[mapguide-commits] r10193 - in branches/4.0/MgDev: Common/Geometry Common/Geometry/CoordinateSystem Common/PlatformBase/MapLayer Common/PlatformBase/Services Portable/MgPortable/Services
svn_mapguide at osgeo.org
Fri Sep 12 06:40:09 PDT 2025
Author: jng
Date: 2025-09-12 06:40:08 -0700 (Fri, 12 Sep 2025)
New Revision: 10193
branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemDatum.h
branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemEnum.h
branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemEnumInteger32.h
branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemFilter.h
branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemFilterInteger32.h
branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemFormatConverter.h
branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemUnitInformation.h
branches/4.0/MgDev/Common/Geometry/CoordinateXY.h
branches/4.0/MgDev/Common/Geometry/CoordinateXYM.h
branches/4.0/MgDev/Common/Geometry/CoordinateXYZ.h
branches/4.0/MgDev/Common/Geometry/CoordinateXYZM.h
branches/4.0/MgDev/Common/Geometry/CurvePolygon.h
branches/4.0/MgDev/Common/Geometry/CurveRing.h
branches/4.0/MgDev/Common/Geometry/CurveString.h
branches/4.0/MgDev/Common/Geometry/Geometry.h
branches/4.0/MgDev/Common/Geometry/LineString.h
branches/4.0/MgDev/Common/Geometry/LinearRing.h
branches/4.0/MgDev/Common/Geometry/LinearSegment.h
branches/4.0/MgDev/Common/Geometry/MultiCurvePolygon.h
branches/4.0/MgDev/Common/Geometry/MultiCurveString.h
branches/4.0/MgDev/Common/Geometry/MultiGeometry.h
branches/4.0/MgDev/Common/Geometry/MultiLineString.h
branches/4.0/MgDev/Common/Geometry/MultiPoint.h
branches/4.0/MgDev/Common/Geometry/MultiPolygon.h
branches/4.0/MgDev/Common/Geometry/Point.h
branches/4.0/MgDev/Common/Geometry/Polygon.h
branches/4.0/MgDev/Common/Geometry/Ring.h
branches/4.0/MgDev/Common/PlatformBase/MapLayer/SelectionBase.h
branches/4.0/MgDev/Common/PlatformBase/Services/FeatureSpatialOperations.h
branches/4.0/MgDev/Common/PlatformBase/Services/Raster.h
branches/4.0/MgDev/Portable/MgPortable/Services/FeatureService.h
API doc sweep on parts of Geometry, PlatformBase and MgPortable APIs
Modified: branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemDatum.h
--- branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemDatum.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemDatum.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -21,6 +21,10 @@
class MgCoordinateSystemEllipsoid;
class MgCoordinateSystemGeodeticTransformation;
+/// \brief
+/// Describes a coordinate system datum
class MgCoordinateSystemDatum : public MgGuardDisposable
DECLARE_CLASSNAME(MgCoordinateSystemDatum)
@@ -68,7 +72,41 @@
/// true if this datum is valid. false otherwise
virtual bool IsValid()=0;
+ /// \brief
+ /// Gets whether the def is usable in the context of the given catalog. The
+ /// IsValid() function, above, simply checks the def for internal validity in
+ /// its own right. This function, on the other hand, checks for other
+ /// conditions such as unresolved references and so forth which can only be
+ /// evaluated in a larger context. For example, a datum definition may specify
+ /// that it uses ellipsoid "FOO", which is a perfectly legitimate ellipsoid
+ /// name, so IsValid() would return true; but unless there is in fact an
+ /// ellipsoid "FOO" present in the catalog where we try to use the datum, it
+ /// can't be used and IsUsable() would return false. Note that this function
+ /// will always return false if IsValid() returns false.
+ /// \return
+ /// true if this datum is usable. false otherwise
virtual bool IsUsable(MgCoordinateSystemCatalog *pCatalog)=0;
+ /// \brief
+ /// \return
virtual bool IsSameAs(MgGuardDisposable *pDef)=0;
@@ -180,7 +218,27 @@
/// true if this datum is protected. false otherwise
virtual bool IsProtected()=0;
+ /// \brief
+ /// Gets the age of the item, in days since last modification, if it's a
+ /// user-defined item (i.e., isn't marked as protected).
+ /// \return
+ /// The age of this item. If it's read-only, then returns -1.
virtual INT16 GetAge()=0;
+ /// \brief
+ /// Sets whether this item is protected or not. When protected,
+ /// methods which attempt to modify the object will
+ /// Throws an exception. (Except for SetProtectMode and SetEncryptMode,
+ /// which can be called even on protected objects.)
