[mapguide-commits] r10262 - in branches/4.0/MgDev: . Bindings Bindings/src/Bindings Bindings/src/Bindings/DotNet Bindings/src/Bindings/DotNet/Portable Common Oem Portable Portable/DotNetUnitTest Portable/MgPortable Portable/MgPortable/Services/Rendering Portable/UnitTest Server/src/Gws Server/src/Gws/GwsCommon Server/src/Gws/GwsQueryEngine cmake/configs cmake/modules
svn_mapguide at osgeo.org
Tue Nov 3 05:53:49 PST 2026
Author: jng
Date: 2026-11-03 05:53:48 -0800 (Tue, 03 Nov 2026)
New Revision: 10262
Added:
branches/4.0/MgDev/cmake/configs/Platform.ini.in
branches/4.0/MgDev/Bindings/setup_linux_native_libs.cmd
branches/4.0/MgDev/Bindings/src/Bindings/CMakeLists.txt
branches/4.0/MgDev/Bindings/src/Bindings/DotNet/CMakeLists.txt
branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Portable/CMakeLists.txt
branches/4.0/MgDev/CMakeLists.txt
branches/4.0/MgDev/Common/CMakeLists.txt
branches/4.0/MgDev/Oem/CMakeLists.txt
branches/4.0/MgDev/Portable/CMakeLists.txt
branches/4.0/MgDev/Portable/DotNetUnitTest/Program.cs
branches/4.0/MgDev/Portable/DotNetUnitTest/ResourceServiceTests.cs
branches/4.0/MgDev/Portable/MgPortable/CMakeLists.txt
branches/4.0/MgDev/Portable/MgPortable/Services/Rendering/MappingUtil.cpp
branches/4.0/MgDev/Portable/UnitTest/CMakeLists.txt
branches/4.0/MgDev/Portable/UnitTest/TestFeatureService.cpp
branches/4.0/MgDev/Portable/UnitTest/TestPerformance.cpp
branches/4.0/MgDev/Portable/UnitTest/TestResourceService.cpp
branches/4.0/MgDev/Portable/UnitTest/TestServiceFactory.cpp
branches/4.0/MgDev/Portable/UnitTest/main.cpp
branches/4.0/MgDev/Server/src/Gws/CMakeLists.txt
branches/4.0/MgDev/Server/src/Gws/GwsCommon/CMakeLists.txt
branches/4.0/MgDev/Server/src/Gws/GwsQueryEngine/CMakeLists.txt
branches/4.0/MgDev/Server/src/Gws/GwsQueryEngine/GwsFlatFdoReader.cpp
branches/4.0/MgDev/cmake/modules/FindMapGuideThirdparty.cmake
branches/4.0/MgDev/cmake_bootstrap.sh
branches/4.0/MgDev/cmake_build.sh
#2897: Add Linux build support for MapGuide Portable
Modified: branches/4.0/MgDev/Bindings/setup_linux_native_libs.cmd
--- branches/4.0/MgDev/Bindings/setup_linux_native_libs.cmd 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Bindings/setup_linux_native_libs.cmd 2026-11-03 13:53:48 UTC (rev 10262)
@@ -1,4 +1,5 @@
SET TARBALL=%1
+SET PORTABLE_TARBALL=%2
SET SOVER=4.0.0
if "%TARBALL%"=="" goto :NoTarball
if not exist "%TARBALL%" goto :NoTarball
@@ -27,7 +28,25 @@
copy /Y /L "%~p0\linux-x64\lib64\libMgWebSupport-%SOVER%.so" "%~p0\src\Managed\DotNet\OSGeo.MapGuide.Web\runtimes\linux-x64\native"
copy /Y /L "%~p0\linux-x64\lib64\libMgHttpHandler-%SOVER%.so" "%~p0\src\Managed\DotNet\OSGeo.MapGuide.Web\runtimes\linux-x64\native"
copy /Y /L "%~p0\linux-x64\lib64\liblib_json.so" "%~p0\src\Managed\DotNet\OSGeo.MapGuide.Web\runtimes\linux-x64\native"
+rem MgPortable setup. The portable tarball is optional; it carries MgPortable, its SWIG glue and
+rem the GWS/Renderers/Stylization/Security libraries the portable API needs.
+if "%PORTABLE_TARBALL%"=="" goto :Done
+if not exist "%PORTABLE_TARBALL%" goto :NoPortableTarball
+"%CD%\..\BuildTools\WebTools\7-Zip\7z.exe" x %PORTABLE_TARBALL% -so | "%CD%\..\BuildTools\WebTools\7-Zip\7z.exe" 7z x -aoa -si -ttar -o"%~p0\linux-x64"
+set PORTABLE_NATIVE=%~p0\src\Managed\DotNet\OSGeo.MapGuide.Portable\runtimes\linux-x64\native
+copy /Y /L "%~p0\linux-x64\lib64\libPortableUnmanagedApi.so" "%PORTABLE_NATIVE%"
+copy /Y /L "%~p0\linux-x64\lib64\libMgPortable-%SOVER%.so" "%PORTABLE_NATIVE%"
+copy /Y /L "%~p0\linux-x64\lib64\libMgMdfModel-%SOVER%.so" "%PORTABLE_NATIVE%"
+copy /Y /L "%~p0\linux-x64\lib64\libMgMdfParser-%SOVER%.so" "%PORTABLE_NATIVE%"
+copy /Y /L "%~p0\linux-x64\lib64\libMgRenderers-%SOVER%.so" "%PORTABLE_NATIVE%"
+copy /Y /L "%~p0\linux-x64\lib64\libMgStylization-%SOVER%.so" "%PORTABLE_NATIVE%"
+copy /Y /L "%~p0\linux-x64\lib64\libMgGwsCommon-%SOVER%.so" "%PORTABLE_NATIVE%"
+copy /Y /L "%~p0\linux-x64\lib64\libMgGwsQueryEngine-%SOVER%.so" "%PORTABLE_NATIVE%"
+copy /Y /L "%~p0\linux-x64\lib64\libMgGwsResource-%SOVER%.so" "%PORTABLE_NATIVE%"
goto :Done
+:NoPortableTarball
+echo No MgPortable linux native libs tarball specified or tarball does not exist.
+goto :Done
:NoTarball
echo No linux native libs tarball specified or tarball does not exist.
:Done
\ No newline at end of file
Modified: branches/4.0/MgDev/Bindings/src/Bindings/CMakeLists.txt
--- branches/4.0/MgDev/Bindings/src/Bindings/CMakeLists.txt 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Bindings/src/Bindings/CMakeLists.txt 2026-11-03 13:53:48 UTC (rev 10262)
@@ -12,13 +12,15 @@
${XERCESC_INCLUDE_DIR}
-# We only need to build the .net SWIG glue libs if building for the common subset
-# We don't build this in a regular full end-to-end MG build
-if (MG_COMMON_SUBSET_ONLY)
+# The .net SWIG glue is only needed for the common subset, or for MgPortable (whose glue is the
+# portable API). A regular full end-to-end MG build does not build it otherwise.
