[mapguide-commits] r10247 - branches/4.0/MgDev
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Nov 2 17:40:23 PST 2026
Author: jng
Date: 2026-11-02 17:40:22 -0800 (Mon, 02 Nov 2026)
New Revision: 10247
   branches/4.0/MgDev/cmake_linuxapt.sh
Rework cmake_linuxapt.sh for more component flexibility
Modified: branches/4.0/MgDev/cmake_linuxapt.sh
--- branches/4.0/MgDev/cmake_linuxapt.sh	2026-11-03 00:30:53 UTC (rev 10246)
+++ branches/4.0/MgDev/cmake_linuxapt.sh	2026-11-03 01:40:22 UTC (rev 10247)
@@ -26,6 +26,7 @@
 USE_CCACHE=0
 USE_STATIC_OPENSSL=0
 USE_PHP_SHARED_MBSTRING=0
+PHP_ONLY=0
 while [ $# -gt 0 ]; do    # Until you run out of parameters...
     case "$1" in
         --prefix)
@@ -46,6 +47,9 @@
         --with-php-shared-mbstring)
             USE_PHP_SHARED_MBSTRING=1
+        --php-only)
+            PHP_ONLY=1
         # "infecting" our ccache with root-elevated cached object files is probably a bad look
         # especially if we need to non-elevated ccache builds further down the road
         #--with-ccache)
@@ -59,6 +63,7 @@
             echo "  --working-dir [working directory, default: ~/mapguide_linuxapt_build]"
             echo "  --with-static-openssl [use static openssl]"
             echo "  --with-php-shared-mbstring [build PHP mbstring extension as a shared module]"
+            echo "  --php-only [build and install only the PHP interpreter, then exit]"
             echo "  --help [Display usage]"
             #echo "  --with-ccache [Use ccache]"
             exit
@@ -169,6 +174,86 @@
 echo "Has PHP: ${HAS_PHP}"
 echo "Has Tomcat Connector: ${HAS_TOMCAT_CONNECTOR}"
+# Builds and installs the PHP interpreter. Split out so that --php-only can run just this, for a
+# dev loop that needs an interpreter for the binding test suite without the rest of the web tier.
+build_php()
+    # The configure flavour has to be decided before the reuse test below, which compares it with
+    # what an existing tree was configured with.
+    PHP_APXS_OPT=
+    if [ -x "${MG_INSTALL_WEB_PREFIX}/apache2/bin/apxs" ]; then
+        PHP_APXS_OPT="--with-apxs2=${MG_INSTALL_WEB_PREFIX}/apache2/bin/apxs"
+    fi
+    # The MapGuide extension is built against a thread-safe PHP, because the web tier it ships with
+    # runs Apache's threaded MPM. --with-apxs2 already implies that; a CLI-only PHP has to ask for
+    # it, or the extension refuses to load with "Module compiled with build ID=API...,TS / PHP
+    # compiled with build ID=API...,NTS".
+    PHP_ZTS_OPT=
+    if [ -z "$PHP_APXS_OPT" ]; then
+        PHP_ZTS_OPT="--enable-zts"
+    fi
+    if test $USE_PHP_SHARED_MBSTRING -eq 1; then
+        PHP_MBSTRING_OPT="--enable-mbstring=shared"
+    else
+        PHP_MBSTRING_OPT="--enable-mbstring"
+    fi
+    PHP_NEEDS_BUILD=0
+    if test $HAS_PHP -eq 0; then
+        PHP_NEEDS_BUILD=1
+    elif [ -f "${PHP_WORKDIR}/config.nice" ]; then
+        # An extracted tree is only reusable when it was configured the same way. A tree configured
+        # with --with-apxs2 cannot even `make install` while httpd's headers are absent (install
+        # rebuilds sapi/apache2handler), and one configured without it is an NTS PHP that the TS
+        # extension will not load.
