[mapguide-commits] r10265 - branches/4.0/MgDev/Portable/MgPortable/System
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Nov 4 17:02:07 PST 2026
Author: jng
Date: 2026-11-04 17:02:06 -0800 (Wed, 04 Nov 2026)
New Revision: 10265
   branches/4.0/MgDev/Portable/MgPortable/System/PlatformInit.cpp
#2897: Setup NLSPATH internally for MgPortable init
Modified: branches/4.0/MgDev/Portable/MgPortable/System/PlatformInit.cpp
--- branches/4.0/MgDev/Portable/MgPortable/System/PlatformInit.cpp	2026-11-04 10:34:11 UTC (rev 10264)
+++ branches/4.0/MgDev/Portable/MgPortable/System/PlatformInit.cpp	2026-11-05 01:02:06 UTC (rev 10265)
@@ -121,6 +121,63 @@
     void* hlib = NULL;
     string updatedPath;
+    // FDO resolves its messages with catopen(), which looks the catalogue up through NLSPATH, and
+    // the SDK installs the catalogues beside the library directory rather than inside it. A
+    // consumer of MgPortable should not have to know either of those, so derive the location from
+    // the configured FdoPath and prepend it to NLSPATH. Without this every message falls back to
+    // its raw symbol (FDOSM_220 rather than English text).
+        // fdoPath is a directory with a trailing slash, normally <fdo root>/lib64/.
+        STRING fdoDir = fdoPath;
+        while (!fdoDir.empty() && (fdoDir[fdoDir.size() - 1] == L'/' || fdoDir[fdoDir.size() - 1] == L'\\'))
+            fdoDir.erase(fdoDir.size() - 1);
+        STRING fdoRoot = fdoDir;
+        STRING::size_type lastSep = fdoRoot.find_last_of(L"/\\");
+        if (lastSep != STRING::npos)
+            fdoRoot = fdoRoot.substr(0, lastSep);
+        // The SDK installs the catalogues at <root>/nls; a build tree keeps them under
+        // <root>/nls/linux/en_US, and a FdoPath that already points at the root (rather than at
+        // lib64) makes <fdoPath>nls the one that exists. Take whichever are present, because a
+        // pattern for a directory that does not exist is dead weight in the search path.
+        STRING nlsCandidates[3];
+        nlsCandidates[0] = fdoRoot + L"/nls";
+        nlsCandidates[1] = fdoRoot + L"/nls/linux/en_US";
+        nlsCandidates[2] = fdoPath + L"nls";
+        STRING nlspath;
+        for (int i = 0; i < 3; i++)
+            if (nlsCandidates[i].empty() || !MgFileUtil::IsDirectory(nlsCandidates[i]))
+                continue;
+            if (!nlspath.empty())
+                nlspath += L":";
+            nlspath += nlsCandidates[i];
+            nlspath += L"/%N";
+            char* existingNlspath = getenv("NLSPATH");
+            if (NULL != existingNlspath && '\0' != existingNlspath[0])
+                nlspath += L":";
+                nlspath += MgUtil::MultiByteToWideChar(string(existingNlspath));
+            std::string mbNlspath = MgUtil::WideCharToMultiByte(nlspath);
+            setenv("NLSPATH", mbNlspath.c_str(), 1);
+            MG_LOG_TRACE_ENTRY(L"NLSPATH = " + nlspath);
+        else
+            MG_LOG_TRACE_ENTRY(L"NLSPATH unchanged: no message catalogues under " + fdoRoot + L"/nls");
     char* ldlibpath = getenv("LD_LIBRARY_PATH");
     if (ldlibpath != NULL)
More information about the mapguide-commits mailing list
