[mapguide-commits] r10283 - branches/4.0/MgDev/Bindings/src/ApiDump
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Nov 11 04:20:55 PST 2026
Author: jng
Date: 2026-11-11 04:20:53 -0800 (Wed, 11 Nov 2026)
New Revision: 10283
   branches/4.0/MgDev/Bindings/src/ApiDump/README.txt
   branches/4.0/MgDev/Bindings/src/ApiDump/api.dotnet.txt
   branches/4.0/MgDev/Bindings/src/ApiDump/api.java.txt
   branches/4.0/MgDev/Bindings/src/ApiDump/api.php.txt
   branches/4.0/MgDev/Bindings/src/ApiDump/dotnet-dump.ps1
   branches/4.0/MgDev/Bindings/src/ApiDump/filelist.linux.generic-common.txt
   branches/4.0/MgDev/Bindings/src/ApiDump/filelist.linux.generic.txt
   branches/4.0/MgDev/Bindings/src/ApiDump/filelist.linux.ubuntu.txt
   branches/4.0/MgDev/Bindings/src/ApiDump/filelist.web.windows.txt
   branches/4.0/MgDev/Bindings/src/ApiDump/java-dump.ps1
API and filelist snapshot baselines for 4.0.1-Test. Update some of the snapshotting scripts to reduce snapshot churn and detect jar.exe more reliably
Modified: branches/4.0/MgDev/Bindings/src/ApiDump/README.txt
--- branches/4.0/MgDev/Bindings/src/ApiDump/README.txt	2026-11-10 07:15:37 UTC (rev 10282)
+++ branches/4.0/MgDev/Bindings/src/ApiDump/README.txt	2026-11-11 12:20:53 UTC (rev 10283)
@@ -8,9 +8,11 @@
 The following tarballs are assumed to be the final artifacts of the docker-based build system (before sfx installer production step)
-tar -tzf $PATH_TO/mapguideopensource-$VERSION-generic-amd64.tar.gz > filelist.linux.generic.txt
-tar -tzf $PATH_TO/mapguideopensource-common-$VERSION-generic-amd64.tar.gz > filelist.linux.generic-common.txt
+tar -tzf $PATH_TO/mapguideopensource-$VERSION-generic-amd64.tar.gz | LC_ALL=C sort > filelist.linux.generic.txt
+tar -tzf $PATH_TO/mapguideopensource-common-$VERSION-generic-linux-amd64.tar.gz | LC_ALL=C sort > filelist.linux.generic-common.txt
 > where NN is the current LTS major version we are currently supporting
-tar -tzf $PATH_TO/mapguideopensource-$VERSION-ubuntuNN-amd64.tar.gz > filelist.linux.ubuntu.txt
\ No newline at end of file
+tar -tzf $PATH_TO/mapguideopensource-$VERSION-ubuntuNN-amd64.tar.gz | LC_ALL=C sort > filelist.linux.ubuntu.txt
+The listing is sorted because tar emits the entries in the order the packaging directory happens to store them, which differs between builds of identical content and turns a one-line change into a whole-file diff.
Modified: branches/4.0/MgDev/Bindings/src/ApiDump/api.dotnet.txt
--- branches/4.0/MgDev/Bindings/src/ApiDump/api.dotnet.txt	2026-11-10 07:15:37 UTC (rev 10282)
+++ branches/4.0/MgDev/Bindings/src/ApiDump/api.dotnet.txt	2026-11-11 12:20:53 UTC (rev 10283)
@@ -1,10375 +1,5187 @@
-ÿþA s s e m b l y :   O S G e o . M a p G u i d e . F o u n d a t i o n ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l  -
- t y p e   O S G e o . M a p G u i d e . M g F e a t u r e P r o p e r t y T y p e   :   S y s t e m . O b j e c t  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( )  -
-         [ F i e l d ]   I n t 3 2   A s s o c i a t i o n P r o p e r t y  -
-         [ F i e l d ]   I n t 3 2   D a t a P r o p e r t y  -
-         [ F i e l d ]   I n t 3 2   G e o m e t r i c P r o p e r t y  -
-         [ F i e l d ]   I n t 3 2   O b j e c t P r o p e r t y  -
-         [ F i e l d ]   I n t 3 2   R a s t e r P r o p e r t y  -
- t y p e   O S G e o . M a p G u i d e . M g M i m e T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A g f  -
-         [ F i e l d ]   S y s t e m . S t r i n g   B i n a r y  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D w f  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G i f  -
-         [ F i e l d ]   S y s t e m . S t r i n g   H t m l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   J p e g  -
-         [ F i e l d ]   S y s t e m . S t r i n g   J s o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   K m l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   K m z  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M e t a  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P n g  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T e x t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T i f f  -
-         [ F i e l d ]   S y s t e m . S t r i n g   X m l  -
- t y p e   O S G e o . M a p G u i d e . M g P r o p e r t y T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   B l o b  -
-         [ F i e l d ]   I n t 3 2   B o o l e a n  -
-         [ F i e l d ]   I n t 3 2   B y t e  -
-         [ F i e l d ]   I n t 3 2   C l o b  -
-         [ F i e l d ]   I n t 3 2   D a t e T i m e  -
-         [ F i e l d ]   I n t 3 2   D e c i m a l  -
-         [ F i e l d ]   I n t 3 2   D o u b l e  -
-         [ F i e l d ]   I n t 3 2   F e a t u r e  -
-         [ F i e l d ]   I n t 3 2   G e o m e t r y  -
-         [ F i e l d ]   I n t 3 2   I n t 1 6  -
-         [ F i e l d ]   I n t 3 2   I n t 3 2  -
-         [ F i e l d ]   I n t 3 2   I n t 6 4  -
-         [ F i e l d ]   I n t 3 2   N u l l  -
-         [ F i e l d ]   I n t 3 2   R a s t e r  -
-         [ F i e l d ]   I n t 3 2   S i n g l e  -
-         [ F i e l d ]   I n t 3 2   S t r i n g  -
- t y p e   O S G e o . M a p G u i d e . M g E x c e p t i o n C o d e s   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g A l l P r o v i d e r C o n n e c t i o n s U s e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g A r g u m e n t O u t O f R a n g e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g A r r a y T y p e M i s m a t c h E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g A u t h e n t i c a t i o n F a i l e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g C l a s s N o t F o u n d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g C o n f i g u r a t i o n E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g C o n f i g u r a t i o n L o a d F a i l e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g C o n f i g u r a t i o n S a v e F a i l e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g C o n n e c t i o n F a i l e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g C o n n e c t i o n N o t O p e n E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g C o o r d i n a t e S y s t e m C o m p u t a t i o n F a i l e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g C o o r d i n a t e S y s t e m C o n v e r s i o n F a i l e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g C o o r d i n a t e S y s t e m I n i t i a l i z a t i o n F a i l e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g C o o r d i n a t e S y s t e m L o a d F a i l e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g C o o r d i n a t e S y s t e m M e a s u r e F a i l e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g C o o r d i n a t e S y s t e m T r a n s f o r m F a i l e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D a t e T i m e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D b E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D b X m l E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D e c r y p t i o n E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D i r e c t o r y N o t F o u n d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D i v i d e B y Z e r o E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D o m a i n E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D u p l i c a t e D i r e c t o r y E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D u p l i c a t e F i l e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D u p l i c a t e G r o u p E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D u p l i c a t e N a m e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D u p l i c a t e O b j e c t E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D u p l i c a t e P a r a m e t e r E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D u p l i c a t e R e p o s i t o r y E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D u p l i c a t e R e s o u r c e D a t a E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D u p l i c a t e R e s o u r c e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D u p l i c a t e R o l e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D u p l i c a t e S e r v e r E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D u p l i c a t e S e s s i o n E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D u p l i c a t e U s e r E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D w f E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D w f S e c t i o n N o t F o u n d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g D w f S e c t i o n R e s o u r c e N o t F o u n d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g E m p t y F e a t u r e S e t E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g E n c r y p t i o n E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g E n d O f S t r e a m E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g E v a l u a t i o n E x p i r e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g F d o E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g F e a t u r e S e r v i c e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g F i l e I o E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g F i l e N o t F o u n d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g G e o m e t r y E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g G r i d D e n s i t y E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g G r o u p N o t F o u n d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n d e x O u t O f R a n g e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d A r g u m e n t E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d C a s t E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d C o o r d i n a t e S y s t e m E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d C o o r d i n a t e S y s t e m T y p e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d C o o r d i n a t e S y s t e m U n i t s E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d D w f P a c k a g e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d D w f S e c t i o n E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d F e a t u r e S o u r c e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d I p A d d r e s s E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d L a y e r D e f i n i t i o n E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d L i c e n s e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d L o g E n t r y E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d M a p D e f i n i t i o n E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d M i m e T y p e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d O p e r a t i o n E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d O p e r a t i o n V e r s i o n E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d P a s s w o r d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d P r i n t L a y o u t F o n t S i z e U n i t s E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d P r i n t L a y o u t P o s i t i o n U n i t s E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d P r i n t L a y o u t S i z e U n i t s E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d P r o p e r t y T y p e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d R e p o s i t o r y N a m e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d R e p o s i t o r y T y p e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d R e s o u r c e D a t a N a m e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d R e s o u r c e D a t a T y p e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d R e s o u r c e N a m e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d R e s o u r c e P a t h E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d R e s o u r c e P r e P r o c e s s i n g T y p e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d R e s o u r c e T y p e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d S e r i a l N u m b e r E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d S e r v e r N a m e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d S t r e a m H e a d e r E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I n v a l i d W a t e r m a r k D e f i n i t i o n E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g I o E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g L a y e r N o t F o u n d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g L e n g t h E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g L i c e n s e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g L i c e n s e E x p i r e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g L o g i c E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g L o g O p e n F a i l e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g N o t F i n i t e N u m b e r E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g N o t I m p l e m e n t e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g N u l l A r g u m e n t E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g N u l l P r o p e r t y V a l u e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g N u l l R e f e r e n c e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g O b j e c t N o t F o u n d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g O p e r a t i o n P r o c e s s i n g E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g O u t O f M e m o r y E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g O u t O f R a n g e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g O v e r f l o w E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g P a r a m e t e r N o t F o u n d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g P a t h T o o L o n g E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g P e r m i s s i o n D e n i e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g P l a t f o r m N o t S u p p o r t e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g P o r t N o t A v a i l a b l e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g P r i n t T o S c a l e M o d e N o t S e l e c t e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g R a s t e r T r a n s f o r m a t i o n N o t S u p p o r t e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g R e p o s i t o r y C r e a t i o n F a i l e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g R e p o s i t o r y N o t F o u n d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g R e p o s i t o r y N o t O p e n E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g R e p o s i t o r y O p e n F a i l e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g R e s o u r c e B u s y E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g R e s o u r c e D a t a N o t F o u n d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g R e s o u r c e N o t F o u n d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g R e s o u r c e s E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g R e s o u r c e s L o a d F a i l e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g R e s o u r c e T a g N o t F o u n d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g R o l e N o t F o u n d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g R u n t i m e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g S e r v e r N o t F o u n d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g S e r v e r N o t O n l i n e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g S e r v i c e N o t A v a i l a b l e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g S e r v i c e N o t S u p p o r t e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g S e s s i o n E x p i r e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g S e s s i o n N o t F o u n d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g S t r e a m I o E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g S t y l i z e L a y e r F a i l e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g T e m p o r a r y F i l e N o t A v a i l a b l e E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g U n a u t h o r i z e d A c c e s s E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g U n c l a s s i f i e d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g U n d e r f l o w E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g U n k n o w n T i l e P r o v i d e r E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g U n s u p p o r t e d P r o v i d e r T h r e a d M o d e l E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g U n s u p p o r t e d T i l e P r o v i d e r E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g U r i F o r m a t E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g U s e r N o t F o u n d E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g X m l E x c e p t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M g X m l P a r s e r E x c e p t i o n  -
- t y p e   O S G e o . M a p G u i d e . M a n a g e d E x c e p t i o n   :   S y s t e m . E x c e p t i o n  -
-         i m p l e m e n t s   S y s t e m . R u n t i m e . S e r i a l i z a t i o n . I S e r i a l i z a b l e  -
-         i m p l e m e n t s   S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . _ E x c e p t i o n  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ M e s s a g e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ S t a c k T r a c e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   T o S t r i n g ( )  -
- [ S y s t e m . R e f l e c t i o n . D e f a u l t M e m b e r A t t r i b u t e ]  -
- t y p e   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g C o l l e c t i o n  -
-         i m p l e m e n t s   S y s t e m . I D i s p o s a b l e  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ S y s t e m . S t r i n g ,   m s c o r l i b ,   V e r s i o n = 4 . 0 . 0 . 0 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = b 7 7 a 5 c 5 6 1 9 3 4 e 0 8 9 ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ S y s t e m . S t r i n g ,   m s c o r l i b ,   V e r s i o n = 4 . 0 . 0 . 0 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = b 7 7 a 5 c 5 6 1 9 3 4 e 0 8 9 ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ S y s t e m . S t r i n g ,   m s c o r l i b ,   V e r s i o n = 4 . 0 . 0 . 0 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = b 7 7 a 5 c 5 6 1 9 3 4 e 0 8 9 ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . I E n u m e r a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ S y s t e m . S t r i n g ] )  -
-         [ M e t h o d ]   V o i d   A d d ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   C l e a r ( )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( S y s t e m . S t r i n g [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ C o u n t ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ I s R e a d O n l y ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t C o u n t ( )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ S y s t e m . S t r i n g ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   R e m o v e A t ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   T o X m l ( )  -
- t y p e   O S G e o . M a p G u i d e . R e a d O n l y R e w i n d a b l e S t r e a m   :   S y s t e m . I O . S t r e a m  -
-         [ M e t h o d ]   B o o l e a n   g e t _ C a n R e a d ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ C a n R e w i n d ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ C a n S e e k ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ C a n W r i t e ( )  -
-         [ M e t h o d ]   I n t 6 4   g e t _ P o s i t i o n ( )  -
-         [ M e t h o d ]   V o i d   R e w i n d ( )  -
-         [ M e t h o d ]   I n t 6 4   S e e k ( I n t 6 4 ,   S y s t e m . I O . S e e k O r i g i n )  -
-         [ M e t h o d ]   V o i d   s e t _ P o s i t i o n ( I n t 6 4 )  -
-         [ M e t h o d ]   V o i d   S e t L e n g t h ( I n t 6 4 )  -
-         [ M e t h o d ]   V o i d   W r i t e ( B y t e [ ] ,   I n t 3 2 ,   I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . G e t B y t e R e a d e r M e t h o d   :   S y s t e m . M u l t i c a s t D e l e g a t e  -
-         i m p l e m e n t s   S y s t e m . I C l o n e a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . O b j e c t ,   I n t P t r )  -
-         [ M e t h o d ]   S y s t e m . I A s y n c R e s u l t   B e g i n I n v o k e ( S y s t e m . A s y n c C a l l b a c k ,   S y s t e m . O b j e c t )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   E n d I n v o k e ( S y s t e m . I A s y n c R e s u l t )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   I n v o k e ( )  -
- t y p e   O S G e o . M a p G u i d e . M g R e a d O n l y S t r e a m   :   O S G e o . M a p G u i d e . R e a d O n l y R e w i n d a b l e S t r e a m  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g B y t e R e a d e r )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . G e t B y t e R e a d e r M e t h o d )  -
-         [ M e t h o d ]   V o i d   F l u s h ( )  -
-         [ M e t h o d ]   I n t 6 4   g e t _ L e n g t h ( )  -
-         [ M e t h o d ]   I n t 3 2   R e a d ( B y t e [ ] ,   I n t 3 2 ,   I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g C o l l e c t i o n  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ,   O S G e o . M a p G u i d e . F o u n d a t i o n ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ,   O S G e o . M a p G u i d e . F o u n d a t i o n ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ,   O S G e o . M a p G u i d e . F o u n d a t i o n ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n )  -
- t y p e   O S G e o . M a p G u i d e . M g B y t e R e a d e r   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   B o o l e a n )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( B y t e [ ] ,   I n t 3 2 ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ M i m e T y p e ( )  -
-         [ M e t h o d ]   S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f   g e t C P t r ( O S G e o . M a p G u i d e . M g B y t e R e a d e r )  -
-         [ M e t h o d ]   I n t 6 4   G e t L e n g t h ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t M i m e T y p e ( )  -
-         [ M e t h o d ]   B o o l e a n   I s R e w i n d a b l e ( )  -
-         [ M e t h o d ]   I n t 3 2   R e a d ( B y t e [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f   s w i g R e l e a s e ( O S G e o . M a p G u i d e . M g B y t e R e a d e r )  -
-         [ M e t h o d ]   V o i d   T o F i l e ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g B y t e S i n k   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
- t y p e   O S G e o . M a p G u i d e . M g B y t e S o u r c e   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( B y t e [ ] ,   I n t 3 2 )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t R e a d e r ( )  -
-         [ M e t h o d ]   V o i d   s e t _ M i m e T y p e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t M i m e T y p e ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ M e t h o d ]   S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f   g e t C P t r ( O S G e o . M a p G u i d e . M g C o l l e c t i o n )  -
-         [ M e t h o d ]   S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f   s w i g R e l e a s e ( O S G e o . M a p G u i d e . M g C o l l e c t i o n )  -
- t y p e   O S G e o . M a p G u i d e . M g D a t e T i m e   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( I n t 1 6 ,   I n t 1 6 ,   I n t 1 6 )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( I n t 1 6 ,   I n t 1 6 ,   I n t 1 6 ,   I n t 3 2 )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( I n t 1 6 ,   I n t 1 6 ,   I n t 1 6 ,   I n t 1 6 ,   I n t 1 6 ,   I n t 1 6 ,   I n t 3 2 )  -
-         [ M e t h o d ]   I n t 1 6   g e t _ D a y ( )  -
-         [ M e t h o d ]   I n t 1 6   g e t _ H o u r ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ M i c r o s e c o n d ( )  -
-         [ M e t h o d ]   I n t 1 6   g e t _ M i n u t e ( )  -
-         [ M e t h o d ]   I n t 1 6   g e t _ M o n t h ( )  -
-         [ M e t h o d ]   I n t 1 6   g e t _ S e c o n d ( )  -
-         [ M e t h o d ]   I n t 1 6   g e t _ Y e a r ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t D a y ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t H o u r ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t M i c r o s e c o n d ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t M i n u t e ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t M o n t h ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t S e c o n d ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t Y e a r ( )  -
-         [ M e t h o d ]   B o o l e a n   I s D a t e ( )  -
-         [ M e t h o d ]   B o o l e a n   I s D a t e T i m e ( )  -
-         [ M e t h o d ]   B o o l e a n   I s T i m e ( )  -
-         [ M e t h o d ]   V o i d   s e t _ D a y ( I n t 1 6 )  -
-         [ M e t h o d ]   V o i d   s e t _ H o u r ( I n t 1 6 )  -
-         [ M e t h o d ]   V o i d   s e t _ M i c r o s e c o n d ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   s e t _ M i n u t e ( I n t 1 6 )  -
-         [ M e t h o d ]   V o i d   s e t _ M o n t h ( I n t 1 6 )  -
-         [ M e t h o d ]   V o i d   s e t _ S e c o n d ( I n t 1 6 )  -
-         [ M e t h o d ]   V o i d   s e t _ Y e a r ( I n t 1 6 )  -
-         [ M e t h o d ]   V o i d   S e t D a y ( I n t 1 6 )  -
-         [ M e t h o d ]   V o i d   S e t H o u r ( I n t 1 6 )  -
-         [ M e t h o d ]   V o i d   S e t M i c r o s e c o n d ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t M i n u t e ( I n t 1 6 )  -
-         [ M e t h o d ]   V o i d   S e t M o n t h ( I n t 1 6 )  -
-         [ M e t h o d ]   V o i d   S e t S e c o n d ( I n t 1 6 )  -
-         [ M e t h o d ]   V o i d   S e t Y e a r ( I n t 1 6 )  -
-         [ M e t h o d ]   V o i d   V a l i d a t e ( )  -
- t y p e   O S G e o . M a p G u i d e . M g D i s p o s a b l e   :   O S G e o . M a p G u i d e . M g O b j e c t  -
-         [ M e t h o d ]   S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f   g e t C P t r ( O S G e o . M a p G u i d e . M g D i s p o s a b l e )  -
-         [ M e t h o d ]   S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f   s w i g R e l e a s e ( O S G e o . M a p G u i d e . M g D i s p o s a b l e )  -
- t y p e   O S G e o . M a p G u i d e . M g D i s p o s a b l e C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g C o l l e c t i o n  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g D i s p o s a b l e )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g D i s p o s a b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D i s p o s a b l e   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g D i s p o s a b l e )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g D i s p o s a b l e )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g D i s p o s a b l e )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g D i s p o s a b l e )  -
- t y p e   O S G e o . M a p G u i d e . M g E x c e p t i o n   :   O S G e o . M a p G u i d e . M a n a g e d E x c e p t i o n  -
-         [ M e t h o d ]   V o i d   A d d S t a c k T r a c e I n f o ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   A d d S t a c k T r a c e I n f o ( S y s t e m . S t r i n g ,   I n t 3 2 ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   D i s p o s e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D e t a i l s ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D e t a i l s ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t E x c e p t i o n C o d e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t E x c e p t i o n M e s s a g e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t E x c e p t i o n M e s s a g e ( )  -
-         [ M e t h o d ]   I n t 6 4   G e t N a t i v e E r r o r C o d e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S t a c k T r a c e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S t a c k T r a c e ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e   :   O S G e o . M a p G u i d e . M g D i s p o s a b l e  -
-         [ M e t h o d ]   S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f   g e t C P t r ( O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e )  -
-         [ M e t h o d ]   S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f   s w i g R e l e a s e ( O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e )  -
- t y p e   O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ M e t h o d ]   S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f   g e t C P t r ( O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e )  -
-         [ M e t h o d ]   S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f   s w i g R e l e a s e ( O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e )  -
- t y p e   O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y   :   O S G e o . M a p G u i d e . M g P r o p e r t y  -
-         [ M e t h o d ]   S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f   g e t C P t r ( O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y )  -
-         [ M e t h o d ]   B o o l e a n   I s N u l l ( )  -
-         [ M e t h o d ]   V o i d   S e t N u l l ( B o o l e a n )  -
-         [ M e t h o d ]   S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f   s w i g R e l e a s e ( O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y )  -
- t y p e   O S G e o . M a p G u i d e . M g O b j e c t   :   S y s t e m . O b j e c t  -
- t y p e   O S G e o . M a p G u i d e . M g P r o p e r t y   :   O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ N a m e ( )  -
-         [ M e t h o d ]   I n t 1 6   g e t _ P r o p e r t y T y p e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t N a m e ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t P r o p e r t y T y p e ( )  -
-         [ M e t h o d ]   V o i d   s e t _ N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t N a m e ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g C o l l e c t i o n  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y ,   O S G e o . M a p G u i d e . F o u n d a t i o n ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y ,   O S G e o . M a p G u i d e . F o u n d a t i o n ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y ,   O S G e o . M a p G u i d e . F o u n d a t i o n ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g P r o p e r t y )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g P r o p e r t y )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g P r o p e r t y [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g P r o p e r t y ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y   G e t I t e m ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g P r o p e r t y )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g P r o p e r t y )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g P r o p e r t y )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g P r o p e r t y )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g P r o p e r t y )  -
- t y p e   O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n   :   O S G e o . M a p G u i d e . M g P r o p e r t y  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   I n t 1 6 )  -
-         [ M e t h o d ]   V o i d   D e l e t e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ Q u a l i f i e d N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f   g e t C P t r ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t Q u a l i f i e d N a m e ( )  -
-         [ M e t h o d ]   V o i d   s e t _ D e s c r i p t i o n ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ Q u a l i f i e d N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t D e s c r i p t i o n ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t Q u a l i f i e d N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f   s w i g R e l e a s e ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n )  -
- t y p e   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f   g e t C P t r ( O S G e o . M a p G u i d e . M g S e r i a l i z a b l e )  -
-         [ M e t h o d ]   S y s t e m . R u n t i m e . I n t e r o p S e r v i c e s . H a n d l e R e f   s w i g R e l e a s e ( O S G e o . M a p G u i d e . M g S e r i a l i z a b l e )  -
- t y p e   O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y   :   O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ V a l u e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t V a l u e ( )  -
-         [ M e t h o d ]   V o i d   S e t V a l u e ( S y s t e m . S t r i n g )  -
- A s s e m b l y :   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e D i m e n s i o n   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   M  -
-         [ F i e l d ]   I n t 3 2   X Y  -
-         [ F i e l d ]   I n t 3 2   X Y Z  -
- t y p e   O S G e o . M a p G u i d e . M g G e o m e t r y E n t i t y T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   G e o m e t r y C o m p o n e n t  -
- t y p e   O S G e o . M a p G u i d e . M g G e o m e t r i c P a t h I n s t r u c t i o n T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   C l o s e  -
-         [ F i e l d ]   I n t 3 2   L i n e T o  -
-         [ F i e l d ]   I n t 3 2   M o v e T o  -
-         [ F i e l d ]   I n t 3 2   Q u a d T o  -
- t y p e   O S G e o . M a p G u i d e . M g G e o m e t r y C o m p o n e n t T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   A r c S e g m e n t  -
-         [ F i e l d ]   I n t 3 2   C u r v e R i n g  -
-         [ F i e l d ]   I n t 3 2   L i n e a r R i n g  -
-         [ F i e l d ]   I n t 3 2   L i n e a r S e g m e n t  -
- t y p e   O S G e o . M a p G u i d e . M g G e o m e t r y T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   C u r v e P o l y g o n  -
-         [ F i e l d ]   I n t 3 2   C u r v e S t r i n g  -
-         [ F i e l d ]   I n t 3 2   L i n e S t r i n g  -
-         [ F i e l d ]   I n t 3 2   M u l t i C u r v e P o l y g o n  -
-         [ F i e l d ]   I n t 3 2   M u l t i C u r v e S t r i n g  -
-         [ F i e l d ]   I n t 3 2   M u l t i G e o m e t r y  -
-         [ F i e l d ]   I n t 3 2   M u l t i L i n e S t r i n g  -
-         [ F i e l d ]   I n t 3 2   M u l t i P o i n t  -
-         [ F i e l d ]   I n t 3 2   M u l t i P o l y g o n  -
-         [ F i e l d ]   I n t 3 2   P o i n t  -
-         [ F i e l d ]   I n t 3 2   P o l y g o n  -
- t y p e   O S G e o . M a p G u i d e . M g G e o m e t r y S i m p l i f i c a t i o n A l g o r i t h m T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   D o u g l a s P e u c k e r  -
-         [ F i e l d ]   I n t 3 2   T o p o l o g y P r e s e r v i n g  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C o d e F o r m a t   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   E p s g  -
-         [ F i e l d ]   I n t 3 2   M e n t o r  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E r r o r C o d e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   A F F Z E R O  -
-         [ F i e l d ]   I n t 3 2   A Z M  -
-         [ F i e l d ]   I n t 3 2   A Z M T H  -
-         [ F i e l d ]   I n t 3 2   C o n v e r s i o n F a i l e d  -
-         [ F i e l d ]   I n t 3 2   C R T M M  -
-         [ F i e l d ]   I n t 3 2   D E N R G N  -
-         [ F i e l d ]   I n t 3 2   E L E V E L  -
-         [ F i e l d ]   I n t 3 2   G E O M M  -
-         [ F i e l d ]   I n t 3 2   H M I S P H R  -
-         [ F i e l d ]   I n t 3 2   I n i t i a l i z a t i o n F a i l e d  -
-         [ F i e l d ]   I n t 3 2   I n v a l i d A r g u m e n t  -
-         [ F i e l d ]   I n t 3 2   I N V D T M  -
-         [ F i e l d ]   I n t 3 2   I N V E L P  -
-         [ F i e l d ]   I n t 3 2   I N V P R J  -
-         [ F i e l d ]   I n t 3 2   I N V Q U A D  -
-         [ F i e l d ]   I n t 3 2   L A T  -
-         [ F i e l d ]   I n t 3 2   L A T E Q U  -
-         [ F i e l d ]   I n t 3 2   L L R N G  -
-         [ F i e l d ]   I n t 3 2   L N G  -
-         [ F i e l d ]   I n t 3 2   L N G E Q U  -
-         [ F i e l d ]   I n t 3 2   M A P S C L  -
-         [ F i e l d ]   I n t 3 2   M A X 1 5  -
-         [ F i e l d ]   I n t 3 2   M E R E Q U  -
-         [ F i e l d ]   I n t 3 2   M R C A T  -
-         [ F i e l d ]   I n t 3 2   M S C O E F  -
-         [ F i e l d ]   I n t 3 2   N O R E F  -
-         [ F i e l d ]   I n t 3 2   N O T N R T H  -
-         [ F i e l d ]   I n t 3 2   N R D A T U M  -
-         [ F i e l d ]   I n t 3 2   N R T H L A T  -
-         [ F i e l d ]   I n t 3 2   N R T H P N T  -
-         [ F i e l d ]   I n t 3 2   N u l l A r g u m e n t  -
-         [ F i e l d ]   I n t 3 2   O B L Q P O L E  -
-         [ F i e l d ]   I n t 3 2   O k  -
-         [ F i e l d ]   I n t 3 2   O R G L A T  -
-         [ F i e l d ]   I n t 3 2   O R G L N G  -
-         [ F i e l d ]   I n t 3 2   O S T N 0 2  -
-         [ F i e l d ]   I n t 3 2   O S T N 9 7  -
-         [ F i e l d ]   I n t 3 2   O u t O f M e m o r y  -
-         [ F i e l d ]   I n t 3 2   P L L 9 0  -
-         [ F i e l d ]   I n t 3 2   P L L E D  -
-         [ F i e l d ]   I n t 3 2   P L L E Q U  -
-         [ F i e l d ]   I n t 3 2   P L L L R G  -
-         [ F i e l d ]   I n t 3 2   P L L R E V  -
-         [ F i e l d ]   I n t 3 2   P L L Z E R O  -
-         [ F i e l d ]   I n t 3 2   P L R L A T  -
-         [ F i e l d ]   I n t 3 2   P O L D D  -
-         [ F i e l d ]   I n t 3 2   P O L D U P  -
-         [ F i e l d ]   I n t 3 2   P O L L A T  -
-         [ F i e l d ]   I n t 3 2   P O L L N G  -
-         [ F i e l d ]   I n t 3 2   Q U A D  -
-         [ F i e l d ]   I n t 3 2   R N G O R D  -
-         [ F i e l d ]   I n t 3 2   S C L R E D  -
-         [ F i e l d ]   I n t 3 2   S O T H L A T  -
-         [ F i e l d ]   I n t 3 2   S T D L A T  -
-         [ F i e l d ]   I n t 3 2   S T D L N G  -
-         [ F i e l d ]   I n t 3 2   S T D P L L  -
-         [ F i e l d ]   I n t 3 2   S T D S O U  -
-         [ F i e l d ]   I n t 3 2   S T D W E S T  -
-         [ F i e l d ]   I n t 3 2   T M K R G 0  -
-         [ F i e l d ]   I n t 3 2   U N I T  -
-         [ F i e l d ]   I n t 3 2   U S E P L R  -
-         [ F i e l d ]   I n t 3 2   U S E S W  -
-         [ F i e l d ]   I n t 3 2   U T M Z O N  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n M e t h o d   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   A G D 6 6  -
-         [ F i e l d ]   I n t 3 2   A G D 8 4  -
-         [ F i e l d ]   I n t 3 2   A T S 7 7  -
-         [ F i e l d ]   I n t 3 2   B u r s a  -
-         [ F i e l d ]   I n t 3 2   C H E N Y X  -
-         [ F i e l d ]   I n t 3 2   C S R S  -
-         [ F i e l d ]   I n t 3 2   D H D N  -
-         [ F i e l d ]   I n t 3 2   E D 5 0  -
-         [ F i e l d ]   I n t 3 2   E T R F 8 9  -
-         [ F i e l d ]   I n t 3 2   F o u r P a r a m e t e r  -
-         [ F i e l d ]   I n t 3 2   G D A 9 4  -
-         [ F i e l d ]   I n t 3 2   G e o c e n t r i c  -
-         [ F i e l d ]   I n t 3 2   H P G N  -
-         [ F i e l d ]   I n t 3 2   L c l g r f  -
-         [ F i e l d ]   I n t 3 2   M o l o d e n s k y  -
-         [ F i e l d ]   I n t 3 2   M R e g  -
-         [ F i e l d ]   I n t 3 2   N A D 2 7  -
-         [ F i e l d ]   I n t 3 2   N A D 8 3  -
-         [ F i e l d ]   I n t 3 2   N o n e  -
-         [ F i e l d ]   I n t 3 2   N Z G D 2 K  -
-         [ F i e l d ]   I n t 3 2   N Z G D 4 9  -
-         [ F i e l d ]   I n t 3 2   R G F 9 3  -
-         [ F i e l d ]   I n t 3 2   S e v e n P a r a m e t e r  -
-         [ F i e l d ]   I n t 3 2   S i x P a r a m e t e r  -
-         [ F i e l d ]   I n t 3 2   T h r e e P a r a m e t e r  -
-         [ F i e l d ]   I n t 3 2   T O K Y O  -
-         [ F i e l d ]   I n t 3 2   W G S 7 2  -
-         [ F i e l d ]   I n t 3 2   W G S 8 4  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d O r i e n t a t i o n   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   B y t e   E a s t W e s t  -
-         [ F i e l d ]   B y t e   N o n e  -
-         [ F i e l d ]   B y t e   N o r t h S o u t h  -
-         [ F i e l d ]   B y t e   U n k n o w n  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i a l i z a t i o n T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   G e n e r i c  -
-         [ F i e l d ]   I n t 3 2   M G R S  -
-         [ F i e l d ]   I n t 3 2   U n k n o w n  -
-         [ F i e l d ]   I n t 3 2   U S N G  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M g r s G r i d L e v e l   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   M g r s 1 0 0 K m  -
-         [ F i e l d ]   I n t 3 2   M g r s 1 0 0 m  -
-         [ F i e l d ]   I n t 3 2   M g r s 1 0 K m  -
-         [ F i e l d ]   I n t 3 2   M g r s 1 0 m  -
-         [ F i e l d ]   I n t 3 2   M g r s 1 K m  -
-         [ F i e l d ]   I n t 3 2   M g r s 1 m  -
-         [ F i e l d ]   I n t 3 2   M g r s N o n e  -
-         [ F i e l d ]   I n t 3 2   M g r s U n k n o w n  -
-         [ F i e l d ]   I n t 3 2   M g r s U p s  -
-         [ F i e l d ]   I n t 3 2   M g r s U t m  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M g r s L e t t e r i n g S c h e m e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   B y t e   A l t e r n a t i v e  -
-         [ F i e l d ]   B y t e   N o r m a l  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M g r s G r i d S q u a r e P o s i t i o n   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   C e n t e r  -
-         [ F i e l d ]   I n t 3 2   E a s t  -
-         [ F i e l d ]   I n t 3 2   N o r t h  -
-         [ F i e l d ]   I n t 3 2   N o r t h E a s t  -
-         [ F i e l d ]   I n t 3 2   N o r t h W e s t  -
-         [ F i e l d ]   I n t 3 2   S o u t h  -
-         [ F i e l d ]   I n t 3 2   S o u t h E a s t  -
-         [ F i e l d ]   I n t 3 2   S o u t h W e s t  -
-         [ F i e l d ]   I n t 3 2   W e s t  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n C o d e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   A l b e r  -
-         [ F i e l d ]   I n t 3 2   A z e d e  -
-         [ F i e l d ]   I n t 3 2   A z m e a  -
-         [ F i e l d ]   I n t 3 2   A z m e d  -
-         [ F i e l d ]   I n t 3 2   B i p o l a r  -
-         [ F i e l d ]   I n t 3 2   B o n n e  -
-         [ F i e l d ]   I n t 3 2   C a s s i n i  -
-         [ F i e l d ]   I n t 3 2   E c k e r t 4  -
-         [ F i e l d ]   I n t 3 2   E c k e r t 6  -
-         [ F i e l d ]   I n t 3 2   E d c n c  -
-         [ F i e l d ]   I n t 3 2   E d c y l  -
-         [ F i e l d ]   I n t 3 2   E d c y l E  -
-         [ F i e l d ]   I n t 3 2   G a u s s K  -
-         [ F i e l d ]   I n t 3 2   G n o m o n i c  -
-         [ F i e l d ]   I n t 3 2   G o o d e  -
-         [ F i e l d ]   I n t 3 2   H o m 1 u v  -
-         [ F i e l d ]   I n t 3 2   H o m 1 x y  -
-         [ F i e l d ]   I n t 3 2   H o m 2 u v  -
-         [ F i e l d ]   I n t 3 2   H o m 2 x y  -
-         [ F i e l d ]   I n t 3 2   K r o v a k  -
-         [ F i e l d ]   I n t 3 2   K r v k 9 5  -
-         [ F i e l d ]   I n t 3 2   L L  -
-         [ F i e l d ]   I n t 3 2   L m 1 s p  -
-         [ F i e l d ]   I n t 3 2   L m 2 s p  -
-         [ F i e l d ]   I n t 3 2   L m b l g  -
-         [ F i e l d ]   I n t 3 2   L m b r t a f  -
-         [ F i e l d ]   I n t 3 2   L m M i c h  -
-         [ F i e l d ]   I n t 3 2   L m t a n  -
-         [ F i e l d ]   I n t 3 2   M i l l e r  -
-         [ F i e l d ]   I n t 3 2   M n d o t l  -
-         [ F i e l d ]   I n t 3 2   M n d o t t  -
-         [ F i e l d ]   I n t 3 2   M o d p c  -
-         [ F i e l d ]   I n t 3 2   M o l l w e i d  -
-         [ F i e l d ]   I n t 3 2   M r c a t  -
-         [ F i e l d ]   I n t 3 2   M r c a t K  -
-         [ F i e l d ]   I n t 3 2   M s t e r o  -
-         [ F i e l d ]   I n t 3 2   N e a c y l  -
-         [ F i e l d ]   I n t 3 2   N e r t h  -
-         [ F i e l d ]   I n t 3 2   N r t h s r t  -
-         [ F i e l d ]   I n t 3 2   N z e a l a n d  -
-         [ F i e l d ]   I n t 3 2   O b l q M  -
-         [ F i e l d ]   I n t 3 2   O b q c y l  -
-         [ F i e l d ]   I n t 3 2   O r t h o  -
-         [ F i e l d ]   I n t 3 2   O s t n 0 2  -
-         [ F i e l d ]   I n t 3 2   O s t n 9 7  -
-         [ F i e l d ]   I n t 3 2   O s t r o  -
-         [ F i e l d ]   I n t 3 2   P l a t e C a r r e e  -
-         [ F i e l d ]   I n t 3 2   P l y c n  -
-         [ F i e l d ]   I n t 3 2   P s t r o  -
-         [ F i e l d ]   I n t 3 2   P s t r o s l  -
-         [ F i e l d ]   I n t 3 2   P v M e r c a t o r  -
-         [ F i e l d ]   I n t 3 2   R o b i n s o n  -
-         [ F i e l d ]   I n t 3 2   R s k e w  -
-         [ F i e l d ]   I n t 3 2   R s k e w c  -
-         [ F i e l d ]   I n t 3 2   R s k e w o  -
-         [ F i e l d ]   I n t 3 2   S i n u s  -
-         [ F i e l d ]   I n t 3 2   S o t r m  -
-         [ F i e l d ]   I n t 3 2   S s t r o  -
-         [ F i e l d ]   I n t 3 2   S w i s s  -
-         [ F i e l d ]   I n t 3 2   S y s 3 4  -
-         [ F i e l d ]   I n t 3 2   S y s 3 4 _ 0 1  -
-         [ F i e l d ]   I n t 3 2   S y s 3 4 _ 9 9  -
-         [ F i e l d ]   I n t 3 2   T e a c y l  -
-         [ F i e l d ]   I n t 3 2   T m  -
-         [ F i e l d ]   I n t 3 2   T r m e r a f  -
-         [ F i e l d ]   I n t 3 2   T r m r k r g  -
-         [ F i e l d ]   I n t 3 2   T r m r s  -
-         [ F i e l d ]   I n t 3 2   U t m  -
-         [ F i e l d ]   I n t 3 2   V d g r n t n  -
-         [ F i e l d ]   I n t 3 2   W c c s l  -
-         [ F i e l d ]   I n t 3 2   W c c s t  -
-         [ F i e l d ]   I n t 3 2   W i n k l  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n F o r m a t T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   A n g d  -
-         [ F i e l d ]   I n t 3 2   C o e f  -
-         [ F i e l d ]   I n t 3 2   L a t  -
-         [ F i e l d ]   I n t 3 2   L n g  -
-         [ F i e l d ]   I n t 3 2   R o t  -
-         [ F i e l d ]   I n t 3 2   S c l  -
-         [ F i e l d ]   I n t 3 2   X x x  -
-         [ F i e l d ]   I n t 3 2   Y y y  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n L o g i c a l T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   A f f i n e C o e f f i c i e n t  -
-         [ F i e l d ]   I n t 3 2   A n g u l a r D i s t a n c e  -
-         [ F i e l d ]   I n t 3 2   A z i m u t h  -
-         [ F i e l d ]   I n t 3 2   C o m p l e x C o e f f i c i e n t  -
-         [ F i e l d ]   I n t 3 2   E l e v a t i o n  -
-         [ F i e l d ]   I n t 3 2   G e o i d H e i g h t  -
-         [ F i e l d ]   I n t 3 2   H e m i s p h e r e S e l e c t i o n  -
-         [ F i e l d ]   I n t 3 2   L a t i t u d e  -
-         [ F i e l d ]   I n t 3 2   L o n g i t u d e  -
-         [ F i e l d ]   I n t 3 2   S c a l e  -
-         [ F i e l d ]   I n t 3 2   U T M Z o n e N u m b e r  -
-         [ F i e l d ]   I n t 3 2   X Y C o o r d i n a t e  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n P a r a m e t e r T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   A d p 1 p 2  -
-         [ F i e l d ]   I n t 3 2   A d s p 1  -
-         [ F i e l d ]   I n t 3 2   A d s p 2  -
-         [ F i e l d ]   I n t 3 2   A e l e v  -
-         [ F i e l d ]   I n t 3 2   A f a 0  -
-         [ F i e l d ]   I n t 3 2   A f a 1  -
-         [ F i e l d ]   I n t 3 2   A f a 2  -
-         [ F i e l d ]   I n t 3 2   A f b 0  -
-         [ F i e l d ]   I n t 3 2   A f b 1  -
-         [ F i e l d ]   I n t 3 2   A f b 2  -
-         [ F i e l d ]   I n t 3 2   C m p l x a n  -
-         [ F i e l d ]   I n t 3 2   C m p l x b n  -
-         [ F i e l d ]   I n t 3 2   C n t m e r  -
-         [ F i e l d ]   I n t 3 2   D e n r g n  -
-         [ F i e l d ]   I n t 3 2   E a s t l l  -
-         [ F i e l d ]   I n t 3 2   E l l i p s o i d S c a l e  -
-         [ F i e l d ]   I n t 3 2   E s t d m e r  -
-         [ F i e l d ]   I n t 3 2   G c a z m  -
-         [ F i e l d ]   I n t 3 2   G c p 1 l a t  -
-         [ F i e l d ]   I n t 3 2   G c p 1 l n g  -
-         [ F i e l d ]   I n t 3 2   G c p 2 l a t  -
-         [ F i e l d ]   I n t 3 2   G c p 2 l n g  -
-         [ F i e l d ]   I n t 3 2   G c p l a t  -
-         [ F i e l d ]   I n t 3 2   G c p l n g  -
-         [ F i e l d ]   I n t 3 2   G h g t  -
-         [ F i e l d ]   I n t 3 2   H s n s  -
-         [ F i e l d ]   I n t 3 2   N o t U s e d  -
-         [ F i e l d ]   I n t 3 2   N p a r a l l  -
-         [ F i e l d ]   I n t 3 2   N r m l p l l  -
-         [ F i e l d ]   I n t 3 2   N r t h r o t  -
-         [ F i e l d ]   I n t 3 2   N r t h s c l  -
-         [ F i e l d ]   I n t 3 2   N s t d p l l  -
-         [ F i e l d ]   I n t 3 2   O s t d p l l  -
-         [ F i e l d ]   I n t 3 2   P 1 l a t  -
-         [ F i e l d ]   I n t 3 2   P 1 l n g  -
-         [ F i e l d ]   I n t 3 2   P 2 l a t  -
-         [ F i e l d ]   I n t 3 2   P 2 l n g  -
-         [ F i e l d ]   I n t 3 2   P o l e l a t  -
-         [ F i e l d ]   I n t 3 2   P o l e l n g  -
-         [ F i e l d ]   I n t 3 2   S c l r o t o r g x  -
-         [ F i e l d ]   I n t 3 2   S c l r o t o r g y  -
-         [ F i e l d ]   I n t 3 2   S k w a z m  -
-         [ F i e l d ]   I n t 3 2   S p a r a l l  -
-         [ F i e l d ]   I n t 3 2   S s t d p l l  -
-         [ F i e l d ]   I n t 3 2   S t d c i r  -
-         [ F i e l d ]   I n t 3 2   S t d p l l  -
-         [ F i e l d ]   I n t 3 2   U t m z n  -
-         [ F i e l d ]   I n t 3 2   W e s t l l  -
-         [ F i e l d ]   I n t 3 2   Y a x i s a z  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   A r b i t r a r y  -
-         [ F i e l d ]   I n t 3 2   G e o g r a p h i c  -
-         [ F i e l d ]   I n t 3 2   P r o j e c t e d  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m U n i t C o d e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   B e n o i t C h a i n  -
-         [ F i e l d ]   I n t 3 2   B e n o i t L i n k  -
-         [ F i e l d ]   I n t 3 2   B r C h a i n T r u n c  -
-         [ F i e l d ]   I n t 3 2   B r e a l e y  -
-         [ F i e l d ]   I n t 3 2   B r F o o t T r u n c  -
-         [ F i e l d ]   I n t 3 2   B r L i n k T r u n c  -
-         [ F i e l d ]   I n t 3 2   C a G r i d  -
-         [ F i e l d ]   I n t 3 2   C a p e F o o t  -
-         [ F i e l d ]   I n t 3 2   C e n t i m e t e r  -
-         [ F i e l d ]   I n t 3 2   C e n t i s e c  -
-         [ F i e l d ]   I n t 3 2   C l a r k e C h a i n  -
-         [ F i e l d ]   I n t 3 2   C l a r k e F o o t  -
-         [ F i e l d ]   I n t 3 2   C l a r k e L i n k  -
-         [ F i e l d ]   I n t 3 2   D e c a m e t e r  -
-         [ F i e l d ]   I n t 3 2   D e c i m e t e r  -
-         [ F i e l d ]   I n t 3 2   D e c i s e c  -
-         [ F i e l d ]   I n t 3 2   D e g r e e  -
-         [ F i e l d ]   I n t 3 2   D e k a m e t e r  -
-         [ F i e l d ]   I n t 3 2   F o o t  -
-         [ F i e l d ]   I n t 3 2   F u r l o n g  -
-         [ F i e l d ]   I n t 3 2   G e r m a n M e t e r  -
-         [ F i e l d ]   I n t 3 2   G o l d C o a s t F o o t  -
-         [ F i e l d ]   I n t 3 2   G r a d  -
-         [ F i e l d ]   I n t 3 2   G r a d e  -
-         [ F i e l d ]   I n t 3 2   G u n t e r C h a i n  -
-         [ F i e l d ]   I n t 3 2   G u n t e r L i n k  -
-         [ F i e l d ]   I n t 3 2   H e c t o m e t e r  -
-         [ F i e l d ]   I n t 3 2   I F o o t  -
-         [ F i e l d ]   I n t 3 2   I I n c h  -
-         [ F i e l d ]   I n t 3 2   I M i l e  -
-         [ F i e l d ]   I n t 3 2   I n c h  -
-         [ F i e l d ]   I n t 3 2   I n d i a n F o o t  -
-         [ F i e l d ]   I n t 3 2   I n d i a n F t 3 7  -
-         [ F i e l d ]   I n t 3 2   I n d i a n F t 6 2  -
-         [ F i e l d ]   I n t 3 2   I n d i a n F t 7 5  -
-         [ F i e l d ]   I n t 3 2   I n d i a n Y a r d  -
-         [ F i e l d ]   I n t 3 2   I n d i a n Y d 3 7  -
-         [ F i e l d ]   I n t 3 2   I n t e r n a t i o n a l C h a i n  -
-         [ F i e l d ]   I n t 3 2   I n t e r n a t i o n a l L i n k  -
-         [ F i e l d ]   I n t 3 2   I Y a r d  -
-         [ F i e l d ]   I n t 3 2   K i l o m e t e r  -
-         [ F i e l d ]   I n t 3 2   K n o t  -
-         [ F i e l d ]   I n t 3 2   L a t 6 6  -
-         [ F i e l d ]   I n t 3 2   L a t 8 3  -
-         [ F i e l d ]   I n t 3 2   M a p I n f o  -
-         [ F i e l d ]   I n t 3 2   M e t e r  -
-         [ F i e l d ]   I n t 3 2   M i c r o I n c h  -
-         [ F i e l d ]   I n t 3 2   M i l  -
-         [ F i e l d ]   I n t 3 2   M i l e  -
-         [ F i e l d ]   I n t 3 2   M i l l i m e t e r  -
-         [ F i e l d ]   I n t 3 2   M i l l i s e c  -
-         [ F i e l d ]   I n t 3 2   M i n u t e  -
-         [ F i e l d ]   I n t 3 2   N a u t M  -
-         [ F i e l d ]   I n t 3 2   P e r c h  -
-         [ F i e l d ]   I n t 3 2   P o l e  -
-         [ F i e l d ]   I n t 3 2   R a d i a n  -
-         [ F i e l d ]   I n t 3 2   R o d  -
-         [ F i e l d ]   I n t 3 2   R o o d  -
-         [ F i e l d ]   I n t 3 2   S e a r s C h a i n  -
-         [ F i e l d ]   I n t 3 2   S e a r s F o o t  -
-         [ F i e l d ]   I n t 3 2   S e a r s L i n k  -
-         [ F i e l d ]   I n t 3 2   S e a r s Y a r d  -
-         [ F i e l d ]   I n t 3 2   S e c o n d  -
-         [ F i e l d ]   I n t 3 2   Y a r d  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m U n i t T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   A n g u l a r  -
-         [ F i e l d ]   I n t 3 2   L i n e a r  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m W k t F l a v o r   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   E s r i  -
-         [ F i e l d ]   I n t 3 2   G e o t i f f  -
-         [ F i e l d ]   I n t 3 2   G e o t o o l s  -
-         [ F i e l d ]   I n t 3 2   O g c  -
-         [ F i e l d ]   I n t 3 2   O r a c l e  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   A n a l y t i c a l  -
-         [ F i e l d ]   I n t 3 2   I n t e r p o l a t i o n  -
-         [ F i e l d ]   I n t 3 2   M u l t i p l e R e g r e s s i o n  -
-         [ F i e l d ]   I n t 3 2   S t a n d a l o n e  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c D i r e c t i o n   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   G e o d e t i c D i r e c t i o n E r r o r  -
-         [ F i e l d ]   I n t 3 2   G e o d e t i c D i r e c t i o n F o r w a r d  -
-         [ F i e l d ]   I n t 3 2   G e o d e t i c D i r e c t i o n I n v e r s e  -
-         [ F i e l d ]   I n t 3 2   G e o d e t i c D i r e c t i o n N o n e  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c A n a l y t i c a l T r a n s f o r m a t i o n M e t h o d   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   A b r i d g e d M o l o d e n s k y  -
-         [ F i e l d ]   I n t 3 2   F r a m e  -
-         [ F i e l d ]   I n t 3 2   M o l o d e n s k y B a d e k a s  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c M u l t i p l e R e g r e s s i o n T r a n s f o r m a t i o n M e t h o d   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   G e n e r a l P o l y n o m i a l E p s g  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c S t a n d a l o n e T r a n s f o r m a t i o n M e t h o d   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   N u l l X  -
-         [ F i e l d ]   I n t 3 2   W g s 7 2  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e F o r m a t   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   G E O C O N  -
-         [ F i e l d ]   I n t 3 2   N A D C O N  -
-         [ F i e l d ]   I n t 3 2   N T v 1  -
-         [ F i e l d ]   I n t 3 2   N T v 2  -
-         [ F i e l d ]   I n t 3 2   O S T 0 2  -
-         [ F i e l d ]   I n t 3 2   O S T 1 5  -
-         [ F i e l d ]   I n t 3 2   O S T 9 7  -
-         [ F i e l d ]   I n t 3 2   P A R  -
-         [ F i e l d ]   I n t 3 2   R G F  -
- t y p e   O S G e o . M a p G u i d e . M g A g f R e a d e r W r i t e r   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y   R e a d ( O S G e o . M a p G u i d e . M g B y t e R e a d e r ,   O S G e o . M a p G u i d e . M g T r a n s f o r m )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y   R e a d ( O S G e o . M a p G u i d e . M g B y t e R e a d e r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   W r i t e ( O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   W r i t e ( O S G e o . M a p G u i d e . M g G e o m e t r y ,   O S G e o . M a p G u i d e . M g T r a n s f o r m )  -
- t y p e   O S G e o . M a p G u i d e . M g A g g r e g a t e G e o m e t r y   :   O S G e o . M a p G u i d e . M g G e o m e t r y  -
- t y p e   O S G e o . M a p G u i d e . M g A r c S e g m e n t   :   O S G e o . M a p G u i d e . M g C u r v e S e g m e n t  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r i c E n t i t y   C o p y ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ C o m p o n e n t T y p e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   g e t _ C o n t r o l C o o r d i n a t e ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ D i m e n s i o n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   g e t _ E n d C o o r d i n a t e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   g e t _ S t a r t C o o r d i n a t e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t C o m p o n e n t T y p e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   G e t C o n t r o l C o o r d i n a t e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t D i m e n s i o n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   G e t E n d C o o r d i n a t e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   G e t S t a r t C o o r d i n a t e ( )  -
-         [ M e t h o d ]   B o o l e a n   I s C l o s e d ( )  -
-         [ M e t h o d ]   B o o l e a n   I s E m p t y ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r i c E n t i t y   T r a n s f o r m ( O S G e o . M a p G u i d e . M g T r a n s f o r m )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ M e t h o d ]   D o u b l e   g e t _ M ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ N o M ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ N o Z ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ X ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ Y ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ Z ( )  -
-         [ M e t h o d ]   D o u b l e   G e t M ( )  -
-         [ M e t h o d ]   D o u b l e   G e t X ( )  -
-         [ M e t h o d ]   D o u b l e   G e t Y ( )  -
-         [ M e t h o d ]   D o u b l e   G e t Z ( )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( )  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g C o o r d i n a t e [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g C o o r d i n a t e ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e I t e r a t o r   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   G e t C u r r e n t ( )  -
-         [ M e t h o d ]   B o o l e a n   M o v e N e x t ( )  -
-         [ M e t h o d ]   V o i d   R e s e t ( )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   V o i d   C a n c e l L o n L a t B o u n d s ( )  -
-         [ M e t h o d ]   V o i d   C a n c e l X Y B o u n d s ( )  -
-         [ M e t h o d ]   V o i d   C o n v e r t C o o r d i n a t e F r o m L o n L a t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   D o u b l e   C o n v e r t C o o r d i n a t e S y s t e m U n i t s T o M e t e r s ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   C o n v e r t C o o r d i n a t e T o L o n L a t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   C o n v e r t F r o m L o n L a t ( D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   C o n v e r t F r o m L o n L a t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   C o n v e r t F r o m L o n L a t ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   D o u b l e   C o n v e r t M e t e r s T o C o o r d i n a t e S y s t e m U n i t s ( D o u b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   C o n v e r t T o L o n L a t ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   C o n v e r t T o L o n L a t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   C o n v e r t T o L o n L a t ( D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m   C r e a t e C l o n e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ C s C o d e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ D a t u m ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ D a t u m D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ E l l i p s o i d ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ E l l i p s o i d D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ E p s g C o d e ( )  -
-         [ M e t h o d ]   I n t 1 6   g e t _ E p s g Q u a d r a n t ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ M a x X ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ M a x Y ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ M i n X ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ M i n Y ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ P r o j e c t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ P r o j e c t i o n D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ S r i d C o d e ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ T y p e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ U n i t s ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ U n i t S c a l e ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t A g e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t A z i m u t h ( D o u b l e ,   D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   D o u b l e   G e t A z i m u t h ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t a l o g   G e t C a t a l o g ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   G e t C a t e g o r i e s ( )  -
-         [ M e t h o d ]   D o u b l e   G e t C o n v e r g e n c e ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   G e t C o o r d i n a t e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   G e t C o o r d i n a t e ( D o u b l e ,   D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t C o u n t r y O r S t a t e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t C s C o d e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D a t u m ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m   G e t D a t u m D e f i n i t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D a t u m D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t E l l i p s o i d ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d   G e t E l l i p s o i d D e f i n i t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t E l l i p s o i d D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t E p s g C o d e ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t E p s g Q u a d r a n t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2   G e t E r r o r s ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t G r o u p ( )  -
-         [ M e t h o d ]   D o u b l e   G e t L a t M a x ( )  -
-         [ M e t h o d ]   D o u b l e   G e t L a t M i n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t L o c a t i o n ( )  -
-         [ M e t h o d ]   D o u b l e   G e t L o n M a x ( )  -
-         [ M e t h o d ]   D o u b l e   G e t L o n M i n ( )  -
-         [ M e t h o d ]   D o u b l e   G e t M a p S c a l e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t M a x X ( )  -
-         [ M e t h o d ]   D o u b l e   G e t M a x Y ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M e a s u r e   G e t M e a s u r e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t M i n X ( )  -
-         [ M e t h o d ]   D o u b l e   G e t M i n Y ( )  -
-         [ M e t h o d ]   D o u b l e   G e t O f f s e t X ( )  -
-         [ M e t h o d ]   D o u b l e   G e t O f f s e t Y ( )  -
-         [ M e t h o d ]   D o u b l e   G e t O r i g i n L a t i t u d e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t O r i g i n L o n g i t u d e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t P r o j e c t i o n ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t P r o j e c t i o n C o d e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t P r o j e c t i o n D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   D o u b l e   G e t P r o j e c t i o n P a r a m e t e r ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t P r o j e c t i o n P a r a m e t e r C o u n t ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t Q u a d r a n t ( )  -
-         [ M e t h o d ]   D o u b l e   G e t S c a l e ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   D o u b l e   G e t S c a l e H ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   D o u b l e   G e t S c a l e K ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   D o u b l e   G e t S c a l e R e d u c t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S o u r c e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t S r i d C o d e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t T y p e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t U n i t C o d e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t U n i t s ( )  -
-         [ M e t h o d ]   D o u b l e   G e t U n i t S c a l e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t Z e r o X ( )  -
-         [ M e t h o d ]   D o u b l e   G e t Z e r o Y ( )  -
-         [ M e t h o d ]   B o o l e a n   I s E n c r y p t e d ( )  -
-         [ M e t h o d ]   B o o l e a n   I s G e o d e t i c ( )  -
-         [ M e t h o d ]   B o o l e a n   I s L e g a l C o u n t r y O r S t a t e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   I s L e g a l C s C o d e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   I s L e g a l D e s c r i p t i o n ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   I s L e g a l G r o u p ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   I s L e g a l L o c a t i o n ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   I s L e g a l S o u r c e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   I s P r o t e c t e d ( )  -
-         [ M e t h o d ]   B o o l e a n   I s S a m e A s ( O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e )  -
-         [ M e t h o d ]   B o o l e a n   I s U s a b l e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t a l o g )  -
-         [ M e t h o d ]   B o o l e a n   I s V a l i d ( )  -
-         [ M e t h o d ]   B o o l e a n   I s V a l i d L o n L a t ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   B o o l e a n   I s V a l i d X Y ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   D o u b l e   M e a s u r e E u c l i d e a n D i s t a n c e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   D o u b l e   M e a s u r e E u c l i d e a n D i s t a n c e ( D o u b l e ,   D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   D o u b l e   M e a s u r e G r e a t C i r c l e D i s t a n c e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   D o u b l e   M e a s u r e G r e a t C i r c l e D i s t a n c e ( D o u b l e ,   D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t C o u n t r y O r S t a t e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t C s C o d e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t D a t u m D e f i n i t i o n ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m )  -
-         [ M e t h o d ]   V o i d   S e t E l l i p s o i d D e f i n i t i o n ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d )  -
-         [ M e t h o d ]   V o i d   S e t E n c r y p t M o d e ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t G r o u p ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t L o c a t i o n ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t L o n L a t B o u n d s ( D o u b l e ,   D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t M a p S c a l e ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t O f f s e t s ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t O r i g i n L a t i t u d e ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t O r i g i n L o n g i t u d e ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t P r o j e c t i o n C o d e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t P r o j e c t i o n P a r a m e t e r ( I n t 3 2 ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t P r o t e c t M o d e ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t Q u a d r a n t ( I n t 1 6 )  -
-         [ M e t h o d ]   V o i d   S e t S c a l e R e d u c t i o n ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t S o u r c e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t U n i t C o d e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t X Y B o u n d s ( D o u b l e ,   D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t Z e r o e s ( D o u b l e ,   D o u b l e )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t a l o g   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   B o o l e a n   A r e D i c t i o n a r y F i l e s W r i t a b l e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y D i c t i o n a r y   G e t C a t e g o r y D i c t i o n a r y ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y   G e t C o o r d i n a t e S y s t e m D i c t i o n a r y ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m D i c t i o n a r y   G e t D a t u m D i c t i o n a r y ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D e f a u l t D i c t i o n a r y D i r ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D e f a u l t U s e r D i c t i o n a r y D i r ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D i c t i o n a r y D i r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y U t i l i t y   G e t D i c t i o n a r y U t i l i t y ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d D i c t i o n a r y   G e t E l l i p s o i d D i c t i o n a r y ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m F o r m a t C o n v e r t e r   G e t F o r m a t C o n v e r t e r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h D i c t i o n a r y   G e t G e o d e t i c P a t h D i c t i o n a r y ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D i s p o s a b l e C o l l e c t i o n   G e t G e o d e t i c T r a n s f o r m a t i o n s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f D i c t i o n a r y   G e t G e o d e t i c T r a n s f o r m D e f D i c t i o n a r y ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M a t h C o m p a r a t o r   G e t M a t h C o m p a r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n I n f o r m a t i o n   G e t P r o j e c t i o n I n f o r m a t i o n ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t P r o t e c t i o n M o d e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m U n i t I n f o r m a t i o n   G e t U n i t I n f o r m a t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t U s e r D i c t i o n a r y D i r ( )  -
-         [ M e t h o d ]   V o i d   S e t D e f a u l t D i c t i o n a r y D i r A n d F i l e N a m e s ( )  -
-         [ M e t h o d ]   V o i d   S e t D i c t i o n a r y D i r ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t P r o t e c t i o n M o d e ( I n t 1 6 )  -
-         [ M e t h o d ]   V o i d   S e t U s e r D i c t i o n a r y D i r ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         i m p l e m e n t s   S y s t e m . I D i s p o s a b l e  -
-         [ M e t h o d ]   V o i d   A d d C o o r d i n a t e S y s t e m ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   C l e a r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y   C r e a t e C l o n e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   G e t C o o r d i n a t e S y s t e m s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m   G e t E n u m ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t S i z e ( )  -
-         [ M e t h o d ]   B o o l e a n   H a s C o o r d i n a t e S y s t e m ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   I s L e g a l N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   R e m o v e C o o r d i n a t e S y s t e m ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y D i c t i o n a r y   :   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y   G e t C a t e g o r y ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y   N e w C a t e g o r y ( )  -
-         [ M e t h o d ]   V o i d   R e n a m e ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m   C r e a t e C l o n e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D t C o d e ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t E p s g C o d e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D i s p o s a b l e C o l l e c t i o n   G e t G e o d e t i c T r a n s f o r m a t i o n s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m )  -
-         [ M e t h o d ]   B o o l e a n   I s L e g a l D t C o d e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t D t C o d e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t E l l i p s o i d ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t E p s g C o d e ( I n t 1 6 )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m D i c t i o n a r y   :   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m   G e t D a t u m ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m   N e w D a t u m ( )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y   :   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m   G e t C o o r d i n a t e S y s t e m ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m   N e w C o o r d i n a t e S y s t e m ( )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e   G e t ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D e f a u l t F i l e N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t F i l e N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t P a t h ( )  -
-         [ M e t h o d ]   B o o l e a n   H a s ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   M o d i f y ( O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e )  -
-         [ M e t h o d ]   V o i d   R e m o v e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t F i l e N a m e ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y U t i l i t y   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   V o i d   C r e a t e C a t e g o r y D i c t i o n a r y ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   C r e a t e C o o r d s y s D i c t i o n a r y ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   C r e a t e D a t u m D i c t i o n a r y ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   C r e a t e E l l i p s o i d D i c t i o n a r y ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d   C r e a t e C l o n e ( )  -
-         [ M e t h o d ]   D o u b l e   E c c e n t r i c i t y T o F l a t t e n i n g R a t i o ( D o u b l e )  -
-         [ M e t h o d ]   D o u b l e   E q u a t o r i a l R a d i u s F r o m P o l a r R a d i u s F l a t t e n i n g R a t i o ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   D o u b l e   F l a t t e n i n g R a t i o F r o m R a d i i ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   D o u b l e   F l a t t e n i n g R a t i o T o E c c e n t r i c i t y ( D o u b l e )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ E l C o d e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t E c c e n t r i c i t y ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t E l C o d e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t E q u a t o r i a l R a d i u s ( )  -
-         [ M e t h o d ]   D o u b l e   G e t F l a t t e n i n g R a t i o ( )  -
-         [ M e t h o d ]   D o u b l e   G e t F l a t t e n i n g R a t i o M a x ( )  -
-         [ M e t h o d ]   D o u b l e   G e t F l a t t e n i n g R a t i o M i n ( )  -
-         [ M e t h o d ]   D o u b l e   G e t G r e a t C i r c l e A z i m u t h ( D o u b l e ,   D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   D o u b l e   G e t G r e a t C i r c l e D i s t a n c e ( D o u b l e ,   D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   D o u b l e   G e t P o l a r R a d i u s ( )  -
-         [ M e t h o d ]   D o u b l e   G e t R a d i u s M a x ( )  -
-         [ M e t h o d ]   D o u b l e   G e t R a d i u s M i n ( )  -
-         [ M e t h o d ]   B o o l e a n   I s L e g a l E l C o d e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   I s L e g a l F l a t t e n i n g R a t i o ( D o u b l e )  -
-         [ M e t h o d ]   B o o l e a n   I s L e g a l R a d i u s ( D o u b l e )  -
-         [ M e t h o d ]   B o o l e a n   I s U s a b l e ( )  -
-         [ M e t h o d ]   D o u b l e   P o l a r R a d i u s F r o m E q u a t o r i a l R a d i u s F l a t t e n i n g R a t i o ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t E l C o d e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t R a d i i ( D o u b l e ,   D o u b l e )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d D i c t i o n a r y   :   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d   G e t E l l i p s o i d ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d   N e w E l l i p s o i d ( )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   V o i d   A d d F i l t e r ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m F i l t e r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m   C r e a t e C l o n e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D i s p o s a b l e C o l l e c t i o n   N e x t ( I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   N e x t D e s c r i p t i o n ( I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   N e x t N a m e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S k i p ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   V o i d   A d d F i l t e r ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m F i l t e r I n t e g e r 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2   C r e a t e C l o n e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   N e x t ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m F a c t o r y   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   C o n v e r t C o o r d i n a t e S y s t e m C o d e T o W k t ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   C o n v e r t E p s g C o d e T o W k t ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   C o n v e r t W k t T o C o o r d i n a t e S y s t e m C o d e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 3 2   C o n v e r t W k t T o E p s g C o d e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m   C r e a t e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m   C r e a t e F r o m C o d e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   E n u m e r a t e C a t e g o r i e s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n   E n u m e r a t e C o o r d i n a t e S y s t e m s ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e   G e n e r i c G r i d ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m ,   B o o l e a n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e   G e n e r i c G r i d ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   B o o l e a n )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t B a s e L i b r a r y ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M g r s   G e t M g r s ( D o u b l e ,   D o u b l e ,   I n t 1 6 ,   B o o l e a n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M g r s   G e t M g r s D a t u m ( S y s t e m . S t r i n g ,   I n t 1 6 ,   B o o l e a n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M g r s   G e t M g r s E l l i p s o i d ( S y s t e m . S t r i n g ,   I n t 1 6 ,   B o o l e a n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m T r a n s f o r m   G e t T r a n s f o r m ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y   G r i d B o u n d a r y ( O S G e o . M a p G u i d e . M g P o l y g o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y   G r i d B o u n d a r y ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n   G r i d S p e c i f i c a t i o n ( I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n   G r i d S p e c i f i c a t i o n ( D o u b l e ,   D o u b l e ,   I n t 3 2 ,   D o u b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n   G r i d S p e c i f i c a t i o n ( )  -
-         [ M e t h o d ]   B o o l e a n   I s V a l i d ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e   M g r s G r i d ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m ,   B o o l e a n ,   I n t 1 6 ,   B o o l e a n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e   M g r s G r i d ( S y s t e m . S t r i n g ,   B o o l e a n ,   I n t 1 6 ,   B o o l e a n )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m F i l t e r   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   B o o l e a n   I s F i l t e r e d O u t ( O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m F i l t e r I n t e g e r 3 2   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   B o o l e a n   I s F i l t e r e d O u t ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m F o r m a t C o n v e r t e r   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   C o d e T o C o d e ( I n t 3 2 ,   S y s t e m . S t r i n g ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m   C o d e T o D e f i n i t i o n ( I n t 3 2 ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   C o d e T o W k t ( I n t 3 2 ,   S y s t e m . S t r i n g ,   I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   D e f i n i t i o n T o C o d e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m ,   I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   D e f i n i t i o n T o W k t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m ,   I n t 3 2 )  -
-         [ M e t h o d ]   B o o l e a n   I s C o d e I n D i c t i o n a r y ( I n t 3 2 ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   W k t T o C o d e ( I n t 3 2 ,   S y s t e m . S t r i n g ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m   W k t T o D e f i n i t i o n ( I n t 3 2 ,   S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c A n a l y t i c a l T r a n s f o r m D e f P a r a m s   :   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s  -
-         [ M e t h o d ]   D o u b l e   G e t D e l t a X ( )  -
-         [ M e t h o d ]   D o u b l e   G e t D e l t a Y ( )  -
-         [ M e t h o d ]   D o u b l e   G e t D e l t a Z ( )  -
-         [ M e t h o d ]   D o u b l e   G e t R o t a t e X ( )  -
-         [ M e t h o d ]   D o u b l e   G e t R o t a t e Y ( )  -
-         [ M e t h o d ]   D o u b l e   G e t R o t a t e Z ( )  -
-         [ M e t h o d ]   D o u b l e   G e t S c a l e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t T r a n s f o r m a t i o n M e t h o d ( )  -
-         [ M e t h o d ]   D o u b l e   G e t T r a n s l a t e X ( )  -
-         [ M e t h o d ]   D o u b l e   G e t T r a n s l a t e Y ( )  -
-         [ M e t h o d ]   D o u b l e   G e t T r a n s l a t e Z ( )  -
-         [ M e t h o d ]   V o i d   S e t D e l t a X ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t D e l t a Y ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t D e l t a Z ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t R o t a t e X ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t R o t a t e Y ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t R o t a t e Z ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t S c a l e ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t T r a n s f o r m a t i o n M e t h o d ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t T r a n s l a t e X ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t T r a n s l a t e Y ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t T r a n s l a t e Z ( D o u b l e )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c I n t e r p o l a t i o n T r a n s f o r m D e f P a r a m s   :   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t F a l l b a c k ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D i s p o s a b l e C o l l e c t i o n   G e t G r i d F i l e s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e   N e w G r i d F i l e ( )  -
-         [ M e t h o d ]   V o i d   S e t F a l l b a c k ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t G r i d F i l e s ( O S G e o . M a p G u i d e . M g D i s p o s a b l e C o l l e c t i o n )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c M u l t i p l e R e g r e s s i o n T r a n s f o r m D e f P a r a m s   :   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s  -
-         [ M e t h o d ]   D o u b l e   G e t C o e f f i c i e n t H e i g h t ( I n t 3 2 )  -
-         [ M e t h o d ]   D o u b l e   G e t C o e f f i c i e n t L a m b d a ( I n t 3 2 )  -
-         [ M e t h o d ]   D o u b l e   G e t C o e f f i c i e n t P h i ( I n t 3 2 )  -
-         [ M e t h o d ]   D o u b l e   G e t D e l t a H e i g h t ( )  -
-         [ M e t h o d ]   D o u b l e   G e t D e l t a L a m b d a ( )  -
-         [ M e t h o d ]   D o u b l e   G e t D e l t a P h i ( )  -
-         [ M e t h o d ]   D o u b l e   G e t L a m b d a O f f s e t ( )  -
-         [ M e t h o d ]   D o u b l e   G e t N o r m a l i z a t i o n S c a l e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t P h i O f f s e t ( )  -
-         [ M e t h o d ]   D o u b l e   G e t T e s t L a m b d a ( )  -
-         [ M e t h o d ]   D o u b l e   G e t T e s t P h i ( )  -
-         [ M e t h o d ]   D o u b l e   G e t V a l i d a t i o n ( )  -
-         [ M e t h o d ]   V o i d   S e t C o e f f i c i e n t H e i g h t ( I n t 3 2 ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t C o e f f i c i e n t L a m b d a ( I n t 3 2 ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t C o e f f i c i e n t P h i ( I n t 3 2 ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t D e l t a H e i g h t ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t D e l t a L a m b d a ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t D e l t a P h i ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t L a m b d a O f f s e t ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t N o r m a l i z a t i o n S c a l e ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t P h i O f f s e t ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t T e s t L a m b d a ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t T e s t P h i ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t V a l i d a t i o n ( D o u b l e )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h   C r e a t e C l o n e ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ A c c u r a c y ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ G r o u p ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ S o u r c e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ S o u r c e D a t u m ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ T a r g e t D a t u m ( )  -
-         [ M e t h o d ]   D o u b l e   G e t A c c u r a c y ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t E p s g V a r i a n t ( )  -
-         [ M e t h o d ]   B o o l e a n   G e t I s R e v e r s i b l e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D i s p o s a b l e C o l l e c t i o n   G e t P a t h E l e m e n t s ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t P a t h N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S o u r c e D a t u m ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t T a r g e t D a t u m ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h E l e m e n t   N e w P a t h E l e m e n t ( )  -
-         [ M e t h o d ]   V o i d   S e t A c c u r a c y ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t D e s c r i p t i o n ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t E p s g C o d e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t E p s g V a r i a n t ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t I s R e v e r s i b l e ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t P a t h E l e m e n t s ( O S G e o . M a p G u i d e . M g D i s p o s a b l e C o l l e c t i o n )  -
-         [ M e t h o d ]   V o i d   S e t P a t h N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t S o u r c e D a t u m ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t T a r g e t D a t u m ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h D i c t i o n a r y   :   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h   G e t G e o d e t i c P a t h ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h   N e w G e o d e t i c P a t h ( )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h E l e m e n t   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   B o o l e a n   G e t I s I n v e r s e d ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t T r a n s f o r m N a m e ( )  -
-         [ M e t h o d ]   V o i d   S e t I s I n v e r s e d ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t T r a n s f o r m N a m e ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c S t a n d a l o n e T r a n s f o r m D e f P a r a m s   :   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s  -
-         [ M e t h o d ]   I n t 3 2   g e t _ T r a n s f o r m a t i o n M e t h o d ( )  -
-         [ M e t h o d ]   V o i d   s e t _ T r a n s f o r m a t i o n M e t h o d ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   D o u b l e   G e t B u r s a W o l f e T r a n s f o r m B w S c a l e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t B u r s a W o l f e T r a n s f o r m R o t a t i o n X ( )  -
-         [ M e t h o d ]   D o u b l e   G e t B u r s a W o l f e T r a n s f o r m R o t a t i o n Y ( )  -
-         [ M e t h o d ]   D o u b l e   G e t B u r s a W o l f e T r a n s f o r m R o t a t i o n Z ( )  -
-         [ M e t h o d ]   D o u b l e   G e t B w S c a l e M a x ( )  -
-         [ M e t h o d ]   D o u b l e   G e t B w S c a l e M i n ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t G e o d e t i c T r a n s f o r m a t i o n M e t h o d ( )  -
-         [ M e t h o d ]   D o u b l e   G e t M a x O f f s e t ( )  -
-         [ M e t h o d ]   D o u b l e   G e t M a x R o t a t i o n ( )  -
-         [ M e t h o d ]   D o u b l e   G e t O f f s e t Z ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m   G e t S o u r c e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m   G e t T a r g e t ( )  -
-         [ M e t h o d ]   B o o l e a n   I s L e g a l B w S c a l e ( D o u b l e )  -
-         [ M e t h o d ]   B o o l e a n   I s L e g a l O f f s e t ( D o u b l e )  -
-         [ M e t h o d ]   B o o l e a n   I s L e g a l R o t a t i o n ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t B u r s a W o l f e T r a n s f o r m ( D o u b l e ,   D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t G e o d e t i c T r a n s f o r m a t i o n M e t h o d ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t O f f s e t ( D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t S o u r c e A n d T a r g e t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   S h i f t ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   S h i f t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   S h i f t ( D o u b l e ,   D o u b l e ,   D o u b l e )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f   C r e a t e C l o n e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n   C r e a t e T r a n s f o r m a t i o n ( B o o l e a n )  -
-         [ M e t h o d ]   D o u b l e   G e t C o n v e r g e n c e V a l u e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t E p s g V a r i a t i o n ( )  -
-         [ M e t h o d ]   D o u b l e   G e t E r r o r V a l u e ( )  -
-         [ M e t h o d ]   B o o l e a n   G e t I n v e r s e S u p p o r t e d ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t M a x I t e r a t i o n s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s   G e t P a r a m e t e r s ( )  -
-         [ M e t h o d ]   D o u b l e   G e t R a n g e M a x L a t i t u d e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t R a n g e M a x L o n g i t u d e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t R a n g e M i n L a t i t u d e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t R a n g e M i n L o n g i t u d e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t T r a n s f o r m D e f T y p e ( )  -
-         [ M e t h o d ]   V o i d   S e t C o n v e r g e n c e V a l u e ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t E p s g V a r i a t i o n ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t E r r o r V a l u e ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t I n v e r s e S u p p o r t e d ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t M a x I t e r a t i o n s ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t P a r a m e t e r s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s )  -
-         [ M e t h o d ]   V o i d   S e t R a n g e M a x L a t i t u d e ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t R a n g e M a x L o n g i t u d e ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t R a n g e M i n L a t i t u d e ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t R a n g e M i n L o n g i t u d e ( D o u b l e )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f D i c t i o n a r y   :   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f   G e t G e o d e t i c T r a n s f o r m a t i o n D e f ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f   N e w G e o d e t i c T r a n s f o r m a t i o n D e f ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   I n t 3 2   G e t F i l e F o r m a t ( )  -
-         [ M e t h o d ]   B o o l e a n   G e t I s I n v e r s e D i r e c t i o n ( )  -
-         [ M e t h o d ]   V o i d   S e t F i l e F o r m a t ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t I s I n v e r s e D i r e c t i o n ( B o o l e a n )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   I n t 3 2   A p p r o x G r i d L i n e M e m o r y U s a g e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n )  -
-         [ M e t h o d ]   I n t 3 2   A p p r o x G r i d R e g i o n M e m o r y U s a g e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n )  -
-         [ M e t h o d ]   I n t 3 2   A p p r o x G r i d T i c k M e m o r y U s a g e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n )  -
-         [ M e t h o d ]   B o o l e a n   A r e E x c e p t i o n s O n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y   G e t B o u n d a r y ( )  -
-         [ M e t h o d ]   D o u b l e   G e t C o n v e r g e n c e A n g l e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d L i n e C o l l e c t i o n   G e t G r i d L i n e s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d R e g i o n C o l l e c t i o n   G e t G r i d R e g i o n s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d T i c k C o l l e c t i o n   G e t G r i d T i c k s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n )  -
-         [ M e t h o d ]   I n t 3 2   G e t L a s t E r r o r ( )  -
-         [ M e t h o d ]   D o u b l e   G e t P r o j e c t i v e G r i d S c a l e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   I n t 3 2   G e t S p e c i a l i z a t i o n T y p e ( )  -
-         [ M e t h o d ]   V o i d   R e s e t L a s t E r r o r ( )  -
-         [ M e t h o d ]   V o i d   S e t B o u n d a r y ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y )  -
-         [ M e t h o d ]   V o i d   S e t E x c e p t i o n s O n ( B o o l e a n )  -
-         [ M e t h o d ]   I n t 3 2   S e t G r i d L i n e E x c e p t i o n L e v e l ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   S e t G r i d R e g i o n E x c e p t i o n L e v e l ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   S e t G r i d T i c k E x c e p t i o n L e v e l ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o l y g o n   G e t B o u n d a r y ( )  -
-         [ M e t h o d ]   V o i d   S e t B o u n d a r y E x t e n t s ( O S G e o . M a p G u i d e . M g P o l y g o n )  -
-         [ M e t h o d ]   V o i d   S e t B o u n d a r y E x t e n t s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d L i n e   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   I n t 3 2   G e t C o u n t ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t G r i d O r i e n t a t i o n ( )  -
-         [ M e t h o d ]   D o u b l e   G e t R e a l V a l u e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e S t r i n g   G e t S e g m e n t ( I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e S t r i n g C o l l e c t i o n   G e t S e g m e n t C o l l e c t i o n ( )  -
-         [ M e t h o d ]   V o i d   S e t S e g m e n t C o l l e c t i o n ( O S G e o . M a p G u i d e . M g L i n e S t r i n g C o l l e c t i o n )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d L i n e C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d L i n e   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( I n t 3 2 ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   R e m o v e A t ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d R e g i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e S t r i n g C o l l e c t i o n   G e t E a s t L i n e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t L a b e l ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e S t r i n g C o l l e c t i o n   G e t N o r t h L i n e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o l y g o n   G e t R e g i o n B o u n d a r y ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   G e t R e g i o n C e n t e r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e S t r i n g C o l l e c t i o n   G e t S o u t h L i n e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e S t r i n g C o l l e c t i o n   G e t W e s t L i n e ( )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d R e g i o n C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d R e g i o n   G e t I t e m ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   D o u b l e   G e t C u r v e P r e c i s i o n ( )  -
-         [ M e t h o d ]   D o u b l e   G e t E a s t i n g B a s e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t E a s t i n g I n c r e m e n t ( )  -
-         [ M e t h o d ]   D o u b l e   G e t N o r t h i n g B a s e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t N o r t h i n g I n c r e m e n t ( )  -
-         [ M e t h o d ]   D o u b l e   G e t T i c k E a s t i n g I n c r e m e n t ( )  -
-         [ M e t h o d ]   D o u b l e   G e t T i c k N o r t h i n g I n c r e m e n t ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t U n i t T y p e ( )  -
-         [ M e t h o d ]   B o o l e a n   I s C o n s i s t e n t ( )  -
-         [ M e t h o d ]   B o o l e a n   I s S a m e A s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n )  -
-         [ M e t h o d ]   V o i d   S e t C u r v e P r e c i s i o n ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t G r i d B a s e ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t G r i d I n c r e m e n t ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t M a x C u r v e P o i n t s ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t T i c k I n c r e m e n t s ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t U n i t s ( I n t 3 2 ,   I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d T i c k   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   G e t D i r e c t i o n V e c t o r ( )  -
-         [ M e t h o d ]   B o o l e a n   G e t I s O n G r i d L i n e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   G e t P o s i t i o n ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t T i c k O r i e n t a t i o n ( )  -
-         [ M e t h o d ]   D o u b l e   G e t V a l u e ( )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d T i c k C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d T i c k   G e t I t e m ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M a t h C o m p a r a t o r   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   B o o l e a n   G e t C o m p a r e I n t e r n a l D a t u m O l d P a r a m e t e r s ( )  -
-         [ M e t h o d ]   B o o l e a n   S a m e ( O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e ,   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e )  -
-         [ M e t h o d ]   B o o l e a n   S a m e C o o r d i n a t e S y s t e m ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m )  -
-         [ M e t h o d ]   B o o l e a n   S a m e D a t u m ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m D a t u m )  -
