[mapguide-commits] r10271 - in branches/4.0/MgDev: Common/CoordinateSystem Common/Geometry/CoordinateSystem Server/src/UnitTesting Web/src/mapviewerjava Web/src/mapviewernet Web/src/mapviewerphp
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Nov 5 23:54:02 PST 2026
Author: jng
Date: 2026-11-05 23:54:02 -0800 (Thu, 05 Nov 2026)
New Revision: 10271
   branches/4.0/MgDev/Common/CoordinateSystem/CoordSysMeasure.cpp
   branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMeasure.h
   branches/4.0/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
   branches/4.0/MgDev/Server/src/UnitTesting/TestGeometry.cpp
   branches/4.0/MgDev/Web/src/mapviewerjava/measure.jsp
   branches/4.0/MgDev/Web/src/mapviewernet/measure.aspx
   branches/4.0/MgDev/Web/src/mapviewerphp/measure.php
Measure distance through the MapGuide measure API
The measure command picked its method from the coordinate system type, so a projected map was
measured as a plane, which overstates ground distance by 1/cos(latitude) on EPSG:3857 - a
factor of 2 at 60N.
MapGuide's MgCoordinateSystemMeasure now applies the rule itself: planar where the projection
is locally representative (State Plane, UTM, State Plane-style grids), ellipsoidal for a world
projection. Call it here instead of duplicating the decision, which also keeps this in step
with the MapAgent geo.distance operation.
Fixes #2891.
Modified: branches/4.0/MgDev/Common/CoordinateSystem/CoordSysMeasure.cpp
--- branches/4.0/MgDev/Common/CoordinateSystem/CoordSysMeasure.cpp	2026-11-06 07:47:46 UTC (rev 10270)
+++ branches/4.0/MgDev/Common/CoordinateSystem/CoordSysMeasure.cpp	2026-11-06 07:54:02 UTC (rev 10271)
@@ -25,6 +25,14 @@
 using namespace CSLibrary;
+// The largest disagreement between the planar and the ellipsoidal measurement of the same segment
+// that is still reported as a planar distance. A projected grid chosen for its area is locally
+// representative -- at 5 km the two agree to within 0.04% for State Plane, a UTM zone and the
+// Victorian grid -- while a world projection diverges by whole percent (4% for WORLD-MERCATOR at
+// 16N, 100% for EPSG:3857 at 60N), so 1% separates the two families with room on both sides.
+// See MgCoordinateSystemMeasure::GetDistance and #2891.
+static const double kdPlanarMeasurementTolerance = 0.01;
 ///<summary>
 /// Initializes a new instance of CCoordinateSystemMeasure given a
@@ -77,14 +85,48 @@
     double distance = 0.0;
     MG_TRY()
-    if(m_pCoordSys->GetType() == MgCoordinateSystemType::Arbitrary)
+    INT32 type = m_pCoordSys->GetType();
+    // The euclidean measurement cannot fail whatever the coordinate system is, so it is both the
+    // answer for a non earth system and the fallback for a projected one whose inverse projection
+    // is unavailable.
+    distance = m_pCoordSys->MeasureEuclideanDistance(x1, y1, x2, y2);
+    if(MgCoordinateSystemType::Arbitrary != type)
-        distance = m_pCoordSys->MeasureEuclideanDistance(x1, y1, x2, y2);
+        try
+            double geodesic = m_pCoordSys->MeasureGreatCircleDistance(x1, y1, x2, y2);
+            // A geographic system measures in angular units, where the euclidean value is not a
+            // length at all, so the geodesic is always its answer. A projected grid chosen for its
+            // area (State Plane, UTM, the Victorian grid) is locally representative -- at 5 km its
+            // planar and geodesic lengths agree to within 0.04% -- so the planar value is the one
+            // its users compute from the projected coordinates themselves and is kept. A world
+            // projection is not representative: EPSG:3857 inflates its eastings by 1/cos(latitude),
+            // 4% at 16N and 100% at 60N, and there the geodesic is the only ground distance. The
+            // tolerance sits 25x above the widest local-grid margin measured and 4x below the
+            // smallest world-projection margin (#2891).
