[mapguide-commits] r10206 - branches/4.0/MgDev/Doc
svn_mapguide at osgeo.org
Sat Mar 14 05:27:16 PDT 2026
Author: jng
Date: 2026-03-14 05:27:15 -0700 (Sat, 14 Mar 2026)
New Revision: 10206
branches/4.0/MgDev/Doc/build.bat
Fix javadoc detection
Modified: branches/4.0/MgDev/Doc/build.bat
--- branches/4.0/MgDev/Doc/build.bat 2026-03-14 10:57:53 UTC (rev 10205)
+++ branches/4.0/MgDev/Doc/build.bat 2026-03-14 12:27:15 UTC (rev 10206)
@@ -1,6 +1,6 @@
@echo off
REM TODO: Move to setenviroment64.bat once this is fully fleshed out
-SET LABEL=4.0 RC1
+SET LABEL=4.0
pushd dotnet_api
docfx metadata
docfx build --metadata _appTitle="MapGuide .net API reference (%LABEL%)"
@@ -10,7 +10,19 @@
REM for the affected classes will still be generated, these errors are mostly about malformed tags that are a by-product
REM of being transferred from the C++ doxygen fragments
REM TODO: These errors will go away by fixing the comments in question at the C++ source
-javadoc -d ..\..\..\..\Doc\landing\_site\java_api org.osgeo.mapguide -overview ..\..\..\..\Doc\java_api\overview.html -windowtitle "MapGuide Java API reference (%LABEL%)"
+set "JAVADOC_EXE="
+where javadoc >nul 2>nul
+if not errorlevel 1 (
+ set "JAVADOC_EXE=javadoc"
+) else if defined JAVA_HOME if exist "%JAVA_HOME%\bin\javadoc.exe" (
+ set "JAVADOC_EXE=%JAVA_HOME%\bin\javadoc.exe"
+if defined JAVADOC_EXE (
+ "%JAVADOC_EXE%" -d ..\..\..\..\Doc\landing\_site\java_api org.osgeo.mapguide -overview ..\..\..\..\Doc\java_api\overview.html -windowtitle "MapGuide Java API reference (%LABEL%)"
+) else (
+ echo WARNING: javadoc not found in PATH or JAVA_HOME. Skipping Java API documentation generation.
popd
pushd mdpreprocess
dotnet run -- ..\landing\topics
More information about the mapguide-commits