+ /// \param bIsProtected (boolean/bool)
+ /// The proection flag
virtual void SetProtectMode(bool bIsProtected)=0;
@@ -191,6 +249,14 @@
/// true if this datum is encrypted. false otherwise
virtual bool IsEncrypted()=0;
+ /// \brief
+ /// Sets whether this item is encrypted or not
+ /// \param bIsEncrypted (boolean/bool)
+ /// The encryption flag
virtual void SetEncryptMode(bool bIsEncrypted)=0;
Modified: branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemEnum.h
--- branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemEnum.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemEnum.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -18,6 +18,10 @@
#ifndef _MGCOORDINATESYSTEMENUM_H_
#define _MGCOORDINATESYSTEMENUM_H_
+/// \brief
+/// Enumerates coordinate systems
class MgCoordinateSystemEnum : public MgGuardDisposable
DECLARE_CLASSNAME(MgCoordinateSystemEnum)
Modified: branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemEnumInteger32.h
--- branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemEnumInteger32.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemEnumInteger32.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -19,6 +19,11 @@
#define _MGCOORDINATESYSTEMENUMINTEGER32_H_
class MgIntCollection;
+/// \brief
+/// Enumerates a set of integers
class MgCoordinateSystemEnumInteger32 : public MgGuardDisposable
DECLARE_CLASSNAME(MgCoordinateSystemEnumInteger32)
Modified: branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemFilter.h
--- branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemFilter.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemFilter.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -18,11 +18,23 @@
#ifndef _MGCOORDINATESYSTEMFILTER_H_
#define _MGCOORDINATESYSTEMFILTER_H_
+/// \brief
+/// A coordinate system filter
class MgCoordinateSystemFilter : public MgGuardDisposable
DECLARE_CLASSNAME(MgCoordinateSystemFilter)
PUBLISHED_API:
+ /// \brief
+ /// This function evaluates the provided def using the current filter
+ /// \param pDef (MgGuardDisposable)
+ /// The provided def
virtual bool IsFilteredOut(MgGuardDisposable *pDef)=0;
protected:
Modified: branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemFilterInteger32.h
--- branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemFilterInteger32.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemFilterInteger32.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -18,11 +18,23 @@
#ifndef _MGCOORDINATESYSTEMFILTERINTEGER32_H_
#define _MGCOORDINATESYSTEMFILTERINTEGER32_H_
+/// \brief
+/// An integer filter
class MgCoordinateSystemFilterInteger32 : public MgGuardDisposable
DECLARE_CLASSNAME(MgCoordinateSystemFilterInteger32)
PUBLISHED_API:
+ /// \brief
+ /// \param nValue (int)
virtual bool IsFilteredOut(INT32 nValue)=0;
protected:
Modified: branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemFormatConverter.h
--- branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemFormatConverter.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemFormatConverter.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -18,6 +18,11 @@
#ifndef _MGCOORDINATESYSTEMFORMATCONVERTER_H_
#define _MGCOORDINATESYSTEMFORMATCONVERTER_H_
+/// \brief
+/// Provides services for converting mentor codes or WKT strings to coordinate systems and
+/// vice versa
class MgCoordinateSystemFormatConverter : public MgGuardDisposable
DECLARE_CLASSNAME(MgCoordinateSystemFormatConverter)
@@ -26,15 +31,136 @@
//WKT methods
//use MgCoordinateSystemWktFlavor values for the WKT format
//use MgCoordinateSystemCodeFormat values for the code format
+ /// \brief
+ /// Gets the WKT for a given coordinate system
+ /// \param pSource (MgCoordinateSystem)
+ /// The coordinate system
+ /// \param nWktFlavor (int)
+ /// Any constant defined in MgCoordinateSystemWktFlavor
+ /// \return
+ /// The WKT string
virtual STRING DefinitionToWkt(MgCoordinateSystem* pSource, INT32 nWktFlavor)=0;
+ /// \brief
+ /// Gets the coordinate system for the given WKT string
+ /// \param sWkt (String)
+ /// \return
virtual MgCoordinateSystem* WktToDefinition(INT32 nWktFlavor, CREFSTRING sWkt)=0;
+ /// \brief
+ /// Gets the WKT string for the given code
+ /// \param nFormatSource (int)
+ /// Any constant defined in MgCoordinateSystemCodeFormat
+ /// \param sCodeSource (String)
+ /// The code
+ /// \return
+ /// The WKT string in the requested flavor
virtual STRING CodeToWkt(INT32 nFormatSource, CREFSTRING sCodeSource, INT32 nWktFlavor)=0;
+ /// \brief
+ /// Gets the code for the given WKT string
+ /// \param nFormatDestination (int)
+ /// \return
+ /// The code in the requested flavor
virtual STRING WktToCode(INT32 nWktFlavor, CREFSTRING sWkt, INT32 nFormatDestination)=0;
//code format conversion
+ /// \brief
+ /// Gets the code for the given coordinate system
+ /// \return
virtual STRING DefinitionToCode(MgCoordinateSystem* pSource, INT32 nFormatDestination)=0;
+ /// \brief
+ /// Gets the coordinate system for the given code
+ /// The code
+ /// \return
virtual MgCoordinateSystem* CodeToDefinition(INT32 nFormatSource, CREFSTRING sCodeSource)=0;
+ /// \brief
+ /// Gets the code in the requested format for the given code in its format
+ /// The code
+ /// \return
virtual STRING CodeToCode(INT32 nFormatSource, CREFSTRING sCodeSource, INT32 nFormatDestination)=0;
+ /// \brief
+ /// Gets whether the given code in the specific format is present in the dictionary
+ /// \param nFormat (int)
+ /// \param sCode (int)
+ /// The code
+ /// \return
+ /// true if the exists. false otherwise
virtual bool IsCodeInDictionary(INT32 nFormat, CREFSTRING sCode)=0;
protected:
Modified: branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemUnitInformation.h
--- branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemUnitInformation.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemUnitInformation.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -27,12 +27,97 @@
DECLARE_CLASSNAME(MgCoordinateSystemUnitInformation)
PUBLISHED_API:
+ /// \brief
+ /// Gets an enumerator for listing all the linear units supported by the API
+ /// \return
+ /// Enumerator containing all supported linear unit codes
+ /// Caller is responsible for releasing the enumerator when done with it
virtual MgCoordinateSystemEnumInteger32* GetEnumLinearUnits()=0;
+ /// \brief
+ /// Gets an enumerator for listing all the angular units supported by the API
+ /// \return
+ /// Enumerator containing all supported angular unit codes
virtual MgCoordinateSystemEnumInteger32* GetEnumAngularUnits()=0;
+ /// \brief
+ /// Gets the scale factor for the specified linear unit type; this is
+ /// the number which one multiplies a value by to get meters.