+            // The two lengths are compared rather than the projection's grid scale (GetScale) being
+            // consulted because measuring the segment is direction-agnostic, whereas GetScale
+            // reports one direction only on an anisotropic projection -- WORLD-ROBINSON at 45N
+            // reports 1.076 while its north-south factor is 0.946 -- and because the comparison
+            // promises what callers need: a distance changes only when it was wrong by more than
+            // the tolerance for that measurement.
+            if(MgCoordinateSystemType::Geographic == type ||
+               ::fabs(geodesic - distance) > kdPlanarMeasurementTolerance * geodesic)
+                distance = geodesic;
+        catch(MgException* e)
+            // A few projected systems have no usable inverse projection (PNG-SG, MAUR-ZONE), so
+            // they keep the euclidean measurement rather than failing the measurement outright.
+            SAFE_RELEASE(e);
-    else
-        distance = m_pCoordSys->MeasureGreatCircleDistance(x1, y1, x2, y2);
     MG_CATCH_AND_THROW(L"MgCoordinateSystemMeasure.GetDistance")
     return distance;
Modified: branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMeasure.h
--- branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMeasure.h	2026-11-06 07:47:46 UTC (rev 10270)
+++ branches/4.0/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMeasure.h	2026-11-06 07:54:02 UTC (rev 10271)
@@ -159,8 +159,20 @@
     /// \return
     /// Returns the distance between (x1, y1) and (x2, y2) as a
-    /// double in meters.
+    /// double in coordinate system units.
+    /// \remarks
+    /// The measurement is a ground distance. A geographic coordinate system is always measured
+    /// along its ellipsoid. A projected coordinate system is measured along the ellipsoid only
+    /// when its projection distorts the measurement by more than 1%: a grid chosen for its area
+    /// (State Plane, a UTM zone) is locally representative, and its planar distance is the one
+    /// computed from the projected coordinates themselves, so it is kept. A world projection such
+    /// as EPSG:3857 is not representative -- it inflates its eastings by 1/cos(latitude), 4% at
+    /// 16N and 100% at 60N -- and is measured along the ellipsoid. A non-earth (arbitrary)
+    /// coordinate system has no ellipsoid to measure along and always returns its planar distance.
+    /// A projected system whose inverse projection is unavailable also falls back to the planar
+    /// distance rather than failing.
     /// <!-- Example (PHP) -->
     /// \htmlinclude PHPExampleTop.html
     /// (-74.806394, 40.714169) is New York City, and (-71.061342,
Modified: branches/4.0/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
--- branches/4.0/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp	2026-11-06 07:47:46 UTC (rev 10270)
+++ branches/4.0/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp	2026-11-06 07:54:02 UTC (rev 10271)
@@ -57,6 +57,10 @@
 const STRING Projected_UTM18_NAD83 = L"PROJCS[\"UTM83-18F\",GEOGCS[\"LL83\",DATUM[\"NAD83\",SPHEROID[\"GRS1980\",6378137.000,298.25722210]],PRIMEM[\"Greenwich\",0],UNIT[\"Degree\",0.017453292519943295]],PROJECTION[\"Transverse_Mercator\"],PARAMETER[\"false_easting\",1640416.667],PARAMETER[\"false_northing\",0.000],PARAMETER[\"central_meridian\",-75.00000000000000],PARAMETER[\"scale_factor\",0.9996],PARAMETER[\"latitude_of_origin\",0.000],UNIT[\"Meter\",1.000000000000]]";
+// EPSG:3857. A conformal projection whose scale is 1/cos(latitude) at every point, so its
+// projected coordinates cannot be measured with Pythagoras (see #2891).