-         [ M e t h o d ]   B o o l e a n   S a m e E l l i p s o i d ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d )  -
-         [ M e t h o d ]   V o i d   S e t C o m p a r e I n t e r n a l D a t u m O l d P a r a m e t e r s ( B o o l e a n )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M e a s u r e   :   O S G e o . M a p G u i d e . M g M e a s u r e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g E n v e l o p e   g e t _ E n v e l o p e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t D i s t a n c e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   D o u b l e   G e t D i s t a n c e ( D o u b l e ,   D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g E n v e l o p e   G e t E n v e l o p e ( )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m M g r s   :   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   C o n v e r t F r o m L o n L a t ( D o u b l e ,   D o u b l e ,   I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   C o n v e r t F r o m L o n L a t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   C o n v e r t T o L o n L a t ( S y s t e m . S t r i n g ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   C o n v e r t T o L o n L a t ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 1 6   G e t L e t t e r i n g S c h e m e ( )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n I n f o r m a t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2   G e t E n u m P r o j e c t i o n s ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t P a r a m e t e r C o u n t ( I n t 3 2 )  -
-         [ M e t h o d ]   D o u b l e   G e t P a r a m e t e r D e f a u l t ( I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t P a r a m e t e r F o r m a t T y p e ( I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t P a r a m e t e r L o g i c a l T y p e ( I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   D o u b l e   G e t P a r a m e t e r M a x ( I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   D o u b l e   G e t P a r a m e t e r M i n ( I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t P a r a m e t e r T y p e ( I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t T a g S t r i n g ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t U n i t T y p e ( I n t 3 2 )  -
-         [ M e t h o d ]   B o o l e a n   I s U s i n g O f f s e t ( I n t 3 2 )  -
-         [ M e t h o d ]   B o o l e a n   I s U s i n g O r i g i n L a t i t u d e ( I n t 3 2 )  -
-         [ M e t h o d ]   B o o l e a n   I s U s i n g O r i g i n L o n g i t u d e ( I n t 3 2 )  -
-         [ M e t h o d ]   B o o l e a n   I s U s i n g P a r a m e t e r ( I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   B o o l e a n   I s U s i n g Q u a d r a n t ( I n t 3 2 )  -
-         [ M e t h o d ]   B o o l e a n   I s U s i n g S c a l e R e d u c t i o n ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m T r a n s f o r m   :   O S G e o . M a p G u i d e . M g T r a n s f o r m  -
-         [ F i e l d ]   I n t 3 2   D a t u m S h i f t E r r o r  -
-         [ F i e l d ]   I n t 3 2   D a t u m S h i f t F a l l b a c k  -
-         [ M e t h o d ]   I n t 3 2   G e t d a t u m W a r n i n g C o u n t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h   G e t E x p l i c i t G e o d e t i c P a t h ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f   G e t G e o d e t i c T r a n s f o r m a t i o n ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t G e o d e t i c T r a n s f o r m a t i o n C o u n t ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t G e o d e t i c T r a n s f o r m a t i o n D i r e c t i o n ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t L a s t T r a n s f o r m S t a t u s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m   G e t S o u r c e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t S o u r c e W a r n i n g C o u n t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m   G e t T a r g e t ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t T a r g e t W a r n i n g C o u n t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e S t r i n g   G r i d L i n e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   D o u b l e ,   I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   I g n o r e D a t u m S h i f t W a r n i n g ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   I g n o r e O u t s i d e D o m a i n W a r n i n g ( B o o l e a n )  -
-         [ M e t h o d ]   B o o l e a n   I s I g n o r e D a t u m S h i f t W a r n i n g ( )  -
-         [ M e t h o d ]   B o o l e a n   I s I g n o r e O u t s i d e D o m a i n W a r n i n g ( )  -
-         [ M e t h o d ]   B o o l e a n   I s V a l i d S o u r c e P o i n t ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   B o o l e a n   I s V a l i d S o u r c e P o i n t ( D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   B o o l e a n   I s V a l i d T a r g e t P o i n t ( D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   B o o l e a n   I s V a l i d T a r g e t P o i n t ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   R e s e t L a s t T r a n s f o r m S t a t u s ( )  -
-         [ M e t h o d ]   V o i d   S e t S o u r c e A n d T a r g e t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m )  -
-         [ F i e l d ]   I n t 3 2   S o u r c e C r s E r r o r  -
-         [ F i e l d ]   I n t 3 2   T a r g e t C r s E r r o r  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   T r a n s f o r m ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   T r a n s f o r m ( O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   T r a n s f o r m ( D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g E n v e l o p e   T r a n s f o r m ( O S G e o . M a p G u i d e . M g E n v e l o p e )  -
-         [ M e t h o d ]   V o i d   T r a n s f o r m C o o r d i n a t e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ F i e l d ]   I n t 3 2   T r a n s f o r m D a t u m S h i f t W a r n i n g  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   T r a n s f o r m M ( D o u b l e ,   D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   T r a n s f o r m M ( D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ F i e l d ]   I n t 3 2   T r a n s f o r m O k  -
-         [ F i e l d ]   I n t 3 2   T r a n s f o r m O u t s i d e D o m a i n W a r n i n g  -
-         [ F i e l d ]   I n t 3 2   T r a n s f o r m T o t a l F a i l u r e  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m U n i t I n f o r m a t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t A b b r e v i a t i o n ( I n t 3 2 )  -
-         [ M e t h o d ]   D o u b l e   G e t A n g u l a r U n i t S c a l e ( I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2   G e t E n u m A n g u l a r U n i t s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2   G e t E n u m L i n e a r U n i t s ( )  -
-         [ M e t h o d ]   D o u b l e   G e t L i n e a r U n i t S c a l e ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e X Y   :   O S G e o . M a p G u i d e . M g C o o r d i n a t e  -
-         [ M e t h o d ]   I n t 3 2   g e t _ D i m e n s i o n ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ M ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ X ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ Y ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ Z ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t D i m e n s i o n ( )  -
-         [ M e t h o d ]   D o u b l e   G e t M ( )  -
-         [ M e t h o d ]   D o u b l e   G e t X ( )  -
-         [ M e t h o d ]   D o u b l e   G e t Y ( )  -
-         [ M e t h o d ]   D o u b l e   G e t Z ( )  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e X Y M   :   O S G e o . M a p G u i d e . M g C o o r d i n a t e  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e X Y Z   :   O S G e o . M a p G u i d e . M g C o o r d i n a t e  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e X Y Z M   :   O S G e o . M a p G u i d e . M g C o o r d i n a t e  -
- t y p e   O S G e o . M a p G u i d e . M g C u r v e   :   O S G e o . M a p G u i d e . M g G e o m e t r y  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   g e t _ E n d C o o r d i n a t e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   g e t _ S t a r t C o o r d i n a t e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   G e t E n d C o o r d i n a t e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   G e t S t a r t C o o r d i n a t e ( )  -
- t y p e   O S G e o . M a p G u i d e . M g C u r v e P o l y g o n   :   O S G e o . M a p G u i d e . M g R e g i o n  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r i c E n t i t y   C o p y ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C u r v e R i n g   g e t _ E x t e r i o r R i n g ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ G e o m e t r y T y p e ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ I n t e r i o r R i n g C o u n t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C u r v e R i n g   G e t E x t e r i o r R i n g ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t G e o m e t r y T y p e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C u r v e R i n g   G e t I n t e r i o r R i n g ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t I n t e r i o r R i n g C o u n t ( )  -
-         [ M e t h o d ]   B o o l e a n   I s C l o s e d ( )  -
-         [ M e t h o d ]   B o o l e a n   I s E m p t y ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r i c E n t i t y   T r a n s f o r m ( O S G e o . M a p G u i d e . M g T r a n s f o r m )  -
- [ S y s t e m . R e f l e c t i o n . D e f a u l t M e m b e r A t t r i b u t e ]  -
- t y p e   O S G e o . M a p G u i d e . M g C u r v e P o l y g o n C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e P o l y g o n ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e P o l y g o n ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e P o l y g o n ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . I E n u m e r a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( )  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g C u r v e P o l y g o n )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g C u r v e P o l y g o n )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g C u r v e P o l y g o n [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ C o u n t ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ I s R e a d O n l y ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C u r v e P o l y g o n   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g C u r v e P o l y g o n ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C u r v e P o l y g o n   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g C u r v e P o l y g o n )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C u r v e P o l y g o n )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g C u r v e P o l y g o n )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C u r v e P o l y g o n )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C u r v e P o l y g o n )  -
- t y p e   O S G e o . M a p G u i d e . M g C u r v e R i n g   :   O S G e o . M a p G u i d e . M g R i n g  -
-         [ M e t h o d ]   I n t 3 2   g e t _ C o m p o n e n t T y p e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t C o m p o n e n t T y p e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C u r v e S e g m e n t   G e t S e g m e n t ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g C u r v e R i n g C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e R i n g ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e R i n g ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e R i n g ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g C u r v e R i n g )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g C u r v e R i n g )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g C u r v e R i n g [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C u r v e R i n g   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g C u r v e R i n g ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C u r v e R i n g   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g C u r v e R i n g )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C u r v e R i n g )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g C u r v e R i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C u r v e R i n g )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C u r v e R i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g C u r v e S e g m e n t   :   O S G e o . M a p G u i d e . M g G e o m e t r y C o m p o n e n t  -
- t y p e   O S G e o . M a p G u i d e . M g C u r v e S e g m e n t C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e S e g m e n t ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e S e g m e n t ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e S e g m e n t ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g C u r v e S e g m e n t )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g C u r v e S e g m e n t )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g C u r v e S e g m e n t [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C u r v e S e g m e n t   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g C u r v e S e g m e n t ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C u r v e S e g m e n t   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g C u r v e S e g m e n t )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C u r v e S e g m e n t )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g C u r v e S e g m e n t )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C u r v e S e g m e n t )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C u r v e S e g m e n t )  -
- t y p e   O S G e o . M a p G u i d e . M g C u r v e S t r i n g   :   O S G e o . M a p G u i d e . M g C u r v e  -
- t y p e   O S G e o . M a p G u i d e . M g C u r v e S t r i n g C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e S t r i n g ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e S t r i n g ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g C u r v e S t r i n g ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g C u r v e S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g C u r v e S t r i n g )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g C u r v e S t r i n g [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C u r v e S t r i n g   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g C u r v e S t r i n g ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C u r v e S t r i n g   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g C u r v e S t r i n g )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C u r v e S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g C u r v e S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C u r v e S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C u r v e S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g E n v e l o p e   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( D o u b l e ,   D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g E n v e l o p e )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g E n v e l o p e )  -
-         [ M e t h o d ]   V o i d   E x p a n d T o I n c l u d e ( O S G e o . M a p G u i d e . M g E n v e l o p e )  -
-         [ M e t h o d ]   V o i d   E x p a n d T o I n c l u d e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   D o u b l e   g e t _ D e p t h ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ H e i g h t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   g e t _ L o w e r L e f t C o o r d i n a t e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   g e t _ U p p e r R i g h t C o o r d i n a t e ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ W i d t h ( )  -
-         [ M e t h o d ]   D o u b l e   G e t D e p t h ( )  -
-         [ M e t h o d ]   D o u b l e   G e t H e i g h t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   G e t L o w e r L e f t C o o r d i n a t e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   G e t U p p e r R i g h t C o o r d i n a t e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t W i d t h ( )  -
-         [ M e t h o d ]   B o o l e a n   I n t e r s e c t s ( O S G e o . M a p G u i d e . M g E n v e l o p e )  -
-         [ M e t h o d ]   B o o l e a n   I s N u l l ( )  -
-         [ M e t h o d ]   V o i d   M a k e N u l l ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g E n v e l o p e   T r a n s f o r m ( O S G e o . M a p G u i d e . M g T r a n s f o r m )  -
- t y p e   O S G e o . M a p G u i d e . M g G e o m e t r i c E n t i t y   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         i m p l e m e n t s   S y s t e m . I D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g E n v e l o p e   E n v e l o p e ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ A r e a ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o i n t   g e t _ C e n t r o i d ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ L e n g t h ( )  -
-         [ M e t h o d ]   D o u b l e   G e t A r e a ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o i n t   G e t C e n t r o i d ( )  -
-         [ M e t h o d ]   D o u b l e   G e t L e n g t h ( )  -
-         [ M e t h o d ]   B o o l e a n   I s S i m p l e ( )  -
-         [ M e t h o d ]   B o o l e a n   I s V a l i d ( )  -
- t y p e   O S G e o . M a p G u i d e . M g G e o m e t r y   :   O S G e o . M a p G u i d e . M g G e o m e t r i c E n t i t y  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y   B o u n d a r y ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y   B u f f e r ( D o u b l e ,   O S G e o . M a p G u i d e . M g M e a s u r e )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y   C o n v e x H u l l ( )  -
-         [ M e t h o d ]   B o o l e a n   C r o s s e s ( O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y   D i f f e r e n c e ( O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   B o o l e a n   D i s j o i n t ( O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   D o u b l e   D i s t a n c e ( O S G e o . M a p G u i d e . M g G e o m e t r y ,   O S G e o . M a p G u i d e . M g M e a s u r e )  -
-         [ M e t h o d ]   B o o l e a n   E q u a l s ( O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y   I n t e r s e c t i o n ( O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   B o o l e a n   I n t e r s e c t s ( O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   B o o l e a n   O v e r l a p s ( O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r e p a r e d G e o m e t r y   P r e p a r e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y   S y m e t r i c D i f f e r e n c e ( O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y   T e s s e l l a t e ( )  -
-         [ M e t h o d ]   B o o l e a n   T o u c h e s ( O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y   U n i o n ( O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   B o o l e a n   W i t h i n ( O S G e o . M a p G u i d e . M g G e o m e t r y )  -
- t y p e   O S G e o . M a p G u i d e . M g G e o m e t r y C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g G e o m e t r y ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g G e o m e t r y ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g G e o m e t r y ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   V o i d   C l e a r ( )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g G e o m e t r y [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g G e o m e t r y ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g G e o m e t r y )  -
- t y p e   O S G e o . M a p G u i d e . M g G e o m e t r y C o m p o n e n t   :   O S G e o . M a p G u i d e . M g G e o m e t r i c E n t i t y  -
- t y p e   O S G e o . M a p G u i d e . M g G e o m e t r y F a c t o r y   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g A r c S e g m e n t   C r e a t e A r c S e g m e n t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   C r e a t e C o o r d i n a t e X Y ( D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   C r e a t e C o o r d i n a t e X Y M ( D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   C r e a t e C o o r d i n a t e X Y Z ( D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   C r e a t e C o o r d i n a t e X Y Z M ( D o u b l e ,   D o u b l e ,   D o u b l e ,   D o u b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C u r v e P o l y g o n   C r e a t e C u r v e P o l y g o n ( O S G e o . M a p G u i d e . M g C u r v e R i n g ,   O S G e o . M a p G u i d e . M g C u r v e R i n g C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C u r v e R i n g   C r e a t e C u r v e R i n g ( O S G e o . M a p G u i d e . M g C u r v e S e g m e n t C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C u r v e S t r i n g   C r e a t e C u r v e S t r i n g ( O S G e o . M a p G u i d e . M g C u r v e S e g m e n t C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e a r R i n g   C r e a t e L i n e a r R i n g ( O S G e o . M a p G u i d e . M g C o o r d i n a t e C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e a r S e g m e n t   C r e a t e L i n e a r S e g m e n t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e S t r i n g   C r e a t e L i n e S t r i n g ( O S G e o . M a p G u i d e . M g C o o r d i n a t e C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g M u l t i C u r v e P o l y g o n   C r e a t e M u l t i C u r v e P o l y g o n ( O S G e o . M a p G u i d e . M g C u r v e P o l y g o n C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g M u l t i C u r v e S t r i n g   C r e a t e M u l t i C u r v e S t r i n g ( O S G e o . M a p G u i d e . M g C u r v e S t r i n g C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g M u l t i G e o m e t r y   C r e a t e M u l t i G e o m e t r y ( O S G e o . M a p G u i d e . M g G e o m e t r y C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g M u l t i L i n e S t r i n g   C r e a t e M u l t i L i n e S t r i n g ( O S G e o . M a p G u i d e . M g L i n e S t r i n g C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g M u l t i P o i n t   C r e a t e M u l t i P o i n t ( O S G e o . M a p G u i d e . M g P o i n t C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g M u l t i P o l y g o n   C r e a t e M u l t i P o l y g o n ( O S G e o . M a p G u i d e . M g P o l y g o n C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o i n t   C r e a t e P o i n t ( O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o l y g o n   C r e a t e P o l y g o n ( O S G e o . M a p G u i d e . M g L i n e a r R i n g ,   O S G e o . M a p G u i d e . M g L i n e a r R i n g C o l l e c t i o n )  -
- t y p e   O S G e o . M a p G u i d e . M g G e o m e t r y S i m p l i f i e r   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y   S i m p l i f y ( O S G e o . M a p G u i d e . M g G e o m e t r y ,   D o u b l e ,   I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g L i n e a r R i n g   :   O S G e o . M a p G u i d e . M g R i n g  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e I t e r a t o r   G e t C o o r d i n a t e s ( )  -
- t y p e   O S G e o . M a p G u i d e . M g L i n e a r R i n g C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g L i n e a r R i n g ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g L i n e a r R i n g ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g L i n e a r R i n g ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g L i n e a r R i n g )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g L i n e a r R i n g )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g L i n e a r R i n g [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e a r R i n g   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g L i n e a r R i n g ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e a r R i n g   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g L i n e a r R i n g )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g L i n e a r R i n g )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g L i n e a r R i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g L i n e a r R i n g )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g L i n e a r R i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g L i n e a r S e g m e n t   :   O S G e o . M a p G u i d e . M g C u r v e S e g m e n t  -
- t y p e   O S G e o . M a p G u i d e . M g L i n e S t r i n g   :   O S G e o . M a p G u i d e . M g C u r v e  -
- t y p e   O S G e o . M a p G u i d e . M g L i n e S t r i n g C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g L i n e S t r i n g ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g L i n e S t r i n g ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g L i n e S t r i n g ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g L i n e S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g L i n e S t r i n g )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g L i n e S t r i n g [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e S t r i n g   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g L i n e S t r i n g ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e S t r i n g   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g L i n e S t r i n g )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g L i n e S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g L i n e S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g L i n e S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g L i n e S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g M e a s u r e   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   D o u b l e   G e t A z i m u t h ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   G e t C o o r d i n a t e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   D o u b l e ,   D o u b l e )  -
- t y p e   O S G e o . M a p G u i d e . M g M u l t i C u r v e P o l y g o n   :   O S G e o . M a p G u i d e . M g A g g r e g a t e G e o m e t r y  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C u r v e P o l y g o n   G e t C u r v e P o l y g o n ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g M u l t i C u r v e S t r i n g   :   O S G e o . M a p G u i d e . M g A g g r e g a t e G e o m e t r y  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C u r v e S t r i n g   G e t C u r v e S t r i n g ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g M u l t i G e o m e t r y   :   O S G e o . M a p G u i d e . M g A g g r e g a t e G e o m e t r y  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y   G e t G e o m e t r y ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g M u l t i L i n e S t r i n g   :   O S G e o . M a p G u i d e . M g A g g r e g a t e G e o m e t r y  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e S t r i n g   G e t L i n e S t r i n g ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g M u l t i P o i n t   :   O S G e o . M a p G u i d e . M g A g g r e g a t e G e o m e t r y  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o i n t   G e t P o i n t ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g M u l t i P o l y g o n   :   O S G e o . M a p G u i d e . M g A g g r e g a t e G e o m e t r y  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e I t e r a t o r   g e t _ C o o r d i n a t e s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o l y g o n   G e t P o l y g o n ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g P o i n t   :   O S G e o . M a p G u i d e . M g G e o m e t r y  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   g e t _ C o o r d i n a t e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   G e t C o o r d i n a t e ( )  -
- t y p e   O S G e o . M a p G u i d e . M g P o i n t C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g P o i n t ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g P o i n t ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g P o i n t ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g P o i n t )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g P o i n t )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g P o i n t [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o i n t   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g P o i n t ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o i n t   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g P o i n t )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g P o i n t )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g P o i n t )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g P o i n t )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g P o i n t )  -
- t y p e   O S G e o . M a p G u i d e . M g P o l y g o n   :   O S G e o . M a p G u i d e . M g R e g i o n  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e a r R i n g   g e t _ E x t e r i o r R i n g ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e a r R i n g   G e t E x t e r i o r R i n g ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L i n e a r R i n g   G e t I n t e r i o r R i n g ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g P o l y g o n C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g P o l y g o n ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g P o l y g o n ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g P o l y g o n ,   O S G e o . M a p G u i d e . G e o m e t r y ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g P o l y g o n )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g P o l y g o n )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g P o l y g o n [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o l y g o n   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g P o l y g o n ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o l y g o n   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g P o l y g o n )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g P o l y g o n )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g P o l y g o n )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g P o l y g o n )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g P o l y g o n )  -
- t y p e   O S G e o . M a p G u i d e . M g P r e p a r e d G e o m e t r y   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
- t y p e   O S G e o . M a p G u i d e . M g R e g i o n   :   O S G e o . M a p G u i d e . M g G e o m e t r y  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o i n t   g e t _ P o i n t I n R e g i o n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o i n t   G e t P o i n t I n R e g i o n ( )  -
- t y p e   O S G e o . M a p G u i d e . M g R i n g   :   O S G e o . M a p G u i d e . M g G e o m e t r y C o m p o n e n t  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o i n t   g e t _ P o i n t I n R i n g ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o i n t   G e t P o i n t I n R i n g ( )  -
- t y p e   O S G e o . M a p G u i d e . M g T r a n s f o r m   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
- t y p e   O S G e o . M a p G u i d e . M g W k t R e a d e r W r i t e r   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y   R e a d ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g T r a n s f o r m )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y   R e a d ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   W r i t e ( O S G e o . M a p G u i d e . M g G e o m e t r y )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   W r i t e ( O S G e o . M a p G u i d e . M g G e o m e t r y ,   O S G e o . M a p G u i d e . M g T r a n s f o r m )  -
- A s s e m b l y :   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l  -
- t y p e   O S G e o . M a p G u i d e . M g L a y e r G r o u p T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   B a s e M a p  -
-         [ F i e l d ]   I n t 3 2   B a s e M a p F r o m T i l e S e t  -
-         [ F i e l d ]   I n t 3 2   N o r m a l  -
- t y p e   O S G e o . M a p G u i d e . M g L a y e r T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   D y n a m i c  -
- t y p e   O S G e o . M a p G u i d e . M g S e r v i c e T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 1 6   D r a w i n g S e r v i c e  -
-         [ F i e l d ]   I n t 1 6   F e a t u r e S e r v i c e  -
-         [ F i e l d ]   I n t 1 6   K m l S e r v i c e  -
-         [ F i e l d ]   I n t 1 6   M a p p i n g S e r v i c e  -
-         [ F i e l d ]   I n t 1 6   P r o f i l i n g S e r v i c e  -
-         [ F i e l d ]   I n t 1 6   R e n d e r i n g S e r v i c e  -
-         [ F i e l d ]   I n t 1 6   R e s o u r c e S e r v i c e  -
-         [ F i e l d ]   I n t 1 6   T i l e S e r v i c e  -
- t y p e   O S G e o . M a p G u i d e . M g U s e r   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A d m i n i s t r a t o r  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A n o n y m o u s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A u t h o r  -
-         [ F i e l d ]   S y s t e m . S t r i n g   W f s U s e r  -
-         [ F i e l d ]   S y s t e m . S t r i n g   W m s U s e r  -
- t y p e   O S G e o . M a p G u i d e . M g G r o u p   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   E v e r y o n e  -
- t y p e   O S G e o . M a p G u i d e . M g R o l e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   V i e w e r  -
- t y p e   O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   D e l e t e F e a t u r e s  -
-         [ F i e l d ]   I n t 3 2   I n s e r t F e a t u r e s  -
-         [ F i e l d ]   I n t 3 2   L o c k F e a t u r e s  -
-         [ F i e l d ]   I n t 3 2   U n l o c k F e a t u r e s  -
-         [ F i e l d ]   I n t 3 2   U p d a t e F e a t u r e s  -
- t y p e   O S G e o . M a p G u i d e . M g F e a t u r e G e o m e t r i c T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   C u r v e  -
-         [ F i e l d ]   I n t 3 2   P o i n t  -
-         [ F i e l d ]   I n t 3 2   S o l i d  -
-         [ F i e l d ]   I n t 3 2   S u r f a c e  -
- t y p e   O S G e o . M a p G u i d e . M g F e a t u r e S p a t i a l O p e r a t i o n s   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   C o n t a i n s  -
-         [ F i e l d ]   I n t 3 2   C o v e r e d B y  -
-         [ F i e l d ]   I n t 3 2   C r o s s e s  -
-         [ F i e l d ]   I n t 3 2   D i s j o i n t  -
-         [ F i e l d ]   I n t 3 2   E n v e l o p e I n t e r s e c t s  -
-         [ F i e l d ]   I n t 3 2   E q u a l s  -
-         [ F i e l d ]   I n t 3 2   I n s i d e  -
-         [ F i e l d ]   I n t 3 2   I n t e r s e c t s  -
-         [ F i e l d ]   I n t 3 2   O v e r l a p s  -
-         [ F i e l d ]   I n t 3 2   T o u c h e s  -
-         [ F i e l d ]   I n t 3 2   W i t h i n  -
- t y p e   O S G e o . M a p G u i d e . M g O b j e c t P r o p e r t y T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   C o l l e c t i o n  -
-         [ F i e l d ]   I n t 3 2   O r d e r e d C o l l e c t i o n  -
-         [ F i e l d ]   I n t 3 2   V a l u e  -
- t y p e   O S G e o . M a p G u i d e . M g O r d e r i n g O p t i o n   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   A s c e n d i n g  -
-         [ F i e l d ]   I n t 3 2   D e s c e n d i n g  -
- t y p e   O S G e o . M a p G u i d e . M g P a r a m e t e r D i r e c t i o n   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   I n p u t  -
-         [ F i e l d ]   I n t 3 2   I n p u t O u t p u t  -
-         [ F i e l d ]   I n t 3 2   O u t p u t  -
-         [ F i e l d ]   I n t 3 2   R e t  -
- t y p e   O S G e o . M a p G u i d e . M g R a s t e r D a t a M o d e l T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   B i t o n a l  -
-         [ F i e l d ]   I n t 3 2   D a t a  -
-         [ F i e l d ]   I n t 3 2   G r a y  -
-         [ F i e l d ]   I n t 3 2   P a l e t t e  -
-         [ F i e l d ]   I n t 3 2   R G B  -
-         [ F i e l d ]   I n t 3 2   R G B A  -
-         [ F i e l d ]   I n t 3 2   U n k n o w n  -
- t y p e   O S G e o . M a p G u i d e . M g R e a d e r T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   D a t a R e a d e r  -
-         [ F i e l d ]   I n t 3 2   F e a t u r e R e a d e r  -
-         [ F i e l d ]   I n t 3 2   S q l D a t a R e a d e r  -
- t y p e   O S G e o . M a p G u i d e . M g R e p o s i t o r y T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   L i b r a r y  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S e s s i o n  -
- t y p e   O S G e o . M a p G u i d e . M g R e s o u r c e T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A p p l i c a t i o n D e f i n i t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D r a w i n g S o u r c e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S o u r c e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F o l d e r  -
-         [ F i e l d ]   S y s t e m . S t r i n g   L a y e r D e f i n i t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   L o a d P r o c e d u r e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M a p  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M a p D e f i n i t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P r i n t L a y o u t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S e l e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S y m b o l D e f i n i t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S y m b o l L i b r a r y  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T i l e S e t D e f i n i t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   W a t e r m a r k D e f i n i t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   W e b L a y o u t  -
- t y p e   O S G e o . M a p G u i d e . M g R e s o u r c e T a g   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D a t a F i l e P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D a t a P a t h A l i a s B e g i n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D a t a P a t h A l i a s E n d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   L o g i n P a s s w o r d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   L o g i n U s e r n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P a s s w o r d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P r o x y P a s s w o r d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P r o x y P o r t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P r o x y S e r v e r  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P r o x y U s e r n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T i l e C a c h e P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   U s e r n a m e  -
- t y p e   O S G e o . M a p G u i d e . M g R e s o u r c e D a t a N a m e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P r o x y C r e d e n t i a l s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P r o x y S e r v e r N a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P r o x y S e r v e r P o r t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   U s e r C r e d e n t i a l s  -
- t y p e   O S G e o . M a p G u i d e . M g R e s o u r c e D a t a T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F i l e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S t r e a m  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S t r i n g  -
- t y p e   O S G e o . M a p G u i d e . M g R e s o u r c e P e r m i s s i o n   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P e r m i s s i o n N o A c c e s s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P e r m i s s i o n R e a d O n l y  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P e r m i s s i o n R e a d W r i t e  -
- t y p e   O S G e o . M a p G u i d e . M g R e s o u r c e H e a d e r P r o p e r t i e s   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   G e n e r a l  -
-         [ F i e l d ]   I n t 3 2   M e t a d a t a  -
-         [ F i e l d ]   I n t 3 2   S e c u r i t y  -
- t y p e   O S G e o . M a p G u i d e . M g S p a t i a l C o n t e x t E x t e n t T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   s c D y n a m i c  -
-         [ F i e l d ]   I n t 3 2   s c S t a t i c  -
- t y p e   O S G e o . M a p G u i d e . M g C o l o r   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( I n t 1 6 ,   I n t 1 6 ,   I n t 1 6 )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . D r a w i n g . C o l o r )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( I n t 1 6 ,   I n t 1 6 ,   I n t 1 6 ,   I n t 1 6 )  -
-         [ M e t h o d ]   I n t 1 6   g e t _ A l p h a ( )  -
-         [ M e t h o d ]   I n t 1 6   g e t _ B l u e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ C o l o r ( )  -
-         [ M e t h o d ]   I n t 1 6   g e t _ G r e e n ( )  -
-         [ M e t h o d ]   I n t 1 6   g e t _ R e d ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t A l p h a ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t B l u e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t C o l o r ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t G r e e n ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t R e d ( )  -
- t y p e   O S G e o . M a p G u i d e . M g B l o b P r o p e r t y   :   O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g B y t e R e a d e r )  -
-         [ M e t h o d ]   I n t 1 6   g e t _ P r o p e r t y T y p e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   g e t _ V a l u e ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t P r o p e r t y T y p e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t V a l u e ( )  -
-         [ M e t h o d ]   V o i d   s e t _ V a l u e ( O S G e o . M a p G u i d e . M g B y t e R e a d e r )  -
-         [ M e t h o d ]   V o i d   S e t V a l u e ( O S G e o . M a p G u i d e . M g B y t e R e a d e r )  -
- t y p e   O S G e o . M a p G u i d e . M g B o o l e a n P r o p e r t y   :   O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   B o o l e a n )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ V a l u e ( )  -
-         [ M e t h o d ]   B o o l e a n   G e t V a l u e ( )  -
-         [ M e t h o d ]   V o i d   s e t _ V a l u e ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t V a l u e ( B o o l e a n )  -
- t y p e   O S G e o . M a p G u i d e . M g B y t e P r o p e r t y   :   O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   B y t e )  -
-         [ M e t h o d ]   B y t e   g e t _ V a l u e ( )  -
-         [ M e t h o d ]   B y t e   G e t V a l u e ( )  -
-         [ M e t h o d ]   V o i d   s e t _ V a l u e ( B y t e )  -
-         [ M e t h o d ]   V o i d   S e t V a l u e ( B y t e )  -
- t y p e   O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n   :   O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e  -
-         [ M e t h o d ]   V o i d   D e l e t e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n   g e t _ B a s e C l a s s D e f i n i t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ D e f a u l t G e o m e t r y P r o p e r t y N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ N a m e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n   G e t B a s e C l a s s D e f i n i t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D e f a u l t G e o m e t r y P r o p e r t y N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n   G e t I d e n t i t y P r o p e r t i e s ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t N a m e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n   G e t P r o p e r t i e s ( )  -
-         [ M e t h o d ]   B o o l e a n   I s A b s t r a c t ( )  -
-         [ M e t h o d ]   B o o l e a n   I s C o m p u t e d ( )  -
-         [ M e t h o d ]   V o i d   s e t _ D e f a u l t G e o m e t r y P r o p e r t y N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ D e s c r i p t i o n ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t D e f a u l t G e o m e t r y P r o p e r t y N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t D e s c r i p t i o n ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t N a m e ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g C o l l e c t i o n  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t C o u n t ( )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n )  -
-         [ M e t h o d ]   V o i d   R e m o v e A t ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   T o X m l ( )  -
- t y p e   O S G e o . M a p G u i d e . M g C l o b P r o p e r t y   :   O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y  -
- t y p e   O S G e o . M a p G u i d e . M g D a t a P r o p e r t y D e f i n i t i o n   :   O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n  -
-         [ M e t h o d ]   I n t 3 2   g e t _ D a t a T y p e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ D e f a u l t V a l u e ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ L e n g t h ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ N u l l a b l e ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ P r e c i s i o n ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ R e a d O n l y ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ S c a l e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t D a t a T y p e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D e f a u l t V a l u e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t L e n g t h ( )  -
-         [ M e t h o d ]   B o o l e a n   G e t N u l l a b l e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t P r e c i s i o n ( )  -
-         [ M e t h o d ]   B o o l e a n   G e t R e a d O n l y ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t S c a l e ( )  -
-         [ M e t h o d ]   B o o l e a n   I s A u t o G e n e r a t e d ( )  -
-         [ M e t h o d ]   V o i d   s e t _ D a t a T y p e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   s e t _ D e f a u l t V a l u e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ L e n g t h ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   s e t _ N u l l a b l e ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   s e t _ P r e c i s i o n ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   s e t _ R e a d O n l y ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   s e t _ S c a l e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t A u t o G e n e r a t i o n ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t D a t a T y p e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t D e f a u l t V a l u e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t L e n g t h ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t N u l l a b l e ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t P r e c i s i o n ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t R e a d O n l y ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t S c a l e ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g D a t a R e a d e r   :   O S G e o . M a p G u i d e . M g R e a d e r  -
- t y p e   O S G e o . M a p G u i d e . M g D a t e T i m e P r o p e r t y   :   O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g D a t e T i m e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D a t e T i m e   g e t _ V a l u e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D a t e T i m e   G e t V a l u e ( )  -
-         [ M e t h o d ]   V o i d   s e t _ V a l u e ( O S G e o . M a p G u i d e . M g D a t e T i m e )  -
-         [ M e t h o d ]   V o i d   S e t V a l u e ( O S G e o . M a p G u i d e . M g D a t e T i m e )  -
- t y p e   O S G e o . M a p G u i d e . M g D e l e t e F e a t u r e s   :   O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ C o m m a n d T y p e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ F e a t u r e C l a s s N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ F i l t e r T e x t ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t C o m m a n d T y p e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t F e a t u r e C l a s s N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t F i l t e r T e x t ( )  -
- t y p e   O S G e o . M a p G u i d e . M g D o u b l e P r o p e r t y   :   O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   D o u b l e )  -
-         [ M e t h o d ]   D o u b l e   g e t _ V a l u e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t V a l u e ( )  -
-         [ M e t h o d ]   V o i d   s e t _ V a l u e ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t V a l u e ( D o u b l e )  -
- t y p e   O S G e o . M a p G u i d e . M g F e a t u r e A g g r e g a t e O p t i o n s   :   O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s  -
-         [ M e t h o d ]   V o i d   S e l e c t D i s t i n c t ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t G r o u p i n g F i l t e r ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
- t y p e   O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d )  -
- t y p e   O S G e o . M a p G u i d e . M g F e a t u r e P r o p e r t y   :   O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   g e t _ V a l u e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   G e t V a l u e ( )  -
-         [ M e t h o d ]   V o i d   s e t _ V a l u e ( O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r )  -
-         [ M e t h o d ]   V o i d   S e t V a l u e ( O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r )  -
- t y p e   O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ M e t h o d ]   I n t 3 2   A d d C o m p u t e d P r o p e r t y ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 3 2   A d d F e a t u r e P r o p e r t y ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   R e m o v e C o m p u t e d P r o p e r t y ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   R e m o v e F e a t u r e P r o p e r t y ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t B i n a r y O p e r a t o r ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t F e t c h S i z e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t F i l t e r ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t O r d e r i n g F i l t e r ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t S p a t i a l F i l t e r ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g G e o m e t r y ,   I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   :   O S G e o . M a p G u i d e . M g R e a d e r  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n   G e t C l a s s D e f i n i t i o n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   G e t F e a t u r e O b j e c t ( I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   G e t F e a t u r e O b j e c t ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a   :   O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n   G e t C l a s s e s ( )  -
- [ S y s t e m . R e f l e c t i o n . D e f a u l t M e m b e r A t t r i b u t e ]  -
- t y p e   O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g C o l l e c t i o n  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . I E n u m e r a b l e  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ C o u n t ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ I s R e a d O n l y ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a )  -
- t y p e   O S G e o . M a p G u i d e . M g F e a t u r e S e r v i c e   :   O S G e o . M a p G u i d e . M g S e r v i c e  -
-         [ M e t h o d ]   V o i d   A p p l y S c h e m a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g T r a n s a c t i o n   B e g i n T r a n s a c t i o n ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   V o i d   C r e a t e F e a t u r e S o u r c e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   O S G e o . M a p G u i d e . M g F e a t u r e S o u r c e P a r a m s )  -
-         [ M e t h o d ]   I n t 3 2   D e l e t e F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g T r a n s a c t i o n )  -
-         [ M e t h o d ]   I n t 3 2   D e l e t e F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ S y s t e m . O b s o l e t e A t t r i b u t e ]  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n   D e s c r i b e S c h e m a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n   D e s c r i b e S c h e m a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   D e s c r i b e S c h e m a A s X m l ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   D e s c r i b e S c h e m a A s X m l ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   D e s c r i b e W f s F e a t u r e T y p e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   D e s c r i b e W f s F e a t u r e T y p e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   E n u m e r a t e D a t a S t o r e s ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 3 2   E x e c u t e S q l N o n Q u e r y ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 3 2   E x e c u t e S q l N o n Q u e r y ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g P a r a m e t e r C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g T r a n s a c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S q l D a t a R e a d e r   E x e c u t e S q l Q u e r y ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S q l D a t a R e a d e r   E x e c u t e S q l Q u e r y ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g P a r a m e t e r C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g T r a n s a c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t C a p a b i l i t i e s ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t C a p a b i l i t i e s ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n   G e t C l a s s D e f i n i t i o n ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   G e t C l a s s e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   G e t C o n n e c t i o n P r o p e r t y V a l u e s ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t F e a t u r e P r o v i d e r s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   G e t L o c k e d F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L o n g T r a n s a c t i o n R e a d e r   G e t L o n g T r a n s a c t i o n s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   B o o l e a n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t S c h e m a M a p p i n g ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   G e t S c h e m a s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S p a t i a l C o n t e x t R e a d e r   G e t S p a t i a l C o n t e x t s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   B o o l e a n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t W f s F e a t u r e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t W f s F e a t u r e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   G e t W f s R e a d e r ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   I n s e r t F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g T r a n s a c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   I n s e r t F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   I n s e r t F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g T r a n s a c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   I n s e r t F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   S c h e m a T o X m l ( O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D a t a R e a d e r   S e l e c t A g g r e g a t e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g F e a t u r e A g g r e g a t e O p t i o n s )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   S e l e c t F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   S e l e c t F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s )  -
-         [ M e t h o d ]   B o o l e a n   S e t L o n g T r a n s a c t i o n ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   T e s t C o n n e c t i o n ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   T e s t C o n n e c t i o n ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n   U p d a t e F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g T r a n s a c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n   U p d a t e F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n ,   B o o l e a n )  -
-         [ M e t h o d ]   I n t 3 2   U p d a t e M a t c h i n g F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g T r a n s a c t i o n )  -
-         [ M e t h o d ]   I n t 3 2   U p d a t e M a t c h i n g F e a t u r e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n   X m l T o S c h e m a ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g F e a t u r e S o u r c e P a r a m s   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         i m p l e m e n t s   S y s t e m . I D i s p o s a b l e  -
- t y p e   O S G e o . M a p G u i d e . M g F i l e F e a t u r e S o u r c e P a r a m s   :   O S G e o . M a p G u i d e . M g F e a t u r e S o u r c e P a r a m s  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ C o o r d i n a t e S y s t e m W k t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a   g e t _ F e a t u r e S c h e m a ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ F i l e N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ P r o v i d e r N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ S p a t i a l C o n t e x t D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ S p a t i a l C o n t e x t N a m e ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ X Y T o l e r a n c e ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ Z T o l e r a n c e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t C o o r d i n a t e S y s t e m W k t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a   G e t F e a t u r e S c h e m a ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t F i l e N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t P r o v i d e r N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S p a t i a l C o n t e x t D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S p a t i a l C o n t e x t N a m e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t X Y T o l e r a n c e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t Z T o l e r a n c e ( )  -
-         [ M e t h o d ]   V o i d   s e t _ C o o r d i n a t e S y s t e m W k t ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ F e a t u r e S c h e m a ( O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a )  -
-         [ M e t h o d ]   V o i d   s e t _ F i l e N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ P r o v i d e r N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ S p a t i a l C o n t e x t D e s c r i p t i o n ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ S p a t i a l C o n t e x t N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ X Y T o l e r a n c e ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   s e t _ Z T o l e r a n c e ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t C o o r d i n a t e S y s t e m W k t ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t F e a t u r e S c h e m a ( O S G e o . M a p G u i d e . M g F e a t u r e S c h e m a )  -
-         [ M e t h o d ]   V o i d   S e t F i l e N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t P r o v i d e r N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t S p a t i a l C o n t e x t D e s c r i p t i o n ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t S p a t i a l C o n t e x t N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t X Y T o l e r a n c e ( D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t Z T o l e r a n c e ( D o u b l e )  -
- t y p e   O S G e o . M a p G u i d e . M g G e o J s o n W r i t e r   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   F e a t u r e T o G e o J s o n ( O S G e o . M a p G u i d e . M g R e a d e r ,   O S G e o . M a p G u i d e . M g T r a n s f o r m ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   F e a t u r e T o G e o J s o n ( O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r ,   O S G e o . M a p G u i d e . M g T r a n s f o r m )  -
-         [ M e t h o d ]   B o o l e a n   I s P r e c i s i o n E n a b l e d ( )  -
-         [ M e t h o d ]   V o i d   S e t P r e c i s i o n E n a b l e d ( B o o l e a n )  -
- t y p e   O S G e o . M a p G u i d e . M g G e o m e t r i c P r o p e r t y D e f i n i t i o n   :   O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n  -
-         [ M e t h o d ]   I n t 3 2   g e t _ G e o m e t r y T y p e s ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ H a s E l e v a t i o n ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ H a s M e a s u r e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ S p a t i a l C o n t e x t A s s o c i a t i o n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y T y p e I n f o   g e t _ S p e c i f i c G e o m e t r y T y p e s ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t G e o m e t r y T y p e s ( )  -
-         [ M e t h o d ]   B o o l e a n   G e t H a s E l e v a t i o n ( )  -
-         [ M e t h o d ]   B o o l e a n   G e t H a s M e a s u r e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S p a t i a l C o n t e x t A s s o c i a t i o n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g G e o m e t r y T y p e I n f o   G e t S p e c i f i c G e o m e t r y T y p e s ( )  -
-         [ M e t h o d ]   V o i d   s e t _ G e o m e t r y T y p e s ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   s e t _ H a s E l e v a t i o n ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   s e t _ H a s M e a s u r e ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   s e t _ S p a t i a l C o n t e x t A s s o c i a t i o n ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ S p e c i f i c G e o m e t r y T y p e s ( O S G e o . M a p G u i d e . M g G e o m e t r y T y p e I n f o )  -
-         [ M e t h o d ]   V o i d   S e t G e o m e t r y T y p e s ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t H a s E l e v a t i o n ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t H a s M e a s u r e ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t S p a t i a l C o n t e x t A s s o c i a t i o n ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t S p e c i f i c G e o m e t r y T y p e s ( O S G e o . M a p G u i d e . M g G e o m e t r y T y p e I n f o )  -
- t y p e   O S G e o . M a p G u i d e . M g G e o m e t r y P r o p e r t y   :   O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y  -
- t y p e   O S G e o . M a p G u i d e . M g G e o m e t r y T y p e I n f o   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ M e t h o d ]   I n t 3 2   G e t T y p e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t T y p e s ( O S G e o . M a p G u i d e . M g I n t C o l l e c t i o n )  -
- t y p e   O S G e o . M a p G u i d e . M g G w s F e a t u r e R e a d e r   :   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r  -
- t y p e   O S G e o . M a p G u i d e . M g I n s e r t F e a t u r e s   :   O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n   g e t _ P r o p e r t y V a l u e s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n   G e t P r o p e r t y V a l u e s ( )  -
- t y p e   O S G e o . M a p G u i d e . M g I n t 1 6 P r o p e r t y   :   O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   I n t 1 6 )  -
-         [ M e t h o d ]   I n t 1 6   g e t _ V a l u e ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t V a l u e ( )  -
-         [ M e t h o d ]   V o i d   s e t _ V a l u e ( I n t 1 6 )  -
-         [ M e t h o d ]   V o i d   S e t V a l u e ( I n t 1 6 )  -
- t y p e   O S G e o . M a p G u i d e . M g I n t 3 2 P r o p e r t y   :   O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ V a l u e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t V a l u e ( )  -
-         [ M e t h o d ]   V o i d   s e t _ V a l u e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t V a l u e ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g I n t 6 4 P r o p e r t y   :   O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   I n t 6 4 )  -
-         [ M e t h o d ]   I n t 6 4   g e t _ V a l u e ( )  -
-         [ M e t h o d ]   I n t 6 4   G e t V a l u e ( )  -
-         [ M e t h o d ]   V o i d   s e t _ V a l u e ( I n t 6 4 )  -
-         [ M e t h o d ]   V o i d   S e t V a l u e ( I n t 6 4 )  -
- t y p e   O S G e o . M a p G u i d e . M g I n t C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g C o l l e c t i o n  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ S y s t e m . I n t 3 2 ,   m s c o r l i b ,   V e r s i o n = 4 . 0 . 0 . 0 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = b 7 7 a 5 c 5 6 1 9 3 4 e 0 8 9 ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ S y s t e m . I n t 3 2 ,   m s c o r l i b ,   V e r s i o n = 4 . 0 . 0 . 0 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = b 7 7 a 5 c 5 6 1 9 3 4 e 0 8 9 ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ S y s t e m . I n t 3 2 ,   m s c o r l i b ,   V e r s i o n = 4 . 0 . 0 . 0 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = b 7 7 a 5 c 5 6 1 9 3 4 e 0 8 9 ] ]  -
-         [ M e t h o d ]   V o i d   A d d ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   C l e a r ( )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( I n t 3 2 [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ S y s t e m . I n t 3 2 ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g L a y e r B a s e   :   O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g T r a n s a c t i o n   B e g i n T r a n s a c t i o n ( )  -
-         [ M e t h o d ]   I n t 3 2   D e l e t e F e a t u r e s ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g T r a n s a c t i o n )  -
-         [ M e t h o d ]   V o i d   F o r c e R e f r e s h ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ D i s p l a y I n L e g e n d ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ E x p a n d I n L e g e n d ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ F e a t u r e G e o m e t r y N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ F e a t u r e S o u r c e I d ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ F i l t e r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L a y e r G r o u p   g e t _ G r o u p ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r   g e t _ L a y e r D e f i n i t i o n ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ L a y e r T y p e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ L e g e n d L a b e l ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ S e l e c t a b l e ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ V i s i b l e ( )  -
-         [ M e t h o d ]   B o o l e a n   G e t D i s p l a y I n L e g e n d ( )  -
-         [ M e t h o d ]   B o o l e a n   G e t E x p a n d I n L e g e n d ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t F e a t u r e G e o m e t r y N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t F e a t u r e S o u r c e I d ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t F i l t e r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L a y e r G r o u p   G e t G r o u p ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r   G e t L a y e r D e f i n i t i o n ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t L a y e r T y p e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t L e g e n d L a b e l ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t O b j e c t I d ( )  -
-         [ M e t h o d ]   B o o l e a n   G e t S e l e c t a b l e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S p a t i a l C o n t e x t R e a d e r   G e t S p a t i a l C o n t e x t s ( B o o l e a n )  -
-         [ M e t h o d ]   B o o l e a n   G e t V i s i b l e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   I n s e r t F e a t u r e s ( O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g T r a n s a c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   I n s e r t F e a t u r e s ( O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g T r a n s a c t i o n )  -
-         [ M e t h o d ]   B o o l e a n   I s V i s i b l e ( )  -
-         [ M e t h o d ]   B o o l e a n   N e e d s R e f r e s h ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D a t a R e a d e r   S e l e c t A g g r e g a t e ( O S G e o . M a p G u i d e . M g F e a t u r e A g g r e g a t e O p t i o n s )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   S e l e c t F e a t u r e s ( O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   S e l e c t F e a t u r e s ( O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s )  -
-         [ M e t h o d ]   V o i d   s e t _ D i s p l a y I n L e g e n d ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   s e t _ G r o u p ( O S G e o . M a p G u i d e . M g L a y e r G r o u p )  -
-         [ M e t h o d ]   V o i d   s e t _ L e g e n d L a b e l ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ S e l e c t a b l e ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   s e t _ V i s i b l e ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t D i s p l a y I n L e g e n d ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t G r o u p ( O S G e o . M a p G u i d e . M g L a y e r G r o u p )  -
-         [ M e t h o d ]   V o i d   S e t L a y e r D e f i n i t i o n ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e )  -
-         [ M e t h o d ]   V o i d   S e t L e g e n d L a b e l ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t S e l e c t a b l e ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t V i s i b l e ( B o o l e a n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n   U p d a t e F e a t u r e s ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n   U p d a t e F e a t u r e s ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g T r a n s a c t i o n )  -
-         [ M e t h o d ]   I n t 3 2   U p d a t e M a t c h i n g F e a t u r e s ( O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g T r a n s a c t i o n )  -
- t y p e   O S G e o . M a p G u i d e . M g L a y e r C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g L a y e r B a s e ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g L a y e r B a s e ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g L a y e r B a s e ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g L a y e r B a s e )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g L a y e r B a s e )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g L a y e r B a s e [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L a y e r B a s e   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g L a y e r B a s e ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L a y e r B a s e   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L a y e r B a s e   G e t I t e m ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g L a y e r B a s e )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g L a y e r B a s e )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g L a y e r B a s e )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g L a y e r B a s e )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g L a y e r B a s e )  -
- t y p e   O S G e o . M a p G u i d e . M g L a y e r G r o u p   :   O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e  -
-         [ M e t h o d ]   I n t 3 2   g e t _ L a y e r G r o u p T y p e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t L a y e r G r o u p T y p e ( )  -
-         [ M e t h o d ]   V o i d   S e t E x p a n d I n L e g e n d ( B o o l e a n )  -
- t y p e   O S G e o . M a p G u i d e . M g L a y e r G r o u p C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g L a y e r G r o u p ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g L a y e r G r o u p ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g L a y e r G r o u p ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g L a y e r G r o u p )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g L a y e r G r o u p )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g L a y e r G r o u p [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L a y e r G r o u p   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g L a y e r G r o u p ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L a y e r G r o u p   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L a y e r G r o u p   G e t I t e m ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g L a y e r G r o u p )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g L a y e r G r o u p )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g L a y e r G r o u p )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g L a y e r G r o u p )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g L a y e r G r o u p )  -
- t y p e   O S G e o . M a p G u i d e . M g L o n g T r a n s a c t i o n R e a d e r   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ M e t h o d ]   V o i d   C l o s e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L o n g T r a n s a c t i o n R e a d e r   g e t _ C h i l d r e n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D a t e T i m e   g e t _ C r e a t i o n D a t e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ O w n e r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L o n g T r a n s a c t i o n R e a d e r   g e t _ P a r e n t s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L o n g T r a n s a c t i o n R e a d e r   G e t C h i l d r e n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D a t e T i m e   G e t C r e a t i o n D a t e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t O w n e r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L o n g T r a n s a c t i o n R e a d e r   G e t P a r e n t s ( )  -
-         [ M e t h o d ]   B o o l e a n   I s A c t i v e ( )  -
-         [ M e t h o d ]   B o o l e a n   I s F r o z e n ( )  -
-         [ M e t h o d ]   B o o l e a n   R e a d N e x t ( )  -
- t y p e   O S G e o . M a p G u i d e . M g M a p B a s e   :   O S G e o . M a p G u i d e . M g R e s o u r c e  -
-         [ M e t h o d ]   V o i d   C r e a t e ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e ,   O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   C r e a t e ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g E n v e l o p e ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g E n v e l o p e   g e t _ D a t a E x t e n t ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ D i s p l a y D p i ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ D i s p l a y H e i g h t ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ D i s p l a y W i d t h ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ F i n i t e D i s p l a y S c a l e C o u n t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r   g e t _ M a p D e f i n i t i o n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g E n v e l o p e   g e t _ M a p E x t e n t ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ M a p S R S ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ S e s s i o n I d ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o i n t   g e t _ V i e w C e n t e r ( )  -
-         [ M e t h o d ]   D o u b l e   g e t _ V i e w S c a l e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t B a c k g r o u n d C o l o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g E n v e l o p e   G e t D a t a E x t e n t ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t D i s p l a y D p i ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t D i s p l a y H e i g h t ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t D i s p l a y W i d t h ( )  -
-         [ M e t h o d ]   D o u b l e   G e t F i n i t e D i s p l a y S c a l e A t ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t F i n i t e D i s p l a y S c a l e C o u n t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L a y e r G r o u p C o l l e c t i o n   G e t L a y e r G r o u p s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L a y e r C o l l e c t i o n   G e t L a y e r s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r   G e t M a p D e f i n i t i o n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g E n v e l o p e   G e t M a p E x t e n t ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t M a p S R S ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S e s s i o n I d ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o i n t   G e t V i e w C e n t e r ( )  -
-         [ M e t h o d ]   D o u b l e   G e t V i e w S c a l e ( )  -
-         [ M e t h o d ]   V o i d   O p e n ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ D i s p l a y D p i ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t D i s p l a y D p i ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g M a p C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g M a p B a s e ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g M a p B a s e ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g M a p B a s e ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g M a p B a s e )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g M a p B a s e )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g M a p B a s e [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g M a p B a s e   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g M a p B a s e ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g M a p B a s e   G e t I t e m ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g M a p B a s e   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g M a p B a s e )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g M a p B a s e )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g M a p B a s e )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g M a p B a s e )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g M a p B a s e )  -
- t y p e   O S G e o . M a p G u i d e . M g O b j e c t P r o p e r t y D e f i n i t i o n   :   O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n   g e t _ C l a s s D e f i n i t i o n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D a t a P r o p e r t y D e f i n i t i o n   g e t _ I d e n t i t y P r o p e r t y ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ O b j e c t T y p e ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ O r d e r T y p e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D a t a P r o p e r t y D e f i n i t i o n   G e t I d e n t i t y P r o p e r t y ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t O b j e c t T y p e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t O r d e r T y p e ( )  -
-         [ M e t h o d ]   V o i d   s e t _ C l a s s D e f i n i t i o n ( O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n )  -
-         [ M e t h o d ]   V o i d   s e t _ I d e n t i t y P r o p e r t y ( O S G e o . M a p G u i d e . M g D a t a P r o p e r t y D e f i n i t i o n )  -
-         [ M e t h o d ]   V o i d   s e t _ O b j e c t T y p e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   s e t _ O r d e r T y p e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t C l a s s D e f i n i t i o n ( O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n )  -
-         [ M e t h o d ]   V o i d   S e t I d e n t i t y P r o p e r t y ( O S G e o . M a p G u i d e . M g D a t a P r o p e r t y D e f i n i t i o n )  -
-         [ M e t h o d ]   V o i d   S e t O b j e c t T y p e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t O r d e r T y p e ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g P a r a m e t e r   :   O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y ,   I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t D i r e c t i o n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y   G e t P r o p e r t y ( )  -
-         [ M e t h o d ]   V o i d   S e t D i r e c t i o n ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t P r o p e r t y ( O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y )  -
- t y p e   O S G e o . M a p G u i d e . M g P a r a m e t e r C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g C o l l e c t i o n  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g P a r a m e t e r )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g P a r a m e t e r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P a r a m e t e r   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g P a r a m e t e r )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g P a r a m e t e r )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g P a r a m e t e r )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g P a r a m e t e r )  -
- t y p e   O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g C o l l e c t i o n  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n ,   O S G e o . M a p G u i d e . F o u n d a t i o n ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n ,   O S G e o . M a p G u i d e . F o u n d a t i o n ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n ,   O S G e o . M a p G u i d e . F o u n d a t i o n ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n   G e t I t e m ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n )  -
- t y p e   O S G e o . M a p G u i d e . M g R a s t e r   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ M e t h o d ]   I n t 3 2   g e t _ B i t s P e r P i x e l ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g E n v e l o p e   g e t _ B o u n d s ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ D a t a M o d e l T y p e ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ I m a g e X S i z e ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ I m a g e Y S i z e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t B i t s P e r P i x e l ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g E n v e l o p e   G e t B o u n d s ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t C u r r e n t B a n d ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t D a t a M o d e l T y p e ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t D a t a T y p e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t I m a g e X S i z e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t I m a g e Y S i z e ( )  -
-         [ M e t h o d ]   I n t 6 4   G e t N u l l V a l u e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t N u l l V a l u e T y p e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t N u m b e r O f B a n d s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t S t r e a m ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t V e r t i c a l U n i t s ( )  -
-         [ M e t h o d ]   B o o l e a n   I s N u l l ( )  -
-         [ M e t h o d ]   V o i d   s e t _ I m a g e X S i z e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   s e t _ I m a g e Y S i z e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t I m a g e X S i z e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t I m a g e Y S i z e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t N u l l ( )  -
- t y p e   O S G e o . M a p G u i d e . M g R a s t e r P r o p e r t y   :   O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g R a s t e r )  -
-         [ M e t h o d ]   I n t 1 6   g e t _ P r o p e r t y T y p e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g R a s t e r   g e t _ V a l u e ( )  -
-         [ M e t h o d ]   I n t 1 6   G e t P r o p e r t y T y p e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g R a s t e r   G e t V a l u e ( )  -
-         [ M e t h o d ]   V o i d   s e t _ V a l u e ( O S G e o . M a p G u i d e . M g R a s t e r )  -
-         [ M e t h o d ]   V o i d   S e t V a l u e ( O S G e o . M a p G u i d e . M g R a s t e r )  -
- t y p e   O S G e o . M a p G u i d e . M g R a s t e r P r o p e r t y D e f i n i t i o n   :   O S G e o . M a p G u i d e . M g P r o p e r t y D e f i n i t i o n  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ D e f a u l t I m a g e X S i z e ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ D e f a u l t I m a g e Y S i z e ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ N u l l a b l e ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ R e a d O n l y ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t D e f a u l t I m a g e X S i z e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t D e f a u l t I m a g e Y S i z e ( )  -
-         [ M e t h o d ]   B o o l e a n   G e t N u l l a b l e ( )  -
-         [ M e t h o d ]   B o o l e a n   G e t R e a d O n l y ( )  -
-         [ M e t h o d ]   V o i d   s e t _ D e f a u l t I m a g e X S i z e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   s e t _ D e f a u l t I m a g e Y S i z e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   s e t _ N u l l a b l e ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   s e t _ R e a d O n l y ( B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t D e f a u l t I m a g e X S i z e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t D e f a u l t I m a g e Y S i z e ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g R e a d e r   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t B L O B ( I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t B L O B ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   G e t B o o l e a n ( I n t 3 2 )  -
-         [ M e t h o d ]   B o o l e a n   G e t B o o l e a n ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B y t e   G e t B y t e ( I n t 3 2 )  -
-         [ M e t h o d ]   B y t e   G e t B y t e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t C L O B ( I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t C L O B ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D a t e T i m e   G e t D a t e T i m e ( I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D a t e T i m e   G e t D a t e T i m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   D o u b l e   G e t D o u b l e ( I n t 3 2 )  -
-         [ M e t h o d ]   D o u b l e   G e t D o u b l e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t G e o m e t r y ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t G e o m e t r y ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 1 6   G e t I n t 1 6 ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 1 6   G e t I n t 1 6 ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t I n t 3 2 ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t I n t 3 2 ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 6 4   G e t I n t 6 4 ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 6 4   G e t I n t 6 4 ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 3 2   G e t P r o p e r t y C o u n t ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t P r o p e r t y I n d e x ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t P r o p e r t y N a m e ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t P r o p e r t y T y p e ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t P r o p e r t y T y p e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g R a s t e r   G e t R a s t e r ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g R a s t e r   G e t R a s t e r ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t R e a d e r T y p e ( )  -
-         [ M e t h o d ]   S i n g l e   G e t S i n g l e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S i n g l e   G e t S i n g l e ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S t r i n g ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S t r i n g ( I n t 3 2 )  -
-         [ M e t h o d ]   B o o l e a n   I s N u l l ( I n t 3 2 )  -
-         [ M e t h o d ]   B o o l e a n   I s N u l l ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   T o X m l ( )  -
- t y p e   O S G e o . M a p G u i d e . M g R e a d O n l y L a y e r C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I R e a d O n l y L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g L a y e r B a s e ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I R e a d O n l y C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g L a y e r B a s e ,   O S G e o . M a p G u i d e . P l a t f o r m B a s e ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         [ M e t h o d ]   I n t 3 2   G e t C o u n t ( )  -
- t y p e   O S G e o . M a p G u i d e . M g R e s o u r c e   :   O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r   G e t R e s o u r c e I d ( )  -
-         [ M e t h o d ]   V o i d   O p e n ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e ,   O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   V o i d   S a v e ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e ,   O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   V o i d   S a v e ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e )  -
- t y p e   O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ P a t h ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ R e p o s i t o r y N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ R e p o s i t o r y T y p e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ R e s o u r c e T y p e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t P a t h ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t R e p o s i t o r y N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t R e p o s i t o r y T y p e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t R e s o u r c e T y p e ( )  -
-         [ M e t h o d ]   V o i d   s e t _ N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ P a t h ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ R e p o s i t o r y N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ R e p o s i t o r y T y p e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   s e t _ R e s o u r c e T y p e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t P a t h ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t R e p o s i t o r y N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t R e p o s i t o r y T y p e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t R e s o u r c e T y p e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   T o S t r i n g ( )  -
-         [ M e t h o d ]   V o i d   V a l i d a t e ( )  -
- t y p e   O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e   :   O S G e o . M a p G u i d e . M g S e r v i c e  -
-         [ M e t h o d ]   V o i d   A p p l y R e s o u r c e P a c k a g e ( O S G e o . M a p G u i d e . M g B y t e R e a d e r )  -
-         [ M e t h o d ]   V o i d   C h a n g e R e s o u r c e O w n e r ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   B o o l e a n )  -
-         [ M e t h o d ]   V o i d   C o p y R e s o u r c e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   B o o l e a n )  -
-         [ M e t h o d ]   V o i d   D e l e t e R e s o u r c e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   V o i d   D e l e t e R e s o u r c e D a t a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   E n u m e r a t e R e f e r e n c e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   E n u m e r a t e R e s o u r c e D a t a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   E n u m e r a t e R e s o u r c e D o c u m e n t s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   S y s t e m . S t r i n g ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   E n u m e r a t e R e s o u r c e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   I n t 3 2 ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   E n u m e r a t e R e s o u r c e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   I n t 3 2 ,   S y s t e m . S t r i n g ,   B o o l e a n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   E n u m e r a t e U n m a n a g e d D a t a ( S y s t e m . S t r i n g ,   B o o l e a n ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t R e p o s i t o r y C o n t e n t ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t R e p o s i t o r y H e a d e r ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t R e s o u r c e C o n t e n t ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   G e t R e s o u r c e C o n t e n t s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t R e s o u r c e D a t a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t R e s o u r c e H e a d e r ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t R e s o u r c e M e t a d a t a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D a t e T i m e   G e t R e s o u r c e M o d i f i e d D a t e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   V o i d   I n h e r i t P e r m i s s i o n s F r o m ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   V o i d   M o v e R e s o u r c e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   B o o l e a n ,   B o o l e a n )  -
-         [ M e t h o d ]   V o i d   M o v e R e s o u r c e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   B o o l e a n )  -
-         [ M e t h o d ]   V o i d   R e n a m e R e s o u r c e D a t a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   B o o l e a n )  -
-         [ M e t h o d ]   B o o l e a n   R e s o u r c e E x i s t s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   V o i d   S e t R e s o u r c e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   O S G e o . M a p G u i d e . M g B y t e R e a d e r ,   O S G e o . M a p G u i d e . M g B y t e R e a d e r )  -
-         [ M e t h o d ]   V o i d   S e t R e s o u r c e D a t a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g B y t e R e a d e r )  -
-         [ M e t h o d ]   V o i d   S e t R e s o u r c e M e t a d a t a ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   O S G e o . M a p G u i d e . M g B y t e R e a d e r )  -
-         [ M e t h o d ]   V o i d   U p d a t e R e p o s i t o r y ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   O S G e o . M a p G u i d e . M g B y t e R e a d e r ,   O S G e o . M a p G u i d e . M g B y t e R e a d e r )  -
- t y p e   O S G e o . M a p G u i d e . M g S e l e c t i o n B a s e   :   O S G e o . M a p G u i d e . M g R e s o u r c e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g M a p B a s e )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g M a p B a s e ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   A d d ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   A d d F e a t u r e I d D o u b l e ( O S G e o . M a p G u i d e . M g L a y e r B a s e ,   S y s t e m . S t r i n g ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   A d d F e a t u r e I d I n t 1 6 ( O S G e o . M a p G u i d e . M g L a y e r B a s e ,   S y s t e m . S t r i n g ,   I n t 1 6 )  -
-         [ M e t h o d ]   V o i d   A d d F e a t u r e I d I n t 3 2 ( O S G e o . M a p G u i d e . M g L a y e r B a s e ,   S y s t e m . S t r i n g ,   I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   A d d F e a t u r e I d I n t 6 4 ( O S G e o . M a p G u i d e . M g L a y e r B a s e ,   S y s t e m . S t r i n g ,   I n t 6 4 )  -
-         [ M e t h o d ]   V o i d   A d d F e a t u r e I d s ( O S G e o . M a p G u i d e . M g L a y e r B a s e ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n )  -
-         [ M e t h o d ]   V o i d   A d d F e a t u r e I d S t r i n g ( O S G e o . M a p G u i d e . M g L a y e r B a s e ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   A d d F e a t u r e s ( O S G e o . M a p G u i d e . M g L a y e r B a s e ,   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r ,   I n t 3 2 )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g L a y e r B a s e ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   F r o m X m l ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e n e r a t e F i l t e r ( O S G e o . M a p G u i d e . M g L a y e r B a s e ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   G e n e r a t e F i l t e r s ( O S G e o . M a p G u i d e . M g L a y e r B a s e ,   S y s t e m . S t r i n g ,   I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t C l a s s ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   G e t C l a s s e s ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g E n v e l o p e   G e t E x t e n t s ( O S G e o . M a p G u i d e . M g F e a t u r e S e r v i c e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g R e a d O n l y L a y e r C o l l e c t i o n   G e t L a y e r s ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t R e s o u r c e N a m e ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   G e t S e l e c t e d F e a t u r e s ( O S G e o . M a p G u i d e . M g L a y e r B a s e ,   S y s t e m . S t r i n g ,   B o o l e a n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   G e t S e l e c t e d F e a t u r e s ( O S G e o . M a p G u i d e . M g L a y e r B a s e ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n )  -
-         [ M e t h o d ]   I n t 3 2   G e t S e l e c t e d F e a t u r e s C o u n t ( O S G e o . M a p G u i d e . M g L a y e r B a s e ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S a v e ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t M a p ( O S G e o . M a p G u i d e . M g M a p B a s e )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   T o X m l ( )  -
- t y p e   O S G e o . M a p G u i d e . M g S e r v i c e   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W a r n i n g s   G e t W a r n i n g s O b j e c t ( )  -
-         [ M e t h o d ]   B o o l e a n   H a s W a r n i n g s ( )  -
- t y p e   O S G e o . M a p G u i d e . M g S i n g l e P r o p e r t y   :   O S G e o . M a p G u i d e . M g N u l l a b l e P r o p e r t y  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   S i n g l e )  -
-         [ M e t h o d ]   S i n g l e   g e t _ V a l u e ( )  -
-         [ M e t h o d ]   S i n g l e   G e t V a l u e ( )  -
-         [ M e t h o d ]   V o i d   s e t _ V a l u e ( S i n g l e )  -
-         [ M e t h o d ]   V o i d   S e t V a l u e ( S i n g l e )  -
- t y p e   O S G e o . M a p G u i d e . M g S p a t i a l C o n t e x t R e a d e r   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ C o o r d i n a t e S y s t e m ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   g e t _ E x t e n t ( )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ E x t e n t T y p e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t C o o r d i n a t e S y s t e m ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t E x t e n t ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t E x t e n t T y p e ( )  -
-         [ S y s t e m . O b s o l e t e A t t r i b u t e ]  -
-         [ M e t h o d ]   V o i d   R e s e t ( )  -
- t y p e   O S G e o . M a p G u i d e . M g S q l D a t a R e a d e r   :   O S G e o . M a p G u i d e . M g R e a d e r  -
- [ S y s t e m . R e f l e c t i o n . D e f a u l t M e m b e r A t t r i b u t e ]  -
- t y p e   O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g C o l l e c t i o n  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y ,   O S G e o . M a p G u i d e . F o u n d a t i o n ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y ,   O S G e o . M a p G u i d e . F o u n d a t i o n ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y ,   O S G e o . M a p G u i d e . F o u n d a t i o n ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . I E n u m e r a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( )  -
-         [ M e t h o d ]   V o i d   A d d ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ C o u n t ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ I s R e a d O n l y ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t N a m e ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t V a l u e ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t V a l u e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y )  -
-         [ M e t h o d ]   V o i d   R e m o v e A t ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g S t r i n g P r o p e r t y )  -
-         [ M e t h o d ]   V o i d   S e t V a l u e ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g T r a n s a c t i o n   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   A d d S a v e P o i n t ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   C o m m i t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r   G e t F e a t u r e S o u r c e ( )  -
-         [ M e t h o d ]   V o i d   R e l e a s e S a v e P o i n t ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   R o l l b a c k ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   R o l l b a c k ( )  -
- t y p e   O S G e o . M a p G u i d e . M g U p d a t e F e a t u r e s   :   O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ C o m m a n d T y p e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ F e a t u r e C l a s s N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   g e t _ F i l t e r T e x t ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t C o m m a n d T y p e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t F e a t u r e C l a s s N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t F i l t e r T e x t ( )  -