+if (MG_COMMON_SUBSET_ONLY OR WITH_PORTABLE)
add_subdirectory(DotNet)
-else (MG_COMMON_SUBSET_ONLY)
+endif (MG_COMMON_SUBSET_ONLY OR WITH_PORTABLE)
+if (NOT MG_COMMON_SUBSET_ONLY)
if (WITH_JAVA)
add_subdirectory(Java)
endif (WITH_JAVA)
add_subdirectory(Php)
-endif (MG_COMMON_SUBSET_ONLY)
+endif (NOT MG_COMMON_SUBSET_ONLY)
Modified: branches/4.0/MgDev/Bindings/src/Bindings/DotNet/CMakeLists.txt
--- branches/4.0/MgDev/Bindings/src/Bindings/DotNet/CMakeLists.txt 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Bindings/src/Bindings/DotNet/CMakeLists.txt 2026-11-03 13:53:48 UTC (rev 10262)
@@ -1,7 +1,17 @@
+file(COPY "dotnetcore_split.i" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
+# PortableApiGen.xml %imports the Foundation, Geometry and PlatformBase glue, so those three are
+# always generated. The MapGuideCommon and Web glue is only needed by the common-libs subset
+# (the published .NET packages); a full build with WITH_PORTABLE only needs the portable glue.
add_subdirectory(Foundation)
add_subdirectory(Geometry)
add_subdirectory(PlatformBase)
-add_subdirectory(MapGuideCommon)
-add_subdirectory(Web)
-file(COPY "dotnetcore_split.i" DESTINATION ${CMAKE_CURRENT_BINARY_DIR})
+if (MG_COMMON_SUBSET_ONLY)
+ add_subdirectory(MapGuideCommon)
+ add_subdirectory(Web)
+endif (MG_COMMON_SUBSET_ONLY)
+if (WITH_PORTABLE)
+ add_subdirectory(Portable)
+endif (WITH_PORTABLE)
Modified: branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Portable/CMakeLists.txt
--- branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Portable/CMakeLists.txt 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Bindings/src/Bindings/DotNet/Portable/CMakeLists.txt 2026-11-03 13:53:48 UTC (rev 10262)
@@ -1,5 +1,16 @@
project(PortableUnmanagedApi)
+# MgPortable.h (and the services it includes) pull in the public DWF Toolkit headers.
+include_directories(
+ ${MG_PORTABLE_DIR}/MgPortable
+ ${MG_OEM_DWF_INCLUDE_DIR}
+ ${MG_OEM_DWF_INCLUDE_DIR}/dwf
+# Keep the portable artifacts together so they can be packaged and excluded as one subtree.
+set(MG_COMPONENT "portable")
+set_install_subdir("portable/")
set(PortableUnmanagedApi_SRCS
${CMAKE_CURRENT_BINARY_DIR}/PortableUnmanagedApi_wrap.cpp
@@ -6,11 +17,18 @@
add_library(PortableUnmanagedApi SHARED ${PortableUnmanagedApi_SRCS})
add_dependencies(PortableUnmanagedApi IMake)
+# PortableApiGen.xml %imports the generated Foundation/Geometry/PlatformBase interfaces.
+add_dependencies(PortableUnmanagedApi
+ FoundationUnmanagedApi
+ GeometryUnmanagedApi
+ PlatformBaseUnmanagedApi)
+add_definitions(-DDWFCORE_STATIC -DDWFTK_STATIC -DDWFTK_USE_DWFCORE_ZLIB -DDWFTK_BUILD_EXPAT -DWHIP_STATIC_LIB)
if (UNIX)
add_definitions(-DDOTNETCORE)
# NOTE: We don't care where this source is generated because the C# source is only built on windows
set(MG_DOTNET_PROJECT_DIR ${CMAKE_CURRENT_BINARY_DIR})
- set_target_properties(PortableUnmanagedApi PROPERTIES INSTALL_RPATH "$ORIGIN")
+ set_target_properties(PortableUnmanagedApi PROPERTIES
+ INSTALL_RPATH "$ORIGIN:$ORIGIN/../../lib64")
endif (UNIX)
if (MSVC)
add_definitions(-DSWIG_PUBLIC_API)
Modified: branches/4.0/MgDev/CMakeLists.txt
--- branches/4.0/MgDev/CMakeLists.txt 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/CMakeLists.txt 2026-11-03 13:53:48 UTC (rev 10262)
@@ -100,7 +100,10 @@
set(MG_SERVER_COMMON_DIR "${CMAKE_CURRENT_SOURCE_DIR}/Server/src/Common")
set(MG_SERVER_SERVICES_DIR "${CMAKE_CURRENT_SOURCE_DIR}/Server/src/Services")
set(MG_SERVER_GWS_DIR "${CMAKE_CURRENT_SOURCE_DIR}/Server/src/Gws")
+set(MG_PORTABLE_DIR "${CMAKE_CURRENT_SOURCE_DIR}/Portable")
+option(WITH_PORTABLE "Build MgPortable (the portable MapGuide API)" OFF)
set(MG_AUTO_GENERATED_HEADER_DIR "${CMAKE_CURRENT_BINARY_DIR}/IncludeAutogenerated")
set(MG_UNIT_TEST_DATA_DIR "${CMAKE_CURRENT_SOURCE_DIR}/UnitTest/TestData")
Modified: branches/4.0/MgDev/Common/CMakeLists.txt
--- branches/4.0/MgDev/Common/CMakeLists.txt 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Common/CMakeLists.txt 2026-11-03 13:53:48 UTC (rev 10262)
@@ -25,6 +25,13 @@
add_subdirectory(Renderers)
add_subdirectory(Stylization)
+elseif (WITH_PORTABLE)
+ # MgPortable renders through Renderers/Stylization, so a portable common-subset build needs
+ # them too. Install them beside MgPortable so the common tarball can exclude them.
+ set_install_subdir("portable/")
+ add_subdirectory(Renderers)
+ add_subdirectory(Stylization)
+ set_install_subdir("")
Modified: branches/4.0/MgDev/Oem/CMakeLists.txt
--- branches/4.0/MgDev/Oem/CMakeLists.txt 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Oem/CMakeLists.txt 2026-11-03 13:53:48 UTC (rev 10262)
@@ -24,9 +24,11 @@
# at the moment, we are just using the system-provided version of GEOS
#set(GEOS_ENABLE_TESTS OFF)
#add_subdirectory(geos)
-if (NOT MG_COMMON_SUBSET_ONLY)
+# MgPortable consumes the DWF Toolkit (DrawingService), so the DWF tree is required whenever
+# MgPortable is built, including in a common-libs subset tree.