+const STRING PseudoMercatorWkt  = L"PROJCS[\"WGS84.PseudoMercator\",GEOGCS[\"LL84\",DATUM[\"WGS84\",SPHEROID[\"WGS84\",6378137.000,298.25722293]],PRIMEM[\"Greenwich\",0],UNIT[\"Degree\",0.017453292519943295]],PROJECTION[\"Popular Visualisation Pseudo Mercator\"],PARAMETER[\"false_easting\",0.000],PARAMETER[\"false_northing\",0.000],PARAMETER[\"central_meridian\",0.00000000000000],UNIT[\"Meter\",1.00000000000000]]";
 const STRING EPSG_4326_Wkt     = L"GEOGCS[\"LL84\",DATUM[\"WGS84\",SPHEROID[\"WGS84\",6378137.000,298.25722356]],PRIMEM[\"Greenwich\",0],UNIT[\"Degree\",0.01745329251994]]";
 const STRING EPSG_4326_Wkt_Alt = L"GEOGCS[\"LL84\",DATUM[\"WGS 84\",SPHEROID[\"WGS 84\",6378137,298.25722293287],TOWGS84[0,0,0,0,0,0,0]],PRIMEM[\"Greenwich\",0],UNIT[\"Degrees\",0.01745329252]]";
@@ -3442,11 +3446,16 @@
         MgCoordinateXY coord1(410961.8644, 1415078.441);
         MgCoordinateXY coord2(432415.4557, 1362302.051);
+        // This projection is a locally representative grid (Transverse Mercator, scale factor
+        // 0.9999), so GetDistance keeps the planar measurement a user computes from the projected
+        // coordinates rather than substituting the geodesic 0.01% away from it (#2891). See
+        // PseudoMercator_Measure_GetDistance for the world-projection case, which does not.
         double distance = measure->GetDistance(&coord1, &coord2);
-        REQUIRE(MgUtil::ValuesEqual(56975.49704, distance));
+        REQUIRE(MgUtil::ValuesEqual(56970.20205, distance));
+        REQUIRE(MgUtil::ValuesEqual(pCoordinateSystem->MeasureEuclideanDistance(&coord1, &coord2), distance));
         double meters = pCoordinateSystem->ConvertCoordinateSystemUnitsToMeters(distance);
-        REQUIRE(MgUtil::ValuesEqual(17366.16623, meters));
+        REQUIRE(MgUtil::ValuesEqual(17364.55231, meters));
@@ -3519,6 +3528,102 @@
+// A world projection has to be measured along the ellipsoid, not with Pythagoras on its projected
+// coordinates. EPSG:3857 makes the difference unmistakable: its eastings are inflated by
+// 1/cos(latitude), so a 1 degree east-west segment at 60N measures twice its ground length if it is
+// treated as a plane. MgCoordinateSystemMeasure::GetDistance is what the viewers, the MapAgent
+// geo.distance operation and MgGeometry::Distance all report through, so it has to return the
+// geodesic value here, while leaving a locally representative grid on its planar measurement
+// (Projected_Measure_GetDistance, #2891).
+TEST_CASE("PseudoMercator_Measure_GetDistance", "[CoordinateSystem]")
+    try
+        MgCoordinateSystemFactory factory;
+        STRING ogcWkt = PseudoMercatorWkt;
+        Ptr<MgCoordinateSystem> pCoordinateSystem = factory.Create(ogcWkt);
+        REQUIRE(pCoordinateSystem);
+        REQUIRE(MgCoordinateSystemType::Projected == pCoordinateSystem->GetType());
+        // 60N, one degree of longitude apart.
+        Ptr<MgCoordinate> pCoord1 = pCoordinateSystem->ConvertFromLonLat(-1.0, 60.0);
+        Ptr<MgCoordinate> pCoord2 = pCoordinateSystem->ConvertFromLonLat(0.0, 60.0);
+        REQUIRE(pCoord1);
+        REQUIRE(pCoord2);
+        Ptr<MgCoordinateSystemMeasure> measure = pCoordinateSystem->GetMeasure();
+        REQUIRE(measure);
+        double planar = pCoordinateSystem->MeasureEuclideanDistance(pCoord1, pCoord2);
+        double distance = measure->GetDistance(pCoord1, pCoord2);
+        REQUIRE(MgUtil::ValuesEqual(pCoordinateSystem->MeasureGreatCircleDistance(pCoord1, pCoord2), distance));
+        REQUIRE(planar > distance);
+        // planar / geodesic is 1/cos(latitude), i.e. 2.0 at 60N.