- t y p e   O S G e o . M a p G u i d e . M g W a r n i n g s   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         i m p l e m e n t s   S y s t e m . I D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   G e t M e s s a g e s ( )  -
- A s s e m b l y :   O S G e o . M a p G u i d e . M a p G u i d e C o m m o n ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l  -
- t y p e   O S G e o . M a p G u i d e . M g I m a g e F o r m a t s   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G i f  -
-         [ F i e l d ]   S y s t e m . S t r i n g   J p e g  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M e t a  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P n g  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P n g 8  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R a w  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T i f f  -
- t y p e   O S G e o . M a p G u i d e . M g P a g e U n i t s T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   I n c h e s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M i l l i m e t e r s  -
- t y p e   O S G e o . M a p G u i d e . M g C o o r d i n a t e S p a c e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D i s p l a y  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M a p  -
-         [ F i e l d ]   S y s t e m . S t r i n g   N o n e  -
- t y p e   O S G e o . M a p G u i d e . M g M a p P l o t I n s t r u c t i o n   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   U s e M a p C e n t e r A n d S c a l e  -
-         [ F i e l d ]   I n t 3 2   U s e O v e r r i d d e n C e n t e r A n d S c a l e  -
-         [ F i e l d ]   I n t 3 2   U s e O v e r r i d d e n E x t e n t  -
- t y p e   O S G e o . M a p G u i d e . M g L o g F i l e T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A c c e s s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A d m i n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A u t h e n t i c a t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   E r r o r  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S e s s i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T r a c e  -
- t y p e   O S G e o . M a p G u i d e . M g S e r v e r I n f o r m a t i o n P r o p e r t i e s   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A d m i n O p e r a t i o n s Q u e u e C o u n t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A p i V e r s i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A v a i l a b l e P h y s i c a l M e m o r y  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A v a i l a b l e V i r t u a l M e m o r y  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A v e r a g e O p e r a t i o n T i m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   C a c h e D r o p p e d E n t r i e s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   C a c h e S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   C l i e n t O p e r a t i o n s Q u e u e C o u n t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   C p u U t i l i z a t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D i s p l a y N a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M a c h i n e I p  -
-         [ F i e l d ]   S y s t e m . S t r i n g   O p e r a t i n g S y s t e m V e r s i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S e r v e r V e r s i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S i t e O p e r a t i o n s Q u e u e C o u n t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S t a t u s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T o t a l A c t i v e C o n n e c t i o n s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T o t a l C o n n e c t i o n s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T o t a l O p e r a t i o n T i m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T o t a l P h y s i c a l M e m o r y  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T o t a l P r o c e s s e d O p e r a t i o n s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T o t a l R e c e i v e d O p e r a t i o n s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T o t a l V i r t u a l M e m o r y  -
-         [ F i e l d ]   S y s t e m . S t r i n g   U p t i m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   V i r t u a l M e m o r y  -
-         [ F i e l d ]   S y s t e m . S t r i n g   W o r k i n g S e t  -
- t y p e   O S G e o . M a p G u i d e . M g U n i t T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M e t r i c  -
-         [ F i e l d ]   S y s t e m . S t r i n g   U S E n g l i s h  -
- t y p e   O S G e o . M a p G u i d e . M g C o n f i g P r o p e r t i e s   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A c c e s s L o g P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A c c e s s L o g P r o p e r t y E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A c c e s s L o g P r o p e r t y F i l e n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A c c e s s L o g P r o p e r t y P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y E m a i l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y P o r t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y Q u e u e S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A d m i n L o g P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A d m i n L o g P r o p e r t y E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A d m i n L o g P r o p e r t y F i l e n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A d m i n L o g P r o p e r t y P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A g e n t A n o n y m o u s D e n y G e t R e s o u r c e C o n t e n t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A g e n t A n o n y m o u s D e n y G e t R e s o u r c e D a t a  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A g e n t A n o n y m o u s D e n y G e t R e s o u r c e H e a d e r  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A g e n t D e b u g P a u s e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A g e n t D i s a b l e A u t h o r i n g  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A g e n t D i s a b l e W f s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A g e n t D i s a b l e W m s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A g e n t E r r o r L o g E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A g e n t E r r o r L o g F i l e n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A g e n t G l o b a l G e t W f s F e a t u r e s L i m i t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A g e n t G l o b a l G e t W m s F e a t u r e I n f o L i m i t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A g e n t G l o b a l M a x F e a t u r e Q u e r y L i m i t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A g e n t G l o b a l M a x M a p F e a t u r e Q u e r y L i m i t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A g e n t P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A g e n t R e q u e s t L o g E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A g e n t R e q u e s t L o g F i l e n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A u t h e n t i c a t i o n L o g P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A u t h e n t i c a t i o n L o g P r o p e r t y E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A u t h e n t i c a t i o n L o g P r o p e r t y F i l e n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   A u t h e n t i c a t i o n L o g P r o p e r t y P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   C I T E W f s E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   C I T E W m s E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   C l i e n t C o n n e c t i o n P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   C l i e n t C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   C l i e n t C o n n e c t i o n P r o p e r t y P o r t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   C l i e n t C o n n e c t i o n P r o p e r t y Q u e u e S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   C l i e n t C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   C o n t a i n e r I n f o F o l d e r  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D B E n v i r o n m e n t P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D B M a x L o c k e r s P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D B M a x T r a n s a c t i o n s P a r a m t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D B P a g e S i z e P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D B T i m e o u t P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D B X M L P a g e S i z e P a r a m e t e r s  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t A c c e s s L o g P r o p e r t y E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t A c c e s s L o g P r o p e r t y F i l e n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t A c c e s s L o g P r o p e r t y P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y E m a i l  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y P o r t  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y Q u e u e S i z e  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t A d m i n L o g P r o p e r t y E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t A d m i n L o g P r o p e r t y F i l e n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t A d m i n L o g P r o p e r t y P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t A g e n t A n o n y m o u s D e n y G e t R e s o u r c e C o n t e n t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t A g e n t A n o n y m o u s D e n y G e t R e s o u r c e D a t a  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t A g e n t A n o n y m o u s D e n y G e t R e s o u r c e H e a d e r  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t A g e n t D e b u g P a u s e  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t A g e n t E r r o r L o g E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t A g e n t E r r o r L o g F i l e n a m e  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t A g e n t G l o b a l G e t W f s F e a t u r e s L i m i t  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t A g e n t G l o b a l G e t W m s F e a t u r e I n f o L i m i t  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t A g e n t G l o b a l M a x F e a t u r e Q u e r y L i m i t  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t A g e n t G l o b a l M a x M a p F e a t u r e Q u e r y L i m i t  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t A g e n t R e q u e s t L o g E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t A g e n t R e q u e s t L o g F i l e n a m e  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t A u t h e n t i c a t i o n L o g P r o p e r t y E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t A u t h e n t i c a t i o n L o g P r o p e r t y F i l e n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t A u t h e n t i c a t i o n L o g P r o p e r t y P a r a m e t e r s  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t C I T E W f s E n a b l e d  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t C I T E W m s E n a b l e d  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t C l i e n t C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t C l i e n t C o n n e c t i o n P r o p e r t y P o r t  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t C l i e n t C o n n e c t i o n P r o p e r t y Q u e u e S i z e  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t C l i e n t C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t C o n f i g u r a t i o n F i l e n a m e  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t D B M a x L o c k e r s P a r a m e t e r s  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t D B M a x T r a n s a c t i o n s P a r a m t e r s  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t D B P a g e S i z e P a r a m e t e r s  -
-         [ F i e l d ]   D o u b l e   D e f a u l t D B T i m e o u t P a r a m e t e r s  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t D B X M L P a g e S i z e P a r a m e t e r s  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t E r r o r L o g P r o p e r t y E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t E r r o r L o g P r o p e r t y F i l e n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t E r r o r L o g P r o p e r t y P a r a m e t e r s  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y C a c h e S i z e  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y C a c h e T i m e L i m i t  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y C a c h e T i m e r I n t e r v a l  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C a c h e S i z e  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l E x c l u d e d P r o v i d e r s  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l S i z e C u s t o m  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n T i m e o u t  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n T i m e r I n t e r v a l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n U s e L i m i t  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a T r a n s a c t i o n T i m e o u t  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a T r a n s a c t i o n T i m e r I n t e r v a l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y F D O C o n n e c t i o n T i m e o u t C u s t o m  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y J o i n Q u e r y B a t c h S i z e  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y U s e F d o J o i n O p t i m i z a t i o n  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t G e n e r a l P r o p e r t y C o n n e c t i o n T i m e o u t  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t G e n e r a l P r o p e r t y C o n n e c t i o n T i m e r I n t e r v a l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y D e f a u l t M e s s a g e L o c a l e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y D i s p l a y N a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y F d o P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y L i c e n s e S e r v e r P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y L i n u x F o n t D i r e c t o r i e s  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t G e n e r a l P r o p e r t y L i n u x M e m D e b u g  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y L o c a l e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y L o g s D e l i m i t e r  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y L o g s D e t a i l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y L o g s P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y M a c h i n e I p  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t G e n e r a l P r o p e r t y M a x L o g F i l e S i z e  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t G e n e r a l P r o p e r t y M a x L o g F i l e S i z e E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y M e n t o r D i c t i o n a r y P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y M e n t o r U s e r D i c t i o n a r y P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y P r e C a c h e M a p s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y R e s o u r c e s P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y S e r i a l N u m b e r  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t G e n e r a l P r o p e r t y S e r v i c e R e g i s t r a t i o n T i m e r I n t e r v a l  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t G e n e r a l P r o p e r t y T c p I p M t u  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y T e m p P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y W f s D o c u m e n t P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y W m s D o c u m e n t P a t h  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t H o s t P r o p e r t y D r a w i n g S e r v i c e  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t H o s t P r o p e r t y F e a t u r e S e r v i c e  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t H o s t P r o p e r t y K m l S e r v i c e  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t H o s t P r o p e r t y M a p p i n g S e r v i c e  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t H o s t P r o p e r t y P r o f i l i n g S e r v i c e  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t H o s t P r o p e r t y R e n d e r i n g S e r v i c e  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t H o s t P r o p e r t y R e s o u r c e S e r v i c e  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t H o s t P r o p e r t y S i t e S e r v i c e  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t H o s t P r o p e r t y T i l e S e r v i c e  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t L i b r a r y C a c h e S i z e P a r a m e t e r s  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t L i b r a r y L o g B u f f e r S i z e P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t M a p p i n g S e r v i c e P r o p e r t y L e g e n d F o n t  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t P e r f o r m a n c e L o g P r o p e r t y E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t P e r f o r m a n c e L o g P r o p e r t y F i l e n a m e  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t P e r f o r m a n c e L o g P r o p e r t y I n t e r v a l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t P e r f o r m a n c e L o g P r o p e r t y P a r a m e t e r s  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t i e s G l o b a l R a s t e r S t y l i z a t i o n L o c k E n a b l e d  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y C l a m p P o i n t s  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y G e n e r a l i z e D a t a  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M a x R a s t e r I m a g e H e i g h t  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M a x R a s t e r I m a g e W i d t h  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M a x R e n d e r I m a g e H e i g h t  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M a x R e n d e r I m a g e W i d t h  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M i n R a s t e r G r i d S i z e  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M i n R a s t e r G r i d S i z e F o r P l o t  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e F o r P l o t  -
-         [ F i e l d ]   D o u b l e   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e O v e r r i d e R a t i o  -
-         [ F i e l d ]   D o u b l e   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e O v e r r i d e R a t i o F o r P l o t  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R e n d e r S e l e c t i o n B a t c h S i z e  -
-         [ F i e l d ]   D o u b l e   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y T i l e E x t e n t O f f s e t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y L i b r a r y R e p o s i t o r y P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y L i b r a r y R e s o u r c e D a t a F i l e P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y P a c k a g e s P a t h  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e p o s i t o r y C h e c k p o i n t s T i m e r I n t e r v a l  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e C h a n g e T i m e r I n t e r v a l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e D a t a F i l e T r a s h F o l d e r N a m e  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e P e r m i s s i o n C a c h e S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e S c h e m a F i l e P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y S e s s i o n R e p o s i t o r y P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y S e s s i o n R e s o u r c e D a t a F i l e P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y S i t e R e p o s i t o r y P a t h  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t S e s s i o n C a c h e S i z e P a r a m t e r s  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t S e s s i o n D B P a g e S i z e P a r a m e t e r s  -
-         [ F i e l d ]   D o u b l e   D e f a u l t S e s s i o n D B X M L P a g e S i z e P a r a m e t e r s  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t S e s s i o n L o g B u f f e r S i z e P a r a m e t e r s  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t S e s s i o n L o g P r o p e r t y E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t S e s s i o n L o g P r o p e r t y F i l e n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t S e s s i o n L o g P r o p e r t y P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t S i t e C o n n e c t i o n P r o p e r t y I p A d d r e s s  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t S i t e C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t S i t e C o n n e c t i o n P r o p e r t y P o r t  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t S i t e C o n n e c t i o n P r o p e r t y Q u e u e S i z e  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t S i t e C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t S i t e S e r v i c e P r o p e r t y S e s s i o n T i m e o u t  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t S i t e S e r v i c e P r o p e r t y S e s s i o n T i m e r I n t e r v a l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t T i l e S e r v i c e P r o p e r t y I m a g e F o r m a t  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t T i l e S e r v i c e P r o p e r t y R e n d e r O n l y  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e C a c h e P a t h  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e C o l u m n s P e r F o l d e r  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e R o w s P e r F o l d e r  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e S i z e X  -
-         [ F i e l d ]   I n t 3 2   D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e S i z e Y  -
-         [ F i e l d ]   B o o l e a n   D e f a u l t T r a c e L o g P r o p e r t y E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t T r a c e L o g P r o p e r t y F i l e n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D e f a u l t T r a c e L o g P r o p e r t y P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   D r a w i n g S e r v i c e P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   E r r o r L o g P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   E r r o r L o g P r o p e r t y E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   E r r o r L o g P r o p e r t y F i l e n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   E r r o r L o g P r o p e r t y P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S e r v i c e P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y C a c h e S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y C a c h e T i m e L i m i t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y C a c h e T i m e r I n t e r v a l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a C a c h e S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l E x c l u d e d P r o v i d e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l S i z e C u s t o m  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n T i m e o u t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n T i m e r I n t e r v a l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n U s e L i m i t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a T r a n s a c t i o n T i m e o u t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a T r a n s a c t i o n T i m e r I n t e r v a l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y F D O C o n n e c t i o n T i m e o u t C u s t o m  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y J o i n Q u e r y B a t c h S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y U s e F d o J o i n O p t i m i z a t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   F o n t A l i a s M a p p i n g S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y C o n n e c t i o n T i m e o u t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y C o n n e c t i o n T i m e r I n t e r v a l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y D e f a u l t M e s s a g e L o c a l e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y D i s p l a y N a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y F d o P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y L i c e n s e S e r v e r P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y L i n u x F o n t D i r e c t o r i e s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y L i n u x M e m D e b u g  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y L o c a l e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y L o g s D e l i m i t e r  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y L o g s D e t a i l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y L o g s P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y M a c h i n e I p  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y M a x L o g F i l e S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y M a x L o g F i l e S i z e E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y M e n t o r D i c t i o n a r y P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y M e n t o r U s e r D i c t i o n a r y P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y P r e C a c h e M a p s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y R e s o u r c e s P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y S e r i a l N u m b e r  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y S e r v i c e R e g i s t r a t i o n T i m e r I n t e r v a l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y T c p I p M t u  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y T e m p P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y W f s D o c u m e n t P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   G e n e r a l P r o p e r t y W m s D o c u m e n t P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   H o s t P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   H o s t P r o p e r t y D r a w i n g S e r v i c e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   H o s t P r o p e r t y F e a t u r e S e r v i c e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   H o s t P r o p e r t y K m l S e r v i c e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   H o s t P r o p e r t y M a p p i n g S e r v i c e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   H o s t P r o p e r t y P r o f i l i n g S e r v i c e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   H o s t P r o p e r t y R e n d e r i n g S e r v i c e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   H o s t P r o p e r t y R e s o u r c e S e r v i c e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   H o s t P r o p e r t y S i t e S e r v i c e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   H o s t P r o p e r t y T i l e S e r v i c e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   L i b r a r y C a c h e S i z e P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   L i b r a r y L o g B u f f e r S i z e P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M a p p i n g S e r v i c e P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   M a p p i n g S e r v i c e P r o p e r t y L e g e n d F o n t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   O g c P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P e r f o r m a n c e L o g P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P e r f o r m a n c e L o g P r o p e r t y E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P e r f o r m a n c e L o g P r o p e r t y F i l e n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P e r f o r m a n c e L o g P r o p e r t y I n t e r v a l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   P e r f o r m a n c e L o g P r o p e r t y P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t i e s G l o b a l R a s t e r S t y l i z a t i o n L o c k E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y C l a m p P o i n t s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y G e n e r a l i z e D a t a  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y M a x R a s t e r I m a g e H e i g h t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y M a x R a s t e r I m a g e W i d t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y M a x R e n d e r I m a g e H e i g h t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y M a x R e n d e r I m a g e W i d t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y M i n R a s t e r G r i d S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y M i n R a s t e r G r i d S i z e F o r P l o t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e F o r P l o t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e O v e r r i d e R a t i o  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e O v e r r i d e R a t i o F o r P l o t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y R e n d e r S e l e c t i o n B a t c h S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y T i l e E x t e n t O f f s e t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y L i b r a r y R e p o s i t o r y P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y L i b r a r y R e s o u r c e D a t a F i l e P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y P a c k a g e s P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y R e p o s i t o r y C h e c k p o i n t s T i m e r I n t e r v a l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e C h a n g e T i m e r I n t e r v a l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e D a t a F i l e T r a s h F o l d e r N a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e P e r m i s s i o n C a c h e S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e S c h e m a F i l e P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y S e s s i o n R e p o s i t o r y P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y S e s s i o n R e s o u r c e D a t a F i l e P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y S i t e R e p o s i t o r y P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S e r v e r C o n f i g u r a t i o n F i l e n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S e s s i o n C a c h e S i z e P a r a m t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S e s s i o n D B P a g e S i z e P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S e s s i o n D B X M L P a g e S i z e P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S e s s i o n L o g B u f f e r S i z e P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S e s s i o n L o g P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S e s s i o n L o g P r o p e r t y E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S e s s i o n L o g P r o p e r t y F i l e n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S e s s i o n L o g P r o p e r t y P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S i t e C o n n e c t i o n P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S i t e C o n n e c t i o n P r o p e r t y I p A d d r e s s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S i t e C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S i t e C o n n e c t i o n P r o p e r t y P o r t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S i t e C o n n e c t i o n P r o p e r t y Q u e u e S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S i t e C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S i t e S e r v i c e P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S i t e S e r v i c e P r o p e r t y S e s s i o n T i m e o u t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   S i t e S e r v i c e P r o p e r t y S e s s i o n T i m e r I n t e r v a l  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T e m p l a t e R o o t F o l d e r  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T i l e S e r v i c e P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T i l e S e r v i c e P r o p e r t y I m a g e F o r m a t  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T i l e S e r v i c e P r o p e r t y R e n d e r O n l y  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T i l e S e r v i c e P r o p e r t y T i l e C a c h e P a t h  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T i l e S e r v i c e P r o p e r t y T i l e C o l u m n s P e r F o l d e r  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T i l e S e r v i c e P r o p e r t y T i l e R o w s P e r F o l d e r  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T i l e S e r v i c e P r o p e r t y T i l e S i z e X  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T i l e S e r v i c e P r o p e r t y T i l e S i z e Y  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T r a c e L o g P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T r a c e L o g P r o p e r t y E n a b l e d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T r a c e L o g P r o p e r t y F i l e n a m e  -
-         [ F i e l d ]   S y s t e m . S t r i n g   T r a c e L o g P r o p e r t y P a r a m e t e r s  -
-         [ F i e l d ]   S y s t e m . S t r i n g   U n m a n a g e d D a t a M a p p i n g s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   W e b A p p l i c a t i o n P r o p e r t i e s S e c t i o n  -
-         [ F i e l d ]   S y s t e m . S t r i n g   W f s P a s s w o r d  -
-         [ F i e l d ]   S y s t e m . S t r i n g   W i d g e t I n f o F o l d e r  -
-         [ F i e l d ]   S y s t e m . S t r i n g   W m s P a s s w o r d  -
- t y p e   O S G e o . M a p G u i d e . M g L o c a l i z e r   :   S y s t e m . O b j e c t  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S t r i n g ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   L o c a l i z e ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t L o c a l i z e d F i l e s P a t h ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g D r a w i n g S e r v i c e   :   O S G e o . M a p G u i d e . M g S e r v i c e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   D e s c r i b e D r a w i n g ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   E n u m e r a t e L a y e r s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   E n u m e r a t e S e c t i o n R e s o u r c e s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   E n u m e r a t e S e c t i o n s ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t C o o r d i n a t e S p a c e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t D r a w i n g ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t L a y e r ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t S e c t i o n ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t S e c t i o n R e s o u r c e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g D w f V e r s i o n   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t F i l e V e r s i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S c h e m a V e r s i o n ( )  -
-         [ M e t h o d ]   V o i d   S e t F i l e V e r s i o n ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t S c h e m a V e r s i o n ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g F e a t u r e I n f o r m a t i o n   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t H y p e r l i n k ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n   G e t P r o p e r t i e s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S e l e c t i o n   G e t S e l e c t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t T o o l t i p ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   T o X m l ( )  -
- t y p e   O S G e o . M a p G u i d e . M g K m l S e r v i c e   :   O S G e o . M a p G u i d e . M g S e r v i c e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t F e a t u r e s K m l ( O S G e o . M a p G u i d e . M g L a y e r ,   O S G e o . M a p G u i d e . M g E n v e l o p e ,   I n t 3 2 ,   I n t 3 2 ,   D o u b l e ,   I n t 3 2 ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t F e a t u r e s K m l ( O S G e o . M a p G u i d e . M g L a y e r ,   O S G e o . M a p G u i d e . M g E n v e l o p e ,   I n t 3 2 ,   I n t 3 2 ,   D o u b l e ,   I n t 3 2 ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t L a y e r K m l ( O S G e o . M a p G u i d e . M g L a y e r ,   O S G e o . M a p G u i d e . M g E n v e l o p e ,   I n t 3 2 ,   I n t 3 2 ,   D o u b l e ,   I n t 3 2 ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t M a p K m l ( O S G e o . M a p G u i d e . M g M a p ,   D o u b l e ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g L a y e r   :   O S G e o . M a p G u i d e . M g L a y e r B a s e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g T r a n s a c t i o n   B e g i n T r a n s a c t i o n ( )  -
-         [ M e t h o d ]   I n t 3 2   D e l e t e F e a t u r e s ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g T r a n s a c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e n e r a t e L e g e n d I m a g e ( I n t 3 2 ,   I n t 3 2 ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e n e r a t e L e g e n d I m a g e ( D o u b l e ,   I n t 3 2 ,   I n t 3 2 ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C l a s s D e f i n i t i o n   G e t C l a s s D e f i n i t i o n ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t C o m p o s i t e T h e m e C a t e g o r y C o u n t ( D o u b l e ,   I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t C o m p o s i t e T h e m e C a t e g o r y C o u n t ( I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g I n t C o l l e c t i o n   G e t G e o m e t r y T y p e S t y l e s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g I n t C o l l e c t i o n   G e t G e o m e t r y T y p e S t y l e s ( D o u b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S p a t i a l C o n t e x t R e a d e r   G e t S p a t i a l C o n t e x t s ( B o o l e a n )  -
-         [ M e t h o d ]   I n t 3 2   G e t T h e m e C a t e g o r y C o u n t ( D o u b l e ,   I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t T h e m e C a t e g o r y C o u n t ( I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   I n s e r t F e a t u r e s ( O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g T r a n s a c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   I n s e r t F e a t u r e s ( O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g T r a n s a c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D a t a R e a d e r   S e l e c t A g g r e g a t e ( O S G e o . M a p G u i d e . M g F e a t u r e A g g r e g a t e O p t i o n s )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   S e l e c t F e a t u r e s ( O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   S e l e c t F e a t u r e s ( O S G e o . M a p G u i d e . M g F e a t u r e Q u e r y O p t i o n s ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n   U p d a t e F e a t u r e s ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n   U p d a t e F e a t u r e s ( O S G e o . M a p G u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g T r a n s a c t i o n )  -
-         [ M e t h o d ]   I n t 3 2   U p d a t e M a t c h i n g F e a t u r e s ( O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g T r a n s a c t i o n )  -
- t y p e   O S G e o . M a p G u i d e . M g L a y o u t   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r   G e t L a y o u t ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t T i t l e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t U n i t T y p e ( )  -
-         [ M e t h o d ]   V o i d   S e t L a y o u t ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   V o i d   S e t T i t l e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t U n i t T y p e ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g M a p   :   O S G e o . M a p G u i d e . M g M a p B a s e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g S i t e C o n n e c t i o n )  -
-         [ M e t h o d ]   V o i d   C r e a t e ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g E n v e l o p e ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   C r e a t e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 ,   D o u b l e ,   D o u b l e ,   D o u b l e ,   I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   C r e a t e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t T i l e F o r m a t ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t T i l e P i x e l R a t i o ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r   G e t T i l e S e t D e f i n i t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t T i l e S e t P r o v i d e r ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t W a t e r m a r k U s a g e ( )  -
-         [ M e t h o d ]   V o i d   O p e n ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S a v e ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e ,   O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   V o i d   S a v e ( )  -
- t y p e   O S G e o . M a p G u i d e . M g M a p p i n g S e r v i c e   :   O S G e o . M a p G u i d e . M g S e r v i c e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   C r e a t e R u n t i m e M a p ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   C r e a t e R u n t i m e M a p ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   D e s c r i b e R u n t i m e M a p ( O S G e o . M a p G u i d e . M g M a p ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   D e s c r i b e R u n t i m e M a p ( O S G e o . M a p G u i d e . M g M a p ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e n e r a t e L e g e n d I m a g e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   D o u b l e ,   I n t 3 2 ,   I n t 3 2 ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e n e r a t e M u l t i P l o t ( O S G e o . M a p G u i d e . M g M a p P l o t C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g D w f V e r s i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e n e r a t e P l o t ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g E n v e l o p e ,   B o o l e a n ,   O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n ,   O S G e o . M a p G u i d e . M g L a y o u t ,   O S G e o . M a p G u i d e . M g D w f V e r s i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e n e r a t e P l o t ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n ,   O S G e o . M a p G u i d e . M g L a y o u t ,   O S G e o . M a p G u i d e . M g D w f V e r s i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e n e r a t e P l o t ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   D o u b l e ,   O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n ,   O S G e o . M a p G u i d e . M g L a y o u t ,   O S G e o . M a p G u i d e . M g D w f V e r s i o n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   Q u e r y F e a t u r e s ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   Q u e r y F e a t u r e s ( O S G e o . M a p G u i d e . M g M a p ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g M a p P l o t   :   O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   D o u b l e ,   O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n ,   O S G e o . M a p G u i d e . M g L a y o u t )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n ,   O S G e o . M a p G u i d e . M g L a y o u t )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g E n v e l o p e ,   B o o l e a n ,   O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n ,   O S G e o . M a p G u i d e . M g L a y o u t )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o o r d i n a t e   G e t C e n t e r ( )  -
-         [ M e t h o d ]   B o o l e a n   G e t E x p a n d T o F i t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g E n v e l o p e   G e t E x t e n t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g L a y o u t   G e t L a y o u t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g M a p   G e t M a p ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t M a p P l o t I n s t r u c t i o n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n   G e t P l o t S p e c i f i c a t i o n ( )  -
-         [ M e t h o d ]   D o u b l e   G e t S c a l e ( )  -
-         [ M e t h o d ]   V o i d   S e t C e n t e r A n d S c a l e ( O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   D o u b l e )  -
-         [ M e t h o d ]   V o i d   S e t E x t e n t ( O S G e o . M a p G u i d e . M g E n v e l o p e ,   B o o l e a n )  -
-         [ M e t h o d ]   V o i d   S e t L a y o u t ( O S G e o . M a p G u i d e . M g L a y o u t )  -
-         [ M e t h o d ]   V o i d   S e t M a p ( O S G e o . M a p G u i d e . M g M a p )  -
-         [ M e t h o d ]   V o i d   S e t M a p P l o t I n s t r u c t i o n ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t P l o t S p e c i f i c a t i o n ( O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n )  -
- [ S y s t e m . R e f l e c t i o n . D e f a u l t M e m b e r A t t r i b u t e ]  -
- t y p e   O S G e o . M a p G u i d e . M g M a p P l o t C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I L i s t ` 1 [ [ O S G e o . M a p G u i d e . M g M a p P l o t ,   O S G e o . M a p G u i d e . M a p G u i d e C o m m o n ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I C o l l e c t i o n ` 1 [ [ O S G e o . M a p G u i d e . M g M a p P l o t ,   O S G e o . M a p G u i d e . M a p G u i d e C o m m o n ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a b l e ` 1 [ [ O S G e o . M a p G u i d e . M g M a p P l o t ,   O S G e o . M a p G u i d e . M a p G u i d e C o m m o n ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l ] ]  -
-         i m p l e m e n t s   S y s t e m . C o l l e c t i o n s . I E n u m e r a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( )  -
-         [ M e t h o d ]   V o i d   A d d ( O S G e o . M a p G u i d e . M g M a p P l o t )  -
-         [ M e t h o d ]   V o i d   C l e a r ( )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g M a p P l o t )  -
-         [ M e t h o d ]   V o i d   C o p y T o ( O S G e o . M a p G u i d e . M g M a p P l o t [ ] ,   I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   g e t _ C o u n t ( )  -
-         [ M e t h o d ]   B o o l e a n   g e t _ I s R e a d O n l y ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g M a p P l o t   g e t _ I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t C o u n t ( )  -
-         [ M e t h o d ]   S y s t e m . C o l l e c t i o n s . G e n e r i c . I E n u m e r a t o r ` 1 [ O S G e o . M a p G u i d e . M g M a p P l o t ]   G e t E n u m e r a t o r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g M a p P l o t   G e t I t e m ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g M a p P l o t   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g M a p P l o t )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   I n s e r t ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g M a p P l o t )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e ( O S G e o . M a p G u i d e . M g M a p P l o t )  -
-         [ M e t h o d ]   V o i d   R e m o v e A t ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   s e t _ I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g M a p P l o t )  -
-         [ M e t h o d ]   V o i d   S e t I t e m ( I n t 3 2 ,   O S G e o . M a p G u i d e . M g M a p P l o t )  -
- t y p e   O S G e o . M a p G u i d e . M g M e t a t i l e   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         i m p l e m e n t s   S y s t e m . I D i s p o s a b l e  -
-         [ M e t h o d ]   I n t 3 2   G e t H e i g h t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t I m a g e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t M e t a T i l i n g F a c t o r ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t R e q u e s t e d H e i g h t ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t R e q u e s t e d W i d t h ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t T i l e I m a g e F o r m a t ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t W i d t h ( )  -
- t y p e   O S G e o . M a p G u i d e . M g P a c k a g e S t a t u s I n f o r m a t i o n   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t A p i N a m e ( )  -
-         [ M e t h o d ]   D o u b l e   G e t A v e r a g e O p e r a t i o n T i m e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D a t e T i m e   G e t E n d T i m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t E r r o r M e s s a g e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t O p e r a t i o n s F a i l e d ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t O p e r a t i o n s R e c e i v e d ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D a t e T i m e   G e t P a c k a g e D a t e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t P a c k a g e D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t P a c k a g e N a m e ( )  -
-         [ M e t h o d ]   I n t 6 4   G e t P a c k a g e S i z e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S e r v e r A d d r e s s ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S e r v e r N a m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S t a c k T r a c e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D a t e T i m e   G e t S t a r t T i m e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S t a t u s C o d e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S t a t u s M e s s a g e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t U s e r N a m e ( )  -
-         [ M e t h o d ]   V o i d   S e t A p i N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t E n d T i m e ( O S G e o . M a p G u i d e . M g D a t e T i m e )  -
-         [ M e t h o d ]   V o i d   S e t E r r o r M e s s a g e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t O p e r a t i o n s F a i l e d ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t O p e r a t i o n s R e c e i v e d ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   S e t P a c k a g e D a t e ( O S G e o . M a p G u i d e . M g D a t e T i m e )  -
-         [ M e t h o d ]   V o i d   S e t P a c k a g e D e s c r i p t i o n ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t P a c k a g e N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t P a c k a g e S i z e ( I n t 6 4 )  -
-         [ M e t h o d ]   V o i d   S e t S e r v e r A d d r e s s ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t S e r v e r N a m e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t S t a c k T r a c e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t S t a r t T i m e ( O S G e o . M a p G u i d e . M g D a t e T i m e )  -
-         [ M e t h o d ]   V o i d   S e t S t a t u s C o d e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t U s e r N a m e ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g P l o t S p e c i f i c a t i o n   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S i n g l e ,   S i n g l e ,   S y s t e m . S t r i n g ,   S i n g l e ,   S i n g l e )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S i n g l e ,   S i n g l e ,   S y s t e m . S t r i n g ,   S i n g l e ,   S i n g l e ,   S i n g l e ,   S i n g l e )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S i n g l e ,   S i n g l e ,   S y s t e m . S t r i n g ,   S i n g l e )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S i n g l e ,   S i n g l e ,   S y s t e m . S t r i n g ,   S i n g l e ,   S i n g l e ,   S i n g l e )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S i n g l e ,   S i n g l e ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S i n g l e   G e t M a r g i n B o t t o m ( )  -
-         [ M e t h o d ]   S i n g l e   G e t M a r g i n L e f t ( )  -
-         [ M e t h o d ]   S i n g l e   G e t M a r g i n R i g h t ( )  -
-         [ M e t h o d ]   S i n g l e   G e t M a r g i n T o p ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t P a g e S i z e U n i t s ( )  -
-         [ M e t h o d ]   S i n g l e   G e t P a p e r H e i g h t ( )  -
-         [ M e t h o d ]   S i n g l e   G e t P a p e r W i d t h ( )  -
-         [ M e t h o d ]   V o i d   S e t M a r g i n s ( S i n g l e ,   S i n g l e ,   S i n g l e ,   S i n g l e )  -
-         [ M e t h o d ]   V o i d   S e t P a g e S i z e U n i t s ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t P a p e r H e i g h t ( S i n g l e )  -
-         [ M e t h o d ]   V o i d   S e t P a p e r W i d t h ( S i n g l e )  -
- t y p e   O S G e o . M a p G u i d e . M g P r o f i l i n g S e r v i c e   :   O S G e o . M a p G u i d e . M g S e r v i c e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   P r o f i l e R e n d e r D y n a m i c O v e r l a y ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S e l e c t i o n ,   O S G e o . M a p G u i d e . M g R e n d e r i n g O p t i o n s )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   P r o f i l e R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S e l e c t i o n ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   D o u b l e ,   I n t 3 2 ,   I n t 3 2 ,   O S G e o . M a p G u i d e . M g C o l o r ,   S y s t e m . S t r i n g ,   B o o l e a n )  -
- t y p e   O S G e o . M a p G u i d e . M g R e n d e r i n g O p t i o n s   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   I n t 3 2 ,   O S G e o . M a p G u i d e . M g C o l o r )  -
-         [ M e t h o d ]   I n t 3 2   G e t B e h a v i o r ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t I m a g e F o r m a t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g C o l o r   G e t S e l e c t i o n C o l o r ( )  -
-         [ F i e l d ]   I n t 3 2   K e e p S e l e c t i o n  -
-         [ F i e l d ]   I n t 3 2   R e n d e r B a s e L a y e r s  -
-         [ F i e l d ]   I n t 3 2   R e n d e r L a y e r s  -
-         [ F i e l d ]   I n t 3 2   R e n d e r S e l e c t i o n  -
- t y p e   O S G e o . M a p G u i d e . M g R e n d e r i n g S e r v i c e   :   O S G e o . M a p G u i d e . M g S e r v i c e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n   Q u e r y F e a t u r e P r o p e r t i e s ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g G e o m e t r y ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n   Q u e r y F e a t u r e P r o p e r t i e s ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g G e o m e t r y ,   I n t 3 2 ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e I n f o r m a t i o n   Q u e r y F e a t u r e s ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g G e o m e t r y ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e I n f o r m a t i o n   Q u e r y F e a t u r e s ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g G e o m e t r y ,   I n t 3 2 ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r D y n a m i c O v e r l a y ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S e l e c t i o n ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r D y n a m i c O v e r l a y ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S e l e c t i o n ,   S y s t e m . S t r i n g ,   B o o l e a n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r D y n a m i c O v e r l a y ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S e l e c t i o n ,   O S G e o . M a p G u i d e . M g R e n d e r i n g O p t i o n s )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S e l e c t i o n ,   O S G e o . M a p G u i d e . M g E n v e l o p e ,   I n t 3 2 ,   I n t 3 2 ,   O S G e o . M a p G u i d e . M g C o l o r ,   S y s t e m . S t r i n g ,   B o o l e a n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S e l e c t i o n ,   S y s t e m . S t r i n g ,   B o o l e a n ,   B o o l e a n ,   O S G e o . M a p G u i d e . M g C o l o r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S e l e c t i o n ,   O S G e o . M a p G u i d e . M g E n v e l o p e ,   I n t 3 2 ,   I n t 3 2 ,   O S G e o . M a p G u i d e . M g C o l o r ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S e l e c t i o n ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   D o u b l e ,   I n t 3 2 ,   I n t 3 2 ,   O S G e o . M a p G u i d e . M g C o l o r ,   S y s t e m . S t r i n g ,   B o o l e a n ,   O S G e o . M a p G u i d e . M g C o l o r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S e l e c t i o n ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   D o u b l e ,   I n t 3 2 ,   I n t 3 2 ,   O S G e o . M a p G u i d e . M g C o l o r ,   S y s t e m . S t r i n g ,   B o o l e a n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S e l e c t i o n ,   O S G e o . M a p G u i d e . M g C o o r d i n a t e ,   D o u b l e ,   I n t 3 2 ,   I n t 3 2 ,   O S G e o . M a p G u i d e . M g C o l o r ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S e l e c t i o n ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S e l e c t i o n ,   S y s t e m . S t r i n g ,   B o o l e a n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r M a p ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g S e l e c t i o n ,   S y s t e m . S t r i n g ,   B o o l e a n ,   B o o l e a n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r M a p L e g e n d ( O S G e o . M a p G u i d e . M g M a p ,   I n t 3 2 ,   I n t 3 2 ,   O S G e o . M a p G u i d e . M g C o l o r ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g M e t a t i l e   R e n d e r M e t a t i l e ( O S G e o . M a p G u i d e . M g M a p ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   S y s t e m . S t r i n g ,   D o u b l e ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g M e t a t i l e   R e n d e r M e t a t i l e X Y Z ( O S G e o . M a p G u i d e . M g M a p ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   S y s t e m . S t r i n g ,   D o u b l e ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ S y s t e m . O b s o l e t e A t t r i b u t e ]  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r T i l e ( O S G e o . M a p G u i d e . M g M a p ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r T i l e ( O S G e o . M a p G u i d e . M g M a p ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r T i l e ( O S G e o . M a p G u i d e . M g M a p ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   S y s t e m . S t r i n g ,   D o u b l e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r T i l e F r o m M e t a T i l e ( O S G e o . M a p G u i d e . M g M a p ,   O S G e o . M a p G u i d e . M g M e t a t i l e ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r T i l e U T F G r i d ( O S G e o . M a p G u i d e . M g M a p ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r T i l e X Y Z ( O S G e o . M a p G u i d e . M g M a p ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   S y s t e m . S t r i n g ,   D o u b l e ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r T i l e X Y Z ( O S G e o . M a p G u i d e . M g M a p ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   R e n d e r T i l e X Y Z ( O S G e o . M a p G u i d e . M g M a p ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g S e l e c t i o n   :   O S G e o . M a p G u i d e . M g S e l e c t i o n B a s e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g M a p ,   S y s t e m . S t r i n g )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g M a p )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   G e t S e l e c t e d F e a t u r e s ( O S G e o . M a p G u i d e . M g L a y e r B a s e ,   S y s t e m . S t r i n g ,   B o o l e a n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g F e a t u r e R e a d e r   G e t S e l e c t e d F e a t u r e s ( O S G e o . M a p G u i d e . M g L a y e r B a s e ,   S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n )  -
-         [ M e t h o d ]   V o i d   O p e n ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S a v e ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e ,   S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g S e r v e r A d m i n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   V o i d   B r i n g O n l i n e ( )  -
-         [ M e t h o d ]   B o o l e a n   C l e a r L o g ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   C l o s e ( )  -
-         [ M e t h o d ]   V o i d   D e l e t e L o g ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   D e l e t e P a c k a g e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   E n a b l e M a x i m u m L o g S i z e ( B o o l e a n )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n   E n u m e r a t e L o g s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   E n u m e r a t e P a c k a g e s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n   G e t C o n f i g u r a t i o n P r o p e r t i e s ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t D o c u m e n t ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n   G e t I n f o r m a t i o n P r o p e r t i e s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t L o g ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g D a t e T i m e ,   O S G e o . M a p G u i d e . M g D a t e T i m e )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t L o g ( S y s t e m . S t r i n g ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t L o g ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t L o g F i l e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t P a c k a g e L o g ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P a c k a g e S t a t u s I n f o r m a t i o n   G e t P a c k a g e S t a t u s ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n   G e t S i t e S t a t u s ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S i t e V e r s i o n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W a r n i n g s   G e t W a r n i n g s O b j e c t ( )  -
-         [ M e t h o d ]   B o o l e a n   H a s W a r n i n g ( )  -
-         [ M e t h o d ]   B o o l e a n   I s M a x i m u m L o g S i z e E n a b l e d ( )  -
-         [ M e t h o d ]   B o o l e a n   I s O n l i n e ( )  -
-         [ M e t h o d ]   V o i d   L o a d P a c k a g e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   M a k e P a c k a g e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   O p e n ( O S G e o . M a p G u i d e . M g U s e r I n f o r m a t i o n )  -
-         [ M e t h o d ]   V o i d   O p e n ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g U s e r I n f o r m a t i o n )  -
-         [ M e t h o d ]   V o i d   R e m o v e C o n f i g u r a t i o n P r o p e r t i e s ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n )  -
-         [ M e t h o d ]   V o i d   R e n a m e L o g ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t C o n f i g u r a t i o n P r o p e r t i e s ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g P r o p e r t y C o l l e c t i o n )  -
-         [ M e t h o d ]   V o i d   S e t D o c u m e n t ( S y s t e m . S t r i n g ,   O S G e o . M a p G u i d e . M g B y t e R e a d e r )  -
-         [ M e t h o d ]   V o i d   S e t L o g D e l i m i t e r ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t M a x i m u m L o g S i z e ( I n t 3 2 )  -
-         [ M e t h o d ]   V o i d   T a k e O f f l i n e ( )  -
- t y p e   O S G e o . M a p G u i d e . M g S i t e   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   V o i d   A d d G r o u p ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   A d d S e r v e r ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   A d d U s e r ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   C r e a t e S e s s i o n ( )  -
-         [ M e t h o d ]   V o i d   D e l e t e G r o u p s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n )  -
-         [ M e t h o d ]   V o i d   D e l e t e U s e r s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n )  -
-         [ M e t h o d ]   V o i d   D e s t r o y S e s s i o n ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   E n u m e r a t e G r o u p s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   E n u m e r a t e G r o u p s ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   E n u m e r a t e G r o u p s ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   E n u m e r a t e R o l e s ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   E n u m e r a t e R o l e s ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   E n u m e r a t e S e r v e r s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   E n u m e r a t e U s e r s ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   E n u m e r a t e U s e r s ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   B o o l e a n )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t C u r r e n t S e s s i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t C u r r e n t S i t e A d d r e s s ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t S e s s i o n T i m e o u t ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t S i t e S e r v e r C o u n t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S i t e I n f o   G e t S i t e S e r v e r I n f o ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t U s e r F o r S e s s i o n ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W a r n i n g s   G e t W a r n i n g ( )  -
-         [ M e t h o d ]   V o i d   G r a n t G r o u p M e m b e r s h i p s T o U s e r s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n )  -
-         [ M e t h o d ]   V o i d   G r a n t R o l e M e m b e r s h i p s T o G r o u p s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n )  -
-         [ M e t h o d ]   V o i d   G r a n t R o l e M e m b e r s h i p s T o U s e r s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n )  -
-         [ M e t h o d ]   V o i d   O p e n ( O S G e o . M a p G u i d e . M g U s e r I n f o r m a t i o n ,   O S G e o . M a p G u i d e . M g S i t e I n f o )  -
-         [ M e t h o d ]   V o i d   R e m o v e S e r v e r ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   R e v o k e G r o u p M e m b e r s h i p s F r o m U s e r s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n )  -
-         [ M e t h o d ]   V o i d   R e v o k e R o l e M e m b e r s h i p s F r o m G r o u p s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n )  -
-         [ M e t h o d ]   V o i d   R e v o k e R o l e M e m b e r s h i p s F r o m U s e r s ( O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n ,   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n )  -
-         [ M e t h o d ]   V o i d   U p d a t e G r o u p ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   U p d a t e S e r v e r ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   U p d a t e U s e r ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g S i t e C o n n e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S e r v i c e   C r e a t e S e r v i c e ( I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S i t e   G e t S i t e ( )  -
- t y p e   O S G e o . M a p G u i d e . M g S i t e I n f o   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t P o r t ( M g P o r t T y p e )  -
-         [ M e t h o d ]   M g S i t e S t a t u s   G e t S t a t u s ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t T a r g e t ( )  -
-         [ M e t h o d ]   V o i d   S e t S t a t u s ( M g S i t e S t a t u s )  -
- t y p e   O S G e o . M a p G u i d e . M g T i l e S e r v i c e   :   O S G e o . M a p G u i d e . M g S e r v i c e  -
-         [ M e t h o d ]   V o i d   C l e a r C a c h e ( O S G e o . M a p G u i d e . M g M a p )  -
-         [ M e t h o d ]   V o i d   C l e a r C a c h e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   I n t 3 2   G e t D e f a u l t T i l e S i z e X ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t D e f a u l t T i l e S i z e X ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   I n t 3 2   G e t D e f a u l t T i l e S i z e Y ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t D e f a u l t T i l e S i z e Y ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t T i l e ( O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t T i l e ( O S G e o . M a p G u i d e . M g M a p ,   S y s t e m . S t r i n g ,   I n t 3 2 ,   I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t T i l e P r o v i d e r s ( )  -
- t y p e   O S G e o . M a p G u i d e . M g U s e r I n f o r m a t i o n   :   O S G e o . M a p G u i d e . M g S e r i a l i z a b l e  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t C l i e n t A g e n t ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t C l i e n t I p ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t L o c a l e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   G e t R e a d e r ( )  -
-         [ M e t h o d ]   V o i d   S e t C l i e n t A g e n t ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t C l i e n t I p ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t L o c a l e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t M g S e s s i o n I d ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t M g U s e r n a m e P a s s w o r d ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g M a p + W a t e r m a r k U s a g e T y p e   :   S y s t e m . E n u m  -
-         i m p l e m e n t s   S y s t e m . I C o m p a r a b l e  -
-         i m p l e m e n t s   S y s t e m . I F o r m a t t a b l e  -
-         i m p l e m e n t s   S y s t e m . I C o n v e r t i b l e  -
-         [ F i e l d ]   I n t 3 2   v a l u e _ _  -
-         [ F i e l d ]   W a t e r m a r k U s a g e T y p e   V i e w e r  -
-         [ F i e l d ]   W a t e r m a r k U s a g e T y p e   W M S  -
- t y p e   O S G e o . M a p G u i d e . M g S i t e I n f o + M g S i t e S t a t u s   :   S y s t e m . E n u m  -
-         [ F i e l d ]   M g S i t e S t a t u s   O k  -
-         [ F i e l d ]   M g S i t e S t a t u s   T i m e d O u t  -
-         [ F i e l d ]   M g S i t e S t a t u s   U n a b l e T o C o n n e c t  -
-         [ F i e l d ]   M g S i t e S t a t u s   U n i n i t i a l i z e d  -
- t y p e   O S G e o . M a p G u i d e . M g S i t e I n f o + M g P o r t T y p e   :   S y s t e m . E n u m  -
-         [ F i e l d ]   M g P o r t T y p e   A d m i n  -
-         [ F i e l d ]   M g P o r t T y p e   C l i e n t  -
-         [ F i e l d ]   M g P o r t T y p e   S i t e  -
- A s s e m b l y :   O S G e o . M a p G u i d e . W e b ,   V e r s i o n = 4 . 0 . 0 . 1 0 2 0 2 ,   C u l t u r e = n e u t r a l ,   P u b l i c K e y T o k e n = n u l l  -
- t y p e   O S G e o . M a p G u i d e . M g W e b A c t i o n s   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   A b o u t  -
-         [ F i e l d ]   I n t 3 2   B u f f e r  -
-         [ F i e l d ]   I n t 3 2   C o p y  -
-         [ F i e l d ]   I n t 3 2   F i t W i n d o w  -
-         [ F i e l d ]   I n t 3 2   G e t P r i n t a b l e P a g e  -
-         [ F i e l d ]   I n t 3 2   H e l p  -
-         [ F i e l d ]   I n t 3 2   I n v o k e S c r i p t  -
-         [ F i e l d ]   I n t 3 2   I n v o k e U r l  -
-         [ F i e l d ]   I n t 3 2   M a p T i p  -
-         [ F i e l d ]   I n t 3 2   M e a s u r e  -
-         [ F i e l d ]   I n t 3 2   P a n  -
-         [ F i e l d ]   I n t 3 2   P a n D o w n  -
-         [ F i e l d ]   I n t 3 2   P a n L e f t  -
-         [ F i e l d ]   I n t 3 2   P a n R i g h t  -
-         [ F i e l d ]   I n t 3 2   P a n U p  -
-         [ F i e l d ]   I n t 3 2   P r i n t M a p  -
-         [ F i e l d ]   I n t 3 2   R e f r e s h  -
-         [ F i e l d ]   I n t 3 2   S e a r c h  -
-         [ F i e l d ]   I n t 3 2   S e l e c t  -
-         [ F i e l d ]   I n t 3 2   S e l e c t C l e a r  -
-         [ F i e l d ]   I n t 3 2   S e l e c t P o l y g o n  -
-         [ F i e l d ]   I n t 3 2   S e l e c t R a d i u s  -
-         [ F i e l d ]   I n t 3 2   S e l e c t W i t h i n  -
-         [ F i e l d ]   I n t 3 2   V i e w N e x t  -
-         [ F i e l d ]   I n t 3 2   V i e w O p t i o n s  -
-         [ F i e l d ]   I n t 3 2   V i e w P r e v i o u s  -
-         [ F i e l d ]   I n t 3 2   V i e w R e s t o r e  -
-         [ F i e l d ]   I n t 3 2   Z o o m  -
-         [ F i e l d ]   I n t 3 2   Z o o m I n  -
-         [ F i e l d ]   I n t 3 2   Z o o m O u t  -
-         [ F i e l d ]   I n t 3 2   Z o o m R e c t a n g l e  -
-         [ F i e l d ]   I n t 3 2   Z o o m S e l e c t i o n  -
- t y p e   O S G e o . M a p G u i d e . M g W e b T a r g e t T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   N e w W i n d o w  -
-         [ F i e l d ]   I n t 3 2   S p e c i f i e d F r a m e  -
-         [ F i e l d ]   I n t 3 2   T a s k P a n e  -
- t y p e   O S G e o . M a p G u i d e . M g W e b T a r g e t V i e w e r T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   A j a x  -
-         [ F i e l d ]   I n t 3 2   A l l  -
-         [ F i e l d ]   I n t 3 2   D w f  -
- t y p e   O S G e o . M a p G u i d e . M g W e b T a s k B u t t o n T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   B a c k  -
-         [ F i e l d ]   I n t 3 2   F o r w a r d  -
-         [ F i e l d ]   I n t 3 2   H o m e  -
-         [ F i e l d ]   I n t 3 2   T a s k s  -
- t y p e   O S G e o . M a p G u i d e . M g W e b W i d g e t T y p e   :   S y s t e m . O b j e c t  -
-         [ F i e l d ]   I n t 3 2   C o m m a n d  -
-         [ F i e l d ]   I n t 3 2   F l y o u t  -
-         [ F i e l d ]   I n t 3 2   S e p a r a t o r  -
-         [ F i e l d ]   I n t 3 2   T a s k B u t t o n  -
- t y p e   O S G e o . M a p G u i d e . M a p G u i d e A p i   :   S y s t e m . O b j e c t  -
-         [ M e t h o d ]   V o i d   M g I n i t i a l i z e W e b T i e r ( S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g H t t p H e a d e r   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   B o o l e a n   A d d H e a d e r ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 3 2   G e t D a t e H e a d e r ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   G e t H e a d e r N a m e s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   G e t H e a d e r s ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t H e a d e r V a l u e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 3 2   G e t I n t H e a d e r ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e H e a d e r ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   S e t H e a d e r V a l u e ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g H t t p P r i m i t i v e V a l u e   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( B o o l e a n )  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( I n t 3 2 )  -
-         [ M e t h o d ]   B o o l e a n   G e t B o o l V a l u e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t I n t e g e r V a l u e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S t r i n g V a l u e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t T y p e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   T o S t r i n g ( )  -
- t y p e   O S G e o . M a p G u i d e . M g H t t p R e q u e s t   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g H t t p R e s p o n s e   E x e c u t e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t A g e n t U r i ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g H t t p H e a d e r   G e t H e a d e r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g H t t p R e q u e s t M e t a d a t a   G e t R e q u e s t M e t a d a t a ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g H t t p R e q u e s t P a r a m   G e t R e q u e s t P a r a m ( )  -
- t y p e   O S G e o . M a p G u i d e . M g H t t p R e q u e s t M e t a d a t a   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   B o o l e a n   A d d P r o p e r t y ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   G e t P r o p e r t y N a m e s ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t P r o p e r t y V a l u e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e P r o p e r t y ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   S e t P r o p e r t y V a l u e ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g H t t p R e q u e s t P a r a m   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   B o o l e a n   A d d P a r a m e t e r ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s P a r a m e t e r ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g S t r i n g C o l l e c t i o n   G e t P a r a m e t e r N a m e s ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t P a r a m e t e r T y p e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t P a r a m e t e r V a l u e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   R e m o v e P a r a m e t e r ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   S e t P a r a m e t e r T y p e ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   B o o l e a n   S e t P a r a m e t e r V a l u e ( S y s t e m . S t r i n g ,   S y s t e m . S t r i n g )  -
- t y p e   O S G e o . M a p G u i d e . M g H t t p R e s p o n s e   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g H t t p R e s u l t   G e t R e s u l t ( )  -
- t y p e   O S G e o . M a p G u i d e . M g H t t p R e s u l t   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D e t a i l e d E r r o r M e s s a g e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t H t t p S t a t u s M e s s a g e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t R e s u l t C o n t e n t T y p e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g D i s p o s a b l e   G e t R e s u l t O b j e c t ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t S t a t u s C o d e ( )  -
-         [ M e t h o d ]   V o i d   S e t D e t a i l e d E r r o r M e s s a g e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t H t t p S t a t u s M e s s a g e ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t R e s u l t O b j e c t ( O S G e o . M a p G u i d e . M g D i s p o s a b l e ,   S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   V o i d   S e t S t a t u s C o d e ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b B u f f e r C o m m a n d   :   O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d  -
- t y p e   O S G e o . M a p G u i d e . M g W e b C o m m a n d   :   O S G e o . M a p G u i d e . M g N a m e d S e r i a l i z a b l e  -
-         [ M e t h o d ]   I n t 3 2   G e t A c t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D e s c r i p t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D i s a b l e d I c o n U r l ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t I c o n U r l ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t L a b e l ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t N a m e ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t T a r g e t V i e w e r T y p e ( )  -
-         [ M e t h o d ]   B o o l e a n   I s U s e d ( )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b C o m m a n d C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g W e b C o m m a n d )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W e b C o m m a n d   G e t I t e m ( I n t 3 2 )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W e b C o m m a n d   G e t I t e m ( S y s t e m . S t r i n g )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g W e b C o m m a n d )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b C o m m a n d W i d g e t   :   O S G e o . M a p G u i d e . M g W e b W i d g e t  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W e b C o m m a n d   G e t C o m m a n d ( )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b C o n t e x t M e n u   :   O S G e o . M a p G u i d e . M g W e b W i d g e t C o l l e c t i o n  -
-         [ M e t h o d ]   B o o l e a n   I s V i s i b l e ( )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b F l y o u t W i d g e t   :   O S G e o . M a p G u i d e . M g W e b W i d g e t  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W e b W i d g e t C o l l e c t i o n   G e t S u b I t e m s ( )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b G e t P r i n t a b l e P a g e C o m m a n d   :   O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d  -
- t y p e   O S G e o . M a p G u i d e . M g W e b H e l p C o m m a n d   :   O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t U r l ( )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b I n f o r m a t i o n P a n e   :   O S G e o . M a p G u i d e . M g W e b U i S i z a b l e P a n e  -
-         [ M e t h o d ]   B o o l e a n   I s L e g e n d B a n d V i s i b l e ( )  -
-         [ M e t h o d ]   B o o l e a n   I s P r o p e r t i e s B a n d V i s i b l e ( )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b I n v o k e S c r i p t C o m m a n d   :   O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S c r i p t C o d e ( )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b I n v o k e U r l C o m m a n d   :   O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d  -
-         [ M e t h o d ]   B o o l e a n   D i s a b l e d I f S e l e c t i o n E m p t y ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t L a y e r C o u n t ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t L a y e r N a m e A t ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t P a r a m e t e r C o u n t ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t P a r a m e t e r N a m e A t ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t P a r a m e t e r V a l u e A t ( I n t 3 2 )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b L a y o u t   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ C o n s t r u c t o r ]   V o i d   . c t o r ( O S G e o . M a p G u i d e . M g R e s o u r c e S e r v i c e ,   O S G e o . M a p G u i d e . M g R e s o u r c e I d e n t i f i e r )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t A j a x P r e v i e w U r l ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g P o i n t   G e t C e n t e r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W e b C o m m a n d C o l l e c t i o n   G e t C o m m a n d s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W e b C o n t e x t M e n u   G e t C o n t e x t M e n u ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t D w f P r e v i e w U r l ( )  -
-         [ M e t h o d ]   B o o l e a n   G e t E n a b l e P i n g S e r v e r ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t H y p e r l i n k T a r g e t ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t H y p e r l i n k T a r g e t F r a m e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W e b I n f o r m a t i o n P a n e   G e t I n f o r m a t i o n P a n e ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t M a p D e f i n i t i o n ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t M a p I m a g e F o r m a t ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t P o i n t S e l e c t i o n B u f f e r ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S e l e c t i o n C o l o r ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S e l e c t i o n I m a g e F o r m a t ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t S t a r t u p S c r i p t ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W e b U i P a n e   G e t S t a t u s B a r ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W e b T a s k P a n e   G e t T a s k P a n e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W e b T o o l B a r   G e t T o o l B a r ( )  -
-         [ M e t h o d ]   B o o l e a n   I s Z o o m C o n t r o l V i s i b l e ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g B y t e R e a d e r   P r o c e s s G e t t i n g S t a r t e d P a g e ( O S G e o . M a p G u i d e . M g B y t e R e a d e r ,   B o o l e a n )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b M e a s u r e C o m m a n d   :   O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d  -
- t y p e   O S G e o . M a p G u i d e . M g W e b P r i n t C o m m a n d   :   O S G e o . M a p G u i d e . M g W e b C o m m a n d  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t P r i n t L a y o u t A t ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   G e t P r i n t L a y o u t C o u n t ( )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b S e a r c h C o m m a n d   :   O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t C o l u m n D i s p l a y N a m e A t ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t C o l u m n P r o p e r t y N a m e A t ( I n t 3 2 )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t F i l t e r ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t L a y e r ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t M a t c h L i m i t ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t P r o m p t ( )  -
-         [ M e t h o d ]   I n t 3 2   G e t R e s u l t C o l u m n C o u n t ( )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b S e l e c t W i t h i n C o m m a n d   :   O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d  -
- t y p e   O S G e o . M a p G u i d e . M g W e b S e p a r a t o r W i d g e t   :   O S G e o . M a p G u i d e . M g W e b W i d g e t  -
- t y p e   O S G e o . M a p G u i d e . M g W e b T a s k B a r   :   O S G e o . M a p G u i d e . M g W e b U i P a n e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W e b W i d g e t C o l l e c t i o n   G e t T a s k B u t t o n s ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W e b W i d g e t C o l l e c t i o n   G e t T a s k L i s t ( )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b T a s k B a r W i d g e t   :   O S G e o . M a p G u i d e . M g W e b W i d g e t  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t T o o l t i p ( )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b T a s k P a n e   :   O S G e o . M a p G u i d e . M g W e b U i S i z a b l e P a n e  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t I n i t i a l T a s k U r l ( )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W e b T a s k B a r   G e t T a s k B a r ( )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b T o o l B a r   :   O S G e o . M a p G u i d e . M g W e b U i P a n e  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W e b W i d g e t C o l l e c t i o n   G e t W i d g e t s ( )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b U i P a n e   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
- t y p e   O S G e o . M a p G u i d e . M g W e b U i S i z a b l e P a n e   :   O S G e o . M a p G u i d e . M g W e b U i P a n e  -
- t y p e   O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d   :   O S G e o . M a p G u i d e . M g W e b C o m m a n d  -
-         [ M e t h o d ]   I n t 3 2   G e t T a r g e t ( )  -
-         [ M e t h o d ]   S y s t e m . S t r i n g   G e t T a r g e t N a m e ( )  -
- t y p e   O S G e o . M a p G u i d e . M g W e b V i e w O p t i o n s C o m m a n d   :   O S G e o . M a p G u i d e . M g W e b U i T a r g e t C o m m a n d  -
- t y p e   O S G e o . M a p G u i d e . M g W e b W i d g e t   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
- t y p e   O S G e o . M a p G u i d e . M g W e b W i d g e t C o l l e c t i o n   :   O S G e o . M a p G u i d e . M g G u a r d D i s p o s a b l e  -
-         [ M e t h o d ]   B o o l e a n   C o n t a i n s ( O S G e o . M a p G u i d e . M g W e b W i d g e t )  -
-         [ M e t h o d ]   O S G e o . M a p G u i d e . M g W e b W i d g e t   G e t W i d g e t ( I n t 3 2 )  -
-         [ M e t h o d ]   I n t 3 2   I n d e x O f ( O S G e o . M a p G u i d e . M g W e b W i d g e t )  -
\ No newline at end of file
+ÿþA
Modified: branches/4.0/MgDev/Bindings/src/ApiDump/api.java.txt
--- branches/4.0/MgDev/Bindings/src/ApiDump/api.java.txt	2026-11-10 07:15:37 UTC (rev 10282)
+++ branches/4.0/MgDev/Bindings/src/ApiDump/api.java.txt	2026-11-11 12:20:53 UTC (rev 10283)
@@ -1,9409 +1,4704 @@
-ÿþC o m p i l e d   f r o m   " A p p T h r o w a b l e . j a v a "  -
- c l a s s   o r g . o s g e o . m a p g u i d e . A p p T h r o w a b l e   e x t e n d s   j a v a . l a n g . R u n t i m e E x c e p t i o n   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . A p p T h r o w a b l e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . A p p T h r o w a b l e ( l o n g ,   b o o l e a n ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t M e s s a g e ( ) ;  -
-     p u b l i c   v o i d   p r i n t S t a c k T r a c e ( ) ;  -
-     p u b l i c   v o i d   d e l e t e ( ) ;  -
- C o m p i l e d   f r o m   " M a p G u i d e J a v a A p i . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M a p G u i d e J a v a A p i   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M a p G u i d e J a v a A p i ( ) ;  -
-     p u b l i c   s t a t i c   v o i d   m g I n i t i a l i z e W e b T i e r ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g A g f R e a d e r W r i t e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g A g f R e a d e r W r i t e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   s y n c h r o n i z e d   v o i d   d e l e t e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g A g f R e a d e r W r i t e r ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   r e a d ( o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   r e a d ( o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ,   o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   w r i t e ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   w r i t e ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ,   o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ;  -
- C o m p i l e d   f r o m   " M g A g g r e g a t e G e o m e t r y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g A g g r e g a t e G e o m e t r y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   {  -
-     p u b l i c   i n t   g e t C o u n t ( ) ;  -
- C o m p i l e d   f r o m   " M g A r c S e g m e n t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g A r c S e g m e n t   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t   {  -
-     p u b l i c   i n t   g e t C o m p o n e n t T y p e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t C o n t r o l C o o r d i n a t e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t S t a r t C o o r d i n a t e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t E n d C o o r d i n a t e ( ) ;  -
-     p u b l i c   i n t   g e t D i m e n s i o n ( ) ;  -
-     p u b l i c   b o o l e a n   i s E m p t y ( ) ;  -
-     p u b l i c   b o o l e a n   i s C l o s e d ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y   c o p y ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y   t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ;  -
- C o m p i l e d   f r o m   " M g B a s e 6 4 . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g B a s e 6 4 $ I n p u t S t r e a m   e x t e n d s   j a v a . i o . F i l t e r I n p u t S t r e a m   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B a s e 6 4 $ I n p u t S t r e a m ( j a v a . i o . I n p u t S t r e a m ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B a s e 6 4 $ I n p u t S t r e a m ( j a v a . i o . I n p u t S t r e a m ,   i n t ) ;  -
-     p u b l i c   i n t   r e a d ( )   t h r o w s   j a v a . i o . I O E x c e p t i o n ;  -
-     p u b l i c   i n t   r e a d ( b y t e [ ] ,   i n t ,   i n t )   t h r o w s   j a v a . i o . I O E x c e p t i o n ;  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g B a s e 6 4 $ O u t p u t S t r e a m   e x t e n d s   j a v a . i o . F i l t e r O u t p u t S t r e a m   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B a s e 6 4 $ O u t p u t S t r e a m ( j a v a . i o . O u t p u t S t r e a m ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B a s e 6 4 $ O u t p u t S t r e a m ( j a v a . i o . O u t p u t S t r e a m ,   i n t ) ;  -
-     p u b l i c   v o i d   w r i t e ( i n t )   t h r o w s   j a v a . i o . I O E x c e p t i o n ;  -
-     p u b l i c   v o i d   w r i t e ( b y t e [ ] ,   i n t ,   i n t )   t h r o w s   j a v a . i o . I O E x c e p t i o n ;  -
-     p u b l i c   v o i d   f l u s h B a s e 6 4 ( )   t h r o w s   j a v a . i o . I O E x c e p t i o n ;  -
-     p u b l i c   v o i d   c l o s e ( )   t h r o w s   j a v a . i o . I O E x c e p t i o n ;  -
-     p u b l i c   v o i d   s u s p e n d E n c o d i n g ( )   t h r o w s   j a v a . i o . I O E x c e p t i o n ;  -
-     p u b l i c   v o i d   r e s u m e E n c o d i n g ( ) ;  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g B a s e 6 4   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N O _ O P T I O N S   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E N C O D E   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D E C O D E   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G Z I P   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D O N T _ B R E A K _ L I N E S   =   8 ;  -
-     p u b l i c   s t a t i c   j a v a . l a n g . S t r i n g   e n c o d e O b j e c t ( j a v a . i o . S e r i a l i z a b l e ) ;  -
-     p u b l i c   s t a t i c   j a v a . l a n g . S t r i n g   e n c o d e O b j e c t ( j a v a . i o . S e r i a l i z a b l e ,   i n t ) ;  -
-     p u b l i c   s t a t i c   j a v a . l a n g . S t r i n g   e n c o d e B y t e s ( b y t e [ ] ) ;  -
-     p u b l i c   s t a t i c   j a v a . l a n g . S t r i n g   e n c o d e B y t e s ( b y t e [ ] ,   i n t ) ;  -
-     p u b l i c   s t a t i c   j a v a . l a n g . S t r i n g   e n c o d e B y t e s ( b y t e [ ] ,   i n t ,   i n t ) ;  -
-     p u b l i c   s t a t i c   j a v a . l a n g . S t r i n g   e n c o d e B y t e s ( b y t e [ ] ,   i n t ,   i n t ,   i n t ) ;  -
-     p u b l i c   s t a t i c   b y t e [ ]   d e c o d e ( b y t e [ ] ,   i n t ,   i n t ) ;  -
-     p u b l i c   s t a t i c   b y t e [ ]   d e c o d e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   s t a t i c   j a v a . l a n g . O b j e c t   d e c o d e T o O b j e c t ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   s t a t i c   b o o l e a n   e n c o d e T o F i l e ( b y t e [ ] ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   s t a t i c   b o o l e a n   d e c o d e T o F i l e ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   s t a t i c   b y t e [ ]   d e c o d e F r o m F i l e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   s t a t i c   j a v a . l a n g . S t r i n g   e n c o d e F r o m F i l e ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g B a t c h P r o p e r t y C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ;  -
-     p u b l i c   v o i d   a d d I t e m ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n   g e t I t e m ( i n t ) ;  -
-     p u b l i c   v o i d   c l e a r ( ) ;  -
-     p u b l i c   v o i d   r e m o v e A t ( i n t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   t o X m l ( ) ;  -
- C o m p i l e d   f r o m   " M g B l o b P r o p e r t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g B l o b P r o p e r t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B l o b P r o p e r t y ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t V a l u e ( ) ;  -
-     p u b l i c   s h o r t   g e t P r o p e r t y T y p e ( ) ;  -
-     p u b l i c   v o i d   s e t V a l u e ( o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ;  -
- C o m p i l e d   f r o m   " M g B o o l e a n P r o p e r t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g B o o l e a n P r o p e r t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B o o l e a n P r o p e r t y ( j a v a . l a n g . S t r i n g ,   b o o l e a n ) ;  -
-     p u b l i c   b o o l e a n   g e t V a l u e ( ) ;  -
-     p u b l i c   v o i d   s e t V a l u e ( b o o l e a n ) ;  -
- C o m p i l e d   f r o m   " M g B y t e P r o p e r t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g B y t e P r o p e r t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e P r o p e r t y ( j a v a . l a n g . S t r i n g ,   b y t e ) ;  -
-     p u b l i c   b y t e   g e t V a l u e ( ) ;  -
-     p u b l i c   v o i d   s e t V a l u e ( b y t e ) ;  -
- C o m p i l e d   f r o m   " M g B y t e R e a d e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ( b y t e [ ] ,   i n t ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   r e a d ( b y t e [ ] ,   i n t ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t M i m e T y p e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   t o S t r i n g ( ) ;  -
-     p u b l i c   v o i d   t o F i l e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   l o n g   g e t L e n g t h ( ) ;  -
-     p u b l i c   b o o l e a n   i s R e w i n d a b l e ( ) ;  -
-     p u b l i c   v o i d   r e w i n d ( ) ;  -
- C o m p i l e d   f r o m   " M g B y t e S i n k . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g B y t e S i n k   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e S i n k ( o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ;  -
- C o m p i l e d   f r o m   " M g B y t e S o u r c e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g B y t e S o u r c e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e S o u r c e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e S o u r c e ( b y t e [ ] ,   i n t ) ;  -
-     p u b l i c   v o i d   s e t M i m e T y p e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t R e a d e r ( ) ;  -
- C o m p i l e d   f r o m   " M g C l a s s D e f i n i t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e   {  -
-     p u b l i c   b o o l e a n   e q u a l s ( j a v a . l a n g . O b j e c t ) ;  -
-     p u b l i c   i n t   h a s h C o d e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n   g e t P r o p e r t i e s ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n   g e t I d e n t i t y P r o p e r t i e s ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D e f a u l t G e o m e t r y P r o p e r t y N a m e ( ) ;  -
-     p u b l i c   v o i d   s e t D e f a u l t G e o m e t r y P r o p e r t y N a m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t N a m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t N a m e ( ) ;  -
-     p u b l i c   v o i d   s e t D e s c r i p t i o n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D e s c r i p t i o n ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n   g e t B a s e C l a s s D e f i n i t i o n ( ) ;  -
-     p u b l i c   b o o l e a n   i s C o m p u t e d ( ) ;  -
-     p u b l i c   b o o l e a n   i s A b s t r a c t ( ) ;  -
-     p u b l i c   v o i d   m a r k A s D e l e t e d ( ) ;  -
- C o m p i l e d   f r o m   " M g C l a s s D e f i n i t i o n C o l l e c t i o n . j a v a "  -
- c l a s s   o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n $ I t e m I t e r a t o r   i m p l e m e n t s   j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n >   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n $ I t e m I t e r a t o r ( o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n ) ;  -
-     p u b l i c   b o o l e a n   h a s N e x t ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n   n e x t ( ) ;  -
-     p u b l i c   v o i d   r e m o v e ( ) ;  -
-     p u b l i c   j a v a . l a n g . O b j e c t   n e x t ( ) ;  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n   i m p l e m e n t s   j a v a . u t i l . C o l l e c t i o n < o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n >   {  -
-     p u b l i c   j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n >   i t e r a t o r ( ) ;  -
-     p u b l i c   b o o l e a n   a d d ( o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ) ;  -
-     p u b l i c   b o o l e a n   a d d A l l ( j a v a . u t i l . C o l l e c t i o n < ?   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n > ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( j a v a . l a n g . O b j e c t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( j a v a . l a n g . O b j e c t ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ;  -
-     p u b l i c   b o o l e a n   r e t a i n A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ;  -
-     p u b l i c   i n t   s i z e ( ) ;  -
-     p u b l i c   j a v a . l a n g . O b j e c t [ ]   t o A r r a y ( ) ;  -
-     p u b l i c   < M g C l a s s D e f i n i t i o n >   M g C l a s s D e f i n i t i o n [ ]   t o A r r a y ( M g C l a s s D e f i n i t i o n [ ] ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ) ;  -