+ /// \param nUnitCode (int)
+ /// The linear unit code
+ /// \return
+ /// Scale factor to convert from this unit to meters
virtual double GetLinearUnitScale(INT32 nUnitCode)=0;
+ /// \brief
+ /// Gets the scale factor for the specified angular unit type; this
+ /// is the number which one multiplies a value by to get degrees.
+ /// The angular unit code
+ /// \return
+ /// Scale factor to convert from this unit to radians
virtual double GetAngularUnitScale(INT32 nUnitCode)=0;
+ /// \brief
+ /// Gets the type (linear or angular) of the specified unit
+ /// The unit code to check
+ /// \return
+ /// kCsUnitTypeLinear if linear units
+ /// kCsUnitTypeAngular if angular units
+ /// kCsUnitTypeUnknown if invalid unit code
virtual INT32 GetUnitType(INT32 nUnitCode)=0;
+ /// \brief
+ /// Gets Mentor's "tag string" for the specified unit (i.e., "Meter"
+ /// for meters, "IFoot" for international feet, etc.).
+ /// \param nUnitCode (INT32)
+ /// The unit code
+ /// \return
+ /// Tag string (e.g. "m" for meters, "ft" for feet)
+ /// \remarks
+ /// The returned string is not localized and should not be used for UI display
+ /// This function is provided mainly for debugging and utility purposes
virtual STRING GetTagString(INT32 nUnitCode)=0;
+ /// \brief
+ /// Gets the standard abbreviation for the specified unit
+ /// The unit code
+ /// \return
+ /// Standard abbreviation for the unit (e.g. "m" for meters)
+ /// \remarks
virtual STRING GetAbbreviation(INT32 nUnitCode)=0;
protected:
Modified: branches/4.0/MgDev/Common/Geometry/CoordinateXY.h
--- branches/4.0/MgDev/Common/Geometry/CoordinateXY.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/CoordinateXY.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -41,6 +41,14 @@
DECLARE_CLASSNAME(MgCoordinateXY)
PUBLISHED_API:
+ /// \brief
+ /// Defines the dimensions supported by this coordinate as a bit mask. The
+ /// return can be a combination of the values of MgCoordinateDimension.
+ /// See MgCoordinateDimension for an explaination of the possible return
+ /// values.
/// <!-- Syntax in .Net, Java, and PHP -->
/// \htmlinclude DotNetSyntaxTop.html
/// virtual int GetDimension();
@@ -54,6 +62,10 @@
virtual INT32 GetDimension(); /// __get, __inherited
+ /// \brief
+ /// Gets the X value of this coordinate.
/// virtual double GetX();
@@ -67,6 +79,10 @@
virtual double GetX(); /// __get, __inherited
+ /// \brief
+ /// Gets the Y value of this coordinate.
/// virtual double GetY();
@@ -80,6 +96,10 @@
virtual double GetY(); /// __get, __inherited
+ /// \brief
+ /// Gets the Z value of this coordinate.
/// virtual double GetZ();
@@ -93,6 +113,10 @@
virtual double GetZ(); /// __get, __inherited
+ /// \brief
+ /// Gets the M value of this coordinate.
/// virtual double GetM();
Modified: branches/4.0/MgDev/Common/Geometry/CoordinateXYM.h
--- branches/4.0/MgDev/Common/Geometry/CoordinateXYM.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/CoordinateXYM.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -44,6 +44,14 @@
DECLARE_CLASSNAME(MgCoordinateXYM)
PUBLISHED_API:
+ /// \brief
+ /// values.
@@ -57,6 +65,10 @@
+ /// \brief
@@ -70,6 +82,10 @@
+ /// \brief
@@ -83,6 +99,10 @@
+ /// \brief
@@ -96,6 +116,10 @@
+ /// \brief
Modified: branches/4.0/MgDev/Common/Geometry/CoordinateXYZ.h
--- branches/4.0/MgDev/Common/Geometry/CoordinateXYZ.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/CoordinateXYZ.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -41,6 +41,14 @@
DECLARE_CLASSNAME(MgCoordinateXYZ)
PUBLISHED_API:
+ /// \brief
+ /// values.
@@ -54,6 +62,10 @@
+ /// \brief
@@ -67,6 +79,10 @@
+ /// \brief
@@ -80,6 +96,10 @@
+ /// \brief
@@ -93,6 +113,10 @@
+ /// \brief
Modified: branches/4.0/MgDev/Common/Geometry/CoordinateXYZM.h
--- branches/4.0/MgDev/Common/Geometry/CoordinateXYZM.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/CoordinateXYZM.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -44,6 +44,14 @@
DECLARE_CLASSNAME(MgCoordinateXYZM)
PUBLISHED_API:
+ /// \brief
+ /// values.
