[mapguide-commits] r10140 - in branches/4.0/MgDev: . Oem/LinuxApt
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon May 5 05:45:31 PDT 2025
Author: jng
Date: 2025-05-05 05:45:30 -0700 (Mon, 05 May 2025)
New Revision: 10140
Added:
   branches/4.0/MgDev/Oem/LinuxApt/apache-tomcat-9.0.104.tar.gz
   branches/4.0/MgDev/Oem/LinuxApt/apr-1.7.5.tar.bz2
   branches/4.0/MgDev/Oem/LinuxApt/httpd-2.4.63.tar.bz2
   branches/4.0/MgDev/Oem/LinuxApt/php-8.3.20.tar.bz2
   branches/4.0/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.50-src.tar.gz
Removed:
   branches/4.0/MgDev/Oem/LinuxApt/apache-tomcat-9.0.89.tar.gz
   branches/4.0/MgDev/Oem/LinuxApt/apr-1.7.4.tar.bz2
   branches/4.0/MgDev/Oem/LinuxApt/httpd-2.4.62.tar.bz2
   branches/4.0/MgDev/Oem/LinuxApt/php-8.1.29.tar.bz2
   branches/4.0/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.49-src.tar.gz
   branches/4.0/MgDev/Oem/LinuxApt/CMakeLists.txt
   branches/4.0/MgDev/cmake_linuxapt.sh
   branches/4.0/MgDev/prepare_webtier_components.bat
#2885: Web Tier component updates
  * httpd 2.4.62 -> 2.4.63
  * php 8.1.29 -> 8.3.20
  * apr 1.7.4 -> 1.7.5
  * tomcat 9.0.89 -> 9.0.104
  * tomcat-connectors 1.2.49 -> 1.2.50
Modified: branches/4.0/MgDev/Oem/LinuxApt/CMakeLists.txt
--- branches/4.0/MgDev/Oem/LinuxApt/CMakeLists.txt	2025-05-05 12:41:13 UTC (rev 10139)
+++ branches/4.0/MgDev/Oem/LinuxApt/CMakeLists.txt	2025-05-05 12:45:30 UTC (rev 10140)
@@ -20,7 +20,7 @@
     file(MAKE_DIRECTORY ${CMAKE_CURRENT_BINARY_DIR}/tomcat)
     # TODO: Offload tomcat version to top-level var
-    execute_process(COMMAND tar -zxf ${CMAKE_CURRENT_SOURCE_DIR}/apache-tomcat-9.0.89.tar.gz -C ${CMAKE_CURRENT_BINARY_DIR}/tomcat --strip-components=1)
+    execute_process(COMMAND tar -zxf ${CMAKE_CURRENT_SOURCE_DIR}/apache-tomcat-9.0.104.tar.gz -C ${CMAKE_CURRENT_BINARY_DIR}/tomcat --strip-components=1)
     configure_file(${CMAKE_MODULE_PATH}/../configs/mapguide.xml.in ${CMAKE_CURRENT_BINARY_DIR}/tomcat/conf/Catalina/localhost/mapguide.xml)
     # Don't overwrite startup.sh in the CMAKE_CURRENT_BINARY_DIR as the subseqent install will do the same thing
Added: branches/4.0/MgDev/Oem/LinuxApt/apache-tomcat-9.0.104.tar.gz
(Binary files differ)
Index: branches/4.0/MgDev/Oem/LinuxApt/apache-tomcat-9.0.104.tar.gz
--- branches/4.0/MgDev/Oem/LinuxApt/apache-tomcat-9.0.104.tar.gz	2025-05-05 12:41:13 UTC (rev 10139)
+++ branches/4.0/MgDev/Oem/LinuxApt/apache-tomcat-9.0.104.tar.gz	2025-05-05 12:45:30 UTC (rev 10140)
Property changes on: branches/4.0/MgDev/Oem/LinuxApt/apache-tomcat-9.0.104.tar.gz
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+application/octet-stream
\ No newline at end of property
Deleted: branches/4.0/MgDev/Oem/LinuxApt/apache-tomcat-9.0.89.tar.gz
Deleted: branches/4.0/MgDev/Oem/LinuxApt/apr-1.7.4.tar.bz2
