a n I s U s i n g O r i g i n L a t i t u d e ( I n t 3 2 ) +
+ [ M e t h o d ] B o o l e a n I s U s i n g O r i g i n L o n g i t u d e ( I n t 3 2 ) +
+ [ M e t h o d ] B o o l e a n I s U s i n g P a r a m e t e r ( I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] B o o l e a n I s U s i n g Q u a d r a n t ( I n t 3 2 ) +
+ [ M e t h o d ] B o o l e a n I s U s i n g S c a l e R e d u c t i o n ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m T r a n s f o r m : O S G e o . M a p G u i d e . M g T r a n s f o r m +
+ [ F i e l d ] I n t 3 2 D a t u m S h i f t E r r o r +
+ [ F i e l d ] I n t 3 2 D a t u m S h i f t F a l l b a c k +
+ [ M e t h o d ] I n t 3 2 G e t d a t u m W a r n i n g C o u n t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h G e t E x p l i c i t G e o d e t i c P a t h ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f G e t G e o d e t i c T r a n s f o r m a t i o n ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t G e o d e t i c T r a n s f o r m a t i o n C o u n t ( ) +
+ [ M e t h o d ] I n t 3 2 G e t G e o d e t i c T r a n s f o r m a t i o n D i r e c t i o n ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t L a s t T r a n s f o r m S t a t u s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e t S o u r c e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t S o u r c e W a r n i n g C o u n t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e t T a r g e t ( ) +
+ [ M e t h o d ] I n t 3 2 G e t T a r g e t W a r n i n g C o u n t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e S t r i n g G r i d L i n e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e , O S G e o . M a p G u i d e . M g C o o r d i n a t e , D o u b l e , I n t 3 2 ) +
+ [ M e t h o d ] V o i d I g n o r e D a t u m S h i f t W a r n i n g ( B o o l e a n ) +
+ [ M e t h o d ] V o i d I g n o r e O u t s i d e D o m a i n W a r n i n g ( B o o l e a n ) +
+ [ M e t h o d ] B o o l e a n I s I g n o r e D a t u m S h i f t W a r n i n g ( ) +
+ [ M e t h o d ] B o o l e a n I s I g n o r e O u t s i d e D o m a i n W a r n i n g ( ) +
+ [ M e t h o d ] B o o l e a n I s V a l i d S o u r c e P o i n t ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] B o o l e a n I s V a l i d S o u r c e P o i n t ( D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] B o o l e a n I s V a l i d T a r g e t P o i n t ( D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] B o o l e a n I s V a l i d T a r g e t P o i n t ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] V o i d R e s e t L a s t T r a n s f o r m S t a t u s ( ) +
+ [ M e t h o d ] V o i d S e t S o u r c e A n d T a r g e t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m , O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m ) +
+ [ F i e l d ] I n t 3 2 S o u r c e C r s E r r o r +
+ [ F i e l d ] I n t 3 2 T a r g e t C r s E r r o r +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e T r a n s f o r m ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e T r a n s f o r m ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e T r a n s f o r m ( D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g E n v e l o p e T r a n s f o r m ( O S G e o . M a p G u i d e . M g E n v e l o p e ) +
+ [ M e t h o d ] V o i d T r a n s f o r m C o o r d i n a t e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ F i e l d ] I n t 3 2 T r a n s f o r m D a t u m S h i f t W a r n i n g +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e T r a n s f o r m M ( D o u b l e , D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e T r a n s f o r m M ( D o u b l e , D o u b l e , D o u b l e ) +
+ [ F i e l d ] I n t 3 2 T r a n s f o r m O k +
+ [ F i e l d ] I n t 3 2 T r a n s f o r m O u t s i d e D o m a i n W a r n i n g +
+ [ F i e l d ] I n t 3 2 T r a n s f o r m T o t a l F a i l u r e +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m U n i t I n f o r m a t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t A b b r e v i a t i o n ( I n t 3 2 ) +
+ [ M e t h o d ] D o u b l e G e t A n g u l a r U n i t S c a l e ( I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2 G e t E n u m A n g u l a r U n i t s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2 G e t E n u m L i n e a r U n i t s ( ) +
+ [ M e t h o d ] D o u b l e G e t L i n e a r U n i t S c a l e ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e X Y : O S G e o . M a p G u i d e . M g C o o r d i n a t e +
+ [ M e t h o d ] I n t 3 2 g e t _ D i m e n s i o n ( ) +
+ [ M e t h o d ] D o u b l e g e t _ M ( ) +
+ [ M e t h o d ] D o u b l e g e t _ X ( ) +
+ [ M e t h o d ] D o u b l e g e t _ Y ( ) +
+ [ M e t h o d ] D o u b l e g e t _ Z ( ) +
+ [ M e t h o d ] I n t 3 2 G e t D i m e n s i o n ( ) +
+ [ M e t h o d ] D o u b l e G e t M ( ) +
+ [ M e t h o d ] D o u b l e G e t X ( ) +
+ [ M e t h o d ] D o u b l e G e t Y ( ) +
+ [ M e t h o d ] D o u b l e G e t Z ( ) +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e X Y M : O S G e o . M a p G u i d e . M g C o o r d i n a t e +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e X Y Z : O S G e o . M a p G u i d e . M g C o o r d i n a t e +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e X Y Z M : O S G e o . M a p G u i d e . M g C o o r d i n a t e +
+ t y p e O S G e o . M a p G u i d e . M g C u r v e : O S G e o . M a p G u i d e . M g G e o m e t r y +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e g e t _ E n d C o o r d i n a t e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e g e t _ S t a r t C o o r d i n a t e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e G e t E n d C o o r d i n a t e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e G e t S t a r t C o o r d i n a t e ( ) +
+ t y p e O S G e o . M a p G u i d e . M g C u r v e P o l y g o n : O S G e o . M a p G u i d e . M g R e g i o n +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r i c E n t i t y C o p y ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C u r v e R i n g g e t _ E x t e r i o r R i n g ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ G e o m e t r y T y p e ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ I n t e r i o r R i n g C o u n t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C u r v e R i n g G e t E x t e r i o r R i n g ( ) +
+ [ M e t h o d ] I n t 3 2 G e t G e o m e t r y T y p e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C u r v e R i n g G e t I n t e r i o r R i n g ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t I n t e r i o r R i n g C o u n t ( ) +
+ [ M e t h o d ] B o o l e a n I s C l o s e d ( ) +
+ [ M e t h o d ] B o o l e a n I s E m p t y ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r i c E n t i t y T r a n s f o r m ( O S G e o . M a p G u i d e . M g T r a n s f o r m ) +
+ [ S y s t e m . R e f l e c t i o n . D e f a u l t M e m b e r A t t r i b u t e ] +
+ t y p e O S G e o . M a p G u i d e . M g C u r v e P o l y g o n C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e P o l y g o n , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e P o l y g o n , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e P o l y g o n , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . I E n u m e r a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( ) +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g C u r v e P o l y g o n ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g C u r v e P o l y g o n ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g C u r v e P o l y g o n [ ] , I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 g e t _ C o u n t ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ I s R e a d O n l y ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C u r v e P o l y g o n g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g C u r v e P o l y g o n ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C u r v e P o l y g o n G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g C u r v e P o l y g o n ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g C u r v e P o l y g o n ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g C u r v e P o l y g o n ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g C u r v e P o l y g o n ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g C u r v e P o l y g o n ) +
+ t y p e O S G e o . M a p G u i d e . M g C u r v e R i n g : O S G e o . M a p G u i d e . M g R i n g +
+ [ M e t h o d ] I n t 3 2 g e t _ C o m p o n e n t T y p e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t C o m p o n e n t T y p e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C u r v e S e g m e n t G e t S e g m e n t ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g C u r v e R i n g C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e R i n g , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e R i n g , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e R i n g , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g C u r v e R i n g ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g C u r v e R i n g ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g C u r v e R i n g [ ] , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C u r v e R i n g g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g C u r v e R i n g ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C u r v e R i n g G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g C u r v e R i n g ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g C u r v e R i n g ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g C u r v e R i n g ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g C u r v e R i n g ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g C u r v e R i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g C u r v e S e g m e n t : O S G e o . M a p G u i d e . M g G e o m e t r y C o m p o n e n t +
+ t y p e O S G e o . M a p G u i d e . M g C u r v e S e g m e n t C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e S e g m e n t , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e S e g m e n t , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e S e g m e n t , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g C u r v e S e g m e n t ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g C u r v e S e g m e n t ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g C u r v e S e g m e n t [ ] , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C u r v e S e g m e n t g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g C u r v e S e g m e n t ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C u r v e S e g m e n t G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g C u r v e S e g m e n t ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g C u r v e S e g m e n t ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g C u r v e S e g m e n t ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g C u r v e S e g m e n t ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g C u r v e S e g m e n t ) +
+ t y p e O S G e o . M a p G u i d e . M g C u r v e S t r i n g : O S G e o . M a p G u i d e . M g C u r v e +
+ t y p e O S G e o . M a p G u i d e . M g C u r v e S t r i n g C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e S t r i n g , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e S t r i n g , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e S t r i n g , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g C u r v e S t r i n g ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g C u r v e S t r i n g ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g C u r v e S t r i n g [ ] , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C u r v e S t r i n g g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g C u r v e S t r i n g ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C u r v e S t r i n g G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g C u r v e S t r i n g ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g C u r v e S t r i n g ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g C u r v e S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g C u r v e S t r i n g ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g C u r v e S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g E n v e l o p e : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g C o o r d i n a t e , O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( D o u b l e , D o u b l e , D o u b l e , D o u b l e ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g E n v e l o p e ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g E n v e l o p e ) +
+ [ M e t h o d ] V o i d E x p a n d T o I n c l u d e ( O S G e o . M a p G u i d e . M g E n v e l o p e ) +
+ [ M e t h o d ] V o i d E x p a n d T o I n c l u d e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] D o u b l e g e t _ D e p t h ( ) +
+ [ M e t h o d ] D o u b l e g e t _ H e i g h t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e g e t _ L o w e r L e f t C o o r d i n a t e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e g e t _ U p p e r R i g h t C o o r d i n a t e ( ) +
+ [ M e t h o d ] D o u b l e g e t _ W i d t h ( ) +
+ [ M e t h o d ] D o u b l e G e t D e p t h ( ) +
+ [ M e t h o d ] D o u b l e G e t H e i g h t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e G e t L o w e r L e f t C o o r d i n a t e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e G e t U p p e r R i g h t C o o r d i n a t e ( ) +
+ [ M e t h o d ] D o u b l e G e t W i d t h ( ) +
+ [ M e t h o d ] B o o l e a n I n t e r s e c t s ( O S G e o . M a p G u i d e . M g E n v e l o p e ) +
+ [ M e t h o d ] B o o l e a n I s N u l l ( ) +
+ [ M e t h o d ] V o i d M a k e N u l l ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g E n v e l o p e T r a n s f o r m ( O S G e o . M a p G u i d e . M g T r a n s f o r m ) +
+ t y p e O S G e o . M a p G u i d e . M g G e o m e t r i c E n t i t y : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ i m p l e m e n t s S y s t e m . I D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g E n v e l o p e E n v e l o p e ( ) +
+ [ M e t h o d ] D o u b l e g e t _ A r e a ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o i n t g e t _ C e n t r o i d ( ) +
+ [ M e t h o d ] D o u b l e g e t _ L e n g t h ( ) +
+ [ M e t h o d ] D o u b l e G e t A r e a ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o i n t G e t C e n t r o i d ( ) +
+ [ M e t h o d ] D o u b l e G e t L e n g t h ( ) +
+ [ M e t h o d ] B o o l e a n I s S i m p l e ( ) +
+ [ M e t h o d ] B o o l e a n I s V a l i d ( ) +
+ t y p e O S G e o . M a p G u i d e . M g G e o m e t r y : O S G e o . M a p G u i d e . M g G e o m e t r i c E n t i t y +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y B o u n d a r y ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y B u f f e r ( D o u b l e , O S G e o . M a p G u i d e . M g M e a s u r e ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y C o n v e x H u l l ( ) +
+ [ M e t h o d ] B o o l e a n C r o s s e s ( O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y D i f f e r e n c e ( O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] B o o l e a n D i s j o i n t ( O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] D o u b l e D i s t a n c e ( O S G e o . M a p G u i d e . M g G e o m e t r y , O S G e o . M a p G u i d e . M g M e a s u r e ) +
+ [ M e t h o d ] B o o l e a n E q u a l s ( O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y I n t e r s e c t i o n ( O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] B o o l e a n I n t e r s e c t s ( O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] B o o l e a n O v e r l a p s ( O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r e p a r e d G e o m e t r y P r e p a r e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y S y m e t r i c D i f f e r e n c e ( O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y T e s s e l l a t e ( ) +
+ [ M e t h o d ] B o o l e a n T o u c h e s ( O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y U n i o n ( O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] B o o l e a n W i t h i n ( O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ t y p e O S G e o . M a p G u i d e . M g G e o m e t r y C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g G e o m e t r y , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g G e o m e t r y , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g G e o m e t r y , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] V o i d C l e a r ( ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g G e o m e t r y [ ] , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g G e o m e t r y ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ t y p e O S G e o . M a p G u i d e . M g G e o m e t r y C o m p o n e n t : O S G e o . M a p G u i d e . M g G e o m e t r i c E n t i t y +
+ t y p e O S G e o . M a p G u i d e . M g G e o m e t r y F a c t o r y : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g A r c S e g m e n t C r e a t e A r c S e g m e n t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e , O S G e o . M a p G u i d e . M g C o o r d i n a t e , O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e C r e a t e C o o r d i n a t e X Y ( D o u b l e , D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e C r e a t e C o o r d i n a t e X Y M ( D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e C r e a t e C o o r d i n a t e X Y Z ( D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e C r e a t e C o o r d i n a t e X Y Z M ( D o u b l e , D o u b l e , D o u b l e , D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C u r v e P o l y g o n C r e a t e C u r v e P o l y g o n ( O S G e o . M a p G u i d e . M g C u r v e R i n g , O S G e o . M a p G u i d e . M g C u r v e R i n g C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C u r v e R i n g C r e a t e C u r v e R i n g ( O S G e o . M a p G u i d e . M g C u r v e S e g m e n t C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C u r v e S t r i n g C r e a t e C u r v e S t r i n g ( O S G e o . M a p G u i d e . M g C u r v e S e g m e n t C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e a r R i n g C r e a t e L i n e a r R i n g ( O S G e o . M a p G u i d e . M g C o o r d i n a t e C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e a r S e g m e n t C r e a t e L i n e a r S e g m e n t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e S t r i n g C r e a t e L i n e S t r i n g ( O S G e o . M a p G u i d e . M g C o o r d i n a t e C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g M u l t i C u r v e P o l y g o n C r e a t e M u l t i C u r v e P o l y g o n ( O S G e o . M a p G u i d e . M g C u r v e P o l y g o n C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g M u l t i C u r v e S t r i n g C r e a t e M u l t i C u r v e S t r i n g ( O S G e o . M a p G u i d e . M g C u r v e S t r i n g C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g M u l t i G e o m e t r y C r e a t e M u l t i G e o m e t r y ( O S G e o . M a p G u i d e . M g G e o m e t r y C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g M u l t i L i n e S t r i n g C r e a t e M u l t i L i n e S t r i n g ( O S G e o . M a p G u i d e . M g L i n e S t r i n g C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g M u l t i P o i n t C r e a t e M u l t i P o i n t ( O S G e o . M a p G u i d e . M g P o i n t C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g M u l t i P o l y g o n C r e a t e M u l t i P o l y g o n ( O S G e o . M a p G u i d e . M g P o l y g o n C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o i n t C r e a t e P o i n t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o l y g o n C r e a t e P o l y g o n ( O S G e o . M a p G u i d e . M g L i n e a r R i n g , O S G e o . M a p G u i d e . M g L i n e a r R i n g C o l l e c t i o n ) +
+ t y p e O S G e o . M a p G u i d e . M g G e o m e t r y S i m p l i f i e r : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y S i m p l i f y ( O S G e o . M a p G u i d e . M g G e o m e t r y , D o u b l e , I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g L i n e a r R i n g : O S G e o . M a p G u i d e . M g R i n g +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e I t e r a t o r G e t C o o r d i n a t e s ( ) +
+ t y p e O S G e o . M a p G u i d e . M g L i n e a r R i n g C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g L i n e a r R i n g , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g L i n e a r R i n g , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g L i n e a r R i n g , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g L i n e a r R i n g ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g L i n e a r R i n g ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g L i n e a r R i n g [ ] , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e a r R i n g g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g L i n e a r R i n g ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e a r R i n g G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g L i n e a r R i n g ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g L i n e a r R i n g ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g L i n e a r R i n g ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g L i n e a r R i n g ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g L i n e a r R i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g L i n e a r S e g m e n t : O S G e o . M a p G u i d e . M g C u r v e S e g m e n t +
+ t y p e O S G e o . M a p G u i d e . M g L i n e S t r i n g : O S G e o . M a p G u i d e . M g C u r v e +
+ t y p e O S G e o . M a p G u i d e . M g L i n e S t r i n g C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g L i n e S t r i n g , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g L i n e S t r i n g , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g L i n e S t r i n g , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g L i n e S t r i n g ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g L i n e S t r i n g ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g L i n e S t r i n g [ ] , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e S t r i n g g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g L i n e S t r i n g ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e S t r i n g G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g L i n e S t r i n g ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g L i n e S t r i n g ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g L i n e S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g L i n e S t r i n g ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g L i n e S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g M e a s u r e : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] D o u b l e G e t A z i m u t h ( O S G e o . M a p G u i d e . M g C o o r d i n a t e , O S G e o . M a p G u i d e . M g C o o r d i n a t e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e G e t C o o r d i n a t e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e , D o u b l e , D o u b l e ) +
+ t y p e O S G e o . M a p G u i d e . M g M u l t i C u r v e P o l y g o n : O S G e o . M a p G u i d e . M g A g g r e g a t e G e o m e t r y +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C u r v e P o l y g o n G e t C u r v e P o l y g o n ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g M u l t i C u r v e S t r i n g : O S G e o . M a p G u i d e . M g A g g r e g a t e G e o m e t r y +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C u r v e S t r i n g G e t C u r v e S t r i n g ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g M u l t i G e o m e t r y : O S G e o . M a p G u i d e . M g A g g r e g a t e G e o m e t r y +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y G e t G e o m e t r y ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g M u l t i L i n e S t r i n g : O S G e o . M a p G u i d e . M g A g g r e g a t e G e o m e t r y +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e S t r i n g G e t L i n e S t r i n g ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g M u l t i P o i n t : O S G e o . M a p G u i d e . M g A g g r e g a t e G e o m e t r y +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o i n t G e t P o i n t ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g M u l t i P o l y g o n : O S G e o . M a p G u i d e . M g A g g r e g a t e G e o m e t r y +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e I t e r a t o r g e t _ C o o r d i n a t e s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o l y g o n G e t P o l y g o n ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g P o i n t : O S G e o . M a p G u i d e . M g G e o m e t r y +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e g e t _ C o o r d i n a t e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e G e t C o o r d i n a t e ( ) +
+ t y p e O S G e o . M a p G u i d e . M g P o i n t C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g P o i n t , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g P o i n t , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g P o i n t , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g P o i n t ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g P o i n t ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g P o i n t [ ] , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o i n t g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g P o i n t ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o i n t G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g P o i n t ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g P o i n t ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g P o i n t ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g P o i n t ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g P o i n t ) +
+ t y p e O S G e o . M a p G u i d e . M g P o l y g o n : O S G e o . M a p G u i d e . M g R e g i o n +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e a r R i n g g e t _ E x t e r i o r R i n g ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e a r R i n g G e t E x t e r i o r R i n g ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L i n e a r R i n g G e t I n t e r i o r R i n g ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g P o l y g o n C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g P o l y g o n , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g P o l y g o n , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g P o l y g o n , O S G e o . M a p G u i d e . G e o m e t r y , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g P o l y g o n ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g P o l y g o n ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g P o l y g o n [ ] , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o l y g o n g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g P o l y g o n ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o l y g o n G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g P o l y g o n ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g P o l y g o n ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g P o l y g o n ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g P o l y g o n ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g P o l y g o n ) +
+ t y p e O S G e o . M a p G u i d e . M g P r e p a r e d G e o m e t r y : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ t y p e O S G e o . M a p G u i d e . M g R e g i o n : O S G e o . M a p G u i d e . M g G e o m e t r y +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o i n t g e t _ P o i n t I n R e g i o n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o i n t G e t P o i n t I n R e g i o n ( ) +
+ t y p e O S G e o . M a p G u i d e . M g R i n g : O S G e o . M a p G u i d e . M g G e o m e t r y C o m p o n e n t +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o i n t g e t _ P o i n t I n R i n g ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o i n t G e t P o i n t I n R i n g ( ) +
+ t y p e O S G e o . M a p G u i d e . M g T r a n s f o r m : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ t y p e O S G e o . M a p G u i d e . M g W k t R e a d e r W r i t e r : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y R e a d ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g T r a n s f o r m ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y R e a d ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g W r i t e ( O S G e o . M a p G u i d e . M g G e o m e t r y ) +
+ [ M e t h o d ] S y s t e m . S t r i n g W r i t e ( O S G e o . M a p G u i d e . M g G e o m e t r y , O S G e o . M a p G u i d e . M g T r a n s f o r m ) +
+ A s s e m b l y : O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l +
+ t y p e O S G e o . M a p G u i d e . M g L a y e r G r o u p T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 B a s e M a p +
+ [ F i e l d ] I n t 3 2 B a s e M a p F r o m T i l e S e t +
+ [ F i e l d ] I n t 3 2 N o r m a l +
+ t y p e O S G e o . M a p G u i d e . M g L a y e r T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 D y n a m i c +
+ t y p e O S G e o . M a p G u i d e . M g S e r v i c e T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 1 6 D r a w i n g S e r v i c e +
+ [ F i e l d ] I n t 1 6 F e a t u r e S e r v i c e +
+ [ F i e l d ] I n t 1 6 K m l S e r v i c e +
+ [ F i e l d ] I n t 1 6 M a p p i n g S e r v i c e +
+ [ F i e l d ] I n t 1 6 P r o f i l i n g S e r v i c e +
+ [ F i e l d ] I n t 1 6 R e n d e r i n g S e r v i c e +
+ [ F i e l d ] I n t 1 6 R e s o u r c e S e r v i c e +
+ [ F i e l d ] I n t 1 6 T i l e S e r v i c e +
+ t y p e O S G e o . M a p G u i d e . M g U s e r : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g A d m i n i s t r a t o r +
+ [ F i e l d ] S y s t e m . S t r i n g A n o n y m o u s +
+ [ F i e l d ] S y s t e m . S t r i n g A u t h o r +
+ [ F i e l d ] S y s t e m . S t r i n g W f s U s e r +
+ [ F i e l d ] S y s t e m . S t r i n g W m s U s e r +
+ t y p e O S G e o . M a p G u i d e . M g G r o u p : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g E v e r y o n e +
+ t y p e O S G e o . M a p G u i d e . M g R o l e : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g V i e w e r +
+ t y p e O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 D e l e t e F e a t u r e s +
+ [ F i e l d ] I n t 3 2 I n s e r t F e a t u r e s +
+ [ F i e l d ] I n t 3 2 L o c k F e a t u r e s +
+ [ F i e l d ] I n t 3 2 U n l o c k F e a t u r e s +
+ [ F i e l d ] I n t 3 2 U p d a t e F e a t u r e s +
+ t y p e O S G e o . M a p G u i d e . M g F e a t u r e G e o m e t r i c T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 C u r v e +
+ [ F i e l d ] I n t 3 2 P o i n t +
+ [ F i e l d ] I n t 3 2 S o l i d +
+ [ F i e l d ] I n t 3 2 S u r f a c e +
+ t y p e O S G e o . M a p G u i d e . M g F e a t u r e S p a t i a l O p e r a t i o n s : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 C o n t a i n s +
+ [ F i e l d ] I n t 3 2 C o v e r e d B y +
+ [ F i e l d ] I n t 3 2 C r o s s e s +
+ [ F i e l d ] I n t 3 2 D i s j o i n t +
+ [ F i e l d ] I n t 3 2 E n v e l o p e I n t e r s e c t s +
+ [ F i e l d ] I n t 3 2 E q u a l s +
+ [ F i e l d ] I n t 3 2 I n s i d e +
+ [ F i e l d ] I n t 3 2 I n t e r s e c t s +
+ [ F i e l d ] I n t 3 2 O v e r l a p s +
+ [ F i e l d ] I n t 3 2 T o u c h e s +
+ [ F i e l d ] I n t 3 2 W i t h i n +
+ t y p e O S G e o . M a p G u i d e . M g O b j e c t P r o p e r t y T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 C o l l e c t i o n +
+ [ F i e l d ] I n t 3 2 O r d e r e d C o l l e c t i o n +
+ [ F i e l d ] I n t 3 2 V a l u e +
+ t y p e O S G e o . M a p G u i d e . M g O r d e r i n g O p t i o n : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 A s c e n d i n g +
+ [ F i e l d ] I n t 3 2 D e s c e n d i n g +
+ t y p e O S G e o . M a p G u i d e . M g P a r a m e t e r D i r e c t i o n : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 I n p u t +
+ [ F i e l d ] I n t 3 2 I n p u t O u t p u t +
+ [ F i e l d ] I n t 3 2 O u t p u t +
+ [ F i e l d ] I n t 3 2 R e t +
+ t y p e O S G e o . M a p G u i d e . M g R a s t e r D a t a M o d e l T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 B i t o n a l +
+ [ F i e l d ] I n t 3 2 D a t a +
+ [ F i e l d ] I n t 3 2 G r a y +
+ [ F i e l d ] I n t 3 2 P a l e t t e +
+ [ F i e l d ] I n t 3 2 R G B +
+ [ F i e l d ] I n t 3 2 R G B A +
+ [ F i e l d ] I n t 3 2 U n k n o w n +
+ t y p e O S G e o . M a p G u i d e . M g R e a d e r T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 D a t a R e a d e r +
+ [ F i e l d ] I n t 3 2 F e a t u r e R e a d e r +
+ [ F i e l d ] I n t 3 2 S q l D a t a R e a d e r +
+ t y p e O S G e o . M a p G u i d e . M g R e p o s i t o r y T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g L i b r a r y +
+ [ F i e l d ] S y s t e m . S t r i n g S e s s i o n +
+ t y p e O S G e o . M a p G u i d e . M g R e s o u r c e T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g A p p l i c a t i o n D e f i n i t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g D r a w i n g S o u r c e +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S o u r c e +
+ [ F i e l d ] S y s t e m . S t r i n g F o l d e r +
+ [ F i e l d ] S y s t e m . S t r i n g L a y e r D e f i n i t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g L o a d P r o c e d u r e +
+ [ F i e l d ] S y s t e m . S t r i n g M a p +
+ [ F i e l d ] S y s t e m . S t r i n g M a p D e f i n i t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g P r i n t L a y o u t +
+ [ F i e l d ] S y s t e m . S t r i n g S e l e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g S y m b o l D e f i n i t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g S y m b o l L i b r a r y +
+ [ F i e l d ] S y s t e m . S t r i n g T i l e S e t D e f i n i t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g W a t e r m a r k D e f i n i t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g W e b L a y o u t +
+ t y p e O S G e o . M a p G u i d e . M g R e s o u r c e T a g : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g D a t a F i l e P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g D a t a P a t h A l i a s B e g i n +
+ [ F i e l d ] S y s t e m . S t r i n g D a t a P a t h A l i a s E n d +
+ [ F i e l d ] S y s t e m . S t r i n g L o g i n P a s s w o r d +
+ [ F i e l d ] S y s t e m . S t r i n g L o g i n U s e r n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g P a s s w o r d +
+ [ F i e l d ] S y s t e m . S t r i n g P r o x y P a s s w o r d +
+ [ F i e l d ] S y s t e m . S t r i n g P r o x y P o r t +
+ [ F i e l d ] S y s t e m . S t r i n g P r o x y S e r v e r +
+ [ F i e l d ] S y s t e m . S t r i n g P r o x y U s e r n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g T i l e C a c h e P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g U s e r n a m e +
+ t y p e O S G e o . M a p G u i d e . M g R e s o u r c e D a t a N a m e : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g P r o x y C r e d e n t i a l s +
+ [ F i e l d ] S y s t e m . S t r i n g P r o x y S e r v e r N a m e +
+ [ F i e l d ] S y s t e m . S t r i n g P r o x y S e r v e r P o r t +
+ [ F i e l d ] S y s t e m . S t r i n g U s e r C r e d e n t i a l s +
+ t y p e O S G e o . M a p G u i d e . M g R e s o u r c e D a t a T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g F i l e +
+ [ F i e l d ] S y s t e m . S t r i n g S t r e a m +
+ [ F i e l d ] S y s t e m . S t r i n g S t r i n g +
+ t y p e O S G e o . M a p G u i d e . M g R e s o u r c e P e r m i s s i o n : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g P e r m i s s i o n N o A c c e s s +
+ [ F i e l d ] S y s t e m . S t r i n g P e r m i s s i o n R e a d O n l y +
+ [ F i e l d ] S y s t e m . S t r i n g P e r m i s s i o n R e a d W r i t e +
+ t y p e O S G e o . M a p G u i d e . M g R e s o u r c e H e a d e r P r o p e r t i e s : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 G e n e r a l +
+ [ F i e l d ] I n t 3 2 M e t a d a t a +
+ [ F i e l d ] I n t 3 2 S e c u r i t y +
+ t y p e O S G e o . M a p G u i d e . M g S p a t i a l C o n t e x t E x t e n t T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 s c D y n a m i c +
+ [ F i e l d ] I n t 3 2 s c S t a t i c +
+ t y p e O S G e o . M a p G u i d e . M g C o l o r : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( I n t 1 6 , I n t 1 6 , I n t 1 6 ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . D r a w i n g . C o l o r ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( I n t 1 6 , I n t 1 6 , I n t 1 6 , I n t 1 6 ) +
+ [ M e t h o d ] I n t 1 6 g e t _ A l p h a ( ) +
+ [ M e t h o d ] I n t 1 6 g e t _ B l u e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ C o l o r ( ) +
+ [ M e t h o d ] I n t 1 6 g e t _ G r e e n ( ) +
+ [ M e t h o d ] I n t 1 6 g e t _ R e d ( ) +
+ [ M e t h o d ] I n t 1 6 G e t A l p h a ( ) +
+ [ M e t h o d ] I n t 1 6 G e t B l u e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t C o l o r ( ) +
+ [ M e t h o d ] I n t 1 6 G e t G r e e n ( ) +
+ [ M e t h o d ] I n t 1 6 G e t R e d ( ) +
+ t y p e O S G e o . M a p G u i d e . M g B l o b P r o p e r t y : O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g B y t e R e a d e r ) +
+ [ M e t h o d ] I n t 1 6 g e t _ P r o p e r t y T y p e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r g e t _ V a l u e ( ) +
+ [ M e t h o d ] I n t 1 6 G e t P r o p e r t y T y p e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t V a l u e ( ) +
+ [ M e t h o d ] V o i d s e t _ V a l u e ( O S G e o . M a p G u i d e . M g B y t e R e a d e r ) +
+ [ M e t h o d ] V o i d S e t V a l u e ( O S G e o . M a p G u i d e . M g B y t e R e a d e r ) +
+ t y p e O S G e o . M a p G u i d e . M g B o o l e a n P r o p e r t y : O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , B o o l e a n ) +
+ [ M e t h o d ] B o o l e a n g e t _ V a l u e ( ) +
+ [ M e t h o d ] B o o l e a n G e t V a l u e ( ) +
+ [ M e t h o d ] V o i d s e t _ V a l u e ( B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t V a l u e ( B o o l e a n ) +
+ t y p e O S G e o . M a p G u i d e . M g B y t e P r o p e r t y : O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , B y t e ) +
+ [ M e t h o d ] B y t e g e t _ V a l u e ( ) +
+ [ M e t h o d ] B y t e G e t V a l u e ( ) +
+ [ M e t h o d ] V o i d s e t _ V a l u e ( B y t e ) +
+ [ M e t h o d ] V o i d S e t V a l u e ( B y t e ) +
+ t y p e O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n : O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e +
+ [ M e t h o d ] V o i d D e l e t e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n g e t _ B a s e C l a s s D e f i n i t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ D e f a u l t G e o m e t r y P r o p e r t y N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ D e s c r i p t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ N a m e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n G e t B a s e C l a s s D e f i n i t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D e f a u l t G e o m e t r y P r o p e r t y N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D e s c r i p t i o n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n G e t I d e n t i t y P r o p e r t i e s ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t N a m e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n G e t P r o p e r t i e s ( ) +
+ [ M e t h o d ] B o o l e a n I s A b s t r a c t ( ) +
+ [ M e t h o d ] B o o l e a n I s C o m p u t e d ( ) +
+ [ M e t h o d ] V o i d s e t _ D e f a u l t G e o m e t r y P r o p e r t y N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ D e s c r i p t i o n ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t D e f a u l t G e o m e t r y P r o p e r t y N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t D e s c r i p t i o n ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t N a m e ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n : O S G e o . M a p G u i d e . M g C o l l e c t i o n +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n [ ] , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t C o u n t ( ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n ) +
+ [ M e t h o d ] V o i d R e m o v e A t ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r T o X m l ( ) +
+ t y p e O S G e o . M a p G u i d e . M g C l o b P r o p e r t y : O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y +
+ t y p e O S G e o . M a p G u i d e . M g D a t a P r o p e r t y D e f i n i t i o n : O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n +
+ [ M e t h o d ] I n t 3 2 g e t _ D a t a T y p e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ D e f a u l t V a l u e ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ L e n g t h ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ N u l l a b l e ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ P r e c i s i o n ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ R e a d O n l y ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ S c a l e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t D a t a T y p e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D e f a u l t V a l u e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t L e n g t h ( ) +
+ [ M e t h o d ] B o o l e a n G e t N u l l a b l e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t P r e c i s i o n ( ) +
+ [ M e t h o d ] B o o l e a n G e t R e a d O n l y ( ) +
+ [ M e t h o d ] I n t 3 2 G e t S c a l e ( ) +
+ [ M e t h o d ] B o o l e a n I s A u t o G e n e r a t e d ( ) +
+ [ M e t h o d ] V o i d s e t _ D a t a T y p e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d s e t _ D e f a u l t V a l u e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ L e n g t h ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d s e t _ N u l l a b l e ( B o o l e a n ) +
+ [ M e t h o d ] V o i d s e t _ P r e c i s i o n ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d s e t _ R e a d O n l y ( B o o l e a n ) +
+ [ M e t h o d ] V o i d s e t _ S c a l e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t A u t o G e n e r a t i o n ( B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t D a t a T y p e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t D e f a u l t V a l u e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t L e n g t h ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t N u l l a b l e ( B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t P r e c i s i o n ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t R e a d O n l y ( B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t S c a l e ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g D a t a R e a d e r : O S G e o . M a p G u i d e . M g R e a d e r +
+ t y p e O S G e o . M a p G u i d e . M g D a t e T i m e P r o p e r t y : O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g D a t e T i m e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D a t e T i m e g e t _ V a l u e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D a t e T i m e G e t V a l u e ( ) +
+ [ M e t h o d ] V o i d s e t _ V a l u e ( O S G e o . M a p G u i d e . M g D a t e T i m e ) +
+ [ M e t h o d ] V o i d S e t V a l u e ( O S G e o . M a p G u i d e . M g D a t e T i m e ) +
+ t y p e O S G e o . M a p G u i d e . M g D e l e t e F e a t u r e s : O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 3 2 g e t _ C o m m a n d T y p e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ F e a t u r e C l a s s N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ F i l t e r T e x t ( ) +
+ [ M e t h o d ] I n t 3 2 G e t C o m m a n d T y p e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t F e a t u r e C l a s s N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t F i l t e r T e x t ( ) +
+ t y p e O S G e o . M a p G u i d e . M g D o u b l e P r o p e r t y : O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , D o u b l e ) +
+ [ M e t h o d ] D o u b l e g e t _ V a l u e ( ) +
+ [ M e t h o d ] D o u b l e G e t V a l u e ( ) +
+ [ M e t h o d ] V o i d s e t _ V a l u e ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t V a l u e ( D o u b l e ) +
+ t y p e O S G e o . M a p G u i d e . M g F e a t u r e A g g r e g a t e O p t i o n s : O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s +
+ [ M e t h o d ] V o i d S e l e c t D i s t i n c t ( B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t G r o u p i n g F i l t e r ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ t y p e O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d [ ] , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d ) +
+ t y p e O S G e o . M a p G u i d e . M g F e a t u r e P r o p e r t y : O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r g e t _ V a l u e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r G e t V a l u e ( ) +
+ [ M e t h o d ] V o i d s e t _ V a l u e ( O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r ) +
+ [ M e t h o d ] V o i d S e t V a l u e ( O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r ) +
+ t y p e O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ M e t h o d ] I n t 3 2 A d d C o m p u t e d P r o p e r t y ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 3 2 A d d F e a t u r e P r o p e r t y ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d R e m o v e C o m p u t e d P r o p e r t y ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d R e m o v e F e a t u r e P r o p e r t y ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t B i n a r y O p e r a t o r ( B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t F e t c h S i z e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t F i l t e r ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t O r d e r i n g F i l t e r ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t S p a t i a l F i l t e r ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g G e o m e t r y , I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r : O S G e o . M a p G u i d e . M g R e a d e r +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n G e t C l a s s D e f i n i t i o n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r G e t F e a t u r e O b j e c t ( I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r G e t F e a t u r e O b j e c t ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a : O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n G e t C l a s s e s ( ) +
+ [ S y s t e m . R e f l e c t i o n . D e f a u l t M e m b e r A t t r i b u t e ] +
+ t y p e O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n : O S G e o . M a p G u i d e . M g C o l l e c t i o n +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . I E n u m e r a b l e +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a [ ] , I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 g e t _ C o u n t ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ I s R e a d O n l y ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a ) +
+ t y p e O S G e o . M a p G u i d e . M g F e a t u r e S e r v i c e : O S G e o . M a p G u i d e . M g S e r v i c e +
+ [ M e t h o d ] V o i d A p p l y S c h e m a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g T r a n s a c t i o n B e g i n T r a n s a c t i o n ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] V o i d C r e a t e F e a t u r e S o u r c e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , O S G e o . M a p G u i d e . M g F e a t u r e S o u r c e P a r a m s ) +
+ [ M e t h o d ] I n t 3 2 D e l e t e F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g T r a n s a c t i o n ) +
+ [ M e t h o d ] I n t 3 2 D e l e t e F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ S y s t e m . O b s o l e t e A t t r i b u t e ] +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n D e s c r i b e S c h e m a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n D e s c r i b e S c h e m a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ) +
+ [ M e t h o d ] S y s t e m . S t r i n g D e s c r i b e S c h e m a A s X m l ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g D e s c r i b e S c h e m a A s X m l ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r D e s c r i b e W f s F e a t u r e T y p e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r D e s c r i b e W f s F e a t u r e T y p e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r E n u m e r a t e D a t a S t o r e s ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 3 2 E x e c u t e S q l N o n Q u e r y ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 3 2 E x e c u t e S q l N o n Q u e r y ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g P a r a m e t e r C o l l e c t i o n , O S G e o . M a p G u i d e . M g T r a n s a c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S q l D a t a R e a d e r E x e c u t e S q l Q u e r y ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S q l D a t a R e a d e r E x e c u t e S q l Q u e r y ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g P a r a m e t e r C o l l e c t i o n , O S G e o . M a p G u i d e . M g T r a n s a c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t C a p a b i l i t i e s ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t C a p a b i l i t i e s ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n G e t C l a s s D e f i n i t i o n ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n G e t C l a s s e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n G e t C o n n e c t i o n P r o p e r t y V a l u e s ( S y s t e m . S t r i n g , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t F e a t u r e P r o v i d e r s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r G e t L o c k e d F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L o n g T r a n s a c t i o n R e a d e r G e t L o n g T r a n s a c t i o n s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , B o o l e a n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t S c h e m a M a p p i n g ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n G e t S c h e m a s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S p a t i a l C o n t e x t R e a d e r G e t S p a t i a l C o n t e x t s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , B o o l e a n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t W f s F e a t u r e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , S y s t e m . S t r i n g , S y s t e m . S t r i n g , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t W f s F e a t u r e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , S y s t e m . S t r i n g , S y s t e m . S t r i n g , I n t 3 2 , S y s t e m . S t r i n g , S y s t e m . S t r i n g , S y s t e m . S t r i n g , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r G e t W f s R e a d e r ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , S y s t e m . S t r i n g , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r I n s e r t F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n , O S G e o . M a p G u i d e . M g T r a n s a c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r I n s e r t F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r I n s e r t F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n , O S G e o . M a p G u i d e . M g T r a n s a c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r I n s e r t F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n ) +
+ [ M e t h o d ] S y s t e m . S t r i n g S c h e m a T o X m l ( O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D a t a R e a d e r S e l e c t A g g r e g a t e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g F e a t u r e A g g r e g a t e O p t i o n s ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r S e l e c t F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r S e l e c t F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s ) +
+ [ M e t h o d ] B o o l e a n S e t L o n g T r a n s a c t i o n ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n T e s t C o n n e c t i o n ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n T e s t C o n n e c t i o n ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n U p d a t e F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n , O S G e o . M a p G u i d e . M g T r a n s a c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n U p d a t e F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n , B o o l e a n ) +
+ [ M e t h o d ] I n t 3 2 U p d a t e M a t c h i n g F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g T r a n s a c t i o n ) +
+ [ M e t h o d ] I n t 3 2 U p d a t e M a t c h i n g F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n X m l T o S c h e m a ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g F e a t u r e S o u r c e P a r a m s : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ i m p l e m e n t s S y s t e m . I D i s p o s a b l e +
+ t y p e O S G e o . M a p G u i d e . M g F i l e F e a t u r e S o u r c e P a r a m s : O S G e o . M a p G u i d e . M g F e a t u r e S o u r c e P a r a m s +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , S y s t e m . S t r i n g , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ C o o r d i n a t e S y s t e m W k t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a g e t _ F e a t u r e S c h e m a ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ F i l e N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ P r o v i d e r N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ S p a t i a l C o n t e x t D e s c r i p t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ S p a t i a l C o n t e x t N a m e ( ) +
+ [ M e t h o d ] D o u b l e g e t _ X Y T o l e r a n c e ( ) +
+ [ M e t h o d ] D o u b l e g e t _ Z T o l e r a n c e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t C o o r d i n a t e S y s t e m W k t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a G e t F e a t u r e S c h e m a ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t F i l e N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t P r o v i d e r N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S p a t i a l C o n t e x t D e s c r i p t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S p a t i a l C o n t e x t N a m e ( ) +
+ [ M e t h o d ] D o u b l e G e t X Y T o l e r a n c e ( ) +
+ [ M e t h o d ] D o u b l e G e t Z T o l e r a n c e ( ) +
+ [ M e t h o d ] V o i d s e t _ C o o r d i n a t e S y s t e m W k t ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ F e a t u r e S c h e m a ( O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a ) +
+ [ M e t h o d ] V o i d s e t _ F i l e N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ P r o v i d e r N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ S p a t i a l C o n t e x t D e s c r i p t i o n ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ S p a t i a l C o n t e x t N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ X Y T o l e r a n c e ( D o u b l e ) +
+ [ M e t h o d ] V o i d s e t _ Z T o l e r a n c e ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t C o o r d i n a t e S y s t e m W k t ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t F e a t u r e S c h e m a ( O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a ) +
+ [ M e t h o d ] V o i d S e t F i l e N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t P r o v i d e r N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t S p a t i a l C o n t e x t D e s c r i p t i o n ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t S p a t i a l C o n t e x t N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t X Y T o l e r a n c e ( D o u b l e ) +
+ [ M e t h o d ] V o i d S e t Z T o l e r a n c e ( D o u b l e ) +
+ t y p e O S G e o . M a p G u i d e . M g G e o J s o n W r i t e r : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] S y s t e m . S t r i n g F e a t u r e T o G e o J s o n ( O S G e o . M a p G u i d e . M g R e a d e r , O S G e o . M a p G u i d e . M g T r a n s f o r m , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g F e a t u r e T o G e o J s o n ( O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r , O S G e o . M a p G u i d e . M g T r a n s f o r m ) +
+ [ M e t h o d ] B o o l e a n I s P r e c i s i o n E n a b l e d ( ) +
+ [ M e t h o d ] V o i d S e t P r e c i s i o n E n a b l e d ( B o o l e a n ) +
+ t y p e O S G e o . M a p G u i d e . M g G e o m e t r i c P r o p e r t y D e f i n i t i o n : O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n +
+ [ M e t h o d ] I n t 3 2 g e t _ G e o m e t r y T y p e s ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ H a s E l e v a t i o n ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ H a s M e a s u r e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ S p a t i a l C o n t e x t A s s o c i a t i o n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y T y p e I n f o g e t _ S p e c i f i c G e o m e t r y T y p e s ( ) +
+ [ M e t h o d ] I n t 3 2 G e t G e o m e t r y T y p e s ( ) +
+ [ M e t h o d ] B o o l e a n G e t H a s E l e v a t i o n ( ) +
+ [ M e t h o d ] B o o l e a n G e t H a s M e a s u r e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S p a t i a l C o n t e x t A s s o c i a t i o n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g G e o m e t r y T y p e I n f o G e t S p e c i f i c G e o m e t r y T y p e s ( ) +
+ [ M e t h o d ] V o i d s e t _ G e o m e t r y T y p e s ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d s e t _ H a s E l e v a t i o n ( B o o l e a n ) +
+ [ M e t h o d ] V o i d s e t _ H a s M e a s u r e ( B o o l e a n ) +
+ [ M e t h o d ] V o i d s e t _ S p a t i a l C o n t e x t A s s o c i a t i o n ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ S p e c i f i c G e o m e t r y T y p e s ( O S G e o . M a p G u i d e . M g G e o m e t r y T y p e I n f o ) +
+ [ M e t h o d ] V o i d S e t G e o m e t r y T y p e s ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t H a s E l e v a t i o n ( B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t H a s M e a s u r e ( B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t S p a t i a l C o n t e x t A s s o c i a t i o n ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t S p e c i f i c G e o m e t r y T y p e s ( O S G e o . M a p G u i d e . M g G e o m e t r y T y p e I n f o ) +
+ t y p e O S G e o . M a p G u i d e . M g G e o m e t r y P r o p e r t y : O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y +
+ t y p e O S G e o . M a p G u i d e . M g G e o m e t r y T y p e I n f o : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ M e t h o d ] I n t 3 2 G e t T y p e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t T y p e s ( O S G e o . M a p G u i d e . M g I n t C o l l e c t i o n ) +
+ t y p e O S G e o . M a p G u i d e . M g G w s F e a t u r e R e a d e r : O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r +
+ t y p e O S G e o . M a p G u i d e . M g I n s e r t F e a t u r e s : O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n g e t _ P r o p e r t y V a l u e s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n G e t P r o p e r t y V a l u e s ( ) +
+ t y p e O S G e o . M a p G u i d e . M g I n t 1 6 P r o p e r t y : O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , I n t 1 6 ) +
+ [ M e t h o d ] I n t 1 6 g e t _ V a l u e ( ) +
+ [ M e t h o d ] I n t 1 6 G e t V a l u e ( ) +
+ [ M e t h o d ] V o i d s e t _ V a l u e ( I n t 1 6 ) +
+ [ M e t h o d ] V o i d S e t V a l u e ( I n t 1 6 ) +
+ t y p e O S G e o . M a p G u i d e . M g I n t 3 2 P r o p e r t y : O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 g e t _ V a l u e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t V a l u e ( ) +
+ [ M e t h o d ] V o i d s e t _ V a l u e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t V a l u e ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g I n t 6 4 P r o p e r t y : O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , I n t 6 4 ) +
+ [ M e t h o d ] I n t 6 4 g e t _ V a l u e ( ) +
+ [ M e t h o d ] I n t 6 4 G e t V a l u e ( ) +
+ [ M e t h o d ] V o i d s e t _ V a l u e ( I n t 6 4 ) +
+ [ M e t h o d ] V o i d S e t V a l u e ( I n t 6 4 ) +
+ t y p e O S G e o . M a p G u i d e . M g I n t C o l l e c t i o n : O S G e o . M a p G u i d e . M g C o l l e c t i o n +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ S y s t e m . I n t 3 2 , m s c o r l i b , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = b 7 7 a 5 c 5 6 1 9 3 4 e 0 8 9 ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ S y s t e m . I n t 3 2 , m s c o r l i b , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = b 7 7 a 5 c 5 6 1 9 3 4 e 0 8 9 ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ S y s t e m . I n t 3 2 , m s c o r l i b , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = b 7 7 a 5 c 5 6 1 9 3 4 e 0 8 9 ] ] +
+ [ M e t h o d ] V o i d A d d ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d C l e a r ( ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d C o p y T o ( I n t 3 2 [ ] , I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ S y s t e m . I n t 3 2 ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] I n t 3 2 G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g L a y e r B a s e : O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g T r a n s a c t i o n B e g i n T r a n s a c t i o n ( ) +
+ [ M e t h o d ] I n t 3 2 D e l e t e F e a t u r e s ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g T r a n s a c t i o n ) +
+ [ M e t h o d ] V o i d F o r c e R e f r e s h ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ D i s p l a y I n L e g e n d ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ E x p a n d I n L e g e n d ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ F e a t u r e G e o m e t r y N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ F e a t u r e S o u r c e I d ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ F i l t e r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L a y e r G r o u p g e t _ G r o u p ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r g e t _ L a y e r D e f i n i t i o n ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ L a y e r T y p e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ L e g e n d L a b e l ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ S e l e c t a b l e ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ V i s i b l e ( ) +
+ [ M e t h o d ] B o o l e a n G e t D i s p l a y I n L e g e n d ( ) +
+ [ M e t h o d ] B o o l e a n G e t E x p a n d I n L e g e n d ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t F e a t u r e G e o m e t r y N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t F e a t u r e S o u r c e I d ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t F i l t e r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L a y e r G r o u p G e t G r o u p ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r G e t L a y e r D e f i n i t i o n ( ) +
+ [ M e t h o d ] I n t 3 2 G e t L a y e r T y p e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t L e g e n d L a b e l ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t O b j e c t I d ( ) +
+ [ M e t h o d ] B o o l e a n G e t S e l e c t a b l e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S p a t i a l C o n t e x t R e a d e r G e t S p a t i a l C o n t e x t s ( B o o l e a n ) +
+ [ M e t h o d ] B o o l e a n G e t V i s i b l e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r I n s e r t F e a t u r e s ( O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n , O S G e o . M a p G u i d e . M g T r a n s a c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r I n s e r t F e a t u r e s ( O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n , O S G e o . M a p G u i d e . M g T r a n s a c t i o n ) +
+ [ M e t h o d ] B o o l e a n I s V i s i b l e ( ) +
+ [ M e t h o d ] B o o l e a n N e e d s R e f r e s h ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D a t a R e a d e r S e l e c t A g g r e g a t e ( O S G e o . M a p G u i d e . M g F e a t u r e A g g r e g a t e O p t i o n s ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r S e l e c t F e a t u r e s ( O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r S e l e c t F e a t u r e s ( O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s ) +
+ [ M e t h o d ] V o i d s e t _ D i s p l a y I n L e g e n d ( B o o l e a n ) +
+ [ M e t h o d ] V o i d s e t _ G r o u p ( O S G e o . M a p G u i d e . M g L a y e r G r o u p ) +
+ [ M e t h o d ] V o i d s e t _ L e g e n d L a b e l ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ S e l e c t a b l e ( B o o l e a n ) +
+ [ M e t h o d ] V o i d s e t _ V i s i b l e ( B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t D i s p l a y I n L e g e n d ( B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t G r o u p ( O S G e o . M a p G u i d e . M g L a y e r G r o u p ) +
+ [ M e t h o d ] V o i d S e t L a y e r D e f i n i t i o n ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e ) +
+ [ M e t h o d ] V o i d S e t L e g e n d L a b e l ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t S e l e c t a b l e ( B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t V i s i b l e ( B o o l e a n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n U p d a t e F e a t u r e s ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n U p d a t e F e a t u r e s ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n , O S G e o . M a p G u i d e . M g T r a n s a c t i o n ) +
+ [ M e t h o d ] I n t 3 2 U p d a t e M a t c h i n g F e a t u r e s ( O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g T r a n s a c t i o n ) +
+ t y p e O S G e o . M a p G u i d e . M g L a y e r C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g L a y e r B a s e , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g L a y e r B a s e , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g L a y e r B a s e , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g L a y e r B a s e ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g L a y e r B a s e ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g L a y e r B a s e [ ] , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L a y e r B a s e g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g L a y e r B a s e ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L a y e r B a s e G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L a y e r B a s e G e t I t e m ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g L a y e r B a s e ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g L a y e r B a s e ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g L a y e r B a s e ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g L a y e r B a s e ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g L a y e r B a s e ) +
+ t y p e O S G e o . M a p G u i d e . M g L a y e r G r o u p : O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e +
+ [ M e t h o d ] I n t 3 2 g e t _ L a y e r G r o u p T y p e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t L a y e r G r o u p T y p e ( ) +
+ [ M e t h o d ] V o i d S e t E x p a n d I n L e g e n d ( B o o l e a n ) +
+ t y p e O S G e o . M a p G u i d e . M g L a y e r G r o u p C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g L a y e r G r o u p , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g L a y e r G r o u p , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g L a y e r G r o u p , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g L a y e r G r o u p ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g L a y e r G r o u p ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g L a y e r G r o u p [ ] , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L a y e r G r o u p g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g L a y e r G r o u p ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L a y e r G r o u p G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L a y e r G r o u p G e t I t e m ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g L a y e r G r o u p ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g L a y e r G r o u p ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g L a y e r G r o u p ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g L a y e r G r o u p ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g L a y e r G r o u p ) +
+ t y p e O S G e o . M a p G u i d e . M g L o n g T r a n s a c t i o n R e a d e r : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ M e t h o d ] V o i d C l o s e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L o n g T r a n s a c t i o n R e a d e r g e t _ C h i l d r e n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D a t e T i m e g e t _ C r e a t i o n D a t e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ O w n e r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L o n g T r a n s a c t i o n R e a d e r g e t _ P a r e n t s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L o n g T r a n s a c t i o n R e a d e r G e t C h i l d r e n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D a t e T i m e G e t C r e a t i o n D a t e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t O w n e r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L o n g T r a n s a c t i o n R e a d e r G e t P a r e n t s ( ) +
+ [ M e t h o d ] B o o l e a n I s A c t i v e ( ) +
+ [ M e t h o d ] B o o l e a n I s F r o z e n ( ) +
+ [ M e t h o d ] B o o l e a n R e a d N e x t ( ) +
+ t y p e O S G e o . M a p G u i d e . M g M a p B a s e : O S G e o . M a p G u i d e . M g R e s o u r c e +
+ [ M e t h o d ] V o i d C r e a t e ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e , O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d C r e a t e ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g E n v e l o p e , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g E n v e l o p e g e t _ D a t a E x t e n t ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ D i s p l a y D p i ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ D i s p l a y H e i g h t ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ D i s p l a y W i d t h ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ F i n i t e D i s p l a y S c a l e C o u n t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r g e t _ M a p D e f i n i t i o n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g E n v e l o p e g e t _ M a p E x t e n t ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ M a p S R S ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ S e s s i o n I d ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o i n t g e t _ V i e w C e n t e r ( ) +
+ [ M e t h o d ] D o u b l e g e t _ V i e w S c a l e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t B a c k g r o u n d C o l o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g E n v e l o p e G e t D a t a E x t e n t ( ) +
+ [ M e t h o d ] I n t 3 2 G e t D i s p l a y D p i ( ) +
+ [ M e t h o d ] I n t 3 2 G e t D i s p l a y H e i g h t ( ) +
+ [ M e t h o d ] I n t 3 2 G e t D i s p l a y W i d t h ( ) +
+ [ M e t h o d ] D o u b l e G e t F i n i t e D i s p l a y S c a l e A t ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t F i n i t e D i s p l a y S c a l e C o u n t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L a y e r G r o u p C o l l e c t i o n G e t L a y e r G r o u p s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L a y e r C o l l e c t i o n G e t L a y e r s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r G e t M a p D e f i n i t i o n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g E n v e l o p e G e t M a p E x t e n t ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t M a p S R S ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S e s s i o n I d ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o i n t G e t V i e w C e n t e r ( ) +
+ [ M e t h o d ] D o u b l e G e t V i e w S c a l e ( ) +
+ [ M e t h o d ] V o i d O p e n ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ D i s p l a y D p i ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t D i s p l a y D p i ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g M a p C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g M a p B a s e , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g M a p B a s e , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g M a p B a s e , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g M a p B a s e ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g M a p B a s e ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g M a p B a s e [ ] , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g M a p B a s e g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g M a p B a s e ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g M a p B a s e G e t I t e m ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g M a p B a s e G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g M a p B a s e ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g M a p B a s e ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g M a p B a s e ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g M a p B a s e ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g M a p B a s e ) +
+ t y p e O S G e o . M a p G u i d e . M g O b j e c t P r o p e r t y D e f i n i t i o n : O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n g e t _ C l a s s D e f i n i t i o n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D a t a P r o p e r t y D e f i n i t i o n g e t _ I d e n t i t y P r o p e r t y ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ O b j e c t T y p e ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ O r d e r T y p e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D a t a P r o p e r t y D e f i n i t i o n G e t I d e n t i t y P r o p e r t y ( ) +
+ [ M e t h o d ] I n t 3 2 G e t O b j e c t T y p e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t O r d e r T y p e ( ) +
+ [ M e t h o d ] V o i d s e t _ C l a s s D e f i n i t i o n ( O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n ) +
+ [ M e t h o d ] V o i d s e t _ I d e n t i t y P r o p e r t y ( O S G e o . M a p G u i d e . M g D a t a P r o p e r t y D e f i n i t i o n ) +
+ [ M e t h o d ] V o i d s e t _ O b j e c t T y p e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d s e t _ O r d e r T y p e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t C l a s s D e f i n i t i o n ( O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n ) +
+ [ M e t h o d ] V o i d S e t I d e n t i t y P r o p e r t y ( O S G e o . M a p G u i d e . M g D a t a P r o p e r t y D e f i n i t i o n ) +
+ [ M e t h o d ] V o i d S e t O b j e c t T y p e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t O r d e r T y p e ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g P a r a m e t e r : O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y , I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t D i r e c t i o n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y G e t P r o p e r t y ( ) +
+ [ M e t h o d ] V o i d S e t D i r e c t i o n ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t P r o p e r t y ( O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y ) +
+ t y p e O S G e o . M a p G u i d e . M g P a r a m e t e r C o l l e c t i o n : O S G e o . M a p G u i d e . M g C o l l e c t i o n +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g P a r a m e t e r ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g P a r a m e t e r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P a r a m e t e r G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g P a r a m e t e r ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g P a r a m e t e r ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g P a r a m e t e r ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g P a r a m e t e r ) +
+ t y p e O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n : O S G e o . M a p G u i d e . M g C o l l e c t i o n +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n , O S G e o . M a p G u i d e . F o u n d a t i o n , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n , O S G e o . M a p G u i d e . F o u n d a t i o n , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n , O S G e o . M a p G u i d e . F o u n d a t i o n , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n [ ] , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n G e t I t e m ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n ) +
+ t y p e O S G e o . M a p G u i d e . M g R a s t e r : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ M e t h o d ] I n t 3 2 g e t _ B i t s P e r P i x e l ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g E n v e l o p e g e t _ B o u n d s ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ D a t a M o d e l T y p e ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ I m a g e X S i z e ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ I m a g e Y S i z e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t B i t s P e r P i x e l ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g E n v e l o p e G e t B o u n d s ( ) +
+ [ M e t h o d ] I n t 3 2 G e t C u r r e n t B a n d ( ) +
+ [ M e t h o d ] I n t 3 2 G e t D a t a M o d e l T y p e ( ) +
+ [ M e t h o d ] I n t 1 6 G e t D a t a T y p e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t I m a g e X S i z e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t I m a g e Y S i z e ( ) +
+ [ M e t h o d ] I n t 6 4 G e t N u l l V a l u e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t N u l l V a l u e T y p e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t N u m b e r O f B a n d s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t S t r e a m ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t V e r t i c a l U n i t s ( ) +
+ [ M e t h o d ] B o o l e a n I s N u l l ( ) +
+ [ M e t h o d ] V o i d s e t _ I m a g e X S i z e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d s e t _ I m a g e Y S i z e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t I m a g e X S i z e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t I m a g e Y S i z e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t N u l l ( ) +
+ t y p e O S G e o . M a p G u i d e . M g R a s t e r P r o p e r t y : O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g R a s t e r ) +
+ [ M e t h o d ] I n t 1 6 g e t _ P r o p e r t y T y p e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g R a s t e r g e t _ V a l u e ( ) +
+ [ M e t h o d ] I n t 1 6 G e t P r o p e r t y T y p e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g R a s t e r G e t V a l u e ( ) +
+ [ M e t h o d ] V o i d s e t _ V a l u e ( O S G e o . M a p G u i d e . M g R a s t e r ) +
+ [ M e t h o d ] V o i d S e t V a l u e ( O S G e o . M a p G u i d e . M g R a s t e r ) +
+ t y p e O S G e o . M a p G u i d e . M g R a s t e r P r o p e r t y D e f i n i t i o n : O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 3 2 g e t _ D e f a u l t I m a g e X S i z e ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ D e f a u l t I m a g e Y S i z e ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ N u l l a b l e ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ R e a d O n l y ( ) +
+ [ M e t h o d ] I n t 3 2 G e t D e f a u l t I m a g e X S i z e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t D e f a u l t I m a g e Y S i z e ( ) +
+ [ M e t h o d ] B o o l e a n G e t N u l l a b l e ( ) +
+ [ M e t h o d ] B o o l e a n G e t R e a d O n l y ( ) +
+ [ M e t h o d ] V o i d s e t _ D e f a u l t I m a g e X S i z e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d s e t _ D e f a u l t I m a g e Y S i z e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d s e t _ N u l l a b l e ( B o o l e a n ) +
+ [ M e t h o d ] V o i d s e t _ R e a d O n l y ( B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t D e f a u l t I m a g e X S i z e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t D e f a u l t I m a g e Y S i z e ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g R e a d e r : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t B L O B ( I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t B L O B ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n G e t B o o l e a n ( I n t 3 2 ) +
+ [ M e t h o d ] B o o l e a n G e t B o o l e a n ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B y t e G e t B y t e ( I n t 3 2 ) +
+ [ M e t h o d ] B y t e G e t B y t e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t C L O B ( I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t C L O B ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D a t e T i m e G e t D a t e T i m e ( I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D a t e T i m e G e t D a t e T i m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] D o u b l e G e t D o u b l e ( I n t 3 2 ) +
+ [ M e t h o d ] D o u b l e G e t D o u b l e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t G e o m e t r y ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t G e o m e t r y ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 1 6 G e t I n t 1 6 ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 1 6 G e t I n t 1 6 ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t I n t 3 2 ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t I n t 3 2 ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 6 4 G e t I n t 6 4 ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 6 4 G e t I n t 6 4 ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 3 2 G e t P r o p e r t y C o u n t ( ) +
+ [ M e t h o d ] I n t 3 2 G e t P r o p e r t y I n d e x ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t P r o p e r t y N a m e ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t P r o p e r t y T y p e ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t P r o p e r t y T y p e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g R a s t e r G e t R a s t e r ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g R a s t e r G e t R a s t e r ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t R e a d e r T y p e ( ) +
+ [ M e t h o d ] S i n g l e G e t S i n g l e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S i n g l e G e t S i n g l e ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S t r i n g ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S t r i n g ( I n t 3 2 ) +
+ [ M e t h o d ] B o o l e a n I s N u l l ( I n t 3 2 ) +
+ [ M e t h o d ] B o o l e a n I s N u l l ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r T o X m l ( ) +
+ t y p e O S G e o . M a p G u i d e . M g R e a d O n l y L a y e r C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I R e a d O n l y L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g L a y e r B a s e , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I R e a d O n l y C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g L a y e r B a s e , O S G e o . M a p G u i d e . P l a t f o r m B a s e , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ [ M e t h o d ] I n t 3 2 G e t C o u n t ( ) +
+ t y p e O S G e o . M a p G u i d e . M g R e s o u r c e : O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r G e t R e s o u r c e I d ( ) +
+ [ M e t h o d ] V o i d O p e n ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e , O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] V o i d S a v e ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e , O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] V o i d S a v e ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e ) +
+ t y p e O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ P a t h ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ R e p o s i t o r y N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ R e p o s i t o r y T y p e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ R e s o u r c e T y p e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t P a t h ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t R e p o s i t o r y N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t R e p o s i t o r y T y p e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t R e s o u r c e T y p e ( ) +
+ [ M e t h o d ] V o i d s e t _ N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ P a t h ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ R e p o s i t o r y N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ R e p o s i t o r y T y p e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d s e t _ R e s o u r c e T y p e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t P a t h ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t R e p o s i t o r y N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t R e p o s i t o r y T y p e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t R e s o u r c e T y p e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g T o S t r i n g ( ) +
+ [ M e t h o d ] V o i d V a l i d a t e ( ) +
+ t y p e O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e : O S G e o . M a p G u i d e . M g S e r v i c e +
+ [ M e t h o d ] V o i d A p p l y R e s o u r c e P a c k a g e ( O S G e o . M a p G u i d e . M g B y t e R e a d e r ) +
+ [ M e t h o d ] V o i d C h a n g e R e s o u r c e O w n e r ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , B o o l e a n ) +
+ [ M e t h o d ] V o i d C o p y R e s o u r c e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , B o o l e a n ) +
+ [ M e t h o d ] V o i d D e l e t e R e s o u r c e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] V o i d D e l e t e R e s o u r c e D a t a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r E n u m e r a t e R e f e r e n c e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r E n u m e r a t e R e s o u r c e D a t a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] S y s t e m . S t r i n g E n u m e r a t e R e s o u r c e D o c u m e n t s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , S y s t e m . S t r i n g , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r E n u m e r a t e R e s o u r c e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , I n t 3 2 , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r E n u m e r a t e R e s o u r c e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , I n t 3 2 , S y s t e m . S t r i n g , B o o l e a n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r E n u m e r a t e U n m a n a g e d D a t a ( S y s t e m . S t r i n g , B o o l e a n , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t R e p o s i t o r y C o n t e n t ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t R e p o s i t o r y H e a d e r ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t R e s o u r c e C o n t e n t ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n G e t R e s o u r c e C o n t e n t s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t R e s o u r c e D a t a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t R e s o u r c e H e a d e r ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t R e s o u r c e M e t a d a t a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D a t e T i m e G e t R e s o u r c e M o d i f i e d D a t e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] V o i d I n h e r i t P e r m i s s i o n s F r o m ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] V o i d M o v e R e s o u r c e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , B o o l e a n , B o o l e a n ) +
+ [ M e t h o d ] V o i d M o v e R e s o u r c e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , B o o l e a n ) +
+ [ M e t h o d ] V o i d R e n a m e R e s o u r c e D a t a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , S y s t e m . S t r i n g , B o o l e a n ) +
+ [ M e t h o d ] B o o l e a n R e s o u r c e E x i s t s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] V o i d S e t R e s o u r c e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , O S G e o . M a p G u i d e . M g B y t e R e a d e r , O S G e o . M a p G u i d e . M g B y t e R e a d e r ) +
+ [ M e t h o d ] V o i d S e t R e s o u r c e D a t a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g B y t e R e a d e r ) +
+ [ M e t h o d ] V o i d S e t R e s o u r c e M e t a d a t a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , O S G e o . M a p G u i d e . M g B y t e R e a d e r ) +
+ [ M e t h o d ] V o i d U p d a t e R e p o s i t o r y ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , O S G e o . M a p G u i d e . M g B y t e R e a d e r , O S G e o . M a p G u i d e . M g B y t e R e a d e r ) +
+ t y p e O S G e o . M a p G u i d e . M g S e l e c t i o n B a s e : O S G e o . M a p G u i d e . M g R e s o u r c e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g M a p B a s e ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g M a p B a s e , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d A d d ( S y s t e m . S t r i n g , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d A d d F e a t u r e I d D o u b l e ( O S G e o . M a p G u i d e . M g L a y e r B a s e , S y s t e m . S t r i n g , D o u b l e ) +
+ [ M e t h o d ] V o i d A d d F e a t u r e I d I n t 1 6 ( O S G e o . M a p G u i d e . M g L a y e r B a s e , S y s t e m . S t r i n g , I n t 1 6 ) +
+ [ M e t h o d ] V o i d A d d F e a t u r e I d I n t 3 2 ( O S G e o . M a p G u i d e . M g L a y e r B a s e , S y s t e m . S t r i n g , I n t 3 2 ) +
+ [ M e t h o d ] V o i d A d d F e a t u r e I d I n t 6 4 ( O S G e o . M a p G u i d e . M g L a y e r B a s e , S y s t e m . S t r i n g , I n t 6 4 ) +
+ [ M e t h o d ] V o i d A d d F e a t u r e I d s ( O S G e o . M a p G u i d e . M g L a y e r B a s e , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ) +
+ [ M e t h o d ] V o i d A d d F e a t u r e I d S t r i n g ( O S G e o . M a p G u i d e . M g L a y e r B a s e , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d A d d F e a t u r e s ( O S G e o . M a p G u i d e . M g L a y e r B a s e , O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r , I n t 3 2 ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g L a y e r B a s e , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d F r o m X m l ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e n e r a t e F i l t e r ( O S G e o . M a p G u i d e . M g L a y e r B a s e , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n G e n e r a t e F i l t e r s ( O S G e o . M a p G u i d e . M g L a y e r B a s e , S y s t e m . S t r i n g , I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t C l a s s ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n G e t C l a s s e s ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g E n v e l o p e G e t E x t e n t s ( O S G e o . M a p G u i d e . M g F e a t u r e S e r v i c e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g R e a d O n l y L a y e r C o l l e c t i o n G e t L a y e r s ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t R e s o u r c e N a m e ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r G e t S e l e c t e d F e a t u r e s ( O S G e o . M a p G u i d e . M g L a y e r B a s e , S y s t e m . S t r i n g , B o o l e a n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r G e t S e l e c t e d F e a t u r e s ( O S G e o . M a p G u i d e . M g L a y e r B a s e , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ) +
+ [ M e t h o d ] I n t 3 2 G e t S e l e c t e d F e a t u r e s C o u n t ( O S G e o . M a p G u i d e . M g L a y e r B a s e , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S a v e ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t M a p ( O S G e o . M a p G u i d e . M g M a p B a s e ) +
+ [ M e t h o d ] S y s t e m . S t r i n g T o X m l ( ) +
+ t y p e O S G e o . M a p G u i d e . M g S e r v i c e : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W a r n i n g s G e t W a r n i n g s O b j e c t ( ) +
+ [ M e t h o d ] B o o l e a n H a s W a r n i n g s ( ) +
+ t y p e O S G e o . M a p G u i d e . M g S i n g l e P r o p e r t y : O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , S i n g l e ) +
+ [ M e t h o d ] S i n g l e g e t _ V a l u e ( ) +
+ [ M e t h o d ] S i n g l e G e t V a l u e ( ) +
+ [ M e t h o d ] V o i d s e t _ V a l u e ( S i n g l e ) +
+ [ M e t h o d ] V o i d S e t V a l u e ( S i n g l e ) +
+ t y p e O S G e o . M a p G u i d e . M g S p a t i a l C o n t e x t R e a d e r : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ C o o r d i n a t e S y s t e m ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ D e s c r i p t i o n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r g e t _ E x t e n t ( ) +
+ [ M e t h o d ] I n t 3 2 g e t _ E x t e n t T y p e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t C o o r d i n a t e S y s t e m ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D e s c r i p t i o n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t E x t e n t ( ) +
+ [ M e t h o d ] I n t 3 2 G e t E x t e n t T y p e ( ) +
+ [ S y s t e m . O b s o l e t e A t t r i b u t e ] +
+ [ M e t h o d ] V o i d R e s e t ( ) +
+ t y p e O S G e o . M a p G u i d e . M g S q l D a t a R e a d e r : O S G e o . M a p G u i d e . M g R e a d e r +
+ [ S y s t e m . R e f l e c t i o n . D e f a u l t M e m b e r A t t r i b u t e ] +
+ t y p e O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y C o l l e c t i o n : O S G e o . M a p G u i d e . M g C o l l e c t i o n +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y , O S G e o . M a p G u i d e . F o u n d a t i o n , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y , O S G e o . M a p G u i d e . F o u n d a t i o n , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y , O S G e o . M a p G u i d e . F o u n d a t i o n , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . I E n u m e r a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( ) +
+ [ M e t h o d ] V o i d A d d ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y [ ] , I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 g e t _ C o u n t ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ I s R e a d O n l y ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t N a m e ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t V a l u e ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t V a l u e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y ) +
+ [ M e t h o d ] V o i d R e m o v e A t ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y ) +
+ [ M e t h o d ] V o i d S e t V a l u e ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g T r a n s a c t i o n : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ M e t h o d ] S y s t e m . S t r i n g A d d S a v e P o i n t ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d C o m m i t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r G e t F e a t u r e S o u r c e ( ) +
+ [ M e t h o d ] V o i d R e l e a s e S a v e P o i n t ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d R o l l b a c k ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d R o l l b a c k ( ) +
+ t y p e O S G e o . M a p G u i d e . M g U p d a t e F e a t u r e s : O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 3 2 g e t _ C o m m a n d T y p e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ F e a t u r e C l a s s N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g g e t _ F i l t e r T e x t ( ) +
+ [ M e t h o d ] I n t 3 2 G e t C o m m a n d T y p e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t F e a t u r e C l a s s N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t F i l t e r T e x t ( ) +
+ t y p e O S G e o . M a p G u i d e . M g W a r n i n g s : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ i m p l e m e n t s S y s t e m . I D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n G e t M e s s a g e s ( ) +
+ A s s e m b l y : O S G e o . M a p G u i d e . M a p G u i d e C o m m o n , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l +
+ t y p e O S G e o . M a p G u i d e . M g I m a g e F o r m a t s : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g G i f +
+ [ F i e l d ] S y s t e m . S t r i n g J p e g +
+ [ F i e l d ] S y s t e m . S t r i n g M e t a +
+ [ F i e l d ] S y s t e m . S t r i n g P n g +
+ [ F i e l d ] S y s t e m . S t r i n g P n g 8 +
+ [ F i e l d ] S y s t e m . S t r i n g R a w +
+ [ F i e l d ] S y s t e m . S t r i n g T i f f +
+ t y p e O S G e o . M a p G u i d e . M g P a g e U n i t s T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g I n c h e s +
+ [ F i e l d ] S y s t e m . S t r i n g M i l l i m e t e r s +
+ t y p e O S G e o . M a p G u i d e . M g C o o r d i n a t e S p a c e : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g D i s p l a y +
+ [ F i e l d ] S y s t e m . S t r i n g M a p +
+ [ F i e l d ] S y s t e m . S t r i n g N o n e +
+ t y p e O S G e o . M a p G u i d e . M g M a p P l o t I n s t r u c t i o n : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 U s e M a p C e n t e r A n d S c a l e +
+ [ F i e l d ] I n t 3 2 U s e O v e r r i d d e n C e n t e r A n d S c a l e +
+ [ F i e l d ] I n t 3 2 U s e O v e r r i d d e n E x t e n t +
+ t y p e O S G e o . M a p G u i d e . M g L o g F i l e T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g A c c e s s +
+ [ F i e l d ] S y s t e m . S t r i n g A d m i n +
+ [ F i e l d ] S y s t e m . S t r i n g A u t h e n t i c a t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g E r r o r +
+ [ F i e l d ] S y s t e m . S t r i n g S e s s i o n +
+ [ F i e l d ] S y s t e m . S t r i n g T r a c e +
+ t y p e O S G e o . M a p G u i d e . M g S e r v e r I n f o r m a t i o n P r o p e r t i e s : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g A d m i n O p e r a t i o n s Q u e u e C o u n t +
+ [ F i e l d ] S y s t e m . S t r i n g A p i V e r s i o n +
+ [ F i e l d ] S y s t e m . S t r i n g A v a i l a b l e P h y s i c a l M e m o r y +
+ [ F i e l d ] S y s t e m . S t r i n g A v a i l a b l e V i r t u a l M e m o r y +
+ [ F i e l d ] S y s t e m . S t r i n g A v e r a g e O p e r a t i o n T i m e +
+ [ F i e l d ] S y s t e m . S t r i n g C a c h e D r o p p e d E n t r i e s +
+ [ F i e l d ] S y s t e m . S t r i n g C a c h e S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g C l i e n t O p e r a t i o n s Q u e u e C o u n t +
+ [ F i e l d ] S y s t e m . S t r i n g C p u U t i l i z a t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g D i s p l a y N a m e +
+ [ F i e l d ] S y s t e m . S t r i n g M a c h i n e I p +
+ [ F i e l d ] S y s t e m . S t r i n g O p e r a t i n g S y s t e m V e r s i o n +
+ [ F i e l d ] S y s t e m . S t r i n g S e r v e r V e r s i o n +
+ [ F i e l d ] S y s t e m . S t r i n g S i t e O p e r a t i o n s Q u e u e C o u n t +
+ [ F i e l d ] S y s t e m . S t r i n g S t a t u s +
+ [ F i e l d ] S y s t e m . S t r i n g T o t a l A c t i v e C o n n e c t i o n s +
+ [ F i e l d ] S y s t e m . S t r i n g T o t a l C o n n e c t i o n s +
+ [ F i e l d ] S y s t e m . S t r i n g T o t a l O p e r a t i o n T i m e +
+ [ F i e l d ] S y s t e m . S t r i n g T o t a l P h y s i c a l M e m o r y +
+ [ F i e l d ] S y s t e m . S t r i n g T o t a l P r o c e s s e d O p e r a t i o n s +
+ [ F i e l d ] S y s t e m . S t r i n g T o t a l R e c e i v e d O p e r a t i o n s +
+ [ F i e l d ] S y s t e m . S t r i n g T o t a l V i r t u a l M e m o r y +
+ [ F i e l d ] S y s t e m . S t r i n g U p t i m e +
+ [ F i e l d ] S y s t e m . S t r i n g V i r t u a l M e m o r y +
+ [ F i e l d ] S y s t e m . S t r i n g W o r k i n g S e t +
+ t y p e O S G e o . M a p G u i d e . M g U n i t T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g M e t r i c +
+ [ F i e l d ] S y s t e m . S t r i n g U S E n g l i s h +
+ t y p e O S G e o . M a p G u i d e . M g C o n f i g P r o p e r t i e s : S y s t e m . O b j e c t +
+ [ F i e l d ] S y s t e m . S t r i n g A c c e s s L o g P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g A c c e s s L o g P r o p e r t y E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g A c c e s s L o g P r o p e r t y F i l e n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g A c c e s s L o g P r o p e r t y P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y E m a i l +
+ [ F i e l d ] S y s t e m . S t r i n g A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s +
+ [ F i e l d ] S y s t e m . S t r i n g A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y P o r t +
+ [ F i e l d ] S y s t e m . S t r i n g A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y Q u e u e S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g A d m i n L o g P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g A d m i n L o g P r o p e r t y E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g A d m i n L o g P r o p e r t y F i l e n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g A d m i n L o g P r o p e r t y P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g A g e n t A n o n y m o u s D e n y G e t R e s o u r c e C o n t e n t +
+ [ F i e l d ] S y s t e m . S t r i n g A g e n t A n o n y m o u s D e n y G e t R e s o u r c e D a t a +
+ [ F i e l d ] S y s t e m . S t r i n g A g e n t A n o n y m o u s D e n y G e t R e s o u r c e H e a d e r +
+ [ F i e l d ] S y s t e m . S t r i n g A g e n t D e b u g P a u s e +
+ [ F i e l d ] S y s t e m . S t r i n g A g e n t D i s a b l e A u t h o r i n g +
+ [ F i e l d ] S y s t e m . S t r i n g A g e n t D i s a b l e W f s +
+ [ F i e l d ] S y s t e m . S t r i n g A g e n t D i s a b l e W m s +
+ [ F i e l d ] S y s t e m . S t r i n g A g e n t E r r o r L o g E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g A g e n t E r r o r L o g F i l e n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g A g e n t G l o b a l G e t W f s F e a t u r e s L i m i t +
+ [ F i e l d ] S y s t e m . S t r i n g A g e n t G l o b a l G e t W m s F e a t u r e I n f o L i m i t +
+ [ F i e l d ] S y s t e m . S t r i n g A g e n t G l o b a l M a x F e a t u r e Q u e r y L i m i t +
+ [ F i e l d ] S y s t e m . S t r i n g A g e n t G l o b a l M a x M a p F e a t u r e Q u e r y L i m i t +
+ [ F i e l d ] S y s t e m . S t r i n g A g e n t P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g A g e n t R e q u e s t L o g E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g A g e n t R e q u e s t L o g F i l e n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g A u t h e n t i c a t i o n L o g P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g A u t h e n t i c a t i o n L o g P r o p e r t y E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g A u t h e n t i c a t i o n L o g P r o p e r t y F i l e n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g A u t h e n t i c a t i o n L o g P r o p e r t y P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g C I T E W f s E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g C I T E W m s E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g C l i e n t C o n n e c t i o n P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g C l i e n t C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s +
+ [ F i e l d ] S y s t e m . S t r i n g C l i e n t C o n n e c t i o n P r o p e r t y P o r t +
+ [ F i e l d ] S y s t e m . S t r i n g C l i e n t C o n n e c t i o n P r o p e r t y Q u e u e S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g C l i e n t C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g C o n t a i n e r I n f o F o l d e r +
+ [ F i e l d ] S y s t e m . S t r i n g D B E n v i r o n m e n t P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g D B M a x L o c k e r s P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g D B M a x T r a n s a c t i o n s P a r a m t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g D B P a g e S i z e P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g D B T i m e o u t P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g D B X M L P a g e S i z e P a r a m e t e r s +
+ [ F i e l d ] B o o l e a n D e f a u l t A c c e s s L o g P r o p e r t y E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t A c c e s s L o g P r o p e r t y F i l e n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t A c c e s s L o g P r o p e r t y P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y E m a i l +
+ [ F i e l d ] I n t 3 2 D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s +
+ [ F i e l d ] I n t 3 2 D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y P o r t +
+ [ F i e l d ] I n t 3 2 D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y Q u e u e S i z e +
+ [ F i e l d ] I n t 3 2 D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e +
+ [ F i e l d ] B o o l e a n D e f a u l t A d m i n L o g P r o p e r t y E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t A d m i n L o g P r o p e r t y F i l e n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t A d m i n L o g P r o p e r t y P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t A g e n t A n o n y m o u s D e n y G e t R e s o u r c e C o n t e n t +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t A g e n t A n o n y m o u s D e n y G e t R e s o u r c e D a t a +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t A g e n t A n o n y m o u s D e n y G e t R e s o u r c e H e a d e r +
+ [ F i e l d ] I n t 3 2 D e f a u l t A g e n t D e b u g P a u s e +
+ [ F i e l d ] B o o l e a n D e f a u l t A g e n t E r r o r L o g E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t A g e n t E r r o r L o g F i l e n a m e +
+ [ F i e l d ] I n t 3 2 D e f a u l t A g e n t G l o b a l G e t W f s F e a t u r e s L i m i t +
+ [ F i e l d ] I n t 3 2 D e f a u l t A g e n t G l o b a l G e t W m s F e a t u r e I n f o L i m i t +
+ [ F i e l d ] I n t 3 2 D e f a u l t A g e n t G l o b a l M a x F e a t u r e Q u e r y L i m i t +
+ [ F i e l d ] I n t 3 2 D e f a u l t A g e n t G l o b a l M a x M a p F e a t u r e Q u e r y L i m i t +
+ [ F i e l d ] B o o l e a n D e f a u l t A g e n t R e q u e s t L o g E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t A g e n t R e q u e s t L o g F i l e n a m e +
+ [ F i e l d ] B o o l e a n D e f a u l t A u t h e n t i c a t i o n L o g P r o p e r t y E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t A u t h e n t i c a t i o n L o g P r o p e r t y F i l e n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t A u t h e n t i c a t i o n L o g P r o p e r t y P a r a m e t e r s +
+ [ F i e l d ] B o o l e a n D e f a u l t C I T E W f s E n a b l e d +
+ [ F i e l d ] B o o l e a n D e f a u l t C I T E W m s E n a b l e d +
+ [ F i e l d ] I n t 3 2 D e f a u l t C l i e n t C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s +
+ [ F i e l d ] I n t 3 2 D e f a u l t C l i e n t C o n n e c t i o n P r o p e r t y P o r t +
+ [ F i e l d ] I n t 3 2 D e f a u l t C l i e n t C o n n e c t i o n P r o p e r t y Q u e u e S i z e +
+ [ F i e l d ] I n t 3 2 D e f a u l t C l i e n t C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t C o n f i g u r a t i o n F i l e n a m e +
+ [ F i e l d ] I n t 3 2 D e f a u l t D B M a x L o c k e r s P a r a m e t e r s +
+ [ F i e l d ] I n t 3 2 D e f a u l t D B M a x T r a n s a c t i o n s P a r a m t e r s +
+ [ F i e l d ] I n t 3 2 D e f a u l t D B P a g e S i z e P a r a m e t e r s +
+ [ F i e l d ] D o u b l e D e f a u l t D B T i m e o u t P a r a m e t e r s +
+ [ F i e l d ] I n t 3 2 D e f a u l t D B X M L P a g e S i z e P a r a m e t e r s +
+ [ F i e l d ] B o o l e a n D e f a u l t E r r o r L o g P r o p e r t y E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t E r r o r L o g P r o p e r t y F i l e n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t E r r o r L o g P r o p e r t y P a r a m e t e r s +
+ [ F i e l d ] I n t 3 2 D e f a u l t F e a t u r e S e r v i c e P r o p e r t y C a c h e S i z e +
+ [ F i e l d ] I n t 3 2 D e f a u l t F e a t u r e S e r v i c e P r o p e r t y C a c h e T i m e L i m i t +
+ [ F i e l d ] I n t 3 2 D e f a u l t F e a t u r e S e r v i c e P r o p e r t y C a c h e T i m e r I n t e r v a l +
+ [ F i e l d ] I n t 3 2 D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C a c h e S i z e +
+ [ F i e l d ] B o o l e a n D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l E x c l u d e d P r o v i d e r s +
+ [ F i e l d ] I n t 3 2 D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l S i z e C u s t o m +
+ [ F i e l d ] I n t 3 2 D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n T i m e o u t +
+ [ F i e l d ] I n t 3 2 D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n T i m e r I n t e r v a l +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n U s e L i m i t +
+ [ F i e l d ] I n t 3 2 D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a T r a n s a c t i o n T i m e o u t +
+ [ F i e l d ] I n t 3 2 D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a T r a n s a c t i o n T i m e r I n t e r v a l +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t F e a t u r e S e r v i c e P r o p e r t y F D O C o n n e c t i o n T i m e o u t C u s t o m +
+ [ F i e l d ] I n t 3 2 D e f a u l t F e a t u r e S e r v i c e P r o p e r t y J o i n Q u e r y B a t c h S i z e +
+ [ F i e l d ] B o o l e a n D e f a u l t F e a t u r e S e r v i c e P r o p e r t y U s e F d o J o i n O p t i m i z a t i o n +
+ [ F i e l d ] I n t 3 2 D e f a u l t G e n e r a l P r o p e r t y C o n n e c t i o n T i m e o u t +
+ [ F i e l d ] I n t 3 2 D e f a u l t G e n e r a l P r o p e r t y C o n n e c t i o n T i m e r I n t e r v a l +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y D e f a u l t M e s s a g e L o c a l e +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y D i s p l a y N a m e +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y F d o P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y L i c e n s e S e r v e r P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y L i n u x F o n t D i r e c t o r i e s +
+ [ F i e l d ] B o o l e a n D e f a u l t G e n e r a l P r o p e r t y L i n u x M e m D e b u g +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y L o c a l e +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y L o g s D e l i m i t e r +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y L o g s D e t a i l +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y L o g s P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y M a c h i n e I p +
+ [ F i e l d ] I n t 3 2 D e f a u l t G e n e r a l P r o p e r t y M a x L o g F i l e S i z e +
+ [ F i e l d ] B o o l e a n D e f a u l t G e n e r a l P r o p e r t y M a x L o g F i l e S i z e E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y M e n t o r D i c t i o n a r y P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y M e n t o r U s e r D i c t i o n a r y P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y P r e C a c h e M a p s +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y R e s o u r c e s P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y S e r i a l N u m b e r +
+ [ F i e l d ] I n t 3 2 D e f a u l t G e n e r a l P r o p e r t y S e r v i c e R e g i s t r a t i o n T i m e r I n t e r v a l +
+ [ F i e l d ] I n t 3 2 D e f a u l t G e n e r a l P r o p e r t y T c p I p M t u +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y T e m p P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y W f s D o c u m e n t P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t G e n e r a l P r o p e r t y W m s D o c u m e n t P a t h +
+ [ F i e l d ] B o o l e a n D e f a u l t H o s t P r o p e r t y D r a w i n g S e r v i c e +
+ [ F i e l d ] B o o l e a n D e f a u l t H o s t P r o p e r t y F e a t u r e S e r v i c e +
+ [ F i e l d ] B o o l e a n D e f a u l t H o s t P r o p e r t y K m l S e r v i c e +
+ [ F i e l d ] B o o l e a n D e f a u l t H o s t P r o p e r t y M a p p i n g S e r v i c e +
+ [ F i e l d ] B o o l e a n D e f a u l t H o s t P r o p e r t y P r o f i l i n g S e r v i c e +
+ [ F i e l d ] B o o l e a n D e f a u l t H o s t P r o p e r t y R e n d e r i n g S e r v i c e +
+ [ F i e l d ] B o o l e a n D e f a u l t H o s t P r o p e r t y R e s o u r c e S e r v i c e +
+ [ F i e l d ] B o o l e a n D e f a u l t H o s t P r o p e r t y S i t e S e r v i c e +
+ [ F i e l d ] B o o l e a n D e f a u l t H o s t P r o p e r t y T i l e S e r v i c e +
+ [ F i e l d ] I n t 3 2 D e f a u l t L i b r a r y C a c h e S i z e P a r a m e t e r s +
+ [ F i e l d ] I n t 3 2 D e f a u l t L i b r a r y L o g B u f f e r S i z e P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t M a p p i n g S e r v i c e P r o p e r t y L e g e n d F o n t +
+ [ F i e l d ] B o o l e a n D e f a u l t P e r f o r m a n c e L o g P r o p e r t y E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t P e r f o r m a n c e L o g P r o p e r t y F i l e n a m e +
+ [ F i e l d ] I n t 3 2 D e f a u l t P e r f o r m a n c e L o g P r o p e r t y I n t e r v a l +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t P e r f o r m a n c e L o g P r o p e r t y P a r a m e t e r s +
+ [ F i e l d ] B o o l e a n D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t i e s G l o b a l R a s t e r S t y l i z a t i o n L o c k E n a b l e d +
+ [ F i e l d ] B o o l e a n D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y C l a m p P o i n t s +
+ [ F i e l d ] B o o l e a n D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y G e n e r a l i z e D a t a +
+ [ F i e l d ] I n t 3 2 D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M a x R a s t e r I m a g e H e i g h t +
+ [ F i e l d ] I n t 3 2 D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M a x R a s t e r I m a g e W i d t h +
+ [ F i e l d ] I n t 3 2 D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M a x R e n d e r I m a g e H e i g h t +
+ [ F i e l d ] I n t 3 2 D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M a x R e n d e r I m a g e W i d t h +
+ [ F i e l d ] I n t 3 2 D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M i n R a s t e r G r i d S i z e +
+ [ F i e l d ] I n t 3 2 D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M i n R a s t e r G r i d S i z e F o r P l o t +
+ [ F i e l d ] I n t 3 2 D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e +
+ [ F i e l d ] I n t 3 2 D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e F o r P l o t +
+ [ F i e l d ] D o u b l e D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e O v e r r i d e R a t i o +
+ [ F i e l d ] D o u b l e D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e O v e r r i d e R a t i o F o r P l o t +