-     p u b l i c   v o i d   a d d I t e m ( o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n   g e t I t e m ( i n t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ) ;  -
-     p u b l i c   b o o l e a n   a d d ( j a v a . l a n g . O b j e c t ) ;  -
- C o m p i l e d   f r o m   " M g C l o b P r o p e r t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C l o b P r o p e r t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C l o b P r o p e r t y ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ;  -
- C o m p i l e d   f r o m   " M g C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
- C o m p i l e d   f r o m   " M g C o l o r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o l o r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o l o r ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o l o r ( s h o r t ,   s h o r t ,   s h o r t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o l o r ( s h o r t ,   s h o r t ,   s h o r t ,   s h o r t ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t C o l o r ( ) ;  -
-     p u b l i c   s h o r t   g e t R e d ( ) ;  -
-     p u b l i c   s h o r t   g e t B l u e ( ) ;  -
-     p u b l i c   s h o r t   g e t G r e e n ( ) ;  -
-     p u b l i c   s h o r t   g e t A l p h a ( ) ;  -
- C o m p i l e d   f r o m   " M g C o n f i g P r o p e r t i e s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o n f i g P r o p e r t i e s   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t C o n f i g u r a t i o n F i l e n a m e   =   " w e b c o n f i g . i n i " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S e r v e r C o n f i g u r a t i o n F i l e n a m e   =   " s e r v e r c o n f i g . i n i " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t i e s S e c t i o n   =   " G e n e r a l P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y C o n n e c t i o n T i m e o u t   =   " C o n n e c t i o n T i m e o u t " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t G e n e r a l P r o p e r t y C o n n e c t i o n T i m e o u t   =   1 2 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y C o n n e c t i o n T i m e r I n t e r v a l   =   " C o n n e c t i o n T i m e r I n t e r v a l " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t G e n e r a l P r o p e r t y C o n n e c t i o n T i m e r I n t e r v a l   =   6 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y L o c a l e   =   " L o c a l e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y L o c a l e   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y D e f a u l t M e s s a g e L o c a l e   =   " D e f a u l t M e s s a g e L o c a l e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y D e f a u l t M e s s a g e L o c a l e   =   " e n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y D i s p l a y N a m e   =   " D i s p l a y N a m e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y D i s p l a y N a m e   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y F d o P a t h   =   " F d o P a t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y F d o P a t h   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y M e n t o r D i c t i o n a r y P a t h   =   " M e n t o r D i c t i o n a r y P a t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y M e n t o r D i c t i o n a r y P a t h   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y M e n t o r U s e r D i c t i o n a r y P a t h   =   " M e n t o r U s e r D i c t i o n a r y P a t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y M e n t o r U s e r D i c t i o n a r y P a t h   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y L i c e n s e S e r v e r P a t h   =   " L i c e n s e S e r v e r P a t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y L i c e n s e S e r v e r P a t h   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y L i n u x M e m D e b u g   =   " L i n u x M e m D e b u g " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t G e n e r a l P r o p e r t y L i n u x M e m D e b u g   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y L i n u x F o n t D i r e c t o r i e s   =   " L i n u x F o n t D i r e c t o r i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y L i n u x F o n t D i r e c t o r i e s   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y L o g s D e l i m i t e r   =   " L o g s D e l i m i t e r " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y L o g s D e l i m i t e r   =   " \ t " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y L o g s D e t a i l   =   " L o g s D e t a i l " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y L o g s D e t a i l   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y L o g s P a t h   =   " L o g s P a t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y L o g s P a t h   =   " L o g s / " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y M a c h i n e I p   =   " M a c h i n e I p " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y M a c h i n e I p   =   " 1 2 7 . 0 . 0 . 1 " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y M a x L o g F i l e S i z e   =   " M a x L o g F i l e S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t G e n e r a l P r o p e r t y M a x L o g F i l e S i z e   =   6 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y M a x L o g F i l e S i z e E n a b l e d   =   " M a x L o g F i l e S i z e E n a b l e d " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t G e n e r a l P r o p e r t y M a x L o g F i l e S i z e E n a b l e d   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y R e s o u r c e s P a t h   =   " R e s o u r c e s P a t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y R e s o u r c e s P a t h   =   " R e s o u r c e s / " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y S e r i a l N u m b e r   =   " S e r i a l N u m b e r " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y S e r i a l N u m b e r   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y S e r v i c e R e g i s t r a t i o n T i m e r I n t e r v a l   =   " S e r v i c e R e g i s t r a t i o n T i m e r I n t e r v a l " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t G e n e r a l P r o p e r t y S e r v i c e R e g i s t r a t i o n T i m e r I n t e r v a l   =   6 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y T c p I p M t u   =   " T c p I p M t u " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t G e n e r a l P r o p e r t y T c p I p M t u   =   1 4 6 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y T e m p P a t h   =   " T e m p P a t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y T e m p P a t h   =   " T e m p / " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y W f s D o c u m e n t P a t h   =   " W f s D o c u m e n t P a t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y W f s D o c u m e n t P a t h   =   " W f s / " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y W m s D o c u m e n t P a t h   =   " W m s D o c u m e n t P a t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y W m s D o c u m e n t P a t h   =   " W m s / " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G e n e r a l P r o p e r t y P r e C a c h e M a p s   =   " P r e C a c h e M a p s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t G e n e r a l P r o p e r t y P r e C a c h e M a p s   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t i e s S e c t i o n   =   " A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y E m a i l   =   " E m a i l " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y E m a i l   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s   =   " M a x C o n n e c t i o n s " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s   =   2 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y P o r t   =   " P o r t " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y P o r t   =   5 5 5 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y Q u e u e S i z e   =   " Q u e u e S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y Q u e u e S i z e   =   1 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e   =   " T h r e a d P o o l S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t A d m i n i s t r a t i v e C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   C l i e n t C o n n e c t i o n P r o p e r t i e s S e c t i o n   =   " C l i e n t C o n n e c t i o n P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   C l i e n t C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s   =   " M a x C o n n e c t i o n s " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t C l i e n t C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s   =   1 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   C l i e n t C o n n e c t i o n P r o p e r t y P o r t   =   " P o r t " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t C l i e n t C o n n e c t i o n P r o p e r t y P o r t   =   4 4 4 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   C l i e n t C o n n e c t i o n P r o p e r t y Q u e u e S i z e   =   " Q u e u e S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t C l i e n t C o n n e c t i o n P r o p e r t y Q u e u e S i z e   =   1 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   C l i e n t C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e   =   " T h r e a d P o o l S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t C l i e n t C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e   =   1 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S i t e C o n n e c t i o n P r o p e r t i e s S e c t i o n   =   " S i t e C o n n e c t i o n P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S i t e C o n n e c t i o n P r o p e r t y I p A d d r e s s   =   " I p A d d r e s s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t S i t e C o n n e c t i o n P r o p e r t y I p A d d r e s s   =   " 1 2 7 . 0 . 0 . 1 " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S i t e C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s   =   " M a x C o n n e c t i o n s " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t S i t e C o n n e c t i o n P r o p e r t y M a x C o n n e c t i o n s   =   2 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S i t e C o n n e c t i o n P r o p e r t y P o r t   =   " P o r t " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t S i t e C o n n e c t i o n P r o p e r t y P o r t   =   3 3 3 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S i t e C o n n e c t i o n P r o p e r t y Q u e u e S i z e   =   " Q u e u e S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t S i t e C o n n e c t i o n P r o p e r t y Q u e u e S i z e   =   1 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S i t e C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e   =   " T h r e a d P o o l S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t S i t e C o n n e c t i o n P r o p e r t y T h r e a d P o o l S i z e   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   H o s t P r o p e r t i e s S e c t i o n   =   " H o s t P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   H o s t P r o p e r t y D r a w i n g S e r v i c e   =   " D r a w i n g S e r v i c e " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t H o s t P r o p e r t y D r a w i n g S e r v i c e   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   H o s t P r o p e r t y F e a t u r e S e r v i c e   =   " F e a t u r e S e r v i c e " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t H o s t P r o p e r t y F e a t u r e S e r v i c e   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   H o s t P r o p e r t y K m l S e r v i c e   =   " K m l S e r v i c e " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t H o s t P r o p e r t y K m l S e r v i c e   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   H o s t P r o p e r t y M a p p i n g S e r v i c e   =   " M a p p i n g S e r v i c e " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t H o s t P r o p e r t y M a p p i n g S e r v i c e   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   H o s t P r o p e r t y R e n d e r i n g S e r v i c e   =   " R e n d e r i n g S e r v i c e " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t H o s t P r o p e r t y R e n d e r i n g S e r v i c e   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   H o s t P r o p e r t y R e s o u r c e S e r v i c e   =   " R e s o u r c e S e r v i c e " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t H o s t P r o p e r t y R e s o u r c e S e r v i c e   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   H o s t P r o p e r t y P r o f i l i n g S e r v i c e   =   " P r o f i l i n g S e r v i c e " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t H o s t P r o p e r t y P r o f i l i n g S e r v i c e   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   H o s t P r o p e r t y S i t e S e r v i c e   =   " S i t e S e r v i c e " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t H o s t P r o p e r t y S i t e S e r v i c e   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   H o s t P r o p e r t y T i l e S e r v i c e   =   " T i l e S e r v i c e " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t H o s t P r o p e r t y T i l e S e r v i c e   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D r a w i n g S e r v i c e P r o p e r t i e s S e c t i o n   =   " D r a w i n g S e r v i c e P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S e r v i c e P r o p e r t i e s S e c t i o n   =   " F e a t u r e S e r v i c e P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y C a c h e S i z e   =   " C a c h e S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y C a c h e S i z e   =   1 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y C a c h e T i m e L i m i t   =   " C a c h e T i m e L i m i t " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y C a c h e T i m e L i m i t   =   8 6 4 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y C a c h e T i m e r I n t e r v a l   =   " C a c h e T i m e r I n t e r v a l " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y C a c h e T i m e r I n t e r v a l   =   3 6 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a C a c h e S i z e   =   " D a t a C a c h e S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C a c h e S i z e   =   1 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l E n a b l e d   =   " D a t a C o n n e c t i o n P o o l E n a b l e d " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l E n a b l e d   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l E x c l u d e d P r o v i d e r s   =   " D a t a C o n n e c t i o n P o o l E x c l u d e d P r o v i d e r s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l E x c l u d e d P r o v i d e r s   =   " O S G e o . S D F , O S G e o . S H P " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l S i z e   =   " D a t a C o n n e c t i o n P o o l S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l S i z e   =   5 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l S i z e C u s t o m   =   " D a t a C o n n e c t i o n P o o l S i z e C u s t o m " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n P o o l S i z e C u s t o m   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n T i m e o u t   =   " D a t a C o n n e c t i o n T i m e o u t " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n T i m e o u t   =   6 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n T i m e r I n t e r v a l   =   " D a t a C o n n e c t i o n T i m e r I n t e r v a l " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n T i m e r I n t e r v a l   =   6 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y J o i n Q u e r y B a t c h S i z e   =   " J o i n Q u e r y B a t c h S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y J o i n Q u e r y B a t c h S i z e   =   1 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n U s e L i m i t   =   " D a t a C o n n e c t i o n U s e L i m i t " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a C o n n e c t i o n U s e L i m i t   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a T r a n s a c t i o n T i m e o u t   =   " D a t a T r a n s a c t i o n T i m e o u t " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a T r a n s a c t i o n T i m e o u t   =   3 6 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y D a t a T r a n s a c t i o n T i m e r I n t e r v a l   =   " D a t a T r a n s a c t i o n T i m e r I n t e r v a l " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y D a t a T r a n s a c t i o n T i m e r I n t e r v a l   =   6 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y F D O C o n n e c t i o n T i m e o u t C u s t o m   =   " F D O C o n n e c t i o n T i m e o u t C u s t o m " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y F D O C o n n e c t i o n T i m e o u t C u s t o m   =   " O S G e o . W M S : 1 2 0 " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S e r v i c e P r o p e r t y U s e F d o J o i n O p t i m i z a t i o n   =   " U s e F d o J o i n O p t i m i z a t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t F e a t u r e S e r v i c e P r o p e r t y U s e F d o J o i n O p t i m i z a t i o n   =   t r u e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M a p p i n g S e r v i c e P r o p e r t i e s S e c t i o n   =   " M a p p i n g S e r v i c e P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M a p p i n g S e r v i c e P r o p e r t y L e g e n d F o n t   =   " L e g e n d F o n t " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t M a p p i n g S e r v i c e P r o p e r t y L e g e n d F o n t   =   " A r i a l " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t i e s S e c t i o n   =   " R e n d e r i n g S e r v i c e P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y T i l e E x t e n t O f f s e t   =   " T i l e E x t e n t O f f s e t " ;  -
-     p u b l i c   s t a t i c   f i n a l   d o u b l e   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y T i l e E x t e n t O f f s e t   =   0 . 3 5 d ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e   =   " R a s t e r G r i d S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e   =   1 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y M i n R a s t e r G r i d S i z e   =   " M i n R a s t e r G r i d S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M i n R a s t e r G r i d S i z e   =   1 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e O v e r r i d e R a t i o   =   " R a s t e r G r i d S i z e O v e r r i d e R a t i o " ;  -
-     p u b l i c   s t a t i c   f i n a l   d o u b l e   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e O v e r r i d e R a t i o   =   0 . 2 5 d ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e F o r P l o t   =   " R a s t e r G r i d S i z e F o r P l o t " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e F o r P l o t   =   5 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y M i n R a s t e r G r i d S i z e F o r P l o t   =   " M i n R a s t e r G r i d S i z e F o r P l o t " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M i n R a s t e r G r i d S i z e F o r P l o t   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e O v e r r i d e R a t i o F o r P l o t   =   " R a s t e r G r i d S i z e O v e r r i d e R a t i o F o r P l o t " ;  -
-     p u b l i c   s t a t i c   f i n a l   d o u b l e   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R a s t e r G r i d S i z e O v e r r i d e R a t i o F o r P l o t   =   0 . 1 d ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y R e n d e r S e l e c t i o n B a t c h S i z e   =   " R e n d e r S e l e c t i o n B a t c h S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y R e n d e r S e l e c t i o n B a t c h S i z e   =   1 0 0 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y C l a m p P o i n t s   =   " C l a m p P o i n t s " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y C l a m p P o i n t s   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y G e n e r a l i z e D a t a   =   " G e n e r a l i z e D a t a " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y G e n e r a l i z e D a t a   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y M a x R a s t e r I m a g e W i d t h   =   " M a x R a s t e r I m a g e W i d t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M a x R a s t e r I m a g e W i d t h   =   2 0 4 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y M a x R a s t e r I m a g e H e i g h t   =   " M a x R a s t e r I m a g e H e i g h t " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M a x R a s t e r I m a g e H e i g h t   =   2 0 4 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y M a x R e n d e r I m a g e W i d t h   =   " M a x R e n d e r I m a g e W i d t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M a x R e n d e r I m a g e W i d t h   =   1 6 3 8 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t y M a x R e n d e r I m a g e H e i g h t   =   " M a x R e n d e r I m a g e H e i g h t " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t y M a x R e n d e r I m a g e H e i g h t   =   1 6 3 8 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e n d e r i n g S e r v i c e P r o p e r t i e s G l o b a l R a s t e r S t y l i z a t i o n L o c k E n a b l e d   =   " G l o b a l R a s t e r S t y l i z a t i o n L o c k E n a b l e d " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t R e n d e r i n g S e r v i c e P r o p e r t i e s G l o b a l R a s t e r S t y l i z a t i o n L o c k E n a b l e d   =   t r u e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F o n t A l i a s M a p p i n g S e c t i o n   =   " F o n t A l i a s e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   U n m a n a g e d D a t a M a p p i n g s S e c t i o n   =   " U n m a n a g e d D a t a M a p p i n g s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t i e s S e c t i o n   =   " R e s o u r c e S e r v i c e P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y L i b r a r y R e p o s i t o r y P a t h   =   " L i b r a r y R e p o s i t o r y P a t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y L i b r a r y R e p o s i t o r y P a t h   =   " R e p o s i t o r i e s / L i b r a r y / " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y L i b r a r y R e s o u r c e D a t a F i l e P a t h   =   " L i b r a r y R e s o u r c e D a t a F i l e P a t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y L i b r a r y R e s o u r c e D a t a F i l e P a t h   =   " R e p o s i t o r i e s / L i b r a r y / D a t a F i l e s / " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y P a c k a g e s P a t h   =   " P a c k a g e s P a t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y P a c k a g e s P a t h   =   " P a c k a g e s / " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y R e p o s i t o r y C h e c k p o i n t s T i m e r I n t e r v a l   =   " R e p o s i t o r y C h e c k p o i n t s T i m e r I n t e r v a l " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e p o s i t o r y C h e c k p o i n t s T i m e r I n t e r v a l   =   6 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e C h a n g e T i m e r I n t e r v a l   =   " R e s o u r c e C h a n g e T i m e r I n t e r v a l " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e C h a n g e T i m e r I n t e r v a l   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e D a t a F i l e T r a s h F o l d e r N a m e   =   " R e s o u r c e D a t a F i l e T r a s h F o l d e r N a m e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e D a t a F i l e T r a s h F o l d e r N a m e   =   " T r a s h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e P e r m i s s i o n C a c h e S i z e   =   " R e s o u r c e P e r m i s s i o n C a c h e S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e P e r m i s s i o n C a c h e S i z e   =   1 0 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e S c h e m a F i l e P a t h   =   " R e s o u r c e S c h e m a F i l e P a t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y R e s o u r c e S c h e m a F i l e P a t h   =   " S c h e m a / " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y S e s s i o n R e p o s i t o r y P a t h   =   " S e s s i o n R e p o s i t o r y P a t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y S e s s i o n R e p o s i t o r y P a t h   =   " R e p o s i t o r i e s / S e s s i o n / " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y S e s s i o n R e s o u r c e D a t a F i l e P a t h   =   " S e s s i o n R e s o u r c e D a t a F i l e P a t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y S e s s i o n R e s o u r c e D a t a F i l e P a t h   =   " R e p o s i t o r i e s / S e s s i o n / D a t a F i l e s / " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R e s o u r c e S e r v i c e P r o p e r t y S i t e R e p o s i t o r y P a t h   =   " S i t e R e p o s i t o r y P a t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t R e s o u r c e S e r v i c e P r o p e r t y S i t e R e p o s i t o r y P a t h   =   " R e p o s i t o r i e s / S i t e / " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S i t e S e r v i c e P r o p e r t i e s S e c t i o n   =   " S i t e S e r v i c e P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S i t e S e r v i c e P r o p e r t y S e s s i o n T i m e o u t   =   " S e s s i o n T i m e o u t " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t S i t e S e r v i c e P r o p e r t y S e s s i o n T i m e o u t   =   1 2 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S i t e S e r v i c e P r o p e r t y S e s s i o n T i m e r I n t e r v a l   =   " S e s s i o n T i m e r I n t e r v a l " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t S i t e S e r v i c e P r o p e r t y S e s s i o n T i m e r I n t e r v a l   =   4 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T i l e S e r v i c e P r o p e r t i e s S e c t i o n   =   " T i l e S e r v i c e P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T i l e S e r v i c e P r o p e r t y R e n d e r O n l y   =   " R e n d e r O n l y " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t T i l e S e r v i c e P r o p e r t y R e n d e r O n l y   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T i l e S e r v i c e P r o p e r t y T i l e C a c h e P a t h   =   " T i l e C a c h e P a t h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e C a c h e P a t h   =   " R e p o s i t o r i e s / T i l e C a c h e / " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T i l e S e r v i c e P r o p e r t y T i l e C o l u m n s P e r F o l d e r   =   " T i l e C o l u m n s P e r F o l d e r " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e C o l u m n s P e r F o l d e r   =   3 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T i l e S e r v i c e P r o p e r t y T i l e R o w s P e r F o l d e r   =   " T i l e R o w s P e r F o l d e r " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e R o w s P e r F o l d e r   =   3 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T i l e S e r v i c e P r o p e r t y T i l e S i z e X   =   " D e f a u l t T i l e S i z e X " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e S i z e X   =   3 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T i l e S e r v i c e P r o p e r t y T i l e S i z e Y   =   " D e f a u l t T i l e S i z e Y " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t T i l e S e r v i c e P r o p e r t y T i l e S i z e Y   =   3 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T i l e S e r v i c e P r o p e r t y I m a g e F o r m a t   =   " I m a g e F o r m a t " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t T i l e S e r v i c e P r o p e r t y I m a g e F o r m a t   =   " P N G " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A c c e s s L o g P r o p e r t i e s S e c t i o n   =   " A c c e s s L o g P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A c c e s s L o g P r o p e r t y E n a b l e d   =   " E n a b l e d " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t A c c e s s L o g P r o p e r t y E n a b l e d   =   t r u e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A c c e s s L o g P r o p e r t y F i l e n a m e   =   " F i l e n a m e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t A c c e s s L o g P r o p e r t y F i l e n a m e   =   " A c c e s s . l o g " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A c c e s s L o g P r o p e r t y P a r a m e t e r s   =   " P a r a m e t e r s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t A c c e s s L o g P r o p e r t y P a r a m e t e r s   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A d m i n L o g P r o p e r t i e s S e c t i o n   =   " A d m i n L o g P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A d m i n L o g P r o p e r t y E n a b l e d   =   " E n a b l e d " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t A d m i n L o g P r o p e r t y E n a b l e d   =   t r u e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A d m i n L o g P r o p e r t y F i l e n a m e   =   " F i l e n a m e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t A d m i n L o g P r o p e r t y F i l e n a m e   =   " A d m i n . l o g " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A d m i n L o g P r o p e r t y P a r a m e t e r s   =   " P a r a m e t e r s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t A d m i n L o g P r o p e r t y P a r a m e t e r s   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A u t h e n t i c a t i o n L o g P r o p e r t i e s S e c t i o n   =   " A u t h e n t i c a t i o n L o g P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A u t h e n t i c a t i o n L o g P r o p e r t y E n a b l e d   =   " E n a b l e d " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t A u t h e n t i c a t i o n L o g P r o p e r t y E n a b l e d   =   t r u e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A u t h e n t i c a t i o n L o g P r o p e r t y F i l e n a m e   =   " F i l e n a m e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t A u t h e n t i c a t i o n L o g P r o p e r t y F i l e n a m e   =   " A u t h e n t i c a t i o n . l o g " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A u t h e n t i c a t i o n L o g P r o p e r t y P a r a m e t e r s   =   " P a r a m e t e r s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t A u t h e n t i c a t i o n L o g P r o p e r t y P a r a m e t e r s   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   E r r o r L o g P r o p e r t i e s S e c t i o n   =   " E r r o r L o g P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   E r r o r L o g P r o p e r t y E n a b l e d   =   " E n a b l e d " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t E r r o r L o g P r o p e r t y E n a b l e d   =   t r u e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   E r r o r L o g P r o p e r t y F i l e n a m e   =   " F i l e n a m e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t E r r o r L o g P r o p e r t y F i l e n a m e   =   " E r r o r . l o g " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   E r r o r L o g P r o p e r t y P a r a m e t e r s   =   " P a r a m e t e r s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t E r r o r L o g P r o p e r t y P a r a m e t e r s   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P e r f o r m a n c e L o g P r o p e r t i e s S e c t i o n   =   " P e r f o r m a n c e L o g P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P e r f o r m a n c e L o g P r o p e r t y E n a b l e d   =   " E n a b l e d " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t P e r f o r m a n c e L o g P r o p e r t y E n a b l e d   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P e r f o r m a n c e L o g P r o p e r t y F i l e n a m e   =   " F i l e n a m e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t P e r f o r m a n c e L o g P r o p e r t y F i l e n a m e   =   " P e r f o r m a n c e . l o g " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P e r f o r m a n c e L o g P r o p e r t y P a r a m e t e r s   =   " P a r a m e t e r s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t P e r f o r m a n c e L o g P r o p e r t y P a r a m e t e r s   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P e r f o r m a n c e L o g P r o p e r t y I n t e r v a l   =   " I n t e r v a l " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t P e r f o r m a n c e L o g P r o p e r t y I n t e r v a l   =   3 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S e s s i o n L o g P r o p e r t i e s S e c t i o n   =   " S e s s i o n L o g P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S e s s i o n L o g P r o p e r t y E n a b l e d   =   " E n a b l e d " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t S e s s i o n L o g P r o p e r t y E n a b l e d   =   t r u e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S e s s i o n L o g P r o p e r t y F i l e n a m e   =   " F i l e n a m e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t S e s s i o n L o g P r o p e r t y F i l e n a m e   =   " S e s s i o n . l o g " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S e s s i o n L o g P r o p e r t y P a r a m e t e r s   =   " P a r a m e t e r s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t S e s s i o n L o g P r o p e r t y P a r a m e t e r s   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T r a c e L o g P r o p e r t i e s S e c t i o n   =   " T r a c e L o g P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T r a c e L o g P r o p e r t y E n a b l e d   =   " E n a b l e d " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t T r a c e L o g P r o p e r t y E n a b l e d   =   t r u e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T r a c e L o g P r o p e r t y F i l e n a m e   =   " F i l e n a m e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t T r a c e L o g P r o p e r t y F i l e n a m e   =   " T r a c e . l o g " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T r a c e L o g P r o p e r t y P a r a m e t e r s   =   " P a r a m e t e r s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t T r a c e L o g P r o p e r t y P a r a m e t e r s   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D B E n v i r o n m e n t P r o p e r t i e s S e c t i o n   =   " D B E n v i r o n m e n t P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   L i b r a r y C a c h e S i z e P a r a m e t e r s   =   " L i b r a r y C a c h e S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t L i b r a r y C a c h e S i z e P a r a m e t e r s   =   3 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S e s s i o n C a c h e S i z e P a r a m t e r s   =   " S e s s i o n C a c h e S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t S e s s i o n C a c h e S i z e P a r a m t e r s   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D B P a g e S i z e P a r a m e t e r s   =   " D B P a g e S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t D B P a g e S i z e P a r a m e t e r s   =   3 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D B X M L P a g e S i z e P a r a m e t e r s   =   " D B X M L P a g e S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t D B X M L P a g e S i z e P a r a m e t e r s   =   3 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   L i b r a r y L o g B u f f e r S i z e P a r a m e t e r s   =   " L i b r a r y L o g B u f f e r S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t L i b r a r y L o g B u f f e r S i z e P a r a m e t e r s   =   1 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S e s s i o n L o g B u f f e r S i z e P a r a m e t e r s   =   " S e s s i o n L o g B u f f e r S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t S e s s i o n L o g B u f f e r S i z e P a r a m e t e r s   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D B M a x T r a n s a c t i o n s P a r a m t e r s   =   " D B M a x T r a n s a c t i o n s " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t D B M a x T r a n s a c t i o n s P a r a m t e r s   =   1 0 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S e s s i o n D B P a g e S i z e P a r a m e t e r s   =   " S e s s i o n D B P a g e S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t S e s s i o n D B P a g e S i z e P a r a m e t e r s   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S e s s i o n D B X M L P a g e S i z e P a r a m e t e r s   =   " S e s s i o n D B X M L P a g e S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   d o u b l e   D e f a u l t S e s s i o n D B X M L P a g e S i z e P a r a m e t e r s   =   0 . 5 d ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D B T i m e o u t P a r a m e t e r s   =   " D B T i m e o u t " ;  -
-     p u b l i c   s t a t i c   f i n a l   d o u b l e   D e f a u l t D B T i m e o u t P a r a m e t e r s   =   0 . 2 d ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D B M a x L o c k e r s P a r a m e t e r s   =   " D B M a x L o c k e r s " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t D B M a x L o c k e r s P a r a m e t e r s   =   1 0 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A g e n t P r o p e r t i e s S e c t i o n   =   " A g e n t P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A g e n t D e b u g P a u s e   =   " D e b u g P a u s e " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t A g e n t D e b u g P a u s e   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A g e n t D i s a b l e A u t h o r i n g   =   " D i s a b l e A u t h o r i n g " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A g e n t D i s a b l e W f s   =   " D i s a b l e W f s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A g e n t D i s a b l e W m s   =   " D i s a b l e W m s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A g e n t E r r o r L o g E n a b l e d   =   " E r r o r L o g E n a b l e d " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t A g e n t E r r o r L o g E n a b l e d   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A g e n t E r r o r L o g F i l e n a m e   =   " E r r o r L o g F i l e n a m e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t A g e n t E r r o r L o g F i l e n a m e   =   " E r r o r . l o g " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A g e n t R e q u e s t L o g E n a b l e d   =   " R e q u e s t L o g E n a b l e d " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t A g e n t R e q u e s t L o g E n a b l e d   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A g e n t R e q u e s t L o g F i l e n a m e   =   " R e q u e s t L o g F i l e n a m e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t A g e n t R e q u e s t L o g F i l e n a m e   =   " R e q u e s t . l o g " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A g e n t G l o b a l M a x F e a t u r e Q u e r y L i m i t   =   " G l o b a l M a x F e a t u r e Q u e r y L i m i t " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t A g e n t G l o b a l M a x F e a t u r e Q u e r y L i m i t   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A g e n t G l o b a l M a x M a p F e a t u r e Q u e r y L i m i t   =   " G l o b a l M a x M a p F e a t u r e Q u e r y L i m i t " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t A g e n t G l o b a l M a x M a p F e a t u r e Q u e r y L i m i t   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A g e n t A n o n y m o u s D e n y G e t R e s o u r c e C o n t e n t   =   " A n o n y m o u s D e n y G e t R e s o u r c e C o n t e n t " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t A g e n t A n o n y m o u s D e n y G e t R e s o u r c e C o n t e n t   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A g e n t A n o n y m o u s D e n y G e t R e s o u r c e D a t a   =   " A n o n y m o u s D e n y G e t R e s o u r c e D a t a " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t A g e n t A n o n y m o u s D e n y G e t R e s o u r c e D a t a   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A g e n t A n o n y m o u s D e n y G e t R e s o u r c e H e a d e r   =   " A n o n y m o u s D e n y G e t R e s o u r c e H e a d e r " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D e f a u l t A g e n t A n o n y m o u s D e n y G e t R e s o u r c e H e a d e r   =   " " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   O g c P r o p e r t i e s S e c t i o n   =   " O g c P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   W f s P a s s w o r d   =   " W f s P a s s w o r d " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   W m s P a s s w o r d   =   " W m s P a s s w o r d " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   C I T E W f s E n a b l e d   =   " C I T E W f s E n a b l e d " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t C I T E W f s E n a b l e d   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   C I T E W m s E n a b l e d   =   " C I T E W m s E n a b l e d " ;  -
-     p u b l i c   s t a t i c   f i n a l   b o o l e a n   D e f a u l t C I T E W m s E n a b l e d   =   f a l s e ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A g e n t G l o b a l G e t W f s F e a t u r e s L i m i t   =   " G l o b a l G e t W f s F e a t u r e s L i m i t " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t A g e n t G l o b a l G e t W f s F e a t u r e s L i m i t   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A g e n t G l o b a l G e t W m s F e a t u r e I n f o L i m i t   =   " G l o b a l G e t W m s F e a t u r e I n f o L i m i t " ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e f a u l t A g e n t G l o b a l G e t W m s F e a t u r e I n f o L i m i t   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   W e b A p p l i c a t i o n P r o p e r t i e s S e c t i o n   =   " W e b A p p l i c a t i o n P r o p e r t i e s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T e m p l a t e R o o t F o l d e r   =   " T e m p l a t e R o o t F o l d e r " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   W i d g e t I n f o F o l d e r   =   " W i d g e t I n f o F o l d e r " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   C o n t a i n e r I n f o F o l d e r   =   " C o n t a i n e r I n f o F o l d e r " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o n f i g P r o p e r t i e s ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   s y n c h r o n i z e d   v o i d   d e l e t e ( ) ;  -
-     p u b l i c   i n t   g e t D i m e n s i o n ( ) ;  -
-     p u b l i c   d o u b l e   g e t X ( ) ;  -
-     p u b l i c   d o u b l e   g e t Y ( ) ;  -
-     p u b l i c   d o u b l e   g e t Z ( ) ;  -
-     p u b l i c   d o u b l e   g e t M ( ) ;  -
-     p u b l i c   s t a t i c   d o u b l e   g e t N o Z ( ) ;  -
-     p u b l i c   s t a t i c   d o u b l e   g e t N o M ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   i n t   g e t C o u n t ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t I t e m ( i n t ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   v o i d   a d d ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   v o i d   c l e a r ( ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   v o i d   r e m o v e A t ( i n t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e C o l l e c t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e D i m e n s i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e D i m e n s i o n   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   X Y   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   X Y Z   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M   =   2 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e D i m e n s i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e I t e r a t o r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e I t e r a t o r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t C u r r e n t ( ) ;  -
-     p u b l i c   b o o l e a n   m o v e N e x t ( ) ;  -
-     p u b l i c   v o i d   r e s e t ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S p a c e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S p a c e   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   N o n e   =   " N o n e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M a p   =   " M a p " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D i s p l a y   =   " D i s p l a y " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S p a c e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   i n t   g e t T y p e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   c o n v e r t F r o m L o n L a t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   c o n v e r t T o L o n L a t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   d o u b l e   c o n v e r t C o o r d i n a t e S y s t e m U n i t s T o M e t e r s ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   c o n v e r t M e t e r s T o C o o r d i n a t e S y s t e m U n i t s ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   m e a s u r e E u c l i d e a n D i s t a n c e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   d o u b l e   m e a s u r e E u c l i d e a n D i s t a n c e ( d o u b l e ,   d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   m e a s u r e G r e a t C i r c l e D i s t a n c e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   d o u b l e   m e a s u r e G r e a t C i r c l e D i s t a n c e ( d o u b l e ,   d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t A z i m u t h ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   d o u b l e   g e t A z i m u t h ( d o u b l e ,   d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t C o o r d i n a t e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t C o o r d i n a t e ( d o u b l e ,   d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   t o S t r i n g ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t U n i t s ( ) ;  -
-     p u b l i c   d o u b l e   g e t U n i t S c a l e ( ) ;  -
-     p u b l i c   d o u b l e   g e t M i n X ( ) ;  -
-     p u b l i c   d o u b l e   g e t M i n Y ( ) ;  -
-     p u b l i c   d o u b l e   g e t M a x X ( ) ;  -
-     p u b l i c   d o u b l e   g e t M a x Y ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t C s C o d e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D e s c r i p t i o n ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t P r o j e c t i o n ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t P r o j e c t i o n D e s c r i p t i o n ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D a t u m ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D a t u m D e s c r i p t i o n ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t E l l i p s o i d ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t E l l i p s o i d D e s c r i p t i o n ( ) ;  -
-     p u b l i c   i n t   g e t E p s g C o d e ( ) ;  -
-     p u b l i c   i n t   g e t S r i d C o d e ( ) ;  -
-     p u b l i c   s h o r t   g e t E p s g Q u a d r a n t ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M e a s u r e   g e t M e a s u r e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   g e t C a t e g o r i e s ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t a l o g   g e t C a t a l o g ( ) ;  -
-     p u b l i c   v o i d   s e t C s C o d e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   i s L e g a l C s C o d e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   i s V a l i d ( ) ;  -
-     p u b l i c   b o o l e a n   i s U s a b l e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t a l o g ) ;  -
-     p u b l i c   b o o l e a n   i s S a m e A s ( o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e ) ;  -
-     p u b l i c   v o i d   s e t D e s c r i p t i o n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   i s L e g a l D e s c r i p t i o n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t G r o u p ( ) ;  -
-     p u b l i c   v o i d   s e t G r o u p ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   i s L e g a l G r o u p ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S o u r c e ( ) ;  -
-     p u b l i c   v o i d   s e t S o u r c e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   i s L e g a l S o u r c e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   i s P r o t e c t e d ( ) ;  -
-     p u b l i c   s h o r t   g e t A g e ( ) ;  -
-     p u b l i c   v o i d   s e t P r o t e c t M o d e ( b o o l e a n ) ;  -
-     p u b l i c   b o o l e a n   i s E n c r y p t e d ( ) ;  -
-     p u b l i c   v o i d   s e t E n c r y p t M o d e ( b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2   g e t E r r o r s ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t L o c a t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t L o c a t i o n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   i s L e g a l L o c a t i o n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t C o u n t r y O r S t a t e ( ) ;  -
-     p u b l i c   v o i d   s e t C o u n t r y O r S t a t e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   i s L e g a l C o u n t r y O r S t a t e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   i s G e o d e t i c ( ) ;  -
-     p u b l i c   i n t   g e t P r o j e c t i o n C o d e ( ) ;  -
-     p u b l i c   v o i d   s e t P r o j e c t i o n C o d e ( i n t ) ;  -
-     p u b l i c   i n t   g e t U n i t C o d e ( ) ;  -
-     p u b l i c   v o i d   s e t U n i t C o d e ( i n t ) ;  -
-     p u b l i c   i n t   g e t P r o j e c t i o n P a r a m e t e r C o u n t ( ) ;  -
-     p u b l i c   d o u b l e   g e t P r o j e c t i o n P a r a m e t e r ( i n t ) ;  -
-     p u b l i c   v o i d   s e t P r o j e c t i o n P a r a m e t e r ( i n t ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t O r i g i n L o n g i t u d e ( ) ;  -
-     p u b l i c   v o i d   s e t O r i g i n L o n g i t u d e ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t O r i g i n L a t i t u d e ( ) ;  -
-     p u b l i c   v o i d   s e t O r i g i n L a t i t u d e ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t O f f s e t X ( ) ;  -
-     p u b l i c   d o u b l e   g e t O f f s e t Y ( ) ;  -
-     p u b l i c   v o i d   s e t O f f s e t s ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t S c a l e R e d u c t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t S c a l e R e d u c t i o n ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t M a p S c a l e ( ) ;  -
-     p u b l i c   v o i d   s e t M a p S c a l e ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t Z e r o X ( ) ;  -
-     p u b l i c   d o u b l e   g e t Z e r o Y ( ) ;  -
-     p u b l i c   v o i d   s e t Z e r o e s ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t L o n M i n ( ) ;  -
-     p u b l i c   d o u b l e   g e t L o n M a x ( ) ;  -
-     p u b l i c   d o u b l e   g e t L a t M i n ( ) ;  -
-     p u b l i c   d o u b l e   g e t L a t M a x ( ) ;  -
-     p u b l i c   v o i d   s e t L o n L a t B o u n d s ( d o u b l e ,   d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   v o i d   c a n c e l L o n L a t B o u n d s ( ) ;  -
-     p u b l i c   v o i d   s e t X Y B o u n d s ( d o u b l e ,   d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   v o i d   c a n c e l X Y B o u n d s ( ) ;  -
-     p u b l i c   s h o r t   g e t Q u a d r a n t ( ) ;  -
-     p u b l i c   v o i d   s e t Q u a d r a n t ( s h o r t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m   g e t D a t u m D e f i n i t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t D a t u m D e f i n i t i o n ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d   g e t E l l i p s o i d D e f i n i t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t E l l i p s o i d D e f i n i t i o n ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d ) ;  -
-     p u b l i c   b o o l e a n   i s V a l i d X Y ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   b o o l e a n   i s V a l i d L o n L a t ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   v o i d   c o n v e r t C o o r d i n a t e F r o m L o n L a t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   v o i d   c o n v e r t C o o r d i n a t e T o L o n L a t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   c o n v e r t T o L o n L a t ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   c o n v e r t T o L o n L a t ( d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   c o n v e r t F r o m L o n L a t ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   c o n v e r t F r o m L o n L a t ( d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t C o n v e r g e n c e ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t S c a l e ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t S c a l e H ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t S c a l e K ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m   c r e a t e C l o n e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m C a t a l o g . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t a l o g   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   v o i d   s e t D e f a u l t D i c t i o n a r y D i r A n d F i l e N a m e s ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D e f a u l t D i c t i o n a r y D i r ( ) ;  -
-     p u b l i c   v o i d   s e t D i c t i o n a r y D i r ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D i c t i o n a r y D i r ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D e f a u l t U s e r D i c t i o n a r y D i r ( ) ;  -
-     p u b l i c   v o i d   s e t U s e r D i c t i o n a r y D i r ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t U s e r D i c t i o n a r y D i r ( ) ;  -
-     p u b l i c   v o i d   s e t P r o t e c t i o n M o d e ( s h o r t ) ;  -
-     p u b l i c   s h o r t   g e t P r o t e c t i o n M o d e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y D i c t i o n a r y   g e t C a t e g o r y D i c t i o n a r y ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y   g e t C o o r d i n a t e S y s t e m D i c t i o n a r y ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m D i c t i o n a r y   g e t D a t u m D i c t i o n a r y ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d D i c t i o n a r y   g e t E l l i p s o i d D i c t i o n a r y ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h D i c t i o n a r y   g e t G e o d e t i c P a t h D i c t i o n a r y ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f D i c t i o n a r y   g e t G e o d e t i c T r a n s f o r m D e f D i c t i o n a r y ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n   g e t G e o d e t i c T r a n s f o r m a t i o n s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M a t h C o m p a r a t o r   g e t M a t h C o m p a r a t o r ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m F o r m a t C o n v e r t e r   g e t F o r m a t C o n v e r t e r ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n I n f o r m a t i o n   g e t P r o j e c t i o n I n f o r m a t i o n ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m U n i t I n f o r m a t i o n   g e t U n i t I n f o r m a t i o n ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y U t i l i t y   g e t D i c t i o n a r y U t i l i t y ( ) ;  -
-     p u b l i c   b o o l e a n   a r e D i c t i o n a r y F i l e s W r i t a b l e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m C a t e g o r y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t N a m e ( ) ;  -
-     p u b l i c   v o i d   s e t N a m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   i s L e g a l N a m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y   c r e a t e C l o n e ( ) ;  -
-     p u b l i c   i n t   g e t S i z e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m   g e t E n u m ( ) ;  -
-     p u b l i c   v o i d   a d d C o o r d i n a t e S y s t e m ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   r e m o v e C o o r d i n a t e S y s t e m ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   h a s C o o r d i n a t e S y s t e m ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   g e t C o o r d i n a t e S y s t e m s ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m C a t e g o r y D i c t i o n a r y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y D i c t i o n a r y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y   n e w C a t e g o r y ( ) ;  -
-     p u b l i c   v o i d   r e n a m e ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C a t e g o r y   g e t C a t e g o r y ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m C o d e F o r m a t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C o d e F o r m a t   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M e n t o r   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E p s g   =   1 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m C o d e F o r m a t ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m D a t u m . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D t C o d e ( ) ;  -
-     p u b l i c   v o i d   s e t D t C o d e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   i s L e g a l D t C o d e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   s h o r t   g e t E p s g C o d e ( ) ;  -
-     p u b l i c   v o i d   s e t E p s g C o d e ( s h o r t ) ;  -
-     p u b l i c   v o i d   s e t E l l i p s o i d ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m   c r e a t e C l o n e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n   g e t G e o d e t i c T r a n s f o r m a t i o n s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m D a t u m D i c t i o n a r y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m D i c t i o n a r y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m   n e w D a t u m ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m   g e t D a t u m ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m D i c t i o n a r y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m   n e w C o o r d i n a t e S y s t e m ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m   g e t C o o r d i n a t e S y s t e m ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D e f a u l t F i l e N a m e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t F i l e N a m e ( ) ;  -
-     p u b l i c   v o i d   s e t F i l e N a m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t P a t h ( ) ;  -
-     p u b l i c   v o i d   a d d ( o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e ) ;  -
-     p u b l i c   v o i d   r e m o v e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   m o d i f y ( o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   g e t ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   h a s ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m D i c t i o n a r y U t i l i t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y U t i l i t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   v o i d   c r e a t e E l l i p s o i d D i c t i o n a r y ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   c r e a t e D a t u m D i c t i o n a r y ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   c r e a t e C o o r d s y s D i c t i o n a r y ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   c r e a t e C a t e g o r y D i c t i o n a r y ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m E l l i p s o i d . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t E l C o d e ( ) ;  -
-     p u b l i c   v o i d   s e t E l C o d e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   i s L e g a l E l C o d e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   i s U s a b l e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d   c r e a t e C l o n e ( ) ;  -
-     p u b l i c   d o u b l e   g e t E q u a t o r i a l R a d i u s ( ) ;  -
-     p u b l i c   d o u b l e   g e t P o l a r R a d i u s ( ) ;  -
-     p u b l i c   d o u b l e   g e t F l a t t e n i n g R a t i o ( ) ;  -
-     p u b l i c   d o u b l e   g e t E c c e n t r i c i t y ( ) ;  -
-     p u b l i c   v o i d   s e t R a d i i ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   f l a t t e n i n g R a t i o T o E c c e n t r i c i t y ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   e c c e n t r i c i t y T o F l a t t e n i n g R a t i o ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   e q u a t o r i a l R a d i u s F r o m P o l a r R a d i u s F l a t t e n i n g R a t i o ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   p o l a r R a d i u s F r o m E q u a t o r i a l R a d i u s F l a t t e n i n g R a t i o ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t G r e a t C i r c l e D i s t a n c e ( d o u b l e ,   d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t G r e a t C i r c l e A z i m u t h ( d o u b l e ,   d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t R a d i u s M i n ( ) ;  -
-     p u b l i c   d o u b l e   g e t R a d i u s M a x ( ) ;  -
-     p u b l i c   b o o l e a n   i s L e g a l R a d i u s ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t F l a t t e n i n g R a t i o M i n ( ) ;  -
-     p u b l i c   d o u b l e   g e t F l a t t e n i n g R a t i o M a x ( ) ;  -
-     p u b l i c   b o o l e a n   i s L e g a l F l a t t e n i n g R a t i o ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   f l a t t e n i n g R a t i o F r o m R a d i i ( d o u b l e ,   d o u b l e ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m E l l i p s o i d D i c t i o n a r y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d D i c t i o n a r y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d   n e w E l l i p s o i d ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d   g e t E l l i p s o i d ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m E n u m . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n   n e x t ( i n t ) ;  -
-     p u b l i c   v o i d   s k i p ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m   c r e a t e C l o n e ( ) ;  -
-     p u b l i c   v o i d   a d d F i l t e r ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m F i l t e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   n e x t N a m e ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   n e x t D e s c r i p t i o n ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2 . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   n e x t ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2   c r e a t e C l o n e ( ) ;  -
-     p u b l i c   v o i d   a d d F i l t e r ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m F i l t e r I n t e g e r 3 2 ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m E r r o r C o d e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E r r o r C o d e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A Z M   =   2 0 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A Z M T H   =   2 0 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L A T   =   2 0 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L A T E Q U   =   2 0 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L N G   =   2 0 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L N G E Q U   =   2 0 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M A P S C L   =   2 0 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M E R E Q U   =   2 0 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M R C A T   =   2 0 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M S C O E F   =   2 1 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N O R E F   =   2 1 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N O T N R T H   =   2 1 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N R T H L A T   =   2 1 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N R T H P N T   =   2 1 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O R G L A T   =   2 1 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O R G L N G   =   2 1 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P L L 9 0   =   2 1 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P L L E Q U   =   2 1 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P L L L R G   =   2 1 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P L L R E V   =   2 2 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P L L Z E R O   =   2 2 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P O L D D   =   2 2 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P O L D U P   =   2 2 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P O L L A T   =   2 2 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P O L L N G   =   2 2 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   Q U A D   =   2 2 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S C L R E D   =   2 2 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S O T H L A T   =   2 2 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S T D L A T   =   2 2 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S T D L N G   =   2 3 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S T D P L L   =   2 3 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S T D S O U   =   2 3 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S T D W E S T   =   2 3 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U N I T   =   2 3 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I N V P R J   =   2 3 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I N V D T M   =   2 3 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I N V E L P   =   2 3 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L L R N G   =   2 3 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R N G O R D   =   2 3 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I N V Q U A D   =   2 4 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G E O M M   =   2 4 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C R T M M   =   2 4 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P L L E D   =   2 4 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P L R L A T   =   2 4 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U S E P L R   =   2 4 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U T M Z O N   =   2 4 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   H M I S P H R   =   2 4 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U S E S W   =   2 4 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M A X 1 5   =   2 4 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O B L Q P O L E   =   2 5 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A F F Z E R O   =   2 5 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N R D A T U M   =   2 5 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O S T N 9 7   =   2 5 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D E N R G N   =   2 5 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E L E V E L   =   2 5 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O S T N 0 2   =   2 5 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T M K R G 0   =   2 5 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O k   =   1 0 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O u t O f M e m o r y   =   1 0 0 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n i t i a l i z a t i o n F a i l e d   =   1 0 0 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C o n v e r s i o n F a i l e d   =   1 0 0 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N u l l A r g u m e n t   =   1 0 0 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n v a l i d A r g u m e n t   =   1 0 0 5 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E r r o r C o d e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m F a c t o r y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m F a c t o r y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m F a c t o r y ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m   c r e a t e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m T r a n s f o r m   g e t T r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m   c r e a t e F r o m C o d e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   c o n v e r t W k t T o C o o r d i n a t e S y s t e m C o d e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   c o n v e r t C o o r d i n a t e S y s t e m C o d e T o W k t ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   e n u m e r a t e C a t e g o r i e s ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n   e n u m e r a t e C o o r d i n a t e S y s t e m s ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   c o n v e r t E p s g C o d e T o W k t ( i n t ) ;  -
-     p u b l i c   i n t   c o n v e r t W k t T o E p s g C o d e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t B a s e L i b r a r y ( ) ;  -
-     p u b l i c   b o o l e a n   i s V a l i d ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y   g r i d B o u n d a r y ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y   g r i d B o u n d a r y ( o r g . o s g e o . m a p g u i d e . M g P o l y g o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n   g r i d S p e c i f i c a t i o n ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n   g r i d S p e c i f i c a t i o n ( d o u b l e ,   d o u b l e ,   i n t ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n   g r i d S p e c i f i c a t i o n ( i n t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e   g e n e r i c G r i d ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e   g e n e r i c G r i d ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s   g e t M g r s ( d o u b l e ,   d o u b l e ,   s h o r t ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s   g e t M g r s E l l i p s o i d ( j a v a . l a n g . S t r i n g ,   s h o r t ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s   g e t M g r s D a t u m ( j a v a . l a n g . S t r i n g ,   s h o r t ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e   m g r s G r i d ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m ,   b o o l e a n ,   s h o r t ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e   m g r s G r i d ( j a v a . l a n g . S t r i n g ,   b o o l e a n ,   s h o r t ,   b o o l e a n ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m F i l t e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m F i l t e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   b o o l e a n   i s F i l t e r e d O u t ( o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m F i l t e r I n t e g e r 3 2 . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m F i l t e r I n t e g e r 3 2   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   b o o l e a n   i s F i l t e r e d O u t ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m F o r m a t C o n v e r t e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m F o r m a t C o n v e r t e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   j a v a . l a n g . S t r i n g   d e f i n i t i o n T o W k t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m   w k t T o D e f i n i t i o n ( i n t ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   c o d e T o W k t ( i n t ,   j a v a . l a n g . S t r i n g ,   i n t ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   w k t T o C o d e ( i n t ,   j a v a . l a n g . S t r i n g ,   i n t ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   d e f i n i t i o n T o C o d e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m   c o d e T o D e f i n i t i o n ( i n t ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   c o d e T o C o d e ( i n t ,   j a v a . l a n g . S t r i n g ,   i n t ) ;  -
-     p u b l i c   b o o l e a n   i s C o d e I n D i c t i o n a r y ( i n t ,   j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G e o d e t i c A n a l y t i c a l T r a n s f o r m a t i o n M e t h o d . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c A n a l y t i c a l T r a n s f o r m a t i o n M e t h o d   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N o n e   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T h r e e P a r a m e t e r   =   8 1 9 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M o l o d e n s k y   =   8 1 9 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A b r i d g e d M o l o d e n s k y   =   8 1 9 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G e o c e n t r i c   =   8 1 9 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   F o u r P a r a m e t e r   =   8 1 9 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S i x P a r a m e t e r   =   8 1 9 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B u r s a   =   8 1 9 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   F r a m e   =   8 2 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S e v e n P a r a m e t e r   =   8 2 0 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M o l o d e n s k y B a d e k a s   =   8 2 0 2 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c A n a l y t i c a l T r a n s f o r m a t i o n M e t h o d ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G e o d e t i c A n a l y t i c a l T r a n s f o r m D e f P a r a m s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c A n a l y t i c a l T r a n s f o r m D e f P a r a m s   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s   {  -
-     p u b l i c   d o u b l e   g e t D e l t a X ( ) ;  -
-     p u b l i c   v o i d   s e t D e l t a X ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t D e l t a Y ( ) ;  -
-     p u b l i c   v o i d   s e t D e l t a Y ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t D e l t a Z ( ) ;  -
-     p u b l i c   v o i d   s e t D e l t a Z ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t R o t a t e X ( ) ;  -
-     p u b l i c   v o i d   s e t R o t a t e X ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t R o t a t e Y ( ) ;  -
-     p u b l i c   v o i d   s e t R o t a t e Y ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t R o t a t e Z ( ) ;  -
-     p u b l i c   v o i d   s e t R o t a t e Z ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t S c a l e ( ) ;  -
-     p u b l i c   v o i d   s e t S c a l e ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t T r a n s l a t e X ( ) ;  -
-     p u b l i c   v o i d   s e t T r a n s l a t e X ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t T r a n s l a t e Y ( ) ;  -
-     p u b l i c   v o i d   s e t T r a n s l a t e Y ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t T r a n s l a t e Z ( ) ;  -
-     p u b l i c   v o i d   s e t T r a n s l a t e Z ( d o u b l e ) ;  -
-     p u b l i c   i n t   g e t T r a n s f o r m a t i o n M e t h o d ( ) ;  -
-     p u b l i c   v o i d   s e t T r a n s f o r m a t i o n M e t h o d ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G e o d e t i c I n t e r p o l a t i o n T r a n s f o r m D e f P a r a m s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c I n t e r p o l a t i o n T r a n s f o r m D e f P a r a m s   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s   {  -
-     p u b l i c   v o i d   s e t G r i d F i l e s ( o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n   g e t G r i d F i l e s ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t F a l l b a c k ( ) ;  -
-     p u b l i c   v o i d   s e t F a l l b a c k ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e   n e w G r i d F i l e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G e o d e t i c M u l t i p l e R e g r e s s i o n T r a n s f o r m a t i o n M e t h o d . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c M u l t i p l e R e g r e s s i o n T r a n s f o r m a t i o n M e t h o d   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M u l t i p l e R e g r e s s i o n   =   2 0 4 8 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G e n e r a l P o l y n o m i a l E p s g   =   2 0 4 8 2 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c M u l t i p l e R e g r e s s i o n T r a n s f o r m a t i o n M e t h o d ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G e o d e t i c M u l t i p l e R e g r e s s i o n T r a n s f o r m D e f P a r a m s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c M u l t i p l e R e g r e s s i o n T r a n s f o r m D e f P a r a m s   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s   {  -
-     p u b l i c   d o u b l e   g e t V a l i d a t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t V a l i d a t i o n ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t T e s t P h i ( ) ;  -
-     p u b l i c   v o i d   s e t T e s t P h i ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t T e s t L a m b d a ( ) ;  -
-     p u b l i c   v o i d   s e t T e s t L a m b d a ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t D e l t a P h i ( ) ;  -
-     p u b l i c   v o i d   s e t D e l t a P h i ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t D e l t a L a m b d a ( ) ;  -
-     p u b l i c   v o i d   s e t D e l t a L a m b d a ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t D e l t a H e i g h t ( ) ;  -
-     p u b l i c   v o i d   s e t D e l t a H e i g h t ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t P h i O f f s e t ( ) ;  -
-     p u b l i c   v o i d   s e t P h i O f f s e t ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t L a m b d a O f f s e t ( ) ;  -
-     p u b l i c   v o i d   s e t L a m b d a O f f s e t ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t N o r m a l i z a t i o n S c a l e ( ) ;  -
-     p u b l i c   v o i d   s e t N o r m a l i z a t i o n S c a l e ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t C o e f f i c i e n t P h i ( i n t ) ;  -
-     p u b l i c   v o i d   s e t C o e f f i c i e n t P h i ( i n t ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t C o e f f i c i e n t L a m b d a ( i n t ) ;  -
-     p u b l i c   v o i d   s e t C o e f f i c i e n t L a m b d a ( i n t ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t C o e f f i c i e n t H e i g h t ( i n t ) ;  -
-     p u b l i c   v o i d   s e t C o e f f i c i e n t H e i g h t ( i n t ,   d o u b l e ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t P a t h N a m e ( ) ;  -
-     p u b l i c   v o i d   s e t P a t h N a m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t T a r g e t D a t u m ( ) ;  -
-     p u b l i c   v o i d   s e t T a r g e t D a t u m ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S o u r c e D a t u m ( ) ;  -
-     p u b l i c   v o i d   s e t S o u r c e D a t u m ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   d o u b l e   g e t A c c u r a c y ( ) ;  -
-     p u b l i c   v o i d   s e t A c c u r a c y ( d o u b l e ) ;  -
-     p u b l i c   b o o l e a n   g e t I s R e v e r s i b l e ( ) ;  -
-     p u b l i c   v o i d   s e t I s R e v e r s i b l e ( b o o l e a n ) ;  -
-     p u b l i c   v o i d   s e t E p s g C o d e ( i n t ) ;  -
-     p u b l i c   i n t   g e t E p s g V a r i a n t ( ) ;  -
-     p u b l i c   v o i d   s e t E p s g V a r i a n t ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n   g e t P a t h E l e m e n t s ( ) ;  -
-     p u b l i c   v o i d   s e t P a t h E l e m e n t s ( o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h E l e m e n t   n e w P a t h E l e m e n t ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h   c r e a t e C l o n e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h D i c t i o n a r y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h D i c t i o n a r y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h   n e w G e o d e t i c P a t h ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h   g e t G e o d e t i c P a t h ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h E l e m e n t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h E l e m e n t   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t T r a n s f o r m N a m e ( ) ;  -
-     p u b l i c   v o i d   s e t T r a n s f o r m N a m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   g e t I s I n v e r s e d ( ) ;  -
-     p u b l i c   v o i d   s e t I s I n v e r s e d ( b o o l e a n ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G e o d e t i c S t a n d a l o n e T r a n s f o r m D e f P a r a m s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c S t a n d a l o n e T r a n s f o r m D e f P a r a m s   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s   {  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   v o i d   s e t S o u r c e A n d T a r g e t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m   g e t S o u r c e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m   g e t T a r g e t ( ) ;  -
-     p u b l i c   v o i d   s h i f t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   s h i f t ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   s h i f t ( d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t O f f s e t Z ( ) ;  -
-     p u b l i c   v o i d   s e t O f f s e t ( d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t B u r s a W o l f e T r a n s f o r m R o t a t i o n X ( ) ;  -
-     p u b l i c   d o u b l e   g e t B u r s a W o l f e T r a n s f o r m R o t a t i o n Y ( ) ;  -
-     p u b l i c   d o u b l e   g e t B u r s a W o l f e T r a n s f o r m R o t a t i o n Z ( ) ;  -
-     p u b l i c   d o u b l e   g e t B u r s a W o l f e T r a n s f o r m B w S c a l e ( ) ;  -
-     p u b l i c   v o i d   s e t B u r s a W o l f e T r a n s f o r m ( d o u b l e ,   d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   i n t   g e t G e o d e t i c T r a n s f o r m a t i o n M e t h o d ( ) ;  -
-     p u b l i c   v o i d   s e t G e o d e t i c T r a n s f o r m a t i o n M e t h o d ( i n t ) ;  -
-     p u b l i c   d o u b l e   g e t M a x O f f s e t ( ) ;  -
-     p u b l i c   b o o l e a n   i s L e g a l O f f s e t ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t M a x R o t a t i o n ( ) ;  -
-     p u b l i c   b o o l e a n   i s L e g a l R o t a t i o n ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t B w S c a l e M i n ( ) ;  -
-     p u b l i c   d o u b l e   g e t B w S c a l e M a x ( ) ;  -
-     p u b l i c   b o o l e a n   i s L e g a l B w S c a l e ( d o u b l e ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n M e t h o d . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n M e t h o d   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M o l o d e n s k y   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M R e g   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B u r s a   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N A D 2 7   =   4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N A D 8 3   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   W G S 8 4   =   6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   W G S 7 2   =   7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   H P G N   =   8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S e v e n P a r a m e t e r   =   9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A G D 6 6   =   1 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T h r e e P a r a m e t e r   =   1 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S i x P a r a m e t e r   =   1 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   F o u r P a r a m e t e r   =   1 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A G D 8 4   =   1 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N Z G D 4 9   =   1 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A T S 7 7   =   1 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G D A 9 4   =   1 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N Z G D 2 K   =   1 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C S R S   =   1 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T O K Y O   =   2 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R G F 9 3   =   2 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E D 5 0   =   2 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D H D N   =   2 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E T R F 8 9   =   2 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L c l g r f   =   9 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G e o c e n t r i c   =   2 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C H E N Y X   =   2 6 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n M e t h o d ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   i n t   g e t E p s g V a r i a t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t E p s g V a r i a t i o n ( i n t ) ;  -
-     p u b l i c   b o o l e a n   g e t I n v e r s e S u p p o r t e d ( ) ;  -
-     p u b l i c   v o i d   s e t I n v e r s e S u p p o r t e d ( b o o l e a n ) ;  -
-     p u b l i c   i n t   g e t M a x I t e r a t i o n s ( ) ;  -
-     p u b l i c   v o i d   s e t M a x I t e r a t i o n s ( i n t ) ;  -
-     p u b l i c   d o u b l e   g e t C o n v e r g e n c e V a l u e ( ) ;  -
-     p u b l i c   v o i d   s e t C o n v e r g e n c e V a l u e ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t E r r o r V a l u e ( ) ;  -
-     p u b l i c   v o i d   s e t E r r o r V a l u e ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t R a n g e M i n L o n g i t u d e ( ) ;  -
-     p u b l i c   v o i d   s e t R a n g e M i n L o n g i t u d e ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t R a n g e M a x L o n g i t u d e ( ) ;  -
-     p u b l i c   v o i d   s e t R a n g e M a x L o n g i t u d e ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t R a n g e M i n L a t i t u d e ( ) ;  -
-     p u b l i c   v o i d   s e t R a n g e M i n L a t i t u d e ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t R a n g e M a x L a t i t u d e ( ) ;  -
-     p u b l i c   v o i d   s e t R a n g e M a x L a t i t u d e ( d o u b l e ) ;  -
-     p u b l i c   i n t   g e t T r a n s f o r m D e f T y p e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s   g e t P a r a m e t e r s ( ) ;  -
-     p u b l i c   v o i d   s e t P a r a m e t e r s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f   c r e a t e C l o n e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m a t i o n   c r e a t e T r a n s f o r m a t i o n ( b o o l e a n ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f D i c t i o n a r y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f D i c t i o n a r y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D i c t i o n a r y B a s e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f   n e w G e o d e t i c T r a n s f o r m a t i o n D e f ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f   g e t G e o d e t i c T r a n s f o r m a t i o n D e f ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f P a r a m s   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S t a n d a l o n e   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A n a l y t i c a l   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n t e r p o l a t i o n   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M u l t i p l e R e g r e s s i o n   =   4 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   s y n c h r o n i z e d   v o i d   d e l e t e ( ) ;  -
-     p u b l i c   i n t   g e t F i l e F o r m a t ( ) ;  -
-     p u b l i c   v o i d   s e t F i l e F o r m a t ( i n t ) ;  -
-     p u b l i c   b o o l e a n   g e t I s I n v e r s e D i r e c t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t I s I n v e r s e D i r e c t i o n ( b o o l e a n ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e F o r m a t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e F o r m a t   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N T v 1   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N T v 2   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N A D C O N   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R G F   =   4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P A R   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A T S 7 7   =   6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O S T 9 7   =   7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O S T 0 2   =   8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O S T 1 5   =   9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G E O C O N   =   1 0 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m G r i d F i l e F o r m a t ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G r i d B a s e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   i n t   g e t S p e c i a l i z a t i o n T y p e ( ) ;  -
-     p u b l i c   v o i d   s e t B o u n d a r y ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y   g e t B o u n d a r y ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d L i n e C o l l e c t i o n   g e t G r i d L i n e s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d R e g i o n C o l l e c t i o n   g e t G r i d R e g i o n s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d T i c k C o l l e c t i o n   g e t G r i d T i c k s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) ;  -
-     p u b l i c   d o u b l e   g e t C o n v e r g e n c e A n g l e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   d o u b l e   g e t P r o j e c t i v e G r i d S c a l e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   i n t   a p p r o x G r i d L i n e M e m o r y U s a g e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) ;  -
-     p u b l i c   i n t   a p p r o x G r i d R e g i o n M e m o r y U s a g e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) ;  -
-     p u b l i c   i n t   a p p r o x G r i d T i c k M e m o r y U s a g e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) ;  -
-     p u b l i c   i n t   s e t G r i d L i n e E x c e p t i o n L e v e l ( i n t ) ;  -
-     p u b l i c   i n t   s e t G r i d R e g i o n E x c e p t i o n L e v e l ( i n t ) ;  -
-     p u b l i c   i n t   s e t G r i d T i c k E x c e p t i o n L e v e l ( i n t ) ;  -
-     p u b l i c   i n t   g e t L a s t E r r o r ( ) ;  -
-     p u b l i c   v o i d   r e s e t L a s t E r r o r ( ) ;  -
-     p u b l i c   b o o l e a n   a r e E x c e p t i o n s O n ( ) ;  -
-     p u b l i c   v o i d   s e t E x c e p t i o n s O n ( b o o l e a n ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B o u n d a r y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   v o i d   s e t B o u n d a r y E x t e n t s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   v o i d   s e t B o u n d a r y E x t e n t s ( o r g . o s g e o . m a p g u i d e . M g P o l y g o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P o l y g o n   g e t B o u n d a r y ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G r i d L i n e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d L i n e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   i n t   g e t G r i d O r i e n t a t i o n ( ) ;  -
-     p u b l i c   d o u b l e   g e t R e a l V a l u e ( ) ;  -
-     p u b l i c   i n t   g e t C o u n t ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g   g e t S e g m e n t ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n   g e t S e g m e n t C o l l e c t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t S e g m e n t C o l l e c t i o n ( o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G r i d L i n e C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d L i n e C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d L i n e   g e t I t e m ( i n t ) ;  -
-     p u b l i c   i n t   i n d e x O f ( i n t ,   d o u b l e ) ;  -
-     p u b l i c   v o i d   r e m o v e A t ( i n t ) ;  -
-     p u b l i c   v o i d   c l e a r ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G r i d O r i e n t a t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d O r i e n t a t i o n   {  -
-     p u b l i c   s t a t i c   f i n a l   s h o r t   N o n e   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   s h o r t   E a s t W e s t   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   s h o r t   N o r t h S o u t h   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   s h o r t   U n k n o w n   =   3 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d O r i e n t a t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G r i d R e g i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d R e g i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t L a b e l ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t R e g i o n C e n t e r ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P o l y g o n   g e t R e g i o n B o u n d a r y ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n   g e t S o u t h L i n e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n   g e t E a s t L i n e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n   g e t N o r t h L i n e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n   g e t W e s t L i n e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G r i d R e g i o n C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d R e g i o n C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d R e g i o n   g e t I t e m ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G r i d S p e c i a l i z a t i o n T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i a l i z a t i o n T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G e n e r i c   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M G R S   =   1 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U S N G   =   1 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U n k n o w n   =   6 5 3 6 6 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i a l i z a t i o n T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   d o u b l e   g e t E a s t i n g B a s e ( ) ;  -
-     p u b l i c   d o u b l e   g e t N o r t h i n g B a s e ( ) ;  -
-     p u b l i c   d o u b l e   g e t E a s t i n g I n c r e m e n t ( ) ;  -
-     p u b l i c   d o u b l e   g e t N o r t h i n g I n c r e m e n t ( ) ;  -
-     p u b l i c   d o u b l e   g e t T i c k E a s t i n g I n c r e m e n t ( ) ;  -
-     p u b l i c   d o u b l e   g e t T i c k N o r t h i n g I n c r e m e n t ( ) ;  -
-     p u b l i c   i n t   g e t U n i t T y p e ( ) ;  -
-     p u b l i c   i n t   g e t U n i t C o d e ( ) ;  -
-     p u b l i c   b o o l e a n   i s S a m e A s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d S p e c i f i c a t i o n ) ;  -
-     p u b l i c   d o u b l e   g e t C u r v e P r e c i s i o n ( ) ;  -
-     p u b l i c   v o i d   s e t G r i d B a s e ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   v o i d   s e t G r i d I n c r e m e n t ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   v o i d   s e t T i c k I n c r e m e n t s ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   v o i d   s e t U n i t s ( i n t ,   i n t ) ;  -
-     p u b l i c   v o i d   s e t C u r v e P r e c i s i o n ( d o u b l e ) ;  -
-     p u b l i c   v o i d   s e t M a x C u r v e P o i n t s ( i n t ) ;  -
-     p u b l i c   b o o l e a n   i s C o n s i s t e n t ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G r i d T i c k . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d T i c k   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   b o o l e a n   g e t I s O n G r i d L i n e ( ) ;  -
-     p u b l i c   i n t   g e t T i c k O r i e n t a t i o n ( ) ;  -
-     p u b l i c   d o u b l e   g e t V a l u e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t P o s i t i o n ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t D i r e c t i o n V e c t o r ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m G r i d T i c k C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d T i c k C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d T i c k   g e t I t e m ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m M a t h C o m p a r a t o r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M a t h C o m p a r a t o r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   b o o l e a n   s a m e ( o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e ,   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e ) ;  -
-     p u b l i c   b o o l e a n   s a m e E l l i p s o i d ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E l l i p s o i d ) ;  -
-     p u b l i c   b o o l e a n   s a m e D a t u m ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m D a t u m ) ;  -
-     p u b l i c   b o o l e a n   s a m e C o o r d i n a t e S y s t e m ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m ) ;  -
-     p u b l i c   v o i d   s e t C o m p a r e I n t e r n a l D a t u m O l d P a r a m e t e r s ( b o o l e a n ) ;  -
-     p u b l i c   b o o l e a n   g e t C o m p a r e I n t e r n a l D a t u m O l d P a r a m e t e r s ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m M e a s u r e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M e a s u r e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g M e a s u r e   {  -
-     p u b l i c   d o u b l e   g e t D i s t a n c e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   d o u b l e   g e t D i s t a n c e ( d o u b l e ,   d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t A z i m u t h ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   d o u b l e   g e t A z i m u t h ( d o u b l e ,   d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t C o o r d i n a t e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t C o o r d i n a t e ( d o u b l e ,   d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e   g e t E n v e l o p e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m M g r s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G r i d B a s e   {  -
-     p u b l i c   j a v a . l a n g . S t r i n g   c o n v e r t F r o m L o n L a t ( d o u b l e ,   d o u b l e ,   i n t ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   c o n v e r t F r o m L o n L a t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   c o n v e r t T o L o n L a t ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   c o n v e r t T o L o n L a t ( j a v a . l a n g . S t r i n g ,   i n t ) ;  -
-     p u b l i c   s h o r t   g e t L e t t e r i n g S c h e m e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m M g r s G r i d L e v e l . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s G r i d L e v e l   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M g r s N o n e   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M g r s U t m   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M g r s U p s   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M g r s 1 0 0 K m   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M g r s 1 0 K m   =   4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M g r s 1 K m   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M g r s 1 0 0 m   =   6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M g r s 1 0 m   =   7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M g r s 1 m   =   8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M g r s U n k n o w n   =   9 9 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s G r i d L e v e l ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m M g r s G r i d S q u a r e P o s i t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s G r i d S q u a r e P o s i t i o n   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C e n t e r   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S o u t h W e s t   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   W e s t   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N o r t h W e s t   =   4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N o r t h   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N o r t h E a s t   =   6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E a s t   =   7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S o u t h E a s t   =   8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S o u t h   =   9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U n k n o w n   =   1 0 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s G r i d S q u a r e P o s i t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m M g r s L e t t e r i n g S c h e m e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s L e t t e r i n g S c h e m e   {  -