+        double ratio = planar / distance;
+        REQUIRE(ratio > 1.99);
+        REQUIRE(ratio < 2.01);
+        // ... and the geodesic value is the length of that parallel at 60N, about 55.8 km.
+        double meters = pCoordinateSystem->ConvertCoordinateSystemUnitsToMeters(distance);
+        REQUIRE(meters > 55700.0);
+        REQUIRE(meters < 55900.0);
+        STRING message = e->GetDetails(TEST_LOCALE);
+        SAFE_RELEASE(e);
+        FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+    catch(...)
+        throw;
+// MgCoordinateSystemMeasure::GetDistance keeps the planar value for a projected coordinate system
+// unless the two measurements disagree by more than 1%, so that a grid a user has always measured
+// on -- State Plane, a UTM zone, the Victorian grid -- keeps reporting the number it always has,
+// and the MapAgent geo.distance operation reports the same thing the viewers do (#2891). That is
+// only safe while a grid's scale factor keeps the disagreement far below the threshold; at 5 km
+// the measured margins are 0.014% (EPSG:3110), 0.010% (the Transverse Mercator system below) and
+// 0.040% (UTM), against 4% for WORLD-MERCATOR at 16N and 100% for EPSG:3857 at 60N. This pins the
+// small end of that margin.
+TEST_CASE("Projected_Measure_PlanarIsLocallyRepresentative", "[CoordinateSystem]")
+    try
+        Ptr<MgCoordinateSystem> pCoordinateSystem = factory.Create(ProjectedWkt);
+        MgCoordinateXY coord1(410961.8644, 1415078.441);
+        MgCoordinateXY coord2(432415.4557, 1362302.051);
+        double planar = pCoordinateSystem->MeasureEuclideanDistance(&coord1, &coord2);
+        double geodesic = pCoordinateSystem->MeasureGreatCircleDistance(&coord1, &coord2);
+        REQUIRE(geodesic > 0.0);
+        // The difference is the grid scale factor of 0.9999: not zero, but two orders of
+        // magnitude below the 1% at which the measure command prefers the geodesic.
+        double relative = ::fabs(planar - geodesic) / geodesic;
+        REQUIRE(relative > 0.0);
+        REQUIRE(relative < 0.001);
+        SAFE_RELEASE(e);
+    catch(...)
+        throw;
 TEST_CASE("Projected_ConvertCode", "[CoordinateSystem]")
     try
Modified: branches/4.0/MgDev/Server/src/UnitTesting/TestGeometry.cpp
--- branches/4.0/MgDev/Server/src/UnitTesting/TestGeometry.cpp	2026-11-06 07:47:46 UTC (rev 10270)
+++ branches/4.0/MgDev/Server/src/UnitTesting/TestGeometry.cpp	2026-11-06 07:54:02 UTC (rev 10271)
@@ -1687,6 +1687,43 @@
+// MgGeometry::Distance has to report whatever the measure's policy says, because the MapAgent
+// geo.distance operation goes through it while the viewer measure commands call the measure
+// directly. If the two disagreed, one of them would still have the EPSG:3857 problem (#2891).
+TEST_CASE("Distance (follows the measure's policy)", "[Geometry]")
+    try
+        MgGeometryFactory factory;
+        Ptr<MgCoordinate> coord1 = factory.CreateCoordinateXY(0.0, 0.0);
+        Ptr<MgCoordinate> coord2 = factory.CreateCoordinateXY(1.0, 1.0);
+        Ptr<MgPoint> point1 = factory.CreatePoint(coord1);
+        Ptr<MgPoint> point2 = factory.CreatePoint(coord2);
+        // An arbitrary system has no ellipsoid, so the measure is planar and the two must agree.
+        Ptr<MgCoordinateSystemMeasure> arbitrary = CreateMeasureArbitrary();
+        REQUIRE(point1->Distance(point2, arbitrary) == arbitrary->GetDistance(coord1, coord2));
+        // A geographic and a projected system both route through the same policy, whichever
+        // branch of it applies to them.