+if (NOT MG_COMMON_SUBSET_ONLY OR WITH_PORTABLE)
add_subdirectory(DWFTK)
-endif (NOT MG_COMMON_SUBSET_ONLY)
+endif (NOT MG_COMMON_SUBSET_ONLY OR WITH_PORTABLE)
add_subdirectory(CsMapLibrary)
Modified: branches/4.0/MgDev/Portable/CMakeLists.txt
--- branches/4.0/MgDev/Portable/CMakeLists.txt 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Portable/CMakeLists.txt 2026-11-03 13:53:48 UTC (rev 10262)
@@ -11,5 +11,11 @@
+# MgPortable links the GWS libraries. A full build has already added them under Server; a
+# common-libs subset tree has not, so add only them here.
+ add_subdirectory(${MG_SERVER_GWS_DIR} ${CMAKE_CURRENT_BINARY_DIR}/Gws)
add_subdirectory(MgPortable)
add_subdirectory(UnitTest)
Modified: branches/4.0/MgDev/Portable/DotNetUnitTest/Program.cs
--- branches/4.0/MgDev/Portable/DotNetUnitTest/Program.cs 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Portable/DotNetUnitTest/Program.cs 2026-11-03 13:53:48 UTC (rev 10262)
@@ -22,11 +22,10 @@
catch (AssertException ex)
- //Console.WriteLine(ex.Message);
failed++;
Console.Write("F");
+ Console.WriteLine("\nFAILED: " + method.Method.Name + ": " + ex.Message);
Trace.TraceInformation("FAILED: " + method.Method.Name);
- //Trace.TraceInformation("F");
@@ -34,6 +33,8 @@
MgPortablePlatform.Initialize("Platform.ini");
+ try
var resTest = new ResourceServiceTests();
try
@@ -140,6 +141,12 @@
Console.WriteLine("\n{0} tests passed {1} tests failed", passed, failed);
Trace.TraceInformation("{0} tests passed {1} tests failed", passed, failed);
+ Environment.ExitCode = failed == 0 ? 0 : 1;
+ finally
+ MgPortablePlatform.Terminate();
Modified: branches/4.0/MgDev/Portable/DotNetUnitTest/ResourceServiceTests.cs
--- branches/4.0/MgDev/Portable/DotNetUnitTest/ResourceServiceTests.cs 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Portable/DotNetUnitTest/ResourceServiceTests.cs 2026-11-03 13:53:48 UTC (rev 10262)
@@ -20,12 +20,13 @@
string resourceDataName = "World_Countries.sdf";
string resourceDataName2 = "New_World_Countries.sdf";
- string repositoryHeaderFileName = "..\\UnitTestFiles\\SampleRepositoryHeader.xm";
- string repositoryContentFileName = "..\\UnitTestFiles\\SampleRepositoryContent.xm";
- string resourceContentFileName = "..\\UnitTestFiles\\TEST.FeatureSource";
- string resourceContentFileName2 = "..\\UnitTestFiles\\TEST.LayerDefinition";
- string dataFileName = "..\\UnitTestFiles\\World_Countries.sdf";
- string packageName = "..\\UnitTestFiles\\Shuttle.zip";
+ // Forward slashes are accepted by the .NET file APIs on Windows and are required on POSIX.
+ string repositoryHeaderFileName = "../UnitTestFiles/SampleRepositoryHeader.xm";
+ string repositoryContentFileName = "../UnitTestFiles/SampleRepositoryContent.xm";
+ string resourceContentFileName = "../UnitTestFiles/TEST.FeatureSource";
+ string resourceContentFileName2 = "../UnitTestFiles/TEST.LayerDefinition";
+ string dataFileName = "../UnitTestFiles/World_Countries.sdf";
+ string packageName = "../UnitTestFiles/Shuttle.zip";
public void TestStart()
@@ -227,7 +228,8 @@
string xml = byteReader.ToString();
Assert.True(xml.Length > 0);
Assert.True(xml.Contains("<FeatureSource"));
- Assert.True(xml.EndsWith("</FeatureSource>"));
+ // The fixture ends with a newline, which some platforms preserve.
+ Assert.True(xml.TrimEnd().EndsWith("</FeatureSource>"));
catch (MgException ex)
@@ -482,11 +484,11 @@
var resource = new MgResourceIdentifier("Library://UnitTests/Data/TEST.FeatureSource");
- var source = new MgByteSource("..\\UnitTestFiles\\TEST.FeatureSource");
+ var source = new MgByteSource("../UnitTestFiles/TEST.FeatureSource");
var reader = source.GetReader();
service.SetResource(resource, reader, null);
- var dataSource = new MgByteSource("..\\UnitTestFiles\\TEST.sdf");
+ var dataSource = new MgByteSource("../UnitTestFiles/TEST.sdf");
var dataReader = dataSource.GetReader();
service.SetResourceData(resource, "TEST.sdf", "File", dataReader);
@@ -512,7 +514,10 @@
var fact = new MgPortableServiceFactory();
var service = (MgResourceService)fact.CreateService(MgServiceType.ResourceService);
- Assert.ThrowsWithCode(() => service.EnumerateUnmanagedData("", true, "", ""), MgExceptionCodes.MgNotImplementedException);
+ // The type must be Folders, Files or Both; MgResourceUnmanagedDataType is a
+ // PlatformBase constant class that the SWIG surface does not expose.
+ Assert.AreEqual(MgMimeType.Xml, service.EnumerateUnmanagedData("", false, "Folders", "").MimeType);
+ Assert.AreEqual(MgMimeType.Xml, service.EnumerateUnmanagedData("", true, "Files", "").MimeType);
Modified: branches/4.0/MgDev/Portable/MgPortable/CMakeLists.txt
--- branches/4.0/MgDev/Portable/MgPortable/CMakeLists.txt 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Portable/MgPortable/CMakeLists.txt 2026-11-03 13:53:48 UTC (rev 10262)
@@ -30,6 +30,10 @@
add_library(MgPortable${MG_VERSION_SUFFIX} SHARED ${MgPortable_SRCS})
+# The library installs beside the GWS libraries under <prefix>/portable/lib64, while the
+# common libraries it links stay in <prefix>/lib64.