-     p u b l i c   s t a t i c   f i n a l   s h o r t   N o r m a l   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   s h o r t   A l t e r n a t i v e   =   1 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m M g r s L e t t e r i n g S c h e m e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m P r o j e c t i o n C o d e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n C o d e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A l b e r   =   4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A z e d e   =   5 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A z m e a   =   1 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A z m e d   =   7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B i p o l a r   =   3 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B o n n e   =   2 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C a s s i n i   =   2 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E c k e r t 4   =   2 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E c k e r t 6   =   2 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E d c n c   =   1 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E d c y l   =   2 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G a u s s K   =   4 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G n o m o n i c   =   1 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G o o d e   =   2 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   H o m 1 u v   =   1 2 8 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   H o m 1 x y   =   1 2 8 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   H o m 2 u v   =   1 2 8 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   H o m 2 x y   =   1 2 8 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   K r o v a k   =   4 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   K r v k 9 5   =   5 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L L   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L m 1 s p   =   3 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L m 2 s p   =   3 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L m b l g   =   3 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L m t a n   =   8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M i l l e r   =   1 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M n d o t l   =   4 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M n d o t t   =   4 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M o d p c   =   1 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M o l l w e i d   =   2 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M r c a t   =   6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M r c a t K   =   4 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M s t e r o   =   1 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N e a c y l   =   2 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N e r t h   =   5 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N z e a l a n d   =   1 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O b l q M   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O b q c y l   =   5 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O r t h o   =   1 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O s t n 0 2   =   6 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O s t n 9 7   =   5 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O s t r o   =   3 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P l y c n   =   9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P s t r o   =   3 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P s t r o s l   =   5 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R s k e w   =   1 2 8 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R s k e w c   =   1 2 8 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R s k e w o   =   1 2 8 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R o b i n s o n   =   2 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S i n u s   =   1 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S o t r m   =   4 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S s t r o   =   3 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S w i s s   =   3 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S y s 3 4   =   5 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S y s 3 4 _ 9 9   =   6 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T e a c y l   =   3 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T m   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T r m e r a f   =   5 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T r m r k r g   =   6 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T r m r s   =   4 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   V d g r n t n   =   2 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   W c c s l   =   3 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   W c c s t   =   4 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U t m   =   4 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   W i n k l   =   6 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N r t h s r t   =   6 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L m b r t a f   =   6 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S y s 3 4 _ 0 1   =   6 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E d c y l E   =   6 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P l a t e C a r r e e   =   6 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P v M e r c a t o r   =   6 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L m M i c h   =   7 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U n k n o w n   =   0 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n C o d e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m P r o j e c t i o n F o r m a t T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n F o r m a t T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L n g   =   5 7 5 0 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L a t   =   4 1 1 5 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A n g d   =   3 2 9 3 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C o e f   =   1 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   X x x   =   4 0 9 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   Y y y   =   4 0 9 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S c l   =   7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R o t   =   4 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n F o r m a t T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m P r o j e c t i o n I n f o r m a t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n I n f o r m a t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2   g e t E n u m P r o j e c t i o n s ( ) ;  -
-     p u b l i c   i n t   g e t P a r a m e t e r C o u n t ( i n t ) ;  -
-     p u b l i c   b o o l e a n   i s U s i n g P a r a m e t e r ( i n t ,   i n t ) ;  -
-     p u b l i c   b o o l e a n   i s U s i n g O r i g i n L o n g i t u d e ( i n t ) ;  -
-     p u b l i c   b o o l e a n   i s U s i n g O r i g i n L a t i t u d e ( i n t ) ;  -
-     p u b l i c   b o o l e a n   i s U s i n g S c a l e R e d u c t i o n ( i n t ) ;  -
-     p u b l i c   b o o l e a n   i s U s i n g Q u a d r a n t ( i n t ) ;  -
-     p u b l i c   b o o l e a n   i s U s i n g O f f s e t ( i n t ) ;  -
-     p u b l i c   d o u b l e   g e t P a r a m e t e r M i n ( i n t ,   i n t ) ;  -
-     p u b l i c   d o u b l e   g e t P a r a m e t e r M a x ( i n t ,   i n t ) ;  -
-     p u b l i c   d o u b l e   g e t P a r a m e t e r D e f a u l t ( i n t ,   i n t ) ;  -
-     p u b l i c   i n t   g e t P a r a m e t e r L o g i c a l T y p e ( i n t ,   i n t ) ;  -
-     p u b l i c   i n t   g e t P a r a m e t e r F o r m a t T y p e ( i n t ,   i n t ) ;  -
-     p u b l i c   i n t   g e t P a r a m e t e r T y p e ( i n t ,   i n t ) ;  -
-     p u b l i c   i n t   g e t U n i t T y p e ( i n t ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t T a g S t r i n g ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m P r o j e c t i o n L o g i c a l T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n L o g i c a l T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L o n g i t u d e   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L a t i t u d e   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A z i m u t h   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A n g u l a r D i s t a n c e   =   4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C o m p l e x C o e f f i c i e n t   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U T M Z o n e N u m b e r   =   6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   H e m i s p h e r e S e l e c t i o n   =   7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G e o i d H e i g h t   =   8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E l e v a t i o n   =   9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A f f i n e C o e f f i c i e n t   =   1 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   X Y C o o r d i n a t e   =   1 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S c a l e   =   1 2 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n L o g i c a l T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m P r o j e c t i o n P a r a m e t e r T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n P a r a m e t e r T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N o t U s e d   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C n t m e r   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N s t d p l l   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S s t d p l l   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S t d p l l   =   4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G c p 1 l n g   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G c p 1 l a t   =   6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G c p 2 l n g   =   7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G c p 2 l a t   =   8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G c p l n g   =   9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G c p l a t   =   1 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G c a z m   =   1 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   Y a x i s a z   =   1 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E s t d m e r   =   1 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N p a r a l l   =   1 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S p a r a l l   =   1 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P 1 l n g   =   1 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P 1 l a t   =   1 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P 2 l n g   =   1 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P 2 l a t   =   1 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A d p 1 p 2   =   2 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A d s p 1   =   2 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A d s p 2   =   2 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C m p l x a n   =   2 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C m p l x b n   =   2 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   W e s t l l   =   2 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E a s t l l   =   2 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U t m z n   =   2 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   H s n s   =   2 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G h g t   =   2 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A e l e v   =   3 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P o l e l n g   =   3 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P o l e l a t   =   3 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O s t d p l l   =   3 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S t d c i r   =   3 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A f a 0   =   3 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A f b 0   =   3 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A f a 1   =   3 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A f a 2   =   3 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A f b 1   =   3 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A f b 2   =   4 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N r m l p l l   =   4 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e n r g n   =   4 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S k w a z m   =   4 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S c l r o t o r g x   =   4 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S c l r o t o r g y   =   4 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N r t h s c l   =   4 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N r t h r o t   =   4 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E l l i p s o i d S c a l e   =   4 8 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m P r o j e c t i o n P a r a m e t e r T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m T r a n s f o r m . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m T r a n s f o r m   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T r a n s f o r m O k ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T r a n s f o r m O u t s i d e D o m a i n W a r n i n g ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T r a n s f o r m D a t u m S h i f t W a r n i n g ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T r a n s f o r m T o t a l F a i l u r e ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S o u r c e C r s E r r o r ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D a t u m S h i f t F a l l b a c k ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D a t u m S h i f t E r r o r ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T a r g e t C r s E r r o r ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   t r a n s f o r m ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   t r a n s f o r m M ( d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   t r a n s f o r m ( d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   t r a n s f o r m M ( d o u b l e ,   d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e   t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ) ;  -
-     p u b l i c   v o i d   t r a n s f o r m C o o r d i n a t e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g   g r i d L i n e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   d o u b l e ,   i n t ) ;  -
-     p u b l i c   b o o l e a n   i s V a l i d S o u r c e P o i n t ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   b o o l e a n   i s V a l i d S o u r c e P o i n t ( d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   b o o l e a n   i s V a l i d T a r g e t P o i n t ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   b o o l e a n   i s V a l i d T a r g e t P o i n t ( d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m   g e t S o u r c e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m   g e t T a r g e t ( ) ;  -
-     p u b l i c   v o i d   s e t S o u r c e A n d T a r g e t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m ) ;  -
-     p u b l i c   i n t   g e t G e o d e t i c T r a n s f o r m a t i o n C o u n t ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c T r a n s f o r m D e f   g e t G e o d e t i c T r a n s f o r m a t i o n ( i n t ) ;  -
-     p u b l i c   i n t   g e t G e o d e t i c T r a n s f o r m a t i o n D i r e c t i o n ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m G e o d e t i c P a t h   g e t E x p l i c i t G e o d e t i c P a t h ( ) ;  -
-     p u b l i c   v o i d   i g n o r e D a t u m S h i f t W a r n i n g ( b o o l e a n ) ;  -
-     p u b l i c   b o o l e a n   i s I g n o r e D a t u m S h i f t W a r n i n g ( ) ;  -
-     p u b l i c   v o i d   i g n o r e O u t s i d e D o m a i n W a r n i n g ( b o o l e a n ) ;  -
-     p u b l i c   b o o l e a n   i s I g n o r e O u t s i d e D o m a i n W a r n i n g ( ) ;  -
-     p u b l i c   i n t   g e t S o u r c e W a r n i n g C o u n t ( ) ;  -
-     p u b l i c   i n t   g e t d a t u m W a r n i n g C o u n t ( ) ;  -
-     p u b l i c   i n t   g e t T a r g e t W a r n i n g C o u n t ( ) ;  -
-     p u b l i c   i n t   g e t L a s t T r a n s f o r m S t a t u s ( ) ;  -
-     p u b l i c   v o i d   r e s e t L a s t T r a n s f o r m S t a t u s ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A r b i t r a r y   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G e o g r a p h i c   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P r o j e c t e d   =   3 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m U n i t C o d e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m U n i t C o d e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M e t e r   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   F o o t   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n c h   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I F o o t   =   4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C l a r k e F o o t   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I I n c h   =   6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C e n t i m e t e r   =   7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   K i l o m e t e r   =   8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   Y a r d   =   9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S e a r s Y a r d   =   1 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M i l e   =   1 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I Y a r d   =   1 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I M i l e   =   1 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   K n o t   =   1 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N a u t M   =   1 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L a t 6 6   =   1 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L a t 8 3   =   1 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e c i m e t e r   =   1 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M i l l i m e t e r   =   1 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e k a m e t e r   =   2 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   H e c t o m e t e r   =   2 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G e r m a n M e t e r   =   2 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C a G r i d   =   2 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C l a r k e C h a i n   =   2 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G u n t e r C h a i n   =   2 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B e n o i t C h a i n   =   2 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S e a r s C h a i n   =   2 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C l a r k e L i n k   =   2 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G u n t e r L i n k   =   2 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B e n o i t L i n k   =   3 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S e a r s L i n k   =   3 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R o d   =   3 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P e r c h   =   3 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P o l e   =   3 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   F u r l o n g   =   3 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R o o d   =   3 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C a p e F o o t   =   3 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B r e a l e y   =   3 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S e a r s F o o t   =   3 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G o l d C o a s t F o o t   =   4 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M i c r o I n c h   =   4 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n d i a n Y a r d   =   4 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n d i a n F o o t   =   4 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n d i a n F t 3 7   =   4 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n d i a n F t 6 2   =   4 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n d i a n F t 7 5   =   4 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n d i a n Y d 3 7   =   4 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e c a m e t e r   =   4 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n t e r n a t i o n a l C h a i n   =   4 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n t e r n a t i o n a l L i n k   =   5 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B r F o o t T r u n c   =   5 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B r C h a i n T r u n c   =   5 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B r L i n k T r u n c   =   5 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e g r e e   =   1 0 0 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G r a d   =   1 0 0 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G r a d e   =   1 0 0 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M a p I n f o   =   1 0 0 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M i l   =   1 0 0 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M i n u t e   =   1 0 0 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R a d i a n   =   1 0 0 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S e c o n d   =   1 0 0 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e c i s e c   =   1 0 0 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C e n t i s e c   =   1 0 1 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M i l l i s e c   =   1 0 1 1 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m U n i t C o d e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m U n i t I n f o r m a t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m U n i t I n f o r m a t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2   g e t E n u m L i n e a r U n i t s ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m E n u m I n t e g e r 3 2   g e t E n u m A n g u l a r U n i t s ( ) ;  -
-     p u b l i c   d o u b l e   g e t L i n e a r U n i t S c a l e ( i n t ) ;  -
-     p u b l i c   d o u b l e   g e t A n g u l a r U n i t S c a l e ( i n t ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t A b b r e v i a t i o n ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m U n i t T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m U n i t T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L i n e a r   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A n g u l a r   =   2 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m U n i t T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e S y s t e m W k t F l a v o r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m W k t F l a v o r   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U n k n o w n   =   - 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O g c   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O r a c l e   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E s r i   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E p s g   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G e o t i f f   =   4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G e o t o o l s   =   5 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e S y s t e m W k t F l a v o r ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e X Y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e X Y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   {  -
-     p u b l i c   i n t   g e t D i m e n s i o n ( ) ;  -
-     p u b l i c   d o u b l e   g e t X ( ) ;  -
-     p u b l i c   d o u b l e   g e t Y ( ) ;  -
-     p u b l i c   d o u b l e   g e t Z ( ) ;  -
-     p u b l i c   d o u b l e   g e t M ( ) ;  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e X Y M . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e X Y M   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   {  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e X Y Z . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e X Y Z   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   {  -
- C o m p i l e d   f r o m   " M g C o o r d i n a t e X Y Z M . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e X Y Z M   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   {  -
- C o m p i l e d   f r o m   " M g C u r v e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C u r v e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t S t a r t C o o r d i n a t e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t E n d C o o r d i n a t e ( ) ;  -
- C o m p i l e d   f r o m   " M g C u r v e P o l y g o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g R e g i o n   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g   g e t E x t e r i o r R i n g ( ) ;  -
-     p u b l i c   i n t   g e t I n t e r i o r R i n g C o u n t ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g   g e t I n t e r i o r R i n g ( i n t ) ;  -
-     p u b l i c   i n t   g e t G e o m e t r y T y p e ( ) ;  -
-     p u b l i c   b o o l e a n   i s E m p t y ( ) ;  -
-     p u b l i c   b o o l e a n   i s C l o s e d ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y   c o p y ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y   t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ;  -
- C o m p i l e d   f r o m   " M g C u r v e P o l y g o n C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n   g e t I t e m ( i n t ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n ) ;  -
-     p u b l i c   v o i d   a d d ( o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n C o l l e c t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g C u r v e R i n g . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g R i n g   {  -
-     p u b l i c   i n t   g e t C o m p o n e n t T y p e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t   g e t S e g m e n t ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g C u r v e R i n g C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g   g e t I t e m ( i n t ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g ) ;  -
-     p u b l i c   v o i d   a d d ( o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g C o l l e c t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g C u r v e S e g m e n t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y C o m p o n e n t   {  -
- C o m p i l e d   f r o m   " M g C u r v e S e g m e n t C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t   g e t I t e m ( i n t ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t ) ;  -
-     p u b l i c   v o i d   a d d ( o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t C o l l e c t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g C u r v e S t r i n g . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C u r v e   {  -
- C o m p i l e d   f r o m   " M g C u r v e S t r i n g C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g   g e t I t e m ( i n t ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g ) ;  -
-     p u b l i c   v o i d   a d d ( o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g C o l l e c t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g D a t a P r o p e r t y D e f i n i t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g D a t a P r o p e r t y D e f i n i t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D a t a P r o p e r t y D e f i n i t i o n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   g e t D a t a T y p e ( ) ;  -
-     p u b l i c   i n t   g e t L e n g t h ( ) ;  -
-     p u b l i c   i n t   g e t P r e c i s i o n ( ) ;  -
-     p u b l i c   i n t   g e t S c a l e ( ) ;  -
-     p u b l i c   b o o l e a n   i s A u t o G e n e r a t e d ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D e f a u l t V a l u e ( ) ;  -
-     p u b l i c   b o o l e a n   g e t N u l l a b l e ( ) ;  -
-     p u b l i c   b o o l e a n   g e t R e a d O n l y ( ) ;  -
-     p u b l i c   v o i d   s e t D a t a T y p e ( i n t ) ;  -
-     p u b l i c   v o i d   s e t R e a d O n l y ( b o o l e a n ) ;  -
-     p u b l i c   v o i d   s e t L e n g t h ( i n t ) ;  -
-     p u b l i c   v o i d   s e t P r e c i s i o n ( i n t ) ;  -
-     p u b l i c   v o i d   s e t S c a l e ( i n t ) ;  -
-     p u b l i c   v o i d   s e t N u l l a b l e ( b o o l e a n ) ;  -
-     p u b l i c   v o i d   s e t D e f a u l t V a l u e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t A u t o G e n e r a t i o n ( b o o l e a n ) ;  -
- C o m p i l e d   f r o m   " M g D a t a R e a d e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g D a t a R e a d e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g R e a d e r   i m p l e m e n t s   j a v a . l a n g . A u t o C l o s e a b l e   {  -
- C o m p i l e d   f r o m   " M g D a t e T i m e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ( s h o r t ,   s h o r t ,   s h o r t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ( s h o r t ,   s h o r t ,   s h o r t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ( s h o r t ,   s h o r t ,   s h o r t ,   s h o r t ,   s h o r t ,   s h o r t ,   i n t ) ;  -
-     p u b l i c   s h o r t   g e t D a y ( ) ;  -
-     p u b l i c   s h o r t   g e t M o n t h ( ) ;  -
-     p u b l i c   s h o r t   g e t Y e a r ( ) ;  -
-     p u b l i c   s h o r t   g e t H o u r ( ) ;  -
-     p u b l i c   s h o r t   g e t M i n u t e ( ) ;  -
-     p u b l i c   s h o r t   g e t S e c o n d ( ) ;  -
-     p u b l i c   i n t   g e t M i c r o s e c o n d ( ) ;  -
-     p u b l i c   v o i d   s e t D a y ( s h o r t ) ;  -
-     p u b l i c   v o i d   s e t M o n t h ( s h o r t ) ;  -
-     p u b l i c   v o i d   s e t Y e a r ( s h o r t ) ;  -
-     p u b l i c   v o i d   s e t H o u r ( s h o r t ) ;  -
-     p u b l i c   v o i d   s e t M i n u t e ( s h o r t ) ;  -
-     p u b l i c   v o i d   s e t S e c o n d ( s h o r t ) ;  -
-     p u b l i c   v o i d   s e t M i c r o s e c o n d ( i n t ) ;  -
-     p u b l i c   v o i d   v a l i d a t e ( ) ;  -
-     p u b l i c   b o o l e a n   i s D a t e ( ) ;  -
-     p u b l i c   b o o l e a n   i s T i m e ( ) ;  -
-     p u b l i c   b o o l e a n   i s D a t e T i m e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   t o S t r i n g ( ) ;  -
- C o m p i l e d   f r o m   " M g D a t e T i m e P r o p e r t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e P r o p e r t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e P r o p e r t y ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e   g e t V a l u e ( ) ;  -
-     p u b l i c   s h o r t   g e t P r o p e r t y T y p e ( ) ;  -
-     p u b l i c   v o i d   s e t V a l u e ( o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ) ;  -
- C o m p i l e d   f r o m   " M g D e l e t e F e a t u r e s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g D e l e t e F e a t u r e s   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D e l e t e F e a t u r e s ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   g e t C o m m a n d T y p e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t F e a t u r e C l a s s N a m e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t F i l t e r T e x t ( ) ;  -
- C o m p i l e d   f r o m   " M g D i s p o s a b l e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g O b j e c t   {  -
- C o m p i l e d   f r o m   " M g D i s p o s a b l e C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e C o l l e c t i o n ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e   g e t I t e m ( i n t ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e ) ;  -
-     p u b l i c   v o i d   a d d ( o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   t o X m l ( ) ;  -
- C o m p i l e d   f r o m   " M g D o u b l e P r o p e r t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g D o u b l e P r o p e r t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D o u b l e P r o p e r t y ( j a v a . l a n g . S t r i n g ,   d o u b l e ) ;  -
-     p u b l i c   v o i d   s e t V a l u e ( d o u b l e ) ;  -
- C o m p i l e d   f r o m   " M g D r a w i n g S e r v i c e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g D r a w i n g S e r v i c e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r v i c e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t D r a w i n g ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   d e s c r i b e D r a w i n g ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t S e c t i o n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t S e c t i o n R e s o u r c e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   e n u m e r a t e L a y e r s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t L a y e r ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   e n u m e r a t e S e c t i o n s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   e n u m e r a t e S e c t i o n R e s o u r c e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t C o o r d i n a t e S p a c e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
- C o m p i l e d   f r o m   " M g D w f V e r s i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g D w f V e r s i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D w f V e r s i o n ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t F i l e V e r s i o n ( ) ;  -
-     p u b l i c   v o i d   s e t F i l e V e r s i o n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S c h e m a V e r s i o n ( ) ;  -
-     p u b l i c   v o i d   s e t S c h e m a V e r s i o n ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g E n v e l o p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   s y n c h r o n i z e d   v o i d   d e l e t e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ( d o u b l e ,   d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ( o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t L o w e r L e f t C o o r d i n a t e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t U p p e r R i g h t C o o r d i n a t e ( ) ;  -
-     p u b l i c   d o u b l e   g e t W i d t h ( ) ;  -
-     p u b l i c   d o u b l e   g e t H e i g h t ( ) ;  -
-     p u b l i c   d o u b l e   g e t D e p t h ( ) ;  -
-     p u b l i c   b o o l e a n   i s N u l l ( ) ;  -
-     p u b l i c   v o i d   m a k e N u l l ( ) ;  -
-     p u b l i c   v o i d   e x p a n d T o I n c l u d e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   v o i d   e x p a n d T o I n c l u d e ( o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ) ;  -
-     p u b l i c   b o o l e a n   i n t e r s e c t s ( o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e   t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ;  -
- C o m p i l e d   f r o m   " M g E x c e p t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g E x c e p t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . A p p T h r o w a b l e   {  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t E x c e p t i o n C o d e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t E x c e p t i o n M e s s a g e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D e t a i l s ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t E x c e p t i o n S t a c k T r a c e ( ) ;  -
-     p u b l i c   l o n g   g e t N a t i v e E r r o r C o d e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t E x c e p t i o n M e s s a g e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D e t a i l s ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t E x c e p t i o n S t a c k T r a c e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   a d d S t a c k T r a c e I n f o ( j a v a . l a n g . S t r i n g ,   i n t ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   a d d S t a c k T r a c e I n f o ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   i n t ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   p r i n t S t a c k T r a c e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t M e s s a g e ( ) ;  -
- C o m p i l e d   f r o m   " M g E x c e p t i o n C o d e s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g E x c e p t i o n C o d e s   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g A l l P r o v i d e r C o n n e c t i o n s U s e d E x c e p t i o n   =   " M g A l l P r o v i d e r C o n n e c t i o n s U s e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g A r g u m e n t O u t O f R a n g e E x c e p t i o n   =   " M g A r g u m e n t O u t O f R a n g e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g A r r a y T y p e M i s m a t c h E x c e p t i o n   =   " M g A r r a y T y p e M i s m a t c h E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g A u t h e n t i c a t i o n F a i l e d E x c e p t i o n   =   " M g A u t h e n t i c a t i o n F a i l e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g C l a s s N o t F o u n d E x c e p t i o n   =   " M g C l a s s N o t F o u n d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g C o n f i g u r a t i o n E x c e p t i o n   =   " M g C o n f i g u r a t i o n E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g C o n f i g u r a t i o n S a v e F a i l e d E x c e p t i o n   =   " M g C o n f i g u r a t i o n S a v e F a i l e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g C o n n e c t i o n F a i l e d E x c e p t i o n   =   " M g C o n n e c t i o n F a i l e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g C o n n e c t i o n N o t O p e n E x c e p t i o n   =   " M g C o n n e c t i o n N o t O p e n E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g C o o r d i n a t e S y s t e m C o m p u t a t i o n F a i l e d E x c e p t i o n   =   " M g C o o r d i n a t e S y s t e m C o m p u t a t i o n F a i l e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g C o o r d i n a t e S y s t e m C o n v e r s i o n F a i l e d E x c e p t i o n   =   " M g C o o r d i n a t e S y s t e m C o n v e r s i o n F a i l e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g C o o r d i n a t e S y s t e m I n i t i a l i z a t i o n F a i l e d E x c e p t i o n   =   " M g C o o r d i n a t e S y s t e m I n i t i a l i z a t i o n F a i l e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g C o o r d i n a t e S y s t e m L o a d F a i l e d E x c e p t i o n   =   " M g C o o r d i n a t e S y s t e m L o a d F a i l e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g C o o r d i n a t e S y s t e m M e a s u r e F a i l e d E x c e p t i o n   =   " M g C o o r d i n a t e S y s t e m M e a s u r e F a i l e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g C o o r d i n a t e S y s t e m T r a n s f o r m F a i l e d E x c e p t i o n   =   " M g C o o r d i n a t e S y s t e m T r a n s f o r m F a i l e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D a t e T i m e E x c e p t i o n   =   " M g D a t e T i m e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D b E x c e p t i o n   =   " M g D b E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D b X m l E x c e p t i o n   =   " M g D b X m l E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D e c r y p t i o n E x c e p t i o n   =   " M g D e c r y p t i o n E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D i r e c t o r y N o t F o u n d E x c e p t i o n   =   " M g D i r e c t o r y N o t F o u n d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D i v i d e B y Z e r o E x c e p t i o n   =   " M g D i v i d e B y Z e r o E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D o m a i n E x c e p t i o n   =   " M g D o m a i n E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D u p l i c a t e D i r e c t o r y E x c e p t i o n   =   " M g D u p l i c a t e D i r e c t o r y E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D u p l i c a t e F i l e E x c e p t i o n   =   " M g D u p l i c a t e F i l e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D u p l i c a t e G r o u p E x c e p t i o n   =   " M g D u p l i c a t e G r o u p E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D u p l i c a t e N a m e E x c e p t i o n   =   " M g D u p l i c a t e N a m e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D u p l i c a t e O b j e c t E x c e p t i o n   =   " M g D u p l i c a t e O b j e c t E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D u p l i c a t e P a r a m e t e r E x c e p t i o n   =   " M g D u p l i c a t e P a r a m e t e r E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D u p l i c a t e R e p o s i t o r y E x c e p t i o n   =   " M g D u p l i c a t e R e p o s i t o r y E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D u p l i c a t e R e s o u r c e D a t a E x c e p t i o n   =   " M g D u p l i c a t e R e s o u r c e D a t a E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D u p l i c a t e R e s o u r c e E x c e p t i o n   =   " M g D u p l i c a t e R e s o u r c e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D u p l i c a t e R o l e E x c e p t i o n   =   " M g D u p l i c a t e R o l e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D u p l i c a t e S e r v e r E x c e p t i o n   =   " M g D u p l i c a t e S e r v e r E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D u p l i c a t e S e s s i o n E x c e p t i o n   =   " M g D u p l i c a t e S e s s i o n E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D u p l i c a t e U s e r E x c e p t i o n   =   " M g D u p l i c a t e U s e r E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D w f E x c e p t i o n   =   " M g D w f E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D w f S e c t i o n N o t F o u n d E x c e p t i o n   =   " M g D w f S e c t i o n N o t F o u n d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g D w f S e c t i o n R e s o u r c e N o t F o u n d E x c e p t i o n   =   " M g D w f S e c t i o n R e s o u r c e N o t F o u n d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g E m p t y F e a t u r e S e t E x c e p t i o n   =   " M g E m p t y F e a t u r e S e t E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g E n c r y p t i o n E x c e p t i o n   =   " M g E n c r y p t i o n E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g E n d O f S t r e a m E x c e p t i o n   =   " M g E n d O f S t r e a m E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g E v a l u a t i o n E x p i r e d E x c e p t i o n   =   " M g E v a l u a t i o n E x p i r e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g F d o E x c e p t i o n   =   " M g F d o E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g F e a t u r e S e r v i c e E x c e p t i o n   =   " M g F e a t u r e S e r v i c e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g F i l e I o E x c e p t i o n   =   " M g F i l e I o E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g F i l e N o t F o u n d E x c e p t i o n   =   " M g F i l e N o t F o u n d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g G e o m e t r y E x c e p t i o n   =   " M g G e o m e t r y E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g G r o u p N o t F o u n d E x c e p t i o n   =   " M g G r o u p N o t F o u n d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n d e x O u t O f R a n g e E x c e p t i o n   =   " M g I n d e x O u t O f R a n g e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d A r g u m e n t E x c e p t i o n   =   " M g I n v a l i d A r g u m e n t E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d C a s t E x c e p t i o n   =   " M g I n v a l i d C a s t E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d C o o r d i n a t e S y s t e m E x c e p t i o n   =   " M g I n v a l i d C o o r d i n a t e S y s t e m E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d C o o r d i n a t e S y s t e m T y p e E x c e p t i o n   =   " M g I n v a l i d C o o r d i n a t e S y s t e m T y p e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d C o o r d i n a t e S y s t e m U n i t s E x c e p t i o n   =   " M g I n v a l i d C o o r d i n a t e S y s t e m U n i t s E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d D w f P a c k a g e E x c e p t i o n   =   " M g I n v a l i d D w f P a c k a g e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d D w f S e c t i o n E x c e p t i o n   =   " M g I n v a l i d D w f S e c t i o n E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d F e a t u r e S o u r c e E x c e p t i o n   =   " M g I n v a l i d F e a t u r e S o u r c e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d I p A d d r e s s E x c e p t i o n   =   " M g I n v a l i d I p A d d r e s s E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d L i c e n s e E x c e p t i o n   =   " M g I n v a l i d L i c e n s e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d L o g E n t r y E x c e p t i o n   =   " M g I n v a l i d L o g E n t r y E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d M a p D e f i n i t i o n E x c e p t i o n   =   " M g I n v a l i d M a p D e f i n i t i o n E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d M i m e T y p e E x c e p t i o n   =   " M g I n v a l i d M i m e T y p e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d O p e r a t i o n E x c e p t i o n   =   " M g I n v a l i d O p e r a t i o n E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d O p e r a t i o n V e r s i o n E x c e p t i o n   =   " M g I n v a l i d O p e r a t i o n V e r s i o n E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d P a s s w o r d E x c e p t i o n   =   " M g I n v a l i d P a s s w o r d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d P r i n t L a y o u t F o n t S i z e U n i t s E x c e p t i o n   =   " M g I n v a l i d P r i n t L a y o u t F o n t S i z e U n i t s E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d P r i n t L a y o u t P o s i t i o n U n i t s E x c e p t i o n   =   " M g I n v a l i d P r i n t L a y o u t P o s i t i o n U n i t s E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d P r i n t L a y o u t S i z e U n i t s E x c e p t i o n   =   " M g I n v a l i d P r i n t L a y o u t S i z e U n i t s E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d P r o p e r t y T y p e E x c e p t i o n   =   " M g I n v a l i d P r o p e r t y T y p e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d R e p o s i t o r y N a m e E x c e p t i o n   =   " M g I n v a l i d R e p o s i t o r y N a m e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d R e p o s i t o r y T y p e E x c e p t i o n   =   " M g I n v a l i d R e p o s i t o r y T y p e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d R e s o u r c e D a t a N a m e E x c e p t i o n   =   " M g I n v a l i d R e s o u r c e D a t a N a m e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d R e s o u r c e D a t a T y p e E x c e p t i o n   =   " M g I n v a l i d R e s o u r c e D a t a T y p e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d R e s o u r c e N a m e E x c e p t i o n   =   " M g I n v a l i d R e s o u r c e N a m e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d R e s o u r c e P a t h E x c e p t i o n   =   " M g I n v a l i d R e s o u r c e P a t h E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d R e s o u r c e P r e P r o c e s s i n g T y p e E x c e p t i o n   =   " M g I n v a l i d R e s o u r c e P r e P r o c e s s i n g T y p e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d R e s o u r c e T y p e E x c e p t i o n   =   " M g I n v a l i d R e s o u r c e T y p e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d S e r v e r N a m e E x c e p t i o n   =   " M g I n v a l i d S e r v e r N a m e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d S e r i a l N u m b e r E x c e p t i o n   =   " M g I n v a l i d S e r i a l N u m b e r E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d S t r e a m H e a d e r E x c e p t i o n   =   " M g I n v a l i d S t r e a m H e a d e r E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I o E x c e p t i o n   =   " M g I o E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g L a y e r N o t F o u n d E x c e p t i o n   =   " M g L a y e r N o t F o u n d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g L e n g t h E x c e p t i o n   =   " M g L e n g t h E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g L i c e n s e E x c e p t i o n   =   " M g L i c e n s e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g L i c e n s e E x p i r e d E x c e p t i o n   =   " M g L i c e n s e E x p i r e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g L o g i c E x c e p t i o n   =   " M g L o g i c E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g L o g O p e n F a i l e d E x c e p t i o n   =   " M g L o g O p e n F a i l e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g N o t F i n i t e N u m b e r E x c e p t i o n   =   " M g N o t F i n i t e N u m b e r E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g N o t I m p l e m e n t e d E x c e p t i o n   =   " M g N o t I m p l e m e n t e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g N u l l A r g u m e n t E x c e p t i o n   =   " M g N u l l A r g u m e n t E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g N u l l P r o p e r t y V a l u e E x c e p t i o n   =   " M g N u l l P r o p e r t y V a l u e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g N u l l R e f e r e n c e E x c e p t i o n   =   " M g N u l l R e f e r e n c e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g O b j e c t N o t F o u n d E x c e p t i o n   =   " M g O b j e c t N o t F o u n d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g O p e r a t i o n P r o c e s s i n g E x c e p t i o n   =   " M g O p e r a t i o n P r o c e s s i n g E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g O u t O f M e m o r y E x c e p t i o n   =   " M g O u t O f M e m o r y E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g O u t O f R a n g e E x c e p t i o n   =   " M g O u t O f R a n g e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g O v e r f l o w E x c e p t i o n   =   " M g O v e r f l o w E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g P a r a m e t e r N o t F o u n d E x c e p t i o n   =   " M g P a r a m e t e r N o t F o u n d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g P a t h T o o L o n g E x c e p t i o n   =   " M g P a t h T o o L o n g E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g P e r m i s s i o n D e n i e d E x c e p t i o n   =   " M g P e r m i s s i o n D e n i e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g P l a t f o r m N o t S u p p o r t e d E x c e p t i o n   =   " M g P l a t f o r m N o t S u p p o r t e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g P o r t N o t A v a i l a b l e E x c e p t i o n   =   " M g P o r t N o t A v a i l a b l e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g P r i n t T o S c a l e M o d e N o t S e l e c t e d E x c e p t i o n   =   " M g P r i n t T o S c a l e M o d e N o t S e l e c t e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g R a s t e r T r a n s f o r m a t i o n N o t S u p p o r t e d E x c e p t i o n   =   " M g R a s t e r T r a n s f o r m a t i o n N o t S u p p o r t e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g R e p o s i t o r y C r e a t i o n F a i l e d E x c e p t i o n   =   " M g R e p o s i t o r y C r e a t i o n F a i l e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g R e p o s i t o r y N o t F o u n d E x c e p t i o n   =   " M g R e p o s i t o r y N o t F o u n d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g R e p o s i t o r y N o t O p e n E x c e p t i o n   =   " M g R e p o s i t o r y N o t O p e n E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g R e p o s i t o r y O p e n F a i l e d E x c e p t i o n   =   " M g R e p o s i t o r y O p e n F a i l e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g R e s o u r c e B u s y E x c e p t i o n   =   " M g R e s o u r c e B u s y E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g R e s o u r c e D a t a N o t F o u n d E x c e p t i o n   =   " M g R e s o u r c e D a t a N o t F o u n d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g R e s o u r c e N o t F o u n d E x c e p t i o n   =   " M g R e s o u r c e N o t F o u n d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g R e s o u r c e s E x c e p t i o n   =   " M g R e s o u r c e s E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g R e s o u r c e T a g N o t F o u n d E x c e p t i o n   =   " M g R e s o u r c e T a g N o t F o u n d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g R o l e N o t F o u n d E x c e p t i o n   =   " M g R o l e N o t F o u n d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g R u n t i m e E x c e p t i o n   =   " M g R u n t i m e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g S e r v e r N o t F o u n d E x c e p t i o n   =   " M g S e r v e r N o t F o u n d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g S e r v e r N o t O n l i n e E x c e p t i o n   =   " M g S e r v e r N o t O n l i n e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g S e r v i c e N o t A v a i l a b l e E x c e p t i o n   =   " M g S e r v i c e N o t A v a i l a b l e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g S e r v i c e N o t S u p p o r t e d E x c e p t i o n   =   " M g S e r v i c e N o t S u p p o r t e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g S e s s i o n E x p i r e d E x c e p t i o n   =   " M g S e s s i o n E x p i r e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g S e s s i o n N o t F o u n d E x c e p t i o n   =   " M g S e s s i o n N o t F o u n d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g S t r e a m I o E x c e p t i o n   =   " M g S t r e a m I o E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g S t y l i z e L a y e r F a i l e d E x c e p t i o n   =   " M g S t y l i z e L a y e r F a i l e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g T e m p o r a r y F i l e N o t A v a i l a b l e E x c e p t i o n   =   " M g T e m p o r a r y F i l e N o t A v a i l a b l e E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g U n a u t h o r i z e d A c c e s s E x c e p t i o n   =   " M g U n a u t h o r i z e d A c c e s s E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g U n c l a s s i f i e d E x c e p t i o n   =   " M g U n c l a s s i f i e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g U n d e r f l o w E x c e p t i o n   =   " M g U n d e r f l o w E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g U n k n o w n T i l e P r o v i d e r E x c e p t i o n   =   " M g U n k n o w n T i l e P r o v i d e r E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g U n s u p p o r t e d P r o v i d e r T h r e a d M o d e l E x c e p t i o n   =   " M g U n s u p p o r t e d P r o v i d e r T h r e a d M o d e l E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g U n s u p p o r t e d T i l e P r o v i d e r E x c e p t i o n   =   " M g U n s u p p o r t e d T i l e P r o v i d e r E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g U r i F o r m a t E x c e p t i o n   =   " M g U r i F o r m a t E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g U s e r N o t F o u n d E x c e p t i o n   =   " M g U s e r N o t F o u n d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g X m l E x c e p t i o n   =   " M g X m l E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g X m l P a r s e r E x c e p t i o n   =   " M g X m l P a r s e r E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g C o n f i g u r a t i o n L o a d F a i l e d E x c e p t i o n   =   " M g C o n f i g u r a t i o n L o a d F a i l e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g R e s o u r c e s L o a d F a i l e d E x c e p t i o n   =   " M g R e s o u r c e s L o a d F a i l e d E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g G r i d D e n s i t y E x c e p t i o n   =   " M g G r i d D e n s i t y E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d L a y e r D e f i n i t i o n E x c e p t i o n   =   " M g I n v a l i d L a y e r D e f i n i t i o n E x c e p t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M g I n v a l i d W a t e r m a r k D e f i n i t i o n E x c e p t i o n   =   " M g I n v a l i d W a t e r m a r k D e f i n i t i o n E x c e p t i o n " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g E x c e p t i o n C o d e s ( ) ;  -
- C o m p i l e d   f r o m   " M g F e a t u r e A g g r e g a t e O p t i o n s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e A g g r e g a t e O p t i o n s   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e Q u e r y O p t i o n s   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e A g g r e g a t e O p t i o n s ( ) ;  -
-     p u b l i c   v o i d   s e l e c t D i s t i n c t ( b o o l e a n ) ;  -
-     p u b l i c   v o i d   s e t G r o u p i n g F i l t e r ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g F e a t u r e C o m m a n d . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
- C o m p i l e d   f r o m   " M g F e a t u r e C o m m a n d C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   i n t   g e t C o u n t ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d   g e t I t e m ( i n t ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d ) ;  -
-     p u b l i c   v o i d   a d d ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d ) ;  -
-     p u b l i c   v o i d   c l e a r ( ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d ) ;  -
-     p u b l i c   v o i d   r e m o v e A t ( i n t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g F e a t u r e C o m m a n d T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n s e r t F e a t u r e s   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U p d a t e F e a t u r e s   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e l e t e F e a t u r e s   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L o c k F e a t u r e s   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U n l o c k F e a t u r e s   =   4 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g F e a t u r e G e o m e t r i c T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e G e o m e t r i c T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P o i n t   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C u r v e   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S u r f a c e   =   4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S o l i d   =   8 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e G e o m e t r i c T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g F e a t u r e I n f o r m a t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e I n f o r m a t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n   g e t S e l e c t i o n ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t T o o l t i p ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t H y p e r l i n k ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n   g e t P r o p e r t i e s ( ) ;  -
- C o m p i l e d   f r o m   " M g F e a t u r e P r o p e r t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e P r o p e r t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e P r o p e r t y ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   g e t V a l u e ( ) ;  -
-     p u b l i c   v o i d   s e t V a l u e ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r ) ;  -
- C o m p i l e d   f r o m   " M g F e a t u r e P r o p e r t y T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e P r o p e r t y T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D a t a P r o p e r t y   =   1 0 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O b j e c t P r o p e r t y   =   1 0 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G e o m e t r i c P r o p e r t y   =   1 0 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A s s o c i a t i o n P r o p e r t y   =   1 0 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R a s t e r P r o p e r t y   =   1 0 4 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e P r o p e r t y T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g F e a t u r e Q u e r y O p t i o n s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e Q u e r y O p t i o n s   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e Q u e r y O p t i o n s ( ) ;  -
-     p u b l i c   i n t   a d d F e a t u r e P r o p e r t y ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   a d d C o m p u t e d P r o p e r t y ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t F i l t e r ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t B i n a r y O p e r a t o r ( b o o l e a n ) ;  -
-     p u b l i c   v o i d   s e t S p a t i a l F i l t e r ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ,   i n t ) ;  -
-     p u b l i c   v o i d   s e t O r d e r i n g F i l t e r ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   i n t ) ;  -
-     p u b l i c   v o i d   r e m o v e F e a t u r e P r o p e r t y ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   r e m o v e C o m p u t e d P r o p e r t y ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t F e t c h S i z e ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g F e a t u r e R e a d e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g R e a d e r   i m p l e m e n t s   j a v a . l a n g . A u t o C l o s e a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n   g e t C l a s s D e f i n i t i o n ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   g e t F e a t u r e O b j e c t ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   g e t F e a t u r e O b j e c t ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g F e a t u r e S c h e m a . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e   {  -
-     p u b l i c   b o o l e a n   e q u a l s ( j a v a . l a n g . O b j e c t ) ;  -
-     p u b l i c   i n t   h a s h C o d e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t N a m e ( ) ;  -
-     p u b l i c   v o i d   s e t N a m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D e s c r i p t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t D e s c r i p t i o n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n C o l l e c t i o n   g e t C l a s s e s ( ) ;  -
-     p u b l i c   v o i d   m a r k A s D e l e t e d ( ) ;  -
- C o m p i l e d   f r o m   " M g F e a t u r e S c h e m a C o l l e c t i o n . j a v a "  -
- c l a s s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n $ I t e m I t e r a t o r   i m p l e m e n t s   j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a >   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n $ I t e m I t e r a t o r ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n ) ;  -
-     p u b l i c   b o o l e a n   h a s N e x t ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a   n e x t ( ) ;  -
-     p u b l i c   v o i d   r e m o v e ( ) ;  -
-     p u b l i c   j a v a . l a n g . O b j e c t   n e x t ( ) ;  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n   i m p l e m e n t s   j a v a . u t i l . C o l l e c t i o n < o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a >   {  -
-     p u b l i c   j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a >   i t e r a t o r ( ) ;  -
-     p u b l i c   b o o l e a n   a d d ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ;  -
-     p u b l i c   b o o l e a n   a d d A l l ( j a v a . u t i l . C o l l e c t i o n < ?   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a > ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( j a v a . l a n g . O b j e c t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( j a v a . l a n g . O b j e c t ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ;  -
-     p u b l i c   b o o l e a n   r e t a i n A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ;  -
-     p u b l i c   i n t   s i z e ( ) ;  -
-     p u b l i c   j a v a . l a n g . O b j e c t [ ]   t o A r r a y ( ) ;  -
-     p u b l i c   < M g F e a t u r e S c h e m a >   M g F e a t u r e S c h e m a [ ]   t o A r r a y ( M g F e a t u r e S c h e m a [ ] ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ;  -
-     p u b l i c   v o i d   a d d I t e m ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a   g e t I t e m ( i n t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ;  -
-     p u b l i c   b o o l e a n   a d d ( j a v a . l a n g . O b j e c t ) ;  -
- C o m p i l e d   f r o m   " M g F e a t u r e S e r v i c e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S e r v i c e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r v i c e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t F e a t u r e P r o v i d e r s ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   g e t C o n n e c t i o n P r o p e r t y V a l u e s ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   t e s t C o n n e c t i o n ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   t e s t C o n n e c t i o n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t C a p a b i l i t i e s ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t C a p a b i l i t i e s ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   a p p l y S c h e m a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n   d e s c r i b e S c h e m a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n   d e s c r i b e S c h e m a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   d e s c r i b e S c h e m a A s X m l ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   d e s c r i b e S c h e m a A s X m l ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   s c h e m a T o X m l ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a C o l l e c t i o n   x m l T o S c h e m a ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   s e l e c t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g F e a t u r e Q u e r y O p t i o n s ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   s e l e c t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g F e a t u r e Q u e r y O p t i o n s ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D a t a R e a d e r   s e l e c t A g g r e g a t e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g F e a t u r e A g g r e g a t e O p t i o n s ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n   u p d a t e F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n   u p d a t e F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   i n s e r t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   i n s e r t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   i n s e r t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   i n s e r t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ;  -
-     p u b l i c   i n t   u p d a t e M a t c h i n g F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   u p d a t e M a t c h i n g F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ;  -
-     p u b l i c   i n t   d e l e t e F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   d e l e t e F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   g e t L o c k e d F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g F e a t u r e Q u e r y O p t i o n s ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n   b e g i n T r a n s a c t i o n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S q l D a t a R e a d e r   e x e c u t e S q l Q u e r y ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S q l D a t a R e a d e r   e x e c u t e S q l Q u e r y ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ;  -
-     p u b l i c   i n t   e x e c u t e S q l N o n Q u e r y ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   e x e c u t e S q l N o n Q u e r y ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S p a t i a l C o n t e x t R e a d e r   g e t S p a t i a l C o n t e x t s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L o n g T r a n s a c t i o n R e a d e r   g e t L o n g T r a n s a c t i o n s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   b o o l e a n ) ;  -
-     p u b l i c   b o o l e a n   s e t L o n g T r a n s a c t i o n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   g e t S c h e m a s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   g e t C l a s s e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n   g e t C l a s s D e f i n i t i o n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   c r e a t e F e a t u r e S o u r c e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S o u r c e P a r a m s ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   d e s c r i b e W f s F e a t u r e T y p e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   d e s c r i b e W f s F e a t u r e T y p e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t W f s F e a t u r e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t W f s F e a t u r e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   i n t ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   g e t W f s R e a d e r ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   e n u m e r a t e D a t a S t o r e s ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t S c h e m a M a p p i n g ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g F e a t u r e S o u r c e P a r a m s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S o u r c e P a r a m s   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
- C o m p i l e d   f r o m   " M g F e a t u r e S p a t i a l O p e r a t i o n s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S p a t i a l O p e r a t i o n s   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C o n t a i n s   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C r o s s e s   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D i s j o i n t   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E q u a l s   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n t e r s e c t s   =   4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O v e r l a p s   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T o u c h e s   =   6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   W i t h i n   =   7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C o v e r e d B y   =   8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n s i d e   =   9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   E n v e l o p e I n t e r s e c t s   =   1 0 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S p a t i a l O p e r a t i o n s ( ) ;  -
- C o m p i l e d   f r o m   " M g F i l e F e a t u r e S o u r c e P a r a m s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g F i l e F e a t u r e S o u r c e P a r a m s   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S o u r c e P a r a m s   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F i l e F e a t u r e S o u r c e P a r a m s ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F i l e F e a t u r e S o u r c e P a r a m s ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F i l e F e a t u r e S o u r c e P a r a m s ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t P r o v i d e r N a m e ( ) ;  -
-     p u b l i c   v o i d   s e t P r o v i d e r N a m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t F i l e N a m e ( ) ;  -
-     p u b l i c   v o i d   s e t F i l e N a m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S p a t i a l C o n t e x t N a m e ( ) ;  -
-     p u b l i c   v o i d   s e t S p a t i a l C o n t e x t N a m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S p a t i a l C o n t e x t D e s c r i p t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t S p a t i a l C o n t e x t D e s c r i p t i o n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t C o o r d i n a t e S y s t e m W k t ( ) ;  -
-     p u b l i c   v o i d   s e t C o o r d i n a t e S y s t e m W k t ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   d o u b l e   g e t X Y T o l e r a n c e ( ) ;  -
-     p u b l i c   v o i d   s e t X Y T o l e r a n c e ( d o u b l e ) ;  -
-     p u b l i c   d o u b l e   g e t Z T o l e r a n c e ( ) ;  -
-     p u b l i c   v o i d   s e t Z T o l e r a n c e ( d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a   g e t F e a t u r e S c h e m a ( ) ;  -
-     p u b l i c   v o i d   s e t F e a t u r e S c h e m a ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S c h e m a ) ;  -
- C o m p i l e d   f r o m   " M g G e o J s o n W r i t e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G e o J s o n W r i t e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o J s o n W r i t e r ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   f e a t u r e T o G e o J s o n ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r ,   o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   f e a t u r e T o G e o J s o n ( o r g . o s g e o . m a p g u i d e . M g R e a d e r ,   o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t P r e c i s i o n ( i n t ) ;  -
-     p u b l i c   i n t   g e t P r e c i s i o n ( ) ;  -
-     p u b l i c   v o i d   s e t P r e c i s i o n E n a b l e d ( b o o l e a n ) ;  -
-     p u b l i c   b o o l e a n   i s P r e c i s i o n E n a b l e d ( ) ;  -
- C o m p i l e d   f r o m   " M g G e o m e t r i c E n t i t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   i n t   g e t D i m e n s i o n ( ) ;  -
-     p u b l i c   b o o l e a n   i s E m p t y ( ) ;  -
-     p u b l i c   b o o l e a n   i s S i m p l e ( ) ;  -
-     p u b l i c   b o o l e a n   i s C l o s e d ( ) ;  -
-     p u b l i c   b o o l e a n   i s V a l i d ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e   e n v e l o p e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y   c o p y ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y   t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ;  -
-     p u b l i c   d o u b l e   g e t A r e a ( ) ;  -
-     p u b l i c   d o u b l e   g e t L e n g t h ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P o i n t   g e t C e n t r o i d ( ) ;  -
- C o m p i l e d   f r o m   " M g G e o m e t r i c P a t h I n s t r u c t i o n T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c P a t h I n s t r u c t i o n T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M o v e T o   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L i n e T o   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   Q u a d T o   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C l o s e   =   4 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c P a t h I n s t r u c t i o n T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g G e o m e t r i c P r o p e r t y D e f i n i t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c P r o p e r t y D e f i n i t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n   {  -
-     p u b l i c   s y n c h r o n i z e d   v o i d   d e l e t e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c P r o p e r t y D e f i n i t i o n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   g e t G e o m e t r y T y p e s ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y T y p e I n f o   g e t S p e c i f i c G e o m e t r y T y p e s ( ) ;  -
-     p u b l i c   b o o l e a n   g e t R e a d O n l y ( ) ;  -
-     p u b l i c   b o o l e a n   g e t H a s E l e v a t i o n ( ) ;  -
-     p u b l i c   b o o l e a n   g e t H a s M e a s u r e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S p a t i a l C o n t e x t A s s o c i a t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t G e o m e t r y T y p e s ( i n t ) ;  -
-     p u b l i c   v o i d   s e t S p e c i f i c G e o m e t r y T y p e s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y T y p e I n f o ) ;  -
-     p u b l i c   v o i d   s e t R e a d O n l y ( b o o l e a n ) ;  -
-     p u b l i c   v o i d   s e t H a s E l e v a t i o n ( b o o l e a n ) ;  -
-     p u b l i c   v o i d   s e t H a s M e a s u r e ( b o o l e a n ) ;  -
-     p u b l i c   v o i d   s e t S p a t i a l C o n t e x t A s s o c i a t i o n ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g G e o m e t r y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y   {  -
-     p u b l i c   i n t   g e t G e o m e t r y T y p e ( ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   b o o l e a n   c r o s s e s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   b o o l e a n   d i s j o i n t ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   b o o l e a n   e q u a l s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   b o o l e a n   i n t e r s e c t s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   b o o l e a n   o v e r l a p s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   b o o l e a n   t o u c h e s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   b o o l e a n   w i t h i n ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   b o u n d a r y ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   b u f f e r ( d o u b l e ,   o r g . o s g e o . m a p g u i d e . M g M e a s u r e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   c o n v e x H u l l ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   d i f f e r e n c e ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   d o u b l e   d i s t a n c e ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ,   o r g . o s g e o . m a p g u i d e . M g M e a s u r e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   i n t e r s e c t i o n ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   s y m e t r i c D i f f e r e n c e ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   u n i o n ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r e p a r e d G e o m e t r y   p r e p a r e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   t e s s e l l a t e ( ) ;  -
- C o m p i l e d   f r o m   " M g G e o m e t r y C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   g e t I t e m ( i n t ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   v o i d   a d d ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y C o l l e c t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g G e o m e t r y C o m p o n e n t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y C o m p o n e n t   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y   {  -
-     p u b l i c   i n t   g e t C o m p o n e n t T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g G e o m e t r y C o m p o n e n t T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y C o m p o n e n t T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L i n e a r R i n g   =   1 2 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A r c S e g m e n t   =   1 3 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L i n e a r S e g m e n t   =   1 3 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C u r v e R i n g   =   1 3 2 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y C o m p o n e n t T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g G e o m e t r y E n t i t y T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y E n t i t y T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G e o m e t r y C o m p o n e n t   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G e o m e t r y   =   1 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y E n t i t y T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g G e o m e t r y F a c t o r y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y F a c t o r y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y F a c t o r y ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   c r e a t e C o o r d i n a t e X Y ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   c r e a t e C o o r d i n a t e X Y M ( d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   c r e a t e C o o r d i n a t e X Y Z ( d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   c r e a t e C o o r d i n a t e X Y Z M ( d o u b l e ,   d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g A r c S e g m e n t   c r e a t e A r c S e g m e n t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L i n e a r S e g m e n t   c r e a t e L i n e a r S e g m e n t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g   c r e a t e L i n e a r R i n g ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g   c r e a t e C u r v e R i n g ( o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P o i n t   c r e a t e P o i n t ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g   c r e a t e L i n e S t r i n g ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g   c r e a t e C u r v e S t r i n g ( o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P o l y g o n   c r e a t e P o l y g o n ( o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g ,   o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n   c r e a t e C u r v e P o l y g o n ( o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g ,   o r g . o s g e o . m a p g u i d e . M g C u r v e R i n g C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M u l t i P o i n t   c r e a t e M u l t i P o i n t ( o r g . o s g e o . m a p g u i d e . M g P o i n t C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M u l t i L i n e S t r i n g   c r e a t e M u l t i L i n e S t r i n g ( o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M u l t i C u r v e S t r i n g   c r e a t e M u l t i C u r v e S t r i n g ( o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M u l t i P o l y g o n   c r e a t e M u l t i P o l y g o n ( o r g . o s g e o . m a p g u i d e . M g P o l y g o n C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M u l t i C u r v e P o l y g o n   c r e a t e M u l t i C u r v e P o l y g o n ( o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M u l t i G e o m e t r y   c r e a t e M u l t i G e o m e t r y ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y C o l l e c t i o n ) ;  -
- C o m p i l e d   f r o m   " M g G e o m e t r y P r o p e r t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y P r o p e r t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y P r o p e r t y ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t V a l u e ( ) ;  -
-     p u b l i c   s h o r t   g e t P r o p e r t y T y p e ( ) ;  -
-     p u b l i c   v o i d   s e t V a l u e ( o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ;  -
- C o m p i l e d   f r o m   " M g G e o m e t r y S i m p l i f i c a t i o n A l g o r i t h m T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y S i m p l i f i c a t i o n A l g o r i t h m T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D o u g l a s P e u c k e r   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T o p o l o g y P r e s e r v i n g   =   1 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y S i m p l i f i c a t i o n A l g o r i t h m T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g G e o m e t r y S i m p l i f i e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y S i m p l i f i e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y S i m p l i f i e r ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   s i m p l i f y ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ,   d o u b l e ,   i n t ) ;  -
- C o m p i l e d   f r o m   " M g G e o m e t r y T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   L i n e S t r i n g   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P o l y g o n   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M u l t i P o i n t   =   4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M u l t i L i n e S t r i n g   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M u l t i P o l y g o n   =   6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M u l t i G e o m e t r y   =   7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C u r v e S t r i n g   =   1 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C u r v e P o l y g o n   =   1 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M u l t i C u r v e S t r i n g   =   1 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M u l t i C u r v e P o l y g o n   =   1 3 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g G e o m e t r y T y p e I n f o . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y T y p e I n f o   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y T y p e I n f o ( ) ;  -
-     p u b l i c   i n t   g e t T y p e ( i n t ) ;  -
-     p u b l i c   v o i d   s e t T y p e s ( o r g . o s g e o . m a p g u i d e . M g I n t C o l l e c t i o n ) ;  -
- C o m p i l e d   f r o m   " M g G r o u p . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G r o u p   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   E v e r y o n e   =   " E v e r y o n e " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G r o u p ( ) ;  -
- C o m p i l e d   f r o m   " M g G u a r d D i s p o s a b l e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e   {  -
- C o m p i l e d   f r o m   " M g G w s F e a t u r e R e a d e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g G w s F e a t u r e R e a d e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   {  -
- C o m p i l e d   f r o m   " M g H t t p H e a d e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g H t t p H e a d e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g H t t p H e a d e r ( ) ;  -
-     p u b l i c   b o o l e a n   a d d H e a d e r ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e H e a d e r ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t H e a d e r V a l u e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   s e t H e a d e r V a l u e ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   g e t D a t e H e a d e r ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   g e t I n t H e a d e r ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   g e t H e a d e r N a m e s ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   g e t H e a d e r s ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g H t t p P r i m i t i v e V a l u e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g H t t p P r i m i t i v e V a l u e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g H t t p P r i m i t i v e V a l u e ( b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g H t t p P r i m i t i v e V a l u e ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g H t t p P r i m i t i v e V a l u e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   g e t T y p e ( ) ;  -
-     p u b l i c   b o o l e a n   g e t B o o l V a l u e ( ) ;  -
-     p u b l i c   i n t   g e t I n t e g e r V a l u e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S t r i n g V a l u e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   t o S t r i n g ( ) ;  -
- C o m p i l e d   f r o m   " M g H t t p R e q u e s t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g H t t p R e q u e s t   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g H t t p R e q u e s t ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g H t t p H e a d e r   g e t H e a d e r ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g H t t p R e q u e s t P a r a m   g e t R e q u e s t P a r a m ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g H t t p R e q u e s t M e t a d a t a   g e t R e q u e s t M e t a d a t a ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g H t t p R e s p o n s e   e x e c u t e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t A g e n t U r i ( ) ;  -
- C o m p i l e d   f r o m   " M g H t t p R e q u e s t M e t a d a t a . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g H t t p R e q u e s t M e t a d a t a   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g H t t p R e q u e s t M e t a d a t a ( ) ;  -
-     p u b l i c   b o o l e a n   a d d P r o p e r t y ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e P r o p e r t y ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t P r o p e r t y V a l u e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   s e t P r o p e r t y V a l u e ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   g e t P r o p e r t y N a m e s ( ) ;  -
- C o m p i l e d   f r o m   " M g H t t p R e q u e s t P a r a m . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g H t t p R e q u e s t P a r a m   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g H t t p R e q u e s t P a r a m ( ) ;  -
-     p u b l i c   b o o l e a n   a d d P a r a m e t e r ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e P a r a m e t e r ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t P a r a m e t e r V a l u e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t P a r a m e t e r T y p e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   s e t P a r a m e t e r V a l u e ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   s e t P a r a m e t e r T y p e ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   g e t P a r a m e t e r N a m e s ( ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s P a r a m e t e r ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g H t t p R e s p o n s e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g H t t p R e s p o n s e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g H t t p R e s p o n s e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g H t t p R e s u l t   g e t R e s u l t ( ) ;  -
- C o m p i l e d   f r o m   " M g H t t p R e s u l t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g H t t p R e s u l t   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   i n t   g e t S t a t u s C o d e ( ) ;  -
-     p u b l i c   v o i d   s e t S t a t u s C o d e ( i n t ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t E r r o r M e s s a g e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D e t a i l e d E r r o r M e s s a g e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t H t t p S t a t u s M e s s a g e ( ) ;  -
-     p u b l i c   v o i d   s e t E r r o r M e s s a g e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t D e t a i l e d E r r o r M e s s a g e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t H t t p S t a t u s M e s s a g e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e   g e t R e s u l t O b j e c t ( ) ;  -
-     p u b l i c   v o i d   s e t R e s u l t O b j e c t ( o r g . o s g e o . m a p g u i d e . M g D i s p o s a b l e ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t R e s u l t C o n t e n t T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g I m a g e F o r m a t s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g I m a g e F o r m a t s   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G i f   =   " G I F " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   J p e g   =   " J P G " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P n g   =   " P N G " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P n g 8   =   " P N G 8 " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T i f f   =   " T I F " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   R a w   =   " R A W " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M e t a   =   " M E T A " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g I m a g e F o r m a t s ( ) ;  -
- C o m p i l e d   f r o m   " M g I n s e r t F e a t u r e s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g I n s e r t F e a t u r e s   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g I n s e r t F e a t u r e s ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g I n s e r t F e a t u r e s ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n ) ;  -
-     p u b l i c   i n t   g e t C o m m a n d T y p e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n   g e t P r o p e r t y V a l u e s ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t F e a t u r e C l a s s N a m e ( ) ;  -
- C o m p i l e d   f r o m   " M g I n t 1 6 P r o p e r t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g I n t 1 6 P r o p e r t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g I n t 1 6 P r o p e r t y ( j a v a . l a n g . S t r i n g ,   s h o r t ) ;  -
-     p u b l i c   s h o r t   g e t V a l u e ( ) ;  -
-     p u b l i c   v o i d   s e t V a l u e ( s h o r t ) ;  -
- C o m p i l e d   f r o m   " M g I n t 3 2 P r o p e r t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g I n t 3 2 P r o p e r t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g I n t 3 2 P r o p e r t y ( j a v a . l a n g . S t r i n g ,   i n t ) ;  -
-     p u b l i c   i n t   g e t V a l u e ( ) ;  -
-     p u b l i c   v o i d   s e t V a l u e ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g I n t 6 4 P r o p e r t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g I n t 6 4 P r o p e r t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g I n t 6 4 P r o p e r t y ( j a v a . l a n g . S t r i n g ,   l o n g ) ;  -
-     p u b l i c   l o n g   g e t V a l u e ( ) ;  -
-     p u b l i c   v o i d   s e t V a l u e ( l o n g ) ;  -
- C o m p i l e d   f r o m   " M g I n t C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g I n t C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g I n t C o l l e c t i o n ( ) ;  -
-     p u b l i c   i n t   g e t I t e m ( i n t ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   i n t ) ;  -
-     p u b l i c   v o i d   a d d I t e m ( i n t ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   i n t ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( i n t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( i n t ) ;  -
-     p u b l i c   i n t   i n d e x O f ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   t o X m l ( ) ;  -
- C o m p i l e d   f r o m   " M g K m l S e r v i c e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g K m l S e r v i c e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r v i c e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t M a p K m l ( o r g . o s g e o . m a p g u i d e . M g M a p ,   d o u b l e ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t L a y e r K m l ( o r g . o s g e o . m a p g u i d e . M g L a y e r ,   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ,   i n t ,   i n t ,   d o u b l e ,   i n t ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t F e a t u r e s K m l ( o r g . o s g e o . m a p g u i d e . M g L a y e r ,   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ,   i n t ,   i n t ,   d o u b l e ,   i n t ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t F e a t u r e s K m l ( o r g . o s g e o . m a p g u i d e . M g L a y e r ,   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ,   i n t ,   i n t ,   d o u b l e ,   i n t ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g L a y e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g L a y e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   s e l e c t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e Q u e r y O p t i o n s ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   s e l e c t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e Q u e r y O p t i o n s ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D a t a R e a d e r   s e l e c t A g g r e g a t e ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e A g g r e g a t e O p t i o n s ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n   u p d a t e F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n   b e g i n T r a n s a c t i o n ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n   u p d a t e F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   i n s e r t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   i n s e r t F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ;  -
-     p u b l i c   i n t   u p d a t e M a t c h i n g F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ;  -
-     p u b l i c   i n t   d e l e t e F e a t u r e s ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g I n t C o l l e c t i o n   g e t G e o m e t r y T y p e S t y l e s ( ) ;  -
-     p u b l i c   i n t   g e t T h e m e C a t e g o r y C o u n t ( i n t ) ;  -
-     p u b l i c   i n t   g e t C o m p o s i t e T h e m e C a t e g o r y C o u n t ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e n e r a t e L e g e n d I m a g e ( i n t ,   i n t ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g I n t C o l l e c t i o n   g e t G e o m e t r y T y p e S t y l e s ( d o u b l e ) ;  -
-     p u b l i c   i n t   g e t T h e m e C a t e g o r y C o u n t ( d o u b l e ,   i n t ) ;  -
-     p u b l i c   i n t   g e t C o m p o s i t e T h e m e C a t e g o r y C o u n t ( d o u b l e ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e n e r a t e L e g e n d I m a g e ( d o u b l e ,   i n t ,   i n t ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S p a t i a l C o n t e x t R e a d e r   g e t S p a t i a l C o n t e x t s ( b o o l e a n ) ;  -
- C o m p i l e d   f r o m   " M g L a y e r B a s e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t O b j e c t I d ( ) ;  -
-     p u b l i c   i n t   g e t L a y e r T y p e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p   g e t G r o u p ( ) ;  -
-     p u b l i c   v o i d   s e t G r o u p ( o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ) ;  -
-     p u b l i c   b o o l e a n   n e e d s R e f r e s h ( ) ;  -
-     p u b l i c   v o i d   f o r c e R e f r e s h ( ) ;  -
-     p u b l i c   b o o l e a n   g e t V i s i b l e ( ) ;  -
-     p u b l i c   v o i d   s e t V i s i b l e ( b o o l e a n ) ;  -
-     p u b l i c   b o o l e a n   i s V i s i b l e ( ) ;  -
-     p u b l i c   b o o l e a n   g e t S e l e c t a b l e ( ) ;  -
-     p u b l i c   v o i d   s e t S e l e c t a b l e ( b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r   g e t L a y e r D e f i n i t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t L a y e r D e f i n i t i o n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e ) ;  -
-     p u b l i c   b o o l e a n   g e t D i s p l a y I n L e g e n d ( ) ;  -
-     p u b l i c   v o i d   s e t D i s p l a y I n L e g e n d ( b o o l e a n ) ;  -
-     p u b l i c   b o o l e a n   g e t E x p a n d I n L e g e n d ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t L e g e n d L a b e l ( ) ;  -
-     p u b l i c   v o i d   s e t L e g e n d L a b e l ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t F e a t u r e S o u r c e I d ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t F i l t e r ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t F e a t u r e G e o m e t r y N a m e ( ) ;  -
- C o m p i l e d   f r o m   " M g L a y e r C o l l e c t i o n . j a v a "  -
- c l a s s   o r g . o s g e o . m a p g u i d e . M g L a y e r C o l l e c t i o n $ I t e m I t e r a t o r   i m p l e m e n t s   j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e >   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r C o l l e c t i o n $ I t e m I t e r a t o r ( o r g . o s g e o . m a p g u i d e . M g L a y e r C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g L a y e r C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e   n e x t ( ) ;  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g L a y e r C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   i m p l e m e n t s   j a v a . u t i l . C o l l e c t i o n < o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e >   {  -
-     p u b l i c   j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e >   i t e r a t o r ( ) ;  -
-     p u b l i c   b o o l e a n   a d d ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ;  -
-     p u b l i c   b o o l e a n   a d d A l l ( j a v a . u t i l . C o l l e c t i o n < ?   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e > ) ;  -
-     p u b l i c   < M g L a y e r B a s e >   M g L a y e r B a s e [ ]   t o A r r a y ( M g L a y e r B a s e [ ] ) ;  -
-     p u b l i c   i n t   g e t C o u n t ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e   g e t I t e m ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e   g e t I t e m ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ;  -
-     p u b l i c   v o i d   a d d I t e m ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ;  -
-     p u b l i c   v o i d   c l e a r ( ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ;  -
-     p u b l i c   v o i d   r e m o v e A t ( i n t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ;  -
-     p u b l i c   i n t   i n d e x O f ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ;  -
- C o m p i l e d   f r o m   " M g L a y e r G r o u p . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   g e t L a y e r G r o u p T y p e ( ) ;  -
-     p u b l i c   v o i d   s e t E x p a n d I n L e g e n d ( b o o l e a n ) ;  -
- C o m p i l e d   f r o m   " M g L a y e r G r o u p C o l l e c t i o n . j a v a "  -
- c l a s s   o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p C o l l e c t i o n $ I t e m I t e r a t o r   i m p l e m e n t s   j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p >   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p C o l l e c t i o n $ I t e m I t e r a t o r ( o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p   n e x t ( ) ;  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   i m p l e m e n t s   j a v a . u t i l . C o l l e c t i o n < o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p >   {  -