@@ -57,6 +65,10 @@
+ /// \brief
@@ -70,6 +82,10 @@
+ /// \brief
@@ -83,6 +99,10 @@
+ /// \brief
@@ -96,6 +116,10 @@
+ /// \brief
Modified: branches/4.0/MgDev/Common/Geometry/CurvePolygon.h
--- branches/4.0/MgDev/Common/Geometry/CurvePolygon.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/CurvePolygon.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -231,6 +231,10 @@
virtual MgCurveRing* GetInteriorRing(INT32 index);
+ /// \brief
+ /// Gets the type of this geometry
/// virtual int GetGeometryType();
@@ -244,6 +248,12 @@
virtual INT32 GetGeometryType(); /// __get, __inherited
+ /// \brief
+ /// Gets the geometric dimension of this entity, indicating whether the
+ /// entity is zero, one, or two dimensional (defined by points, defined
+ /// by curves, or defined by regions).
@@ -257,6 +267,10 @@
+ /// \brief
+ /// Gets whether this instance is empty
/// virtual bool IsEmpty();
@@ -270,6 +284,10 @@
+ /// \brief
+ /// Gets whether this instance is closed
/// virtual bool IsClosed();
@@ -283,6 +301,10 @@
+ /// \brief
+ /// Creates a copy of this instance
/// virtual MgGeometricEntity Copy();
Modified: branches/4.0/MgDev/Common/Geometry/CurveRing.h
--- branches/4.0/MgDev/Common/Geometry/CurveRing.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/CurveRing.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -41,6 +41,11 @@
DECLARE_CLASSNAME(MgCurveRing)
PUBLISHED_API:
+ /// \brief
+ /// Gets the type of this geometry component
/// virtual int GetComponentType();
@@ -98,6 +103,12 @@
virtual MgCurveSegment* GetSegment(INT32 index);
+ /// \brief
@@ -111,6 +122,10 @@
+ /// \brief
@@ -124,6 +139,10 @@
+ /// \brief
@@ -137,6 +156,10 @@
+ /// \brief
@@ -150,6 +173,10 @@
virtual MgGeometricEntity* Copy();
+ /// \brief
+ /// Returns a transformed copy of this instance
/// virtual MgGeometricEntity Transform(MgTransform transform);
Modified: branches/4.0/MgDev/Common/Geometry/CurveString.h
--- branches/4.0/MgDev/Common/Geometry/CurveString.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/CurveString.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -230,6 +230,10 @@
+ /// \brief
+ /// Gets the starting coordinate of the curve
/// virtual MgCoordinate GetStartCoordinate();
@@ -243,6 +247,10 @@
virtual MgCoordinate* GetStartCoordinate(); /// __get, __inherited
+ /// \brief
+ /// Gets the ending coordinate of the curve
/// virtual MgCoordinate GetEndCoordinate();
@@ -256,6 +264,10 @@
virtual MgCoordinate* GetEndCoordinate(); /// __get, __inherited
+ /// \brief
@@ -269,6 +281,12 @@
+ /// \brief
@@ -282,6 +300,10 @@
+ /// \brief
@@ -295,6 +317,10 @@
+ /// \brief
@@ -308,6 +334,10 @@
+ /// \brief
+ /// Creates a copy of the instance
Modified: branches/4.0/MgDev/Common/Geometry/Geometry.h
--- branches/4.0/MgDev/Common/Geometry/Geometry.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/Geometry.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -350,6 +350,8 @@
/// \brief
+ /// Returns the closure of the combinitorial boundary of this geometric
+ /// entity as a topologically closed geometry.
/// \remarks
/// <TABLE border="1" class="RuledTable">
@@ -484,6 +486,8 @@
/// \brief
+ /// Returns a geometry that represents the convex hull of this geometric
+ /// entity.
/// \remarks
/// In section 12.4.2 [\link JTS14 JTS1.4 \endlink] states:
Modified: branches/4.0/MgDev/Common/Geometry/LineString.h
--- branches/4.0/MgDev/Common/Geometry/LineString.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/LineString.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -126,6 +126,10 @@
virtual MgCoordinateIterator* GetCoordinates();
+ /// \brief
+ /// Gets the starting coordinate of the curve.
@@ -139,6 +143,10 @@
+ /// \brief
+ /// Gets the ending coordinate of the curve.
@@ -152,6 +160,10 @@
+ /// \brief
+ /// Gets the type fo this geometry.
@@ -165,6 +177,12 @@
+ /// \brief
@@ -178,6 +196,10 @@
+ /// \brief
@@ -191,6 +213,10 @@
+ /// \brief
@@ -204,6 +230,10 @@
+ /// \brief
Modified: branches/4.0/MgDev/Common/Geometry/LinearRing.h
--- branches/4.0/MgDev/Common/Geometry/LinearRing.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/LinearRing.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -44,6 +44,11 @@
DECLARE_CLASSNAME(MgLinearRing)
PUBLISHED_API:
+ /// \brief
+ /// Gets the type of this geometry component.
@@ -78,6 +83,12 @@
+ /// \brief
@@ -91,6 +102,10 @@
+ /// \brief
@@ -104,6 +119,10 @@
+ /// \brief
@@ -117,6 +136,10 @@
+ /// \brief
Modified: branches/4.0/MgDev/Common/Geometry/LinearSegment.h
--- branches/4.0/MgDev/Common/Geometry/LinearSegment.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/LinearSegment.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -45,6 +45,11 @@
DECLARE_CLASSNAME(MgLinearSegment)
PUBLISHED_API:
+ /// \brief
@@ -79,6 +84,10 @@
+ /// \brief
+ /// Gets the starting coordinate of the curve segment.