+set_target_properties(MgPortable${MG_VERSION_SUFFIX} PROPERTIES
install(TARGETS MgPortable${MG_VERSION_SUFFIX} DESTINATION ${LIB_INSTALL_DIR} COMPONENT ${MG_COMPONENT})
install_symlink(libMgPortable${MG_VERSION_SUFFIX}.so libMgPortable.so ${MG_COMPONENT})
@@ -38,12 +42,15 @@
${XERCESC_LIBRARIES}
${FDO_LIBRARY}
${FDO_EXPRESSIONENGINE_LIBRARY}
- #dwfcore
- #dwftk
- #dwfwhiptk
+ # DrawingService.cpp and DrawingServiceUtil.cpp use the DWF Toolkit directly. The static
+ # libraries are linked the same way MgServerDrawingService links them.
+ -Wl,--exclude-libs,ALL
+ dwfcore-1.7.0
+ dwftk-7.7.0
MgMdfModel${MG_VERSION_SUFFIX}
MgMdfParser${MG_VERSION_SUFFIX}
MgFoundation${MG_VERSION_SUFFIX}
+ MgGeometry${MG_VERSION_SUFFIX}
MgPlatformBase${MG_VERSION_SUFFIX}
MgSecurity${MG_VERSION_SUFFIX}
MgRenderers${MG_VERSION_SUFFIX}
@@ -50,5 +57,6 @@
MgStylization${MG_VERSION_SUFFIX}
MgGwsCommon${MG_VERSION_SUFFIX}
MgGwsQueryEngine${MG_VERSION_SUFFIX}
+ dl
pthread
Modified: branches/4.0/MgDev/Portable/MgPortable/Services/Rendering/MappingUtil.cpp
--- branches/4.0/MgDev/Portable/MgPortable/Services/Rendering/MappingUtil.cpp 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Portable/MgPortable/Services/Rendering/MappingUtil.cpp 2026-11-03 13:53:48 UTC (rev 10262)
@@ -35,6 +35,7 @@
#include "SymbolVisitor.h"
#include "SymbolDefinition.h"
#include "Services/Feature/TransformCache.h"
+#include "System/TimerUtil.h"
#include <algorithm>
@@ -46,7 +47,12 @@
#ifndef _WIN32
#define _wcsnicmp wcsncasecmp
-extern long GetTickCount();
+// The timing calls below are Debug-only and use GetTickCount(), which only exists on Windows.
+// Provide the same millisecond counter on POSIX so a Debug build links.
+static long GetTickCount()
+ return static_cast<long>(MgPortableTimerUtil::GetTime());
#endif
Modified: branches/4.0/MgDev/Portable/UnitTest/CMakeLists.txt
--- branches/4.0/MgDev/Portable/UnitTest/CMakeLists.txt 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Portable/UnitTest/CMakeLists.txt 2026-11-03 13:53:48 UTC (rev 10262)
@@ -5,7 +5,6 @@
${CMAKE_CURRENT_SOURCE_DIR}/../MgPortable
${CMAKE_CURRENT_SOURCE_DIR}/../MgPortable/Services
- ${CPPUNIT_INCLUDE_DIR}
${MG_COMMON_DIR}/PlatformBase
${MG_COMMON_DIR}/CoordinateSystem
${MG_COMMON_DIR}/Security
@@ -40,10 +39,10 @@
${ACE_LIBRARY}
${FDO_LIBRARY}
- ${CPPUNIT_LIBRARIES}
Modified: branches/4.0/MgDev/Portable/UnitTest/TestFeatureService.cpp
--- branches/4.0/MgDev/Portable/UnitTest/TestFeatureService.cpp 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Portable/UnitTest/TestFeatureService.cpp 2026-11-03 13:53:48 UTC (rev 10262)
@@ -90,7 +90,7 @@
const STRING provider = L"OSGeo.SDF";
#ifdef _WIN32
- const STRING connectionString = L"File=..\\UnitTestFiles\\Sheboygan_Parcels.sdf";
+ const STRING connectionString = L"File=../UnitTestFiles/Sheboygan_Parcels.sdf";
#else
#endif
Modified: branches/4.0/MgDev/Portable/UnitTest/TestPerformance.cpp
--- branches/4.0/MgDev/Portable/UnitTest/TestPerformance.cpp 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Portable/UnitTest/TestPerformance.cpp 2026-11-03 13:53:48 UTC (rev 10262)
@@ -81,8 +81,8 @@
MgResourceIdentifier resourceIdentifier1(L"Library://UnitTests/Data/Sheboygan_Parcels.FeatureSource");
#ifdef _WIN32
- STRING resourceContentFileName1 = L"..\\UnitTestFiles\\Sheboygan_Parcels.FeatureSource";
- STRING dataFileName1 = L"..\\UnitTestFiles\\Sheboygan_Parcels.sdf";
+ STRING resourceContentFileName1 = L"../UnitTestFiles/Sheboygan_Parcels.FeatureSource";
+ STRING dataFileName1 = L"../UnitTestFiles/Sheboygan_Parcels.sdf";
#else
Modified: branches/4.0/MgDev/Portable/UnitTest/TestResourceService.cpp
--- branches/4.0/MgDev/Portable/UnitTest/TestResourceService.cpp 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Portable/UnitTest/TestResourceService.cpp 2026-11-03 13:53:48 UTC (rev 10262)
@@ -51,12 +51,12 @@
STRING resourceDataName2 = L"New_World_Countries.sdf";
#ifdef _WIN32
-STRING repositoryHeaderFileName = L"..\\UnitTestFiles\\SampleRepositoryHeader.xml";
-STRING repositoryContentFileName = L"..\\UnitTestFiles\\SampleRepositoryContent.xml";
-STRING resourceContentFileName = L"..\\UnitTestFiles\\TEST.FeatureSource";
-STRING resourceContentFileName2 = L"..\\UnitTestFiles\\TEST.LayerDefinition";
-STRING dataFileName = L"..\\UnitTestFiles\\World_Countries.sdf";
-STRING packageName = L"..\\UnitTestFiles\\Shuttle.zip";
+STRING repositoryHeaderFileName = L"../UnitTestFiles/SampleRepositoryHeader.xml";
+STRING repositoryContentFileName = L"../UnitTestFiles/SampleRepositoryContent.xml";
+STRING resourceContentFileName = L"../UnitTestFiles/TEST.FeatureSource";
+STRING resourceContentFileName2 = L"../UnitTestFiles/TEST.LayerDefinition";
+STRING dataFileName = L"../UnitTestFiles/World_Countries.sdf";
+STRING packageName = L"../UnitTestFiles/Shuttle.zip";
#else
@@ -958,8 +958,8 @@
resource = new MgResourceIdentifier(L"Library://UnitTests/Data/TEST.FeatureSource");