+ [ F i e l d ] I n t 3 2 D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R e n d e r S e l e c t i o n B a t c h S i z e +
+ [ F i e l d ] D o u b l e D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y T i l e E x t e n t O f f s e t +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y L i b r a r y R e p o s i t o r y P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y L i b r a r y R e s o u r c e D a t a F i l e P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y P a c k a g e s P a t h +
+ [ F i e l d ] I n t 3 2 D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e p o s i t o r y C h e c k p o i n t s T i m e r I n t e r v a l +
+ [ F i e l d ] I n t 3 2 D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e C h a n g e T i m e r I n t e r v a l +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e D a t a F i l e T r a s h F o l d e r N a m e +
+ [ F i e l d ] I n t 3 2 D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e P e r m i s s i o n C a c h e S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e S c h e m a F i l e P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y S e s s i o n R e p o s i t o r y P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y S e s s i o n R e s o u r c e D a t a F i l e P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y S i t e R e p o s i t o r y P a t h +
+ [ F i e l d ] I n t 3 2 D e f a u l t S e s s i o n C a c h e S i z e P a r a m t e r s +
+ [ F i e l d ] I n t 3 2 D e f a u l t S e s s i o n D B P a g e S i z e P a r a m e t e r s +
+ [ F i e l d ] D o u b l e D e f a u l t S e s s i o n D B X M L P a g e S i z e P a r a m e t e r s +
+ [ F i e l d ] I n t 3 2 D e f a u l t S e s s i o n L o g B u f f e r S i z e P a r a m e t e r s +
+ [ F i e l d ] B o o l e a n D e f a u l t S e s s i o n L o g P r o p e r t y E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t S e s s i o n L o g P r o p e r t y F i l e n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t S e s s i o n L o g P r o p e r t y P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t S i t e C o n n e c t i o n P r o p e r t y I p A d d r e s s +
+ [ F i e l d ] I n t 3 2 D e f a u l t S i t e C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s +
+ [ F i e l d ] I n t 3 2 D e f a u l t S i t e C o n n e c t i o n P r o p e r t y P o r t +
+ [ F i e l d ] I n t 3 2 D e f a u l t S i t e C o n n e c t i o n P r o p e r t y Q u e u e S i z e +
+ [ F i e l d ] I n t 3 2 D e f a u l t S i t e C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e +
+ [ F i e l d ] I n t 3 2 D e f a u l t S i t e S e r v i c e P r o p e r t y S e s s i o n T i m e o u t +
+ [ F i e l d ] I n t 3 2 D e f a u l t S i t e S e r v i c e P r o p e r t y S e s s i o n T i m e r I n t e r v a l +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t T i l e S e r v i c e P r o p e r t y I m a g e F o r m a t +
+ [ F i e l d ] B o o l e a n D e f a u l t T i l e S e r v i c e P r o p e r t y R e n d e r O n l y +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e C a c h e P a t h +
+ [ F i e l d ] I n t 3 2 D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e C o l u m n s P e r F o l d e r +
+ [ F i e l d ] I n t 3 2 D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e R o w s P e r F o l d e r +
+ [ F i e l d ] I n t 3 2 D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e S i z e X +
+ [ F i e l d ] I n t 3 2 D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e S i z e Y +
+ [ F i e l d ] B o o l e a n D e f a u l t T r a c e L o g P r o p e r t y E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t T r a c e L o g P r o p e r t y F i l e n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g D e f a u l t T r a c e L o g P r o p e r t y P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g D r a w i n g S e r v i c e P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g E r r o r L o g P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g E r r o r L o g P r o p e r t y E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g E r r o r L o g P r o p e r t y F i l e n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g E r r o r L o g P r o p e r t y P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S e r v i c e P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S e r v i c e P r o p e r t y C a c h e S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S e r v i c e P r o p e r t y C a c h e T i m e L i m i t +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S e r v i c e P r o p e r t y C a c h e T i m e r I n t e r v a l +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a C a c h e S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l E x c l u d e d P r o v i d e r s +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l S i z e C u s t o m +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n T i m e o u t +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n T i m e r I n t e r v a l +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n U s e L i m i t +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a T r a n s a c t i o n T i m e o u t +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a T r a n s a c t i o n T i m e r I n t e r v a l +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S e r v i c e P r o p e r t y F D O C o n n e c t i o n T i m e o u t C u s t o m +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S e r v i c e P r o p e r t y J o i n Q u e r y B a t c h S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g F e a t u r e S e r v i c e P r o p e r t y U s e F d o J o i n O p t i m i z a t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g F o n t A l i a s M a p p i n g S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y C o n n e c t i o n T i m e o u t +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y C o n n e c t i o n T i m e r I n t e r v a l +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y D e f a u l t M e s s a g e L o c a l e +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y D i s p l a y N a m e +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y F d o P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y L i c e n s e S e r v e r P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y L i n u x F o n t D i r e c t o r i e s +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y L i n u x M e m D e b u g +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y L o c a l e +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y L o g s D e l i m i t e r +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y L o g s D e t a i l +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y L o g s P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y M a c h i n e I p +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y M a x L o g F i l e S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y M a x L o g F i l e S i z e E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y M e n t o r D i c t i o n a r y P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y M e n t o r U s e r D i c t i o n a r y P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y P r e C a c h e M a p s +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y R e s o u r c e s P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y S e r i a l N u m b e r +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y S e r v i c e R e g i s t r a t i o n T i m e r I n t e r v a l +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y T c p I p M t u +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y T e m p P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y W f s D o c u m e n t P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g G e n e r a l P r o p e r t y W m s D o c u m e n t P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g H o s t P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g H o s t P r o p e r t y D r a w i n g S e r v i c e +
+ [ F i e l d ] S y s t e m . S t r i n g H o s t P r o p e r t y F e a t u r e S e r v i c e +
+ [ F i e l d ] S y s t e m . S t r i n g H o s t P r o p e r t y K m l S e r v i c e +
+ [ F i e l d ] S y s t e m . S t r i n g H o s t P r o p e r t y M a p p i n g S e r v i c e +
+ [ F i e l d ] S y s t e m . S t r i n g H o s t P r o p e r t y P r o f i l i n g S e r v i c e +
+ [ F i e l d ] S y s t e m . S t r i n g H o s t P r o p e r t y R e n d e r i n g S e r v i c e +
+ [ F i e l d ] S y s t e m . S t r i n g H o s t P r o p e r t y R e s o u r c e S e r v i c e +
+ [ F i e l d ] S y s t e m . S t r i n g H o s t P r o p e r t y S i t e S e r v i c e +
+ [ F i e l d ] S y s t e m . S t r i n g H o s t P r o p e r t y T i l e S e r v i c e +
+ [ F i e l d ] S y s t e m . S t r i n g L i b r a r y C a c h e S i z e P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g L i b r a r y L o g B u f f e r S i z e P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g M a p p i n g S e r v i c e P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g M a p p i n g S e r v i c e P r o p e r t y L e g e n d F o n t +
+ [ F i e l d ] S y s t e m . S t r i n g O g c P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g P e r f o r m a n c e L o g P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g P e r f o r m a n c e L o g P r o p e r t y E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g P e r f o r m a n c e L o g P r o p e r t y F i l e n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g P e r f o r m a n c e L o g P r o p e r t y I n t e r v a l +
+ [ F i e l d ] S y s t e m . S t r i n g P e r f o r m a n c e L o g P r o p e r t y P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t i e s G l o b a l R a s t e r S t y l i z a t i o n L o c k E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y C l a m p P o i n t s +
+ [ F i e l d ] S y s t e m . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y G e n e r a l i z e D a t a +
+ [ F i e l d ] S y s t e m . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y M a x R a s t e r I m a g e H e i g h t +
+ [ F i e l d ] S y s t e m . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y M a x R a s t e r I m a g e W i d t h +
+ [ F i e l d ] S y s t e m . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y M a x R e n d e r I m a g e H e i g h t +
+ [ F i e l d ] S y s t e m . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y M a x R e n d e r I m a g e W i d t h +
+ [ F i e l d ] S y s t e m . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y M i n R a s t e r G r i d S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y M i n R a s t e r G r i d S i z e F o r P l o t +
+ [ F i e l d ] S y s t e m . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e F o r P l o t +
+ [ F i e l d ] S y s t e m . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e O v e r r i d e R a t i o +
+ [ F i e l d ] S y s t e m . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e O v e r r i d e R a t i o F o r P l o t +
+ [ F i e l d ] S y s t e m . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y R e n d e r S e l e c t i o n B a t c h S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y T i l e E x t e n t O f f s e t +
+ [ F i e l d ] S y s t e m . S t r i n g R e s o u r c e S e r v i c e P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y L i b r a r y R e p o s i t o r y P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y L i b r a r y R e s o u r c e D a t a F i l e P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y P a c k a g e s P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y R e p o s i t o r y C h e c k p o i n t s T i m e r I n t e r v a l +
+ [ F i e l d ] S y s t e m . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e C h a n g e T i m e r I n t e r v a l +
+ [ F i e l d ] S y s t e m . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e D a t a F i l e T r a s h F o l d e r N a m e +
+ [ F i e l d ] S y s t e m . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e P e r m i s s i o n C a c h e S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e S c h e m a F i l e P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y S e s s i o n R e p o s i t o r y P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y S e s s i o n R e s o u r c e D a t a F i l e P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y S i t e R e p o s i t o r y P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g S e r v e r C o n f i g u r a t i o n F i l e n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g S e s s i o n C a c h e S i z e P a r a m t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g S e s s i o n D B P a g e S i z e P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g S e s s i o n D B X M L P a g e S i z e P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g S e s s i o n L o g B u f f e r S i z e P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g S e s s i o n L o g P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g S e s s i o n L o g P r o p e r t y E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g S e s s i o n L o g P r o p e r t y F i l e n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g S e s s i o n L o g P r o p e r t y P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g S i t e C o n n e c t i o n P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g S i t e C o n n e c t i o n P r o p e r t y I p A d d r e s s +
+ [ F i e l d ] S y s t e m . S t r i n g S i t e C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s +
+ [ F i e l d ] S y s t e m . S t r i n g S i t e C o n n e c t i o n P r o p e r t y P o r t +
+ [ F i e l d ] S y s t e m . S t r i n g S i t e C o n n e c t i o n P r o p e r t y Q u e u e S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g S i t e C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e +
+ [ F i e l d ] S y s t e m . S t r i n g S i t e S e r v i c e P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g S i t e S e r v i c e P r o p e r t y S e s s i o n T i m e o u t +
+ [ F i e l d ] S y s t e m . S t r i n g S i t e S e r v i c e P r o p e r t y S e s s i o n T i m e r I n t e r v a l +
+ [ F i e l d ] S y s t e m . S t r i n g T e m p l a t e R o o t F o l d e r +
+ [ F i e l d ] S y s t e m . S t r i n g T i l e S e r v i c e P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g T i l e S e r v i c e P r o p e r t y I m a g e F o r m a t +
+ [ F i e l d ] S y s t e m . S t r i n g T i l e S e r v i c e P r o p e r t y R e n d e r O n l y +
+ [ F i e l d ] S y s t e m . S t r i n g T i l e S e r v i c e P r o p e r t y T i l e C a c h e P a t h +
+ [ F i e l d ] S y s t e m . S t r i n g T i l e S e r v i c e P r o p e r t y T i l e C o l u m n s P e r F o l d e r +
+ [ F i e l d ] S y s t e m . S t r i n g T i l e S e r v i c e P r o p e r t y T i l e R o w s P e r F o l d e r +
+ [ F i e l d ] S y s t e m . S t r i n g T i l e S e r v i c e P r o p e r t y T i l e S i z e X +
+ [ F i e l d ] S y s t e m . S t r i n g T i l e S e r v i c e P r o p e r t y T i l e S i z e Y +
+ [ F i e l d ] S y s t e m . S t r i n g T r a c e L o g P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g T r a c e L o g P r o p e r t y E n a b l e d +
+ [ F i e l d ] S y s t e m . S t r i n g T r a c e L o g P r o p e r t y F i l e n a m e +
+ [ F i e l d ] S y s t e m . S t r i n g T r a c e L o g P r o p e r t y P a r a m e t e r s +
+ [ F i e l d ] S y s t e m . S t r i n g U n m a n a g e d D a t a M a p p i n g s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g W e b A p p l i c a t i o n P r o p e r t i e s S e c t i o n +
+ [ F i e l d ] S y s t e m . S t r i n g W f s P a s s w o r d +
+ [ F i e l d ] S y s t e m . S t r i n g W i d g e t I n f o F o l d e r +
+ [ F i e l d ] S y s t e m . S t r i n g W m s P a s s w o r d +
+ t y p e O S G e o . M a p G u i d e . M g L o c a l i z e r : S y s t e m . O b j e c t +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S t r i n g ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g L o c a l i z e ( S y s t e m . S t r i n g , S y s t e m . S t r i n g , I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t L o c a l i z e d F i l e s P a t h ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g D r a w i n g S e r v i c e : O S G e o . M a p G u i d e . M g S e r v i c e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r D e s c r i b e D r a w i n g ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n E n u m e r a t e L a y e r s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r E n u m e r a t e S e c t i o n R e s o u r c e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r E n u m e r a t e S e c t i o n s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t C o o r d i n a t e S p a c e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t D r a w i n g ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t L a y e r ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t S e c t i o n ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t S e c t i o n R e s o u r c e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g D w f V e r s i o n : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t F i l e V e r s i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S c h e m a V e r s i o n ( ) +
+ [ M e t h o d ] V o i d S e t F i l e V e r s i o n ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t S c h e m a V e r s i o n ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g F e a t u r e I n f o r m a t i o n : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t H y p e r l i n k ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n G e t P r o p e r t i e s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S e l e c t i o n G e t S e l e c t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t T o o l t i p ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r T o X m l ( ) +
+ t y p e O S G e o . M a p G u i d e . M g K m l S e r v i c e : O S G e o . M a p G u i d e . M g S e r v i c e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t F e a t u r e s K m l ( O S G e o . M a p G u i d e . M g L a y e r , O S G e o . M a p G u i d e . M g E n v e l o p e , I n t 3 2 , I n t 3 2 , D o u b l e , I n t 3 2 , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t F e a t u r e s K m l ( O S G e o . M a p G u i d e . M g L a y e r , O S G e o . M a p G u i d e . M g E n v e l o p e , I n t 3 2 , I n t 3 2 , D o u b l e , I n t 3 2 , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t L a y e r K m l ( O S G e o . M a p G u i d e . M g L a y e r , O S G e o . M a p G u i d e . M g E n v e l o p e , I n t 3 2 , I n t 3 2 , D o u b l e , I n t 3 2 , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t M a p K m l ( O S G e o . M a p G u i d e . M g M a p , D o u b l e , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g L a y e r : O S G e o . M a p G u i d e . M g L a y e r B a s e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g T r a n s a c t i o n B e g i n T r a n s a c t i o n ( ) +
+ [ M e t h o d ] I n t 3 2 D e l e t e F e a t u r e s ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g T r a n s a c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e n e r a t e L e g e n d I m a g e ( I n t 3 2 , I n t 3 2 , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e n e r a t e L e g e n d I m a g e ( D o u b l e , I n t 3 2 , I n t 3 2 , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n G e t C l a s s D e f i n i t i o n ( ) +
+ [ M e t h o d ] I n t 3 2 G e t C o m p o s i t e T h e m e C a t e g o r y C o u n t ( D o u b l e , I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t C o m p o s i t e T h e m e C a t e g o r y C o u n t ( I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g I n t C o l l e c t i o n G e t G e o m e t r y T y p e S t y l e s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g I n t C o l l e c t i o n G e t G e o m e t r y T y p e S t y l e s ( D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S p a t i a l C o n t e x t R e a d e r G e t S p a t i a l C o n t e x t s ( B o o l e a n ) +
+ [ M e t h o d ] I n t 3 2 G e t T h e m e C a t e g o r y C o u n t ( D o u b l e , I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t T h e m e C a t e g o r y C o u n t ( I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r I n s e r t F e a t u r e s ( O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n , O S G e o . M a p G u i d e . M g T r a n s a c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r I n s e r t F e a t u r e s ( O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n , O S G e o . M a p G u i d e . M g T r a n s a c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D a t a R e a d e r S e l e c t A g g r e g a t e ( O S G e o . M a p G u i d e . M g F e a t u r e A g g r e g a t e O p t i o n s ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r S e l e c t F e a t u r e s ( O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r S e l e c t F e a t u r e s ( O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n U p d a t e F e a t u r e s ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n U p d a t e F e a t u r e s ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n , O S G e o . M a p G u i d e . M g T r a n s a c t i o n ) +
+ [ M e t h o d ] I n t 3 2 U p d a t e M a t c h i n g F e a t u r e s ( O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g T r a n s a c t i o n ) +
+ t y p e O S G e o . M a p G u i d e . M g L a y o u t : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r G e t L a y o u t ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t T i t l e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t U n i t T y p e ( ) +
+ [ M e t h o d ] V o i d S e t L a y o u t ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] V o i d S e t T i t l e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t U n i t T y p e ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g M a p : O S G e o . M a p G u i d e . M g M a p B a s e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g S i t e C o n n e c t i o n ) +
+ [ M e t h o d ] V o i d C r e a t e ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g E n v e l o p e , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d C r e a t e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 , D o u b l e , D o u b l e , D o u b l e , I n t 3 2 ) +
+ [ M e t h o d ] V o i d C r e a t e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t T i l e F o r m a t ( ) +
+ [ M e t h o d ] I n t 3 2 G e t T i l e P i x e l R a t i o ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r G e t T i l e S e t D e f i n i t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t T i l e S e t P r o v i d e r ( ) +
+ [ M e t h o d ] I n t 3 2 G e t W a t e r m a r k U s a g e ( ) +
+ [ M e t h o d ] V o i d O p e n ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S a v e ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e , O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] V o i d S a v e ( ) +
+ t y p e O S G e o . M a p G u i d e . M g M a p p i n g S e r v i c e : O S G e o . M a p G u i d e . M g S e r v i c e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r C r e a t e R u n t i m e M a p ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , S y s t e m . S t r i n g , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 , I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r C r e a t e R u n t i m e M a p ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r D e s c r i b e R u n t i m e M a p ( O S G e o . M a p G u i d e . M g M a p , I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r D e s c r i b e R u n t i m e M a p ( O S G e o . M a p G u i d e . M g M a p , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 , I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e n e r a t e L e g e n d I m a g e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , D o u b l e , I n t 3 2 , I n t 3 2 , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e n e r a t e M u l t i P l o t ( O S G e o . M a p G u i d e . M g M a p P l o t C o l l e c t i o n , O S G e o . M a p G u i d e . M g D w f V e r s i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e n e r a t e P l o t ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g E n v e l o p e , B o o l e a n , O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n , O S G e o . M a p G u i d e . M g L a y o u t , O S G e o . M a p G u i d e . M g D w f V e r s i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e n e r a t e P l o t ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n , O S G e o . M a p G u i d e . M g L a y o u t , O S G e o . M a p G u i d e . M g D w f V e r s i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e n e r a t e P l o t ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g C o o r d i n a t e , D o u b l e , O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n , O S G e o . M a p G u i d e . M g L a y o u t , O S G e o . M a p G u i d e . M g D w f V e r s i o n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r Q u e r y F e a t u r e s ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , I n t 3 2 , I n t 3 2 , I n t 3 2 , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r Q u e r y F e a t u r e s ( O S G e o . M a p G u i d e . M g M a p , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g M a p P l o t : O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g C o o r d i n a t e , D o u b l e , O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n , O S G e o . M a p G u i d e . M g L a y o u t ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n , O S G e o . M a p G u i d e . M g L a y o u t ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g E n v e l o p e , B o o l e a n , O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n , O S G e o . M a p G u i d e . M g L a y o u t ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o o r d i n a t e G e t C e n t e r ( ) +
+ [ M e t h o d ] B o o l e a n G e t E x p a n d T o F i t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g E n v e l o p e G e t E x t e n t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g L a y o u t G e t L a y o u t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g M a p G e t M a p ( ) +
+ [ M e t h o d ] I n t 3 2 G e t M a p P l o t I n s t r u c t i o n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n G e t P l o t S p e c i f i c a t i o n ( ) +
+ [ M e t h o d ] D o u b l e G e t S c a l e ( ) +
+ [ M e t h o d ] V o i d S e t C e n t e r A n d S c a l e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e , D o u b l e ) +
+ [ M e t h o d ] V o i d S e t E x t e n t ( O S G e o . M a p G u i d e . M g E n v e l o p e , B o o l e a n ) +
+ [ M e t h o d ] V o i d S e t L a y o u t ( O S G e o . M a p G u i d e . M g L a y o u t ) +
+ [ M e t h o d ] V o i d S e t M a p ( O S G e o . M a p G u i d e . M g M a p ) +
+ [ M e t h o d ] V o i d S e t M a p P l o t I n s t r u c t i o n ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t P l o t S p e c i f i c a t i o n ( O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n ) +
+ [ S y s t e m . R e f l e c t i o n . D e f a u l t M e m b e r A t t r i b u t e ] +
+ t y p e O S G e o . M a p G u i d e . M g M a p P l o t C o l l e c t i o n : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g M a p P l o t , O S G e o . M a p G u i d e . M a p G u i d e C o m m o n , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g M a p P l o t , O S G e o . M a p G u i d e . M a p G u i d e C o m m o n , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g M a p P l o t , O S G e o . M a p G u i d e . M a p G u i d e C o m m o n , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l ] ] +
+ i m p l e m e n t s S y s t e m . C o l l e c t i o n s . I E n u m e r a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( ) +
+ [ M e t h o d ] V o i d A d d ( O S G e o . M a p G u i d e . M g M a p P l o t ) +
+ [ M e t h o d ] V o i d C l e a r ( ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g M a p P l o t ) +
+ [ M e t h o d ] V o i d C o p y T o ( O S G e o . M a p G u i d e . M g M a p P l o t [ ] , I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 g e t _ C o u n t ( ) +
+ [ M e t h o d ] B o o l e a n g e t _ I s R e a d O n l y ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g M a p P l o t g e t _ I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t C o u n t ( ) +
+ [ M e t h o d ] S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g M a p P l o t ] G e t E n u m e r a t o r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g M a p P l o t G e t I t e m ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g M a p P l o t G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g M a p P l o t ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d I n s e r t ( I n t 3 2 , O S G e o . M a p G u i d e . M g M a p P l o t ) +
+ [ M e t h o d ] B o o l e a n R e m o v e ( O S G e o . M a p G u i d e . M g M a p P l o t ) +
+ [ M e t h o d ] V o i d R e m o v e A t ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d s e t _ I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g M a p P l o t ) +
+ [ M e t h o d ] V o i d S e t I t e m ( I n t 3 2 , O S G e o . M a p G u i d e . M g M a p P l o t ) +
+ t y p e O S G e o . M a p G u i d e . M g M e t a t i l e : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ i m p l e m e n t s S y s t e m . I D i s p o s a b l e +
+ [ M e t h o d ] I n t 3 2 G e t H e i g h t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t I m a g e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t M e t a T i l i n g F a c t o r ( ) +
+ [ M e t h o d ] I n t 3 2 G e t R e q u e s t e d H e i g h t ( ) +
+ [ M e t h o d ] I n t 3 2 G e t R e q u e s t e d W i d t h ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t T i l e I m a g e F o r m a t ( ) +
+ [ M e t h o d ] I n t 3 2 G e t W i d t h ( ) +
+ t y p e O S G e o . M a p G u i d e . M g P a c k a g e S t a t u s I n f o r m a t i o n : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t A p i N a m e ( ) +
+ [ M e t h o d ] D o u b l e G e t A v e r a g e O p e r a t i o n T i m e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D a t e T i m e G e t E n d T i m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t E r r o r M e s s a g e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t O p e r a t i o n s F a i l e d ( ) +
+ [ M e t h o d ] I n t 3 2 G e t O p e r a t i o n s R e c e i v e d ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D a t e T i m e G e t P a c k a g e D a t e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t P a c k a g e D e s c r i p t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t P a c k a g e N a m e ( ) +
+ [ M e t h o d ] I n t 6 4 G e t P a c k a g e S i z e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S e r v e r A d d r e s s ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S e r v e r N a m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S t a c k T r a c e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D a t e T i m e G e t S t a r t T i m e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S t a t u s C o d e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S t a t u s M e s s a g e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t U s e r N a m e ( ) +
+ [ M e t h o d ] V o i d S e t A p i N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t E n d T i m e ( O S G e o . M a p G u i d e . M g D a t e T i m e ) +
+ [ M e t h o d ] V o i d S e t E r r o r M e s s a g e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t O p e r a t i o n s F a i l e d ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t O p e r a t i o n s R e c e i v e d ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d S e t P a c k a g e D a t e ( O S G e o . M a p G u i d e . M g D a t e T i m e ) +
+ [ M e t h o d ] V o i d S e t P a c k a g e D e s c r i p t i o n ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t P a c k a g e N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t P a c k a g e S i z e ( I n t 6 4 ) +
+ [ M e t h o d ] V o i d S e t S e r v e r A d d r e s s ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t S e r v e r N a m e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t S t a c k T r a c e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t S t a r t T i m e ( O S G e o . M a p G u i d e . M g D a t e T i m e ) +
+ [ M e t h o d ] V o i d S e t S t a t u s C o d e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t U s e r N a m e ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S i n g l e , S i n g l e , S y s t e m . S t r i n g , S i n g l e , S i n g l e ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S i n g l e , S i n g l e , S y s t e m . S t r i n g , S i n g l e , S i n g l e , S i n g l e , S i n g l e ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S i n g l e , S i n g l e , S y s t e m . S t r i n g , S i n g l e ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S i n g l e , S i n g l e , S y s t e m . S t r i n g , S i n g l e , S i n g l e , S i n g l e ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S i n g l e , S i n g l e , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S i n g l e G e t M a r g i n B o t t o m ( ) +
+ [ M e t h o d ] S i n g l e G e t M a r g i n L e f t ( ) +
+ [ M e t h o d ] S i n g l e G e t M a r g i n R i g h t ( ) +
+ [ M e t h o d ] S i n g l e G e t M a r g i n T o p ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t P a g e S i z e U n i t s ( ) +
+ [ M e t h o d ] S i n g l e G e t P a p e r H e i g h t ( ) +
+ [ M e t h o d ] S i n g l e G e t P a p e r W i d t h ( ) +
+ [ M e t h o d ] V o i d S e t M a r g i n s ( S i n g l e , S i n g l e , S i n g l e , S i n g l e ) +
+ [ M e t h o d ] V o i d S e t P a g e S i z e U n i t s ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t P a p e r H e i g h t ( S i n g l e ) +
+ [ M e t h o d ] V o i d S e t P a p e r W i d t h ( S i n g l e ) +
+ t y p e O S G e o . M a p G u i d e . M g P r o f i l i n g S e r v i c e : O S G e o . M a p G u i d e . M g S e r v i c e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r P r o f i l e R e n d e r D y n a m i c O v e r l a y ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S e l e c t i o n , O S G e o . M a p G u i d e . M g R e n d e r i n g O p t i o n s ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r P r o f i l e R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S e l e c t i o n , O S G e o . M a p G u i d e . M g C o o r d i n a t e , D o u b l e , I n t 3 2 , I n t 3 2 , O S G e o . M a p G u i d e . M g C o l o r , S y s t e m . S t r i n g , B o o l e a n ) +
+ t y p e O S G e o . M a p G u i d e . M g R e n d e r i n g O p t i o n s : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , I n t 3 2 , O S G e o . M a p G u i d e . M g C o l o r ) +
+ [ M e t h o d ] I n t 3 2 G e t B e h a v i o r ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t I m a g e F o r m a t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g C o l o r G e t S e l e c t i o n C o l o r ( ) +
+ [ F i e l d ] I n t 3 2 K e e p S e l e c t i o n +
+ [ F i e l d ] I n t 3 2 R e n d e r B a s e L a y e r s +
+ [ F i e l d ] I n t 3 2 R e n d e r L a y e r s +
+ [ F i e l d ] I n t 3 2 R e n d e r S e l e c t i o n +
+ t y p e O S G e o . M a p G u i d e . M g R e n d e r i n g S e r v i c e : O S G e o . M a p G u i d e . M g S e r v i c e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n Q u e r y F e a t u r e P r o p e r t i e s ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , O S G e o . M a p G u i d e . M g G e o m e t r y , I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n Q u e r y F e a t u r e P r o p e r t i e s ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , O S G e o . M a p G u i d e . M g G e o m e t r y , I n t 3 2 , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e I n f o r m a t i o n Q u e r y F e a t u r e s ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , O S G e o . M a p G u i d e . M g G e o m e t r y , I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e I n f o r m a t i o n Q u e r y F e a t u r e s ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , O S G e o . M a p G u i d e . M g G e o m e t r y , I n t 3 2 , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r D y n a m i c O v e r l a y ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S e l e c t i o n , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r D y n a m i c O v e r l a y ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S e l e c t i o n , S y s t e m . S t r i n g , B o o l e a n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r D y n a m i c O v e r l a y ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S e l e c t i o n , O S G e o . M a p G u i d e . M g R e n d e r i n g O p t i o n s ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S e l e c t i o n , O S G e o . M a p G u i d e . M g E n v e l o p e , I n t 3 2 , I n t 3 2 , O S G e o . M a p G u i d e . M g C o l o r , S y s t e m . S t r i n g , B o o l e a n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S e l e c t i o n , S y s t e m . S t r i n g , B o o l e a n , B o o l e a n , O S G e o . M a p G u i d e . M g C o l o r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S e l e c t i o n , O S G e o . M a p G u i d e . M g E n v e l o p e , I n t 3 2 , I n t 3 2 , O S G e o . M a p G u i d e . M g C o l o r , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S e l e c t i o n , O S G e o . M a p G u i d e . M g C o o r d i n a t e , D o u b l e , I n t 3 2 , I n t 3 2 , O S G e o . M a p G u i d e . M g C o l o r , S y s t e m . S t r i n g , B o o l e a n , O S G e o . M a p G u i d e . M g C o l o r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S e l e c t i o n , O S G e o . M a p G u i d e . M g C o o r d i n a t e , D o u b l e , I n t 3 2 , I n t 3 2 , O S G e o . M a p G u i d e . M g C o l o r , S y s t e m . S t r i n g , B o o l e a n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S e l e c t i o n , O S G e o . M a p G u i d e . M g C o o r d i n a t e , D o u b l e , I n t 3 2 , I n t 3 2 , O S G e o . M a p G u i d e . M g C o l o r , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S e l e c t i o n , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S e l e c t i o n , S y s t e m . S t r i n g , B o o l e a n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g S e l e c t i o n , S y s t e m . S t r i n g , B o o l e a n , B o o l e a n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r M a p L e g e n d ( O S G e o . M a p G u i d e . M g M a p , I n t 3 2 , I n t 3 2 , O S G e o . M a p G u i d e . M g C o l o r , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g M e t a t i l e R e n d e r M e t a t i l e ( O S G e o . M a p G u i d e . M g M a p , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 , I n t 3 2 , I n t 3 2 , I n t 3 2 , S y s t e m . S t r i n g , D o u b l e , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g M e t a t i l e R e n d e r M e t a t i l e X Y Z ( O S G e o . M a p G u i d e . M g M a p , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 , I n t 3 2 , I n t 3 2 , S y s t e m . S t r i n g , D o u b l e , I n t 3 2 , I n t 3 2 ) +
+ [ S y s t e m . O b s o l e t e A t t r i b u t e ] +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r T i l e ( O S G e o . M a p G u i d e . M g M a p , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r T i l e ( O S G e o . M a p G u i d e . M g M a p , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 , I n t 3 2 , I n t 3 2 , I n t 3 2 , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r T i l e ( O S G e o . M a p G u i d e . M g M a p , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 , I n t 3 2 , I n t 3 2 , I n t 3 2 , S y s t e m . S t r i n g , D o u b l e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r T i l e F r o m M e t a T i l e ( O S G e o . M a p G u i d e . M g M a p , O S G e o . M a p G u i d e . M g M e t a t i l e , I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r T i l e U T F G r i d ( O S G e o . M a p G u i d e . M g M a p , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 , I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r T i l e X Y Z ( O S G e o . M a p G u i d e . M g M a p , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 , I n t 3 2 , I n t 3 2 , S y s t e m . S t r i n g , D o u b l e , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r T i l e X Y Z ( O S G e o . M a p G u i d e . M g M a p , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 , I n t 3 2 , I n t 3 2 , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r R e n d e r T i l e X Y Z ( O S G e o . M a p G u i d e . M g M a p , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 , I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g S e l e c t i o n : O S G e o . M a p G u i d e . M g S e l e c t i o n B a s e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g M a p , S y s t e m . S t r i n g ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g M a p ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r G e t S e l e c t e d F e a t u r e s ( O S G e o . M a p G u i d e . M g L a y e r B a s e , S y s t e m . S t r i n g , B o o l e a n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r G e t S e l e c t e d F e a t u r e s ( O S G e o . M a p G u i d e . M g L a y e r B a s e , S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ) +
+ [ M e t h o d ] V o i d O p e n ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S a v e ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e , S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g S e r v e r A d m i n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] V o i d B r i n g O n l i n e ( ) +
+ [ M e t h o d ] B o o l e a n C l e a r L o g ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d C l o s e ( ) +
+ [ M e t h o d ] V o i d D e l e t e L o g ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d D e l e t e P a c k a g e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d E n a b l e M a x i m u m L o g S i z e ( B o o l e a n ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n E n u m e r a t e L o g s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n E n u m e r a t e P a c k a g e s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n G e t C o n f i g u r a t i o n P r o p e r t i e s ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t D o c u m e n t ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n G e t I n f o r m a t i o n P r o p e r t i e s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t L o g ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g D a t e T i m e , O S G e o . M a p G u i d e . M g D a t e T i m e ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t L o g ( S y s t e m . S t r i n g , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t L o g ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t L o g F i l e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t P a c k a g e L o g ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P a c k a g e S t a t u s I n f o r m a t i o n G e t P a c k a g e S t a t u s ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n G e t S i t e S t a t u s ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S i t e V e r s i o n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W a r n i n g s G e t W a r n i n g s O b j e c t ( ) +
+ [ M e t h o d ] B o o l e a n H a s W a r n i n g ( ) +
+ [ M e t h o d ] B o o l e a n I s M a x i m u m L o g S i z e E n a b l e d ( ) +
+ [ M e t h o d ] B o o l e a n I s O n l i n e ( ) +
+ [ M e t h o d ] V o i d L o a d P a c k a g e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d M a k e P a c k a g e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d O p e n ( O S G e o . M a p G u i d e . M g U s e r I n f o r m a t i o n ) +
+ [ M e t h o d ] V o i d O p e n ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g U s e r I n f o r m a t i o n ) +
+ [ M e t h o d ] V o i d R e m o v e C o n f i g u r a t i o n P r o p e r t i e s ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ) +
+ [ M e t h o d ] V o i d R e n a m e L o g ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t C o n f i g u r a t i o n P r o p e r t i e s ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ) +
+ [ M e t h o d ] V o i d S e t D o c u m e n t ( S y s t e m . S t r i n g , O S G e o . M a p G u i d e . M g B y t e R e a d e r ) +
+ [ M e t h o d ] V o i d S e t L o g D e l i m i t e r ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t M a x i m u m L o g S i z e ( I n t 3 2 ) +
+ [ M e t h o d ] V o i d T a k e O f f l i n e ( ) +
+ t y p e O S G e o . M a p G u i d e . M g S i t e : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] V o i d A d d G r o u p ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d A d d S e r v e r ( S y s t e m . S t r i n g , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d A d d U s e r ( S y s t e m . S t r i n g , S y s t e m . S t r i n g , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g C r e a t e S e s s i o n ( ) +
+ [ M e t h o d ] V o i d D e l e t e G r o u p s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ) +
+ [ M e t h o d ] V o i d D e l e t e U s e r s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ) +
+ [ M e t h o d ] V o i d D e s t r o y S e s s i o n ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r E n u m e r a t e G r o u p s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r E n u m e r a t e G r o u p s ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r E n u m e r a t e G r o u p s ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n E n u m e r a t e R o l e s ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n E n u m e r a t e R o l e s ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r E n u m e r a t e S e r v e r s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r E n u m e r a t e U s e r s ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r E n u m e r a t e U s e r s ( S y s t e m . S t r i n g , S y s t e m . S t r i n g , B o o l e a n ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t C u r r e n t S e s s i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t C u r r e n t S i t e A d d r e s s ( ) +
+ [ M e t h o d ] I n t 3 2 G e t S e s s i o n T i m e o u t ( ) +
+ [ M e t h o d ] I n t 3 2 G e t S i t e S e r v e r C o u n t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S i t e I n f o G e t S i t e S e r v e r I n f o ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t U s e r F o r S e s s i o n ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W a r n i n g s G e t W a r n i n g ( ) +
+ [ M e t h o d ] V o i d G r a n t G r o u p M e m b e r s h i p s T o U s e r s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ) +
+ [ M e t h o d ] V o i d G r a n t R o l e M e m b e r s h i p s T o G r o u p s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ) +
+ [ M e t h o d ] V o i d G r a n t R o l e M e m b e r s h i p s T o U s e r s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ) +
+ [ M e t h o d ] V o i d O p e n ( O S G e o . M a p G u i d e . M g U s e r I n f o r m a t i o n , O S G e o . M a p G u i d e . M g S i t e I n f o ) +
+ [ M e t h o d ] V o i d R e m o v e S e r v e r ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d R e v o k e G r o u p M e m b e r s h i p s F r o m U s e r s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ) +
+ [ M e t h o d ] V o i d R e v o k e R o l e M e m b e r s h i p s F r o m G r o u p s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ) +
+ [ M e t h o d ] V o i d R e v o k e R o l e M e m b e r s h i p s F r o m U s e r s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n , O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ) +
+ [ M e t h o d ] V o i d U p d a t e G r o u p ( S y s t e m . S t r i n g , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d U p d a t e S e r v e r ( S y s t e m . S t r i n g , S y s t e m . S t r i n g , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d U p d a t e U s e r ( S y s t e m . S t r i n g , S y s t e m . S t r i n g , S y s t e m . S t r i n g , S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g S i t e C o n n e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S e r v i c e C r e a t e S e r v i c e ( I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S i t e G e t S i t e ( ) +
+ t y p e O S G e o . M a p G u i d e . M g S i t e I n f o : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t P o r t ( M g P o r t T y p e ) +
+ [ M e t h o d ] M g S i t e S t a t u s G e t S t a t u s ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t T a r g e t ( ) +
+ [ M e t h o d ] V o i d S e t S t a t u s ( M g S i t e S t a t u s ) +
+ t y p e O S G e o . M a p G u i d e . M g T i l e S e r v i c e : O S G e o . M a p G u i d e . M g S e r v i c e +
+ [ M e t h o d ] V o i d C l e a r C a c h e ( O S G e o . M a p G u i d e . M g M a p ) +
+ [ M e t h o d ] V o i d C l e a r C a c h e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] I n t 3 2 G e t D e f a u l t T i l e S i z e X ( ) +
+ [ M e t h o d ] I n t 3 2 G e t D e f a u l t T i l e S i z e X ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] I n t 3 2 G e t D e f a u l t T i l e S i z e Y ( ) +
+ [ M e t h o d ] I n t 3 2 G e t D e f a u l t T i l e S i z e Y ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t T i l e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t T i l e ( O S G e o . M a p G u i d e . M g M a p , S y s t e m . S t r i n g , I n t 3 2 , I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t T i l e P r o v i d e r s ( ) +
+ t y p e O S G e o . M a p G u i d e . M g U s e r I n f o r m a t i o n : O S G e o . M a p G u i d e . M g S e r i a l i z a b l e +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t C l i e n t A g e n t ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t C l i e n t I p ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t L o c a l e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r G e t R e a d e r ( ) +
+ [ M e t h o d ] V o i d S e t C l i e n t A g e n t ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t C l i e n t I p ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t L o c a l e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t M g S e s s i o n I d ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t M g U s e r n a m e P a s s w o r d ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g M a p + W a t e r m a r k U s a g e T y p e : S y s t e m . E n u m +
+ i m p l e m e n t s S y s t e m . I C o m p a r a b l e +
+ i m p l e m e n t s S y s t e m . I F o r m a t t a b l e +
+ i m p l e m e n t s S y s t e m . I C o n v e r t i b l e +
+ [ F i e l d ] I n t 3 2 v a l u e _ _ +
+ [ F i e l d ] W a t e r m a r k U s a g e T y p e V i e w e r +
+ [ F i e l d ] W a t e r m a r k U s a g e T y p e W M S +
+ t y p e O S G e o . M a p G u i d e . M g S i t e I n f o + M g S i t e S t a t u s : S y s t e m . E n u m +
+ [ F i e l d ] M g S i t e S t a t u s O k +
+ [ F i e l d ] M g S i t e S t a t u s T i m e d O u t +
+ [ F i e l d ] M g S i t e S t a t u s U n a b l e T o C o n n e c t +
+ [ F i e l d ] M g S i t e S t a t u s U n i n i t i a l i z e d +
+ t y p e O S G e o . M a p G u i d e . M g S i t e I n f o + M g P o r t T y p e : S y s t e m . E n u m +
+ [ F i e l d ] M g P o r t T y p e A d m i n +
+ [ F i e l d ] M g P o r t T y p e C l i e n t +
+ [ F i e l d ] M g P o r t T y p e S i t e +
+ A s s e m b l y : O S G e o . M a p G u i d e . W e b , V e r s i o n = 4 . 0 . 0 . 0 , C u l t u r e = n e u t r a l , P u b l i c K e y T o k e n = n u l l +
+ t y p e O S G e o . M a p G u i d e . M g W e b A c t i o n s : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 A b o u t +
+ [ F i e l d ] I n t 3 2 B u f f e r +
+ [ F i e l d ] I n t 3 2 C o p y +
+ [ F i e l d ] I n t 3 2 F i t W i n d o w +
+ [ F i e l d ] I n t 3 2 G e t P r i n t a b l e P a g e +
+ [ F i e l d ] I n t 3 2 H e l p +
+ [ F i e l d ] I n t 3 2 I n v o k e S c r i p t +
+ [ F i e l d ] I n t 3 2 I n v o k e U r l +
+ [ F i e l d ] I n t 3 2 M a p T i p +
+ [ F i e l d ] I n t 3 2 M e a s u r e +
+ [ F i e l d ] I n t 3 2 P a n +
+ [ F i e l d ] I n t 3 2 P a n D o w n +
+ [ F i e l d ] I n t 3 2 P a n L e f t +
+ [ F i e l d ] I n t 3 2 P a n R i g h t +
+ [ F i e l d ] I n t 3 2 P a n U p +
+ [ F i e l d ] I n t 3 2 P r i n t M a p +
+ [ F i e l d ] I n t 3 2 R e f r e s h +
+ [ F i e l d ] I n t 3 2 S e a r c h +
+ [ F i e l d ] I n t 3 2 S e l e c t +
+ [ F i e l d ] I n t 3 2 S e l e c t C l e a r +
+ [ F i e l d ] I n t 3 2 S e l e c t P o l y g o n +
+ [ F i e l d ] I n t 3 2 S e l e c t R a d i u s +
+ [ F i e l d ] I n t 3 2 S e l e c t W i t h i n +
+ [ F i e l d ] I n t 3 2 V i e w N e x t +
+ [ F i e l d ] I n t 3 2 V i e w O p t i o n s +
+ [ F i e l d ] I n t 3 2 V i e w P r e v i o u s +
+ [ F i e l d ] I n t 3 2 V i e w R e s t o r e +
+ [ F i e l d ] I n t 3 2 Z o o m +
+ [ F i e l d ] I n t 3 2 Z o o m I n +
+ [ F i e l d ] I n t 3 2 Z o o m O u t +
+ [ F i e l d ] I n t 3 2 Z o o m R e c t a n g l e +
+ [ F i e l d ] I n t 3 2 Z o o m S e l e c t i o n +
+ t y p e O S G e o . M a p G u i d e . M g W e b T a r g e t T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 N e w W i n d o w +
+ [ F i e l d ] I n t 3 2 S p e c i f i e d F r a m e +
+ [ F i e l d ] I n t 3 2 T a s k P a n e +
+ t y p e O S G e o . M a p G u i d e . M g W e b T a r g e t V i e w e r T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 A j a x +
+ [ F i e l d ] I n t 3 2 A l l +
+ [ F i e l d ] I n t 3 2 D w f +
+ t y p e O S G e o . M a p G u i d e . M g W e b T a s k B u t t o n T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 B a c k +
+ [ F i e l d ] I n t 3 2 F o r w a r d +
+ [ F i e l d ] I n t 3 2 H o m e +
+ [ F i e l d ] I n t 3 2 T a s k s +
+ t y p e O S G e o . M a p G u i d e . M g W e b W i d g e t T y p e : S y s t e m . O b j e c t +
+ [ F i e l d ] I n t 3 2 C o m m a n d +
+ [ F i e l d ] I n t 3 2 F l y o u t +
+ [ F i e l d ] I n t 3 2 S e p a r a t o r +
+ [ F i e l d ] I n t 3 2 T a s k B u t t o n +
+ t y p e O S G e o . M a p G u i d e . M a p G u i d e A p i : S y s t e m . O b j e c t +
+ [ M e t h o d ] V o i d M g I n i t i a l i z e W e b T i e r ( S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g H t t p H e a d e r : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] B o o l e a n A d d H e a d e r ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 3 2 G e t D a t e H e a d e r ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n G e t H e a d e r N a m e s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n G e t H e a d e r s ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t H e a d e r V a l u e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 3 2 G e t I n t H e a d e r ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n R e m o v e H e a d e r ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n S e t H e a d e r V a l u e ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g H t t p P r i m i t i v e V a l u e : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( B o o l e a n ) +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( I n t 3 2 ) +
+ [ M e t h o d ] B o o l e a n G e t B o o l V a l u e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t I n t e g e r V a l u e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S t r i n g V a l u e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t T y p e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g T o S t r i n g ( ) +
+ t y p e O S G e o . M a p G u i d e . M g H t t p R e q u e s t : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g H t t p R e s p o n s e E x e c u t e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t A g e n t U r i ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g H t t p H e a d e r G e t H e a d e r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g H t t p R e q u e s t M e t a d a t a G e t R e q u e s t M e t a d a t a ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g H t t p R e q u e s t P a r a m G e t R e q u e s t P a r a m ( ) +
+ t y p e O S G e o . M a p G u i d e . M g H t t p R e q u e s t M e t a d a t a : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] B o o l e a n A d d P r o p e r t y ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n G e t P r o p e r t y N a m e s ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t P r o p e r t y V a l u e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n R e m o v e P r o p e r t y ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n S e t P r o p e r t y V a l u e ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g H t t p R e q u e s t P a r a m : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] B o o l e a n A d d P a r a m e t e r ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n C o n t a i n s P a r a m e t e r ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n G e t P a r a m e t e r N a m e s ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t P a r a m e t e r T y p e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t P a r a m e t e r V a l u e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n R e m o v e P a r a m e t e r ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n S e t P a r a m e t e r T y p e ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] B o o l e a n S e t P a r a m e t e r V a l u e ( S y s t e m . S t r i n g , S y s t e m . S t r i n g ) +
+ t y p e O S G e o . M a p G u i d e . M g H t t p R e s p o n s e : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g H t t p R e s u l t G e t R e s u l t ( ) +
+ t y p e O S G e o . M a p G u i d e . M g H t t p R e s u l t : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D e t a i l e d E r r o r M e s s a g e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t H t t p S t a t u s M e s s a g e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t R e s u l t C o n t e n t T y p e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g D i s p o s a b l e G e t R e s u l t O b j e c t ( ) +
+ [ M e t h o d ] I n t 3 2 G e t S t a t u s C o d e ( ) +
+ [ M e t h o d ] V o i d S e t D e t a i l e d E r r o r M e s s a g e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t H t t p S t a t u s M e s s a g e ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t R e s u l t O b j e c t ( O S G e o . M a p G u i d e . M g D i s p o s a b l e , S y s t e m . S t r i n g ) +
+ [ M e t h o d ] V o i d S e t S t a t u s C o d e ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b B u f f e r C o m m a n d : O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d +
+ t y p e O S G e o . M a p G u i d e . M g W e b C o m m a n d : O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e +
+ [ M e t h o d ] I n t 3 2 G e t A c t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D e s c r i p t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D i s a b l e d I c o n U r l ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t I c o n U r l ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t L a b e l ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t N a m e ( ) +
+ [ M e t h o d ] I n t 3 2 G e t T a r g e t V i e w e r T y p e ( ) +
+ [ M e t h o d ] B o o l e a n I s U s e d ( ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b C o m m a n d C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g W e b C o m m a n d ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W e b C o m m a n d G e t I t e m ( I n t 3 2 ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W e b C o m m a n d G e t I t e m ( S y s t e m . S t r i n g ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g W e b C o m m a n d ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b C o m m a n d W i d g e t : O S G e o . M a p G u i d e . M g W e b W i d g e t +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W e b C o m m a n d G e t C o m m a n d ( ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b C o n t e x t M e n u : O S G e o . M a p G u i d e . M g W e b W i d g e t C o l l e c t i o n +
+ [ M e t h o d ] B o o l e a n I s V i s i b l e ( ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b F l y o u t W i d g e t : O S G e o . M a p G u i d e . M g W e b W i d g e t +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W e b W i d g e t C o l l e c t i o n G e t S u b I t e m s ( ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b G e t P r i n t a b l e P a g e C o m m a n d : O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d +
+ t y p e O S G e o . M a p G u i d e . M g W e b H e l p C o m m a n d : O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t U r l ( ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b I n f o r m a t i o n P a n e : O S G e o . M a p G u i d e . M g W e b U i S i z a b l e P a n e +
+ [ M e t h o d ] B o o l e a n I s L e g e n d B a n d V i s i b l e ( ) +
+ [ M e t h o d ] B o o l e a n I s P r o p e r t i e s B a n d V i s i b l e ( ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b I n v o k e S c r i p t C o m m a n d : O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S c r i p t C o d e ( ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b I n v o k e U r l C o m m a n d : O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d +
+ [ M e t h o d ] B o o l e a n D i s a b l e d I f S e l e c t i o n E m p t y ( ) +
+ [ M e t h o d ] I n t 3 2 G e t L a y e r C o u n t ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t L a y e r N a m e A t ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t P a r a m e t e r C o u n t ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t P a r a m e t e r N a m e A t ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t P a r a m e t e r V a l u e A t ( I n t 3 2 ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b L a y o u t : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ C o n s t r u c t o r ] V o i d . c t o r ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e , O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t A j a x P r e v i e w U r l ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g P o i n t G e t C e n t e r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W e b C o m m a n d C o l l e c t i o n G e t C o m m a n d s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W e b C o n t e x t M e n u G e t C o n t e x t M e n u ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t D w f P r e v i e w U r l ( ) +
+ [ M e t h o d ] B o o l e a n G e t E n a b l e P i n g S e r v e r ( ) +
+ [ M e t h o d ] I n t 3 2 G e t H y p e r l i n k T a r g e t ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t H y p e r l i n k T a r g e t F r a m e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W e b I n f o r m a t i o n P a n e G e t I n f o r m a t i o n P a n e ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t M a p D e f i n i t i o n ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t M a p I m a g e F o r m a t ( ) +
+ [ M e t h o d ] I n t 3 2 G e t P o i n t S e l e c t i o n B u f f e r ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S e l e c t i o n C o l o r ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S e l e c t i o n I m a g e F o r m a t ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t S t a r t u p S c r i p t ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W e b U i P a n e G e t S t a t u s B a r ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W e b T a s k P a n e G e t T a s k P a n e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W e b T o o l B a r G e t T o o l B a r ( ) +
+ [ M e t h o d ] B o o l e a n I s Z o o m C o n t r o l V i s i b l e ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g B y t e R e a d e r P r o c e s s G e t t i n g S t a r t e d P a g e ( O S G e o . M a p G u i d e . M g B y t e R e a d e r , B o o l e a n ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b M e a s u r e C o m m a n d : O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d +
+ t y p e O S G e o . M a p G u i d e . M g W e b P r i n t C o m m a n d : O S G e o . M a p G u i d e . M g W e b C o m m a n d +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t P r i n t L a y o u t A t ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 G e t P r i n t L a y o u t C o u n t ( ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b S e a r c h C o m m a n d : O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t C o l u m n D i s p l a y N a m e A t ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t C o l u m n P r o p e r t y N a m e A t ( I n t 3 2 ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t F i l t e r ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t L a y e r ( ) +
+ [ M e t h o d ] I n t 3 2 G e t M a t c h L i m i t ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t P r o m p t ( ) +
+ [ M e t h o d ] I n t 3 2 G e t R e s u l t C o l u m n C o u n t ( ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b S e l e c t W i t h i n C o m m a n d : O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d +
+ t y p e O S G e o . M a p G u i d e . M g W e b S e p a r a t o r W i d g e t : O S G e o . M a p G u i d e . M g W e b W i d g e t +
+ t y p e O S G e o . M a p G u i d e . M g W e b T a s k B a r : O S G e o . M a p G u i d e . M g W e b U i P a n e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W e b W i d g e t C o l l e c t i o n G e t T a s k B u t t o n s ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W e b W i d g e t C o l l e c t i o n G e t T a s k L i s t ( ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b T a s k B a r W i d g e t : O S G e o . M a p G u i d e . M g W e b W i d g e t +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t T o o l t i p ( ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b T a s k P a n e : O S G e o . M a p G u i d e . M g W e b U i S i z a b l e P a n e +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t I n i t i a l T a s k U r l ( ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W e b T a s k B a r G e t T a s k B a r ( ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b T o o l B a r : O S G e o . M a p G u i d e . M g W e b U i P a n e +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W e b W i d g e t C o l l e c t i o n G e t W i d g e t s ( ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b U i P a n e : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ t y p e O S G e o . M a p G u i d e . M g W e b U i S i z a b l e P a n e : O S G e o . M a p G u i d e . M g W e b U i P a n e +
+ t y p e O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d : O S G e o . M a p G u i d e . M g W e b C o m m a n d +
+ [ M e t h o d ] I n t 3 2 G e t T a r g e t ( ) +
+ [ M e t h o d ] S y s t e m . S t r i n g G e t T a r g e t N a m e ( ) +
+ t y p e O S G e o . M a p G u i d e . M g W e b V i e w O p t i o n s C o m m a n d : O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d +
+ t y p e O S G e o . M a p G u i d e . M g W e b W i d g e t : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ t y p e O S G e o . M a p G u i d e . M g W e b W i d g e t C o l l e c t i o n : O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e +
+ [ M e t h o d ] B o o l e a n C o n t a i n s ( O S G e o . M a p G u i d e . M g W e b W i d g e t ) +
+ [ M e t h o d ] O S G e o . M a p G u i d e . M g W e b W i d g e t G e t W i d g e t ( I n t 3 2 ) +
+ [ M e t h o d ] I n t 3 2 I n d e x O f ( O S G e o . M a p G u i d e . M g W e b W i d g e t ) +
\ No newline at end of file
Modified: branches/4.0/MgDev/Bindings/src/ApiDump/api.java.txt
--- branches/4.0/MgDev/Bindings/src/ApiDump/api.java.txt 2025-05-01 11:50:30 UTC (rev 10134)
+++ branches/4.0/MgDev/Bindings/src/ApiDump/api.java.txt 2025-05-05 10:45:53 UTC (rev 10135)
@@ -1,4704 +1,9409 @@
-Compiled from "AppThrowable.java"
-class org.osgeo.mapguide.AppThrowable extends java.lang.RuntimeException {
- public org.osgeo.mapguide.AppThrowable();
- public org.osgeo.mapguide.AppThrowable(long, boolean);
- public java.lang.String getMessage();
- public void printStackTrace();
- public void delete();
-Compiled from "MapGuideJavaApi.java"
-public class org.osgeo.mapguide.MapGuideJavaApi {
- public org.osgeo.mapguide.MapGuideJavaApi();
- public static void mgInitializeWebTier(java.lang.String);
-Compiled from "MgAgfReaderWriter.java"
-public class org.osgeo.mapguide.MgAgfReaderWriter extends org.osgeo.mapguide.MgGuardDisposable {
- public synchronized void delete();
- public org.osgeo.mapguide.MgAgfReaderWriter();
- public org.osgeo.mapguide.MgGeometry read(org.osgeo.mapguide.MgByteReader);
- public org.osgeo.mapguide.MgGeometry read(org.osgeo.mapguide.MgByteReader, org.osgeo.mapguide.MgTransform);
- public org.osgeo.mapguide.MgByteReader write(org.osgeo.mapguide.MgGeometry);
- public org.osgeo.mapguide.MgByteReader write(org.osgeo.mapguide.MgGeometry, org.osgeo.mapguide.MgTransform);
-Compiled from "MgAggregateGeometry.java"
-public class org.osgeo.mapguide.MgAggregateGeometry extends org.osgeo.mapguide.MgGeometry {
- public int getCount();
-Compiled from "MgArcSegment.java"
-public class org.osgeo.mapguide.MgArcSegment extends org.osgeo.mapguide.MgCurveSegment {
- public int getComponentType();
- public org.osgeo.mapguide.MgCoordinate getControlCoordinate();
- public org.osgeo.mapguide.MgCoordinate getStartCoordinate();
- public org.osgeo.mapguide.MgCoordinate getEndCoordinate();
- public int getDimension();
- public boolean isEmpty();
- public boolean isClosed();
- public org.osgeo.mapguide.MgGeometricEntity copy();
- public org.osgeo.mapguide.MgGeometricEntity transform(org.osgeo.mapguide.MgTransform);
-Compiled from "MgBase64.java"
-public class org.osgeo.mapguide.MgBase64$InputStream extends java.io.FilterInputStream {
- public org.osgeo.mapguide.MgBase64$InputStream(java.io.InputStream);
- public org.osgeo.mapguide.MgBase64$InputStream(java.io.InputStream, int);
- public int read() throws java.io.IOException;
- public int read(byte[], int, int) throws java.io.IOException;
-public class org.osgeo.mapguide.MgBase64$OutputStream extends java.io.FilterOutputStream {
- public org.osgeo.mapguide.MgBase64$OutputStream(java.io.OutputStream);
- public org.osgeo.mapguide.MgBase64$OutputStream(java.io.OutputStream, int);
- public void write(int) throws java.io.IOException;
- public void write(byte[], int, int) throws java.io.IOException;
- public void flushBase64() throws java.io.IOException;
- public void close() throws java.io.IOException;
- public void suspendEncoding() throws java.io.IOException;
- public void resumeEncoding();
-public class org.osgeo.mapguide.MgBase64 {
- public static final int NO_OPTIONS = 0;
- public static final int ENCODE = 1;
- public static final int DECODE = 0;
- public static final int GZIP = 2;
- public static final int DONT_BREAK_LINES = 8;
- public static java.lang.String encodeObject(java.io.Serializable);
- public static java.lang.String encodeObject(java.io.Serializable, int);
- public static java.lang.String encodeBytes(byte[]);
- public static java.lang.String encodeBytes(byte[], int);
- public static java.lang.String encodeBytes(byte[], int, int);
- public static java.lang.String encodeBytes(byte[], int, int, int);
- public static byte[] decode(byte[], int, int);
- public static byte[] decode(java.lang.String);
- public static java.lang.Object decodeToObject(java.lang.String);
- public static boolean encodeToFile(byte[], java.lang.String);
- public static boolean decodeToFile(java.lang.String, java.lang.String);
- public static byte[] decodeFromFile(java.lang.String);
- public static java.lang.String encodeFromFile(java.lang.String);
-Compiled from "MgBatchPropertyCollection.java"
-public class org.osgeo.mapguide.MgBatchPropertyCollection extends org.osgeo.mapguide.MgCollection {
- public org.osgeo.mapguide.MgBatchPropertyCollection();
- public void setItem(int, org.osgeo.mapguide.MgPropertyCollection);
- public void addItem(org.osgeo.mapguide.MgPropertyCollection);
- public void insert(int, org.osgeo.mapguide.MgPropertyCollection);
- public boolean remove(org.osgeo.mapguide.MgPropertyCollection);
- public org.osgeo.mapguide.MgPropertyCollection getItem(int);
- public void clear();
- public void removeAt(int);
- public boolean contains(org.osgeo.mapguide.MgPropertyDefinition);
- public int indexOf(org.osgeo.mapguide.MgPropertyDefinition);
- public org.osgeo.mapguide.MgByteReader toXml();
-Compiled from "MgBlobProperty.java"
-public class org.osgeo.mapguide.MgBlobProperty extends org.osgeo.mapguide.MgNullableProperty {
- public org.osgeo.mapguide.MgBlobProperty(java.lang.String, org.osgeo.mapguide.MgByteReader);
- public org.osgeo.mapguide.MgByteReader getValue();
- public short getPropertyType();
- public void setValue(org.osgeo.mapguide.MgByteReader);
-Compiled from "MgBooleanProperty.java"
-public class org.osgeo.mapguide.MgBooleanProperty extends org.osgeo.mapguide.MgNullableProperty {
- public org.osgeo.mapguide.MgBooleanProperty(java.lang.String, boolean);
- public boolean getValue();
- public void setValue(boolean);
-Compiled from "MgByteProperty.java"
-public class org.osgeo.mapguide.MgByteProperty extends org.osgeo.mapguide.MgNullableProperty {
- public org.osgeo.mapguide.MgByteProperty(java.lang.String, byte);
- public byte getValue();
- public void setValue(byte);
-Compiled from "MgByteReader.java"
-public class org.osgeo.mapguide.MgByteReader extends org.osgeo.mapguide.MgSerializable {
- public org.osgeo.mapguide.MgByteReader(java.lang.String, java.lang.String, boolean);
- public org.osgeo.mapguide.MgByteReader(java.lang.String, java.lang.String);
- public org.osgeo.mapguide.MgByteReader(byte[], int, java.lang.String);
- public int read(byte[], int);
- public java.lang.String getMimeType();
- public java.lang.String toString();
- public void toFile(java.lang.String);
- public long getLength();
- public boolean isRewindable();
- public void rewind();
-Compiled from "MgByteSink.java"
-public class org.osgeo.mapguide.MgByteSink extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgByteSink(org.osgeo.mapguide.MgByteReader);
-Compiled from "MgByteSource.java"
-public class org.osgeo.mapguide.MgByteSource extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgByteSource(java.lang.String);
- public org.osgeo.mapguide.MgByteSource(byte[], int);
- public void setMimeType(java.lang.String);
- public org.osgeo.mapguide.MgByteReader getReader();
-Compiled from "MgClassDefinition.java"
-public class org.osgeo.mapguide.MgClassDefinition extends org.osgeo.mapguide.MgNamedSerializable {
- public boolean equals(java.lang.Object);
- public int hashCode();
- public org.osgeo.mapguide.MgClassDefinition();
- public org.osgeo.mapguide.MgPropertyDefinitionCollection getProperties();
- public org.osgeo.mapguide.MgPropertyDefinitionCollection getIdentityProperties();
- public java.lang.String getDefaultGeometryPropertyName();
- public void setDefaultGeometryPropertyName(java.lang.String);
- public void setName(java.lang.String);
- public java.lang.String getName();
- public void setDescription(java.lang.String);
- public java.lang.String getDescription();
- public org.osgeo.mapguide.MgClassDefinition getBaseClassDefinition();
- public boolean isComputed();
- public boolean isAbstract();
- public void markAsDeleted();
-Compiled from "MgClassDefinitionCollection.java"
-class org.osgeo.mapguide.MgClassDefinitionCollection$ItemIterator implements java.util.Iterator<org.osgeo.mapguide.MgClassDefinition> {
- public org.osgeo.mapguide.MgClassDefinitionCollection$ItemIterator(org.osgeo.mapguide.MgClassDefinitionCollection, org.osgeo.mapguide.MgClassDefinitionCollection);
- public boolean hasNext();
- public org.osgeo.mapguide.MgClassDefinition next();
- public void remove();
- public java.lang.Object next();
-public class org.osgeo.mapguide.MgClassDefinitionCollection extends org.osgeo.mapguide.MgCollection implements java.util.Collection<org.osgeo.mapguide.MgClassDefinition> {
- public java.util.Iterator<org.osgeo.mapguide.MgClassDefinition> iterator();
- public boolean add(org.osgeo.mapguide.MgClassDefinition);
- public boolean addAll(java.util.Collection<? extends org.osgeo.mapguide.MgClassDefinition>);
- public boolean contains(java.lang.Object);
- public boolean containsAll(java.util.Collection<?>);
- public boolean remove(java.lang.Object);
- public boolean removeAll(java.util.Collection<?>);
- public boolean retainAll(java.util.Collection<?>);
- public int size();
- public java.lang.Object[] toArray();
- public <MgClassDefinition> MgClassDefinition[] toArray(MgClassDefinition[]);
- public org.osgeo.mapguide.MgClassDefinitionCollection();
- public void setItem(int, org.osgeo.mapguide.MgClassDefinition);
- public void addItem(org.osgeo.mapguide.MgClassDefinition);
- public void insert(int, org.osgeo.mapguide.MgClassDefinition);
- public boolean remove(org.osgeo.mapguide.MgClassDefinition);
- public org.osgeo.mapguide.MgClassDefinition getItem(int);
- public boolean contains(org.osgeo.mapguide.MgClassDefinition);
- public int indexOf(org.osgeo.mapguide.MgClassDefinition);
- public boolean add(java.lang.Object);
-Compiled from "MgClobProperty.java"
-public class org.osgeo.mapguide.MgClobProperty extends org.osgeo.mapguide.MgNullableProperty {
- public org.osgeo.mapguide.MgClobProperty(java.lang.String, org.osgeo.mapguide.MgByteReader);
-Compiled from "MgCollection.java"
-public class org.osgeo.mapguide.MgCollection extends org.osgeo.mapguide.MgSerializable {
-Compiled from "MgColor.java"
-public class org.osgeo.mapguide.MgColor extends org.osgeo.mapguide.MgSerializable {
- public org.osgeo.mapguide.MgColor(java.lang.String);
- public org.osgeo.mapguide.MgColor(short, short, short);
- public org.osgeo.mapguide.MgColor(short, short, short, short);
- public java.lang.String getColor();
- public short getRed();
- public short getBlue();
- public short getGreen();
- public short getAlpha();
-Compiled from "MgConfigProperties.java"
-public class org.osgeo.mapguide.MgConfigProperties {
- public static final java.lang.String DefaultConfigurationFilename = "webconfig.ini";
- public static final java.lang.String ServerConfigurationFilename = "serverconfig.ini";
- public static final java.lang.String GeneralPropertiesSection = "GeneralProperties";
- public static final java.lang.String GeneralPropertyConnectionTimeout = "ConnectionTimeout";
- public static final int DefaultGeneralPropertyConnectionTimeout = 120;
- public static final java.lang.String GeneralPropertyConnectionTimerInterval = "ConnectionTimerInterval";
- public static final int DefaultGeneralPropertyConnectionTimerInterval = 60;
- public static final java.lang.String GeneralPropertyLocale = "Locale";
- public static final java.lang.String DefaultGeneralPropertyLocale = "";
- public static final java.lang.String GeneralPropertyDefaultMessageLocale = "DefaultMessageLocale";
- public static final java.lang.String DefaultGeneralPropertyDefaultMessageLocale = "en";
- public static final java.lang.String GeneralPropertyDisplayName = "DisplayName";
- public static final java.lang.String DefaultGeneralPropertyDisplayName = "";
- public static final java.lang.String GeneralPropertyFdoPath = "FdoPath";
- public static final java.lang.String DefaultGeneralPropertyFdoPath = "";
- public static final java.lang.String GeneralPropertyMentorDictionaryPath = "MentorDictionaryPath";
- public static final java.lang.String DefaultGeneralPropertyMentorDictionaryPath = "";
- public static final java.lang.String GeneralPropertyMentorUserDictionaryPath = "MentorUserDictionaryPath";
- public static final java.lang.String DefaultGeneralPropertyMentorUserDictionaryPath = "";
- public static final java.lang.String GeneralPropertyLicenseServerPath = "LicenseServerPath";
- public static final java.lang.String DefaultGeneralPropertyLicenseServerPath = "";
- public static final java.lang.String GeneralPropertyLinuxMemDebug = "LinuxMemDebug";
- public static final boolean DefaultGeneralPropertyLinuxMemDebug = false;
- public static final java.lang.String GeneralPropertyLinuxFontDirectories = "LinuxFontDirectories";
- public static final java.lang.String DefaultGeneralPropertyLinuxFontDirectories = "";
- public static final java.lang.String GeneralPropertyLogsDelimiter = "LogsDelimiter";
- public static final java.lang.String DefaultGeneralPropertyLogsDelimiter = "\t";
- public static final java.lang.String GeneralPropertyLogsDetail = "LogsDetail";
- public static final java.lang.String DefaultGeneralPropertyLogsDetail = "";
- public static final java.lang.String GeneralPropertyLogsPath = "LogsPath";
- public static final java.lang.String DefaultGeneralPropertyLogsPath = "Logs/";
- public static final java.lang.String GeneralPropertyMachineIp = "MachineIp";
- public static final java.lang.String DefaultGeneralPropertyMachineIp = "127.0.0.1";
- public static final java.lang.String GeneralPropertyMaxLogFileSize = "MaxLogFileSize";
- public static final int DefaultGeneralPropertyMaxLogFileSize = 64;
- public static final java.lang.String GeneralPropertyMaxLogFileSizeEnabled = "MaxLogFileSizeEnabled";
- public static final boolean DefaultGeneralPropertyMaxLogFileSizeEnabled = false;
- public static final java.lang.String GeneralPropertyResourcesPath = "ResourcesPath";
- public static final java.lang.String DefaultGeneralPropertyResourcesPath = "Resources/";
- public static final java.lang.String GeneralPropertySerialNumber = "SerialNumber";
- public static final java.lang.String DefaultGeneralPropertySerialNumber = "";
- public static final java.lang.String GeneralPropertyServiceRegistrationTimerInterval = "ServiceRegistrationTimerInterval";
- public static final int DefaultGeneralPropertyServiceRegistrationTimerInterval = 60;
- public static final java.lang.String GeneralPropertyTcpIpMtu = "TcpIpMtu";
- public static final int DefaultGeneralPropertyTcpIpMtu = 1460;
- public static final java.lang.String GeneralPropertyTempPath = "TempPath";
- public static final java.lang.String DefaultGeneralPropertyTempPath = "Temp/";
- public static final java.lang.String GeneralPropertyWfsDocumentPath = "WfsDocumentPath";
- public static final java.lang.String DefaultGeneralPropertyWfsDocumentPath = "Wfs/";
- public static final java.lang.String GeneralPropertyWmsDocumentPath = "WmsDocumentPath";
- public static final java.lang.String DefaultGeneralPropertyWmsDocumentPath = "Wms/";
- public static final java.lang.String GeneralPropertyPreCacheMaps = "PreCacheMaps";
- public static final java.lang.String DefaultGeneralPropertyPreCacheMaps = "";
- public static final java.lang.String AdministrativeConnectionPropertiesSection = "AdministrativeConnectionProperties";
- public static final java.lang.String AdministrativeConnectionPropertyEmail = "Email";
- public static final java.lang.String DefaultAdministrativeConnectionPropertyEmail = "";
- public static final java.lang.String AdministrativeConnectionPropertyMaxConnections = "MaxConnections";
- public static final int DefaultAdministrativeConnectionPropertyMaxConnections = 20;
- public static final java.lang.String AdministrativeConnectionPropertyPort = "Port";
- public static final int DefaultAdministrativeConnectionPropertyPort = 5555;
- public static final java.lang.String AdministrativeConnectionPropertyQueueSize = "QueueSize";
- public static final int DefaultAdministrativeConnectionPropertyQueueSize = 10;
- public static final java.lang.String AdministrativeConnectionPropertyThreadPoolSize = "ThreadPoolSize";
- public static final int DefaultAdministrativeConnectionPropertyThreadPoolSize = 5;
- public static final java.lang.String ClientConnectionPropertiesSection = "ClientConnectionProperties";
- public static final java.lang.String ClientConnectionPropertyMaxConnections = "MaxConnections";
- public static final int DefaultClientConnectionPropertyMaxConnections = 100;
- public static final java.lang.String ClientConnectionPropertyPort = "Port";
- public static final int DefaultClientConnectionPropertyPort = 4444;
- public static final java.lang.String ClientConnectionPropertyQueueSize = "QueueSize";
- public static final int DefaultClientConnectionPropertyQueueSize = 10;
- public static final java.lang.String ClientConnectionPropertyThreadPoolSize = "ThreadPoolSize";
- public static final int DefaultClientConnectionPropertyThreadPoolSize = 10;
- public static final java.lang.String SiteConnectionPropertiesSection = "SiteConnectionProperties";
- public static final java.lang.String SiteConnectionPropertyIpAddress = "IpAddress";
- public static final java.lang.String DefaultSiteConnectionPropertyIpAddress = "127.0.0.1";
- public static final java.lang.String SiteConnectionPropertyMaxConnections = "MaxConnections";
- public static final int DefaultSiteConnectionPropertyMaxConnections = 20;
- public static final java.lang.String SiteConnectionPropertyPort = "Port";
- public static final int DefaultSiteConnectionPropertyPort = 3333;
- public static final java.lang.String SiteConnectionPropertyQueueSize = "QueueSize";
- public static final int DefaultSiteConnectionPropertyQueueSize = 10;
- public static final java.lang.String SiteConnectionPropertyThreadPoolSize = "ThreadPoolSize";
- public static final int DefaultSiteConnectionPropertyThreadPoolSize = 5;
- public static final java.lang.String HostPropertiesSection = "HostProperties";
- public static final java.lang.String HostPropertyDrawingService = "DrawingService";
- public static final boolean DefaultHostPropertyDrawingService = false;
- public static final java.lang.String HostPropertyFeatureService = "FeatureService";
- public static final boolean DefaultHostPropertyFeatureService = false;
- public static final java.lang.String HostPropertyKmlService = "KmlService";
- public static final boolean DefaultHostPropertyKmlService = false;
- public static final java.lang.String HostPropertyMappingService = "MappingService";
- public static final boolean DefaultHostPropertyMappingService = false;
- public static final java.lang.String HostPropertyRenderingService = "RenderingService";
- public static final boolean DefaultHostPropertyRenderingService = false;
- public static final java.lang.String HostPropertyResourceService = "ResourceService";
- public static final boolean DefaultHostPropertyResourceService = false;
- public static final java.lang.String HostPropertyProfilingService = "ProfilingService";
- public static final boolean DefaultHostPropertyProfilingService = false;
- public static final java.lang.String HostPropertySiteService = "SiteService";
- public static final boolean DefaultHostPropertySiteService = false;
- public static final java.lang.String HostPropertyTileService = "TileService";
- public static final boolean DefaultHostPropertyTileService = false;
- public static final java.lang.String DrawingServicePropertiesSection = "DrawingServiceProperties";
- public static final java.lang.String FeatureServicePropertiesSection = "FeatureServiceProperties";
- public static final java.lang.String FeatureServicePropertyCacheSize = "CacheSize";
- public static final int DefaultFeatureServicePropertyCacheSize = 100;
- public static final java.lang.String FeatureServicePropertyCacheTimeLimit = "CacheTimeLimit";
- public static final int DefaultFeatureServicePropertyCacheTimeLimit = 86400;
- public static final java.lang.String FeatureServicePropertyCacheTimerInterval = "CacheTimerInterval";
- public static final int DefaultFeatureServicePropertyCacheTimerInterval = 3600;
- public static final java.lang.String FeatureServicePropertyDataCacheSize = "DataCacheSize";
- public static final int DefaultFeatureServicePropertyDataCacheSize = 100;
- public static final java.lang.String FeatureServicePropertyDataConnectionPoolEnabled = "DataConnectionPoolEnabled";
- public static final boolean DefaultFeatureServicePropertyDataConnectionPoolEnabled = false;
- public static final java.lang.String FeatureServicePropertyDataConnectionPoolExcludedProviders = "DataConnectionPoolExcludedProviders";
- public static final java.lang.String DefaultFeatureServicePropertyDataConnectionPoolExcludedProviders = "OSGeo.SDF,OSGeo.SHP";
- public static final java.lang.String FeatureServicePropertyDataConnectionPoolSize = "DataConnectionPoolSize";
- public static final int DefaultFeatureServicePropertyDataConnectionPoolSize = 50;
- public static final java.lang.String FeatureServicePropertyDataConnectionPoolSizeCustom = "DataConnectionPoolSizeCustom";
- public static final java.lang.String DefaultFeatureServicePropertyDataConnectionPoolSizeCustom = "";
- public static final java.lang.String FeatureServicePropertyDataConnectionTimeout = "DataConnectionTimeout";
- public static final int DefaultFeatureServicePropertyDataConnectionTimeout = 600;
- public static final java.lang.String FeatureServicePropertyDataConnectionTimerInterval = "DataConnectionTimerInterval";
- public static final int DefaultFeatureServicePropertyDataConnectionTimerInterval = 60;
- public static final java.lang.String FeatureServicePropertyJoinQueryBatchSize = "JoinQueryBatchSize";
- public static final int DefaultFeatureServicePropertyJoinQueryBatchSize = 100;
- public static final java.lang.String FeatureServicePropertyDataConnectionUseLimit = "DataConnectionUseLimit";
- public static final java.lang.String DefaultFeatureServicePropertyDataConnectionUseLimit = "";
- public static final java.lang.String FeatureServicePropertyDataTransactionTimeout = "DataTransactionTimeout";
- public static final int DefaultFeatureServicePropertyDataTransactionTimeout = 360;
- public static final java.lang.String FeatureServicePropertyDataTransactionTimerInterval = "DataTransactionTimerInterval";
- public static final int DefaultFeatureServicePropertyDataTransactionTimerInterval = 60;
- public static final java.lang.String FeatureServicePropertyFDOConnectionTimeoutCustom = "FDOConnectionTimeoutCustom";
- public static final java.lang.String DefaultFeatureServicePropertyFDOConnectionTimeoutCustom = "OSGeo.WMS:120";
- public static final java.lang.String FeatureServicePropertyUseFdoJoinOptimization = "UseFdoJoinOptimization";
- public static final boolean DefaultFeatureServicePropertyUseFdoJoinOptimization = true;
- public static final java.lang.String MappingServicePropertiesSection = "MappingServiceProperties";
- public static final java.lang.String MappingServicePropertyLegendFont = "LegendFont";
- public static final java.lang.String DefaultMappingServicePropertyLegendFont = "Arial";
- public static final java.lang.String RenderingServicePropertiesSection = "RenderingServiceProperties";
- public static final java.lang.String RenderingServicePropertyTileExtentOffset = "TileExtentOffset";
- public static final double DefaultRenderingServicePropertyTileExtentOffset = 0.35d;
- public static final java.lang.String RenderingServicePropertyRasterGridSize = "RasterGridSize";
- public static final int DefaultRenderingServicePropertyRasterGridSize = 100;
- public static final java.lang.String RenderingServicePropertyMinRasterGridSize = "MinRasterGridSize";
- public static final int DefaultRenderingServicePropertyMinRasterGridSize = 10;
- public static final java.lang.String RenderingServicePropertyRasterGridSizeOverrideRatio = "RasterGridSizeOverrideRatio";
- public static final double DefaultRenderingServicePropertyRasterGridSizeOverrideRatio = 0.25d;
- public static final java.lang.String RenderingServicePropertyRasterGridSizeForPlot = "RasterGridSizeForPlot";
- public static final int DefaultRenderingServicePropertyRasterGridSizeForPlot = 50;
- public static final java.lang.String RenderingServicePropertyMinRasterGridSizeForPlot = "MinRasterGridSizeForPlot";
- public static final int DefaultRenderingServicePropertyMinRasterGridSizeForPlot = 5;
- public static final java.lang.String RenderingServicePropertyRasterGridSizeOverrideRatioForPlot = "RasterGridSizeOverrideRatioForPlot";
- public static final double DefaultRenderingServicePropertyRasterGridSizeOverrideRatioForPlot = 0.1d;
- public static final java.lang.String RenderingServicePropertyRenderSelectionBatchSize = "RenderSelectionBatchSize";
- public static final int DefaultRenderingServicePropertyRenderSelectionBatchSize = 10000;
- public static final java.lang.String RenderingServicePropertyClampPoints = "ClampPoints";
- public static final boolean DefaultRenderingServicePropertyClampPoints = false;
- public static final java.lang.String RenderingServicePropertyGeneralizeData = "GeneralizeData";
- public static final boolean DefaultRenderingServicePropertyGeneralizeData = false;
- public static final java.lang.String RenderingServicePropertyMaxRasterImageWidth = "MaxRasterImageWidth";
- public static final int DefaultRenderingServicePropertyMaxRasterImageWidth = 2048;
- public static final java.lang.String RenderingServicePropertyMaxRasterImageHeight = "MaxRasterImageHeight";
- public static final int DefaultRenderingServicePropertyMaxRasterImageHeight = 2048;
- public static final java.lang.String RenderingServicePropertyMaxRenderImageWidth = "MaxRenderImageWidth";
- public static final int DefaultRenderingServicePropertyMaxRenderImageWidth = 16384;
- public static final java.lang.String RenderingServicePropertyMaxRenderImageHeight = "MaxRenderImageHeight";
- public static final int DefaultRenderingServicePropertyMaxRenderImageHeight = 16384;
- public static final java.lang.String RenderingServicePropertiesGlobalRasterStylizationLockEnabled = "GlobalRasterStylizationLockEnabled";
- public static final boolean DefaultRenderingServicePropertiesGlobalRasterStylizationLockEnabled = true;
- public static final java.lang.String FontAliasMappingSection = "FontAliases";
- public static final java.lang.String UnmanagedDataMappingsSection = "UnmanagedDataMappings";
- public static final java.lang.String ResourceServicePropertiesSection = "ResourceServiceProperties";
- public static final java.lang.String ResourceServicePropertyLibraryRepositoryPath = "LibraryRepositoryPath";
- public static final java.lang.String DefaultResourceServicePropertyLibraryRepositoryPath = "Repositories/Library/";
- public static final java.lang.String ResourceServicePropertyLibraryResourceDataFilePath = "LibraryResourceDataFilePath";
- public static final java.lang.String DefaultResourceServicePropertyLibraryResourceDataFilePath = "Repositories/Library/DataFiles/";
- public static final java.lang.String ResourceServicePropertyPackagesPath = "PackagesPath";
- public static final java.lang.String DefaultResourceServicePropertyPackagesPath = "Packages/";
- public static final java.lang.String ResourceServicePropertyRepositoryCheckpointsTimerInterval = "RepositoryCheckpointsTimerInterval";
- public static final int DefaultResourceServicePropertyRepositoryCheckpointsTimerInterval = 600;
- public static final java.lang.String ResourceServicePropertyResourceChangeTimerInterval = "ResourceChangeTimerInterval";
- public static final int DefaultResourceServicePropertyResourceChangeTimerInterval = 5;
- public static final java.lang.String ResourceServicePropertyResourceDataFileTrashFolderName = "ResourceDataFileTrashFolderName";
- public static final java.lang.String DefaultResourceServicePropertyResourceDataFileTrashFolderName = "Trash";
- public static final java.lang.String ResourceServicePropertyResourcePermissionCacheSize = "ResourcePermissionCacheSize";
- public static final int DefaultResourceServicePropertyResourcePermissionCacheSize = 1000;
- public static final java.lang.String ResourceServicePropertyResourceSchemaFilePath = "ResourceSchemaFilePath";
- public static final java.lang.String DefaultResourceServicePropertyResourceSchemaFilePath = "Schema/";
- public static final java.lang.String ResourceServicePropertySessionRepositoryPath = "SessionRepositoryPath";
- public static final java.lang.String DefaultResourceServicePropertySessionRepositoryPath = "Repositories/Session/";
- public static final java.lang.String ResourceServicePropertySessionResourceDataFilePath = "SessionResourceDataFilePath";
- public static final java.lang.String DefaultResourceServicePropertySessionResourceDataFilePath = "Repositories/Session/DataFiles/";
- public static final java.lang.String ResourceServicePropertySiteRepositoryPath = "SiteRepositoryPath";
- public static final java.lang.String DefaultResourceServicePropertySiteRepositoryPath = "Repositories/Site/";
- public static final java.lang.String SiteServicePropertiesSection = "SiteServiceProperties";
- public static final java.lang.String SiteServicePropertySessionTimeout = "SessionTimeout";
- public static final int DefaultSiteServicePropertySessionTimeout = 1200;
- public static final java.lang.String SiteServicePropertySessionTimerInterval = "SessionTimerInterval";
- public static final int DefaultSiteServicePropertySessionTimerInterval = 400;
- public static final java.lang.String TileServicePropertiesSection = "TileServiceProperties";
- public static final java.lang.String TileServicePropertyRenderOnly = "RenderOnly";
- public static final boolean DefaultTileServicePropertyRenderOnly = false;
- public static final java.lang.String TileServicePropertyTileCachePath = "TileCachePath";
- public static final java.lang.String DefaultTileServicePropertyTileCachePath = "Repositories/TileCache/";
- public static final java.lang.String TileServicePropertyTileColumnsPerFolder = "TileColumnsPerFolder";
- public static final int DefaultTileServicePropertyTileColumnsPerFolder = 30;
- public static final java.lang.String TileServicePropertyTileRowsPerFolder = "TileRowsPerFolder";
- public static final int DefaultTileServicePropertyTileRowsPerFolder = 30;
- public static final java.lang.String TileServicePropertyTileSizeX = "DefaultTileSizeX";
- public static final int DefaultTileServicePropertyTileSizeX = 300;
- public static final java.lang.String TileServicePropertyTileSizeY = "DefaultTileSizeY";
- public static final int DefaultTileServicePropertyTileSizeY = 300;
- public static final java.lang.String TileServicePropertyImageFormat = "ImageFormat";
- public static final java.lang.String DefaultTileServicePropertyImageFormat = "PNG";
- public static final java.lang.String AccessLogPropertiesSection = "AccessLogProperties";
- public static final java.lang.String AccessLogPropertyEnabled = "Enabled";
- public static final boolean DefaultAccessLogPropertyEnabled = true;
- public static final java.lang.String AccessLogPropertyFilename = "Filename";
- public static final java.lang.String DefaultAccessLogPropertyFilename = "Access.log";
- public static final java.lang.String AccessLogPropertyParameters = "Parameters";
- public static final java.lang.String DefaultAccessLogPropertyParameters = "";
- public static final java.lang.String AdminLogPropertiesSection = "AdminLogProperties";
- public static final java.lang.String AdminLogPropertyEnabled = "Enabled";
- public static final boolean DefaultAdminLogPropertyEnabled = true;
- public static final java.lang.String AdminLogPropertyFilename = "Filename";
- public static final java.lang.String DefaultAdminLogPropertyFilename = "Admin.log";
- public static final java.lang.String AdminLogPropertyParameters = "Parameters";
- public static final java.lang.String DefaultAdminLogPropertyParameters = "";
- public static final java.lang.String AuthenticationLogPropertiesSection = "AuthenticationLogProperties";
- public static final java.lang.String AuthenticationLogPropertyEnabled = "Enabled";
- public static final boolean DefaultAuthenticationLogPropertyEnabled = true;
- public static final java.lang.String AuthenticationLogPropertyFilename = "Filename";
- public static final java.lang.String DefaultAuthenticationLogPropertyFilename = "Authentication.log";
- public static final java.lang.String AuthenticationLogPropertyParameters = "Parameters";
- public static final java.lang.String DefaultAuthenticationLogPropertyParameters = "";
- public static final java.lang.String ErrorLogPropertiesSection = "ErrorLogProperties";
- public static final java.lang.String ErrorLogPropertyEnabled = "Enabled";
- public static final boolean DefaultErrorLogPropertyEnabled = true;
- public static final java.lang.String ErrorLogPropertyFilename = "Filename";
- public static final java.lang.String DefaultErrorLogPropertyFilename = "Error.log";
- public static final java.lang.String ErrorLogPropertyParameters = "Parameters";
- public static final java.lang.String DefaultErrorLogPropertyParameters = "";
- public static final java.lang.String PerformanceLogPropertiesSection = "PerformanceLogProperties";
- public static final java.lang.String PerformanceLogPropertyEnabled = "Enabled";
- public static final boolean DefaultPerformanceLogPropertyEnabled = false;
- public static final java.lang.String PerformanceLogPropertyFilename = "Filename";
- public static final java.lang.String DefaultPerformanceLogPropertyFilename = "Performance.log";
- public static final java.lang.String PerformanceLogPropertyParameters = "Parameters";
- public static final java.lang.String DefaultPerformanceLogPropertyParameters = "";
- public static final java.lang.String PerformanceLogPropertyInterval = "Interval";
- public static final int DefaultPerformanceLogPropertyInterval = 300;
- public static final java.lang.String SessionLogPropertiesSection = "SessionLogProperties";
- public static final java.lang.String SessionLogPropertyEnabled = "Enabled";
- public static final boolean DefaultSessionLogPropertyEnabled = true;
- public static final java.lang.String SessionLogPropertyFilename = "Filename";
- public static final java.lang.String DefaultSessionLogPropertyFilename = "Session.log";
- public static final java.lang.String SessionLogPropertyParameters = "Parameters";
- public static final java.lang.String DefaultSessionLogPropertyParameters = "";
- public static final java.lang.String TraceLogPropertiesSection = "TraceLogProperties";
- public static final java.lang.String TraceLogPropertyEnabled = "Enabled";
- public static final boolean DefaultTraceLogPropertyEnabled = true;
- public static final java.lang.String TraceLogPropertyFilename = "Filename";
- public static final java.lang.String DefaultTraceLogPropertyFilename = "Trace.log";
- public static final java.lang.String TraceLogPropertyParameters = "Parameters";
- public static final java.lang.String DefaultTraceLogPropertyParameters = "";
- public static final java.lang.String DBEnvironmentPropertiesSection = "DBEnvironmentProperties";
- public static final java.lang.String LibraryCacheSizeParameters = "LibraryCacheSize";
- public static final int DefaultLibraryCacheSizeParameters = 32;
- public static final java.lang.String SessionCacheSizeParamters = "SessionCacheSize";
- public static final int DefaultSessionCacheSizeParamters = 2;
- public static final java.lang.String DBPageSizeParameters = "DBPageSize";
- public static final int DefaultDBPageSizeParameters = 32;
- public static final java.lang.String DBXMLPageSizeParameters = "DBXMLPageSize";
- public static final int DefaultDBXMLPageSizeParameters = 32;
- public static final java.lang.String LibraryLogBufferSizeParameters = "LibraryLogBufferSize";
- public static final int DefaultLibraryLogBufferSizeParameters = 12;
- public static final java.lang.String SessionLogBufferSizeParameters = "SessionLogBufferSize";
- public static final int DefaultSessionLogBufferSizeParameters = 1;
- public static final java.lang.String DBMaxTransactionsParamters = "DBMaxTransactions";
- public static final int DefaultDBMaxTransactionsParamters = 1000;
- public static final java.lang.String SessionDBPageSizeParameters = "SessionDBPageSize";
- public static final int DefaultSessionDBPageSizeParameters = 2;
- public static final java.lang.String SessionDBXMLPageSizeParameters = "SessionDBXMLPageSize";
- public static final double DefaultSessionDBXMLPageSizeParameters = 0.5d;
- public static final java.lang.String DBTimeoutParameters = "DBTimeout";
- public static final double DefaultDBTimeoutParameters = 0.2d;
- public static final java.lang.String DBMaxLockersParameters = "DBMaxLockers";
- public static final int DefaultDBMaxLockersParameters = 1000;
- public static final java.lang.String AgentPropertiesSection = "AgentProperties";
- public static final java.lang.String AgentDebugPause = "DebugPause";
- public static final int DefaultAgentDebugPause = 0;
- public static final java.lang.String AgentDisableAuthoring = "DisableAuthoring";
- public static final java.lang.String AgentDisableWfs = "DisableWfs";
- public static final java.lang.String AgentDisableWms = "DisableWms";
- public static final java.lang.String AgentErrorLogEnabled = "ErrorLogEnabled";
- public static final boolean DefaultAgentErrorLogEnabled = false;
- public static final java.lang.String AgentErrorLogFilename = "ErrorLogFilename";
- public static final java.lang.String DefaultAgentErrorLogFilename = "Error.log";
- public static final java.lang.String AgentRequestLogEnabled = "RequestLogEnabled";
- public static final boolean DefaultAgentRequestLogEnabled = false;
- public static final java.lang.String AgentRequestLogFilename = "RequestLogFilename";
- public static final java.lang.String DefaultAgentRequestLogFilename = "Request.log";
- public static final java.lang.String AgentGlobalMaxFeatureQueryLimit = "GlobalMaxFeatureQueryLimit";
- public static final int DefaultAgentGlobalMaxFeatureQueryLimit = 0;
- public static final java.lang.String AgentGlobalMaxMapFeatureQueryLimit = "GlobalMaxMapFeatureQueryLimit";
- public static final int DefaultAgentGlobalMaxMapFeatureQueryLimit = 0;
- public static final java.lang.String AgentAnonymousDenyGetResourceContent = "AnonymousDenyGetResourceContent";
- public static final java.lang.String DefaultAgentAnonymousDenyGetResourceContent = "";
- public static final java.lang.String AgentAnonymousDenyGetResourceData = "AnonymousDenyGetResourceData";
- public static final java.lang.String DefaultAgentAnonymousDenyGetResourceData = "";
- public static final java.lang.String AgentAnonymousDenyGetResourceHeader = "AnonymousDenyGetResourceHeader";
- public static final java.lang.String DefaultAgentAnonymousDenyGetResourceHeader = "";
- public static final java.lang.String OgcPropertiesSection = "OgcProperties";
- public static final java.lang.String WfsPassword = "WfsPassword";
- public static final java.lang.String WmsPassword = "WmsPassword";
- public static final java.lang.String CITEWfsEnabled = "CITEWfsEnabled";
- public static final boolean DefaultCITEWfsEnabled = false;
- public static final java.lang.String CITEWmsEnabled = "CITEWmsEnabled";
- public static final boolean DefaultCITEWmsEnabled = false;
- public static final java.lang.String AgentGlobalGetWfsFeaturesLimit = "GlobalGetWfsFeaturesLimit";
- public static final int DefaultAgentGlobalGetWfsFeaturesLimit = 0;
- public static final java.lang.String AgentGlobalGetWmsFeatureInfoLimit = "GlobalGetWmsFeatureInfoLimit";
- public static final int DefaultAgentGlobalGetWmsFeatureInfoLimit = 0;
- public static final java.lang.String WebApplicationPropertiesSection = "WebApplicationProperties";
- public static final java.lang.String TemplateRootFolder = "TemplateRootFolder";
- public static final java.lang.String WidgetInfoFolder = "WidgetInfoFolder";
- public static final java.lang.String ContainerInfoFolder = "ContainerInfoFolder";
- public org.osgeo.mapguide.MgConfigProperties();
-Compiled from "MgCoordinate.java"
-public class org.osgeo.mapguide.MgCoordinate extends org.osgeo.mapguide.MgSerializable {
- public double getX();
- public double getY();
- public double getZ();
- public double getM();
- public static double getNoZ();
- public static double getNoM();
-Compiled from "MgCoordinateCollection.java"
-public class org.osgeo.mapguide.MgCoordinateCollection extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgCoordinate getItem(int);
- public void setItem(int, org.osgeo.mapguide.MgCoordinate);
- public void add(org.osgeo.mapguide.MgCoordinate);
- public void insert(int, org.osgeo.mapguide.MgCoordinate);
- public boolean remove(org.osgeo.mapguide.MgCoordinate);
- public boolean contains(org.osgeo.mapguide.MgCoordinate);
- public int indexOf(org.osgeo.mapguide.MgCoordinate);
- public org.osgeo.mapguide.MgCoordinateCollection();
-Compiled from "MgCoordinateDimension.java"
-public class org.osgeo.mapguide.MgCoordinateDimension {
- public static final int XY = 0;
- public static final int XYZ = 1;
- public static final int M = 2;
- public org.osgeo.mapguide.MgCoordinateDimension();
-Compiled from "MgCoordinateIterator.java"
-public class org.osgeo.mapguide.MgCoordinateIterator extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgCoordinate getCurrent();
- public boolean moveNext();
- public void reset();
-Compiled from "MgCoordinateSpace.java"
-public class org.osgeo.mapguide.MgCoordinateSpace {
- public static final java.lang.String None = "None";
- public static final java.lang.String Map = "Map";
- public static final java.lang.String Display = "Display";
- public org.osgeo.mapguide.MgCoordinateSpace();
-Compiled from "MgCoordinateSystem.java"
-public class org.osgeo.mapguide.MgCoordinateSystem extends org.osgeo.mapguide.MgGuardDisposable {
- public int getType();
- public org.osgeo.mapguide.MgCoordinate convertFromLonLat(org.osgeo.mapguide.MgCoordinate);
- public org.osgeo.mapguide.MgCoordinate convertToLonLat(org.osgeo.mapguide.MgCoordinate);
- public double convertCoordinateSystemUnitsToMeters(double);
- public double convertMetersToCoordinateSystemUnits(double);
- public double measureEuclideanDistance(org.osgeo.mapguide.MgCoordinate, org.osgeo.mapguide.MgCoordinate);
- public double measureEuclideanDistance(double, double, double, double);
- public double measureGreatCircleDistance(org.osgeo.mapguide.MgCoordinate, org.osgeo.mapguide.MgCoordinate);
- public double measureGreatCircleDistance(double, double, double, double);
- public double getAzimuth(org.osgeo.mapguide.MgCoordinate, org.osgeo.mapguide.MgCoordinate);
- public double getAzimuth(double, double, double, double);
- public org.osgeo.mapguide.MgCoordinate getCoordinate(org.osgeo.mapguide.MgCoordinate, double, double);
- public org.osgeo.mapguide.MgCoordinate getCoordinate(double, double, double, double);
- public java.lang.String getUnits();
- public double getUnitScale();
- public double getMinX();
- public double getMinY();
- public double getMaxX();
- public double getMaxY();
- public java.lang.String getCsCode();
- public java.lang.String getProjection();
- public java.lang.String getProjectionDescription();
- public java.lang.String getDatum();
- public java.lang.String getDatumDescription();
- public java.lang.String getEllipsoid();
- public java.lang.String getEllipsoidDescription();
- public int getEpsgCode();
- public int getSridCode();
- public short getEpsgQuadrant();
- public org.osgeo.mapguide.MgCoordinateSystemMeasure getMeasure();
- public org.osgeo.mapguide.MgStringCollection getCategories();
- public org.osgeo.mapguide.MgCoordinateSystemCatalog getCatalog();
- public void setCsCode(java.lang.String);
- public boolean isLegalCsCode(java.lang.String);
- public boolean isValid();
- public boolean isUsable(org.osgeo.mapguide.MgCoordinateSystemCatalog);
- public boolean isSameAs(org.osgeo.mapguide.MgGuardDisposable);
- public boolean isLegalDescription(java.lang.String);
- public java.lang.String getGroup();
- public void setGroup(java.lang.String);
- public boolean isLegalGroup(java.lang.String);
- public java.lang.String getSource();
- public void setSource(java.lang.String);
- public boolean isLegalSource(java.lang.String);
- public boolean isProtected();
- public short getAge();
- public void setProtectMode(boolean);
- public boolean isEncrypted();
- public void setEncryptMode(boolean);
- public org.osgeo.mapguide.MgCoordinateSystemEnumInteger32 getErrors();
- public java.lang.String getLocation();
- public void setLocation(java.lang.String);
- public boolean isLegalLocation(java.lang.String);
- public java.lang.String getCountryOrState();
- public void setCountryOrState(java.lang.String);
- public boolean isLegalCountryOrState(java.lang.String);
- public boolean isGeodetic();
- public int getProjectionCode();
- public void setProjectionCode(int);
- public int getUnitCode();
- public void setUnitCode(int);
- public int getProjectionParameterCount();
- public double getProjectionParameter(int);
- public void setProjectionParameter(int, double);
- public double getOriginLongitude();
- public void setOriginLongitude(double);
- public double getOriginLatitude();
- public void setOriginLatitude(double);
- public double getOffsetX();
- public double getOffsetY();
- public void setOffsets(double, double);
- public double getScaleReduction();
- public void setScaleReduction(double);
- public double getMapScale();
- public void setMapScale(double);
- public double getZeroX();
- public double getZeroY();
- public void setZeroes(double, double);
- public double getLonMin();
- public double getLonMax();
- public double getLatMin();
- public double getLatMax();
- public void setLonLatBounds(double, double, double, double);
- public void cancelLonLatBounds();
- public void setXYBounds(double, double, double, double);
- public void cancelXYBounds();
- public short getQuadrant();
- public void setQuadrant(short);
- public org.osgeo.mapguide.MgCoordinateSystemDatum getDatumDefinition();
- public void setDatumDefinition(org.osgeo.mapguide.MgCoordinateSystemDatum);
- public org.osgeo.mapguide.MgCoordinateSystemEllipsoid getEllipsoidDefinition();
- public void setEllipsoidDefinition(org.osgeo.mapguide.MgCoordinateSystemEllipsoid);
- public boolean isValidXY(double, double);
- public boolean isValidLonLat(double, double);
- public void convertCoordinateFromLonLat(org.osgeo.mapguide.MgCoordinate);
- public void convertCoordinateToLonLat(org.osgeo.mapguide.MgCoordinate);
- public org.osgeo.mapguide.MgCoordinate convertToLonLat(double, double);
- public org.osgeo.mapguide.MgCoordinate convertToLonLat(double, double, double);
- public org.osgeo.mapguide.MgCoordinate convertFromLonLat(double, double);
- public org.osgeo.mapguide.MgCoordinate convertFromLonLat(double, double, double);
- public double getConvergence(double, double);
- public double getScale(double, double);
- public double getScaleH(double, double);
- public double getScaleK(double, double);
- public org.osgeo.mapguide.MgCoordinateSystem createClone();
-Compiled from "MgCoordinateSystemCatalog.java"
-public class org.osgeo.mapguide.MgCoordinateSystemCatalog extends org.osgeo.mapguide.MgGuardDisposable {
- public void setDefaultDictionaryDirAndFileNames();
- public java.lang.String getDefaultDictionaryDir();
- public void setDictionaryDir(java.lang.String);
- public java.lang.String getDictionaryDir();
- public java.lang.String getDefaultUserDictionaryDir();
- public void setUserDictionaryDir(java.lang.String);
- public java.lang.String getUserDictionaryDir();
- public void setProtectionMode(short);
- public short getProtectionMode();
- public org.osgeo.mapguide.MgCoordinateSystemCategoryDictionary getCategoryDictionary();
- public org.osgeo.mapguide.MgCoordinateSystemDictionary getCoordinateSystemDictionary();
- public org.osgeo.mapguide.MgCoordinateSystemDatumDictionary getDatumDictionary();
- public org.osgeo.mapguide.MgCoordinateSystemEllipsoidDictionary getEllipsoidDictionary();
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticPathDictionary getGeodeticPathDictionary();
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformDefDictionary getGeodeticTransformDefDictionary();
- public org.osgeo.mapguide.MgDisposableCollection getGeodeticTransformations(org.osgeo.mapguide.MgCoordinateSystemDatum, org.osgeo.mapguide.MgCoordinateSystemDatum);
- public org.osgeo.mapguide.MgCoordinateSystemMathComparator getMathComparator();
- public org.osgeo.mapguide.MgCoordinateSystemFormatConverter getFormatConverter();
- public org.osgeo.mapguide.MgCoordinateSystemProjectionInformation getProjectionInformation();