-     p u b l i c   j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p >   i t e r a t o r ( ) ;  -
-     p u b l i c   b o o l e a n   a d d ( o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ) ;  -
-     p u b l i c   b o o l e a n   a d d A l l ( j a v a . u t i l . C o l l e c t i o n < ?   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p > ) ;  -
-     p u b l i c   < M g L a y e r G r o u p >   M g L a y e r G r o u p [ ]   t o A r r a y ( M g L a y e r G r o u p [ ] ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p   g e t I t e m ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p   g e t I t e m ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ) ;  -
-     p u b l i c   v o i d   a d d I t e m ( o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p ) ;  -
- C o m p i l e d   f r o m   " M g L a y e r G r o u p T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N o r m a l   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B a s e M a p   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B a s e M a p F r o m T i l e S e t   =   3 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g L a y e r T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g L a y e r T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D y n a m i c   =   1 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g L a y o u t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g L a y o u t   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y o u t ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r   g e t L a y o u t ( ) ;  -
-     p u b l i c   v o i d   s e t L a y o u t ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t T i t l e ( ) ;  -
-     p u b l i c   v o i d   s e t T i t l e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t U n i t T y p e ( ) ;  -
-     p u b l i c   v o i d   s e t U n i t T y p e ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g L i n e a r R i n g . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g R i n g   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e I t e r a t o r   g e t C o o r d i n a t e s ( ) ;  -
- C o m p i l e d   f r o m   " M g L i n e a r R i n g C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g   g e t I t e m ( i n t ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g ) ;  -
-     p u b l i c   v o i d   a d d ( o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g C o l l e c t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g L i n e a r S e g m e n t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g L i n e a r S e g m e n t   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C u r v e S e g m e n t   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t S t a r t C o o r d i n a t e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t E n d C o o r d i n a t e ( ) ;  -
- C o m p i l e d   f r o m   " M g L i n e S t r i n g . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C u r v e   {  -
- C o m p i l e d   f r o m   " M g L i n e S t r i n g C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g   g e t I t e m ( i n t ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g ) ;  -
-     p u b l i c   v o i d   a d d ( o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g C o l l e c t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g L o c a l i z e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g L o c a l i z e r   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L o c a l i z e r ( ) ;  -
-     p u b l i c   s t a t i c   v o i d   S e t L o c a l i z e d F i l e s P a t h ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   s t a t i c   j a v a . l a n g . S t r i n g   L o c a l i z e ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   i n t ) ;  -
-     p u b l i c   s t a t i c   j a v a . l a n g . S t r i n g   G e t S t r i n g ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g L o g F i l e T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g L o g F i l e T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A c c e s s   =   " A c c e s s L o g " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A d m i n   =   " A d m i n L o g " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A u t h e n t i c a t i o n   =   " A u t h e n t i c a t i o n L o g " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   E r r o r   =   " E r r o r L o g " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S e s s i o n   =   " S e s s i o n L o g " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T r a c e   =   " T r a c e L o g " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L o g F i l e T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g L o n g T r a n s a c t i o n R e a d e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g L o n g T r a n s a c t i o n R e a d e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   i m p l e m e n t s   j a v a . l a n g . A u t o C l o s e a b l e   {  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t N a m e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D e s c r i p t i o n ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L o n g T r a n s a c t i o n R e a d e r   g e t C h i l d r e n ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L o n g T r a n s a c t i o n R e a d e r   g e t P a r e n t s ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t O w n e r ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e   g e t C r e a t i o n D a t e ( ) ;  -
-     p u b l i c   b o o l e a n   i s A c t i v e ( ) ;  -
-     p u b l i c   b o o l e a n   i s F r o z e n ( ) ;  -
-     p u b l i c   b o o l e a n   r e a d N e x t ( ) ;  -
-     p u b l i c   v o i d   c l o s e ( ) ;  -
- C o m p i l e d   f r o m   " M g M a p . j a v a "  -
- p u b l i c   f i n a l   c l a s s   o r g . o s g e o . m a p g u i d e . M g M a p $ W a t e r m a r k U s a g e T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   o r g . o s g e o . m a p g u i d e . M g M a p $ W a t e r m a r k U s a g e T y p e   W M S ;  -
-     p u b l i c   s t a t i c   f i n a l   o r g . o s g e o . m a p g u i d e . M g M a p $ W a t e r m a r k U s a g e T y p e   V i e w e r ;  -
-     p u b l i c   f i n a l   i n t   s w i g V a l u e ( ) ;  -
-     p u b l i c   s t a t i c   o r g . o s g e o . m a p g u i d e . M g M a p $ W a t e r m a r k U s a g e T y p e   s w i g T o E n u m ( i n t ) ;  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g M a p   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g M a p B a s e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M a p ( o r g . o s g e o . m a p g u i d e . M g S i t e C o n n e c t i o n ) ;  -
-     p u b l i c   v o i d   c r e a t e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   c r e a t e ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   c r e a t e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ,   d o u b l e ,   d o u b l e ,   d o u b l e ,   i n t ) ;  -
-     p u b l i c   v o i d   o p e n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s a v e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e ,   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   v o i d   s a v e ( ) ;  -
-     p u b l i c   i n t   g e t W a t e r m a r k U s a g e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r   g e t T i l e S e t D e f i n i t i o n ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t T i l e S e t P r o v i d e r ( ) ;  -
-     p u b l i c   i n t   g e t T i l e P i x e l R a t i o ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t T i l e F o r m a t ( ) ;  -
- C o m p i l e d   f r o m   " M g M a p B a s e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g M a p B a s e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M a p B a s e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S e s s i o n I d ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r   g e t M a p D e f i n i t i o n ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t M a p S R S ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e   g e t M a p E x t e n t ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r C o l l e c t i o n   g e t L a y e r s ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r G r o u p C o l l e c t i o n   g e t L a y e r G r o u p s ( ) ;  -
-     p u b l i c   v o i d   c r e a t e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e ,   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   o p e n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P o i n t   g e t V i e w C e n t e r ( ) ;  -
-     p u b l i c   d o u b l e   g e t V i e w S c a l e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e   g e t D a t a E x t e n t ( ) ;  -
-     p u b l i c   i n t   g e t D i s p l a y D p i ( ) ;  -
-     p u b l i c   v o i d   s e t D i s p l a y D p i ( i n t ) ;  -
-     p u b l i c   i n t   g e t D i s p l a y W i d t h ( ) ;  -
-     p u b l i c   i n t   g e t D i s p l a y H e i g h t ( ) ;  -
-     p u b l i c   i n t   g e t F i n i t e D i s p l a y S c a l e C o u n t ( ) ;  -
-     p u b l i c   d o u b l e   g e t F i n i t e D i s p l a y S c a l e A t ( i n t ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t B a c k g r o u n d C o l o r ( ) ;  -
- C o m p i l e d   f r o m   " M g M a p C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g M a p C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M a p B a s e   g e t I t e m ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M a p B a s e   g e t I t e m ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g M a p B a s e ) ;  -
-     p u b l i c   v o i d   a d d ( o r g . o s g e o . m a p g u i d e . M g M a p B a s e ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g M a p B a s e ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g M a p B a s e ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g M a p B a s e ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g M a p B a s e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M a p C o l l e c t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g M a p p i n g S e r v i c e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g M a p p i n g S e r v i c e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r v i c e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e n e r a t e P l o t ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ,   o r g . o s g e o . m a p g u i d e . M g L a y o u t ,   o r g . o s g e o . m a p g u i d e . M g D w f V e r s i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e n e r a t e P l o t ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   d o u b l e ,   o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ,   o r g . o s g e o . m a p g u i d e . M g L a y o u t ,   o r g . o s g e o . m a p g u i d e . M g D w f V e r s i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e n e r a t e P l o t ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ,   b o o l e a n ,   o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ,   o r g . o s g e o . m a p g u i d e . M g L a y o u t ,   o r g . o s g e o . m a p g u i d e . M g D w f V e r s i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e n e r a t e M u l t i P l o t ( o r g . o s g e o . m a p g u i d e . M g M a p P l o t C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g D w f V e r s i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e n e r a t e L e g e n d I m a g e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   d o u b l e ,   i n t ,   i n t ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   c r e a t e R u n t i m e M a p ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   c r e a t e R u n t i m e M a p ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ,   i n t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   d e s c r i b e R u n t i m e M a p ( o r g . o s g e o . m a p g u i d e . M g M a p ,   i n t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   d e s c r i b e R u n t i m e M a p ( o r g . o s g e o . m a p g u i d e . M g M a p ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ,   i n t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   q u e r y F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g M a p ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   q u e r y F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   i n t ,   i n t ,   i n t ,   j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g M a p P l o t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g M a p P l o t   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M a p P l o t ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ,   o r g . o s g e o . m a p g u i d e . M g L a y o u t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M a p P l o t ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   d o u b l e ,   o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ,   o r g . o s g e o . m a p g u i d e . M g L a y o u t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M a p P l o t ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ,   b o o l e a n ,   o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ,   o r g . o s g e o . m a p g u i d e . M g L a y o u t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M a p   g e t M a p ( ) ;  -
-     p u b l i c   v o i d   s e t M a p ( o r g . o s g e o . m a p g u i d e . M g M a p ) ;  -
-     p u b l i c   i n t   g e t M a p P l o t I n s t r u c t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t M a p P l o t I n s t r u c t i o n ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t C e n t e r ( ) ;  -
-     p u b l i c   d o u b l e   g e t S c a l e ( ) ;  -
-     p u b l i c   v o i d   s e t C e n t e r A n d S c a l e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e   g e t E x t e n t ( ) ;  -
-     p u b l i c   b o o l e a n   g e t E x p a n d T o F i t ( ) ;  -
-     p u b l i c   v o i d   s e t E x t e n t ( o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n   g e t P l o t S p e c i f i c a t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t P l o t S p e c i f i c a t i o n ( o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y o u t   g e t L a y o u t ( ) ;  -
-     p u b l i c   v o i d   s e t L a y o u t ( o r g . o s g e o . m a p g u i d e . M g L a y o u t ) ;  -
- C o m p i l e d   f r o m   " M g M a p P l o t C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g M a p P l o t C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M a p P l o t   g e t I t e m ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M a p P l o t   g e t I t e m ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g M a p P l o t ) ;  -
-     p u b l i c   v o i d   a d d ( o r g . o s g e o . m a p g u i d e . M g M a p P l o t ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g M a p P l o t ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g M a p P l o t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g M a p P l o t ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g M a p P l o t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M a p P l o t C o l l e c t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g M a p P l o t I n s t r u c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g M a p P l o t I n s t r u c t i o n   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U s e M a p C e n t e r A n d S c a l e   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U s e O v e r r i d d e n C e n t e r A n d S c a l e   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U s e O v e r r i d d e n E x t e n t   =   2 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M a p P l o t I n s t r u c t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g M e a s u r e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g M e a s u r e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   s y n c h r o n i z e d   v o i d   d e l e t e ( ) ;  -
-     p u b l i c   d o u b l e   g e t D i s t a n c e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   d o u b l e   g e t A z i m u t h ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t C o o r d i n a t e ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   d o u b l e ,   d o u b l e ) ;  -
- C o m p i l e d   f r o m   " M g M e t a t i l e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g M e t a t i l e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t I m a g e ( ) ;  -
-     p u b l i c   i n t   g e t R e q u e s t e d W i d t h ( ) ;  -
-     p u b l i c   i n t   g e t R e q u e s t e d H e i g h t ( ) ;  -
-     p u b l i c   i n t   g e t W i d t h ( ) ;  -
-     p u b l i c   i n t   g e t H e i g h t ( ) ;  -
-     p u b l i c   i n t   g e t M e t a T i l i n g F a c t o r ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t T i l e I m a g e F o r m a t ( ) ;  -
- C o m p i l e d   f r o m   " M g M i m e T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g M i m e T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A g f   =   " a p p l i c a t i o n / a g f " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   B i n a r y   =   " a p p l i c a t i o n / o c t e t - s t r e a m " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D w f   =   " m o d e l / v n d . d w f " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   G i f   =   " i m a g e / g i f " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   J p e g   =   " i m a g e / j p e g " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P n g   =   " i m a g e / p n g " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T e x t   =   " t e x t / p l a i n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T i f f   =   " i m a g e / t i f f " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   X m l   =   " t e x t / x m l " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   J s o n   =   " a p p l i c a t i o n / j s o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   H t m l   =   " t e x t / h t m l " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   K m l   =   " a p p l i c a t i o n / v n d . g o o g l e - e a r t h . k m l + x m l " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   K m z   =   " a p p l i c a t i o n / v n d . g o o g l e - e a r t h . k m z " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M e t a   =   " a p p l i c a t i o n / m e t a t i l e " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M i m e T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g M u l t i C u r v e P o l y g o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g M u l t i C u r v e P o l y g o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g A g g r e g a t e G e o m e t r y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C u r v e P o l y g o n   g e t C u r v e P o l y g o n ( i n t ) ;  -
-     p u b l i c   i n t   g e t G e o m e t r y T y p e ( ) ;  -
-     p u b l i c   i n t   g e t D i m e n s i o n ( ) ;  -
-     p u b l i c   b o o l e a n   i s E m p t y ( ) ;  -
-     p u b l i c   b o o l e a n   i s C l o s e d ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y   c o p y ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r i c E n t i t y   t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ;  -
- C o m p i l e d   f r o m   " M g M u l t i C u r v e S t r i n g . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g M u l t i C u r v e S t r i n g   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g A g g r e g a t e G e o m e t r y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C u r v e S t r i n g   g e t C u r v e S t r i n g ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g M u l t i G e o m e t r y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g M u l t i G e o m e t r y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g A g g r e g a t e G e o m e t r y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   g e t G e o m e t r y ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g M u l t i L i n e S t r i n g . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g M u l t i L i n e S t r i n g   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g A g g r e g a t e G e o m e t r y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L i n e S t r i n g   g e t L i n e S t r i n g ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g M u l t i P o i n t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g M u l t i P o i n t   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g A g g r e g a t e G e o m e t r y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P o i n t   g e t P o i n t ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g M u l t i P o l y g o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g M u l t i P o l y g o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g A g g r e g a t e G e o m e t r y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P o l y g o n   g e t P o l y g o n ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g N a m e d S e r i a l i z a b l e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
- C o m p i l e d   f r o m   " M g N u l l a b l e P r o p e r t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y   {  -
-     p u b l i c   v o i d   s e t N u l l ( b o o l e a n ) ;  -
-     p u b l i c   b o o l e a n   i s N u l l ( ) ;  -
- C o m p i l e d   f r o m   " M g O b j e c t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g O b j e c t   {  -
-     p u b l i c   i n t   g e t C l a s s I d ( ) ;  -
- C o m p i l e d   f r o m   " M g O b j e c t P r o p e r t y D e f i n i t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g O b j e c t P r o p e r t y D e f i n i t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g O b j e c t P r o p e r t y D e f i n i t i o n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n   g e t C l a s s D e f i n i t i o n ( ) ;  -
-     p u b l i c   i n t   g e t O b j e c t T y p e ( ) ;  -
-     p u b l i c   i n t   g e t O r d e r T y p e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D a t a P r o p e r t y D e f i n i t i o n   g e t I d e n t i t y P r o p e r t y ( ) ;  -
-     p u b l i c   v o i d   s e t C l a s s D e f i n i t i o n ( o r g . o s g e o . m a p g u i d e . M g C l a s s D e f i n i t i o n ) ;  -
-     p u b l i c   v o i d   s e t O b j e c t T y p e ( i n t ) ;  -
-     p u b l i c   v o i d   s e t O r d e r T y p e ( i n t ) ;  -
-     p u b l i c   v o i d   s e t I d e n t i t y P r o p e r t y ( o r g . o s g e o . m a p g u i d e . M g D a t a P r o p e r t y D e f i n i t i o n ) ;  -
- C o m p i l e d   f r o m   " M g O b j e c t P r o p e r t y T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g O b j e c t P r o p e r t y T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   V a l u e   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C o l l e c t i o n   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O r d e r e d C o l l e c t i o n   =   2 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g O b j e c t P r o p e r t y T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g O r d e r i n g O p t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g O r d e r i n g O p t i o n   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A s c e n d i n g   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e s c e n d i n g   =   1 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g O r d e r i n g O p t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g P a c k a g e S t a t u s I n f o r m a t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g P a c k a g e S t a t u s I n f o r m a t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P a c k a g e S t a t u s I n f o r m a t i o n ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S t a t u s M e s s a g e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S t a t u s C o d e ( ) ;  -
-     p u b l i c   v o i d   s e t S t a t u s C o d e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t A p i N a m e ( ) ;  -
-     p u b l i c   v o i d   s e t A p i N a m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t P a c k a g e N a m e ( ) ;  -
-     p u b l i c   v o i d   s e t P a c k a g e N a m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t P a c k a g e D e s c r i p t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t P a c k a g e D e s c r i p t i o n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e   g e t P a c k a g e D a t e ( ) ;  -
-     p u b l i c   v o i d   s e t P a c k a g e D a t e ( o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ) ;  -
-     p u b l i c   l o n g   g e t P a c k a g e S i z e ( ) ;  -
-     p u b l i c   v o i d   s e t P a c k a g e S i z e ( l o n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t U s e r N a m e ( ) ;  -
-     p u b l i c   v o i d   s e t U s e r N a m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S e r v e r N a m e ( ) ;  -
-     p u b l i c   v o i d   s e t S e r v e r N a m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S e r v e r A d d r e s s ( ) ;  -
-     p u b l i c   v o i d   s e t S e r v e r A d d r e s s ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e   g e t S t a r t T i m e ( ) ;  -
-     p u b l i c   v o i d   s e t S t a r t T i m e ( o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e   g e t E n d T i m e ( ) ;  -
-     p u b l i c   v o i d   s e t E n d T i m e ( o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ) ;  -
-     p u b l i c   i n t   g e t O p e r a t i o n s F a i l e d ( ) ;  -
-     p u b l i c   v o i d   s e t O p e r a t i o n s F a i l e d ( i n t ) ;  -
-     p u b l i c   i n t   g e t O p e r a t i o n s R e c e i v e d ( ) ;  -
-     p u b l i c   v o i d   s e t O p e r a t i o n s R e c e i v e d ( i n t ) ;  -
-     p u b l i c   d o u b l e   g e t A v e r a g e O p e r a t i o n T i m e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S t a c k T r a c e ( ) ;  -
-     p u b l i c   v o i d   s e t S t a c k T r a c e ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g P a g e U n i t s T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g P a g e U n i t s T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   I n c h e s   =   " i n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M i l l i m e t e r s   =   " m m " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P a g e U n i t s T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g P a r a m e t e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r ( o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r ( o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y ,   i n t ) ;  -
-     p u b l i c   v o i d   s e t P r o p e r t y ( o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y   g e t P r o p e r t y ( ) ;  -
-     p u b l i c   v o i d   s e t D i r e c t i o n ( i n t ) ;  -
-     p u b l i c   i n t   g e t D i r e c t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t N a m e ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g P a r a m e t e r C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r C o l l e c t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r ) ;  -
-     p u b l i c   v o i d   a d d ( o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r   g e t I t e m ( i n t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r ) ;  -
- C o m p i l e d   f r o m   " M g P a r a m e t e r D i r e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r D i r e c t i o n   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n p u t   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   O u t p u t   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n p u t O u t p u t   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R e t   =   3 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P a r a m e t e r D i r e c t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g P l o t S p e c i f i c a t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ( f l o a t ,   f l o a t ,   j a v a . l a n g . S t r i n g ,   f l o a t ,   f l o a t ,   f l o a t ,   f l o a t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ( f l o a t ,   f l o a t ,   j a v a . l a n g . S t r i n g ,   f l o a t ,   f l o a t ,   f l o a t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ( f l o a t ,   f l o a t ,   j a v a . l a n g . S t r i n g ,   f l o a t ,   f l o a t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ( f l o a t ,   f l o a t ,   j a v a . l a n g . S t r i n g ,   f l o a t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P l o t S p e c i f i c a t i o n ( f l o a t ,   f l o a t ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   f l o a t   g e t P a p e r W i d t h ( ) ;  -
-     p u b l i c   v o i d   s e t P a p e r W i d t h ( f l o a t ) ;  -
-     p u b l i c   f l o a t   g e t P a p e r H e i g h t ( ) ;  -
-     p u b l i c   v o i d   s e t P a p e r H e i g h t ( f l o a t ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t P a g e S i z e U n i t s ( ) ;  -
-     p u b l i c   v o i d   s e t P a g e S i z e U n i t s ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   f l o a t   g e t M a r g i n L e f t ( ) ;  -
-     p u b l i c   f l o a t   g e t M a r g i n T o p ( ) ;  -
-     p u b l i c   f l o a t   g e t M a r g i n R i g h t ( ) ;  -
-     p u b l i c   f l o a t   g e t M a r g i n B o t t o m ( ) ;  -
-     p u b l i c   v o i d   s e t M a r g i n s ( f l o a t ,   f l o a t ,   f l o a t ,   f l o a t ) ;  -
- C o m p i l e d   f r o m   " M g P o i n t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g P o i n t   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   g e t C o o r d i n a t e ( ) ;  -
- C o m p i l e d   f r o m   " M g P o i n t C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g P o i n t C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P o i n t   g e t I t e m ( i n t ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g P o i n t ) ;  -
-     p u b l i c   v o i d   a d d ( o r g . o s g e o . m a p g u i d e . M g P o i n t ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g P o i n t ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g P o i n t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g P o i n t ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g P o i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P o i n t C o l l e c t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g P o l y g o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g P o l y g o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g R e g i o n   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g   g e t E x t e r i o r R i n g ( ) ;  -
-     p u b l i c   i n t   g e t I n t e r i o r R i n g C o u n t ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L i n e a r R i n g   g e t I n t e r i o r R i n g ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g P o l y g o n C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g P o l y g o n C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P o l y g o n   g e t I t e m ( i n t ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g P o l y g o n ) ;  -
-     p u b l i c   v o i d   a d d ( o r g . o s g e o . m a p g u i d e . M g P o l y g o n ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g P o l y g o n ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g P o l y g o n ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g P o l y g o n ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g P o l y g o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P o l y g o n C o l l e c t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g P r e p a r e d G e o m e t r y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g P r e p a r e d G e o m e t r y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   b o o l e a n   c r o s s e s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   b o o l e a n   d i s j o i n t ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   b o o l e a n   i n t e r s e c t s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   b o o l e a n   o v e r l a p s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   b o o l e a n   t o u c h e s ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   b o o l e a n   w i t h i n ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
- C o m p i l e d   f r o m   " M g P r o f i l i n g S e r v i c e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g P r o f i l i n g S e r v i c e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r v i c e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   p r o f i l e R e n d e r D y n a m i c O v e r l a y ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g R e n d e r i n g O p t i o n s ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   p r o f i l e R e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   d o u b l e ,   i n t ,   i n t ,   o r g . o s g e o . m a p g u i d e . M g C o l o r ,   j a v a . l a n g . S t r i n g ,   b o o l e a n ) ;  -
- C o m p i l e d   f r o m   " M g P r o p e r t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e   {  -
-     p u b l i c   b o o l e a n   e q u a l s ( j a v a . l a n g . O b j e c t ) ;  -
-     p u b l i c   i n t   h a s h C o d e ( ) ;  -
-     p u b l i c   s h o r t   g e t P r o p e r t y T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g P r o p e r t y C o l l e c t i o n . j a v a "  -
- c l a s s   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n $ I t e m I t e r a t o r   i m p l e m e n t s   j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g P r o p e r t y >   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n $ I t e m I t e r a t o r ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ;  -
-     p u b l i c   b o o l e a n   h a s N e x t ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y   n e x t ( ) ;  -
-     p u b l i c   v o i d   r e m o v e ( ) ;  -
-     p u b l i c   j a v a . l a n g . O b j e c t   n e x t ( ) ;  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n   i m p l e m e n t s   j a v a . u t i l . C o l l e c t i o n < o r g . o s g e o . m a p g u i d e . M g P r o p e r t y >   {  -
-     p u b l i c   j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g P r o p e r t y >   i t e r a t o r ( ) ;  -
-     p u b l i c   b o o l e a n   a d d ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y ) ;  -
-     p u b l i c   b o o l e a n   a d d A l l ( j a v a . u t i l . C o l l e c t i o n < ?   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y > ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( j a v a . l a n g . O b j e c t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( j a v a . l a n g . O b j e c t ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ;  -
-     p u b l i c   b o o l e a n   r e t a i n A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ;  -
-     p u b l i c   i n t   s i z e ( ) ;  -
-     p u b l i c   j a v a . l a n g . O b j e c t [ ]   t o A r r a y ( ) ;  -
-     p u b l i c   < M g P r o p e r t y >   M g P r o p e r t y [ ]   t o A r r a y ( M g P r o p e r t y [ ] ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y ) ;  -
-     p u b l i c   v o i d   a d d I t e m ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y   g e t I t e m ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y   g e t I t e m ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y ) ;  -
-     p u b l i c   b o o l e a n   a d d ( j a v a . l a n g . O b j e c t ) ;  -
- C o m p i l e d   f r o m   " M g P r o p e r t y D e f i n i t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ( j a v a . l a n g . S t r i n g ,   s h o r t ) ;  -
-     p u b l i c   v o i d   s e t D e s c r i p t i o n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t Q u a l i f i e d N a m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t Q u a l i f i e d N a m e ( ) ;  -
-     p u b l i c   v o i d   m a r k A s D e l e t e d ( ) ;  -
- C o m p i l e d   f r o m   " M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n . j a v a "  -
- c l a s s   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n $ I t e m I t e r a t o r   i m p l e m e n t s   j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n >   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n $ I t e m I t e r a t o r ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n   n e x t ( ) ;  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n   i m p l e m e n t s   j a v a . u t i l . C o l l e c t i o n < o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n >   {  -
-     p u b l i c   j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n >   i t e r a t o r ( ) ;  -
-     p u b l i c   b o o l e a n   a d d ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ;  -
-     p u b l i c   b o o l e a n   a d d A l l ( j a v a . u t i l . C o l l e c t i o n < ?   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n > ) ;  -
-     p u b l i c   < M g P r o p e r t y D e f i n i t i o n >   M g P r o p e r t y D e f i n i t i o n [ ]   t o A r r a y ( M g P r o p e r t y D e f i n i t i o n [ ] ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n C o l l e c t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ;  -
-     p u b l i c   v o i d   a d d I t e m ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n   g e t I t e m ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n   g e t I t e m ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   t o X m l ( ) ;  -
- C o m p i l e d   f r o m   " M g P r o p e r t y T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N u l l   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B o o l e a n   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B y t e   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D a t e T i m e   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S i n g l e   =   4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D o u b l e   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n t 1 6   =   6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n t 3 2   =   7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n t 6 4   =   8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S t r i n g   =   9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B l o b   =   1 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C l o b   =   1 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   F e a t u r e   =   1 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G e o m e t r y   =   1 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R a s t e r   =   1 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D e c i m a l   =   1 5 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g R a s t e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R a s t e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   v o i d   s e t N u l l ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e   g e t B o u n d s ( ) ;  -
-     p u b l i c   i n t   g e t I m a g e X S i z e ( ) ;  -
-     p u b l i c   v o i d   s e t I m a g e X S i z e ( i n t ) ;  -
-     p u b l i c   i n t   g e t I m a g e Y S i z e ( ) ;  -
-     p u b l i c   v o i d   s e t I m a g e Y S i z e ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t S t r e a m ( ) ;  -
-     p u b l i c   i n t   g e t B i t s P e r P i x e l ( ) ;  -
-     p u b l i c   i n t   g e t D a t a M o d e l T y p e ( ) ;  -
-     p u b l i c   i n t   g e t N u m b e r O f B a n d s ( ) ;  -
-     p u b l i c   i n t   g e t C u r r e n t B a n d ( ) ;  -
-     p u b l i c   s h o r t   g e t D a t a T y p e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t V e r t i c a l U n i t s ( ) ;  -
-     p u b l i c   i n t   g e t N u l l V a l u e T y p e ( ) ;  -
-     p u b l i c   l o n g   g e t N u l l V a l u e ( ) ;  -
- C o m p i l e d   f r o m   " M g R a s t e r D a t a M o d e l T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R a s t e r D a t a M o d e l T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   U n k n o w n   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D a t a   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B i t o n a l   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G r a y   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R G B   =   4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R G B A   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P a l e t t e   =   6 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R a s t e r D a t a M o d e l T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g R a s t e r P r o p e r t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R a s t e r P r o p e r t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R a s t e r P r o p e r t y ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g R a s t e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R a s t e r   g e t V a l u e ( ) ;  -
-     p u b l i c   v o i d   s e t V a l u e ( o r g . o s g e o . m a p g u i d e . M g R a s t e r ) ;  -
- C o m p i l e d   f r o m   " M g R a s t e r P r o p e r t y D e f i n i t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R a s t e r P r o p e r t y D e f i n i t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y D e f i n i t i o n   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R a s t e r P r o p e r t y D e f i n i t i o n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   g e t R e a d O n l y ( ) ;  -
-     p u b l i c   b o o l e a n   g e t N u l l a b l e ( ) ;  -
-     p u b l i c   i n t   g e t D e f a u l t I m a g e X S i z e ( ) ;  -
-     p u b l i c   i n t   g e t D e f a u l t I m a g e Y S i z e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S p a t i a l C o n t e x t A s s o c i a t i o n ( ) ;  -
-     p u b l i c   v o i d   s e t R e a d O n l y ( b o o l e a n ) ;  -
-     p u b l i c   v o i d   s e t N u l l a b l e ( b o o l e a n ) ;  -
-     p u b l i c   v o i d   s e t D e f a u l t I m a g e X S i z e ( i n t ) ;  -
-     p u b l i c   v o i d   s e t D e f a u l t I m a g e Y S i z e ( i n t ) ;  -
-     p u b l i c   v o i d   s e t S p a t i a l C o n t e x t A s s o c i a t i o n ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g R e a d e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R e a d e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   i m p l e m e n t s   j a v a . l a n g . A u t o C l o s e a b l e   {  -
-     p u b l i c   i n t   g e t P r o p e r t y C o u n t ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t P r o p e r t y N a m e ( i n t ) ;  -
-     p u b l i c   i n t   g e t P r o p e r t y T y p e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   g e t P r o p e r t y T y p e ( i n t ) ;  -
-     p u b l i c   b o o l e a n   i s N u l l ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   g e t B o o l e a n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b y t e   g e t B y t e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e   g e t D a t e T i m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   f l o a t   g e t S i n g l e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   d o u b l e   g e t D o u b l e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   s h o r t   g e t I n t 1 6 ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   g e t I n t 3 2 ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   l o n g   g e t I n t 6 4 ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S t r i n g ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t B L O B ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t C L O B ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t G e o m e t r y ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R a s t e r   g e t R a s t e r ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   g e t P r o p e r t y I n d e x ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   i s N u l l ( i n t ) ;  -
-     p u b l i c   b o o l e a n   g e t B o o l e a n ( i n t ) ;  -
-     p u b l i c   b y t e   g e t B y t e ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e   g e t D a t e T i m e ( i n t ) ;  -
-     p u b l i c   f l o a t   g e t S i n g l e ( i n t ) ;  -
-     p u b l i c   d o u b l e   g e t D o u b l e ( i n t ) ;  -
-     p u b l i c   s h o r t   g e t I n t 1 6 ( i n t ) ;  -
-     p u b l i c   i n t   g e t I n t 3 2 ( i n t ) ;  -
-     p u b l i c   l o n g   g e t I n t 6 4 ( i n t ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S t r i n g ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t B L O B ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t C L O B ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t G e o m e t r y ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R a s t e r   g e t R a s t e r ( i n t ) ;  -
-     p u b l i c   i n t   g e t R e a d e r T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g R e a d e r T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R e a d e r T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   F e a t u r e R e a d e r   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D a t a R e a d e r   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S q l D a t a R e a d e r   =   2 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e a d e r T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g R e a d O n l y L a y e r C o l l e c t i o n . j a v a "  -
- c l a s s   o r g . o s g e o . m a p g u i d e . M g R e a d O n l y L a y e r C o l l e c t i o n $ I t e m I t e r a t o r   i m p l e m e n t s   j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e >   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e a d O n l y L a y e r C o l l e c t i o n $ I t e m I t e r a t o r ( o r g . o s g e o . m a p g u i d e . M g R e a d O n l y L a y e r C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g R e a d O n l y L a y e r C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e   n e x t ( ) ;  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R e a d O n l y L a y e r C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   i m p l e m e n t s   j a v a . l a n g . I t e r a b l e < o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e >   {  -
-     p u b l i c   j a v a . u t i l . I t e r a t o r < o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e >   i t e r a t o r ( ) ;  -
-     p u b l i c   i n t   g e t C o u n t ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e   g e t I t e m ( i n t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ) ;  -
- C o m p i l e d   f r o m   " M g R e g i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R e g i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P o i n t   g e t P o i n t I n R e g i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g R e n d e r i n g O p t i o n s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R e n d e r i n g O p t i o n s   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R e n d e r S e l e c t i o n ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R e n d e r L a y e r s ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   K e e p S e l e c t i o n ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R e n d e r B a s e L a y e r s ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e n d e r i n g O p t i o n s ( j a v a . l a n g . S t r i n g ,   i n t ,   o r g . o s g e o . m a p g u i d e . M g C o l o r ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t I m a g e F o r m a t ( ) ;  -
-     p u b l i c   i n t   g e t B e h a v i o r ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o l o r   g e t S e l e c t i o n C o l o r ( ) ;  -
- C o m p i l e d   f r o m   " M g R e n d e r i n g S e r v i c e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R e n d e r i n g S e r v i c e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r v i c e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r T i l e ( o r g . o s g e o . m a p g u i d e . M g M a p ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r T i l e ( o r g . o s g e o . m a p g u i d e . M g M a p ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ,   i n t ,   i n t ,   i n t ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r T i l e ( o r g . o s g e o . m a p g u i d e . M g M a p ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ,   i n t ,   i n t ,   i n t ,   j a v a . l a n g . S t r i n g ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r T i l e X Y Z ( o r g . o s g e o . m a p g u i d e . M g M a p ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r T i l e X Y Z ( o r g . o s g e o . m a p g u i d e . M g M a p ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ,   i n t ,   i n t ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r T i l e X Y Z ( o r g . o s g e o . m a p g u i d e . M g M a p ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ,   i n t ,   i n t ,   j a v a . l a n g . S t r i n g ,   d o u b l e ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r T i l e U T F G r i d ( o r g . o s g e o . m a p g u i d e . M g M a p ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ,   i n t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r D y n a m i c O v e r l a y ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r D y n a m i c O v e r l a y ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ,   j a v a . l a n g . S t r i n g ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r D y n a m i c O v e r l a y ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g R e n d e r i n g O p t i o n s ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ,   j a v a . l a n g . S t r i n g ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ,   j a v a . l a n g . S t r i n g ,   b o o l e a n ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ,   j a v a . l a n g . S t r i n g ,   b o o l e a n ,   b o o l e a n ,   o r g . o s g e o . m a p g u i d e . M g C o l o r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ,   i n t ,   i n t ,   o r g . o s g e o . m a p g u i d e . M g C o l o r ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ,   i n t ,   i n t ,   o r g . o s g e o . m a p g u i d e . M g C o l o r ,   j a v a . l a n g . S t r i n g ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   d o u b l e ,   i n t ,   i n t ,   o r g . o s g e o . m a p g u i d e . M g C o l o r ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   d o u b l e ,   i n t ,   i n t ,   o r g . o s g e o . m a p g u i d e . M g C o l o r ,   j a v a . l a n g . S t r i n g ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r M a p ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ,   d o u b l e ,   i n t ,   i n t ,   o r g . o s g e o . m a p g u i d e . M g C o l o r ,   j a v a . l a n g . S t r i n g ,   b o o l e a n ,   o r g . o s g e o . m a p g u i d e . M g C o l o r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r M a p L e g e n d ( o r g . o s g e o . m a p g u i d e . M g M a p ,   i n t ,   i n t ,   o r g . o s g e o . m a p g u i d e . M g C o l o r ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e I n f o r m a t i o n   q u e r y F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ,   i n t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e I n f o r m a t i o n   q u e r y F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ,   i n t ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n   q u e r y F e a t u r e P r o p e r t i e s ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ,   i n t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B a t c h P r o p e r t y C o l l e c t i o n   q u e r y F e a t u r e P r o p e r t i e s ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ,   i n t ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M e t a t i l e   r e n d e r M e t a t i l e ( o r g . o s g e o . m a p g u i d e . M g M a p ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ,   i n t ,   i n t ,   i n t ,   j a v a . l a n g . S t r i n g ,   d o u b l e ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g M e t a t i l e   r e n d e r M e t a t i l e X Y Z ( o r g . o s g e o . m a p g u i d e . M g M a p ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ,   i n t ,   i n t ,   j a v a . l a n g . S t r i n g ,   d o u b l e ,   i n t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   r e n d e r T i l e F r o m M e t a T i l e ( o r g . o s g e o . m a p g u i d e . M g M a p ,   o r g . o s g e o . m a p g u i d e . M g M e t a t i l e ,   i n t ,   i n t ) ;  -
- C o m p i l e d   f r o m   " M g R e p o s i t o r y T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R e p o s i t o r y T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   L i b r a r y   =   " L i b r a r y " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S e s s i o n   =   " S e s s i o n " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e p o s i t o r y T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g R e s o u r c e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r   g e t R e s o u r c e I d ( ) ;  -
-     p u b l i c   v o i d   o p e n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e ,   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   v o i d   s a v e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e ) ;  -
-     p u b l i c   v o i d   s a v e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e ,   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
- C o m p i l e d   f r o m   " M g R e s o u r c e D a t a N a m e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e D a t a N a m e   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   U s e r C r e d e n t i a l s   =   " M G _ U S E R _ C R E D E N T I A L S " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P r o x y S e r v e r N a m e   =   " M G _ P R O X Y _ S E R V E R " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P r o x y S e r v e r P o r t   =   " M G _ P R O X Y _ P O R T " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P r o x y C r e d e n t i a l s   =   " M G _ P R O X Y _ C R E D E N T I A L S " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e D a t a N a m e ( ) ;  -
- C o m p i l e d   f r o m   " M g R e s o u r c e D a t a T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e D a t a T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F i l e   =   " F i l e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S t r e a m   =   " S t r e a m " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S t r i n g   =   " S t r i n g " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e D a t a T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g R e s o u r c e H e a d e r P r o p e r t i e s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e H e a d e r P r o p e r t i e s   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G e n e r a l   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S e c u r i t y   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M e t a d a t a   =   4 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e H e a d e r P r o p e r t i e s ( ) ;  -
- C o m p i l e d   f r o m   " M g R e s o u r c e I d e n t i f i e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t R e p o s i t o r y T y p e ( ) ;  -
-     p u b l i c   v o i d   s e t R e p o s i t o r y T y p e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t R e p o s i t o r y N a m e ( ) ;  -
-     p u b l i c   v o i d   s e t R e p o s i t o r y N a m e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   t o S t r i n g ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t P a t h ( ) ;  -
-     p u b l i c   v o i d   s e t P a t h ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t N a m e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t R e s o u r c e T y p e ( ) ;  -
-     p u b l i c   v o i d   s e t R e s o u r c e T y p e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   v a l i d a t e ( ) ;  -
- C o m p i l e d   f r o m   " M g R e s o u r c e P e r m i s s i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e P e r m i s s i o n   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P e r m i s s i o n N o A c c e s s   =   " n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P e r m i s s i o n R e a d O n l y   =   " r " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P e r m i s s i o n R e a d W r i t e   =   " r , w " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e P e r m i s s i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g R e s o u r c e S e r v i c e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r v i c e   {  -
-     p u b l i c   v o i d   u p d a t e R e p o s i t o r y ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ,   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ;  -
-     p u b l i c   v o i d   a p p l y R e s o u r c e P a c k a g e ( o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   e n u m e r a t e R e s o u r c e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   i n t ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   e n u m e r a t e R e s o u r c e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   i n t ,   j a v a . l a n g . S t r i n g ,   b o o l e a n ) ;  -
-     p u b l i c   v o i d   s e t R e s o u r c e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ,   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ;  -
-     p u b l i c   v o i d   d e l e t e R e s o u r c e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   v o i d   m o v e R e s o u r c e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   b o o l e a n ) ;  -
-     p u b l i c   v o i d   m o v e R e s o u r c e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   b o o l e a n ,   b o o l e a n ) ;  -
-     p u b l i c   v o i d   c o p y R e s o u r c e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t R e s o u r c e C o n t e n t ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   g e t R e s o u r c e C o n t e n t s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t R e s o u r c e H e a d e r ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   v o i d   c h a n g e R e s o u r c e O w n e r ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   b o o l e a n ) ;  -
-     p u b l i c   v o i d   i n h e r i t P e r m i s s i o n s F r o m ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   v o i d   s e t R e s o u r c e D a t a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ;  -
-     p u b l i c   v o i d   d e l e t e R e s o u r c e D a t a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   r e n a m e R e s o u r c e D a t a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t R e s o u r c e D a t a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   e n u m e r a t e R e s o u r c e D a t a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t R e p o s i t o r y C o n t e n t ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t R e p o s i t o r y H e a d e r ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   e n u m e r a t e R e f e r e n c e s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   b o o l e a n   r e s o u r c e E x i s t s ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   e n u m e r a t e U n m a n a g e d D a t a ( j a v a . l a n g . S t r i n g ,   b o o l e a n ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   e n u m e r a t e R e s o u r c e D o c u m e n t s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   j a v a . l a n g . S t r i n g ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e   g e t R e s o u r c e M o d i f i e d D a t e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   v o i d   s e t R e s o u r c e M e t a d a t a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t R e s o u r c e M e t a d a t a ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
- C o m p i l e d   f r o m   " M g R e s o u r c e T a g . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e T a g   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   L o g i n U s e r n a m e   =   " % M G _ L O G I N _ U S E R N A M E % " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   L o g i n P a s s w o r d   =   " % M G _ L O G I N _ P A S S W O R D % " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   U s e r n a m e   =   " % M G _ U S E R N A M E % " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P a s s w o r d   =   " % M G _ P A S S W O R D % " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P r o x y S e r v e r   =   " % M G _ P R O X Y _ S E R V E R % " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P r o x y P o r t   =   " % M G _ P R O X Y _ P O R T % " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P r o x y U s e r n a m e   =   " % M G _ P R O X Y _ U S E R N A M E % " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P r o x y P a s s w o r d   =   " % M G _ P R O X Y _ P A S S W O R D % " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D a t a F i l e P a t h   =   " % M G _ D A T A _ F I L E _ P A T H % " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T i l e C a c h e P a t h   =   " % M G _ T I L E _ C A C H E _ P A T H % " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D a t a P a t h A l i a s B e g i n   =   " % M G _ D A T A _ P A T H _ A L I A S [ " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D a t a P a t h A l i a s E n d   =   " ] % " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e T a g ( ) ;  -
- C o m p i l e d   f r o m   " M g R e s o u r c e T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M a p   =   " M a p " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M a p D e f i n i t i o n   =   " M a p D e f i n i t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   L a y e r D e f i n i t i o n   =   " L a y e r D e f i n i t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D r a w i n g S o u r c e   =   " D r a w i n g S o u r c e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F e a t u r e S o u r c e   =   " F e a t u r e S o u r c e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   F o l d e r   =   " F o l d e r " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   L o a d P r o c e d u r e   =   " L o a d P r o c e d u r e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   P r i n t L a y o u t   =   " P r i n t L a y o u t " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S e l e c t i o n   =   " S e l e c t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S y m b o l D e f i n i t i o n   =   " S y m b o l D e f i n i t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S y m b o l L i b r a r y   =   " S y m b o l L i b r a r y " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   W e b L a y o u t   =   " W e b L a y o u t " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A p p l i c a t i o n D e f i n i t i o n   =   " A p p l i c a t i o n D e f i n i t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   W a t e r m a r k D e f i n i t i o n   =   " W a t e r m a r k D e f i n i t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T i l e S e t D e f i n i t i o n   =   " T i l e S e t D e f i n i t i o n " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g R i n g . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R i n g   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y C o m p o n e n t   {  -
-     p u b l i c   s y n c h r o n i z e d   v o i d   d e l e t e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P o i n t   g e t P o i n t I n R i n g ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e I t e r a t o r   g e t C o o r d i n a t e s ( ) ;  -
- C o m p i l e d   f r o m   " M g R o l e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g R o l e   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A d m i n i s t r a t o r   =   " A d m i n i s t r a t o r " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A u t h o r   =   " A u t h o r " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   V i e w e r   =   " V i e w e r " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R o l e ( ) ;  -
- C o m p i l e d   f r o m   " M g S e l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n B a s e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ( o r g . o s g e o . m a p g u i d e . M g M a p ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ( o r g . o s g e o . m a p g u i d e . M g M a p ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   g e t S e l e c t e d F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ,   j a v a . l a n g . S t r i n g ,   b o o l e a n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r   g e t S e l e c t e d F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ;  -
-     p u b l i c   v o i d   o p e n ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s a v e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n ( ) ;  -
- C o m p i l e d   f r o m   " M g S e l e c t i o n B a s e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n B a s e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n B a s e ( o r g . o s g e o . m a p g u i d e . M g M a p B a s e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S e l e c t i o n B a s e ( o r g . o s g e o . m a p g u i d e . M g M a p B a s e ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   g e t S e l e c t e d F e a t u r e s C o u n t ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   f r o m X m l ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   t o X m l ( ) ;  -
-     p u b l i c   v o i d   a d d F e a t u r e s ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ,   o r g . o s g e o . m a p g u i d e . M g F e a t u r e R e a d e r ,   i n t ) ;  -
-     p u b l i c   v o i d   a d d F e a t u r e I d s ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ,   j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ;  -
-     p u b l i c   v o i d   a d d F e a t u r e I d I n t 1 6 ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ,   j a v a . l a n g . S t r i n g ,   s h o r t ) ;  -
-     p u b l i c   v o i d   a d d F e a t u r e I d I n t 3 2 ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ,   j a v a . l a n g . S t r i n g ,   i n t ) ;  -
-     p u b l i c   v o i d   a d d F e a t u r e I d I n t 6 4 ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ,   j a v a . l a n g . S t r i n g ,   l o n g ) ;  -
-     p u b l i c   v o i d   a d d F e a t u r e I d S t r i n g ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   a d d F e a t u r e I d D o u b l e ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ,   j a v a . l a n g . S t r i n g ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e a d O n l y L a y e r C o l l e c t i o n   g e t L a y e r s ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   g e t C l a s s e s ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t C l a s s ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e n e r a t e F i l t e r ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   g e n e r a t e F i l t e r s ( o r g . o s g e o . m a p g u i d e . M g L a y e r B a s e ,   j a v a . l a n g . S t r i n g ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e   g e t E x t e n t s ( o r g . o s g e o . m a p g u i d e . M g F e a t u r e S e r v i c e ) ;  -
-     p u b l i c   v o i d   a d d ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t R e s o u r c e N a m e ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t M a p ( o r g . o s g e o . m a p g u i d e . M g M a p B a s e ) ;  -
- C o m p i l e d   f r o m   " M g S e r i a l i z a b l e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
- C o m p i l e d   f r o m   " M g S e r v e r A d m i n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g S e r v e r A d m i n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S e r v e r A d m i n ( ) ;  -
-     p u b l i c   v o i d   o p e n ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g U s e r I n f o r m a t i o n ) ;  -
-     p u b l i c   v o i d   o p e n ( o r g . o s g e o . m a p g u i d e . M g U s e r I n f o r m a t i o n ) ;  -
-     p u b l i c   v o i d   c l o s e ( ) ;  -
-     p u b l i c   b o o l e a n   h a s W a r n i n g ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W a r n i n g s   g e t W a r n i n g s O b j e c t ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n   g e t C o n f i g u r a t i o n P r o p e r t i e s ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t C o n f i g u r a t i o n P r o p e r t i e s ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ;  -
-     p u b l i c   v o i d   r e m o v e C o n f i g u r a t i o n P r o p e r t i e s ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ) ;  -
-     p u b l i c   b o o l e a n   c l e a r L o g ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   d e l e t e L o g ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   r e n a m e L o g ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n   e n u m e r a t e L o g s ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t L o g ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t L o g ( j a v a . l a n g . S t r i n g ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t L o g ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ,   o r g . o s g e o . m a p g u i d e . M g D a t e T i m e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t L o g F i l e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   b r i n g O n l i n e ( ) ;  -
-     p u b l i c   v o i d   t a k e O f f l i n e ( ) ;  -
-     p u b l i c   b o o l e a n   i s O n l i n e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n   g e t I n f o r m a t i o n P r o p e r t i e s ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S i t e V e r s i o n ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n   g e t S i t e S t a t u s ( ) ;  -
-     p u b l i c   v o i d   d e l e t e P a c k a g e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   e n u m e r a t e P a c k a g e s ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t P a c k a g e L o g ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P a c k a g e S t a t u s I n f o r m a t i o n   g e t P a c k a g e S t a t u s ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   l o a d P a c k a g e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   m a k e P a c k a g e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t M a x i m u m L o g S i z e ( i n t ) ;  -
-     p u b l i c   v o i d   s e t L o g D e l i m i t e r ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   e n a b l e M a x i m u m L o g S i z e ( b o o l e a n ) ;  -
-     p u b l i c   b o o l e a n   i s M a x i m u m L o g S i z e E n a b l e d ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t D o c u m e n t ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t D o c u m e n t ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ) ;  -
- C o m p i l e d   f r o m   " M g S e r v e r I n f o r m a t i o n P r o p e r t i e s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g S e r v e r I n f o r m a t i o n P r o p e r t i e s   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S e r v e r V e r s i o n   =   " S e r v e r V e r s i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A p i V e r s i o n   =   " A p i V e r s i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A d m i n O p e r a t i o n s Q u e u e C o u n t   =   " A d m i n O p e r a t i o n s Q u e u e C o u n t " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   C l i e n t O p e r a t i o n s Q u e u e C o u n t   =   " C l i e n t O p e r a t i o n s Q u e u e C o u n t " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S i t e O p e r a t i o n s Q u e u e C o u n t   =   " S i t e O p e r a t i o n s Q u e u e C o u n t " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A v e r a g e O p e r a t i o n T i m e   =   " A v e r a g e O p e r a t i o n T i m e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T o t a l O p e r a t i o n T i m e   =   " T o t a l O p e r a t i o n T i m e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   C p u U t i l i z a t i o n   =   " C p u U t i l i z a t i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T o t a l P h y s i c a l M e m o r y   =   " T o t a l P h y s i c a l M e m o r y " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A v a i l a b l e P h y s i c a l M e m o r y   =   " A v a i l a b l e P h y s i c a l M e m o r y " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T o t a l V i r t u a l M e m o r y   =   " T o t a l V i r t u a l M e m o r y " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A v a i l a b l e V i r t u a l M e m o r y   =   " A v a i l a b l e V i r t u a l M e m o r y " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   U p t i m e   =   " U p t i m e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   S t a t u s   =   " S t a t u s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   D i s p l a y N a m e   =   " D i s p l a y N a m e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M a c h i n e I p   =   " M a c h i n e I p " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T o t a l R e c e i v e d O p e r a t i o n s   =   " T o t a l R e c e i v e d O p e r a t i o n s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T o t a l P r o c e s s e d O p e r a t i o n s   =   " T o t a l P r o c e s s e d O p e r a t i o n s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T o t a l C o n n e c t i o n s   =   " T o t a l C o n n e c t i o n s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   T o t a l A c t i v e C o n n e c t i o n s   =   " T o t a l A c t i v e C o n n e c t i o n s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   O p e r a t i n g S y s t e m V e r s i o n   =   " O p e r a t i n g S y s t e m V e r s i o n " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   W o r k i n g S e t   =   " W o r k i n g S e t " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   V i r t u a l M e m o r y   =   " V i r t u a l M e m o r y " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   C a c h e S i z e   =   " C a c h e S i z e " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   C a c h e D r o p p e d E n t r i e s   =   " C a c h e D r o p p e d E n t r i e s " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S e r v e r I n f o r m a t i o n P r o p e r t i e s ( ) ;  -
- C o m p i l e d   f r o m   " M g S e r v i c e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g S e r v i c e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   b o o l e a n   h a s W a r n i n g s ( ) ;  -
- C o m p i l e d   f r o m   " M g S e r v i c e T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g S e r v i c e T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   s h o r t   R e s o u r c e S e r v i c e   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   s h o r t   D r a w i n g S e r v i c e   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   s h o r t   F e a t u r e S e r v i c e   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   s h o r t   M a p p i n g S e r v i c e   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   s h o r t   R e n d e r i n g S e r v i c e   =   4 ;  -
-     p u b l i c   s t a t i c   f i n a l   s h o r t   T i l e S e r v i c e   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   s h o r t   K m l S e r v i c e   =   6 ;  -
-     p u b l i c   s t a t i c   f i n a l   s h o r t   P r o f i l i n g S e r v i c e   =   1 0 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S e r v i c e T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g S i n g l e P r o p e r t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g S i n g l e P r o p e r t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S i n g l e P r o p e r t y ( j a v a . l a n g . S t r i n g ,   f l o a t ) ;  -
-     p u b l i c   f l o a t   g e t V a l u e ( ) ;  -
-     p u b l i c   v o i d   s e t V a l u e ( f l o a t ) ;  -
- C o m p i l e d   f r o m   " M g S i t e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g S i t e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   e n u m e r a t e U s e r s ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   e n u m e r a t e G r o u p s ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   c r e a t e S e s s i o n ( ) ;  -
-     p u b l i c   v o i d   d e s t r o y S e s s i o n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t C u r r e n t S e s s i o n ( ) ;  -
-     p u b l i c   i n t   g e t S e s s i o n T i m e o u t ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t U s e r F o r S e s s i o n ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   e n u m e r a t e G r o u p s ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   e n u m e r a t e R o l e s ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S i t e ( ) ;  -
-     p u b l i c   v o i d   o p e n ( o r g . o s g e o . m a p g u i d e . M g U s e r I n f o r m a t i o n ,   o r g . o s g e o . m a p g u i d e . M g S i t e I n f o ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W a r n i n g s   g e t W a r n i n g ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   e n u m e r a t e U s e r s ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   b o o l e a n ) ;  -
-     p u b l i c   v o i d   a d d U s e r ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   u p d a t e U s e r ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   d e l e t e U s e r s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ;  -
-     p u b l i c   v o i d   g r a n t R o l e M e m b e r s h i p s T o U s e r s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ;  -
-     p u b l i c   v o i d   r e v o k e R o l e M e m b e r s h i p s F r o m U s e r s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ;  -
-     p u b l i c   v o i d   g r a n t G r o u p M e m b e r s h i p s T o U s e r s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ;  -
-     p u b l i c   v o i d   r e v o k e G r o u p M e m b e r s h i p s F r o m U s e r s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   e n u m e r a t e G r o u p s ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   a d d G r o u p ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   u p d a t e G r o u p ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   d e l e t e G r o u p s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ;  -
-     p u b l i c   v o i d   g r a n t R o l e M e m b e r s h i p s T o G r o u p s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ;  -
-     p u b l i c   v o i d   r e v o k e R o l e M e m b e r s h i p s F r o m G r o u p s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   e n u m e r a t e R o l e s ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   e n u m e r a t e S e r v e r s ( ) ;  -
-     p u b l i c   v o i d   a d d S e r v e r ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   u p d a t e S e r v e r ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   r e m o v e S e r v e r ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S i t e I n f o   g e t S i t e S e r v e r I n f o ( i n t ) ;  -
-     p u b l i c   i n t   g e t S i t e S e r v e r C o u n t ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t C u r r e n t S i t e A d d r e s s ( ) ;  -
- C o m p i l e d   f r o m   " M g S i t e C o n n e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g S i t e C o n n e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S i t e C o n n e c t i o n ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S e r v i c e   c r e a t e S e r v i c e ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S i t e   g e t S i t e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S i t e C o n n e c t i o n ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g S i t e I n f o . j a v a "  -
- p u b l i c   f i n a l   c l a s s   o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g P o r t T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g P o r t T y p e   C l i e n t ;  -
-     p u b l i c   s t a t i c   f i n a l   o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g P o r t T y p e   S i t e ;  -
-     p u b l i c   s t a t i c   f i n a l   o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g P o r t T y p e   A d m i n ;  -
-     p u b l i c   f i n a l   i n t   s w i g V a l u e ( ) ;  -
-     p u b l i c   s t a t i c   o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g P o r t T y p e   s w i g T o E n u m ( i n t ) ;  -
- p u b l i c   f i n a l   c l a s s   o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g S i t e S t a t u s   {  -
-     p u b l i c   s t a t i c   f i n a l   o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g S i t e S t a t u s   O k ;  -
-     p u b l i c   s t a t i c   f i n a l   o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g S i t e S t a t u s   U n a b l e T o C o n n e c t ;  -
-     p u b l i c   s t a t i c   f i n a l   o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g S i t e S t a t u s   T i m e d O u t ;  -
-     p u b l i c   s t a t i c   f i n a l   o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g S i t e S t a t u s   U n i n i t i a l i z e d ;  -
-     p u b l i c   s t a t i c   o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g S i t e S t a t u s   s w i g T o E n u m ( i n t ) ;  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g S i t e I n f o   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S i t e I n f o ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S i t e I n f o ( j a v a . l a n g . S t r i n g ,   i n t ,   i n t ,   i n t ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t T a r g e t ( ) ;  -
-     p u b l i c   i n t   g e t P o r t ( o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g P o r t T y p e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g S i t e S t a t u s   g e t S t a t u s ( ) ;  -
-     p u b l i c   v o i d   s e t S t a t u s ( o r g . o s g e o . m a p g u i d e . M g S i t e I n f o $ M g S i t e S t a t u s ) ;  -
- C o m p i l e d   f r o m   " M g S p a t i a l C o n t e x t E x t e n t T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g S p a t i a l C o n t e x t E x t e n t T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   s c S t a t i c   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   s c D y n a m i c   =   1 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S p a t i a l C o n t e x t E x t e n t T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g S p a t i a l C o n t e x t R e a d e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g S p a t i a l C o n t e x t R e a d e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   i m p l e m e n t s   j a v a . l a n g . A u t o C l o s e a b l e   {  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D e s c r i p t i o n ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t C o o r d i n a t e S y s t e m ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t C o o r d i n a t e S y s t e m W k t ( ) ;  -
-     p u b l i c   i n t   g e t E x t e n t T y p e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t E x t e n t ( ) ;  -
-     p u b l i c   d o u b l e   g e t X Y T o l e r a n c e ( ) ;  -
-     p u b l i c   d o u b l e   g e t Z T o l e r a n c e ( ) ;  -
-     p u b l i c   b o o l e a n   i s A c t i v e ( ) ;  -
-     p u b l i c   b o o l e a n   r e a d N e x t ( ) ;  -
-     p u b l i c   v o i d   r e s e t ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   t o X m l ( ) ;  -
- C o m p i l e d   f r o m   " M g S q l D a t a R e a d e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g S q l D a t a R e a d e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g R e a d e r   i m p l e m e n t s   j a v a . l a n g . A u t o C l o s e a b l e   {  -
- C o m p i l e d   f r o m   " M g S t r i n g C o l l e c t i o n . j a v a "  -
- c l a s s   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n $ I t e m I t e r a t o r   i m p l e m e n t s   j a v a . u t i l . I t e r a t o r < j a v a . l a n g . S t r i n g >   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n $ I t e m I t e r a t o r ( o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ) ;  -
-     p u b l i c   b o o l e a n   h a s N e x t ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   n e x t ( ) ;  -
-     p u b l i c   v o i d   r e m o v e ( ) ;  -
-     p u b l i c   j a v a . l a n g . O b j e c t   n e x t ( ) ;  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n   i m p l e m e n t s   j a v a . u t i l . C o l l e c t i o n < j a v a . l a n g . S t r i n g >   {  -
-     p u b l i c   j a v a . u t i l . I t e r a t o r < j a v a . l a n g . S t r i n g >   i t e r a t o r ( ) ;  -
-     p u b l i c   b o o l e a n   a d d ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   a d d A l l ( j a v a . u t i l . C o l l e c t i o n < ?   e x t e n d s   j a v a . l a n g . S t r i n g > ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( j a v a . l a n g . O b j e c t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ;  -
-     p u b l i c   b o o l e a n   i s E m p t y ( ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( j a v a . l a n g . O b j e c t ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ;  -
-     p u b l i c   b o o l e a n   r e t a i n A l l ( j a v a . u t i l . C o l l e c t i o n < ? > ) ;  -
-     p u b l i c   i n t   s i z e ( ) ;  -
-     p u b l i c   j a v a . l a n g . O b j e c t [ ]   t o A r r a y ( ) ;  -
-     p u b l i c   < S t r i n g >   S t r i n g [ ]   t o A r r a y ( S t r i n g [ ] ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t I t e m ( i n t ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   a d d I t e m ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   c l e a r ( ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   r e m o v e A t ( i n t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   i n d e x O f ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   a d d ( j a v a . l a n g . O b j e c t ) ;  -
- C o m p i l e d   f r o m   " M g S t r i n g P r o p e r t y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N u l l a b l e P r o p e r t y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t V a l u e ( ) ;  -
-     p u b l i c   s h o r t   g e t P r o p e r t y T y p e ( ) ;  -
-     p u b l i c   v o i d   s e t V a l u e ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g S t r i n g P r o p e r t y C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g C o l l e c t i o n   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y C o l l e c t i o n ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t N a m e ( i n t ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t V a l u e ( i n t ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t V a l u e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t V a l u e ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   a d d ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   a d d ( o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   i n s e r t ( i n t ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y ) ;  -
-     p u b l i c   b o o l e a n   r e m o v e ( o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y   g e t I t e m ( i n t ) ;  -
-     p u b l i c   v o i d   s e t I t e m ( i n t ,   o r g . o s g e o . m a p g u i d e . M g S t r i n g P r o p e r t y ) ;  -
- C o m p i l e d   f r o m   " M g T i l e S e r v i c e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g T i l e S e r v i c e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r v i c e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t T i l e ( o r g . o s g e o . m a p g u i d e . M g M a p ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t T i l e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ,   j a v a . l a n g . S t r i n g ,   i n t ,   i n t ,   i n t ) ;  -
-     p u b l i c   v o i d   c l e a r C a c h e ( o r g . o s g e o . m a p g u i d e . M g M a p ) ;  -
-     p u b l i c   v o i d   c l e a r C a c h e ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   i n t   g e t D e f a u l t T i l e S i z e X ( ) ;  -
-     p u b l i c   i n t   g e t D e f a u l t T i l e S i z e Y ( ) ;  -
-     p u b l i c   i n t   g e t D e f a u l t T i l e S i z e X ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   i n t   g e t D e f a u l t T i l e S i z e Y ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t T i l e P r o v i d e r s ( ) ;  -
- C o m p i l e d   f r o m   " M g T r a n s a c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g T r a n s a c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   v o i d   c o m m i t ( ) ;  -
-     p u b l i c   v o i d   r o l l b a c k ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r   g e t F e a t u r e S o u r c e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   a d d S a v e P o i n t ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   r e l e a s e S a v e P o i n t ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   r o l l b a c k ( j a v a . l a n g . S t r i n g ) ;  -
- C o m p i l e d   f r o m   " M g T r a n s f o r m . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   t r a n s f o r m ( d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   t r a n s f o r m ( d o u b l e ,   d o u b l e ,   d o u b l e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e   t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g C o o r d i n a t e ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g E n v e l o p e   t r a n s f o r m ( o r g . o s g e o . m a p g u i d e . M g E n v e l o p e ) ;  -
- C o m p i l e d   f r o m   " M g U n i t T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g U n i t T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   U S E n g l i s h   =   " U S - E n g l i s h " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   M e t r i c   =   " M e t r i c " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g U n i t T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g U p d a t e F e a t u r e s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g U p d a t e F e a t u r e s   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g F e a t u r e C o m m a n d   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g U p d a t e F e a t u r e s ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   i n t   g e t C o m m a n d T y p e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P r o p e r t y C o l l e c t i o n   g e t P r o p e r t y V a l u e s ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t F e a t u r e C l a s s N a m e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t F i l t e r T e x t ( ) ;  -
- C o m p i l e d   f r o m   " M g U s e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g U s e r   {  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   A n o n y m o u s   =   " A n o n y m o u s " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   W f s U s e r   =   " W f s U s e r " ;  -
-     p u b l i c   s t a t i c   f i n a l   j a v a . l a n g . S t r i n g   W m s U s e r   =   " W m s U s e r " ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g U s e r ( ) ;  -
- C o m p i l e d   f r o m   " M g U s e r I n f o r m a t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g U s e r I n f o r m a t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g U s e r I n f o r m a t i o n ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g U s e r I n f o r m a t i o n ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g U s e r I n f o r m a t i o n ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t M g U s e r n a m e P a s s w o r d ( j a v a . l a n g . S t r i n g ,   j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t M g S e s s i o n I d ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   v o i d   s e t L o c a l e ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t L o c a l e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   g e t R e a d e r ( ) ;  -
-     p u b l i c   v o i d   s e t C l i e n t A g e n t ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t C l i e n t A g e n t ( ) ;  -
-     p u b l i c   v o i d   s e t C l i e n t I p ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t C l i e n t I p ( ) ;  -
- C o m p i l e d   f r o m   " M g W a r n i n g s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W a r n i n g s   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g S e r i a l i z a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g S t r i n g C o l l e c t i o n   g e t M e s s a g e s ( ) ;  -
-     p u b l i c   i n t   g e t C o u n t ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b A c t i o n s . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b A c t i o n s   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P a n   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P a n U p   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P a n D o w n   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P a n R i g h t   =   4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P a n L e f t   =   5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   Z o o m   =   6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   Z o o m I n   =   7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   Z o o m O u t   =   8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   Z o o m R e c t a n g l e   =   9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   Z o o m S e l e c t i o n   =   1 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   F i t W i n d o w   =   1 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   V i e w P r e v i o u s   =   1 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   V i e w N e x t   =   1 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   V i e w R e s t o r e   =   1 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S e l e c t   =   1 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S e l e c t R a d i u s   =   1 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S e l e c t P o l y g o n   =   1 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S e l e c t C l e a r   =   1 9 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   R e f r e s h   =   2 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C o p y   =   2 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A b o u t   =   2 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   P r i n t M a p   =   2 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   G e t P r i n t a b l e P a g e   =   2 4 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M e a s u r e   =   2 5 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n v o k e U r l   =   2 6 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S e a r c h   =   2 7 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B u f f e r   =   2 8 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   V i e w O p t i o n s   =   3 0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   I n v o k e S c r i p t   =   3 1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S e l e c t W i t h i n   =   3 2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   H e l p   =   3 3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   M a p T i p   =   3 4 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b A c t i o n s ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b B u f f e r C o m m a n d . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b B u f f e r C o m m a n d   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d   {  -
- C o m p i l e d   f r o m   " M g W e b C o m m a n d . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g N a m e d S e r i a l i z a b l e   {  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t L a b e l ( ) ;  -
-     p u b l i c   i n t   g e t A c t i o n ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t I c o n U r l ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D i s a b l e d I c o n U r l ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t T o o l t i p ( ) ;  -
-     p u b l i c   i n t   g e t T a r g e t V i e w e r T y p e ( ) ;  -
-     p u b l i c   b o o l e a n   i s U s e d ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b C o m m a n d C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d   g e t I t e m ( i n t ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d   g e t I t e m ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d ) ;  -
- C o m p i l e d   f r o m   " M g W e b C o m m a n d W i d g e t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d W i d g e t   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d   g e t C o m m a n d ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b C o n t e x t M e n u . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b C o n t e x t M e n u   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t C o l l e c t i o n   {  -
-     p u b l i c   b o o l e a n   i s V i s i b l e ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b F l y o u t W i d g e t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b F l y o u t W i d g e t   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t C o l l e c t i o n   g e t S u b I t e m s ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b G e t P r i n t a b l e P a g e C o m m a n d . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b G e t P r i n t a b l e P a g e C o m m a n d   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d   {  -
- C o m p i l e d   f r o m   " M g W e b H e l p C o m m a n d . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b H e l p C o m m a n d   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d   {  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t U r l ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b I n f o r m a t i o n P a n e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b I n f o r m a t i o n P a n e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b U i S i z a b l e P a n e   {  -
-     p u b l i c   b o o l e a n   i s L e g e n d B a n d V i s i b l e ( ) ;  -
-     p u b l i c   b o o l e a n   i s P r o p e r t i e s B a n d V i s i b l e ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b I n v o k e S c r i p t C o m m a n d . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b I n v o k e S c r i p t C o m m a n d   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d   {  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S c r i p t C o d e ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b I n v o k e U r l C o m m a n d . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b I n v o k e U r l C o m m a n d   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d   {  -
-     p u b l i c   i n t   g e t P a r a m e t e r C o u n t ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t P a r a m e t e r N a m e A t ( i n t ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t P a r a m e t e r V a l u e A t ( i n t ) ;  -
-     p u b l i c   b o o l e a n   d i s a b l e d I f S e l e c t i o n E m p t y ( ) ;  -
-     p u b l i c   i n t   g e t L a y e r C o u n t ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t L a y e r N a m e A t ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g W e b L a y o u t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b L a y o u t   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b L a y o u t ( o r g . o s g e o . m a p g u i d e . M g R e s o u r c e S e r v i c e ,   o r g . o s g e o . m a p g u i d e . M g R e s o u r c e I d e n t i f i e r ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t T i t l e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t M a p D e f i n i t i o n ( ) ;  -
-     p u b l i c   b o o l e a n   g e t E n a b l e P i n g S e r v e r ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S e l e c t i o n C o l o r ( ) ;  -
-     p u b l i c   i n t   g e t P o i n t S e l e c t i o n B u f f e r ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t M a p I m a g e F o r m a t ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S e l e c t i o n I m a g e F o r m a t ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t S t a r t u p S c r i p t ( ) ;  -
-     p u b l i c   d o u b l e   g e t S c a l e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g P o i n t   g e t C e n t e r ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b T o o l B a r   g e t T o o l B a r ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b U i P a n e   g e t S t a t u s B a r ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b T a s k P a n e   g e t T a s k P a n e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b I n f o r m a t i o n P a n e   g e t I n f o r m a t i o n P a n e ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t D w f P r e v i e w U r l ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t A j a x P r e v i e w U r l ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d C o l l e c t i o n   g e t C o m m a n d s ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b C o n t e x t M e n u   g e t C o n t e x t M e n u ( ) ;  -