#ifdef _WIN32
- STRING rcName = L"..\\UnitTestFiles\\TEST.FeatureSource";
- STRING dfName = L"..\\UnitTestFiles\\TEST.sdf";
+ STRING rcName = L"../UnitTestFiles/TEST.FeatureSource";
+ STRING dfName = L"../UnitTestFiles/TEST.sdf";
#else
@@ -1148,7 +1148,7 @@
pService->DeleteResource(&resId);
- Ptr<MgByteSource> byteSource = new MgByteSource(L"..\\UnitTestFiles\\PackageTest.mgp");
+ Ptr<MgByteSource> byteSource = new MgByteSource(L"../UnitTestFiles/PackageTest.mgp");
Ptr<MgByteReader> byteReader = byteSource->GetReader();
//This package contains an UPDATEREPOSITORY directive, which should no-op when loaded by mg-desktop
Modified: branches/4.0/MgDev/Portable/UnitTest/TestServiceFactory.cpp
--- branches/4.0/MgDev/Portable/UnitTest/TestServiceFactory.cpp 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Portable/UnitTest/TestServiceFactory.cpp 2026-11-03 13:53:48 UTC (rev 10262)
@@ -897,23 +897,23 @@
MgResourceIdentifier resourceIdentifier8(L"Library://UnitTests/Data/FdoJoin.FeatureSource");
MgResourceIdentifier resourceIdentifier9(L"Library://UnitTests/Data/SecuredCredentials.FeatureSource");
#ifdef _WIN32
- STRING resourceContentFileName2 = L"..\\UnitTestFiles\\Redding_Parcels.FeatureSource";
- STRING resourceContentFileName3 = L"..\\UnitTestFiles\\Sheboygan_BuildingOutlines.FeatureSource";
- STRING resourceContentFileName4 = L"..\\UnitTestFiles\\Sheboygan_VotingDistricts.FeatureSource";
- STRING resourceContentFileName5 = L"..\\UnitTestFiles\\TESTChainedInner1ToManyJoin.FeatureSource";
- STRING resourceContentFileName6 = L"..\\UnitTestFiles\\Empty.FeatureSource";
- STRING resourceContentFileName7 = L"..\\UnitTestFiles\\Sheboygan_Parcels_Writable.FeatureSource";
- STRING resourceContentFileName8 = L"..\\UnitTestFiles\\UT_FdoJoin.FeatureSource";
- STRING resourceContentFileName9 = L"..\\UnitTestFiles\\SecuredCredentials.fs";
- STRING dataFileName2 = L"..\\UnitTestFiles\\Redding_Parcels.shp";
- STRING dataFileName3 = L"..\\UnitTestFiles\\Redding_Parcels.dbf";
- STRING dataFileName4 = L"..\\UnitTestFiles\\Redding_Parcels.shx";
- STRING dataFileName5 = L"..\\UnitTestFiles\\Sheboygan_BuildingOutlines.sdf";
- STRING dataFileName6 = L"..\\UnitTestFiles\\Sheboygan_VotingDistricts.sdf";
- STRING dataFileName7 = L"..\\UnitTestFiles\\Empty.sdf";
- STRING dataFileName8 = L"..\\UnitTestFiles\\JoinTest.sqlite";
+ STRING resourceContentFileName2 = L"../UnitTestFiles/Redding_Parcels.FeatureSource";
+ STRING resourceContentFileName3 = L"../UnitTestFiles/Sheboygan_BuildingOutlines.FeatureSource";
+ STRING resourceContentFileName4 = L"../UnitTestFiles/Sheboygan_VotingDistricts.FeatureSource";
+ STRING resourceContentFileName5 = L"../UnitTestFiles/TESTChainedInner1ToManyJoin.FeatureSource";
+ STRING resourceContentFileName6 = L"../UnitTestFiles/Empty.FeatureSource";
+ STRING resourceContentFileName7 = L"../UnitTestFiles/Sheboygan_Parcels_Writable.FeatureSource";
+ STRING resourceContentFileName8 = L"../UnitTestFiles/UT_FdoJoin.FeatureSource";
+ STRING resourceContentFileName9 = L"../UnitTestFiles/SecuredCredentials.fs";
+ STRING dataFileName2 = L"../UnitTestFiles/Redding_Parcels.shp";
+ STRING dataFileName3 = L"../UnitTestFiles/Redding_Parcels.dbf";
+ STRING dataFileName4 = L"../UnitTestFiles/Redding_Parcels.shx";
+ STRING dataFileName5 = L"../UnitTestFiles/Sheboygan_BuildingOutlines.sdf";
+ STRING dataFileName6 = L"../UnitTestFiles/Sheboygan_VotingDistricts.sdf";
+ STRING dataFileName7 = L"../UnitTestFiles/Empty.sdf";
+ STRING dataFileName8 = L"../UnitTestFiles/JoinTest.sqlite";
#else
Modified: branches/4.0/MgDev/Portable/UnitTest/main.cpp
--- branches/4.0/MgDev/Portable/UnitTest/main.cpp 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Portable/UnitTest/main.cpp 2026-11-03 13:53:48 UTC (rev 10262)
@@ -53,6 +53,15 @@
#if !defined(USING_VLD)
_CrtSetDbgFlag(_CRTDBG_ALLOC_MEM_DF | _CRTDBG_LEAK_CHECK_DF);
+ // The leak report is written to the debugger's output, which a plain command-line run
+ // discards. Set MG_CRT_LEAK_CHECK=1 to send it to stderr instead, so it shows up in the
+ // run's console output and in the log file a test run tees to.
+ if (getenv("MG_CRT_LEAK_CHECK") != NULL)
+ _CrtSetReportMode(_CRT_WARN, _CRTDBG_MODE_FILE);
+ _CrtSetReportFile(_CRT_WARN, _CRTDBG_FILE_STDERR);
#ifdef _DEBUG
// to debug memory leaks, set a breakpoint here and set iBlock
// to the block allocation you want to break on
Modified: branches/4.0/MgDev/Server/src/Gws/CMakeLists.txt
--- branches/4.0/MgDev/Server/src/Gws/CMakeLists.txt 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Server/src/Gws/CMakeLists.txt 2026-11-03 13:53:48 UTC (rev 10262)
@@ -1,7 +1,14 @@
set(MG_COMPONENT "common")
set(CMAKE_INSTALL_PREFIX "${MG_INSTALL_PREFIX}")
-set_install_subdir("")
+# In a common-libs subset tree the GWS libraries are only built for MgPortable. Install them
+# beside it so the common tarball can exclude them wholesale.