- public org.osgeo.mapguide.MgCoordinateSystemUnitInformation getUnitInformation();
- public org.osgeo.mapguide.MgCoordinateSystemDictionaryUtility getDictionaryUtility();
- public boolean areDictionaryFilesWritable();
-Compiled from "MgCoordinateSystemCategory.java"
-public class org.osgeo.mapguide.MgCoordinateSystemCategory extends org.osgeo.mapguide.MgGuardDisposable {
- public boolean isLegalName(java.lang.String);
- public org.osgeo.mapguide.MgCoordinateSystemCategory createClone();
- public int getSize();
- public org.osgeo.mapguide.MgCoordinateSystemEnum getEnum();
- public void addCoordinateSystem(java.lang.String);
- public void removeCoordinateSystem(java.lang.String);
- public boolean hasCoordinateSystem(java.lang.String);
- public org.osgeo.mapguide.MgStringCollection getCoordinateSystems();
-Compiled from "MgCoordinateSystemCategoryDictionary.java"
-public class org.osgeo.mapguide.MgCoordinateSystemCategoryDictionary extends org.osgeo.mapguide.MgCoordinateSystemDictionaryBase {
- public org.osgeo.mapguide.MgCoordinateSystemCategory newCategory();
- public void rename(java.lang.String, java.lang.String);
- public org.osgeo.mapguide.MgCoordinateSystemCategory getCategory(java.lang.String);
-Compiled from "MgCoordinateSystemCodeFormat.java"
-public class org.osgeo.mapguide.MgCoordinateSystemCodeFormat {
- public static final int Mentor = 0;
- public static final int Epsg = 1;
- public org.osgeo.mapguide.MgCoordinateSystemCodeFormat();
-Compiled from "MgCoordinateSystemDatum.java"
-public class org.osgeo.mapguide.MgCoordinateSystemDatum extends org.osgeo.mapguide.MgGuardDisposable {
- public java.lang.String getDtCode();
- public void setDtCode(java.lang.String);
- public boolean isLegalDtCode(java.lang.String);
- public short getEpsgCode();
- public void setEpsgCode(short);
- public void setEllipsoid(java.lang.String);
- public org.osgeo.mapguide.MgCoordinateSystemDatum createClone();
- public org.osgeo.mapguide.MgDisposableCollection getGeodeticTransformations(org.osgeo.mapguide.MgCoordinateSystemDatum);
-Compiled from "MgCoordinateSystemDatumDictionary.java"
-public class org.osgeo.mapguide.MgCoordinateSystemDatumDictionary extends org.osgeo.mapguide.MgCoordinateSystemDictionaryBase {
- public org.osgeo.mapguide.MgCoordinateSystemDatum newDatum();
- public org.osgeo.mapguide.MgCoordinateSystemDatum getDatum(java.lang.String);
-Compiled from "MgCoordinateSystemDictionary.java"
-public class org.osgeo.mapguide.MgCoordinateSystemDictionary extends org.osgeo.mapguide.MgCoordinateSystemDictionaryBase {
- public org.osgeo.mapguide.MgCoordinateSystem newCoordinateSystem();
- public org.osgeo.mapguide.MgCoordinateSystem getCoordinateSystem(java.lang.String);
-Compiled from "MgCoordinateSystemDictionaryBase.java"
-public class org.osgeo.mapguide.MgCoordinateSystemDictionaryBase extends org.osgeo.mapguide.MgGuardDisposable {
- public java.lang.String getDefaultFileName();
- public java.lang.String getFileName();
- public void setFileName(java.lang.String);
- public java.lang.String getPath();
- public void add(org.osgeo.mapguide.MgGuardDisposable);
- public void remove(java.lang.String);
- public void modify(org.osgeo.mapguide.MgGuardDisposable);
- public org.osgeo.mapguide.MgGuardDisposable get(java.lang.String);
- public boolean has(java.lang.String);
-Compiled from "MgCoordinateSystemDictionaryUtility.java"
-public class org.osgeo.mapguide.MgCoordinateSystemDictionaryUtility extends org.osgeo.mapguide.MgGuardDisposable {
- public void createEllipsoidDictionary(java.lang.String);
- public void createDatumDictionary(java.lang.String);
- public void createCoordsysDictionary(java.lang.String);
- public void createCategoryDictionary(java.lang.String);
-Compiled from "MgCoordinateSystemEllipsoid.java"
-public class org.osgeo.mapguide.MgCoordinateSystemEllipsoid extends org.osgeo.mapguide.MgGuardDisposable {
- public java.lang.String getElCode();
- public void setElCode(java.lang.String);
- public boolean isLegalElCode(java.lang.String);
- public boolean isUsable();
- public org.osgeo.mapguide.MgCoordinateSystemEllipsoid createClone();
- public double getEquatorialRadius();
- public double getPolarRadius();
- public double getFlatteningRatio();
- public double getEccentricity();
- public void setRadii(double, double);
- public double flatteningRatioToEccentricity(double);
- public double eccentricityToFlatteningRatio(double);
- public double equatorialRadiusFromPolarRadiusFlatteningRatio(double, double);
- public double polarRadiusFromEquatorialRadiusFlatteningRatio(double, double);
- public double getGreatCircleDistance(double, double, double, double);
- public double getGreatCircleAzimuth(double, double, double, double);
- public double getRadiusMin();
- public double getRadiusMax();
- public boolean isLegalRadius(double);
- public double getFlatteningRatioMin();
- public double getFlatteningRatioMax();
- public boolean isLegalFlatteningRatio(double);
- public double flatteningRatioFromRadii(double, double);
-Compiled from "MgCoordinateSystemEllipsoidDictionary.java"
-public class org.osgeo.mapguide.MgCoordinateSystemEllipsoidDictionary extends org.osgeo.mapguide.MgCoordinateSystemDictionaryBase {
- public org.osgeo.mapguide.MgCoordinateSystemEllipsoid newEllipsoid();
- public org.osgeo.mapguide.MgCoordinateSystemEllipsoid getEllipsoid(java.lang.String);
-Compiled from "MgCoordinateSystemEnum.java"
-public class org.osgeo.mapguide.MgCoordinateSystemEnum extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgDisposableCollection next(int);
- public void skip(int);
- public org.osgeo.mapguide.MgCoordinateSystemEnum createClone();
- public void addFilter(org.osgeo.mapguide.MgCoordinateSystemFilter);
- public org.osgeo.mapguide.MgStringCollection nextName(int);
- public org.osgeo.mapguide.MgStringCollection nextDescription(int);
-Compiled from "MgCoordinateSystemEnumInteger32.java"
-public class org.osgeo.mapguide.MgCoordinateSystemEnumInteger32 extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgStringCollection next(int);
- public org.osgeo.mapguide.MgCoordinateSystemEnumInteger32 createClone();
- public void addFilter(org.osgeo.mapguide.MgCoordinateSystemFilterInteger32);
-Compiled from "MgCoordinateSystemErrorCode.java"
-public class org.osgeo.mapguide.MgCoordinateSystemErrorCode {
- public static final int AZM = 201;
- public static final int AZMTH = 202;
- public static final int LAT = 203;
- public static final int LATEQU = 204;
- public static final int LNG = 205;
- public static final int LNGEQU = 206;
- public static final int MAPSCL = 207;
- public static final int MEREQU = 208;
- public static final int MRCAT = 209;
- public static final int MSCOEF = 210;
- public static final int NOREF = 211;
- public static final int NOTNRTH = 212;
- public static final int NRTHLAT = 213;
- public static final int NRTHPNT = 214;
- public static final int ORGLAT = 215;
- public static final int ORGLNG = 216;
- public static final int PLL90 = 217;
- public static final int PLLEQU = 218;
- public static final int PLLLRG = 219;
- public static final int PLLREV = 220;
- public static final int PLLZERO = 221;
- public static final int POLDD = 222;
- public static final int POLDUP = 223;
- public static final int POLLAT = 224;
- public static final int POLLNG = 225;
- public static final int QUAD = 226;
- public static final int SCLRED = 227;
- public static final int SOTHLAT = 228;
- public static final int STDLAT = 229;
- public static final int STDLNG = 230;
- public static final int STDPLL = 231;
- public static final int STDSOU = 232;
- public static final int STDWEST = 233;
- public static final int UNIT = 234;
- public static final int INVPRJ = 235;
- public static final int INVDTM = 236;
- public static final int INVELP = 237;
- public static final int LLRNG = 238;
- public static final int RNGORD = 239;
- public static final int INVQUAD = 240;
- public static final int GEOMM = 241;
- public static final int CRTMM = 242;
- public static final int PLLED = 243;
- public static final int PLRLAT = 244;
- public static final int USEPLR = 245;
- public static final int UTMZON = 246;
- public static final int HMISPHR = 247;
- public static final int USESW = 248;
- public static final int MAX15 = 249;
- public static final int OBLQPOLE = 250;
- public static final int AFFZERO = 251;
- public static final int NRDATUM = 252;
- public static final int OSTN97 = 253;
- public static final int DENRGN = 253;
- public static final int ELEVEL = 254;
- public static final int OSTN02 = 255;
- public static final int TMKRG0 = 256;
- public static final int Ok = 1000;
- public static final int OutOfMemory = 1001;
- public static final int InitializationFailed = 1002;
- public static final int ConversionFailed = 1003;
- public static final int NullArgument = 1004;
- public static final int InvalidArgument = 1005;
- public org.osgeo.mapguide.MgCoordinateSystemErrorCode();
-Compiled from "MgCoordinateSystemFactory.java"
-public class org.osgeo.mapguide.MgCoordinateSystemFactory extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgCoordinateSystemFactory();
- public org.osgeo.mapguide.MgCoordinateSystem create(java.lang.String);
- public org.osgeo.mapguide.MgCoordinateSystemTransform getTransform(org.osgeo.mapguide.MgCoordinateSystem, org.osgeo.mapguide.MgCoordinateSystem);
- public org.osgeo.mapguide.MgCoordinateSystem createFromCode(java.lang.String);
- public java.lang.String convertWktToCoordinateSystemCode(java.lang.String);
- public java.lang.String convertCoordinateSystemCodeToWkt(java.lang.String);
- public org.osgeo.mapguide.MgStringCollection enumerateCategories();
- public org.osgeo.mapguide.MgBatchPropertyCollection enumerateCoordinateSystems(java.lang.String);
- public java.lang.String convertEpsgCodeToWkt(int);
- public int convertWktToEpsgCode(java.lang.String);
- public java.lang.String getBaseLibrary();
- public boolean isValid(java.lang.String);
- public org.osgeo.mapguide.MgCoordinateSystemGridBoundary gridBoundary(org.osgeo.mapguide.MgCoordinate, org.osgeo.mapguide.MgCoordinate);
- public org.osgeo.mapguide.MgCoordinateSystemGridBoundary gridBoundary(org.osgeo.mapguide.MgPolygon);
- public org.osgeo.mapguide.MgCoordinateSystemGridSpecification gridSpecification();
- public org.osgeo.mapguide.MgCoordinateSystemGridSpecification gridSpecification(double, double, int, double);
- public org.osgeo.mapguide.MgCoordinateSystemGridSpecification gridSpecification(int, int);
- public org.osgeo.mapguide.MgCoordinateSystemGridBase genericGrid(java.lang.String, java.lang.String, boolean);
- public org.osgeo.mapguide.MgCoordinateSystemGridBase genericGrid(org.osgeo.mapguide.MgCoordinateSystem, org.osgeo.mapguide.MgCoordinateSystem, boolean);
- public org.osgeo.mapguide.MgCoordinateSystemMgrs getMgrs(double, double, short, boolean);
- public org.osgeo.mapguide.MgCoordinateSystemMgrs getMgrsEllipsoid(java.lang.String, short, boolean);
- public org.osgeo.mapguide.MgCoordinateSystemMgrs getMgrsDatum(java.lang.String, short, boolean);
- public org.osgeo.mapguide.MgCoordinateSystemGridBase mgrsGrid(org.osgeo.mapguide.MgCoordinateSystem, boolean, short, boolean);
- public org.osgeo.mapguide.MgCoordinateSystemGridBase mgrsGrid(java.lang.String, boolean, short, boolean);
-Compiled from "MgCoordinateSystemFilter.java"
-public class org.osgeo.mapguide.MgCoordinateSystemFilter extends org.osgeo.mapguide.MgGuardDisposable {
- public boolean isFilteredOut(org.osgeo.mapguide.MgGuardDisposable);
-Compiled from "MgCoordinateSystemFilterInteger32.java"
-public class org.osgeo.mapguide.MgCoordinateSystemFilterInteger32 extends org.osgeo.mapguide.MgGuardDisposable {
- public boolean isFilteredOut(int);
-Compiled from "MgCoordinateSystemFormatConverter.java"
-public class org.osgeo.mapguide.MgCoordinateSystemFormatConverter extends org.osgeo.mapguide.MgGuardDisposable {
- public java.lang.String definitionToWkt(org.osgeo.mapguide.MgCoordinateSystem, int);
- public org.osgeo.mapguide.MgCoordinateSystem wktToDefinition(int, java.lang.String);
- public java.lang.String codeToWkt(int, java.lang.String, int);
- public java.lang.String wktToCode(int, java.lang.String, int);
- public java.lang.String definitionToCode(org.osgeo.mapguide.MgCoordinateSystem, int);
- public org.osgeo.mapguide.MgCoordinateSystem codeToDefinition(int, java.lang.String);
- public java.lang.String codeToCode(int, java.lang.String, int);
- public boolean isCodeInDictionary(int, java.lang.String);
-Compiled from "MgCoordinateSystemGeodeticAnalyticalTransformationMethod.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGeodeticAnalyticalTransformationMethod {
- public static final int None = 0;
- public static final int ThreeParameter = 8193;
- public static final int Molodensky = 8194;
- public static final int AbridgedMolodensky = 8195;
- public static final int Geocentric = 8196;
- public static final int FourParameter = 8197;
- public static final int SixParameter = 8198;
- public static final int Bursa = 8199;
- public static final int Frame = 8200;
- public static final int SevenParameter = 8201;
- public static final int MolodenskyBadekas = 8202;
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticAnalyticalTransformationMethod();
-Compiled from "MgCoordinateSystemGeodeticAnalyticalTransformDefParams.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGeodeticAnalyticalTransformDefParams extends org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformDefParams {
- public synchronized void delete();
- public double getDeltaX();
- public void setDeltaX(double);
- public double getDeltaY();
- public void setDeltaY(double);
- public double getDeltaZ();
- public void setDeltaZ(double);
- public double getRotateX();
- public void setRotateX(double);
- public double getRotateY();
- public void setRotateY(double);
- public double getRotateZ();
- public void setRotateZ(double);
- public double getScale();
- public void setScale(double);
- public double getTranslateX();
- public void setTranslateX(double);
- public double getTranslateY();
- public void setTranslateY(double);
- public double getTranslateZ();
- public void setTranslateZ(double);
- public int getTransformationMethod();
- public void setTransformationMethod(int);
-Compiled from "MgCoordinateSystemGeodeticInterpolationTransformDefParams.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGeodeticInterpolationTransformDefParams extends org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformDefParams {
- public void setGridFiles(org.osgeo.mapguide.MgDisposableCollection);
- public org.osgeo.mapguide.MgDisposableCollection getGridFiles();
- public java.lang.String getFallback();
- public void setFallback(java.lang.String);
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformGridFile newGridFile();
-Compiled from "MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod {
- public static final int MultipleRegression = 20481;
- public static final int GeneralPolynomialEpsg = 20482;
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod();
-Compiled from "MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams extends org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformDefParams {
- public double getValidation();
- public void setValidation(double);
- public double getTestPhi();
- public void setTestPhi(double);
- public double getTestLambda();
- public void setTestLambda(double);
- public double getDeltaPhi();
- public void setDeltaPhi(double);
- public double getDeltaLambda();
- public void setDeltaLambda(double);
- public double getDeltaHeight();
- public void setDeltaHeight(double);
- public double getPhiOffset();
- public void setPhiOffset(double);
- public double getLambdaOffset();
- public void setLambdaOffset(double);
- public double getNormalizationScale();
- public void setNormalizationScale(double);
- public double getCoefficientPhi(int);
- public void setCoefficientPhi(int, double);
- public double getCoefficientLambda(int);
- public void setCoefficientLambda(int, double);
- public double getCoefficientHeight(int);
- public void setCoefficientHeight(int, double);
-Compiled from "MgCoordinateSystemGeodeticPath.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGeodeticPath extends org.osgeo.mapguide.MgGuardDisposable {
- public java.lang.String getPathName();
- public void setPathName(java.lang.String);
- public java.lang.String getTargetDatum();
- public void setTargetDatum(java.lang.String);
- public java.lang.String getSourceDatum();
- public void setSourceDatum(java.lang.String);
- public double getAccuracy();
- public void setAccuracy(double);
- public boolean getIsReversible();
- public void setIsReversible(boolean);
- public void setEpsgCode(int);
- public int getEpsgVariant();
- public void setEpsgVariant(int);
- public org.osgeo.mapguide.MgDisposableCollection getPathElements();
- public void setPathElements(org.osgeo.mapguide.MgDisposableCollection);
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticPathElement newPathElement();
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticPath createClone();
-Compiled from "MgCoordinateSystemGeodeticPathDictionary.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGeodeticPathDictionary extends org.osgeo.mapguide.MgCoordinateSystemDictionaryBase {
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticPath newGeodeticPath();
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticPath getGeodeticPath(java.lang.String);
-Compiled from "MgCoordinateSystemGeodeticPathElement.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGeodeticPathElement extends org.osgeo.mapguide.MgGuardDisposable {
- public java.lang.String getTransformName();
- public void setTransformName(java.lang.String);
- public boolean getIsInversed();
- public void setIsInversed(boolean);
-Compiled from "MgCoordinateSystemGeodeticStandaloneTransformDefParams.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGeodeticStandaloneTransformDefParams extends org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformDefParams {
-Compiled from "MgCoordinateSystemGeodeticTransformation.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformation extends org.osgeo.mapguide.MgGuardDisposable {
- public void setSourceAndTarget(org.osgeo.mapguide.MgCoordinateSystemDatum, org.osgeo.mapguide.MgCoordinateSystemDatum);
- public org.osgeo.mapguide.MgCoordinateSystemDatum getSource();
- public org.osgeo.mapguide.MgCoordinateSystemDatum getTarget();
- public void shift(org.osgeo.mapguide.MgCoordinate);
- public org.osgeo.mapguide.MgCoordinate shift(double, double);
- public org.osgeo.mapguide.MgCoordinate shift(double, double, double);
- public double getOffsetZ();
- public void setOffset(double, double, double);
- public double getBursaWolfeTransformRotationX();
- public double getBursaWolfeTransformRotationY();
- public double getBursaWolfeTransformRotationZ();
- public double getBursaWolfeTransformBwScale();
- public void setBursaWolfeTransform(double, double, double, double);
- public int getGeodeticTransformationMethod();
- public void setGeodeticTransformationMethod(int);
- public double getMaxOffset();
- public boolean isLegalOffset(double);
- public double getMaxRotation();
- public boolean isLegalRotation(double);
- public double getBwScaleMin();
- public double getBwScaleMax();
- public boolean isLegalBwScale(double);
-Compiled from "MgCoordinateSystemGeodeticTransformationMethod.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformationMethod {
- public static final int Molodensky = 1;
- public static final int MReg = 2;
- public static final int Bursa = 3;
- public static final int NAD27 = 4;
- public static final int NAD83 = 5;
- public static final int WGS84 = 6;
- public static final int WGS72 = 7;
- public static final int HPGN = 8;
- public static final int SevenParameter = 9;
- public static final int AGD66 = 10;
- public static final int ThreeParameter = 11;
- public static final int SixParameter = 12;
- public static final int FourParameter = 13;
- public static final int AGD84 = 14;
- public static final int NZGD49 = 15;
- public static final int ATS77 = 16;
- public static final int GDA94 = 17;
- public static final int NZGD2K = 18;
- public static final int CSRS = 19;
- public static final int TOKYO = 20;
- public static final int RGF93 = 21;
- public static final int ED50 = 22;
- public static final int DHDN = 23;
- public static final int ETRF89 = 24;
- public static final int Lclgrf = 99;
- public static final int Geocentric = 25;
- public static final int CHENYX = 26;
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformationMethod();
-Compiled from "MgCoordinateSystemGeodeticTransformDef.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformDef extends org.osgeo.mapguide.MgGuardDisposable {
- public java.lang.String getDescription();
- public void setDescription(java.lang.String);
- public int getEpsgVariation();
- public void setEpsgVariation(int);
- public boolean getInverseSupported();
- public void setInverseSupported(boolean);
- public int getMaxIterations();
- public void setMaxIterations(int);
- public double getConvergenceValue();
- public void setConvergenceValue(double);
- public double getErrorValue();
- public void setErrorValue(double);
- public double getRangeMinLongitude();
- public void setRangeMinLongitude(double);
- public double getRangeMaxLongitude();
- public void setRangeMaxLongitude(double);
- public double getRangeMinLatitude();
- public void setRangeMinLatitude(double);
- public double getRangeMaxLatitude();
- public void setRangeMaxLatitude(double);
- public int getTransformDefType();
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformDefParams getParameters();
- public void setParameters(org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformDefParams);
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformDef createClone();
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformation createTransformation(boolean);
-Compiled from "MgCoordinateSystemGeodeticTransformDefDictionary.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformDefDictionary extends org.osgeo.mapguide.MgCoordinateSystemDictionaryBase {
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformDef newGeodeticTransformationDef(int);
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformDef getGeodeticTransformationDef(java.lang.String);
-Compiled from "MgCoordinateSystemGeodeticTransformDefParams.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformDefParams extends org.osgeo.mapguide.MgGuardDisposable {
-Compiled from "MgCoordinateSystemGeodeticTransformDefType.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformDefType {
- public static final int Standalone = 1;
- public static final int Analytical = 2;
- public static final int Interpolation = 3;
- public static final int MultipleRegression = 4;
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformDefType();
-Compiled from "MgCoordinateSystemGeodeticTransformGridFile.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformGridFile extends org.osgeo.mapguide.MgGuardDisposable {
- public int getFileFormat();
- public void setFileFormat(int);
- public boolean getIsInverseDirection();
- public void setIsInverseDirection(boolean);
-Compiled from "MgCoordinateSystemGeodeticTransformGridFileFormat.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformGridFileFormat {
- public static final int NTv1 = 1;
- public static final int NTv2 = 2;
- public static final int NADCON = 3;
- public static final int RGF = 4;
- public static final int PAR = 5;
- public static final int ATS77 = 6;
- public static final int OST97 = 7;
- public static final int OST02 = 8;
- public static final int OST15 = 9;
- public static final int GEOCON = 10;
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformGridFileFormat();
-Compiled from "MgCoordinateSystemGridBase.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGridBase extends org.osgeo.mapguide.MgGuardDisposable {
- public int getSpecializationType();
- public void setBoundary(org.osgeo.mapguide.MgCoordinateSystemGridBoundary);
- public org.osgeo.mapguide.MgCoordinateSystemGridBoundary getBoundary();
- public org.osgeo.mapguide.MgCoordinateSystemGridLineCollection getGridLines(org.osgeo.mapguide.MgCoordinateSystemGridSpecification);
- public org.osgeo.mapguide.MgCoordinateSystemGridRegionCollection getGridRegions(org.osgeo.mapguide.MgCoordinateSystemGridSpecification);
- public org.osgeo.mapguide.MgCoordinateSystemGridTickCollection getGridTicks(org.osgeo.mapguide.MgCoordinateSystemGridSpecification);
- public double getConvergenceAngle(org.osgeo.mapguide.MgCoordinate);
- public double getProjectiveGridScale(org.osgeo.mapguide.MgCoordinate);
- public int approxGridLineMemoryUsage(org.osgeo.mapguide.MgCoordinateSystemGridSpecification);
- public int approxGridRegionMemoryUsage(org.osgeo.mapguide.MgCoordinateSystemGridSpecification);
- public int approxGridTickMemoryUsage(org.osgeo.mapguide.MgCoordinateSystemGridSpecification);
- public int setGridLineExceptionLevel(int);
- public int setGridRegionExceptionLevel(int);
- public int setGridTickExceptionLevel(int);
- public int getLastError();
- public void resetLastError();
- public boolean areExceptionsOn();
- public void setExceptionsOn(boolean);
-Compiled from "MgCoordinateSystemGridBoundary.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGridBoundary extends org.osgeo.mapguide.MgGuardDisposable {
- public void setBoundaryExtents(org.osgeo.mapguide.MgCoordinate, org.osgeo.mapguide.MgCoordinate);
- public void setBoundaryExtents(org.osgeo.mapguide.MgPolygon);
- public org.osgeo.mapguide.MgPolygon getBoundary();
-Compiled from "MgCoordinateSystemGridLine.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGridLine extends org.osgeo.mapguide.MgGuardDisposable {
- public int getGridOrientation();
- public double getRealValue();
- public int getCount();
- public org.osgeo.mapguide.MgLineString getSegment(int);
- public org.osgeo.mapguide.MgLineStringCollection getSegmentCollection();
- public void setSegmentCollection(org.osgeo.mapguide.MgLineStringCollection);
-Compiled from "MgCoordinateSystemGridLineCollection.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGridLineCollection extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgCoordinateSystemGridLine getItem(int);
- public int indexOf(int, double);
- public void removeAt(int);
- public void clear();
-Compiled from "MgCoordinateSystemGridOrientation.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGridOrientation {
- public static final short None = 0;
- public static final short EastWest = 1;
- public static final short NorthSouth = 2;
- public static final short Unknown = 3;
- public org.osgeo.mapguide.MgCoordinateSystemGridOrientation();
-Compiled from "MgCoordinateSystemGridRegion.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGridRegion extends org.osgeo.mapguide.MgGuardDisposable {
- public java.lang.String getLabel();
- public org.osgeo.mapguide.MgCoordinate getRegionCenter();
- public org.osgeo.mapguide.MgPolygon getRegionBoundary();
- public org.osgeo.mapguide.MgLineStringCollection getSouthLine();
- public org.osgeo.mapguide.MgLineStringCollection getEastLine();
- public org.osgeo.mapguide.MgLineStringCollection getNorthLine();
- public org.osgeo.mapguide.MgLineStringCollection getWestLine();
-Compiled from "MgCoordinateSystemGridRegionCollection.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGridRegionCollection extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgCoordinateSystemGridRegion getItem(int);
-Compiled from "MgCoordinateSystemGridSpecializationType.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGridSpecializationType {
- public static final int Generic = 1;
- public static final int MGRS = 17;
- public static final int USNG = 18;
- public static final int Unknown = 65366;
- public org.osgeo.mapguide.MgCoordinateSystemGridSpecializationType();
-Compiled from "MgCoordinateSystemGridSpecification.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGridSpecification extends org.osgeo.mapguide.MgGuardDisposable {
- public double getEastingBase();
- public double getNorthingBase();
- public double getEastingIncrement();
- public double getNorthingIncrement();
- public double getTickEastingIncrement();
- public double getTickNorthingIncrement();
- public int getUnitType();
- public boolean isSameAs(org.osgeo.mapguide.MgCoordinateSystemGridSpecification);
- public double getCurvePrecision();
- public void setGridBase(double, double);
- public void setGridIncrement(double, double);
- public void setTickIncrements(double, double);
- public void setUnits(int, int);
- public void setCurvePrecision(double);
- public void setMaxCurvePoints(int);
- public boolean isConsistent();
-Compiled from "MgCoordinateSystemGridTick.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGridTick extends org.osgeo.mapguide.MgGuardDisposable {
- public boolean getIsOnGridLine();
- public int getTickOrientation();
- public double getValue();
- public org.osgeo.mapguide.MgCoordinate getPosition();
- public org.osgeo.mapguide.MgCoordinate getDirectionVector();
-Compiled from "MgCoordinateSystemGridTickCollection.java"
-public class org.osgeo.mapguide.MgCoordinateSystemGridTickCollection extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgCoordinateSystemGridTick getItem(int);
-Compiled from "MgCoordinateSystemMathComparator.java"
-public class org.osgeo.mapguide.MgCoordinateSystemMathComparator extends org.osgeo.mapguide.MgGuardDisposable {
- public boolean same(org.osgeo.mapguide.MgGuardDisposable, org.osgeo.mapguide.MgGuardDisposable);
- public boolean sameEllipsoid(org.osgeo.mapguide.MgCoordinateSystemEllipsoid, org.osgeo.mapguide.MgCoordinateSystemEllipsoid);
- public boolean sameDatum(org.osgeo.mapguide.MgCoordinateSystemDatum, org.osgeo.mapguide.MgCoordinateSystemDatum);
- public boolean sameCoordinateSystem(org.osgeo.mapguide.MgCoordinateSystem, org.osgeo.mapguide.MgCoordinateSystem);
- public void setCompareInternalDatumOldParameters(boolean);
- public boolean getCompareInternalDatumOldParameters();
-Compiled from "MgCoordinateSystemMeasure.java"
-public class org.osgeo.mapguide.MgCoordinateSystemMeasure extends org.osgeo.mapguide.MgMeasure {
- public double getDistance(org.osgeo.mapguide.MgCoordinate, org.osgeo.mapguide.MgCoordinate);
- public double getDistance(double, double, double, double);
- public org.osgeo.mapguide.MgEnvelope getEnvelope();
-Compiled from "MgCoordinateSystemMgrs.java"
-public class org.osgeo.mapguide.MgCoordinateSystemMgrs extends org.osgeo.mapguide.MgCoordinateSystemGridBase {
- public java.lang.String convertFromLonLat(double, double, int);
- public java.lang.String convertFromLonLat(org.osgeo.mapguide.MgCoordinate, int);
- public org.osgeo.mapguide.MgCoordinate convertToLonLat(java.lang.String);
- public org.osgeo.mapguide.MgCoordinate convertToLonLat(java.lang.String, int);
- public short getLetteringScheme();
-Compiled from "MgCoordinateSystemMgrsGridLevel.java"
-public class org.osgeo.mapguide.MgCoordinateSystemMgrsGridLevel {
- public static final int MgrsNone = 0;
- public static final int MgrsUtm = 1;
- public static final int MgrsUps = 2;
- public static final int Mgrs100Km = 3;
- public static final int Mgrs10Km = 4;
- public static final int Mgrs1Km = 5;
- public static final int Mgrs100m = 6;
- public static final int Mgrs10m = 7;
- public static final int Mgrs1m = 8;
- public static final int MgrsUnknown = 99;
- public org.osgeo.mapguide.MgCoordinateSystemMgrsGridLevel();
-Compiled from "MgCoordinateSystemMgrsGridSquarePosition.java"
-public class org.osgeo.mapguide.MgCoordinateSystemMgrsGridSquarePosition {
- public static final int Center = 1;
- public static final int SouthWest = 2;
- public static final int West = 3;
- public static final int NorthWest = 4;
- public static final int North = 5;
- public static final int NorthEast = 6;
- public static final int East = 7;
- public static final int SouthEast = 8;
- public static final int South = 9;
- public static final int Unknown = 10;
- public org.osgeo.mapguide.MgCoordinateSystemMgrsGridSquarePosition();
-Compiled from "MgCoordinateSystemMgrsLetteringScheme.java"
-public class org.osgeo.mapguide.MgCoordinateSystemMgrsLetteringScheme {
- public static final short Normal = 0;
- public static final short Alternative = 1;
- public org.osgeo.mapguide.MgCoordinateSystemMgrsLetteringScheme();
-Compiled from "MgCoordinateSystemProjectionCode.java"
-public class org.osgeo.mapguide.MgCoordinateSystemProjectionCode {
- public static final int Alber = 4;
- public static final int Azede = 59;
- public static final int Azmea = 11;
- public static final int Azmed = 7;
- public static final int Bipolar = 31;
- public static final int Bonne = 24;
- public static final int Cassini = 22;
- public static final int Eckert4 = 25;
- public static final int Eckert6 = 26;
- public static final int Edcnc = 12;
- public static final int Edcyl = 20;
- public static final int GaussK = 46;
- public static final int Gnomonic = 19;
- public static final int Goode = 28;
- public static final int Hom1uv = 1281;
- public static final int Hom1xy = 1282;
- public static final int Hom2uv = 1283;
- public static final int Hom2xy = 1284;
- public static final int Krovak = 47;
- public static final int Krvk95 = 51;
- public static final int LL = 1;
- public static final int Lm1sp = 36;
- public static final int Lm2sp = 37;
- public static final int Lmblg = 38;
- public static final int Lmtan = 8;
- public static final int Miller = 13;
- public static final int Mndotl = 41;
- public static final int Mndott = 42;
- public static final int Modpc = 10;
- public static final int Mollweid = 27;
- public static final int Mrcat = 6;
- public static final int MrcatK = 49;
- public static final int Mstero = 15;
- public static final int Neacyl = 29;
- public static final int Nerth = 55;
- public static final int Nzealand = 16;
- public static final int OblqM = 5;
- public static final int Obqcyl = 56;
- public static final int Ortho = 18;
- public static final int Ostn02 = 60;
- public static final int Ostn97 = 58;
- public static final int Ostro = 34;
- public static final int Plycn = 9;
- public static final int Pstro = 33;
- public static final int Pstrosl = 53;
- public static final int Rskew = 1285;
- public static final int Rskewc = 1286;
- public static final int Rskewo = 1287;
- public static final int Robinson = 23;
- public static final int Sinus = 17;
- public static final int Sotrm = 43;
- public static final int Sstro = 35;
- public static final int Swiss = 32;
- public static final int Sys34 = 57;
- public static final int Sys34_99 = 61;
- public static final int Teacyl = 30;
- public static final int Tm = 3;
- public static final int Trmeraf = 54;
- public static final int Trmrkrg = 62;
- public static final int Trmrs = 45;
- public static final int Vdgrntn = 21;
- public static final int Wccsl = 39;
- public static final int Wccst = 40;
- public static final int Utm = 44;
- public static final int Winkl = 63;
- public static final int Nrthsrt = 64;
- public static final int Lmbrtaf = 65;
- public static final int Sys34_01 = 66;
- public static final int EdcylE = 67;
- public static final int PlateCarree = 68;
- public static final int PvMercator = 69;
- public static final int LmMich = 70;
- public static final int Unknown = 0;
- public org.osgeo.mapguide.MgCoordinateSystemProjectionCode();
-Compiled from "MgCoordinateSystemProjectionFormatType.java"
-public class org.osgeo.mapguide.MgCoordinateSystemProjectionFormatType {
- public static final int Lng = 57509;
- public static final int Lat = 41157;
- public static final int Angd = 32933;
- public static final int Coef = 13;
- public static final int Xxx = 4099;
- public static final int Yyy = 4099;
- public static final int Scl = 7;
- public static final int Rot = 4;
- public org.osgeo.mapguide.MgCoordinateSystemProjectionFormatType();
-Compiled from "MgCoordinateSystemProjectionInformation.java"
-public class org.osgeo.mapguide.MgCoordinateSystemProjectionInformation extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgCoordinateSystemEnumInteger32 getEnumProjections();
- public int getParameterCount(int);
- public boolean isUsingParameter(int, int);
- public boolean isUsingOriginLongitude(int);
- public boolean isUsingOriginLatitude(int);
- public boolean isUsingScaleReduction(int);
- public boolean isUsingQuadrant(int);
- public boolean isUsingOffset(int);
- public double getParameterMin(int, int);
- public double getParameterMax(int, int);
- public double getParameterDefault(int, int);
- public int getParameterLogicalType(int, int);
- public int getParameterFormatType(int, int);
- public int getParameterType(int, int);
- public int getUnitType(int);
- public java.lang.String getTagString(int);
-Compiled from "MgCoordinateSystemProjectionLogicalType.java"
-public class org.osgeo.mapguide.MgCoordinateSystemProjectionLogicalType {
- public static final int Longitude = 1;
- public static final int Latitude = 2;
- public static final int Azimuth = 3;
- public static final int AngularDistance = 4;
- public static final int ComplexCoefficient = 5;
- public static final int UTMZoneNumber = 6;
- public static final int HemisphereSelection = 7;
- public static final int GeoidHeight = 8;
- public static final int Elevation = 9;
- public static final int AffineCoefficient = 10;
- public static final int XYCoordinate = 11;
- public static final int Scale = 12;
- public org.osgeo.mapguide.MgCoordinateSystemProjectionLogicalType();
-Compiled from "MgCoordinateSystemProjectionParameterType.java"
-public class org.osgeo.mapguide.MgCoordinateSystemProjectionParameterType {
- public static final int NotUsed = 0;
- public static final int Cntmer = 1;
- public static final int Nstdpll = 2;
- public static final int Sstdpll = 3;
- public static final int Stdpll = 4;
- public static final int Gcp1lng = 5;
- public static final int Gcp1lat = 6;
- public static final int Gcp2lng = 7;
- public static final int Gcp2lat = 8;
- public static final int Gcplng = 9;
- public static final int Gcplat = 10;
- public static final int Gcazm = 11;
- public static final int Yaxisaz = 12;
- public static final int Estdmer = 13;
- public static final int Nparall = 14;
- public static final int Sparall = 15;
- public static final int P1lng = 16;
- public static final int P1lat = 17;
- public static final int P2lng = 18;
- public static final int P2lat = 19;
- public static final int Adp1p2 = 20;
- public static final int Adsp1 = 21;
- public static final int Adsp2 = 22;
- public static final int Cmplxan = 23;
- public static final int Cmplxbn = 24;
- public static final int Westll = 25;
- public static final int Eastll = 26;
- public static final int Utmzn = 27;
- public static final int Hsns = 28;
- public static final int Ghgt = 29;
- public static final int Aelev = 30;
- public static final int Polelng = 31;
- public static final int Polelat = 32;
- public static final int Ostdpll = 33;
- public static final int Stdcir = 34;
- public static final int Afa0 = 35;
- public static final int Afb0 = 36;
- public static final int Afa1 = 37;
- public static final int Afa2 = 38;
- public static final int Afb1 = 39;
- public static final int Afb2 = 40;
- public static final int Nrmlpll = 41;
- public static final int Denrgn = 42;
- public static final int Skwazm = 43;
- public static final int Sclrotorgx = 44;
- public static final int Sclrotorgy = 45;
- public static final int Nrthscl = 46;
- public static final int Nrthrot = 47;
- public static final int EllipsoidScale = 48;
- public org.osgeo.mapguide.MgCoordinateSystemProjectionParameterType();
-Compiled from "MgCoordinateSystemTransform.java"
-public class org.osgeo.mapguide.MgCoordinateSystemTransform extends org.osgeo.mapguide.MgTransform {
- public static final int TransformOk;
- public static final int TransformOutsideDomainWarning;
- public static final int TransformDatumShiftWarning;
- public static final int TransformTotalFailure;
- public static final int SourceCrsError;
- public static final int DatumShiftFallback;
- public static final int DatumShiftError;
- public static final int TargetCrsError;
- public org.osgeo.mapguide.MgCoordinate transform(double, double);
- public org.osgeo.mapguide.MgCoordinate transformM(double, double, double);
- public org.osgeo.mapguide.MgCoordinate transform(double, double, double);
- public org.osgeo.mapguide.MgCoordinate transformM(double, double, double, double);
- public org.osgeo.mapguide.MgCoordinate transform(org.osgeo.mapguide.MgCoordinate);
- public org.osgeo.mapguide.MgEnvelope transform(org.osgeo.mapguide.MgEnvelope);
- public void transformCoordinate(org.osgeo.mapguide.MgCoordinate);
- public org.osgeo.mapguide.MgLineString gridLine(org.osgeo.mapguide.MgCoordinate, org.osgeo.mapguide.MgCoordinate, double, int);
- public boolean isValidSourcePoint(double, double);
- public boolean isValidSourcePoint(double, double, double);
- public boolean isValidTargetPoint(double, double);
- public boolean isValidTargetPoint(double, double, double);
- public org.osgeo.mapguide.MgCoordinateSystem getSource();
- public org.osgeo.mapguide.MgCoordinateSystem getTarget();
- public void setSourceAndTarget(org.osgeo.mapguide.MgCoordinateSystem, org.osgeo.mapguide.MgCoordinateSystem);
- public int getGeodeticTransformationCount();
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticTransformDef getGeodeticTransformation(int);
- public int getGeodeticTransformationDirection(int);
- public org.osgeo.mapguide.MgCoordinateSystemGeodeticPath getExplicitGeodeticPath();
- public void ignoreDatumShiftWarning(boolean);
- public boolean isIgnoreDatumShiftWarning();
- public void ignoreOutsideDomainWarning(boolean);
- public boolean isIgnoreOutsideDomainWarning();
- public int getSourceWarningCount();
- public int getdatumWarningCount();
- public int getTargetWarningCount();
- public int getLastTransformStatus();
- public void resetLastTransformStatus();
-Compiled from "MgCoordinateSystemType.java"
-public class org.osgeo.mapguide.MgCoordinateSystemType {
- public static final int Arbitrary = 1;
- public static final int Geographic = 2;
- public static final int Projected = 3;
- public org.osgeo.mapguide.MgCoordinateSystemType();
-Compiled from "MgCoordinateSystemUnitCode.java"
-public class org.osgeo.mapguide.MgCoordinateSystemUnitCode {
- public static final int Meter = 1;
- public static final int Foot = 2;
- public static final int Inch = 3;
- public static final int IFoot = 4;
- public static final int ClarkeFoot = 5;
- public static final int IInch = 6;
- public static final int Centimeter = 7;
- public static final int Kilometer = 8;
- public static final int Yard = 9;
- public static final int SearsYard = 10;
- public static final int Mile = 11;
- public static final int IYard = 12;
- public static final int IMile = 13;
- public static final int Knot = 14;
- public static final int NautM = 15;
- public static final int Lat66 = 16;
- public static final int Lat83 = 17;
- public static final int Decimeter = 18;
- public static final int Millimeter = 19;
- public static final int Dekameter = 20;
- public static final int Hectometer = 21;
- public static final int GermanMeter = 22;
- public static final int CaGrid = 23;
- public static final int ClarkeChain = 24;
- public static final int GunterChain = 25;
- public static final int BenoitChain = 26;
- public static final int SearsChain = 27;
- public static final int ClarkeLink = 28;
- public static final int GunterLink = 29;
- public static final int BenoitLink = 30;
- public static final int SearsLink = 31;
- public static final int Rod = 32;
- public static final int Perch = 33;
- public static final int Pole = 34;
- public static final int Furlong = 35;
- public static final int Rood = 36;
- public static final int CapeFoot = 37;
- public static final int Brealey = 38;
- public static final int SearsFoot = 39;
- public static final int GoldCoastFoot = 40;
- public static final int MicroInch = 41;
- public static final int IndianYard = 42;
- public static final int IndianFoot = 43;
- public static final int IndianFt37 = 44;
- public static final int IndianFt62 = 45;
- public static final int IndianFt75 = 46;
- public static final int IndianYd37 = 47;
- public static final int Decameter = 48;
- public static final int InternationalChain = 49;
- public static final int InternationalLink = 50;
- public static final int BrFootTrunc = 51;
- public static final int BrChainTrunc = 52;
- public static final int BrLinkTrunc = 53;
- public static final int Degree = 1001;
- public static final int Grad = 1002;
- public static final int Grade = 1003;
- public static final int MapInfo = 1004;
- public static final int Mil = 1005;
- public static final int Minute = 1006;
- public static final int Radian = 1007;
- public static final int Second = 1008;
- public static final int Decisec = 1009;
- public static final int Centisec = 1010;
- public static final int Millisec = 1011;
- public org.osgeo.mapguide.MgCoordinateSystemUnitCode();
-Compiled from "MgCoordinateSystemUnitInformation.java"
-public class org.osgeo.mapguide.MgCoordinateSystemUnitInformation extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgCoordinateSystemEnumInteger32 getEnumLinearUnits();
- public org.osgeo.mapguide.MgCoordinateSystemEnumInteger32 getEnumAngularUnits();
- public double getLinearUnitScale(int);
- public double getAngularUnitScale(int);
- public java.lang.String getAbbreviation(int);
-Compiled from "MgCoordinateSystemUnitType.java"
-public class org.osgeo.mapguide.MgCoordinateSystemUnitType {
- public static final int Linear = 1;
- public static final int Angular = 2;
- public org.osgeo.mapguide.MgCoordinateSystemUnitType();
-Compiled from "MgCoordinateSystemWktFlavor.java"
-public class org.osgeo.mapguide.MgCoordinateSystemWktFlavor {
- public static final int Unknown = -1;
- public static final int Ogc = 0;
- public static final int Oracle = 1;
- public static final int Esri = 2;
- public static final int Epsg = 3;
- public static final int Geotiff = 4;
- public static final int Geotools = 5;
- public org.osgeo.mapguide.MgCoordinateSystemWktFlavor();
-Compiled from "MgCoordinateXY.java"
-public class org.osgeo.mapguide.MgCoordinateXY extends org.osgeo.mapguide.MgCoordinate {
- public int getDimension();
-Compiled from "MgCoordinateXYM.java"
-public class org.osgeo.mapguide.MgCoordinateXYM extends org.osgeo.mapguide.MgCoordinate {
-Compiled from "MgCoordinateXYZ.java"
-public class org.osgeo.mapguide.MgCoordinateXYZ extends org.osgeo.mapguide.MgCoordinate {
-Compiled from "MgCoordinateXYZM.java"
-public class org.osgeo.mapguide.MgCoordinateXYZM extends org.osgeo.mapguide.MgCoordinate {
-Compiled from "MgCurve.java"
-public class org.osgeo.mapguide.MgCurve extends org.osgeo.mapguide.MgGeometry {
- public org.osgeo.mapguide.MgCoordinate getStartCoordinate();
- public org.osgeo.mapguide.MgCoordinate getEndCoordinate();
-Compiled from "MgCurvePolygon.java"
-public class org.osgeo.mapguide.MgCurvePolygon extends org.osgeo.mapguide.MgRegion {
- public org.osgeo.mapguide.MgCurveRing getExteriorRing();
- public int getInteriorRingCount();
- public org.osgeo.mapguide.MgCurveRing getInteriorRing(int);
- public int getGeometryType();
- public boolean isEmpty();
- public boolean isClosed();
- public org.osgeo.mapguide.MgGeometricEntity copy();
- public org.osgeo.mapguide.MgGeometricEntity transform(org.osgeo.mapguide.MgTransform);
-Compiled from "MgCurvePolygonCollection.java"
-public class org.osgeo.mapguide.MgCurvePolygonCollection extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgCurvePolygon getItem(int);
- public void setItem(int, org.osgeo.mapguide.MgCurvePolygon);
- public void add(org.osgeo.mapguide.MgCurvePolygon);
- public void insert(int, org.osgeo.mapguide.MgCurvePolygon);
- public boolean remove(org.osgeo.mapguide.MgCurvePolygon);
- public boolean contains(org.osgeo.mapguide.MgCurvePolygon);
- public int indexOf(org.osgeo.mapguide.MgCurvePolygon);
- public org.osgeo.mapguide.MgCurvePolygonCollection();
-Compiled from "MgCurveRing.java"
-public class org.osgeo.mapguide.MgCurveRing extends org.osgeo.mapguide.MgRing {
- public int getComponentType();
- public org.osgeo.mapguide.MgCurveSegment getSegment(int);
-Compiled from "MgCurveRingCollection.java"
-public class org.osgeo.mapguide.MgCurveRingCollection extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgCurveRing getItem(int);
- public void setItem(int, org.osgeo.mapguide.MgCurveRing);
- public void add(org.osgeo.mapguide.MgCurveRing);
- public void insert(int, org.osgeo.mapguide.MgCurveRing);
- public boolean remove(org.osgeo.mapguide.MgCurveRing);
- public boolean contains(org.osgeo.mapguide.MgCurveRing);
- public int indexOf(org.osgeo.mapguide.MgCurveRing);
- public org.osgeo.mapguide.MgCurveRingCollection();
-Compiled from "MgCurveSegment.java"
-public class org.osgeo.mapguide.MgCurveSegment extends org.osgeo.mapguide.MgGeometryComponent {
-Compiled from "MgCurveSegmentCollection.java"
-public class org.osgeo.mapguide.MgCurveSegmentCollection extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgCurveSegment getItem(int);
- public void setItem(int, org.osgeo.mapguide.MgCurveSegment);
- public void add(org.osgeo.mapguide.MgCurveSegment);
- public void insert(int, org.osgeo.mapguide.MgCurveSegment);
- public boolean remove(org.osgeo.mapguide.MgCurveSegment);
- public boolean contains(org.osgeo.mapguide.MgCurveSegment);
- public int indexOf(org.osgeo.mapguide.MgCurveSegment);
- public org.osgeo.mapguide.MgCurveSegmentCollection();
-Compiled from "MgCurveString.java"
-public class org.osgeo.mapguide.MgCurveString extends org.osgeo.mapguide.MgCurve {
-Compiled from "MgCurveStringCollection.java"
-public class org.osgeo.mapguide.MgCurveStringCollection extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgCurveString getItem(int);
- public void setItem(int, org.osgeo.mapguide.MgCurveString);
- public void add(org.osgeo.mapguide.MgCurveString);
- public void insert(int, org.osgeo.mapguide.MgCurveString);
- public boolean remove(org.osgeo.mapguide.MgCurveString);
- public boolean contains(org.osgeo.mapguide.MgCurveString);
- public int indexOf(org.osgeo.mapguide.MgCurveString);
- public org.osgeo.mapguide.MgCurveStringCollection();
-Compiled from "MgDataPropertyDefinition.java"
-public class org.osgeo.mapguide.MgDataPropertyDefinition extends org.osgeo.mapguide.MgPropertyDefinition {
- public org.osgeo.mapguide.MgDataPropertyDefinition(java.lang.String);
- public int getDataType();
- public int getLength();
- public int getPrecision();
- public int getScale();
- public boolean isAutoGenerated();
- public java.lang.String getDefaultValue();
- public boolean getNullable();
- public boolean getReadOnly();
- public void setDataType(int);
- public void setReadOnly(boolean);
- public void setLength(int);
- public void setPrecision(int);
- public void setScale(int);
- public void setNullable(boolean);
- public void setDefaultValue(java.lang.String);
- public void setAutoGeneration(boolean);
-Compiled from "MgDataReader.java"
-public class org.osgeo.mapguide.MgDataReader extends org.osgeo.mapguide.MgReader implements java.lang.AutoCloseable {
-Compiled from "MgDateTime.java"
-public class org.osgeo.mapguide.MgDateTime extends org.osgeo.mapguide.MgSerializable {
- public org.osgeo.mapguide.MgDateTime();
- public org.osgeo.mapguide.MgDateTime(short, short, short);
- public org.osgeo.mapguide.MgDateTime(short, short, short, int);
- public org.osgeo.mapguide.MgDateTime(short, short, short, short, short, short, int);
- public short getDay();
- public short getMonth();
- public short getYear();
- public short getHour();
- public short getMinute();
- public short getSecond();
- public int getMicrosecond();
- public void setDay(short);
- public void setMonth(short);
- public void setYear(short);
- public void setHour(short);
- public void setMinute(short);
- public void setSecond(short);
- public void setMicrosecond(int);
- public void validate();
- public boolean isDate();
- public boolean isTime();
- public boolean isDateTime();
- public java.lang.String toString();
-Compiled from "MgDateTimeProperty.java"
-public class org.osgeo.mapguide.MgDateTimeProperty extends org.osgeo.mapguide.MgNullableProperty {
- public org.osgeo.mapguide.MgDateTimeProperty(java.lang.String, org.osgeo.mapguide.MgDateTime);
- public org.osgeo.mapguide.MgDateTime getValue();
- public short getPropertyType();
- public void setValue(org.osgeo.mapguide.MgDateTime);
-Compiled from "MgDeleteFeatures.java"
-public class org.osgeo.mapguide.MgDeleteFeatures extends org.osgeo.mapguide.MgFeatureCommand {
- public org.osgeo.mapguide.MgDeleteFeatures(java.lang.String, java.lang.String);
- public int getCommandType();
- public java.lang.String getFeatureClassName();
- public java.lang.String getFilterText();
-Compiled from "MgDisposable.java"
-public class org.osgeo.mapguide.MgDisposable extends org.osgeo.mapguide.MgObject {
-Compiled from "MgDisposableCollection.java"
-public class org.osgeo.mapguide.MgDisposableCollection extends org.osgeo.mapguide.MgCollection {
- public org.osgeo.mapguide.MgDisposableCollection();
- public org.osgeo.mapguide.MgDisposable getItem(int);
- public void setItem(int, org.osgeo.mapguide.MgDisposable);
- public void add(org.osgeo.mapguide.MgDisposable);
- public void insert(int, org.osgeo.mapguide.MgDisposable);
- public boolean remove(org.osgeo.mapguide.MgDisposable);
- public boolean contains(org.osgeo.mapguide.MgDisposable);
- public int indexOf(org.osgeo.mapguide.MgDisposable);
- public org.osgeo.mapguide.MgByteReader toXml();
-Compiled from "MgDoubleProperty.java"
-public class org.osgeo.mapguide.MgDoubleProperty extends org.osgeo.mapguide.MgNullableProperty {
- public org.osgeo.mapguide.MgDoubleProperty(java.lang.String, double);
- public void setValue(double);
-Compiled from "MgDrawingService.java"
-public class org.osgeo.mapguide.MgDrawingService extends org.osgeo.mapguide.MgService {
- public org.osgeo.mapguide.MgByteReader getDrawing(org.osgeo.mapguide.MgResourceIdentifier);
- public org.osgeo.mapguide.MgByteReader describeDrawing(org.osgeo.mapguide.MgResourceIdentifier);
- public org.osgeo.mapguide.MgByteReader getSection(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String);
- public org.osgeo.mapguide.MgByteReader getSectionResource(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String);
- public org.osgeo.mapguide.MgStringCollection enumerateLayers(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String);
- public org.osgeo.mapguide.MgByteReader getLayer(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, java.lang.String);
- public org.osgeo.mapguide.MgByteReader enumerateSections(org.osgeo.mapguide.MgResourceIdentifier);
- public org.osgeo.mapguide.MgByteReader enumerateSectionResources(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String);
- public java.lang.String getCoordinateSpace(org.osgeo.mapguide.MgResourceIdentifier);
-Compiled from "MgDwfVersion.java"
-public class org.osgeo.mapguide.MgDwfVersion extends org.osgeo.mapguide.MgSerializable {
- public org.osgeo.mapguide.MgDwfVersion(java.lang.String, java.lang.String);
- public java.lang.String getFileVersion();
- public void setFileVersion(java.lang.String);
- public java.lang.String getSchemaVersion();
- public void setSchemaVersion(java.lang.String);
-Compiled from "MgEnvelope.java"
-public class org.osgeo.mapguide.MgEnvelope extends org.osgeo.mapguide.MgSerializable {
- public org.osgeo.mapguide.MgEnvelope();
- public org.osgeo.mapguide.MgEnvelope(org.osgeo.mapguide.MgCoordinate);
- public org.osgeo.mapguide.MgEnvelope(org.osgeo.mapguide.MgCoordinate, org.osgeo.mapguide.MgCoordinate);
- public org.osgeo.mapguide.MgEnvelope(double, double, double, double);
- public org.osgeo.mapguide.MgEnvelope(org.osgeo.mapguide.MgEnvelope);
- public org.osgeo.mapguide.MgCoordinate getLowerLeftCoordinate();
- public org.osgeo.mapguide.MgCoordinate getUpperRightCoordinate();
- public double getWidth();
- public double getHeight();
- public double getDepth();
- public boolean isNull();
- public void makeNull();
- public void expandToInclude(org.osgeo.mapguide.MgCoordinate);
- public void expandToInclude(org.osgeo.mapguide.MgEnvelope);
- public boolean contains(org.osgeo.mapguide.MgCoordinate);
- public boolean contains(org.osgeo.mapguide.MgEnvelope);
- public boolean intersects(org.osgeo.mapguide.MgEnvelope);
- public org.osgeo.mapguide.MgEnvelope transform(org.osgeo.mapguide.MgTransform);
-Compiled from "MgException.java"
-public class org.osgeo.mapguide.MgException extends org.osgeo.mapguide.AppThrowable {
- public java.lang.String getExceptionCode();
- public java.lang.String getExceptionMessage();
- public java.lang.String getDetails();
- public java.lang.String getExceptionStackTrace();
- public long getNativeErrorCode();
- public java.lang.String getExceptionMessage(java.lang.String);
- public java.lang.String getDetails(java.lang.String);
- public java.lang.String getExceptionStackTrace(java.lang.String);
- public void addStackTraceInfo(java.lang.String, int, java.lang.String);
- public void addStackTraceInfo(java.lang.String, java.lang.String, int, java.lang.String);
- public void printStackTrace();
- public java.lang.String getMessage();
-Compiled from "MgExceptionCodes.java"
-public class org.osgeo.mapguide.MgExceptionCodes {
- public static final java.lang.String MgAllProviderConnectionsUsedException = "MgAllProviderConnectionsUsedException";
- public static final java.lang.String MgArgumentOutOfRangeException = "MgArgumentOutOfRangeException";
- public static final java.lang.String MgArrayTypeMismatchException = "MgArrayTypeMismatchException";
- public static final java.lang.String MgAuthenticationFailedException = "MgAuthenticationFailedException";
- public static final java.lang.String MgClassNotFoundException = "MgClassNotFoundException";
- public static final java.lang.String MgConfigurationException = "MgConfigurationException";
- public static final java.lang.String MgConfigurationSaveFailedException = "MgConfigurationSaveFailedException";
- public static final java.lang.String MgConnectionFailedException = "MgConnectionFailedException";
- public static final java.lang.String MgConnectionNotOpenException = "MgConnectionNotOpenException";
- public static final java.lang.String MgCoordinateSystemComputationFailedException = "MgCoordinateSystemComputationFailedException";
- public static final java.lang.String MgCoordinateSystemConversionFailedException = "MgCoordinateSystemConversionFailedException";
- public static final java.lang.String MgCoordinateSystemInitializationFailedException = "MgCoordinateSystemInitializationFailedException";
- public static final java.lang.String MgCoordinateSystemLoadFailedException = "MgCoordinateSystemLoadFailedException";
- public static final java.lang.String MgCoordinateSystemMeasureFailedException = "MgCoordinateSystemMeasureFailedException";
- public static final java.lang.String MgCoordinateSystemTransformFailedException = "MgCoordinateSystemTransformFailedException";
- public static final java.lang.String MgDateTimeException = "MgDateTimeException";
- public static final java.lang.String MgDbException = "MgDbException";
- public static final java.lang.String MgDbXmlException = "MgDbXmlException";
- public static final java.lang.String MgDecryptionException = "MgDecryptionException";
- public static final java.lang.String MgDirectoryNotFoundException = "MgDirectoryNotFoundException";
- public static final java.lang.String MgDivideByZeroException = "MgDivideByZeroException";
- public static final java.lang.String MgDomainException = "MgDomainException";
- public static final java.lang.String MgDuplicateDirectoryException = "MgDuplicateDirectoryException";
- public static final java.lang.String MgDuplicateFileException = "MgDuplicateFileException";
- public static final java.lang.String MgDuplicateGroupException = "MgDuplicateGroupException";
- public static final java.lang.String MgDuplicateNameException = "MgDuplicateNameException";
- public static final java.lang.String MgDuplicateObjectException = "MgDuplicateObjectException";
- public static final java.lang.String MgDuplicateParameterException = "MgDuplicateParameterException";
- public static final java.lang.String MgDuplicateRepositoryException = "MgDuplicateRepositoryException";
- public static final java.lang.String MgDuplicateResourceDataException = "MgDuplicateResourceDataException";
- public static final java.lang.String MgDuplicateResourceException = "MgDuplicateResourceException";
- public static final java.lang.String MgDuplicateRoleException = "MgDuplicateRoleException";
- public static final java.lang.String MgDuplicateServerException = "MgDuplicateServerException";
- public static final java.lang.String MgDuplicateSessionException = "MgDuplicateSessionException";
- public static final java.lang.String MgDuplicateUserException = "MgDuplicateUserException";
- public static final java.lang.String MgDwfException = "MgDwfException";
- public static final java.lang.String MgDwfSectionNotFoundException = "MgDwfSectionNotFoundException";
- public static final java.lang.String MgDwfSectionResourceNotFoundException = "MgDwfSectionResourceNotFoundException";
- public static final java.lang.String MgEmptyFeatureSetException = "MgEmptyFeatureSetException";
- public static final java.lang.String MgEncryptionException = "MgEncryptionException";
- public static final java.lang.String MgEndOfStreamException = "MgEndOfStreamException";
- public static final java.lang.String MgEvaluationExpiredException = "MgEvaluationExpiredException";
- public static final java.lang.String MgFdoException = "MgFdoException";
- public static final java.lang.String MgFeatureServiceException = "MgFeatureServiceException";
- public static final java.lang.String MgFileIoException = "MgFileIoException";
- public static final java.lang.String MgFileNotFoundException = "MgFileNotFoundException";
- public static final java.lang.String MgGeometryException = "MgGeometryException";
- public static final java.lang.String MgGroupNotFoundException = "MgGroupNotFoundException";
- public static final java.lang.String MgIndexOutOfRangeException = "MgIndexOutOfRangeException";
- public static final java.lang.String MgInvalidArgumentException = "MgInvalidArgumentException";
- public static final java.lang.String MgInvalidCastException = "MgInvalidCastException";
- public static final java.lang.String MgInvalidCoordinateSystemException = "MgInvalidCoordinateSystemException";
- public static final java.lang.String MgInvalidCoordinateSystemTypeException = "MgInvalidCoordinateSystemTypeException";
- public static final java.lang.String MgInvalidCoordinateSystemUnitsException = "MgInvalidCoordinateSystemUnitsException";
- public static final java.lang.String MgInvalidDwfPackageException = "MgInvalidDwfPackageException";
- public static final java.lang.String MgInvalidDwfSectionException = "MgInvalidDwfSectionException";
- public static final java.lang.String MgInvalidFeatureSourceException = "MgInvalidFeatureSourceException";
- public static final java.lang.String MgInvalidIpAddressException = "MgInvalidIpAddressException";
- public static final java.lang.String MgInvalidLicenseException = "MgInvalidLicenseException";
- public static final java.lang.String MgInvalidLogEntryException = "MgInvalidLogEntryException";
- public static final java.lang.String MgInvalidMapDefinitionException = "MgInvalidMapDefinitionException";
- public static final java.lang.String MgInvalidMimeTypeException = "MgInvalidMimeTypeException";
- public static final java.lang.String MgInvalidOperationException = "MgInvalidOperationException";
- public static final java.lang.String MgInvalidOperationVersionException = "MgInvalidOperationVersionException";
- public static final java.lang.String MgInvalidPasswordException = "MgInvalidPasswordException";
- public static final java.lang.String MgInvalidPrintLayoutFontSizeUnitsException = "MgInvalidPrintLayoutFontSizeUnitsException";
- public static final java.lang.String MgInvalidPrintLayoutPositionUnitsException = "MgInvalidPrintLayoutPositionUnitsException";
- public static final java.lang.String MgInvalidPrintLayoutSizeUnitsException = "MgInvalidPrintLayoutSizeUnitsException";
- public static final java.lang.String MgInvalidPropertyTypeException = "MgInvalidPropertyTypeException";
- public static final java.lang.String MgInvalidRepositoryNameException = "MgInvalidRepositoryNameException";
- public static final java.lang.String MgInvalidRepositoryTypeException = "MgInvalidRepositoryTypeException";
- public static final java.lang.String MgInvalidResourceDataNameException = "MgInvalidResourceDataNameException";
- public static final java.lang.String MgInvalidResourceDataTypeException = "MgInvalidResourceDataTypeException";
- public static final java.lang.String MgInvalidResourceNameException = "MgInvalidResourceNameException";
- public static final java.lang.String MgInvalidResourcePathException = "MgInvalidResourcePathException";
- public static final java.lang.String MgInvalidResourcePreProcessingTypeException = "MgInvalidResourcePreProcessingTypeException";
- public static final java.lang.String MgInvalidResourceTypeException = "MgInvalidResourceTypeException";
- public static final java.lang.String MgInvalidServerNameException = "MgInvalidServerNameException";
- public static final java.lang.String MgInvalidSerialNumberException = "MgInvalidSerialNumberException";
- public static final java.lang.String MgInvalidStreamHeaderException = "MgInvalidStreamHeaderException";
- public static final java.lang.String MgIoException = "MgIoException";
- public static final java.lang.String MgLayerNotFoundException = "MgLayerNotFoundException";
- public static final java.lang.String MgLengthException = "MgLengthException";
- public static final java.lang.String MgLicenseException = "MgLicenseException";
- public static final java.lang.String MgLicenseExpiredException = "MgLicenseExpiredException";
- public static final java.lang.String MgLogicException = "MgLogicException";
- public static final java.lang.String MgLogOpenFailedException = "MgLogOpenFailedException";
- public static final java.lang.String MgNotFiniteNumberException = "MgNotFiniteNumberException";
- public static final java.lang.String MgNotImplementedException = "MgNotImplementedException";
- public static final java.lang.String MgNullArgumentException = "MgNullArgumentException";
- public static final java.lang.String MgNullPropertyValueException = "MgNullPropertyValueException";
- public static final java.lang.String MgNullReferenceException = "MgNullReferenceException";
- public static final java.lang.String MgObjectNotFoundException = "MgObjectNotFoundException";
- public static final java.lang.String MgOperationProcessingException = "MgOperationProcessingException";
- public static final java.lang.String MgOutOfMemoryException = "MgOutOfMemoryException";
- public static final java.lang.String MgOutOfRangeException = "MgOutOfRangeException";
- public static final java.lang.String MgOverflowException = "MgOverflowException";
- public static final java.lang.String MgParameterNotFoundException = "MgParameterNotFoundException";
- public static final java.lang.String MgPathTooLongException = "MgPathTooLongException";
- public static final java.lang.String MgPermissionDeniedException = "MgPermissionDeniedException";
- public static final java.lang.String MgPlatformNotSupportedException = "MgPlatformNotSupportedException";
- public static final java.lang.String MgPortNotAvailableException = "MgPortNotAvailableException";
- public static final java.lang.String MgPrintToScaleModeNotSelectedException = "MgPrintToScaleModeNotSelectedException";
- public static final java.lang.String MgRasterTransformationNotSupportedException = "MgRasterTransformationNotSupportedException";
- public static final java.lang.String MgRepositoryCreationFailedException = "MgRepositoryCreationFailedException";
- public static final java.lang.String MgRepositoryNotFoundException = "MgRepositoryNotFoundException";
- public static final java.lang.String MgRepositoryNotOpenException = "MgRepositoryNotOpenException";
- public static final java.lang.String MgRepositoryOpenFailedException = "MgRepositoryOpenFailedException";
- public static final java.lang.String MgResourceBusyException = "MgResourceBusyException";
- public static final java.lang.String MgResourceDataNotFoundException = "MgResourceDataNotFoundException";
- public static final java.lang.String MgResourceNotFoundException = "MgResourceNotFoundException";
- public static final java.lang.String MgResourcesException = "MgResourcesException";
- public static final java.lang.String MgResourceTagNotFoundException = "MgResourceTagNotFoundException";
- public static final java.lang.String MgRoleNotFoundException = "MgRoleNotFoundException";
- public static final java.lang.String MgRuntimeException = "MgRuntimeException";
- public static final java.lang.String MgServerNotFoundException = "MgServerNotFoundException";
- public static final java.lang.String MgServerNotOnlineException = "MgServerNotOnlineException";
- public static final java.lang.String MgServiceNotAvailableException = "MgServiceNotAvailableException";
- public static final java.lang.String MgServiceNotSupportedException = "MgServiceNotSupportedException";
- public static final java.lang.String MgSessionExpiredException = "MgSessionExpiredException";
- public static final java.lang.String MgSessionNotFoundException = "MgSessionNotFoundException";
- public static final java.lang.String MgStreamIoException = "MgStreamIoException";
- public static final java.lang.String MgStylizeLayerFailedException = "MgStylizeLayerFailedException";
- public static final java.lang.String MgTemporaryFileNotAvailableException = "MgTemporaryFileNotAvailableException";
- public static final java.lang.String MgUnauthorizedAccessException = "MgUnauthorizedAccessException";
- public static final java.lang.String MgUnclassifiedException = "MgUnclassifiedException";
- public static final java.lang.String MgUnderflowException = "MgUnderflowException";
- public static final java.lang.String MgUnknownTileProviderException = "MgUnknownTileProviderException";
- public static final java.lang.String MgUnsupportedProviderThreadModelException = "MgUnsupportedProviderThreadModelException";
- public static final java.lang.String MgUnsupportedTileProviderException = "MgUnsupportedTileProviderException";
- public static final java.lang.String MgUriFormatException = "MgUriFormatException";
- public static final java.lang.String MgUserNotFoundException = "MgUserNotFoundException";
- public static final java.lang.String MgXmlException = "MgXmlException";
- public static final java.lang.String MgXmlParserException = "MgXmlParserException";
- public static final java.lang.String MgConfigurationLoadFailedException = "MgConfigurationLoadFailedException";
- public static final java.lang.String MgResourcesLoadFailedException = "MgResourcesLoadFailedException";
- public static final java.lang.String MgGridDensityException = "MgGridDensityException";
- public static final java.lang.String MgInvalidLayerDefinitionException = "MgInvalidLayerDefinitionException";
- public static final java.lang.String MgInvalidWatermarkDefinitionException = "MgInvalidWatermarkDefinitionException";
- public org.osgeo.mapguide.MgExceptionCodes();
-Compiled from "MgFeatureAggregateOptions.java"
-public class org.osgeo.mapguide.MgFeatureAggregateOptions extends org.osgeo.mapguide.MgFeatureQueryOptions {
- public org.osgeo.mapguide.MgFeatureAggregateOptions();
- public void selectDistinct(boolean);
- public void setGroupingFilter(org.osgeo.mapguide.MgStringCollection, java.lang.String);
-Compiled from "MgFeatureCommand.java"
-public class org.osgeo.mapguide.MgFeatureCommand extends org.osgeo.mapguide.MgSerializable {
-Compiled from "MgFeatureCommandCollection.java"
-public class org.osgeo.mapguide.MgFeatureCommandCollection extends org.osgeo.mapguide.MgSerializable {
- public org.osgeo.mapguide.MgFeatureCommand getItem(int);
- public void setItem(int, org.osgeo.mapguide.MgFeatureCommand);
- public void add(org.osgeo.mapguide.MgFeatureCommand);
- public void insert(int, org.osgeo.mapguide.MgFeatureCommand);
- public boolean remove(org.osgeo.mapguide.MgFeatureCommand);
- public boolean contains(org.osgeo.mapguide.MgFeatureCommand);
- public int indexOf(org.osgeo.mapguide.MgFeatureCommand);
- public org.osgeo.mapguide.MgFeatureCommandCollection();
-Compiled from "MgFeatureCommandType.java"
-public class org.osgeo.mapguide.MgFeatureCommandType {
- public static final int InsertFeatures = 0;
- public static final int UpdateFeatures = 1;
- public static final int DeleteFeatures = 2;
- public static final int LockFeatures = 3;
- public static final int UnlockFeatures = 4;
- public org.osgeo.mapguide.MgFeatureCommandType();
-Compiled from "MgFeatureGeometricType.java"
-public class org.osgeo.mapguide.MgFeatureGeometricType {
- public static final int Point = 1;
- public static final int Curve = 2;
- public static final int Surface = 4;
- public static final int Solid = 8;
- public org.osgeo.mapguide.MgFeatureGeometricType();
-Compiled from "MgFeatureInformation.java"
-public class org.osgeo.mapguide.MgFeatureInformation extends org.osgeo.mapguide.MgSerializable {
- public synchronized void delete();
- public org.osgeo.mapguide.MgSelection getSelection();
- public java.lang.String getTooltip();
- public java.lang.String getHyperlink();
- public org.osgeo.mapguide.MgPropertyCollection getProperties();
-Compiled from "MgFeatureProperty.java"
-public class org.osgeo.mapguide.MgFeatureProperty extends org.osgeo.mapguide.MgNullableProperty {
- public org.osgeo.mapguide.MgFeatureProperty(java.lang.String, org.osgeo.mapguide.MgFeatureReader);
- public org.osgeo.mapguide.MgFeatureReader getValue();
- public void setValue(org.osgeo.mapguide.MgFeatureReader);
-Compiled from "MgFeaturePropertyType.java"
-public class org.osgeo.mapguide.MgFeaturePropertyType {
- public static final int DataProperty = 100;
- public static final int ObjectProperty = 101;
- public static final int GeometricProperty = 102;
- public static final int AssociationProperty = 103;
- public static final int RasterProperty = 104;
- public org.osgeo.mapguide.MgFeaturePropertyType();
-Compiled from "MgFeatureQueryOptions.java"
-public class org.osgeo.mapguide.MgFeatureQueryOptions extends org.osgeo.mapguide.MgSerializable {
- public org.osgeo.mapguide.MgFeatureQueryOptions();
- public int addFeatureProperty(java.lang.String);
- public int addComputedProperty(java.lang.String, java.lang.String);
- public void setFilter(java.lang.String);
- public void setBinaryOperator(boolean);
- public void setSpatialFilter(java.lang.String, org.osgeo.mapguide.MgGeometry, int);
- public void setOrderingFilter(org.osgeo.mapguide.MgStringCollection, int);
- public void removeFeatureProperty(java.lang.String);
- public void removeComputedProperty(java.lang.String);
- public void setFetchSize(int);
-Compiled from "MgFeatureReader.java"
-public class org.osgeo.mapguide.MgFeatureReader extends org.osgeo.mapguide.MgReader implements java.lang.AutoCloseable {
- public org.osgeo.mapguide.MgClassDefinition getClassDefinition();
- public org.osgeo.mapguide.MgFeatureReader getFeatureObject(java.lang.String);
- public org.osgeo.mapguide.MgFeatureReader getFeatureObject(int);
-Compiled from "MgFeatureSchema.java"
-public class org.osgeo.mapguide.MgFeatureSchema extends org.osgeo.mapguide.MgNamedSerializable {
- public boolean equals(java.lang.Object);
- public int hashCode();
- public org.osgeo.mapguide.MgFeatureSchema();
- public org.osgeo.mapguide.MgFeatureSchema(java.lang.String, java.lang.String);
- public java.lang.String getName();
- public void setName(java.lang.String);
- public org.osgeo.mapguide.MgClassDefinitionCollection getClasses();
- public void markAsDeleted();
-Compiled from "MgFeatureSchemaCollection.java"
-class org.osgeo.mapguide.MgFeatureSchemaCollection$ItemIterator implements java.util.Iterator<org.osgeo.mapguide.MgFeatureSchema> {
- public org.osgeo.mapguide.MgFeatureSchemaCollection$ItemIterator(org.osgeo.mapguide.MgFeatureSchemaCollection, org.osgeo.mapguide.MgFeatureSchemaCollection);
- public boolean hasNext();
- public org.osgeo.mapguide.MgFeatureSchema next();
- public void remove();
- public java.lang.Object next();
-public class org.osgeo.mapguide.MgFeatureSchemaCollection extends org.osgeo.mapguide.MgCollection implements java.util.Collection<org.osgeo.mapguide.MgFeatureSchema> {
- public java.util.Iterator<org.osgeo.mapguide.MgFeatureSchema> iterator();
- public boolean add(org.osgeo.mapguide.MgFeatureSchema);
- public boolean addAll(java.util.Collection<? extends org.osgeo.mapguide.MgFeatureSchema>);
- public boolean contains(java.lang.Object);
- public boolean containsAll(java.util.Collection<?>);
- public boolean remove(java.lang.Object);
- public boolean removeAll(java.util.Collection<?>);
- public boolean retainAll(java.util.Collection<?>);
- public int size();
- public java.lang.Object[] toArray();
- public <MgFeatureSchema> MgFeatureSchema[] toArray(MgFeatureSchema[]);
- public org.osgeo.mapguide.MgFeatureSchemaCollection();
- public void setItem(int, org.osgeo.mapguide.MgFeatureSchema);
- public void addItem(org.osgeo.mapguide.MgFeatureSchema);
- public void insert(int, org.osgeo.mapguide.MgFeatureSchema);
- public boolean remove(org.osgeo.mapguide.MgFeatureSchema);
- public org.osgeo.mapguide.MgFeatureSchema getItem(int);
- public boolean contains(org.osgeo.mapguide.MgFeatureSchema);
- public int indexOf(org.osgeo.mapguide.MgFeatureSchema);
- public boolean add(java.lang.Object);
-Compiled from "MgFeatureService.java"
-public class org.osgeo.mapguide.MgFeatureService extends org.osgeo.mapguide.MgService {
- public org.osgeo.mapguide.MgByteReader getFeatureProviders();
- public org.osgeo.mapguide.MgStringCollection getConnectionPropertyValues(java.lang.String, java.lang.String, java.lang.String);
- public boolean testConnection(java.lang.String, java.lang.String);
- public boolean testConnection(org.osgeo.mapguide.MgResourceIdentifier);
- public org.osgeo.mapguide.MgByteReader getCapabilities(java.lang.String);
- public org.osgeo.mapguide.MgByteReader getCapabilities(java.lang.String, java.lang.String);
- public void applySchema(org.osgeo.mapguide.MgResourceIdentifier, org.osgeo.mapguide.MgFeatureSchema);
- public org.osgeo.mapguide.MgFeatureSchemaCollection describeSchema(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, org.osgeo.mapguide.MgStringCollection);
- public org.osgeo.mapguide.MgFeatureSchemaCollection describeSchema(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String);
- public java.lang.String describeSchemaAsXml(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, org.osgeo.mapguide.MgStringCollection);
- public java.lang.String describeSchemaAsXml(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String);
- public java.lang.String schemaToXml(org.osgeo.mapguide.MgFeatureSchemaCollection);
- public org.osgeo.mapguide.MgFeatureSchemaCollection xmlToSchema(java.lang.String);
- public org.osgeo.mapguide.MgFeatureReader selectFeatures(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, org.osgeo.mapguide.MgFeatureQueryOptions);
- public org.osgeo.mapguide.MgFeatureReader selectFeatures(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, org.osgeo.mapguide.MgFeatureQueryOptions, java.lang.String);
- public org.osgeo.mapguide.MgDataReader selectAggregate(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, org.osgeo.mapguide.MgFeatureAggregateOptions);
- public org.osgeo.mapguide.MgPropertyCollection updateFeatures(org.osgeo.mapguide.MgResourceIdentifier, org.osgeo.mapguide.MgFeatureCommandCollection, boolean);
- public org.osgeo.mapguide.MgPropertyCollection updateFeatures(org.osgeo.mapguide.MgResourceIdentifier, org.osgeo.mapguide.MgFeatureCommandCollection, org.osgeo.mapguide.MgTransaction);
- public org.osgeo.mapguide.MgFeatureReader insertFeatures(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, org.osgeo.mapguide.MgPropertyCollection);
- public org.osgeo.mapguide.MgFeatureReader insertFeatures(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, org.osgeo.mapguide.MgPropertyCollection, org.osgeo.mapguide.MgTransaction);
- public org.osgeo.mapguide.MgFeatureReader insertFeatures(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, org.osgeo.mapguide.MgBatchPropertyCollection);
- public org.osgeo.mapguide.MgFeatureReader insertFeatures(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, org.osgeo.mapguide.MgBatchPropertyCollection, org.osgeo.mapguide.MgTransaction);
- public int updateMatchingFeatures(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, org.osgeo.mapguide.MgPropertyCollection, java.lang.String);
- public int updateMatchingFeatures(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, org.osgeo.mapguide.MgPropertyCollection, java.lang.String, org.osgeo.mapguide.MgTransaction);
- public int deleteFeatures(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, java.lang.String);
- public int deleteFeatures(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, java.lang.String, org.osgeo.mapguide.MgTransaction);
- public org.osgeo.mapguide.MgFeatureReader getLockedFeatures(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, org.osgeo.mapguide.MgFeatureQueryOptions);
- public org.osgeo.mapguide.MgTransaction beginTransaction(org.osgeo.mapguide.MgResourceIdentifier);
- public org.osgeo.mapguide.MgSqlDataReader executeSqlQuery(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String);
- public org.osgeo.mapguide.MgSqlDataReader executeSqlQuery(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, org.osgeo.mapguide.MgParameterCollection, org.osgeo.mapguide.MgTransaction);
- public int executeSqlNonQuery(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String);
- public int executeSqlNonQuery(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, org.osgeo.mapguide.MgParameterCollection, org.osgeo.mapguide.MgTransaction);
- public org.osgeo.mapguide.MgSpatialContextReader getSpatialContexts(org.osgeo.mapguide.MgResourceIdentifier, boolean);
- public org.osgeo.mapguide.MgLongTransactionReader getLongTransactions(org.osgeo.mapguide.MgResourceIdentifier, boolean);
- public boolean setLongTransaction(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String);
- public org.osgeo.mapguide.MgStringCollection getSchemas(org.osgeo.mapguide.MgResourceIdentifier);
- public org.osgeo.mapguide.MgStringCollection getClasses(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String);
- public org.osgeo.mapguide.MgClassDefinition getClassDefinition(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, java.lang.String);
- public void createFeatureSource(org.osgeo.mapguide.MgResourceIdentifier, org.osgeo.mapguide.MgFeatureSourceParams);
- public org.osgeo.mapguide.MgByteReader describeWfsFeatureType(org.osgeo.mapguide.MgResourceIdentifier, org.osgeo.mapguide.MgStringCollection);
- public org.osgeo.mapguide.MgByteReader describeWfsFeatureType(org.osgeo.mapguide.MgResourceIdentifier, org.osgeo.mapguide.MgStringCollection, java.lang.String, java.lang.String);
- public org.osgeo.mapguide.MgByteReader getWfsFeature(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, org.osgeo.mapguide.MgStringCollection, java.lang.String, java.lang.String, int);
- public org.osgeo.mapguide.MgByteReader getWfsFeature(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, org.osgeo.mapguide.MgStringCollection, java.lang.String, java.lang.String, int, java.lang.String, java.lang.String, java.lang.String, java.lang.String, java.lang.String);
- public org.osgeo.mapguide.MgFeatureReader getWfsReader(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, org.osgeo.mapguide.MgStringCollection, java.lang.String, java.lang.String, java.lang.String);
- public org.osgeo.mapguide.MgByteReader enumerateDataStores(java.lang.String, java.lang.String);
- public org.osgeo.mapguide.MgByteReader getSchemaMapping(java.lang.String, java.lang.String);
-Compiled from "MgFeatureSourceParams.java"
-public class org.osgeo.mapguide.MgFeatureSourceParams extends org.osgeo.mapguide.MgSerializable {
-Compiled from "MgFeatureSpatialOperations.java"
-public class org.osgeo.mapguide.MgFeatureSpatialOperations {
- public static final int Contains = 0;
- public static final int Crosses = 1;
- public static final int Disjoint = 2;
- public static final int Equals = 3;
- public static final int Intersects = 4;
- public static final int Overlaps = 5;
- public static final int Touches = 6;
- public static final int Within = 7;
- public static final int CoveredBy = 8;
- public static final int Inside = 9;
- public static final int EnvelopeIntersects = 10;
- public org.osgeo.mapguide.MgFeatureSpatialOperations();
-Compiled from "MgFileFeatureSourceParams.java"
-public class org.osgeo.mapguide.MgFileFeatureSourceParams extends org.osgeo.mapguide.MgFeatureSourceParams {
- public org.osgeo.mapguide.MgFileFeatureSourceParams();
- public org.osgeo.mapguide.MgFileFeatureSourceParams(java.lang.String);
- public org.osgeo.mapguide.MgFileFeatureSourceParams(java.lang.String, java.lang.String, java.lang.String, org.osgeo.mapguide.MgFeatureSchema);
- public java.lang.String getProviderName();
- public void setProviderName(java.lang.String);
- public java.lang.String getFileName();
- public void setFileName(java.lang.String);
- public java.lang.String getSpatialContextName();
- public void setSpatialContextName(java.lang.String);
- public java.lang.String getSpatialContextDescription();
- public void setSpatialContextDescription(java.lang.String);
- public java.lang.String getCoordinateSystemWkt();
- public void setCoordinateSystemWkt(java.lang.String);
- public double getXYTolerance();
- public void setXYTolerance(double);
- public double getZTolerance();
- public void setZTolerance(double);
- public org.osgeo.mapguide.MgFeatureSchema getFeatureSchema();
- public void setFeatureSchema(org.osgeo.mapguide.MgFeatureSchema);
-Compiled from "MgGeoJsonWriter.java"
-public class org.osgeo.mapguide.MgGeoJsonWriter extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgGeoJsonWriter();
- public java.lang.String featureToGeoJson(org.osgeo.mapguide.MgFeatureReader, org.osgeo.mapguide.MgTransform);
- public java.lang.String featureToGeoJson(org.osgeo.mapguide.MgReader, org.osgeo.mapguide.MgTransform, java.lang.String, java.lang.String);
- public void setPrecisionEnabled(boolean);
- public boolean isPrecisionEnabled();
-Compiled from "MgGeometricEntity.java"
-public class org.osgeo.mapguide.MgGeometricEntity extends org.osgeo.mapguide.MgSerializable {
- public boolean isSimple();
- public boolean isValid();
- public org.osgeo.mapguide.MgEnvelope envelope();
- public double getArea();
- public double getLength();
- public org.osgeo.mapguide.MgPoint getCentroid();
-Compiled from "MgGeometricPathInstructionType.java"
-public class org.osgeo.mapguide.MgGeometricPathInstructionType {
- public static final int MoveTo = 0;
- public static final int LineTo = 1;
- public static final int QuadTo = 2;
- public static final int Close = 4;
- public org.osgeo.mapguide.MgGeometricPathInstructionType();
-Compiled from "MgGeometricPropertyDefinition.java"
-public class org.osgeo.mapguide.MgGeometricPropertyDefinition extends org.osgeo.mapguide.MgPropertyDefinition {
- public org.osgeo.mapguide.MgGeometricPropertyDefinition(java.lang.String);
- public int getGeometryTypes();
- public org.osgeo.mapguide.MgGeometryTypeInfo getSpecificGeometryTypes();
- public boolean getHasElevation();
- public boolean getHasMeasure();
- public java.lang.String getSpatialContextAssociation();
- public void setGeometryTypes(int);
- public void setSpecificGeometryTypes(org.osgeo.mapguide.MgGeometryTypeInfo);
- public void setHasElevation(boolean);
- public void setHasMeasure(boolean);
- public void setSpatialContextAssociation(java.lang.String);
-Compiled from "MgGeometry.java"
-public class org.osgeo.mapguide.MgGeometry extends org.osgeo.mapguide.MgGeometricEntity {
- public boolean contains(org.osgeo.mapguide.MgGeometry);
- public boolean crosses(org.osgeo.mapguide.MgGeometry);
- public boolean disjoint(org.osgeo.mapguide.MgGeometry);
- public boolean equals(org.osgeo.mapguide.MgGeometry);
- public boolean intersects(org.osgeo.mapguide.MgGeometry);
- public boolean overlaps(org.osgeo.mapguide.MgGeometry);
- public boolean touches(org.osgeo.mapguide.MgGeometry);
- public boolean within(org.osgeo.mapguide.MgGeometry);
- public org.osgeo.mapguide.MgGeometry boundary();
- public org.osgeo.mapguide.MgGeometry buffer(double, org.osgeo.mapguide.MgMeasure);
- public org.osgeo.mapguide.MgGeometry convexHull();
- public org.osgeo.mapguide.MgGeometry difference(org.osgeo.mapguide.MgGeometry);
- public double distance(org.osgeo.mapguide.MgGeometry, org.osgeo.mapguide.MgMeasure);
- public org.osgeo.mapguide.MgGeometry intersection(org.osgeo.mapguide.MgGeometry);
- public org.osgeo.mapguide.MgGeometry symetricDifference(org.osgeo.mapguide.MgGeometry);
- public org.osgeo.mapguide.MgGeometry union(org.osgeo.mapguide.MgGeometry);
- public org.osgeo.mapguide.MgPreparedGeometry prepare();
- public org.osgeo.mapguide.MgGeometry tessellate();
-Compiled from "MgGeometryCollection.java"
-public class org.osgeo.mapguide.MgGeometryCollection extends org.osgeo.mapguide.MgGuardDisposable {
- public int getCount();
- public org.osgeo.mapguide.MgGeometry getItem(int);
- public void setItem(int, org.osgeo.mapguide.MgGeometry);
- public void add(org.osgeo.mapguide.MgGeometry);
- public void insert(int, org.osgeo.mapguide.MgGeometry);
- public void clear();
- public boolean remove(org.osgeo.mapguide.MgGeometry);
- public void removeAt(int);
- public int indexOf(org.osgeo.mapguide.MgGeometry);
- public org.osgeo.mapguide.MgGeometryCollection();
-Compiled from "MgGeometryComponent.java"
-public class org.osgeo.mapguide.MgGeometryComponent extends org.osgeo.mapguide.MgGeometricEntity {
-Compiled from "MgGeometryComponentType.java"
-public class org.osgeo.mapguide.MgGeometryComponentType {
- public static final int LinearRing = 129;
- public static final int ArcSegment = 130;
- public static final int LinearSegment = 131;
- public static final int CurveRing = 132;
- public org.osgeo.mapguide.MgGeometryComponentType();
-Compiled from "MgGeometryEntityType.java"
-public class org.osgeo.mapguide.MgGeometryEntityType {
- public static final int GeometryComponent = 0;
- public static final int Geometry = 1;
- public org.osgeo.mapguide.MgGeometryEntityType();
-Compiled from "MgGeometryFactory.java"
-public class org.osgeo.mapguide.MgGeometryFactory extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgGeometryFactory();
- public org.osgeo.mapguide.MgCoordinate createCoordinateXY(double, double);
- public org.osgeo.mapguide.MgCoordinate createCoordinateXYM(double, double, double);
- public org.osgeo.mapguide.MgCoordinate createCoordinateXYZ(double, double, double);
- public org.osgeo.mapguide.MgCoordinate createCoordinateXYZM(double, double, double, double);
- public org.osgeo.mapguide.MgArcSegment createArcSegment(org.osgeo.mapguide.MgCoordinate, org.osgeo.mapguide.MgCoordinate, org.osgeo.mapguide.MgCoordinate);
- public org.osgeo.mapguide.MgLinearSegment createLinearSegment(org.osgeo.mapguide.MgCoordinateCollection);
- public org.osgeo.mapguide.MgLinearRing createLinearRing(org.osgeo.mapguide.MgCoordinateCollection);
- public org.osgeo.mapguide.MgCurveRing createCurveRing(org.osgeo.mapguide.MgCurveSegmentCollection);
- public org.osgeo.mapguide.MgPoint createPoint(org.osgeo.mapguide.MgCoordinate);
- public org.osgeo.mapguide.MgLineString createLineString(org.osgeo.mapguide.MgCoordinateCollection);
- public org.osgeo.mapguide.MgCurveString createCurveString(org.osgeo.mapguide.MgCurveSegmentCollection);
- public org.osgeo.mapguide.MgPolygon createPolygon(org.osgeo.mapguide.MgLinearRing, org.osgeo.mapguide.MgLinearRingCollection);
- public org.osgeo.mapguide.MgCurvePolygon createCurvePolygon(org.osgeo.mapguide.MgCurveRing, org.osgeo.mapguide.MgCurveRingCollection);
- public org.osgeo.mapguide.MgMultiPoint createMultiPoint(org.osgeo.mapguide.MgPointCollection);
- public org.osgeo.mapguide.MgMultiLineString createMultiLineString(org.osgeo.mapguide.MgLineStringCollection);
- public org.osgeo.mapguide.MgMultiCurveString createMultiCurveString(org.osgeo.mapguide.MgCurveStringCollection);
- public org.osgeo.mapguide.MgMultiPolygon createMultiPolygon(org.osgeo.mapguide.MgPolygonCollection);
- public org.osgeo.mapguide.MgMultiCurvePolygon createMultiCurvePolygon(org.osgeo.mapguide.MgCurvePolygonCollection);
- public org.osgeo.mapguide.MgMultiGeometry createMultiGeometry(org.osgeo.mapguide.MgGeometryCollection);
-Compiled from "MgGeometryProperty.java"
-public class org.osgeo.mapguide.MgGeometryProperty extends org.osgeo.mapguide.MgNullableProperty {
- public org.osgeo.mapguide.MgGeometryProperty(java.lang.String, org.osgeo.mapguide.MgByteReader);
- public org.osgeo.mapguide.MgByteReader getValue();
- public void setValue(org.osgeo.mapguide.MgByteReader);
-Compiled from "MgGeometrySimplificationAlgorithmType.java"
-public class org.osgeo.mapguide.MgGeometrySimplificationAlgorithmType {
- public static final int DouglasPeucker = 0;
- public static final int TopologyPreserving = 1;
- public org.osgeo.mapguide.MgGeometrySimplificationAlgorithmType();
-Compiled from "MgGeometrySimplifier.java"
-public class org.osgeo.mapguide.MgGeometrySimplifier extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgGeometrySimplifier();
- public org.osgeo.mapguide.MgGeometry simplify(org.osgeo.mapguide.MgGeometry, double, int);
-Compiled from "MgGeometryType.java"
-public class org.osgeo.mapguide.MgGeometryType {
- public static final int LineString = 2;
- public static final int Polygon = 3;
- public static final int MultiPoint = 4;
- public static final int MultiLineString = 5;
- public static final int MultiPolygon = 6;
- public static final int MultiGeometry = 7;
- public static final int CurveString = 10;
- public static final int CurvePolygon = 11;
- public static final int MultiCurveString = 12;
- public static final int MultiCurvePolygon = 13;
- public org.osgeo.mapguide.MgGeometryType();
-Compiled from "MgGeometryTypeInfo.java"
-public class org.osgeo.mapguide.MgGeometryTypeInfo extends org.osgeo.mapguide.MgSerializable {
- public org.osgeo.mapguide.MgGeometryTypeInfo();
- public int getType(int);
- public void setTypes(org.osgeo.mapguide.MgIntCollection);
-Compiled from "MgGroup.java"
-public class org.osgeo.mapguide.MgGroup {
- public static final java.lang.String Everyone = "Everyone";
- public org.osgeo.mapguide.MgGroup();
-Compiled from "MgGuardDisposable.java"
-public class org.osgeo.mapguide.MgGuardDisposable extends org.osgeo.mapguide.MgDisposable {
-Compiled from "MgGwsFeatureReader.java"
-public class org.osgeo.mapguide.MgGwsFeatureReader extends org.osgeo.mapguide.MgFeatureReader {
-Compiled from "MgHttpHeader.java"
-public class org.osgeo.mapguide.MgHttpHeader extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgHttpHeader();
- public boolean addHeader(java.lang.String, java.lang.String);
- public boolean removeHeader(java.lang.String);
- public java.lang.String getHeaderValue(java.lang.String);
- public boolean setHeaderValue(java.lang.String, java.lang.String);
- public int getDateHeader(java.lang.String);
- public int getIntHeader(java.lang.String);
- public org.osgeo.mapguide.MgStringCollection getHeaderNames();
- public org.osgeo.mapguide.MgStringCollection getHeaders(java.lang.String);
-Compiled from "MgHttpPrimitiveValue.java"
-public class org.osgeo.mapguide.MgHttpPrimitiveValue extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgHttpPrimitiveValue(boolean);
- public org.osgeo.mapguide.MgHttpPrimitiveValue(int);
- public org.osgeo.mapguide.MgHttpPrimitiveValue(java.lang.String);
- public int getType();
- public boolean getBoolValue();
- public int getIntegerValue();
- public java.lang.String getStringValue();
-Compiled from "MgHttpRequest.java"
-public class org.osgeo.mapguide.MgHttpRequest extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgHttpRequest(java.lang.String);
- public org.osgeo.mapguide.MgHttpHeader getHeader();
- public org.osgeo.mapguide.MgHttpRequestParam getRequestParam();
- public org.osgeo.mapguide.MgHttpRequestMetadata getRequestMetadata();
- public org.osgeo.mapguide.MgHttpResponse execute();
- public java.lang.String getAgentUri();
-Compiled from "MgHttpRequestMetadata.java"
-public class org.osgeo.mapguide.MgHttpRequestMetadata extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgHttpRequestMetadata();
- public boolean addProperty(java.lang.String, java.lang.String);
- public boolean removeProperty(java.lang.String);
- public java.lang.String getPropertyValue(java.lang.String);
- public boolean setPropertyValue(java.lang.String, java.lang.String);
- public org.osgeo.mapguide.MgStringCollection getPropertyNames();
-Compiled from "MgHttpRequestParam.java"
-public class org.osgeo.mapguide.MgHttpRequestParam extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgHttpRequestParam();
- public boolean addParameter(java.lang.String, java.lang.String);
- public boolean removeParameter(java.lang.String);
- public java.lang.String getParameterValue(java.lang.String);
- public java.lang.String getParameterType(java.lang.String);
- public boolean setParameterValue(java.lang.String, java.lang.String);
- public boolean setParameterType(java.lang.String, java.lang.String);
- public org.osgeo.mapguide.MgStringCollection getParameterNames();
- public boolean containsParameter(java.lang.String);
-Compiled from "MgHttpResponse.java"
-public class org.osgeo.mapguide.MgHttpResponse extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgHttpResponse();
- public org.osgeo.mapguide.MgHttpResult getResult();
-Compiled from "MgHttpResult.java"
-public class org.osgeo.mapguide.MgHttpResult extends org.osgeo.mapguide.MgGuardDisposable {
- public int getStatusCode();
- public void setStatusCode(int);
- public java.lang.String getErrorMessage();
- public java.lang.String getDetailedErrorMessage();
- public java.lang.String getHttpStatusMessage();
- public void setErrorMessage(java.lang.String);
- public void setDetailedErrorMessage(java.lang.String);
- public void setHttpStatusMessage(java.lang.String);
- public org.osgeo.mapguide.MgDisposable getResultObject();
- public void setResultObject(org.osgeo.mapguide.MgDisposable, java.lang.String);
- public java.lang.String getResultContentType();
-Compiled from "MgImageFormats.java"
-public class org.osgeo.mapguide.MgImageFormats {
- public static final java.lang.String Gif = "GIF";
- public static final java.lang.String Jpeg = "JPG";
- public static final java.lang.String Png = "PNG";
- public static final java.lang.String Png8 = "PNG8";
- public static final java.lang.String Tiff = "TIF";
- public static final java.lang.String Raw = "RAW";
- public static final java.lang.String Meta = "META";
- public org.osgeo.mapguide.MgImageFormats();
-Compiled from "MgInsertFeatures.java"
-public class org.osgeo.mapguide.MgInsertFeatures extends org.osgeo.mapguide.MgFeatureCommand {
- public org.osgeo.mapguide.MgInsertFeatures(java.lang.String, org.osgeo.mapguide.MgPropertyCollection);
- public org.osgeo.mapguide.MgInsertFeatures(java.lang.String, org.osgeo.mapguide.MgBatchPropertyCollection);
- public org.osgeo.mapguide.MgPropertyCollection getPropertyValues();
-Compiled from "MgInt16Property.java"
-public class org.osgeo.mapguide.MgInt16Property extends org.osgeo.mapguide.MgNullableProperty {
- public org.osgeo.mapguide.MgInt16Property(java.lang.String, short);
- public short getValue();
- public void setValue(short);
-Compiled from "MgInt32Property.java"
-public class org.osgeo.mapguide.MgInt32Property extends org.osgeo.mapguide.MgNullableProperty {
- public org.osgeo.mapguide.MgInt32Property(java.lang.String, int);
- public int getValue();
- public void setValue(int);
-Compiled from "MgInt64Property.java"
-public class org.osgeo.mapguide.MgInt64Property extends org.osgeo.mapguide.MgNullableProperty {
- public org.osgeo.mapguide.MgInt64Property(java.lang.String, long);
- public long getValue();
- public void setValue(long);
-Compiled from "MgIntCollection.java"
-public class org.osgeo.mapguide.MgIntCollection extends org.osgeo.mapguide.MgCollection {
- public org.osgeo.mapguide.MgIntCollection();
- public int getItem(int);
- public void setItem(int, int);
- public void addItem(int);
- public void insert(int, int);
- public boolean remove(int);
- public boolean contains(int);
- public int indexOf(int);
-Compiled from "MgKmlService.java"
-public class org.osgeo.mapguide.MgKmlService extends org.osgeo.mapguide.MgService {
- public org.osgeo.mapguide.MgByteReader getMapKml(org.osgeo.mapguide.MgMap, double, java.lang.String, java.lang.String);
- public org.osgeo.mapguide.MgByteReader getLayerKml(org.osgeo.mapguide.MgLayer, org.osgeo.mapguide.MgEnvelope, int, int, double, int, java.lang.String, java.lang.String);
- public org.osgeo.mapguide.MgByteReader getFeaturesKml(org.osgeo.mapguide.MgLayer, org.osgeo.mapguide.MgEnvelope, int, int, double, int, java.lang.String);
- public org.osgeo.mapguide.MgByteReader getFeaturesKml(org.osgeo.mapguide.MgLayer, org.osgeo.mapguide.MgEnvelope, int, int, double, int, java.lang.String, java.lang.String);
-Compiled from "MgLayer.java"
-public class org.osgeo.mapguide.MgLayer extends org.osgeo.mapguide.MgLayerBase {
- public org.osgeo.mapguide.MgLayer(org.osgeo.mapguide.MgResourceIdentifier, org.osgeo.mapguide.MgResourceService);
- public org.osgeo.mapguide.MgFeatureReader selectFeatures(org.osgeo.mapguide.MgFeatureQueryOptions);
- public org.osgeo.mapguide.MgFeatureReader selectFeatures(org.osgeo.mapguide.MgFeatureQueryOptions, java.lang.String);
- public org.osgeo.mapguide.MgDataReader selectAggregate(org.osgeo.mapguide.MgFeatureAggregateOptions);
- public org.osgeo.mapguide.MgPropertyCollection updateFeatures(org.osgeo.mapguide.MgFeatureCommandCollection);
- public org.osgeo.mapguide.MgTransaction beginTransaction();
- public org.osgeo.mapguide.MgPropertyCollection updateFeatures(org.osgeo.mapguide.MgFeatureCommandCollection, org.osgeo.mapguide.MgTransaction);
- public org.osgeo.mapguide.MgFeatureReader insertFeatures(org.osgeo.mapguide.MgPropertyCollection, org.osgeo.mapguide.MgTransaction);
- public org.osgeo.mapguide.MgFeatureReader insertFeatures(org.osgeo.mapguide.MgBatchPropertyCollection, org.osgeo.mapguide.MgTransaction);
- public int updateMatchingFeatures(org.osgeo.mapguide.MgPropertyCollection, java.lang.String, org.osgeo.mapguide.MgTransaction);
- public int deleteFeatures(java.lang.String, org.osgeo.mapguide.MgTransaction);
- public org.osgeo.mapguide.MgIntCollection getGeometryTypeStyles();
- public int getThemeCategoryCount(int);
- public int getCompositeThemeCategoryCount(int);
- public org.osgeo.mapguide.MgByteReader generateLegendImage(int, int, java.lang.String, int, int);
- public org.osgeo.mapguide.MgIntCollection getGeometryTypeStyles(double);
- public int getThemeCategoryCount(double, int);
- public int getCompositeThemeCategoryCount(double, int);
- public org.osgeo.mapguide.MgByteReader generateLegendImage(double, int, int, java.lang.String, int, int);
- public org.osgeo.mapguide.MgSpatialContextReader getSpatialContexts(boolean);
-Compiled from "MgLayerBase.java"
-public class org.osgeo.mapguide.MgLayerBase extends org.osgeo.mapguide.MgNamedSerializable {
- public org.osgeo.mapguide.MgLayerBase(org.osgeo.mapguide.MgResourceIdentifier, org.osgeo.mapguide.MgResourceService);
- public java.lang.String getObjectId();
- public int getLayerType();
- public org.osgeo.mapguide.MgLayerGroup getGroup();
- public void setGroup(org.osgeo.mapguide.MgLayerGroup);
- public boolean needsRefresh();
- public void forceRefresh();
- public boolean getVisible();
- public void setVisible(boolean);
- public boolean isVisible();
- public boolean getSelectable();
- public void setSelectable(boolean);
- public org.osgeo.mapguide.MgResourceIdentifier getLayerDefinition();
- public void setLayerDefinition(org.osgeo.mapguide.MgResourceIdentifier, org.osgeo.mapguide.MgResourceService);
- public boolean getDisplayInLegend();
- public void setDisplayInLegend(boolean);
- public boolean getExpandInLegend();
- public java.lang.String getLegendLabel();
- public void setLegendLabel(java.lang.String);
- public java.lang.String getFeatureSourceId();
- public java.lang.String getFilter();
- public java.lang.String getFeatureGeometryName();
-Compiled from "MgLayerCollection.java"
-class org.osgeo.mapguide.MgLayerCollection$ItemIterator implements java.util.Iterator<org.osgeo.mapguide.MgLayerBase> {
- public org.osgeo.mapguide.MgLayerCollection$ItemIterator(org.osgeo.mapguide.MgLayerCollection, org.osgeo.mapguide.MgLayerCollection);
- public org.osgeo.mapguide.MgLayerBase next();
-public class org.osgeo.mapguide.MgLayerCollection extends org.osgeo.mapguide.MgGuardDisposable implements java.util.Collection<org.osgeo.mapguide.MgLayerBase> {
- public java.util.Iterator<org.osgeo.mapguide.MgLayerBase> iterator();
- public boolean add(org.osgeo.mapguide.MgLayerBase);
- public boolean addAll(java.util.Collection<? extends org.osgeo.mapguide.MgLayerBase>);
- public <MgLayerBase> MgLayerBase[] toArray(MgLayerBase[]);
- public org.osgeo.mapguide.MgLayerBase getItem(int);
- public org.osgeo.mapguide.MgLayerBase getItem(java.lang.String);
- public void setItem(int, org.osgeo.mapguide.MgLayerBase);
- public void addItem(org.osgeo.mapguide.MgLayerBase);
- public void insert(int, org.osgeo.mapguide.MgLayerBase);
- public boolean remove(org.osgeo.mapguide.MgLayerBase);
- public boolean contains(java.lang.String);
- public boolean contains(org.osgeo.mapguide.MgLayerBase);
- public int indexOf(java.lang.String);
- public int indexOf(org.osgeo.mapguide.MgLayerBase);
-Compiled from "MgLayerGroup.java"
-public class org.osgeo.mapguide.MgLayerGroup extends org.osgeo.mapguide.MgNamedSerializable {
- public org.osgeo.mapguide.MgLayerGroup(java.lang.String);
- public int getLayerGroupType();
- public void setExpandInLegend(boolean);
-Compiled from "MgLayerGroupCollection.java"
-class org.osgeo.mapguide.MgLayerGroupCollection$ItemIterator implements java.util.Iterator<org.osgeo.mapguide.MgLayerGroup> {
- public org.osgeo.mapguide.MgLayerGroupCollection$ItemIterator(org.osgeo.mapguide.MgLayerGroupCollection, org.osgeo.mapguide.MgLayerGroupCollection);
- public org.osgeo.mapguide.MgLayerGroup next();
-public class org.osgeo.mapguide.MgLayerGroupCollection extends org.osgeo.mapguide.MgGuardDisposable implements java.util.Collection<org.osgeo.mapguide.MgLayerGroup> {
- public java.util.Iterator<org.osgeo.mapguide.MgLayerGroup> iterator();
- public boolean add(org.osgeo.mapguide.MgLayerGroup);
- public boolean addAll(java.util.Collection<? extends org.osgeo.mapguide.MgLayerGroup>);
- public boolean isEmpty();
- public <MgLayerGroup> MgLayerGroup[] toArray(MgLayerGroup[]);
- public org.osgeo.mapguide.MgLayerGroup getItem(int);
- public org.osgeo.mapguide.MgLayerGroup getItem(java.lang.String);
- public void setItem(int, org.osgeo.mapguide.MgLayerGroup);
- public void addItem(org.osgeo.mapguide.MgLayerGroup);
- public void insert(int, org.osgeo.mapguide.MgLayerGroup);
- public boolean remove(org.osgeo.mapguide.MgLayerGroup);
- public boolean contains(org.osgeo.mapguide.MgLayerGroup);
- public int indexOf(org.osgeo.mapguide.MgLayerGroup);
-Compiled from "MgLayerGroupType.java"
-public class org.osgeo.mapguide.MgLayerGroupType {
- public static final int Normal = 1;
- public static final int BaseMap = 2;
- public static final int BaseMapFromTileSet = 3;
- public org.osgeo.mapguide.MgLayerGroupType();
-Compiled from "MgLayerType.java"
-public class org.osgeo.mapguide.MgLayerType {
- public static final int Dynamic = 1;
- public org.osgeo.mapguide.MgLayerType();
-Compiled from "MgLayout.java"
-public class org.osgeo.mapguide.MgLayout extends org.osgeo.mapguide.MgSerializable {
- public org.osgeo.mapguide.MgLayout(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, java.lang.String);
- public org.osgeo.mapguide.MgResourceIdentifier getLayout();
- public void setLayout(org.osgeo.mapguide.MgResourceIdentifier);
- public java.lang.String getTitle();
- public void setTitle(java.lang.String);
- public java.lang.String getUnitType();
- public void setUnitType(java.lang.String);
-Compiled from "MgLinearRing.java"
-public class org.osgeo.mapguide.MgLinearRing extends org.osgeo.mapguide.MgRing {
- public int getComponentType();
- public org.osgeo.mapguide.MgCoordinateIterator getCoordinates();
- public int getDimension();
- public boolean isClosed();
- public org.osgeo.mapguide.MgGeometricEntity copy();
- public org.osgeo.mapguide.MgGeometricEntity transform(org.osgeo.mapguide.MgTransform);
-Compiled from "MgLinearRingCollection.java"
-public class org.osgeo.mapguide.MgLinearRingCollection extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgLinearRing getItem(int);
- public void setItem(int, org.osgeo.mapguide.MgLinearRing);
- public void add(org.osgeo.mapguide.MgLinearRing);
- public void insert(int, org.osgeo.mapguide.MgLinearRing);
- public boolean remove(org.osgeo.mapguide.MgLinearRing);
- public boolean contains(org.osgeo.mapguide.MgLinearRing);
- public int indexOf(org.osgeo.mapguide.MgLinearRing);
- public org.osgeo.mapguide.MgLinearRingCollection();
-Compiled from "MgLinearSegment.java"
-public class org.osgeo.mapguide.MgLinearSegment extends org.osgeo.mapguide.MgCurveSegment {
- public org.osgeo.mapguide.MgCoordinate getStartCoordinate();
- public org.osgeo.mapguide.MgCoordinate getEndCoordinate();
-Compiled from "MgLineString.java"
-public class org.osgeo.mapguide.MgLineString extends org.osgeo.mapguide.MgCurve {
- public int getGeometryType();
-Compiled from "MgLineStringCollection.java"
-public class org.osgeo.mapguide.MgLineStringCollection extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgLineString getItem(int);
- public void setItem(int, org.osgeo.mapguide.MgLineString);
- public void add(org.osgeo.mapguide.MgLineString);
- public void insert(int, org.osgeo.mapguide.MgLineString);
- public boolean remove(org.osgeo.mapguide.MgLineString);
- public boolean contains(org.osgeo.mapguide.MgLineString);
- public int indexOf(org.osgeo.mapguide.MgLineString);
- public org.osgeo.mapguide.MgLineStringCollection();
-Compiled from "MgLocalizer.java"
-public class org.osgeo.mapguide.MgLocalizer {
- public org.osgeo.mapguide.MgLocalizer();
- public static void SetLocalizedFilesPath(java.lang.String);
- public static java.lang.String Localize(java.lang.String, java.lang.String, int);
- public static java.lang.String GetString(java.lang.String, java.lang.String);
-Compiled from "MgLogFileType.java"
-public class org.osgeo.mapguide.MgLogFileType {
- public static final java.lang.String Access = "AccessLog";
- public static final java.lang.String Admin = "AdminLog";
- public static final java.lang.String Authentication = "AuthenticationLog";
- public static final java.lang.String Error = "ErrorLog";
- public static final java.lang.String Session = "SessionLog";
- public static final java.lang.String Trace = "TraceLog";
- public org.osgeo.mapguide.MgLogFileType();
-Compiled from "MgLongTransactionReader.java"
-public class org.osgeo.mapguide.MgLongTransactionReader extends org.osgeo.mapguide.MgSerializable implements java.lang.AutoCloseable {
- public java.lang.String getDescription();
- public org.osgeo.mapguide.MgLongTransactionReader getChildren();
- public org.osgeo.mapguide.MgLongTransactionReader getParents();
- public java.lang.String getOwner();
- public org.osgeo.mapguide.MgDateTime getCreationDate();
- public boolean isActive();
- public boolean isFrozen();
- public boolean readNext();
- public void close();
-Compiled from "MgMap.java"
-public final class org.osgeo.mapguide.MgMap$WatermarkUsageType {
- public static final org.osgeo.mapguide.MgMap$WatermarkUsageType WMS;
- public static final org.osgeo.mapguide.MgMap$WatermarkUsageType Viewer;
- public final int swigValue();
- public java.lang.String toString();
- public static org.osgeo.mapguide.MgMap$WatermarkUsageType swigToEnum(int);
-public class org.osgeo.mapguide.MgMap extends org.osgeo.mapguide.MgMapBase {
- public org.osgeo.mapguide.MgMap(org.osgeo.mapguide.MgSiteConnection);
- public void create(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String);
- public void create(java.lang.String, org.osgeo.mapguide.MgEnvelope, java.lang.String);
- public void create(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, int, int, double, double, double, int);
- public void open(java.lang.String);
- public void save(org.osgeo.mapguide.MgResourceService, org.osgeo.mapguide.MgResourceIdentifier);
- public void save();
- public int getWatermarkUsage();
- public org.osgeo.mapguide.MgResourceIdentifier getTileSetDefinition();
- public java.lang.String getTileSetProvider();
- public int getTilePixelRatio();
- public java.lang.String getTileFormat();
-Compiled from "MgMapBase.java"
-public class org.osgeo.mapguide.MgMapBase extends org.osgeo.mapguide.MgResource {
- public org.osgeo.mapguide.MgMapBase();
- public java.lang.String getSessionId();
- public org.osgeo.mapguide.MgResourceIdentifier getMapDefinition();
- public java.lang.String getMapSRS();
- public org.osgeo.mapguide.MgEnvelope getMapExtent();
- public org.osgeo.mapguide.MgLayerCollection getLayers();
- public org.osgeo.mapguide.MgLayerGroupCollection getLayerGroups();
- public void create(org.osgeo.mapguide.MgResourceService, org.osgeo.mapguide.MgResourceIdentifier, java.lang.String);
- public void open(org.osgeo.mapguide.MgResourceService, java.lang.String);
- public org.osgeo.mapguide.MgPoint getViewCenter();
- public double getViewScale();
- public org.osgeo.mapguide.MgEnvelope getDataExtent();
- public int getDisplayDpi();
- public void setDisplayDpi(int);
- public int getDisplayWidth();
- public int getDisplayHeight();
- public int getFiniteDisplayScaleCount();
- public double getFiniteDisplayScaleAt(int);
- public java.lang.String getBackgroundColor();
-Compiled from "MgMapCollection.java"
-public class org.osgeo.mapguide.MgMapCollection extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgMapBase getItem(int);
- public org.osgeo.mapguide.MgMapBase getItem(java.lang.String);
- public void setItem(int, org.osgeo.mapguide.MgMapBase);
- public void add(org.osgeo.mapguide.MgMapBase);
- public void insert(int, org.osgeo.mapguide.MgMapBase);
- public boolean remove(org.osgeo.mapguide.MgMapBase);
- public boolean contains(org.osgeo.mapguide.MgMapBase);
- public int indexOf(org.osgeo.mapguide.MgMapBase);
- public org.osgeo.mapguide.MgMapCollection();
-Compiled from "MgMappingService.java"
-public class org.osgeo.mapguide.MgMappingService extends org.osgeo.mapguide.MgService {
- public org.osgeo.mapguide.MgByteReader generatePlot(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgPlotSpecification, org.osgeo.mapguide.MgLayout, org.osgeo.mapguide.MgDwfVersion);
- public org.osgeo.mapguide.MgByteReader generatePlot(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgCoordinate, double, org.osgeo.mapguide.MgPlotSpecification, org.osgeo.mapguide.MgLayout, org.osgeo.mapguide.MgDwfVersion);
- public org.osgeo.mapguide.MgByteReader generatePlot(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgEnvelope, boolean, org.osgeo.mapguide.MgPlotSpecification, org.osgeo.mapguide.MgLayout, org.osgeo.mapguide.MgDwfVersion);
- public org.osgeo.mapguide.MgByteReader generateMultiPlot(org.osgeo.mapguide.MgMapPlotCollection, org.osgeo.mapguide.MgDwfVersion);
- public org.osgeo.mapguide.MgByteReader generateLegendImage(org.osgeo.mapguide.MgResourceIdentifier, double, int, int, java.lang.String, int, int);
- public org.osgeo.mapguide.MgByteReader createRuntimeMap(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, int, int);
- public org.osgeo.mapguide.MgByteReader createRuntimeMap(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, java.lang.String, java.lang.String, int, int, int, int);
- public org.osgeo.mapguide.MgByteReader describeRuntimeMap(org.osgeo.mapguide.MgMap, int, int);
- public org.osgeo.mapguide.MgByteReader describeRuntimeMap(org.osgeo.mapguide.MgMap, java.lang.String, int, int, int, int);