+        Ptr<MgCoordinateSystemMeasure> geographic = CreateMeasureGeographic();
+        REQUIRE(point1->Distance(point2, geographic) == geographic->GetDistance(coord1, coord2));
+        Ptr<MgCoordinateSystemMeasure> projected = CreateMeasureProjected();
+        REQUIRE(point1->Distance(point2, projected) == projected->GetDistance(coord1, coord2));
+    catch (MgException* e)
+        STRING message = e->GetDetails(TestServiceFactory::TEST_LOCALE);
+        SAFE_RELEASE(e);
+    catch (...)
+        throw;
 TEST_CASE("Distance", "[Geometry]")
     try
Modified: branches/4.0/MgDev/Web/src/mapviewerjava/measure.jsp
--- branches/4.0/MgDev/Web/src/mapviewerjava/measure.jsp	2026-11-06 07:47:46 UTC (rev 10270)
+++ branches/4.0/MgDev/Web/src/mapviewerjava/measure.jsp	2026-11-06 07:54:02 UTC (rev 10271)
@@ -116,11 +116,10 @@
             MgCoordinateSystemFactory srsFactory = new MgCoordinateSystemFactory();
             MgCoordinateSystem srsMap = srsFactory.create(srs);
-            int srsType = srsMap.getType();
-            if(srsType == MgCoordinateSystemType.Geographic)
-                distance = srsMap.measureGreatCircleDistance(x1, y1, x2, y2);
-            else
-                distance = srsMap.measureEuclideanDistance(x1, y1, x2, y2);
+            // The measurement rule -- planar for a locally representative grid, ellipsoidal for a
+            // world projection such as EPSG:3857 -- lives in MgCoordinateSystemMeasure, so this
+            // agrees with the MapAgent geo.distance operation by construction (#2891).
+            distance = srsMap.getMeasure().getDistance(x1, y1, x2, y2);
             distance = srsMap.convertCoordinateSystemUnitsToMeters(distance);
Modified: branches/4.0/MgDev/Web/src/mapviewernet/measure.aspx
--- branches/4.0/MgDev/Web/src/mapviewernet/measure.aspx	2026-11-06 07:47:46 UTC (rev 10270)
+++ branches/4.0/MgDev/Web/src/mapviewernet/measure.aspx	2026-11-06 07:54:02 UTC (rev 10271)
@@ -94,11 +94,10 @@
                 MgCoordinateSystem srsMap = srsFactory.Create(srs);
-                int srsType = srsMap.GetType();
-                if (srsType == MgCoordinateSystemType.Geographic)
-                    distance = srsMap.MeasureGreatCircleDistance(x1, y1, x2, y2);
-                else
-                    distance = srsMap.MeasureEuclideanDistance(x1, y1, x2, y2);
+                // for a world projection such as EPSG:3857 -- lives in MgCoordinateSystemMeasure,
+                // so this agrees with the MapAgent geo.distance operation by construction (#2891).
+                distance = srsMap.GetMeasure().GetDistance(x1, y1, x2, y2);
                 distance = srsMap.ConvertCoordinateSystemUnitsToMeters(distance);
Modified: branches/4.0/MgDev/Web/src/mapviewerphp/measure.php
--- branches/4.0/MgDev/Web/src/mapviewerphp/measure.php	2026-11-06 07:47:46 UTC (rev 10270)
+++ branches/4.0/MgDev/Web/src/mapviewerphp/measure.php	2026-11-06 07:54:02 UTC (rev 10271)
@@ -84,11 +84,11 @@
             $srsFactory = new MgCoordinateSystemFactory();
             $srsMap = $srsFactory->Create($srs);
-            $srsType = $srsMap->GetType();
-            if($srsType == MgCoordinateSystemType::Geographic)
-                $distance = $srsMap->MeasureGreatCircleDistance($x1, $y1, $x2, $y2);
-            else
-                $distance = $srsMap->MeasureEuclideanDistance($x1, $y1, $x2, $y2);
+            // agrees with the MapAgent geo.distance operation by construction (#2891). The
+            // four-double overload is GetDistanceSimple in PHP (monkey_patch.i).
+            $distance = $srsMap->GetMeasure()->GetDistanceSimple($x1, $y1, $x2, $y2);
             $distance = $srsMap->ConvertCoordinateSystemUnitsToMeters($distance);
More information about the mapguide-commits mailing list