Added: branches/4.0/MgDev/Oem/LinuxApt/apr-1.7.5.tar.bz2
Index: branches/4.0/MgDev/Oem/LinuxApt/apr-1.7.5.tar.bz2
--- branches/4.0/MgDev/Oem/LinuxApt/apr-1.7.5.tar.bz2	2025-05-05 12:41:13 UTC (rev 10139)
+++ branches/4.0/MgDev/Oem/LinuxApt/apr-1.7.5.tar.bz2	2025-05-05 12:45:30 UTC (rev 10140)
Property changes on: branches/4.0/MgDev/Oem/LinuxApt/apr-1.7.5.tar.bz2
## -0,0 +1 ##
Deleted: branches/4.0/MgDev/Oem/LinuxApt/httpd-2.4.62.tar.bz2
Added: branches/4.0/MgDev/Oem/LinuxApt/httpd-2.4.63.tar.bz2
Index: branches/4.0/MgDev/Oem/LinuxApt/httpd-2.4.63.tar.bz2
--- branches/4.0/MgDev/Oem/LinuxApt/httpd-2.4.63.tar.bz2	2025-05-05 12:41:13 UTC (rev 10139)
+++ branches/4.0/MgDev/Oem/LinuxApt/httpd-2.4.63.tar.bz2	2025-05-05 12:45:30 UTC (rev 10140)
Property changes on: branches/4.0/MgDev/Oem/LinuxApt/httpd-2.4.63.tar.bz2
## -0,0 +1 ##
Deleted: branches/4.0/MgDev/Oem/LinuxApt/php-8.1.29.tar.bz2
Added: branches/4.0/MgDev/Oem/LinuxApt/php-8.3.20.tar.bz2
Index: branches/4.0/MgDev/Oem/LinuxApt/php-8.3.20.tar.bz2
--- branches/4.0/MgDev/Oem/LinuxApt/php-8.3.20.tar.bz2	2025-05-05 12:41:13 UTC (rev 10139)
+++ branches/4.0/MgDev/Oem/LinuxApt/php-8.3.20.tar.bz2	2025-05-05 12:45:30 UTC (rev 10140)
Property changes on: branches/4.0/MgDev/Oem/LinuxApt/php-8.3.20.tar.bz2
## -0,0 +1 ##
Deleted: branches/4.0/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.49-src.tar.gz
Added: branches/4.0/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.50-src.tar.gz
Index: branches/4.0/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.50-src.tar.gz
--- branches/4.0/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.50-src.tar.gz	2025-05-05 12:41:13 UTC (rev 10139)
+++ branches/4.0/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.50-src.tar.gz	2025-05-05 12:45:30 UTC (rev 10140)
Property changes on: branches/4.0/MgDev/Oem/LinuxApt/tomcat-connectors-1.2.50-src.tar.gz
## -0,0 +1 ##
Modified: branches/4.0/MgDev/cmake_linuxapt.sh
--- branches/4.0/MgDev/cmake_linuxapt.sh	2025-05-05 12:41:13 UTC (rev 10139)
+++ branches/4.0/MgDev/cmake_linuxapt.sh	2025-05-05 12:45:30 UTC (rev 10140)
@@ -123,10 +123,10 @@
     echo "Created LinuxApt working dir at: $LINUXAPT_WORK_DIR"
 fi
-PHP_VER=8.1.29
-HTTPD_VER=2.4.62
-TC_VER=1.2.49
-APR_VER=1.7.4
+PHP_VER=8.3.20
+HTTPD_VER=2.4.63
+TC_VER=1.2.50
+APR_VER=1.7.5
 APR_UTIL_VER=1.6.3
 HTTPD_PORT=8008
Modified: branches/4.0/MgDev/prepare_webtier_components.bat
--- branches/4.0/MgDev/prepare_webtier_components.bat	2025-05-05 12:41:13 UTC (rev 10139)
+++ branches/4.0/MgDev/prepare_webtier_components.bat	2025-05-05 12:45:30 UTC (rev 10140)
@@ -1,6 +1,6 @@
 @echo off
 SET SEVENZ=%CD%\BuildTools\WebTools\7-zip\7z.exe
-SET HTTPD_VER=2.4.62
+SET HTTPD_VER=2.4.63
 pushd Oem\LinuxApt
 :check_httpd
 if not exist httpd-%HTTPD_VER% goto unpack_httpd
More information about the mapguide-commits mailing list