- public org.osgeo.mapguide.MgByteReader queryFeatures(org.osgeo.mapguide.MgMap, java.lang.String, java.lang.String);
- public org.osgeo.mapguide.MgByteReader queryFeatures(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgStringCollection, int, int, int, java.lang.String);
-Compiled from "MgMapPlot.java"
-public class org.osgeo.mapguide.MgMapPlot extends org.osgeo.mapguide.MgNamedSerializable {
- public org.osgeo.mapguide.MgMapPlot(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgPlotSpecification, org.osgeo.mapguide.MgLayout);
- public org.osgeo.mapguide.MgMapPlot(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgCoordinate, double, org.osgeo.mapguide.MgPlotSpecification, org.osgeo.mapguide.MgLayout);
- public org.osgeo.mapguide.MgMapPlot(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgEnvelope, boolean, org.osgeo.mapguide.MgPlotSpecification, org.osgeo.mapguide.MgLayout);
- public org.osgeo.mapguide.MgMap getMap();
- public void setMap(org.osgeo.mapguide.MgMap);
- public int getMapPlotInstruction();
- public void setMapPlotInstruction(int);
- public org.osgeo.mapguide.MgCoordinate getCenter();
- public double getScale();
- public void setCenterAndScale(org.osgeo.mapguide.MgCoordinate, double);
- public org.osgeo.mapguide.MgEnvelope getExtent();
- public boolean getExpandToFit();
- public void setExtent(org.osgeo.mapguide.MgEnvelope, boolean);
- public org.osgeo.mapguide.MgPlotSpecification getPlotSpecification();
- public void setPlotSpecification(org.osgeo.mapguide.MgPlotSpecification);
- public org.osgeo.mapguide.MgLayout getLayout();
- public void setLayout(org.osgeo.mapguide.MgLayout);
-Compiled from "MgMapPlotCollection.java"
-public class org.osgeo.mapguide.MgMapPlotCollection extends org.osgeo.mapguide.MgSerializable {
- public org.osgeo.mapguide.MgMapPlot getItem(int);
- public org.osgeo.mapguide.MgMapPlot getItem(java.lang.String);
- public void setItem(int, org.osgeo.mapguide.MgMapPlot);
- public void add(org.osgeo.mapguide.MgMapPlot);
- public void insert(int, org.osgeo.mapguide.MgMapPlot);
- public boolean remove(org.osgeo.mapguide.MgMapPlot);
- public boolean contains(org.osgeo.mapguide.MgMapPlot);
- public int indexOf(org.osgeo.mapguide.MgMapPlot);
- public org.osgeo.mapguide.MgMapPlotCollection();
-Compiled from "MgMapPlotInstruction.java"
-public class org.osgeo.mapguide.MgMapPlotInstruction {
- public static final int UseMapCenterAndScale = 0;
- public static final int UseOverriddenCenterAndScale = 1;
- public static final int UseOverriddenExtent = 2;
- public org.osgeo.mapguide.MgMapPlotInstruction();
-Compiled from "MgMeasure.java"
-public class org.osgeo.mapguide.MgMeasure extends org.osgeo.mapguide.MgGuardDisposable {
- public double getDistance(org.osgeo.mapguide.MgCoordinate, org.osgeo.mapguide.MgCoordinate);
- public double getAzimuth(org.osgeo.mapguide.MgCoordinate, org.osgeo.mapguide.MgCoordinate);
- public org.osgeo.mapguide.MgCoordinate getCoordinate(org.osgeo.mapguide.MgCoordinate, double, double);
-Compiled from "MgMetatile.java"
-public class org.osgeo.mapguide.MgMetatile extends org.osgeo.mapguide.MgSerializable {
- public org.osgeo.mapguide.MgByteReader getImage();
- public int getRequestedWidth();
- public int getRequestedHeight();
- public int getWidth();
- public int getHeight();
- public int getMetaTilingFactor();
- public java.lang.String getTileImageFormat();
-Compiled from "MgMimeType.java"
-public class org.osgeo.mapguide.MgMimeType {
- public static final java.lang.String Agf = "application/agf";
- public static final java.lang.String Binary = "application/octet-stream";
- public static final java.lang.String Dwf = "model/vnd.dwf";
- public static final java.lang.String Gif = "image/gif";
- public static final java.lang.String Jpeg = "image/jpeg";
- public static final java.lang.String Png = "image/png";
- public static final java.lang.String Text = "text/plain";
- public static final java.lang.String Tiff = "image/tiff";
- public static final java.lang.String Xml = "text/xml";
- public static final java.lang.String Json = "application/json";
- public static final java.lang.String Html = "text/html";
- public static final java.lang.String Kml = "application/vnd.google-earth.kml+xml";
- public static final java.lang.String Kmz = "application/vnd.google-earth.kmz";
- public static final java.lang.String Meta = "application/metatile";
- public org.osgeo.mapguide.MgMimeType();
-Compiled from "MgMultiCurvePolygon.java"
-public class org.osgeo.mapguide.MgMultiCurvePolygon extends org.osgeo.mapguide.MgAggregateGeometry {
- public org.osgeo.mapguide.MgCurvePolygon getCurvePolygon(int);
-Compiled from "MgMultiCurveString.java"
-public class org.osgeo.mapguide.MgMultiCurveString extends org.osgeo.mapguide.MgAggregateGeometry {
- public org.osgeo.mapguide.MgCurveString getCurveString(int);
-Compiled from "MgMultiGeometry.java"
-public class org.osgeo.mapguide.MgMultiGeometry extends org.osgeo.mapguide.MgAggregateGeometry {
- public org.osgeo.mapguide.MgGeometry getGeometry(int);
-Compiled from "MgMultiLineString.java"
-public class org.osgeo.mapguide.MgMultiLineString extends org.osgeo.mapguide.MgAggregateGeometry {
- public org.osgeo.mapguide.MgLineString getLineString(int);
-Compiled from "MgMultiPoint.java"
-public class org.osgeo.mapguide.MgMultiPoint extends org.osgeo.mapguide.MgAggregateGeometry {
- public org.osgeo.mapguide.MgPoint getPoint(int);
-Compiled from "MgMultiPolygon.java"
-public class org.osgeo.mapguide.MgMultiPolygon extends org.osgeo.mapguide.MgAggregateGeometry {
- public org.osgeo.mapguide.MgPolygon getPolygon(int);
-Compiled from "MgNamedSerializable.java"
-public class org.osgeo.mapguide.MgNamedSerializable extends org.osgeo.mapguide.MgSerializable {
-Compiled from "MgNullableProperty.java"
-public class org.osgeo.mapguide.MgNullableProperty extends org.osgeo.mapguide.MgProperty {
- public void setNull(boolean);
- public boolean isNull();
-Compiled from "MgObject.java"
-public class org.osgeo.mapguide.MgObject {
- public int getClassId();
-Compiled from "MgObjectPropertyDefinition.java"
-public class org.osgeo.mapguide.MgObjectPropertyDefinition extends org.osgeo.mapguide.MgPropertyDefinition {
- public org.osgeo.mapguide.MgObjectPropertyDefinition(java.lang.String);
- public int getObjectType();
- public int getOrderType();
- public org.osgeo.mapguide.MgDataPropertyDefinition getIdentityProperty();
- public void setClassDefinition(org.osgeo.mapguide.MgClassDefinition);
- public void setObjectType(int);
- public void setOrderType(int);
- public void setIdentityProperty(org.osgeo.mapguide.MgDataPropertyDefinition);
-Compiled from "MgObjectPropertyType.java"
-public class org.osgeo.mapguide.MgObjectPropertyType {
- public static final int Value = 0;
- public static final int Collection = 1;
- public static final int OrderedCollection = 2;
- public org.osgeo.mapguide.MgObjectPropertyType();
-Compiled from "MgOrderingOption.java"
-public class org.osgeo.mapguide.MgOrderingOption {
- public static final int Ascending = 0;
- public static final int Descending = 1;
- public org.osgeo.mapguide.MgOrderingOption();
-Compiled from "MgPackageStatusInformation.java"
-public class org.osgeo.mapguide.MgPackageStatusInformation extends org.osgeo.mapguide.MgSerializable {
- public org.osgeo.mapguide.MgPackageStatusInformation();
- public java.lang.String getStatusMessage();
- public java.lang.String getStatusCode();
- public void setStatusCode(java.lang.String);
- public java.lang.String getApiName();
- public void setApiName(java.lang.String);
- public java.lang.String getPackageName();
- public void setPackageName(java.lang.String);
- public java.lang.String getPackageDescription();
- public void setPackageDescription(java.lang.String);
- public org.osgeo.mapguide.MgDateTime getPackageDate();
- public void setPackageDate(org.osgeo.mapguide.MgDateTime);
- public long getPackageSize();
- public void setPackageSize(long);
- public java.lang.String getUserName();
- public void setUserName(java.lang.String);
- public java.lang.String getServerName();
- public void setServerName(java.lang.String);
- public java.lang.String getServerAddress();
- public void setServerAddress(java.lang.String);
- public org.osgeo.mapguide.MgDateTime getStartTime();
- public void setStartTime(org.osgeo.mapguide.MgDateTime);
- public org.osgeo.mapguide.MgDateTime getEndTime();
- public void setEndTime(org.osgeo.mapguide.MgDateTime);
- public int getOperationsFailed();
- public void setOperationsFailed(int);
- public int getOperationsReceived();
- public void setOperationsReceived(int);
- public double getAverageOperationTime();
- public java.lang.String getStackTrace();
- public void setStackTrace(java.lang.String);
-Compiled from "MgPageUnitsType.java"
-public class org.osgeo.mapguide.MgPageUnitsType {
- public static final java.lang.String Inches = "in";
- public static final java.lang.String Millimeters = "mm";
- public org.osgeo.mapguide.MgPageUnitsType();
-Compiled from "MgParameter.java"
-public class org.osgeo.mapguide.MgParameter extends org.osgeo.mapguide.MgNamedSerializable {
- public org.osgeo.mapguide.MgParameter(org.osgeo.mapguide.MgNullableProperty);
- public org.osgeo.mapguide.MgParameter(org.osgeo.mapguide.MgNullableProperty, int);
- public void setProperty(org.osgeo.mapguide.MgNullableProperty);
- public org.osgeo.mapguide.MgNullableProperty getProperty();
- public void setDirection(int);
- public int getDirection();
-Compiled from "MgParameterCollection.java"
-public class org.osgeo.mapguide.MgParameterCollection extends org.osgeo.mapguide.MgCollection {
- public org.osgeo.mapguide.MgParameterCollection();
- public void setItem(int, org.osgeo.mapguide.MgParameter);
- public void add(org.osgeo.mapguide.MgParameter);
- public void insert(int, org.osgeo.mapguide.MgParameter);
- public boolean remove(org.osgeo.mapguide.MgParameter);
- public org.osgeo.mapguide.MgParameter getItem(int);
- public boolean contains(org.osgeo.mapguide.MgParameter);
- public int indexOf(org.osgeo.mapguide.MgParameter);
- public org.osgeo.mapguide.MgByteReader toXml();
-Compiled from "MgParameterDirection.java"
-public class org.osgeo.mapguide.MgParameterDirection {
- public static final int Input = 0;
- public static final int Output = 1;
- public static final int InputOutput = 2;
- public static final int Ret = 3;
- public org.osgeo.mapguide.MgParameterDirection();
-Compiled from "MgPlotSpecification.java"
-public class org.osgeo.mapguide.MgPlotSpecification extends org.osgeo.mapguide.MgSerializable {
- public org.osgeo.mapguide.MgPlotSpecification(float, float, java.lang.String, float, float, float, float);
- public org.osgeo.mapguide.MgPlotSpecification(float, float, java.lang.String, float, float, float);
- public org.osgeo.mapguide.MgPlotSpecification(float, float, java.lang.String, float, float);
- public org.osgeo.mapguide.MgPlotSpecification(float, float, java.lang.String, float);
- public org.osgeo.mapguide.MgPlotSpecification(float, float, java.lang.String);
- public float getPaperWidth();
- public void setPaperWidth(float);
- public float getPaperHeight();
- public void setPaperHeight(float);
- public java.lang.String getPageSizeUnits();
- public void setPageSizeUnits(java.lang.String);
- public float getMarginLeft();
- public float getMarginTop();
- public float getMarginRight();
- public float getMarginBottom();
- public void setMargins(float, float, float, float);
-Compiled from "MgPoint.java"
-public class org.osgeo.mapguide.MgPoint extends org.osgeo.mapguide.MgGeometry {
- public org.osgeo.mapguide.MgCoordinate getCoordinate();
-Compiled from "MgPointCollection.java"
-public class org.osgeo.mapguide.MgPointCollection extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgPoint getItem(int);
- public void setItem(int, org.osgeo.mapguide.MgPoint);
- public void add(org.osgeo.mapguide.MgPoint);
- public void insert(int, org.osgeo.mapguide.MgPoint);
- public boolean remove(org.osgeo.mapguide.MgPoint);
- public boolean contains(org.osgeo.mapguide.MgPoint);
- public int indexOf(org.osgeo.mapguide.MgPoint);
- public org.osgeo.mapguide.MgPointCollection();
-Compiled from "MgPolygon.java"
-public class org.osgeo.mapguide.MgPolygon extends org.osgeo.mapguide.MgRegion {
- public org.osgeo.mapguide.MgLinearRing getExteriorRing();
- public int getInteriorRingCount();
- public org.osgeo.mapguide.MgLinearRing getInteriorRing(int);
-Compiled from "MgPolygonCollection.java"
-public class org.osgeo.mapguide.MgPolygonCollection extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgPolygon getItem(int);
- public void setItem(int, org.osgeo.mapguide.MgPolygon);
- public void add(org.osgeo.mapguide.MgPolygon);
- public void insert(int, org.osgeo.mapguide.MgPolygon);
- public boolean remove(org.osgeo.mapguide.MgPolygon);
- public boolean contains(org.osgeo.mapguide.MgPolygon);
- public int indexOf(org.osgeo.mapguide.MgPolygon);
- public org.osgeo.mapguide.MgPolygonCollection();
-Compiled from "MgPreparedGeometry.java"
-public class org.osgeo.mapguide.MgPreparedGeometry extends org.osgeo.mapguide.MgGuardDisposable {
-Compiled from "MgProfilingService.java"
-public class org.osgeo.mapguide.MgProfilingService extends org.osgeo.mapguide.MgService {
- public org.osgeo.mapguide.MgByteReader profileRenderDynamicOverlay(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgSelection, org.osgeo.mapguide.MgRenderingOptions);
- public org.osgeo.mapguide.MgByteReader profileRenderMap(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgSelection, org.osgeo.mapguide.MgCoordinate, double, int, int, org.osgeo.mapguide.MgColor, java.lang.String, boolean);
-Compiled from "MgProperty.java"
-public class org.osgeo.mapguide.MgProperty extends org.osgeo.mapguide.MgNamedSerializable {
- public short getPropertyType();
-Compiled from "MgPropertyCollection.java"
-class org.osgeo.mapguide.MgPropertyCollection$ItemIterator implements java.util.Iterator<org.osgeo.mapguide.MgProperty> {
- public org.osgeo.mapguide.MgPropertyCollection$ItemIterator(org.osgeo.mapguide.MgPropertyCollection, org.osgeo.mapguide.MgPropertyCollection);
- public org.osgeo.mapguide.MgProperty next();
-public class org.osgeo.mapguide.MgPropertyCollection extends org.osgeo.mapguide.MgCollection implements java.util.Collection<org.osgeo.mapguide.MgProperty> {
- public java.util.Iterator<org.osgeo.mapguide.MgProperty> iterator();
- public boolean add(org.osgeo.mapguide.MgProperty);
- public boolean addAll(java.util.Collection<? extends org.osgeo.mapguide.MgProperty>);
- public <MgProperty> MgProperty[] toArray(MgProperty[]);
- public org.osgeo.mapguide.MgPropertyCollection();
- public void setItem(int, org.osgeo.mapguide.MgProperty);
- public void addItem(org.osgeo.mapguide.MgProperty);
- public void insert(int, org.osgeo.mapguide.MgProperty);
- public boolean remove(org.osgeo.mapguide.MgProperty);
- public org.osgeo.mapguide.MgProperty getItem(int);
- public org.osgeo.mapguide.MgProperty getItem(java.lang.String);
- public boolean contains(org.osgeo.mapguide.MgProperty);
- public int indexOf(org.osgeo.mapguide.MgProperty);
-Compiled from "MgPropertyDefinition.java"
-public class org.osgeo.mapguide.MgPropertyDefinition extends org.osgeo.mapguide.MgProperty {
- public org.osgeo.mapguide.MgPropertyDefinition(java.lang.String, short);
- public void setDescription(java.lang.String);
- public void setQualifiedName(java.lang.String);
- public java.lang.String getQualifiedName();
-Compiled from "MgPropertyDefinitionCollection.java"
-class org.osgeo.mapguide.MgPropertyDefinitionCollection$ItemIterator implements java.util.Iterator<org.osgeo.mapguide.MgPropertyDefinition> {
- public org.osgeo.mapguide.MgPropertyDefinitionCollection$ItemIterator(org.osgeo.mapguide.MgPropertyDefinitionCollection, org.osgeo.mapguide.MgPropertyDefinitionCollection);
- public org.osgeo.mapguide.MgPropertyDefinition next();
-public class org.osgeo.mapguide.MgPropertyDefinitionCollection extends org.osgeo.mapguide.MgCollection implements java.util.Collection<org.osgeo.mapguide.MgPropertyDefinition> {
- public java.util.Iterator<org.osgeo.mapguide.MgPropertyDefinition> iterator();
- public boolean add(org.osgeo.mapguide.MgPropertyDefinition);
- public boolean addAll(java.util.Collection<? extends org.osgeo.mapguide.MgPropertyDefinition>);
- public <MgPropertyDefinition> MgPropertyDefinition[] toArray(MgPropertyDefinition[]);
- public org.osgeo.mapguide.MgPropertyDefinitionCollection();
- public void setItem(int, org.osgeo.mapguide.MgPropertyDefinition);
- public void addItem(org.osgeo.mapguide.MgPropertyDefinition);
- public void insert(int, org.osgeo.mapguide.MgPropertyDefinition);
- public boolean remove(org.osgeo.mapguide.MgPropertyDefinition);
- public org.osgeo.mapguide.MgPropertyDefinition getItem(int);
- public org.osgeo.mapguide.MgPropertyDefinition getItem(java.lang.String);
- public boolean contains(org.osgeo.mapguide.MgPropertyDefinition);
- public int indexOf(org.osgeo.mapguide.MgPropertyDefinition);
-Compiled from "MgPropertyType.java"
-public class org.osgeo.mapguide.MgPropertyType {
- public static final int Null = 0;
- public static final int Boolean = 1;
- public static final int Byte = 2;
- public static final int DateTime = 3;
- public static final int Single = 4;
- public static final int Double = 5;
- public static final int Int16 = 6;
- public static final int Int32 = 7;
- public static final int Int64 = 8;
- public static final int String = 9;
- public static final int Blob = 10;
- public static final int Clob = 11;
- public static final int Feature = 12;
- public static final int Geometry = 13;
- public static final int Raster = 14;
- public static final int Decimal = 15;
- public org.osgeo.mapguide.MgPropertyType();
-Compiled from "MgRaster.java"
-public class org.osgeo.mapguide.MgRaster extends org.osgeo.mapguide.MgSerializable {
- public synchronized void delete();
- public void setNull();
- public org.osgeo.mapguide.MgEnvelope getBounds();
- public int getImageXSize();
- public void setImageXSize(int);
- public int getImageYSize();
- public void setImageYSize(int);
- public org.osgeo.mapguide.MgByteReader getStream();
- public int getBitsPerPixel();
- public int getDataModelType();
- public int getNumberOfBands();
- public int getCurrentBand();
- public short getDataType();
- public java.lang.String getVerticalUnits();
- public int getNullValueType();
- public long getNullValue();
-Compiled from "MgRasterDataModelType.java"
-public class org.osgeo.mapguide.MgRasterDataModelType {
- public static final int Unknown = 0;
- public static final int Data = 1;
- public static final int Bitonal = 2;
- public static final int Gray = 3;
- public static final int RGB = 4;
- public static final int RGBA = 5;
- public static final int Palette = 6;
- public org.osgeo.mapguide.MgRasterDataModelType();
-Compiled from "MgRasterProperty.java"
-public class org.osgeo.mapguide.MgRasterProperty extends org.osgeo.mapguide.MgNullableProperty {
- public org.osgeo.mapguide.MgRasterProperty(java.lang.String, org.osgeo.mapguide.MgRaster);
- public org.osgeo.mapguide.MgRaster getValue();
- public void setValue(org.osgeo.mapguide.MgRaster);
-Compiled from "MgRasterPropertyDefinition.java"
-public class org.osgeo.mapguide.MgRasterPropertyDefinition extends org.osgeo.mapguide.MgPropertyDefinition {
- public org.osgeo.mapguide.MgRasterPropertyDefinition(java.lang.String);
- public boolean getReadOnly();
- public boolean getNullable();
- public int getDefaultImageXSize();
- public int getDefaultImageYSize();
- public void setReadOnly(boolean);
- public void setNullable(boolean);
- public void setDefaultImageXSize(int);
- public void setDefaultImageYSize(int);
-Compiled from "MgReader.java"
-public class org.osgeo.mapguide.MgReader extends org.osgeo.mapguide.MgSerializable implements java.lang.AutoCloseable {
- public int getPropertyCount();
- public java.lang.String getPropertyName(int);
- public int getPropertyType(java.lang.String);
- public int getPropertyType(int);
- public boolean isNull(java.lang.String);
- public boolean getBoolean(java.lang.String);
- public byte getByte(java.lang.String);
- public org.osgeo.mapguide.MgDateTime getDateTime(java.lang.String);
- public float getSingle(java.lang.String);
- public double getDouble(java.lang.String);
- public short getInt16(java.lang.String);
- public int getInt32(java.lang.String);
- public long getInt64(java.lang.String);
- public java.lang.String getString(java.lang.String);
- public org.osgeo.mapguide.MgByteReader getBLOB(java.lang.String);
- public org.osgeo.mapguide.MgByteReader getCLOB(java.lang.String);
- public org.osgeo.mapguide.MgByteReader getGeometry(java.lang.String);
- public org.osgeo.mapguide.MgRaster getRaster(java.lang.String);
- public int getPropertyIndex(java.lang.String);
- public boolean isNull(int);
- public boolean getBoolean(int);
- public byte getByte(int);
- public org.osgeo.mapguide.MgDateTime getDateTime(int);
- public float getSingle(int);
- public double getDouble(int);
- public short getInt16(int);
- public int getInt32(int);
- public long getInt64(int);
- public java.lang.String getString(int);
- public org.osgeo.mapguide.MgByteReader getBLOB(int);
- public org.osgeo.mapguide.MgByteReader getCLOB(int);
- public org.osgeo.mapguide.MgByteReader getGeometry(int);
- public org.osgeo.mapguide.MgRaster getRaster(int);
- public int getReaderType();
-Compiled from "MgReaderType.java"
-public class org.osgeo.mapguide.MgReaderType {
- public static final int FeatureReader = 0;
- public static final int DataReader = 1;
- public static final int SqlDataReader = 2;
- public org.osgeo.mapguide.MgReaderType();
-Compiled from "MgReadOnlyLayerCollection.java"
-class org.osgeo.mapguide.MgReadOnlyLayerCollection$ItemIterator implements java.util.Iterator<org.osgeo.mapguide.MgLayerBase> {
- public org.osgeo.mapguide.MgReadOnlyLayerCollection$ItemIterator(org.osgeo.mapguide.MgReadOnlyLayerCollection, org.osgeo.mapguide.MgReadOnlyLayerCollection);
- public boolean hasNext();
- public void remove();
- public java.lang.Object next();
-public class org.osgeo.mapguide.MgReadOnlyLayerCollection extends org.osgeo.mapguide.MgGuardDisposable implements java.lang.Iterable<org.osgeo.mapguide.MgLayerBase> {
-Compiled from "MgRegion.java"
-public class org.osgeo.mapguide.MgRegion extends org.osgeo.mapguide.MgGeometry {
- public org.osgeo.mapguide.MgPoint getPointInRegion();
-Compiled from "MgRenderingOptions.java"
-public class org.osgeo.mapguide.MgRenderingOptions extends org.osgeo.mapguide.MgSerializable {
- public static final int RenderSelection;
- public static final int RenderLayers;
- public static final int KeepSelection;
- public static final int RenderBaseLayers;
- public org.osgeo.mapguide.MgRenderingOptions(java.lang.String, int, org.osgeo.mapguide.MgColor);
- public java.lang.String getImageFormat();
- public int getBehavior();
- public org.osgeo.mapguide.MgColor getSelectionColor();
-Compiled from "MgRenderingService.java"
-public class org.osgeo.mapguide.MgRenderingService extends org.osgeo.mapguide.MgService {
- public org.osgeo.mapguide.MgByteReader renderTile(org.osgeo.mapguide.MgMap, java.lang.String, int, int);
- public org.osgeo.mapguide.MgByteReader renderTile(org.osgeo.mapguide.MgMap, java.lang.String, int, int, int, int, int, java.lang.String);
- public org.osgeo.mapguide.MgByteReader renderTile(org.osgeo.mapguide.MgMap, java.lang.String, int, int, int, int, int, java.lang.String, double);
- public org.osgeo.mapguide.MgByteReader renderTileXYZ(org.osgeo.mapguide.MgMap, java.lang.String, int, int, int);
- public org.osgeo.mapguide.MgByteReader renderTileXYZ(org.osgeo.mapguide.MgMap, java.lang.String, int, int, int, int, java.lang.String);
- public org.osgeo.mapguide.MgByteReader renderTileXYZ(org.osgeo.mapguide.MgMap, java.lang.String, int, int, int, int, java.lang.String, double, int);
- public org.osgeo.mapguide.MgByteReader renderTileUTFGrid(org.osgeo.mapguide.MgMap, java.lang.String, int, int, int, int);
- public org.osgeo.mapguide.MgByteReader renderDynamicOverlay(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgSelection, java.lang.String);
- public org.osgeo.mapguide.MgByteReader renderDynamicOverlay(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgSelection, java.lang.String, boolean);
- public org.osgeo.mapguide.MgByteReader renderDynamicOverlay(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgSelection, org.osgeo.mapguide.MgRenderingOptions);
- public org.osgeo.mapguide.MgByteReader renderMap(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgSelection, java.lang.String);
- public org.osgeo.mapguide.MgByteReader renderMap(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgSelection, java.lang.String, boolean);
- public org.osgeo.mapguide.MgByteReader renderMap(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgSelection, java.lang.String, boolean, boolean);
- public org.osgeo.mapguide.MgByteReader renderMap(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgSelection, java.lang.String, boolean, boolean, org.osgeo.mapguide.MgColor);
- public org.osgeo.mapguide.MgByteReader renderMap(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgSelection, org.osgeo.mapguide.MgEnvelope, int, int, org.osgeo.mapguide.MgColor, java.lang.String);
- public org.osgeo.mapguide.MgByteReader renderMap(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgSelection, org.osgeo.mapguide.MgEnvelope, int, int, org.osgeo.mapguide.MgColor, java.lang.String, boolean);
- public org.osgeo.mapguide.MgByteReader renderMap(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgSelection, org.osgeo.mapguide.MgCoordinate, double, int, int, org.osgeo.mapguide.MgColor, java.lang.String);
- public org.osgeo.mapguide.MgByteReader renderMap(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgSelection, org.osgeo.mapguide.MgCoordinate, double, int, int, org.osgeo.mapguide.MgColor, java.lang.String, boolean);
- public org.osgeo.mapguide.MgByteReader renderMap(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgSelection, org.osgeo.mapguide.MgCoordinate, double, int, int, org.osgeo.mapguide.MgColor, java.lang.String, boolean, org.osgeo.mapguide.MgColor);
- public org.osgeo.mapguide.MgByteReader renderMapLegend(org.osgeo.mapguide.MgMap, int, int, org.osgeo.mapguide.MgColor, java.lang.String);
- public org.osgeo.mapguide.MgFeatureInformation queryFeatures(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgStringCollection, org.osgeo.mapguide.MgGeometry, int, int);
- public org.osgeo.mapguide.MgFeatureInformation queryFeatures(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgStringCollection, org.osgeo.mapguide.MgGeometry, int, java.lang.String, int, int);
- public org.osgeo.mapguide.MgBatchPropertyCollection queryFeatureProperties(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgStringCollection, org.osgeo.mapguide.MgGeometry, int, int);
- public org.osgeo.mapguide.MgBatchPropertyCollection queryFeatureProperties(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgStringCollection, org.osgeo.mapguide.MgGeometry, int, java.lang.String, int, int);
- public org.osgeo.mapguide.MgMetatile renderMetatile(org.osgeo.mapguide.MgMap, java.lang.String, int, int, int, int, int, java.lang.String, double, int);
- public org.osgeo.mapguide.MgMetatile renderMetatileXYZ(org.osgeo.mapguide.MgMap, java.lang.String, int, int, int, int, java.lang.String, double, int, int);
- public org.osgeo.mapguide.MgByteReader renderTileFromMetaTile(org.osgeo.mapguide.MgMap, org.osgeo.mapguide.MgMetatile, int, int);
-Compiled from "MgRepositoryType.java"
-public class org.osgeo.mapguide.MgRepositoryType {
- public static final java.lang.String Library = "Library";
- public static final java.lang.String Session = "Session";
- public org.osgeo.mapguide.MgRepositoryType();
-Compiled from "MgResource.java"
-public class org.osgeo.mapguide.MgResource extends org.osgeo.mapguide.MgNamedSerializable {
- public org.osgeo.mapguide.MgResourceIdentifier getResourceId();
- public void open(org.osgeo.mapguide.MgResourceService, org.osgeo.mapguide.MgResourceIdentifier);
- public void save(org.osgeo.mapguide.MgResourceService);
-Compiled from "MgResourceDataName.java"
-public class org.osgeo.mapguide.MgResourceDataName {
- public static final java.lang.String UserCredentials = "MG_USER_CREDENTIALS";
- public static final java.lang.String ProxyServerName = "MG_PROXY_SERVER";
- public static final java.lang.String ProxyServerPort = "MG_PROXY_PORT";
- public static final java.lang.String ProxyCredentials = "MG_PROXY_CREDENTIALS";
- public org.osgeo.mapguide.MgResourceDataName();
-Compiled from "MgResourceDataType.java"
-public class org.osgeo.mapguide.MgResourceDataType {
- public static final java.lang.String File = "File";
- public static final java.lang.String Stream = "Stream";
- public static final java.lang.String String = "String";
- public org.osgeo.mapguide.MgResourceDataType();
-Compiled from "MgResourceHeaderProperties.java"
-public class org.osgeo.mapguide.MgResourceHeaderProperties {
- public static final int General = 1;
- public static final int Security = 2;
- public static final int Metadata = 4;
- public org.osgeo.mapguide.MgResourceHeaderProperties();
-Compiled from "MgResourceIdentifier.java"
-public class org.osgeo.mapguide.MgResourceIdentifier extends org.osgeo.mapguide.MgSerializable {
- public org.osgeo.mapguide.MgResourceIdentifier(java.lang.String);
- public java.lang.String getRepositoryType();
- public void setRepositoryType(java.lang.String);
- public java.lang.String getRepositoryName();
- public void setRepositoryName(java.lang.String);
- public java.lang.String getPath();
- public void setPath(java.lang.String);
- public java.lang.String getName();
- public void setName(java.lang.String);
- public java.lang.String getResourceType();
- public void setResourceType(java.lang.String);
- public void validate();
-Compiled from "MgResourcePermission.java"
-public class org.osgeo.mapguide.MgResourcePermission {
- public static final java.lang.String PermissionNoAccess = "n";
- public static final java.lang.String PermissionReadOnly = "r";
- public static final java.lang.String PermissionReadWrite = "r,w";
- public org.osgeo.mapguide.MgResourcePermission();
-Compiled from "MgResourceService.java"
-public class org.osgeo.mapguide.MgResourceService extends org.osgeo.mapguide.MgService {
- public void updateRepository(org.osgeo.mapguide.MgResourceIdentifier, org.osgeo.mapguide.MgByteReader, org.osgeo.mapguide.MgByteReader);
- public void applyResourcePackage(org.osgeo.mapguide.MgByteReader);
- public org.osgeo.mapguide.MgByteReader enumerateResources(org.osgeo.mapguide.MgResourceIdentifier, int, java.lang.String);
- public org.osgeo.mapguide.MgByteReader enumerateResources(org.osgeo.mapguide.MgResourceIdentifier, int, java.lang.String, boolean);
- public void setResource(org.osgeo.mapguide.MgResourceIdentifier, org.osgeo.mapguide.MgByteReader, org.osgeo.mapguide.MgByteReader);
- public void deleteResource(org.osgeo.mapguide.MgResourceIdentifier);
- public void moveResource(org.osgeo.mapguide.MgResourceIdentifier, org.osgeo.mapguide.MgResourceIdentifier, boolean);
- public void moveResource(org.osgeo.mapguide.MgResourceIdentifier, org.osgeo.mapguide.MgResourceIdentifier, boolean, boolean);
- public void copyResource(org.osgeo.mapguide.MgResourceIdentifier, org.osgeo.mapguide.MgResourceIdentifier, boolean);
- public org.osgeo.mapguide.MgByteReader getResourceContent(org.osgeo.mapguide.MgResourceIdentifier);
- public org.osgeo.mapguide.MgStringCollection getResourceContents(org.osgeo.mapguide.MgStringCollection, org.osgeo.mapguide.MgStringCollection);
- public org.osgeo.mapguide.MgByteReader getResourceHeader(org.osgeo.mapguide.MgResourceIdentifier);
- public void changeResourceOwner(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, boolean);
- public void inheritPermissionsFrom(org.osgeo.mapguide.MgResourceIdentifier);
- public void setResourceData(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, java.lang.String, org.osgeo.mapguide.MgByteReader);
- public void deleteResourceData(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String);
- public void renameResourceData(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, java.lang.String, boolean);
- public org.osgeo.mapguide.MgByteReader getResourceData(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String);
- public org.osgeo.mapguide.MgByteReader enumerateResourceData(org.osgeo.mapguide.MgResourceIdentifier);
- public org.osgeo.mapguide.MgByteReader getRepositoryContent(org.osgeo.mapguide.MgResourceIdentifier);
- public org.osgeo.mapguide.MgByteReader getRepositoryHeader(org.osgeo.mapguide.MgResourceIdentifier);
- public org.osgeo.mapguide.MgByteReader enumerateReferences(org.osgeo.mapguide.MgResourceIdentifier);
- public boolean resourceExists(org.osgeo.mapguide.MgResourceIdentifier);
- public org.osgeo.mapguide.MgByteReader enumerateUnmanagedData(java.lang.String, boolean, java.lang.String, java.lang.String);
- public java.lang.String enumerateResourceDocuments(org.osgeo.mapguide.MgStringCollection, java.lang.String, int);
- public org.osgeo.mapguide.MgDateTime getResourceModifiedDate(org.osgeo.mapguide.MgResourceIdentifier);
- public void setResourceMetadata(org.osgeo.mapguide.MgResourceIdentifier, org.osgeo.mapguide.MgByteReader);
- public org.osgeo.mapguide.MgByteReader getResourceMetadata(org.osgeo.mapguide.MgResourceIdentifier);
-Compiled from "MgResourceTag.java"
-public class org.osgeo.mapguide.MgResourceTag {
- public static final java.lang.String LoginUsername = "%MG_LOGIN_USERNAME%";
- public static final java.lang.String LoginPassword = "%MG_LOGIN_PASSWORD%";
- public static final java.lang.String Username = "%MG_USERNAME%";
- public static final java.lang.String Password = "%MG_PASSWORD%";
- public static final java.lang.String ProxyServer = "%MG_PROXY_SERVER%";
- public static final java.lang.String ProxyPort = "%MG_PROXY_PORT%";
- public static final java.lang.String ProxyUsername = "%MG_PROXY_USERNAME%";
- public static final java.lang.String ProxyPassword = "%MG_PROXY_PASSWORD%";
- public static final java.lang.String DataFilePath = "%MG_DATA_FILE_PATH%";
- public static final java.lang.String TileCachePath = "%MG_TILE_CACHE_PATH%";
- public static final java.lang.String DataPathAliasBegin = "%MG_DATA_PATH_ALIAS[";
- public static final java.lang.String DataPathAliasEnd = "]%";
- public org.osgeo.mapguide.MgResourceTag();
-Compiled from "MgResourceType.java"
-public class org.osgeo.mapguide.MgResourceType {
- public static final java.lang.String Map = "Map";
- public static final java.lang.String MapDefinition = "MapDefinition";
- public static final java.lang.String LayerDefinition = "LayerDefinition";
- public static final java.lang.String DrawingSource = "DrawingSource";
- public static final java.lang.String FeatureSource = "FeatureSource";
- public static final java.lang.String Folder = "Folder";
- public static final java.lang.String LoadProcedure = "LoadProcedure";
- public static final java.lang.String PrintLayout = "PrintLayout";
- public static final java.lang.String Selection = "Selection";
- public static final java.lang.String SymbolDefinition = "SymbolDefinition";
- public static final java.lang.String SymbolLibrary = "SymbolLibrary";
- public static final java.lang.String WebLayout = "WebLayout";
- public static final java.lang.String ApplicationDefinition = "ApplicationDefinition";
- public static final java.lang.String WatermarkDefinition = "WatermarkDefinition";
- public static final java.lang.String TileSetDefinition = "TileSetDefinition";
- public org.osgeo.mapguide.MgResourceType();
-Compiled from "MgRing.java"
-public class org.osgeo.mapguide.MgRing extends org.osgeo.mapguide.MgGeometryComponent {
- public org.osgeo.mapguide.MgPoint getPointInRing();
-Compiled from "MgRole.java"
-public class org.osgeo.mapguide.MgRole {
- public static final java.lang.String Administrator = "Administrator";
- public static final java.lang.String Author = "Author";
- public static final java.lang.String Viewer = "Viewer";
- public org.osgeo.mapguide.MgRole();
-Compiled from "MgSelection.java"
-public class org.osgeo.mapguide.MgSelection extends org.osgeo.mapguide.MgSelectionBase {
- public org.osgeo.mapguide.MgSelection(org.osgeo.mapguide.MgMap);
- public org.osgeo.mapguide.MgSelection(org.osgeo.mapguide.MgMap, java.lang.String);
- public org.osgeo.mapguide.MgFeatureReader getSelectedFeatures(org.osgeo.mapguide.MgLayerBase, java.lang.String, boolean);
- public org.osgeo.mapguide.MgFeatureReader getSelectedFeatures(org.osgeo.mapguide.MgLayerBase, java.lang.String, org.osgeo.mapguide.MgStringCollection);
- public void save(org.osgeo.mapguide.MgResourceService, java.lang.String);
- public org.osgeo.mapguide.MgSelection();
-Compiled from "MgSelectionBase.java"
-public class org.osgeo.mapguide.MgSelectionBase extends org.osgeo.mapguide.MgResource {
- public org.osgeo.mapguide.MgSelectionBase(org.osgeo.mapguide.MgMapBase);
- public org.osgeo.mapguide.MgSelectionBase(org.osgeo.mapguide.MgMapBase, java.lang.String);
- public int getSelectedFeaturesCount(org.osgeo.mapguide.MgLayerBase, java.lang.String);
- public void fromXml(java.lang.String);
- public java.lang.String toXml();
- public void addFeatures(org.osgeo.mapguide.MgLayerBase, org.osgeo.mapguide.MgFeatureReader, int);
- public void addFeatureIds(org.osgeo.mapguide.MgLayerBase, java.lang.String, org.osgeo.mapguide.MgPropertyCollection);
- public void addFeatureIdInt16(org.osgeo.mapguide.MgLayerBase, java.lang.String, short);
- public void addFeatureIdInt32(org.osgeo.mapguide.MgLayerBase, java.lang.String, int);
- public void addFeatureIdInt64(org.osgeo.mapguide.MgLayerBase, java.lang.String, long);
- public void addFeatureIdString(org.osgeo.mapguide.MgLayerBase, java.lang.String, java.lang.String);
- public void addFeatureIdDouble(org.osgeo.mapguide.MgLayerBase, java.lang.String, double);
- public org.osgeo.mapguide.MgReadOnlyLayerCollection getLayers();
- public org.osgeo.mapguide.MgStringCollection getClasses(java.lang.String);
- public java.lang.String getClass(java.lang.String);
- public boolean contains(org.osgeo.mapguide.MgLayerBase, java.lang.String);
- public java.lang.String generateFilter(org.osgeo.mapguide.MgLayerBase, java.lang.String);
- public org.osgeo.mapguide.MgStringCollection generateFilters(org.osgeo.mapguide.MgLayerBase, java.lang.String, int);
- public org.osgeo.mapguide.MgEnvelope getExtents(org.osgeo.mapguide.MgFeatureService);
- public void add(java.lang.String, java.lang.String, java.lang.String);
- public java.lang.String getResourceName(java.lang.String, java.lang.String);
- public void setMap(org.osgeo.mapguide.MgMapBase);
-Compiled from "MgSerializable.java"
-public class org.osgeo.mapguide.MgSerializable extends org.osgeo.mapguide.MgGuardDisposable {
-Compiled from "MgServerAdmin.java"
-public class org.osgeo.mapguide.MgServerAdmin extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgServerAdmin();
- public void open(java.lang.String, org.osgeo.mapguide.MgUserInformation);
- public void open(org.osgeo.mapguide.MgUserInformation);
- public boolean hasWarning();
- public org.osgeo.mapguide.MgWarnings getWarningsObject();
- public org.osgeo.mapguide.MgPropertyCollection getConfigurationProperties(java.lang.String);
- public void setConfigurationProperties(java.lang.String, org.osgeo.mapguide.MgPropertyCollection);
- public void removeConfigurationProperties(java.lang.String, org.osgeo.mapguide.MgPropertyCollection);
- public boolean clearLog(java.lang.String);
- public void deleteLog(java.lang.String);
- public void renameLog(java.lang.String, java.lang.String);
- public org.osgeo.mapguide.MgPropertyCollection enumerateLogs();
- public org.osgeo.mapguide.MgByteReader getLog(java.lang.String);
- public org.osgeo.mapguide.MgByteReader getLog(java.lang.String, int);
- public org.osgeo.mapguide.MgByteReader getLog(java.lang.String, org.osgeo.mapguide.MgDateTime, org.osgeo.mapguide.MgDateTime);
- public org.osgeo.mapguide.MgByteReader getLogFile(java.lang.String);
- public void bringOnline();
- public void takeOffline();
- public boolean isOnline();
- public org.osgeo.mapguide.MgPropertyCollection getInformationProperties();
- public java.lang.String getSiteVersion();
- public org.osgeo.mapguide.MgPropertyCollection getSiteStatus();
- public void deletePackage(java.lang.String);
- public org.osgeo.mapguide.MgStringCollection enumeratePackages();
- public org.osgeo.mapguide.MgByteReader getPackageLog(java.lang.String);
- public org.osgeo.mapguide.MgPackageStatusInformation getPackageStatus(java.lang.String);
- public void loadPackage(java.lang.String);
- public void makePackage(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, java.lang.String);
- public void setMaximumLogSize(int);
- public void setLogDelimiter(java.lang.String);
- public void enableMaximumLogSize(boolean);
- public boolean isMaximumLogSizeEnabled();
- public org.osgeo.mapguide.MgByteReader getDocument(java.lang.String);
- public void setDocument(java.lang.String, org.osgeo.mapguide.MgByteReader);
-Compiled from "MgServerInformationProperties.java"
-public class org.osgeo.mapguide.MgServerInformationProperties {
- public static final java.lang.String ServerVersion = "ServerVersion";
- public static final java.lang.String ApiVersion = "ApiVersion";
- public static final java.lang.String AdminOperationsQueueCount = "AdminOperationsQueueCount";
- public static final java.lang.String ClientOperationsQueueCount = "ClientOperationsQueueCount";
- public static final java.lang.String SiteOperationsQueueCount = "SiteOperationsQueueCount";
- public static final java.lang.String AverageOperationTime = "AverageOperationTime";
- public static final java.lang.String TotalOperationTime = "TotalOperationTime";
- public static final java.lang.String CpuUtilization = "CpuUtilization";
- public static final java.lang.String TotalPhysicalMemory = "TotalPhysicalMemory";
- public static final java.lang.String AvailablePhysicalMemory = "AvailablePhysicalMemory";
- public static final java.lang.String TotalVirtualMemory = "TotalVirtualMemory";
- public static final java.lang.String AvailableVirtualMemory = "AvailableVirtualMemory";
- public static final java.lang.String Uptime = "Uptime";
- public static final java.lang.String Status = "Status";
- public static final java.lang.String DisplayName = "DisplayName";
- public static final java.lang.String MachineIp = "MachineIp";
- public static final java.lang.String TotalReceivedOperations = "TotalReceivedOperations";
- public static final java.lang.String TotalProcessedOperations = "TotalProcessedOperations";
- public static final java.lang.String TotalConnections = "TotalConnections";
- public static final java.lang.String TotalActiveConnections = "TotalActiveConnections";
- public static final java.lang.String OperatingSystemVersion = "OperatingSystemVersion";
- public static final java.lang.String WorkingSet = "WorkingSet";
- public static final java.lang.String VirtualMemory = "VirtualMemory";
- public static final java.lang.String CacheSize = "CacheSize";
- public static final java.lang.String CacheDroppedEntries = "CacheDroppedEntries";
- public org.osgeo.mapguide.MgServerInformationProperties();
-Compiled from "MgService.java"
-public class org.osgeo.mapguide.MgService extends org.osgeo.mapguide.MgGuardDisposable {
- public boolean hasWarnings();
-Compiled from "MgServiceType.java"
-public class org.osgeo.mapguide.MgServiceType {
- public static final short ResourceService = 0;
- public static final short DrawingService = 1;
- public static final short FeatureService = 2;
- public static final short MappingService = 3;
- public static final short RenderingService = 4;
- public static final short TileService = 5;
- public static final short KmlService = 6;
- public static final short ProfilingService = 10;
- public org.osgeo.mapguide.MgServiceType();
-Compiled from "MgSingleProperty.java"
-public class org.osgeo.mapguide.MgSingleProperty extends org.osgeo.mapguide.MgNullableProperty {
- public org.osgeo.mapguide.MgSingleProperty(java.lang.String, float);
- public float getValue();
- public void setValue(float);
-Compiled from "MgSite.java"
-public class org.osgeo.mapguide.MgSite extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgByteReader enumerateUsers(java.lang.String);
- public org.osgeo.mapguide.MgByteReader enumerateGroups();
- public java.lang.String createSession();
- public void destroySession(java.lang.String);
- public java.lang.String getCurrentSession();
- public int getSessionTimeout();
- public java.lang.String getUserForSession();
- public org.osgeo.mapguide.MgByteReader enumerateGroups(java.lang.String);
- public org.osgeo.mapguide.MgStringCollection enumerateRoles(java.lang.String);
- public org.osgeo.mapguide.MgSite();
- public void open(org.osgeo.mapguide.MgUserInformation, org.osgeo.mapguide.MgSiteInfo);
- public org.osgeo.mapguide.MgWarnings getWarning();
- public org.osgeo.mapguide.MgByteReader enumerateUsers(java.lang.String, java.lang.String, boolean);
- public void addUser(java.lang.String, java.lang.String, java.lang.String, java.lang.String);
- public void updateUser(java.lang.String, java.lang.String, java.lang.String, java.lang.String, java.lang.String);
- public void deleteUsers(org.osgeo.mapguide.MgStringCollection);
- public void grantRoleMembershipsToUsers(org.osgeo.mapguide.MgStringCollection, org.osgeo.mapguide.MgStringCollection);
- public void revokeRoleMembershipsFromUsers(org.osgeo.mapguide.MgStringCollection, org.osgeo.mapguide.MgStringCollection);
- public void grantGroupMembershipsToUsers(org.osgeo.mapguide.MgStringCollection, org.osgeo.mapguide.MgStringCollection);
- public void revokeGroupMembershipsFromUsers(org.osgeo.mapguide.MgStringCollection, org.osgeo.mapguide.MgStringCollection);
- public org.osgeo.mapguide.MgByteReader enumerateGroups(java.lang.String, java.lang.String);
- public void addGroup(java.lang.String, java.lang.String);
- public void updateGroup(java.lang.String, java.lang.String, java.lang.String);
- public void deleteGroups(org.osgeo.mapguide.MgStringCollection);
- public void grantRoleMembershipsToGroups(org.osgeo.mapguide.MgStringCollection, org.osgeo.mapguide.MgStringCollection);
- public void revokeRoleMembershipsFromGroups(org.osgeo.mapguide.MgStringCollection, org.osgeo.mapguide.MgStringCollection);
- public org.osgeo.mapguide.MgStringCollection enumerateRoles(java.lang.String, java.lang.String);
- public org.osgeo.mapguide.MgByteReader enumerateServers();
- public void addServer(java.lang.String, java.lang.String, java.lang.String);
- public void updateServer(java.lang.String, java.lang.String, java.lang.String, java.lang.String);
- public void removeServer(java.lang.String);
- public org.osgeo.mapguide.MgSiteInfo getSiteServerInfo(int);
- public int getSiteServerCount();
- public java.lang.String getCurrentSiteAddress();
-Compiled from "MgSiteConnection.java"
-public class org.osgeo.mapguide.MgSiteConnection extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgSiteConnection();
- public org.osgeo.mapguide.MgService createService(int);
- public org.osgeo.mapguide.MgSite getSite();
- public org.osgeo.mapguide.MgSiteConnection(java.lang.String);
-Compiled from "MgSiteInfo.java"
-public final class org.osgeo.mapguide.MgSiteInfo$MgPortType {
- public static final org.osgeo.mapguide.MgSiteInfo$MgPortType Client;
- public static final org.osgeo.mapguide.MgSiteInfo$MgPortType Site;
- public static final org.osgeo.mapguide.MgSiteInfo$MgPortType Admin;
- public static org.osgeo.mapguide.MgSiteInfo$MgPortType swigToEnum(int);
-public final class org.osgeo.mapguide.MgSiteInfo$MgSiteStatus {
- public static final org.osgeo.mapguide.MgSiteInfo$MgSiteStatus Ok;
- public static final org.osgeo.mapguide.MgSiteInfo$MgSiteStatus UnableToConnect;
- public static final org.osgeo.mapguide.MgSiteInfo$MgSiteStatus TimedOut;
- public static final org.osgeo.mapguide.MgSiteInfo$MgSiteStatus Uninitialized;
- public static org.osgeo.mapguide.MgSiteInfo$MgSiteStatus swigToEnum(int);
-public class org.osgeo.mapguide.MgSiteInfo extends org.osgeo.mapguide.MgSerializable {
- public org.osgeo.mapguide.MgSiteInfo();
- public org.osgeo.mapguide.MgSiteInfo(java.lang.String, int, int, int);
- public java.lang.String getTarget();
- public int getPort(org.osgeo.mapguide.MgSiteInfo$MgPortType);
- public org.osgeo.mapguide.MgSiteInfo$MgSiteStatus getStatus();
- public void setStatus(org.osgeo.mapguide.MgSiteInfo$MgSiteStatus);
-Compiled from "MgSpatialContextExtentType.java"
-public class org.osgeo.mapguide.MgSpatialContextExtentType {
- public static final int scStatic = 0;
- public static final int scDynamic = 1;
- public org.osgeo.mapguide.MgSpatialContextExtentType();
-Compiled from "MgSpatialContextReader.java"
-public class org.osgeo.mapguide.MgSpatialContextReader extends org.osgeo.mapguide.MgSerializable implements java.lang.AutoCloseable {
- public java.lang.String getCoordinateSystem();
- public java.lang.String getCoordinateSystemWkt();
- public int getExtentType();
- public org.osgeo.mapguide.MgByteReader getExtent();
- public double getXYTolerance();
- public double getZTolerance();
- public void reset();
-Compiled from "MgSqlDataReader.java"
-public class org.osgeo.mapguide.MgSqlDataReader extends org.osgeo.mapguide.MgReader implements java.lang.AutoCloseable {
-Compiled from "MgStringCollection.java"
-class org.osgeo.mapguide.MgStringCollection$ItemIterator implements java.util.Iterator<java.lang.String> {
- public org.osgeo.mapguide.MgStringCollection$ItemIterator(org.osgeo.mapguide.MgStringCollection, org.osgeo.mapguide.MgStringCollection);
- public java.lang.String next();
-public class org.osgeo.mapguide.MgStringCollection extends org.osgeo.mapguide.MgCollection implements java.util.Collection<java.lang.String> {
- public java.util.Iterator<java.lang.String> iterator();
- public boolean add(java.lang.String);
- public boolean addAll(java.util.Collection<? extends java.lang.String>);
- public boolean contains(java.lang.Object);
- public boolean containsAll(java.util.Collection<?>);
- public boolean remove(java.lang.Object);
- public boolean removeAll(java.util.Collection<?>);
- public boolean retainAll(java.util.Collection<?>);
- public int size();
- public java.lang.Object[] toArray();
- public <String> String[] toArray(String[]);
- public org.osgeo.mapguide.MgStringCollection();
- public int getCount();
- public java.lang.String getItem(int);
- public void setItem(int, java.lang.String);
- public void addItem(java.lang.String);
- public void insert(int, java.lang.String);
- public void clear();
- public boolean remove(java.lang.String);
- public void removeAt(int);
- public boolean contains(java.lang.String);
- public int indexOf(java.lang.String);
- public boolean add(java.lang.Object);
-Compiled from "MgStringProperty.java"
-public class org.osgeo.mapguide.MgStringProperty extends org.osgeo.mapguide.MgNullableProperty {
- public org.osgeo.mapguide.MgStringProperty(java.lang.String, java.lang.String);
- public java.lang.String getValue();
- public void setValue(java.lang.String);
-Compiled from "MgStringPropertyCollection.java"
-public class org.osgeo.mapguide.MgStringPropertyCollection extends org.osgeo.mapguide.MgCollection {
- public org.osgeo.mapguide.MgStringPropertyCollection();
- public java.lang.String getName(int);
- public java.lang.String getValue(int);
- public java.lang.String getValue(java.lang.String);
- public void setValue(java.lang.String, java.lang.String);
- public void add(java.lang.String, java.lang.String);
- public void add(org.osgeo.mapguide.MgStringProperty);
- public void insert(int, java.lang.String, java.lang.String);
- public void insert(int, org.osgeo.mapguide.MgStringProperty);
- public boolean remove(org.osgeo.mapguide.MgStringProperty);
- public boolean contains(org.osgeo.mapguide.MgStringProperty);
- public int indexOf(org.osgeo.mapguide.MgStringProperty);
- public org.osgeo.mapguide.MgStringProperty getItem(int);
- public void setItem(int, org.osgeo.mapguide.MgStringProperty);
-Compiled from "MgTileService.java"
-public class org.osgeo.mapguide.MgTileService extends org.osgeo.mapguide.MgService {
- public org.osgeo.mapguide.MgByteReader getTile(org.osgeo.mapguide.MgMap, java.lang.String, int, int);
- public org.osgeo.mapguide.MgByteReader getTile(org.osgeo.mapguide.MgResourceIdentifier, java.lang.String, int, int, int);
- public void clearCache(org.osgeo.mapguide.MgMap);
- public void clearCache(org.osgeo.mapguide.MgResourceIdentifier);
- public int getDefaultTileSizeX();
- public int getDefaultTileSizeY();
- public int getDefaultTileSizeX(org.osgeo.mapguide.MgResourceIdentifier);
- public int getDefaultTileSizeY(org.osgeo.mapguide.MgResourceIdentifier);
- public org.osgeo.mapguide.MgByteReader getTileProviders();
-Compiled from "MgTransaction.java"
-public class org.osgeo.mapguide.MgTransaction extends org.osgeo.mapguide.MgSerializable {
- public void commit();
- public void rollback();
- public org.osgeo.mapguide.MgResourceIdentifier getFeatureSource();
- public java.lang.String addSavePoint(java.lang.String);
- public void releaseSavePoint(java.lang.String);
- public void rollback(java.lang.String);
-Compiled from "MgTransform.java"
-public class org.osgeo.mapguide.MgTransform extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgCoordinate transform(double, double);
- public org.osgeo.mapguide.MgCoordinate transform(double, double, double);
- public org.osgeo.mapguide.MgCoordinate transform(org.osgeo.mapguide.MgCoordinate);
- public org.osgeo.mapguide.MgEnvelope transform(org.osgeo.mapguide.MgEnvelope);
-Compiled from "MgUnitType.java"
-public class org.osgeo.mapguide.MgUnitType {
- public static final java.lang.String USEnglish = "US-English";
- public static final java.lang.String Metric = "Metric";
- public org.osgeo.mapguide.MgUnitType();
-Compiled from "MgUpdateFeatures.java"
-public class org.osgeo.mapguide.MgUpdateFeatures extends org.osgeo.mapguide.MgFeatureCommand {
- public org.osgeo.mapguide.MgUpdateFeatures(java.lang.String, org.osgeo.mapguide.MgPropertyCollection, java.lang.String);
- public int getCommandType();
- public org.osgeo.mapguide.MgPropertyCollection getPropertyValues();
- public java.lang.String getFeatureClassName();
- public java.lang.String getFilterText();
-Compiled from "MgUser.java"
-public class org.osgeo.mapguide.MgUser {
- public static final java.lang.String Anonymous = "Anonymous";
- public static final java.lang.String WfsUser = "WfsUser";
- public static final java.lang.String WmsUser = "WmsUser";
- public org.osgeo.mapguide.MgUser();
-Compiled from "MgUserInformation.java"
-public class org.osgeo.mapguide.MgUserInformation extends org.osgeo.mapguide.MgSerializable {
- public org.osgeo.mapguide.MgUserInformation();
- public org.osgeo.mapguide.MgUserInformation(java.lang.String);
- public org.osgeo.mapguide.MgUserInformation(java.lang.String, java.lang.String);
- public void setMgUsernamePassword(java.lang.String, java.lang.String);
- public void setMgSessionId(java.lang.String);
- public void setLocale(java.lang.String);
- public java.lang.String getLocale();
- public org.osgeo.mapguide.MgByteReader getReader();
- public void setClientAgent(java.lang.String);
- public java.lang.String getClientAgent();
- public void setClientIp(java.lang.String);
- public java.lang.String getClientIp();
-Compiled from "MgWarnings.java"
-public class org.osgeo.mapguide.MgWarnings extends org.osgeo.mapguide.MgSerializable {
- public org.osgeo.mapguide.MgStringCollection getMessages();
-Compiled from "MgWebActions.java"
-public class org.osgeo.mapguide.MgWebActions {
- public static final int Pan = 1;
- public static final int PanUp = 2;
- public static final int PanDown = 3;
- public static final int PanRight = 4;
- public static final int PanLeft = 5;
- public static final int Zoom = 6;
- public static final int ZoomIn = 7;
- public static final int ZoomOut = 8;
- public static final int ZoomRectangle = 9;
- public static final int ZoomSelection = 10;
- public static final int FitWindow = 11;
- public static final int ViewPrevious = 12;
- public static final int ViewNext = 13;
- public static final int ViewRestore = 14;
- public static final int Select = 15;
- public static final int SelectRadius = 16;
- public static final int SelectPolygon = 17;
- public static final int SelectClear = 19;
- public static final int Refresh = 20;
- public static final int Copy = 21;
- public static final int About = 22;
- public static final int PrintMap = 23;
- public static final int GetPrintablePage = 24;
- public static final int Measure = 25;
- public static final int InvokeUrl = 26;
- public static final int Search = 27;
- public static final int Buffer = 28;
- public static final int ViewOptions = 30;
- public static final int InvokeScript = 31;
- public static final int SelectWithin = 32;
- public static final int Help = 33;
- public static final int MapTip = 34;
- public org.osgeo.mapguide.MgWebActions();
-Compiled from "MgWebBufferCommand.java"
-public class org.osgeo.mapguide.MgWebBufferCommand extends org.osgeo.mapguide.MgWebUiTargetCommand {
-Compiled from "MgWebCommand.java"
-public class org.osgeo.mapguide.MgWebCommand extends org.osgeo.mapguide.MgNamedSerializable {
- public java.lang.String getLabel();
- public int getAction();
- public java.lang.String getIconUrl();
- public java.lang.String getDisabledIconUrl();
- public java.lang.String getTooltip();
- public java.lang.String getDescription();
- public int getTargetViewerType();
- public boolean isUsed();
-Compiled from "MgWebCommandCollection.java"
-public class org.osgeo.mapguide.MgWebCommandCollection extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgWebCommand getItem(int);
- public org.osgeo.mapguide.MgWebCommand getItem(java.lang.String);
- public boolean contains(org.osgeo.mapguide.MgWebCommand);
- public int indexOf(org.osgeo.mapguide.MgWebCommand);
-Compiled from "MgWebCommandWidget.java"
-public class org.osgeo.mapguide.MgWebCommandWidget extends org.osgeo.mapguide.MgWebWidget {
- public org.osgeo.mapguide.MgWebCommand getCommand();
-Compiled from "MgWebContextMenu.java"
-public class org.osgeo.mapguide.MgWebContextMenu extends org.osgeo.mapguide.MgWebWidgetCollection {
- public boolean isVisible();
-Compiled from "MgWebFlyoutWidget.java"
-public class org.osgeo.mapguide.MgWebFlyoutWidget extends org.osgeo.mapguide.MgWebWidget {
- public org.osgeo.mapguide.MgWebWidgetCollection getSubItems();
-Compiled from "MgWebGetPrintablePageCommand.java"
-public class org.osgeo.mapguide.MgWebGetPrintablePageCommand extends org.osgeo.mapguide.MgWebUiTargetCommand {
-Compiled from "MgWebHelpCommand.java"
-public class org.osgeo.mapguide.MgWebHelpCommand extends org.osgeo.mapguide.MgWebUiTargetCommand {
- public java.lang.String getUrl();
-Compiled from "MgWebInformationPane.java"
-public class org.osgeo.mapguide.MgWebInformationPane extends org.osgeo.mapguide.MgWebUiSizablePane {
- public boolean isLegendBandVisible();
- public boolean isPropertiesBandVisible();
-Compiled from "MgWebInvokeScriptCommand.java"
-public class org.osgeo.mapguide.MgWebInvokeScriptCommand extends org.osgeo.mapguide.MgWebUiTargetCommand {
- public java.lang.String getScriptCode();
-Compiled from "MgWebInvokeUrlCommand.java"
-public class org.osgeo.mapguide.MgWebInvokeUrlCommand extends org.osgeo.mapguide.MgWebUiTargetCommand {
- public int getParameterCount();
- public java.lang.String getParameterNameAt(int);
- public java.lang.String getParameterValueAt(int);
- public boolean disabledIfSelectionEmpty();
- public int getLayerCount();
- public java.lang.String getLayerNameAt(int);
-Compiled from "MgWebLayout.java"
-public class org.osgeo.mapguide.MgWebLayout extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgWebLayout(org.osgeo.mapguide.MgResourceService, org.osgeo.mapguide.MgResourceIdentifier);
- public java.lang.String getTitle();
- public java.lang.String getMapDefinition();
- public boolean getEnablePingServer();
- public java.lang.String getSelectionColor();
- public int getPointSelectionBuffer();
- public java.lang.String getMapImageFormat();
- public java.lang.String getSelectionImageFormat();
- public java.lang.String getStartupScript();
- public org.osgeo.mapguide.MgPoint getCenter();
- public org.osgeo.mapguide.MgWebToolBar getToolBar();
- public org.osgeo.mapguide.MgWebUiPane getStatusBar();
- public org.osgeo.mapguide.MgWebTaskPane getTaskPane();
- public org.osgeo.mapguide.MgWebInformationPane getInformationPane();
- public java.lang.String getDwfPreviewUrl();
- public java.lang.String getAjaxPreviewUrl();
- public org.osgeo.mapguide.MgWebCommandCollection getCommands();
- public org.osgeo.mapguide.MgWebContextMenu getContextMenu();
- public int getHyperlinkTarget();
- public java.lang.String getHyperlinkTargetFrame();
- public boolean isZoomControlVisible();
- public org.osgeo.mapguide.MgByteReader processGettingStartedPage(org.osgeo.mapguide.MgByteReader, boolean);
-Compiled from "MgWebMeasureCommand.java"
-public class org.osgeo.mapguide.MgWebMeasureCommand extends org.osgeo.mapguide.MgWebUiTargetCommand {
-Compiled from "MgWebPrintCommand.java"
-public class org.osgeo.mapguide.MgWebPrintCommand extends org.osgeo.mapguide.MgWebCommand {
- public int getPrintLayoutCount();
- public java.lang.String getPrintLayoutAt(int);
-Compiled from "MgWebSearchCommand.java"
-public class org.osgeo.mapguide.MgWebSearchCommand extends org.osgeo.mapguide.MgWebUiTargetCommand {
- public java.lang.String getLayer();
- public java.lang.String getPrompt();
- public int getResultColumnCount();
- public java.lang.String getColumnDisplayNameAt(int);
- public java.lang.String getColumnPropertyNameAt(int);
- public java.lang.String getFilter();
- public int getMatchLimit();
-Compiled from "MgWebSelectWithinCommand.java"
-public class org.osgeo.mapguide.MgWebSelectWithinCommand extends org.osgeo.mapguide.MgWebUiTargetCommand {
-Compiled from "MgWebSeparatorWidget.java"
-public class org.osgeo.mapguide.MgWebSeparatorWidget extends org.osgeo.mapguide.MgWebWidget {
-Compiled from "MgWebTargetType.java"
-public class org.osgeo.mapguide.MgWebTargetType {
- public static final int TaskPane = 1;
- public static final int NewWindow = 2;
- public static final int SpecifiedFrame = 3;
- public org.osgeo.mapguide.MgWebTargetType();
-Compiled from "MgWebTargetViewerType.java"
-public class org.osgeo.mapguide.MgWebTargetViewerType {
- public static final int Dwf = 1;
- public static final int Ajax = 2;
- public static final int All = 3;
- public org.osgeo.mapguide.MgWebTargetViewerType();
-Compiled from "MgWebTaskBar.java"
-public class org.osgeo.mapguide.MgWebTaskBar extends org.osgeo.mapguide.MgWebUiPane {
- public org.osgeo.mapguide.MgWebWidgetCollection getTaskList();
- public org.osgeo.mapguide.MgWebWidgetCollection getTaskButtons();
-Compiled from "MgWebTaskBarWidget.java"
-public class org.osgeo.mapguide.MgWebTaskBarWidget extends org.osgeo.mapguide.MgWebWidget {
-Compiled from "MgWebTaskButtonType.java"
-public class org.osgeo.mapguide.MgWebTaskButtonType {
- public static final int Home = 0;
- public static final int Back = 1;
- public static final int Forward = 2;
- public static final int Tasks = 3;
- public org.osgeo.mapguide.MgWebTaskButtonType();
-Compiled from "MgWebTaskPane.java"
-public class org.osgeo.mapguide.MgWebTaskPane extends org.osgeo.mapguide.MgWebUiSizablePane {
- public org.osgeo.mapguide.MgWebTaskBar getTaskBar();
- public java.lang.String getInitialTaskUrl();
-Compiled from "MgWebToolBar.java"
-public class org.osgeo.mapguide.MgWebToolBar extends org.osgeo.mapguide.MgWebUiPane {
- public org.osgeo.mapguide.MgWebWidgetCollection getWidgets();
-Compiled from "MgWebUiPane.java"
-public class org.osgeo.mapguide.MgWebUiPane extends org.osgeo.mapguide.MgGuardDisposable {
-Compiled from "MgWebUiSizablePane.java"
-public class org.osgeo.mapguide.MgWebUiSizablePane extends org.osgeo.mapguide.MgWebUiPane {
- public int getWidth();
-Compiled from "MgWebUiTargetCommand.java"
-public class org.osgeo.mapguide.MgWebUiTargetCommand extends org.osgeo.mapguide.MgWebCommand {
- public int getTarget();
- public java.lang.String getTargetName();
-Compiled from "MgWebViewOptionsCommand.java"
-public class org.osgeo.mapguide.MgWebViewOptionsCommand extends org.osgeo.mapguide.MgWebUiTargetCommand {
-Compiled from "MgWebWidget.java"
-public class org.osgeo.mapguide.MgWebWidget extends org.osgeo.mapguide.MgGuardDisposable {
- public int getType();
-Compiled from "MgWebWidgetCollection.java"
-public class org.osgeo.mapguide.MgWebWidgetCollection extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgWebWidget getWidget(int);
- public boolean contains(org.osgeo.mapguide.MgWebWidget);
- public int indexOf(org.osgeo.mapguide.MgWebWidget);
-Compiled from "MgWebWidgetType.java"
-public class org.osgeo.mapguide.MgWebWidgetType {
- public static final int Command = 1;
- public static final int Separator = 2;
- public static final int Flyout = 3;
- public static final int TaskButton = 4;
- public org.osgeo.mapguide.MgWebWidgetType();
-Compiled from "MgWktReaderWriter.java"
-public class org.osgeo.mapguide.MgWktReaderWriter extends org.osgeo.mapguide.MgGuardDisposable {
- public org.osgeo.mapguide.MgWktReaderWriter();
- public org.osgeo.mapguide.MgGeometry read(java.lang.String);
- public org.osgeo.mapguide.MgGeometry read(java.lang.String, org.osgeo.mapguide.MgTransform);
- public java.lang.String write(org.osgeo.mapguide.MgGeometry);
- public java.lang.String write(org.osgeo.mapguide.MgGeometry, org.osgeo.mapguide.MgTransform);
-Compiled from "ObjectFactory.java"
-public class org.osgeo.mapguide.ObjectFactory {
- public org.osgeo.mapguide.ObjectFactory();
- public static java.lang.Object createObject(int, long, boolean);
+ÿþC o m p i l e d f r o m " A p p T h r o w a b l e . j a v a " +
+ c l a s s o r g . o s g e o . m a p g u i d e . A p p T h r o w a b l e e x t e n d s j a v a . l a n g . R u n t i m e E x c e p t i o n { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . A p p T h r o w a b l e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . A p p T h r o w a b l e ( l o n g , b o o l e a n ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t M e s s a g e ( ) ; +
+ p u b l i c v o i d p r i n t S t a c k T r a c e ( ) ; +
+ p u b l i c v o i d d e l e t e ( ) ; +
+ C o m p i l e d f r o m " M a p G u i d e J a v a A p i . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M a p G u i d e J a v a A p i { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M a p G u i d e J a v a A p i ( ) ; +
+ p u b l i c s t a t i c v o i d m g I n i t i a l i z e W e b T i e r ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g A g f R e a d e r W r i t e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g A g f R e a d e r W r i t e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c s y n c h r o n i z e d v o i d d e l e t e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g A g f R e a d e r W r i t e r ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y r e a d ( o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y r e a d ( o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r , o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r w r i t e ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r w r i t e ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y , o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ; +
+ C o m p i l e d f r o m " M g A g g r e g a t e G e o m e t r y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g A g g r e g a t e G e o m e t r y e x t e n d s o r g . o s g e o . m a p g u i d e . M g G e o m e t r y { +
+ p u b l i c i n t g e t C o u n t ( ) ; +
+ C o m p i l e d f r o m " M g A r c S e g m e n t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g A r c S e g m e n t e x t e n d s o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t { +
+ p u b l i c i n t g e t C o m p o n e n t T y p e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t C o n t r o l C o o r d i n a t e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t S t a r t C o o r d i n a t e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t E n d C o o r d i n a t e ( ) ; +
+ p u b l i c i n t g e t D i m e n s i o n ( ) ; +
+ p u b l i c b o o l e a n i s E m p t y ( ) ; +
+ p u b l i c b o o l e a n i s C l o s e d ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y c o p y ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ; +
+ C o m p i l e d f r o m " M g B a s e 6 4 . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g B a s e 6 4 $ I n p u t S t r e a m e x t e n d s j a v a . i o . F i l t e r I n p u t S t r e a m { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B a s e 6 4 $ I n p u t S t r e a m ( j a v a . i o . I n p u t S t r e a m ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B a s e 6 4 $ I n p u t S t r e a m ( j a v a . i o . I n p u t S t r e a m , i n t ) ; +
+ p u b l i c i n t r e a d ( ) t h r o w s j a v a . i o . I O E x c e p t i o n ; +
+ p u b l i c i n t r e a d ( b y t e [ ] , i n t , i n t ) t h r o w s j a v a . i o . I O E x c e p t i o n ; +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g B a s e 6 4 $ O u t p u t S t r e a m e x t e n d s j a v a . i o . F i l t e r O u t p u t S t r e a m { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B a s e 6 4 $ O u t p u t S t r e a m ( j a v a . i o . O u t p u t S t r e a m ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B a s e 6 4 $ O u t p u t S t r e a m ( j a v a . i o . O u t p u t S t r e a m , i n t ) ; +
+ p u b l i c v o i d w r i t e ( i n t ) t h r o w s j a v a . i o . I O E x c e p t i o n ; +
+ p u b l i c v o i d w r i t e ( b y t e [ ] , i n t , i n t ) t h r o w s j a v a . i o . I O E x c e p t i o n ; +
+ p u b l i c v o i d f l u s h B a s e 6 4 ( ) t h r o w s j a v a . i o . I O E x c e p t i o n ; +
+ p u b l i c v o i d c l o s e ( ) t h r o w s j a v a . i o . I O E x c e p t i o n ; +
+ p u b l i c v o i d s u s p e n d E n c o d i n g ( ) t h r o w s j a v a . i o . I O E x c e p t i o n ; +
+ p u b l i c v o i d r e s u m e E n c o d i n g ( ) ; +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g B a s e 6 4 { +
+ p u b l i c s t a t i c f i n a l i n t N O _ O P T I O N S = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t E N C O D E = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t D E C O D E = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t G Z I P = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t D O N T _ B R E A K _ L I N E S = 8 ; +
+ p u b l i c s t a t i c j a v a . l a n g . S t r i n g e n c o d e O b j e c t ( j a v a . i o . S e r i a l i z a b l e ) ; +
+ p u b l i c s t a t i c j a v a . l a n g . S t r i n g e n c o d e O b j e c t ( j a v a . i o . S e r i a l i z a b l e , i n t ) ; +
+ p u b l i c s t a t i c j a v a . l a n g . S t r i n g e n c o d e B y t e s ( b y t e [ ] ) ; +
+ p u b l i c s t a t i c j a v a . l a n g . S t r i n g e n c o d e B y t e s ( b y t e [ ] , i n t ) ; +
+ p u b l i c s t a t i c j a v a . l a n g . S t r i n g e n c o d e B y t e s ( b y t e [ ] , i n t , i n t ) ; +
+ p u b l i c s t a t i c j a v a . l a n g . S t r i n g e n c o d e B y t e s ( b y t e [ ] , i n t , i n t , i n t ) ; +
+ p u b l i c s t a t i c b y t e [ ] d e c o d e ( b y t e [ ] , i n t , i n t ) ; +
+ p u b l i c s t a t i c b y t e [ ] d e c o d e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c s t a t i c j a v a . l a n g . O b j e c t d e c o d e T o O b j e c t ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c s t a t i c b o o l e a n e n c o d e T o F i l e ( b y t e [ ] , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c s t a t i c b o o l e a n d e c o d e T o F i l e ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c s t a t i c b y t e [ ] d e c o d e F r o m F i l e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c s t a t i c j a v a . l a n g . S t r i n g e n c o d e F r o m F i l e ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g B a t c h P r o p e r t y C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n ( ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ; +
+ p u b l i c v o i d a d d I t e m ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n g e t I t e m ( i n t ) ; +
+ p u b l i c v o i d c l e a r ( ) ; +
+ p u b l i c v o i d r e m o v e A t ( i n t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r t o X m l ( ) ; +
+ C o m p i l e d f r o m " M g B l o b P r o p e r t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g B l o b P r o p e r t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B l o b P r o p e r t y ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t V a l u e ( ) ; +
+ p u b l i c s h o r t g e t P r o p e r t y T y p e ( ) ; +
+ p u b l i c v o i d s e t V a l u e ( o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ; +
+ C o m p i l e d f r o m " M g B o o l e a n P r o p e r t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g B o o l e a n P r o p e r t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B o o l e a n P r o p e r t y ( j a v a . l a n g . S t r i n g , b o o l e a n ) ; +
+ p u b l i c b o o l e a n g e t V a l u e ( ) ; +
+ p u b l i c v o i d s e t V a l u e ( b o o l e a n ) ; +
+ C o m p i l e d f r o m " M g B y t e P r o p e r t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g B y t e P r o p e r t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e P r o p e r t y ( j a v a . l a n g . S t r i n g , b y t e ) ; +
+ p u b l i c b y t e g e t V a l u e ( ) ; +
+ p u b l i c v o i d s e t V a l u e ( b y t e ) ; +
+ C o m p i l e d f r o m " M g B y t e R e a d e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ( b y t e [ ] , i n t , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t r e a d ( b y t e [ ] , i n t ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t M i m e T y p e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g t o S t r i n g ( ) ; +
+ p u b l i c v o i d t o F i l e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c l o n g g e t L e n g t h ( ) ; +
+ p u b l i c b o o l e a n i s R e w i n d a b l e ( ) ; +
+ p u b l i c v o i d r e w i n d ( ) ; +
+ C o m p i l e d f r o m " M g B y t e S i n k . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g B y t e S i n k e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e S i n k ( o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ; +
+ C o m p i l e d f r o m " M g B y t e S o u r c e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g B y t e S o u r c e e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e S o u r c e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e S o u r c e ( b y t e [ ] , i n t ) ; +
+ p u b l i c v o i d s e t M i m e T y p e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t R e a d e r ( ) ; +
+ C o m p i l e d f r o m " M g C l a s s D e f i n i t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e { +
+ p u b l i c b o o l e a n e q u a l s ( j a v a . l a n g . O b j e c t ) ; +
+ p u b l i c i n t h a s h C o d e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n g e t P r o p e r t i e s ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n g e t I d e n t i t y P r o p e r t i e s ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D e f a u l t G e o m e t r y P r o p e r t y N a m e ( ) ; +
+ p u b l i c v o i d s e t D e f a u l t G e o m e t r y P r o p e r t y N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t N a m e ( ) ; +
+ p u b l i c v o i d s e t D e s c r i p t i o n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D e s c r i p t i o n ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n g e t B a s e C l a s s D e f i n i t i o n ( ) ; +
+ p u b l i c b o o l e a n i s C o m p u t e d ( ) ; +
+ p u b l i c b o o l e a n i s A b s t r a c t ( ) ; +
+ p u b l i c v o i d m a r k A s D e l e t e d ( ) ; +
+ C o m p i l e d f r o m " M g C l a s s D e f i n i t i o n C o l l e c t i o n . j a v a " +
+ c l a s s o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n $ I t e m I t e r a t o r i m p l e m e n t s j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n > { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n $ I t e m I t e r a t o r ( o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n ) ; +
+ p u b l i c b o o l e a n h a s N e x t ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n n e x t ( ) ; +
+ p u b l i c v o i d r e m o v e ( ) ; +
+ p u b l i c j a v a . l a n g . O b j e c t n e x t ( ) ; +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n i m p l e m e n t s j a v a . u t i l . C o l l e c t i o n < o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n > { +
+ p u b l i c j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n > i t e r a t o r ( ) ; +
+ p u b l i c b o o l e a n a d d ( o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ) ; +
+ p u b l i c b o o l e a n a d d A l l ( j a v a . u t i l . C o l l e c t i o n < ? e x t e n d s o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n > ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( j a v a . l a n g . O b j e c t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ; +
+ p u b l i c b o o l e a n r e m o v e ( j a v a . l a n g . O b j e c t ) ; +
+ p u b l i c b o o l e a n r e m o v e A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ; +
+ p u b l i c b o o l e a n r e t a i n A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ; +
+ p u b l i c i n t s i z e ( ) ; +
+ p u b l i c j a v a . l a n g . O b j e c t [ ] t o A r r a y ( ) ; +
+ p u b l i c < M g C l a s s D e f i n i t i o n > M g C l a s s D e f i n i t i o n [ ] t o A r r a y ( M g C l a s s D e f i n i t i o n [ ] ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n ( ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ) ; +
+ p u b l i c v o i d a d d I t e m ( o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n g e t I t e m ( i n t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ) ; +
+ p u b l i c b o o l e a n a d d ( j a v a . l a n g . O b j e c t ) ; +
+ C o m p i l e d f r o m " M g C l o b P r o p e r t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C l o b P r o p e r t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C l o b P r o p e r t y ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ; +
+ C o m p i l e d f r o m " M g C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ C o m p i l e d f r o m " M g C o l o r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o l o r e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o l o r ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o l o r ( s h o r t , s h o r t , s h o r t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o l o r ( s h o r t , s h o r t , s h o r t , s h o r t ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t C o l o r ( ) ; +
+ p u b l i c s h o r t g e t R e d ( ) ; +
+ p u b l i c s h o r t g e t B l u e ( ) ; +
+ p u b l i c s h o r t g e t G r e e n ( ) ; +
+ p u b l i c s h o r t g e t A l p h a ( ) ; +
+ C o m p i l e d f r o m " M g C o n f i g P r o p e r t i e s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o n f i g P r o p e r t i e s { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t C o n f i g u r a t i o n F i l e n a m e = " w e b c o n f i g . i n i " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S e r v e r C o n f i g u r a t i o n F i l e n a m e = " s e r v e r c o n f i g . i n i " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t i e s S e c t i o n = " G e n e r a l P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y C o n n e c t i o n T i m e o u t = " C o n n e c t i o n T i m e o u t " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t G e n e r a l P r o p e r t y C o n n e c t i o n T i m e o u t = 1 2 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y C o n n e c t i o n T i m e r I n t e r v a l = " C o n n e c t i o n T i m e r I n t e r v a l " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t G e n e r a l P r o p e r t y C o n n e c t i o n T i m e r I n t e r v a l = 6 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y L o c a l e = " L o c a l e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y L o c a l e = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y D e f a u l t M e s s a g e L o c a l e = " D e f a u l t M e s s a g e L o c a l e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y D e f a u l t M e s s a g e L o c a l e = " e n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y D i s p l a y N a m e = " D i s p l a y N a m e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y D i s p l a y N a m e = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y F d o P a t h = " F d o P a t h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y F d o P a t h = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y M e n t o r D i c t i o n a r y P a t h = " M e n t o r D i c t i o n a r y P a t h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y M e n t o r D i c t i o n a r y P a t h = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y M e n t o r U s e r D i c t i o n a r y P a t h = " M e n t o r U s e r D i c t i o n a r y P a t h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y M e n t o r U s e r D i c t i o n a r y P a t h = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y L i c e n s e S e r v e r P a t h = " L i c e n s e S e r v e r P a t h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y L i c e n s e S e r v e r P a t h = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y L i n u x M e m D e b u g = " L i n u x M e m D e b u g " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t G e n e r a l P r o p e r t y L i n u x M e m D e b u g = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y L i n u x F o n t D i r e c t o r i e s = " L i n u x F o n t D i r e c t o r i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y L i n u x F o n t D i r e c t o r i e s = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y L o g s D e l i m i t e r = " L o g s D e l i m i t e r " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y L o g s D e l i m i t e r = " \ t " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y L o g s D e t a i l = " L o g s D e t a i l " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y L o g s D e t a i l = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y L o g s P a t h = " L o g s P a t h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y L o g s P a t h = " L o g s / " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y M a c h i n e I p = " M a c h i n e I p " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y M a c h i n e I p = " 1 2 7 . 0 . 0 . 1 " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y M a x L o g F i l e S i z e = " M a x L o g F i l e S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t G e n e r a l P r o p e r t y M a x L o g F i l e S i z e = 6 4 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y M a x L o g F i l e S i z e E n a b l e d = " M a x L o g F i l e S i z e E n a b l e d " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t G e n e r a l P r o p e r t y M a x L o g F i l e S i z e E n a b l e d = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y R e s o u r c e s P a t h = " R e s o u r c e s P a t h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y R e s o u r c e s P a t h = " R e s o u r c e s / " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y S e r i a l N u m b e r = " S e r i a l N u m b e r " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y S e r i a l N u m b e r = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y S e r v i c e R e g i s t r a t i o n T i m e r I n t e r v a l = " S e r v i c e R e g i s t r a t i o n T i m e r I n t e r v a l " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t G e n e r a l P r o p e r t y S e r v i c e R e g i s t r a t i o n T i m e r I n t e r v a l = 6 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y T c p I p M t u = " T c p I p M t u " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t G e n e r a l P r o p e r t y T c p I p M t u = 1 4 6 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y T e m p P a t h = " T e m p P a t h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y T e m p P a t h = " T e m p / " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y W f s D o c u m e n t P a t h = " W f s D o c u m e n t P a t h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y W f s D o c u m e n t P a t h = " W f s / " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y W m s D o c u m e n t P a t h = " W m s D o c u m e n t P a t h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y W m s D o c u m e n t P a t h = " W m s / " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G e n e r a l P r o p e r t y P r e C a c h e M a p s = " P r e C a c h e M a p s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t G e n e r a l P r o p e r t y P r e C a c h e M a p s = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t i e s S e c t i o n = " A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y E m a i l = " E m a i l " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y E m a i l = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s = " M a x C o n n e c t i o n s " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s = 2 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y P o r t = " P o r t " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y P o r t = 5 5 5 5 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y Q u e u e S i z e = " Q u e u e S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y Q u e u e S i z e = 1 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e = " T h r e a d P o o l S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e = 5 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g C l i e n t C o n n e c t i o n P r o p e r t i e s S e c t i o n = " C l i e n t C o n n e c t i o n P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g C l i e n t C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s = " M a x C o n n e c t i o n s " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t C l i e n t C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s = 1 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g C l i e n t C o n n e c t i o n P r o p e r t y P o r t = " P o r t " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t C l i e n t C o n n e c t i o n P r o p e r t y P o r t = 4 4 4 4 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g C l i e n t C o n n e c t i o n P r o p e r t y Q u e u e S i z e = " Q u e u e S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t C l i e n t C o n n e c t i o n P r o p e r t y Q u e u e S i z e = 1 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g C l i e n t C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e = " T h r e a d P o o l S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t C l i e n t C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e = 1 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S i t e C o n n e c t i o n P r o p e r t i e s S e c t i o n = " S i t e C o n n e c t i o n P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S i t e C o n n e c t i o n P r o p e r t y I p A d d r e s s = " I p A d d r e s s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t S i t e C o n n e c t i o n P r o p e r t y I p A d d r e s s = " 1 2 7 . 0 . 0 . 1 " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S i t e C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s = " M a x C o n n e c t i o n s " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t S i t e C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s = 2 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S i t e C o n n e c t i o n P r o p e r t y P o r t = " P o r t " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t S i t e C o n n e c t i o n P r o p e r t y P o r t = 3 3 3 3 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S i t e C o n n e c t i o n P r o p e r t y Q u e u e S i z e = " Q u e u e S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t S i t e C o n n e c t i o n P r o p e r t y Q u e u e S i z e = 1 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S i t e C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e = " T h r e a d P o o l S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t S i t e C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e = 5 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g H o s t P r o p e r t i e s S e c t i o n = " H o s t P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g H o s t P r o p e r t y D r a w i n g S e r v i c e = " D r a w i n g S e r v i c e " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t H o s t P r o p e r t y D r a w i n g S e r v i c e = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g H o s t P r o p e r t y F e a t u r e S e r v i c e = " F e a t u r e S e r v i c e " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t H o s t P r o p e r t y F e a t u r e S e r v i c e = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g H o s t P r o p e r t y K m l S e r v i c e = " K m l S e r v i c e " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t H o s t P r o p e r t y K m l S e r v i c e = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g H o s t P r o p e r t y M a p p i n g S e r v i c e = " M a p p i n g S e r v i c e " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t H o s t P r o p e r t y M a p p i n g S e r v i c e = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g H o s t P r o p e r t y R e n d e r i n g S e r v i c e = " R e n d e r i n g S e r v i c e " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t H o s t P r o p e r t y R e n d e r i n g S e r v i c e = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g H o s t P r o p e r t y R e s o u r c e S e r v i c e = " R e s o u r c e S e r v i c e " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t H o s t P r o p e r t y R e s o u r c e S e r v i c e = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g H o s t P r o p e r t y P r o f i l i n g S e r v i c e = " P r o f i l i n g S e r v i c e " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t H o s t P r o p e r t y P r o f i l i n g S e r v i c e = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g H o s t P r o p e r t y S i t e S e r v i c e = " S i t e S e r v i c e " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t H o s t P r o p e r t y S i t e S e r v i c e = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g H o s t P r o p e r t y T i l e S e r v i c e = " T i l e S e r v i c e " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t H o s t P r o p e r t y T i l e S e r v i c e = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D r a w i n g S e r v i c e P r o p e r t i e s S e c t i o n = " D r a w i n g S e r v i c e P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S e r v i c e P r o p e r t i e s S e c t i o n = " F e a t u r e S e r v i c e P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S e r v i c e P r o p e r t y C a c h e S i z e = " C a c h e S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t F e a t u r e S e r v i c e P r o p e r t y C a c h e S i z e = 1 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S e r v i c e P r o p e r t y C a c h e T i m e L i m i t = " C a c h e T i m e L i m i t " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t F e a t u r e S e r v i c e P r o p e r t y C a c h e T i m e L i m i t = 8 6 4 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S e r v i c e P r o p e r t y C a c h e T i m e r I n t e r v a l = " C a c h e T i m e r I n t e r v a l " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t F e a t u r e S e r v i c e P r o p e r t y C a c h e T i m e r I n t e r v a l = 3 6 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a C a c h e S i z e = " D a t a C a c h e S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C a c h e S i z e = 1 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l E n a b l e d = " D a t a C o n n e c t i o n P o o l E n a b l e d " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l E n a b l e d = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l E x c l u d e d P r o v i d e r s = " D a t a C o n n e c t i o n P o o l E x c l u d e d P r o v i d e r s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l E x c l u d e d P r o v i d e r s = " O S G e o . S D F , O S G e o . S H P " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l S i z e = " D a t a C o n n e c t i o n P o o l S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l S i z e = 5 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l S i z e C u s t o m = " D a t a C o n n e c t i o n P o o l S i z e C u s t o m " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l S i z e C u s t o m = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n T i m e o u t = " D a t a C o n n e c t i o n T i m e o u t " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n T i m e o u t = 6 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n T i m e r I n t e r v a l = " D a t a C o n n e c t i o n T i m e r I n t e r v a l " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n T i m e r I n t e r v a l = 6 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S e r v i c e P r o p e r t y J o i n Q u e r y B a t c h S i z e = " J o i n Q u e r y B a t c h S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t F e a t u r e S e r v i c e P r o p e r t y J o i n Q u e r y B a t c h S i z e = 1 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n U s e L i m i t = " D a t a C o n n e c t i o n U s e L i m i t " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n U s e L i m i t = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a T r a n s a c t i o n T i m e o u t = " D a t a T r a n s a c t i o n T i m e o u t " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a T r a n s a c t i o n T i m e o u t = 3 6 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S e r v i c e P r o p e r t y D a t a T r a n s a c t i o n T i m e r I n t e r v a l = " D a t a T r a n s a c t i o n T i m e r I n t e r v a l " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a T r a n s a c t i o n T i m e r I n t e r v a l = 6 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S e r v i c e P r o p e r t y F D O C o n n e c t i o n T i m e o u t C u s t o m = " F D O C o n n e c t i o n T i m e o u t C u s t o m " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t F e a t u r e S e r v i c e P r o p e r t y F D O C o n n e c t i o n T i m e o u t C u s t o m = " O S G e o . W M S : 1 2 0 " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S e r v i c e P r o p e r t y U s e F d o J o i n O p t i m i z a t i o n = " U s e F d o J o i n O p t i m i z a t i o n " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t F e a t u r e S e r v i c e P r o p e r t y U s e F d o J o i n O p t i m i z a t i o n = t r u e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M a p p i n g S e r v i c e P r o p e r t i e s S e c t i o n = " M a p p i n g S e r v i c e P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M a p p i n g S e r v i c e P r o p e r t y L e g e n d F o n t = " L e g e n d F o n t " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t M a p p i n g S e r v i c e P r o p e r t y L e g e n d F o n t = " A r i a l " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t i e s S e c t i o n = " R e n d e r i n g S e r v i c e P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y T i l e E x t e n t O f f s e t = " T i l e E x t e n t O f f s e t " ; +
+ p u b l i c s t a t i c f i n a l d o u b l e D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y T i l e E x t e n t O f f s e t = 0 . 3 5 d ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e = " R a s t e r G r i d S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e = 1 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y M i n R a s t e r G r i d S i z e = " M i n R a s t e r G r i d S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M i n R a s t e r G r i d S i z e = 1 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e O v e r r i d e R a t i o = " R a s t e r G r i d S i z e O v e r r i d e R a t i o " ; +
+ p u b l i c s t a t i c f i n a l d o u b l e D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e O v e r r i d e R a t i o = 0 . 2 5 d ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e F o r P l o t = " R a s t e r G r i d S i z e F o r P l o t " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e F o r P l o t = 5 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y M i n R a s t e r G r i d S i z e F o r P l o t = " M i n R a s t e r G r i d S i z e F o r P l o t " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M i n R a s t e r G r i d S i z e F o r P l o t = 5 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e O v e r r i d e R a t i o F o r P l o t = " R a s t e r G r i d S i z e O v e r r i d e R a t i o F o r P l o t " ; +
+ p u b l i c s t a t i c f i n a l d o u b l e D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e O v e r r i d e R a t i o F o r P l o t = 0 . 1 d ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y R e n d e r S e l e c t i o n B a t c h S i z e = " R e n d e r S e l e c t i o n B a t c h S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R e n d e r S e l e c t i o n B a t c h S i z e = 1 0 0 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y C l a m p P o i n t s = " C l a m p P o i n t s " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y C l a m p P o i n t s = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y G e n e r a l i z e D a t a = " G e n e r a l i z e D a t a " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y G e n e r a l i z e D a t a = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y M a x R a s t e r I m a g e W i d t h = " M a x R a s t e r I m a g e W i d t h " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M a x R a s t e r I m a g e W i d t h = 2 0 4 8 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y M a x R a s t e r I m a g e H e i g h t = " M a x R a s t e r I m a g e H e i g h t " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M a x R a s t e r I m a g e H e i g h t = 2 0 4 8 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y M a x R e n d e r I m a g e W i d t h = " M a x R e n d e r I m a g e W i d t h " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M a x R e n d e r I m a g e W i d t h = 1 6 3 8 4 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t y M a x R e n d e r I m a g e H e i g h t = " M a x R e n d e r I m a g e H e i g h t " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M a x R e n d e r I m a g e H e i g h t = 1 6 3 8 4 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e n d e r i n g S e r v i c e P r o p e r t i e s G l o b a l R a s t e r S t y l i z a t i o n L o c k E n a b l e d = " G l o b a l R a s t e r S t y l i z a t i o n L o c k E n a b l e d " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t i e s G l o b a l R a s t e r S t y l i z a t i o n L o c k E n a b l e d = t r u e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F o n t A l i a s M a p p i n g S e c t i o n = " F o n t A l i a s e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g U n m a n a g e d D a t a M a p p i n g s S e c t i o n = " U n m a n a g e d D a t a M a p p i n g s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e s o u r c e S e r v i c e P r o p e r t i e s S e c t i o n = " R e s o u r c e S e r v i c e P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y L i b r a r y R e p o s i t o r y P a t h = " L i b r a r y R e p o s i t o r y P a t h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y L i b r a r y R e p o s i t o r y P a t h = " R e p o s i t o r i e s / L i b r a r y / " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y L i b r a r y R e s o u r c e D a t a F i l e P a t h = " L i b r a r y R e s o u r c e D a t a F i l e P a t h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y L i b r a r y R e s o u r c e D a t a F i l e P a t h = " R e p o s i t o r i e s / L i b r a r y / D a t a F i l e s / " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y P a c k a g e s P a t h = " P a c k a g e s P a t h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y P a c k a g e s P a t h = " P a c k a g e s / " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y R e p o s i t o r y C h e c k p o i n t s T i m e r I n t e r v a l = " R e p o s i t o r y C h e c k p o i n t s T i m e r I n t e r v a l " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e p o s i t o r y C h e c k p o i n t s T i m e r I n t e r v a l = 6 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e C h a n g e T i m e r I n t e r v a l = " R e s o u r c e C h a n g e T i m e r I n t e r v a l " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e C h a n g e T i m e r I n t e r v a l = 5 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e D a t a F i l e T r a s h F o l d e r N a m e = " R e s o u r c e D a t a F i l e T r a s h F o l d e r N a m e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e D a t a F i l e T r a s h F o l d e r N a m e = " T r a s h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e P e r m i s s i o n C a c h e S i z e = " R e s o u r c e P e r m i s s i o n C a c h e S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e P e r m i s s i o n C a c h e S i z e = 1 0 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e S c h e m a F i l e P a t h = " R e s o u r c e S c h e m a F i l e P a t h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e S c h e m a F i l e P a t h = " S c h e m a / " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y S e s s i o n R e p o s i t o r y P a t h = " S e s s i o n R e p o s i t o r y P a t h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y S e s s i o n R e p o s i t o r y P a t h = " R e p o s i t o r i e s / S e s s i o n / " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y S e s s i o n R e s o u r c e D a t a F i l e P a t h = " S e s s i o n R e s o u r c e D a t a F i l e P a t h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y S e s s i o n R e s o u r c e D a t a F i l e P a t h = " R e p o s i t o r i e s / S e s s i o n / D a t a F i l e s / " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R e s o u r c e S e r v i c e P r o p e r t y S i t e R e p o s i t o r y P a t h = " S i t e R e p o s i t o r y P a t h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y S i t e R e p o s i t o r y P a t h = " R e p o s i t o r i e s / S i t e / " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S i t e S e r v i c e P r o p e r t i e s S e c t i o n = " S i t e S e r v i c e P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S i t e S e r v i c e P r o p e r t y S e s s i o n T i m e o u t = " S e s s i o n T i m e o u t " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t S i t e S e r v i c e P r o p e r t y S e s s i o n T i m e o u t = 1 2 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S i t e S e r v i c e P r o p e r t y S e s s i o n T i m e r I n t e r v a l = " S e s s i o n T i m e r I n t e r v a l " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t S i t e S e r v i c e P r o p e r t y S e s s i o n T i m e r I n t e r v a l = 4 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T i l e S e r v i c e P r o p e r t i e s S e c t i o n = " T i l e S e r v i c e P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T i l e S e r v i c e P r o p e r t y R e n d e r O n l y = " R e n d e r O n l y " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t T i l e S e r v i c e P r o p e r t y R e n d e r O n l y = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T i l e S e r v i c e P r o p e r t y T i l e C a c h e P a t h = " T i l e C a c h e P a t h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e C a c h e P a t h = " R e p o s i t o r i e s / T i l e C a c h e / " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T i l e S e r v i c e P r o p e r t y T i l e C o l u m n s P e r F o l d e r = " T i l e C o l u m n s P e r F o l d e r " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e C o l u m n s P e r F o l d e r = 3 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T i l e S e r v i c e P r o p e r t y T i l e R o w s P e r F o l d e r = " T i l e R o w s P e r F o l d e r " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e R o w s P e r F o l d e r = 3 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T i l e S e r v i c e P r o p e r t y T i l e S i z e X = " D e f a u l t T i l e S i z e X " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e S i z e X = 3 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T i l e S e r v i c e P r o p e r t y T i l e S i z e Y = " D e f a u l t T i l e S i z e Y " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e S i z e Y = 3 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T i l e S e r v i c e P r o p e r t y I m a g e F o r m a t = " I m a g e F o r m a t " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t T i l e S e r v i c e P r o p e r t y I m a g e F o r m a t = " P N G " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A c c e s s L o g P r o p e r t i e s S e c t i o n = " A c c e s s L o g P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A c c e s s L o g P r o p e r t y E n a b l e d = " E n a b l e d " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t A c c e s s L o g P r o p e r t y E n a b l e d = t r u e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A c c e s s L o g P r o p e r t y F i l e n a m e = " F i l e n a m e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t A c c e s s L o g P r o p e r t y F i l e n a m e = " A c c e s s . l o g " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A c c e s s L o g P r o p e r t y P a r a m e t e r s = " P a r a m e t e r s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t A c c e s s L o g P r o p e r t y P a r a m e t e r s = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A d m i n L o g P r o p e r t i e s S e c t i o n = " A d m i n L o g P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A d m i n L o g P r o p e r t y E n a b l e d = " E n a b l e d " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t A d m i n L o g P r o p e r t y E n a b l e d = t r u e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A d m i n L o g P r o p e r t y F i l e n a m e = " F i l e n a m e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t A d m i n L o g P r o p e r t y F i l e n a m e = " A d m i n . l o g " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A d m i n L o g P r o p e r t y P a r a m e t e r s = " P a r a m e t e r s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t A d m i n L o g P r o p e r t y P a r a m e t e r s = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A u t h e n t i c a t i o n L o g P r o p e r t i e s S e c t i o n = " A u t h e n t i c a t i o n L o g P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A u t h e n t i c a t i o n L o g P r o p e r t y E n a b l e d = " E n a b l e d " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t A u t h e n t i c a t i o n L o g P r o p e r t y E n a b l e d = t r u e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A u t h e n t i c a t i o n L o g P r o p e r t y F i l e n a m e = " F i l e n a m e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t A u t h e n t i c a t i o n L o g P r o p e r t y F i l e n a m e = " A u t h e n t i c a t i o n . l o g " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A u t h e n t i c a t i o n L o g P r o p e r t y P a r a m e t e r s = " P a r a m e t e r s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t A u t h e n t i c a t i o n L o g P r o p e r t y P a r a m e t e r s = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g E r r o r L o g P r o p e r t i e s S e c t i o n = " E r r o r L o g P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g E r r o r L o g P r o p e r t y E n a b l e d = " E n a b l e d " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t E r r o r L o g P r o p e r t y E n a b l e d = t r u e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g E r r o r L o g P r o p e r t y F i l e n a m e = " F i l e n a m e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t E r r o r L o g P r o p e r t y F i l e n a m e = " E r r o r . l o g " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g E r r o r L o g P r o p e r t y P a r a m e t e r s = " P a r a m e t e r s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t E r r o r L o g P r o p e r t y P a r a m e t e r s = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P e r f o r m a n c e L o g P r o p e r t i e s S e c t i o n = " P e r f o r m a n c e L o g P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P e r f o r m a n c e L o g P r o p e r t y E n a b l e d = " E n a b l e d " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t P e r f o r m a n c e L o g P r o p e r t y E n a b l e d = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P e r f o r m a n c e L o g P r o p e r t y F i l e n a m e = " F i l e n a m e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t P e r f o r m a n c e L o g P r o p e r t y F i l e n a m e = " P e r f o r m a n c e . l o g " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P e r f o r m a n c e L o g P r o p e r t y P a r a m e t e r s = " P a r a m e t e r s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t P e r f o r m a n c e L o g P r o p e r t y P a r a m e t e r s = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P e r f o r m a n c e L o g P r o p e r t y I n t e r v a l = " I n t e r v a l " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t P e r f o r m a n c e L o g P r o p e r t y I n t e r v a l = 3 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S e s s i o n L o g P r o p e r t i e s S e c t i o n = " S e s s i o n L o g P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S e s s i o n L o g P r o p e r t y E n a b l e d = " E n a b l e d " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t S e s s i o n L o g P r o p e r t y E n a b l e d = t r u e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S e s s i o n L o g P r o p e r t y F i l e n a m e = " F i l e n a m e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t S e s s i o n L o g P r o p e r t y F i l e n a m e = " S e s s i o n . l o g " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S e s s i o n L o g P r o p e r t y P a r a m e t e r s = " P a r a m e t e r s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t S e s s i o n L o g P r o p e r t y P a r a m e t e r s = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T r a c e L o g P r o p e r t i e s S e c t i o n = " T r a c e L o g P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T r a c e L o g P r o p e r t y E n a b l e d = " E n a b l e d " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t T r a c e L o g P r o p e r t y E n a b l e d = t r u e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T r a c e L o g P r o p e r t y F i l e n a m e = " F i l e n a m e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t T r a c e L o g P r o p e r t y F i l e n a m e = " T r a c e . l o g " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T r a c e L o g P r o p e r t y P a r a m e t e r s = " P a r a m e t e r s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t T r a c e L o g P r o p e r t y P a r a m e t e r s = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D B E n v i r o n m e n t P r o p e r t i e s S e c t i o n = " D B E n v i r o n m e n t P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g L i b r a r y C a c h e S i z e P a r a m e t e r s = " L i b r a r y C a c h e S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t L i b r a r y C a c h e S i z e P a r a m e t e r s = 3 2 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S e s s i o n C a c h e S i z e P a r a m t e r s = " S e s s i o n C a c h e S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t S e s s i o n C a c h e S i z e P a r a m t e r s = 2 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D B P a g e S i z e P a r a m e t e r s = " D B P a g e S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t D B P a g e S i z e P a r a m e t e r s = 3 2 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D B X M L P a g e S i z e P a r a m e t e r s = " D B X M L P a g e S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t D B X M L P a g e S i z e P a r a m e t e r s = 3 2 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g L i b r a r y L o g B u f f e r S i z e P a r a m e t e r s = " L i b r a r y L o g B u f f e r S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t L i b r a r y L o g B u f f e r S i z e P a r a m e t e r s = 1 2 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S e s s i o n L o g B u f f e r S i z e P a r a m e t e r s = " S e s s i o n L o g B u f f e r S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t S e s s i o n L o g B u f f e r S i z e P a r a m e t e r s = 1 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D B M a x T r a n s a c t i o n s P a r a m t e r s = " D B M a x T r a n s a c t i o n s " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t D B M a x T r a n s a c t i o n s P a r a m t e r s = 1 0 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S e s s i o n D B P a g e S i z e P a r a m e t e r s = " S e s s i o n D B P a g e S i z e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t S e s s i o n D B P a g e S i z e P a r a m e t e r s = 2 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S e s s i o n D B X M L P a g e S i z e P a r a m e t e r s = " S e s s i o n D B X M L P a g e S i z e " ; +
+ p u b l i c s t a t i c f i n a l d o u b l e D e f a u l t S e s s i o n D B X M L P a g e S i z e P a r a m e t e r s = 0 . 5 d ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D B T i m e o u t P a r a m e t e r s = " D B T i m e o u t " ; +