+if (MG_COMMON_SUBSET_ONLY AND WITH_PORTABLE)
+ set(MG_COMPONENT "portable")
+else (MG_COMMON_SUBSET_ONLY AND WITH_PORTABLE)
+endif (MG_COMMON_SUBSET_ONLY AND WITH_PORTABLE)
add_subdirectory(GwsCommon)
add_subdirectory(GwsQueryEngine)
Modified: branches/4.0/MgDev/Server/src/Gws/GwsCommon/CMakeLists.txt
--- branches/4.0/MgDev/Server/src/Gws/GwsCommon/CMakeLists.txt 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Server/src/Gws/GwsCommon/CMakeLists.txt 2026-11-03 13:53:48 UTC (rev 10262)
@@ -24,5 +24,13 @@
add_library(MgGwsCommon${MG_VERSION_SUFFIX} SHARED ${GwsCommon_SRCS})
+# A portable build links the GWS libraries into libMgPortable with --no-undefined, so their own
+# FDO/Foundation/Geometry dependencies have to be explicit rather than resolved by the server
+# process at load time.
+target_link_libraries(MgGwsCommon${MG_VERSION_SUFFIX}
+ ${FDO_LIBRARY}
+ MgFoundation${MG_VERSION_SUFFIX}
install(TARGETS MgGwsCommon${MG_VERSION_SUFFIX} DESTINATION ${LIB_INSTALL_DIR} COMPONENT ${MG_COMPONENT})
install_symlink(libMgGwsCommon${MG_VERSION_SUFFIX}.so libMgGwsCommon.so ${MG_COMPONENT})
Modified: branches/4.0/MgDev/Server/src/Gws/GwsQueryEngine/CMakeLists.txt
--- branches/4.0/MgDev/Server/src/Gws/GwsQueryEngine/CMakeLists.txt 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Server/src/Gws/GwsQueryEngine/CMakeLists.txt 2026-11-03 13:53:48 UTC (rev 10262)
@@ -50,5 +50,10 @@
add_library(MgGwsQueryEngine${MG_VERSION_SUFFIX} SHARED ${GwsQueryEngine_SRCS})
+target_link_libraries(MgGwsQueryEngine${MG_VERSION_SUFFIX}
+ ${FDO_LIBRARY}
+ ${FDO_EXPRESSIONENGINE_LIBRARY}
+ MgGwsCommon${MG_VERSION_SUFFIX}
install(TARGETS MgGwsQueryEngine${MG_VERSION_SUFFIX} DESTINATION ${LIB_INSTALL_DIR} COMPONENT ${MG_COMPONENT})
install_symlink(libMgGwsQueryEngine${MG_VERSION_SUFFIX}.so libMgGwsQueryEngine.so ${MG_COMPONENT})
Modified: branches/4.0/MgDev/Server/src/Gws/GwsQueryEngine/GwsFlatFdoReader.cpp
--- branches/4.0/MgDev/Server/src/Gws/GwsQueryEngine/GwsFlatFdoReader.cpp 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/Server/src/Gws/GwsQueryEngine/GwsFlatFdoReader.cpp 2026-11-03 13:53:48 UTC (rev 10262)
@@ -26,7 +26,16 @@
#include "GwsQueryEngineImp.h"
#ifndef _WIN32
+#include <sys/time.h>
+// CGwsTimer is compiled on every platform but the Windows GetTickCount() it calls does not exist
+// on POSIX. Only GWSTIMER expands to it, which is a Debug-only macro.
+ timeval tv;
+ gettimeofday(&tv, NULL);
+ return (tv.tv_sec * 1000) + (tv.tv_usec / 1000);
#endif
Added: branches/4.0/MgDev/cmake/configs/Platform.ini.in
--- branches/4.0/MgDev/cmake/configs/Platform.ini.in (rev 0)
+++ branches/4.0/MgDev/cmake/configs/Platform.ini.in 2026-11-03 13:53:48 UTC (rev 10262)
@@ -0,0 +1,336 @@
+# MapGuide Portable Platform Configuration File
+# The following configuration is based on a single CPU with a single core.
+# WARNING: BE VERY CAREFUL WHEN MODIFYING THIS FILE AS IT COULD
+# ADVERSLY IMPACT APPLICATION PERFORMANCE
+# When saving this file use a UTF-8 encoding.
+# COMMON VALIDATION INFORMATION
+# (Unless otherwise noted under the property description)
+# String Property Range of String Length Reserved Characters
+# File Name 0 < Length <= 128 \/:*?"<>|
+# Folder Name 0 < Length <= 128 \/:*?"<>|
+# Log Parameters 0 <= Length <= 1024
+# Password 0 <= Length <= 64 \t\r\n\v\f
+# Path 0 < Length <= 255 *?"<>|
+# Numeric Property Range of Numeric Value
+# Port Number 0 <= Value <= 65535
+[GeneralProperties]
+# G E N E R A L
+# Property Name Description
+# DefaultMessageLocale ISO 639-1 name for the message locale
+# Length = 2
+# Example: en
+# FdoPath Path where FDO is installed
+# Locale The server's locale. If left blank it will default to the operating system locale
+# 0 <= Length <= 255
+# Format : lang[_country_region.code_page]
+# Example (Windows): English_United States.1252
+# Example Linux) : en_US.iso88591
+# LogsDelimiter Delimiter that separates the data fields in
+# the log files
+# LogsDetail Level of logging detail per service
+# 0 - Errors without parameters (default)
+# 1 - Warnings and Errors with parameters
+# 2 - Trace, Warnings, and Errors
+# 3 - Internal Trace, Trace, Warnings, and Errors
+# Service keys: ResourceService, DrawingService, FeatureService, MappingService,
+# RenderingService, TileService, KmlService, ServerAdminService, SiteService
+# Example: MappingService:3,FeatureService:1
+# LogsPath Path where log files are stored
+# MentorDictionaryPath Path where the CS-Map cooridnate system dictionaries is installed
+# PreCacheMaps The list of maps to precache at server startup.
+# Value = Map resource name(s) separated by ","
+# Example: Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition
+# Renderer Image renderer to use (GD or AGG)
+# ResourcesPath Path where the localization resource files are stored
+# TempPath Path where the temporary files are stored
+# WfsDocumentPath Document path location for WFS documents
+# WmsDocumentPath Document path location for WMS documents
+DefaultMessageLocale = en
+FdoPath = @FDO_LIBRARY_DIR@
+MentorDictionaryPath = @MG_INSTALL_COORDSYS_PREFIX_ABS@
+Locale =
+LogsDelimiter = \t
+LogsDetail =
+LogsPath = Logs/
+PreCacheMaps =
+Renderer = AGG
+ResourcesPath = Resources/
+TempPath = Temp/
+WfsDocumentPath = Wfs/
+WmsDocumentPath = Wms/
+[DrawingServiceProperties]
+# D R A W I N G S E R V I C E
+[FeatureServiceProperties]
+# F E A T U R E S E R V I C E
+# CacheSize Max # of internal data objects to cache
+# (schemas, classes, etc...)
