[mapguide-commits] r10198 - in branches/4.0/MgDev: Bindings/src/IMake Common/MapGuideCommon/MapLayer Common/MapGuideCommon/Services
svn_mapguide at osgeo.org
Fri Oct 3 09:21:16 PDT 2025
Author: jng
Date: 2025-10-03 09:21:15 -0700 (Fri, 03 Oct 2025)
New Revision: 10198
branches/4.0/MgDev/Bindings/src/IMake/IMake.cpp
branches/4.0/MgDev/Common/MapGuideCommon/MapLayer/Layer.h
branches/4.0/MgDev/Common/MapGuideCommon/MapLayer/Map.h
branches/4.0/MgDev/Common/MapGuideCommon/Services/RenderingService.h
branches/4.0/MgDev/Common/MapGuideCommon/Services/TileService.h
IMake: Fix up <exception> doc generation so that it emits MgException with code MgExceptionCodes.code_name format
Also fix up invalid parameter references in various docs.
Modified: branches/4.0/MgDev/Bindings/src/IMake/IMake.cpp
--- branches/4.0/MgDev/Bindings/src/IMake/IMake.cpp 2025-09-28 15:44:55 UTC (rev 10197)
+++ branches/4.0/MgDev/Bindings/src/IMake/IMake.cpp 2025-10-03 16:21:15 UTC (rev 10198)
@@ -702,7 +702,7 @@
output.append(".MgException");
output.append("\" /> with code <see cref=\"");
output.append(nspace);
- output.append("MgExceptionCodes.");
+ output.append(".MgExceptionCodes.");
output.append(mgClassName);
output.append("\" />");
@@ -1216,22 +1216,12 @@
csharpDoc.append("///<exception cref=\"");
csharpDoc.append(nspace);
csharpDoc.append(".MgException\">");
- if (eelems.size() > 1) {
- csharpDoc.append("with code (<see cref=\"");
- csharpDoc.append(nspace);
- csharpDoc.append(".MgExceptionCodes.");
- csharpDoc.append(eelems[0]);
- csharpDoc.append("\" />) ");
- for (size_t j = 1; j < eelems.size(); j++) {
- csharpDoc.append(" ");
- csharpDoc.append(eelems[j]);
- csharpDoc.append("</exception>\n");
- else {
- csharpDoc.append("\"></exception>\n");
+ csharpDoc.append("with code (<see cref=\"");
+ csharpDoc.append(nspace);
+ csharpDoc.append(".MgExceptionCodes.");
+ csharpDoc.append(eelems[0]);
+ csharpDoc.append("\" />) ");
+ csharpDoc.append("</exception>\n");
Modified: branches/4.0/MgDev/Common/MapGuideCommon/MapLayer/Layer.h
--- branches/4.0/MgDev/Common/MapGuideCommon/MapLayer/Layer.h 2025-09-28 15:44:55 UTC (rev 10197)
+++ branches/4.0/MgDev/Common/MapGuideCommon/MapLayer/Layer.h 2025-10-03 16:21:15 UTC (rev 10198)
@@ -583,12 +583,6 @@
/// virtual MgByteReader GenerateLegendImage(int width, int height, string format, int geomType, int themeCategory);
/// \htmlinclude SyntaxBottom.html
- /// \param resource (MgResourceIdentifier)
- /// Input
- /// MgResourceIdentifier object identifying the layer definition resource.
- /// \param scale (double)
- /// Input
- /// The scale at which the symbolization is requested.
/// \param width (int)
/// Input
/// The requested image width in pixels.
@@ -722,9 +716,6 @@
/// virtual MgByteReader GenerateLegendImage(double scale, int width, int height, string format, int geomType, int themeCategory);
- /// Input
/// Input
Modified: branches/4.0/MgDev/Common/MapGuideCommon/MapLayer/Map.h
--- branches/4.0/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2025-09-28 15:44:55 UTC (rev 10197)
+++ branches/4.0/MgDev/Common/MapGuideCommon/MapLayer/Map.h 2025-10-03 16:21:15 UTC (rev 10198)
@@ -404,7 +404,7 @@
/// \endcode
/// \htmlinclude ExampleBottom.html
- virtual void Create(MgResourceIdentifier* resource, CREFSTRING mapName, INT32 displayWidth, INT32 displayheight, double x, double y, double scale, INT32 dpi);
+ virtual void Create(MgResourceIdentifier* resource, CREFSTRING mapName, INT32 displayWidth, INT32 displayHeight, double x, double y, double scale, INT32 dpi);
/// \brief
Modified: branches/4.0/MgDev/Common/MapGuideCommon/Services/RenderingService.h
--- branches/4.0/MgDev/Common/MapGuideCommon/Services/RenderingService.h 2025-09-28 15:44:55 UTC (rev 10197)
+++ branches/4.0/MgDev/Common/MapGuideCommon/Services/RenderingService.h 2025-10-03 16:21:15 UTC (rev 10198)
@@ -320,9 +320,6 @@
/// \param dpi
/// Input
/// Specifies the dpi of the tile to return.
- /// \param tileImageFormat
- /// Input
- /// Specifies the image format of the tile to return.
/// \return
/// A byte reader containing the rendered tile image.
@@ -513,6 +510,9 @@
/// \param bClip
/// Input
/// true if you want to clip feature geometry
+ /// \param selectionColor
+ /// Input
+ /// The color to use for rendered selections
/// \return
/// A byte reader containing the rendered image
Modified: branches/4.0/MgDev/Common/MapGuideCommon/Services/TileService.h
--- branches/4.0/MgDev/Common/MapGuideCommon/Services/TileService.h 2025-09-28 15:44:55 UTC (rev 10197)
+++ branches/4.0/MgDev/Common/MapGuideCommon/Services/TileService.h 2025-10-03 16:21:15 UTC (rev 10198)
@@ -112,9 +112,9 @@
/// Clears the entire tile cache for the given tile set. Tiles for all base
/// map layer groups and finite scales will be removed.
- /// \param map
+ /// \param tileSet
/// Input
- /// Specifies the map whose tile cache will be cleared.
+ /// Specifies the tile set whose tile cache will be cleared.
/// \since 3.0
virtual void ClearCache(MgResourceIdentifier* tileSet) = 0;
More information about the mapguide-commits