+        if [ -n "$PHP_APXS_OPT" ] && ! grep -q -- "--with-apxs2" "${PHP_WORKDIR}/config.nice"; then
+            echo "PHP is configured without --with-apxs2 but httpd is installed; rebuilding with it"
+            PHP_NEEDS_BUILD=1
+        fi
+        if [ -z "$PHP_APXS_OPT" ] && grep -q -- "--with-apxs2" "${PHP_WORKDIR}/config.nice"; then
+            echo "PHP is configured with --with-apxs2 but httpd is not installed; rebuilding CLI-only"
+            PHP_NEEDS_BUILD=1
+        fi
+        if [ -n "$PHP_ZTS_OPT" ] && ! grep -q -- "--enable-zts" "${PHP_WORKDIR}/config.nice"; then
+            echo "PHP is configured without thread safety; rebuilding with --enable-zts"
+            PHP_NEEDS_BUILD=1
+        fi
+    fi
+    if [ -z "$PHP_APXS_OPT" ] && test $PHP_NEEDS_BUILD -eq 1; then
+        echo "No apxs at ${MG_INSTALL_WEB_PREFIX}/apache2/bin/apxs: building PHP without the Apache module"
+    fi
+    if test $PHP_NEEDS_BUILD -eq 1; then
+        # Reconfigure from clean sources rather than over a half-built tree with stale objects
+        if [ -d "${PHP_WORKDIR}" ] && [ -f "${PHP_WORKDIR}/config.nice" ]; then
+            rm -rf "${PHP_WORKDIR}"
+        fi
+        cd "$SOURCE_DIR/Oem/LinuxApt" || exit
+        if [ ! -d "${PHP_WORKDIR}" ]; then
+            echo "Extracting PHP tarball"
+            tar -jxf php-${PHP_VER}.tar.bz2 -C "${LA_WORKDIR}"
+            check_build
+        fi
+        echo "Configuring PHP"
+        cd "${PHP_WORKDIR}" || exit
+        ./configure --prefix="${MG_INSTALL_WEB_PREFIX}/php" $PHP_APXS_OPT $PHP_ZTS_OPT --with-openssl $PHP_MBSTRING_OPT --enable-gd --with-jpeg --with-libxml 2>&1 | tee "$LINUXAPT_WORK_DIR/configure_php.log"
+        check_build
+        echo "Building PHP. Please wait"
+        make 2>&1 | tee "$LINUXAPT_WORK_DIR/make_php.log"
+        check_build
+    fi
+    echo "Installing PHP"
+    make install 2>&1 | tee "$LINUXAPT_WORK_DIR/make_install_php.log"
+    check_build
+if test $PHP_ONLY -eq 1; then
+    build_php
+    exit 0
+fi
 if test $HAS_HTTPD -eq 0; then
     echo "Extracting httpd tarballs"
@@ -214,30 +299,8 @@
 export MENTOR_DICTIONARY_PATH=${MG_INST_PREFIX}/share/gis/coordsys
 END-OF-ENVVARS
-if test $HAS_PHP -eq 0; then
-    cd "$SOURCE_DIR/Oem/LinuxApt" || exit
-    echo "Extracting PHP tarball"
-    tar -jxf php-${PHP_VER}.tar.bz2 -C "${LA_WORKDIR}"
-    check_build
-    echo "Configuring PHP"
-    cd "${PHP_WORKDIR}" || exit
-    if test $USE_PHP_SHARED_MBSTRING -eq 1; then
-        ./configure --prefix="${MG_INSTALL_WEB_PREFIX}/php" --with-apxs2="${MG_INSTALL_WEB_PREFIX}/apache2/bin/apxs" --with-openssl --enable-mbstring=shared --enable-gd --with-jpeg --with-libxml 2>&1 | tee "$LINUXAPT_WORK_DIR/configure_php.log"
-        check_build
-    else
-        ./configure --prefix="${MG_INSTALL_WEB_PREFIX}/php" --with-apxs2="${MG_INSTALL_WEB_PREFIX}/apache2/bin/apxs" --with-openssl --enable-mbstring --enable-gd --with-jpeg --with-libxml 2>&1 | tee "$LINUXAPT_WORK_DIR/configure_php.log"
-        check_build
-    fi
-    echo "Building PHP. Please wait"
-    make 2>&1 | tee "$LINUXAPT_WORK_DIR/make_php.log"
-    check_build
-fi
+build_php
-cd "${PHP_WORKDIR}" || exit
-echo "Installing PHP"
-make install 2>&1 | tee "$LINUXAPT_WORK_DIR/make_install_php.log"
-check_build
 if test $HAS_TOMCAT_CONNECTOR -eq 0; then
     echo "Extracting Tomcat Connector tarball"
More information about the mapguide-commits mailing list