+# 0 < Value <= 5000
+# CacheTimeLimit Time duration in seconds for how long to
+# cache the internal data objects
+# 0 < Value <= 2147483647
+# CacheTimerInterval Time interval in seconds for when the server
+# checks for expired cache entries
+# DataConnectionPoolEnabled FDO connection pooling
+# 0 = disabled, 1 = enabled
+# DataConnectionPoolExcludedProviders The list of providers to exclude from connection pooling.
+# 0 <= Length <= 1024
+# Value = provider name(s) separated by ","
+# Example: OSGeo.SDF,OSGeo.SHP
+# JoinQueryBatchSize Join query batch size
+# 1 < Value <= 10000
+# UseFdoJoinOptimization Determines whether to use FDO Join APIs for feature joins between
+# classes from the same Feature Source for FDO providers that support it
+# 1 = Use FDO Join APIs if possible, 0 = Fallback to GwsQueryEngine
+CacheSize = 100
+CacheTimeLimit = 86400
+CacheTimerInterval = 3600
+DataConnectionPoolEnabled = 1
+DataConnectionPoolExcludedProviders= OSGeo.SDF,OSGeo.SHP,OSGeo.SQLite
+JoinQueryBatchSize = 1000
+UseFdoJoinOptimization = 1
+[MappingServiceProperties]
+# M A P P I N G S E R V I C E
+# LegendFont Font to use when rendering legend elements
+# 0 < Length <= 255
+LegendFont = Arial
+[RenderingServiceProperties]
+# R E N D E R I N G S E R V I C E
+# TileExtentOffset Max request extent offset to use when
+# requesting features for a tile, specified as
+# a factor of the tile size
+# 0.0 <= Value <= 1.0
+# RasterGridSize Size of raster re-projection grid in pixels
+# MinRasterGridSize Minimum size of raster re-projection grid in
+# pixels. This should be less than RasterGridSize.
+# RasterGridSizeOverrideRatio If the RasterGridSize is larger than the
+# image's height or width multiplied by the
+# RasterGridSizeOverrideRatio, then the
+# RasterGridSize is overridden with this value.
+# Set to 0 or 1 to disable the override.
+# RasterGridSizeForPlot Size of raster re-projection grid in pixels
+# for plot
+# MinRasterGridSizeForPlot Minimum size of raster re-projection grid in
+# pixels for plot. This must be less than
+# RasterGridSizeForPlot.
+# RasterGridSizeOverrideRatioForPlot If the RasterGridSizeForPlot is larger than the
+# RasterGridSizeOverrideRatioForPlot, then the
+# RasterGridSizeForPlot is overridden with this
+# value.
+# Change this setting to 1 to disable the
+# override.
+# RenderSelectionBatchSize The batch size to use when rendering a selection
+# ClampPoints Specifies whether point coordinates are clamped
+# to integer values before passing them to the
+# AGG renderer (experimental)
+# 0 = false and 1 = true
+# GeneralizeData Specifies whether feature geometry is generalized
+# before being rendered (experimental)
+TileExtentOffset = 0.35
+RasterGridSize = 100
+MinRasterGridSize = 10
+RasterGridSizeOverrideRatio = 0.25
+RasterGridSizeForPlot = 50
+MinRasterGridSizeForPlot = 5
+RasterGridSizeOverrideRatioForPlot = 0.10
+RenderSelectionBatchSize = 50000
+ClampPoints = 0
+GeneralizeData = 0
+[ResourceServiceProperties]
+# R E S O U R C E S E R V I C E
+# LibraryRepositoryPath Path where the Library repository is stored
+# LibraryResourceDataFilePath Path where the Library resource data files
+# are stored
+# PackagesPath Path where the resource packages can be found
+# ResourceDataFileTrashFolderName Folder where the repository trash files are
+# stored
+# ResourceSchemaFilePath Path where the resource schema files are
+# stored
+# SessionRepositoryPath Path where the Session repository is stored
+# SessionResourceDataFilePath Path where the Session resource data files
+# are stored
+# SiteRepositoryPath Path where the Site repository is stored
+LibraryRepositoryPath = Repositories/Library/Content/
+LibraryResourceDataFilePath = Repositories/Library/DataFiles/
+PackagesPath = Packages/
+ResourceDataFileTrashFolderName = Trash
+ResourceSchemaFilePath = Schema/
+SessionRepositoryPath = Repositories/Session/Content/
+SessionResourceDataFilePath = Repositories/Session/DataFiles/
+SiteRepositoryPath = Repositories/Site/
+[TileServiceProperties]
+# T I L E S E R V I C E
+# RenderOnly Renders the tile only
+# TileCachePath Root path of the image tile cache
+# TileColumnsPerFolder Number of columns of tiles per folder
+# 0 < Value <= 1000
+# TileRowsPerFolder Number of rows of tiles per folder
+# DefaultTileSizeX Width of generated tiles in pixels
+# 50 < value <= 10000
+# DefaultTileSizeY Height of generated tiles in pixels
+# ImageFormat Image format for generated tiles
+# PNG, PNG8, GIF or JPG
+RenderOnly = 0
+TileCachePath = Repositories/TileCache/
+TileColumnsPerFolder = 30
+TileRowsPerFolder = 30
+DefaultTileSizeX = 300
+DefaultTileSizeY = 300
+ImageFormat = PNG
+[AccessLogProperties]
+# A C C E S S L O G
+# Enabled 0 = log disabled, 1 = log enabled
+# Filename Name of the log file
+# Parameters Log parameters
+Enabled = 1
+Filename = "Access.log"
+Parameters = CLIENT,CLIENTIP,USER,OPID
+[AdminLogProperties]
+# A D M I N L O G (Not used by mg-portable)
+Enabled = 1
+Filename = "Admin.log"
+[AuthenticationLogProperties]
+# A U T H E N T I C A T I O N L O G (Not used by mg-portable)
+Enabled = 1
+Filename = "Authentication.log"
+[ErrorLogProperties]
+# E R R O R L O G
+Enabled = 1
+Filename = "Error.log"
+Parameters = CLIENT,CLIENTIP,USER,ERROR,STACKTRACE
+[TraceLogProperties]
+# T R A C E L O G
+Enabled = 0
+Filename = "Trace.log"
+Parameters = INFO
+[FontAliases]
+# F O N T A L I A S E S
+# This section is used to map a font family name to another. The left side
+# is a name that might be specified by the user and the right side is what
+# font to actually use.
+MS ゴシック = MS Gothic
+MS Pゴシック = MS PGothic
+MS 明朝 = MS Mincho
+MS P明朝 = MS PMincho
+굴림 = Gulim
+굴림체 = GulimChe
+돋움 = Dotum
+돋움체 = DotumChe
+바탕 = Batang
+바탕체 = BatangChe
+궁서 = Gungsuh
+궁서체 = GungsuhChe
+[UnmanagedDataMappings]
+# U N M A N A G E D D A T A M A P P I N G S
+# This section is used to map a mapping name to an unmanaged data folder.