@@ -92,6 +101,10 @@
+ /// \brief
+ /// Gets the ending coordinate of the curve segment
@@ -105,6 +118,12 @@
+ /// \brief
@@ -118,6 +137,10 @@
+ /// \brief
@@ -131,6 +154,10 @@
+ /// \brief
@@ -144,6 +171,10 @@
+ /// \brief
Modified: branches/4.0/MgDev/Common/Geometry/MultiCurvePolygon.h
--- branches/4.0/MgDev/Common/Geometry/MultiCurvePolygon.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/MultiCurvePolygon.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -109,6 +109,11 @@
DECLARE_CLASSNAME(MgMultiCurvePolygon)
PUBLISHED_API:
+ /// \brief
+ /// Gets the number of geometries in this aggregate.
/// virtual int GetCount();
@@ -147,6 +152,10 @@
virtual MgCurvePolygon* GetCurvePolygon(INT32 index);
+ /// \brief
+ /// Gets the type of this geometry.
@@ -160,6 +169,12 @@
+ /// \brief
@@ -173,6 +188,10 @@
+ /// \brief
@@ -186,6 +205,10 @@
+ /// \brief
@@ -199,6 +222,10 @@
+ /// \brief
Modified: branches/4.0/MgDev/Common/Geometry/MultiCurveString.h
--- branches/4.0/MgDev/Common/Geometry/MultiCurveString.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/MultiCurveString.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -113,6 +113,11 @@
DECLARE_CLASSNAME(MgMultiCurveString)
PUBLISHED_API:
+ /// \brief
@@ -151,6 +156,10 @@
virtual MgCurveString* GetCurveString(INT32 index);
+ /// \brief
@@ -164,6 +173,12 @@
+ /// \brief
@@ -177,6 +192,10 @@
+ /// \brief
+ /// Gets whether this instances is empty
@@ -190,6 +209,10 @@
+ /// \brief
@@ -203,6 +226,10 @@
+ /// \brief
Modified: branches/4.0/MgDev/Common/Geometry/MultiGeometry.h
--- branches/4.0/MgDev/Common/Geometry/MultiGeometry.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/MultiGeometry.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -112,6 +112,11 @@
DECLARE_CLASSNAME(MgMultiGeometry)
PUBLISHED_API:
+ /// \brief
@@ -150,6 +155,10 @@
virtual MgGeometry* GetGeometry(INT32 index);
+ /// \brief
@@ -163,6 +172,12 @@
+ /// \brief
@@ -176,6 +191,10 @@
+ /// \brief
@@ -189,6 +208,10 @@
+ /// \brief
@@ -202,6 +225,10 @@
+ /// \brief
Modified: branches/4.0/MgDev/Common/Geometry/MultiLineString.h
--- branches/4.0/MgDev/Common/Geometry/MultiLineString.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/MultiLineString.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -110,6 +110,11 @@
DECLARE_CLASSNAME(MgMultiLineString)
PUBLISHED_API:
+ /// \brief
@@ -148,6 +153,10 @@
virtual MgLineString* GetLineString(INT32 index);
+ /// \brief
@@ -161,6 +170,12 @@
+ /// \brief
@@ -174,6 +189,10 @@
+ /// \brief
@@ -187,6 +206,10 @@
+ /// \brief
@@ -200,6 +223,10 @@
+ /// \brief
@@ -213,6 +240,10 @@
+ /// \brief
+ /// Creates a transformed copy of this geometric entity
Modified: branches/4.0/MgDev/Common/Geometry/MultiPoint.h
--- branches/4.0/MgDev/Common/Geometry/MultiPoint.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/MultiPoint.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -101,6 +101,11 @@
DECLARE_CLASSNAME(MgMultiPoint)
PUBLISHED_API:
+ /// \brief
@@ -139,6 +144,10 @@
virtual MgPoint* GetPoint(INT32 index);
+ /// \brief
@@ -152,6 +161,12 @@
+ /// \brief
@@ -165,6 +180,10 @@
+ /// \brief
@@ -178,6 +197,10 @@
+ /// \brief
@@ -191,6 +214,10 @@
+ /// \brief
Modified: branches/4.0/MgDev/Common/Geometry/MultiPolygon.h
--- branches/4.0/MgDev/Common/Geometry/MultiPolygon.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/MultiPolygon.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -113,6 +113,9 @@
PUBLISHED_API:
+ /// \brief
@@ -152,6 +155,9 @@
virtual MgPolygon* GetPolygon(INT32 index);
+ /// \brief
@@ -166,6 +172,11 @@
+ /// \brief
@@ -180,6 +191,9 @@
+ /// \brief
@@ -194,6 +208,9 @@
+ /// \brief
@@ -208,6 +225,9 @@
+ /// \brief
Modified: branches/4.0/MgDev/Common/Geometry/Point.h
--- branches/4.0/MgDev/Common/Geometry/Point.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/Point.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -93,6 +93,9 @@
PUBLISHED_API:
+ /// \brief
@@ -127,6 +130,11 @@
virtual MgCoordinate* GetCoordinate(); /// __get
+ /// \brief
@@ -141,6 +149,9 @@
+ /// \brief
@@ -155,6 +166,9 @@
+ /// \brief
@@ -169,6 +183,9 @@
+ /// \brief
Modified: branches/4.0/MgDev/Common/Geometry/Polygon.h
--- branches/4.0/MgDev/Common/Geometry/Polygon.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/Polygon.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -262,6 +262,10 @@
virtual MgLinearRing* GetInteriorRing(INT32 index);
+ /// \brief
@@ -275,6 +279,12 @@
+ /// \brief
@@ -288,6 +298,10 @@
+ /// \brief
@@ -301,6 +315,10 @@
+ /// \brief
@@ -314,6 +332,10 @@
+ /// \brief
Modified: branches/4.0/MgDev/Common/Geometry/Ring.h
--- branches/4.0/MgDev/Common/Geometry/Ring.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/Geometry/Ring.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -26,9 +26,9 @@
+/// \brief
/// MgRing is an abstract base class. The concrete classes are
/// MgCurveRing and MgLinearRing.