+ p u b l i c s t a t i c f i n a l d o u b l e D e f a u l t D B T i m e o u t P a r a m e t e r s = 0 . 2 d ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D B M a x L o c k e r s P a r a m e t e r s = " D B M a x L o c k e r s " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t D B M a x L o c k e r s P a r a m e t e r s = 1 0 0 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A g e n t P r o p e r t i e s S e c t i o n = " A g e n t P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A g e n t D e b u g P a u s e = " D e b u g P a u s e " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t A g e n t D e b u g P a u s e = 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A g e n t D i s a b l e A u t h o r i n g = " D i s a b l e A u t h o r i n g " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A g e n t D i s a b l e W f s = " D i s a b l e W f s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A g e n t D i s a b l e W m s = " D i s a b l e W m s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A g e n t E r r o r L o g E n a b l e d = " E r r o r L o g E n a b l e d " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t A g e n t E r r o r L o g E n a b l e d = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A g e n t E r r o r L o g F i l e n a m e = " E r r o r L o g F i l e n a m e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t A g e n t E r r o r L o g F i l e n a m e = " E r r o r . l o g " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A g e n t R e q u e s t L o g E n a b l e d = " R e q u e s t L o g E n a b l e d " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t A g e n t R e q u e s t L o g E n a b l e d = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A g e n t R e q u e s t L o g F i l e n a m e = " R e q u e s t L o g F i l e n a m e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t A g e n t R e q u e s t L o g F i l e n a m e = " R e q u e s t . l o g " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A g e n t G l o b a l M a x F e a t u r e Q u e r y L i m i t = " G l o b a l M a x F e a t u r e Q u e r y L i m i t " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t A g e n t G l o b a l M a x F e a t u r e Q u e r y L i m i t = 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A g e n t G l o b a l M a x M a p F e a t u r e Q u e r y L i m i t = " G l o b a l M a x M a p F e a t u r e Q u e r y L i m i t " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t A g e n t G l o b a l M a x M a p F e a t u r e Q u e r y L i m i t = 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A g e n t A n o n y m o u s D e n y G e t R e s o u r c e C o n t e n t = " A n o n y m o u s D e n y G e t R e s o u r c e C o n t e n t " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t A g e n t A n o n y m o u s D e n y G e t R e s o u r c e C o n t e n t = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A g e n t A n o n y m o u s D e n y G e t R e s o u r c e D a t a = " A n o n y m o u s D e n y G e t R e s o u r c e D a t a " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t A g e n t A n o n y m o u s D e n y G e t R e s o u r c e D a t a = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A g e n t A n o n y m o u s D e n y G e t R e s o u r c e H e a d e r = " A n o n y m o u s D e n y G e t R e s o u r c e H e a d e r " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D e f a u l t A g e n t A n o n y m o u s D e n y G e t R e s o u r c e H e a d e r = " " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g O g c P r o p e r t i e s S e c t i o n = " O g c P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g W f s P a s s w o r d = " W f s P a s s w o r d " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g W m s P a s s w o r d = " W m s P a s s w o r d " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g C I T E W f s E n a b l e d = " C I T E W f s E n a b l e d " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t C I T E W f s E n a b l e d = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g C I T E W m s E n a b l e d = " C I T E W m s E n a b l e d " ; +
+ p u b l i c s t a t i c f i n a l b o o l e a n D e f a u l t C I T E W m s E n a b l e d = f a l s e ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A g e n t G l o b a l G e t W f s F e a t u r e s L i m i t = " G l o b a l G e t W f s F e a t u r e s L i m i t " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t A g e n t G l o b a l G e t W f s F e a t u r e s L i m i t = 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A g e n t G l o b a l G e t W m s F e a t u r e I n f o L i m i t = " G l o b a l G e t W m s F e a t u r e I n f o L i m i t " ; +
+ p u b l i c s t a t i c f i n a l i n t D e f a u l t A g e n t G l o b a l G e t W m s F e a t u r e I n f o L i m i t = 0 ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g W e b A p p l i c a t i o n P r o p e r t i e s S e c t i o n = " W e b A p p l i c a t i o n P r o p e r t i e s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T e m p l a t e R o o t F o l d e r = " T e m p l a t e R o o t F o l d e r " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g W i d g e t I n f o F o l d e r = " W i d g e t I n f o F o l d e r " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g C o n t a i n e r I n f o F o l d e r = " C o n t a i n e r I n f o F o l d e r " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o n f i g P r o p e r t i e s ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c s y n c h r o n i z e d v o i d d e l e t e ( ) ; +
+ p u b l i c i n t g e t D i m e n s i o n ( ) ; +
+ p u b l i c d o u b l e g e t X ( ) ; +
+ p u b l i c d o u b l e g e t Y ( ) ; +
+ p u b l i c d o u b l e g e t Z ( ) ; +
+ p u b l i c d o u b l e g e t M ( ) ; +
+ p u b l i c s t a t i c d o u b l e g e t N o Z ( ) ; +
+ p u b l i c s t a t i c d o u b l e g e t N o M ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c i n t g e t C o u n t ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t I t e m ( i n t ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c v o i d a d d ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c v o i d c l e a r ( ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c v o i d r e m o v e A t ( i n t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e C o l l e c t i o n ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e D i m e n s i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e D i m e n s i o n { +
+ p u b l i c s t a t i c f i n a l i n t X Y = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t X Y Z = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t M = 2 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e D i m e n s i o n ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e I t e r a t o r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e I t e r a t o r e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t C u r r e n t ( ) ; +
+ p u b l i c b o o l e a n m o v e N e x t ( ) ; +
+ p u b l i c v o i d r e s e t ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S p a c e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S p a c e { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g N o n e = " N o n e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M a p = " M a p " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D i s p l a y = " D i s p l a y " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S p a c e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c i n t g e t T y p e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e c o n v e r t F r o m L o n L a t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e c o n v e r t T o L o n L a t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c d o u b l e c o n v e r t C o o r d i n a t e S y s t e m U n i t s T o M e t e r s ( d o u b l e ) ; +
+ p u b l i c d o u b l e c o n v e r t M e t e r s T o C o o r d i n a t e S y s t e m U n i t s ( d o u b l e ) ; +
+ p u b l i c d o u b l e m e a s u r e E u c l i d e a n D i s t a n c e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c d o u b l e m e a s u r e E u c l i d e a n D i s t a n c e ( d o u b l e , d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c d o u b l e m e a s u r e G r e a t C i r c l e D i s t a n c e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c d o u b l e m e a s u r e G r e a t C i r c l e D i s t a n c e ( d o u b l e , d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c d o u b l e g e t A z i m u t h ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c d o u b l e g e t A z i m u t h ( d o u b l e , d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t C o o r d i n a t e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t C o o r d i n a t e ( d o u b l e , d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g t o S t r i n g ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t U n i t s ( ) ; +
+ p u b l i c d o u b l e g e t U n i t S c a l e ( ) ; +
+ p u b l i c d o u b l e g e t M i n X ( ) ; +
+ p u b l i c d o u b l e g e t M i n Y ( ) ; +
+ p u b l i c d o u b l e g e t M a x X ( ) ; +
+ p u b l i c d o u b l e g e t M a x Y ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t C s C o d e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D e s c r i p t i o n ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t P r o j e c t i o n ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t P r o j e c t i o n D e s c r i p t i o n ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D a t u m ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D a t u m D e s c r i p t i o n ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t E l l i p s o i d ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t E l l i p s o i d D e s c r i p t i o n ( ) ; +
+ p u b l i c i n t g e t E p s g C o d e ( ) ; +
+ p u b l i c i n t g e t S r i d C o d e ( ) ; +
+ p u b l i c s h o r t g e t E p s g Q u a d r a n t ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M e a s u r e g e t M e a s u r e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n g e t C a t e g o r i e s ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t a l o g g e t C a t a l o g ( ) ; +
+ p u b l i c v o i d s e t C s C o d e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n i s L e g a l C s C o d e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n i s V a l i d ( ) ; +
+ p u b l i c b o o l e a n i s U s a b l e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t a l o g ) ; +
+ p u b l i c b o o l e a n i s S a m e A s ( o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e ) ; +
+ p u b l i c v o i d s e t D e s c r i p t i o n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n i s L e g a l D e s c r i p t i o n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t G r o u p ( ) ; +
+ p u b l i c v o i d s e t G r o u p ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n i s L e g a l G r o u p ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S o u r c e ( ) ; +
+ p u b l i c v o i d s e t S o u r c e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n i s L e g a l S o u r c e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n i s P r o t e c t e d ( ) ; +
+ p u b l i c s h o r t g e t A g e ( ) ; +
+ p u b l i c v o i d s e t P r o t e c t M o d e ( b o o l e a n ) ; +
+ p u b l i c b o o l e a n i s E n c r y p t e d ( ) ; +
+ p u b l i c v o i d s e t E n c r y p t M o d e ( b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2 g e t E r r o r s ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t L o c a t i o n ( ) ; +
+ p u b l i c v o i d s e t L o c a t i o n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n i s L e g a l L o c a t i o n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t C o u n t r y O r S t a t e ( ) ; +
+ p u b l i c v o i d s e t C o u n t r y O r S t a t e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n i s L e g a l C o u n t r y O r S t a t e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n i s G e o d e t i c ( ) ; +
+ p u b l i c i n t g e t P r o j e c t i o n C o d e ( ) ; +
+ p u b l i c v o i d s e t P r o j e c t i o n C o d e ( i n t ) ; +
+ p u b l i c i n t g e t U n i t C o d e ( ) ; +
+ p u b l i c v o i d s e t U n i t C o d e ( i n t ) ; +
+ p u b l i c i n t g e t P r o j e c t i o n P a r a m e t e r C o u n t ( ) ; +
+ p u b l i c d o u b l e g e t P r o j e c t i o n P a r a m e t e r ( i n t ) ; +
+ p u b l i c v o i d s e t P r o j e c t i o n P a r a m e t e r ( i n t , d o u b l e ) ; +
+ p u b l i c d o u b l e g e t O r i g i n L o n g i t u d e ( ) ; +
+ p u b l i c v o i d s e t O r i g i n L o n g i t u d e ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t O r i g i n L a t i t u d e ( ) ; +
+ p u b l i c v o i d s e t O r i g i n L a t i t u d e ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t O f f s e t X ( ) ; +
+ p u b l i c d o u b l e g e t O f f s e t Y ( ) ; +
+ p u b l i c v o i d s e t O f f s e t s ( d o u b l e , d o u b l e ) ; +
+ p u b l i c d o u b l e g e t S c a l e R e d u c t i o n ( ) ; +
+ p u b l i c v o i d s e t S c a l e R e d u c t i o n ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t M a p S c a l e ( ) ; +
+ p u b l i c v o i d s e t M a p S c a l e ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t Z e r o X ( ) ; +
+ p u b l i c d o u b l e g e t Z e r o Y ( ) ; +
+ p u b l i c v o i d s e t Z e r o e s ( d o u b l e , d o u b l e ) ; +
+ p u b l i c d o u b l e g e t L o n M i n ( ) ; +
+ p u b l i c d o u b l e g e t L o n M a x ( ) ; +
+ p u b l i c d o u b l e g e t L a t M i n ( ) ; +
+ p u b l i c d o u b l e g e t L a t M a x ( ) ; +
+ p u b l i c v o i d s e t L o n L a t B o u n d s ( d o u b l e , d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c v o i d c a n c e l L o n L a t B o u n d s ( ) ; +
+ p u b l i c v o i d s e t X Y B o u n d s ( d o u b l e , d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c v o i d c a n c e l X Y B o u n d s ( ) ; +
+ p u b l i c s h o r t g e t Q u a d r a n t ( ) ; +
+ p u b l i c v o i d s e t Q u a d r a n t ( s h o r t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m g e t D a t u m D e f i n i t i o n ( ) ; +
+ p u b l i c v o i d s e t D a t u m D e f i n i t i o n ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d g e t E l l i p s o i d D e f i n i t i o n ( ) ; +
+ p u b l i c v o i d s e t E l l i p s o i d D e f i n i t i o n ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d ) ; +
+ p u b l i c b o o l e a n i s V a l i d X Y ( d o u b l e , d o u b l e ) ; +
+ p u b l i c b o o l e a n i s V a l i d L o n L a t ( d o u b l e , d o u b l e ) ; +
+ p u b l i c v o i d c o n v e r t C o o r d i n a t e F r o m L o n L a t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c v o i d c o n v e r t C o o r d i n a t e T o L o n L a t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e c o n v e r t T o L o n L a t ( d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e c o n v e r t T o L o n L a t ( d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e c o n v e r t F r o m L o n L a t ( d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e c o n v e r t F r o m L o n L a t ( d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c d o u b l e g e t C o n v e r g e n c e ( d o u b l e , d o u b l e ) ; +
+ p u b l i c d o u b l e g e t S c a l e ( d o u b l e , d o u b l e ) ; +
+ p u b l i c d o u b l e g e t S c a l e H ( d o u b l e , d o u b l e ) ; +
+ p u b l i c d o u b l e g e t S c a l e K ( d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m c r e a t e C l o n e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m C a t a l o g . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t a l o g e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c v o i d s e t D e f a u l t D i c t i o n a r y D i r A n d F i l e N a m e s ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D e f a u l t D i c t i o n a r y D i r ( ) ; +
+ p u b l i c v o i d s e t D i c t i o n a r y D i r ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D i c t i o n a r y D i r ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D e f a u l t U s e r D i c t i o n a r y D i r ( ) ; +
+ p u b l i c v o i d s e t U s e r D i c t i o n a r y D i r ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t U s e r D i c t i o n a r y D i r ( ) ; +
+ p u b l i c v o i d s e t P r o t e c t i o n M o d e ( s h o r t ) ; +
+ p u b l i c s h o r t g e t P r o t e c t i o n M o d e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y D i c t i o n a r y g e t C a t e g o r y D i c t i o n a r y ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y g e t C o o r d i n a t e S y s t e m D i c t i o n a r y ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m D i c t i o n a r y g e t D a t u m D i c t i o n a r y ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d D i c t i o n a r y g e t E l l i p s o i d D i c t i o n a r y ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h D i c t i o n a r y g e t G e o d e t i c P a t h D i c t i o n a r y ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f D i c t i o n a r y g e t G e o d e t i c T r a n s f o r m D e f D i c t i o n a r y ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n g e t G e o d e t i c T r a n s f o r m a t i o n s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M a t h C o m p a r a t o r g e t M a t h C o m p a r a t o r ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m F o r m a t C o n v e r t e r g e t F o r m a t C o n v e r t e r ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n I n f o r m a t i o n g e t P r o j e c t i o n I n f o r m a t i o n ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m U n i t I n f o r m a t i o n g e t U n i t I n f o r m a t i o n ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y U t i l i t y g e t D i c t i o n a r y U t i l i t y ( ) ; +
+ p u b l i c b o o l e a n a r e D i c t i o n a r y F i l e s W r i t a b l e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m C a t e g o r y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c j a v a . l a n g . S t r i n g g e t N a m e ( ) ; +
+ p u b l i c v o i d s e t N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n i s L e g a l N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y c r e a t e C l o n e ( ) ; +
+ p u b l i c i n t g e t S i z e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m g e t E n u m ( ) ; +
+ p u b l i c v o i d a d d C o o r d i n a t e S y s t e m ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d r e m o v e C o o r d i n a t e S y s t e m ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n h a s C o o r d i n a t e S y s t e m ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n g e t C o o r d i n a t e S y s t e m s ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m C a t e g o r y D i c t i o n a r y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y D i c t i o n a r y e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y n e w C a t e g o r y ( ) ; +
+ p u b l i c v o i d r e n a m e ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y g e t C a t e g o r y ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m C o d e F o r m a t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C o d e F o r m a t { +
+ p u b l i c s t a t i c f i n a l i n t M e n t o r = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t E p s g = 1 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C o d e F o r m a t ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m D a t u m . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D t C o d e ( ) ; +
+ p u b l i c v o i d s e t D t C o d e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n i s L e g a l D t C o d e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c s h o r t g e t E p s g C o d e ( ) ; +
+ p u b l i c v o i d s e t E p s g C o d e ( s h o r t ) ; +
+ p u b l i c v o i d s e t E l l i p s o i d ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m c r e a t e C l o n e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n g e t G e o d e t i c T r a n s f o r m a t i o n s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m D a t u m D i c t i o n a r y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m D i c t i o n a r y e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m n e w D a t u m ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m g e t D a t u m ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m D i c t i o n a r y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m n e w C o o r d i n a t e S y s t e m ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m g e t C o o r d i n a t e S y s t e m ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D e f a u l t F i l e N a m e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t F i l e N a m e ( ) ; +
+ p u b l i c v o i d s e t F i l e N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t P a t h ( ) ; +
+ p u b l i c v o i d a d d ( o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e ) ; +
+ p u b l i c v o i d r e m o v e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d m o d i f y ( o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e g e t ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n h a s ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m D i c t i o n a r y U t i l i t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y U t i l i t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c v o i d c r e a t e E l l i p s o i d D i c t i o n a r y ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d c r e a t e D a t u m D i c t i o n a r y ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d c r e a t e C o o r d s y s D i c t i o n a r y ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d c r e a t e C a t e g o r y D i c t i o n a r y ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m E l l i p s o i d . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c j a v a . l a n g . S t r i n g g e t E l C o d e ( ) ; +
+ p u b l i c v o i d s e t E l C o d e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n i s L e g a l E l C o d e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n i s U s a b l e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d c r e a t e C l o n e ( ) ; +
+ p u b l i c d o u b l e g e t E q u a t o r i a l R a d i u s ( ) ; +
+ p u b l i c d o u b l e g e t P o l a r R a d i u s ( ) ; +
+ p u b l i c d o u b l e g e t F l a t t e n i n g R a t i o ( ) ; +
+ p u b l i c d o u b l e g e t E c c e n t r i c i t y ( ) ; +
+ p u b l i c v o i d s e t R a d i i ( d o u b l e , d o u b l e ) ; +
+ p u b l i c d o u b l e f l a t t e n i n g R a t i o T o E c c e n t r i c i t y ( d o u b l e ) ; +
+ p u b l i c d o u b l e e c c e n t r i c i t y T o F l a t t e n i n g R a t i o ( d o u b l e ) ; +
+ p u b l i c d o u b l e e q u a t o r i a l R a d i u s F r o m P o l a r R a d i u s F l a t t e n i n g R a t i o ( d o u b l e , d o u b l e ) ; +
+ p u b l i c d o u b l e p o l a r R a d i u s F r o m E q u a t o r i a l R a d i u s F l a t t e n i n g R a t i o ( d o u b l e , d o u b l e ) ; +
+ p u b l i c d o u b l e g e t G r e a t C i r c l e D i s t a n c e ( d o u b l e , d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c d o u b l e g e t G r e a t C i r c l e A z i m u t h ( d o u b l e , d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c d o u b l e g e t R a d i u s M i n ( ) ; +
+ p u b l i c d o u b l e g e t R a d i u s M a x ( ) ; +
+ p u b l i c b o o l e a n i s L e g a l R a d i u s ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t F l a t t e n i n g R a t i o M i n ( ) ; +
+ p u b l i c d o u b l e g e t F l a t t e n i n g R a t i o M a x ( ) ; +
+ p u b l i c b o o l e a n i s L e g a l F l a t t e n i n g R a t i o ( d o u b l e ) ; +
+ p u b l i c d o u b l e f l a t t e n i n g R a t i o F r o m R a d i i ( d o u b l e , d o u b l e ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m E l l i p s o i d D i c t i o n a r y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d D i c t i o n a r y e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d n e w E l l i p s o i d ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d g e t E l l i p s o i d ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m E n u m . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n n e x t ( i n t ) ; +
+ p u b l i c v o i d s k i p ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m c r e a t e C l o n e ( ) ; +
+ p u b l i c v o i d a d d F i l t e r ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m F i l t e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n n e x t N a m e ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n n e x t D e s c r i p t i o n ( i n t ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2 . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2 e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n n e x t ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2 c r e a t e C l o n e ( ) ; +
+ p u b l i c v o i d a d d F i l t e r ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m F i l t e r I n t e g e r 3 2 ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m E r r o r C o d e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E r r o r C o d e { +
+ p u b l i c s t a t i c f i n a l i n t A Z M = 2 0 1 ; +
+ p u b l i c s t a t i c f i n a l i n t A Z M T H = 2 0 2 ; +
+ p u b l i c s t a t i c f i n a l i n t L A T = 2 0 3 ; +
+ p u b l i c s t a t i c f i n a l i n t L A T E Q U = 2 0 4 ; +
+ p u b l i c s t a t i c f i n a l i n t L N G = 2 0 5 ; +
+ p u b l i c s t a t i c f i n a l i n t L N G E Q U = 2 0 6 ; +
+ p u b l i c s t a t i c f i n a l i n t M A P S C L = 2 0 7 ; +
+ p u b l i c s t a t i c f i n a l i n t M E R E Q U = 2 0 8 ; +
+ p u b l i c s t a t i c f i n a l i n t M R C A T = 2 0 9 ; +
+ p u b l i c s t a t i c f i n a l i n t M S C O E F = 2 1 0 ; +
+ p u b l i c s t a t i c f i n a l i n t N O R E F = 2 1 1 ; +
+ p u b l i c s t a t i c f i n a l i n t N O T N R T H = 2 1 2 ; +
+ p u b l i c s t a t i c f i n a l i n t N R T H L A T = 2 1 3 ; +
+ p u b l i c s t a t i c f i n a l i n t N R T H P N T = 2 1 4 ; +
+ p u b l i c s t a t i c f i n a l i n t O R G L A T = 2 1 5 ; +
+ p u b l i c s t a t i c f i n a l i n t O R G L N G = 2 1 6 ; +
+ p u b l i c s t a t i c f i n a l i n t P L L 9 0 = 2 1 7 ; +
+ p u b l i c s t a t i c f i n a l i n t P L L E Q U = 2 1 8 ; +
+ p u b l i c s t a t i c f i n a l i n t P L L L R G = 2 1 9 ; +
+ p u b l i c s t a t i c f i n a l i n t P L L R E V = 2 2 0 ; +
+ p u b l i c s t a t i c f i n a l i n t P L L Z E R O = 2 2 1 ; +
+ p u b l i c s t a t i c f i n a l i n t P O L D D = 2 2 2 ; +
+ p u b l i c s t a t i c f i n a l i n t P O L D U P = 2 2 3 ; +
+ p u b l i c s t a t i c f i n a l i n t P O L L A T = 2 2 4 ; +
+ p u b l i c s t a t i c f i n a l i n t P O L L N G = 2 2 5 ; +
+ p u b l i c s t a t i c f i n a l i n t Q U A D = 2 2 6 ; +
+ p u b l i c s t a t i c f i n a l i n t S C L R E D = 2 2 7 ; +
+ p u b l i c s t a t i c f i n a l i n t S O T H L A T = 2 2 8 ; +
+ p u b l i c s t a t i c f i n a l i n t S T D L A T = 2 2 9 ; +
+ p u b l i c s t a t i c f i n a l i n t S T D L N G = 2 3 0 ; +
+ p u b l i c s t a t i c f i n a l i n t S T D P L L = 2 3 1 ; +
+ p u b l i c s t a t i c f i n a l i n t S T D S O U = 2 3 2 ; +
+ p u b l i c s t a t i c f i n a l i n t S T D W E S T = 2 3 3 ; +
+ p u b l i c s t a t i c f i n a l i n t U N I T = 2 3 4 ; +
+ p u b l i c s t a t i c f i n a l i n t I N V P R J = 2 3 5 ; +
+ p u b l i c s t a t i c f i n a l i n t I N V D T M = 2 3 6 ; +
+ p u b l i c s t a t i c f i n a l i n t I N V E L P = 2 3 7 ; +
+ p u b l i c s t a t i c f i n a l i n t L L R N G = 2 3 8 ; +
+ p u b l i c s t a t i c f i n a l i n t R N G O R D = 2 3 9 ; +
+ p u b l i c s t a t i c f i n a l i n t I N V Q U A D = 2 4 0 ; +
+ p u b l i c s t a t i c f i n a l i n t G E O M M = 2 4 1 ; +
+ p u b l i c s t a t i c f i n a l i n t C R T M M = 2 4 2 ; +
+ p u b l i c s t a t i c f i n a l i n t P L L E D = 2 4 3 ; +
+ p u b l i c s t a t i c f i n a l i n t P L R L A T = 2 4 4 ; +
+ p u b l i c s t a t i c f i n a l i n t U S E P L R = 2 4 5 ; +
+ p u b l i c s t a t i c f i n a l i n t U T M Z O N = 2 4 6 ; +
+ p u b l i c s t a t i c f i n a l i n t H M I S P H R = 2 4 7 ; +
+ p u b l i c s t a t i c f i n a l i n t U S E S W = 2 4 8 ; +
+ p u b l i c s t a t i c f i n a l i n t M A X 1 5 = 2 4 9 ; +
+ p u b l i c s t a t i c f i n a l i n t O B L Q P O L E = 2 5 0 ; +
+ p u b l i c s t a t i c f i n a l i n t A F F Z E R O = 2 5 1 ; +
+ p u b l i c s t a t i c f i n a l i n t N R D A T U M = 2 5 2 ; +
+ p u b l i c s t a t i c f i n a l i n t O S T N 9 7 = 2 5 3 ; +
+ p u b l i c s t a t i c f i n a l i n t D E N R G N = 2 5 3 ; +
+ p u b l i c s t a t i c f i n a l i n t E L E V E L = 2 5 4 ; +
+ p u b l i c s t a t i c f i n a l i n t O S T N 0 2 = 2 5 5 ; +
+ p u b l i c s t a t i c f i n a l i n t T M K R G 0 = 2 5 6 ; +
+ p u b l i c s t a t i c f i n a l i n t O k = 1 0 0 0 ; +
+ p u b l i c s t a t i c f i n a l i n t O u t O f M e m o r y = 1 0 0 1 ; +
+ p u b l i c s t a t i c f i n a l i n t I n i t i a l i z a t i o n F a i l e d = 1 0 0 2 ; +
+ p u b l i c s t a t i c f i n a l i n t C o n v e r s i o n F a i l e d = 1 0 0 3 ; +
+ p u b l i c s t a t i c f i n a l i n t N u l l A r g u m e n t = 1 0 0 4 ; +
+ p u b l i c s t a t i c f i n a l i n t I n v a l i d A r g u m e n t = 1 0 0 5 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E r r o r C o d e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m F a c t o r y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m F a c t o r y e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m F a c t o r y ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m c r e a t e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m T r a n s f o r m g e t T r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m c r e a t e F r o m C o d e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g c o n v e r t W k t T o C o o r d i n a t e S y s t e m C o d e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g c o n v e r t C o o r d i n a t e S y s t e m C o d e T o W k t ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n e n u m e r a t e C a t e g o r i e s ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n e n u m e r a t e C o o r d i n a t e S y s t e m s ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g c o n v e r t E p s g C o d e T o W k t ( i n t ) ; +
+ p u b l i c i n t c o n v e r t W k t T o E p s g C o d e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t B a s e L i b r a r y ( ) ; +
+ p u b l i c b o o l e a n i s V a l i d ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y g r i d B o u n d a r y ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y g r i d B o u n d a r y ( o r g . o s g e o . m a p g u i d e . M g P o l y g o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n g r i d S p e c i f i c a t i o n ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n g r i d S p e c i f i c a t i o n ( d o u b l e , d o u b l e , i n t , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n g r i d S p e c i f i c a t i o n ( i n t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e g e n e r i c G r i d ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e g e n e r i c G r i d ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s g e t M g r s ( d o u b l e , d o u b l e , s h o r t , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s g e t M g r s E l l i p s o i d ( j a v a . l a n g . S t r i n g , s h o r t , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s g e t M g r s D a t u m ( j a v a . l a n g . S t r i n g , s h o r t , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e m g r s G r i d ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m , b o o l e a n , s h o r t , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e m g r s G r i d ( j a v a . l a n g . S t r i n g , b o o l e a n , s h o r t , b o o l e a n ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m F i l t e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m F i l t e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c b o o l e a n i s F i l t e r e d O u t ( o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m F i l t e r I n t e g e r 3 2 . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m F i l t e r I n t e g e r 3 2 e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c b o o l e a n i s F i l t e r e d O u t ( i n t ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m F o r m a t C o n v e r t e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m F o r m a t C o n v e r t e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c j a v a . l a n g . S t r i n g d e f i n i t i o n T o W k t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m w k t T o D e f i n i t i o n ( i n t , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g c o d e T o W k t ( i n t , j a v a . l a n g . S t r i n g , i n t ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g w k t T o C o d e ( i n t , j a v a . l a n g . S t r i n g , i n t ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g d e f i n i t i o n T o C o d e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m c o d e T o D e f i n i t i o n ( i n t , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g c o d e T o C o d e ( i n t , j a v a . l a n g . S t r i n g , i n t ) ; +
+ p u b l i c b o o l e a n i s C o d e I n D i c t i o n a r y ( i n t , j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G e o d e t i c A n a l y t i c a l T r a n s f o r m a t i o n M e t h o d . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c A n a l y t i c a l T r a n s f o r m a t i o n M e t h o d { +
+ p u b l i c s t a t i c f i n a l i n t N o n e = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t T h r e e P a r a m e t e r = 8 1 9 3 ; +
+ p u b l i c s t a t i c f i n a l i n t M o l o d e n s k y = 8 1 9 4 ; +
+ p u b l i c s t a t i c f i n a l i n t A b r i d g e d M o l o d e n s k y = 8 1 9 5 ; +
+ p u b l i c s t a t i c f i n a l i n t G e o c e n t r i c = 8 1 9 6 ; +
+ p u b l i c s t a t i c f i n a l i n t F o u r P a r a m e t e r = 8 1 9 7 ; +
+ p u b l i c s t a t i c f i n a l i n t S i x P a r a m e t e r = 8 1 9 8 ; +
+ p u b l i c s t a t i c f i n a l i n t B u r s a = 8 1 9 9 ; +
+ p u b l i c s t a t i c f i n a l i n t F r a m e = 8 2 0 0 ; +
+ p u b l i c s t a t i c f i n a l i n t S e v e n P a r a m e t e r = 8 2 0 1 ; +
+ p u b l i c s t a t i c f i n a l i n t M o l o d e n s k y B a d e k a s = 8 2 0 2 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c A n a l y t i c a l T r a n s f o r m a t i o n M e t h o d ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G e o d e t i c A n a l y t i c a l T r a n s f o r m D e f P a r a m s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c A n a l y t i c a l T r a n s f o r m D e f P a r a m s e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s { +
+ p u b l i c d o u b l e g e t D e l t a X ( ) ; +
+ p u b l i c v o i d s e t D e l t a X ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t D e l t a Y ( ) ; +
+ p u b l i c v o i d s e t D e l t a Y ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t D e l t a Z ( ) ; +
+ p u b l i c v o i d s e t D e l t a Z ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t R o t a t e X ( ) ; +
+ p u b l i c v o i d s e t R o t a t e X ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t R o t a t e Y ( ) ; +
+ p u b l i c v o i d s e t R o t a t e Y ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t R o t a t e Z ( ) ; +
+ p u b l i c v o i d s e t R o t a t e Z ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t S c a l e ( ) ; +
+ p u b l i c v o i d s e t S c a l e ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t T r a n s l a t e X ( ) ; +
+ p u b l i c v o i d s e t T r a n s l a t e X ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t T r a n s l a t e Y ( ) ; +
+ p u b l i c v o i d s e t T r a n s l a t e Y ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t T r a n s l a t e Z ( ) ; +
+ p u b l i c v o i d s e t T r a n s l a t e Z ( d o u b l e ) ; +
+ p u b l i c i n t g e t T r a n s f o r m a t i o n M e t h o d ( ) ; +
+ p u b l i c v o i d s e t T r a n s f o r m a t i o n M e t h o d ( i n t ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G e o d e t i c I n t e r p o l a t i o n T r a n s f o r m D e f P a r a m s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c I n t e r p o l a t i o n T r a n s f o r m D e f P a r a m s e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s { +
+ p u b l i c v o i d s e t G r i d F i l e s ( o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n g e t G r i d F i l e s ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t F a l l b a c k ( ) ; +
+ p u b l i c v o i d s e t F a l l b a c k ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e n e w G r i d F i l e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G e o d e t i c M u l t i p l e R e g r e s s i o n T r a n s f o r m a t i o n M e t h o d . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c M u l t i p l e R e g r e s s i o n T r a n s f o r m a t i o n M e t h o d { +
+ p u b l i c s t a t i c f i n a l i n t M u l t i p l e R e g r e s s i o n = 2 0 4 8 1 ; +
+ p u b l i c s t a t i c f i n a l i n t G e n e r a l P o l y n o m i a l E p s g = 2 0 4 8 2 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c M u l t i p l e R e g r e s s i o n T r a n s f o r m a t i o n M e t h o d ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G e o d e t i c M u l t i p l e R e g r e s s i o n T r a n s f o r m D e f P a r a m s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c M u l t i p l e R e g r e s s i o n T r a n s f o r m D e f P a r a m s e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s { +
+ p u b l i c d o u b l e g e t V a l i d a t i o n ( ) ; +
+ p u b l i c v o i d s e t V a l i d a t i o n ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t T e s t P h i ( ) ; +
+ p u b l i c v o i d s e t T e s t P h i ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t T e s t L a m b d a ( ) ; +
+ p u b l i c v o i d s e t T e s t L a m b d a ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t D e l t a P h i ( ) ; +
+ p u b l i c v o i d s e t D e l t a P h i ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t D e l t a L a m b d a ( ) ; +
+ p u b l i c v o i d s e t D e l t a L a m b d a ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t D e l t a H e i g h t ( ) ; +
+ p u b l i c v o i d s e t D e l t a H e i g h t ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t P h i O f f s e t ( ) ; +
+ p u b l i c v o i d s e t P h i O f f s e t ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t L a m b d a O f f s e t ( ) ; +
+ p u b l i c v o i d s e t L a m b d a O f f s e t ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t N o r m a l i z a t i o n S c a l e ( ) ; +
+ p u b l i c v o i d s e t N o r m a l i z a t i o n S c a l e ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t C o e f f i c i e n t P h i ( i n t ) ; +
+ p u b l i c v o i d s e t C o e f f i c i e n t P h i ( i n t , d o u b l e ) ; +
+ p u b l i c d o u b l e g e t C o e f f i c i e n t L a m b d a ( i n t ) ; +
+ p u b l i c v o i d s e t C o e f f i c i e n t L a m b d a ( i n t , d o u b l e ) ; +
+ p u b l i c d o u b l e g e t C o e f f i c i e n t H e i g h t ( i n t ) ; +
+ p u b l i c v o i d s e t C o e f f i c i e n t H e i g h t ( i n t , d o u b l e ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c j a v a . l a n g . S t r i n g g e t P a t h N a m e ( ) ; +
+ p u b l i c v o i d s e t P a t h N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t T a r g e t D a t u m ( ) ; +
+ p u b l i c v o i d s e t T a r g e t D a t u m ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S o u r c e D a t u m ( ) ; +
+ p u b l i c v o i d s e t S o u r c e D a t u m ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c d o u b l e g e t A c c u r a c y ( ) ; +
+ p u b l i c v o i d s e t A c c u r a c y ( d o u b l e ) ; +
+ p u b l i c b o o l e a n g e t I s R e v e r s i b l e ( ) ; +
+ p u b l i c v o i d s e t I s R e v e r s i b l e ( b o o l e a n ) ; +
+ p u b l i c v o i d s e t E p s g C o d e ( i n t ) ; +
+ p u b l i c i n t g e t E p s g V a r i a n t ( ) ; +
+ p u b l i c v o i d s e t E p s g V a r i a n t ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n g e t P a t h E l e m e n t s ( ) ; +
+ p u b l i c v o i d s e t P a t h E l e m e n t s ( o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h E l e m e n t n e w P a t h E l e m e n t ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h c r e a t e C l o n e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h D i c t i o n a r y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h D i c t i o n a r y e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h n e w G e o d e t i c P a t h ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h g e t G e o d e t i c P a t h ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h E l e m e n t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h E l e m e n t e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c j a v a . l a n g . S t r i n g g e t T r a n s f o r m N a m e ( ) ; +
+ p u b l i c v o i d s e t T r a n s f o r m N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n g e t I s I n v e r s e d ( ) ; +
+ p u b l i c v o i d s e t I s I n v e r s e d ( b o o l e a n ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G e o d e t i c S t a n d a l o n e T r a n s f o r m D e f P a r a m s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c S t a n d a l o n e T r a n s f o r m D e f P a r a m s e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s { +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c v o i d s e t S o u r c e A n d T a r g e t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m g e t S o u r c e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m g e t T a r g e t ( ) ; +
+ p u b l i c v o i d s h i f t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e s h i f t ( d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e s h i f t ( d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c d o u b l e g e t O f f s e t Z ( ) ; +
+ p u b l i c v o i d s e t O f f s e t ( d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c d o u b l e g e t B u r s a W o l f e T r a n s f o r m R o t a t i o n X ( ) ; +
+ p u b l i c d o u b l e g e t B u r s a W o l f e T r a n s f o r m R o t a t i o n Y ( ) ; +
+ p u b l i c d o u b l e g e t B u r s a W o l f e T r a n s f o r m R o t a t i o n Z ( ) ; +
+ p u b l i c d o u b l e g e t B u r s a W o l f e T r a n s f o r m B w S c a l e ( ) ; +
+ p u b l i c v o i d s e t B u r s a W o l f e T r a n s f o r m ( d o u b l e , d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c i n t g e t G e o d e t i c T r a n s f o r m a t i o n M e t h o d ( ) ; +
+ p u b l i c v o i d s e t G e o d e t i c T r a n s f o r m a t i o n M e t h o d ( i n t ) ; +
+ p u b l i c d o u b l e g e t M a x O f f s e t ( ) ; +
+ p u b l i c b o o l e a n i s L e g a l O f f s e t ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t M a x R o t a t i o n ( ) ; +
+ p u b l i c b o o l e a n i s L e g a l R o t a t i o n ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t B w S c a l e M i n ( ) ; +
+ p u b l i c d o u b l e g e t B w S c a l e M a x ( ) ; +
+ p u b l i c b o o l e a n i s L e g a l B w S c a l e ( d o u b l e ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n M e t h o d . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n M e t h o d { +
+ p u b l i c s t a t i c f i n a l i n t M o l o d e n s k y = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t M R e g = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t B u r s a = 3 ; +
+ p u b l i c s t a t i c f i n a l i n t N A D 2 7 = 4 ; +
+ p u b l i c s t a t i c f i n a l i n t N A D 8 3 = 5 ; +
+ p u b l i c s t a t i c f i n a l i n t W G S 8 4 = 6 ; +
+ p u b l i c s t a t i c f i n a l i n t W G S 7 2 = 7 ; +
+ p u b l i c s t a t i c f i n a l i n t H P G N = 8 ; +
+ p u b l i c s t a t i c f i n a l i n t S e v e n P a r a m e t e r = 9 ; +
+ p u b l i c s t a t i c f i n a l i n t A G D 6 6 = 1 0 ; +
+ p u b l i c s t a t i c f i n a l i n t T h r e e P a r a m e t e r = 1 1 ; +
+ p u b l i c s t a t i c f i n a l i n t S i x P a r a m e t e r = 1 2 ; +
+ p u b l i c s t a t i c f i n a l i n t F o u r P a r a m e t e r = 1 3 ; +
+ p u b l i c s t a t i c f i n a l i n t A G D 8 4 = 1 4 ; +
+ p u b l i c s t a t i c f i n a l i n t N Z G D 4 9 = 1 5 ; +
+ p u b l i c s t a t i c f i n a l i n t A T S 7 7 = 1 6 ; +
+ p u b l i c s t a t i c f i n a l i n t G D A 9 4 = 1 7 ; +
+ p u b l i c s t a t i c f i n a l i n t N Z G D 2 K = 1 8 ; +
+ p u b l i c s t a t i c f i n a l i n t C S R S = 1 9 ; +
+ p u b l i c s t a t i c f i n a l i n t T O K Y O = 2 0 ; +
+ p u b l i c s t a t i c f i n a l i n t R G F 9 3 = 2 1 ; +
+ p u b l i c s t a t i c f i n a l i n t E D 5 0 = 2 2 ; +
+ p u b l i c s t a t i c f i n a l i n t D H D N = 2 3 ; +
+ p u b l i c s t a t i c f i n a l i n t E T R F 8 9 = 2 4 ; +
+ p u b l i c s t a t i c f i n a l i n t L c l g r f = 9 9 ; +
+ p u b l i c s t a t i c f i n a l i n t G e o c e n t r i c = 2 5 ; +
+ p u b l i c s t a t i c f i n a l i n t C H E N Y X = 2 6 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n M e t h o d ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c i n t g e t E p s g V a r i a t i o n ( ) ; +
+ p u b l i c v o i d s e t E p s g V a r i a t i o n ( i n t ) ; +
+ p u b l i c b o o l e a n g e t I n v e r s e S u p p o r t e d ( ) ; +
+ p u b l i c v o i d s e t I n v e r s e S u p p o r t e d ( b o o l e a n ) ; +
+ p u b l i c i n t g e t M a x I t e r a t i o n s ( ) ; +
+ p u b l i c v o i d s e t M a x I t e r a t i o n s ( i n t ) ; +
+ p u b l i c d o u b l e g e t C o n v e r g e n c e V a l u e ( ) ; +
+ p u b l i c v o i d s e t C o n v e r g e n c e V a l u e ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t E r r o r V a l u e ( ) ; +
+ p u b l i c v o i d s e t E r r o r V a l u e ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t R a n g e M i n L o n g i t u d e ( ) ; +
+ p u b l i c v o i d s e t R a n g e M i n L o n g i t u d e ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t R a n g e M a x L o n g i t u d e ( ) ; +
+ p u b l i c v o i d s e t R a n g e M a x L o n g i t u d e ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t R a n g e M i n L a t i t u d e ( ) ; +
+ p u b l i c v o i d s e t R a n g e M i n L a t i t u d e ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t R a n g e M a x L a t i t u d e ( ) ; +
+ p u b l i c v o i d s e t R a n g e M a x L a t i t u d e ( d o u b l e ) ; +
+ p u b l i c i n t g e t T r a n s f o r m D e f T y p e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s g e t P a r a m e t e r s ( ) ; +
+ p u b l i c v o i d s e t P a r a m e t e r s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f c r e a t e C l o n e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n c r e a t e T r a n s f o r m a t i o n ( b o o l e a n ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f D i c t i o n a r y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f D i c t i o n a r y e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f n e w G e o d e t i c T r a n s f o r m a t i o n D e f ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f g e t G e o d e t i c T r a n s f o r m a t i o n D e f ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f T y p e { +
+ p u b l i c s t a t i c f i n a l i n t S t a n d a l o n e = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t A n a l y t i c a l = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t I n t e r p o l a t i o n = 3 ; +
+ p u b l i c s t a t i c f i n a l i n t M u l t i p l e R e g r e s s i o n = 4 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f T y p e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c s y n c h r o n i z e d v o i d d e l e t e ( ) ; +
+ p u b l i c i n t g e t F i l e F o r m a t ( ) ; +
+ p u b l i c v o i d s e t F i l e F o r m a t ( i n t ) ; +
+ p u b l i c b o o l e a n g e t I s I n v e r s e D i r e c t i o n ( ) ; +
+ p u b l i c v o i d s e t I s I n v e r s e D i r e c t i o n ( b o o l e a n ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e F o r m a t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e F o r m a t { +
+ p u b l i c s t a t i c f i n a l i n t N T v 1 = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t N T v 2 = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t N A D C O N = 3 ; +
+ p u b l i c s t a t i c f i n a l i n t R G F = 4 ; +
+ p u b l i c s t a t i c f i n a l i n t P A R = 5 ; +
+ p u b l i c s t a t i c f i n a l i n t A T S 7 7 = 6 ; +
+ p u b l i c s t a t i c f i n a l i n t O S T 9 7 = 7 ; +
+ p u b l i c s t a t i c f i n a l i n t O S T 0 2 = 8 ; +
+ p u b l i c s t a t i c f i n a l i n t O S T 1 5 = 9 ; +
+ p u b l i c s t a t i c f i n a l i n t G E O C O N = 1 0 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e F o r m a t ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G r i d B a s e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c i n t g e t S p e c i a l i z a t i o n T y p e ( ) ; +
+ p u b l i c v o i d s e t B o u n d a r y ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y g e t B o u n d a r y ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d L i n e C o l l e c t i o n g e t G r i d L i n e s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d R e g i o n C o l l e c t i o n g e t G r i d R e g i o n s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d T i c k C o l l e c t i o n g e t G r i d T i c k s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) ; +
+ p u b l i c d o u b l e g e t C o n v e r g e n c e A n g l e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c d o u b l e g e t P r o j e c t i v e G r i d S c a l e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c i n t a p p r o x G r i d L i n e M e m o r y U s a g e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) ; +
+ p u b l i c i n t a p p r o x G r i d R e g i o n M e m o r y U s a g e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) ; +
+ p u b l i c i n t a p p r o x G r i d T i c k M e m o r y U s a g e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) ; +
+ p u b l i c i n t s e t G r i d L i n e E x c e p t i o n L e v e l ( i n t ) ; +
+ p u b l i c i n t s e t G r i d R e g i o n E x c e p t i o n L e v e l ( i n t ) ; +
+ p u b l i c i n t s e t G r i d T i c k E x c e p t i o n L e v e l ( i n t ) ; +
+ p u b l i c i n t g e t L a s t E r r o r ( ) ; +
+ p u b l i c v o i d r e s e t L a s t E r r o r ( ) ; +
+ p u b l i c b o o l e a n a r e E x c e p t i o n s O n ( ) ; +
+ p u b l i c v o i d s e t E x c e p t i o n s O n ( b o o l e a n ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c v o i d s e t B o u n d a r y E x t e n t s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c v o i d s e t B o u n d a r y E x t e n t s ( o r g . o s g e o . m a p g u i d e . M g P o l y g o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P o l y g o n g e t B o u n d a r y ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G r i d L i n e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d L i n e e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c i n t g e t G r i d O r i e n t a t i o n ( ) ; +
+ p u b l i c d o u b l e g e t R e a l V a l u e ( ) ; +
+ p u b l i c i n t g e t C o u n t ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g g e t S e g m e n t ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n g e t S e g m e n t C o l l e c t i o n ( ) ; +
+ p u b l i c v o i d s e t S e g m e n t C o l l e c t i o n ( o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G r i d L i n e C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d L i n e C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d L i n e g e t I t e m ( i n t ) ; +
+ p u b l i c i n t i n d e x O f ( i n t , d o u b l e ) ; +
+ p u b l i c v o i d r e m o v e A t ( i n t ) ; +
+ p u b l i c v o i d c l e a r ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G r i d O r i e n t a t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d O r i e n t a t i o n { +
+ p u b l i c s t a t i c f i n a l s h o r t N o n e = 0 ; +
+ p u b l i c s t a t i c f i n a l s h o r t E a s t W e s t = 1 ; +
+ p u b l i c s t a t i c f i n a l s h o r t N o r t h S o u t h = 2 ; +
+ p u b l i c s t a t i c f i n a l s h o r t U n k n o w n = 3 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d O r i e n t a t i o n ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G r i d R e g i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d R e g i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c j a v a . l a n g . S t r i n g g e t L a b e l ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t R e g i o n C e n t e r ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P o l y g o n g e t R e g i o n B o u n d a r y ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n g e t S o u t h L i n e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n g e t E a s t L i n e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n g e t N o r t h L i n e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n g e t W e s t L i n e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G r i d R e g i o n C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d R e g i o n C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d R e g i o n g e t I t e m ( i n t ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G r i d S p e c i a l i z a t i o n T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i a l i z a t i o n T y p e { +
+ p u b l i c s t a t i c f i n a l i n t G e n e r i c = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t M G R S = 1 7 ; +
+ p u b l i c s t a t i c f i n a l i n t U S N G = 1 8 ; +
+ p u b l i c s t a t i c f i n a l i n t U n k n o w n = 6 5 3 6 6 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i a l i z a t i o n T y p e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c d o u b l e g e t E a s t i n g B a s e ( ) ; +
+ p u b l i c d o u b l e g e t N o r t h i n g B a s e ( ) ; +
+ p u b l i c d o u b l e g e t E a s t i n g I n c r e m e n t ( ) ; +
+ p u b l i c d o u b l e g e t N o r t h i n g I n c r e m e n t ( ) ; +
+ p u b l i c d o u b l e g e t T i c k E a s t i n g I n c r e m e n t ( ) ; +
+ p u b l i c d o u b l e g e t T i c k N o r t h i n g I n c r e m e n t ( ) ; +
+ p u b l i c i n t g e t U n i t T y p e ( ) ; +
+ p u b l i c i n t g e t U n i t C o d e ( ) ; +
+ p u b l i c b o o l e a n i s S a m e A s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) ; +
+ p u b l i c d o u b l e g e t C u r v e P r e c i s i o n ( ) ; +
+ p u b l i c v o i d s e t G r i d B a s e ( d o u b l e , d o u b l e ) ; +
+ p u b l i c v o i d s e t G r i d I n c r e m e n t ( d o u b l e , d o u b l e ) ; +
+ p u b l i c v o i d s e t T i c k I n c r e m e n t s ( d o u b l e , d o u b l e ) ; +
+ p u b l i c v o i d s e t U n i t s ( i n t , i n t ) ; +
+ p u b l i c v o i d s e t C u r v e P r e c i s i o n ( d o u b l e ) ; +
+ p u b l i c v o i d s e t M a x C u r v e P o i n t s ( i n t ) ; +
+ p u b l i c b o o l e a n i s C o n s i s t e n t ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G r i d T i c k . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d T i c k e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c b o o l e a n g e t I s O n G r i d L i n e ( ) ; +
+ p u b l i c i n t g e t T i c k O r i e n t a t i o n ( ) ; +
+ p u b l i c d o u b l e g e t V a l u e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t P o s i t i o n ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t D i r e c t i o n V e c t o r ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m G r i d T i c k C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d T i c k C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d T i c k g e t I t e m ( i n t ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m M a t h C o m p a r a t o r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M a t h C o m p a r a t o r e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c b o o l e a n s a m e ( o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e , o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e ) ; +
+ p u b l i c b o o l e a n s a m e E l l i p s o i d ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d ) ; +
+ p u b l i c b o o l e a n s a m e D a t u m ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m ) ; +
+ p u b l i c b o o l e a n s a m e C o o r d i n a t e S y s t e m ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m ) ; +
+ p u b l i c v o i d s e t C o m p a r e I n t e r n a l D a t u m O l d P a r a m e t e r s ( b o o l e a n ) ; +
+ p u b l i c b o o l e a n g e t C o m p a r e I n t e r n a l D a t u m O l d P a r a m e t e r s ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m M e a s u r e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M e a s u r e e x t e n d s o r g . o s g e o . m a p g u i d e . M g M e a s u r e { +
+ p u b l i c d o u b l e g e t D i s t a n c e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c d o u b l e g e t D i s t a n c e ( d o u b l e , d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c d o u b l e g e t A z i m u t h ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c d o u b l e g e t A z i m u t h ( d o u b l e , d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t C o o r d i n a t e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t C o o r d i n a t e ( d o u b l e , d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g E n v e l o p e g e t E n v e l o p e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m M g r s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e { +
+ p u b l i c j a v a . l a n g . S t r i n g c o n v e r t F r o m L o n L a t ( d o u b l e , d o u b l e , i n t ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g c o n v e r t F r o m L o n L a t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e c o n v e r t T o L o n L a t ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e c o n v e r t T o L o n L a t ( j a v a . l a n g . S t r i n g , i n t ) ; +
+ p u b l i c s h o r t g e t L e t t e r i n g S c h e m e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m M g r s G r i d L e v e l . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s G r i d L e v e l { +
+ p u b l i c s t a t i c f i n a l i n t M g r s N o n e = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t M g r s U t m = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t M g r s U p s = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t M g r s 1 0 0 K m = 3 ; +
+ p u b l i c s t a t i c f i n a l i n t M g r s 1 0 K m = 4 ; +
+ p u b l i c s t a t i c f i n a l i n t M g r s 1 K m = 5 ; +
+ p u b l i c s t a t i c f i n a l i n t M g r s 1 0 0 m = 6 ; +
+ p u b l i c s t a t i c f i n a l i n t M g r s 1 0 m = 7 ; +
+ p u b l i c s t a t i c f i n a l i n t M g r s 1 m = 8 ; +
+ p u b l i c s t a t i c f i n a l i n t M g r s U n k n o w n = 9 9 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s G r i d L e v e l ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m M g r s G r i d S q u a r e P o s i t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s G r i d S q u a r e P o s i t i o n { +
+ p u b l i c s t a t i c f i n a l i n t C e n t e r = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t S o u t h W e s t = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t W e s t = 3 ; +
+ p u b l i c s t a t i c f i n a l i n t N o r t h W e s t = 4 ; +
+ p u b l i c s t a t i c f i n a l i n t N o r t h = 5 ; +
+ p u b l i c s t a t i c f i n a l i n t N o r t h E a s t = 6 ; +
+ p u b l i c s t a t i c f i n a l i n t E a s t = 7 ; +
+ p u b l i c s t a t i c f i n a l i n t S o u t h E a s t = 8 ; +
+ p u b l i c s t a t i c f i n a l i n t S o u t h = 9 ; +
+ p u b l i c s t a t i c f i n a l i n t U n k n o w n = 1 0 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s G r i d S q u a r e P o s i t i o n ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m M g r s L e t t e r i n g S c h e m e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s L e t t e r i n g S c h e m e { +
+ p u b l i c s t a t i c f i n a l s h o r t N o r m a l = 0 ; +
+ p u b l i c s t a t i c f i n a l s h o r t A l t e r n a t i v e = 1 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s L e t t e r i n g S c h e m e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m P r o j e c t i o n C o d e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n C o d e { +
+ p u b l i c s t a t i c f i n a l i n t A l b e r = 4 ; +
+ p u b l i c s t a t i c f i n a l i n t A z e d e = 5 9 ; +
+ p u b l i c s t a t i c f i n a l i n t A z m e a = 1 1 ; +
+ p u b l i c s t a t i c f i n a l i n t A z m e d = 7 ; +
+ p u b l i c s t a t i c f i n a l i n t B i p o l a r = 3 1 ; +
+ p u b l i c s t a t i c f i n a l i n t B o n n e = 2 4 ; +
+ p u b l i c s t a t i c f i n a l i n t C a s s i n i = 2 2 ; +
+ p u b l i c s t a t i c f i n a l i n t E c k e r t 4 = 2 5 ; +
+ p u b l i c s t a t i c f i n a l i n t E c k e r t 6 = 2 6 ; +
+ p u b l i c s t a t i c f i n a l i n t E d c n c = 1 2 ; +
+ p u b l i c s t a t i c f i n a l i n t E d c y l = 2 0 ; +
+ p u b l i c s t a t i c f i n a l i n t G a u s s K = 4 6 ; +
+ p u b l i c s t a t i c f i n a l i n t G n o m o n i c = 1 9 ; +
+ p u b l i c s t a t i c f i n a l i n t G o o d e = 2 8 ; +
+ p u b l i c s t a t i c f i n a l i n t H o m 1 u v = 1 2 8 1 ; +
+ p u b l i c s t a t i c f i n a l i n t H o m 1 x y = 1 2 8 2 ; +
+ p u b l i c s t a t i c f i n a l i n t H o m 2 u v = 1 2 8 3 ; +
+ p u b l i c s t a t i c f i n a l i n t H o m 2 x y = 1 2 8 4 ; +
+ p u b l i c s t a t i c f i n a l i n t K r o v a k = 4 7 ; +
+ p u b l i c s t a t i c f i n a l i n t K r v k 9 5 = 5 1 ; +
+ p u b l i c s t a t i c f i n a l i n t L L = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t L m 1 s p = 3 6 ; +
+ p u b l i c s t a t i c f i n a l i n t L m 2 s p = 3 7 ; +
+ p u b l i c s t a t i c f i n a l i n t L m b l g = 3 8 ; +
+ p u b l i c s t a t i c f i n a l i n t L m t a n = 8 ; +
+ p u b l i c s t a t i c f i n a l i n t M i l l e r = 1 3 ; +
+ p u b l i c s t a t i c f i n a l i n t M n d o t l = 4 1 ; +
+ p u b l i c s t a t i c f i n a l i n t M n d o t t = 4 2 ; +
+ p u b l i c s t a t i c f i n a l i n t M o d p c = 1 0 ; +
+ p u b l i c s t a t i c f i n a l i n t M o l l w e i d = 2 7 ; +
+ p u b l i c s t a t i c f i n a l i n t M r c a t = 6 ; +
+ p u b l i c s t a t i c f i n a l i n t M r c a t K = 4 9 ; +
+ p u b l i c s t a t i c f i n a l i n t M s t e r o = 1 5 ; +
+ p u b l i c s t a t i c f i n a l i n t N e a c y l = 2 9 ; +
+ p u b l i c s t a t i c f i n a l i n t N e r t h = 5 5 ; +
+ p u b l i c s t a t i c f i n a l i n t N z e a l a n d = 1 6 ; +
+ p u b l i c s t a t i c f i n a l i n t O b l q M = 5 ; +
+ p u b l i c s t a t i c f i n a l i n t O b q c y l = 5 6 ; +
+ p u b l i c s t a t i c f i n a l i n t O r t h o = 1 8 ; +
+ p u b l i c s t a t i c f i n a l i n t O s t n 0 2 = 6 0 ; +
+ p u b l i c s t a t i c f i n a l i n t O s t n 9 7 = 5 8 ; +
+ p u b l i c s t a t i c f i n a l i n t O s t r o = 3 4 ; +
+ p u b l i c s t a t i c f i n a l i n t P l y c n = 9 ; +
+ p u b l i c s t a t i c f i n a l i n t P s t r o = 3 3 ; +
+ p u b l i c s t a t i c f i n a l i n t P s t r o s l = 5 3 ; +
+ p u b l i c s t a t i c f i n a l i n t R s k e w = 1 2 8 5 ; +
+ p u b l i c s t a t i c f i n a l i n t R s k e w c = 1 2 8 6 ; +
+ p u b l i c s t a t i c f i n a l i n t R s k e w o = 1 2 8 7 ; +
+ p u b l i c s t a t i c f i n a l i n t R o b i n s o n = 2 3 ; +
+ p u b l i c s t a t i c f i n a l i n t S i n u s = 1 7 ; +
+ p u b l i c s t a t i c f i n a l i n t S o t r m = 4 3 ; +
+ p u b l i c s t a t i c f i n a l i n t S s t r o = 3 5 ; +
+ p u b l i c s t a t i c f i n a l i n t S w i s s = 3 2 ; +
+ p u b l i c s t a t i c f i n a l i n t S y s 3 4 = 5 7 ; +
+ p u b l i c s t a t i c f i n a l i n t S y s 3 4 _ 9 9 = 6 1 ; +
+ p u b l i c s t a t i c f i n a l i n t T e a c y l = 3 0 ; +
+ p u b l i c s t a t i c f i n a l i n t T m = 3 ; +
+ p u b l i c s t a t i c f i n a l i n t T r m e r a f = 5 4 ; +
+ p u b l i c s t a t i c f i n a l i n t T r m r k r g = 6 2 ; +
+ p u b l i c s t a t i c f i n a l i n t T r m r s = 4 5 ; +
+ p u b l i c s t a t i c f i n a l i n t V d g r n t n = 2 1 ; +
+ p u b l i c s t a t i c f i n a l i n t W c c s l = 3 9 ; +
+ p u b l i c s t a t i c f i n a l i n t W c c s t = 4 0 ; +
+ p u b l i c s t a t i c f i n a l i n t U t m = 4 4 ; +
+ p u b l i c s t a t i c f i n a l i n t W i n k l = 6 3 ; +
+ p u b l i c s t a t i c f i n a l i n t N r t h s r t = 6 4 ; +
+ p u b l i c s t a t i c f i n a l i n t L m b r t a f = 6 5 ; +
+ p u b l i c s t a t i c f i n a l i n t S y s 3 4 _ 0 1 = 6 6 ; +
+ p u b l i c s t a t i c f i n a l i n t E d c y l E = 6 7 ; +
+ p u b l i c s t a t i c f i n a l i n t P l a t e C a r r e e = 6 8 ; +
+ p u b l i c s t a t i c f i n a l i n t P v M e r c a t o r = 6 9 ; +
+ p u b l i c s t a t i c f i n a l i n t L m M i c h = 7 0 ; +
+ p u b l i c s t a t i c f i n a l i n t U n k n o w n = 0 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n C o d e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m P r o j e c t i o n F o r m a t T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n F o r m a t T y p e { +
+ p u b l i c s t a t i c f i n a l i n t L n g = 5 7 5 0 9 ; +
+ p u b l i c s t a t i c f i n a l i n t L a t = 4 1 1 5 7 ; +
+ p u b l i c s t a t i c f i n a l i n t A n g d = 3 2 9 3 3 ; +
+ p u b l i c s t a t i c f i n a l i n t C o e f = 1 3 ; +
+ p u b l i c s t a t i c f i n a l i n t X x x = 4 0 9 9 ; +
+ p u b l i c s t a t i c f i n a l i n t Y y y = 4 0 9 9 ; +
+ p u b l i c s t a t i c f i n a l i n t S c l = 7 ; +
+ p u b l i c s t a t i c f i n a l i n t R o t = 4 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n F o r m a t T y p e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m P r o j e c t i o n I n f o r m a t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n I n f o r m a t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2 g e t E n u m P r o j e c t i o n s ( ) ; +
+ p u b l i c i n t g e t P a r a m e t e r C o u n t ( i n t ) ; +
+ p u b l i c b o o l e a n i s U s i n g P a r a m e t e r ( i n t , i n t ) ; +
+ p u b l i c b o o l e a n i s U s i n g O r i g i n L o n g i t u d e ( i n t ) ; +
+ p u b l i c b o o l e a n i s U s i n g O r i g i n L a t i t u d e ( i n t ) ; +
+ p u b l i c b o o l e a n i s U s i n g S c a l e R e d u c t i o n ( i n t ) ; +
+ p u b l i c b o o l e a n i s U s i n g Q u a d r a n t ( i n t ) ; +
+ p u b l i c b o o l e a n i s U s i n g O f f s e t ( i n t ) ; +
+ p u b l i c d o u b l e g e t P a r a m e t e r M i n ( i n t , i n t ) ; +
+ p u b l i c d o u b l e g e t P a r a m e t e r M a x ( i n t , i n t ) ; +
+ p u b l i c d o u b l e g e t P a r a m e t e r D e f a u l t ( i n t , i n t ) ; +
+ p u b l i c i n t g e t P a r a m e t e r L o g i c a l T y p e ( i n t , i n t ) ; +
+ p u b l i c i n t g e t P a r a m e t e r F o r m a t T y p e ( i n t , i n t ) ; +
+ p u b l i c i n t g e t P a r a m e t e r T y p e ( i n t , i n t ) ; +
+ p u b l i c i n t g e t U n i t T y p e ( i n t ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t T a g S t r i n g ( i n t ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m P r o j e c t i o n L o g i c a l T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n L o g i c a l T y p e { +
+ p u b l i c s t a t i c f i n a l i n t L o n g i t u d e = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t L a t i t u d e = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t A z i m u t h = 3 ; +
+ p u b l i c s t a t i c f i n a l i n t A n g u l a r D i s t a n c e = 4 ; +
+ p u b l i c s t a t i c f i n a l i n t C o m p l e x C o e f f i c i e n t = 5 ; +
+ p u b l i c s t a t i c f i n a l i n t U T M Z o n e N u m b e r = 6 ; +
+ p u b l i c s t a t i c f i n a l i n t H e m i s p h e r e S e l e c t i o n = 7 ; +
+ p u b l i c s t a t i c f i n a l i n t G e o i d H e i g h t = 8 ; +
+ p u b l i c s t a t i c f i n a l i n t E l e v a t i o n = 9 ; +
+ p u b l i c s t a t i c f i n a l i n t A f f i n e C o e f f i c i e n t = 1 0 ; +
+ p u b l i c s t a t i c f i n a l i n t X Y C o o r d i n a t e = 1 1 ; +
+ p u b l i c s t a t i c f i n a l i n t S c a l e = 1 2 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n L o g i c a l T y p e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m P r o j e c t i o n P a r a m e t e r T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n P a r a m e t e r T y p e { +
+ p u b l i c s t a t i c f i n a l i n t N o t U s e d = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t C n t m e r = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t N s t d p l l = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t S s t d p l l = 3 ; +
+ p u b l i c s t a t i c f i n a l i n t S t d p l l = 4 ; +
+ p u b l i c s t a t i c f i n a l i n t G c p 1 l n g = 5 ; +
+ p u b l i c s t a t i c f i n a l i n t G c p 1 l a t = 6 ; +
+ p u b l i c s t a t i c f i n a l i n t G c p 2 l n g = 7 ; +
+ p u b l i c s t a t i c f i n a l i n t G c p 2 l a t = 8 ; +
+ p u b l i c s t a t i c f i n a l i n t G c p l n g = 9 ; +
+ p u b l i c s t a t i c f i n a l i n t G c p l a t = 1 0 ; +
+ p u b l i c s t a t i c f i n a l i n t G c a z m = 1 1 ; +
+ p u b l i c s t a t i c f i n a l i n t Y a x i s a z = 1 2 ; +
+ p u b l i c s t a t i c f i n a l i n t E s t d m e r = 1 3 ; +
+ p u b l i c s t a t i c f i n a l i n t N p a r a l l = 1 4 ; +
+ p u b l i c s t a t i c f i n a l i n t S p a r a l l = 1 5 ; +
+ p u b l i c s t a t i c f i n a l i n t P 1 l n g = 1 6 ; +
+ p u b l i c s t a t i c f i n a l i n t P 1 l a t = 1 7 ; +
+ p u b l i c s t a t i c f i n a l i n t P 2 l n g = 1 8 ; +
+ p u b l i c s t a t i c f i n a l i n t P 2 l a t = 1 9 ; +
+ p u b l i c s t a t i c f i n a l i n t A d p 1 p 2 = 2 0 ; +
+ p u b l i c s t a t i c f i n a l i n t A d s p 1 = 2 1 ; +
+ p u b l i c s t a t i c f i n a l i n t A d s p 2 = 2 2 ; +
+ p u b l i c s t a t i c f i n a l i n t C m p l x a n = 2 3 ; +
+ p u b l i c s t a t i c f i n a l i n t C m p l x b n = 2 4 ; +
+ p u b l i c s t a t i c f i n a l i n t W e s t l l = 2 5 ; +
+ p u b l i c s t a t i c f i n a l i n t E a s t l l = 2 6 ; +
+ p u b l i c s t a t i c f i n a l i n t U t m z n = 2 7 ; +
+ p u b l i c s t a t i c f i n a l i n t H s n s = 2 8 ; +
+ p u b l i c s t a t i c f i n a l i n t G h g t = 2 9 ; +
+ p u b l i c s t a t i c f i n a l i n t A e l e v = 3 0 ; +
+ p u b l i c s t a t i c f i n a l i n t P o l e l n g = 3 1 ; +
+ p u b l i c s t a t i c f i n a l i n t P o l e l a t = 3 2 ; +
+ p u b l i c s t a t i c f i n a l i n t O s t d p l l = 3 3 ; +
+ p u b l i c s t a t i c f i n a l i n t S t d c i r = 3 4 ; +
+ p u b l i c s t a t i c f i n a l i n t A f a 0 = 3 5 ; +
+ p u b l i c s t a t i c f i n a l i n t A f b 0 = 3 6 ; +
+ p u b l i c s t a t i c f i n a l i n t A f a 1 = 3 7 ; +
+ p u b l i c s t a t i c f i n a l i n t A f a 2 = 3 8 ; +
+ p u b l i c s t a t i c f i n a l i n t A f b 1 = 3 9 ; +
+ p u b l i c s t a t i c f i n a l i n t A f b 2 = 4 0 ; +
+ p u b l i c s t a t i c f i n a l i n t N r m l p l l = 4 1 ; +
+ p u b l i c s t a t i c f i n a l i n t D e n r g n = 4 2 ; +
+ p u b l i c s t a t i c f i n a l i n t S k w a z m = 4 3 ; +
+ p u b l i c s t a t i c f i n a l i n t S c l r o t o r g x = 4 4 ; +
+ p u b l i c s t a t i c f i n a l i n t S c l r o t o r g y = 4 5 ; +
+ p u b l i c s t a t i c f i n a l i n t N r t h s c l = 4 6 ; +
+ p u b l i c s t a t i c f i n a l i n t N r t h r o t = 4 7 ; +
+ p u b l i c s t a t i c f i n a l i n t E l l i p s o i d S c a l e = 4 8 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n P a r a m e t e r T y p e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m T r a n s f o r m . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m T r a n s f o r m e x t e n d s o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m { +
+ p u b l i c s t a t i c f i n a l i n t T r a n s f o r m O k ; +
+ p u b l i c s t a t i c f i n a l i n t T r a n s f o r m O u t s i d e D o m a i n W a r n i n g ; +
+ p u b l i c s t a t i c f i n a l i n t T r a n s f o r m D a t u m S h i f t W a r n i n g ; +
+ p u b l i c s t a t i c f i n a l i n t T r a n s f o r m T o t a l F a i l u r e ; +
+ p u b l i c s t a t i c f i n a l i n t S o u r c e C r s E r r o r ; +
+ p u b l i c s t a t i c f i n a l i n t D a t u m S h i f t F a l l b a c k ; +
+ p u b l i c s t a t i c f i n a l i n t D a t u m S h i f t E r r o r ; +
+ p u b l i c s t a t i c f i n a l i n t T a r g e t C r s E r r o r ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e t r a n s f o r m ( d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e t r a n s f o r m M ( d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e t r a n s f o r m ( d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e t r a n s f o r m M ( d o u b l e , d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g E n v e l o p e t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ) ; +
+ p u b l i c v o i d t r a n s f o r m C o o r d i n a t e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g g r i d L i n e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , d o u b l e , i n t ) ; +
+ p u b l i c b o o l e a n i s V a l i d S o u r c e P o i n t ( d o u b l e , d o u b l e ) ; +
+ p u b l i c b o o l e a n i s V a l i d S o u r c e P o i n t ( d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c b o o l e a n i s V a l i d T a r g e t P o i n t ( d o u b l e , d o u b l e ) ; +
+ p u b l i c b o o l e a n i s V a l i d T a r g e t P o i n t ( d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m g e t S o u r c e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m g e t T a r g e t ( ) ; +
+ p u b l i c v o i d s e t S o u r c e A n d T a r g e t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m ) ; +
+ p u b l i c i n t g e t G e o d e t i c T r a n s f o r m a t i o n C o u n t ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f g e t G e o d e t i c T r a n s f o r m a t i o n ( i n t ) ; +
+ p u b l i c i n t g e t G e o d e t i c T r a n s f o r m a t i o n D i r e c t i o n ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h g e t E x p l i c i t G e o d e t i c P a t h ( ) ; +
+ p u b l i c v o i d i g n o r e D a t u m S h i f t W a r n i n g ( b o o l e a n ) ; +
+ p u b l i c b o o l e a n i s I g n o r e D a t u m S h i f t W a r n i n g ( ) ; +
+ p u b l i c v o i d i g n o r e O u t s i d e D o m a i n W a r n i n g ( b o o l e a n ) ; +
+ p u b l i c b o o l e a n i s I g n o r e O u t s i d e D o m a i n W a r n i n g ( ) ; +
+ p u b l i c i n t g e t S o u r c e W a r n i n g C o u n t ( ) ; +
+ p u b l i c i n t g e t d a t u m W a r n i n g C o u n t ( ) ; +
+ p u b l i c i n t g e t T a r g e t W a r n i n g C o u n t ( ) ; +
+ p u b l i c i n t g e t L a s t T r a n s f o r m S t a t u s ( ) ; +
+ p u b l i c v o i d r e s e t L a s t T r a n s f o r m S t a t u s ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m T y p e { +
+ p u b l i c s t a t i c f i n a l i n t A r b i t r a r y = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t G e o g r a p h i c = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t P r o j e c t e d = 3 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m T y p e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m U n i t C o d e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m U n i t C o d e { +
+ p u b l i c s t a t i c f i n a l i n t M e t e r = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t F o o t = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t I n c h = 3 ; +
+ p u b l i c s t a t i c f i n a l i n t I F o o t = 4 ; +
+ p u b l i c s t a t i c f i n a l i n t C l a r k e F o o t = 5 ; +
+ p u b l i c s t a t i c f i n a l i n t I I n c h = 6 ; +
+ p u b l i c s t a t i c f i n a l i n t C e n t i m e t e r = 7 ; +
+ p u b l i c s t a t i c f i n a l i n t K i l o m e t e r = 8 ; +
+ p u b l i c s t a t i c f i n a l i n t Y a r d = 9 ; +
+ p u b l i c s t a t i c f i n a l i n t S e a r s Y a r d = 1 0 ; +
+ p u b l i c s t a t i c f i n a l i n t M i l e = 1 1 ; +
+ p u b l i c s t a t i c f i n a l i n t I Y a r d = 1 2 ; +
+ p u b l i c s t a t i c f i n a l i n t I M i l e = 1 3 ; +
+ p u b l i c s t a t i c f i n a l i n t K n o t = 1 4 ; +
+ p u b l i c s t a t i c f i n a l i n t N a u t M = 1 5 ; +
+ p u b l i c s t a t i c f i n a l i n t L a t 6 6 = 1 6 ; +
+ p u b l i c s t a t i c f i n a l i n t L a t 8 3 = 1 7 ; +
+ p u b l i c s t a t i c f i n a l i n t D e c i m e t e r = 1 8 ; +
+ p u b l i c s t a t i c f i n a l i n t M i l l i m e t e r = 1 9 ; +
+ p u b l i c s t a t i c f i n a l i n t D e k a m e t e r = 2 0 ; +
+ p u b l i c s t a t i c f i n a l i n t H e c t o m e t e r = 2 1 ; +
+ p u b l i c s t a t i c f i n a l i n t G e r m a n M e t e r = 2 2 ; +
+ p u b l i c s t a t i c f i n a l i n t C a G r i d = 2 3 ; +
+ p u b l i c s t a t i c f i n a l i n t C l a r k e C h a i n = 2 4 ; +
+ p u b l i c s t a t i c f i n a l i n t G u n t e r C h a i n = 2 5 ; +
+ p u b l i c s t a t i c f i n a l i n t B e n o i t C h a i n = 2 6 ; +
+ p u b l i c s t a t i c f i n a l i n t S e a r s C h a i n = 2 7 ; +
+ p u b l i c s t a t i c f i n a l i n t C l a r k e L i n k = 2 8 ; +
+ p u b l i c s t a t i c f i n a l i n t G u n t e r L i n k = 2 9 ; +
+ p u b l i c s t a t i c f i n a l i n t B e n o i t L i n k = 3 0 ; +
+ p u b l i c s t a t i c f i n a l i n t S e a r s L i n k = 3 1 ; +
+ p u b l i c s t a t i c f i n a l i n t R o d = 3 2 ; +
+ p u b l i c s t a t i c f i n a l i n t P e r c h = 3 3 ; +
+ p u b l i c s t a t i c f i n a l i n t P o l e = 3 4 ; +
+ p u b l i c s t a t i c f i n a l i n t F u r l o n g = 3 5 ; +
+ p u b l i c s t a t i c f i n a l i n t R o o d = 3 6 ; +
+ p u b l i c s t a t i c f i n a l i n t C a p e F o o t = 3 7 ; +
+ p u b l i c s t a t i c f i n a l i n t B r e a l e y = 3 8 ; +
+ p u b l i c s t a t i c f i n a l i n t S e a r s F o o t = 3 9 ; +
+ p u b l i c s t a t i c f i n a l i n t G o l d C o a s t F o o t = 4 0 ; +
+ p u b l i c s t a t i c f i n a l i n t M i c r o I n c h = 4 1 ; +
+ p u b l i c s t a t i c f i n a l i n t I n d i a n Y a r d = 4 2 ; +
+ p u b l i c s t a t i c f i n a l i n t I n d i a n F o o t = 4 3 ; +
+ p u b l i c s t a t i c f i n a l i n t I n d i a n F t 3 7 = 4 4 ; +
+ p u b l i c s t a t i c f i n a l i n t I n d i a n F t 6 2 = 4 5 ; +
+ p u b l i c s t a t i c f i n a l i n t I n d i a n F t 7 5 = 4 6 ; +
+ p u b l i c s t a t i c f i n a l i n t I n d i a n Y d 3 7 = 4 7 ; +
+ p u b l i c s t a t i c f i n a l i n t D e c a m e t e r = 4 8 ; +
+ p u b l i c s t a t i c f i n a l i n t I n t e r n a t i o n a l C h a i n = 4 9 ; +
+ p u b l i c s t a t i c f i n a l i n t I n t e r n a t i o n a l L i n k = 5 0 ; +
+ p u b l i c s t a t i c f i n a l i n t B r F o o t T r u n c = 5 1 ; +
+ p u b l i c s t a t i c f i n a l i n t B r C h a i n T r u n c = 5 2 ; +
+ p u b l i c s t a t i c f i n a l i n t B r L i n k T r u n c = 5 3 ; +
+ p u b l i c s t a t i c f i n a l i n t D e g r e e = 1 0 0 1 ; +
+ p u b l i c s t a t i c f i n a l i n t G r a d = 1 0 0 2 ; +
+ p u b l i c s t a t i c f i n a l i n t G r a d e = 1 0 0 3 ; +
+ p u b l i c s t a t i c f i n a l i n t M a p I n f o = 1 0 0 4 ; +
+ p u b l i c s t a t i c f i n a l i n t M i l = 1 0 0 5 ; +
+ p u b l i c s t a t i c f i n a l i n t M i n u t e = 1 0 0 6 ; +
+ p u b l i c s t a t i c f i n a l i n t R a d i a n = 1 0 0 7 ; +
+ p u b l i c s t a t i c f i n a l i n t S e c o n d = 1 0 0 8 ; +
+ p u b l i c s t a t i c f i n a l i n t D e c i s e c = 1 0 0 9 ; +
+ p u b l i c s t a t i c f i n a l i n t C e n t i s e c = 1 0 1 0 ; +
+ p u b l i c s t a t i c f i n a l i n t M i l l i s e c = 1 0 1 1 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m U n i t C o d e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m U n i t I n f o r m a t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m U n i t I n f o r m a t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2 g e t E n u m L i n e a r U n i t s ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2 g e t E n u m A n g u l a r U n i t s ( ) ; +
+ p u b l i c d o u b l e g e t L i n e a r U n i t S c a l e ( i n t ) ; +
+ p u b l i c d o u b l e g e t A n g u l a r U n i t S c a l e ( i n t ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t A b b r e v i a t i o n ( i n t ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m U n i t T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m U n i t T y p e { +
+ p u b l i c s t a t i c f i n a l i n t L i n e a r = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t A n g u l a r = 2 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m U n i t T y p e ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e S y s t e m W k t F l a v o r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m W k t F l a v o r { +
+ p u b l i c s t a t i c f i n a l i n t U n k n o w n = - 1 ; +
+ p u b l i c s t a t i c f i n a l i n t O g c = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t O r a c l e = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t E s r i = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t E p s g = 3 ; +
+ p u b l i c s t a t i c f i n a l i n t G e o t i f f = 4 ; +
+ p u b l i c s t a t i c f i n a l i n t G e o t o o l s = 5 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m W k t F l a v o r ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e X Y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e X Y e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e { +
+ p u b l i c i n t g e t D i m e n s i o n ( ) ; +
+ p u b l i c d o u b l e g e t X ( ) ; +
+ p u b l i c d o u b l e g e t Y ( ) ; +
+ p u b l i c d o u b l e g e t Z ( ) ; +
+ p u b l i c d o u b l e g e t M ( ) ; +
+ C o m p i l e d f r o m " M g C o o r d i n a t e X Y M . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e X Y M e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e { +
+ C o m p i l e d f r o m " M g C o o r d i n a t e X Y Z . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e X Y Z e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e { +
+ C o m p i l e d f r o m " M g C o o r d i n a t e X Y Z M . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e X Y Z M e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e { +
+ C o m p i l e d f r o m " M g C u r v e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C u r v e e x t e n d s o r g . o s g e o . m a p g u i d e . M g G e o m e t r y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t S t a r t C o o r d i n a t e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t E n d C o o r d i n a t e ( ) ; +
+ C o m p i l e d f r o m " M g C u r v e P o l y g o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g R e g i o n { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g g e t E x t e r i o r R i n g ( ) ; +
+ p u b l i c i n t g e t I n t e r i o r R i n g C o u n t ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g g e t I n t e r i o r R i n g ( i n t ) ; +
+ p u b l i c i n t g e t G e o m e t r y T y p e ( ) ; +
+ p u b l i c b o o l e a n i s E m p t y ( ) ; +
+ p u b l i c b o o l e a n i s C l o s e d ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y c o p y ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ; +
+ C o m p i l e d f r o m " M g C u r v e P o l y g o n C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n g e t I t e m ( i n t ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n ) ; +
+ p u b l i c v o i d a d d ( o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n C o l l e c t i o n ( ) ; +
+ C o m p i l e d f r o m " M g C u r v e R i n g . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g e x t e n d s o r g . o s g e o . m a p g u i d e . M g R i n g { +
+ p u b l i c i n t g e t C o m p o n e n t T y p e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t g e t S e g m e n t ( i n t ) ; +
+ C o m p i l e d f r o m " M g C u r v e R i n g C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g g e t I t e m ( i n t ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g ) ; +
+ p u b l i c v o i d a d d ( o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g C o l l e c t i o n ( ) ; +
+ C o m p i l e d f r o m " M g C u r v e S e g m e n t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t e x t e n d s o r g . o s g e o . m a p g u i d e . M g G e o m e t r y C o m p o n e n t { +
+ C o m p i l e d f r o m " M g C u r v e S e g m e n t C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t g e t I t e m ( i n t ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t ) ; +
+ p u b l i c v o i d a d d ( o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t C o l l e c t i o n ( ) ; +
+ C o m p i l e d f r o m " M g C u r v e S t r i n g . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g e x t e n d s o r g . o s g e o . m a p g u i d e . M g C u r v e { +
+ C o m p i l e d f r o m " M g C u r v e S t r i n g C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g g e t I t e m ( i n t ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g ) ; +
+ p u b l i c v o i d a d d ( o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g C o l l e c t i o n ( ) ; +
+ C o m p i l e d f r o m " M g D a t a P r o p e r t y D e f i n i t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g D a t a P r o p e r t y D e f i n i t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D a t a P r o p e r t y D e f i n i t i o n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t g e t D a t a T y p e ( ) ; +
+ p u b l i c i n t g e t L e n g t h ( ) ; +
+ p u b l i c i n t g e t P r e c i s i o n ( ) ; +
+ p u b l i c i n t g e t S c a l e ( ) ; +
+ p u b l i c b o o l e a n i s A u t o G e n e r a t e d ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D e f a u l t V a l u e ( ) ; +
+ p u b l i c b o o l e a n g e t N u l l a b l e ( ) ; +
+ p u b l i c b o o l e a n g e t R e a d O n l y ( ) ; +
+ p u b l i c v o i d s e t D a t a T y p e ( i n t ) ; +
+ p u b l i c v o i d s e t R e a d O n l y ( b o o l e a n ) ; +
+ p u b l i c v o i d s e t L e n g t h ( i n t ) ; +
+ p u b l i c v o i d s e t P r e c i s i o n ( i n t ) ; +
+ p u b l i c v o i d s e t S c a l e ( i n t ) ; +
+ p u b l i c v o i d s e t N u l l a b l e ( b o o l e a n ) ; +
+ p u b l i c v o i d s e t D e f a u l t V a l u e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t A u t o G e n e r a t i o n ( b o o l e a n ) ; +
+ C o m p i l e d f r o m " M g D a t a R e a d e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g D a t a R e a d e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g R e a d e r i m p l e m e n t s j a v a . l a n g . A u t o C l o s e a b l e { +
+ C o m p i l e d f r o m " M g D a t e T i m e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g D a t e T i m e e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ( s h o r t , s h o r t , s h o r t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ( s h o r t , s h o r t , s h o r t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ( s h o r t , s h o r t , s h o r t , s h o r t , s h o r t , s h o r t , i n t ) ; +
+ p u b l i c s h o r t g e t D a y ( ) ; +
+ p u b l i c s h o r t g e t M o n t h ( ) ; +
+ p u b l i c s h o r t g e t Y e a r ( ) ; +
+ p u b l i c s h o r t g e t H o u r ( ) ; +
+ p u b l i c s h o r t g e t M i n u t e ( ) ; +
+ p u b l i c s h o r t g e t S e c o n d ( ) ; +
+ p u b l i c i n t g e t M i c r o s e c o n d ( ) ; +
+ p u b l i c v o i d s e t D a y ( s h o r t ) ; +
+ p u b l i c v o i d s e t M o n t h ( s h o r t ) ; +
+ p u b l i c v o i d s e t Y e a r ( s h o r t ) ; +
+ p u b l i c v o i d s e t H o u r ( s h o r t ) ; +
+ p u b l i c v o i d s e t M i n u t e ( s h o r t ) ; +
+ p u b l i c v o i d s e t S e c o n d ( s h o r t ) ; +
+ p u b l i c v o i d s e t M i c r o s e c o n d ( i n t ) ; +
+ p u b l i c v o i d v a l i d a t e ( ) ; +
+ p u b l i c b o o l e a n i s D a t e ( ) ; +
+ p u b l i c b o o l e a n i s T i m e ( ) ; +
+ p u b l i c b o o l e a n i s D a t e T i m e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g t o S t r i n g ( ) ; +
+ C o m p i l e d f r o m " M g D a t e T i m e P r o p e r t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g D a t e T i m e P r o p e r t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D a t e T i m e P r o p e r t y ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D a t e T i m e g e t V a l u e ( ) ; +
+ p u b l i c s h o r t g e t P r o p e r t y T y p e ( ) ; +
+ p u b l i c v o i d s e t V a l u e ( o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ) ; +
+ C o m p i l e d f r o m " M g D e l e t e F e a t u r e s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g D e l e t e F e a t u r e s e x t e n d s o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D e l e t e F e a t u r e s ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t g e t C o m m a n d T y p e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t F e a t u r e C l a s s N a m e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t F i l t e r T e x t ( ) ; +
+ C o m p i l e d f r o m " M g D i s p o s a b l e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e e x t e n d s o r g . o s g e o . m a p g u i d e . M g O b j e c t { +
+ C o m p i l e d f r o m " M g D i s p o s a b l e C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e g e t I t e m ( i n t ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e ) ; +
+ p u b l i c v o i d a d d ( o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r t o X m l ( ) ; +
+ C o m p i l e d f r o m " M g D o u b l e P r o p e r t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g D o u b l e P r o p e r t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D o u b l e P r o p e r t y ( j a v a . l a n g . S t r i n g , d o u b l e ) ; +
+ p u b l i c v o i d s e t V a l u e ( d o u b l e ) ; +
+ C o m p i l e d f r o m " M g D r a w i n g S e r v i c e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g D r a w i n g S e r v i c e e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r v i c e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t D r a w i n g ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r d e s c r i b e D r a w i n g ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t S e c t i o n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t S e c t i o n R e s o u r c e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n e n u m e r a t e L a y e r s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t L a y e r ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r e n u m e r a t e S e c t i o n s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r e n u m e r a t e S e c t i o n R e s o u r c e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t C o o r d i n a t e S p a c e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ C o m p i l e d f r o m " M g D w f V e r s i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g D w f V e r s i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D w f V e r s i o n ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t F i l e V e r s i o n ( ) ; +
+ p u b l i c v o i d s e t F i l e V e r s i o n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S c h e m a V e r s i o n ( ) ; +
+ p u b l i c v o i d s e t S c h e m a V e r s i o n ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g E n v e l o p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g E n v e l o p e e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c s y n c h r o n i z e d v o i d d e l e t e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ( d o u b l e , d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ( o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t L o w e r L e f t C o o r d i n a t e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t U p p e r R i g h t C o o r d i n a t e ( ) ; +
+ p u b l i c d o u b l e g e t W i d t h ( ) ; +
+ p u b l i c d o u b l e g e t H e i g h t ( ) ; +
+ p u b l i c d o u b l e g e t D e p t h ( ) ; +
+ p u b l i c b o o l e a n i s N u l l ( ) ; +
+ p u b l i c v o i d m a k e N u l l ( ) ; +
+ p u b l i c v o i d e x p a n d T o I n c l u d e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c v o i d e x p a n d T o I n c l u d e ( o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ) ; +
+ p u b l i c b o o l e a n i n t e r s e c t s ( o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g E n v e l o p e t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ; +
+ C o m p i l e d f r o m " M g E x c e p t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g E x c e p t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . A p p T h r o w a b l e { +
+ p u b l i c j a v a . l a n g . S t r i n g g e t E x c e p t i o n C o d e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t E x c e p t i o n M e s s a g e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D e t a i l s ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t E x c e p t i o n S t a c k T r a c e ( ) ; +
+ p u b l i c l o n g g e t N a t i v e E r r o r C o d e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t E x c e p t i o n M e s s a g e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D e t a i l s ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t E x c e p t i o n S t a c k T r a c e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d a d d S t a c k T r a c e I n f o ( j a v a . l a n g . S t r i n g , i n t , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d a d d S t a c k T r a c e I n f o ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , i n t , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d p r i n t S t a c k T r a c e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t M e s s a g e ( ) ; +
+ C o m p i l e d f r o m " M g E x c e p t i o n C o d e s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g E x c e p t i o n C o d e s { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g A l l P r o v i d e r C o n n e c t i o n s U s e d E x c e p t i o n = " M g A l l P r o v i d e r C o n n e c t i o n s U s e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g A r g u m e n t O u t O f R a n g e E x c e p t i o n = " M g A r g u m e n t O u t O f R a n g e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g A r r a y T y p e M i s m a t c h E x c e p t i o n = " M g A r r a y T y p e M i s m a t c h E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g A u t h e n t i c a t i o n F a i l e d E x c e p t i o n = " M g A u t h e n t i c a t i o n F a i l e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g C l a s s N o t F o u n d E x c e p t i o n = " M g C l a s s N o t F o u n d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g C o n f i g u r a t i o n E x c e p t i o n = " M g C o n f i g u r a t i o n E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g C o n f i g u r a t i o n S a v e F a i l e d E x c e p t i o n = " M g C o n f i g u r a t i o n S a v e F a i l e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g C o n n e c t i o n F a i l e d E x c e p t i o n = " M g C o n n e c t i o n F a i l e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g C o n n e c t i o n N o t O p e n E x c e p t i o n = " M g C o n n e c t i o n N o t O p e n E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g C o o r d i n a t e S y s t e m C o m p u t a t i o n F a i l e d E x c e p t i o n = " M g C o o r d i n a t e S y s t e m C o m p u t a t i o n F a i l e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g C o o r d i n a t e S y s t e m C o n v e r s i o n F a i l e d E x c e p t i o n = " M g C o o r d i n a t e S y s t e m C o n v e r s i o n F a i l e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g C o o r d i n a t e S y s t e m I n i t i a l i z a t i o n F a i l e d E x c e p t i o n = " M g C o o r d i n a t e S y s t e m I n i t i a l i z a t i o n F a i l e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g C o o r d i n a t e S y s t e m L o a d F a i l e d E x c e p t i o n = " M g C o o r d i n a t e S y s t e m L o a d F a i l e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g C o o r d i n a t e S y s t e m M e a s u r e F a i l e d E x c e p t i o n = " M g C o o r d i n a t e S y s t e m M e a s u r e F a i l e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g C o o r d i n a t e S y s t e m T r a n s f o r m F a i l e d E x c e p t i o n = " M g C o o r d i n a t e S y s t e m T r a n s f o r m F a i l e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D a t e T i m e E x c e p t i o n = " M g D a t e T i m e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D b E x c e p t i o n = " M g D b E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D b X m l E x c e p t i o n = " M g D b X m l E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D e c r y p t i o n E x c e p t i o n = " M g D e c r y p t i o n E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D i r e c t o r y N o t F o u n d E x c e p t i o n = " M g D i r e c t o r y N o t F o u n d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D i v i d e B y Z e r o E x c e p t i o n = " M g D i v i d e B y Z e r o E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D o m a i n E x c e p t i o n = " M g D o m a i n E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D u p l i c a t e D i r e c t o r y E x c e p t i o n = " M g D u p l i c a t e D i r e c t o r y E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D u p l i c a t e F i l e E x c e p t i o n = " M g D u p l i c a t e F i l e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D u p l i c a t e G r o u p E x c e p t i o n = " M g D u p l i c a t e G r o u p E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D u p l i c a t e N a m e E x c e p t i o n = " M g D u p l i c a t e N a m e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D u p l i c a t e O b j e c t E x c e p t i o n = " M g D u p l i c a t e O b j e c t E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D u p l i c a t e P a r a m e t e r E x c e p t i o n = " M g D u p l i c a t e P a r a m e t e r E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D u p l i c a t e R e p o s i t o r y E x c e p t i o n = " M g D u p l i c a t e R e p o s i t o r y E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D u p l i c a t e R e s o u r c e D a t a E x c e p t i o n = " M g D u p l i c a t e R e s o u r c e D a t a E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D u p l i c a t e R e s o u r c e E x c e p t i o n = " M g D u p l i c a t e R e s o u r c e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D u p l i c a t e R o l e E x c e p t i o n = " M g D u p l i c a t e R o l e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D u p l i c a t e S e r v e r E x c e p t i o n = " M g D u p l i c a t e S e r v e r E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D u p l i c a t e S e s s i o n E x c e p t i o n = " M g D u p l i c a t e S e s s i o n E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D u p l i c a t e U s e r E x c e p t i o n = " M g D u p l i c a t e U s e r E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D w f E x c e p t i o n = " M g D w f E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D w f S e c t i o n N o t F o u n d E x c e p t i o n = " M g D w f S e c t i o n N o t F o u n d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g D w f S e c t i o n R e s o u r c e N o t F o u n d E x c e p t i o n = " M g D w f S e c t i o n R e s o u r c e N o t F o u n d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g E m p t y F e a t u r e S e t E x c e p t i o n = " M g E m p t y F e a t u r e S e t E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g E n c r y p t i o n E x c e p t i o n = " M g E n c r y p t i o n E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g E n d O f S t r e a m E x c e p t i o n = " M g E n d O f S t r e a m E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g E v a l u a t i o n E x p i r e d E x c e p t i o n = " M g E v a l u a t i o n E x p i r e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g F d o E x c e p t i o n = " M g F d o E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g F e a t u r e S e r v i c e E x c e p t i o n = " M g F e a t u r e S e r v i c e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g F i l e I o E x c e p t i o n = " M g F i l e I o E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g F i l e N o t F o u n d E x c e p t i o n = " M g F i l e N o t F o u n d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g G e o m e t r y E x c e p t i o n = " M g G e o m e t r y E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g G r o u p N o t F o u n d E x c e p t i o n = " M g G r o u p N o t F o u n d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n d e x O u t O f R a n g e E x c e p t i o n = " M g I n d e x O u t O f R a n g e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d A r g u m e n t E x c e p t i o n = " M g I n v a l i d A r g u m e n t E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d C a s t E x c e p t i o n = " M g I n v a l i d C a s t E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d C o o r d i n a t e S y s t e m E x c e p t i o n = " M g I n v a l i d C o o r d i n a t e S y s t e m E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d C o o r d i n a t e S y s t e m T y p e E x c e p t i o n = " M g I n v a l i d C o o r d i n a t e S y s t e m T y p e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d C o o r d i n a t e S y s t e m U n i t s E x c e p t i o n = " M g I n v a l i d C o o r d i n a t e S y s t e m U n i t s E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d D w f P a c k a g e E x c e p t i o n = " M g I n v a l i d D w f P a c k a g e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d D w f S e c t i o n E x c e p t i o n = " M g I n v a l i d D w f S e c t i o n E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d F e a t u r e S o u r c e E x c e p t i o n = " M g I n v a l i d F e a t u r e S o u r c e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d I p A d d r e s s E x c e p t i o n = " M g I n v a l i d I p A d d r e s s E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d L i c e n s e E x c e p t i o n = " M g I n v a l i d L i c e n s e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d L o g E n t r y E x c e p t i o n = " M g I n v a l i d L o g E n t r y E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d M a p D e f i n i t i o n E x c e p t i o n = " M g I n v a l i d M a p D e f i n i t i o n E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d M i m e T y p e E x c e p t i o n = " M g I n v a l i d M i m e T y p e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d O p e r a t i o n E x c e p t i o n = " M g I n v a l i d O p e r a t i o n E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d O p e r a t i o n V e r s i o n E x c e p t i o n = " M g I n v a l i d O p e r a t i o n V e r s i o n E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d P a s s w o r d E x c e p t i o n = " M g I n v a l i d P a s s w o r d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d P r i n t L a y o u t F o n t S i z e U n i t s E x c e p t i o n = " M g I n v a l i d P r i n t L a y o u t F o n t S i z e U n i t s E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d P r i n t L a y o u t P o s i t i o n U n i t s E x c e p t i o n = " M g I n v a l i d P r i n t L a y o u t P o s i t i o n U n i t s E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d P r i n t L a y o u t S i z e U n i t s E x c e p t i o n = " M g I n v a l i d P r i n t L a y o u t S i z e U n i t s E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d P r o p e r t y T y p e E x c e p t i o n = " M g I n v a l i d P r o p e r t y T y p e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d R e p o s i t o r y N a m e E x c e p t i o n = " M g I n v a l i d R e p o s i t o r y N a m e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d R e p o s i t o r y T y p e E x c e p t i o n = " M g I n v a l i d R e p o s i t o r y T y p e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d R e s o u r c e D a t a N a m e E x c e p t i o n = " M g I n v a l i d R e s o u r c e D a t a N a m e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d R e s o u r c e D a t a T y p e E x c e p t i o n = " M g I n v a l i d R e s o u r c e D a t a T y p e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d R e s o u r c e N a m e E x c e p t i o n = " M g I n v a l i d R e s o u r c e N a m e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d R e s o u r c e P a t h E x c e p t i o n = " M g I n v a l i d R e s o u r c e P a t h E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d R e s o u r c e P r e P r o c e s s i n g T y p e E x c e p t i o n = " M g I n v a l i d R e s o u r c e P r e P r o c e s s i n g T y p e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d R e s o u r c e T y p e E x c e p t i o n = " M g I n v a l i d R e s o u r c e T y p e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d S e r v e r N a m e E x c e p t i o n = " M g I n v a l i d S e r v e r N a m e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d S e r i a l N u m b e r E x c e p t i o n = " M g I n v a l i d S e r i a l N u m b e r E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d S t r e a m H e a d e r E x c e p t i o n = " M g I n v a l i d S t r e a m H e a d e r E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I o E x c e p t i o n = " M g I o E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g L a y e r N o t F o u n d E x c e p t i o n = " M g L a y e r N o t F o u n d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g L e n g t h E x c e p t i o n = " M g L e n g t h E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g L i c e n s e E x c e p t i o n = " M g L i c e n s e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g L i c e n s e E x p i r e d E x c e p t i o n = " M g L i c e n s e E x p i r e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g L o g i c E x c e p t i o n = " M g L o g i c E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g L o g O p e n F a i l e d E x c e p t i o n = " M g L o g O p e n F a i l e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g N o t F i n i t e N u m b e r E x c e p t i o n = " M g N o t F i n i t e N u m b e r E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g N o t I m p l e m e n t e d E x c e p t i o n = " M g N o t I m p l e m e n t e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g N u l l A r g u m e n t E x c e p t i o n = " M g N u l l A r g u m e n t E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g N u l l P r o p e r t y V a l u e E x c e p t i o n = " M g N u l l P r o p e r t y V a l u e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g N u l l R e f e r e n c e E x c e p t i o n = " M g N u l l R e f e r e n c e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g O b j e c t N o t F o u n d E x c e p t i o n = " M g O b j e c t N o t F o u n d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g O p e r a t i o n P r o c e s s i n g E x c e p t i o n = " M g O p e r a t i o n P r o c e s s i n g E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g O u t O f M e m o r y E x c e p t i o n = " M g O u t O f M e m o r y E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g O u t O f R a n g e E x c e p t i o n = " M g O u t O f R a n g e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g O v e r f l o w E x c e p t i o n = " M g O v e r f l o w E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g P a r a m e t e r N o t F o u n d E x c e p t i o n = " M g P a r a m e t e r N o t F o u n d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g P a t h T o o L o n g E x c e p t i o n = " M g P a t h T o o L o n g E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g P e r m i s s i o n D e n i e d E x c e p t i o n = " M g P e r m i s s i o n D e n i e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g P l a t f o r m N o t S u p p o r t e d E x c e p t i o n = " M g P l a t f o r m N o t S u p p o r t e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g P o r t N o t A v a i l a b l e E x c e p t i o n = " M g P o r t N o t A v a i l a b l e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g P r i n t T o S c a l e M o d e N o t S e l e c t e d E x c e p t i o n = " M g P r i n t T o S c a l e M o d e N o t S e l e c t e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g R a s t e r T r a n s f o r m a t i o n N o t S u p p o r t e d E x c e p t i o n = " M g R a s t e r T r a n s f o r m a t i o n N o t S u p p o r t e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g R e p o s i t o r y C r e a t i o n F a i l e d E x c e p t i o n = " M g R e p o s i t o r y C r e a t i o n F a i l e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g R e p o s i t o r y N o t F o u n d E x c e p t i o n = " M g R e p o s i t o r y N o t F o u n d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g R e p o s i t o r y N o t O p e n E x c e p t i o n = " M g R e p o s i t o r y N o t O p e n E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g R e p o s i t o r y O p e n F a i l e d E x c e p t i o n = " M g R e p o s i t o r y O p e n F a i l e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g R e s o u r c e B u s y E x c e p t i o n = " M g R e s o u r c e B u s y E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g R e s o u r c e D a t a N o t F o u n d E x c e p t i o n = " M g R e s o u r c e D a t a N o t F o u n d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g R e s o u r c e N o t F o u n d E x c e p t i o n = " M g R e s o u r c e N o t F o u n d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g R e s o u r c e s E x c e p t i o n = " M g R e s o u r c e s E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g R e s o u r c e T a g N o t F o u n d E x c e p t i o n = " M g R e s o u r c e T a g N o t F o u n d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g R o l e N o t F o u n d E x c e p t i o n = " M g R o l e N o t F o u n d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g R u n t i m e E x c e p t i o n = " M g R u n t i m e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g S e r v e r N o t F o u n d E x c e p t i o n = " M g S e r v e r N o t F o u n d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g S e r v e r N o t O n l i n e E x c e p t i o n = " M g S e r v e r N o t O n l i n e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g S e r v i c e N o t A v a i l a b l e E x c e p t i o n = " M g S e r v i c e N o t A v a i l a b l e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g S e r v i c e N o t S u p p o r t e d E x c e p t i o n = " M g S e r v i c e N o t S u p p o r t e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g S e s s i o n E x p i r e d E x c e p t i o n = " M g S e s s i o n E x p i r e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g S e s s i o n N o t F o u n d E x c e p t i o n = " M g S e s s i o n N o t F o u n d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g S t r e a m I o E x c e p t i o n = " M g S t r e a m I o E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g S t y l i z e L a y e r F a i l e d E x c e p t i o n = " M g S t y l i z e L a y e r F a i l e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g T e m p o r a r y F i l e N o t A v a i l a b l e E x c e p t i o n = " M g T e m p o r a r y F i l e N o t A v a i l a b l e E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g U n a u t h o r i z e d A c c e s s E x c e p t i o n = " M g U n a u t h o r i z e d A c c e s s E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g U n c l a s s i f i e d E x c e p t i o n = " M g U n c l a s s i f i e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g U n d e r f l o w E x c e p t i o n = " M g U n d e r f l o w E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g U n k n o w n T i l e P r o v i d e r E x c e p t i o n = " M g U n k n o w n T i l e P r o v i d e r E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g U n s u p p o r t e d P r o v i d e r T h r e a d M o d e l E x c e p t i o n = " M g U n s u p p o r t e d P r o v i d e r T h r e a d M o d e l E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g U n s u p p o r t e d T i l e P r o v i d e r E x c e p t i o n = " M g U n s u p p o r t e d T i l e P r o v i d e r E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g U r i F o r m a t E x c e p t i o n = " M g U r i F o r m a t E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g U s e r N o t F o u n d E x c e p t i o n = " M g U s e r N o t F o u n d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g X m l E x c e p t i o n = " M g X m l E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g X m l P a r s e r E x c e p t i o n = " M g X m l P a r s e r E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g C o n f i g u r a t i o n L o a d F a i l e d E x c e p t i o n = " M g C o n f i g u r a t i o n L o a d F a i l e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g R e s o u r c e s L o a d F a i l e d E x c e p t i o n = " M g R e s o u r c e s L o a d F a i l e d E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g G r i d D e n s i t y E x c e p t i o n = " M g G r i d D e n s i t y E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d L a y e r D e f i n i t i o n E x c e p t i o n = " M g I n v a l i d L a y e r D e f i n i t i o n E x c e p t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M g I n v a l i d W a t e r m a r k D e f i n i t i o n E x c e p t i o n = " M g I n v a l i d W a t e r m a r k D e f i n i t i o n E x c e p t i o n " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g E x c e p t i o n C o d e s ( ) ; +
+ C o m p i l e d f r o m " M g F e a t u r e A g g r e g a t e O p t i o n s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g F e a t u r e A g g r e g a t e O p t i o n s e x t e n d s o r g . o s g e o . m a p g u i d e . M g F e a t u r e Q u e r y O p t i o n s { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e A g g r e g a t e O p t i o n s ( ) ; +
+ p u b l i c v o i d s e l e c t D i s t i n c t ( b o o l e a n ) ; +
+ p u b l i c v o i d s e t G r o u p i n g F i l t e r ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g F e a t u r e C o m m a n d . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ C o m p i l e d f r o m " M g F e a t u r e C o m m a n d C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c i n t g e t C o u n t ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d g e t I t e m ( i n t ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d ) ; +
+ p u b l i c v o i d a d d ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d ) ; +
+ p u b l i c v o i d c l e a r ( ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d ) ; +
+ p u b l i c v o i d r e m o v e A t ( i n t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n ( ) ; +
+ C o m p i l e d f r o m " M g F e a t u r e C o m m a n d T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d T y p e { +
+ p u b l i c s t a t i c f i n a l i n t I n s e r t F e a t u r e s = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t U p d a t e F e a t u r e s = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t D e l e t e F e a t u r e s = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t L o c k F e a t u r e s = 3 ; +
+ p u b l i c s t a t i c f i n a l i n t U n l o c k F e a t u r e s = 4 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d T y p e ( ) ; +
+ C o m p i l e d f r o m " M g F e a t u r e G e o m e t r i c T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g F e a t u r e G e o m e t r i c T y p e { +
+ p u b l i c s t a t i c f i n a l i n t P o i n t = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t C u r v e = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t S u r f a c e = 4 ; +
+ p u b l i c s t a t i c f i n a l i n t S o l i d = 8 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e G e o m e t r i c T y p e ( ) ; +
+ C o m p i l e d f r o m " M g F e a t u r e I n f o r m a t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g F e a t u r e I n f o r m a t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n g e t S e l e c t i o n ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t T o o l t i p ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t H y p e r l i n k ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n g e t P r o p e r t i e s ( ) ; +
+ C o m p i l e d f r o m " M g F e a t u r e P r o p e r t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g F e a t u r e P r o p e r t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e P r o p e r t y ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r g e t V a l u e ( ) ; +
+ p u b l i c v o i d s e t V a l u e ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r ) ; +
+ C o m p i l e d f r o m " M g F e a t u r e P r o p e r t y T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g F e a t u r e P r o p e r t y T y p e { +