-     p u b l i c   i n t   g e t H y p e r l i n k T a r g e t ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t H y p e r l i n k T a r g e t F r a m e ( ) ;  -
-     p u b l i c   b o o l e a n   i s Z o o m C o n t r o l V i s i b l e ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r   p r o c e s s G e t t i n g S t a r t e d P a g e ( o r g . o s g e o . m a p g u i d e . M g B y t e R e a d e r ,   b o o l e a n ) ;  -
- C o m p i l e d   f r o m   " M g W e b M e a s u r e C o m m a n d . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b M e a s u r e C o m m a n d   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d   {  -
- C o m p i l e d   f r o m   " M g W e b P r i n t C o m m a n d . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b P r i n t C o m m a n d   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d   {  -
-     p u b l i c   i n t   g e t P r i n t L a y o u t C o u n t ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t P r i n t L a y o u t A t ( i n t ) ;  -
- C o m p i l e d   f r o m   " M g W e b S e a r c h C o m m a n d . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b S e a r c h C o m m a n d   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d   {  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t L a y e r ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t P r o m p t ( ) ;  -
-     p u b l i c   i n t   g e t R e s u l t C o l u m n C o u n t ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t C o l u m n D i s p l a y N a m e A t ( i n t ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t C o l u m n P r o p e r t y N a m e A t ( i n t ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t F i l t e r ( ) ;  -
-     p u b l i c   i n t   g e t M a t c h L i m i t ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b S e l e c t W i t h i n C o m m a n d . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b S e l e c t W i t h i n C o m m a n d   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d   {  -
- C o m p i l e d   f r o m   " M g W e b S e p a r a t o r W i d g e t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b S e p a r a t o r W i d g e t   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t   {  -
- C o m p i l e d   f r o m   " M g W e b T a r g e t T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b T a r g e t T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T a s k P a n e   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   N e w W i n d o w   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S p e c i f i e d F r a m e   =   3 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b T a r g e t T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b T a r g e t V i e w e r T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b T a r g e t V i e w e r T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   D w f   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A j a x   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   A l l   =   3 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b T a r g e t V i e w e r T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b T a s k B a r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b T a s k B a r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b U i P a n e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t C o l l e c t i o n   g e t T a s k L i s t ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t C o l l e c t i o n   g e t T a s k B u t t o n s ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b T a s k B a r W i d g e t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b T a s k B a r W i d g e t   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t   {  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t N a m e ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b T a s k B u t t o n T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b T a s k B u t t o n T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   H o m e   =   0 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   B a c k   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   F o r w a r d   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T a s k s   =   3 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b T a s k B u t t o n T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b T a s k P a n e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b T a s k P a n e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b U i S i z a b l e P a n e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b T a s k B a r   g e t T a s k B a r ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t I n i t i a l T a s k U r l ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b T o o l B a r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b T o o l B a r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b U i P a n e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t C o l l e c t i o n   g e t W i d g e t s ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b U i P a n e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b U i P a n e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
- C o m p i l e d   f r o m   " M g W e b U i S i z a b l e P a n e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b U i S i z a b l e P a n e   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b U i P a n e   {  -
-     p u b l i c   i n t   g e t W i d t h ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b U i T a r g e t C o m m a n d . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b C o m m a n d   {  -
-     p u b l i c   i n t   g e t T a r g e t ( ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   g e t T a r g e t N a m e ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b V i e w O p t i o n s C o m m a n d . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b V i e w O p t i o n s C o m m a n d   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g W e b U i T a r g e t C o m m a n d   {  -
- C o m p i l e d   f r o m   " M g W e b W i d g e t . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   i n t   g e t T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g W e b W i d g e t C o l l e c t i o n . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t C o l l e c t i o n   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t   g e t W i d g e t ( i n t ) ;  -
-     p u b l i c   b o o l e a n   c o n t a i n s ( o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t ) ;  -
-     p u b l i c   i n t   i n d e x O f ( o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t ) ;  -
- C o m p i l e d   f r o m   " M g W e b W i d g e t T y p e . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t T y p e   {  -
-     p u b l i c   s t a t i c   f i n a l   i n t   C o m m a n d   =   1 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   S e p a r a t o r   =   2 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   F l y o u t   =   3 ;  -
-     p u b l i c   s t a t i c   f i n a l   i n t   T a s k B u t t o n   =   4 ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W e b W i d g e t T y p e ( ) ;  -
- C o m p i l e d   f r o m   " M g W k t R e a d e r W r i t e r . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . M g W k t R e a d e r W r i t e r   e x t e n d s   o r g . o s g e o . m a p g u i d e . M g G u a r d D i s p o s a b l e   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g W k t R e a d e r W r i t e r ( ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   r e a d ( j a v a . l a n g . S t r i n g ) ;  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . M g G e o m e t r y   r e a d ( j a v a . l a n g . S t r i n g ,   o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   w r i t e ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ) ;  -
-     p u b l i c   j a v a . l a n g . S t r i n g   w r i t e ( o r g . o s g e o . m a p g u i d e . M g G e o m e t r y ,   o r g . o s g e o . m a p g u i d e . M g T r a n s f o r m ) ;  -
- C o m p i l e d   f r o m   " O b j e c t F a c t o r y . j a v a "  -
- p u b l i c   c l a s s   o r g . o s g e o . m a p g u i d e . O b j e c t F a c t o r y   {  -
-     p u b l i c   o r g . o s g e o . m a p g u i d e . O b j e c t F a c t o r y ( ) ;  -
-     p u b l i c   s t a t i c   j a v a . l a n g . O b j e c t   c r e a t e O b j e c t ( i n t ,   l o n g ,   b o o l e a n ) ;  -
\ No newline at end of file
+ÿþC
Modified: branches/4.0/MgDev/Bindings/src/ApiDump/api.php.txt
--- branches/4.0/MgDev/Bindings/src/ApiDump/api.php.txt	2026-11-10 07:15:37 UTC (rev 10282)
+++ branches/4.0/MgDev/Bindings/src/ApiDump/api.php.txt	2026-11-11 12:20:53 UTC (rev 10283)
@@ -1824,7 +1824,7 @@
     Constant [ public string RenderingServicePropertyRasterGridSizeOverrideRatioForPlot ] { RasterGridSizeOverrideRatioForPlot }
     Constant [ public float DefaultRenderingServicePropertyRasterGridSizeOverrideRatioForPlot ] { 0.1 }
     Constant [ public string RenderingServicePropertyRenderSelectionBatchSize ] { RenderSelectionBatchSize }
-    Constant [ public int DefaultRenderingServicePropertyRenderSelectionBatchSize ] { 50000 }
+    Constant [ public int DefaultRenderingServicePropertyRenderSelectionBatchSize ] { 1000 }
     Constant [ public string RenderingServicePropertyClampPoints ] { ClampPoints }
     Constant [ public bool DefaultRenderingServicePropertyClampPoints ] {  }
     Constant [ public string RenderingServicePropertyGeneralizeData ] { GeneralizeData }
Modified: branches/4.0/MgDev/Bindings/src/ApiDump/dotnet-dump.ps1
--- branches/4.0/MgDev/Bindings/src/ApiDump/dotnet-dump.ps1	2026-11-10 07:15:37 UTC (rev 10282)
+++ branches/4.0/MgDev/Bindings/src/ApiDump/dotnet-dump.ps1	2026-11-11 12:20:53 UTC (rev 10283)
@@ -10,6 +10,24 @@
 if (Test-Path $outputPath) {
     Clear-Content -Path $outputPath
+# Some of the names the reflection API hands back are assembly-qualified ("Type, Assembly,
+# Version=x.y.z.n, Culture=neutral, PublicKeyToken=..."). The version's last component is the
+# build number, so it changes on every build and makes the snapshot diff unreadable. Name a
+# closed generic's arguments by recursion instead of trusting FullName, and strip any assembly
+# identity that is left, so the snapshot only changes when the API itself does.
+function Format-TypeName([Type]$type) {
+    if ($null -eq $type) { return '' }
+    if ($type.IsGenericType -and -not $type.IsGenericTypeDefinition) {
+        $definition = $type.GetGenericTypeDefinition().FullName
+        $arguments = @($type.GetGenericArguments() | ForEach-Object { Format-TypeName $_ })
+        return "$definition[$($arguments -join ',')]"
+    return $type.FullName
+function Write-ApiLine([string]$line) {
+    $line = [regex]::Replace($line, ',\s*[^,\[\]]+,\s*Version=[^,\[\]]+,\s*Culture=[^,\[\]]+,\s*PublicKeyToken=[^,\]]+', '')
+    $line | Out-File -FilePath $outputPath -Append
 $assemblies = @()
 $assemblies += [System.Reflection.Assembly]::LoadFrom([System.IO.Path]::Combine($libPath, "OSGeo.MapGuide.Foundation.dll"));
 $assemblies += [System.Reflection.Assembly]::LoadFrom([System.IO.Path]::Combine($libPath, "OSGeo.MapGuide.Geometry.dll"));
@@ -17,27 +35,27 @@
 $assemblies += [System.Reflection.Assembly]::LoadFrom([System.IO.Path]::Combine($libPath, "OSGeo.MapGuide.MapGuideCommon.dll"));
 $assemblies += [System.Reflection.Assembly]::LoadFrom([System.IO.Path]::Combine($libPath, "OSGeo.MapGuide.Web.dll"));
 foreach ($asm in $assemblies) {
-    "Assembly: $($asm.FullName)" | Out-File -FilePath $outputPath -Append
+    Write-ApiLine "Assembly: $($asm.GetName().Name)"
     foreach ($type in $asm.ExportedTypes) {
         foreach ($attr in $type.GetCustomAttributes($false)) {
-            "[$attr]" | Out-File -FilePath $outputPath -Append
+            Write-ApiLine "[$attr]"
-        "type $($type.FullName) : $($type.BaseType.FullName)" | Out-File -FilePath $outputPath -Append
+        Write-ApiLine "type $(Format-TypeName $type) : $(Format-TypeName $type.BaseType)"
         foreach ($iface in $type.GetInterfaces()) {
-            "    implements $($iface.FullName)" | Out-File -FilePath $outputPath -Append
+            Write-ApiLine "    implements $(Format-TypeName $iface)"
-        "{" | Out-File -FilePath $outputPath -Append
+        Write-ApiLine "{"
         # Sort members by name as we cannot be certain of the determinism of the order of these members will be preserved
         $memberList = $type.DeclaredMembers | Sort-Object -Property Name
         foreach ($member in $memberList) {
             if ($member.IsPublic) {
                 foreach ($attr in $member.GetCustomAttributes($false)) {
-                    "    [$attr]" | Out-File -FilePath $outputPath -Append
+                    Write-ApiLine "    [$attr]"
-                "    [$($member.MemberType)] $member" | Out-File -FilePath $outputPath -Append
+                Write-ApiLine "    [$($member.MemberType)] $member"
-        "}" | Out-File -FilePath $outputPath -Append
+        Write-ApiLine "}"
 Write-Host "API surface written to $outputPath"
Modified: branches/4.0/MgDev/Bindings/src/ApiDump/filelist.linux.generic-common.txt
--- branches/4.0/MgDev/Bindings/src/ApiDump/filelist.linux.generic-common.txt	2026-11-10 07:15:37 UTC (rev 10282)
+++ branches/4.0/MgDev/Bindings/src/ApiDump/filelist.linux.generic-common.txt	2026-11-11 12:20:53 UTC (rev 10283)
@@ -1,678 +1,678 @@
 include/
-include/Web/
-include/Web/HttpHandler/
-include/Web/HttpHandler/HttpReaderStreamer.h
-include/Web/HttpHandler/HttpEnumerateUsers.h
-include/Web/HttpHandler/XmlJsonConvert.h
-include/Web/HttpHandler/OgcWmsException.h
-include/Web/HttpHandler/HttpKmlGetFeatures.h
-include/Web/HttpHandler/HttpGetTileProviders.h
-include/Web/HttpHandler/HttpGetFeatureProviders.h
-include/Web/HttpHandler/HttpEnumerateApplicationContainers.h
-include/Web/HttpHandler/HttpWmsGetFeatureInfo.h
-include/Web/HttpHandler/HttpGetSiteVersion.h
-include/Web/HttpHandler/HttpEnumerateResources.h
-include/Web/HttpHandler/HttpGeoConvexHull.h
-include/Web/HttpHandler/WmsFeatureProperties.h
-include/Web/HttpHandler/OgcWmsServer.h
-include/Web/HttpHandler/WfsFeatureDefinitions.h
-include/Web/HttpHandler/OgcDataAccessor.h
-include/Web/HttpHandler/HttpCsConvertCoordinateSystemCodeToWkt.h
-include/Web/HttpHandler/WmsMapUtil.h
-include/Web/HttpHandler/HttpDeleteResourceData.h
-include/Web/HttpHandler/HttpDeleteResource.h
-include/Web/HttpHandler/HttpCsEnumerateCategories.h
-include/Web/HttpHandler/OgcServer.h
-include/Web/HttpHandler/HttpGetLegendImage.h
-include/Web/HttpHandler/HttpQueryMapFeatures.h
-include/Web/HttpHandler/ReaderByteSourceImpl.h
-include/Web/HttpHandler/HttpEnumerateDrawingLayers.h
-include/Web/HttpHandler/HttpCsConvertWktToEpsgCode.h
-include/Web/HttpHandler/HttpEnumerateUnmanagedData.h
-include/Web/HttpHandler/XmlElementEmitter.h
-include/Web/HttpHandler/HttpEnumerateResourceData.h
-include/Web/HttpHandler/OgcFramework.h
-include/Web/HttpHandler/JsonDoc.h
-include/Web/HttpHandler/HttpGetResourceHeader.h
-include/Web/HttpHandler/HttpResponse.h
-include/Web/HttpHandler/HttpGetClassDefinition.h
-include/Web/HttpHandler/HttpResourceStrings.h
-include/Web/HttpHandler/HttpDescribeDrawing.h
-include/Web/HttpHandler/HttpSelectFeatures.h
-include/Web/HttpHandler/HttpGetMapImage.h
-include/Web/HttpHandler/StringStream.h
-include/Web/HttpHandler/HttpKmlGetMap.h
-include/Web/HttpHandler/HttpCsConvertEpsgCodeToWkt.h
-include/Web/HttpHandler/HttpCsTransformCoordinates.h
-include/Web/HttpHandler/HttpGetSchemas.h
-include/Web/HttpHandler/HttpGetRepositoryHeader.h
-include/Web/HttpHandler/HttpGetDrawingLayer.h
-include/Web/HttpHandler/HttpEnumerateGroups.h
-include/Web/HttpHandler/HttpGeoSpatialPredicate.h
-include/Web/HttpHandler/HttpGetFdoCacheInfo.h
-include/Web/HttpHandler/HttpMoveResource.h
-include/Web/HttpHandler/HttpGetRepositoryContent.h
-include/Web/HttpHandler/HttpAnonymousCheck.h
-include/Web/HttpHandler/HttpGetDrawingCoordinateSpace.h
-include/Web/HttpHandler/HttpRequestParam.h
-include/Web/HttpHandler/HttpHandlerClassId.h
-include/Web/HttpHandler/HttpGetVisibleMapExtent.h
-include/Web/HttpHandler/HttpGetTileImage.h
-include/Web/HttpHandler/HttpCsIsValid.h
-include/Web/HttpHandler/HttpCsEnumerateCoordinateSystems.h
-include/Web/HttpHandler/HttpResourceExists.h
-include/Web/HttpHandler/HttpGetClasses.h
-include/Web/HttpHandler/HttpSelectFeaturesSpatially.h
-include/Web/HttpHandler/HttpGetDrawing.h
-include/Web/HttpHandler/HttpEnumerateApplicationWidgets.h
-include/Web/HttpHandler/HttpRequestMetadata.h
-include/Web/HttpHandler/ResponseStream.h
-include/Web/HttpHandler/HttpGetSessionTimeout.h
-include/Web/HttpHandler/WfsGetFeatureParams.h
-include/Web/HttpHandler/HttpSetResourceData.h
-include/Web/HttpHandler/HttpHandlerApiDllExport.h
-include/Web/HttpHandler/HttpRequest.h
-include/Web/HttpHandler/HttpRenameResourceData.h
-include/Web/HttpHandler/HttpSetResource.h
-include/Web/HttpHandler/NameValueCollection.h
-include/Web/HttpHandler/HttpWfsDescribeFeatureType.h
-include/Web/HttpHandler/HttpGetSiteStatus.h
-include/Web/HttpHandler/XmlParser.h
-include/Web/HttpHandler/HttpUtil.h
-include/Web/HttpHandler/HttpGetSchemaMapping.h
-include/Web/HttpHandler/HttpEnumerateApplicationTemplates.h
-include/Web/HttpHandler/HttpEnumerateDrawingSections.h
-include/Web/HttpHandler/HttpGetDwfViewerPage.h
-include/Web/HttpHandler/HttpGeoDistance.h
-include/Web/HttpHandler/HttpGeoTessellate.h
-include/Web/HttpHandler/HttpGetCapabilities.h
-include/Web/HttpHandler/HttpEnumerateDataStores.h
-include/Web/HttpHandler/HttpGetDrawingSection.h
-include/Web/HttpHandler/HttpRequestParameters.h
-include/Web/HttpHandler/HttpChangeResourceOwner.h
-include/Web/HttpHandler/HttpCreateRepository.h
-include/Web/HttpHandler/HttpHandler.h
-include/Web/HttpHandler/HttpCsGetBaseLibrary.h
-include/Web/HttpHandler/HttpDeleteRepository.h
-include/Web/HttpHandler/HttpWfsGetCapabilities.h
-include/Web/HttpHandler/WmsLayerDefinitions.h
-include/Web/HttpHandler/WmsFeatureInfo.h
-include/Web/HttpHandler/HttpPrimitiveValue.h
-include/Web/HttpHandler/HttpResult.h
-include/Web/HttpHandler/HttpWmsGetCapabilities.h
-include/Web/HttpHandler/HttpWfsGetFeature.h
-include/Web/HttpHandler/HttpClearTileCache.h
-include/Web/HttpHandler/HttpGetMapLegendImage.h
-include/Web/HttpHandler/HttpApplyResourcePackage.h
-include/Web/HttpHandler/HttpCsConvertWktToCoordinateSystemCode.h
-include/Web/HttpHandler/HttpGetSiteInfo.h
-include/Web/HttpHandler/NameStringValueCollection.h
-include/Web/HttpHandler/HttpGeoBinaryOperation.h
-include/Web/HttpHandler/HttpPrimitiveValueTypes.h
-include/Web/HttpHandler/HttpKmlGetLayer.h
-include/Web/HttpHandler/HttpWmsGetMap.h
-include/Web/HttpHandler/HttpGetIdentityProperties.h
-include/Web/HttpHandler/HttpDescribeRuntimeMap.h
-include/Web/HttpHandler/HttpGeoBoundary.h
-include/Web/HttpHandler/HttpInheritPermissionsFrom.h
-include/Web/HttpHandler/HttpStatusCodes.h
-include/Web/HttpHandler/HttpGetConnectionPropertyValues.h
-include/Web/HttpHandler/HttpGetResourceContent.h
-include/Web/HttpHandler/HttpTestConnection.h
-include/Web/HttpHandler/HttpEnumerateRepositories.h
-include/Web/HttpHandler/HttpGeoSimplify.h
-include/Web/HttpHandler/Dictionary.h
-include/Web/HttpHandler/HttpCreateSession.h
-include/Web/HttpHandler/HttpGetDrawingSectionResource.h
-include/Web/HttpHandler/HttpGeometryInfo.h
-include/Web/HttpHandler/HttpGetSpatialContexts.h
-include/Web/HttpHandler/HttpDescribeSchema.h
-include/Web/HttpHandler/HttpGetLongTransactions.h
-include/Web/HttpHandler/HttpGetHtmlViewerPage.h
-include/Web/HttpHandler/HttpCopyResource.h
-include/Web/HttpHandler/HttpGetResourceData.h
-include/Web/HttpHandler/HttpHeader.h
-include/Web/HttpHandler/HttpGetDefaultTileSizeY.h
-include/Web/HttpHandler/HttpGetDefaultTileSizeX.h
-include/Web/HttpHandler/OgcWfsServer.h
-include/Web/HttpHandler/HttpEnumerateDrawingSectionResources.h
-include/Web/HttpHandler/WmsFeatureGeometry.h
-include/Web/HttpHandler/OgcException.h
-include/Web/HttpHandler/HttpGetPlot.h
-include/Web/HttpHandler/Stream.h
-include/Web/HttpHandler/HttpEnumerateResourceReferences.h
-include/Web/HttpHandler/HttpRequestResponseHandler.h
-include/Web/HttpHandler/HttpGetFeatureSetEnvelope.h
-include/Web/HttpHandler/HttpGeoBuffer.h
-include/Web/HttpHandler/HttpUpdateRepository.h
-include/Web/HttpHandler/OgcWfsException.h
-include/Web/HttpHandler/HttpCreateRuntimeMap.h
-include/Web/HttpHandler/HttpGetDynamicMapOverlayImage.h
-include/Web/WebApp/
-include/Web/WebApp/WebInformationPane.h
-include/Web/WebApp/WebLayout.h
-include/Web/WebApp/WebInvokeUrlCommand.h
-include/Web/WebApp/WebUiSizablePane.h
-include/Web/WebApp/WebWidgetCollection.h
-include/Web/WebApp/WebTaskBarWidget.h
-include/Web/WebApp/WebMeasureCommand.h
-include/Web/WebApp/WebTaskPane.h
-include/Web/WebApp/WebBufferCommand.h
-include/Web/WebApp/WebUiTargetCommand.h
-include/Web/WebApp/WebViewOptionsCommand.h
-include/Web/WebApp/WebWidget.h
-include/Web/WebApp/WebAppClassId.h
-include/Web/WebApp/WebSeparatorWidget.h
-include/Web/WebApp/WebContextMenu.h
-include/Web/WebApp/WebWidgetType.h
-include/Web/WebApp/WebGetPrintablePageCommand.h
-include/Web/WebApp/WebApp.h
-include/Web/WebApp/WebHelpCommand.h
-include/Web/WebApp/WebTargetViewerType.h
-include/Web/WebApp/WebCommandWidget.h
-include/Web/WebApp/WebPrintCommand.h
-include/Web/WebApp/WebTaskButtonType.h
-include/Web/WebApp/WebSelectWithinCommand.h
-include/Web/WebApp/WebFlyoutWidget.h
-include/Web/WebApp/WebTargetType.h
-include/Web/WebApp/WebSearchCommand.h
-include/Web/WebApp/WebTaskBar.h
-include/Web/WebApp/WebUiPane.h
-include/Web/WebApp/WebCommand.h
-include/Web/WebApp/WebAppExport.h
-include/Web/WebApp/WebActions.h
-include/Web/WebApp/WebInvokeScriptCommand.h
-include/Web/WebApp/WebToolbar.h
-include/Web/WebApp/WebCommandCollection.h
 include/Common/
+include/Common/Foundation/
+include/Common/Foundation/Data/
+include/Common/Foundation/Data/BatchPropertyCollection.h
+include/Common/Foundation/Data/Byte.h
+include/Common/Foundation/Data/ByteReader.h
+include/Common/Foundation/Data/ByteSink.h
+include/Common/Foundation/Data/ByteSource.h
+include/Common/Foundation/Data/Collection.h
+include/Common/Foundation/Data/DateTime.h
+include/Common/Foundation/Data/FeaturePropertyType.h
+include/Common/Foundation/Data/MimeType.h
+include/Common/Foundation/Data/NamedCollection.h
+include/Common/Foundation/Data/NullableProperty.h
+include/Common/Foundation/Data/Property.h
+include/Common/Foundation/Data/PropertyCollection.h
+include/Common/Foundation/Data/PropertyDefinition.h
+include/Common/Foundation/Data/PropertyType.h
+include/Common/Foundation/Data/StringCollection.h
+include/Common/Foundation/Data/StringProperty.h
+include/Common/Foundation/Exception/
+include/Common/Foundation/Exception/Exception.h
+include/Common/Foundation/Exception/ExceptionCodes.h
+include/Common/Foundation/Exception/ExceptionDefs.h
+include/Common/Foundation/Foundation.h
+include/Common/Foundation/FoundationDefs.h
+include/Common/Foundation/System/
+include/Common/Foundation/System/AceStreamHelper.h
+include/Common/Foundation/System/ArgumentPacket.h
+include/Common/Foundation/System/BasicPacket.h
+include/Common/Foundation/System/BinaryStreamArgumentPacket.h
+include/Common/Foundation/System/ByteSourceFileImpl.h
+include/Common/Foundation/System/ByteSourceImpl.h
+include/Common/Foundation/System/ByteSourceMemoryImpl.h
+include/Common/Foundation/System/ByteSourceSocketStreamImpl.h
+include/Common/Foundation/System/ByteSourceStreamImpl.h
+include/Common/Foundation/System/ClassFactory.h
+include/Common/Foundation/System/CollectionPacket.h
+include/Common/Foundation/System/Configuration.h
+include/Common/Foundation/System/ConfigurationHeap.h
+include/Common/Foundation/System/ConfigurationSection.h
+include/Common/Foundation/System/ConfigurationSectionCollection.h
+include/Common/Foundation/System/ControlPacket.h
+include/Common/Foundation/System/Disposable.h
+include/Common/Foundation/System/DisposableCollection.h
+include/Common/Foundation/System/FileUtil.h
+include/Common/Foundation/System/FoundationClassId.h
+include/Common/Foundation/System/FoundationConfigProperties.h
+include/Common/Foundation/System/GuardDisposable.h
+include/Common/Foundation/System/LibraryInit.h
+include/Common/Foundation/System/LinuxMemoryStatus.h
+include/Common/Foundation/System/MemoryStreamHelper.h
+include/Common/Foundation/System/NamedSerializable.h
+include/Common/Foundation/System/Object.h
+include/Common/Foundation/System/OperationPacket.h
+include/Common/Foundation/System/OperationResponsePacket.h
+include/Common/Foundation/System/PacketParser.h
+include/Common/Foundation/System/PacketStructure.h
+include/Common/Foundation/System/Ptr.h
+include/Common/Foundation/System/Resources.h
+include/Common/Foundation/System/Serializable.h
+include/Common/Foundation/System/ServerConnectionBase.h
+include/Common/Foundation/System/SetLocale.h
+include/Common/Foundation/System/Stream.h
+include/Common/Foundation/System/StreamData.h
+include/Common/Foundation/System/StreamHeader.h
+include/Common/Foundation/System/StreamHelper.h
+include/Common/Foundation/System/StreamParser.h
+include/Common/Foundation/System/StreamReader.h
+include/Common/Foundation/System/StreamWriter.h
+include/Common/Foundation/System/Util.h
+include/Common/Foundation/System/XmlDefs.h
+include/Common/Foundation/System/XmlUtil.h
 include/Common/Geometry/
-include/Common/Geometry/MoveToInstruction.h
-include/Common/Geometry/CurvePolygonCollection.h
-include/Common/Geometry/CurveStringCollection.h
-include/Common/Geometry/Region.h
-include/Common/Geometry/Coordinate.h
-include/Common/Geometry/PreparedGeometry.h
-include/Common/Geometry/GeometryExceptionDef.h
-include/Common/Geometry/MultiCurveString.h
-include/Common/Geometry/GeosInclude.h
+include/Common/Geometry/AgfReaderWriter.h
+include/Common/Geometry/AgfStream.h
+include/Common/Geometry/AggregateGeometry.h
 include/Common/Geometry/ArcSegment.h
+include/Common/Geometry/Buffer/
+include/Common/Geometry/Buffer/BorderWalker.h
+include/Common/Geometry/Buffer/DumpFFGF.h
+include/Common/Geometry/Buffer/FloatTransform.h
+include/Common/Geometry/Buffer/GreatCircleBufferUtil.h
+include/Common/Geometry/Buffer/LatLonBorderWalker.h
+include/Common/Geometry/Buffer/MgBuffer.h
+include/Common/Geometry/Buffer/buffer.h
+include/Common/Geometry/Buffer/bufraloc.h
+include/Common/Geometry/Buffer/bufrsort.h
+include/Common/Geometry/Buffer/bufrutil.h
+include/Common/Geometry/Buffer/eventarr.h
+include/Common/Geometry/Buffer/eventint.h
+include/Common/Geometry/Buffer/interlst.h
+include/Common/Geometry/Buffer/interprc.h
+include/Common/Geometry/Buffer/oarray.h
+include/Common/Geometry/Buffer/oextent.h
+include/Common/Geometry/Buffer/ogeomtry.h
+include/Common/Geometry/Buffer/olinep.h
+include/Common/Geometry/Buffer/oobject.h
+include/Common/Geometry/Buffer/opline.h
+include/Common/Geometry/Buffer/opoint.h
+include/Common/Geometry/Buffer/opolygnp.h
+include/Common/Geometry/Buffer/opolygon.h
+include/Common/Geometry/Buffer/oppolygn.h
+include/Common/Geometry/Buffer/oppolyln.h
+include/Common/Geometry/Buffer/opsprimitive.h
+include/Common/Geometry/Buffer/orpplygn.h
+include/Common/Geometry/Buffer/ortree.h
+include/Common/Geometry/Buffer/performanceOptions.h
+include/Common/Geometry/Buffer/planeswp.h
+include/Common/Geometry/Buffer/plgnbufr.h
+include/Common/Geometry/Buffer/plgnsbak.h
+include/Common/Geometry/Buffer/plinbufr.h
+include/Common/Geometry/Buffer/pobjbufr.h
+include/Common/Geometry/Buffer/ppgunion.h
+include/Common/Geometry/Buffer/progcbck.h
+include/Common/Geometry/Buffer/sedgaloc.h
+include/Common/Geometry/Buffer/sweepedg.h
+include/Common/Geometry/Buffer/tuplearr.h
+include/Common/Geometry/Buffer/vertaloc.h
+include/Common/Geometry/Buffer/wedgaloc.h
+include/Common/Geometry/Buffer/wedgearr.h
+include/Common/Geometry/Buffer/wingedge.h
+include/Common/Geometry/Buffer/worklist.h
+include/Common/Geometry/Buffer/xordtree.h
 include/Common/Geometry/CloseInstruction.h
-include/Common/Geometry/MultiPoint.h
+include/Common/Geometry/Coordinate.h
 include/Common/Geometry/CoordinateCollection.h
-include/Common/Geometry/MultiCurvePolygon.h
-include/Common/Geometry/Ring.h
-include/Common/Geometry/AgfReaderWriter.h
-include/Common/Geometry/GeometricDimension.h
-include/Common/Geometry/CurveRing.h
+include/Common/Geometry/CoordinateDimension.h
+include/Common/Geometry/CoordinateIterator.h
 include/Common/Geometry/CoordinateSystem/
-include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformation.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystem.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemCache.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemCatalog.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemCategory.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemCategoryDictionary.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemCodeFormat.h
 include/Common/Geometry/CoordinateSystem/CoordinateSystemCommon.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionParameterType.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFile.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemDatum.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemDatumDictionary.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemDictionary.h
 include/Common/Geometry/CoordinateSystem/CoordinateSystemDictionaryBase.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemGridGeneric.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionInformation.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefDictionary.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemDictionaryUtility.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemEllipsoid.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemEllipsoidDictionary.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemEnum.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemEnumInteger32.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemErrorCode.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemFactory.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemFilter.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemFilterInteger32.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemFormatConverter.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformDefParams.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformationMethod.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticDirection.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticInterpolationTransformDefParams.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformDefParams.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformationMethod.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPath.h
 include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathDictionary.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemType.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFileFormat.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystem.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefType.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemFactory.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemDictionary.h
 include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPathElement.h
 include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticStandaloneTransformDefParams.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemCodeFormat.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemDatumDictionary.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemUnitCode.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticInterpolationTransformDefParams.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformDefParams.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemTransform.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemMeasure.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionFormatType.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemUnitInformation.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemFilter.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticDirection.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemEllipsoidDictionary.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemWktFlavor.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionLogicalType.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemFilterInteger32.h
 include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticStandaloneTransformationMethod.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridLevel.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemErrorCode.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemDictionaryUtility.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemCatalog.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefDictionary.h
 include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefParams.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDefType.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFile.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformGridFileFormat.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformation.h
 include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformationMethod.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemEnum.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemEllipsoid.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemGridGeneric.h
 include/Common/Geometry/CoordinateSystem/CoordinateSystemGridOrientation.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemGrids.h
 include/Common/Geometry/CoordinateSystem/CoordinateSystemMathComparator.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemFormatConverter.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemMeasure.h
 include/Common/Geometry/CoordinateSystem/CoordinateSystemMgrs.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticMultipleRegressionTransformationMethod.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformDefParams.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridLevel.h
 include/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridSquarePosition.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticTransformDef.h
 include/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsLetteringScheme.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemDatum.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionCode.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionFormatType.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionInformation.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionLogicalType.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionParameterType.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemTransform.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemType.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemUnitCode.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemUnitInformation.h
 include/Common/Geometry/CoordinateSystem/CoordinateSystemUnitType.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemEnumInteger32.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemCategory.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemCategoryDictionary.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemCache.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticPath.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemProjectionCode.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemGrids.h
-include/Common/Geometry/CoordinateSystem/CoordinateSystemGeodeticAnalyticalTransformationMethod.h
-include/Common/Geometry/Buffer/
-include/Common/Geometry/Buffer/BorderWalker.h
-include/Common/Geometry/Buffer/DumpFFGF.h
-include/Common/Geometry/Buffer/pobjbufr.h
-include/Common/Geometry/Buffer/FloatTransform.h
-include/Common/Geometry/Buffer/buffer.h
-include/Common/Geometry/Buffer/plinbufr.h
-include/Common/Geometry/Buffer/opline.h
-include/Common/Geometry/Buffer/progcbck.h
-include/Common/Geometry/Buffer/bufrutil.h
-include/Common/Geometry/Buffer/LatLonBorderWalker.h
-include/Common/Geometry/Buffer/vertaloc.h
-include/Common/Geometry/Buffer/oppolygn.h
-include/Common/Geometry/Buffer/wedgearr.h
-include/Common/Geometry/Buffer/opolygnp.h
-include/Common/Geometry/Buffer/ogeomtry.h
-include/Common/Geometry/Buffer/eventint.h
-include/Common/Geometry/Buffer/interlst.h
-include/Common/Geometry/Buffer/oppolyln.h
-include/Common/Geometry/Buffer/bufrsort.h
-include/Common/Geometry/Buffer/performanceOptions.h
-include/Common/Geometry/Buffer/plgnbufr.h
-include/Common/Geometry/Buffer/oobject.h
-include/Common/Geometry/Buffer/opoint.h
-include/Common/Geometry/Buffer/tuplearr.h
-include/Common/Geometry/Buffer/ppgunion.h
-include/Common/Geometry/Buffer/sweepedg.h
-include/Common/Geometry/Buffer/bufraloc.h
-include/Common/Geometry/Buffer/orpplygn.h
-include/Common/Geometry/Buffer/xordtree.h
-include/Common/Geometry/Buffer/ortree.h
-include/Common/Geometry/Buffer/oarray.h
-include/Common/Geometry/Buffer/plgnsbak.h
-include/Common/Geometry/Buffer/opsprimitive.h
-include/Common/Geometry/Buffer/oextent.h
-include/Common/Geometry/Buffer/worklist.h
-include/Common/Geometry/Buffer/interprc.h
-include/Common/Geometry/Buffer/MgBuffer.h
-include/Common/Geometry/Buffer/eventarr.h
-include/Common/Geometry/Buffer/sedgaloc.h
-include/Common/Geometry/Buffer/planeswp.h
-include/Common/Geometry/Buffer/wedgaloc.h
-include/Common/Geometry/Buffer/wingedge.h
-include/Common/Geometry/Buffer/olinep.h
-include/Common/Geometry/Buffer/opolygon.h
-include/Common/Geometry/Buffer/GreatCircleBufferUtil.h
-include/Common/Geometry/AgfStream.h
-include/Common/Geometry/LineString.h
-include/Common/Geometry/MultiGeometry.h
-include/Common/Geometry/Polygon.h
-include/Common/Geometry/WktReaderWriter.h
+include/Common/Geometry/CoordinateSystem/CoordinateSystemWktFlavor.h
+include/Common/Geometry/CoordinateXY.h
+include/Common/Geometry/CoordinateXYM.h
+include/Common/Geometry/CoordinateXYZ.h
+include/Common/Geometry/CoordinateXYZM.h
+include/Common/Geometry/Curve.h
+include/Common/Geometry/CurvePolygon.h
+include/Common/Geometry/CurvePolygonCollection.h
+include/Common/Geometry/CurveRing.h
 include/Common/Geometry/CurveRingCollection.h
+include/Common/Geometry/CurveSegment.h
+include/Common/Geometry/CurveSegmentCollection.h
+include/Common/Geometry/CurveString.h
+include/Common/Geometry/CurveStringCollection.h
+include/Common/Geometry/Envelope.h
+include/Common/Geometry/Exception/
+include/Common/Geometry/GeometricDimension.h
+include/Common/Geometry/GeometricEntity.h
+include/Common/Geometry/GeometricEntityType.h
+include/Common/Geometry/GeometricPathInstruction.h
+include/Common/Geometry/GeometricPathInstructionType.h
+include/Common/Geometry/GeometricPathIterator.h
+include/Common/Geometry/Geometry.h
+include/Common/Geometry/GeometryClassId.h
 include/Common/Geometry/GeometryCollection.h
+include/Common/Geometry/GeometryCommon.h
+include/Common/Geometry/GeometryComponent.h
+include/Common/Geometry/GeometryComponentType.h
 include/Common/Geometry/GeometryConsoleTest/
+include/Common/Geometry/GeometryConsoleTest/inc/
+include/Common/Geometry/GeometryConsoleTest/inc/GctTestParameters.h
+include/Common/Geometry/GeometryConsoleTest/inc/GctTestSupport.h
+include/Common/Geometry/GeometryConsoleTest/inc/GeometryConsoleTest.h
 include/Common/Geometry/GeometryConsoleTest/src/
 include/Common/Geometry/GeometryConsoleTest/stdafx.h
 include/Common/Geometry/GeometryConsoleTest/targetver.h
-include/Common/Geometry/GeometryConsoleTest/inc/
-include/Common/Geometry/GeometryConsoleTest/inc/GeometryConsoleTest.h
-include/Common/Geometry/GeometryConsoleTest/inc/GctTestSupport.h
-include/Common/Geometry/GeometryConsoleTest/inc/GctTestParameters.h
-include/Common/Geometry/GeometricEntity.h
-include/Common/Geometry/PointCollection.h
+include/Common/Geometry/GeometryExceptionDef.h
 include/Common/Geometry/GeometryFactory.h
-include/Common/Geometry/GeometryComponent.h
-include/Common/Geometry/GeometricEntityType.h
-include/Common/Geometry/CurveString.h
-include/Common/Geometry/CoordinateXYM.h
-include/Common/Geometry/CoordinateIterator.h
+include/Common/Geometry/GeometrySimplificationAlgorithmType.h
+include/Common/Geometry/GeometrySimplifier.h
+include/Common/Geometry/GeometryType.h
+include/Common/Geometry/GeometryUtil.h
+include/Common/Geometry/GeosInclude.h
+include/Common/Geometry/GeosUtil.h
+include/Common/Geometry/LineString.h
 include/Common/Geometry/LineStringCollection.h
-include/Common/Geometry/GeometryType.h
+include/Common/Geometry/LineToInstruction.h
+include/Common/Geometry/LinearRing.h
 include/Common/Geometry/LinearRingCollection.h
+include/Common/Geometry/LinearSegment.h
+include/Common/Geometry/Measure.h
+include/Common/Geometry/MoveToInstruction.h
+include/Common/Geometry/MultiCurvePolygon.h
+include/Common/Geometry/MultiCurveString.h
+include/Common/Geometry/MultiGeometry.h
+include/Common/Geometry/MultiLineString.h
+include/Common/Geometry/MultiPoint.h
+include/Common/Geometry/MultiPolygon.h
 include/Common/Geometry/Parse/
 include/Common/Geometry/Parse/Array.h
+include/Common/Geometry/Parse/ArrayHelper.h
 include/Common/Geometry/Parse/LexAwkt.h
+include/Common/Geometry/Parse/ParseAwkt.h
+include/Common/Geometry/Parse/ParseAwktUtil.h
 include/Common/Geometry/Parse/StringUtility.h
-include/Common/Geometry/Parse/ParseAwkt.h
 include/Common/Geometry/Parse/yyAwkt.h
-include/Common/Geometry/Parse/ArrayHelper.h
-include/Common/Geometry/Parse/ParseAwktUtil.h
-include/Common/Geometry/AggregateGeometry.h
 include/Common/Geometry/Point.h
-include/Common/Geometry/CurvePolygon.h
+include/Common/Geometry/PointCollection.h
+include/Common/Geometry/Polygon.h
 include/Common/Geometry/PolygonCollection.h
-include/Common/Geometry/GeometryComponentType.h
-include/Common/Geometry/CurveSegmentCollection.h
-include/Common/Geometry/GeosUtil.h
-include/Common/Geometry/Transform.h
-include/Common/Geometry/GeometryClassId.h
-include/Common/Geometry/Measure.h
-include/Common/Geometry/GeometricPathInstructionType.h
-include/Common/Geometry/CurveSegment.h
-include/Common/Geometry/GeometrySimplifier.h
-include/Common/Geometry/Geometry.h
-include/Common/Geometry/Envelope.h
-include/Common/Geometry/GeometryCommon.h
-include/Common/Geometry/GeometryUtil.h
-include/Common/Geometry/Exception/
-include/Common/Geometry/MultiPolygon.h
-include/Common/Geometry/LinearSegment.h
+include/Common/Geometry/PreparedGeometry.h
 include/Common/Geometry/QuadToInstruction.h
-include/Common/Geometry/CoordinateXYZ.h
-include/Common/Geometry/GeometrySimplificationAlgorithmType.h
-include/Common/Geometry/CoordinateDimension.h
-include/Common/Geometry/Curve.h
-include/Common/Geometry/CoordinateXYZM.h
-include/Common/Geometry/CoordinateXY.h
-include/Common/Geometry/GeometricPathInstruction.h
-include/Common/Geometry/MultiLineString.h
+include/Common/Geometry/Region.h
+include/Common/Geometry/Ring.h
 include/Common/Geometry/Spatial/
-include/Common/Geometry/Spatial/SpatialUtilityCircularArc.h
 include/Common/Geometry/Spatial/MathUtility.h
 include/Common/Geometry/Spatial/SpatialUtilities.h
+include/Common/Geometry/Spatial/SpatialUtilityCircularArc.h
+include/Common/Geometry/Spatial/SpatialUtilityStatus.h
 include/Common/Geometry/Spatial/SpatialUtilityVectorAngle.h
-include/Common/Geometry/Spatial/SpatialUtilityStatus.h
-include/Common/Geometry/LinearRing.h
-include/Common/Geometry/LineToInstruction.h
-include/Common/Geometry/GeometricPathIterator.h
-include/Common/PlatformBase/
-include/Common/PlatformBase/Services/
-include/Common/PlatformBase/Services/FeatureQueryOptions.h
-include/Common/PlatformBase/Services/OrderingOption.h
-include/Common/PlatformBase/Services/FeatureGeometricType.h
-include/Common/PlatformBase/Services/FeatureCommand.h
-include/Common/PlatformBase/Services/ResourceService.h
-include/Common/PlatformBase/Services/FeatureSchemaCollection.h
-include/Common/PlatformBase/Services/FeatureDefs.h
-include/Common/PlatformBase/Services/FeatureServiceCommon.h
-include/Common/PlatformBase/Services/ReaderType.h
-include/Common/PlatformBase/Services/RasterTypes.h
-include/Common/PlatformBase/Services/ClassDefinitionCollection.h
-include/Common/PlatformBase/Services/FeatureSourceParams.h
-include/Common/PlatformBase/Services/Transaction.h
-include/Common/PlatformBase/Services/DeleteFeatures.h
-include/Common/PlatformBase/Services/FeatureSet.h
-include/Common/PlatformBase/Services/GeometryProperty.h
-include/Common/PlatformBase/Services/ObjectPropertyDefinition.h
-include/Common/PlatformBase/Services/FeatureCommandType.h
-include/Common/PlatformBase/Services/ClassDefinition.h
-include/Common/PlatformBase/Services/FeatureProperty.h
-include/Common/PlatformBase/Services/PrintLayoutService/
-include/Common/PlatformBase/Services/PrintLayoutService/PrintLayoutBase.h
-include/Common/PlatformBase/Services/PrintLayoutService/PrintLayoutDefs.h
-include/Common/PlatformBase/Services/PrintLayoutService/PrintLayoutElementFactoryBase.h
-include/Common/PlatformBase/Services/PrintLayoutService/MapViewportBase.h
-include/Common/PlatformBase/Services/PrintLayoutService/PrintLayoutServiceBase.h
-include/Common/PlatformBase/Services/PrintLayoutService/MapView.h
-include/Common/PlatformBase/Services/PrintLayoutService/PropertyMappingCollection.h
-include/Common/PlatformBase/Services/PrintLayoutService/PropertyMapping.h
-include/Common/PlatformBase/Services/PrintLayoutService/PrintLayoutElementCollection.h
-include/Common/PlatformBase/Services/PrintLayoutService/PrintLayoutElementBase.h
-include/Common/PlatformBase/Services/LockFeatures.h
-include/Common/PlatformBase/Services/GeoJsonWriter.h
-include/Common/PlatformBase/Services/ObjectPropertyType.h
-include/Common/PlatformBase/Services/ResourceDefs.h
-include/Common/PlatformBase/Services/BaseService.h
-include/Common/PlatformBase/Services/FeatureCommandCollection.h
-include/Common/PlatformBase/Services/ResourceIdentifier.h
-include/Common/PlatformBase/Services/FeatureSchema.h
-include/Common/PlatformBase/Services/FeatureSpatialOperations.h
-include/Common/PlatformBase/Services/FeatureService.h
-include/Common/PlatformBase/Services/Warnings.h
-include/Common/PlatformBase/Services/BaseServiceDefs.h
-include/Common/PlatformBase/Services/FeatureAggregateOptions.h
-include/Common/PlatformBase/Services/PlatformBaseClassId.h
-include/Common/PlatformBase/Services/Reader.h
-include/Common/PlatformBase/Services/SqlDataReader.h
-include/Common/PlatformBase/Services/RasterProperty.h
-include/Common/PlatformBase/Services/GwsFeatureReader.h
-include/Common/PlatformBase/Services/ParameterDirection.h
-include/Common/PlatformBase/Services/FeatureReader.h
-include/Common/PlatformBase/Services/UpdateFeatures.h
-include/Common/PlatformBase/Services/RasterPropertyDefinition.h
-include/Common/PlatformBase/Services/SpatialContextData.h
-include/Common/PlatformBase/Services/DataPropertyDefinition.h
-include/Common/PlatformBase/Services/Parameter.h
-include/Common/PlatformBase/Services/Raster.h
-include/Common/PlatformBase/Services/GeometricPropertyDefinition.h
-include/Common/PlatformBase/Services/Resource.h
-include/Common/PlatformBase/Services/LongTransactionReader.h
-include/Common/PlatformBase/Services/SpatialContextReader.h
-include/Common/PlatformBase/Services/SpatialContextExtentType.h
-include/Common/PlatformBase/Services/Service.h
-include/Common/PlatformBase/Services/GeometryTypeInfo.h
-include/Common/PlatformBase/Services/ServiceRegistry.h
-include/Common/PlatformBase/Services/DataReader.h
-include/Common/PlatformBase/Services/FileFeatureSourceParams.h
-include/Common/PlatformBase/Services/InsertFeatures.h
-include/Common/PlatformBase/Services/LongTransactionData.h
-include/Common/PlatformBase/Services/UnlockFeatures.h
-include/Common/PlatformBase/Services/ParameterCollection.h
-include/Common/PlatformBase/MapLayer/
-include/Common/PlatformBase/MapLayer/MapCollection.h
-include/Common/PlatformBase/MapLayer/LayerGroupCollection.h
-include/Common/PlatformBase/MapLayer/ReadOnlyLayerCollection.h
-include/Common/PlatformBase/MapLayer/LayerGroup.h
-include/Common/PlatformBase/MapLayer/LayerBase.h
-include/Common/PlatformBase/MapLayer/LayerGroupType.h
-include/Common/PlatformBase/MapLayer/ObjectChange.h
-include/Common/PlatformBase/MapLayer/MapBase.h
-include/Common/PlatformBase/MapLayer/LayerType.h
-include/Common/PlatformBase/MapLayer/Watermark.h
-include/Common/PlatformBase/MapLayer/SelectionBase.h
-include/Common/PlatformBase/MapLayer/ChangeList.h
-include/Common/PlatformBase/MapLayer/LayerCollection.h
-include/Common/PlatformBase/Data/
-include/Common/PlatformBase/Data/DoubleProperty.h
-include/Common/PlatformBase/Data/ClobProperty.h
-include/Common/PlatformBase/Data/Int16Property.h
-include/Common/PlatformBase/Data/DateTimeProperty.h
-include/Common/PlatformBase/Data/Vector3D.h
-include/Common/PlatformBase/Data/Color.h
-include/Common/PlatformBase/Data/Size2D.h
-include/Common/PlatformBase/Data/Margin.h
-include/Common/PlatformBase/Data/Int32Property.h
-include/Common/PlatformBase/Data/IntCollection.h
-include/Common/PlatformBase/Data/PropertyDefinitionCollection.h
-include/Common/PlatformBase/Data/BooleanProperty.h
-include/Common/PlatformBase/Data/SingleProperty.h
-include/Common/PlatformBase/Data/Point3D.h
-include/Common/PlatformBase/Data/ByteProperty.h
-include/Common/PlatformBase/Data/StringPropertyCollection.h
-include/Common/PlatformBase/Data/BlobProperty.h
-include/Common/PlatformBase/Data/Int64Property.h
-include/Common/PlatformBase/Data/SerializableCollection.h
-include/Common/PlatformBase/PlatformBase.h
+include/Common/Geometry/Transform.h
+include/Common/Geometry/WktReaderWriter.h
 include/Common/MapGuideCommon/
 include/Common/MapGuideCommon/Controller/
+include/Common/MapGuideCommon/Controller/Controller.h
+include/Common/MapGuideCommon/Controller/DwfController.h
 include/Common/MapGuideCommon/Controller/HtmlController.h
-include/Common/MapGuideCommon/Controller/DwfController.h
-include/Common/MapGuideCommon/Controller/Controller.h
+include/Common/MapGuideCommon/MapGuideCommon.h
+include/Common/MapGuideCommon/MapLayer/
+include/Common/MapGuideCommon/MapLayer/Layer.h
+include/Common/MapGuideCommon/MapLayer/Map.h
+include/Common/MapGuideCommon/MapLayer/Selection.h
+include/Common/MapGuideCommon/Net/
+include/Common/MapGuideCommon/Net/IOperationHandler.h
+include/Common/MapGuideCommon/Resources/
 include/Common/MapGuideCommon/Services/
-include/Common/MapGuideCommon/Services/ProxyFeatureTransaction.h
-include/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.h
-include/Common/MapGuideCommon/Services/ProxyDrawingService.h
-include/Common/MapGuideCommon/Services/SiteConnection.h
-include/Common/MapGuideCommon/Services/ProxyKmlService.h
-include/Common/MapGuideCommon/Services/ServerConnection.h
 include/Common/MapGuideCommon/Services/Command.h
 include/Common/MapGuideCommon/Services/ConnectionProperties.h
-include/Common/MapGuideCommon/Services/TileDefs.h
-include/Common/MapGuideCommon/Services/ProfilingDefs.h
+include/Common/MapGuideCommon/Services/CustomLogoInfo.h
+include/Common/MapGuideCommon/Services/CustomTextInfo.h
+include/Common/MapGuideCommon/Services/DrawingDefs.h
+include/Common/MapGuideCommon/Services/DrawingService.h
+include/Common/MapGuideCommon/Services/DwfVersion.h
+include/Common/MapGuideCommon/Services/FeatureInformation.h
+include/Common/MapGuideCommon/Services/ImageFormats.h
 include/Common/MapGuideCommon/Services/KmlDefs.h
+include/Common/MapGuideCommon/Services/KmlService.h
+include/Common/MapGuideCommon/Services/Layout.h
+include/Common/MapGuideCommon/Services/MapPlot.h
+include/Common/MapGuideCommon/Services/MapPlotCollection.h
+include/Common/MapGuideCommon/Services/MapPlotInstruction.h
 include/Common/MapGuideCommon/Services/MappingDefs.h
-include/Common/MapGuideCommon/Services/ImageFormats.h
-include/Common/MapGuideCommon/Services/ProxyProfilingService.h
-include/Common/MapGuideCommon/Services/MapPlotInstruction.h
-include/Common/MapGuideCommon/Services/ServerConnectionPool.h
-include/Common/MapGuideCommon/Services/ServerConnectionImp.h
-include/Common/MapGuideCommon/Services/Layout.h
-include/Common/MapGuideCommon/Services/ProxySqlDataReader.h
-include/Common/MapGuideCommon/Services/TileService.h
-include/Common/MapGuideCommon/Services/RenderingDefs.h
+include/Common/MapGuideCommon/Services/MappingService.h
+include/Common/MapGuideCommon/Services/Metatile.h
 include/Common/MapGuideCommon/Services/PackageStatusInformation.h
-include/Common/MapGuideCommon/Services/MapPlotCollection.h
-include/Common/MapGuideCommon/Services/ServerAdmin.h
+include/Common/MapGuideCommon/Services/PlotSpecification.h
+include/Common/MapGuideCommon/Services/PrintLayout.h
+include/Common/MapGuideCommon/Services/ProfilingDefs.h
+include/Common/MapGuideCommon/Services/ProfilingService.h
+include/Common/MapGuideCommon/Services/ProxyDataReader.h
+include/Common/MapGuideCommon/Services/ProxyDrawingService.h
 include/Common/MapGuideCommon/Services/ProxyFeatureReader.h
-include/Common/MapGuideCommon/Services/CustomLogoInfo.h
 include/Common/MapGuideCommon/Services/ProxyFeatureService.h
-include/Common/MapGuideCommon/Services/FeatureInformation.h
-include/Common/MapGuideCommon/Services/SiteInfo.h
-include/Common/MapGuideCommon/Services/PlotSpecification.h
-include/Common/MapGuideCommon/Services/DrawingService.h
+include/Common/MapGuideCommon/Services/ProxyFeatureTransaction.h
+include/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.h
+include/Common/MapGuideCommon/Services/ProxyKmlService.h
+include/Common/MapGuideCommon/Services/ProxyMappingService.h
+include/Common/MapGuideCommon/Services/ProxyProfilingService.h
 include/Common/MapGuideCommon/Services/ProxyRenderingService.h
+include/Common/MapGuideCommon/Services/ProxyResourceService.h
+include/Common/MapGuideCommon/Services/ProxySqlDataReader.h
+include/Common/MapGuideCommon/Services/ProxyTileService.h
+include/Common/MapGuideCommon/Services/RenderingDefs.h
 include/Common/MapGuideCommon/Services/RenderingOptions.h
+include/Common/MapGuideCommon/Services/RenderingService.h
+include/Common/MapGuideCommon/Services/ServerAdmin.h
 include/Common/MapGuideCommon/Services/ServerAdminDefs.h
-include/Common/MapGuideCommon/Services/RenderingService.h
-include/Common/MapGuideCommon/Services/ProxyDataReader.h
-include/Common/MapGuideCommon/Services/ProxyTileService.h
+include/Common/MapGuideCommon/Services/ServerConnection.h
+include/Common/MapGuideCommon/Services/ServerConnectionEventHandler.h
+include/Common/MapGuideCommon/Services/ServerConnectionImp.h
+include/Common/MapGuideCommon/Services/ServerConnectionPool.h
 include/Common/MapGuideCommon/Services/ServerConnectionStack.h
-include/Common/MapGuideCommon/Services/DwfVersion.h
-include/Common/MapGuideCommon/Services/ProxyMappingService.h
-include/Common/MapGuideCommon/Services/ServerConnectionEventHandler.h
 include/Common/MapGuideCommon/Services/ServerInformation.h
-include/Common/MapGuideCommon/Services/KmlService.h
-include/Common/MapGuideCommon/Services/MapPlot.h
-include/Common/MapGuideCommon/Services/CustomTextInfo.h
+include/Common/MapGuideCommon/Services/Site.h
+include/Common/MapGuideCommon/Services/SiteConnection.h
+include/Common/MapGuideCommon/Services/SiteInfo.h
+include/Common/MapGuideCommon/Services/SiteManager.h
 include/Common/MapGuideCommon/Services/SqlResult.h
-include/Common/MapGuideCommon/Services/MappingService.h
-include/Common/MapGuideCommon/Services/Site.h
-include/Common/MapGuideCommon/Services/DrawingDefs.h
-include/Common/MapGuideCommon/Services/PrintLayout.h
+include/Common/MapGuideCommon/Services/TileDefs.h
+include/Common/MapGuideCommon/Services/TileService.h
 include/Common/MapGuideCommon/Services/UnitType.h
-include/Common/MapGuideCommon/Services/Metatile.h
-include/Common/MapGuideCommon/Services/ProfilingService.h
-include/Common/MapGuideCommon/Services/ProxyResourceService.h
-include/Common/MapGuideCommon/Services/SiteManager.h
-include/Common/MapGuideCommon/Net/
-include/Common/MapGuideCommon/Net/IOperationHandler.h
-include/Common/MapGuideCommon/Util/
-include/Common/MapGuideCommon/Util/TimerUtil.h
-include/Common/MapGuideCommon/Util/IpUtil.h
-include/Common/MapGuideCommon/MapLayer/
-include/Common/MapGuideCommon/MapLayer/Selection.h
-include/Common/MapGuideCommon/MapLayer/Layer.h
-include/Common/MapGuideCommon/MapLayer/Map.h
-include/Common/MapGuideCommon/MapGuideCommon.h
 include/Common/MapGuideCommon/System/
+include/Common/MapGuideCommon/System/ConfigProperties.h
+include/Common/MapGuideCommon/System/CryptographyManager.h
+include/Common/MapGuideCommon/System/MapGuideCommonClassId.h
 include/Common/MapGuideCommon/System/MapGuideStream.h
-include/Common/MapGuideCommon/System/CryptographyManager.h
 include/Common/MapGuideCommon/System/UserInformation.h
-include/Common/MapGuideCommon/System/ConfigProperties.h
-include/Common/MapGuideCommon/System/MapGuideCommonClassId.h
-include/Common/MapGuideCommon/Resources/
-include/Common/Foundation/
-include/Common/Foundation/Foundation.h
-include/Common/Foundation/Data/
-include/Common/Foundation/Data/PropertyType.h
-include/Common/Foundation/Data/FeaturePropertyType.h
-include/Common/Foundation/Data/Byte.h
-include/Common/Foundation/Data/MimeType.h
-include/Common/Foundation/Data/NullableProperty.h
-include/Common/Foundation/Data/PropertyCollection.h
-include/Common/Foundation/Data/NamedCollection.h
-include/Common/Foundation/Data/StringProperty.h
-include/Common/Foundation/Data/ByteReader.h
-include/Common/Foundation/Data/PropertyDefinition.h
-include/Common/Foundation/Data/DateTime.h
-include/Common/Foundation/Data/StringCollection.h
-include/Common/Foundation/Data/ByteSink.h
-include/Common/Foundation/Data/Property.h
-include/Common/Foundation/Data/ByteSource.h
-include/Common/Foundation/Data/BatchPropertyCollection.h
-include/Common/Foundation/Data/Collection.h
-include/Common/Foundation/Exception/
-include/Common/Foundation/Exception/ExceptionDefs.h
-include/Common/Foundation/Exception/Exception.h
-include/Common/Foundation/Exception/ExceptionCodes.h
-include/Common/Foundation/System/
-include/Common/Foundation/System/MemoryStreamHelper.h
-include/Common/Foundation/System/XmlDefs.h
-include/Common/Foundation/System/ConfigurationSection.h
-include/Common/Foundation/System/Object.h
-include/Common/Foundation/System/GuardDisposable.h
-include/Common/Foundation/System/AceStreamHelper.h
-include/Common/Foundation/System/StreamHelper.h
-include/Common/Foundation/System/FoundationClassId.h
-include/Common/Foundation/System/FoundationConfigProperties.h
-include/Common/Foundation/System/CollectionPacket.h
-include/Common/Foundation/System/DisposableCollection.h
-include/Common/Foundation/System/StreamHeader.h
-include/Common/Foundation/System/StreamWriter.h
-include/Common/Foundation/System/PacketParser.h
-include/Common/Foundation/System/ServerConnectionBase.h
-include/Common/Foundation/System/ByteSourceStreamImpl.h
-include/Common/Foundation/System/StreamParser.h
-include/Common/Foundation/System/BinaryStreamArgumentPacket.h
-include/Common/Foundation/System/BasicPacket.h
-include/Common/Foundation/System/Configuration.h
-include/Common/Foundation/System/ConfigurationHeap.h
-include/Common/Foundation/System/OperationResponsePacket.h
-include/Common/Foundation/System/Util.h
-include/Common/Foundation/System/ByteSourceSocketStreamImpl.h
-include/Common/Foundation/System/ControlPacket.h
-include/Common/Foundation/System/ByteSourceMemoryImpl.h
-include/Common/Foundation/System/Serializable.h
-include/Common/Foundation/System/ByteSourceFileImpl.h
-include/Common/Foundation/System/XmlUtil.h
-include/Common/Foundation/System/SetLocale.h
-include/Common/Foundation/System/ArgumentPacket.h
-include/Common/Foundation/System/NamedSerializable.h
-include/Common/Foundation/System/Disposable.h
-include/Common/Foundation/System/PacketStructure.h
-include/Common/Foundation/System/OperationPacket.h
-include/Common/Foundation/System/LinuxMemoryStatus.h
-include/Common/Foundation/System/Resources.h
-include/Common/Foundation/System/StreamData.h
-include/Common/Foundation/System/ConfigurationSectionCollection.h
-include/Common/Foundation/System/StreamReader.h
-include/Common/Foundation/System/LibraryInit.h
-include/Common/Foundation/System/FileUtil.h
-include/Common/Foundation/System/ClassFactory.h
-include/Common/Foundation/System/Stream.h
-include/Common/Foundation/System/Ptr.h
-include/Common/Foundation/System/ByteSourceImpl.h
-include/Common/Foundation/FoundationDefs.h
+include/Common/MapGuideCommon/Util/
+include/Common/MapGuideCommon/Util/IpUtil.h
+include/Common/MapGuideCommon/Util/TimerUtil.h
+include/Common/PlatformBase/
+include/Common/PlatformBase/Data/
+include/Common/PlatformBase/Data/BlobProperty.h
+include/Common/PlatformBase/Data/BooleanProperty.h
+include/Common/PlatformBase/Data/ByteProperty.h
+include/Common/PlatformBase/Data/ClobProperty.h
+include/Common/PlatformBase/Data/Color.h
+include/Common/PlatformBase/Data/DateTimeProperty.h
+include/Common/PlatformBase/Data/DoubleProperty.h
+include/Common/PlatformBase/Data/Int16Property.h
+include/Common/PlatformBase/Data/Int32Property.h
+include/Common/PlatformBase/Data/Int64Property.h
+include/Common/PlatformBase/Data/IntCollection.h
+include/Common/PlatformBase/Data/Margin.h
+include/Common/PlatformBase/Data/Point3D.h
+include/Common/PlatformBase/Data/PropertyDefinitionCollection.h
+include/Common/PlatformBase/Data/SerializableCollection.h
+include/Common/PlatformBase/Data/SingleProperty.h
+include/Common/PlatformBase/Data/Size2D.h
+include/Common/PlatformBase/Data/StringPropertyCollection.h
+include/Common/PlatformBase/Data/Vector3D.h
+include/Common/PlatformBase/MapLayer/
+include/Common/PlatformBase/MapLayer/ChangeList.h
+include/Common/PlatformBase/MapLayer/LayerBase.h
+include/Common/PlatformBase/MapLayer/LayerCollection.h
+include/Common/PlatformBase/MapLayer/LayerGroup.h
+include/Common/PlatformBase/MapLayer/LayerGroupCollection.h
+include/Common/PlatformBase/MapLayer/LayerGroupType.h
+include/Common/PlatformBase/MapLayer/LayerType.h
+include/Common/PlatformBase/MapLayer/MapBase.h
+include/Common/PlatformBase/MapLayer/MapCollection.h
+include/Common/PlatformBase/MapLayer/ObjectChange.h
+include/Common/PlatformBase/MapLayer/ReadOnlyLayerCollection.h
+include/Common/PlatformBase/MapLayer/SelectionBase.h
+include/Common/PlatformBase/MapLayer/Watermark.h
+include/Common/PlatformBase/PlatformBase.h
+include/Common/PlatformBase/Services/
+include/Common/PlatformBase/Services/BaseService.h
+include/Common/PlatformBase/Services/BaseServiceDefs.h
+include/Common/PlatformBase/Services/ClassDefinition.h
+include/Common/PlatformBase/Services/ClassDefinitionCollection.h
+include/Common/PlatformBase/Services/DataPropertyDefinition.h
+include/Common/PlatformBase/Services/DataReader.h
+include/Common/PlatformBase/Services/DeleteFeatures.h
+include/Common/PlatformBase/Services/FeatureAggregateOptions.h
+include/Common/PlatformBase/Services/FeatureCommand.h
+include/Common/PlatformBase/Services/FeatureCommandCollection.h
+include/Common/PlatformBase/Services/FeatureCommandType.h
+include/Common/PlatformBase/Services/FeatureDefs.h
+include/Common/PlatformBase/Services/FeatureGeometricType.h
+include/Common/PlatformBase/Services/FeatureProperty.h
+include/Common/PlatformBase/Services/FeatureQueryOptions.h
+include/Common/PlatformBase/Services/FeatureReader.h
+include/Common/PlatformBase/Services/FeatureSchema.h
+include/Common/PlatformBase/Services/FeatureSchemaCollection.h
+include/Common/PlatformBase/Services/FeatureService.h
+include/Common/PlatformBase/Services/FeatureServiceCommon.h
+include/Common/PlatformBase/Services/FeatureSet.h
+include/Common/PlatformBase/Services/FeatureSourceParams.h
+include/Common/PlatformBase/Services/FeatureSpatialOperations.h
+include/Common/PlatformBase/Services/FileFeatureSourceParams.h
+include/Common/PlatformBase/Services/GeoJsonWriter.h
+include/Common/PlatformBase/Services/GeometricPropertyDefinition.h
+include/Common/PlatformBase/Services/GeometryProperty.h
+include/Common/PlatformBase/Services/GeometryTypeInfo.h
+include/Common/PlatformBase/Services/GwsFeatureReader.h
+include/Common/PlatformBase/Services/InsertFeatures.h
+include/Common/PlatformBase/Services/LockFeatures.h
+include/Common/PlatformBase/Services/LongTransactionData.h
+include/Common/PlatformBase/Services/LongTransactionReader.h
+include/Common/PlatformBase/Services/ObjectPropertyDefinition.h
+include/Common/PlatformBase/Services/ObjectPropertyType.h
+include/Common/PlatformBase/Services/OrderingOption.h
+include/Common/PlatformBase/Services/Parameter.h
+include/Common/PlatformBase/Services/ParameterCollection.h
+include/Common/PlatformBase/Services/ParameterDirection.h
+include/Common/PlatformBase/Services/PlatformBaseClassId.h
+include/Common/PlatformBase/Services/PrintLayoutService/
+include/Common/PlatformBase/Services/PrintLayoutService/MapView.h
+include/Common/PlatformBase/Services/PrintLayoutService/MapViewportBase.h
+include/Common/PlatformBase/Services/PrintLayoutService/PrintLayoutBase.h
+include/Common/PlatformBase/Services/PrintLayoutService/PrintLayoutDefs.h
+include/Common/PlatformBase/Services/PrintLayoutService/PrintLayoutElementBase.h
+include/Common/PlatformBase/Services/PrintLayoutService/PrintLayoutElementCollection.h
+include/Common/PlatformBase/Services/PrintLayoutService/PrintLayoutElementFactoryBase.h
+include/Common/PlatformBase/Services/PrintLayoutService/PrintLayoutServiceBase.h
+include/Common/PlatformBase/Services/PrintLayoutService/PropertyMapping.h
+include/Common/PlatformBase/Services/PrintLayoutService/PropertyMappingCollection.h
+include/Common/PlatformBase/Services/Raster.h
+include/Common/PlatformBase/Services/RasterProperty.h
+include/Common/PlatformBase/Services/RasterPropertyDefinition.h
+include/Common/PlatformBase/Services/RasterTypes.h
+include/Common/PlatformBase/Services/Reader.h
+include/Common/PlatformBase/Services/ReaderType.h
+include/Common/PlatformBase/Services/Resource.h
+include/Common/PlatformBase/Services/ResourceDefs.h
+include/Common/PlatformBase/Services/ResourceIdentifier.h
+include/Common/PlatformBase/Services/ResourceService.h
+include/Common/PlatformBase/Services/Service.h
+include/Common/PlatformBase/Services/ServiceRegistry.h
+include/Common/PlatformBase/Services/SpatialContextData.h
+include/Common/PlatformBase/Services/SpatialContextExtentType.h
+include/Common/PlatformBase/Services/SpatialContextReader.h
+include/Common/PlatformBase/Services/SqlDataReader.h
+include/Common/PlatformBase/Services/Transaction.h
+include/Common/PlatformBase/Services/UnlockFeatures.h
+include/Common/PlatformBase/Services/UpdateFeatures.h
+include/Common/PlatformBase/Services/Warnings.h
+include/Web/
+include/Web/HttpHandler/
+include/Web/HttpHandler/Dictionary.h
+include/Web/HttpHandler/HttpAnonymousCheck.h
+include/Web/HttpHandler/HttpApplyResourcePackage.h
+include/Web/HttpHandler/HttpChangeResourceOwner.h
+include/Web/HttpHandler/HttpClearTileCache.h
+include/Web/HttpHandler/HttpCopyResource.h
+include/Web/HttpHandler/HttpCreateRepository.h
+include/Web/HttpHandler/HttpCreateRuntimeMap.h
+include/Web/HttpHandler/HttpCreateSession.h
+include/Web/HttpHandler/HttpCsConvertCoordinateSystemCodeToWkt.h
+include/Web/HttpHandler/HttpCsConvertEpsgCodeToWkt.h
+include/Web/HttpHandler/HttpCsConvertWktToCoordinateSystemCode.h
+include/Web/HttpHandler/HttpCsConvertWktToEpsgCode.h
+include/Web/HttpHandler/HttpCsEnumerateCategories.h
+include/Web/HttpHandler/HttpCsEnumerateCoordinateSystems.h
+include/Web/HttpHandler/HttpCsGetBaseLibrary.h
+include/Web/HttpHandler/HttpCsIsValid.h
+include/Web/HttpHandler/HttpCsTransformCoordinates.h
+include/Web/HttpHandler/HttpDeleteRepository.h
+include/Web/HttpHandler/HttpDeleteResource.h
+include/Web/HttpHandler/HttpDeleteResourceData.h
+include/Web/HttpHandler/HttpDescribeDrawing.h
+include/Web/HttpHandler/HttpDescribeRuntimeMap.h
+include/Web/HttpHandler/HttpDescribeSchema.h
+include/Web/HttpHandler/HttpEnumerateApplicationContainers.h
+include/Web/HttpHandler/HttpEnumerateApplicationTemplates.h
+include/Web/HttpHandler/HttpEnumerateApplicationWidgets.h
+include/Web/HttpHandler/HttpEnumerateDataStores.h
+include/Web/HttpHandler/HttpEnumerateDrawingLayers.h
+include/Web/HttpHandler/HttpEnumerateDrawingSectionResources.h
+include/Web/HttpHandler/HttpEnumerateDrawingSections.h
+include/Web/HttpHandler/HttpEnumerateGroups.h
+include/Web/HttpHandler/HttpEnumerateRepositories.h
+include/Web/HttpHandler/HttpEnumerateResourceData.h
+include/Web/HttpHandler/HttpEnumerateResourceReferences.h
+include/Web/HttpHandler/HttpEnumerateResources.h
+include/Web/HttpHandler/HttpEnumerateUnmanagedData.h
+include/Web/HttpHandler/HttpEnumerateUsers.h
+include/Web/HttpHandler/HttpGeoBinaryOperation.h
+include/Web/HttpHandler/HttpGeoBoundary.h
+include/Web/HttpHandler/HttpGeoBuffer.h
+include/Web/HttpHandler/HttpGeoConvexHull.h
+include/Web/HttpHandler/HttpGeoDistance.h
+include/Web/HttpHandler/HttpGeoSimplify.h
+include/Web/HttpHandler/HttpGeoSpatialPredicate.h
+include/Web/HttpHandler/HttpGeoTessellate.h
+include/Web/HttpHandler/HttpGeometryInfo.h
+include/Web/HttpHandler/HttpGetCapabilities.h
+include/Web/HttpHandler/HttpGetClassDefinition.h
+include/Web/HttpHandler/HttpGetClasses.h
+include/Web/HttpHandler/HttpGetConnectionPropertyValues.h
+include/Web/HttpHandler/HttpGetDefaultTileSizeX.h
+include/Web/HttpHandler/HttpGetDefaultTileSizeY.h
+include/Web/HttpHandler/HttpGetDrawing.h
+include/Web/HttpHandler/HttpGetDrawingCoordinateSpace.h
+include/Web/HttpHandler/HttpGetDrawingLayer.h
+include/Web/HttpHandler/HttpGetDrawingSection.h
+include/Web/HttpHandler/HttpGetDrawingSectionResource.h
+include/Web/HttpHandler/HttpGetDwfViewerPage.h
+include/Web/HttpHandler/HttpGetDynamicMapOverlayImage.h
+include/Web/HttpHandler/HttpGetFdoCacheInfo.h
+include/Web/HttpHandler/HttpGetFeatureProviders.h
+include/Web/HttpHandler/HttpGetFeatureSetEnvelope.h
+include/Web/HttpHandler/HttpGetHtmlViewerPage.h
+include/Web/HttpHandler/HttpGetIdentityProperties.h
+include/Web/HttpHandler/HttpGetLegendImage.h
+include/Web/HttpHandler/HttpGetLongTransactions.h
+include/Web/HttpHandler/HttpGetMapImage.h
+include/Web/HttpHandler/HttpGetMapLegendImage.h
+include/Web/HttpHandler/HttpGetPlot.h
+include/Web/HttpHandler/HttpGetRepositoryContent.h
+include/Web/HttpHandler/HttpGetRepositoryHeader.h
+include/Web/HttpHandler/HttpGetResourceContent.h
+include/Web/HttpHandler/HttpGetResourceData.h
+include/Web/HttpHandler/HttpGetResourceHeader.h
+include/Web/HttpHandler/HttpGetSchemaMapping.h
+include/Web/HttpHandler/HttpGetSchemas.h
+include/Web/HttpHandler/HttpGetSessionTimeout.h
+include/Web/HttpHandler/HttpGetSiteInfo.h
+include/Web/HttpHandler/HttpGetSiteStatus.h
+include/Web/HttpHandler/HttpGetSiteVersion.h
+include/Web/HttpHandler/HttpGetSpatialContexts.h
+include/Web/HttpHandler/HttpGetTileImage.h
+include/Web/HttpHandler/HttpGetTileProviders.h
+include/Web/HttpHandler/HttpGetVisibleMapExtent.h
+include/Web/HttpHandler/HttpHandler.h
+include/Web/HttpHandler/HttpHandlerApiDllExport.h
+include/Web/HttpHandler/HttpHandlerClassId.h
+include/Web/HttpHandler/HttpHeader.h
+include/Web/HttpHandler/HttpInheritPermissionsFrom.h
+include/Web/HttpHandler/HttpKmlGetFeatures.h
+include/Web/HttpHandler/HttpKmlGetLayer.h
+include/Web/HttpHandler/HttpKmlGetMap.h
+include/Web/HttpHandler/HttpMoveResource.h
+include/Web/HttpHandler/HttpPrimitiveValue.h
+include/Web/HttpHandler/HttpPrimitiveValueTypes.h
+include/Web/HttpHandler/HttpQueryMapFeatures.h
+include/Web/HttpHandler/HttpReaderStreamer.h
+include/Web/HttpHandler/HttpRenameResourceData.h
+include/Web/HttpHandler/HttpRequest.h
+include/Web/HttpHandler/HttpRequestMetadata.h
+include/Web/HttpHandler/HttpRequestParam.h
+include/Web/HttpHandler/HttpRequestParameters.h
+include/Web/HttpHandler/HttpRequestResponseHandler.h
+include/Web/HttpHandler/HttpResourceExists.h
+include/Web/HttpHandler/HttpResourceStrings.h
+include/Web/HttpHandler/HttpResponse.h
+include/Web/HttpHandler/HttpResult.h
+include/Web/HttpHandler/HttpSelectFeatures.h
+include/Web/HttpHandler/HttpSelectFeaturesSpatially.h
+include/Web/HttpHandler/HttpSetResource.h
+include/Web/HttpHandler/HttpSetResourceData.h
+include/Web/HttpHandler/HttpStatusCodes.h
+include/Web/HttpHandler/HttpTestConnection.h
+include/Web/HttpHandler/HttpUpdateRepository.h
+include/Web/HttpHandler/HttpUtil.h
+include/Web/HttpHandler/HttpWfsDescribeFeatureType.h
+include/Web/HttpHandler/HttpWfsGetCapabilities.h
+include/Web/HttpHandler/HttpWfsGetFeature.h
+include/Web/HttpHandler/HttpWmsGetCapabilities.h
+include/Web/HttpHandler/HttpWmsGetFeatureInfo.h
+include/Web/HttpHandler/HttpWmsGetMap.h
+include/Web/HttpHandler/JsonDoc.h
+include/Web/HttpHandler/NameStringValueCollection.h
+include/Web/HttpHandler/NameValueCollection.h
+include/Web/HttpHandler/OgcDataAccessor.h
+include/Web/HttpHandler/OgcException.h
+include/Web/HttpHandler/OgcFramework.h
+include/Web/HttpHandler/OgcServer.h
+include/Web/HttpHandler/OgcWfsException.h
+include/Web/HttpHandler/OgcWfsServer.h
+include/Web/HttpHandler/OgcWmsException.h
+include/Web/HttpHandler/OgcWmsServer.h
+include/Web/HttpHandler/ReaderByteSourceImpl.h
+include/Web/HttpHandler/ResponseStream.h
+include/Web/HttpHandler/Stream.h
+include/Web/HttpHandler/StringStream.h
+include/Web/HttpHandler/WfsFeatureDefinitions.h
+include/Web/HttpHandler/WfsGetFeatureParams.h
+include/Web/HttpHandler/WmsFeatureGeometry.h
+include/Web/HttpHandler/WmsFeatureInfo.h
+include/Web/HttpHandler/WmsFeatureProperties.h
+include/Web/HttpHandler/WmsLayerDefinitions.h
+include/Web/HttpHandler/WmsMapUtil.h
+include/Web/HttpHandler/XmlElementEmitter.h
+include/Web/HttpHandler/XmlJsonConvert.h
+include/Web/HttpHandler/XmlParser.h
+include/Web/WebApp/
+include/Web/WebApp/WebActions.h
+include/Web/WebApp/WebApp.h
+include/Web/WebApp/WebAppClassId.h
+include/Web/WebApp/WebAppExport.h
+include/Web/WebApp/WebBufferCommand.h
+include/Web/WebApp/WebCommand.h
+include/Web/WebApp/WebCommandCollection.h
+include/Web/WebApp/WebCommandWidget.h
+include/Web/WebApp/WebContextMenu.h
+include/Web/WebApp/WebFlyoutWidget.h
+include/Web/WebApp/WebGetPrintablePageCommand.h
+include/Web/WebApp/WebHelpCommand.h
+include/Web/WebApp/WebInformationPane.h
+include/Web/WebApp/WebInvokeScriptCommand.h
+include/Web/WebApp/WebInvokeUrlCommand.h
+include/Web/WebApp/WebLayout.h
+include/Web/WebApp/WebMeasureCommand.h
+include/Web/WebApp/WebPrintCommand.h
+include/Web/WebApp/WebSearchCommand.h
+include/Web/WebApp/WebSelectWithinCommand.h
+include/Web/WebApp/WebSeparatorWidget.h
+include/Web/WebApp/WebTargetType.h
+include/Web/WebApp/WebTargetViewerType.h
+include/Web/WebApp/WebTaskBar.h
+include/Web/WebApp/WebTaskBarWidget.h
+include/Web/WebApp/WebTaskButtonType.h
+include/Web/WebApp/WebTaskPane.h
+include/Web/WebApp/WebToolbar.h
+include/Web/WebApp/WebUiPane.h
+include/Web/WebApp/WebUiSizablePane.h
+include/Web/WebApp/WebUiTargetCommand.h
+include/Web/WebApp/WebViewOptionsCommand.h
+include/Web/WebApp/WebWidget.h
+include/Web/WebApp/WebWidgetCollection.h
+include/Web/WebApp/WebWidgetType.h
 lib64/
+lib64/libACE.so
+lib64/libACE.so.6.2.6
+lib64/libFoundationUnmanagedApi.so
+lib64/libGeometryUnmanagedApi.so
 lib64/libMapGuideCommonUnmanagedApi.so
-lib64/libMgWebApp.so
-lib64/libMgPlatformBase.so
+lib64/libMgFoundation-4.0.1.so
+lib64/libMgFoundation.so
+lib64/libMgGeometry-4.0.1.so
 lib64/libMgGeometry.so
-lib64/libMgMdfParser-4.0.0.so
-lib64/libACE.so.6.2.6
-lib64/libMgWebSupport-4.0.0.so
-lib64/libWebUnmanagedApi.so
-lib64/libMgGeometry-4.0.0.so
-lib64/libMgMdfModel-4.0.0.so
-lib64/libGeometryUnmanagedApi.so
-lib64/libMgMapGuideCommon-4.0.0.so
-lib64/libMgFoundation-4.0.0.so
-lib64/libACE.so
-lib64/libMgHttpHandler-4.0.0.so
-lib64/liblib_json.so
-lib64/libMgWebApp-4.0.0.so
-lib64/libxerces-c-3.1.so
-lib64/libFoundationUnmanagedApi.so
-lib64/libMgPlatformBase-4.0.0.so
+lib64/libMgHttpHandler-4.0.1.so
 lib64/libMgHttpHandler.so
-lib64/libMgFoundation.so
+lib64/libMgMapGuideCommon-4.0.1.so
 lib64/libMgMapGuideCommon.so
+lib64/libMgMdfModel-4.0.1.so
+lib64/libMgMdfModel.so
+lib64/libMgMdfParser-4.0.1.so
+lib64/libMgMdfParser.so
+lib64/libMgPlatformBase-4.0.1.so
+lib64/libMgPlatformBase.so
+lib64/libMgWebApp-4.0.1.so
+lib64/libMgWebApp.so
+lib64/libMgWebSupport-4.0.1.so
 lib64/libMgWebSupport.so
-lib64/libMgMdfParser.so
 lib64/libPlatformBaseUnmanagedApi.so
+lib64/libWebUnmanagedApi.so
+lib64/liblib_json.so
+lib64/libxerces-c-3.1.so
 lib64/libxerces-c.so
-lib64/libMgMdfModel.so
 share/
 share/gis/
 share/gis/coordsys/
+share/gis/coordsys/CS_Comp
 share/gis/coordsys/CS_DictDiff
-share/gis/coordsys/CS_Comp
Modified: branches/4.0/MgDev/Bindings/src/ApiDump/filelist.linux.generic.txt
--- branches/4.0/MgDev/Bindings/src/ApiDump/filelist.linux.generic.txt	2026-11-10 07:15:37 UTC (rev 10282)
+++ branches/4.0/MgDev/Bindings/src/ApiDump/filelist.linux.generic.txt	2026-11-11 12:20:53 UTC (rev 10283)
@@ -1,5189 +1,5363 @@
 lib64/
+lib64/libACE.so
+lib64/libMgGwsCommon-4.0.1.so
+lib64/libMgGwsCommon.so
+lib64/libMgGwsQueryEngine-4.0.1.so
 lib64/libMgGwsQueryEngine.so
-lib64/libACE.so
-lib64/libMgGwsQueryEngine-4.0.0.so
-lib64/libMgGwsResource-4.0.0.so
-lib64/libMgStylization.so
+lib64/libMgGwsResource-4.0.1.so
 lib64/libMgGwsResource.so
-lib64/libMgStylization-4.0.0.so
-lib64/libMgRenderers-4.0.0.so
+lib64/libMgRenderers-4.0.1.so
 lib64/libMgRenderers.so
-lib64/libMgGwsCommon.so
-lib64/libMgGwsCommon-4.0.0.so
+lib64/libMgStylization-4.0.1.so
+lib64/libMgStylization.so
 server/
 server/Logs/
+server/Packages/
+server/Repositories/
+server/RepositoryAdmin/
+server/RepositoryAdmin/BackUpOfflineRepositories.sh
+server/RepositoryAdmin/BackUpOnlineRepositories.sh
+server/RepositoryAdmin/COPYRIGHT
+server/RepositoryAdmin/DotMake.CommandLine.dll
+server/RepositoryAdmin/MapGuide.RepositoryAdmin
+server/RepositoryAdmin/MapGuide.RepositoryAdmin.deps.json
+server/RepositoryAdmin/MapGuide.RepositoryAdmin.dll
+server/RepositoryAdmin/MapGuide.RepositoryAdmin.runtimeconfig.json
+server/RepositoryAdmin/README.txt
+server/RepositoryAdmin/RecoverRepositories.sh
+server/RepositoryAdmin/RestoreColdBackupRepositories.sh
+server/RepositoryAdmin/RestoreHotBackupRepositories.sh
+server/RepositoryAdmin/SetupRepositoryIndices.sh
+server/RepositoryAdmin/System.Collections.Concurrent.dll
+server/RepositoryAdmin/System.Collections.Immutable.dll
+server/RepositoryAdmin/System.Collections.NonGeneric.dll
+server/RepositoryAdmin/System.Collections.dll
+server/RepositoryAdmin/System.CommandLine.dll
+server/RepositoryAdmin/System.ComponentModel.Primitives.dll
+server/RepositoryAdmin/System.ComponentModel.TypeConverter.dll
+server/RepositoryAdmin/System.Console.dll
+server/RepositoryAdmin/System.Diagnostics.Process.dll
+server/RepositoryAdmin/System.Diagnostics.StackTrace.dll
+server/RepositoryAdmin/System.IO.Compression.dll
+server/RepositoryAdmin/System.IO.MemoryMappedFiles.dll
+server/RepositoryAdmin/System.IO.Pipes.dll
+server/RepositoryAdmin/System.Linq.dll
+server/RepositoryAdmin/System.Net.Primitives.dll
+server/RepositoryAdmin/System.Net.Sockets.dll
+server/RepositoryAdmin/System.ObjectModel.dll
+server/RepositoryAdmin/System.Private.CoreLib.dll
+server/RepositoryAdmin/System.Private.Uri.dll
+server/RepositoryAdmin/System.Reflection.Metadata.dll
+server/RepositoryAdmin/System.Text.RegularExpressions.dll
+server/RepositoryAdmin/System.dll
+server/RepositoryAdmin/UpgradeRepositories.sh
+server/RepositoryAdmin/createdump
+server/RepositoryAdmin/libSystem.Globalization.Native.so
+server/RepositoryAdmin/libSystem.IO.Compression.Native.so
+server/RepositoryAdmin/libSystem.Native.so
+server/RepositoryAdmin/libSystem.Net.Security.Native.so
+server/RepositoryAdmin/libSystem.Security.Cryptography.Native.OpenSsl.so
+server/RepositoryAdmin/libclrgc.so
+server/RepositoryAdmin/libclrjit.so
+server/RepositoryAdmin/libcoreclr.so
+server/RepositoryAdmin/libcoreclrtraceptprovider.so
+server/RepositoryAdmin/libhostfxr.so
+server/RepositoryAdmin/libhostpolicy.so
+server/RepositoryAdmin/libmscordaccore.so
+server/RepositoryAdmin/libmscordbi.so
+server/Resources/
+server/Resources/mapguide_en.res
 server/Schema/
-server/Schema/ResourceDocumentHeader-1.0.0.xsd
-server/Schema/WatermarkDefinition-2.4.0.xsd
-server/Schema/DrawingSource-1.0.0.xsd
-server/Schema/RepositoryList-1.0.0.xsd
-server/Schema/LayerDefinition-1.2.0.xsd
-server/Schema/Role-1.0.0.xsd
-server/Schema/FdoProviderCapabilities-1.1.0.xsd
-server/Schema/PrintLayout-1.0.0.xsd
-server/Schema/FeatureSet-1.0.0.xsd
-server/Schema/LayerDefinition-2.3.0.xsd
-server/Schema/Server-1.0.0.xsd
-server/Schema/SqlSelect-1.0.0.xsd
-server/Schema/WebLayout-2.4.0.xsd
-server/Schema/RuntimeMap-3.0.0.xsd
-server/Schema/UnitOfMeasure-4.0.0.xsd
-server/Schema/WebLayout-2.6.0.xsd
-server/Schema/SymbolDefinition-1.0.0.xsd
-server/Schema/ResourceFolderHeader-1.0.0.xsd
-server/Schema/SiteInformation-2.2.0.xsd
+server/Schema/ApplicationDefinition-1.0.0.xsd
+server/Schema/ApplicationDefinitionInfo-1.0.0.xsd
 server/Schema/BatchPropertyCollection-1.0.0.xsd
-server/Schema/SelectAggregate-1.0.0.xsd
-server/Schema/LayerDefinition-1.1.0.xsd
-server/Schema/TileProviderList-3.0.0.xsd
-server/Schema/ResourceDataList-1.0.0.xsd
-server/Schema/MapDefinition-2.4.0.xsd
-server/Schema/SiteStatus-2.2.0.xsd
-server/Schema/FdoSpatialContextList-1.0.0.xsd
 server/Schema/ClassDefinition-4.0.0.xsd
-server/Schema/WatermarkDefinition-2.3.0.xsd
-server/Schema/FeatureSource-1.0.0.xsd
 server/Schema/DataStoreList-1.0.0.xsd
+server/Schema/DrawingSectionList-1.0.0.xsd
+server/Schema/DrawingSectionResourceList-1.0.0.xsd
+server/Schema/DrawingSource-1.0.0.xsd
 server/Schema/Envelope-1.0.0.xsd
-server/Schema/MapDefinition-1.0.0.xsd
+server/Schema/FdoLongTransactionList-1.0.0.xsd
 server/Schema/FdoProviderCapabilities-1.0.0.xsd
-server/Schema/TileSetDefinition-3.0.0.xsd
-server/Schema/ProfileResult-2.4.0.xsd
-server/Schema/User-1.0.0.xsd
-server/Schema/UnmanagedDataList-1.0.0.xsd
-server/Schema/SymbolDefinition-2.4.0.xsd
-server/Schema/LoadProcedure-1.0.0.xsd
-server/Schema/SymbolLibrary-1.0.0.xsd
+server/Schema/FdoProviderCapabilities-1.1.0.xsd
+server/Schema/FdoSpatialContextList-1.0.0.xsd
 server/Schema/FeatureProviderRegistry-1.0.0.xsd
-server/Schema/WebLayout-1.1.0.xsd
 server/Schema/FeatureSchemaCollection-4.0.0.xsd
+server/Schema/FeatureSet-1.0.0.xsd
+server/Schema/FeatureSource-1.0.0.xsd
+server/Schema/GeometryInfo-4.0.0.xsd
+server/Schema/Group-1.0.0.xsd
+server/Schema/GroupList-1.0.0.xsd
+server/Schema/LayerDefinition-1.0.0.xsd
+server/Schema/LayerDefinition-1.1.0.xsd
+server/Schema/LayerDefinition-1.2.0.xsd
+server/Schema/LayerDefinition-1.3.0.xsd
+server/Schema/LayerDefinition-2.3.0.xsd
 server/Schema/LayerDefinition-2.4.0.xsd
-server/Schema/SiteVersion-1.0.0.xsd
-server/Schema/WebLayout-1.0.0.xsd
+server/Schema/LayerDefinition-4.0.0.xsd
+server/Schema/LoadProcedure-1.0.0.xsd
+server/Schema/LoadProcedure-1.1.0.xsd
+server/Schema/LoadProcedure-2.2.0.xsd
+server/Schema/MapDefinition-1.0.0.xsd
+server/Schema/MapDefinition-2.3.0.xsd
+server/Schema/MapDefinition-2.4.0.xsd
+server/Schema/MapDefinition-3.0.0.xsd
+server/Schema/PlatformCommon-1.0.0.xsd
+server/Schema/PrintLayout-1.0.0.xsd
+server/Schema/ProfileResult-2.4.0.xsd
 server/Schema/RepositoryContent-1.0.0.xsd
-server/Schema/Group-1.0.0.xsd
-server/Schema/GeometryInfo-4.0.0.xsd
+server/Schema/RepositoryList-1.0.0.xsd
+server/Schema/ResourceDataList-1.0.0.xsd
+server/Schema/ResourceDocumentHeader-1.0.0.xsd
+server/Schema/ResourceFolderHeader-1.0.0.xsd
+server/Schema/ResourceList-1.0.0.xsd
+server/Schema/ResourcePackageManifest-1.0.0.xsd
+server/Schema/ResourceReferenceList-1.0.0.xsd
+server/Schema/ResourceSecurity-1.0.0.xsd
+server/Schema/Role-1.0.0.xsd
+server/Schema/RuntimeMap-2.6.0.xsd
+server/Schema/RuntimeMap-3.0.0.xsd
 server/Schema/RuntimeMap-4.0.0.xsd
+server/Schema/SelectAggregate-1.0.0.xsd
+server/Schema/Server-1.0.0.xsd
 server/Schema/ServerList-1.0.0.xsd
 server/Schema/SiteInformation-1.0.0.xsd
+server/Schema/SiteInformation-2.2.0.xsd
+server/Schema/SiteStatus-2.2.0.xsd
+server/Schema/SiteVersion-1.0.0.xsd
+server/Schema/SiteVersion-2.2.0.xsd
+server/Schema/SqlSelect-1.0.0.xsd
 server/Schema/StringCollection-1.0.0.xsd
-server/Schema/DrawingSectionResourceList-1.0.0.xsd
-server/Schema/ResourcePackageManifest-1.0.0.xsd
-server/Schema/MapDefinition-2.3.0.xsd
-server/Schema/LoadProcedure-1.1.0.xsd
-server/Schema/FdoLongTransactionList-1.0.0.xsd
+server/Schema/SymbolDefinition-1.0.0.xsd
+server/Schema/SymbolDefinition-1.1.0.xsd
+server/Schema/SymbolDefinition-2.4.0.xsd
+server/Schema/SymbolLibrary-1.0.0.xsd
+server/Schema/TileProviderList-3.0.0.xsd
+server/Schema/TileSetDefinition-3.0.0.xsd
+server/Schema/TransformedCoordinateCollection-4.0.0.xsd
 server/Schema/Types-1.0.0.xsd
-server/Schema/DrawingSectionList-1.0.0.xsd
-server/Schema/ApplicationDefinitionInfo-1.0.0.xsd
-server/Schema/ResourceReferenceList-1.0.0.xsd
-server/Schema/LayerDefinition-4.0.0.xsd
+server/Schema/UnitOfMeasure-4.0.0.xsd
+server/Schema/UnmanagedDataList-1.0.0.xsd
+server/Schema/User-1.0.0.xsd
 server/Schema/UserList-1.0.0.xsd
-server/Schema/SymbolDefinition-1.1.0.xsd
-server/Schema/ApplicationDefinition-1.0.0.xsd
-server/Schema/LoadProcedure-2.2.0.xsd
-server/Schema/GroupList-1.0.0.xsd
-server/Schema/LayerDefinition-1.0.0.xsd
-server/Schema/SiteVersion-2.2.0.xsd
-server/Schema/ResourceList-1.0.0.xsd
-server/Schema/RuntimeMap-2.6.0.xsd
-server/Schema/MapDefinition-3.0.0.xsd
-server/Schema/TransformedCoordinateCollection-4.0.0.xsd
-server/Schema/LayerDefinition-1.3.0.xsd
-server/Schema/ResourceSecurity-1.0.0.xsd
-server/Schema/PlatformCommon-1.0.0.xsd
-server/RepositoryAdmin/
-server/RepositoryAdmin/UpgradeRepositories.sh
-server/RepositoryAdmin/MapGuide.RepositoryAdmin
-server/RepositoryAdmin/COPYRIGHT
-server/RepositoryAdmin/README.txt
-server/RepositoryAdmin/BackUpOfflineRepositories.sh
-server/RepositoryAdmin/BackUpOnlineRepositories.sh
-server/RepositoryAdmin/SetupRepositoryIndices.sh
-server/RepositoryAdmin/RestoreColdBackupRepositories.sh
-server/RepositoryAdmin/RestoreHotBackupRepositories.sh
-server/RepositoryAdmin/RecoverRepositories.sh
-server/Packages/
+server/Schema/WatermarkDefinition-2.3.0.xsd
+server/Schema/WatermarkDefinition-2.4.0.xsd
+server/Schema/WebLayout-1.0.0.xsd
+server/Schema/WebLayout-1.1.0.xsd
+server/Schema/WebLayout-2.4.0.xsd
+server/Schema/WebLayout-2.6.0.xsd
 server/Temp/
+server/Trash/
+server/Wfs/
+server/Wfs/1.0.0.xml.awd
+server/Wfs/1.1.0.xml.awd
+server/Wfs/OgcWfsService.config.awd
 server/Wms/
-server/Wms/REGRESS.xml.awd
-server/Wms/1.3.0.xml.awd
-server/Wms/1.1.1.xml.awd
 server/Wms/1.0.0.xml.awd
 server/Wms/1.1.0.xml.awd
+server/Wms/1.1.1.xml.awd
+server/Wms/1.3.0.xml.awd
 server/Wms/OgcWmsService.config.awd
-server/Wfs/
-server/Wfs/OgcWfsService.config.awd
-server/Wfs/1.0.0.xml.awd
-server/Wfs/1.1.0.xml.awd
+server/Wms/REGRESS.xml.awd
+server/bin/
+server/bin/db_archive
+server/bin/db_checkpoint
+server/bin/db_dump
+server/bin/db_hotbackup
+server/bin/db_load
+server/bin/db_recover
+server/bin/db_upgrade
+server/bin/db_verify
+server/bin/dbxml
+server/bin/dbxml_dump
+server/bin/dbxml_load
+server/bin/mapguidectl
+server/bin/mgserver
+server/bin/mgserver.sh
+server/bin/mgserver_test.sh
+server/bin/mgserverd.sh
+server/bin/serverconfig.ini
 server/lib64/
-server/lib64/libMgServerFeatureService-4.0.0.so
-server/lib64/libdb_cxx.so
-server/lib64/libdbxml-2.5.so
-server/lib64/libMgServerRenderingService-4.0.0.so
-server/lib64/libMgServerResourceService-4.0.0.so
-server/lib64/libdb-4.8.so
-server/lib64/libMgServerMappingService-4.0.0.so
-server/lib64/libMgServerBase-4.0.0.so
+server/lib64/libMgServerAdminService-4.0.1.so
 server/lib64/libMgServerAdminService.so
+server/lib64/libMgServerBase-4.0.1.so
+server/lib64/libMgServerBase.so
+server/lib64/libMgServerCache-4.0.1.so
+server/lib64/libMgServerCache.so
+server/lib64/libMgServerDrawingService-4.0.1.so
+server/lib64/libMgServerDrawingService.so
+server/lib64/libMgServerFeatureService-4.0.1.so
+server/lib64/libMgServerFeatureService.so
+server/lib64/libMgServerKmlService-4.0.1.so
+server/lib64/libMgServerKmlService.so
+server/lib64/libMgServerManager-4.0.1.so
+server/lib64/libMgServerManager.so
+server/lib64/libMgServerMappingService-4.0.1.so
+server/lib64/libMgServerMappingService.so
+server/lib64/libMgServerProfilingService-4.0.1.so
+server/lib64/libMgServerProfilingService.so
+server/lib64/libMgServerRenderingService-4.0.1.so
+server/lib64/libMgServerRenderingService.so
+server/lib64/libMgServerResourceService-4.0.1.so
+server/lib64/libMgServerResourceService.so
+server/lib64/libMgServerSiteService-4.0.1.so
+server/lib64/libMgServerSiteService.so
+server/lib64/libMgServerThread-4.0.1.so
+server/lib64/libMgServerThread.so
+server/lib64/libMgServerTileService-4.0.1.so
 server/lib64/libMgServerTileService.so
-server/lib64/libMgServerSiteService-4.0.0.so
-server/lib64/libMgServerProfilingService-4.0.0.so
-server/lib64/libxqilla.so.5
+server/lib64/libMgUnitTesting.so
+server/lib64/libdb-4.8.so
 server/lib64/libdb-4.so
-server/lib64/libMgServerSiteService.so
-server/lib64/libMgServerManager-4.0.0.so
-server/lib64/libMgServerBase.so
 server/lib64/libdb.so
-server/lib64/libMgServerRenderingService.so
 server/lib64/libdb_cxx-4.8.so
-server/lib64/libMgServerThread-4.0.0.so
-server/lib64/libMgServerDrawingService.so
-server/lib64/libMgServerDrawingService-4.0.0.so
-server/lib64/libMgServerManager.so
-server/lib64/libMgServerFeatureService.so
-server/lib64/libMgUnitTesting.so
-server/lib64/libMgServerThread.so
-server/lib64/libMgServerKmlService-4.0.0.so
-server/lib64/libMgServerKmlService.so
 server/lib64/libdb_cxx-4.so
+server/lib64/libdb_cxx.so
+server/lib64/libdbxml-2.5.so
 server/lib64/libdbxml.so
-server/lib64/libMgServerTileService-4.0.0.so
-server/lib64/libMgServerCache-4.0.0.so
-server/lib64/libMgServerResourceService.so
-server/lib64/libMgServerAdminService-4.0.0.so
+server/lib64/libxqilla.so
+server/lib64/libxqilla.so.5
 server/lib64/libxqilla.so.5.0.4
-server/lib64/libMgServerMappingService.so
-server/lib64/libMgServerProfilingService.so
-server/lib64/libMgServerCache.so
-server/bin/
-server/bin/db_recover
-server/bin/db_checkpoint
-server/bin/dbxml_dump
-server/bin/dbxml
-server/bin/db_load
-server/bin/db_upgrade
-server/bin/db_archive
-server/bin/dbxml_load
-server/bin/db_dump
-server/bin/db_verify
-server/bin/serverconfig.ini
-server/bin/mgserver_test.sh
-server/bin/mapguidectl
-server/bin/mgserverd.sh
-server/bin/mgserver.sh
-server/bin/db_hotbackup
-server/Repositories/
-server/Trash/
-server/Resources/
-server/Resources/mapguide_en.res
 share/
 share/gis/
 share/gis/coordsys/
-share/gis/coordsys/NameMapper.csv
+share/gis/coordsys/Australia/
+share/gis/coordsys/Australia/Agd66/
+share/gis/coordsys/Australia/Agd66/A66National(13.09.01).gsb
+share/gis/coordsys/Australia/Agd84/
+share/gis/coordsys/Australia/Agd84/National84(02.07.01).gsb
+share/gis/coordsys/Australia/Gda94/
+share/gis/coordsys/Brazil/
+share/gis/coordsys/Brazil/CA61_003.GSB
+share/gis/coordsys/Brazil/CA7072_003.GSB
+share/gis/coordsys/CS-MAP.GID
+share/gis/coordsys/CS_DictDiff
+share/gis/coordsys/Canada/
+share/gis/coordsys/Canada/ReadMe.txt
+share/gis/coordsys/Category.CSD
+share/gis/coordsys/Coordsys.CSD
+share/gis/coordsys/Datums.CSD
+share/gis/coordsys/Elipsoid.CSD
+share/gis/coordsys/France/
+share/gis/coordsys/France/gr3df97a.txt
+share/gis/coordsys/GeodeticPath.CSD
+share/gis/coordsys/GeodeticPath.asc
+share/gis/coordsys/GeodeticTransform.CSD
+share/gis/coordsys/GeodeticTransformation.asc
+share/gis/coordsys/GeoidHeight.gdc
 share/gis/coordsys/Germany/
 share/gis/coordsys/Germany/BETA2007.gsb
+share/gis/coordsys/Japan/
+share/gis/coordsys/Japan/ReadMe.txt
+share/gis/coordsys/Japan/TKY2JGD._par
+share/gis/coordsys/Japan/TKY2JGD.par
+share/gis/coordsys/NameMapper.csv
+share/gis/coordsys/NewZealand/
+share/gis/coordsys/NewZealand/nzgd2kgrid0005.gsb
+share/gis/coordsys/OSGM91.TXT
+share/gis/coordsys/OSTN02._02
+share/gis/coordsys/OSTN02.txt
+share/gis/coordsys/OSTN97.TXT
 share/gis/coordsys/OSTN97._nt
-share/gis/coordsys/France/
-share/gis/coordsys/France/gr3df97a.txt
-share/gis/coordsys/Vertcon.gdc
-share/gis/coordsys/license.txt
-share/gis/coordsys/CS_DictDiff
-share/gis/coordsys/Canada/
-share/gis/coordsys/Canada/ReadMe.txt
+share/gis/coordsys/Portugal/
+share/gis/coordsys/Portugal/D73_ETRS89_geo.gsb
+share/gis/coordsys/Portugal/DLX_ETRS89_geo.gsb
+share/gis/coordsys/Portugal/pt73_e89.gsb
+share/gis/coordsys/Portugal/ptED_e89.gsb
+share/gis/coordsys/Portugal/ptLB_e89.gsb
+share/gis/coordsys/Portugal/ptLX_e89.gsb
+share/gis/coordsys/Spain/
+share/gis/coordsys/Spain/copyright_and_disclaimer.txt
+share/gis/coordsys/Spain/sped2et-2005.gsb
+share/gis/coordsys/Switzerland/
+share/gis/coordsys/Switzerland/CHENYX06.gsb
+share/gis/coordsys/UK/
+share/gis/coordsys/UK/HS2TN02_NTv2.gsb
+share/gis/coordsys/UK/HS2TN15_NTv2.gsb
+share/gis/coordsys/UK/OSTN15_NTv2_OSGBtoETRS.gsb
+share/gis/coordsys/UK/OSTN15_OSGM15_GB.txt
+share/gis/coordsys/UK/TN15-ETRS89-to-EWR2-IRF.gsb
+share/gis/coordsys/UK/ostn02.gsb
 share/gis/coordsys/Usa/
-share/gis/coordsys/Usa/Nadcon/
-share/gis/coordsys/Usa/Nadcon/stlrnc.los
-share/gis/coordsys/Usa/Nadcon/hawaii.las
-share/gis/coordsys/Usa/Nadcon/prvi.las
-share/gis/coordsys/Usa/Nadcon/stgeorge.las
-share/gis/coordsys/Usa/Nadcon/conus.los
-share/gis/coordsys/Usa/Nadcon/conus.las
-share/gis/coordsys/Usa/Nadcon/hawaii.los
-share/gis/coordsys/Usa/Nadcon/alaska.los
-share/gis/coordsys/Usa/Nadcon/stpaul.los
-share/gis/coordsys/Usa/Nadcon/stgeorge.los
-share/gis/coordsys/Usa/Nadcon/alaska.las
-share/gis/coordsys/Usa/Nadcon/prvi.los
-share/gis/coordsys/Usa/Nadcon/stpaul.las
-share/gis/coordsys/Usa/Nadcon/stlrnc.las
 share/gis/coordsys/Usa/Harn/
-share/gis/coordsys/Usa/Harn/nchpgn.las
-share/gis/coordsys/Usa/Harn/kshpgn.las
-share/gis/coordsys/Usa/Harn/nmhpgn.las
-share/gis/coordsys/Usa/Harn/uthpgn.los
-share/gis/coordsys/Usa/Harn/nbhpgn.los
-share/gis/coordsys/Usa/Harn/wohpgn.los
-share/gis/coordsys/Usa/Harn/nbhpgn.las
-share/gis/coordsys/Usa/Harn/wihpgn.los
-share/gis/coordsys/Usa/Harn/mohpgn.los
-share/gis/coordsys/Usa/Harn/mshpgn.los
+share/gis/coordsys/Usa/Harn/48hpgn.las
+share/gis/coordsys/Usa/Harn/48hpgn.los
+share/gis/coordsys/Usa/Harn/alhpgn.las
+share/gis/coordsys/Usa/Harn/alhpgn.los
+share/gis/coordsys/Usa/Harn/arhpgn.las
 share/gis/coordsys/Usa/Harn/arhpgn.los
+share/gis/coordsys/Usa/Harn/azhpgn.las
+share/gis/coordsys/Usa/Harn/azhpgn.los
+share/gis/coordsys/Usa/Harn/cahpgn.las
+share/gis/coordsys/Usa/Harn/cahpgn.los
+share/gis/coordsys/Usa/Harn/cnhpgn.las
+share/gis/coordsys/Usa/Harn/cnhpgn.los
+share/gis/coordsys/Usa/Harn/cohpgn.las
+share/gis/coordsys/Usa/Harn/cohpgn.los
+share/gis/coordsys/Usa/Harn/cshpgn.las
 share/gis/coordsys/Usa/Harn/cshpgn.los
-share/gis/coordsys/Usa/Harn/wihpgn.las
-share/gis/coordsys/Usa/Harn/nvhpgn.las
-share/gis/coordsys/Usa/Harn/okhpgn.los
-share/gis/coordsys/Usa/Harn/okhpgn.las
-share/gis/coordsys/Usa/Harn/48hpgn.las
 share/gis/coordsys/Usa/Harn/emhpgn.las
-share/gis/coordsys/Usa/Harn/wshpgn.las
-share/gis/coordsys/Usa/Harn/ohhpgn.los
-share/gis/coordsys/Usa/Harn/sdhpgn.las
-share/gis/coordsys/Usa/Harn/sdhpgn.los
-share/gis/coordsys/Usa/Harn/pahpgn.las
+share/gis/coordsys/Usa/Harn/emhpgn.los
+share/gis/coordsys/Usa/Harn/eshpgn.las
+share/gis/coordsys/Usa/Harn/eshpgn.los
+share/gis/coordsys/Usa/Harn/ethpgn.las
+share/gis/coordsys/Usa/Harn/ethpgn.los
+share/gis/coordsys/Usa/Harn/flhpgn.las
+share/gis/coordsys/Usa/Harn/flhpgn.los
+share/gis/coordsys/Usa/Harn/gahpgn.las
+share/gis/coordsys/Usa/Harn/gahpgn.los
+share/gis/coordsys/Usa/Harn/guhpgn.las
+share/gis/coordsys/Usa/Harn/guhpgn.los
+share/gis/coordsys/Usa/Harn/hihpgn.las
+share/gis/coordsys/Usa/Harn/hihpgn.los
+share/gis/coordsys/Usa/Harn/iahpgn.las
+share/gis/coordsys/Usa/Harn/iahpgn.los
+share/gis/coordsys/Usa/Harn/ilhpgn.las
+share/gis/coordsys/Usa/Harn/ilhpgn.los
+share/gis/coordsys/Usa/Harn/inhpgn.las
+share/gis/coordsys/Usa/Harn/inhpgn.los
+share/gis/coordsys/Usa/Harn/kshpgn.las
+share/gis/coordsys/Usa/Harn/kshpgn.los
 share/gis/coordsys/Usa/Harn/kyhpgn.las
-share/gis/coordsys/Usa/Harn/cshpgn.las
-share/gis/coordsys/Usa/Harn/wohpgn.las
-share/gis/coordsys/Usa/Harn/hihpgn.las
-share/gis/coordsys/Usa/Harn/ethpgn.las
-share/gis/coordsys/Usa/Harn/cahpgn.las
-share/gis/coordsys/Usa/Harn/alhpgn.las
-share/gis/coordsys/Usa/Harn/nehpgn.los
-share/gis/coordsys/Usa/Harn/njhpgn.las
-share/gis/coordsys/Usa/Harn/wyhpgn.las
-share/gis/coordsys/Usa/Harn/alhpgn.los
+share/gis/coordsys/Usa/Harn/kyhpgn.los
+share/gis/coordsys/Usa/Harn/lahpgn.las
+share/gis/coordsys/Usa/Harn/lahpgn.los
+share/gis/coordsys/Usa/Harn/mdhpgn.las
+share/gis/coordsys/Usa/Harn/mdhpgn.los
+share/gis/coordsys/Usa/Harn/mehpgn.las
+share/gis/coordsys/Usa/Harn/mehpgn.los
+share/gis/coordsys/Usa/Harn/mihpgn.las
 share/gis/coordsys/Usa/Harn/mihpgn.los
-share/gis/coordsys/Usa/Harn/iahpgn.los
-share/gis/coordsys/Usa/Harn/eshpgn.los
-share/gis/coordsys/Usa/Harn/wvhpgn.las
-share/gis/coordsys/Usa/Harn/schpgn.las
-share/gis/coordsys/Usa/Harn/hihpgn.los
+share/gis/coordsys/Usa/Harn/mnhpgn.las
+share/gis/coordsys/Usa/Harn/mnhpgn.los
+share/gis/coordsys/Usa/Harn/mohpgn.las
+share/gis/coordsys/Usa/Harn/mohpgn.los
+share/gis/coordsys/Usa/Harn/mshpgn.las
+share/gis/coordsys/Usa/Harn/mshpgn.los
+share/gis/coordsys/Usa/Harn/nbhpgn.las
+share/gis/coordsys/Usa/Harn/nbhpgn.los
+share/gis/coordsys/Usa/Harn/nchpgn.las
+share/gis/coordsys/Usa/Harn/nchpgn.los
 share/gis/coordsys/Usa/Harn/ndhpgn.las
-share/gis/coordsys/Usa/Harn/vahpgn.los
-share/gis/coordsys/Usa/Harn/emhpgn.los
 share/gis/coordsys/Usa/Harn/ndhpgn.los
-share/gis/coordsys/Usa/Harn/mihpgn.las
-share/gis/coordsys/Usa/Harn/kshpgn.los
-share/gis/coordsys/Usa/Harn/azhpgn.los
-share/gis/coordsys/Usa/Harn/ilhpgn.las
-share/gis/coordsys/Usa/Harn/wthpgn.las
-share/gis/coordsys/Usa/Harn/wthpgn.los
+share/gis/coordsys/Usa/Harn/nehpgn.las
+share/gis/coordsys/Usa/Harn/nehpgn.los
+share/gis/coordsys/Usa/Harn/njhpgn.las
+share/gis/coordsys/Usa/Harn/njhpgn.los
+share/gis/coordsys/Usa/Harn/nmhpgn.las
 share/gis/coordsys/Usa/Harn/nmhpgn.los
-share/gis/coordsys/Usa/Harn/lahpgn.los
+share/gis/coordsys/Usa/Harn/nvhpgn.las
 share/gis/coordsys/Usa/Harn/nvhpgn.los
+share/gis/coordsys/Usa/Harn/nyhpgn.las
+share/gis/coordsys/Usa/Harn/nyhpgn.los
+share/gis/coordsys/Usa/Harn/ohhpgn.las
+share/gis/coordsys/Usa/Harn/ohhpgn.los
+share/gis/coordsys/Usa/Harn/okhpgn.las
+share/gis/coordsys/Usa/Harn/okhpgn.los
+share/gis/coordsys/Usa/Harn/pahpgn.las
 share/gis/coordsys/Usa/Harn/pahpgn.los
+share/gis/coordsys/Usa/Harn/pvhpgn.las
+share/gis/coordsys/Usa/Harn/pvhpgn.los
+share/gis/coordsys/Usa/Harn/schpgn.las
 share/gis/coordsys/Usa/Harn/schpgn.los
-share/gis/coordsys/Usa/Harn/guhpgn.las
-share/gis/coordsys/Usa/Harn/mshpgn.las
-share/gis/coordsys/Usa/Harn/mnhpgn.los
-share/gis/coordsys/Usa/Harn/wvhpgn.los
-share/gis/coordsys/Usa/Harn/ilhpgn.los
-share/gis/coordsys/Usa/Harn/wmhpgn.los
-share/gis/coordsys/Usa/Harn/mnhpgn.las
-share/gis/coordsys/Usa/Harn/cahpgn.los
-share/gis/coordsys/Usa/Harn/uthpgn.las
-share/gis/coordsys/Usa/Harn/gahpgn.los
-share/gis/coordsys/Usa/Harn/ohhpgn.las
-share/gis/coordsys/Usa/Harn/guhpgn.los
-share/gis/coordsys/Usa/Harn/mdhpgn.las
+share/gis/coordsys/Usa/Harn/sdhpgn.las
+share/gis/coordsys/Usa/Harn/sdhpgn.los
 share/gis/coordsys/Usa/Harn/tnhpgn.las
-share/gis/coordsys/Usa/Harn/wyhpgn.los
-share/gis/coordsys/Usa/Harn/nehpgn.las
-share/gis/coordsys/Usa/Harn/mdhpgn.los
-share/gis/coordsys/Usa/Harn/wshpgn.los
-share/gis/coordsys/Usa/Harn/mehpgn.los
 share/gis/coordsys/Usa/Harn/tnhpgn.los
-share/gis/coordsys/Usa/Harn/nyhpgn.los
-share/gis/coordsys/Usa/Harn/mehpgn.las
-share/gis/coordsys/Usa/Harn/flhpgn.los
-share/gis/coordsys/Usa/Harn/kyhpgn.los
-share/gis/coordsys/Usa/Harn/cnhpgn.los
-share/gis/coordsys/Usa/Harn/cohpgn.los
+share/gis/coordsys/Usa/Harn/uthpgn.las
+share/gis/coordsys/Usa/Harn/uthpgn.los
 share/gis/coordsys/Usa/Harn/vahpgn.las
-share/gis/coordsys/Usa/Harn/iahpgn.las
-share/gis/coordsys/Usa/Harn/inhpgn.las
-share/gis/coordsys/Usa/Harn/cohpgn.las
-share/gis/coordsys/Usa/Harn/gahpgn.las
-share/gis/coordsys/Usa/Harn/lahpgn.las
-share/gis/coordsys/Usa/Harn/arhpgn.las
-share/gis/coordsys/Usa/Harn/pvhpgn.las
-share/gis/coordsys/Usa/Harn/nyhpgn.las
-share/gis/coordsys/Usa/Harn/48hpgn.los
+share/gis/coordsys/Usa/Harn/vahpgn.los
+share/gis/coordsys/Usa/Harn/wihpgn.las
+share/gis/coordsys/Usa/Harn/wihpgn.los
 share/gis/coordsys/Usa/Harn/wmhpgn.las
-share/gis/coordsys/Usa/Harn/inhpgn.los
-share/gis/coordsys/Usa/Harn/nchpgn.los
-share/gis/coordsys/Usa/Harn/ethpgn.los
-share/gis/coordsys/Usa/Harn/eshpgn.las
-share/gis/coordsys/Usa/Harn/azhpgn.las
-share/gis/coordsys/Usa/Harn/cnhpgn.las
-share/gis/coordsys/Usa/Harn/pvhpgn.los
-share/gis/coordsys/Usa/Harn/flhpgn.las
-share/gis/coordsys/Usa/Harn/mohpgn.las
-share/gis/coordsys/Usa/Harn/njhpgn.los
+share/gis/coordsys/Usa/Harn/wmhpgn.los
+share/gis/coordsys/Usa/Harn/wohpgn.las
+share/gis/coordsys/Usa/Harn/wohpgn.los
+share/gis/coordsys/Usa/Harn/wshpgn.las
+share/gis/coordsys/Usa/Harn/wshpgn.los
+share/gis/coordsys/Usa/Harn/wthpgn.las
+share/gis/coordsys/Usa/Harn/wthpgn.los
+share/gis/coordsys/Usa/Harn/wvhpgn.las
+share/gis/coordsys/Usa/Harn/wvhpgn.los
+share/gis/coordsys/Usa/Harn/wyhpgn.las
+share/gis/coordsys/Usa/Harn/wyhpgn.los
+share/gis/coordsys/Usa/Nadcon/
+share/gis/coordsys/Usa/Nadcon/alaska.las
+share/gis/coordsys/Usa/Nadcon/alaska.los
+share/gis/coordsys/Usa/Nadcon/conus.las
+share/gis/coordsys/Usa/Nadcon/conus.los
+share/gis/coordsys/Usa/Nadcon/hawaii.las
+share/gis/coordsys/Usa/Nadcon/hawaii.los
+share/gis/coordsys/Usa/Nadcon/prvi.las
+share/gis/coordsys/Usa/Nadcon/prvi.los
+share/gis/coordsys/Usa/Nadcon/stgeorge.las
+share/gis/coordsys/Usa/Nadcon/stgeorge.los
+share/gis/coordsys/Usa/Nadcon/stlrnc.las
+share/gis/coordsys/Usa/Nadcon/stlrnc.los
+share/gis/coordsys/Usa/Nadcon/stpaul.las
+share/gis/coordsys/Usa/Nadcon/stpaul.los
 share/gis/coordsys/Usa/Vertcon/
 share/gis/coordsys/Usa/Vertcon/VERTCONC.94
+share/gis/coordsys/Usa/Vertcon/VERTCONE.94
