[mapguide-commits] r10137 - branches/4.0/MgDev
    svn_mapguide at osgeo.org
    Mon May  5 04:31:23 PDT 2025
Author: jng
Date: 2025-05-05 04:31:21 -0700 (Mon, 05 May 2025)
New Revision: 10137
   branches/4.0/MgDev/build.bat
Copy snapshot scripts as part of "install"
Modified: branches/4.0/MgDev/build.bat
--- branches/4.0/MgDev/build.bat	2025-05-05 10:48:18 UTC (rev 10136)
+++ branches/4.0/MgDev/build.bat	2025-05-05 11:31:21 UTC (rev 10137)
@@ -75,6 +75,7 @@
 SET MG_OUTPUT_WEB=%MG_OUTPUT%\Web
 SET MG_OUTPUT_CSMAP=%MG_OUTPUT%\CS-Map
 SET MG_OUTPUT_TEST=%MG_OUTPUT%\Test
+SET MG_OUTPUT_SNAPSHOT=%MG_OUTPUT%\Snapshot
 goto next_param
 :get_action
@@ -483,6 +484,11 @@
 copy /Y "%MG_UNIT_TEST%\test_readme.txt" "%MG_OUTPUT_TEST%"
 copy /Y "%MG_UNIT_TEST%\run_server_tests.bat" "%MG_OUTPUT_TEST%"
 copy /Y "%MG_UNIT_TEST%\run_web_tests.bat" "%MG_OUTPUT_TEST%"
+echo [install]: Snapshot scripts
+%XCOPY% "Bindings\src\ApiDump\*.ps1" "%MG_OUTPUT_SNAPSHOT%"
+%XCOPY% "Bindings\src\ApiDump\*.php" "%MG_OUTPUT_SNAPSHOT%"
+%XCOPY% "Bindings\src\ApiDump\*.bat" "%MG_OUTPUT_SNAPSHOT%"
+copy /Y "Bindings\src\ApiDump\README.txt" "%MG_OUTPUT_SNAPSHOT%"
 goto quit
 :error
More information about the mapguide-commits