+ p u b l i c s t a t i c f i n a l i n t D a t a P r o p e r t y = 1 0 0 ; +
+ p u b l i c s t a t i c f i n a l i n t O b j e c t P r o p e r t y = 1 0 1 ; +
+ p u b l i c s t a t i c f i n a l i n t G e o m e t r i c P r o p e r t y = 1 0 2 ; +
+ p u b l i c s t a t i c f i n a l i n t A s s o c i a t i o n P r o p e r t y = 1 0 3 ; +
+ p u b l i c s t a t i c f i n a l i n t R a s t e r P r o p e r t y = 1 0 4 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e P r o p e r t y T y p e ( ) ; +
+ C o m p i l e d f r o m " M g F e a t u r e Q u e r y O p t i o n s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g F e a t u r e Q u e r y O p t i o n s e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e Q u e r y O p t i o n s ( ) ; +
+ p u b l i c i n t a d d F e a t u r e P r o p e r t y ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t a d d C o m p u t e d P r o p e r t y ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t F i l t e r ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t B i n a r y O p e r a t o r ( b o o l e a n ) ; +
+ p u b l i c v o i d s e t S p a t i a l F i l t e r ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g G e o m e t r y , i n t ) ; +
+ p u b l i c v o i d s e t O r d e r i n g F i l t e r ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , i n t ) ; +
+ p u b l i c v o i d r e m o v e F e a t u r e P r o p e r t y ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d r e m o v e C o m p u t e d P r o p e r t y ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t F e t c h S i z e ( i n t ) ; +
+ C o m p i l e d f r o m " M g F e a t u r e R e a d e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g R e a d e r i m p l e m e n t s j a v a . l a n g . A u t o C l o s e a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n g e t C l a s s D e f i n i t i o n ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r g e t F e a t u r e O b j e c t ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r g e t F e a t u r e O b j e c t ( i n t ) ; +
+ C o m p i l e d f r o m " M g F e a t u r e S c h e m a . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a e x t e n d s o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e { +
+ p u b l i c b o o l e a n e q u a l s ( j a v a . l a n g . O b j e c t ) ; +
+ p u b l i c i n t h a s h C o d e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t N a m e ( ) ; +
+ p u b l i c v o i d s e t N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D e s c r i p t i o n ( ) ; +
+ p u b l i c v o i d s e t D e s c r i p t i o n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n g e t C l a s s e s ( ) ; +
+ p u b l i c v o i d m a r k A s D e l e t e d ( ) ; +
+ C o m p i l e d f r o m " M g F e a t u r e S c h e m a C o l l e c t i o n . j a v a " +
+ c l a s s o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n $ I t e m I t e r a t o r i m p l e m e n t s j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a > { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n $ I t e m I t e r a t o r ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n ) ; +
+ p u b l i c b o o l e a n h a s N e x t ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a n e x t ( ) ; +
+ p u b l i c v o i d r e m o v e ( ) ; +
+ p u b l i c j a v a . l a n g . O b j e c t n e x t ( ) ; +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n i m p l e m e n t s j a v a . u t i l . C o l l e c t i o n < o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a > { +
+ p u b l i c j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a > i t e r a t o r ( ) ; +
+ p u b l i c b o o l e a n a d d ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ; +
+ p u b l i c b o o l e a n a d d A l l ( j a v a . u t i l . C o l l e c t i o n < ? e x t e n d s o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a > ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( j a v a . l a n g . O b j e c t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ; +
+ p u b l i c b o o l e a n r e m o v e ( j a v a . l a n g . O b j e c t ) ; +
+ p u b l i c b o o l e a n r e m o v e A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ; +
+ p u b l i c b o o l e a n r e t a i n A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ; +
+ p u b l i c i n t s i z e ( ) ; +
+ p u b l i c j a v a . l a n g . O b j e c t [ ] t o A r r a y ( ) ; +
+ p u b l i c < M g F e a t u r e S c h e m a > M g F e a t u r e S c h e m a [ ] t o A r r a y ( M g F e a t u r e S c h e m a [ ] ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n ( ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ; +
+ p u b l i c v o i d a d d I t e m ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a g e t I t e m ( i n t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ; +
+ p u b l i c b o o l e a n a d d ( j a v a . l a n g . O b j e c t ) ; +
+ C o m p i l e d f r o m " M g F e a t u r e S e r v i c e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g F e a t u r e S e r v i c e e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r v i c e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t F e a t u r e P r o v i d e r s ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n g e t C o n n e c t i o n P r o p e r t y V a l u e s ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n t e s t C o n n e c t i o n ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n t e s t C o n n e c t i o n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t C a p a b i l i t i e s ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t C a p a b i l i t i e s ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d a p p l y S c h e m a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n d e s c r i b e S c h e m a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n d e s c r i b e S c h e m a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g d e s c r i b e S c h e m a A s X m l ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g d e s c r i b e S c h e m a A s X m l ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g s c h e m a T o X m l ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n x m l T o S c h e m a ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r s e l e c t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g F e a t u r e Q u e r y O p t i o n s ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r s e l e c t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g F e a t u r e Q u e r y O p t i o n s , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D a t a R e a d e r s e l e c t A g g r e g a t e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g F e a t u r e A g g r e g a t e O p t i o n s ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n u p d a t e F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n u p d a t e F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r i n s e r t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r i n s e r t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r i n s e r t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r i n s e r t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ; +
+ p u b l i c i n t u p d a t e M a t c h i n g F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t u p d a t e M a t c h i n g F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ; +
+ p u b l i c i n t d e l e t e F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t d e l e t e F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r g e t L o c k e d F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g F e a t u r e Q u e r y O p t i o n s ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n b e g i n T r a n s a c t i o n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S q l D a t a R e a d e r e x e c u t e S q l Q u e r y ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S q l D a t a R e a d e r e x e c u t e S q l Q u e r y ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ; +
+ p u b l i c i n t e x e c u t e S q l N o n Q u e r y ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t e x e c u t e S q l N o n Q u e r y ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S p a t i a l C o n t e x t R e a d e r g e t S p a t i a l C o n t e x t s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L o n g T r a n s a c t i o n R e a d e r g e t L o n g T r a n s a c t i o n s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , b o o l e a n ) ; +
+ p u b l i c b o o l e a n s e t L o n g T r a n s a c t i o n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n g e t S c h e m a s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n g e t C l a s s e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n g e t C l a s s D e f i n i t i o n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d c r e a t e F e a t u r e S o u r c e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , o r g . o s g e o . m a p g u i d e . M g F e a t u r e S o u r c e P a r a m s ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r d e s c r i b e W f s F e a t u r e T y p e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r d e s c r i b e W f s F e a t u r e T y p e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t W f s F e a t u r e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t W f s F e a t u r e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , i n t , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r g e t W f s R e a d e r ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r e n u m e r a t e D a t a S t o r e s ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t S c h e m a M a p p i n g ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g F e a t u r e S o u r c e P a r a m s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g F e a t u r e S o u r c e P a r a m s e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ C o m p i l e d f r o m " M g F e a t u r e S p a t i a l O p e r a t i o n s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g F e a t u r e S p a t i a l O p e r a t i o n s { +
+ p u b l i c s t a t i c f i n a l i n t C o n t a i n s = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t C r o s s e s = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t D i s j o i n t = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t E q u a l s = 3 ; +
+ p u b l i c s t a t i c f i n a l i n t I n t e r s e c t s = 4 ; +
+ p u b l i c s t a t i c f i n a l i n t O v e r l a p s = 5 ; +
+ p u b l i c s t a t i c f i n a l i n t T o u c h e s = 6 ; +
+ p u b l i c s t a t i c f i n a l i n t W i t h i n = 7 ; +
+ p u b l i c s t a t i c f i n a l i n t C o v e r e d B y = 8 ; +
+ p u b l i c s t a t i c f i n a l i n t I n s i d e = 9 ; +
+ p u b l i c s t a t i c f i n a l i n t E n v e l o p e I n t e r s e c t s = 1 0 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e S p a t i a l O p e r a t i o n s ( ) ; +
+ C o m p i l e d f r o m " M g F i l e F e a t u r e S o u r c e P a r a m s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g F i l e F e a t u r e S o u r c e P a r a m s e x t e n d s o r g . o s g e o . m a p g u i d e . M g F e a t u r e S o u r c e P a r a m s { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F i l e F e a t u r e S o u r c e P a r a m s ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F i l e F e a t u r e S o u r c e P a r a m s ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F i l e F e a t u r e S o u r c e P a r a m s ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t P r o v i d e r N a m e ( ) ; +
+ p u b l i c v o i d s e t P r o v i d e r N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t F i l e N a m e ( ) ; +
+ p u b l i c v o i d s e t F i l e N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S p a t i a l C o n t e x t N a m e ( ) ; +
+ p u b l i c v o i d s e t S p a t i a l C o n t e x t N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S p a t i a l C o n t e x t D e s c r i p t i o n ( ) ; +
+ p u b l i c v o i d s e t S p a t i a l C o n t e x t D e s c r i p t i o n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t C o o r d i n a t e S y s t e m W k t ( ) ; +
+ p u b l i c v o i d s e t C o o r d i n a t e S y s t e m W k t ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c d o u b l e g e t X Y T o l e r a n c e ( ) ; +
+ p u b l i c v o i d s e t X Y T o l e r a n c e ( d o u b l e ) ; +
+ p u b l i c d o u b l e g e t Z T o l e r a n c e ( ) ; +
+ p u b l i c v o i d s e t Z T o l e r a n c e ( d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a g e t F e a t u r e S c h e m a ( ) ; +
+ p u b l i c v o i d s e t F e a t u r e S c h e m a ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ; +
+ C o m p i l e d f r o m " M g G e o J s o n W r i t e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G e o J s o n W r i t e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o J s o n W r i t e r ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g f e a t u r e T o G e o J s o n ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r , o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g f e a t u r e T o G e o J s o n ( o r g . o s g e o . m a p g u i d e . M g R e a d e r , o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t P r e c i s i o n ( i n t ) ; +
+ p u b l i c i n t g e t P r e c i s i o n ( ) ; +
+ p u b l i c v o i d s e t P r e c i s i o n E n a b l e d ( b o o l e a n ) ; +
+ p u b l i c b o o l e a n i s P r e c i s i o n E n a b l e d ( ) ; +
+ C o m p i l e d f r o m " M g G e o m e t r i c E n t i t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c i n t g e t D i m e n s i o n ( ) ; +
+ p u b l i c b o o l e a n i s E m p t y ( ) ; +
+ p u b l i c b o o l e a n i s S i m p l e ( ) ; +
+ p u b l i c b o o l e a n i s C l o s e d ( ) ; +
+ p u b l i c b o o l e a n i s V a l i d ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g E n v e l o p e e n v e l o p e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y c o p y ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ; +
+ p u b l i c d o u b l e g e t A r e a ( ) ; +
+ p u b l i c d o u b l e g e t L e n g t h ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P o i n t g e t C e n t r o i d ( ) ; +
+ C o m p i l e d f r o m " M g G e o m e t r i c P a t h I n s t r u c t i o n T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c P a t h I n s t r u c t i o n T y p e { +
+ p u b l i c s t a t i c f i n a l i n t M o v e T o = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t L i n e T o = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t Q u a d T o = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t C l o s e = 4 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c P a t h I n s t r u c t i o n T y p e ( ) ; +
+ C o m p i l e d f r o m " M g G e o m e t r i c P r o p e r t y D e f i n i t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c P r o p e r t y D e f i n i t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n { +
+ p u b l i c s y n c h r o n i z e d v o i d d e l e t e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c P r o p e r t y D e f i n i t i o n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t g e t G e o m e t r y T y p e s ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y T y p e I n f o g e t S p e c i f i c G e o m e t r y T y p e s ( ) ; +
+ p u b l i c b o o l e a n g e t R e a d O n l y ( ) ; +
+ p u b l i c b o o l e a n g e t H a s E l e v a t i o n ( ) ; +
+ p u b l i c b o o l e a n g e t H a s M e a s u r e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S p a t i a l C o n t e x t A s s o c i a t i o n ( ) ; +
+ p u b l i c v o i d s e t G e o m e t r y T y p e s ( i n t ) ; +
+ p u b l i c v o i d s e t S p e c i f i c G e o m e t r y T y p e s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y T y p e I n f o ) ; +
+ p u b l i c v o i d s e t R e a d O n l y ( b o o l e a n ) ; +
+ p u b l i c v o i d s e t H a s E l e v a t i o n ( b o o l e a n ) ; +
+ p u b l i c v o i d s e t H a s M e a s u r e ( b o o l e a n ) ; +
+ p u b l i c v o i d s e t S p a t i a l C o n t e x t A s s o c i a t i o n ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g G e o m e t r y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G e o m e t r y e x t e n d s o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y { +
+ p u b l i c i n t g e t G e o m e t r y T y p e ( ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c b o o l e a n c r o s s e s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c b o o l e a n d i s j o i n t ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c b o o l e a n e q u a l s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c b o o l e a n i n t e r s e c t s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c b o o l e a n o v e r l a p s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c b o o l e a n t o u c h e s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c b o o l e a n w i t h i n ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y b o u n d a r y ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y b u f f e r ( d o u b l e , o r g . o s g e o . m a p g u i d e . M g M e a s u r e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y c o n v e x H u l l ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y d i f f e r e n c e ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c d o u b l e d i s t a n c e ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y , o r g . o s g e o . m a p g u i d e . M g M e a s u r e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y i n t e r s e c t i o n ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y s y m e t r i c D i f f e r e n c e ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y u n i o n ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r e p a r e d G e o m e t r y p r e p a r e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y t e s s e l l a t e ( ) ; +
+ C o m p i l e d f r o m " M g G e o m e t r y C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G e o m e t r y C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y g e t I t e m ( i n t ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c v o i d a d d ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y C o l l e c t i o n ( ) ; +
+ C o m p i l e d f r o m " M g G e o m e t r y C o m p o n e n t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G e o m e t r y C o m p o n e n t e x t e n d s o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y { +
+ p u b l i c i n t g e t C o m p o n e n t T y p e ( ) ; +
+ C o m p i l e d f r o m " M g G e o m e t r y C o m p o n e n t T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G e o m e t r y C o m p o n e n t T y p e { +
+ p u b l i c s t a t i c f i n a l i n t L i n e a r R i n g = 1 2 9 ; +
+ p u b l i c s t a t i c f i n a l i n t A r c S e g m e n t = 1 3 0 ; +
+ p u b l i c s t a t i c f i n a l i n t L i n e a r S e g m e n t = 1 3 1 ; +
+ p u b l i c s t a t i c f i n a l i n t C u r v e R i n g = 1 3 2 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y C o m p o n e n t T y p e ( ) ; +
+ C o m p i l e d f r o m " M g G e o m e t r y E n t i t y T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G e o m e t r y E n t i t y T y p e { +
+ p u b l i c s t a t i c f i n a l i n t G e o m e t r y C o m p o n e n t = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t G e o m e t r y = 1 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y E n t i t y T y p e ( ) ; +
+ C o m p i l e d f r o m " M g G e o m e t r y F a c t o r y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G e o m e t r y F a c t o r y e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y F a c t o r y ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e c r e a t e C o o r d i n a t e X Y ( d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e c r e a t e C o o r d i n a t e X Y M ( d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e c r e a t e C o o r d i n a t e X Y Z ( d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e c r e a t e C o o r d i n a t e X Y Z M ( d o u b l e , d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g A r c S e g m e n t c r e a t e A r c S e g m e n t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L i n e a r S e g m e n t c r e a t e L i n e a r S e g m e n t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g c r e a t e L i n e a r R i n g ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g c r e a t e C u r v e R i n g ( o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P o i n t c r e a t e P o i n t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g c r e a t e L i n e S t r i n g ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g c r e a t e C u r v e S t r i n g ( o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P o l y g o n c r e a t e P o l y g o n ( o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g , o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n c r e a t e C u r v e P o l y g o n ( o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g , o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M u l t i P o i n t c r e a t e M u l t i P o i n t ( o r g . o s g e o . m a p g u i d e . M g P o i n t C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M u l t i L i n e S t r i n g c r e a t e M u l t i L i n e S t r i n g ( o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M u l t i C u r v e S t r i n g c r e a t e M u l t i C u r v e S t r i n g ( o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M u l t i P o l y g o n c r e a t e M u l t i P o l y g o n ( o r g . o s g e o . m a p g u i d e . M g P o l y g o n C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M u l t i C u r v e P o l y g o n c r e a t e M u l t i C u r v e P o l y g o n ( o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M u l t i G e o m e t r y c r e a t e M u l t i G e o m e t r y ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y C o l l e c t i o n ) ; +
+ C o m p i l e d f r o m " M g G e o m e t r y P r o p e r t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G e o m e t r y P r o p e r t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y P r o p e r t y ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t V a l u e ( ) ; +
+ p u b l i c s h o r t g e t P r o p e r t y T y p e ( ) ; +
+ p u b l i c v o i d s e t V a l u e ( o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ; +
+ C o m p i l e d f r o m " M g G e o m e t r y S i m p l i f i c a t i o n A l g o r i t h m T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G e o m e t r y S i m p l i f i c a t i o n A l g o r i t h m T y p e { +
+ p u b l i c s t a t i c f i n a l i n t D o u g l a s P e u c k e r = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t T o p o l o g y P r e s e r v i n g = 1 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y S i m p l i f i c a t i o n A l g o r i t h m T y p e ( ) ; +
+ C o m p i l e d f r o m " M g G e o m e t r y S i m p l i f i e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G e o m e t r y S i m p l i f i e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y S i m p l i f i e r ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y s i m p l i f y ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y , d o u b l e , i n t ) ; +
+ C o m p i l e d f r o m " M g G e o m e t r y T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G e o m e t r y T y p e { +
+ p u b l i c s t a t i c f i n a l i n t L i n e S t r i n g = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t P o l y g o n = 3 ; +
+ p u b l i c s t a t i c f i n a l i n t M u l t i P o i n t = 4 ; +
+ p u b l i c s t a t i c f i n a l i n t M u l t i L i n e S t r i n g = 5 ; +
+ p u b l i c s t a t i c f i n a l i n t M u l t i P o l y g o n = 6 ; +
+ p u b l i c s t a t i c f i n a l i n t M u l t i G e o m e t r y = 7 ; +
+ p u b l i c s t a t i c f i n a l i n t C u r v e S t r i n g = 1 0 ; +
+ p u b l i c s t a t i c f i n a l i n t C u r v e P o l y g o n = 1 1 ; +
+ p u b l i c s t a t i c f i n a l i n t M u l t i C u r v e S t r i n g = 1 2 ; +
+ p u b l i c s t a t i c f i n a l i n t M u l t i C u r v e P o l y g o n = 1 3 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y T y p e ( ) ; +
+ C o m p i l e d f r o m " M g G e o m e t r y T y p e I n f o . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G e o m e t r y T y p e I n f o e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y T y p e I n f o ( ) ; +
+ p u b l i c i n t g e t T y p e ( i n t ) ; +
+ p u b l i c v o i d s e t T y p e s ( o r g . o s g e o . m a p g u i d e . M g I n t C o l l e c t i o n ) ; +
+ C o m p i l e d f r o m " M g G r o u p . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G r o u p { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g E v e r y o n e = " E v e r y o n e " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G r o u p ( ) ; +
+ C o m p i l e d f r o m " M g G u a r d D i s p o s a b l e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e e x t e n d s o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e { +
+ C o m p i l e d f r o m " M g G w s F e a t u r e R e a d e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g G w s F e a t u r e R e a d e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r { +
+ C o m p i l e d f r o m " M g H t t p H e a d e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g H t t p H e a d e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g H t t p H e a d e r ( ) ; +
+ p u b l i c b o o l e a n a d d H e a d e r ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n r e m o v e H e a d e r ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t H e a d e r V a l u e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n s e t H e a d e r V a l u e ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t g e t D a t e H e a d e r ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t g e t I n t H e a d e r ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n g e t H e a d e r N a m e s ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n g e t H e a d e r s ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g H t t p P r i m i t i v e V a l u e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g H t t p P r i m i t i v e V a l u e e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g H t t p P r i m i t i v e V a l u e ( b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g H t t p P r i m i t i v e V a l u e ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g H t t p P r i m i t i v e V a l u e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t g e t T y p e ( ) ; +
+ p u b l i c b o o l e a n g e t B o o l V a l u e ( ) ; +
+ p u b l i c i n t g e t I n t e g e r V a l u e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S t r i n g V a l u e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g t o S t r i n g ( ) ; +
+ C o m p i l e d f r o m " M g H t t p R e q u e s t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g H t t p R e q u e s t e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g H t t p R e q u e s t ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g H t t p H e a d e r g e t H e a d e r ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g H t t p R e q u e s t P a r a m g e t R e q u e s t P a r a m ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g H t t p R e q u e s t M e t a d a t a g e t R e q u e s t M e t a d a t a ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g H t t p R e s p o n s e e x e c u t e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t A g e n t U r i ( ) ; +
+ C o m p i l e d f r o m " M g H t t p R e q u e s t M e t a d a t a . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g H t t p R e q u e s t M e t a d a t a e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g H t t p R e q u e s t M e t a d a t a ( ) ; +
+ p u b l i c b o o l e a n a d d P r o p e r t y ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n r e m o v e P r o p e r t y ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t P r o p e r t y V a l u e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n s e t P r o p e r t y V a l u e ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n g e t P r o p e r t y N a m e s ( ) ; +
+ C o m p i l e d f r o m " M g H t t p R e q u e s t P a r a m . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g H t t p R e q u e s t P a r a m e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g H t t p R e q u e s t P a r a m ( ) ; +
+ p u b l i c b o o l e a n a d d P a r a m e t e r ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n r e m o v e P a r a m e t e r ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t P a r a m e t e r V a l u e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t P a r a m e t e r T y p e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n s e t P a r a m e t e r V a l u e ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n s e t P a r a m e t e r T y p e ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n g e t P a r a m e t e r N a m e s ( ) ; +
+ p u b l i c b o o l e a n c o n t a i n s P a r a m e t e r ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g H t t p R e s p o n s e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g H t t p R e s p o n s e e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g H t t p R e s p o n s e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g H t t p R e s u l t g e t R e s u l t ( ) ; +
+ C o m p i l e d f r o m " M g H t t p R e s u l t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g H t t p R e s u l t e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c i n t g e t S t a t u s C o d e ( ) ; +
+ p u b l i c v o i d s e t S t a t u s C o d e ( i n t ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t E r r o r M e s s a g e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D e t a i l e d E r r o r M e s s a g e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t H t t p S t a t u s M e s s a g e ( ) ; +
+ p u b l i c v o i d s e t E r r o r M e s s a g e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t D e t a i l e d E r r o r M e s s a g e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t H t t p S t a t u s M e s s a g e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e g e t R e s u l t O b j e c t ( ) ; +
+ p u b l i c v o i d s e t R e s u l t O b j e c t ( o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t R e s u l t C o n t e n t T y p e ( ) ; +
+ C o m p i l e d f r o m " M g I m a g e F o r m a t s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g I m a g e F o r m a t s { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G i f = " G I F " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g J p e g = " J P G " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P n g = " P N G " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P n g 8 = " P N G 8 " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T i f f = " T I F " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g R a w = " R A W " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M e t a = " M E T A " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g I m a g e F o r m a t s ( ) ; +
+ C o m p i l e d f r o m " M g I n s e r t F e a t u r e s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g I n s e r t F e a t u r e s e x t e n d s o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g I n s e r t F e a t u r e s ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g I n s e r t F e a t u r e s ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n ) ; +
+ p u b l i c i n t g e t C o m m a n d T y p e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n g e t P r o p e r t y V a l u e s ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t F e a t u r e C l a s s N a m e ( ) ; +
+ C o m p i l e d f r o m " M g I n t 1 6 P r o p e r t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g I n t 1 6 P r o p e r t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g I n t 1 6 P r o p e r t y ( j a v a . l a n g . S t r i n g , s h o r t ) ; +
+ p u b l i c s h o r t g e t V a l u e ( ) ; +
+ p u b l i c v o i d s e t V a l u e ( s h o r t ) ; +
+ C o m p i l e d f r o m " M g I n t 3 2 P r o p e r t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g I n t 3 2 P r o p e r t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g I n t 3 2 P r o p e r t y ( j a v a . l a n g . S t r i n g , i n t ) ; +
+ p u b l i c i n t g e t V a l u e ( ) ; +
+ p u b l i c v o i d s e t V a l u e ( i n t ) ; +
+ C o m p i l e d f r o m " M g I n t 6 4 P r o p e r t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g I n t 6 4 P r o p e r t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g I n t 6 4 P r o p e r t y ( j a v a . l a n g . S t r i n g , l o n g ) ; +
+ p u b l i c l o n g g e t V a l u e ( ) ; +
+ p u b l i c v o i d s e t V a l u e ( l o n g ) ; +
+ C o m p i l e d f r o m " M g I n t C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g I n t C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g I n t C o l l e c t i o n ( ) ; +
+ p u b l i c i n t g e t I t e m ( i n t ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , i n t ) ; +
+ p u b l i c v o i d a d d I t e m ( i n t ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , i n t ) ; +
+ p u b l i c b o o l e a n r e m o v e ( i n t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( i n t ) ; +
+ p u b l i c i n t i n d e x O f ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r t o X m l ( ) ; +
+ C o m p i l e d f r o m " M g K m l S e r v i c e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g K m l S e r v i c e e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r v i c e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t M a p K m l ( o r g . o s g e o . m a p g u i d e . M g M a p , d o u b l e , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t L a y e r K m l ( o r g . o s g e o . m a p g u i d e . M g L a y e r , o r g . o s g e o . m a p g u i d e . M g E n v e l o p e , i n t , i n t , d o u b l e , i n t , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t F e a t u r e s K m l ( o r g . o s g e o . m a p g u i d e . M g L a y e r , o r g . o s g e o . m a p g u i d e . M g E n v e l o p e , i n t , i n t , d o u b l e , i n t , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t F e a t u r e s K m l ( o r g . o s g e o . m a p g u i d e . M g L a y e r , o r g . o s g e o . m a p g u i d e . M g E n v e l o p e , i n t , i n t , d o u b l e , i n t , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g L a y e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g L a y e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r s e l e c t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e Q u e r y O p t i o n s ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r s e l e c t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e Q u e r y O p t i o n s , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D a t a R e a d e r s e l e c t A g g r e g a t e ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e A g g r e g a t e O p t i o n s ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n u p d a t e F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n b e g i n T r a n s a c t i o n ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n u p d a t e F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r i n s e r t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r i n s e r t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ; +
+ p u b l i c i n t u p d a t e M a t c h i n g F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ; +
+ p u b l i c i n t d e l e t e F e a t u r e s ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g I n t C o l l e c t i o n g e t G e o m e t r y T y p e S t y l e s ( ) ; +
+ p u b l i c i n t g e t T h e m e C a t e g o r y C o u n t ( i n t ) ; +
+ p u b l i c i n t g e t C o m p o s i t e T h e m e C a t e g o r y C o u n t ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e n e r a t e L e g e n d I m a g e ( i n t , i n t , j a v a . l a n g . S t r i n g , i n t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g I n t C o l l e c t i o n g e t G e o m e t r y T y p e S t y l e s ( d o u b l e ) ; +
+ p u b l i c i n t g e t T h e m e C a t e g o r y C o u n t ( d o u b l e , i n t ) ; +
+ p u b l i c i n t g e t C o m p o s i t e T h e m e C a t e g o r y C o u n t ( d o u b l e , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e n e r a t e L e g e n d I m a g e ( d o u b l e , i n t , i n t , j a v a . l a n g . S t r i n g , i n t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S p a t i a l C o n t e x t R e a d e r g e t S p a t i a l C o n t e x t s ( b o o l e a n ) ; +
+ C o m p i l e d f r o m " M g L a y e r B a s e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e e x t e n d s o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t O b j e c t I d ( ) ; +
+ p u b l i c i n t g e t L a y e r T y p e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p g e t G r o u p ( ) ; +
+ p u b l i c v o i d s e t G r o u p ( o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ) ; +
+ p u b l i c b o o l e a n n e e d s R e f r e s h ( ) ; +
+ p u b l i c v o i d f o r c e R e f r e s h ( ) ; +
+ p u b l i c b o o l e a n g e t V i s i b l e ( ) ; +
+ p u b l i c v o i d s e t V i s i b l e ( b o o l e a n ) ; +
+ p u b l i c b o o l e a n i s V i s i b l e ( ) ; +
+ p u b l i c b o o l e a n g e t S e l e c t a b l e ( ) ; +
+ p u b l i c v o i d s e t S e l e c t a b l e ( b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r g e t L a y e r D e f i n i t i o n ( ) ; +
+ p u b l i c v o i d s e t L a y e r D e f i n i t i o n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e ) ; +
+ p u b l i c b o o l e a n g e t D i s p l a y I n L e g e n d ( ) ; +
+ p u b l i c v o i d s e t D i s p l a y I n L e g e n d ( b o o l e a n ) ; +
+ p u b l i c b o o l e a n g e t E x p a n d I n L e g e n d ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t L e g e n d L a b e l ( ) ; +
+ p u b l i c v o i d s e t L e g e n d L a b e l ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t F e a t u r e S o u r c e I d ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t F i l t e r ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t F e a t u r e G e o m e t r y N a m e ( ) ; +
+ C o m p i l e d f r o m " M g L a y e r C o l l e c t i o n . j a v a " +
+ c l a s s o r g . o s g e o . m a p g u i d e . M g L a y e r C o l l e c t i o n $ I t e m I t e r a t o r i m p l e m e n t s j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e > { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r C o l l e c t i o n $ I t e m I t e r a t o r ( o r g . o s g e o . m a p g u i d e . M g L a y e r C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g L a y e r C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e n e x t ( ) ; +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g L a y e r C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e i m p l e m e n t s j a v a . u t i l . C o l l e c t i o n < o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e > { +
+ p u b l i c j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e > i t e r a t o r ( ) ; +
+ p u b l i c b o o l e a n a d d ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ; +
+ p u b l i c b o o l e a n a d d A l l ( j a v a . u t i l . C o l l e c t i o n < ? e x t e n d s o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e > ) ; +
+ p u b l i c < M g L a y e r B a s e > M g L a y e r B a s e [ ] t o A r r a y ( M g L a y e r B a s e [ ] ) ; +
+ p u b l i c i n t g e t C o u n t ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e g e t I t e m ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e g e t I t e m ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ; +
+ p u b l i c v o i d a d d I t e m ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ; +
+ p u b l i c v o i d c l e a r ( ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ; +
+ p u b l i c v o i d r e m o v e A t ( i n t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ; +
+ p u b l i c i n t i n d e x O f ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ; +
+ C o m p i l e d f r o m " M g L a y e r G r o u p . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p e x t e n d s o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t g e t L a y e r G r o u p T y p e ( ) ; +
+ p u b l i c v o i d s e t E x p a n d I n L e g e n d ( b o o l e a n ) ; +
+ C o m p i l e d f r o m " M g L a y e r G r o u p C o l l e c t i o n . j a v a " +
+ c l a s s o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p C o l l e c t i o n $ I t e m I t e r a t o r i m p l e m e n t s j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p > { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p C o l l e c t i o n $ I t e m I t e r a t o r ( o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p n e x t ( ) ; +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e i m p l e m e n t s j a v a . u t i l . C o l l e c t i o n < o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p > { +
+ p u b l i c j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p > i t e r a t o r ( ) ; +
+ p u b l i c b o o l e a n a d d ( o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ) ; +
+ p u b l i c b o o l e a n a d d A l l ( j a v a . u t i l . C o l l e c t i o n < ? e x t e n d s o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p > ) ; +
+ p u b l i c < M g L a y e r G r o u p > M g L a y e r G r o u p [ ] t o A r r a y ( M g L a y e r G r o u p [ ] ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p g e t I t e m ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p g e t I t e m ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ) ; +
+ p u b l i c v o i d a d d I t e m ( o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ) ; +
+ C o m p i l e d f r o m " M g L a y e r G r o u p T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p T y p e { +
+ p u b l i c s t a t i c f i n a l i n t N o r m a l = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t B a s e M a p = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t B a s e M a p F r o m T i l e S e t = 3 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p T y p e ( ) ; +
+ C o m p i l e d f r o m " M g L a y e r T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g L a y e r T y p e { +
+ p u b l i c s t a t i c f i n a l i n t D y n a m i c = 1 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r T y p e ( ) ; +
+ C o m p i l e d f r o m " M g L a y o u t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g L a y o u t e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y o u t ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r g e t L a y o u t ( ) ; +
+ p u b l i c v o i d s e t L a y o u t ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t T i t l e ( ) ; +
+ p u b l i c v o i d s e t T i t l e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t U n i t T y p e ( ) ; +
+ p u b l i c v o i d s e t U n i t T y p e ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g L i n e a r R i n g . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g e x t e n d s o r g . o s g e o . m a p g u i d e . M g R i n g { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e I t e r a t o r g e t C o o r d i n a t e s ( ) ; +
+ C o m p i l e d f r o m " M g L i n e a r R i n g C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g g e t I t e m ( i n t ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g ) ; +
+ p u b l i c v o i d a d d ( o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g C o l l e c t i o n ( ) ; +
+ C o m p i l e d f r o m " M g L i n e a r S e g m e n t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g L i n e a r S e g m e n t e x t e n d s o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t S t a r t C o o r d i n a t e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t E n d C o o r d i n a t e ( ) ; +
+ C o m p i l e d f r o m " M g L i n e S t r i n g . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g e x t e n d s o r g . o s g e o . m a p g u i d e . M g C u r v e { +
+ C o m p i l e d f r o m " M g L i n e S t r i n g C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g g e t I t e m ( i n t ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g ) ; +
+ p u b l i c v o i d a d d ( o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n ( ) ; +
+ C o m p i l e d f r o m " M g L o c a l i z e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g L o c a l i z e r { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L o c a l i z e r ( ) ; +
+ p u b l i c s t a t i c v o i d S e t L o c a l i z e d F i l e s P a t h ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c s t a t i c j a v a . l a n g . S t r i n g L o c a l i z e ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , i n t ) ; +
+ p u b l i c s t a t i c j a v a . l a n g . S t r i n g G e t S t r i n g ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g L o g F i l e T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g L o g F i l e T y p e { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A c c e s s = " A c c e s s L o g " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A d m i n = " A d m i n L o g " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A u t h e n t i c a t i o n = " A u t h e n t i c a t i o n L o g " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g E r r o r = " E r r o r L o g " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S e s s i o n = " S e s s i o n L o g " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T r a c e = " T r a c e L o g " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L o g F i l e T y p e ( ) ; +
+ C o m p i l e d f r o m " M g L o n g T r a n s a c t i o n R e a d e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g L o n g T r a n s a c t i o n R e a d e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e i m p l e m e n t s j a v a . l a n g . A u t o C l o s e a b l e { +
+ p u b l i c j a v a . l a n g . S t r i n g g e t N a m e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D e s c r i p t i o n ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L o n g T r a n s a c t i o n R e a d e r g e t C h i l d r e n ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L o n g T r a n s a c t i o n R e a d e r g e t P a r e n t s ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t O w n e r ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D a t e T i m e g e t C r e a t i o n D a t e ( ) ; +
+ p u b l i c b o o l e a n i s A c t i v e ( ) ; +
+ p u b l i c b o o l e a n i s F r o z e n ( ) ; +
+ p u b l i c b o o l e a n r e a d N e x t ( ) ; +
+ p u b l i c v o i d c l o s e ( ) ; +
+ C o m p i l e d f r o m " M g M a p . j a v a " +
+ p u b l i c f i n a l c l a s s o r g . o s g e o . m a p g u i d e . M g M a p $ W a t e r m a r k U s a g e T y p e { +
+ p u b l i c s t a t i c f i n a l o r g . o s g e o . m a p g u i d e . M g M a p $ W a t e r m a r k U s a g e T y p e W M S ; +
+ p u b l i c s t a t i c f i n a l o r g . o s g e o . m a p g u i d e . M g M a p $ W a t e r m a r k U s a g e T y p e V i e w e r ; +
+ p u b l i c f i n a l i n t s w i g V a l u e ( ) ; +
+ p u b l i c s t a t i c o r g . o s g e o . m a p g u i d e . M g M a p $ W a t e r m a r k U s a g e T y p e s w i g T o E n u m ( i n t ) ; +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g M a p e x t e n d s o r g . o s g e o . m a p g u i d e . M g M a p B a s e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M a p ( o r g . o s g e o . m a p g u i d e . M g S i t e C o n n e c t i o n ) ; +
+ p u b l i c v o i d c r e a t e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d c r e a t e ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g E n v e l o p e , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d c r e a t e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , i n t , i n t , d o u b l e , d o u b l e , d o u b l e , i n t ) ; +
+ p u b l i c v o i d o p e n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s a v e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e , o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c v o i d s a v e ( ) ; +
+ p u b l i c i n t g e t W a t e r m a r k U s a g e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r g e t T i l e S e t D e f i n i t i o n ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t T i l e S e t P r o v i d e r ( ) ; +
+ p u b l i c i n t g e t T i l e P i x e l R a t i o ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t T i l e F o r m a t ( ) ; +
+ C o m p i l e d f r o m " M g M a p B a s e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g M a p B a s e e x t e n d s o r g . o s g e o . m a p g u i d e . M g R e s o u r c e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M a p B a s e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S e s s i o n I d ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r g e t M a p D e f i n i t i o n ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t M a p S R S ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g E n v e l o p e g e t M a p E x t e n t ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r C o l l e c t i o n g e t L a y e r s ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p C o l l e c t i o n g e t L a y e r G r o u p s ( ) ; +
+ p u b l i c v o i d c r e a t e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e , o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d o p e n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P o i n t g e t V i e w C e n t e r ( ) ; +
+ p u b l i c d o u b l e g e t V i e w S c a l e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g E n v e l o p e g e t D a t a E x t e n t ( ) ; +
+ p u b l i c i n t g e t D i s p l a y D p i ( ) ; +
+ p u b l i c v o i d s e t D i s p l a y D p i ( i n t ) ; +
+ p u b l i c i n t g e t D i s p l a y W i d t h ( ) ; +
+ p u b l i c i n t g e t D i s p l a y H e i g h t ( ) ; +
+ p u b l i c i n t g e t F i n i t e D i s p l a y S c a l e C o u n t ( ) ; +
+ p u b l i c d o u b l e g e t F i n i t e D i s p l a y S c a l e A t ( i n t ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t B a c k g r o u n d C o l o r ( ) ; +
+ C o m p i l e d f r o m " M g M a p C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g M a p C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M a p B a s e g e t I t e m ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M a p B a s e g e t I t e m ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g M a p B a s e ) ; +
+ p u b l i c v o i d a d d ( o r g . o s g e o . m a p g u i d e . M g M a p B a s e ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g M a p B a s e ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g M a p B a s e ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g M a p B a s e ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g M a p B a s e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M a p C o l l e c t i o n ( ) ; +
+ C o m p i l e d f r o m " M g M a p p i n g S e r v i c e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g M a p p i n g S e r v i c e e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r v i c e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e n e r a t e P l o t ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n , o r g . o s g e o . m a p g u i d e . M g L a y o u t , o r g . o s g e o . m a p g u i d e . M g D w f V e r s i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e n e r a t e P l o t ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , d o u b l e , o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n , o r g . o s g e o . m a p g u i d e . M g L a y o u t , o r g . o s g e o . m a p g u i d e . M g D w f V e r s i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e n e r a t e P l o t ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g E n v e l o p e , b o o l e a n , o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n , o r g . o s g e o . m a p g u i d e . M g L a y o u t , o r g . o s g e o . m a p g u i d e . M g D w f V e r s i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e n e r a t e M u l t i P l o t ( o r g . o s g e o . m a p g u i d e . M g M a p P l o t C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g D w f V e r s i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e n e r a t e L e g e n d I m a g e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , d o u b l e , i n t , i n t , j a v a . l a n g . S t r i n g , i n t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r c r e a t e R u n t i m e M a p ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , i n t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r c r e a t e R u n t i m e M a p ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , i n t , i n t , i n t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r d e s c r i b e R u n t i m e M a p ( o r g . o s g e o . m a p g u i d e . M g M a p , i n t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r d e s c r i b e R u n t i m e M a p ( o r g . o s g e o . m a p g u i d e . M g M a p , j a v a . l a n g . S t r i n g , i n t , i n t , i n t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r q u e r y F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g M a p , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r q u e r y F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , i n t , i n t , i n t , j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g M a p P l o t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g M a p P l o t e x t e n d s o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M a p P l o t ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n , o r g . o s g e o . m a p g u i d e . M g L a y o u t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M a p P l o t ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , d o u b l e , o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n , o r g . o s g e o . m a p g u i d e . M g L a y o u t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M a p P l o t ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g E n v e l o p e , b o o l e a n , o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n , o r g . o s g e o . m a p g u i d e . M g L a y o u t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M a p g e t M a p ( ) ; +
+ p u b l i c v o i d s e t M a p ( o r g . o s g e o . m a p g u i d e . M g M a p ) ; +
+ p u b l i c i n t g e t M a p P l o t I n s t r u c t i o n ( ) ; +
+ p u b l i c v o i d s e t M a p P l o t I n s t r u c t i o n ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t C e n t e r ( ) ; +
+ p u b l i c d o u b l e g e t S c a l e ( ) ; +
+ p u b l i c v o i d s e t C e n t e r A n d S c a l e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g E n v e l o p e g e t E x t e n t ( ) ; +
+ p u b l i c b o o l e a n g e t E x p a n d T o F i t ( ) ; +
+ p u b l i c v o i d s e t E x t e n t ( o r g . o s g e o . m a p g u i d e . M g E n v e l o p e , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n g e t P l o t S p e c i f i c a t i o n ( ) ; +
+ p u b l i c v o i d s e t P l o t S p e c i f i c a t i o n ( o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y o u t g e t L a y o u t ( ) ; +
+ p u b l i c v o i d s e t L a y o u t ( o r g . o s g e o . m a p g u i d e . M g L a y o u t ) ; +
+ C o m p i l e d f r o m " M g M a p P l o t C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g M a p P l o t C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M a p P l o t g e t I t e m ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M a p P l o t g e t I t e m ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g M a p P l o t ) ; +
+ p u b l i c v o i d a d d ( o r g . o s g e o . m a p g u i d e . M g M a p P l o t ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g M a p P l o t ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g M a p P l o t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g M a p P l o t ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g M a p P l o t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M a p P l o t C o l l e c t i o n ( ) ; +
+ C o m p i l e d f r o m " M g M a p P l o t I n s t r u c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g M a p P l o t I n s t r u c t i o n { +
+ p u b l i c s t a t i c f i n a l i n t U s e M a p C e n t e r A n d S c a l e = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t U s e O v e r r i d d e n C e n t e r A n d S c a l e = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t U s e O v e r r i d d e n E x t e n t = 2 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M a p P l o t I n s t r u c t i o n ( ) ; +
+ C o m p i l e d f r o m " M g M e a s u r e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g M e a s u r e e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c s y n c h r o n i z e d v o i d d e l e t e ( ) ; +
+ p u b l i c d o u b l e g e t D i s t a n c e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c d o u b l e g e t A z i m u t h ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t C o o r d i n a t e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , d o u b l e , d o u b l e ) ; +
+ C o m p i l e d f r o m " M g M e t a t i l e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g M e t a t i l e e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t I m a g e ( ) ; +
+ p u b l i c i n t g e t R e q u e s t e d W i d t h ( ) ; +
+ p u b l i c i n t g e t R e q u e s t e d H e i g h t ( ) ; +
+ p u b l i c i n t g e t W i d t h ( ) ; +
+ p u b l i c i n t g e t H e i g h t ( ) ; +
+ p u b l i c i n t g e t M e t a T i l i n g F a c t o r ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t T i l e I m a g e F o r m a t ( ) ; +
+ C o m p i l e d f r o m " M g M i m e T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g M i m e T y p e { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A g f = " a p p l i c a t i o n / a g f " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g B i n a r y = " a p p l i c a t i o n / o c t e t - s t r e a m " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D w f = " m o d e l / v n d . d w f " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g G i f = " i m a g e / g i f " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g J p e g = " i m a g e / j p e g " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P n g = " i m a g e / p n g " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T e x t = " t e x t / p l a i n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T i f f = " i m a g e / t i f f " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g X m l = " t e x t / x m l " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g J s o n = " a p p l i c a t i o n / j s o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g H t m l = " t e x t / h t m l " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g K m l = " a p p l i c a t i o n / v n d . g o o g l e - e a r t h . k m l + x m l " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g K m z = " a p p l i c a t i o n / v n d . g o o g l e - e a r t h . k m z " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M e t a = " a p p l i c a t i o n / m e t a t i l e " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M i m e T y p e ( ) ; +
+ C o m p i l e d f r o m " M g M u l t i C u r v e P o l y g o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g M u l t i C u r v e P o l y g o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g A g g r e g a t e G e o m e t r y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n g e t C u r v e P o l y g o n ( i n t ) ; +
+ p u b l i c i n t g e t G e o m e t r y T y p e ( ) ; +
+ p u b l i c i n t g e t D i m e n s i o n ( ) ; +
+ p u b l i c b o o l e a n i s E m p t y ( ) ; +
+ p u b l i c b o o l e a n i s C l o s e d ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y c o p y ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ; +
+ C o m p i l e d f r o m " M g M u l t i C u r v e S t r i n g . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g M u l t i C u r v e S t r i n g e x t e n d s o r g . o s g e o . m a p g u i d e . M g A g g r e g a t e G e o m e t r y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g g e t C u r v e S t r i n g ( i n t ) ; +
+ C o m p i l e d f r o m " M g M u l t i G e o m e t r y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g M u l t i G e o m e t r y e x t e n d s o r g . o s g e o . m a p g u i d e . M g A g g r e g a t e G e o m e t r y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y g e t G e o m e t r y ( i n t ) ; +
+ C o m p i l e d f r o m " M g M u l t i L i n e S t r i n g . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g M u l t i L i n e S t r i n g e x t e n d s o r g . o s g e o . m a p g u i d e . M g A g g r e g a t e G e o m e t r y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g g e t L i n e S t r i n g ( i n t ) ; +
+ C o m p i l e d f r o m " M g M u l t i P o i n t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g M u l t i P o i n t e x t e n d s o r g . o s g e o . m a p g u i d e . M g A g g r e g a t e G e o m e t r y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P o i n t g e t P o i n t ( i n t ) ; +
+ C o m p i l e d f r o m " M g M u l t i P o l y g o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g M u l t i P o l y g o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g A g g r e g a t e G e o m e t r y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P o l y g o n g e t P o l y g o n ( i n t ) ; +
+ C o m p i l e d f r o m " M g N a m e d S e r i a l i z a b l e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ C o m p i l e d f r o m " M g N u l l a b l e P r o p e r t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g P r o p e r t y { +
+ p u b l i c v o i d s e t N u l l ( b o o l e a n ) ; +
+ p u b l i c b o o l e a n i s N u l l ( ) ; +
+ C o m p i l e d f r o m " M g O b j e c t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g O b j e c t { +
+ p u b l i c i n t g e t C l a s s I d ( ) ; +
+ C o m p i l e d f r o m " M g O b j e c t P r o p e r t y D e f i n i t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g O b j e c t P r o p e r t y D e f i n i t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g O b j e c t P r o p e r t y D e f i n i t i o n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n g e t C l a s s D e f i n i t i o n ( ) ; +
+ p u b l i c i n t g e t O b j e c t T y p e ( ) ; +
+ p u b l i c i n t g e t O r d e r T y p e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D a t a P r o p e r t y D e f i n i t i o n g e t I d e n t i t y P r o p e r t y ( ) ; +
+ p u b l i c v o i d s e t C l a s s D e f i n i t i o n ( o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ) ; +
+ p u b l i c v o i d s e t O b j e c t T y p e ( i n t ) ; +
+ p u b l i c v o i d s e t O r d e r T y p e ( i n t ) ; +
+ p u b l i c v o i d s e t I d e n t i t y P r o p e r t y ( o r g . o s g e o . m a p g u i d e . M g D a t a P r o p e r t y D e f i n i t i o n ) ; +
+ C o m p i l e d f r o m " M g O b j e c t P r o p e r t y T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g O b j e c t P r o p e r t y T y p e { +
+ p u b l i c s t a t i c f i n a l i n t V a l u e = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t C o l l e c t i o n = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t O r d e r e d C o l l e c t i o n = 2 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g O b j e c t P r o p e r t y T y p e ( ) ; +
+ C o m p i l e d f r o m " M g O r d e r i n g O p t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g O r d e r i n g O p t i o n { +
+ p u b l i c s t a t i c f i n a l i n t A s c e n d i n g = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t D e s c e n d i n g = 1 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g O r d e r i n g O p t i o n ( ) ; +
+ C o m p i l e d f r o m " M g P a c k a g e S t a t u s I n f o r m a t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g P a c k a g e S t a t u s I n f o r m a t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P a c k a g e S t a t u s I n f o r m a t i o n ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S t a t u s M e s s a g e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S t a t u s C o d e ( ) ; +
+ p u b l i c v o i d s e t S t a t u s C o d e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t A p i N a m e ( ) ; +
+ p u b l i c v o i d s e t A p i N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t P a c k a g e N a m e ( ) ; +
+ p u b l i c v o i d s e t P a c k a g e N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t P a c k a g e D e s c r i p t i o n ( ) ; +
+ p u b l i c v o i d s e t P a c k a g e D e s c r i p t i o n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D a t e T i m e g e t P a c k a g e D a t e ( ) ; +
+ p u b l i c v o i d s e t P a c k a g e D a t e ( o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ) ; +
+ p u b l i c l o n g g e t P a c k a g e S i z e ( ) ; +
+ p u b l i c v o i d s e t P a c k a g e S i z e ( l o n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t U s e r N a m e ( ) ; +
+ p u b l i c v o i d s e t U s e r N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S e r v e r N a m e ( ) ; +
+ p u b l i c v o i d s e t S e r v e r N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S e r v e r A d d r e s s ( ) ; +
+ p u b l i c v o i d s e t S e r v e r A d d r e s s ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D a t e T i m e g e t S t a r t T i m e ( ) ; +
+ p u b l i c v o i d s e t S t a r t T i m e ( o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D a t e T i m e g e t E n d T i m e ( ) ; +
+ p u b l i c v o i d s e t E n d T i m e ( o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ) ; +
+ p u b l i c i n t g e t O p e r a t i o n s F a i l e d ( ) ; +
+ p u b l i c v o i d s e t O p e r a t i o n s F a i l e d ( i n t ) ; +
+ p u b l i c i n t g e t O p e r a t i o n s R e c e i v e d ( ) ; +
+ p u b l i c v o i d s e t O p e r a t i o n s R e c e i v e d ( i n t ) ; +
+ p u b l i c d o u b l e g e t A v e r a g e O p e r a t i o n T i m e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S t a c k T r a c e ( ) ; +
+ p u b l i c v o i d s e t S t a c k T r a c e ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g P a g e U n i t s T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g P a g e U n i t s T y p e { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g I n c h e s = " i n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M i l l i m e t e r s = " m m " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P a g e U n i t s T y p e ( ) ; +
+ C o m p i l e d f r o m " M g P a r a m e t e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r ( o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r ( o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y , i n t ) ; +
+ p u b l i c v o i d s e t P r o p e r t y ( o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y g e t P r o p e r t y ( ) ; +
+ p u b l i c v o i d s e t D i r e c t i o n ( i n t ) ; +
+ p u b l i c i n t g e t D i r e c t i o n ( ) ; +
+ p u b l i c v o i d s e t N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g P a r a m e t e r C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r C o l l e c t i o n ( ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r ) ; +
+ p u b l i c v o i d a d d ( o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r g e t I t e m ( i n t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r ) ; +
+ C o m p i l e d f r o m " M g P a r a m e t e r D i r e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r D i r e c t i o n { +
+ p u b l i c s t a t i c f i n a l i n t I n p u t = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t O u t p u t = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t I n p u t O u t p u t = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t R e t = 3 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r D i r e c t i o n ( ) ; +
+ C o m p i l e d f r o m " M g P l o t S p e c i f i c a t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ( f l o a t , f l o a t , j a v a . l a n g . S t r i n g , f l o a t , f l o a t , f l o a t , f l o a t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ( f l o a t , f l o a t , j a v a . l a n g . S t r i n g , f l o a t , f l o a t , f l o a t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ( f l o a t , f l o a t , j a v a . l a n g . S t r i n g , f l o a t , f l o a t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ( f l o a t , f l o a t , j a v a . l a n g . S t r i n g , f l o a t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ( f l o a t , f l o a t , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c f l o a t g e t P a p e r W i d t h ( ) ; +
+ p u b l i c v o i d s e t P a p e r W i d t h ( f l o a t ) ; +
+ p u b l i c f l o a t g e t P a p e r H e i g h t ( ) ; +
+ p u b l i c v o i d s e t P a p e r H e i g h t ( f l o a t ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t P a g e S i z e U n i t s ( ) ; +
+ p u b l i c v o i d s e t P a g e S i z e U n i t s ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c f l o a t g e t M a r g i n L e f t ( ) ; +
+ p u b l i c f l o a t g e t M a r g i n T o p ( ) ; +
+ p u b l i c f l o a t g e t M a r g i n R i g h t ( ) ; +
+ p u b l i c f l o a t g e t M a r g i n B o t t o m ( ) ; +
+ p u b l i c v o i d s e t M a r g i n s ( f l o a t , f l o a t , f l o a t , f l o a t ) ; +
+ C o m p i l e d f r o m " M g P o i n t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g P o i n t e x t e n d s o r g . o s g e o . m a p g u i d e . M g G e o m e t r y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e g e t C o o r d i n a t e ( ) ; +
+ C o m p i l e d f r o m " M g P o i n t C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g P o i n t C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P o i n t g e t I t e m ( i n t ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g P o i n t ) ; +
+ p u b l i c v o i d a d d ( o r g . o s g e o . m a p g u i d e . M g P o i n t ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g P o i n t ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g P o i n t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g P o i n t ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g P o i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P o i n t C o l l e c t i o n ( ) ; +
+ C o m p i l e d f r o m " M g P o l y g o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g P o l y g o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g R e g i o n { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g g e t E x t e r i o r R i n g ( ) ; +
+ p u b l i c i n t g e t I n t e r i o r R i n g C o u n t ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g g e t I n t e r i o r R i n g ( i n t ) ; +
+ C o m p i l e d f r o m " M g P o l y g o n C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g P o l y g o n C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P o l y g o n g e t I t e m ( i n t ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g P o l y g o n ) ; +
+ p u b l i c v o i d a d d ( o r g . o s g e o . m a p g u i d e . M g P o l y g o n ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g P o l y g o n ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g P o l y g o n ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g P o l y g o n ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g P o l y g o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P o l y g o n C o l l e c t i o n ( ) ; +
+ C o m p i l e d f r o m " M g P r e p a r e d G e o m e t r y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g P r e p a r e d G e o m e t r y e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c b o o l e a n c r o s s e s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c b o o l e a n d i s j o i n t ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c b o o l e a n i n t e r s e c t s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c b o o l e a n o v e r l a p s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c b o o l e a n t o u c h e s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c b o o l e a n w i t h i n ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ C o m p i l e d f r o m " M g P r o f i l i n g S e r v i c e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g P r o f i l i n g S e r v i c e e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r v i c e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r p r o f i l e R e n d e r D y n a m i c O v e r l a y ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n , o r g . o s g e o . m a p g u i d e . M g R e n d e r i n g O p t i o n s ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r p r o f i l e R e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , d o u b l e , i n t , i n t , o r g . o s g e o . m a p g u i d e . M g C o l o r , j a v a . l a n g . S t r i n g , b o o l e a n ) ; +
+ C o m p i l e d f r o m " M g P r o p e r t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g P r o p e r t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e { +
+ p u b l i c b o o l e a n e q u a l s ( j a v a . l a n g . O b j e c t ) ; +
+ p u b l i c i n t h a s h C o d e ( ) ; +
+ p u b l i c s h o r t g e t P r o p e r t y T y p e ( ) ; +
+ C o m p i l e d f r o m " M g P r o p e r t y C o l l e c t i o n . j a v a " +
+ c l a s s o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n $ I t e m I t e r a t o r i m p l e m e n t s j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g P r o p e r t y > { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n $ I t e m I t e r a t o r ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ; +
+ p u b l i c b o o l e a n h a s N e x t ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y n e x t ( ) ; +
+ p u b l i c v o i d r e m o v e ( ) ; +
+ p u b l i c j a v a . l a n g . O b j e c t n e x t ( ) ; +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n i m p l e m e n t s j a v a . u t i l . C o l l e c t i o n < o r g . o s g e o . m a p g u i d e . M g P r o p e r t y > { +
+ p u b l i c j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g P r o p e r t y > i t e r a t o r ( ) ; +
+ p u b l i c b o o l e a n a d d ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y ) ; +
+ p u b l i c b o o l e a n a d d A l l ( j a v a . u t i l . C o l l e c t i o n < ? e x t e n d s o r g . o s g e o . m a p g u i d e . M g P r o p e r t y > ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( j a v a . l a n g . O b j e c t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ; +
+ p u b l i c b o o l e a n r e m o v e ( j a v a . l a n g . O b j e c t ) ; +
+ p u b l i c b o o l e a n r e m o v e A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ; +
+ p u b l i c b o o l e a n r e t a i n A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ; +
+ p u b l i c i n t s i z e ( ) ; +
+ p u b l i c j a v a . l a n g . O b j e c t [ ] t o A r r a y ( ) ; +
+ p u b l i c < M g P r o p e r t y > M g P r o p e r t y [ ] t o A r r a y ( M g P r o p e r t y [ ] ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ( ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g P r o p e r t y ) ; +
+ p u b l i c v o i d a d d I t e m ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g P r o p e r t y ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y g e t I t e m ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y g e t I t e m ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y ) ; +
+ p u b l i c b o o l e a n a d d ( j a v a . l a n g . O b j e c t ) ; +
+ C o m p i l e d f r o m " M g P r o p e r t y D e f i n i t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g P r o p e r t y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ( j a v a . l a n g . S t r i n g , s h o r t ) ; +
+ p u b l i c v o i d s e t D e s c r i p t i o n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t Q u a l i f i e d N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t Q u a l i f i e d N a m e ( ) ; +
+ p u b l i c v o i d m a r k A s D e l e t e d ( ) ; +
+ C o m p i l e d f r o m " M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n . j a v a " +
+ c l a s s o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n $ I t e m I t e r a t o r i m p l e m e n t s j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n > { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n $ I t e m I t e r a t o r ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n n e x t ( ) ; +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n i m p l e m e n t s j a v a . u t i l . C o l l e c t i o n < o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n > { +
+ p u b l i c j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n > i t e r a t o r ( ) ; +
+ p u b l i c b o o l e a n a d d ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ; +
+ p u b l i c b o o l e a n a d d A l l ( j a v a . u t i l . C o l l e c t i o n < ? e x t e n d s o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n > ) ; +
+ p u b l i c < M g P r o p e r t y D e f i n i t i o n > M g P r o p e r t y D e f i n i t i o n [ ] t o A r r a y ( M g P r o p e r t y D e f i n i t i o n [ ] ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n ( ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ; +
+ p u b l i c v o i d a d d I t e m ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n g e t I t e m ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n g e t I t e m ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r t o X m l ( ) ; +
+ C o m p i l e d f r o m " M g P r o p e r t y T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g P r o p e r t y T y p e { +
+ p u b l i c s t a t i c f i n a l i n t N u l l = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t B o o l e a n = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t B y t e = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t D a t e T i m e = 3 ; +
+ p u b l i c s t a t i c f i n a l i n t S i n g l e = 4 ; +
+ p u b l i c s t a t i c f i n a l i n t D o u b l e = 5 ; +
+ p u b l i c s t a t i c f i n a l i n t I n t 1 6 = 6 ; +
+ p u b l i c s t a t i c f i n a l i n t I n t 3 2 = 7 ; +
+ p u b l i c s t a t i c f i n a l i n t I n t 6 4 = 8 ; +
+ p u b l i c s t a t i c f i n a l i n t S t r i n g = 9 ; +
+ p u b l i c s t a t i c f i n a l i n t B l o b = 1 0 ; +
+ p u b l i c s t a t i c f i n a l i n t C l o b = 1 1 ; +
+ p u b l i c s t a t i c f i n a l i n t F e a t u r e = 1 2 ; +
+ p u b l i c s t a t i c f i n a l i n t G e o m e t r y = 1 3 ; +
+ p u b l i c s t a t i c f i n a l i n t R a s t e r = 1 4 ; +
+ p u b l i c s t a t i c f i n a l i n t D e c i m a l = 1 5 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y T y p e ( ) ; +
+ C o m p i l e d f r o m " M g R a s t e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R a s t e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c v o i d s e t N u l l ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g E n v e l o p e g e t B o u n d s ( ) ; +
+ p u b l i c i n t g e t I m a g e X S i z e ( ) ; +
+ p u b l i c v o i d s e t I m a g e X S i z e ( i n t ) ; +
+ p u b l i c i n t g e t I m a g e Y S i z e ( ) ; +
+ p u b l i c v o i d s e t I m a g e Y S i z e ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t S t r e a m ( ) ; +
+ p u b l i c i n t g e t B i t s P e r P i x e l ( ) ; +
+ p u b l i c i n t g e t D a t a M o d e l T y p e ( ) ; +
+ p u b l i c i n t g e t N u m b e r O f B a n d s ( ) ; +
+ p u b l i c i n t g e t C u r r e n t B a n d ( ) ; +
+ p u b l i c s h o r t g e t D a t a T y p e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t V e r t i c a l U n i t s ( ) ; +
+ p u b l i c i n t g e t N u l l V a l u e T y p e ( ) ; +
+ p u b l i c l o n g g e t N u l l V a l u e ( ) ; +
+ C o m p i l e d f r o m " M g R a s t e r D a t a M o d e l T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R a s t e r D a t a M o d e l T y p e { +
+ p u b l i c s t a t i c f i n a l i n t U n k n o w n = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t D a t a = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t B i t o n a l = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t G r a y = 3 ; +
+ p u b l i c s t a t i c f i n a l i n t R G B = 4 ; +
+ p u b l i c s t a t i c f i n a l i n t R G B A = 5 ; +
+ p u b l i c s t a t i c f i n a l i n t P a l e t t e = 6 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R a s t e r D a t a M o d e l T y p e ( ) ; +
+ C o m p i l e d f r o m " M g R a s t e r P r o p e r t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R a s t e r P r o p e r t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R a s t e r P r o p e r t y ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g R a s t e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R a s t e r g e t V a l u e ( ) ; +
+ p u b l i c v o i d s e t V a l u e ( o r g . o s g e o . m a p g u i d e . M g R a s t e r ) ; +
+ C o m p i l e d f r o m " M g R a s t e r P r o p e r t y D e f i n i t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R a s t e r P r o p e r t y D e f i n i t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R a s t e r P r o p e r t y D e f i n i t i o n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n g e t R e a d O n l y ( ) ; +
+ p u b l i c b o o l e a n g e t N u l l a b l e ( ) ; +
+ p u b l i c i n t g e t D e f a u l t I m a g e X S i z e ( ) ; +
+ p u b l i c i n t g e t D e f a u l t I m a g e Y S i z e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S p a t i a l C o n t e x t A s s o c i a t i o n ( ) ; +
+ p u b l i c v o i d s e t R e a d O n l y ( b o o l e a n ) ; +
+ p u b l i c v o i d s e t N u l l a b l e ( b o o l e a n ) ; +
+ p u b l i c v o i d s e t D e f a u l t I m a g e X S i z e ( i n t ) ; +
+ p u b l i c v o i d s e t D e f a u l t I m a g e Y S i z e ( i n t ) ; +
+ p u b l i c v o i d s e t S p a t i a l C o n t e x t A s s o c i a t i o n ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g R e a d e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R e a d e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e i m p l e m e n t s j a v a . l a n g . A u t o C l o s e a b l e { +
+ p u b l i c i n t g e t P r o p e r t y C o u n t ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t P r o p e r t y N a m e ( i n t ) ; +
+ p u b l i c i n t g e t P r o p e r t y T y p e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t g e t P r o p e r t y T y p e ( i n t ) ; +
+ p u b l i c b o o l e a n i s N u l l ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n g e t B o o l e a n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b y t e g e t B y t e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D a t e T i m e g e t D a t e T i m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c f l o a t g e t S i n g l e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c d o u b l e g e t D o u b l e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c s h o r t g e t I n t 1 6 ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t g e t I n t 3 2 ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c l o n g g e t I n t 6 4 ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S t r i n g ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t B L O B ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t C L O B ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t G e o m e t r y ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R a s t e r g e t R a s t e r ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t g e t P r o p e r t y I n d e x ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n i s N u l l ( i n t ) ; +
+ p u b l i c b o o l e a n g e t B o o l e a n ( i n t ) ; +
+ p u b l i c b y t e g e t B y t e ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D a t e T i m e g e t D a t e T i m e ( i n t ) ; +
+ p u b l i c f l o a t g e t S i n g l e ( i n t ) ; +
+ p u b l i c d o u b l e g e t D o u b l e ( i n t ) ; +
+ p u b l i c s h o r t g e t I n t 1 6 ( i n t ) ; +
+ p u b l i c i n t g e t I n t 3 2 ( i n t ) ; +
+ p u b l i c l o n g g e t I n t 6 4 ( i n t ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S t r i n g ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t B L O B ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t C L O B ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t G e o m e t r y ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R a s t e r g e t R a s t e r ( i n t ) ; +
+ p u b l i c i n t g e t R e a d e r T y p e ( ) ; +
+ C o m p i l e d f r o m " M g R e a d e r T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R e a d e r T y p e { +
+ p u b l i c s t a t i c f i n a l i n t F e a t u r e R e a d e r = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t D a t a R e a d e r = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t S q l D a t a R e a d e r = 2 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e a d e r T y p e ( ) ; +
+ C o m p i l e d f r o m " M g R e a d O n l y L a y e r C o l l e c t i o n . j a v a " +
+ c l a s s o r g . o s g e o . m a p g u i d e . M g R e a d O n l y L a y e r C o l l e c t i o n $ I t e m I t e r a t o r i m p l e m e n t s j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e > { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e a d O n l y L a y e r C o l l e c t i o n $ I t e m I t e r a t o r ( o r g . o s g e o . m a p g u i d e . M g R e a d O n l y L a y e r C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g R e a d O n l y L a y e r C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e n e x t ( ) ; +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R e a d O n l y L a y e r C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e i m p l e m e n t s j a v a . l a n g . I t e r a b l e < o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e > { +
+ p u b l i c j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e > i t e r a t o r ( ) ; +
+ p u b l i c i n t g e t C o u n t ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e g e t I t e m ( i n t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ; +
+ C o m p i l e d f r o m " M g R e g i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R e g i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G e o m e t r y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P o i n t g e t P o i n t I n R e g i o n ( ) ; +
+ C o m p i l e d f r o m " M g R e n d e r i n g O p t i o n s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R e n d e r i n g O p t i o n s e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c s t a t i c f i n a l i n t R e n d e r S e l e c t i o n ; +
+ p u b l i c s t a t i c f i n a l i n t R e n d e r L a y e r s ; +
+ p u b l i c s t a t i c f i n a l i n t K e e p S e l e c t i o n ; +
+ p u b l i c s t a t i c f i n a l i n t R e n d e r B a s e L a y e r s ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e n d e r i n g O p t i o n s ( j a v a . l a n g . S t r i n g , i n t , o r g . o s g e o . m a p g u i d e . M g C o l o r ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t I m a g e F o r m a t ( ) ; +
+ p u b l i c i n t g e t B e h a v i o r ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o l o r g e t S e l e c t i o n C o l o r ( ) ; +
+ C o m p i l e d f r o m " M g R e n d e r i n g S e r v i c e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R e n d e r i n g S e r v i c e e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r v i c e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r T i l e ( o r g . o s g e o . m a p g u i d e . M g M a p , j a v a . l a n g . S t r i n g , i n t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r T i l e ( o r g . o s g e o . m a p g u i d e . M g M a p , j a v a . l a n g . S t r i n g , i n t , i n t , i n t , i n t , i n t , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r T i l e ( o r g . o s g e o . m a p g u i d e . M g M a p , j a v a . l a n g . S t r i n g , i n t , i n t , i n t , i n t , i n t , j a v a . l a n g . S t r i n g , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r T i l e X Y Z ( o r g . o s g e o . m a p g u i d e . M g M a p , j a v a . l a n g . S t r i n g , i n t , i n t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r T i l e X Y Z ( o r g . o s g e o . m a p g u i d e . M g M a p , j a v a . l a n g . S t r i n g , i n t , i n t , i n t , i n t , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r T i l e X Y Z ( o r g . o s g e o . m a p g u i d e . M g M a p , j a v a . l a n g . S t r i n g , i n t , i n t , i n t , i n t , j a v a . l a n g . S t r i n g , d o u b l e , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r T i l e U T F G r i d ( o r g . o s g e o . m a p g u i d e . M g M a p , j a v a . l a n g . S t r i n g , i n t , i n t , i n t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r D y n a m i c O v e r l a y ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r D y n a m i c O v e r l a y ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n , j a v a . l a n g . S t r i n g , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r D y n a m i c O v e r l a y ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n , o r g . o s g e o . m a p g u i d e . M g R e n d e r i n g O p t i o n s ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n , j a v a . l a n g . S t r i n g , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n , j a v a . l a n g . S t r i n g , b o o l e a n , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n , j a v a . l a n g . S t r i n g , b o o l e a n , b o o l e a n , o r g . o s g e o . m a p g u i d e . M g C o l o r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n , o r g . o s g e o . m a p g u i d e . M g E n v e l o p e , i n t , i n t , o r g . o s g e o . m a p g u i d e . M g C o l o r , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n , o r g . o s g e o . m a p g u i d e . M g E n v e l o p e , i n t , i n t , o r g . o s g e o . m a p g u i d e . M g C o l o r , j a v a . l a n g . S t r i n g , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , d o u b l e , i n t , i n t , o r g . o s g e o . m a p g u i d e . M g C o l o r , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , d o u b l e , i n t , i n t , o r g . o s g e o . m a p g u i d e . M g C o l o r , j a v a . l a n g . S t r i n g , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n , o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e , d o u b l e , i n t , i n t , o r g . o s g e o . m a p g u i d e . M g C o l o r , j a v a . l a n g . S t r i n g , b o o l e a n , o r g . o s g e o . m a p g u i d e . M g C o l o r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r M a p L e g e n d ( o r g . o s g e o . m a p g u i d e . M g M a p , i n t , i n t , o r g . o s g e o . m a p g u i d e . M g C o l o r , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e I n f o r m a t i o n q u e r y F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g G e o m e t r y , i n t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e I n f o r m a t i o n q u e r y F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g G e o m e t r y , i n t , j a v a . l a n g . S t r i n g , i n t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n q u e r y F e a t u r e P r o p e r t i e s ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g G e o m e t r y , i n t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n q u e r y F e a t u r e P r o p e r t i e s ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g G e o m e t r y , i n t , j a v a . l a n g . S t r i n g , i n t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M e t a t i l e r e n d e r M e t a t i l e ( o r g . o s g e o . m a p g u i d e . M g M a p , j a v a . l a n g . S t r i n g , i n t , i n t , i n t , i n t , i n t , j a v a . l a n g . S t r i n g , d o u b l e , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g M e t a t i l e r e n d e r M e t a t i l e X Y Z ( o r g . o s g e o . m a p g u i d e . M g M a p , j a v a . l a n g . S t r i n g , i n t , i n t , i n t , i n t , j a v a . l a n g . S t r i n g , d o u b l e , i n t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r r e n d e r T i l e F r o m M e t a T i l e ( o r g . o s g e o . m a p g u i d e . M g M a p , o r g . o s g e o . m a p g u i d e . M g M e t a t i l e , i n t , i n t ) ; +
+ C o m p i l e d f r o m " M g R e p o s i t o r y T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R e p o s i t o r y T y p e { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g L i b r a r y = " L i b r a r y " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S e s s i o n = " S e s s i o n " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e p o s i t o r y T y p e ( ) ; +
+ C o m p i l e d f r o m " M g R e s o u r c e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R e s o u r c e e x t e n d s o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r g e t R e s o u r c e I d ( ) ; +
+ p u b l i c v o i d o p e n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e , o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c v o i d s a v e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e ) ; +
+ p u b l i c v o i d s a v e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e , o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ C o m p i l e d f r o m " M g R e s o u r c e D a t a N a m e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R e s o u r c e D a t a N a m e { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g U s e r C r e d e n t i a l s = " M G _ U S E R _ C R E D E N T I A L S " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P r o x y S e r v e r N a m e = " M G _ P R O X Y _ S E R V E R " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P r o x y S e r v e r P o r t = " M G _ P R O X Y _ P O R T " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P r o x y C r e d e n t i a l s = " M G _ P R O X Y _ C R E D E N T I A L S " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e s o u r c e D a t a N a m e ( ) ; +
+ C o m p i l e d f r o m " M g R e s o u r c e D a t a T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R e s o u r c e D a t a T y p e { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F i l e = " F i l e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S t r e a m = " S t r e a m " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S t r i n g = " S t r i n g " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e s o u r c e D a t a T y p e ( ) ; +
+ C o m p i l e d f r o m " M g R e s o u r c e H e a d e r P r o p e r t i e s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R e s o u r c e H e a d e r P r o p e r t i e s { +
+ p u b l i c s t a t i c f i n a l i n t G e n e r a l = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t S e c u r i t y = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t M e t a d a t a = 4 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e s o u r c e H e a d e r P r o p e r t i e s ( ) ; +
+ C o m p i l e d f r o m " M g R e s o u r c e I d e n t i f i e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t R e p o s i t o r y T y p e ( ) ; +
+ p u b l i c v o i d s e t R e p o s i t o r y T y p e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t R e p o s i t o r y N a m e ( ) ; +
+ p u b l i c v o i d s e t R e p o s i t o r y N a m e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g t o S t r i n g ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t P a t h ( ) ; +
+ p u b l i c v o i d s e t P a t h ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t N a m e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t R e s o u r c e T y p e ( ) ; +
+ p u b l i c v o i d s e t R e s o u r c e T y p e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d v a l i d a t e ( ) ; +
+ C o m p i l e d f r o m " M g R e s o u r c e P e r m i s s i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R e s o u r c e P e r m i s s i o n { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P e r m i s s i o n N o A c c e s s = " n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P e r m i s s i o n R e a d O n l y = " r " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P e r m i s s i o n R e a d W r i t e = " r , w " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e s o u r c e P e r m i s s i o n ( ) ; +
+ C o m p i l e d f r o m " M g R e s o u r c e S e r v i c e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r v i c e { +
+ p u b l i c v o i d u p d a t e R e p o s i t o r y ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r , o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ; +
+ p u b l i c v o i d a p p l y R e s o u r c e P a c k a g e ( o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r e n u m e r a t e R e s o u r c e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , i n t , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r e n u m e r a t e R e s o u r c e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , i n t , j a v a . l a n g . S t r i n g , b o o l e a n ) ; +
+ p u b l i c v o i d s e t R e s o u r c e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r , o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ; +
+ p u b l i c v o i d d e l e t e R e s o u r c e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c v o i d m o v e R e s o u r c e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , b o o l e a n ) ; +
+ p u b l i c v o i d m o v e R e s o u r c e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , b o o l e a n , b o o l e a n ) ; +
+ p u b l i c v o i d c o p y R e s o u r c e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t R e s o u r c e C o n t e n t ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n g e t R e s o u r c e C o n t e n t s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t R e s o u r c e H e a d e r ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c v o i d c h a n g e R e s o u r c e O w n e r ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , b o o l e a n ) ; +
+ p u b l i c v o i d i n h e r i t P e r m i s s i o n s F r o m ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c v o i d s e t R e s o u r c e D a t a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ; +
+ p u b l i c v o i d d e l e t e R e s o u r c e D a t a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d r e n a m e R e s o u r c e D a t a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t R e s o u r c e D a t a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r e n u m e r a t e R e s o u r c e D a t a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t R e p o s i t o r y C o n t e n t ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t R e p o s i t o r y H e a d e r ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r e n u m e r a t e R e f e r e n c e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c b o o l e a n r e s o u r c e E x i s t s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r e n u m e r a t e U n m a n a g e d D a t a ( j a v a . l a n g . S t r i n g , b o o l e a n , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g e n u m e r a t e R e s o u r c e D o c u m e n t s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , j a v a . l a n g . S t r i n g , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g D a t e T i m e g e t R e s o u r c e M o d i f i e d D a t e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c v o i d s e t R e s o u r c e M e t a d a t a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t R e s o u r c e M e t a d a t a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ C o m p i l e d f r o m " M g R e s o u r c e T a g . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R e s o u r c e T a g { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g L o g i n U s e r n a m e = " % M G _ L O G I N _ U S E R N A M E % " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g L o g i n P a s s w o r d = " % M G _ L O G I N _ P A S S W O R D % " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g U s e r n a m e = " % M G _ U S E R N A M E % " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P a s s w o r d = " % M G _ P A S S W O R D % " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P r o x y S e r v e r = " % M G _ P R O X Y _ S E R V E R % " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P r o x y P o r t = " % M G _ P R O X Y _ P O R T % " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P r o x y U s e r n a m e = " % M G _ P R O X Y _ U S E R N A M E % " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P r o x y P a s s w o r d = " % M G _ P R O X Y _ P A S S W O R D % " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D a t a F i l e P a t h = " % M G _ D A T A _ F I L E _ P A T H % " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T i l e C a c h e P a t h = " % M G _ T I L E _ C A C H E _ P A T H % " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D a t a P a t h A l i a s B e g i n = " % M G _ D A T A _ P A T H _ A L I A S [ " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D a t a P a t h A l i a s E n d = " ] % " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e s o u r c e T a g ( ) ; +
+ C o m p i l e d f r o m " M g R e s o u r c e T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R e s o u r c e T y p e { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M a p = " M a p " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M a p D e f i n i t i o n = " M a p D e f i n i t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g L a y e r D e f i n i t i o n = " L a y e r D e f i n i t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D r a w i n g S o u r c e = " D r a w i n g S o u r c e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F e a t u r e S o u r c e = " F e a t u r e S o u r c e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g F o l d e r = " F o l d e r " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g L o a d P r o c e d u r e = " L o a d P r o c e d u r e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g P r i n t L a y o u t = " P r i n t L a y o u t " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S e l e c t i o n = " S e l e c t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S y m b o l D e f i n i t i o n = " S y m b o l D e f i n i t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S y m b o l L i b r a r y = " S y m b o l L i b r a r y " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g W e b L a y o u t = " W e b L a y o u t " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A p p l i c a t i o n D e f i n i t i o n = " A p p l i c a t i o n D e f i n i t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g W a t e r m a r k D e f i n i t i o n = " W a t e r m a r k D e f i n i t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T i l e S e t D e f i n i t i o n = " T i l e S e t D e f i n i t i o n " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e s o u r c e T y p e ( ) ; +
+ C o m p i l e d f r o m " M g R i n g . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R i n g e x t e n d s o r g . o s g e o . m a p g u i d e . M g G e o m e t r y C o m p o n e n t { +
+ p u b l i c s y n c h r o n i z e d v o i d d e l e t e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P o i n t g e t P o i n t I n R i n g ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e I t e r a t o r g e t C o o r d i n a t e s ( ) ; +
+ C o m p i l e d f r o m " M g R o l e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g R o l e { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A d m i n i s t r a t o r = " A d m i n i s t r a t o r " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A u t h o r = " A u t h o r " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g V i e w e r = " V i e w e r " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R o l e ( ) ; +
+ C o m p i l e d f r o m " M g S e l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n B a s e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ( o r g . o s g e o . m a p g u i d e . M g M a p ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ( o r g . o s g e o . m a p g u i d e . M g M a p , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r g e t S e l e c t e d F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e , j a v a . l a n g . S t r i n g , b o o l e a n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r g e t S e l e c t e d F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ; +
+ p u b l i c v o i d o p e n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s a v e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ( ) ; +
+ C o m p i l e d f r o m " M g S e l e c t i o n B a s e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n B a s e e x t e n d s o r g . o s g e o . m a p g u i d e . M g R e s o u r c e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n B a s e ( o r g . o s g e o . m a p g u i d e . M g M a p B a s e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n B a s e ( o r g . o s g e o . m a p g u i d e . M g M a p B a s e , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t g e t S e l e c t e d F e a t u r e s C o u n t ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d f r o m X m l ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g t o X m l ( ) ; +
+ p u b l i c v o i d a d d F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e , o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r , i n t ) ; +
+ p u b l i c v o i d a d d F e a t u r e I d s ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e , j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ; +
+ p u b l i c v o i d a d d F e a t u r e I d I n t 1 6 ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e , j a v a . l a n g . S t r i n g , s h o r t ) ; +
+ p u b l i c v o i d a d d F e a t u r e I d I n t 3 2 ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e , j a v a . l a n g . S t r i n g , i n t ) ; +
+ p u b l i c v o i d a d d F e a t u r e I d I n t 6 4 ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e , j a v a . l a n g . S t r i n g , l o n g ) ; +
+ p u b l i c v o i d a d d F e a t u r e I d S t r i n g ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d a d d F e a t u r e I d D o u b l e ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e , j a v a . l a n g . S t r i n g , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e a d O n l y L a y e r C o l l e c t i o n g e t L a y e r s ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n g e t C l a s s e s ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t C l a s s ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e n e r a t e F i l t e r ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n g e n e r a t e F i l t e r s ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e , j a v a . l a n g . S t r i n g , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g E n v e l o p e g e t E x t e n t s ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S e r v i c e ) ; +
+ p u b l i c v o i d a d d ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t R e s o u r c e N a m e ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t M a p ( o r g . o s g e o . m a p g u i d e . M g M a p B a s e ) ; +
+ C o m p i l e d f r o m " M g S e r i a l i z a b l e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ C o m p i l e d f r o m " M g S e r v e r A d m i n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g S e r v e r A d m i n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S e r v e r A d m i n ( ) ; +
+ p u b l i c v o i d o p e n ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g U s e r I n f o r m a t i o n ) ; +
+ p u b l i c v o i d o p e n ( o r g . o s g e o . m a p g u i d e . M g U s e r I n f o r m a t i o n ) ; +
+ p u b l i c v o i d c l o s e ( ) ; +
+ p u b l i c b o o l e a n h a s W a r n i n g ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W a r n i n g s g e t W a r n i n g s O b j e c t ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n g e t C o n f i g u r a t i o n P r o p e r t i e s ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t C o n f i g u r a t i o n P r o p e r t i e s ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ; +
+ p u b l i c v o i d r e m o v e C o n f i g u r a t i o n P r o p e r t i e s ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ; +
+ p u b l i c b o o l e a n c l e a r L o g ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d d e l e t e L o g ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d r e n a m e L o g ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n e n u m e r a t e L o g s ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t L o g ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t L o g ( j a v a . l a n g . S t r i n g , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t L o g ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g D a t e T i m e , o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t L o g F i l e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d b r i n g O n l i n e ( ) ; +
+ p u b l i c v o i d t a k e O f f l i n e ( ) ; +
+ p u b l i c b o o l e a n i s O n l i n e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n g e t I n f o r m a t i o n P r o p e r t i e s ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S i t e V e r s i o n ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n g e t S i t e S t a t u s ( ) ; +
+ p u b l i c v o i d d e l e t e P a c k a g e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n e n u m e r a t e P a c k a g e s ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t P a c k a g e L o g ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P a c k a g e S t a t u s I n f o r m a t i o n g e t P a c k a g e S t a t u s ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d l o a d P a c k a g e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d m a k e P a c k a g e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t M a x i m u m L o g S i z e ( i n t ) ; +
+ p u b l i c v o i d s e t L o g D e l i m i t e r ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d e n a b l e M a x i m u m L o g S i z e ( b o o l e a n ) ; +
+ p u b l i c b o o l e a n i s M a x i m u m L o g S i z e E n a b l e d ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t D o c u m e n t ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t D o c u m e n t ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ; +
+ C o m p i l e d f r o m " M g S e r v e r I n f o r m a t i o n P r o p e r t i e s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g S e r v e r I n f o r m a t i o n P r o p e r t i e s { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S e r v e r V e r s i o n = " S e r v e r V e r s i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A p i V e r s i o n = " A p i V e r s i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A d m i n O p e r a t i o n s Q u e u e C o u n t = " A d m i n O p e r a t i o n s Q u e u e C o u n t " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g C l i e n t O p e r a t i o n s Q u e u e C o u n t = " C l i e n t O p e r a t i o n s Q u e u e C o u n t " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S i t e O p e r a t i o n s Q u e u e C o u n t = " S i t e O p e r a t i o n s Q u e u e C o u n t " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A v e r a g e O p e r a t i o n T i m e = " A v e r a g e O p e r a t i o n T i m e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T o t a l O p e r a t i o n T i m e = " T o t a l O p e r a t i o n T i m e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g C p u U t i l i z a t i o n = " C p u U t i l i z a t i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T o t a l P h y s i c a l M e m o r y = " T o t a l P h y s i c a l M e m o r y " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A v a i l a b l e P h y s i c a l M e m o r y = " A v a i l a b l e P h y s i c a l M e m o r y " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T o t a l V i r t u a l M e m o r y = " T o t a l V i r t u a l M e m o r y " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A v a i l a b l e V i r t u a l M e m o r y = " A v a i l a b l e V i r t u a l M e m o r y " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g U p t i m e = " U p t i m e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g S t a t u s = " S t a t u s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g D i s p l a y N a m e = " D i s p l a y N a m e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M a c h i n e I p = " M a c h i n e I p " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T o t a l R e c e i v e d O p e r a t i o n s = " T o t a l R e c e i v e d O p e r a t i o n s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T o t a l P r o c e s s e d O p e r a t i o n s = " T o t a l P r o c e s s e d O p e r a t i o n s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T o t a l C o n n e c t i o n s = " T o t a l C o n n e c t i o n s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g T o t a l A c t i v e C o n n e c t i o n s = " T o t a l A c t i v e C o n n e c t i o n s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g O p e r a t i n g S y s t e m V e r s i o n = " O p e r a t i n g S y s t e m V e r s i o n " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g W o r k i n g S e t = " W o r k i n g S e t " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g V i r t u a l M e m o r y = " V i r t u a l M e m o r y " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g C a c h e S i z e = " C a c h e S i z e " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g C a c h e D r o p p e d E n t r i e s = " C a c h e D r o p p e d E n t r i e s " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S e r v e r I n f o r m a t i o n P r o p e r t i e s ( ) ; +
+ C o m p i l e d f r o m " M g S e r v i c e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g S e r v i c e e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c b o o l e a n h a s W a r n i n g s ( ) ; +
+ C o m p i l e d f r o m " M g S e r v i c e T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g S e r v i c e T y p e { +
+ p u b l i c s t a t i c f i n a l s h o r t R e s o u r c e S e r v i c e = 0 ; +
+ p u b l i c s t a t i c f i n a l s h o r t D r a w i n g S e r v i c e = 1 ; +
+ p u b l i c s t a t i c f i n a l s h o r t F e a t u r e S e r v i c e = 2 ; +
+ p u b l i c s t a t i c f i n a l s h o r t M a p p i n g S e r v i c e = 3 ; +
+ p u b l i c s t a t i c f i n a l s h o r t R e n d e r i n g S e r v i c e = 4 ; +
+ p u b l i c s t a t i c f i n a l s h o r t T i l e S e r v i c e = 5 ; +
+ p u b l i c s t a t i c f i n a l s h o r t K m l S e r v i c e = 6 ; +
+ p u b l i c s t a t i c f i n a l s h o r t P r o f i l i n g S e r v i c e = 1 0 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S e r v i c e T y p e ( ) ; +
+ C o m p i l e d f r o m " M g S i n g l e P r o p e r t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g S i n g l e P r o p e r t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S i n g l e P r o p e r t y ( j a v a . l a n g . S t r i n g , f l o a t ) ; +
+ p u b l i c f l o a t g e t V a l u e ( ) ; +
+ p u b l i c v o i d s e t V a l u e ( f l o a t ) ; +
+ C o m p i l e d f r o m " M g S i t e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g S i t e e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r e n u m e r a t e U s e r s ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r e n u m e r a t e G r o u p s ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g c r e a t e S e s s i o n ( ) ; +