class MG_GEOMETRY_API MgRing : public MgGeometryComponent
PUBLISHED_API:
Modified: branches/4.0/MgDev/Common/PlatformBase/MapLayer/SelectionBase.h
--- branches/4.0/MgDev/Common/PlatformBase/MapLayer/SelectionBase.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/PlatformBase/MapLayer/SelectionBase.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -24,6 +24,7 @@
class MG_PLATFORMBASE_API MgMemoryStreamHelper;
+/// \brief
/// Exposed API class for handling selection
/// Represents a set of selections for multiple layers and classes
class MG_PLATFORMBASE_API MgSelectionBase : public MgResource
@@ -121,6 +122,7 @@
/// \since 2.0
virtual MgFeatureReader* GetSelectedFeatures(MgLayerBase* layer, CREFSTRING className, bool mappedOnly);
+ /// \brief
/// Returns the selected feature data for the specified feature class.
Modified: branches/4.0/MgDev/Common/PlatformBase/Services/FeatureSpatialOperations.h
--- branches/4.0/MgDev/Common/PlatformBase/Services/FeatureSpatialOperations.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/PlatformBase/Services/FeatureSpatialOperations.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -33,46 +33,57 @@
PUBLISHED_API:
+ /// \brief
/// Test whether the geometric property value spatially \link Contains contains \endlink
/// the literal geometric value.
static const int Contains = 0;
+ /// \brief
/// Test whether the geometric property value \link Crosses crosses \endlink
/// the given geometry.
static const int Crosses = 1;
+ /// \brief
/// Test whether the geometric property value is \link Disjoint disjoint \endlink
/// from the given geometry.
static const int Disjoint = 2;
+ /// \brief
/// Test whether the geometric property value is \link Equals equal \endlink
/// to the given geometry.
static const int Equals = 3;
+ /// \brief
/// Test whether the geometric property \link Intersects intersects \endlink
static const int Intersects = 4;
+ /// \brief
/// Test whether the geometric property \link Overlaps overlaps \endlink
static const int Overlaps = 5;
+ /// \brief
/// Test whether the geometric property \link Touches touches \endlink the
/// given geometry.
static const int Touches = 6;
+ /// \brief
/// Test whether the geometric property is \link Within within \endlink
static const int Within = 7;
+ /// \brief
/// Test whether the geometric property value is \link CoveredBy covered by \endlink
static const int CoveredBy = 8;
+ /// \brief
/// Test whether the geometric property is \link Inside inside \endlink
static const int Inside = 9;
+ /// \brief
/// Test whether the envelope of the geometric property \link EnvelopeIntersects intersects \endlink
/// the envelope of the given geometry.
static const int EnvelopeIntersects = 10;
Modified: branches/4.0/MgDev/Common/PlatformBase/Services/Raster.h
--- branches/4.0/MgDev/Common/PlatformBase/Services/Raster.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Common/PlatformBase/Services/Raster.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -27,6 +27,11 @@
template class MG_PLATFORMBASE_API Ptr<MgRaster>;
// INTERNAL_CLASS
+/// \brief
+/// Describes a raster image
class MG_PLATFORMBASE_API MgRaster : public MgSerializable
MG_DECL_DYNCREATE();
Modified: branches/4.0/MgDev/Portable/MgPortable/Services/FeatureService.h
--- branches/4.0/MgDev/Portable/MgPortable/Services/FeatureService.h 2025-09-12 11:11:27 UTC (rev 10192)
+++ branches/4.0/MgDev/Portable/MgPortable/Services/FeatureService.h 2025-09-12 13:40:08 UTC (rev 10193)
@@ -44,110 +44,403 @@
virtual void Dispose() { delete this; }
PUBLISHED_API:
+ /// \brief
+ /// Gets a list of available feature providers
+ /// \return
+ /// A MgByteReader containing the XML list of providers
virtual MgByteReader* GetFeatureProviders();
+ /// \brief
+ /// Gets connection property values for the specified provider and property
+ /// \param providerName (String)
+ /// Name of the feature provider
+ /// \param propertyName (String)
+ /// Name of the connection property
+ /// \param partialConnString (String)
+ /// Partial connection string
+ /// \return
+ /// Collection of valid property values
virtual MgStringCollection* GetConnectionPropertyValues(CREFSTRING providerName,
- CREFSTRING propertyName,
- CREFSTRING partialConnString);
+ CREFSTRING propertyName,
+ CREFSTRING partialConnString);
+ /// \brief
+ /// Tests if a connection can be established with the given parameters
+ /// \param connectionString (String)
+ /// Connection string to test
+ /// \return
+ /// true if connection successful, false otherwise
virtual bool TestConnection(CREFSTRING providerName, CREFSTRING connectionString);
+ /// \brief
+ /// Tests if a connection can be established with the given resource
+ /// \param resource (MgResourceIdentifier)
+ /// Feature source resource identifier
+ /// \return
virtual bool TestConnection(MgResourceIdentifier* resource);
+ /// \brief
+ /// Gets provider capabilities
+ /// \return