Modified: branches/4.0/MgDev/cmake/modules/FindMapGuideThirdparty.cmake
--- branches/4.0/MgDev/cmake/modules/FindMapGuideThirdparty.cmake 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/cmake/modules/FindMapGuideThirdparty.cmake 2026-11-03 13:53:48 UTC (rev 10262)
@@ -77,7 +77,7 @@
find_package(XercesC REQUIRED)
endif (INTERNAL_XERCES)
if (INTERNAL_GD)
message(STATUS "Using internal GD")
@@ -155,7 +155,7 @@
find_package(PNG REQUIRED)
endif (INTERNAL_PNG)
if (INTERNAL_JSON)
message(STATUS "Using internal jsoncpp")
@@ -199,4 +199,10 @@
+# MgPortable and the GWS libraries a portable common-subset build adds need FDO. The rest of the
+# subset does not, so only look for it when portable is on.
+ find_package(FDO REQUIRED)
find_package(TCLAP REQUIRED)
Modified: branches/4.0/MgDev/cmake_bootstrap.sh
--- branches/4.0/MgDev/cmake_bootstrap.sh 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/cmake_bootstrap.sh 2026-11-03 13:53:48 UTC (rev 10262)
@@ -10,6 +10,7 @@
INTERNAL_JSON=0
INTERNAL_GEOS=0
COMMON_SUBSET_ONLY=0
+WITH_PORTABLE=0
BUILD_CPU=32
BUILD_CONFIG=Release
HAVE_SYSTEM_XERCES=0
@@ -31,6 +32,11 @@
--common-subset-only)
COMMON_SUBSET_ONLY=1
+ --with-portable)
+ # MgPortable needs the renderers/stylization libraries even in a common-subset
+ # tree, so the graphics thirdparty libs have to be built there too.
+ WITH_PORTABLE=1
--with-all-internal)
INTERNAL_ACE=1
INTERNAL_ZLIB=1
@@ -91,6 +97,8 @@
echo " --with-internal-json [Build/Use internal JsonCpp]"
echo " --with-internal-geos [Build/Use internal GEOS]"
echo " --with-all-internal [Build/Use all internal libs]"
+ echo " --common-subset-only [Only prepare the common libs subset]"
+ echo " --with-portable [Also build the graphics libs a portable subset needs]"
echo " --with-ccache [Use ccache]"
exit
@@ -197,7 +205,13 @@
check_build
fi
mkdir -p "${OEM_WORK_DIR}/gd"
-if [ "$COMMON_SUBSET_ONLY" != "1" ] && [ "$INTERNAL_ZLIB" = "1" ]; then
+# Renderers/Stylization are part of a portable common-subset build, and they need the graphics
+# thirdparty libraries, so build them even when the rest of the subset does not use them.
+BUILD_GRAPHICS_LIBS=0
+if [ "$COMMON_SUBSET_ONLY" != "1" ] || [ "$WITH_PORTABLE" = "1" ]; then
+ BUILD_GRAPHICS_LIBS=1
+fi
+if [ "$BUILD_GRAPHICS_LIBS" = "1" ] && [ "$INTERNAL_ZLIB" = "1" ]; then
echo "Building zlib (internal)"
cp -Rf "${SOURCE_DIR}/Oem/gd/zlib" "${OEM_WORK_DIR}/gd/zlib"
cd "${OEM_WORK_DIR}/gd/zlib" || exit
@@ -211,7 +225,7 @@
make && make install
check_build
fi
-if [ "$COMMON_SUBSET_ONLY" != "1" ] && [ "$INTERNAL_LIBPNG" = "1" ]; then
+if [ "$BUILD_GRAPHICS_LIBS" = "1" ] && [ "$INTERNAL_LIBPNG" = "1" ]; then
echo "Building libpng (internal)"
cp -Rf "${SOURCE_DIR}/Oem/gd/lpng" "${OEM_WORK_DIR}/gd/lpng"
cd "${OEM_WORK_DIR}/gd/lpng" || exit
@@ -230,7 +244,7 @@
check_build
fi
fi
-if [ "$COMMON_SUBSET_ONLY" != "1" ] && [ "$INTERNAL_JPEG" = "1" ]; then
+if [ "$BUILD_GRAPHICS_LIBS" = "1" ] && [ "$INTERNAL_JPEG" = "1" ]; then
echo "Building libjpeg (internal)"
cp -Rf "${SOURCE_DIR}/Oem/gd/jpeg" "${OEM_WORK_DIR}/gd/jpeg"
cd "${OEM_WORK_DIR}/gd/jpeg" || exit
@@ -255,7 +269,7 @@
check_build
fi
fi
-if [ "$COMMON_SUBSET_ONLY" != "1" ] && [ "$INTERNAL_FREETYPE" = "1" ]; then
+if [ "$BUILD_GRAPHICS_LIBS" = "1" ] && [ "$INTERNAL_FREETYPE" = "1" ]; then
echo "Building freetype (internal)"
cp -Rf "${SOURCE_DIR}/Oem/gd/freetype" "${OEM_WORK_DIR}/gd/freetype"
cd "${OEM_WORK_DIR}/gd/freetype" || exit
@@ -286,7 +300,7 @@
PHP_ZLIB_DIR="$OEM_WORK_DIR/install/zlib"
fi
-if [ "$COMMON_SUBSET_ONLY" != "1" ] && [ "$INTERNAL_GD" = "1" ]; then
+if [ "$BUILD_GRAPHICS_LIBS" = "1" ] && [ "$INTERNAL_GD" = "1" ]; then
echo "Building GD (internal)"
cp -Rf "${SOURCE_DIR}/Oem/gd/gd" "${OEM_WORK_DIR}/gd/gd"
cd "${OEM_WORK_DIR}/gd/gd" || exit
Modified: branches/4.0/MgDev/cmake_build.sh
--- branches/4.0/MgDev/cmake_build.sh 2026-11-03 12:22:56 UTC (rev 10261)
+++ branches/4.0/MgDev/cmake_build.sh 2026-11-03 13:53:48 UTC (rev 10262)
@@ -60,6 +60,8 @@
echo " --oem-working-dir [OEM build directory, default: ~/mapguide_oem_build]"
echo " --with-asan [build with ASAN (if available)]"
echo " --with-gold [link with gold instead of ld (if available)]"
+ echo " --common-subset-only [Configure the common libs subset]"
+ echo " --with-portable [Build MgPortable and its SWIG glue]"
echo " --ninja [Use ninja build system]"
echo " --help [Display usage]"
exit
More information about the mapguide-commits