+ p u b l i c v o i d d e s t r o y S e s s i o n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t C u r r e n t S e s s i o n ( ) ; +
+ p u b l i c i n t g e t S e s s i o n T i m e o u t ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t U s e r F o r S e s s i o n ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r e n u m e r a t e G r o u p s ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n e n u m e r a t e R o l e s ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S i t e ( ) ; +
+ p u b l i c v o i d o p e n ( o r g . o s g e o . m a p g u i d e . M g U s e r I n f o r m a t i o n , o r g . o s g e o . m a p g u i d e . M g S i t e I n f o ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W a r n i n g s g e t W a r n i n g ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r e n u m e r a t e U s e r s ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , b o o l e a n ) ; +
+ p u b l i c v o i d a d d U s e r ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d u p d a t e U s e r ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d d e l e t e U s e r s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ; +
+ p u b l i c v o i d g r a n t R o l e M e m b e r s h i p s T o U s e r s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ; +
+ p u b l i c v o i d r e v o k e R o l e M e m b e r s h i p s F r o m U s e r s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ; +
+ p u b l i c v o i d g r a n t G r o u p M e m b e r s h i p s T o U s e r s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ; +
+ p u b l i c v o i d r e v o k e G r o u p M e m b e r s h i p s F r o m U s e r s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r e n u m e r a t e G r o u p s ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d a d d G r o u p ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d u p d a t e G r o u p ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d d e l e t e G r o u p s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ; +
+ p u b l i c v o i d g r a n t R o l e M e m b e r s h i p s T o G r o u p s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ; +
+ p u b l i c v o i d r e v o k e R o l e M e m b e r s h i p s F r o m G r o u p s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n e n u m e r a t e R o l e s ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r e n u m e r a t e S e r v e r s ( ) ; +
+ p u b l i c v o i d a d d S e r v e r ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d u p d a t e S e r v e r ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d r e m o v e S e r v e r ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S i t e I n f o g e t S i t e S e r v e r I n f o ( i n t ) ; +
+ p u b l i c i n t g e t S i t e S e r v e r C o u n t ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t C u r r e n t S i t e A d d r e s s ( ) ; +
+ C o m p i l e d f r o m " M g S i t e C o n n e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g S i t e C o n n e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S i t e C o n n e c t i o n ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S e r v i c e c r e a t e S e r v i c e ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S i t e g e t S i t e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S i t e C o n n e c t i o n ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g S i t e I n f o . j a v a " +
+ p u b l i c f i n a l c l a s s o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g P o r t T y p e { +
+ p u b l i c s t a t i c f i n a l o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g P o r t T y p e C l i e n t ; +
+ p u b l i c s t a t i c f i n a l o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g P o r t T y p e S i t e ; +
+ p u b l i c s t a t i c f i n a l o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g P o r t T y p e A d m i n ; +
+ p u b l i c f i n a l i n t s w i g V a l u e ( ) ; +
+ p u b l i c s t a t i c o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g P o r t T y p e s w i g T o E n u m ( i n t ) ; +
+ p u b l i c f i n a l c l a s s o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g S i t e S t a t u s { +
+ p u b l i c s t a t i c f i n a l o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g S i t e S t a t u s O k ; +
+ p u b l i c s t a t i c f i n a l o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g S i t e S t a t u s U n a b l e T o C o n n e c t ; +
+ p u b l i c s t a t i c f i n a l o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g S i t e S t a t u s T i m e d O u t ; +
+ p u b l i c s t a t i c f i n a l o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g S i t e S t a t u s U n i n i t i a l i z e d ; +
+ p u b l i c s t a t i c o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g S i t e S t a t u s s w i g T o E n u m ( i n t ) ; +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g S i t e I n f o e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S i t e I n f o ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S i t e I n f o ( j a v a . l a n g . S t r i n g , i n t , i n t , i n t ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t T a r g e t ( ) ; +
+ p u b l i c i n t g e t P o r t ( o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g P o r t T y p e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g S i t e S t a t u s g e t S t a t u s ( ) ; +
+ p u b l i c v o i d s e t S t a t u s ( o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g S i t e S t a t u s ) ; +
+ C o m p i l e d f r o m " M g S p a t i a l C o n t e x t E x t e n t T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g S p a t i a l C o n t e x t E x t e n t T y p e { +
+ p u b l i c s t a t i c f i n a l i n t s c S t a t i c = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t s c D y n a m i c = 1 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S p a t i a l C o n t e x t E x t e n t T y p e ( ) ; +
+ C o m p i l e d f r o m " M g S p a t i a l C o n t e x t R e a d e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g S p a t i a l C o n t e x t R e a d e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e i m p l e m e n t s j a v a . l a n g . A u t o C l o s e a b l e { +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D e s c r i p t i o n ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t C o o r d i n a t e S y s t e m ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t C o o r d i n a t e S y s t e m W k t ( ) ; +
+ p u b l i c i n t g e t E x t e n t T y p e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t E x t e n t ( ) ; +
+ p u b l i c d o u b l e g e t X Y T o l e r a n c e ( ) ; +
+ p u b l i c d o u b l e g e t Z T o l e r a n c e ( ) ; +
+ p u b l i c b o o l e a n i s A c t i v e ( ) ; +
+ p u b l i c b o o l e a n r e a d N e x t ( ) ; +
+ p u b l i c v o i d r e s e t ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r t o X m l ( ) ; +
+ C o m p i l e d f r o m " M g S q l D a t a R e a d e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g S q l D a t a R e a d e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g R e a d e r i m p l e m e n t s j a v a . l a n g . A u t o C l o s e a b l e { +
+ C o m p i l e d f r o m " M g S t r i n g C o l l e c t i o n . j a v a " +
+ c l a s s o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n $ I t e m I t e r a t o r i m p l e m e n t s j a v a . u t i l . I t e r a t o r < j a v a . l a n g . S t r i n g > { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n $ I t e m I t e r a t o r ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n , o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ; +
+ p u b l i c b o o l e a n h a s N e x t ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g n e x t ( ) ; +
+ p u b l i c v o i d r e m o v e ( ) ; +
+ p u b l i c j a v a . l a n g . O b j e c t n e x t ( ) ; +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n i m p l e m e n t s j a v a . u t i l . C o l l e c t i o n < j a v a . l a n g . S t r i n g > { +
+ p u b l i c j a v a . u t i l . I t e r a t o r < j a v a . l a n g . S t r i n g > i t e r a t o r ( ) ; +
+ p u b l i c b o o l e a n a d d ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n a d d A l l ( j a v a . u t i l . C o l l e c t i o n < ? e x t e n d s j a v a . l a n g . S t r i n g > ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( j a v a . l a n g . O b j e c t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ; +
+ p u b l i c b o o l e a n i s E m p t y ( ) ; +
+ p u b l i c b o o l e a n r e m o v e ( j a v a . l a n g . O b j e c t ) ; +
+ p u b l i c b o o l e a n r e m o v e A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ; +
+ p u b l i c b o o l e a n r e t a i n A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ; +
+ p u b l i c i n t s i z e ( ) ; +
+ p u b l i c j a v a . l a n g . O b j e c t [ ] t o A r r a y ( ) ; +
+ p u b l i c < S t r i n g > S t r i n g [ ] t o A r r a y ( S t r i n g [ ] ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t I t e m ( i n t ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d a d d I t e m ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d c l e a r ( ) ; +
+ p u b l i c b o o l e a n r e m o v e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d r e m o v e A t ( i n t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t i n d e x O f ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n a d d ( j a v a . l a n g . O b j e c t ) ; +
+ C o m p i l e d f r o m " M g S t r i n g P r o p e r t y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y e x t e n d s o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t V a l u e ( ) ; +
+ p u b l i c s h o r t g e t P r o p e r t y T y p e ( ) ; +
+ p u b l i c v o i d s e t V a l u e ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g S t r i n g P r o p e r t y C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y C o l l e c t i o n ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t N a m e ( i n t ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t V a l u e ( i n t ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t V a l u e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t V a l u e ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d a d d ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d a d d ( o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d i n s e r t ( i n t , o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y ) ; +
+ p u b l i c b o o l e a n r e m o v e ( o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y g e t I t e m ( i n t ) ; +
+ p u b l i c v o i d s e t I t e m ( i n t , o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y ) ; +
+ C o m p i l e d f r o m " M g T i l e S e r v i c e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g T i l e S e r v i c e e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r v i c e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t T i l e ( o r g . o s g e o . m a p g u i d e . M g M a p , j a v a . l a n g . S t r i n g , i n t , i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t T i l e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r , j a v a . l a n g . S t r i n g , i n t , i n t , i n t ) ; +
+ p u b l i c v o i d c l e a r C a c h e ( o r g . o s g e o . m a p g u i d e . M g M a p ) ; +
+ p u b l i c v o i d c l e a r C a c h e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c i n t g e t D e f a u l t T i l e S i z e X ( ) ; +
+ p u b l i c i n t g e t D e f a u l t T i l e S i z e Y ( ) ; +
+ p u b l i c i n t g e t D e f a u l t T i l e S i z e X ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c i n t g e t D e f a u l t T i l e S i z e Y ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t T i l e P r o v i d e r s ( ) ; +
+ C o m p i l e d f r o m " M g T r a n s a c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c v o i d c o m m i t ( ) ; +
+ p u b l i c v o i d r o l l b a c k ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r g e t F e a t u r e S o u r c e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g a d d S a v e P o i n t ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d r e l e a s e S a v e P o i n t ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d r o l l b a c k ( j a v a . l a n g . S t r i n g ) ; +
+ C o m p i l e d f r o m " M g T r a n s f o r m . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e t r a n s f o r m ( d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e t r a n s f o r m ( d o u b l e , d o u b l e , d o u b l e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g E n v e l o p e t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ) ; +
+ C o m p i l e d f r o m " M g U n i t T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g U n i t T y p e { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g U S E n g l i s h = " U S - E n g l i s h " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g M e t r i c = " M e t r i c " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g U n i t T y p e ( ) ; +
+ C o m p i l e d f r o m " M g U p d a t e F e a t u r e s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g U p d a t e F e a t u r e s e x t e n d s o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g U p d a t e F e a t u r e s ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c i n t g e t C o m m a n d T y p e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n g e t P r o p e r t y V a l u e s ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t F e a t u r e C l a s s N a m e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t F i l t e r T e x t ( ) ; +
+ C o m p i l e d f r o m " M g U s e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g U s e r { +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g A n o n y m o u s = " A n o n y m o u s " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g W f s U s e r = " W f s U s e r " ; +
+ p u b l i c s t a t i c f i n a l j a v a . l a n g . S t r i n g W m s U s e r = " W m s U s e r " ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g U s e r ( ) ; +
+ C o m p i l e d f r o m " M g U s e r I n f o r m a t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g U s e r I n f o r m a t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g U s e r I n f o r m a t i o n ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g U s e r I n f o r m a t i o n ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g U s e r I n f o r m a t i o n ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t M g U s e r n a m e P a s s w o r d ( j a v a . l a n g . S t r i n g , j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t M g S e s s i o n I d ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c v o i d s e t L o c a l e ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t L o c a l e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r g e t R e a d e r ( ) ; +
+ p u b l i c v o i d s e t C l i e n t A g e n t ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t C l i e n t A g e n t ( ) ; +
+ p u b l i c v o i d s e t C l i e n t I p ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t C l i e n t I p ( ) ; +
+ C o m p i l e d f r o m " M g W a r n i n g s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W a r n i n g s e x t e n d s o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n g e t M e s s a g e s ( ) ; +
+ p u b l i c i n t g e t C o u n t ( ) ; +
+ C o m p i l e d f r o m " M g W e b A c t i o n s . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b A c t i o n s { +
+ p u b l i c s t a t i c f i n a l i n t P a n = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t P a n U p = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t P a n D o w n = 3 ; +
+ p u b l i c s t a t i c f i n a l i n t P a n R i g h t = 4 ; +
+ p u b l i c s t a t i c f i n a l i n t P a n L e f t = 5 ; +
+ p u b l i c s t a t i c f i n a l i n t Z o o m = 6 ; +
+ p u b l i c s t a t i c f i n a l i n t Z o o m I n = 7 ; +
+ p u b l i c s t a t i c f i n a l i n t Z o o m O u t = 8 ; +
+ p u b l i c s t a t i c f i n a l i n t Z o o m R e c t a n g l e = 9 ; +
+ p u b l i c s t a t i c f i n a l i n t Z o o m S e l e c t i o n = 1 0 ; +
+ p u b l i c s t a t i c f i n a l i n t F i t W i n d o w = 1 1 ; +
+ p u b l i c s t a t i c f i n a l i n t V i e w P r e v i o u s = 1 2 ; +
+ p u b l i c s t a t i c f i n a l i n t V i e w N e x t = 1 3 ; +
+ p u b l i c s t a t i c f i n a l i n t V i e w R e s t o r e = 1 4 ; +
+ p u b l i c s t a t i c f i n a l i n t S e l e c t = 1 5 ; +
+ p u b l i c s t a t i c f i n a l i n t S e l e c t R a d i u s = 1 6 ; +
+ p u b l i c s t a t i c f i n a l i n t S e l e c t P o l y g o n = 1 7 ; +
+ p u b l i c s t a t i c f i n a l i n t S e l e c t C l e a r = 1 9 ; +
+ p u b l i c s t a t i c f i n a l i n t R e f r e s h = 2 0 ; +
+ p u b l i c s t a t i c f i n a l i n t C o p y = 2 1 ; +
+ p u b l i c s t a t i c f i n a l i n t A b o u t = 2 2 ; +
+ p u b l i c s t a t i c f i n a l i n t P r i n t M a p = 2 3 ; +
+ p u b l i c s t a t i c f i n a l i n t G e t P r i n t a b l e P a g e = 2 4 ; +
+ p u b l i c s t a t i c f i n a l i n t M e a s u r e = 2 5 ; +
+ p u b l i c s t a t i c f i n a l i n t I n v o k e U r l = 2 6 ; +
+ p u b l i c s t a t i c f i n a l i n t S e a r c h = 2 7 ; +
+ p u b l i c s t a t i c f i n a l i n t B u f f e r = 2 8 ; +
+ p u b l i c s t a t i c f i n a l i n t V i e w O p t i o n s = 3 0 ; +
+ p u b l i c s t a t i c f i n a l i n t I n v o k e S c r i p t = 3 1 ; +
+ p u b l i c s t a t i c f i n a l i n t S e l e c t W i t h i n = 3 2 ; +
+ p u b l i c s t a t i c f i n a l i n t H e l p = 3 3 ; +
+ p u b l i c s t a t i c f i n a l i n t M a p T i p = 3 4 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b A c t i o n s ( ) ; +
+ C o m p i l e d f r o m " M g W e b B u f f e r C o m m a n d . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b B u f f e r C o m m a n d e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d { +
+ C o m p i l e d f r o m " M g W e b C o m m a n d . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d e x t e n d s o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e { +
+ p u b l i c j a v a . l a n g . S t r i n g g e t L a b e l ( ) ; +
+ p u b l i c i n t g e t A c t i o n ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t I c o n U r l ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D i s a b l e d I c o n U r l ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t T o o l t i p ( ) ; +
+ p u b l i c i n t g e t T a r g e t V i e w e r T y p e ( ) ; +
+ p u b l i c b o o l e a n i s U s e d ( ) ; +
+ C o m p i l e d f r o m " M g W e b C o m m a n d C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d g e t I t e m ( i n t ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d g e t I t e m ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d ) ; +
+ C o m p i l e d f r o m " M g W e b C o m m a n d W i d g e t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d W i d g e t e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d g e t C o m m a n d ( ) ; +
+ C o m p i l e d f r o m " M g W e b C o n t e x t M e n u . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b C o n t e x t M e n u e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t C o l l e c t i o n { +
+ p u b l i c b o o l e a n i s V i s i b l e ( ) ; +
+ C o m p i l e d f r o m " M g W e b F l y o u t W i d g e t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b F l y o u t W i d g e t e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t C o l l e c t i o n g e t S u b I t e m s ( ) ; +
+ C o m p i l e d f r o m " M g W e b G e t P r i n t a b l e P a g e C o m m a n d . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b G e t P r i n t a b l e P a g e C o m m a n d e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d { +
+ C o m p i l e d f r o m " M g W e b H e l p C o m m a n d . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b H e l p C o m m a n d e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d { +
+ p u b l i c j a v a . l a n g . S t r i n g g e t U r l ( ) ; +
+ C o m p i l e d f r o m " M g W e b I n f o r m a t i o n P a n e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b I n f o r m a t i o n P a n e e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b U i S i z a b l e P a n e { +
+ p u b l i c b o o l e a n i s L e g e n d B a n d V i s i b l e ( ) ; +
+ p u b l i c b o o l e a n i s P r o p e r t i e s B a n d V i s i b l e ( ) ; +
+ C o m p i l e d f r o m " M g W e b I n v o k e S c r i p t C o m m a n d . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b I n v o k e S c r i p t C o m m a n d e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d { +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S c r i p t C o d e ( ) ; +
+ C o m p i l e d f r o m " M g W e b I n v o k e U r l C o m m a n d . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b I n v o k e U r l C o m m a n d e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d { +
+ p u b l i c i n t g e t P a r a m e t e r C o u n t ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t P a r a m e t e r N a m e A t ( i n t ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t P a r a m e t e r V a l u e A t ( i n t ) ; +
+ p u b l i c b o o l e a n d i s a b l e d I f S e l e c t i o n E m p t y ( ) ; +
+ p u b l i c i n t g e t L a y e r C o u n t ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t L a y e r N a m e A t ( i n t ) ; +
+ C o m p i l e d f r o m " M g W e b L a y o u t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b L a y o u t e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b L a y o u t ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e , o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t T i t l e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t M a p D e f i n i t i o n ( ) ; +
+ p u b l i c b o o l e a n g e t E n a b l e P i n g S e r v e r ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S e l e c t i o n C o l o r ( ) ; +
+ p u b l i c i n t g e t P o i n t S e l e c t i o n B u f f e r ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t M a p I m a g e F o r m a t ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S e l e c t i o n I m a g e F o r m a t ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t S t a r t u p S c r i p t ( ) ; +
+ p u b l i c d o u b l e g e t S c a l e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g P o i n t g e t C e n t e r ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b T o o l B a r g e t T o o l B a r ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b U i P a n e g e t S t a t u s B a r ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b T a s k P a n e g e t T a s k P a n e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b I n f o r m a t i o n P a n e g e t I n f o r m a t i o n P a n e ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t D w f P r e v i e w U r l ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t A j a x P r e v i e w U r l ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d C o l l e c t i o n g e t C o m m a n d s ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b C o n t e x t M e n u g e t C o n t e x t M e n u ( ) ; +
+ p u b l i c i n t g e t H y p e r l i n k T a r g e t ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t H y p e r l i n k T a r g e t F r a m e ( ) ; +
+ p u b l i c b o o l e a n i s Z o o m C o n t r o l V i s i b l e ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r p r o c e s s G e t t i n g S t a r t e d P a g e ( o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r , b o o l e a n ) ; +
+ C o m p i l e d f r o m " M g W e b M e a s u r e C o m m a n d . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b M e a s u r e C o m m a n d e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d { +
+ C o m p i l e d f r o m " M g W e b P r i n t C o m m a n d . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b P r i n t C o m m a n d e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d { +
+ p u b l i c i n t g e t P r i n t L a y o u t C o u n t ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t P r i n t L a y o u t A t ( i n t ) ; +
+ C o m p i l e d f r o m " M g W e b S e a r c h C o m m a n d . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b S e a r c h C o m m a n d e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d { +
+ p u b l i c j a v a . l a n g . S t r i n g g e t L a y e r ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t P r o m p t ( ) ; +
+ p u b l i c i n t g e t R e s u l t C o l u m n C o u n t ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t C o l u m n D i s p l a y N a m e A t ( i n t ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t C o l u m n P r o p e r t y N a m e A t ( i n t ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t F i l t e r ( ) ; +
+ p u b l i c i n t g e t M a t c h L i m i t ( ) ; +
+ C o m p i l e d f r o m " M g W e b S e l e c t W i t h i n C o m m a n d . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b S e l e c t W i t h i n C o m m a n d e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d { +
+ C o m p i l e d f r o m " M g W e b S e p a r a t o r W i d g e t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b S e p a r a t o r W i d g e t e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t { +
+ C o m p i l e d f r o m " M g W e b T a r g e t T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b T a r g e t T y p e { +
+ p u b l i c s t a t i c f i n a l i n t T a s k P a n e = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t N e w W i n d o w = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t S p e c i f i e d F r a m e = 3 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b T a r g e t T y p e ( ) ; +
+ C o m p i l e d f r o m " M g W e b T a r g e t V i e w e r T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b T a r g e t V i e w e r T y p e { +
+ p u b l i c s t a t i c f i n a l i n t D w f = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t A j a x = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t A l l = 3 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b T a r g e t V i e w e r T y p e ( ) ; +
+ C o m p i l e d f r o m " M g W e b T a s k B a r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b T a s k B a r e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b U i P a n e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t C o l l e c t i o n g e t T a s k L i s t ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t C o l l e c t i o n g e t T a s k B u t t o n s ( ) ; +
+ C o m p i l e d f r o m " M g W e b T a s k B a r W i d g e t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b T a s k B a r W i d g e t e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t { +
+ p u b l i c j a v a . l a n g . S t r i n g g e t N a m e ( ) ; +
+ C o m p i l e d f r o m " M g W e b T a s k B u t t o n T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b T a s k B u t t o n T y p e { +
+ p u b l i c s t a t i c f i n a l i n t H o m e = 0 ; +
+ p u b l i c s t a t i c f i n a l i n t B a c k = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t F o r w a r d = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t T a s k s = 3 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b T a s k B u t t o n T y p e ( ) ; +
+ C o m p i l e d f r o m " M g W e b T a s k P a n e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b T a s k P a n e e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b U i S i z a b l e P a n e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b T a s k B a r g e t T a s k B a r ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t I n i t i a l T a s k U r l ( ) ; +
+ C o m p i l e d f r o m " M g W e b T o o l B a r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b T o o l B a r e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b U i P a n e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t C o l l e c t i o n g e t W i d g e t s ( ) ; +
+ C o m p i l e d f r o m " M g W e b U i P a n e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b U i P a n e e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ C o m p i l e d f r o m " M g W e b U i S i z a b l e P a n e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b U i S i z a b l e P a n e e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b U i P a n e { +
+ p u b l i c i n t g e t W i d t h ( ) ; +
+ C o m p i l e d f r o m " M g W e b U i T a r g e t C o m m a n d . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d { +
+ p u b l i c i n t g e t T a r g e t ( ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g g e t T a r g e t N a m e ( ) ; +
+ C o m p i l e d f r o m " M g W e b V i e w O p t i o n s C o m m a n d . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b V i e w O p t i o n s C o m m a n d e x t e n d s o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d { +
+ C o m p i l e d f r o m " M g W e b W i d g e t . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c i n t g e t T y p e ( ) ; +
+ C o m p i l e d f r o m " M g W e b W i d g e t C o l l e c t i o n . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t C o l l e c t i o n e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t g e t W i d g e t ( i n t ) ; +
+ p u b l i c b o o l e a n c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t ) ; +
+ p u b l i c i n t i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t ) ; +
+ C o m p i l e d f r o m " M g W e b W i d g e t T y p e . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t T y p e { +
+ p u b l i c s t a t i c f i n a l i n t C o m m a n d = 1 ; +
+ p u b l i c s t a t i c f i n a l i n t S e p a r a t o r = 2 ; +
+ p u b l i c s t a t i c f i n a l i n t F l y o u t = 3 ; +
+ p u b l i c s t a t i c f i n a l i n t T a s k B u t t o n = 4 ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t T y p e ( ) ; +
+ C o m p i l e d f r o m " M g W k t R e a d e r W r i t e r . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . M g W k t R e a d e r W r i t e r e x t e n d s o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g W k t R e a d e r W r i t e r ( ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y r e a d ( j a v a . l a n g . S t r i n g ) ; +
+ p u b l i c o r g . o s g e o . m a p g u i d e . M g G e o m e t r y r e a d ( j a v a . l a n g . S t r i n g , o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g w r i t e ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ; +
+ p u b l i c j a v a . l a n g . S t r i n g w r i t e ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y , o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ; +
+ C o m p i l e d f r o m " O b j e c t F a c t o r y . j a v a " +
+ p u b l i c c l a s s o r g . o s g e o . m a p g u i d e . O b j e c t F a c t o r y { +
+ p u b l i c o r g . o s g e o . m a p g u i d e . O b j e c t F a c t o r y ( ) ; +
+ p u b l i c s t a t i c j a v a . l a n g . O b j e c t c r e a t e O b j e c t ( i n t , l o n g , b o o l e a n ) ; +
\ No newline at end of file
Modified: branches/4.0/MgDev/Bindings/src/ApiDump/api.php.txt
--- branches/4.0/MgDev/Bindings/src/ApiDump/api.php.txt 2025-05-01 11:50:30 UTC (rev 10134)
+++ branches/4.0/MgDev/Bindings/src/ApiDump/api.php.txt 2025-05-05 10:45:53 UTC (rev 10135)
@@ -0,0 +1,34333 @@
+Class [ <internal:MapGuideApi> class MapGuideApi ] {
+ - Constants [0] {
+ - Static properties [0] {
+ - Static methods [4] {
+ Method [ <internal:MapGuideApi> static public method MgInitializeWebTier ] {
+ - Parameters [1] {
+ Parameter #0 [ <required> $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> static public method SetLocalizedFilesPath ] {
+ Parameter #0 [ <required> string $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> static public method Localize ] {
+ - Parameters [3] {
+ Parameter #1 [ <required> string $arg2 ]
+ Parameter #2 [ <required> int $arg3 ]
+ Method [ <internal:MapGuideApi> static public method GetLocalizedString ] {
+ - Parameters [2] {
+ - Properties [0] {
+ - Methods [0] {
+Class [ <internal:MapGuideApi> class MgAgfReaderWriter extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Static methods [0] {
+ - Methods [6] {
+ Method [ <internal:MapGuideApi, ctor> public method __construct ] {
+ - Parameters [0] {
+ Method [ <internal:MapGuideApi> public method Read ] {
+ Parameter #0 [ <required> ?MgByteReader $arg1 ]
+ Parameter #1 [ <required> ?MgTransform $arg2 ]
+ Method [ <internal:MapGuideApi> public method Write ] {
+ Parameter #0 [ <required> ?MgGeometry $arg1 ]
+ Method [ <internal:MapGuideApi, overwrites MgGuardDisposable, prototype MgObject> public method __set ] {
+ Parameter #1 [ <optional> $arg2 = <default> ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgGuardDisposable, prototype MgObject> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgGuardDisposable, prototype MgObject> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgAggregateGeometry extends MgGeometry implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [34] {
+ Method [ <internal:MapGuideApi> public method GetCount ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgGeometry, prototype MgGeometricEntity> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgGeometry, prototype MgGeometricEntity> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgGeometry, prototype MgGeometricEntity> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method GetGeometryType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Contains ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Crosses ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Disjoint ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Equals ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Intersects ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Overlaps ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Touches ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Within ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Boundary ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Buffer ] {
+ Parameter #0 [ <required> float $arg1 ]
+ Parameter #1 [ <required> ?MgMeasure $arg2 ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method ConvexHull ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Difference ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Distance ] {
+ - Return [ float ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Intersection ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method SymetricDifference ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Union ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Prepare ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Tessellate ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method GetDimension ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method IsEmpty ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method IsSimple ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method IsClosed ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method IsValid ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method Envelope ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method Copy ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method Transform ] {
+ Parameter #0 [ <required> ?MgTransform $arg1 ]
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method GetArea ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method GetLength ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method GetCentroid ] {
+Class [ <internal:MapGuideApi> class MgArcSegment extends MgCurveSegment implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [18] {
+ Method [ <internal:MapGuideApi, overwrites MgGeometryComponent, prototype MgGeometryComponent> public method GetComponentType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetControlCoordinate ] {
+ Method [ <internal:MapGuideApi, overwrites MgCurveSegment, prototype MgCurveSegment> public method GetStartCoordinate ] {
+ Method [ <internal:MapGuideApi, overwrites MgCurveSegment, prototype MgCurveSegment> public method GetEndCoordinate ] {
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method GetDimension ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method IsEmpty ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method IsClosed ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method Copy ] {
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method Transform ] {
+ Method [ <internal:MapGuideApi, overwrites MgCurveSegment, prototype MgGeometricEntity> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgCurveSegment, prototype MgGeometricEntity> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgCurveSegment, prototype MgGeometricEntity> public method __isset ] {
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgBatchPropertyCollection extends MgCollection implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [15] {
+ Method [ <internal:MapGuideApi> public method SetItem ] {
+ Parameter #0 [ <required> int $arg1 ]
+ Parameter #1 [ <required> ?MgPropertyCollection $arg2 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Add ] {
+ Parameter #0 [ <required> ?MgPropertyCollection $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Insert ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Remove ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetItem ] {
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method GetCount ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method Clear ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method RemoveAt ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Contains ] {
+ Parameter #0 [ <required> ?MgPropertyDefinition $arg1 ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IndexOf ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method ToXml ] {
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgBlobProperty extends MgNullableProperty implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [11] {
+ Parameter #1 [ <required> ?MgByteReader $arg2 ]
+ Method [ <internal:MapGuideApi> public method GetValue ] {
+ Method [ <internal:MapGuideApi, overwrites MgProperty, prototype MgProperty> public method GetPropertyType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetValue ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgNullableProperty, prototype MgNamedSerializable> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgNullableProperty, prototype MgNamedSerializable> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgNullableProperty, prototype MgNamedSerializable> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgNullableProperty> public method SetNull ] {
+ Parameter #0 [ <required> bool $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgNullableProperty> public method IsNull ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgProperty> public method GetName ] {
+ Method [ <internal:MapGuideApi, inherits MgProperty> public method SetName ] {
+ - Return [ void ]
+Class [ <internal:MapGuideApi> class MgBooleanProperty extends MgNullableProperty implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [11] {
+ Parameter #1 [ <required> bool $arg2 ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+Class [ <internal:MapGuideApi> class MgByteProperty extends MgNullableProperty implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [11] {
+ Parameter #1 [ <required> int $arg2 ]
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+Class [ <internal:MapGuideApi> class MgByteReader implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [11] {
+ Parameter #1 [ <required> $arg2 ]
+ Parameter #2 [ <required> $arg3 ]
+ Parameter #0 [ <required> &$arg1 ]
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetMimeType ] {
+ Method [ <internal:MapGuideApi> public method ToString ] {
+ Method [ <internal:MapGuideApi> public method ToFile ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetLength ] {
+ Method [ <internal:MapGuideApi> public method IsRewindable ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method Rewind ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method __get ] {
+ Method [ <internal:MapGuideApi> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgByteSink extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [5] {
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgByteSource extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [7] {
+ Method [ <internal:MapGuideApi> public method SetMimeType ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetReader ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgClassDefinition extends MgNamedSerializable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [16] {
+ Method [ <internal:MapGuideApi> public method GetProperties ] {
+ Method [ <internal:MapGuideApi> public method GetIdentityProperties ] {
+ Method [ <internal:MapGuideApi> public method GetDefaultGeometryPropertyName ] {
+ Method [ <internal:MapGuideApi> public method SetDefaultGeometryPropertyName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetName ] {
+ Method [ <internal:MapGuideApi> public method SetDescription ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetDescription ] {
+ Method [ <internal:MapGuideApi> public method GetBaseClassDefinition ] {
+ Method [ <internal:MapGuideApi> public method IsComputed ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsAbstract ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method Delete ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgNamedSerializable, prototype MgNamedSerializable> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgNamedSerializable, prototype MgNamedSerializable> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgNamedSerializable, prototype MgNamedSerializable> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgClassDefinitionCollection extends MgCollection implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [15] {
+ Parameter #1 [ <required> ?MgClassDefinition $arg2 ]
+ - Return [ void ]
+ Parameter #0 [ <required> ?MgClassDefinition $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgClobProperty extends MgNullableProperty implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [11] {
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+Class [ <internal:MapGuideApi> class MgCollection implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [7] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method Clear ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method RemoveAt ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method ToXml ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgColor implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [9] {
+ - Parameters [4] {
+ Parameter #3 [ <required> int $arg4 ]
+ Method [ <internal:MapGuideApi> public method GetColor ] {
+ Method [ <internal:MapGuideApi> public method GetRed ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetBlue ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetGreen ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetAlpha ] {
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgConfigProperties implements SWIG\wrapped ] {
+ - Constants [329] {
+ Constant [ public string DefaultConfigurationFilename ] { webconfig.ini }
+ Constant [ public string ServerConfigurationFilename ] { serverconfig.ini }
+ Constant [ public string GeneralPropertiesSection ] { GeneralProperties }
+ Constant [ public string GeneralPropertyConnectionTimeout ] { ConnectionTimeout }
+ Constant [ public int DefaultGeneralPropertyConnectionTimeout ] { 120 }
+ Constant [ public string GeneralPropertyConnectionTimerInterval ] { ConnectionTimerInterval }
+ Constant [ public int DefaultGeneralPropertyConnectionTimerInterval ] { 60 }
+ Constant [ public string GeneralPropertyLocale ] { Locale }
+ Constant [ public string DefaultGeneralPropertyLocale ] { }
+ Constant [ public string GeneralPropertyDefaultMessageLocale ] { DefaultMessageLocale }
+ Constant [ public string DefaultGeneralPropertyDefaultMessageLocale ] { en }
+ Constant [ public string GeneralPropertyDisplayName ] { DisplayName }
+ Constant [ public string DefaultGeneralPropertyDisplayName ] { }
+ Constant [ public string GeneralPropertyFdoPath ] { FdoPath }
+ Constant [ public string DefaultGeneralPropertyFdoPath ] { }
+ Constant [ public string GeneralPropertyMentorDictionaryPath ] { MentorDictionaryPath }
+ Constant [ public string DefaultGeneralPropertyMentorDictionaryPath ] { }
+ Constant [ public string GeneralPropertyMentorUserDictionaryPath ] { MentorUserDictionaryPath }
+ Constant [ public string DefaultGeneralPropertyMentorUserDictionaryPath ] { }
+ Constant [ public string GeneralPropertyLicenseServerPath ] { LicenseServerPath }
+ Constant [ public string DefaultGeneralPropertyLicenseServerPath ] { }
+ Constant [ public string GeneralPropertyLinuxMemDebug ] { LinuxMemDebug }
+ Constant [ public bool DefaultGeneralPropertyLinuxMemDebug ] { }
+ Constant [ public string GeneralPropertyLinuxFontDirectories ] { LinuxFontDirectories }
+ Constant [ public string DefaultGeneralPropertyLinuxFontDirectories ] { }
+ Constant [ public string GeneralPropertyLogsDelimiter ] { LogsDelimiter }
+ Constant [ public string DefaultGeneralPropertyLogsDelimiter ] { }
+ Constant [ public string GeneralPropertyLogsDetail ] { LogsDetail }
+ Constant [ public string DefaultGeneralPropertyLogsDetail ] { }
+ Constant [ public string GeneralPropertyLogsPath ] { LogsPath }
+ Constant [ public string DefaultGeneralPropertyLogsPath ] { Logs/ }
+ Constant [ public string GeneralPropertyMachineIp ] { MachineIp }
+ Constant [ public string DefaultGeneralPropertyMachineIp ] { 127.0.0.1 }
+ Constant [ public string GeneralPropertyMaxLogFileSize ] { MaxLogFileSize }
+ Constant [ public int DefaultGeneralPropertyMaxLogFileSize ] { 1024 }
+ Constant [ public string GeneralPropertyMaxLogFileSizeEnabled ] { MaxLogFileSizeEnabled }
+ Constant [ public bool DefaultGeneralPropertyMaxLogFileSizeEnabled ] { }
+ Constant [ public string GeneralPropertyResourcesPath ] { ResourcesPath }
+ Constant [ public string DefaultGeneralPropertyResourcesPath ] { Resources/ }
+ Constant [ public string GeneralPropertySerialNumber ] { SerialNumber }
+ Constant [ public string DefaultGeneralPropertySerialNumber ] { }
+ Constant [ public string GeneralPropertyServiceRegistrationTimerInterval ] { ServiceRegistrationTimerInterval }
+ Constant [ public int DefaultGeneralPropertyServiceRegistrationTimerInterval ] { 60 }
+ Constant [ public string GeneralPropertyTcpIpMtu ] { TcpIpMtu }
+ Constant [ public int DefaultGeneralPropertyTcpIpMtu ] { 1460 }
+ Constant [ public string GeneralPropertyTempPath ] { TempPath }
+ Constant [ public string DefaultGeneralPropertyTempPath ] { Temp/ }
+ Constant [ public string GeneralPropertyWfsDocumentPath ] { WfsDocumentPath }
+ Constant [ public string DefaultGeneralPropertyWfsDocumentPath ] { Wfs/ }
+ Constant [ public string GeneralPropertyWmsDocumentPath ] { WmsDocumentPath }
+ Constant [ public string DefaultGeneralPropertyWmsDocumentPath ] { Wms/ }
+ Constant [ public string GeneralPropertyPreCacheMaps ] { PreCacheMaps }
+ Constant [ public string DefaultGeneralPropertyPreCacheMaps ] { }
+ Constant [ public string AdministrativeConnectionPropertiesSection ] { AdministrativeConnectionProperties }
+ Constant [ public string AdministrativeConnectionPropertyEmail ] { Email }
+ Constant [ public string DefaultAdministrativeConnectionPropertyEmail ] { }
+ Constant [ public string AdministrativeConnectionPropertyMaxConnections ] { MaxConnections }
+ Constant [ public int DefaultAdministrativeConnectionPropertyMaxConnections ] { 20 }
+ Constant [ public string AdministrativeConnectionPropertyPort ] { Port }
+ Constant [ public int DefaultAdministrativeConnectionPropertyPort ] { 5555 }
+ Constant [ public string AdministrativeConnectionPropertyQueueSize ] { QueueSize }
+ Constant [ public int DefaultAdministrativeConnectionPropertyQueueSize ] { 10 }
+ Constant [ public string AdministrativeConnectionPropertyThreadPoolSize ] { ThreadPoolSize }
+ Constant [ public int DefaultAdministrativeConnectionPropertyThreadPoolSize ] { 5 }
+ Constant [ public string ClientConnectionPropertiesSection ] { ClientConnectionProperties }
+ Constant [ public string ClientConnectionPropertyMaxConnections ] { MaxConnections }
+ Constant [ public int DefaultClientConnectionPropertyMaxConnections ] { 100 }
+ Constant [ public string ClientConnectionPropertyPort ] { Port }
+ Constant [ public int DefaultClientConnectionPropertyPort ] { 4444 }
+ Constant [ public string ClientConnectionPropertyQueueSize ] { QueueSize }
+ Constant [ public int DefaultClientConnectionPropertyQueueSize ] { 20 }
+ Constant [ public string ClientConnectionPropertyThreadPoolSize ] { ThreadPoolSize }
+ Constant [ public int DefaultClientConnectionPropertyThreadPoolSize ] { 10 }
+ Constant [ public string SiteConnectionPropertiesSection ] { SiteConnectionProperties }
+ Constant [ public string SiteConnectionPropertyIpAddress ] { IpAddress }
+ Constant [ public string DefaultSiteConnectionPropertyIpAddress ] { 127.0.0.1 }
+ Constant [ public string SiteConnectionPropertyMaxConnections ] { MaxConnections }
+ Constant [ public int DefaultSiteConnectionPropertyMaxConnections ] { 20 }
+ Constant [ public string SiteConnectionPropertyPort ] { Port }
+ Constant [ public int DefaultSiteConnectionPropertyPort ] { 3333 }
+ Constant [ public string SiteConnectionPropertyQueueSize ] { QueueSize }
+ Constant [ public int DefaultSiteConnectionPropertyQueueSize ] { 10 }
+ Constant [ public string SiteConnectionPropertyThreadPoolSize ] { ThreadPoolSize }
+ Constant [ public int DefaultSiteConnectionPropertyThreadPoolSize ] { 5 }
+ Constant [ public string HostPropertiesSection ] { HostProperties }
+ Constant [ public string HostPropertyDrawingService ] { DrawingService }
+ Constant [ public bool DefaultHostPropertyDrawingService ] { }
+ Constant [ public string HostPropertyFeatureService ] { FeatureService }
+ Constant [ public bool DefaultHostPropertyFeatureService ] { }
+ Constant [ public string HostPropertyKmlService ] { KmlService }
+ Constant [ public bool DefaultHostPropertyKmlService ] { }
+ Constant [ public string HostPropertyMappingService ] { MappingService }
+ Constant [ public bool DefaultHostPropertyMappingService ] { }
+ Constant [ public string HostPropertyRenderingService ] { RenderingService }
+ Constant [ public bool DefaultHostPropertyRenderingService ] { }
+ Constant [ public string HostPropertyResourceService ] { ResourceService }
+ Constant [ public bool DefaultHostPropertyResourceService ] { }
+ Constant [ public string HostPropertyProfilingService ] { ProfilingService }
+ Constant [ public bool DefaultHostPropertyProfilingService ] { }
+ Constant [ public string HostPropertySiteService ] { SiteService }
+ Constant [ public bool DefaultHostPropertySiteService ] { }
+ Constant [ public string HostPropertyTileService ] { TileService }
+ Constant [ public bool DefaultHostPropertyTileService ] { }
+ Constant [ public string DrawingServicePropertiesSection ] { DrawingServiceProperties }
+ Constant [ public string FeatureServicePropertiesSection ] { FeatureServiceProperties }
+ Constant [ public string FeatureServicePropertyCacheSize ] { CacheSize }
+ Constant [ public int DefaultFeatureServicePropertyCacheSize ] { 100 }
+ Constant [ public string FeatureServicePropertyCacheTimeLimit ] { CacheTimeLimit }
+ Constant [ public int DefaultFeatureServicePropertyCacheTimeLimit ] { 86400 }
+ Constant [ public string FeatureServicePropertyCacheTimerInterval ] { CacheTimerInterval }
+ Constant [ public int DefaultFeatureServicePropertyCacheTimerInterval ] { 3600 }
+ Constant [ public string FeatureServicePropertyDataCacheSize ] { DataCacheSize }
+ Constant [ public int DefaultFeatureServicePropertyDataCacheSize ] { 100 }
+ Constant [ public string FeatureServicePropertyDataConnectionPoolEnabled ] { DataConnectionPoolEnabled }
+ Constant [ public bool DefaultFeatureServicePropertyDataConnectionPoolEnabled ] { }
+ Constant [ public string FeatureServicePropertyDataConnectionPoolExcludedProviders ] { DataConnectionPoolExcludedProviders }
+ Constant [ public string DefaultFeatureServicePropertyDataConnectionPoolExcludedProviders ] { }
+ Constant [ public string FeatureServicePropertyDataConnectionPoolSize ] { DataConnectionPoolSize }
+ Constant [ public int DefaultFeatureServicePropertyDataConnectionPoolSize ] { 50 }
+ Constant [ public string FeatureServicePropertyDataConnectionPoolSizeCustom ] { DataConnectionPoolSizeCustom }
+ Constant [ public string DefaultFeatureServicePropertyDataConnectionPoolSizeCustom ] { }
+ Constant [ public string FeatureServicePropertyDataConnectionTimeout ] { DataConnectionTimeout }
+ Constant [ public int DefaultFeatureServicePropertyDataConnectionTimeout ] { 600 }
+ Constant [ public string FeatureServicePropertyDataConnectionTimerInterval ] { DataConnectionTimerInterval }
+ Constant [ public int DefaultFeatureServicePropertyDataConnectionTimerInterval ] { 60 }
+ Constant [ public string FeatureServicePropertyJoinQueryBatchSize ] { JoinQueryBatchSize }
+ Constant [ public int DefaultFeatureServicePropertyJoinQueryBatchSize ] { 100 }
+ Constant [ public string FeatureServicePropertyDataConnectionUseLimit ] { DataConnectionUseLimit }
+ Constant [ public string DefaultFeatureServicePropertyDataConnectionUseLimit ] { }
+ Constant [ public string FeatureServicePropertyDataTransactionTimeout ] { DataTransactionTimeout }
+ Constant [ public int DefaultFeatureServicePropertyDataTransactionTimeout ] { 360 }
+ Constant [ public string FeatureServicePropertyDataTransactionTimerInterval ] { DataTransactionTimerInterval }
+ Constant [ public int DefaultFeatureServicePropertyDataTransactionTimerInterval ] { 60 }
+ Constant [ public string FeatureServicePropertyFDOConnectionTimeoutCustom ] { FDOConnectionTimeoutCustom }
+ Constant [ public string DefaultFeatureServicePropertyFDOConnectionTimeoutCustom ] { OSGeo.WMS:120 }
+ Constant [ public string FeatureServicePropertyUseFdoJoinOptimization ] { UseFdoJoinOptimization }
+ Constant [ public bool DefaultFeatureServicePropertyUseFdoJoinOptimization ] { 1 }
+ Constant [ public string MappingServicePropertiesSection ] { MappingServiceProperties }
+ Constant [ public string MappingServicePropertyLegendFont ] { LegendFont }
+ Constant [ public string DefaultMappingServicePropertyLegendFont ] { Arial }
+ Constant [ public string RenderingServicePropertiesSection ] { RenderingServiceProperties }
+ Constant [ public string RenderingServicePropertyTileExtentOffset ] { TileExtentOffset }
+ Constant [ public float DefaultRenderingServicePropertyTileExtentOffset ] { 0.35 }
+ Constant [ public string RenderingServicePropertyRasterGridSize ] { RasterGridSize }
+ Constant [ public int DefaultRenderingServicePropertyRasterGridSize ] { 100 }
+ Constant [ public string RenderingServicePropertyMinRasterGridSize ] { MinRasterGridSize }
+ Constant [ public int DefaultRenderingServicePropertyMinRasterGridSize ] { 10 }
+ Constant [ public string RenderingServicePropertyRasterGridSizeOverrideRatio ] { RasterGridSizeOverrideRatio }
+ Constant [ public float DefaultRenderingServicePropertyRasterGridSizeOverrideRatio ] { 0.25 }
+ Constant [ public string RenderingServicePropertyRasterGridSizeForPlot ] { RasterGridSizeForPlot }
+ Constant [ public int DefaultRenderingServicePropertyRasterGridSizeForPlot ] { 50 }
+ Constant [ public string RenderingServicePropertyMinRasterGridSizeForPlot ] { MinRasterGridSizeForPlot }
+ Constant [ public int DefaultRenderingServicePropertyMinRasterGridSizeForPlot ] { 5 }
+ Constant [ public string RenderingServicePropertyRasterGridSizeOverrideRatioForPlot ] { RasterGridSizeOverrideRatioForPlot }
+ Constant [ public float DefaultRenderingServicePropertyRasterGridSizeOverrideRatioForPlot ] { 0.1 }
+ Constant [ public string RenderingServicePropertyRenderSelectionBatchSize ] { RenderSelectionBatchSize }
+ Constant [ public int DefaultRenderingServicePropertyRenderSelectionBatchSize ] { 50000 }
+ Constant [ public string RenderingServicePropertyClampPoints ] { ClampPoints }
+ Constant [ public bool DefaultRenderingServicePropertyClampPoints ] { }
+ Constant [ public string RenderingServicePropertyGeneralizeData ] { GeneralizeData }
+ Constant [ public bool DefaultRenderingServicePropertyGeneralizeData ] { }
+ Constant [ public string RenderingServicePropertyMaxRasterImageWidth ] { MaxRasterImageWidth }
+ Constant [ public int DefaultRenderingServicePropertyMaxRasterImageWidth ] { 2048 }
+ Constant [ public string RenderingServicePropertyMaxRasterImageHeight ] { MaxRasterImageHeight }
+ Constant [ public int DefaultRenderingServicePropertyMaxRasterImageHeight ] { 2048 }
+ Constant [ public string RenderingServicePropertyMaxRenderImageWidth ] { MaxRenderImageWidth }
+ Constant [ public int DefaultRenderingServicePropertyMaxRenderImageWidth ] { 16384 }
+ Constant [ public string RenderingServicePropertyMaxRenderImageHeight ] { MaxRenderImageHeight }
+ Constant [ public int DefaultRenderingServicePropertyMaxRenderImageHeight ] { 16384 }
+ Constant [ public string RenderingServicePropertiesGlobalRasterStylizationLockEnabled ] { GlobalRasterStylizationLockEnabled }
+ Constant [ public bool DefaultRenderingServicePropertiesGlobalRasterStylizationLockEnabled ] { 1 }
+ Constant [ public string FontAliasMappingSection ] { FontAliases }
+ Constant [ public string UnmanagedDataMappingsSection ] { UnmanagedDataMappings }
+ Constant [ public string ResourceServicePropertiesSection ] { ResourceServiceProperties }
+ Constant [ public string ResourceServicePropertyLibraryRepositoryPath ] { LibraryRepositoryPath }
+ Constant [ public string DefaultResourceServicePropertyLibraryRepositoryPath ] { Repositories/Library/ }
+ Constant [ public string ResourceServicePropertyLibraryResourceDataFilePath ] { LibraryResourceDataFilePath }
+ Constant [ public string DefaultResourceServicePropertyLibraryResourceDataFilePath ] { Repositories/Library/DataFiles/ }
+ Constant [ public string ResourceServicePropertyPackagesPath ] { PackagesPath }
+ Constant [ public string DefaultResourceServicePropertyPackagesPath ] { Packages/ }
+ Constant [ public string ResourceServicePropertyRepositoryCheckpointsTimerInterval ] { RepositoryCheckpointsTimerInterval }
+ Constant [ public int DefaultResourceServicePropertyRepositoryCheckpointsTimerInterval ] { 600 }
+ Constant [ public string ResourceServicePropertyResourceChangeTimerInterval ] { ResourceChangeTimerInterval }
+ Constant [ public int DefaultResourceServicePropertyResourceChangeTimerInterval ] { 5 }
+ Constant [ public string ResourceServicePropertyResourceDataFileTrashFolderName ] { ResourceDataFileTrashFolderName }
+ Constant [ public string DefaultResourceServicePropertyResourceDataFileTrashFolderName ] { Trash }
+ Constant [ public string ResourceServicePropertyResourcePermissionCacheSize ] { ResourcePermissionCacheSize }
+ Constant [ public int DefaultResourceServicePropertyResourcePermissionCacheSize ] { 1000 }
+ Constant [ public string ResourceServicePropertyResourceSchemaFilePath ] { ResourceSchemaFilePath }
+ Constant [ public string DefaultResourceServicePropertyResourceSchemaFilePath ] { Schema/ }
+ Constant [ public string ResourceServicePropertySessionRepositoryPath ] { SessionRepositoryPath }
+ Constant [ public string DefaultResourceServicePropertySessionRepositoryPath ] { Repositories/Session/ }
+ Constant [ public string ResourceServicePropertySessionResourceDataFilePath ] { SessionResourceDataFilePath }
+ Constant [ public string DefaultResourceServicePropertySessionResourceDataFilePath ] { Repositories/Session/DataFiles/ }
+ Constant [ public string ResourceServicePropertySiteRepositoryPath ] { SiteRepositoryPath }
+ Constant [ public string DefaultResourceServicePropertySiteRepositoryPath ] { Repositories/Site/ }
+ Constant [ public string SiteServicePropertiesSection ] { SiteServiceProperties }
+ Constant [ public string SiteServicePropertySessionTimeout ] { SessionTimeout }
+ Constant [ public int DefaultSiteServicePropertySessionTimeout ] { 1200 }
+ Constant [ public string SiteServicePropertySessionTimerInterval ] { SessionTimerInterval }
+ Constant [ public int DefaultSiteServicePropertySessionTimerInterval ] { 400 }
+ Constant [ public string TileServicePropertiesSection ] { TileServiceProperties }
+ Constant [ public string TileServicePropertyRenderOnly ] { RenderOnly }
+ Constant [ public bool DefaultTileServicePropertyRenderOnly ] { }
+ Constant [ public string TileServicePropertyTileCachePath ] { TileCachePath }
+ Constant [ public string DefaultTileServicePropertyTileCachePath ] { Repositories/TileCache/ }
+ Constant [ public string TileServicePropertyTileColumnsPerFolder ] { TileColumnsPerFolder }
+ Constant [ public int DefaultTileServicePropertyTileColumnsPerFolder ] { 30 }
+ Constant [ public string TileServicePropertyTileRowsPerFolder ] { TileRowsPerFolder }
+ Constant [ public int DefaultTileServicePropertyTileRowsPerFolder ] { 30 }
+ Constant [ public string TileServicePropertyTileSizeX ] { DefaultTileSizeX }
+ Constant [ public int DefaultTileServicePropertyTileSizeX ] { 300 }
+ Constant [ public string TileServicePropertyTileSizeY ] { DefaultTileSizeY }
+ Constant [ public int DefaultTileServicePropertyTileSizeY ] { 300 }
+ Constant [ public string TileServicePropertyImageFormat ] { ImageFormat }
+ Constant [ public string DefaultTileServicePropertyImageFormat ] { PNG }
+ Constant [ public string AccessLogPropertiesSection ] { AccessLogProperties }
+ Constant [ public string AccessLogPropertyEnabled ] { Enabled }
+ Constant [ public bool DefaultAccessLogPropertyEnabled ] { 1 }
+ Constant [ public string AccessLogPropertyFilename ] { Filename }
+ Constant [ public string DefaultAccessLogPropertyFilename ] { Access.log }
+ Constant [ public string AccessLogPropertyParameters ] { Parameters }
+ Constant [ public string DefaultAccessLogPropertyParameters ] { }
+ Constant [ public string AdminLogPropertiesSection ] { AdminLogProperties }
+ Constant [ public string AdminLogPropertyEnabled ] { Enabled }
+ Constant [ public bool DefaultAdminLogPropertyEnabled ] { 1 }
+ Constant [ public string AdminLogPropertyFilename ] { Filename }
+ Constant [ public string DefaultAdminLogPropertyFilename ] { Admin.log }
+ Constant [ public string AdminLogPropertyParameters ] { Parameters }
+ Constant [ public string DefaultAdminLogPropertyParameters ] { }
+ Constant [ public string AuthenticationLogPropertiesSection ] { AuthenticationLogProperties }
+ Constant [ public string AuthenticationLogPropertyEnabled ] { Enabled }
+ Constant [ public bool DefaultAuthenticationLogPropertyEnabled ] { 1 }
+ Constant [ public string AuthenticationLogPropertyFilename ] { Filename }
+ Constant [ public string DefaultAuthenticationLogPropertyFilename ] { Authentication.log }
+ Constant [ public string AuthenticationLogPropertyParameters ] { Parameters }
+ Constant [ public string DefaultAuthenticationLogPropertyParameters ] { }
+ Constant [ public string ErrorLogPropertiesSection ] { ErrorLogProperties }
+ Constant [ public string ErrorLogPropertyEnabled ] { Enabled }
+ Constant [ public bool DefaultErrorLogPropertyEnabled ] { 1 }
+ Constant [ public string ErrorLogPropertyFilename ] { Filename }
+ Constant [ public string DefaultErrorLogPropertyFilename ] { Error.log }
+ Constant [ public string ErrorLogPropertyParameters ] { Parameters }
+ Constant [ public string DefaultErrorLogPropertyParameters ] { }
+ Constant [ public string PerformanceLogPropertiesSection ] { PerformanceLogProperties }
+ Constant [ public string PerformanceLogPropertyEnabled ] { Enabled }
+ Constant [ public bool DefaultPerformanceLogPropertyEnabled ] { }
+ Constant [ public string PerformanceLogPropertyFilename ] { Filename }
+ Constant [ public string DefaultPerformanceLogPropertyFilename ] { Performance.log }
+ Constant [ public string PerformanceLogPropertyParameters ] { Parameters }
+ Constant [ public string DefaultPerformanceLogPropertyParameters ] { }
+ Constant [ public string PerformanceLogPropertyInterval ] { Interval }
+ Constant [ public int DefaultPerformanceLogPropertyInterval ] { 300 }
+ Constant [ public string SessionLogPropertiesSection ] { SessionLogProperties }
+ Constant [ public string SessionLogPropertyEnabled ] { Enabled }
+ Constant [ public bool DefaultSessionLogPropertyEnabled ] { }
+ Constant [ public string SessionLogPropertyFilename ] { Filename }
+ Constant [ public string DefaultSessionLogPropertyFilename ] { Session.log }
+ Constant [ public string SessionLogPropertyParameters ] { Parameters }
+ Constant [ public string DefaultSessionLogPropertyParameters ] { }
+ Constant [ public string TraceLogPropertiesSection ] { TraceLogProperties }
+ Constant [ public string TraceLogPropertyEnabled ] { Enabled }
+ Constant [ public bool DefaultTraceLogPropertyEnabled ] { }
+ Constant [ public string TraceLogPropertyFilename ] { Filename }
+ Constant [ public string DefaultTraceLogPropertyFilename ] { Trace.log }
+ Constant [ public string TraceLogPropertyParameters ] { Parameters }
+ Constant [ public string DefaultTraceLogPropertyParameters ] { }
+ Constant [ public string DBEnvironmentPropertiesSection ] { DBEnvironmentProperties }
+ Constant [ public string LibraryCacheSizeParameters ] { LibraryCacheSize }
+ Constant [ public int DefaultLibraryCacheSizeParameters ] { 32 }
+ Constant [ public string SessionCacheSizeParamters ] { SessionCacheSize }
+ Constant [ public int DefaultSessionCacheSizeParamters ] { 2 }
+ Constant [ public string DBPageSizeParameters ] { DBPageSize }
+ Constant [ public int DefaultDBPageSizeParameters ] { 32 }
+ Constant [ public string DBXMLPageSizeParameters ] { DBXMLPageSize }
+ Constant [ public int DefaultDBXMLPageSizeParameters ] { 32 }
+ Constant [ public string LibraryLogBufferSizeParameters ] { LibraryLogBufferSize }
+ Constant [ public int DefaultLibraryLogBufferSizeParameters ] { 12 }
+ Constant [ public string SessionLogBufferSizeParameters ] { SessionLogBufferSize }
+ Constant [ public int DefaultSessionLogBufferSizeParameters ] { 1 }
+ Constant [ public string DBMaxTransactionsParamters ] { DBMaxTransactions }
+ Constant [ public int DefaultDBMaxTransactionsParamters ] { 1000 }
+ Constant [ public string SessionDBPageSizeParameters ] { SessionDBPageSize }
+ Constant [ public int DefaultSessionDBPageSizeParameters ] { 2 }
+ Constant [ public string SessionDBXMLPageSizeParameters ] { SessionDBXMLPageSize }
+ Constant [ public float DefaultSessionDBXMLPageSizeParameters ] { 0.5 }
+ Constant [ public string DBTimeoutParameters ] { DBTimeout }
+ Constant [ public float DefaultDBTimeoutParameters ] { 0.2 }
+ Constant [ public string DBMaxLockersParameters ] { DBMaxLockers }
+ Constant [ public int DefaultDBMaxLockersParameters ] { 1000 }
+ Constant [ public string AgentPropertiesSection ] { AgentProperties }
+ Constant [ public string AgentDebugPause ] { DebugPause }
+ Constant [ public int DefaultAgentDebugPause ] { 0 }
+ Constant [ public string AgentDisableAuthoring ] { DisableAuthoring }
+ Constant [ public string AgentDisableWfs ] { DisableWfs }
+ Constant [ public string AgentDisableWms ] { DisableWms }
+ Constant [ public string AgentErrorLogEnabled ] { ErrorLogEnabled }
+ Constant [ public bool DefaultAgentErrorLogEnabled ] { }
+ Constant [ public string AgentErrorLogFilename ] { ErrorLogFilename }
+ Constant [ public string DefaultAgentErrorLogFilename ] { Error.log }
+ Constant [ public string AgentRequestLogEnabled ] { RequestLogEnabled }
+ Constant [ public bool DefaultAgentRequestLogEnabled ] { }
+ Constant [ public string AgentRequestLogFilename ] { RequestLogFilename }
+ Constant [ public string DefaultAgentRequestLogFilename ] { Request.log }
+ Constant [ public string AgentGlobalMaxFeatureQueryLimit ] { GlobalMaxFeatureQueryLimit }
+ Constant [ public int DefaultAgentGlobalMaxFeatureQueryLimit ] { 0 }
+ Constant [ public string AgentGlobalMaxMapFeatureQueryLimit ] { GlobalMaxMapFeatureQueryLimit }
+ Constant [ public int DefaultAgentGlobalMaxMapFeatureQueryLimit ] { 0 }
+ Constant [ public string AgentAnonymousDenyGetResourceContent ] { AnonymousDenyGetResourceContent }
+ Constant [ public string DefaultAgentAnonymousDenyGetResourceContent ] { }
+ Constant [ public string AgentAnonymousDenyGetResourceData ] { AnonymousDenyGetResourceData }
+ Constant [ public string DefaultAgentAnonymousDenyGetResourceData ] { }
+ Constant [ public string AgentAnonymousDenyGetResourceHeader ] { AnonymousDenyGetResourceHeader }
+ Constant [ public string DefaultAgentAnonymousDenyGetResourceHeader ] { }
+ Constant [ public string OgcPropertiesSection ] { OgcProperties }
+ Constant [ public string WfsPassword ] { WfsPassword }
+ Constant [ public string WmsPassword ] { WmsPassword }
+ Constant [ public string CITEWfsEnabled ] { CITEWfsEnabled }
+ Constant [ public bool DefaultCITEWfsEnabled ] { }
+ Constant [ public string CITEWmsEnabled ] { CITEWmsEnabled }
+ Constant [ public bool DefaultCITEWmsEnabled ] { }
+ Constant [ public string AgentGlobalGetWfsFeaturesLimit ] { GlobalGetWfsFeaturesLimit }
+ Constant [ public int DefaultAgentGlobalGetWfsFeaturesLimit ] { 0 }
+ Constant [ public string AgentGlobalGetWmsFeatureInfoLimit ] { GlobalGetWmsFeatureInfoLimit }
+ Constant [ public int DefaultAgentGlobalGetWmsFeatureInfoLimit ] { 0 }
+ Constant [ public string WebApplicationPropertiesSection ] { WebApplicationProperties }
+ Constant [ public string TemplateRootFolder ] { TemplateRootFolder }
+ Constant [ public string WidgetInfoFolder ] { WidgetInfoFolder }
+ Constant [ public string ContainerInfoFolder ] { ContainerInfoFolder }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinate implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Static methods [2] {
+ Method [ <internal:MapGuideApi> static public method NoZ ] {
+ Method [ <internal:MapGuideApi> static public method NoM ] {
+ - Methods [8] {
+ Method [ <internal:MapGuideApi> public method GetDimension ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetX ] {
+ Method [ <internal:MapGuideApi> public method GetY ] {
+ Method [ <internal:MapGuideApi> public method GetZ ] {
+ Method [ <internal:MapGuideApi> public method GetM ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateCollection extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [14] {
+ - Return [ int ]
+ Parameter #1 [ <required> ?MgCoordinate $arg2 ]
+ - Return [ void ]
+ Parameter #0 [ <required> ?MgCoordinate $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateDimension implements SWIG\wrapped ] {
+ - Constants [3] {
+ Constant [ public int XY ] { 0 }
+ Constant [ public int XYZ ] { 1 }
+ Constant [ public int M ] { 2 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateIterator extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [6] {
+ Method [ <internal:MapGuideApi> public method GetCurrent ] {
+ Method [ <internal:MapGuideApi> public method MoveNext ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method Reset ] {
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSpace implements SWIG\wrapped ] {
+ - Constants [3] {
+ Constant [ public string None ] { None }
+ Constant [ public string Map ] { Map }
+ Constant [ public string Display ] { Display }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystem extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [103] {
+ Method [ <internal:MapGuideApi> public method GetType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method ConvertCoordinateSystemUnitsToMeters ] {
+ Method [ <internal:MapGuideApi> public method ConvertMetersToCoordinateSystemUnits ] {
+ Method [ <internal:MapGuideApi> public method MeasureEuclideanDistance ] {
+ Parameter #0 [ <required> MgCoordinate|float|null $arg1 ]
+ Parameter #1 [ <required> MgCoordinate|float|null $arg2 ]
+ Parameter #2 [ <required> float $arg3 ]
+ Parameter #3 [ <required> float $arg4 ]
+ Method [ <internal:MapGuideApi> public method MeasureGreatCircleDistance ] {
+ Method [ <internal:MapGuideApi> public method GetAzimuth ] {
+ Method [ <internal:MapGuideApi> public method GetCoordinate ] {
+ Parameter #1 [ <required> float $arg2 ]
+ Method [ <internal:MapGuideApi> public method GetUnits ] {
+ Method [ <internal:MapGuideApi> public method GetUnitScale ] {
+ Method [ <internal:MapGuideApi> public method GetMinX ] {
+ Method [ <internal:MapGuideApi> public method GetMinY ] {
+ Method [ <internal:MapGuideApi> public method GetMaxX ] {
+ Method [ <internal:MapGuideApi> public method GetMaxY ] {
+ Method [ <internal:MapGuideApi> public method GetCsCode ] {
+ Method [ <internal:MapGuideApi> public method GetProjection ] {
+ Method [ <internal:MapGuideApi> public method GetProjectionDescription ] {
+ Method [ <internal:MapGuideApi> public method GetDatum ] {
+ Method [ <internal:MapGuideApi> public method GetDatumDescription ] {
+ Method [ <internal:MapGuideApi> public method GetEllipsoid ] {
+ Method [ <internal:MapGuideApi> public method GetEllipsoidDescription ] {
+ Method [ <internal:MapGuideApi> public method GetEpsgCode ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetSridCode ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetEpsgQuadrant ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetMeasure ] {
+ Method [ <internal:MapGuideApi> public method GetCategories ] {
+ Method [ <internal:MapGuideApi> public method GetCatalog ] {
+ Method [ <internal:MapGuideApi> public method SetCsCode ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsLegalCsCode ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsValid ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsUsable ] {
+ Parameter #0 [ <required> ?MgCoordinateSystemCatalog $arg1 ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsSameAs ] {
+ Parameter #0 [ <required> ?MgGuardDisposable $arg1 ]
+ - Return [ bool ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsLegalDescription ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetGroup ] {
+ Method [ <internal:MapGuideApi> public method SetGroup ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsLegalGroup ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetSource ] {
+ Method [ <internal:MapGuideApi> public method SetSource ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsLegalSource ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsProtected ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetAge ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetProtectMode ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsEncrypted ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method SetEncryptMode ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetErrors ] {
+ Method [ <internal:MapGuideApi> public method GetLocation ] {
+ Method [ <internal:MapGuideApi> public method SetLocation ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsLegalLocation ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetCountryOrState ] {
+ Method [ <internal:MapGuideApi> public method SetCountryOrState ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsLegalCountryOrState ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsGeodetic ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetProjectionCode ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetProjectionCode ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetUnitCode ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetUnitCode ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetProjectionParameterCount ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetProjectionParameter ] {
+ Method [ <internal:MapGuideApi> public method SetProjectionParameter ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetOriginLongitude ] {
+ Method [ <internal:MapGuideApi> public method SetOriginLongitude ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetOriginLatitude ] {
+ Method [ <internal:MapGuideApi> public method SetOriginLatitude ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetOffsetX ] {
+ Method [ <internal:MapGuideApi> public method GetOffsetY ] {
+ Method [ <internal:MapGuideApi> public method SetOffsets ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetScaleReduction ] {
+ Method [ <internal:MapGuideApi> public method SetScaleReduction ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetMapScale ] {
+ Method [ <internal:MapGuideApi> public method SetMapScale ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetZeroX ] {
+ Method [ <internal:MapGuideApi> public method GetZeroY ] {
+ Method [ <internal:MapGuideApi> public method SetZeroes ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetLonMin ] {
+ Method [ <internal:MapGuideApi> public method GetLonMax ] {
+ Method [ <internal:MapGuideApi> public method GetLatMin ] {
+ Method [ <internal:MapGuideApi> public method GetLatMax ] {
+ Method [ <internal:MapGuideApi> public method SetLonLatBounds ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method CancelLonLatBounds ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetXYBounds ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method CancelXYBounds ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetQuadrant ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetQuadrant ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetDatumDefinition ] {
+ Method [ <internal:MapGuideApi> public method SetDatumDefinition ] {
+ Parameter #0 [ <required> ?MgCoordinateSystemDatum $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetEllipsoidDefinition ] {
+ Method [ <internal:MapGuideApi> public method SetEllipsoidDefinition ] {
+ Parameter #0 [ <required> ?MgCoordinateSystemEllipsoid $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsValidXY ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsValidLonLat ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method ConvertCoordinateFromLonLat ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method ConvertCoordinateToLonLat ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method ConvertToLonLat ] {
+ Method [ <internal:MapGuideApi> public method ConvertFromLonLat ] {
+ Method [ <internal:MapGuideApi> public method GetConvergence ] {
+ Method [ <internal:MapGuideApi> public method GetScale ] {
+ Method [ <internal:MapGuideApi> public method GetScaleH ] {
+ Method [ <internal:MapGuideApi> public method GetScaleK ] {
+ Method [ <internal:MapGuideApi> public method CreateClone ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemCatalog extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [25] {
+ Method [ <internal:MapGuideApi> public method SetDefaultDictionaryDirAndFileNames ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetDefaultDictionaryDir ] {
+ Method [ <internal:MapGuideApi> public method SetDictionaryDir ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetDictionaryDir ] {
+ Method [ <internal:MapGuideApi> public method GetDefaultUserDictionaryDir ] {
+ Method [ <internal:MapGuideApi> public method SetUserDictionaryDir ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetUserDictionaryDir ] {
+ Method [ <internal:MapGuideApi> public method SetProtectionMode ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetProtectionMode ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetCategoryDictionary ] {
+ Method [ <internal:MapGuideApi> public method GetCoordinateSystemDictionary ] {
+ Method [ <internal:MapGuideApi> public method GetDatumDictionary ] {
+ Method [ <internal:MapGuideApi> public method GetEllipsoidDictionary ] {
+ Method [ <internal:MapGuideApi> public method GetGeodeticPathDictionary ] {
+ Method [ <internal:MapGuideApi> public method GetGeodeticTransformDefDictionary ] {
+ Method [ <internal:MapGuideApi> public method GetGeodeticTransformations ] {
+ Parameter #1 [ <required> ?MgCoordinateSystemDatum $arg2 ]
+ Method [ <internal:MapGuideApi> public method GetMathComparator ] {
+ Method [ <internal:MapGuideApi> public method GetFormatConverter ] {
+ Method [ <internal:MapGuideApi> public method GetProjectionInformation ] {
+ Method [ <internal:MapGuideApi> public method GetUnitInformation ] {
+ Method [ <internal:MapGuideApi> public method GetDictionaryUtility ] {
+ Method [ <internal:MapGuideApi> public method AreDictionaryFilesWritable ] {
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemCategory extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [18] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsLegalName ] {
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetSize ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetEnum ] {
+ Method [ <internal:MapGuideApi> public method AddCoordinateSystem ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method RemoveCoordinateSystem ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method HasCoordinateSystem ] {
+ - Return [ bool ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetCoordinateSystems ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemCategoryDictionary extends MgCoordinateSystemDictionaryBase implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [18] {
+ Method [ <internal:MapGuideApi> public method NewCategory ] {
+ Method [ <internal:MapGuideApi> public method Rename ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetCategory ] {
+ Method [ <internal:MapGuideApi, overwrites MgCoordinateSystemDictionaryBase, prototype MgObject> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgCoordinateSystemDictionaryBase, prototype MgObject> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgCoordinateSystemDictionaryBase, prototype MgObject> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemDictionaryBase> public method GetCatalog ] {
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemDictionaryBase> public method GetDefaultFileName ] {
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemDictionaryBase> public method GetFileName ] {
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemDictionaryBase> public method SetFileName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemDictionaryBase> public method GetPath ] {
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemDictionaryBase> public method GetSize ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemDictionaryBase> public method Add ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemDictionaryBase> public method Remove ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemDictionaryBase> public method Modify ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemDictionaryBase> public method Get ] {
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemDictionaryBase> public method Has ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemDictionaryBase> public method GetEnum ] {
+Class [ <internal:MapGuideApi> class MgCoordinateSystemCodeFormat implements SWIG\wrapped ] {
+ - Constants [2] {
+ Constant [ public int Mentor ] { 0 }
+ Constant [ public int Epsg ] { 1 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemDatum extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [38] {
+ Method [ <internal:MapGuideApi> public method GetDtCode ] {
+ Method [ <internal:MapGuideApi> public method SetDtCode ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsLegalDtCode ] {
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetEpsgCode ] {
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method SetEllipsoid ] {
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemDatumDictionary extends MgCoordinateSystemDictionaryBase implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [17] {
+ Method [ <internal:MapGuideApi> public method NewDatum ] {
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemDictionary extends MgCoordinateSystemDictionaryBase implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [17] {
+ Method [ <internal:MapGuideApi> public method NewCoordinateSystem ] {
+ Method [ <internal:MapGuideApi> public method GetCoordinateSystem ] {
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemDictionaryBase extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [15] {
+ Method [ <internal:MapGuideApi> public method GetDefaultFileName ] {
+ Method [ <internal:MapGuideApi> public method GetFileName ] {
+ Method [ <internal:MapGuideApi> public method SetFileName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetPath ] {
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Modify ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Get ] {
+ Method [ <internal:MapGuideApi> public method Has ] {
+ - Return [ bool ]
+ - Return [ void ]
+ - Parameters [1] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemDictionaryUtility extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Static properties [0] {
+ - Methods [8] {
+ Method [ <internal:MapGuideApi> public method CreateEllipsoidDictionary ] {
+ Parameter #0 [ <required> $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method CreateDatumDictionary ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method CreateCoordsysDictionary ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method CreateCategoryDictionary ] {
+ - Return [ void ]
+ - Parameters [2] {
+ Parameter #0 [ <required> string $arg1 ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemEllipsoid extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Static methods [0] {
+ - Properties [0] {
+ - Methods [45] {
+ Method [ <internal:MapGuideApi> public method GetElCode ] {
+ - Parameters [0] {
+ Method [ <internal:MapGuideApi> public method SetElCode ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsLegalElCode ] {
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetEquatorialRadius ] {
+ Method [ <internal:MapGuideApi> public method GetPolarRadius ] {
+ Method [ <internal:MapGuideApi> public method GetFlatteningRatio ] {
+ Method [ <internal:MapGuideApi> public method GetEccentricity ] {
+ Method [ <internal:MapGuideApi> public method SetRadii ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method FlatteningRatioToEccentricity ] {
+ Method [ <internal:MapGuideApi> public method EccentricityToFlatteningRatio ] {
+ Method [ <internal:MapGuideApi> public method EquatorialRadiusFromPolarRadiusFlatteningRatio ] {
+ Method [ <internal:MapGuideApi> public method PolarRadiusFromEquatorialRadiusFlatteningRatio ] {
+ Method [ <internal:MapGuideApi> public method GetGreatCircleDistance ] {
+ Method [ <internal:MapGuideApi> public method GetGreatCircleAzimuth ] {
+ Method [ <internal:MapGuideApi> public method GetRadiusMin ] {
+ Method [ <internal:MapGuideApi> public method GetRadiusMax ] {
+ Method [ <internal:MapGuideApi> public method IsLegalRadius ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetFlatteningRatioMin ] {
+ Method [ <internal:MapGuideApi> public method GetFlatteningRatioMax ] {
+ Method [ <internal:MapGuideApi> public method IsLegalFlatteningRatio ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method FlatteningRatioFromRadii ] {
+ Method [ <internal:MapGuideApi, overwrites MgGuardDisposable, prototype MgObject> public method __set ] {
+ Parameter #1 [ <optional> $arg2 = <default> ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgGuardDisposable, prototype MgObject> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgGuardDisposable, prototype MgObject> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemEllipsoidDictionary extends MgCoordinateSystemDictionaryBase implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [17] {
+ Method [ <internal:MapGuideApi> public method NewEllipsoid ] {
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemEnum extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [10] {
+ Method [ <internal:MapGuideApi> public method Next ] {
+ Method [ <internal:MapGuideApi> public method Skip ] {
+ - Return [ void ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method AddFilter ] {
+ Parameter #0 [ <required> ?MgCoordinateSystemFilter $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method NextName ] {
+ Method [ <internal:MapGuideApi> public method NextDescription ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemEnumInteger32 extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [8] {
+ - Return [ void ]
+ - Return [ void ]
+ Parameter #0 [ <required> ?MgCoordinateSystemFilterInteger32 $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemErrorCode implements SWIG\wrapped ] {
+ - Constants [63] {
+ Constant [ public int AZM ] { 201 }
+ Constant [ public int AZMTH ] { 202 }
+ Constant [ public int LAT ] { 203 }
+ Constant [ public int LATEQU ] { 204 }
+ Constant [ public int LNG ] { 205 }
+ Constant [ public int LNGEQU ] { 206 }
+ Constant [ public int MAPSCL ] { 207 }
+ Constant [ public int MEREQU ] { 208 }
+ Constant [ public int MRCAT ] { 209 }
+ Constant [ public int MSCOEF ] { 210 }
+ Constant [ public int NOREF ] { 211 }
+ Constant [ public int NOTNRTH ] { 212 }
+ Constant [ public int NRTHLAT ] { 213 }
+ Constant [ public int NRTHPNT ] { 214 }
+ Constant [ public int ORGLAT ] { 215 }
+ Constant [ public int ORGLNG ] { 216 }
+ Constant [ public int PLL90 ] { 217 }
+ Constant [ public int PLLEQU ] { 218 }
+ Constant [ public int PLLLRG ] { 219 }
+ Constant [ public int PLLREV ] { 220 }
+ Constant [ public int PLLZERO ] { 221 }
+ Constant [ public int POLDD ] { 222 }
+ Constant [ public int POLDUP ] { 223 }
+ Constant [ public int POLLAT ] { 224 }
+ Constant [ public int POLLNG ] { 225 }
+ Constant [ public int QUAD ] { 226 }
+ Constant [ public int SCLRED ] { 227 }
+ Constant [ public int SOTHLAT ] { 228 }
+ Constant [ public int STDLAT ] { 229 }
+ Constant [ public int STDLNG ] { 230 }
+ Constant [ public int STDPLL ] { 231 }
+ Constant [ public int STDSOU ] { 232 }
+ Constant [ public int STDWEST ] { 233 }
+ Constant [ public int UNIT ] { 234 }
+ Constant [ public int INVPRJ ] { 235 }
+ Constant [ public int INVDTM ] { 236 }
+ Constant [ public int INVELP ] { 237 }
+ Constant [ public int LLRNG ] { 238 }
+ Constant [ public int RNGORD ] { 239 }
+ Constant [ public int INVQUAD ] { 240 }
+ Constant [ public int GEOMM ] { 241 }
+ Constant [ public int CRTMM ] { 242 }
+ Constant [ public int PLLED ] { 243 }
+ Constant [ public int PLRLAT ] { 244 }
+ Constant [ public int USEPLR ] { 245 }
+ Constant [ public int UTMZON ] { 246 }
+ Constant [ public int HMISPHR ] { 247 }
+ Constant [ public int USESW ] { 248 }
+ Constant [ public int MAX15 ] { 249 }
+ Constant [ public int OBLQPOLE ] { 250 }
+ Constant [ public int AFFZERO ] { 251 }
+ Constant [ public int NRDATUM ] { 252 }
+ Constant [ public int OSTN97 ] { 253 }
+ Constant [ public int DENRGN ] { 253 }
+ Constant [ public int ELEVEL ] { 254 }
+ Constant [ public int OSTN02 ] { 255 }
+ Constant [ public int TMKRG0 ] { 256 }
+ Constant [ public int Ok ] { 1000 }
+ Constant [ public int OutOfMemory ] { 1001 }
+ Constant [ public int InitializationFailed ] { 1002 }
+ Constant [ public int ConversionFailed ] { 1003 }
+ Constant [ public int NullArgument ] { 1004 }
+ Constant [ public int InvalidArgument ] { 1005 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemFactory extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [23] {
+ Method [ <internal:MapGuideApi, ctor> public method __construct ] {
+ Method [ <internal:MapGuideApi> public method Create ] {
+ Method [ <internal:MapGuideApi> public method GetTransform ] {
+ Parameter #0 [ <required> ?MgCoordinateSystem $arg1 ]
+ Parameter #1 [ <required> ?MgCoordinateSystem $arg2 ]
+ Method [ <internal:MapGuideApi> public method CreateFromCode ] {
+ Method [ <internal:MapGuideApi> public method ConvertWktToCoordinateSystemCode ] {
+ Method [ <internal:MapGuideApi> public method ConvertCoordinateSystemCodeToWkt ] {
+ Method [ <internal:MapGuideApi> public method EnumerateCategories ] {
+ Method [ <internal:MapGuideApi> public method EnumerateCoordinateSystems ] {
+ Method [ <internal:MapGuideApi> public method ConvertEpsgCodeToWkt ] {
+ Parameter #0 [ <required> int $arg1 ]
+ Method [ <internal:MapGuideApi> public method ConvertWktToEpsgCode ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetBaseLibrary ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GridBoundary ] {
+ Parameter #0 [ <required> MgCoordinate|MgPolygon|null $arg1 ]
+ Parameter #1 [ <optional> ?MgCoordinate $arg2 = <default> ]
+ Method [ <internal:MapGuideApi> public method GridSpecification ] {
+ Parameter #0 [ <required> int|float $arg1 ]
+ Parameter #1 [ <required> int|float $arg2 ]
+ Parameter #2 [ <optional> int $arg3 = <default> ]
+ Parameter #3 [ <optional> float $arg4 = <default> ]
+ Method [ <internal:MapGuideApi> public method GenericGrid ] {
+ - Parameters [3] {
+ Parameter #2 [ <required> bool $arg3 ]
+ Method [ <internal:MapGuideApi> public method GetMgrs ] {
+ Parameter #0 [ <required> float $arg1 ]
+ Parameter #2 [ <required> int $arg3 ]
+ Parameter #3 [ <required> bool $arg4 ]
+ Method [ <internal:MapGuideApi> public method GetMgrsEllipsoid ] {
+ Method [ <internal:MapGuideApi> public method GetMgrsDatum ] {
+ Method [ <internal:MapGuideApi> public method MgrsGrid ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemFilter extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [4] {
+ Method [ <internal:MapGuideApi> public method IsFilteredOut ] {
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemFilterInteger32 extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [4] {
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemFormatConverter extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [11] {
+ Method [ <internal:MapGuideApi> public method DefinitionToWkt ] {
+ Parameter #1 [ <required> int $arg2 ]
+ Method [ <internal:MapGuideApi> public method WktToDefinition ] {
+ Method [ <internal:MapGuideApi> public method CodeToWkt ] {
+ Method [ <internal:MapGuideApi> public method WktToCode ] {
+ Parameter #1 [ <required> $arg2 ]
+ Method [ <internal:MapGuideApi> public method DefinitionToCode ] {
+ Method [ <internal:MapGuideApi> public method CodeToDefinition ] {
+ Method [ <internal:MapGuideApi> public method CodeToCode ] {
+ Method [ <internal:MapGuideApi> public method IsCodeInDictionary ] {
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGeodeticAnalyticalTransformDefParams extends MgCoordinateSystemGeodeticTransformDefParams implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [27] {
+ Method [ <internal:MapGuideApi> public method GetDeltaX ] {
+ - Return [ float ]
+ Method [ <internal:MapGuideApi> public method SetDeltaX ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetDeltaY ] {
+ Method [ <internal:MapGuideApi> public method SetDeltaY ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetDeltaZ ] {
+ Method [ <internal:MapGuideApi> public method SetDeltaZ ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetRotateX ] {
+ Method [ <internal:MapGuideApi> public method SetRotateX ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetRotateY ] {
+ Method [ <internal:MapGuideApi> public method SetRotateY ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetRotateZ ] {
+ Method [ <internal:MapGuideApi> public method SetRotateZ ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetScale ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetTranslateX ] {
+ Method [ <internal:MapGuideApi> public method SetTranslateX ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetTranslateY ] {
+ Method [ <internal:MapGuideApi> public method SetTranslateY ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetTranslateZ ] {
+ Method [ <internal:MapGuideApi> public method SetTranslateZ ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetTransformationMethod ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetTransformationMethod ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgCoordinateSystemGeodeticTransformDefParams, prototype MgObject> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgCoordinateSystemGeodeticTransformDefParams, prototype MgObject> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgCoordinateSystemGeodeticTransformDefParams, prototype MgObject> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGeodeticTransformDefParams> public method IsValid ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGeodeticTransformDefParams> public method IsProtected ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGeodeticAnalyticalTransformationMethod implements SWIG\wrapped ] {
+ - Constants [11] {
+ Constant [ public int None ] { 0 }
+ Constant [ public int ThreeParameter ] { 8193 }
+ Constant [ public int Molodensky ] { 8194 }
+ Constant [ public int AbridgedMolodensky ] { 8195 }
+ Constant [ public int Geocentric ] { 8196 }
+ Constant [ public int FourParameter ] { 8197 }
+ Constant [ public int SixParameter ] { 8198 }
+ Constant [ public int Bursa ] { 8199 }
+ Constant [ public int Frame ] { 8200 }
+ Constant [ public int SevenParameter ] { 8201 }
+ Constant [ public int MolodenskyBadekas ] { 8202 }
+ - Methods [3] {
+ Method [ <internal:MapGuideApi> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method __get ] {
+ Method [ <internal:MapGuideApi> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGeodeticInterpolationTransformDefParams extends MgCoordinateSystemGeodeticTransformDefParams implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [10] {
+ Method [ <internal:MapGuideApi> public method SetGridFiles ] {
+ Parameter #0 [ <required> ?MgDisposableCollection $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetGridFiles ] {
+ Method [ <internal:MapGuideApi> public method GetFallback ] {
+ Method [ <internal:MapGuideApi> public method SetFallback ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method NewGridFile ] {
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGeodeticMultipleRegressionTransformDefParams extends MgCoordinateSystemGeodeticTransformDefParams implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [31] {
+ Method [ <internal:MapGuideApi> public method GetValidation ] {
+ Method [ <internal:MapGuideApi> public method SetValidation ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetTestPhi ] {
+ Method [ <internal:MapGuideApi> public method SetTestPhi ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetTestLambda ] {
+ Method [ <internal:MapGuideApi> public method SetTestLambda ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetDeltaPhi ] {
+ Method [ <internal:MapGuideApi> public method SetDeltaPhi ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetDeltaLambda ] {
+ Method [ <internal:MapGuideApi> public method SetDeltaLambda ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetDeltaHeight ] {
+ Method [ <internal:MapGuideApi> public method SetDeltaHeight ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetPhiOffset ] {
+ Method [ <internal:MapGuideApi> public method SetPhiOffset ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetLambdaOffset ] {
+ Method [ <internal:MapGuideApi> public method SetLambdaOffset ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetNormalizationScale ] {
+ Method [ <internal:MapGuideApi> public method SetNormalizationScale ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetCoefficientPhi ] {
+ Method [ <internal:MapGuideApi> public method SetCoefficientPhi ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetCoefficientLambda ] {
+ Method [ <internal:MapGuideApi> public method SetCoefficientLambda ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetCoefficientHeight ] {
+ Method [ <internal:MapGuideApi> public method SetCoefficientHeight ] {
+ - Return [ void ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGeodeticMultipleRegressionTransformationMethod implements SWIG\wrapped ] {
+ - Constants [3] {
+ Constant [ public int MultipleRegression ] { 20481 }
+ Constant [ public int GeneralPolynomialEpsg ] { 20482 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGeodeticPath extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [29] {
+ Method [ <internal:MapGuideApi> public method GetPathName ] {
+ Method [ <internal:MapGuideApi> public method SetPathName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetDescription ] {
+ Method [ <internal:MapGuideApi> public method SetDescription ] {
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetTargetDatum ] {
+ Method [ <internal:MapGuideApi> public method SetTargetDatum ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetSourceDatum ] {
+ Method [ <internal:MapGuideApi> public method SetSourceDatum ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetAccuracy ] {
+ Method [ <internal:MapGuideApi> public method SetAccuracy ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetIsReversible ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method SetIsReversible ] {
+ Parameter #0 [ <required> bool $arg1 ]
+ - Return [ void ]
+ - Return [ int ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetEpsgVariant ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetEpsgVariant ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetPathElements ] {
+ Method [ <internal:MapGuideApi> public method SetPathElements ] {
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method NewPathElement ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGeodeticPathDictionary extends MgCoordinateSystemDictionaryBase implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [17] {
+ Method [ <internal:MapGuideApi> public method NewGeodeticPath ] {
+ Method [ <internal:MapGuideApi> public method GetGeodeticPath ] {
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGeodeticPathElement extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [9] {
+ Method [ <internal:MapGuideApi> public method GetTransformName ] {
+ Method [ <internal:MapGuideApi> public method SetTransformName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetIsInversed ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method SetIsInversed ] {
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGeodeticStandaloneTransformDefParams extends MgCoordinateSystemGeodeticTransformDefParams implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [7] {
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGeodeticTransformDef extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [44] {
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ int ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetEpsgVariation ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetEpsgVariation ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetInverseSupported ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method SetInverseSupported ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetMaxIterations ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetMaxIterations ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetConvergenceValue ] {
+ Method [ <internal:MapGuideApi> public method SetConvergenceValue ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetErrorValue ] {
+ Method [ <internal:MapGuideApi> public method SetErrorValue ] {
+ - Return [ void ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetRangeMinLongitude ] {
+ Method [ <internal:MapGuideApi> public method SetRangeMinLongitude ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetRangeMaxLongitude ] {
+ Method [ <internal:MapGuideApi> public method SetRangeMaxLongitude ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetRangeMinLatitude ] {
+ Method [ <internal:MapGuideApi> public method SetRangeMinLatitude ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetRangeMaxLatitude ] {
+ Method [ <internal:MapGuideApi> public method SetRangeMaxLatitude ] {
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetTransformDefType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetParameters ] {
+ Method [ <internal:MapGuideApi> public method SetParameters ] {
+ Parameter #0 [ <required> ?MgCoordinateSystemGeodeticTransformDefParams $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method CreateTransformation ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGeodeticTransformDefDictionary extends MgCoordinateSystemDictionaryBase implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [17] {
+ Method [ <internal:MapGuideApi> public method NewGeodeticTransformationDef ] {
+ Method [ <internal:MapGuideApi> public method GetGeodeticTransformationDef ] {
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGeodeticTransformDefParams extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [5] {
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGeodeticTransformDefType implements SWIG\wrapped ] {
+ - Constants [5] {
+ Constant [ public int Standalone ] { 1 }
+ Constant [ public int Analytical ] { 2 }
+ Constant [ public int Interpolation ] { 3 }
+ Constant [ public int MultipleRegression ] { 4 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGeodeticTransformGridFile extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [11] {
+ Method [ <internal:MapGuideApi> public method GetFileFormat ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetFileFormat ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetIsInverseDirection ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method SetIsInverseDirection ] {
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGeodeticTransformGridFileFormat implements SWIG\wrapped ] {
+ Constant [ public int NTv1 ] { 1 }
+ Constant [ public int NTv2 ] { 2 }
+ Constant [ public int NADCON ] { 3 }
+ Constant [ public int RGF ] { 4 }
+ Constant [ public int PAR ] { 5 }
+ Constant [ public int ATS77 ] { 6 }
+ Constant [ public int OST97 ] { 7 }
+ Constant [ public int OST02 ] { 8 }
+ Constant [ public int OST15 ] { 9 }
+ Constant [ public int GEOCON ] { 10 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGeodeticTransformation extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [25] {
+ Method [ <internal:MapGuideApi> public method SetSourceAndTarget ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetTarget ] {
+ Method [ <internal:MapGuideApi> public method Shift ] {
+ Method [ <internal:MapGuideApi> public method GetOffsetZ ] {
+ Method [ <internal:MapGuideApi> public method SetOffset ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetBursaWolfeTransformRotationX ] {
+ Method [ <internal:MapGuideApi> public method GetBursaWolfeTransformRotationY ] {
+ Method [ <internal:MapGuideApi> public method GetBursaWolfeTransformRotationZ ] {
+ Method [ <internal:MapGuideApi> public method GetBursaWolfeTransformBwScale ] {
+ Method [ <internal:MapGuideApi> public method SetBursaWolfeTransform ] {
+ - Parameters [4] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetGeodeticTransformationMethod ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetGeodeticTransformationMethod ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetMaxOffset ] {
+ Method [ <internal:MapGuideApi> public method IsLegalOffset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetMaxRotation ] {
+ Method [ <internal:MapGuideApi> public method IsLegalRotation ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetBwScaleMin ] {
+ Method [ <internal:MapGuideApi> public method GetBwScaleMax ] {
+ Method [ <internal:MapGuideApi> public method IsLegalBwScale ] {
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGeodeticTransformationMethod implements SWIG\wrapped ] {
+ - Constants [28] {
+ Constant [ public int Molodensky ] { 1 }
+ Constant [ public int MReg ] { 2 }
+ Constant [ public int Bursa ] { 3 }
+ Constant [ public int NAD27 ] { 4 }
+ Constant [ public int NAD83 ] { 5 }
+ Constant [ public int WGS84 ] { 6 }
+ Constant [ public int WGS72 ] { 7 }
+ Constant [ public int HPGN ] { 8 }
+ Constant [ public int SevenParameter ] { 9 }
+ Constant [ public int AGD66 ] { 10 }
+ Constant [ public int ThreeParameter ] { 11 }
+ Constant [ public int SixParameter ] { 12 }
+ Constant [ public int FourParameter ] { 13 }
+ Constant [ public int AGD84 ] { 14 }
+ Constant [ public int NZGD49 ] { 15 }
+ Constant [ public int ATS77 ] { 16 }
+ Constant [ public int GDA94 ] { 17 }
+ Constant [ public int NZGD2K ] { 18 }
+ Constant [ public int CSRS ] { 19 }
+ Constant [ public int TOKYO ] { 20 }
+ Constant [ public int RGF93 ] { 21 }
+ Constant [ public int ED50 ] { 22 }
+ Constant [ public int DHDN ] { 23 }
+ Constant [ public int ETRF89 ] { 24 }
+ Constant [ public int Lclgrf ] { 99 }
+ Constant [ public int Geocentric ] { 25 }
+ Constant [ public int CHENYX ] { 26 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGridBase extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [21] {
+ Method [ <internal:MapGuideApi> public method GetSpecializationType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetBoundary ] {
+ Parameter #0 [ <required> ?MgCoordinateSystemGridBoundary $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetBoundary ] {
+ Method [ <internal:MapGuideApi> public method GetGridLines ] {
+ Parameter #0 [ <required> ?MgCoordinateSystemGridSpecification $arg1 ]
+ Method [ <internal:MapGuideApi> public method GetGridRegions ] {
+ Method [ <internal:MapGuideApi> public method GetGridTicks ] {
+ Method [ <internal:MapGuideApi> public method GetConvergenceAngle ] {
+ Method [ <internal:MapGuideApi> public method GetProjectiveGridScale ] {
+ Method [ <internal:MapGuideApi> public method ApproxGridLineMemoryUsage ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method ApproxGridRegionMemoryUsage ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method ApproxGridTickMemoryUsage ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetGridLineExceptionLevel ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetGridRegionExceptionLevel ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetGridTickExceptionLevel ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetLastError ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method ResetLastError ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method AreExceptionsOn ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method SetExceptionsOn ] {
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGridBoundary extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [5] {
+ Method [ <internal:MapGuideApi> public method SetBoundaryExtents ] {
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGridLine extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [9] {
+ Method [ <internal:MapGuideApi> public method GetGridOrientation ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetRealValue ] {
+ Method [ <internal:MapGuideApi> public method GetCount ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetSegment ] {
+ Method [ <internal:MapGuideApi> public method GetSegmentCollection ] {
+ Method [ <internal:MapGuideApi> public method SetSegmentCollection ] {
+ Parameter #0 [ <required> ?MgLineStringCollection $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGridLineCollection extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [8] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetItem ] {
+ Method [ <internal:MapGuideApi> public method IndexOf ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method RemoveAt ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Clear ] {
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGridOrientation implements SWIG\wrapped ] {
+ - Constants [4] {
+ Constant [ public int EastWest ] { 1 }
+ Constant [ public int NorthSouth ] { 2 }
+ Constant [ public int Unknown ] { 3 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGridRegion extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [10] {
+ Method [ <internal:MapGuideApi> public method GetLabel ] {
+ Method [ <internal:MapGuideApi> public method GetRegionCenter ] {
+ Method [ <internal:MapGuideApi> public method GetRegionBoundary ] {
+ Method [ <internal:MapGuideApi> public method GetSouthLine ] {
+ Method [ <internal:MapGuideApi> public method GetEastLine ] {
+ Method [ <internal:MapGuideApi> public method GetNorthLine ] {
+ Method [ <internal:MapGuideApi> public method GetWestLine ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGridRegionCollection extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [7] {
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGridSpecializationType implements SWIG\wrapped ] {
+ - Constants [5] {
+ Constant [ public int Generic ] { 1 }
+ Constant [ public int MGRS ] { 17 }
+ Constant [ public int USNG ] { 18 }
+ Constant [ public int Unknown ] { 65366 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGridSpecification extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [20] {
+ Method [ <internal:MapGuideApi> public method GetEastingBase ] {
+ Method [ <internal:MapGuideApi> public method GetNorthingBase ] {
+ Method [ <internal:MapGuideApi> public method GetEastingIncrement ] {
+ Method [ <internal:MapGuideApi> public method GetNorthingIncrement ] {
+ Method [ <internal:MapGuideApi> public method GetTickEastingIncrement ] {
+ Method [ <internal:MapGuideApi> public method GetTickNorthingIncrement ] {
+ Method [ <internal:MapGuideApi> public method GetUnitType ] {
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetCurvePrecision ] {
+ Method [ <internal:MapGuideApi> public method SetGridBase ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetGridIncrement ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetTickIncrements ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetUnits ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetCurvePrecision ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetMaxCurvePoints ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsConsistent ] {
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGridTick extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [8] {
+ Method [ <internal:MapGuideApi> public method GetIsOnGridLine ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetTickOrientation ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetValue ] {
+ Method [ <internal:MapGuideApi> public method GetPosition ] {
+ Method [ <internal:MapGuideApi> public method GetDirectionVector ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemGridTickCollection extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [7] {
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemMathComparator extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [9] {
+ Method [ <internal:MapGuideApi> public method Same ] {
+ Parameter #1 [ <required> ?MgGuardDisposable $arg2 ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method SameEllipsoid ] {
+ Parameter #1 [ <required> ?MgCoordinateSystemEllipsoid $arg2 ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method SameDatum ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method SameCoordinateSystem ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method SetCompareInternalDatumOldParameters ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetCompareInternalDatumOldParameters ] {
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemMeasure extends MgMeasure implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [10] {
+ Method [ <internal:MapGuideApi, overwrites MgMeasure, prototype MgMeasure> public method GetDistance ] {
+ Method [ <internal:MapGuideApi> public method GetDistanceSimple ] {
+ Method [ <internal:MapGuideApi, overwrites MgMeasure, prototype MgMeasure> public method GetAzimuth ] {
+ Method [ <internal:MapGuideApi> public method GetAzimuthSimple ] {
+ Method [ <internal:MapGuideApi, overwrites MgMeasure, prototype MgMeasure> public method GetCoordinate ] {
+ Method [ <internal:MapGuideApi> public method GetCoordinateSimple ] {
+ Method [ <internal:MapGuideApi> public method GetEnvelope ] {
+ Method [ <internal:MapGuideApi, overwrites MgMeasure, prototype MgObject> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgMeasure, prototype MgObject> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgMeasure, prototype MgObject> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemMgrs extends MgCoordinateSystemGridBase implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [24] {