+ /// XML reader containing capability information
virtual MgByteReader* GetCapabilities(CREFSTRING providerName);
+ /// \brief
+ /// Gets provider capabilities for specific connection
+ /// \return
virtual MgByteReader* GetCapabilities(CREFSTRING providerName, CREFSTRING connectionString);
+ /// \brief
+ /// Applies a feature schema to a data source
+ /// \param schema (MgFeatureSchema)
+ /// Feature schema to apply
virtual void ApplySchema(MgResourceIdentifier* resource, MgFeatureSchema* schema);
+ /// \brief
+ /// Gets schema description for specified classes
+ /// \param schemaName (String)
+ /// Name of schema to describe
+ /// \param classNames (MgStringCollection)
+ /// Collection of class names to describe
+ /// \return
+ /// Collection of feature schemas
virtual MgFeatureSchemaCollection* DescribeSchema(MgResourceIdentifier* resource,
CREFSTRING schemaName,
MgStringCollection* classNames);
+ /// \brief
+ /// \return
CREFSTRING schemaName);
+ /// \brief
+ /// Gets XML schema description for specified classes
+ /// \return
+ /// XML schema description
virtual STRING DescribeSchemaAsXml(MgResourceIdentifier* resource,
+ /// \brief
+ /// \return
+ /// \brief
+ /// Converts feature schema to XML
+ /// \param schema (MgFeatureSchemaCollection)
+ /// Feature schema collection to convert
+ /// \return
+ /// XML representation of schema
virtual STRING SchemaToXml(MgFeatureSchemaCollection* schema);
+ /// \brief
+ /// Converts XML to feature schema
+ /// \param xml (String)
+ /// \return
virtual MgFeatureSchemaCollection* XmlToSchema(CREFSTRING xml);
+ /// \brief
+ /// Selects features based on query options
+ /// \param className (String)
+ /// Name of feature class to query
+ /// \param options (MgFeatureQueryOptions)
+ /// Query options
+ /// \return
+ /// Feature reader containing results
virtual MgFeatureReader* SelectFeatures(MgResourceIdentifier* resource,
MgFeatureQueryOptions* options);
+ /// \brief
+ /// Selects features with coordinate system
+ /// Query options
+ /// \param coordinateSystem (String)
+ /// Target coordinate system
+ /// \return
MgFeatureQueryOptions* options,
CREFSTRING coordinateSystem);
+ /// \brief
+ /// Performs aggregate query
+ /// \param options (MgFeatureAggregateOptions)
+ /// Aggregate options
+ /// \return
+ /// Data reader with aggregate results
virtual MgDataReader* SelectAggregate(MgResourceIdentifier* resource,
MgFeatureAggregateOptions* options);
+ /// \brief
+ /// Updates features using commands
+ /// \param commands (MgFeatureCommandCollection)
+ /// Collection of update commands
+ /// \param useTransaction (boolean/bool)
+ /// Whether to use transaction
+ /// \return
+ /// Collection of affected properties
virtual MgPropertyCollection* UpdateFeatures(MgResourceIdentifier* resource,
MgFeatureCommandCollection* commands,
bool useTransaction);
+ /// \brief
+ /// Updates features using transaction
+ /// \param transaction (MgTransaction)
+ /// Transaction to use
+ /// \return
MgTransaction* transaction);
+ /// \brief
+ /// Gets locked features
+ /// Query options
+ /// \return
+ /// Feature reader with locked features
virtual MgFeatureReader* GetLockedFeatures(MgResourceIdentifier* resource,
+ /// \brief
+ /// Begins a new transaction
+ /// \return
+ /// New transaction object
virtual MgTransaction* BeginTransaction(MgResourceIdentifier* resource);
+ /// \brief
+ /// Executes SQL query
+ /// \param sqlStatement (String)
+ /// SQL query statement
+ /// \return SQL data reader with results
virtual MgSqlDataReader* ExecuteSqlQuery(MgResourceIdentifier* resource,
CREFSTRING sqlStatement);
+ /// \brief
+ /// Executes parameterized SQL query
+ /// \param parameters (MgParameterCollection)
+ /// Query parameters
+ /// \return
+ /// SQL data reader with results
CREFSTRING sqlStatement,
MgParameterCollection* parameters,
+ /// \brief
+ /// Executes non-query SQL statement
+ /// \param sqlNonSelectStatement (String)
+ /// SQL non-select statement
+ /// \return
+ /// Number of rows affected
virtual INT32 ExecuteSqlNonQuery(MgResourceIdentifier* resource,
CREFSTRING sqlNonSelectStatement);
+ /// \brief
+ /// Executes parameterized non-query SQL
+ /// \return
CREFSTRING sqlNonSelectStatement,
+ /// \brief
+ /// Gets spatial contexts
+ /// \param bActiveOnly (boolean/bool)
+ /// Whether to get only active contexts
+ /// \return
+ /// Spatial context reader
virtual MgSpatialContextReader* GetSpatialContexts(MgResourceIdentifier* resource,
bool bActiveOnly);
+ /// \brief
+ /// Gets long transactions
+ /// \param resource (MgResourceIdentifer)
+ /// Whether to get only active transactions
+ /// \return
+ /// Long transaction reader
virtual MgLongTransactionReader* GetLongTransactions(MgResourceIdentifier* resource,
bool bActiveOnly);
+ /// \brief
+ /// Sets active long transaction
+ /// \param featureSourceId (MgResourceIdentifier)
+ /// Feature source identifier
+ /// \param longTransactionName (String)
+ /// Name of transaction
+ /// \return
+ /// true if successful
virtual bool SetLongTransaction(MgResourceIdentifier* featureSourceId,
CREFSTRING longTransactionName);
+ /// \brief
+ /// Gets available schemas
+ /// \return
+ /// Collection of schema names
virtual MgStringCollection* GetSchemas(MgResourceIdentifier* resource);
+ /// \brief
+ /// Gets feature classes in schema
+ /// \return
virtual MgStringCollection* GetClasses(MgResourceIdentifier* resource, CREFSTRING schemaName);
+ /// \brief
+ /// Gets class definition
+ /// Name of class
+ /// \return
+ /// Class definition
virtual MgClassDefinition* GetClassDefinition(MgResourceIdentifier* resource,
CREFSTRING className);
+ /// \brief
+ /// Creates a new feature source
+ /// \param sourceParams (MgFeatureSourceParams)
+ /// Feature source parameters
virtual void CreateFeatureSource(MgResourceIdentifier* resource, MgFeatureSourceParams* sourceParams);
+ /// \brief
+ /// Gets WFS feature type description
+ /// \param featureClasses (MgStringCollection)
+ /// Feature classes to describe
+ /// \return
+ /// XML reader with feature type description
virtual MgByteReader* DescribeWfsFeatureType(MgResourceIdentifier* featureSourceId,
MgStringCollection* featureClasses);
+ /// \brief
+ /// Gets WFS feature type description with namespace
+ /// \param namespacePrefix (String)
+ /// Namespace prefix
+ /// \param namespaceUrl (String)
+ /// Namespace URL
+ /// \return
MgStringCollection* featureClasses,
CREFSTRING namespacePrefix,
CREFSTRING namespaceUrl);
+ /// \brief
+ /// Gets WFS features
+ /// \param featureClass (String)
+ /// Feature class name
+ /// \param requiredProperties (MgStringCollection)
+ /// Required properties
+ /// \param srs (String)
+ /// Spatial reference system
+ /// \param filter (String)
+ /// Filter expression
+ /// \param maxFeatures (int)
+ /// Maximum features to return
+ /// \return
+ /// XML reader with features
virtual MgByteReader* GetWfsFeature(MgResourceIdentifier* featureSourceId,
CREFSTRING featureClass,
MgStringCollection* requiredProperties,
@@ -155,6 +448,32 @@
CREFSTRING filter,
INT32 maxFeatures);
+ /// \brief
+ /// Gets WFS features with additional options
+ /// \param wfsVersion (String)
+ /// WFS version
+ /// \param outputFormat (String)
+ /// Output format
+ /// \param sortCriteria (String)
+ /// Sort criteria
+ /// Namespace URL
+ /// \return
@@ -167,24 +486,132 @@
+ /// \brief
+ /// Enumerates available data stores
+ /// Provider name
+ /// \return
+ /// XML reader with data store list
virtual MgByteReader* EnumerateDataStores(CREFSTRING providerName, CREFSTRING partialConnString);
+ /// \brief
+ /// Gets schema mapping
+ /// Provider name
+ /// \return
+ /// XML reader with schema mapping
virtual MgByteReader* GetSchemaMapping(CREFSTRING providerName, CREFSTRING partialConnString);
+ /// \brief
+ /// Inserts new features
+ /// \param propertyValues (MgPropertyCollection)
+ /// Property values to insert
+ /// \return
+ /// Feature reader with inserted features
virtual MgFeatureReader* InsertFeatures(MgResourceIdentifier* resource, CREFSTRING className, MgPropertyCollection* propertyValues);
+ /// \brief
+ /// Inserts features with transaction
+ /// \param trans (MgTransaction)
+ /// \return
virtual MgFeatureReader* InsertFeatures(MgResourceIdentifier* resource, CREFSTRING className, MgPropertyCollection* propertyValues, MgTransaction* trans);
+ /// \brief
+ /// Inserts batch of features
+ /// \param batchPropertyValues (MgBatchPropertyCollection)
+ /// Batch of property values
+ /// \return
virtual MgFeatureReader* InsertFeatures(MgResourceIdentifier* resource, CREFSTRING className, MgBatchPropertyCollection* batchPropertyValues);
+ /// \brief
+ /// Inserts batch of features with transaction
+ /// \return
virtual MgFeatureReader* InsertFeatures(MgResourceIdentifier* resource, CREFSTRING className, MgBatchPropertyCollection* batchPropertyValues, MgTransaction* trans);
+ /// \brief
+ /// Deletes features matching filter
+ /// \return
+ /// Number of features deleted
virtual INT32 DeleteFeatures(MgResourceIdentifier* resource, CREFSTRING className, CREFSTRING filter);
+ /// \brief
+ /// Deletes features with transaction
+ /// \return
virtual INT32 DeleteFeatures(MgResourceIdentifier* resource, CREFSTRING className, CREFSTRING filter, MgTransaction* trans);
+ /// \brief
+ /// Updates features matching filter
+ /// New property values
+ /// \return
+ /// Number of features updated
virtual INT32 UpdateMatchingFeatures(MgResourceIdentifier* resource, CREFSTRING className, MgPropertyCollection* propertyValues, CREFSTRING filter);
+ /// \brief
+ /// Updates features with transaction
+ /// \return
virtual INT32 UpdateMatchingFeatures(MgResourceIdentifier* resource, CREFSTRING className, MgPropertyCollection* propertyValues, CREFSTRING filter, MgTransaction* trans);
//------- Portable API additions --------//
More information about the mapguide-commits