+ Method [ <internal:MapGuideApi> public method GetLetteringScheme ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgCoordinateSystemGridBase, prototype MgObject> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgCoordinateSystemGridBase, prototype MgObject> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgCoordinateSystemGridBase, prototype MgObject> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method GetSpecializationType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method SetBoundary ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method GetBoundary ] {
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method GetGridLines ] {
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method GetGridRegions ] {
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method GetGridTicks ] {
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method GetConvergenceAngle ] {
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method GetProjectiveGridScale ] {
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method ApproxGridLineMemoryUsage ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method ApproxGridRegionMemoryUsage ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method ApproxGridTickMemoryUsage ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method SetGridLineExceptionLevel ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method SetGridRegionExceptionLevel ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method SetGridTickExceptionLevel ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method GetLastError ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method ResetLastError ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method AreExceptionsOn ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgCoordinateSystemGridBase> public method SetExceptionsOn ] {
+ - Return [ void ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemMgrsGridLevel implements SWIG\wrapped ] {
+ - Constants [10] {
+ Constant [ public int MgrsNone ] { 0 }
+ Constant [ public int MgrsUtm ] { 1 }
+ Constant [ public int MgrsUps ] { 2 }
+ Constant [ public int Mgrs100Km ] { 3 }
+ Constant [ public int Mgrs10Km ] { 4 }
+ Constant [ public int Mgrs1Km ] { 5 }
+ Constant [ public int Mgrs100m ] { 6 }
+ Constant [ public int Mgrs10m ] { 7 }
+ Constant [ public int Mgrs1m ] { 8 }
+ Constant [ public int MgrsUnknown ] { 99 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemMgrsGridSquarePosition implements SWIG\wrapped ] {
+ Constant [ public int Center ] { 1 }
+ Constant [ public int SouthWest ] { 2 }
+ Constant [ public int West ] { 3 }
+ Constant [ public int NorthWest ] { 4 }
+ Constant [ public int North ] { 5 }
+ Constant [ public int NorthEast ] { 6 }
+ Constant [ public int East ] { 7 }
+ Constant [ public int SouthEast ] { 8 }
+ Constant [ public int South ] { 9 }
+ Constant [ public int Unknown ] { 10 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemMgrsLetteringScheme implements SWIG\wrapped ] {
+ - Constants [2] {
+ Constant [ public int Normal ] { 0 }
+ Constant [ public int Alternative ] { 1 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemProjectionCode implements SWIG\wrapped ] {
+ - Constants [73] {
+ Constant [ public int Alber ] { 4 }
+ Constant [ public int Azede ] { 59 }
+ Constant [ public int Azmea ] { 11 }
+ Constant [ public int Azmed ] { 7 }
+ Constant [ public int Bipolar ] { 31 }
+ Constant [ public int Bonne ] { 24 }
+ Constant [ public int Cassini ] { 22 }
+ Constant [ public int Eckert4 ] { 25 }
+ Constant [ public int Eckert6 ] { 26 }
+ Constant [ public int Edcnc ] { 12 }
+ Constant [ public int Edcyl ] { 20 }
+ Constant [ public int GaussK ] { 46 }
+ Constant [ public int Gnomonic ] { 19 }
+ Constant [ public int Goode ] { 28 }
+ Constant [ public int Hom1uv ] { 1281 }
+ Constant [ public int Hom1xy ] { 1282 }
+ Constant [ public int Hom2uv ] { 1283 }
+ Constant [ public int Hom2xy ] { 1284 }
+ Constant [ public int Krovak ] { 47 }
+ Constant [ public int Krvk95 ] { 51 }
+ Constant [ public int LL ] { 1 }
+ Constant [ public int Lm1sp ] { 36 }
+ Constant [ public int Lm2sp ] { 37 }
+ Constant [ public int Lmblg ] { 38 }
+ Constant [ public int Lmtan ] { 8 }
+ Constant [ public int Miller ] { 13 }
+ Constant [ public int Mndotl ] { 41 }
+ Constant [ public int Mndott ] { 42 }
+ Constant [ public int Modpc ] { 10 }
+ Constant [ public int Mollweid ] { 27 }
+ Constant [ public int Mrcat ] { 6 }
+ Constant [ public int MrcatK ] { 49 }
+ Constant [ public int Mstero ] { 15 }
+ Constant [ public int Neacyl ] { 29 }
+ Constant [ public int Nerth ] { 55 }
+ Constant [ public int Nzealand ] { 16 }
+ Constant [ public int OblqM ] { 5 }
+ Constant [ public int Obqcyl ] { 56 }
+ Constant [ public int Ortho ] { 18 }
+ Constant [ public int Ostn02 ] { 60 }
+ Constant [ public int Ostn97 ] { 58 }
+ Constant [ public int Ostro ] { 34 }
+ Constant [ public int Plycn ] { 9 }
+ Constant [ public int Pstro ] { 33 }
+ Constant [ public int Pstrosl ] { 53 }
+ Constant [ public int Rskew ] { 1285 }
+ Constant [ public int Rskewc ] { 1286 }
+ Constant [ public int Rskewo ] { 1287 }
+ Constant [ public int Robinson ] { 23 }
+ Constant [ public int Sinus ] { 17 }
+ Constant [ public int Sotrm ] { 43 }
+ Constant [ public int Sstro ] { 35 }
+ Constant [ public int Swiss ] { 32 }
+ Constant [ public int Sys34 ] { 57 }
+ Constant [ public int Sys34_99 ] { 61 }
+ Constant [ public int Teacyl ] { 30 }
+ Constant [ public int Tm ] { 3 }
+ Constant [ public int Trmeraf ] { 54 }
+ Constant [ public int Trmrkrg ] { 62 }
+ Constant [ public int Trmrs ] { 45 }
+ Constant [ public int Vdgrntn ] { 21 }
+ Constant [ public int Wccsl ] { 39 }
+ Constant [ public int Wccst ] { 40 }
+ Constant [ public int Utm ] { 44 }
+ Constant [ public int Winkl ] { 63 }
+ Constant [ public int Nrthsrt ] { 64 }
+ Constant [ public int Lmbrtaf ] { 65 }
+ Constant [ public int Sys34_01 ] { 66 }
+ Constant [ public int EdcylE ] { 67 }
+ Constant [ public int PlateCarree ] { 68 }
+ Constant [ public int PvMercator ] { 69 }
+ Constant [ public int LmMich ] { 70 }
+ Constant [ public int Unknown ] { 0 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemProjectionFormatType implements SWIG\wrapped ] {
+ - Constants [9] {
+ Constant [ public int Lng ] { 57509 }
+ Constant [ public int Lat ] { 41157 }
+ Constant [ public int Angd ] { 32933 }
+ Constant [ public int Coef ] { 13 }
+ Constant [ public int Xxx ] { 4099 }
+ Constant [ public int Yyy ] { 4099 }
+ Constant [ public int Scl ] { 7 }
+ Constant [ public int Rot ] { 4 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemProjectionInformation extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [19] {
+ Method [ <internal:MapGuideApi> public method GetEnumProjections ] {
+ Method [ <internal:MapGuideApi> public method GetParameterCount ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method IsUsingParameter ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsUsingOriginLongitude ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsUsingOriginLatitude ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsUsingScaleReduction ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsUsingQuadrant ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsUsingOffset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetParameterMin ] {
+ Method [ <internal:MapGuideApi> public method GetParameterMax ] {
+ Method [ <internal:MapGuideApi> public method GetParameterDefault ] {
+ Method [ <internal:MapGuideApi> public method GetParameterLogicalType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetParameterFormatType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetParameterType ] {
+ - Return [ int ]
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetTagString ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemProjectionLogicalType implements SWIG\wrapped ] {
+ - Constants [13] {
+ Constant [ public int Longitude ] { 1 }
+ Constant [ public int Latitude ] { 2 }
+ Constant [ public int Azimuth ] { 3 }
+ Constant [ public int AngularDistance ] { 4 }
+ Constant [ public int ComplexCoefficient ] { 5 }
+ Constant [ public int UTMZoneNumber ] { 6 }
+ Constant [ public int HemisphereSelection ] { 7 }
+ Constant [ public int GeoidHeight ] { 8 }
+ Constant [ public int Elevation ] { 9 }
+ Constant [ public int AffineCoefficient ] { 10 }
+ Constant [ public int XYCoordinate ] { 11 }
+ Constant [ public int Scale ] { 12 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemProjectionParameterType implements SWIG\wrapped ] {
+ - Constants [49] {
+ Constant [ public int NotUsed ] { 0 }
+ Constant [ public int Cntmer ] { 1 }
+ Constant [ public int Nstdpll ] { 2 }
+ Constant [ public int Sstdpll ] { 3 }
+ Constant [ public int Stdpll ] { 4 }
+ Constant [ public int Gcp1lng ] { 5 }
+ Constant [ public int Gcp1lat ] { 6 }
+ Constant [ public int Gcp2lng ] { 7 }
+ Constant [ public int Gcp2lat ] { 8 }
+ Constant [ public int Gcplng ] { 9 }
+ Constant [ public int Gcplat ] { 10 }
+ Constant [ public int Gcazm ] { 11 }
+ Constant [ public int Yaxisaz ] { 12 }
+ Constant [ public int Estdmer ] { 13 }
+ Constant [ public int Nparall ] { 14 }
+ Constant [ public int Sparall ] { 15 }
+ Constant [ public int P1lng ] { 16 }
+ Constant [ public int P1lat ] { 17 }
+ Constant [ public int P2lng ] { 18 }
+ Constant [ public int P2lat ] { 19 }
+ Constant [ public int Adp1p2 ] { 20 }
+ Constant [ public int Adsp1 ] { 21 }
+ Constant [ public int Adsp2 ] { 22 }
+ Constant [ public int Cmplxan ] { 23 }
+ Constant [ public int Cmplxbn ] { 24 }
+ Constant [ public int Westll ] { 25 }
+ Constant [ public int Eastll ] { 26 }
+ Constant [ public int Utmzn ] { 27 }
+ Constant [ public int Hsns ] { 28 }
+ Constant [ public int Ghgt ] { 29 }
+ Constant [ public int Aelev ] { 30 }
+ Constant [ public int Polelng ] { 31 }
+ Constant [ public int Polelat ] { 32 }
+ Constant [ public int Ostdpll ] { 33 }
+ Constant [ public int Stdcir ] { 34 }
+ Constant [ public int Afa0 ] { 35 }
+ Constant [ public int Afb0 ] { 36 }
+ Constant [ public int Afa1 ] { 37 }
+ Constant [ public int Afa2 ] { 38 }
+ Constant [ public int Afb1 ] { 39 }
+ Constant [ public int Afb2 ] { 40 }
+ Constant [ public int Nrmlpll ] { 41 }
+ Constant [ public int Denrgn ] { 42 }
+ Constant [ public int Skwazm ] { 43 }
+ Constant [ public int Sclrotorgx ] { 44 }
+ Constant [ public int Sclrotorgy ] { 45 }
+ Constant [ public int Nrthscl ] { 46 }
+ Constant [ public int Nrthrot ] { 47 }
+ Constant [ public int EllipsoidScale ] { 48 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemTransform extends MgTransform implements SWIG\wrapped ] {
+ - Constants [7] {
+ Constant [ public int TransformOutsideDomainWarning ] { 1 }
+ Constant [ public int TransformDatumShiftWarning ] { 2 }
+ Constant [ public int TransformTotalFailure ] { 3 }
+ Constant [ public int SourceCrsError ] { 1 }
+ Constant [ public int DatumShiftFallback ] { 2 }
+ Constant [ public int DatumShiftError ] { 4 }
+ Constant [ public int TargetCrsError ] { 8 }
+ - Static methods [1] {
+ Method [ <internal:MapGuideApi> static public method TransformOk ] {
+ - Return [ int ]
+ - Methods [25] {
+ Method [ <internal:MapGuideApi> public method TransformM ] {
+ Parameter #1 [ <required> float $arg2 ]
+ Parameter #2 [ <required> float $arg3 ]
+ Parameter #3 [ <required> float $arg4 ]
+ Method [ <internal:MapGuideApi, overwrites MgTransform, prototype MgTransform> public method Transform ] {
+ Parameter #0 [ <required> MgCoordinate|MgEnvelope|float|null $arg1 ]
+ Parameter #1 [ <optional> float $arg2 = <default> ]
+ Parameter #2 [ <optional> float $arg3 = <default> ]
+ Method [ <internal:MapGuideApi> public method TransformCoordinate ] {
+ Parameter #0 [ <required> ?MgCoordinate $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GridLine ] {
+ Parameter #1 [ <required> ?MgCoordinate $arg2 ]
+ Parameter #3 [ <required> int $arg4 ]
+ Method [ <internal:MapGuideApi> public method IsValidSourcePoint ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsValidTargetPoint ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetSource ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetGeodeticTransformationCount ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetGeodeticTransformation ] {
+ Method [ <internal:MapGuideApi> public method GetGeodeticTransformationDirection ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetExplicitGeodeticPath ] {
+ Method [ <internal:MapGuideApi> public method IgnoreDatumShiftWarning ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsIgnoreDatumShiftWarning ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IgnoreOutsideDomainWarning ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsIgnoreOutsideDomainWarning ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetSourceWarningCount ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetdatumWarningCount ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetTargetWarningCount ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetLastTransformStatus ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method ResetLastTransformStatus ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgTransform, prototype MgObject> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgTransform, prototype MgObject> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgTransform, prototype MgObject> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemType implements SWIG\wrapped ] {
+ - Constants [4] {
+ Constant [ public int Arbitrary ] { 1 }
+ Constant [ public int Geographic ] { 2 }
+ Constant [ public int Projected ] { 3 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemUnitCode implements SWIG\wrapped ] {
+ - Constants [65] {
+ Constant [ public int Meter ] { 1 }
+ Constant [ public int Foot ] { 2 }
+ Constant [ public int Inch ] { 3 }
+ Constant [ public int IFoot ] { 4 }
+ Constant [ public int ClarkeFoot ] { 5 }
+ Constant [ public int IInch ] { 6 }
+ Constant [ public int Centimeter ] { 7 }
+ Constant [ public int Kilometer ] { 8 }
+ Constant [ public int Yard ] { 9 }
+ Constant [ public int SearsYard ] { 10 }
+ Constant [ public int Mile ] { 11 }
+ Constant [ public int IYard ] { 12 }
+ Constant [ public int IMile ] { 13 }
+ Constant [ public int Knot ] { 14 }
+ Constant [ public int NautM ] { 15 }
+ Constant [ public int Lat66 ] { 16 }
+ Constant [ public int Lat83 ] { 17 }
+ Constant [ public int Decimeter ] { 18 }
+ Constant [ public int Millimeter ] { 19 }
+ Constant [ public int Dekameter ] { 20 }
+ Constant [ public int Hectometer ] { 21 }
+ Constant [ public int GermanMeter ] { 22 }
+ Constant [ public int CaGrid ] { 23 }
+ Constant [ public int ClarkeChain ] { 24 }
+ Constant [ public int GunterChain ] { 25 }
+ Constant [ public int BenoitChain ] { 26 }
+ Constant [ public int SearsChain ] { 27 }
+ Constant [ public int ClarkeLink ] { 28 }
+ Constant [ public int GunterLink ] { 29 }
+ Constant [ public int BenoitLink ] { 30 }
+ Constant [ public int SearsLink ] { 31 }
+ Constant [ public int Rod ] { 32 }
+ Constant [ public int Perch ] { 33 }
+ Constant [ public int Pole ] { 34 }
+ Constant [ public int Furlong ] { 35 }
+ Constant [ public int Rood ] { 36 }
+ Constant [ public int CapeFoot ] { 37 }
+ Constant [ public int Brealey ] { 38 }
+ Constant [ public int SearsFoot ] { 39 }
+ Constant [ public int GoldCoastFoot ] { 40 }
+ Constant [ public int MicroInch ] { 41 }
+ Constant [ public int IndianYard ] { 42 }
+ Constant [ public int IndianFoot ] { 43 }
+ Constant [ public int IndianFt37 ] { 44 }
+ Constant [ public int IndianFt62 ] { 45 }
+ Constant [ public int IndianFt75 ] { 46 }
+ Constant [ public int IndianYd37 ] { 47 }
+ Constant [ public int Decameter ] { 48 }
+ Constant [ public int InternationalChain ] { 49 }
+ Constant [ public int InternationalLink ] { 50 }
+ Constant [ public int BrFootTrunc ] { 51 }
+ Constant [ public int BrChainTrunc ] { 52 }
+ Constant [ public int BrLinkTrunc ] { 53 }
+ Constant [ public int Degree ] { 1001 }
+ Constant [ public int Grad ] { 1002 }
+ Constant [ public int Grade ] { 1003 }
+ Constant [ public int MapInfo ] { 1004 }
+ Constant [ public int Mil ] { 1005 }
+ Constant [ public int Minute ] { 1006 }
+ Constant [ public int Radian ] { 1007 }
+ Constant [ public int Second ] { 1008 }
+ Constant [ public int Decisec ] { 1009 }
+ Constant [ public int Centisec ] { 1010 }
+ Constant [ public int Millisec ] { 1011 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemUnitInformation extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [10] {
+ Method [ <internal:MapGuideApi> public method GetEnumLinearUnits ] {
+ Method [ <internal:MapGuideApi> public method GetEnumAngularUnits ] {
+ Method [ <internal:MapGuideApi> public method GetLinearUnitScale ] {
+ Method [ <internal:MapGuideApi> public method GetAngularUnitScale ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetAbbreviation ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemUnitType implements SWIG\wrapped ] {
+ - Constants [3] {
+ Constant [ public int Linear ] { 1 }
+ Constant [ public int Angular ] { 2 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateSystemWktFlavor implements SWIG\wrapped ] {
+ - Constants [7] {
+ Constant [ public int Unknown ] { -1 }
+ Constant [ public int Ogc ] { 0 }
+ Constant [ public int Oracle ] { 1 }
+ Constant [ public int Esri ] { 2 }
+ Constant [ public int Epsg ] { 3 }
+ Constant [ public int Geotiff ] { 4 }
+ Constant [ public int Geotools ] { 5 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateXY extends MgCoordinate implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Static methods [2] {
+ Method [ <internal:MapGuideApi, inherits MgCoordinate> static public method NoZ ] {
+ Method [ <internal:MapGuideApi, inherits MgCoordinate> static public method NoM ] {
+ - Methods [8] {
+ Method [ <internal:MapGuideApi, overwrites MgCoordinate, prototype MgCoordinate> public method GetDimension ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgCoordinate, prototype MgCoordinate> public method GetX ] {
+ Method [ <internal:MapGuideApi, overwrites MgCoordinate, prototype MgCoordinate> public method GetY ] {
+ Method [ <internal:MapGuideApi, overwrites MgCoordinate, prototype MgCoordinate> public method GetZ ] {
+ Method [ <internal:MapGuideApi, overwrites MgCoordinate, prototype MgCoordinate> public method GetM ] {
+ Method [ <internal:MapGuideApi, overwrites MgCoordinate, prototype MgCoordinate> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgCoordinate, prototype MgCoordinate> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgCoordinate, prototype MgCoordinate> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateXYM extends MgCoordinate implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [8] {
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateXYZ extends MgCoordinate implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [8] {
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCoordinateXYZM extends MgCoordinate implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [8] {
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCurve extends MgGeometry implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [35] {
+ Method [ <internal:MapGuideApi> public method GetStartCoordinate ] {
+ Method [ <internal:MapGuideApi> public method GetEndCoordinate ] {
+ Method [ <internal:MapGuideApi, overwrites MgGeometry, prototype MgGeometricEntity> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgGeometry, prototype MgGeometricEntity> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgGeometry, prototype MgGeometricEntity> public method __isset ] {
+ - Parameters [1] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method GetGeometryType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Contains ] {
+ Parameter #0 [ <required> ?MgGeometry $arg1 ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Crosses ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Disjoint ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Equals ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Intersects ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Overlaps ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Touches ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Within ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Boundary ] {
+ - Parameters [0] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Buffer ] {
+ - Parameters [2] {
+ Parameter #1 [ <required> ?MgMeasure $arg2 ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method ConvexHull ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Difference ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Distance ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Intersection ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method SymetricDifference ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Union ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Prepare ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Tessellate ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method GetDimension ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method IsEmpty ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method IsSimple ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method IsClosed ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method IsValid ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method Envelope ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method Copy ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method Transform ] {
+ Parameter #0 [ <required> ?MgTransform $arg1 ]
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method GetArea ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method GetLength ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method GetCentroid ] {
+Class [ <internal:MapGuideApi> class MgCurvePolygon extends MgRegion implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Static properties [0] {
+ - Static methods [0] {
+ - Properties [0] {
+ - Methods [38] {
+ Method [ <internal:MapGuideApi> public method GetExteriorRing ] {
+ Method [ <internal:MapGuideApi> public method GetInteriorRingCount ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetInteriorRing ] {
+ Method [ <internal:MapGuideApi, overwrites MgGeometry, prototype MgGeometry> public method GetGeometryType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method GetDimension ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method IsEmpty ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method IsClosed ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method Copy ] {
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method Transform ] {
+ Method [ <internal:MapGuideApi, overwrites MgRegion, prototype MgGeometricEntity> public method __set ] {
+ Parameter #0 [ <required> string $arg1 ]
+ Parameter #1 [ <optional> $arg2 = <default> ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgRegion, prototype MgGeometricEntity> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgRegion, prototype MgGeometricEntity> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgRegion> public method GetPointInRegion ] {
+ Method [ <internal:MapGuideApi, inherits MgRegion> public method GetCoordinates ] {
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCurvePolygonCollection extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [14] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetItem ] {
+ Parameter #1 [ <required> ?MgCurvePolygon $arg2 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Add ] {
+ Parameter #0 [ <required> ?MgCurvePolygon $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Insert ] {
+ - Return [ void ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Remove ] {
+ - Return [ bool ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Contains ] {
+ - Return [ bool ]
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgGuardDisposable, prototype MgObject> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgGuardDisposable, prototype MgObject> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgGuardDisposable, prototype MgObject> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCurveRing extends MgRing implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [19] {
+ Method [ <internal:MapGuideApi, overwrites MgGeometryComponent, prototype MgGeometryComponent> public method GetComponentType ] {
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ bool ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, overwrites MgRing, prototype MgGeometricEntity> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgRing, prototype MgGeometricEntity> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgRing, prototype MgGeometricEntity> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgRing> public method GetPointInRing ] {
+ Method [ <internal:MapGuideApi, inherits MgRing> public method GetCoordinates ] {
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCurveRingCollection extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [14] {
+ - Return [ int ]
+ Parameter #1 [ <required> ?MgCurveRing $arg2 ]
+ - Return [ void ]
+ Parameter #0 [ <required> ?MgCurveRing $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCurveSegment extends MgGeometryComponent implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [17] {
+ Method [ <internal:MapGuideApi, overwrites MgGeometryComponent, prototype MgGeometricEntity> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgGeometryComponent, prototype MgGeometricEntity> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgGeometryComponent, prototype MgGeometricEntity> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometryComponent> public method GetComponentType ] {
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCurveSegmentCollection extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [14] {
+ - Return [ int ]
+ Parameter #0 [ <required> int $arg1 ]
+ Parameter #1 [ <required> ?MgCurveSegment $arg2 ]
+ - Return [ void ]
+ Parameter #0 [ <required> ?MgCurveSegment $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, ctor> public method __construct ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCurveString extends MgCurve implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [37] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgCurve, prototype MgCurve> public method GetStartCoordinate ] {
+ Method [ <internal:MapGuideApi, overwrites MgCurve, prototype MgCurve> public method GetEndCoordinate ] {
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ bool ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, overwrites MgCurve, prototype MgGeometricEntity> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgCurve, prototype MgGeometricEntity> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgCurve, prototype MgGeometricEntity> public method __isset ] {
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ Parameter #0 [ <required> float $arg1 ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgCurveStringCollection extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [14] {
+ - Return [ int ]
+ Parameter #1 [ <required> ?MgCurveString $arg2 ]
+ - Return [ void ]
+ Parameter #0 [ <required> ?MgCurveString $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgDataPropertyDefinition extends MgPropertyDefinition implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [28] {
+ Method [ <internal:MapGuideApi, overwrites MgPropertyDefinition, ctor> public method __construct ] {
+ Parameter #0 [ <required> $arg1 ]
+ Method [ <internal:MapGuideApi> public method GetDataType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetLength ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetPrecision ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetScale ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method IsAutoGenerated ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetDefaultValue ] {
+ Method [ <internal:MapGuideApi> public method GetNullable ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetReadOnly ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method SetDataType ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetReadOnly ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetLength ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetPrecision ] {
+ - Return [ void ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetNullable ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetDefaultValue ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetAutoGeneration ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgPropertyDefinition, prototype MgNamedSerializable> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgPropertyDefinition, prototype MgNamedSerializable> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgPropertyDefinition, prototype MgNamedSerializable> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgPropertyDefinition, prototype MgProperty> public method GetPropertyType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgPropertyDefinition> public method SetDescription ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgPropertyDefinition> public method GetDescription ] {
+ Method [ <internal:MapGuideApi, inherits MgPropertyDefinition> public method SetQualifiedName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgPropertyDefinition> public method GetQualifiedName ] {
+ Method [ <internal:MapGuideApi, inherits MgPropertyDefinition> public method Delete ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgProperty> public method GetName ] {
+ Method [ <internal:MapGuideApi, inherits MgProperty> public method SetName ] {
+ - Return [ void ]
+Class [ <internal:MapGuideApi> class MgDataReader extends MgReader implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [25] {
+ Method [ <internal:MapGuideApi, overwrites MgReader, prototype MgReader> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgReader, prototype MgReader> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgReader, prototype MgReader> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgReader> public method ReadNext ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetPropertyCount ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetPropertyName ] {
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetPropertyType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetPropertyIndex ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgReader> public method IsNull ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetBoolean ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetByte ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetDateTime ] {
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetSingle ] {
+ - Return [ float ]
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetDouble ] {
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetInt16 ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetInt32 ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetInt64 ] {
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetString ] {
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetBLOB ] {
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetCLOB ] {
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetGeometry ] {
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetRaster ] {
+ Method [ <internal:MapGuideApi, inherits MgReader> public method Close ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgReader> public method GetReaderType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgReader> public method ToXml ] {
+Class [ <internal:MapGuideApi> class MgDateTime implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [23] {
+ - Parameters [7] {
+ Parameter #1 [ <required> int $arg2 ]
+ Parameter #2 [ <required> int $arg3 ]
+ Parameter #4 [ <required> int $arg5 ]
+ Parameter #5 [ <required> int $arg6 ]
+ Parameter #6 [ <required> int $arg7 ]
+ Method [ <internal:MapGuideApi> public method GetDay ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetMonth ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetYear ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetHour ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetMinute ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetSecond ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetMicrosecond ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetDay ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetMonth ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetYear ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetHour ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetMinute ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetSecond ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetMicrosecond ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Validate ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsDate ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsTime ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsDateTime ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method ToString ] {
+ Method [ <internal:MapGuideApi> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method __get ] {
+ Method [ <internal:MapGuideApi> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgDateTimeProperty extends MgNullableProperty implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [11] {
+ Parameter #1 [ <required> ?MgDateTime $arg2 ]
+ Method [ <internal:MapGuideApi, overwrites MgProperty, prototype MgProperty> public method GetPropertyType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetValue ] {
+ Parameter #0 [ <required> ?MgDateTime $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgNullableProperty, prototype MgNamedSerializable> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgNullableProperty, prototype MgNamedSerializable> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgNullableProperty, prototype MgNamedSerializable> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgNullableProperty> public method SetNull ] {
+ Parameter #0 [ <required> bool $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgNullableProperty> public method IsNull ] {
+ - Return [ bool ]
+ - Return [ void ]
+Class [ <internal:MapGuideApi> class MgDeleteFeatures extends MgFeatureCommand implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [7] {
+ Parameter #1 [ <required> $arg2 ]
+ Method [ <internal:MapGuideApi, overwrites MgFeatureCommand, prototype MgFeatureCommand> public method GetCommandType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetFeatureClassName ] {
+ Method [ <internal:MapGuideApi> public method GetFilterText ] {
+ Method [ <internal:MapGuideApi, overwrites MgFeatureCommand, prototype MgFeatureCommand> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgFeatureCommand, prototype MgFeatureCommand> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgFeatureCommand, prototype MgFeatureCommand> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgDisposable extends MgObject implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [3] {
+ Method [ <internal:MapGuideApi, overwrites MgObject, prototype MgObject> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgObject, prototype MgObject> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgObject, prototype MgObject> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgDisposableCollection extends MgCollection implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [15] {
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method GetCount ] {
+ - Return [ int ]
+ Parameter #1 [ <required> ?MgDisposable $arg2 ]
+ - Return [ void ]
+ Parameter #0 [ <required> ?MgDisposable $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method Clear ] {
+ - Return [ void ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method RemoveAt ] {
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method ToXml ] {
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgDoubleProperty extends MgNullableProperty implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [11] {
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+Class [ <internal:MapGuideApi> class MgDrawingService extends MgService implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [14] {
+ Method [ <internal:MapGuideApi> public method GetDrawing ] {
+ Parameter #0 [ <required> ?MgResourceIdentifier $arg1 ]
+ Method [ <internal:MapGuideApi> public method DescribeDrawing ] {
+ Method [ <internal:MapGuideApi> public method GetSection ] {
+ Method [ <internal:MapGuideApi> public method GetSectionResource ] {
+ Method [ <internal:MapGuideApi> public method EnumerateLayers ] {
+ Method [ <internal:MapGuideApi> public method GetLayer ] {
+ - Parameters [3] {
+ Parameter #2 [ <required> $arg3 ]
+ Method [ <internal:MapGuideApi> public method EnumerateSections ] {
+ Method [ <internal:MapGuideApi> public method EnumerateSectionResources ] {
+ Method [ <internal:MapGuideApi> public method GetCoordinateSpace ] {
+ Method [ <internal:MapGuideApi, overwrites MgService, prototype MgObject> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgService, prototype MgObject> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgService, prototype MgObject> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgService> public method HasWarnings ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgService> public method GetWarningsObject ] {
+Class [ <internal:MapGuideApi> class MgDwfVersion implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [8] {
+ Method [ <internal:MapGuideApi> public method GetFileVersion ] {
+ Method [ <internal:MapGuideApi> public method SetFileVersion ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetSchemaVersion ] {
+ Method [ <internal:MapGuideApi> public method SetSchemaVersion ] {
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgEnvelope implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [15] {
+ Parameter #1 [ <optional> MgCoordinate|float|null $arg2 = <default> ]
+ Parameter #3 [ <optional> float $arg4 = <default> ]
+ Method [ <internal:MapGuideApi> public method GetLowerLeftCoordinate ] {
+ Method [ <internal:MapGuideApi> public method GetUpperRightCoordinate ] {
+ Method [ <internal:MapGuideApi> public method GetWidth ] {
+ Method [ <internal:MapGuideApi> public method GetHeight ] {
+ Method [ <internal:MapGuideApi> public method GetDepth ] {
+ Method [ <internal:MapGuideApi> public method IsNull ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method MakeNull ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method ExpandToInclude ] {
+ Parameter #0 [ <required> MgCoordinate|MgEnvelope|null $arg1 ]
+ - Return [ void ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method Intersects ] {
+ Parameter #0 [ <required> ?MgEnvelope $arg1 ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method Transform ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgException extends Exception implements Throwable, Stringable, SWIG\wrapped ] {
+ - Constants [0] {
+ - Properties [4] {
+ Property [ protected $message = '' ]
+ Property [ protected $code = 0 ]
+ Property [ protected string $file = '' ]
+ Property [ protected int $line = 0 ]
+ - Methods [19] {
+ Method [ <internal:MapGuideApi> public method GetExceptionCode ] {
+ Method [ <internal:MapGuideApi> public method GetNativeErrorCode ] {
+ Method [ <internal:MapGuideApi> public method GetExceptionMessage ] {
+ Method [ <internal:MapGuideApi> public method GetDetails ] {
+ Method [ <internal:MapGuideApi> public method GetStackTrace ] {
+ Method [ <internal:MapGuideApi> public method AddStackTraceInfo ] {
+ Parameter #3 [ <required> $arg4 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ Method [ <internal:Core, inherits Exception, ctor> public method __construct ] {
+ Parameter #0 [ <optional> string $message = "" ]
+ Parameter #1 [ <optional> int $code = 0 ]
+ Parameter #2 [ <optional> ?Throwable $previous = null ]
+ Method [ <internal:Core, inherits Exception> public method __wakeup ] {
+ - Tentative return [ void ]
+ Method [ <internal:Core, inherits Exception, prototype Throwable> final public method getMessage ] {
+ - Return [ string ]
+ Method [ <internal:Core, inherits Exception, prototype Throwable> final public method getCode ] {
+ Method [ <internal:Core, inherits Exception, prototype Throwable> final public method getFile ] {
+ Method [ <internal:Core, inherits Exception, prototype Throwable> final public method getLine ] {
+ - Return [ int ]
+ Method [ <internal:Core, inherits Exception, prototype Throwable> final public method getTrace ] {
+ - Return [ array ]
+ Method [ <internal:Core, inherits Exception, prototype Throwable> final public method getPrevious ] {
+ - Return [ ?Throwable ]
+ Method [ <internal:Core, inherits Exception, prototype Throwable> final public method getTraceAsString ] {
+ Method [ <internal:Core, inherits Exception, prototype Stringable> public method __toString ] {
+Class [ <internal:MapGuideApi> class MgExceptionCodes implements SWIG\wrapped ] {
+ - Constants [139] {
+ Constant [ public string MgAllProviderConnectionsUsedException ] { MgAllProviderConnectionsUsedException }
+ Constant [ public string MgArgumentOutOfRangeException ] { MgArgumentOutOfRangeException }
+ Constant [ public string MgArrayTypeMismatchException ] { MgArrayTypeMismatchException }
+ Constant [ public string MgAuthenticationFailedException ] { MgAuthenticationFailedException }
+ Constant [ public string MgClassNotFoundException ] { MgClassNotFoundException }
+ Constant [ public string MgConfigurationException ] { MgConfigurationException }
+ Constant [ public string MgConfigurationSaveFailedException ] { MgConfigurationSaveFailedException }
+ Constant [ public string MgConnectionFailedException ] { MgConnectionFailedException }
+ Constant [ public string MgConnectionNotOpenException ] { MgConnectionNotOpenException }
+ Constant [ public string MgCoordinateSystemComputationFailedException ] { MgCoordinateSystemComputationFailedException }
+ Constant [ public string MgCoordinateSystemConversionFailedException ] { MgCoordinateSystemConversionFailedException }
+ Constant [ public string MgCoordinateSystemInitializationFailedException ] { MgCoordinateSystemInitializationFailedException }
+ Constant [ public string MgCoordinateSystemLoadFailedException ] { MgCoordinateSystemLoadFailedException }
+ Constant [ public string MgCoordinateSystemMeasureFailedException ] { MgCoordinateSystemMeasureFailedException }
+ Constant [ public string MgCoordinateSystemTransformFailedException ] { MgCoordinateSystemTransformFailedException }
+ Constant [ public string MgDateTimeException ] { MgDateTimeException }
+ Constant [ public string MgDbException ] { MgDbException }
+ Constant [ public string MgDbXmlException ] { MgDbXmlException }
+ Constant [ public string MgDecryptionException ] { MgDecryptionException }
+ Constant [ public string MgDirectoryNotFoundException ] { MgDirectoryNotFoundException }
+ Constant [ public string MgDivideByZeroException ] { MgDivideByZeroException }
+ Constant [ public string MgDomainException ] { MgDomainException }
+ Constant [ public string MgDuplicateDirectoryException ] { MgDuplicateDirectoryException }
+ Constant [ public string MgDuplicateFileException ] { MgDuplicateFileException }
+ Constant [ public string MgDuplicateGroupException ] { MgDuplicateGroupException }
+ Constant [ public string MgDuplicateNameException ] { MgDuplicateNameException }
+ Constant [ public string MgDuplicateObjectException ] { MgDuplicateObjectException }
+ Constant [ public string MgDuplicateParameterException ] { MgDuplicateParameterException }
+ Constant [ public string MgDuplicateRepositoryException ] { MgDuplicateRepositoryException }
+ Constant [ public string MgDuplicateResourceDataException ] { MgDuplicateResourceDataException }
+ Constant [ public string MgDuplicateResourceException ] { MgDuplicateResourceException }
+ Constant [ public string MgDuplicateRoleException ] { MgDuplicateRoleException }
+ Constant [ public string MgDuplicateServerException ] { MgDuplicateServerException }
+ Constant [ public string MgDuplicateSessionException ] { MgDuplicateSessionException }
+ Constant [ public string MgDuplicateUserException ] { MgDuplicateUserException }
+ Constant [ public string MgDwfException ] { MgDwfException }
+ Constant [ public string MgDwfSectionNotFoundException ] { MgDwfSectionNotFoundException }
+ Constant [ public string MgDwfSectionResourceNotFoundException ] { MgDwfSectionResourceNotFoundException }
+ Constant [ public string MgEmptyFeatureSetException ] { MgEmptyFeatureSetException }
+ Constant [ public string MgEncryptionException ] { MgEncryptionException }
+ Constant [ public string MgEndOfStreamException ] { MgEndOfStreamException }
+ Constant [ public string MgEvaluationExpiredException ] { MgEvaluationExpiredException }
+ Constant [ public string MgFdoException ] { MgFdoException }
+ Constant [ public string MgFeatureServiceException ] { MgFeatureServiceException }
+ Constant [ public string MgFileIoException ] { MgFileIoException }
+ Constant [ public string MgFileNotFoundException ] { MgFileNotFoundException }
+ Constant [ public string MgGeometryException ] { MgGeometryException }
+ Constant [ public string MgGroupNotFoundException ] { MgGroupNotFoundException }
+ Constant [ public string MgIndexOutOfRangeException ] { MgIndexOutOfRangeException }
+ Constant [ public string MgInvalidArgumentException ] { MgInvalidArgumentException }
+ Constant [ public string MgInvalidCastException ] { MgInvalidCastException }
+ Constant [ public string MgInvalidCoordinateSystemException ] { MgInvalidCoordinateSystemException }
+ Constant [ public string MgInvalidCoordinateSystemTypeException ] { MgInvalidCoordinateSystemTypeException }
+ Constant [ public string MgInvalidCoordinateSystemUnitsException ] { MgInvalidCoordinateSystemUnitsException }
+ Constant [ public string MgInvalidDwfPackageException ] { MgInvalidDwfPackageException }
+ Constant [ public string MgInvalidDwfSectionException ] { MgInvalidDwfSectionException }
+ Constant [ public string MgInvalidFeatureSourceException ] { MgInvalidFeatureSourceException }
+ Constant [ public string MgInvalidIpAddressException ] { MgInvalidIpAddressException }
+ Constant [ public string MgInvalidLicenseException ] { MgInvalidLicenseException }
+ Constant [ public string MgInvalidLogEntryException ] { MgInvalidLogEntryException }
+ Constant [ public string MgInvalidMapDefinitionException ] { MgInvalidMapDefinitionException }
+ Constant [ public string MgInvalidMimeTypeException ] { MgInvalidMimeTypeException }
+ Constant [ public string MgInvalidOperationException ] { MgInvalidOperationException }
+ Constant [ public string MgInvalidOperationVersionException ] { MgInvalidOperationVersionException }
+ Constant [ public string MgInvalidPasswordException ] { MgInvalidPasswordException }
+ Constant [ public string MgInvalidPrintLayoutFontSizeUnitsException ] { MgInvalidPrintLayoutFontSizeUnitsException }
+ Constant [ public string MgInvalidPrintLayoutPositionUnitsException ] { MgInvalidPrintLayoutPositionUnitsException }
+ Constant [ public string MgInvalidPrintLayoutSizeUnitsException ] { MgInvalidPrintLayoutSizeUnitsException }
+ Constant [ public string MgInvalidPropertyTypeException ] { MgInvalidPropertyTypeException }
+ Constant [ public string MgInvalidRepositoryNameException ] { MgInvalidRepositoryNameException }
+ Constant [ public string MgInvalidRepositoryTypeException ] { MgInvalidRepositoryTypeException }
+ Constant [ public string MgInvalidResourceDataNameException ] { MgInvalidResourceDataNameException }
+ Constant [ public string MgInvalidResourceDataTypeException ] { MgInvalidResourceDataTypeException }
+ Constant [ public string MgInvalidResourceNameException ] { MgInvalidResourceNameException }
+ Constant [ public string MgInvalidResourcePathException ] { MgInvalidResourcePathException }
+ Constant [ public string MgInvalidResourcePreProcessingTypeException ] { MgInvalidResourcePreProcessingTypeException }
+ Constant [ public string MgInvalidResourceTypeException ] { MgInvalidResourceTypeException }
+ Constant [ public string MgInvalidServerNameException ] { MgInvalidServerNameException }
+ Constant [ public string MgInvalidSerialNumberException ] { MgInvalidSerialNumberException }
+ Constant [ public string MgInvalidStreamHeaderException ] { MgInvalidStreamHeaderException }
+ Constant [ public string MgIoException ] { MgIoException }
+ Constant [ public string MgLayerNotFoundException ] { MgLayerNotFoundException }
+ Constant [ public string MgLengthException ] { MgLengthException }
+ Constant [ public string MgLicenseException ] { MgLicenseException }
+ Constant [ public string MgLicenseExpiredException ] { MgLicenseExpiredException }
+ Constant [ public string MgLogicException ] { MgLogicException }
+ Constant [ public string MgLogOpenFailedException ] { MgLogOpenFailedException }
+ Constant [ public string MgNotFiniteNumberException ] { MgNotFiniteNumberException }
+ Constant [ public string MgNotImplementedException ] { MgNotImplementedException }
+ Constant [ public string MgNullArgumentException ] { MgNullArgumentException }
+ Constant [ public string MgNullPropertyValueException ] { MgNullPropertyValueException }
+ Constant [ public string MgNullReferenceException ] { MgNullReferenceException }
+ Constant [ public string MgObjectNotFoundException ] { MgObjectNotFoundException }
+ Constant [ public string MgOperationProcessingException ] { MgOperationProcessingException }
+ Constant [ public string MgOutOfMemoryException ] { MgOutOfMemoryException }
+ Constant [ public string MgOutOfRangeException ] { MgOutOfRangeException }
+ Constant [ public string MgOverflowException ] { MgOverflowException }
+ Constant [ public string MgParameterNotFoundException ] { MgParameterNotFoundException }
+ Constant [ public string MgPathTooLongException ] { MgPathTooLongException }
+ Constant [ public string MgPermissionDeniedException ] { MgPermissionDeniedException }
+ Constant [ public string MgPlatformNotSupportedException ] { MgPlatformNotSupportedException }
+ Constant [ public string MgPortNotAvailableException ] { MgPortNotAvailableException }
+ Constant [ public string MgPrintToScaleModeNotSelectedException ] { MgPrintToScaleModeNotSelectedException }
+ Constant [ public string MgRasterTransformationNotSupportedException ] { MgRasterTransformationNotSupportedException }
+ Constant [ public string MgRepositoryCreationFailedException ] { MgRepositoryCreationFailedException }
+ Constant [ public string MgRepositoryNotFoundException ] { MgRepositoryNotFoundException }
+ Constant [ public string MgRepositoryNotOpenException ] { MgRepositoryNotOpenException }
+ Constant [ public string MgRepositoryOpenFailedException ] { MgRepositoryOpenFailedException }
+ Constant [ public string MgResourceBusyException ] { MgResourceBusyException }
+ Constant [ public string MgResourceDataNotFoundException ] { MgResourceDataNotFoundException }
+ Constant [ public string MgResourceNotFoundException ] { MgResourceNotFoundException }
+ Constant [ public string MgResourcesException ] { MgResourcesException }
+ Constant [ public string MgResourceTagNotFoundException ] { MgResourceTagNotFoundException }
+ Constant [ public string MgRoleNotFoundException ] { MgRoleNotFoundException }
+ Constant [ public string MgRuntimeException ] { MgRuntimeException }
+ Constant [ public string MgServerNotFoundException ] { MgServerNotFoundException }
+ Constant [ public string MgServerNotOnlineException ] { MgServerNotOnlineException }
+ Constant [ public string MgServiceNotAvailableException ] { MgServiceNotAvailableException }
+ Constant [ public string MgServiceNotSupportedException ] { MgServiceNotSupportedException }
+ Constant [ public string MgSessionExpiredException ] { MgSessionExpiredException }
+ Constant [ public string MgSessionNotFoundException ] { MgSessionNotFoundException }
+ Constant [ public string MgStreamIoException ] { MgStreamIoException }
+ Constant [ public string MgStylizeLayerFailedException ] { MgStylizeLayerFailedException }
+ Constant [ public string MgTemporaryFileNotAvailableException ] { MgTemporaryFileNotAvailableException }
+ Constant [ public string MgUnauthorizedAccessException ] { MgUnauthorizedAccessException }
+ Constant [ public string MgUnclassifiedException ] { MgUnclassifiedException }
+ Constant [ public string MgUnderflowException ] { MgUnderflowException }
+ Constant [ public string MgUnknownTileProviderException ] { MgUnknownTileProviderException }
+ Constant [ public string MgUnsupportedProviderThreadModelException ] { MgUnsupportedProviderThreadModelException }
+ Constant [ public string MgUnsupportedTileProviderException ] { MgUnsupportedTileProviderException }
+ Constant [ public string MgUriFormatException ] { MgUriFormatException }
+ Constant [ public string MgUserNotFoundException ] { MgUserNotFoundException }
+ Constant [ public string MgXmlException ] { MgXmlException }
+ Constant [ public string MgXmlParserException ] { MgXmlParserException }
+ Constant [ public string MgConfigurationLoadFailedException ] { MgConfigurationLoadFailedException }
+ Constant [ public string MgResourcesLoadFailedException ] { MgResourcesLoadFailedException }
+ Constant [ public string MgGridDensityException ] { MgGridDensityException }
+ Constant [ public string MgInvalidLayerDefinitionException ] { MgInvalidLayerDefinitionException }
+ Constant [ public string MgInvalidWatermarkDefinitionException ] { MgInvalidWatermarkDefinitionException }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgFeatureAggregateOptions extends MgFeatureQueryOptions implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [15] {
+ Method [ <internal:MapGuideApi, overwrites MgFeatureQueryOptions, ctor> public method __construct ] {
+ Method [ <internal:MapGuideApi> public method SelectDistinct ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetGroupingFilter ] {
+ Parameter #0 [ <required> ?MgStringCollection $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgFeatureQueryOptions, prototype MgFeatureQueryOptions> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgFeatureQueryOptions, prototype MgFeatureQueryOptions> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgFeatureQueryOptions, prototype MgFeatureQueryOptions> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgFeatureQueryOptions> public method AddFeatureProperty ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgFeatureQueryOptions> public method AddComputedProperty ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgFeatureQueryOptions> public method SetFilter ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgFeatureQueryOptions> public method SetBinaryOperator ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgFeatureQueryOptions> public method SetSpatialFilter ] {
+ Parameter #1 [ <required> ?MgGeometry $arg2 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgFeatureQueryOptions> public method SetOrderingFilter ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgFeatureQueryOptions> public method RemoveFeatureProperty ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgFeatureQueryOptions> public method RemoveComputedProperty ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgFeatureQueryOptions> public method SetFetchSize ] {
+ - Return [ void ]
+Class [ <internal:MapGuideApi> class MgFeatureCommand implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [4] {
+ Method [ <internal:MapGuideApi> public method GetCommandType ] {
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgFeatureCommandCollection implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [14] {
+ Method [ <internal:MapGuideApi> public method GetCount ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetItem ] {
+ Parameter #1 [ <required> ?MgFeatureCommand $arg2 ]
+ - Return [ void ]
+ Parameter #0 [ <required> ?MgFeatureCommand $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Clear ] {
+ - Return [ void ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method RemoveAt ] {
+ - Return [ void ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IndexOf ] {
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgFeatureCommandType implements SWIG\wrapped ] {
+ - Constants [5] {
+ Constant [ public int InsertFeatures ] { 0 }
+ Constant [ public int UpdateFeatures ] { 1 }
+ Constant [ public int DeleteFeatures ] { 2 }
+ Constant [ public int LockFeatures ] { 3 }
+ Constant [ public int UnlockFeatures ] { 4 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgFeatureGeometricType implements SWIG\wrapped ] {
+ - Constants [4] {
+ Constant [ public int Point ] { 1 }
+ Constant [ public int Curve ] { 2 }
+ Constant [ public int Surface ] { 4 }
+ Constant [ public int Solid ] { 8 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgFeatureInformation implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [8] {
+ Method [ <internal:MapGuideApi> public method GetSelection ] {
+ Method [ <internal:MapGuideApi> public method GetTooltip ] {
+ Method [ <internal:MapGuideApi> public method GetHyperlink ] {
+ Method [ <internal:MapGuideApi> public method GetProperties ] {
+ Method [ <internal:MapGuideApi> public method ToXml ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgFeatureProperty extends MgNullableProperty implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [11] {
+ Parameter #1 [ <required> ?MgFeatureReader $arg2 ]
+ Method [ <internal:MapGuideApi> public method GetValue ] {
+ - Return [ int ]
+ Parameter #0 [ <required> ?MgFeatureReader $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+Class [ <internal:MapGuideApi> class MgFeaturePropertyType implements SWIG\wrapped ] {
+ - Constants [5] {
+ Constant [ public int DataProperty ] { 100 }
+ Constant [ public int ObjectProperty ] { 101 }
+ Constant [ public int GeometricProperty ] { 102 }
+ Constant [ public int AssociationProperty ] { 103 }
+ Constant [ public int RasterProperty ] { 104 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgFeatureQueryOptions implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [13] {
+ Method [ <internal:MapGuideApi> public method AddFeatureProperty ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method AddComputedProperty ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetFilter ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetBinaryOperator ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetSpatialFilter ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetOrderingFilter ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method RemoveFeatureProperty ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method RemoveComputedProperty ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetFetchSize ] {
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgFeatureReader extends MgReader implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [27] {
+ Method [ <internal:MapGuideApi> public method GetClassDefinition ] {
+ Method [ <internal:MapGuideApi> public method GetFeatureObject ] {
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ int ]
+Class [ <internal:MapGuideApi> class MgFeatureSchema extends MgNamedSerializable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [10] {
+ Method [ <internal:MapGuideApi> public method GetName ] {
+ Method [ <internal:MapGuideApi> public method SetName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetDescription ] {
+ Method [ <internal:MapGuideApi> public method SetDescription ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetClasses ] {
+ Method [ <internal:MapGuideApi> public method Delete ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgNamedSerializable, prototype MgNamedSerializable> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgNamedSerializable, prototype MgNamedSerializable> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgNamedSerializable, prototype MgNamedSerializable> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgFeatureSchemaCollection extends MgCollection implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [15] {
+ Parameter #1 [ <required> ?MgFeatureSchema $arg2 ]
+ - Return [ void ]
+ Parameter #0 [ <required> ?MgFeatureSchema $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgFeatureService extends MgService implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [36] {
+ Method [ <internal:MapGuideApi> public method GetFeatureProviders ] {
+ Method [ <internal:MapGuideApi> public method GetConnectionPropertyValues ] {
+ Method [ <internal:MapGuideApi> public method TestConnection ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetCapabilities ] {
+ Method [ <internal:MapGuideApi> public method ApplySchema ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method DescribeSchema ] {
+ Parameter #2 [ <optional> ?MgStringCollection $arg3 = <default> ]
+ Method [ <internal:MapGuideApi> public method DescribeSchemaAsXml ] {
+ Method [ <internal:MapGuideApi> public method SchemaToXml ] {
+ Parameter #0 [ <required> ?MgFeatureSchemaCollection $arg1 ]
+ Method [ <internal:MapGuideApi> public method XmlToSchema ] {
+ Method [ <internal:MapGuideApi> public method SelectFeatures ] {
+ - Parameters [4] {
+ Parameter #2 [ <required> ?MgFeatureQueryOptions $arg3 ]
+ Method [ <internal:MapGuideApi> public method SelectAggregate ] {
+ Parameter #2 [ <required> ?MgFeatureAggregateOptions $arg3 ]
+ Method [ <internal:MapGuideApi> public method UpdateFeatures ] {
+ Parameter #1 [ <required> ?MgFeatureCommandCollection $arg2 ]
+ Parameter #2 [ <required> MgTransaction|bool|null $arg3 ]
+ Method [ <internal:MapGuideApi> public method InsertFeatures ] {
+ Parameter #2 [ <required> MgBatchPropertyCollection|MgPropertyCollection|null $arg3 ]
+ Parameter #3 [ <required> ?MgTransaction $arg4 ]
+ Method [ <internal:MapGuideApi> public method UpdateMatchingFeatures ] {
+ - Parameters [5] {
+ Parameter #2 [ <required> ?MgPropertyCollection $arg3 ]
+ Parameter #4 [ <required> ?MgTransaction $arg5 ]
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method DeleteFeatures ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetLockedFeatures ] {
+ Method [ <internal:MapGuideApi> public method BeginTransaction ] {
+ Method [ <internal:MapGuideApi> public method ExecuteSqlQuery ] {
+ Parameter #2 [ <required> ?MgParameterCollection $arg3 ]
+ Method [ <internal:MapGuideApi> public method ExecuteSqlNonQuery ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetSpatialContexts ] {
+ Parameter #1 [ <required> bool $arg2 ]
+ Method [ <internal:MapGuideApi> public method GetLongTransactions ] {
+ Method [ <internal:MapGuideApi> public method SetLongTransaction ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetSchemas ] {
+ Method [ <internal:MapGuideApi> public method CreateFeatureSource ] {
+ Parameter #1 [ <required> ?MgFeatureSourceParams $arg2 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method DescribeWfsFeatureType ] {
+ Parameter #1 [ <required> ?MgStringCollection $arg2 ]
+ Method [ <internal:MapGuideApi> public method GetWfsFeature ] {
+ - Parameters [11] {
+ Parameter #2 [ <required> ?MgStringCollection $arg3 ]
+ Parameter #4 [ <required> $arg5 ]
+ Parameter #6 [ <required> $arg7 ]
+ Parameter #7 [ <required> $arg8 ]
+ Parameter #8 [ <required> $arg9 ]
+ Parameter #9 [ <required> $arg10 ]
+ Parameter #10 [ <required> $arg11 ]
+ Method [ <internal:MapGuideApi> public method GetWfsReader ] {
+ - Parameters [6] {
+ Parameter #5 [ <required> $arg6 ]
+ Method [ <internal:MapGuideApi> public method EnumerateDataStores ] {
+ Method [ <internal:MapGuideApi> public method GetSchemaMapping ] {
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgFeatureSourceParams implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgFeatureSpatialOperations implements SWIG\wrapped ] {
+ - Constants [11] {
+ Constant [ public int Contains ] { 0 }
+ Constant [ public int Crosses ] { 1 }
+ Constant [ public int Disjoint ] { 2 }
+ Constant [ public int Equals ] { 3 }
+ Constant [ public int Intersects ] { 4 }
+ Constant [ public int Overlaps ] { 5 }
+ Constant [ public int Touches ] { 6 }
+ Constant [ public int Within ] { 7 }
+ Constant [ public int CoveredBy ] { 8 }
+ Constant [ public int Inside ] { 9 }
+ Constant [ public int EnvelopeIntersects ] { 10 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgFileFeatureSourceParams extends MgFeatureSourceParams implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [20] {
+ Parameter #3 [ <required> ?MgFeatureSchema $arg4 ]
+ Method [ <internal:MapGuideApi> public method GetProviderName ] {
+ Method [ <internal:MapGuideApi> public method SetProviderName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetFileName ] {
+ Method [ <internal:MapGuideApi> public method SetFileName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetSpatialContextName ] {
+ Method [ <internal:MapGuideApi> public method SetSpatialContextName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetSpatialContextDescription ] {
+ Method [ <internal:MapGuideApi> public method SetSpatialContextDescription ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetCoordinateSystemWkt ] {
+ Method [ <internal:MapGuideApi> public method SetCoordinateSystemWkt ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetXYTolerance ] {
+ Method [ <internal:MapGuideApi> public method SetXYTolerance ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetZTolerance ] {
+ Method [ <internal:MapGuideApi> public method SetZTolerance ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetFeatureSchema ] {
+ Method [ <internal:MapGuideApi> public method SetFeatureSchema ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgFeatureSourceParams, prototype MgFeatureSourceParams> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgFeatureSourceParams, prototype MgFeatureSourceParams> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgFeatureSourceParams, prototype MgFeatureSourceParams> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgGeoJsonWriter extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [9] {
+ Method [ <internal:MapGuideApi> public method FeatureToGeoJson ] {
+ Parameter #0 [ <required> ?MgReader $arg1 ]
+ Parameter #1 [ <required> ?MgTransform $arg2 ]
+ - Return [ void ]
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetPrecisionEnabled ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsPrecisionEnabled ] {
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgGeometricEntity implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [14] {
+ Method [ <internal:MapGuideApi> public method GetDimension ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method IsEmpty ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsSimple ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsClosed ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsValid ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method Envelope ] {
+ Method [ <internal:MapGuideApi> public method Copy ] {
+ Method [ <internal:MapGuideApi> public method GetArea ] {
+ Method [ <internal:MapGuideApi> public method GetCentroid ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgGeometricPathInstructionType implements SWIG\wrapped ] {
+ - Constants [4] {
+ Constant [ public int MoveTo ] { 0 }
+ Constant [ public int LineTo ] { 1 }
+ Constant [ public int QuadTo ] { 2 }
+ Constant [ public int Close ] { 4 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgGeometricPropertyDefinition extends MgPropertyDefinition implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [24] {
+ Method [ <internal:MapGuideApi> public method GetGeometryTypes ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetSpecificGeometryTypes ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetHasElevation ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetHasMeasure ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetSpatialContextAssociation ] {
+ Method [ <internal:MapGuideApi> public method SetGeometryTypes ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetSpecificGeometryTypes ] {
+ Parameter #0 [ <required> ?MgGeometryTypeInfo $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetHasElevation ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetHasMeasure ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetSpatialContextAssociation ] {
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+Class [ <internal:MapGuideApi> class MgGeometry extends MgGeometricEntity implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [33] {
+ Method [ <internal:MapGuideApi> public method GetGeometryType ] {
+ - Return [ int ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method Crosses ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method Disjoint ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method Equals ] {
+ - Return [ bool ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method Overlaps ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method Touches ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method Within ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method Boundary ] {
+ Method [ <internal:MapGuideApi> public method Buffer ] {
+ Method [ <internal:MapGuideApi> public method ConvexHull ] {
+ Method [ <internal:MapGuideApi> public method Difference ] {
+ Method [ <internal:MapGuideApi> public method Distance ] {
+ Method [ <internal:MapGuideApi> public method Intersection ] {
+ Method [ <internal:MapGuideApi> public method SymetricDifference ] {
+ Method [ <internal:MapGuideApi> public method Union ] {
+ Method [ <internal:MapGuideApi> public method Prepare ] {
+ Method [ <internal:MapGuideApi> public method Tessellate ] {
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method __isset ] {
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgGeometryCollection extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [14] {
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgGeometryComponent extends MgGeometricEntity implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [15] {
+ Method [ <internal:MapGuideApi> public method GetComponentType ] {
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgGeometryComponentType implements SWIG\wrapped ] {
+ - Constants [4] {
+ Constant [ public int LinearRing ] { 129 }
+ Constant [ public int ArcSegment ] { 130 }
+ Constant [ public int LinearSegment ] { 131 }
+ Constant [ public int CurveRing ] { 132 }
+ - Methods [3] {
+ - Return [ void ]
+ - Parameters [1] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgGeometryEntityType implements SWIG\wrapped ] {
+ - Constants [2] {
+ Constant [ public int GeometryComponent ] { 0 }
+ Constant [ public int Geometry ] { 1 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgGeometryFactory extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [23] {
+ Method [ <internal:MapGuideApi> public method CreateCoordinateXY ] {
+ Parameter #1 [ <required> float $arg2 ]
+ Method [ <internal:MapGuideApi> public method CreateCoordinateXYM ] {
+ Parameter #2 [ <required> float $arg3 ]
+ Method [ <internal:MapGuideApi> public method CreateCoordinateXYZ ] {
+ Method [ <internal:MapGuideApi> public method CreateCoordinateXYZM ] {
+ Parameter #3 [ <required> float $arg4 ]
+ Method [ <internal:MapGuideApi> public method CreateArcSegment ] {
+ Parameter #0 [ <required> ?MgCoordinate $arg1 ]
+ Parameter #1 [ <required> ?MgCoordinate $arg2 ]
+ Parameter #2 [ <required> ?MgCoordinate $arg3 ]
+ Method [ <internal:MapGuideApi> public method CreateLinearSegment ] {
+ Parameter #0 [ <required> ?MgCoordinateCollection $arg1 ]
+ Method [ <internal:MapGuideApi> public method CreateLinearRing ] {
+ Method [ <internal:MapGuideApi> public method CreateCurveRing ] {
+ Parameter #0 [ <required> ?MgCurveSegmentCollection $arg1 ]
+ Method [ <internal:MapGuideApi> public method CreatePoint ] {
+ Method [ <internal:MapGuideApi> public method CreateLineString ] {
+ Method [ <internal:MapGuideApi> public method CreateCurveString ] {
+ Method [ <internal:MapGuideApi> public method CreatePolygon ] {
+ - Parameters [2] {
+ Parameter #0 [ <required> ?MgLinearRing $arg1 ]
+ Parameter #1 [ <required> ?MgLinearRingCollection $arg2 ]
+ Method [ <internal:MapGuideApi> public method CreateCurvePolygon ] {
+ Parameter #1 [ <required> ?MgCurveRingCollection $arg2 ]
+ Method [ <internal:MapGuideApi> public method CreateMultiPoint ] {
+ Parameter #0 [ <required> ?MgPointCollection $arg1 ]
+ Method [ <internal:MapGuideApi> public method CreateMultiLineString ] {
+ Parameter #0 [ <required> ?MgLineStringCollection $arg1 ]
+ Method [ <internal:MapGuideApi> public method CreateMultiCurveString ] {
+ Parameter #0 [ <required> ?MgCurveStringCollection $arg1 ]
+ Method [ <internal:MapGuideApi> public method CreateMultiPolygon ] {
+ Parameter #0 [ <required> ?MgPolygonCollection $arg1 ]
+ Method [ <internal:MapGuideApi> public method CreateMultiCurvePolygon ] {
+ Parameter #0 [ <required> ?MgCurvePolygonCollection $arg1 ]
+ Method [ <internal:MapGuideApi> public method CreateMultiGeometry ] {
+ Parameter #0 [ <required> ?MgGeometryCollection $arg1 ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgGeometryProperty extends MgNullableProperty implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [11] {
+ Parameter #1 [ <required> ?MgByteReader $arg2 ]
+ - Parameters [0] {
+ - Return [ int ]
+ Parameter #0 [ <required> ?MgByteReader $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+Class [ <internal:MapGuideApi> class MgGeometrySimplificationAlgorithmType implements SWIG\wrapped ] {
+ - Constants [2] {
+ Constant [ public int DouglasPeucker ] { 0 }
+ Constant [ public int TopologyPreserving ] { 1 }
+ - Static properties [0] {
+ - Static methods [0] {
+ - Properties [0] {
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgGeometrySimplifier extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [5] {
+ Method [ <internal:MapGuideApi> public method Simplify ] {
+ Parameter #0 [ <required> ?MgGeometry $arg1 ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgGeometryType implements SWIG\wrapped ] {
+ Constant [ public int LineString ] { 2 }
+ Constant [ public int Polygon ] { 3 }
+ Constant [ public int MultiPoint ] { 4 }
+ Constant [ public int MultiLineString ] { 5 }
+ Constant [ public int MultiPolygon ] { 6 }
+ Constant [ public int MultiGeometry ] { 7 }
+ Constant [ public int CurveString ] { 10 }
+ Constant [ public int CurvePolygon ] { 11 }
+ Constant [ public int MultiCurveString ] { 12 }
+ Constant [ public int MultiCurvePolygon ] { 13 }
+ - Methods [3] {
+ Parameter #0 [ <required> string $arg1 ]
+ Parameter #1 [ <optional> $arg2 = <default> ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgGeometryTypeInfo implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [7] {
+ Method [ <internal:MapGuideApi> public method GetType ] {
+ - Return [ int ]
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetTypes ] {
+ Parameter #0 [ <required> ?MgIntCollection $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgGroup implements SWIG\wrapped ] {
+ - Constants [1] {
+ Constant [ public string Everyone ] { Everyone }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgGuardDisposable extends MgDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [3] {
+ Method [ <internal:MapGuideApi, overwrites MgDisposable, prototype MgObject> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgDisposable, prototype MgObject> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgDisposable, prototype MgObject> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgGwsFeatureReader extends MgFeatureReader implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [27] {
+ Method [ <internal:MapGuideApi, overwrites MgFeatureReader, prototype MgReader> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgFeatureReader, prototype MgReader> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgFeatureReader, prototype MgReader> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgFeatureReader> public method GetClassDefinition ] {
+ Method [ <internal:MapGuideApi, inherits MgFeatureReader> public method GetFeatureObject ] {
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ int ]
+Class [ <internal:MapGuideApi> class MgHttpHeader extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [12] {
+ Method [ <internal:MapGuideApi> public method AddHeader ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method RemoveHeader ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetHeaderValue ] {
+ Method [ <internal:MapGuideApi> public method SetHeaderValue ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetDateHeader ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetIntHeader ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetHeaderNames ] {
+ Method [ <internal:MapGuideApi> public method GetHeaders ] {
+ Method [ <internal:MapGuideApi, overwrites MgGuardDisposable, prototype MgObject> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgGuardDisposable, prototype MgObject> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgGuardDisposable, prototype MgObject> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgHttpPrimitiveValue extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [9] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetBoolValue ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetIntegerValue ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetStringValue ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgHttpRequest extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [9] {
+ Method [ <internal:MapGuideApi> public method GetHeader ] {
+ Method [ <internal:MapGuideApi> public method GetRequestParam ] {
+ Method [ <internal:MapGuideApi> public method GetRequestMetadata ] {
+ Method [ <internal:MapGuideApi> public method Execute ] {
+ Method [ <internal:MapGuideApi> public method GetAgentUri ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgHttpRequestMetadata extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [9] {
+ Method [ <internal:MapGuideApi> public method AddProperty ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method RemoveProperty ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetPropertyValue ] {
+ Method [ <internal:MapGuideApi> public method SetPropertyValue ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetPropertyNames ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgHttpRequestParam extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [12] {
+ Method [ <internal:MapGuideApi, ctor> public method __construct ] {
+ Method [ <internal:MapGuideApi> public method AddParameter ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method RemoveParameter ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetParameterValue ] {
+ Method [ <internal:MapGuideApi> public method GetParameterType ] {
+ Method [ <internal:MapGuideApi> public method SetParameterValue ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method SetParameterType ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetParameterNames ] {
+ Method [ <internal:MapGuideApi> public method ContainsParameter ] {
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgHttpResponse extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [6] {
+ Method [ <internal:MapGuideApi> public method GetResult ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgHttpResult extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [14] {
+ Method [ <internal:MapGuideApi> public method GetStatusCode ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetStatusCode ] {
+ Parameter #0 [ <required> int $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetErrorMessage ] {
+ Method [ <internal:MapGuideApi> public method GetDetailedErrorMessage ] {
+ Method [ <internal:MapGuideApi> public method GetHttpStatusMessage ] {
+ Method [ <internal:MapGuideApi> public method SetErrorMessage ] {
+ Parameter #0 [ <required> $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetDetailedErrorMessage ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetHttpStatusMessage ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetResultObject ] {
+ Method [ <internal:MapGuideApi> public method SetResultObject ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetResultContentType ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgImageFormats implements SWIG\wrapped ] {
+ - Constants [7] {
+ Constant [ public string Gif ] { GIF }
+ Constant [ public string Jpeg ] { JPG }
+ Constant [ public string Png ] { PNG }
+ Constant [ public string Png8 ] { PNG8 }
+ Constant [ public string Tiff ] { TIF }
+ Constant [ public string Raw ] { RAW }
+ Constant [ public string Meta ] { META }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgInsertFeatures extends MgFeatureCommand implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [7] {
+ Parameter #1 [ <required> MgBatchPropertyCollection|MgPropertyCollection|null $arg2 ]
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetPropertyValues ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgInt16Property extends MgNullableProperty implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [11] {
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+Class [ <internal:MapGuideApi> class MgInt32Property extends MgNullableProperty implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [11] {
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+Class [ <internal:MapGuideApi> class MgInt64Property extends MgNullableProperty implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [11] {
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgProperty> public method GetName ] {
+ Method [ <internal:MapGuideApi, inherits MgProperty> public method SetName ] {
+ - Return [ void ]
+Class [ <internal:MapGuideApi> class MgIntCollection extends MgCollection implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [15] {
+ - Return [ int ]
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetItem ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Add ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Insert ] {
+ - Return [ void ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Remove ] {
+ - Return [ bool ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Contains ] {
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgKmlService extends MgService implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [8] {
+ Method [ <internal:MapGuideApi> public method GetMapKml ] {
+ Parameter #0 [ <required> ?MgMap $arg1 ]
+ Method [ <internal:MapGuideApi> public method GetLayerKml ] {
+ - Parameters [8] {
+ Parameter #0 [ <required> ?MgLayer $arg1 ]
+ Parameter #1 [ <required> ?MgEnvelope $arg2 ]
+ Parameter #3 [ <required> int $arg4 ]
+ Parameter #4 [ <required> float $arg5 ]
+ Method [ <internal:MapGuideApi> public method GetFeaturesKml ] {
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgLayer extends MgLayerBase implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [41] {
+ Method [ <internal:MapGuideApi, overwrites MgLayerBase, ctor> public method __construct ] {
+ Parameter #1 [ <required> ?MgResourceService $arg2 ]
+ Method [ <internal:MapGuideApi, overwrites MgLayerBase, prototype MgLayerBase> public method GetClassDefinition ] {
+ Method [ <internal:MapGuideApi, overwrites MgLayerBase, prototype MgLayerBase> public method SelectFeatures ] {
+ Parameter #0 [ <required> ?MgFeatureQueryOptions $arg1 ]
+ Method [ <internal:MapGuideApi, overwrites MgLayerBase, prototype MgLayerBase> public method SelectAggregate ] {
+ Parameter #0 [ <required> ?MgFeatureAggregateOptions $arg1 ]
+ Method [ <internal:MapGuideApi, overwrites MgLayerBase, prototype MgLayerBase> public method BeginTransaction ] {
+ Method [ <internal:MapGuideApi, overwrites MgLayerBase, prototype MgLayerBase> public method UpdateFeatures ] {
+ Parameter #0 [ <required> ?MgFeatureCommandCollection $arg1 ]
+ Parameter #1 [ <required> ?MgTransaction $arg2 ]
+ Method [ <internal:MapGuideApi, overwrites MgLayerBase, prototype MgLayerBase> public method InsertFeatures ] {
+ Parameter #0 [ <required> MgBatchPropertyCollection|MgPropertyCollection|null $arg1 ]
+ Method [ <internal:MapGuideApi, overwrites MgLayerBase, prototype MgLayerBase> public method UpdateMatchingFeatures ] {
+ Parameter #0 [ <required> ?MgPropertyCollection $arg1 ]
+ Parameter #2 [ <required> ?MgTransaction $arg3 ]
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgLayerBase, prototype MgLayerBase> public method DeleteFeatures ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetGeometryTypeStyles ] {
+ Parameter #0 [ <required> float $arg1 ]
+ Method [ <internal:MapGuideApi> public method GetThemeCategoryCount ] {
+ Parameter #0 [ <required> int|float $arg1 ]
+ Parameter #1 [ <required> int $arg2 ]
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetCompositeThemeCategoryCount ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GenerateLegendImage ] {
+ Parameter #4 [ <required> int $arg5 ]
+ Parameter #5 [ <required> int $arg6 ]
+ Method [ <internal:MapGuideApi, overwrites MgLayerBase, prototype MgLayerBase> public method GetSpatialContexts ] {
+ Method [ <internal:MapGuideApi, overwrites MgLayerBase, prototype MgNamedSerializable> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgLayerBase, prototype MgNamedSerializable> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgLayerBase, prototype MgNamedSerializable> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method GetName ] {
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method SetName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method GetObjectId ] {
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method GetLayerType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method GetGroup ] {
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method SetGroup ] {
+ Parameter #0 [ <required> ?MgLayerGroup $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method NeedsRefresh ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method ForceRefresh ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method GetVisible ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method SetVisible ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method IsVisible ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method GetSelectable ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method SetSelectable ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method GetLayerDefinition ] {
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method SetLayerDefinition ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method GetDisplayInLegend ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method SetDisplayInLegend ] {
+ Parameter #0 [ <required> bool $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method GetExpandInLegend ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method GetLegendLabel ] {
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method SetLegendLabel ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method GetFeatureSourceId ] {
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method GetFeatureClassName ] {
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method GetFilter ] {
+ Method [ <internal:MapGuideApi, inherits MgLayerBase> public method GetFeatureGeometryName ] {
+Class [ <internal:MapGuideApi> class MgLayerBase extends MgNamedSerializable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [37] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetObjectId ] {
+ Method [ <internal:MapGuideApi> public method GetLayerType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetGroup ] {
+ Method [ <internal:MapGuideApi> public method SetGroup ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method NeedsRefresh ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method ForceRefresh ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetVisible ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method SetVisible ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsVisible ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetSelectable ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method SetSelectable ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetLayerDefinition ] {
+ Method [ <internal:MapGuideApi> public method SetLayerDefinition ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetDisplayInLegend ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method SetDisplayInLegend ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetExpandInLegend ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetLegendLabel ] {
+ Method [ <internal:MapGuideApi> public method SetLegendLabel ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetFeatureSourceId ] {
+ Method [ <internal:MapGuideApi> public method GetFeatureClassName ] {
+ Method [ <internal:MapGuideApi> public method GetFilter ] {
+ Method [ <internal:MapGuideApi> public method GetFeatureGeometryName ] {
+ Parameter #1 [ <required> $arg2 ]
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgLayerCollection extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [13] {
+ - Return [ int ]
+ Parameter #1 [ <required> ?MgLayerBase $arg2 ]
+ - Return [ void ]
+ Parameter #0 [ <required> ?MgLayerBase $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgLayerGroup extends MgNamedSerializable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [18] {
+ Method [ <internal:MapGuideApi> public method GetLayerGroupType ] {
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetExpandInLegend ] {
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgLayerGroupCollection extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [13] {
+ - Return [ int ]
+ Parameter #1 [ <required> ?MgLayerGroup $arg2 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgLayerGroupType implements SWIG\wrapped ] {
+ - Constants [3] {
+ Constant [ public int Normal ] { 1 }
+ Constant [ public int BaseMap ] { 2 }
+ Constant [ public int BaseMapFromTileSet ] { 3 }
+ - Methods [3] {
+ Method [ <internal:MapGuideApi> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method __get ] {
+ Method [ <internal:MapGuideApi> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgLayerType implements SWIG\wrapped ] {
+ - Constants [2] {
+ Constant [ public int Dynamic ] { 1 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgLayout implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [10] {
+ - Parameters [3] {
+ Parameter #0 [ <required> ?MgResourceIdentifier $arg1 ]
+ Parameter #2 [ <required> $arg3 ]
+ Method [ <internal:MapGuideApi> public method GetLayout ] {
+ Method [ <internal:MapGuideApi> public method SetLayout ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetTitle ] {
+ Method [ <internal:MapGuideApi> public method SetTitle ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetUnitType ] {
+ Method [ <internal:MapGuideApi> public method SetUnitType ] {
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgLineString extends MgCurve implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [36] {
+ Method [ <internal:MapGuideApi> public method GetCoordinates ] {
+ Method [ <internal:MapGuideApi, overwrites MgCurve, prototype MgCurve> public method GetStartCoordinate ] {
+ Method [ <internal:MapGuideApi, overwrites MgCurve, prototype MgCurve> public method GetEndCoordinate ] {
+ Method [ <internal:MapGuideApi, overwrites MgGeometry, prototype MgGeometry> public method GetGeometryType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method GetDimension ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method IsEmpty ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method IsClosed ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method Copy ] {
+ Method [ <internal:MapGuideApi, overwrites MgGeometricEntity, prototype MgGeometricEntity> public method Transform ] {
+ Parameter #0 [ <required> ?MgTransform $arg1 ]
+ Method [ <internal:MapGuideApi, overwrites MgCurve, prototype MgGeometricEntity> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgCurve, prototype MgGeometricEntity> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgCurve, prototype MgGeometricEntity> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Contains ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Crosses ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Disjoint ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Equals ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Intersects ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Overlaps ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Touches ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Within ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Boundary ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Buffer ] {
+ Parameter #1 [ <required> ?MgMeasure $arg2 ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method ConvexHull ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Difference ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Distance ] {
+ - Return [ float ]
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Intersection ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method SymetricDifference ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Union ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Prepare ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometry> public method Tessellate ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method IsSimple ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method IsValid ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method Envelope ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method GetArea ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method GetLength ] {
+ Method [ <internal:MapGuideApi, inherits MgGeometricEntity> public method GetCentroid ] {
+Class [ <internal:MapGuideApi> class MgLineStringCollection extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [14] {
+ - Return [ int ]
+ Parameter #1 [ <required> ?MgLineString $arg2 ]
+ - Return [ void ]
+ Parameter #0 [ <required> ?MgLineString $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgLinearRing extends MgRing implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [17] {
+ Method [ <internal:MapGuideApi, overwrites MgGeometryComponent, prototype MgGeometryComponent> public method GetComponentType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgRing, prototype MgRing> public method GetCoordinates ] {
+ - Return [ int ]
+ - Return [ bool ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, overwrites MgRing, prototype MgGeometricEntity> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgRing, prototype MgGeometricEntity> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgRing, prototype MgGeometricEntity> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgRing> public method GetPointInRing ] {
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgLinearRingCollection extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [14] {
+ - Return [ int ]
+ Parameter #1 [ <required> ?MgLinearRing $arg2 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgLinearSegment extends MgCurveSegment implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [18] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgCurveSegment, prototype MgCurveSegment> public method GetStartCoordinate ] {
+ Method [ <internal:MapGuideApi, overwrites MgCurveSegment, prototype MgCurveSegment> public method GetEndCoordinate ] {
+ - Return [ int ]
+ - Return [ bool ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, overwrites MgCurveSegment, prototype MgGeometricEntity> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgCurveSegment, prototype MgGeometricEntity> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgCurveSegment, prototype MgGeometricEntity> public method __isset ] {
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgLogFileType implements SWIG\wrapped ] {
+ - Constants [6] {
+ Constant [ public string Access ] { AccessLog }
+ Constant [ public string Admin ] { AdminLog }
+ Constant [ public string Authentication ] { AuthenticationLog }
+ Constant [ public string Error ] { ErrorLog }
+ Constant [ public string Session ] { SessionLog }
+ Constant [ public string Trace ] { TraceLog }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgLongTransactionReader implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [14] {
+ Method [ <internal:MapGuideApi> public method GetChildren ] {
+ Method [ <internal:MapGuideApi> public method GetParents ] {
+ Method [ <internal:MapGuideApi> public method GetOwner ] {
+ Method [ <internal:MapGuideApi> public method GetCreationDate ] {
+ Method [ <internal:MapGuideApi> public method IsActive ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IsFrozen ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method ReadNext ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method Close ] {
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgMap extends MgMapBase implements SWIG\wrapped ] {
+ - Constants [2] {
+ Constant [ public int WMS ] { 1 }
+ Constant [ public int Viewer ] { 2 }
+ - Methods [31] {
+ Method [ <internal:MapGuideApi, overwrites MgMapBase, ctor> public method __construct ] {
+ Parameter #0 [ <required> ?MgSiteConnection $arg1 ]
+ Method [ <internal:MapGuideApi, overwrites MgMapBase, prototype MgMapBase> public method Create ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method CreateStateless ] {
+ Parameter #2 [ <required> int $arg3 ]
+ Parameter #5 [ <required> float $arg6 ]
+ Parameter #6 [ <required> float $arg7 ]
+ Parameter #7 [ <required> int $arg8 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Open ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method Save ] {
+ Parameter #0 [ <optional> ?MgResourceService $arg1 = <default> ]
+ Parameter #1 [ <optional> ?MgResourceIdentifier $arg2 = <default> ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetWatermarkUsage ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetTileSetDefinition ] {
+ Method [ <internal:MapGuideApi> public method GetTileSetProvider ] {
+ Method [ <internal:MapGuideApi> public method GetTilePixelRatio ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetTileFormat ] {
+ Method [ <internal:MapGuideApi, overwrites MgMapBase, prototype MgMapBase> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgMapBase, prototype MgMapBase> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgMapBase, prototype MgMapBase> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method GetName ] {
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method GetSessionId ] {
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method GetObjectId ] {
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method GetMapDefinition ] {
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method GetMapSRS ] {
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method GetMapExtent ] {
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method GetLayers ] {
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method GetLayerGroups ] {
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method GetViewCenter ] {
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method GetViewScale ] {
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method GetDataExtent ] {
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method GetDisplayDpi ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method SetDisplayDpi ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method GetDisplayWidth ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method GetDisplayHeight ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method GetFiniteDisplayScaleCount ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method GetFiniteDisplayScaleAt ] {
+ Method [ <internal:MapGuideApi, inherits MgMapBase> public method GetBackgroundColor ] {
+Class [ <internal:MapGuideApi> class MgMapBase implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [23] {
+ Method [ <internal:MapGuideApi> public method GetSessionId ] {
+ Method [ <internal:MapGuideApi> public method GetMapDefinition ] {
+ Method [ <internal:MapGuideApi> public method GetMapSRS ] {
+ Method [ <internal:MapGuideApi> public method GetMapExtent ] {
+ Method [ <internal:MapGuideApi> public method GetLayers ] {
+ Method [ <internal:MapGuideApi> public method GetLayerGroups ] {
+ Method [ <internal:MapGuideApi> public method Create ] {
+ Parameter #1 [ <required> MgEnvelope|MgResourceIdentifier|null $arg2 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetViewCenter ] {
+ Method [ <internal:MapGuideApi> public method GetViewScale ] {
+ Method [ <internal:MapGuideApi> public method GetDataExtent ] {
+ Method [ <internal:MapGuideApi> public method GetDisplayDpi ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetDisplayDpi ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetDisplayWidth ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetDisplayHeight ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetFiniteDisplayScaleCount ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetFiniteDisplayScaleAt ] {
+ Method [ <internal:MapGuideApi> public method GetBackgroundColor ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgMapCollection extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [14] {
+ - Return [ int ]
+ Parameter #1 [ <required> ?MgMapBase $arg2 ]
+ - Return [ void ]
+ Parameter #0 [ <required> ?MgMapBase $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgMapPlot extends MgNamedSerializable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [18] {
+ Parameter #1 [ <required> MgCoordinate|MgEnvelope|MgPlotSpecification|null $arg2 ]
+ Parameter #2 [ <required> MgLayout|float|bool|null $arg3 ]
+ Parameter #3 [ <required> ?MgPlotSpecification $arg4 ]
+ Parameter #4 [ <required> ?MgLayout $arg5 ]
+ Method [ <internal:MapGuideApi> public method GetMap ] {
+ Method [ <internal:MapGuideApi> public method SetMap ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetMapPlotInstruction ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetMapPlotInstruction ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetCenter ] {
+ Method [ <internal:MapGuideApi> public method GetScale ] {
+ Method [ <internal:MapGuideApi> public method SetCenterAndScale ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetExtent ] {
+ Method [ <internal:MapGuideApi> public method GetExpandToFit ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method SetExtent ] {
+ Parameter #0 [ <required> ?MgEnvelope $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetPlotSpecification ] {
+ Method [ <internal:MapGuideApi> public method SetPlotSpecification ] {
+ Parameter #0 [ <required> ?MgPlotSpecification $arg1 ]
+ - Return [ void ]
+ Parameter #0 [ <required> ?MgLayout $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgMapPlotCollection implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [14] {
+ - Return [ int ]
+ Parameter #1 [ <required> ?MgMapPlot $arg2 ]
+ - Return [ void ]
+ Parameter #0 [ <required> ?MgMapPlot $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ int ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgMapPlotInstruction implements SWIG\wrapped ] {
+ - Constants [3] {
+ Constant [ public int UseMapCenterAndScale ] { 0 }
+ Constant [ public int UseOverriddenCenterAndScale ] { 1 }
+ Constant [ public int UseOverriddenExtent ] { 2 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgMappingService extends MgService implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [11] {
+ Method [ <internal:MapGuideApi> public method GeneratePlot ] {
+ Parameter #3 [ <required> MgDwfVersion|MgPlotSpecification|null $arg4 ]
+ Parameter #5 [ <required> ?MgDwfVersion $arg6 ]
+ Method [ <internal:MapGuideApi> public method GenerateMultiPlot ] {
+ Parameter #0 [ <required> ?MgMapPlotCollection $arg1 ]
+ Parameter #1 [ <required> ?MgDwfVersion $arg2 ]
+ - Parameters [7] {
+ Parameter #6 [ <required> int $arg7 ]
+ Method [ <internal:MapGuideApi> public method CreateRuntimeMap ] {
+ Parameter #3 [ <required> $arg4 ]
+ Method [ <internal:MapGuideApi> public method DescribeRuntimeMap ] {
+ Method [ <internal:MapGuideApi> public method QueryFeatures ] {
+ Method [ <internal:MapGuideApi, overwrites MgService, prototype MgObject> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgService, prototype MgObject> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgService, prototype MgObject> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgService> public method HasWarnings ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgService> public method GetWarningsObject ] {
+Class [ <internal:MapGuideApi> class MgMeasure extends MgGuardDisposable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [6] {
+ Method [ <internal:MapGuideApi> public method GetDistance ] {
+ Method [ <internal:MapGuideApi> public method GetAzimuth ] {
+ Method [ <internal:MapGuideApi> public method GetCoordinate ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgMetatile implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [10] {
+ Method [ <internal:MapGuideApi> public method GetImage ] {
+ Method [ <internal:MapGuideApi> public method GetRequestedWidth ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetRequestedHeight ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetWidth ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetHeight ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetMetaTilingFactor ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetTileImageFormat ] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgMimeType implements SWIG\wrapped ] {
+ - Constants [14] {
+ Constant [ public string Agf ] { application/agf }
+ Constant [ public string Binary ] { application/octet-stream }
+ Constant [ public string Dwf ] { model/vnd.dwf }
+ Constant [ public string Gif ] { image/gif }
+ Constant [ public string Jpeg ] { image/jpeg }
+ Constant [ public string Png ] { image/png }
+ Constant [ public string Text ] { text/plain }
+ Constant [ public string Tiff ] { image/tiff }
+ Constant [ public string Xml ] { text/xml }
+ Constant [ public string Json ] { application/json }
+ Constant [ public string Html ] { text/html }
+ Constant [ public string Kml ] { application/vnd.google-earth.kml+xml }
+ Constant [ public string Kmz ] { application/vnd.google-earth.kmz }
+ Constant [ public string Meta ] { application/metatile }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgMultiCurvePolygon extends MgAggregateGeometry implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [35] {
+ Method [ <internal:MapGuideApi, overwrites MgAggregateGeometry, prototype MgAggregateGeometry> public method GetCount ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetCurvePolygon ] {
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ bool ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, overwrites MgAggregateGeometry, prototype MgGeometricEntity> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgAggregateGeometry, prototype MgGeometricEntity> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgAggregateGeometry, prototype MgGeometricEntity> public method __isset ] {
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgMultiCurveString extends MgAggregateGeometry implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [35] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetCurveString ] {
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgMultiGeometry extends MgAggregateGeometry implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [35] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetGeometry ] {
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgMultiLineString extends MgAggregateGeometry implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [35] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetLineString ] {
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgMultiPoint extends MgAggregateGeometry implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [35] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetPoint ] {
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgMultiPolygon extends MgAggregateGeometry implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [36] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetPolygon ] {
+ - Return [ int ]
+ - Return [ int ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ void ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgNamedSerializable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgNullableProperty extends MgProperty implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [8] {
+ Method [ <internal:MapGuideApi> public method SetNull ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method IsNull ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, overwrites MgProperty, prototype MgNamedSerializable> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgProperty, prototype MgNamedSerializable> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgProperty, prototype MgNamedSerializable> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgProperty> public method GetPropertyType ] {
+ - Return [ int ]
+ - Return [ void ]
+Class [ <internal:MapGuideApi> class MgObject implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgObjectPropertyDefinition extends MgPropertyDefinition implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [20] {
+ Method [ <internal:MapGuideApi, overwrites MgPropertyDefinition, ctor> public method __construct ] {
+ Method [ <internal:MapGuideApi> public method GetClassDefinition ] {
+ Method [ <internal:MapGuideApi> public method GetObjectType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetOrderType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetIdentityProperty ] {
+ Method [ <internal:MapGuideApi> public method SetClassDefinition ] {
+ Parameter #0 [ <required> ?MgClassDefinition $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetObjectType ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetOrderType ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method SetIdentityProperty ] {
+ Parameter #0 [ <required> ?MgDataPropertyDefinition $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgPropertyDefinition, prototype MgNamedSerializable> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgPropertyDefinition, prototype MgNamedSerializable> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgPropertyDefinition, prototype MgNamedSerializable> public method __isset ] {
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi, inherits MgPropertyDefinition, prototype MgProperty> public method GetPropertyType ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, inherits MgPropertyDefinition> public method SetDescription ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgPropertyDefinition> public method GetDescription ] {
+ Method [ <internal:MapGuideApi, inherits MgPropertyDefinition> public method SetQualifiedName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, inherits MgPropertyDefinition> public method GetQualifiedName ] {
+ Method [ <internal:MapGuideApi, inherits MgPropertyDefinition> public method Delete ] {
+ - Return [ void ]
+ - Return [ void ]
+Class [ <internal:MapGuideApi> class MgObjectPropertyType implements SWIG\wrapped ] {
+ - Constants [3] {
+ Constant [ public int Value ] { 0 }
+ Constant [ public int Collection ] { 1 }
+ Constant [ public int OrderedCollection ] { 2 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgOrderingOption implements SWIG\wrapped ] {
+ - Constants [2] {
+ Constant [ public int Ascending ] { 0 }
+ Constant [ public int Descending ] { 1 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgPackageStatusInformation implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [36] {
+ Method [ <internal:MapGuideApi> public method GetStatusMessage ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetApiName ] {
+ Method [ <internal:MapGuideApi> public method SetApiName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetPackageName ] {
+ Method [ <internal:MapGuideApi> public method SetPackageName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetPackageDescription ] {
+ Method [ <internal:MapGuideApi> public method SetPackageDescription ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetPackageDate ] {
+ Method [ <internal:MapGuideApi> public method SetPackageDate ] {
+ Parameter #0 [ <required> ?MgDateTime $arg1 ]
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetPackageSize ] {
+ Method [ <internal:MapGuideApi> public method SetPackageSize ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetUserName ] {
+ Method [ <internal:MapGuideApi> public method SetUserName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetServerName ] {
+ Method [ <internal:MapGuideApi> public method SetServerName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetServerAddress ] {
+ Method [ <internal:MapGuideApi> public method SetServerAddress ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetStartTime ] {
+ Method [ <internal:MapGuideApi> public method SetStartTime ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetEndTime ] {
+ Method [ <internal:MapGuideApi> public method SetEndTime ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetOperationsFailed ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetOperationsFailed ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetOperationsReceived ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method SetOperationsReceived ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetAverageOperationTime ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetStackTrace ] {
+ Method [ <internal:MapGuideApi> public method SetStackTrace ] {
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgPageUnitsType implements SWIG\wrapped ] {
+ - Constants [2] {
+ Constant [ public string Inches ] { in }
+ Constant [ public string Millimeters ] { mm }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgParameter extends MgNamedSerializable implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [10] {
+ Parameter #0 [ <required> ?MgNullableProperty $arg1 ]
+ Method [ <internal:MapGuideApi> public method SetProperty ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetProperty ] {
+ Method [ <internal:MapGuideApi> public method SetDirection ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetDirection ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi> public method GetName ] {
+ Method [ <internal:MapGuideApi> public method SetName ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgNamedSerializable, prototype MgNamedSerializable> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgNamedSerializable, prototype MgNamedSerializable> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgNamedSerializable, prototype MgNamedSerializable> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgParameterCollection extends MgCollection implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [15] {
+ Parameter #1 [ <required> ?MgParameter $arg2 ]
+ - Return [ void ]
+ Parameter #0 [ <required> ?MgParameter $arg1 ]
+ - Return [ void ]
+ - Return [ void ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method GetItem ] {
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method GetCount ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method Clear ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method RemoveAt ] {
+ - Return [ void ]
+ - Return [ bool ]
+ Method [ <internal:MapGuideApi> public method IndexOf ] {
+ - Return [ int ]
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method ToXml ] {
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method __set ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method __get ] {
+ Method [ <internal:MapGuideApi, overwrites MgCollection, prototype MgCollection> public method __isset ] {
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgParameterDirection implements SWIG\wrapped ] {
+ - Constants [4] {
+ Constant [ public int Input ] { 0 }
+ Constant [ public int Output ] { 1 }
+ Constant [ public int InputOutput ] { 2 }
+ Constant [ public int Ret ] { 3 }
+ - Methods [3] {
+ - Return [ void ]
+ - Return [ bool ]
+Class [ <internal:MapGuideApi> class MgPlotSpecification implements SWIG\wrapped ] {
+ - Constants [0] {
+ - Methods [15] {
+ Method [ <internal:MapGuideApi> public method GetPaperWidth ] {
+ Method [ <internal:MapGuideApi> public method SetPaperWidth ] {
+ - Return [ void ]
+ Method [ <internal:MapGuideApi> public method GetPaperHeight ] {