 share/gis/coordsys/Usa/Vertcon/VERTCONW.94
-share/gis/coordsys/Usa/Vertcon/VERTCONE.94
-share/gis/coordsys/Coordsys.CSD
-share/gis/coordsys/GeodeticTransformation.asc
-share/gis/coordsys/coordsys.asc
-share/gis/coordsys/GeodeticPath.asc
-share/gis/coordsys/GeoidHeight.gdc
-share/gis/coordsys/Switzerland/
-share/gis/coordsys/Switzerland/CHENYX06.gsb
-share/gis/coordsys/GeodeticTransform.CSD
-share/gis/coordsys/GeodeticPath.CSD
-share/gis/coordsys/Portugal/
-share/gis/coordsys/Portugal/ptLB_e89.gsb
-share/gis/coordsys/Portugal/ptLX_e89.gsb
-share/gis/coordsys/Portugal/ptED_e89.gsb
-share/gis/coordsys/Portugal/pt73_e89.gsb
-share/gis/coordsys/Portugal/D73_ETRS89_geo.gsb
-share/gis/coordsys/Portugal/DLX_ETRS89_geo.gsb
-share/gis/coordsys/CS-MAP.GID
-share/gis/coordsys/datums.asc
-share/gis/coordsys/version.txt
-share/gis/coordsys/OSTN02._02
-share/gis/coordsys/Japan/
-share/gis/coordsys/Japan/ReadMe.txt
-share/gis/coordsys/Japan/TKY2JGD.par
-share/gis/coordsys/Japan/TKY2JGD._par
-share/gis/coordsys/NewZealand/
-share/gis/coordsys/NewZealand/nzgd2kgrid0005.gsb
 share/gis/coordsys/Venezuela/
+share/gis/coordsys/Venezuela/canoa_wgs84_mb.gsb
 share/gis/coordsys/Venezuela/description.txt
-share/gis/coordsys/Venezuela/canoa_wgs84_mb.gsb
-share/gis/coordsys/UK/
-share/gis/coordsys/UK/TN15-ETRS89-to-EWR2-IRF.gsb
-share/gis/coordsys/UK/HS2TN15_NTv2.gsb
-share/gis/coordsys/UK/ostn02.gsb
-share/gis/coordsys/UK/OSTN15_NTv2_OSGBtoETRS.gsb
-share/gis/coordsys/UK/HS2TN02_NTv2.gsb
-share/gis/coordsys/UK/OSTN15_OSGM15_GB.txt
+share/gis/coordsys/Vertcon.gdc
 share/gis/coordsys/category.asc
-share/gis/coordsys/Datums.CSD
-share/gis/coordsys/OSTN02.txt
+share/gis/coordsys/coordsys.asc
+share/gis/coordsys/datums.asc
 share/gis/coordsys/elipsoid.asc
-share/gis/coordsys/Spain/
-share/gis/coordsys/Spain/copyright_and_disclaimer.txt
-share/gis/coordsys/Spain/sped2et-2005.gsb
-share/gis/coordsys/Brazil/
-share/gis/coordsys/Brazil/CA61_003.GSB
-share/gis/coordsys/Brazil/CA7072_003.GSB
-share/gis/coordsys/Elipsoid.CSD
-share/gis/coordsys/OSTN97.TXT
-share/gis/coordsys/Category.CSD
-share/gis/coordsys/Australia/
-share/gis/coordsys/Australia/Gda94/
-share/gis/coordsys/Australia/Agd66/
-share/gis/coordsys/Australia/Agd66/A66National(13.09.01).gsb
-share/gis/coordsys/Australia/Agd84/
-share/gis/coordsys/Australia/Agd84/National84(02.07.01).gsb
-share/gis/coordsys/OSGM91.TXT
+share/gis/coordsys/license.txt
+share/gis/coordsys/version.txt
 webserverextensions/
-webserverextensions/tomcat/
-webserverextensions/tomcat/temp/
-webserverextensions/tomcat/temp/safeToDelete.tmp
-webserverextensions/tomcat/LICENSE
-webserverextensions/tomcat/work/
-webserverextensions/tomcat/README.md
-webserverextensions/tomcat/conf/
-webserverextensions/tomcat/conf/jaspic-providers.xsd
-webserverextensions/tomcat/conf/Catalina/
-webserverextensions/tomcat/conf/Catalina/localhost/
-webserverextensions/tomcat/conf/Catalina/localhost/mapguide.xml
-webserverextensions/tomcat/conf/tomcat-users.xml
-webserverextensions/tomcat/conf/logging.properties
-webserverextensions/tomcat/conf/server.xml
-webserverextensions/tomcat/conf/web.xml
-webserverextensions/tomcat/conf/tomcat-users.xsd
-webserverextensions/tomcat/conf/catalina.properties
-webserverextensions/tomcat/conf/catalina.policy
-webserverextensions/tomcat/conf/context.xml
-webserverextensions/tomcat/conf/jaspic-providers.xml
-webserverextensions/tomcat/webapps/
-webserverextensions/tomcat/webapps/manager/
-webserverextensions/tomcat/webapps/manager/WEB-INF/
-webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/
-webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/403.jsp
-webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/sessionDetail.jsp
-webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/connectorTrustedCerts.jsp
-webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/401.jsp
-webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/connectorCiphers.jsp
-webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/sessionsList.jsp
-webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/connectorCerts.jsp
-webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/404.jsp
-webserverextensions/tomcat/webapps/manager/WEB-INF/web.xml
-webserverextensions/tomcat/webapps/manager/index.jsp
-webserverextensions/tomcat/webapps/manager/css/
-webserverextensions/tomcat/webapps/manager/css/manager.css
-webserverextensions/tomcat/webapps/manager/status.xsd
-webserverextensions/tomcat/webapps/manager/xform.xsl
-webserverextensions/tomcat/webapps/manager/images/
-webserverextensions/tomcat/webapps/manager/images/tomcat.svg
-webserverextensions/tomcat/webapps/manager/images/favicon.ico
-webserverextensions/tomcat/webapps/manager/images/asf-logo.svg
-webserverextensions/tomcat/webapps/manager/META-INF/
-webserverextensions/tomcat/webapps/manager/META-INF/context.xml
-webserverextensions/tomcat/webapps/examples/
-webserverextensions/tomcat/webapps/examples/websocket/
-webserverextensions/tomcat/webapps/examples/websocket/echo.xhtml
-webserverextensions/tomcat/webapps/examples/websocket/chat.xhtml
-webserverextensions/tomcat/webapps/examples/websocket/drawboard.xhtml
-webserverextensions/tomcat/webapps/examples/websocket/index.xhtml
-webserverextensions/tomcat/webapps/examples/websocket/snake.xhtml
-webserverextensions/tomcat/webapps/examples/WEB-INF/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/RequestParamExample.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/HelloWorldExample.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/ExamplesConfig.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/ExamplesConfig.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Room$2.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Room$Player.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawMessage.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawboardEndpoint$3.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Client$1.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawboardEndpoint.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/StringWebsocketMessage.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/CloseWebsocketMessage.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/AbstractWebsocketMessage.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/BinaryWebsocketMessage.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/StringWebsocketMessage.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/CloseWebsocketMessage.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/BinaryWebsocketMessage.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/AbstractWebsocketMessage.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Room.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Room$MessageType.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawboardEndpoint$1.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawboardEndpoint$3$1.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawboardContextListener.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Room$1.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawMessage.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawMessage$ParseException.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Client.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawboardEndpoint.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Room.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Client.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawboardEndpoint$2.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Room$1$1.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawboardContextListener.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/chat/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/chat/ChatAnnotation.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/chat/ChatAnnotation.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/Snake.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/SnakeTimer$1.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/SnakeTimer.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/Direction.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/Direction.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/SnakeTimer.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/SnakeAnnotation.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/Location.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/Location$1.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/SnakeAnnotation.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/Snake.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/Location.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoAsyncAnnotation$CompletedFuture.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoEndpoint$1.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoEndpoint.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoEndpoint$EchoMessageHandlerText.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoAsyncAnnotation$1.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoAsyncAnnotation.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoEndpoint.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/servers.json
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoStreamAnnotation.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoStreamAnnotation.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoEndpoint$EchoMessageHandlerBinary.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoAsyncAnnotation.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoAnnotation.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoAnnotation.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/el/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/el/Functions.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/el/Functions.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/BookBean.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/ValuesBean.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/FooBean.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/EchoAttributesTag.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/HelloWorldSimpleTag.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/RepeatSimpleTag.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/EchoAttributesTag.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/TileSimpleTag.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/TileSimpleTag.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/RepeatSimpleTag.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/FindBookSimpleTag.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/HelloWorldSimpleTag.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/ShuffleSimpleTag.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/FindBookSimpleTag.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/ShuffleSimpleTag.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/BookBean.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/FooBean.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/ValuesBean.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings.properties
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/RequestHeaderExample.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_cs.properties
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/validators/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/validators/DebugValidator.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/validators/DebugValidator.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_de.properties
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/RequestInfoExample.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/trailers/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/trailers/ResponseTrailers$TrailerFieldSupplier.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/trailers/ResponseTrailers.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/trailers/ResponseTrailers.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/trailers/ResponseTrailers$1.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/checkbox/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/checkbox/CheckTest.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/checkbox/CheckTest.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/ServletToJsp.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_ko.properties
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/FooTag.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/LogTag.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/FooTagExtraInfo.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/FooTag.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/ExampleTagBase.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/ValuesTag.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/ExampleTagBase.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/FooTagExtraInfo.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/ValuesTag.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/LogTag.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/CookieExample.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/ByteCounter.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/NumberWriter.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/NumberWriter$1.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/ByteCounter.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/NumberWriter.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/ByteCounter$CounterListener.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/ByteCounter$1.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/NumberWriter$NumberWriterListener.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/num/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/num/NumberGuessBean.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/num/NumberGuessBean.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async2.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async1$1.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async0.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async1.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/AsyncStockContextListener.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async2.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async2$1.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async3.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/AsyncStockServlet.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Stockticker$TickListener.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async0$1.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Stockticker.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/AsyncStockServlet.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async1.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async0.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Stockticker$Stock.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/AsyncStockContextListener.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Stockticker.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async3.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_pt.properties
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/RequestParamExample.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/filters/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/filters/ExampleFilter.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/filters/ExampleFilter.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/util/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/util/CookieFilter.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/util/HTMLFilter.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/util/CookieFilter.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/util/HTMLFilter.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_ru.properties
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_fr.properties
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/dates/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/dates/JspCalendar.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/dates/JspCalendar.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/HelloWorldExample.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/sessions/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/sessions/DummyCart.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/sessions/DummyCart.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/sessions/Item.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/sessions/Item.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/ServletToJsp.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/colors/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/colors/ColorGameBean.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/colors/ColorGameBean.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_pt_BR.properties
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_ja.properties
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_zh_CN.properties
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/CompressionResponseStream.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/CompressionFilter.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/CompressionFilterTestServlet.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/CompressionResponseStream.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/CompressionFilterTestServlet.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/CompressionServletResponseWrapper.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/CompressionFilter.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/CompressionServletResponseWrapper.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/RequestInfoExample.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/listeners/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/listeners/ContextListener.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/listeners/ContextListener.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/listeners/SessionListener.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/listeners/SessionListener.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/SessionExample.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/http2/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/http2/SimpleImagePush.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/http2/SimpleImagePush.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/error/
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/error/Smart.class
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/error/Smart.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_es.properties
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/RequestHeaderExample.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/CookieExample.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/classes/SessionExample.java
-webserverextensions/tomcat/webapps/examples/WEB-INF/tags/
-webserverextensions/tomcat/webapps/examples/WEB-INF/tags/helloWorld.tag
-webserverextensions/tomcat/webapps/examples/WEB-INF/tags/displayProducts.tag
-webserverextensions/tomcat/webapps/examples/WEB-INF/tags/panel.tag
-webserverextensions/tomcat/webapps/examples/WEB-INF/lib/
-webserverextensions/tomcat/webapps/examples/WEB-INF/lib/taglibs-standard-impl-1.2.5.jar
-webserverextensions/tomcat/webapps/examples/WEB-INF/lib/taglibs-standard-spec-1.2.5.jar
-webserverextensions/tomcat/webapps/examples/WEB-INF/jsp/
-webserverextensions/tomcat/webapps/examples/WEB-INF/jsp/403.jsp
-webserverextensions/tomcat/webapps/examples/WEB-INF/jsp/403.jsp.html
-webserverextensions/tomcat/webapps/examples/WEB-INF/jsp/debug-taglib.tld
-webserverextensions/tomcat/webapps/examples/WEB-INF/jsp/example-taglib.tld
-webserverextensions/tomcat/webapps/examples/WEB-INF/jsp/jsp2-example-taglib.tld
-webserverextensions/tomcat/webapps/examples/WEB-INF/web.xml
-webserverextensions/tomcat/webapps/examples/jsp/
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/ShuffleSimpleTag.java.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/shuffle.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/jspattribute.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/HelloWorldSimpleTag.java.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/shuffle.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/jspattribute.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/TileSimpleTag.java.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/FooBean.java.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/basic-arithmetic.jsp
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/basic-comparisons.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/composite.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/implicit-objects.jsp
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/implicit-objects.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/basic-arithmetic.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/composite.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/implicit-objects.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/basic-comparisons.jsp
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/functions.jsp
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/basic-arithmetic.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/ValuesTag.java.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/ValuesBean.java.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/basic-comparisons.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/Functions.java.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/functions.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/functions.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/basic.jspx
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/basic.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/textRotate.jspx
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/svgexample.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/textRotate.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/textRotate.jpg
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/textRotate.jspx.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/basic.jspx.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/hello.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/repeat.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/HelloWorldSimpleTag.java.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/book.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/hello.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/repeat.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/book.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/FindBookSimpleTag.java.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/BookBean.java.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/Functions.java.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/RepeatSimpleTag.java.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/EchoAttributesTag.java.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/config.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/dynamicattrs.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/prelude.jspf
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/config.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/coda.jspf.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/dynamicattrs.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/prelude.jspf.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/panel.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/hello.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/products.jsp
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/panel.tag.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/panel.jsp
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/hello.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/panel.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/displayProducts.tag.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/products.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/products.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/helloWorld.tag.html
-webserverextensions/tomcat/webapps/examples/jsp/include/
-webserverextensions/tomcat/webapps/examples/jsp/include/include.jsp
-webserverextensions/tomcat/webapps/examples/jsp/include/foo.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/include/inc.html
-webserverextensions/tomcat/webapps/examples/jsp/include/include.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/include/foo.html
-webserverextensions/tomcat/webapps/examples/jsp/jsptoserv/
-webserverextensions/tomcat/webapps/examples/jsp/jsptoserv/jsptoservlet.jsp
-webserverextensions/tomcat/webapps/examples/jsp/jsptoserv/ServletToJsp.java.html
-webserverextensions/tomcat/webapps/examples/jsp/jsptoserv/hello.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/jsptoserv/jts.html
-webserverextensions/tomcat/webapps/examples/jsp/jsptoserv/jsptoservlet.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/checkbox/
-webserverextensions/tomcat/webapps/examples/jsp/checkbox/CheckTest.html
-webserverextensions/tomcat/webapps/examples/jsp/checkbox/cresult.html
-webserverextensions/tomcat/webapps/examples/jsp/checkbox/check.html
-webserverextensions/tomcat/webapps/examples/jsp/checkbox/checkresult.jsp
-webserverextensions/tomcat/webapps/examples/jsp/checkbox/checkresult.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/tagplugin/
-webserverextensions/tomcat/webapps/examples/jsp/tagplugin/howto.html
-webserverextensions/tomcat/webapps/examples/jsp/tagplugin/choose.html
-webserverextensions/tomcat/webapps/examples/jsp/tagplugin/if.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/tagplugin/choose.jsp
-webserverextensions/tomcat/webapps/examples/jsp/tagplugin/foreach.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/tagplugin/foreach.html
-webserverextensions/tomcat/webapps/examples/jsp/tagplugin/if.html
-webserverextensions/tomcat/webapps/examples/jsp/tagplugin/choose.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/tagplugin/notes.html
-webserverextensions/tomcat/webapps/examples/jsp/forward/
-webserverextensions/tomcat/webapps/examples/jsp/forward/fwd.html
-webserverextensions/tomcat/webapps/examples/jsp/forward/forward.jsp
-webserverextensions/tomcat/webapps/examples/jsp/forward/forward.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/forward/one.jsp
-webserverextensions/tomcat/webapps/examples/jsp/forward/one.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/forward/two.html
-webserverextensions/tomcat/webapps/examples/jsp/num/
-webserverextensions/tomcat/webapps/examples/jsp/num/numguess.jsp
-webserverextensions/tomcat/webapps/examples/jsp/num/numguess.html
-webserverextensions/tomcat/webapps/examples/jsp/num/numguess.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/async/
-webserverextensions/tomcat/webapps/examples/jsp/async/async3.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/async/index.jsp
-webserverextensions/tomcat/webapps/examples/jsp/async/async1.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/async/index.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/simpletag/
-webserverextensions/tomcat/webapps/examples/jsp/simpletag/foo.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/simpletag/foo.html
-webserverextensions/tomcat/webapps/examples/jsp/security/
-webserverextensions/tomcat/webapps/examples/jsp/security/protected/
-webserverextensions/tomcat/webapps/examples/jsp/security/protected/login.jsp
-webserverextensions/tomcat/webapps/examples/jsp/security/protected/index.jsp
-webserverextensions/tomcat/webapps/examples/jsp/security/protected/error.jsp
-webserverextensions/tomcat/webapps/examples/jsp/security/protected/index.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/security/protected/login.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/security/protected/error.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/xml/
-webserverextensions/tomcat/webapps/examples/jsp/xml/xml.html
-webserverextensions/tomcat/webapps/examples/jsp/xml/xml.jsp
-webserverextensions/tomcat/webapps/examples/jsp/xml/xml.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/dates/
-webserverextensions/tomcat/webapps/examples/jsp/dates/date.jsp
-webserverextensions/tomcat/webapps/examples/jsp/dates/date.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/dates/date.html
-webserverextensions/tomcat/webapps/examples/jsp/sessions/
-webserverextensions/tomcat/webapps/examples/jsp/sessions/shopping.jsp
-webserverextensions/tomcat/webapps/examples/jsp/sessions/carts.jsp
-webserverextensions/tomcat/webapps/examples/jsp/sessions/shopping.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/sessions/carts.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/sessions/DummyCart.html
-webserverextensions/tomcat/webapps/examples/jsp/sessions/crt.html
-webserverextensions/tomcat/webapps/examples/jsp/colors/
-webserverextensions/tomcat/webapps/examples/jsp/colors/colors.html
-webserverextensions/tomcat/webapps/examples/jsp/colors/ColorGameBean.html
-webserverextensions/tomcat/webapps/examples/jsp/colors/colrs.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/colors/clr.html
-webserverextensions/tomcat/webapps/examples/jsp/images/
-webserverextensions/tomcat/webapps/examples/jsp/images/code.gif
-webserverextensions/tomcat/webapps/examples/jsp/images/execute.gif
-webserverextensions/tomcat/webapps/examples/jsp/images/return.gif
-webserverextensions/tomcat/webapps/examples/jsp/index.html
-webserverextensions/tomcat/webapps/examples/jsp/error/
-webserverextensions/tomcat/webapps/examples/jsp/error/err.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/error/er.html
-webserverextensions/tomcat/webapps/examples/jsp/error/errorpge.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/error/error.html
-webserverextensions/tomcat/webapps/examples/jsp/snp/
-webserverextensions/tomcat/webapps/examples/jsp/snp/snoop.jsp.html
-webserverextensions/tomcat/webapps/examples/jsp/snp/snoop.html
-webserverextensions/tomcat/webapps/examples/index.html
-webserverextensions/tomcat/webapps/examples/servlets/
-webserverextensions/tomcat/webapps/examples/servlets/reqinfo.html
-webserverextensions/tomcat/webapps/examples/servlets/cookies.html
-webserverextensions/tomcat/webapps/examples/servlets/sessions.html
-webserverextensions/tomcat/webapps/examples/servlets/helloworld.html
-webserverextensions/tomcat/webapps/examples/servlets/nonblocking/
-webserverextensions/tomcat/webapps/examples/servlets/nonblocking/bytecounter.html
-webserverextensions/tomcat/webapps/examples/servlets/reqparams.html
-webserverextensions/tomcat/webapps/examples/servlets/images/
-webserverextensions/tomcat/webapps/examples/servlets/images/code.gif
-webserverextensions/tomcat/webapps/examples/servlets/images/execute.gif
-webserverextensions/tomcat/webapps/examples/servlets/images/return.gif
-webserverextensions/tomcat/webapps/examples/servlets/reqheaders.html
-webserverextensions/tomcat/webapps/examples/servlets/index.html
-webserverextensions/tomcat/webapps/examples/META-INF/
-webserverextensions/tomcat/webapps/examples/META-INF/context.xml
-webserverextensions/tomcat/webapps/docs/
-webserverextensions/tomcat/webapps/docs/virtual-hosting-howto.html
-webserverextensions/tomcat/webapps/docs/developers.html
-webserverextensions/tomcat/webapps/docs/jasper-howto.html
-webserverextensions/tomcat/webapps/docs/deployer-howto.html
-webserverextensions/tomcat/webapps/docs/ssl-howto.html
-webserverextensions/tomcat/webapps/docs/servletapi/
-webserverextensions/tomcat/webapps/docs/servletapi/index.html
-webserverextensions/tomcat/webapps/docs/WEB-INF/
-webserverextensions/tomcat/webapps/docs/WEB-INF/jsp/
-webserverextensions/tomcat/webapps/docs/WEB-INF/jsp/403.jsp
-webserverextensions/tomcat/webapps/docs/WEB-INF/web.xml
-webserverextensions/tomcat/webapps/docs/mbeans-descriptors-howto.html
-webserverextensions/tomcat/webapps/docs/jdbc-pool.html
-webserverextensions/tomcat/webapps/docs/aio.html
-webserverextensions/tomcat/webapps/docs/windows-service-howto.html
-webserverextensions/tomcat/webapps/docs/html-host-manager-howto.html
-webserverextensions/tomcat/webapps/docs/architecture/
-webserverextensions/tomcat/webapps/docs/architecture/overview.html
-webserverextensions/tomcat/webapps/docs/architecture/startup/
-webserverextensions/tomcat/webapps/docs/architecture/startup/2_catalina_init.png
-webserverextensions/tomcat/webapps/docs/architecture/startup/5_catalina_start_3.plantuml
-webserverextensions/tomcat/webapps/docs/architecture/startup/7_catalina_context_config.png
-webserverextensions/tomcat/webapps/docs/architecture/startup/4_catalina_start_2.png
-webserverextensions/tomcat/webapps/docs/architecture/startup/1_overview.png
-webserverextensions/tomcat/webapps/docs/architecture/startup/4_catalina_start_2.plantuml
-webserverextensions/tomcat/webapps/docs/architecture/startup/2_catalina_init.plantuml
-webserverextensions/tomcat/webapps/docs/architecture/startup/serverStartup.txt
-webserverextensions/tomcat/webapps/docs/architecture/startup/7_catalina_context_config.plantuml
-webserverextensions/tomcat/webapps/docs/architecture/startup/5_catalina_start_3.png
-webserverextensions/tomcat/webapps/docs/architecture/startup/1_overview.plantuml
-webserverextensions/tomcat/webapps/docs/architecture/startup/3_catalina_start_1.png
-webserverextensions/tomcat/webapps/docs/architecture/startup/3_catalina_start_1.plantuml
-webserverextensions/tomcat/webapps/docs/architecture/startup/6_catalina_host_config.plantuml
-webserverextensions/tomcat/webapps/docs/architecture/startup/6_catalina_host_config.png
-webserverextensions/tomcat/webapps/docs/architecture/requestProcess.html
-webserverextensions/tomcat/webapps/docs/architecture/startup.html
-webserverextensions/tomcat/webapps/docs/architecture/requestProcess/
-webserverextensions/tomcat/webapps/docs/architecture/requestProcess/41_basic.plantuml
-webserverextensions/tomcat/webapps/docs/architecture/requestProcess/21_http11.png
-webserverextensions/tomcat/webapps/docs/architecture/requestProcess/21_http11.plantuml
-webserverextensions/tomcat/webapps/docs/architecture/requestProcess/11_nio.plantuml
-webserverextensions/tomcat/webapps/docs/architecture/requestProcess/31_synchronous.png
-webserverextensions/tomcat/webapps/docs/architecture/requestProcess/41_basic.png
-webserverextensions/tomcat/webapps/docs/architecture/requestProcess/11_nio.png
-webserverextensions/tomcat/webapps/docs/architecture/requestProcess/31_synchronous.plantuml
-webserverextensions/tomcat/webapps/docs/architecture/index.html
-webserverextensions/tomcat/webapps/docs/default-servlet.html
-webserverextensions/tomcat/webapps/docs/logging.html
-webserverextensions/tomcat/webapps/docs/proxy-howto.html
-webserverextensions/tomcat/webapps/docs/appdev/
-webserverextensions/tomcat/webapps/docs/appdev/sample/
-webserverextensions/tomcat/webapps/docs/appdev/sample/build.xml
-webserverextensions/tomcat/webapps/docs/appdev/sample/src/
-webserverextensions/tomcat/webapps/docs/appdev/sample/src/mypackage/
-webserverextensions/tomcat/webapps/docs/appdev/sample/src/mypackage/Hello.java
-webserverextensions/tomcat/webapps/docs/appdev/sample/sample.war
-webserverextensions/tomcat/webapps/docs/appdev/sample/web/
-webserverextensions/tomcat/webapps/docs/appdev/sample/web/WEB-INF/
-webserverextensions/tomcat/webapps/docs/appdev/sample/web/WEB-INF/web.xml
-webserverextensions/tomcat/webapps/docs/appdev/sample/web/hello.jsp
-webserverextensions/tomcat/webapps/docs/appdev/sample/web/images/
-webserverextensions/tomcat/webapps/docs/appdev/sample/web/images/tomcat.gif
-webserverextensions/tomcat/webapps/docs/appdev/sample/web/index.html
-webserverextensions/tomcat/webapps/docs/appdev/sample/docs/
-webserverextensions/tomcat/webapps/docs/appdev/sample/docs/README.txt
-webserverextensions/tomcat/webapps/docs/appdev/sample/index.html
-webserverextensions/tomcat/webapps/docs/appdev/build.xml.txt
-webserverextensions/tomcat/webapps/docs/appdev/deployment.html
-webserverextensions/tomcat/webapps/docs/appdev/source.html
-webserverextensions/tomcat/webapps/docs/appdev/web.xml.txt
-webserverextensions/tomcat/webapps/docs/appdev/installation.html
-webserverextensions/tomcat/webapps/docs/appdev/index.html
-webserverextensions/tomcat/webapps/docs/appdev/introduction.html
-webserverextensions/tomcat/webapps/docs/appdev/processes.html
-webserverextensions/tomcat/webapps/docs/tribes/
-webserverextensions/tomcat/webapps/docs/tribes/developers.html
-webserverextensions/tomcat/webapps/docs/tribes/membership.html
-webserverextensions/tomcat/webapps/docs/tribes/setup.html
-webserverextensions/tomcat/webapps/docs/tribes/status.html
-webserverextensions/tomcat/webapps/docs/tribes/faq.html
-webserverextensions/tomcat/webapps/docs/tribes/interceptors.html
-webserverextensions/tomcat/webapps/docs/tribes/transport.html
-webserverextensions/tomcat/webapps/docs/tribes/introduction.html
-webserverextensions/tomcat/webapps/docs/mbeans-descriptors.dtd
-webserverextensions/tomcat/webapps/docs/balancer-howto.html
-webserverextensions/tomcat/webapps/docs/manager-howto.html
-webserverextensions/tomcat/webapps/docs/ssi-howto.html
-webserverextensions/tomcat/webapps/docs/config/
-webserverextensions/tomcat/webapps/docs/config/host.html
-webserverextensions/tomcat/webapps/docs/config/cluster-channel.html
-webserverextensions/tomcat/webapps/docs/config/globalresources.html
-webserverextensions/tomcat/webapps/docs/config/filter.html
-webserverextensions/tomcat/webapps/docs/config/server.html
-webserverextensions/tomcat/webapps/docs/config/listeners.html
-webserverextensions/tomcat/webapps/docs/config/cookie-processor.html
-webserverextensions/tomcat/webapps/docs/config/cluster-sender.html
-webserverextensions/tomcat/webapps/docs/config/cluster-receiver.html
-webserverextensions/tomcat/webapps/docs/config/manager.html
-webserverextensions/tomcat/webapps/docs/config/systemprops.html
-webserverextensions/tomcat/webapps/docs/config/cluster-deployer.html
-webserverextensions/tomcat/webapps/docs/config/valve.html
-webserverextensions/tomcat/webapps/docs/config/credentialhandler.html
-webserverextensions/tomcat/webapps/docs/config/cluster-interceptor.html
-webserverextensions/tomcat/webapps/docs/config/jar-scan-filter.html
-webserverextensions/tomcat/webapps/docs/config/cluster.html
-webserverextensions/tomcat/webapps/docs/config/ajp.html
-webserverextensions/tomcat/webapps/docs/config/cluster-membership.html
-webserverextensions/tomcat/webapps/docs/config/http2.html
-webserverextensions/tomcat/webapps/docs/config/jar-scanner.html
-webserverextensions/tomcat/webapps/docs/config/executor.html
-webserverextensions/tomcat/webapps/docs/config/automatic-deployment.html
-webserverextensions/tomcat/webapps/docs/config/http.html
-webserverextensions/tomcat/webapps/docs/config/cluster-manager.html
-webserverextensions/tomcat/webapps/docs/config/engine.html
-webserverextensions/tomcat/webapps/docs/config/jaspic.html
-webserverextensions/tomcat/webapps/docs/config/context.html
-webserverextensions/tomcat/webapps/docs/config/runtime-attributes.html
-webserverextensions/tomcat/webapps/docs/config/service.html
-webserverextensions/tomcat/webapps/docs/config/index.html
-webserverextensions/tomcat/webapps/docs/config/cluster-valve.html
-webserverextensions/tomcat/webapps/docs/config/resources.html
-webserverextensions/tomcat/webapps/docs/config/loader.html
-webserverextensions/tomcat/webapps/docs/config/cluster-listener.html
-webserverextensions/tomcat/webapps/docs/config/sessionidgenerator.html
-webserverextensions/tomcat/webapps/docs/config/realm.html
-webserverextensions/tomcat/webapps/docs/web-socket-howto.html
-webserverextensions/tomcat/webapps/docs/setup.html
-webserverextensions/tomcat/webapps/docs/class-loader-howto.html
-webserverextensions/tomcat/webapps/docs/cluster-howto.html
-webserverextensions/tomcat/webapps/docs/rewrite.html
-webserverextensions/tomcat/webapps/docs/elapi/
-webserverextensions/tomcat/webapps/docs/elapi/index.html
-webserverextensions/tomcat/webapps/docs/cgi-howto.html
-webserverextensions/tomcat/webapps/docs/cdi.html
-webserverextensions/tomcat/webapps/docs/RUNNING.txt
-webserverextensions/tomcat/webapps/docs/websocketapi/
-webserverextensions/tomcat/webapps/docs/websocketapi/index.html
-webserverextensions/tomcat/webapps/docs/comments.html
-webserverextensions/tomcat/webapps/docs/BUILDING.txt
-webserverextensions/tomcat/webapps/docs/changelog.html
-webserverextensions/tomcat/webapps/docs/RELEASE-NOTES.txt
-webserverextensions/tomcat/webapps/docs/connectors.html
-webserverextensions/tomcat/webapps/docs/building.html
-webserverextensions/tomcat/webapps/docs/maven-jars.html
-webserverextensions/tomcat/webapps/docs/apr.html
-webserverextensions/tomcat/webapps/docs/jaspicapi/
-webserverextensions/tomcat/webapps/docs/jaspicapi/index.html
-webserverextensions/tomcat/webapps/docs/jspapi/
-webserverextensions/tomcat/webapps/docs/jspapi/index.html
-webserverextensions/tomcat/webapps/docs/realm-howto.html
-webserverextensions/tomcat/webapps/docs/security-howto.html
-webserverextensions/tomcat/webapps/docs/images/
-webserverextensions/tomcat/webapps/docs/images/void.gif
-webserverextensions/tomcat/webapps/docs/images/code.gif
-webserverextensions/tomcat/webapps/docs/images/fix.gif
-webserverextensions/tomcat/webapps/docs/images/docs-stylesheet.css
-webserverextensions/tomcat/webapps/docs/images/fonts/
-webserverextensions/tomcat/webapps/docs/images/fonts/OpenSans400italic.woff
-webserverextensions/tomcat/webapps/docs/images/fonts/OpenSans600.woff
-webserverextensions/tomcat/webapps/docs/images/fonts/OpenSans700.woff
-webserverextensions/tomcat/webapps/docs/images/fonts/OpenSans400.woff
-webserverextensions/tomcat/webapps/docs/images/fonts/OpenSans600italic.woff
-webserverextensions/tomcat/webapps/docs/images/fonts/OpenSans700italic.woff
-webserverextensions/tomcat/webapps/docs/images/fonts/fonts.css
-webserverextensions/tomcat/webapps/docs/images/docs.gif
-webserverextensions/tomcat/webapps/docs/images/tomcat.png
-webserverextensions/tomcat/webapps/docs/images/update.gif
-webserverextensions/tomcat/webapps/docs/images/tomcat.gif
-webserverextensions/tomcat/webapps/docs/images/design.gif
-webserverextensions/tomcat/webapps/docs/images/asf-logo.svg
-webserverextensions/tomcat/webapps/docs/images/add.gif
-webserverextensions/tomcat/webapps/docs/images/cors-flowchart.png
-webserverextensions/tomcat/webapps/docs/jndi-resources-howto.html
-webserverextensions/tomcat/webapps/docs/windows-auth-howto.html
-webserverextensions/tomcat/webapps/docs/index.html
-webserverextensions/tomcat/webapps/docs/security-manager-howto.html
-webserverextensions/tomcat/webapps/docs/monitoring.html
-webserverextensions/tomcat/webapps/docs/host-manager-howto.html
-webserverextensions/tomcat/webapps/docs/introduction.html
-webserverextensions/tomcat/webapps/docs/jndi-datasource-examples-howto.html
-webserverextensions/tomcat/webapps/docs/api/
-webserverextensions/tomcat/webapps/docs/api/index.html
-webserverextensions/tomcat/webapps/docs/annotationapi/
-webserverextensions/tomcat/webapps/docs/annotationapi/index.html
-webserverextensions/tomcat/webapps/docs/html-manager-howto.html
-webserverextensions/tomcat/webapps/docs/graal.html
-webserverextensions/tomcat/webapps/docs/META-INF/
-webserverextensions/tomcat/webapps/docs/META-INF/context.xml
-webserverextensions/tomcat/webapps/ROOT/
-webserverextensions/tomcat/webapps/ROOT/tomcat.svg
-webserverextensions/tomcat/webapps/ROOT/WEB-INF/
-webserverextensions/tomcat/webapps/ROOT/WEB-INF/web.xml
-webserverextensions/tomcat/webapps/ROOT/bg-nav.png
-webserverextensions/tomcat/webapps/ROOT/index.jsp
-webserverextensions/tomcat/webapps/ROOT/bg-upper.png
-webserverextensions/tomcat/webapps/ROOT/asf-logo-wide.svg
-webserverextensions/tomcat/webapps/ROOT/favicon.ico
-webserverextensions/tomcat/webapps/ROOT/RELEASE-NOTES.txt
-webserverextensions/tomcat/webapps/ROOT/tomcat.css
-webserverextensions/tomcat/webapps/ROOT/bg-middle.png
-webserverextensions/tomcat/webapps/ROOT/bg-button.png
-webserverextensions/tomcat/webapps/host-manager/
-webserverextensions/tomcat/webapps/host-manager/WEB-INF/
-webserverextensions/tomcat/webapps/host-manager/WEB-INF/manager.xml
-webserverextensions/tomcat/webapps/host-manager/WEB-INF/jsp/
-webserverextensions/tomcat/webapps/host-manager/WEB-INF/jsp/403.jsp
-webserverextensions/tomcat/webapps/host-manager/WEB-INF/jsp/401.jsp
-webserverextensions/tomcat/webapps/host-manager/WEB-INF/jsp/404.jsp
-webserverextensions/tomcat/webapps/host-manager/WEB-INF/web.xml
-webserverextensions/tomcat/webapps/host-manager/index.jsp
-webserverextensions/tomcat/webapps/host-manager/css/
-webserverextensions/tomcat/webapps/host-manager/css/manager.css
-webserverextensions/tomcat/webapps/host-manager/images/
-webserverextensions/tomcat/webapps/host-manager/images/tomcat.svg
-webserverextensions/tomcat/webapps/host-manager/images/favicon.ico
-webserverextensions/tomcat/webapps/host-manager/images/asf-logo.svg
-webserverextensions/tomcat/webapps/host-manager/META-INF/
-webserverextensions/tomcat/webapps/host-manager/META-INF/context.xml
-webserverextensions/tomcat/lib/
-webserverextensions/tomcat/lib/catalina-ha.jar
-webserverextensions/tomcat/lib/tomcat-dbcp.jar
-webserverextensions/tomcat/lib/tomcat-i18n-pt-BR.jar
-webserverextensions/tomcat/lib/tomcat-coyote-ffm.jar
-webserverextensions/tomcat/lib/tomcat-util.jar
-webserverextensions/tomcat/lib/catalina-ant.jar
-webserverextensions/tomcat/lib/tomcat-i18n-ja.jar
-webserverextensions/tomcat/lib/websocket-api.jar
-webserverextensions/tomcat/lib/tomcat-jni.jar
-webserverextensions/tomcat/lib/tomcat-i18n-de.jar
-webserverextensions/tomcat/lib/jasper-el.jar
-webserverextensions/tomcat/lib/tomcat-i18n-cs.jar
-webserverextensions/tomcat/lib/tomcat-i18n-es.jar
-webserverextensions/tomcat/lib/jasper.jar
-webserverextensions/tomcat/lib/catalina-tribes.jar
-webserverextensions/tomcat/lib/catalina-ssi.jar
-webserverextensions/tomcat/lib/tomcat-util-scan.jar
-webserverextensions/tomcat/lib/annotations-api.jar
-webserverextensions/tomcat/lib/catalina-storeconfig.jar
-webserverextensions/tomcat/lib/servlet-api.jar
-webserverextensions/tomcat/lib/tomcat-api.jar
-webserverextensions/tomcat/lib/tomcat-i18n-ko.jar
-webserverextensions/tomcat/lib/tomcat-i18n-ru.jar
-webserverextensions/tomcat/lib/tomcat-websocket.jar
-webserverextensions/tomcat/lib/jaspic-api.jar
-webserverextensions/tomcat/lib/catalina.jar
-webserverextensions/tomcat/lib/tomcat-coyote.jar
-webserverextensions/tomcat/lib/el-api.jar
-webserverextensions/tomcat/lib/tomcat-i18n-fr.jar
-webserverextensions/tomcat/lib/jsp-api.jar
-webserverextensions/tomcat/lib/tomcat-i18n-zh-CN.jar
-webserverextensions/tomcat/lib/ecj-4.20.jar
-webserverextensions/tomcat/lib/tomcat-jdbc.jar
-webserverextensions/tomcat/RELEASE-NOTES
-webserverextensions/tomcat/RUNNING.txt
-webserverextensions/tomcat/BUILDING.txt
-webserverextensions/tomcat/bin/
-webserverextensions/tomcat/bin/version.bat
-webserverextensions/tomcat/bin/shutdown.sh
-webserverextensions/tomcat/bin/catalina-tasks.xml
-webserverextensions/tomcat/bin/shutdown.bat
-webserverextensions/tomcat/bin/version.sh
-webserverextensions/tomcat/bin/startup.bat
-webserverextensions/tomcat/bin/setclasspath.bat
-webserverextensions/tomcat/bin/configtest.sh
-webserverextensions/tomcat/bin/tool-wrapper.sh
-webserverextensions/tomcat/bin/startup.sh
-webserverextensions/tomcat/bin/tomcat-juli.jar
-webserverextensions/tomcat/bin/configtest.bat
-webserverextensions/tomcat/bin/tool-wrapper.bat
-webserverextensions/tomcat/bin/commons-daemon.jar
-webserverextensions/tomcat/bin/setclasspath.sh
-webserverextensions/tomcat/bin/digest.sh
-webserverextensions/tomcat/bin/catalina.bat
-webserverextensions/tomcat/bin/ciphers.sh
-webserverextensions/tomcat/bin/catalina.sh
-webserverextensions/tomcat/bin/ciphers.bat
-webserverextensions/tomcat/bin/daemon.sh
-webserverextensions/tomcat/bin/digest.bat
-webserverextensions/tomcat/bin/makebase.sh
-webserverextensions/tomcat/bin/bootstrap.jar
-webserverextensions/tomcat/bin/makebase.bat
-webserverextensions/tomcat/bin/commons-daemon-native.tar.gz
-webserverextensions/tomcat/bin/tomcat-native.tar.gz
-webserverextensions/tomcat/NOTICE
-webserverextensions/tomcat/CONTRIBUTING.md
-webserverextensions/tomcat/logs/
-webserverextensions/php/
-webserverextensions/php/include/
-webserverextensions/php/include/php/
-webserverextensions/php/include/php/ext/
-webserverextensions/php/include/php/ext/pdo/
-webserverextensions/php/include/php/ext/pdo/php_pdo_error.h
-webserverextensions/php/include/php/ext/pdo/php_pdo.h
-webserverextensions/php/include/php/ext/pdo/php_pdo_driver.h
-webserverextensions/php/include/php/ext/random/
-webserverextensions/php/include/php/ext/random/php_random.h
-webserverextensions/php/include/php/ext/date/
-webserverextensions/php/include/php/ext/date/lib/
-webserverextensions/php/include/php/ext/date/lib/timelib.h
-webserverextensions/php/include/php/ext/date/lib/timelib_config.h
-webserverextensions/php/include/php/ext/date/php_date.h
-webserverextensions/php/include/php/ext/mbstring/
-webserverextensions/php/include/php/ext/mbstring/mbstring.h
-webserverextensions/php/include/php/ext/mbstring/php_onig_compat.h
-webserverextensions/php/include/php/ext/mbstring/php_mbregex.h
-webserverextensions/php/include/php/ext/mbstring/libmbfl/
-webserverextensions/php/include/php/ext/mbstring/libmbfl/config.h
-webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/
-webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfl_memory_device.h
-webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfl_string.h
-webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfilter_pass.h
-webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfl_consts.h
-webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/eaw_table.h
-webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfilter.h
-webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfl_convert.h
-webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfilter_wchar.h
-webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfl_encoding.h
-webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfl_defs.h
-webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfl_language.h
-webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfl_filter_output.h
-webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfilter_8bit.h
-webserverextensions/php/include/php/ext/iconv/
-webserverextensions/php/include/php/ext/iconv/iconv_arginfo.h
-webserverextensions/php/include/php/ext/iconv/php_iconv.h
-webserverextensions/php/include/php/ext/pcre/
-webserverextensions/php/include/php/ext/pcre/pcre2lib/
-webserverextensions/php/include/php/ext/pcre/pcre2lib/pcre2_intmodedep.h
-webserverextensions/php/include/php/ext/pcre/pcre2lib/pcre2_jit_neon_inc.h
-webserverextensions/php/include/php/ext/pcre/pcre2lib/pcre2.h
-webserverextensions/php/include/php/ext/pcre/pcre2lib/config.h
-webserverextensions/php/include/php/ext/pcre/pcre2lib/pcre2_jit_simd_inc.h
-webserverextensions/php/include/php/ext/pcre/pcre2lib/pcre2_ucp.h
-webserverextensions/php/include/php/ext/pcre/pcre2lib/pcre2_internal.h
-webserverextensions/php/include/php/ext/pcre/php_pcre.h
-webserverextensions/php/include/php/ext/standard/
-webserverextensions/php/include/php/ext/standard/php_browscap.h
-webserverextensions/php/include/php/ext/standard/php_ext_syslog.h
-webserverextensions/php/include/php/ext/standard/php_crypt.h
-webserverextensions/php/include/php/ext/standard/scanf.h
-webserverextensions/php/include/php/ext/standard/quot_print.h
-webserverextensions/php/include/php/ext/standard/php_crypt_r.h
-webserverextensions/php/include/php/ext/standard/pageinfo.h
-webserverextensions/php/include/php/ext/standard/php_math.h
-webserverextensions/php/include/php/ext/standard/php_http.h
-webserverextensions/php/include/php/ext/standard/php_string.h
-webserverextensions/php/include/php/ext/standard/head.h
-webserverextensions/php/include/php/ext/standard/crc32.h
-webserverextensions/php/include/php/ext/standard/fsock.h
-webserverextensions/php/include/php/ext/standard/php_array.h
-webserverextensions/php/include/php/ext/standard/php_filestat.h
-webserverextensions/php/include/php/ext/standard/html.h
-webserverextensions/php/include/php/ext/standard/datetime.h
-webserverextensions/php/include/php/ext/standard/info.h
-webserverextensions/php/include/php/ext/standard/php_fopen_wrappers.h
-webserverextensions/php/include/php/ext/standard/flock_compat.h
-webserverextensions/php/include/php/ext/standard/dl_arginfo.h
-webserverextensions/php/include/php/ext/standard/md5.h
-webserverextensions/php/include/php/ext/standard/streamsfuncs.h
-webserverextensions/php/include/php/ext/standard/php_mt_rand.h
-webserverextensions/php/include/php/ext/standard/php_incomplete_class.h
-webserverextensions/php/include/php/ext/standard/css.h
-webserverextensions/php/include/php/ext/standard/crc32_x86.h
-webserverextensions/php/include/php/ext/standard/php_rand.h
-webserverextensions/php/include/php/ext/standard/base64.h
-webserverextensions/php/include/php/ext/standard/php_lcg.h
-webserverextensions/php/include/php/ext/standard/file.h
-webserverextensions/php/include/php/ext/standard/php_dir.h
-webserverextensions/php/include/php/ext/standard/php_net.h
-webserverextensions/php/include/php/ext/standard/url.h
-webserverextensions/php/include/php/ext/standard/php_versioning.h
-webserverextensions/php/include/php/ext/standard/sha1.h
-webserverextensions/php/include/php/ext/standard/url_scanner_ex.h
-webserverextensions/php/include/php/ext/standard/dl.h
-webserverextensions/php/include/php/ext/standard/proc_open.h
-webserverextensions/php/include/php/ext/standard/php_assert.h
-webserverextensions/php/include/php/ext/standard/php_var.h
-webserverextensions/php/include/php/ext/standard/winver.h
-webserverextensions/php/include/php/ext/standard/credits_ext.h
-webserverextensions/php/include/php/ext/standard/crypt_freesec.h
-webserverextensions/php/include/php/ext/standard/php_smart_string_public.h
-webserverextensions/php/include/php/ext/standard/php_password.h
-webserverextensions/php/include/php/ext/standard/file_arginfo.h
-webserverextensions/php/include/php/ext/standard/dir_arginfo.h
-webserverextensions/php/include/php/ext/standard/php_random.h
-webserverextensions/php/include/php/ext/standard/basic_functions_arginfo.h
-webserverextensions/php/include/php/ext/standard/php_image.h
-webserverextensions/php/include/php/ext/standard/php_smart_string.h
-webserverextensions/php/include/php/ext/standard/pack.h
-webserverextensions/php/include/php/ext/standard/crypt_blowfish.h
-webserverextensions/php/include/php/ext/standard/php_mail.h
-webserverextensions/php/include/php/ext/standard/credits_sapi.h
-webserverextensions/php/include/php/ext/standard/credits.h
-webserverextensions/php/include/php/ext/standard/php_uuencode.h
-webserverextensions/php/include/php/ext/standard/html_tables.h
-webserverextensions/php/include/php/ext/standard/user_filters_arginfo.h
-webserverextensions/php/include/php/ext/standard/php_standard.h
-webserverextensions/php/include/php/ext/standard/exec.h
-webserverextensions/php/include/php/ext/standard/basic_functions.h
-webserverextensions/php/include/php/ext/standard/php_dns.h
-webserverextensions/php/include/php/ext/libxml/
-webserverextensions/php/include/php/ext/libxml/php_libxml.h
-webserverextensions/php/include/php/ext/json/
-webserverextensions/php/include/php/ext/json/php_json_scanner.h
-webserverextensions/php/include/php/ext/json/php_json_parser.h
-webserverextensions/php/include/php/ext/json/php_json.h
-webserverextensions/php/include/php/ext/gd/
-webserverextensions/php/include/php/ext/gd/php_gd.h
-webserverextensions/php/include/php/ext/gd/libgd/
-webserverextensions/php/include/php/ext/gd/libgd/gdfontg.h
-webserverextensions/php/include/php/ext/gd/libgd/gdfonts.h
-webserverextensions/php/include/php/ext/gd/libgd/gd_io.h
-webserverextensions/php/include/php/ext/gd/libgd/gdcache.h
-webserverextensions/php/include/php/ext/gd/libgd/gdfontmb.h
-webserverextensions/php/include/php/ext/gd/libgd/gdfontl.h
-webserverextensions/php/include/php/ext/gd/libgd/gd_errors.h
-webserverextensions/php/include/php/ext/gd/libgd/wbmp.h
-webserverextensions/php/include/php/ext/gd/libgd/jisx0208.h
-webserverextensions/php/include/php/ext/gd/libgd/gdfontt.h
-webserverextensions/php/include/php/ext/gd/libgd/gdhelpers.h
-webserverextensions/php/include/php/ext/gd/libgd/bmp.h
-webserverextensions/php/include/php/ext/gd/libgd/gd_intern.h
-webserverextensions/php/include/php/ext/gd/libgd/gd.h
-webserverextensions/php/include/php/ext/gd/libgd/gd_tga.h
-webserverextensions/php/include/php/ext/gd/gd_arginfo.h
-webserverextensions/php/include/php/ext/gd/gd_compat.h
-webserverextensions/php/include/php/ext/xml/
-webserverextensions/php/include/php/ext/xml/xml_arginfo.h
-webserverextensions/php/include/php/ext/xml/expat_compat.h
-webserverextensions/php/include/php/ext/xml/php_xml.h
-webserverextensions/php/include/php/ext/session/
-webserverextensions/php/include/php/ext/session/php_session.h
-webserverextensions/php/include/php/ext/session/mod_user.h
-webserverextensions/php/include/php/ext/session/mod_files.h
-webserverextensions/php/include/php/ext/phar/
-webserverextensions/php/include/php/ext/phar/php_phar.h
-webserverextensions/php/include/php/ext/hash/
-webserverextensions/php/include/php/ext/hash/php_hash_fnv.h
-webserverextensions/php/include/php/ext/hash/php_hash_snefru.h
-webserverextensions/php/include/php/ext/hash/php_hash_tiger.h
-webserverextensions/php/include/php/ext/hash/php_hash_xxhash.h
-webserverextensions/php/include/php/ext/hash/php_hash_whirlpool.h
-webserverextensions/php/include/php/ext/hash/php_hash_joaat.h
-webserverextensions/php/include/php/ext/hash/php_hash_sha3.h
-webserverextensions/php/include/php/ext/hash/php_hash_md.h
-webserverextensions/php/include/php/ext/hash/php_hash_crc32.h
-webserverextensions/php/include/php/ext/hash/php_hash_adler32.h
-webserverextensions/php/include/php/ext/hash/php_hash_gost.h
-webserverextensions/php/include/php/ext/hash/php_hash.h
-webserverextensions/php/include/php/ext/hash/php_hash_haval.h
-webserverextensions/php/include/php/ext/hash/php_hash_sha.h
-webserverextensions/php/include/php/ext/hash/php_hash_ripemd.h
-webserverextensions/php/include/php/ext/hash/php_hash_murmur.h
-webserverextensions/php/include/php/ext/spl/
-webserverextensions/php/include/php/ext/spl/spl_exceptions.h
-webserverextensions/php/include/php/ext/spl/spl_observer.h
-webserverextensions/php/include/php/ext/spl/php_spl.h
-webserverextensions/php/include/php/ext/spl/spl_functions.h
-webserverextensions/php/include/php/ext/spl/spl_dllist.h
-webserverextensions/php/include/php/ext/spl/spl_iterators.h
-webserverextensions/php/include/php/ext/spl/spl_fixedarray.h
-webserverextensions/php/include/php/ext/spl/spl_array.h
-webserverextensions/php/include/php/ext/spl/spl_heap.h
-webserverextensions/php/include/php/ext/spl/spl_directory.h
-webserverextensions/php/include/php/ext/spl/spl_engine.h
-webserverextensions/php/include/php/ext/simplexml/
-webserverextensions/php/include/php/ext/simplexml/php_simplexml.h
-webserverextensions/php/include/php/ext/simplexml/php_simplexml_exports.h
-webserverextensions/php/include/php/ext/filter/
-webserverextensions/php/include/php/ext/filter/php_filter.h
-webserverextensions/php/include/php/ext/dom/
-webserverextensions/php/include/php/ext/dom/xml_common.h
-webserverextensions/php/include/php/TSRM/
-webserverextensions/php/include/php/TSRM/tsrm_win32.h
-webserverextensions/php/include/php/TSRM/TSRM.h
-webserverextensions/php/include/php/include/
-webserverextensions/php/include/php/Zend/
-webserverextensions/php/include/php/Zend/zend_portability.h
-webserverextensions/php/include/php/Zend/zend_stream.h
-webserverextensions/php/include/php/Zend/zend_observer.h
-webserverextensions/php/include/php/Zend/zend_object_handlers.h
-webserverextensions/php/include/php/Zend/zend_objects.h
-webserverextensions/php/include/php/Zend/Optimizer/
-webserverextensions/php/include/php/Zend/Optimizer/zend_dfg.h
-webserverextensions/php/include/php/Zend/Optimizer/zend_inference.h
-webserverextensions/php/include/php/Zend/Optimizer/zend_dump.h
-webserverextensions/php/include/php/Zend/Optimizer/zend_cfg.h
-webserverextensions/php/include/php/Zend/Optimizer/zend_func_info.h
-webserverextensions/php/include/php/Zend/Optimizer/zend_ssa.h
-webserverextensions/php/include/php/Zend/Optimizer/zend_optimizer.h
-webserverextensions/php/include/php/Zend/Optimizer/zend_call_graph.h
-webserverextensions/php/include/php/Zend/zend_language_scanner.h
-webserverextensions/php/include/php/Zend/zend_errors.h
-webserverextensions/php/include/php/Zend/zend_API.h
-webserverextensions/php/include/php/Zend/zend_vm_trace_handlers.h
-webserverextensions/php/include/php/Zend/zend_attributes.h
-webserverextensions/php/include/php/Zend/zend_language_parser.h
-webserverextensions/php/include/php/Zend/zend_vm_trace_lines.h
-webserverextensions/php/include/php/Zend/zend_iterators.h
-webserverextensions/php/include/php/Zend/zend_operators.h
-webserverextensions/php/include/php/Zend/zend_stack.h
-webserverextensions/php/include/php/Zend/zend_alloc_sizes.h
-webserverextensions/php/include/php/Zend/zend_objects_API.h
-webserverextensions/php/include/php/Zend/zend_alloc.h
-webserverextensions/php/include/php/Zend/zend_attributes_arginfo.h
-webserverextensions/php/include/php/Zend/zend_type_info.h
-webserverextensions/php/include/php/Zend/zend_interfaces.h
-webserverextensions/php/include/php/Zend/zend_enum.h
-webserverextensions/php/include/php/Zend/zend_constants.h
-webserverextensions/php/include/php/Zend/zend_smart_string_public.h
-webserverextensions/php/include/php/Zend/zend_enum_arginfo.h
-webserverextensions/php/include/php/Zend/zend_map_ptr.h
-webserverextensions/php/include/php/Zend/zend_variables.h
-webserverextensions/php/include/php/Zend/zend.h
-webserverextensions/php/include/php/Zend/zend_multiply.h
-webserverextensions/php/include/php/Zend/zend_list.h
-webserverextensions/php/include/php/Zend/zend_exceptions.h
-webserverextensions/php/include/php/Zend/zend_bitset.h
-webserverextensions/php/include/php/Zend/zend_max_execution_timer.h
-webserverextensions/php/include/php/Zend/zend_ini.h
-webserverextensions/php/include/php/Zend/zend_istdiostream.h
-webserverextensions/php/include/php/Zend/zend_gdb.h
-webserverextensions/php/include/php/Zend/zend_closures_arginfo.h
-webserverextensions/php/include/php/Zend/zend_sort.h
-webserverextensions/php/include/php/Zend/zend_system_id.h
-webserverextensions/php/include/php/Zend/zend_extensions.h
-webserverextensions/php/include/php/Zend/zend_hash.h
-webserverextensions/php/include/php/Zend/zend_llist.h
-webserverextensions/php/include/php/Zend/zend_language_scanner_defs.h
-webserverextensions/php/include/php/Zend/zend_string.h
-webserverextensions/php/include/php/Zend/zend_smart_str.h
-webserverextensions/php/include/php/Zend/zend_config.w32.h
-webserverextensions/php/include/php/Zend/zend_builtin_functions.h
-webserverextensions/php/include/php/Zend/zend_config.h
-webserverextensions/php/include/php/Zend/zend_vm_opcodes.h
-webserverextensions/php/include/php/Zend/zend_vm_trace_map.h
-webserverextensions/php/include/php/Zend/zend_ast.h
-webserverextensions/php/include/php/Zend/zend_arena.h
-webserverextensions/php/include/php/Zend/zend_gc.h
-webserverextensions/php/include/php/Zend/zend_ini_scanner.h
-webserverextensions/php/include/php/Zend/zend_mmap.h
-webserverextensions/php/include/php/Zend/zend_ini_scanner_defs.h
-webserverextensions/php/include/php/Zend/zend_builtin_functions_arginfo.h
-webserverextensions/php/include/php/Zend/zend_ptr_stack.h
-webserverextensions/php/include/php/Zend/zend_signal.h
-webserverextensions/php/include/php/Zend/zend_globals_macros.h
-webserverextensions/php/include/php/Zend/zend_fibers.h
-webserverextensions/php/include/php/Zend/zend_weakrefs_arginfo.h
-webserverextensions/php/include/php/Zend/zend_strtod.h
-webserverextensions/php/include/php/Zend/zend_interfaces_arginfo.h
-webserverextensions/php/include/php/Zend/zend_closures.h
-webserverextensions/php/include/php/Zend/zend_generators.h
-webserverextensions/php/include/php/Zend/zend_vm_execute.h
-webserverextensions/php/include/php/Zend/zend_smart_string.h
-webserverextensions/php/include/php/Zend/zend_weakrefs.h
-webserverextensions/php/include/php/Zend/zend_generators_arginfo.h
-webserverextensions/php/include/php/Zend/zend_vm_handlers.h
-webserverextensions/php/include/php/Zend/zend_smart_str_public.h
-webserverextensions/php/include/php/Zend/zend_call_stack.h
-webserverextensions/php/include/php/Zend/zend_inheritance.h
-webserverextensions/php/include/php/Zend/zend_fibers_arginfo.h
-webserverextensions/php/include/php/Zend/zend_constants_arginfo.h
-webserverextensions/php/include/php/Zend/zend_ini_parser.h
-webserverextensions/php/include/php/Zend/zend_execute.h
-webserverextensions/php/include/php/Zend/zend_cpuinfo.h
-webserverextensions/php/include/php/Zend/zend_compile.h
-webserverextensions/php/include/php/Zend/zend_float.h
-webserverextensions/php/include/php/Zend/zend_build.h
-webserverextensions/php/include/php/Zend/zend_long.h
-webserverextensions/php/include/php/Zend/zend_exceptions_arginfo.h
-webserverextensions/php/include/php/Zend/zend_globals.h
-webserverextensions/php/include/php/Zend/zend_multibyte.h
-webserverextensions/php/include/php/Zend/zend_dtrace.h
-webserverextensions/php/include/php/Zend/zend_modules.h
-webserverextensions/php/include/php/Zend/zend_types.h
-webserverextensions/php/include/php/Zend/zend_atomic.h
-webserverextensions/php/include/php/Zend/zend_hrtime.h
-webserverextensions/php/include/php/Zend/zend_virtual_cwd.h
-webserverextensions/php/include/php/Zend/zend_vm_def.h
-webserverextensions/php/include/php/Zend/zend_highlight.h
-webserverextensions/php/include/php/Zend/zend_strtod_int.h
-webserverextensions/php/include/php/Zend/zend_range_check.h
-webserverextensions/php/include/php/Zend/zend_vm.h
-webserverextensions/php/include/php/main/
-webserverextensions/php/include/php/main/php_ini.h
-webserverextensions/php/include/php/main/streams/
-webserverextensions/php/include/php/main/streams/php_stream_transport.h
-webserverextensions/php/include/php/main/streams/php_stream_plain_wrapper.h
-webserverextensions/php/include/php/main/streams/php_stream_filter_api.h
-webserverextensions/php/include/php/main/streams/php_stream_mmap.h
-webserverextensions/php/include/php/main/streams/php_stream_userspace.h
-webserverextensions/php/include/php/main/streams/php_stream_context.h
-webserverextensions/php/include/php/main/streams/userspace_arginfo.h
-webserverextensions/php/include/php/main/streams/php_stream_glob_wrapper.h
-webserverextensions/php/include/php/main/streams/php_streams_int.h
-webserverextensions/php/include/php/main/php_odbc_utils.h
-webserverextensions/php/include/php/main/fastcgi.h
-webserverextensions/php/include/php/main/spprintf.h
-webserverextensions/php/include/php/main/build-defs.h
-webserverextensions/php/include/php/main/php_open_temporary_file.h
-webserverextensions/php/include/php/main/http_status_codes.h
-webserverextensions/php/include/php/main/php_syslog.h
-webserverextensions/php/include/php/main/php_globals.h
-webserverextensions/php/include/php/main/php_main.h
-webserverextensions/php/include/php/main/php_config.h
-webserverextensions/php/include/php/main/php_getopt.h
-webserverextensions/php/include/php/main/php.h
-webserverextensions/php/include/php/main/php_scandir.h
-webserverextensions/php/include/php/main/php_content_types.h
-webserverextensions/php/include/php/main/php_variables.h
-webserverextensions/php/include/php/main/main_arginfo.h
-webserverextensions/php/include/php/main/php_reentrancy.h
-webserverextensions/php/include/php/main/php_streams.h
-webserverextensions/php/include/php/main/php_network.h
-webserverextensions/php/include/php/main/SAPI.h
-webserverextensions/php/include/php/main/php_compat.h
-webserverextensions/php/include/php/main/php_version.h
-webserverextensions/php/include/php/main/php_memory_streams.h
-webserverextensions/php/include/php/main/snprintf.h
-webserverextensions/php/include/php/main/php_output.h
-webserverextensions/php/include/php/main/fopen_wrappers.h
-webserverextensions/php/include/php/main/php_ini_builder.h
-webserverextensions/php/include/php/main/php_ticks.h
-webserverextensions/php/include/php/main/rfc1867.h
-webserverextensions/php/include/php/sapi/
-webserverextensions/php/include/php/sapi/cli/
-webserverextensions/php/include/php/sapi/cli/cli.h
-webserverextensions/php/lib/
-webserverextensions/php/lib/php/
-webserverextensions/php/lib/php/extensions/
-webserverextensions/php/lib/php/extensions/no-debug-zts-20230831/
-webserverextensions/php/lib/php/extensions/no-debug-zts-20230831/mbstring.so
-webserverextensions/php/lib/php/extensions/no-debug-zts-20230831/opcache.so
-webserverextensions/php/lib/php/build/
-webserverextensions/php/lib/php/build/phpize.m4
-webserverextensions/php/lib/php/build/run-tests.php
-webserverextensions/php/lib/php/build/ax_check_compile_flag.m4
-webserverextensions/php/lib/php/build/php_cxx_compile_stdcxx.m4
-webserverextensions/php/lib/php/build/Makefile.global
-webserverextensions/php/lib/php/build/config.sub
-webserverextensions/php/lib/php/build/config.guess
-webserverextensions/php/lib/php/build/shtool
-webserverextensions/php/lib/php/build/ax_gcc_func_attribute.m4
-webserverextensions/php/lib/php/build/pkg.m4
-webserverextensions/php/lib/php/build/libtool.m4
-webserverextensions/php/lib/php/build/gen_stub.php
-webserverextensions/php/lib/php/build/ltmain.sh
-webserverextensions/php/lib/php/build/php.m4
-webserverextensions/php/lib/php.ini
-webserverextensions/php/php/
-webserverextensions/php/php/man/
-webserverextensions/php/php/man/man1/
-webserverextensions/php/php/man/man1/phpdbg.1
-webserverextensions/php/php/man/man1/php-cgi.1
-webserverextensions/php/php/man/man1/phar.phar.1
-webserverextensions/php/php/man/man1/phpize.1
-webserverextensions/php/php/man/man1/php.1
-webserverextensions/php/php/man/man1/php-config.1
-webserverextensions/php/php/man/man1/phar.1
-webserverextensions/php/bin/
-webserverextensions/php/bin/php-cgi
-webserverextensions/php/bin/php-config
-webserverextensions/php/bin/phpdbg
-webserverextensions/php/bin/phar
-webserverextensions/php/bin/phpize
-webserverextensions/php/bin/phar.phar
-webserverextensions/php/var/
-webserverextensions/php/var/run/
-webserverextensions/php/var/log/
 webserverextensions/Temp/
 webserverextensions/apache2/
+webserverextensions/apache2/bin/
+webserverextensions/apache2/bin/ab
+webserverextensions/apache2/bin/apachectl
+webserverextensions/apache2/bin/apr-1-config
+webserverextensions/apache2/bin/apu-1-config
+webserverextensions/apache2/bin/apxs
+webserverextensions/apache2/bin/checkgid
+webserverextensions/apache2/bin/dbmmanage
+webserverextensions/apache2/bin/envvars
+webserverextensions/apache2/bin/envvars-std
+webserverextensions/apache2/bin/fcgistarter
+webserverextensions/apache2/bin/htcacheclean
+webserverextensions/apache2/bin/htdbm
+webserverextensions/apache2/bin/htdigest
+webserverextensions/apache2/bin/htpasswd
+webserverextensions/apache2/bin/httpd
+webserverextensions/apache2/bin/httxt2dbm
+webserverextensions/apache2/bin/logresolve
+webserverextensions/apache2/bin/rotatelogs
+webserverextensions/apache2/build/
+webserverextensions/apache2/build/apr_rules.mk
+webserverextensions/apache2/build/config.nice
+webserverextensions/apache2/build/config_vars.mk
+webserverextensions/apache2/build/instdso.sh
+webserverextensions/apache2/build/library.mk
+webserverextensions/apache2/build/libtool
+webserverextensions/apache2/build/ltlib.mk
+webserverextensions/apache2/build/make_exports.awk
+webserverextensions/apache2/build/make_var_export.awk
+webserverextensions/apache2/build/mkdir.sh
+webserverextensions/apache2/build/program.mk
+webserverextensions/apache2/build/rules.mk
+webserverextensions/apache2/build/special.mk
 webserverextensions/apache2/cgi-bin/
+webserverextensions/apache2/cgi-bin/printenv
+webserverextensions/apache2/cgi-bin/printenv.vbs
 webserverextensions/apache2/cgi-bin/printenv.wsf
-webserverextensions/apache2/cgi-bin/printenv
 webserverextensions/apache2/cgi-bin/test-cgi
-webserverextensions/apache2/cgi-bin/printenv.vbs
+webserverextensions/apache2/conf/
+webserverextensions/apache2/conf/extra/
+webserverextensions/apache2/conf/extra/httpd-autoindex.conf
+webserverextensions/apache2/conf/extra/httpd-dav.conf
+webserverextensions/apache2/conf/extra/httpd-default.conf
+webserverextensions/apache2/conf/extra/httpd-info.conf
+webserverextensions/apache2/conf/extra/httpd-languages.conf
+webserverextensions/apache2/conf/extra/httpd-manual.conf
+webserverextensions/apache2/conf/extra/httpd-mpm.conf
+webserverextensions/apache2/conf/extra/httpd-multilang-errordoc.conf
+webserverextensions/apache2/conf/extra/httpd-ssl.conf
+webserverextensions/apache2/conf/extra/httpd-userdir.conf
+webserverextensions/apache2/conf/extra/httpd-vhosts.conf
+webserverextensions/apache2/conf/extra/proxy-html.conf
+webserverextensions/apache2/conf/httpd.conf
+webserverextensions/apache2/conf/httpd.conf.bak
+webserverextensions/apache2/conf/magic
+webserverextensions/apache2/conf/mapguide/
+webserverextensions/apache2/conf/mapguide/mapguide.conf
+webserverextensions/apache2/conf/mapguide/tomcat.conf
+webserverextensions/apache2/conf/mapguide/workers.properties
+webserverextensions/apache2/conf/mime.types
+webserverextensions/apache2/conf/original/
+webserverextensions/apache2/conf/original/extra/
+webserverextensions/apache2/conf/original/extra/httpd-autoindex.conf
+webserverextensions/apache2/conf/original/extra/httpd-dav.conf
+webserverextensions/apache2/conf/original/extra/httpd-default.conf
+webserverextensions/apache2/conf/original/extra/httpd-info.conf
+webserverextensions/apache2/conf/original/extra/httpd-languages.conf
+webserverextensions/apache2/conf/original/extra/httpd-manual.conf
+webserverextensions/apache2/conf/original/extra/httpd-mpm.conf
+webserverextensions/apache2/conf/original/extra/httpd-multilang-errordoc.conf
+webserverextensions/apache2/conf/original/extra/httpd-ssl.conf
+webserverextensions/apache2/conf/original/extra/httpd-userdir.conf
+webserverextensions/apache2/conf/original/extra/httpd-vhosts.conf
+webserverextensions/apache2/conf/original/extra/proxy-html.conf
+webserverextensions/apache2/conf/original/httpd.conf
+webserverextensions/apache2/error/
+webserverextensions/apache2/error/HTTP_BAD_GATEWAY.html.var
+webserverextensions/apache2/error/HTTP_BAD_REQUEST.html.var
+webserverextensions/apache2/error/HTTP_FORBIDDEN.html.var
+webserverextensions/apache2/error/HTTP_GATEWAY_TIME_OUT.html.var
+webserverextensions/apache2/error/HTTP_GONE.html.var
+webserverextensions/apache2/error/HTTP_INTERNAL_SERVER_ERROR.html.var
+webserverextensions/apache2/error/HTTP_LENGTH_REQUIRED.html.var
+webserverextensions/apache2/error/HTTP_METHOD_NOT_ALLOWED.html.var
+webserverextensions/apache2/error/HTTP_NOT_FOUND.html.var
+webserverextensions/apache2/error/HTTP_NOT_IMPLEMENTED.html.var
+webserverextensions/apache2/error/HTTP_PRECONDITION_FAILED.html.var
+webserverextensions/apache2/error/HTTP_REQUEST_ENTITY_TOO_LARGE.html.var
+webserverextensions/apache2/error/HTTP_REQUEST_TIME_OUT.html.var
+webserverextensions/apache2/error/HTTP_REQUEST_URI_TOO_LARGE.html.var
+webserverextensions/apache2/error/HTTP_SERVICE_UNAVAILABLE.html.var
+webserverextensions/apache2/error/HTTP_UNAUTHORIZED.html.var
+webserverextensions/apache2/error/HTTP_UNSUPPORTED_MEDIA_TYPE.html.var
+webserverextensions/apache2/error/HTTP_VARIANT_ALSO_VARIES.html.var
+webserverextensions/apache2/error/README
+webserverextensions/apache2/error/contact.html.var
+webserverextensions/apache2/error/include/
+webserverextensions/apache2/error/include/bottom.html
+webserverextensions/apache2/error/include/spacer.html
+webserverextensions/apache2/error/include/top.html
+webserverextensions/apache2/htdocs/
+webserverextensions/apache2/htdocs/index.html
+webserverextensions/apache2/icons/
+webserverextensions/apache2/icons/README
+webserverextensions/apache2/icons/README.html
+webserverextensions/apache2/icons/a.gif
+webserverextensions/apache2/icons/a.png
+webserverextensions/apache2/icons/alert.black.gif
+webserverextensions/apache2/icons/alert.black.png
+webserverextensions/apache2/icons/alert.red.gif
+webserverextensions/apache2/icons/alert.red.png
+webserverextensions/apache2/icons/apache_pb.gif
+webserverextensions/apache2/icons/apache_pb.png
+webserverextensions/apache2/icons/apache_pb.svg
+webserverextensions/apache2/icons/apache_pb2.gif
+webserverextensions/apache2/icons/apache_pb2.png
+webserverextensions/apache2/icons/back.gif
+webserverextensions/apache2/icons/back.png
+webserverextensions/apache2/icons/ball.gray.gif
+webserverextensions/apache2/icons/ball.gray.png
+webserverextensions/apache2/icons/ball.red.gif
+webserverextensions/apache2/icons/ball.red.png
+webserverextensions/apache2/icons/binary.gif
+webserverextensions/apache2/icons/binary.png
+webserverextensions/apache2/icons/binhex.gif
+webserverextensions/apache2/icons/binhex.png
+webserverextensions/apache2/icons/blank.gif
+webserverextensions/apache2/icons/blank.png
+webserverextensions/apache2/icons/bomb.gif
+webserverextensions/apache2/icons/bomb.png
+webserverextensions/apache2/icons/box1.gif
+webserverextensions/apache2/icons/box1.png
+webserverextensions/apache2/icons/box2.gif
+webserverextensions/apache2/icons/box2.png
+webserverextensions/apache2/icons/broken.gif
+webserverextensions/apache2/icons/broken.png
+webserverextensions/apache2/icons/burst.gif
+webserverextensions/apache2/icons/burst.png
+webserverextensions/apache2/icons/c.gif
+webserverextensions/apache2/icons/c.png
+webserverextensions/apache2/icons/comp.blue.gif
+webserverextensions/apache2/icons/comp.blue.png
+webserverextensions/apache2/icons/comp.gray.gif
+webserverextensions/apache2/icons/comp.gray.png
+webserverextensions/apache2/icons/compressed.gif
+webserverextensions/apache2/icons/compressed.png
+webserverextensions/apache2/icons/continued.gif
+webserverextensions/apache2/icons/continued.png
+webserverextensions/apache2/icons/dir.gif
+webserverextensions/apache2/icons/dir.png
+webserverextensions/apache2/icons/diskimg.gif
+webserverextensions/apache2/icons/diskimg.png
+webserverextensions/apache2/icons/down.gif
+webserverextensions/apache2/icons/down.png
+webserverextensions/apache2/icons/dvi.gif
+webserverextensions/apache2/icons/dvi.png
+webserverextensions/apache2/icons/f.gif
+webserverextensions/apache2/icons/f.png
+webserverextensions/apache2/icons/folder.gif
+webserverextensions/apache2/icons/folder.open.gif
+webserverextensions/apache2/icons/folder.open.png
+webserverextensions/apache2/icons/folder.png
+webserverextensions/apache2/icons/folder.sec.gif
+webserverextensions/apache2/icons/folder.sec.png
+webserverextensions/apache2/icons/forward.gif
+webserverextensions/apache2/icons/forward.png
+webserverextensions/apache2/icons/generic.gif
+webserverextensions/apache2/icons/generic.png
+webserverextensions/apache2/icons/generic.red.gif
+webserverextensions/apache2/icons/generic.red.png
+webserverextensions/apache2/icons/generic.sec.gif
+webserverextensions/apache2/icons/generic.sec.png
+webserverextensions/apache2/icons/hand.right.gif
+webserverextensions/apache2/icons/hand.right.png
+webserverextensions/apache2/icons/hand.up.gif
+webserverextensions/apache2/icons/hand.up.png
+webserverextensions/apache2/icons/icon.sheet.gif
+webserverextensions/apache2/icons/icon.sheet.png
+webserverextensions/apache2/icons/image1.gif
+webserverextensions/apache2/icons/image1.png
+webserverextensions/apache2/icons/image2.gif
+webserverextensions/apache2/icons/image2.png
+webserverextensions/apache2/icons/image3.gif
+webserverextensions/apache2/icons/image3.png
+webserverextensions/apache2/icons/index.gif
+webserverextensions/apache2/icons/index.png
+webserverextensions/apache2/icons/layout.gif
+webserverextensions/apache2/icons/layout.png
+webserverextensions/apache2/icons/left.gif
+webserverextensions/apache2/icons/left.png
+webserverextensions/apache2/icons/link.gif
+webserverextensions/apache2/icons/link.png
+webserverextensions/apache2/icons/movie.gif
+webserverextensions/apache2/icons/movie.png
+webserverextensions/apache2/icons/odf6odb.png
+webserverextensions/apache2/icons/odf6odc.png
+webserverextensions/apache2/icons/odf6odf.png
+webserverextensions/apache2/icons/odf6odg.png
+webserverextensions/apache2/icons/odf6odi.png
+webserverextensions/apache2/icons/odf6odm.png
+webserverextensions/apache2/icons/odf6odp.png
+webserverextensions/apache2/icons/odf6ods.png
+webserverextensions/apache2/icons/odf6odt.png
+webserverextensions/apache2/icons/odf6otc.png
+webserverextensions/apache2/icons/odf6otf.png
+webserverextensions/apache2/icons/odf6otg.png
+webserverextensions/apache2/icons/odf6oth.png
+webserverextensions/apache2/icons/odf6oti.png
+webserverextensions/apache2/icons/odf6otp.png
+webserverextensions/apache2/icons/odf6ots.png
+webserverextensions/apache2/icons/odf6ott.png
+webserverextensions/apache2/icons/p.gif
+webserverextensions/apache2/icons/p.png
+webserverextensions/apache2/icons/patch.gif
+webserverextensions/apache2/icons/patch.png
+webserverextensions/apache2/icons/pdf.gif
+webserverextensions/apache2/icons/pdf.png
+webserverextensions/apache2/icons/pie0.gif
+webserverextensions/apache2/icons/pie0.png
+webserverextensions/apache2/icons/pie1.gif
+webserverextensions/apache2/icons/pie1.png
+webserverextensions/apache2/icons/pie2.gif
+webserverextensions/apache2/icons/pie2.png
+webserverextensions/apache2/icons/pie3.gif
+webserverextensions/apache2/icons/pie3.png
+webserverextensions/apache2/icons/pie4.gif
+webserverextensions/apache2/icons/pie4.png
+webserverextensions/apache2/icons/pie5.gif
+webserverextensions/apache2/icons/pie5.png
+webserverextensions/apache2/icons/pie6.gif
+webserverextensions/apache2/icons/pie6.png
+webserverextensions/apache2/icons/pie7.gif
+webserverextensions/apache2/icons/pie7.png
+webserverextensions/apache2/icons/pie8.gif
+webserverextensions/apache2/icons/pie8.png
+webserverextensions/apache2/icons/portal.gif
+webserverextensions/apache2/icons/portal.png
+webserverextensions/apache2/icons/ps.gif
+webserverextensions/apache2/icons/ps.png
+webserverextensions/apache2/icons/quill.gif
+webserverextensions/apache2/icons/quill.png
+webserverextensions/apache2/icons/right.gif
+webserverextensions/apache2/icons/right.png
+webserverextensions/apache2/icons/screw1.gif
+webserverextensions/apache2/icons/screw1.png
+webserverextensions/apache2/icons/screw2.gif
+webserverextensions/apache2/icons/screw2.png
+webserverextensions/apache2/icons/script.gif
+webserverextensions/apache2/icons/script.png
+webserverextensions/apache2/icons/small/
+webserverextensions/apache2/icons/small/back.gif
+webserverextensions/apache2/icons/small/back.png
+webserverextensions/apache2/icons/small/binary.gif
+webserverextensions/apache2/icons/small/binary.png
+webserverextensions/apache2/icons/small/binhex.gif
+webserverextensions/apache2/icons/small/binhex.png
+webserverextensions/apache2/icons/small/blank.gif
+webserverextensions/apache2/icons/small/blank.png
+webserverextensions/apache2/icons/small/broken.gif
+webserverextensions/apache2/icons/small/broken.png
+webserverextensions/apache2/icons/small/burst.gif
+webserverextensions/apache2/icons/small/burst.png
+webserverextensions/apache2/icons/small/comp1.gif
+webserverextensions/apache2/icons/small/comp1.png
+webserverextensions/apache2/icons/small/comp2.gif
+webserverextensions/apache2/icons/small/comp2.png
+webserverextensions/apache2/icons/small/compressed.gif
+webserverextensions/apache2/icons/small/compressed.png
+webserverextensions/apache2/icons/small/continued.gif
+webserverextensions/apache2/icons/small/continued.png
+webserverextensions/apache2/icons/small/doc.gif
+webserverextensions/apache2/icons/small/doc.png
+webserverextensions/apache2/icons/small/folder.gif
+webserverextensions/apache2/icons/small/folder.png
+webserverextensions/apache2/icons/small/folder2.gif
+webserverextensions/apache2/icons/small/folder2.png
+webserverextensions/apache2/icons/small/forward.gif
+webserverextensions/apache2/icons/small/forward.png
+webserverextensions/apache2/icons/small/generic.gif
+webserverextensions/apache2/icons/small/generic.png
+webserverextensions/apache2/icons/small/generic2.gif
+webserverextensions/apache2/icons/small/generic2.png
+webserverextensions/apache2/icons/small/generic3.gif
+webserverextensions/apache2/icons/small/generic3.png
+webserverextensions/apache2/icons/small/image.gif
+webserverextensions/apache2/icons/small/image.png
+webserverextensions/apache2/icons/small/image2.gif
+webserverextensions/apache2/icons/small/image2.png
+webserverextensions/apache2/icons/small/index.gif
+webserverextensions/apache2/icons/small/index.png
+webserverextensions/apache2/icons/small/key.gif
+webserverextensions/apache2/icons/small/key.png
+webserverextensions/apache2/icons/small/movie.gif
+webserverextensions/apache2/icons/small/movie.png
+webserverextensions/apache2/icons/small/patch.gif
+webserverextensions/apache2/icons/small/patch.png
+webserverextensions/apache2/icons/small/ps.gif
+webserverextensions/apache2/icons/small/ps.png
+webserverextensions/apache2/icons/small/rainbow.gif
+webserverextensions/apache2/icons/small/rainbow.png
+webserverextensions/apache2/icons/small/sound.gif
+webserverextensions/apache2/icons/small/sound.png
+webserverextensions/apache2/icons/small/sound2.gif
+webserverextensions/apache2/icons/small/sound2.png
+webserverextensions/apache2/icons/small/tar.gif
+webserverextensions/apache2/icons/small/tar.png
+webserverextensions/apache2/icons/small/text.gif
+webserverextensions/apache2/icons/small/text.png
+webserverextensions/apache2/icons/small/transfer.gif
+webserverextensions/apache2/icons/small/transfer.png
+webserverextensions/apache2/icons/small/unknown.gif
+webserverextensions/apache2/icons/small/unknown.png
+webserverextensions/apache2/icons/small/uu.gif
+webserverextensions/apache2/icons/small/uu.png
+webserverextensions/apache2/icons/sound1.gif
+webserverextensions/apache2/icons/sound1.png
+webserverextensions/apache2/icons/sound2.gif
+webserverextensions/apache2/icons/sound2.png
+webserverextensions/apache2/icons/sphere1.gif
+webserverextensions/apache2/icons/sphere1.png
+webserverextensions/apache2/icons/sphere2.gif
+webserverextensions/apache2/icons/sphere2.png
+webserverextensions/apache2/icons/svg.png
+webserverextensions/apache2/icons/tar.gif
+webserverextensions/apache2/icons/tar.png
+webserverextensions/apache2/icons/tex.gif
+webserverextensions/apache2/icons/tex.png
+webserverextensions/apache2/icons/text.gif
+webserverextensions/apache2/icons/text.png
+webserverextensions/apache2/icons/transfer.gif
+webserverextensions/apache2/icons/transfer.png
+webserverextensions/apache2/icons/unknown.gif
+webserverextensions/apache2/icons/unknown.png
+webserverextensions/apache2/icons/up.gif
+webserverextensions/apache2/icons/up.png
+webserverextensions/apache2/icons/uu.gif
+webserverextensions/apache2/icons/uu.png
+webserverextensions/apache2/icons/uuencoded.gif
+webserverextensions/apache2/icons/uuencoded.png
+webserverextensions/apache2/icons/world1.gif
+webserverextensions/apache2/icons/world1.png
+webserverextensions/apache2/icons/world2.gif
+webserverextensions/apache2/icons/world2.png
+webserverextensions/apache2/icons/xml.png
 webserverextensions/apache2/include/
-webserverextensions/apache2/include/apu_errno.h
-webserverextensions/apache2/include/ap_mpm.h
+webserverextensions/apache2/include/ap_compat.h
+webserverextensions/apache2/include/ap_config.h
+webserverextensions/apache2/include/ap_config_auto.h
+webserverextensions/apache2/include/ap_config_layout.h
+webserverextensions/apache2/include/ap_expr.h
+webserverextensions/apache2/include/ap_hooks.h
 webserverextensions/apache2/include/ap_listen.h
 webserverextensions/apache2/include/ap_mmn.h
-webserverextensions/apache2/include/util_xml.h
-webserverextensions/apache2/include/mod_cgi.h
-webserverextensions/apache2/include/util_cookies.h
-webserverextensions/apache2/include/apr_xml.h
-webserverextensions/apache2/include/http_config.h
+webserverextensions/apache2/include/ap_mpm.h
+webserverextensions/apache2/include/ap_provider.h
 webserverextensions/apache2/include/ap_regex.h
-webserverextensions/apache2/include/apr_time.h
-webserverextensions/apache2/include/mod_log_config.h
-webserverextensions/apache2/include/http_request.h
-webserverextensions/apache2/include/apr_xlate.h
-webserverextensions/apache2/include/apr_md5.h
+webserverextensions/apache2/include/ap_regkey.h
+webserverextensions/apache2/include/ap_release.h
+webserverextensions/apache2/include/ap_slotmem.h
+webserverextensions/apache2/include/ap_socache.h
+webserverextensions/apache2/include/apache_noprobes.h
+webserverextensions/apache2/include/apr.h
+webserverextensions/apache2/include/apr_allocator.h
+webserverextensions/apache2/include/apr_anylock.h
+webserverextensions/apache2/include/apr_atomic.h
+webserverextensions/apache2/include/apr_base64.h
+webserverextensions/apache2/include/apr_buckets.h
+webserverextensions/apache2/include/apr_crypto.h
+webserverextensions/apache2/include/apr_cstr.h
+webserverextensions/apache2/include/apr_date.h
 webserverextensions/apache2/include/apr_dbd.h
-webserverextensions/apache2/include/util_ldap.h
-webserverextensions/apache2/include/apr.h
-webserverextensions/apache2/include/http_core.h
-webserverextensions/apache2/include/mod_ssl_openssl.h
-webserverextensions/apache2/include/mod_core.h
-webserverextensions/apache2/include/apr_thread_pool.h
-webserverextensions/apache2/include/apr_sha1.h
+webserverextensions/apache2/include/apr_dbm.h
+webserverextensions/apache2/include/apr_dso.h
+webserverextensions/apache2/include/apr_encode.h
+webserverextensions/apache2/include/apr_env.h
+webserverextensions/apache2/include/apr_errno.h
+webserverextensions/apache2/include/apr_escape.h
+webserverextensions/apache2/include/apr_file_info.h
+webserverextensions/apache2/include/apr_file_io.h
 webserverextensions/apache2/include/apr_fnmatch.h
-webserverextensions/apache2/include/apr_env.h
+webserverextensions/apache2/include/apr_general.h
+webserverextensions/apache2/include/apr_getopt.h
+webserverextensions/apache2/include/apr_global_mutex.h
+webserverextensions/apache2/include/apr_hash.h
+webserverextensions/apache2/include/apr_hooks.h
 webserverextensions/apache2/include/apr_inherit.h
-webserverextensions/apache2/include/mod_ssl.h
-webserverextensions/apache2/include/ap_socache.h
-webserverextensions/apache2/include/mod_http2.h
-webserverextensions/apache2/include/mod_dbd.h
-webserverextensions/apache2/include/apr_uri.h
-webserverextensions/apache2/include/apr_global_mutex.h
-webserverextensions/apache2/include/apr_crypto.h
+webserverextensions/apache2/include/apr_ldap.h
+webserverextensions/apache2/include/apr_ldap_init.h
+webserverextensions/apache2/include/apr_ldap_option.h
+webserverextensions/apache2/include/apr_ldap_rebind.h
+webserverextensions/apache2/include/apr_ldap_url.h
+webserverextensions/apache2/include/apr_lib.h
+webserverextensions/apache2/include/apr_md4.h
+webserverextensions/apache2/include/apr_md5.h
+webserverextensions/apache2/include/apr_memcache.h
+webserverextensions/apache2/include/apr_mmap.h
+webserverextensions/apache2/include/apr_network_io.h
+webserverextensions/apache2/include/apr_optional.h
+webserverextensions/apache2/include/apr_optional_hooks.h
+webserverextensions/apache2/include/apr_perms_set.h
+webserverextensions/apache2/include/apr_poll.h
+webserverextensions/apache2/include/apr_pools.h
+webserverextensions/apache2/include/apr_portable.h
 webserverextensions/apache2/include/apr_proc_mutex.h
-webserverextensions/apache2/include/apr_dso.h
-webserverextensions/apache2/include/mod_session.h
-webserverextensions/apache2/include/apr_optional.h
-webserverextensions/apache2/include/apr_file_io.h
-webserverextensions/apache2/include/util_varbuf.h
+webserverextensions/apache2/include/apr_queue.h
+webserverextensions/apache2/include/apr_random.h
+webserverextensions/apache2/include/apr_redis.h
 webserverextensions/apache2/include/apr_reslist.h
-webserverextensions/apache2/include/ap_expr.h
-webserverextensions/apache2/include/apr_thread_cond.h
-webserverextensions/apache2/include/apr_ldap_url.h
+webserverextensions/apache2/include/apr_ring.h
+webserverextensions/apache2/include/apr_rmm.h
+webserverextensions/apache2/include/apr_sdbm.h
+webserverextensions/apache2/include/apr_sha1.h
+webserverextensions/apache2/include/apr_shm.h
 webserverextensions/apache2/include/apr_signal.h
-webserverextensions/apache2/include/apu.h
-webserverextensions/apache2/include/mod_xml2enc.h
-webserverextensions/apache2/include/apr_hooks.h
-webserverextensions/apache2/include/apr_want.h
+webserverextensions/apache2/include/apr_siphash.h
+webserverextensions/apache2/include/apr_skiplist.h
+webserverextensions/apache2/include/apr_strings.h
+webserverextensions/apache2/include/apr_strmatch.h
+webserverextensions/apache2/include/apr_support.h
 webserverextensions/apache2/include/apr_tables.h
-webserverextensions/apache2/include/ap_config_auto.h
-webserverextensions/apache2/include/ap_config.h
-webserverextensions/apache2/include/ap_provider.h
-webserverextensions/apache2/include/mod_proxy.h
+webserverextensions/apache2/include/apr_thread_cond.h
+webserverextensions/apache2/include/apr_thread_mutex.h
+webserverextensions/apache2/include/apr_thread_pool.h
+webserverextensions/apache2/include/apr_thread_proc.h
+webserverextensions/apache2/include/apr_thread_rwlock.h
+webserverextensions/apache2/include/apr_time.h
+webserverextensions/apache2/include/apr_uri.h
+webserverextensions/apache2/include/apr_user.h
 webserverextensions/apache2/include/apr_uuid.h
-webserverextensions/apache2/include/apr_allocator.h
-webserverextensions/apache2/include/apr_thread_mutex.h
-webserverextensions/apache2/include/apr_mmap.h
+webserverextensions/apache2/include/apr_version.h
+webserverextensions/apache2/include/apr_want.h
+webserverextensions/apache2/include/apr_xlate.h
+webserverextensions/apache2/include/apr_xml.h
+webserverextensions/apache2/include/apu.h
+webserverextensions/apache2/include/apu_errno.h
+webserverextensions/apache2/include/apu_version.h
+webserverextensions/apache2/include/apu_want.h
+webserverextensions/apache2/include/cache_common.h
+webserverextensions/apache2/include/heartbeat.h
+webserverextensions/apache2/include/http_config.h
+webserverextensions/apache2/include/http_connection.h
+webserverextensions/apache2/include/http_core.h
+webserverextensions/apache2/include/http_log.h
+webserverextensions/apache2/include/http_main.h
+webserverextensions/apache2/include/http_protocol.h
+webserverextensions/apache2/include/http_request.h
+webserverextensions/apache2/include/http_ssl.h
+webserverextensions/apache2/include/http_vhost.h
+webserverextensions/apache2/include/httpd.h
+webserverextensions/apache2/include/mod_auth.h
 webserverextensions/apache2/include/mod_cache.h
-webserverextensions/apache2/include/apr_strings.h
-webserverextensions/apache2/include/apr_support.h
-webserverextensions/apache2/include/ap_compat.h
+webserverextensions/apache2/include/mod_cgi.h
+webserverextensions/apache2/include/mod_core.h
+webserverextensions/apache2/include/mod_dav.h
+webserverextensions/apache2/include/mod_dbd.h
+webserverextensions/apache2/include/mod_http2.h
+webserverextensions/apache2/include/mod_include.h
+webserverextensions/apache2/include/mod_log_config.h
+webserverextensions/apache2/include/mod_proxy.h
+webserverextensions/apache2/include/mod_request.h
+webserverextensions/apache2/include/mod_rewrite.h
+webserverextensions/apache2/include/mod_session.h
 webserverextensions/apache2/include/mod_so.h
-webserverextensions/apache2/include/mod_watchdog.h
-webserverextensions/apache2/include/mod_rewrite.h
-webserverextensions/apache2/include/ap_regkey.h
-webserverextensions/apache2/include/ap_slotmem.h
-webserverextensions/apache2/include/apr_atomic.h
-webserverextensions/apache2/include/apr_encode.h
-webserverextensions/apache2/include/util_md5.h
-webserverextensions/apache2/include/http_protocol.h
-webserverextensions/apache2/include/apr_siphash.h
-webserverextensions/apache2/include/apr_cstr.h
+webserverextensions/apache2/include/mod_ssl.h
+webserverextensions/apache2/include/mod_ssl_openssl.h
 webserverextensions/apache2/include/mod_status.h
-webserverextensions/apache2/include/apu_version.h
-webserverextensions/apache2/include/apr_random.h
-webserverextensions/apache2/include/ap_config_layout.h
 webserverextensions/apache2/include/mod_unixd.h
-webserverextensions/apache2/include/http_ssl.h
-webserverextensions/apache2/include/apu_want.h
-webserverextensions/apache2/include/apr_network_io.h
-webserverextensions/apache2/include/ap_hooks.h
-webserverextensions/apache2/include/mod_auth.h
+webserverextensions/apache2/include/mod_watchdog.h
+webserverextensions/apache2/include/mod_xml2enc.h
+webserverextensions/apache2/include/mpm_common.h
+webserverextensions/apache2/include/os.h
+webserverextensions/apache2/include/scoreboard.h
+webserverextensions/apache2/include/unixd.h
 webserverextensions/apache2/include/util_cfgtree.h
-webserverextensions/apache2/include/apr_queue.h
-webserverextensions/apache2/include/apr_shm.h
-webserverextensions/apache2/include/util_time.h
-webserverextensions/apache2/include/apr_ldap.h
-webserverextensions/apache2/include/apr_rmm.h
-webserverextensions/apache2/include/apr_anylock.h
-webserverextensions/apache2/include/http_log.h
+webserverextensions/apache2/include/util_charset.h
+webserverextensions/apache2/include/util_cookies.h
 webserverextensions/apache2/include/util_ebcdic.h
-webserverextensions/apache2/include/unixd.h
-webserverextensions/apache2/include/apr_errno.h
-webserverextensions/apache2/include/apr_buckets.h
-webserverextensions/apache2/include/util_charset.h
-webserverextensions/apache2/include/httpd.h
-webserverextensions/apache2/include/apr_strmatch.h
+webserverextensions/apache2/include/util_fcgi.h
 webserverextensions/apache2/include/util_filter.h
+webserverextensions/apache2/include/util_ldap.h
+webserverextensions/apache2/include/util_md5.h
 webserverextensions/apache2/include/util_mutex.h
-webserverextensions/apache2/include/scoreboard.h
-webserverextensions/apache2/include/util_fcgi.h
-webserverextensions/apache2/include/http_main.h
-webserverextensions/apache2/include/ap_release.h
-webserverextensions/apache2/include/apr_skiplist.h
-webserverextensions/apache2/include/apr_dbm.h
-webserverextensions/apache2/include/apr_sdbm.h
-webserverextensions/apache2/include/apr_base64.h
-webserverextensions/apache2/include/apr_thread_rwlock.h
-webserverextensions/apache2/include/mod_dav.h
-webserverextensions/apache2/include/apr_perms_set.h
-webserverextensions/apache2/include/mpm_common.h
-webserverextensions/apache2/include/apr_escape.h
-webserverextensions/apache2/include/apr_date.h
-webserverextensions/apache2/include/mod_request.h
-webserverextensions/apache2/include/apr_portable.h
-webserverextensions/apache2/include/apr_file_info.h
-webserverextensions/apache2/include/http_vhost.h
-webserverextensions/apache2/include/os.h
-webserverextensions/apache2/include/apr_version.h
-webserverextensions/apache2/include/apr_hash.h
-webserverextensions/apache2/include/heartbeat.h
-webserverextensions/apache2/include/apr_md4.h
-webserverextensions/apache2/include/apr_user.h
-webserverextensions/apache2/include/http_connection.h
-webserverextensions/apache2/include/apr_redis.h
-webserverextensions/apache2/include/apr_ldap_init.h
-webserverextensions/apache2/include/apr_ring.h
-webserverextensions/apache2/include/apr_ldap_rebind.h
-webserverextensions/apache2/include/mod_include.h
-webserverextensions/apache2/include/apr_thread_proc.h
-webserverextensions/apache2/include/apr_getopt.h
-webserverextensions/apache2/include/apr_poll.h
 webserverextensions/apache2/include/util_script.h
-webserverextensions/apache2/include/apr_optional_hooks.h
-webserverextensions/apache2/include/apr_lib.h
-webserverextensions/apache2/include/cache_common.h
-webserverextensions/apache2/include/apache_noprobes.h
-webserverextensions/apache2/include/apr_pools.h
-webserverextensions/apache2/include/apr_memcache.h
-webserverextensions/apache2/include/apr_ldap_option.h
-webserverextensions/apache2/include/apr_general.h
+webserverextensions/apache2/include/util_time.h
+webserverextensions/apache2/include/util_varbuf.h
+webserverextensions/apache2/include/util_xml.h
+webserverextensions/apache2/lib/
+webserverextensions/apache2/lib/apr.exp
+webserverextensions/apache2/lib/aprutil.exp
+webserverextensions/apache2/lib/libapr-1.a
+webserverextensions/apache2/lib/libapr-1.la
+webserverextensions/apache2/lib/libapr-1.so
+webserverextensions/apache2/lib/libapr-1.so.0
+webserverextensions/apache2/lib/libapr-1.so.0.7.6
+webserverextensions/apache2/lib/libaprutil-1.a
+webserverextensions/apache2/lib/libaprutil-1.la
+webserverextensions/apache2/lib/libaprutil-1.so
+webserverextensions/apache2/lib/libaprutil-1.so.0
+webserverextensions/apache2/lib/libaprutil-1.so.0.6.5
+webserverextensions/apache2/lib/pkgconfig/
+webserverextensions/apache2/lib/pkgconfig/apr-1.pc
+webserverextensions/apache2/lib/pkgconfig/apr-util-1.pc
+webserverextensions/apache2/logs/
 webserverextensions/apache2/man/
 webserverextensions/apache2/man/man1/
+webserverextensions/apache2/man/man1/ab.1
+webserverextensions/apache2/man/man1/apxs.1
+webserverextensions/apache2/man/man1/dbmmanage.1
 webserverextensions/apache2/man/man1/htdbm.1
+webserverextensions/apache2/man/man1/htdigest.1
+webserverextensions/apache2/man/man1/htpasswd.1
 webserverextensions/apache2/man/man1/httxt2dbm.1
-webserverextensions/apache2/man/man1/htdigest.1
-webserverextensions/apache2/man/man1/apxs.1
-webserverextensions/apache2/man/man1/dbmmanage.1
-webserverextensions/apache2/man/man1/ab.1
 webserverextensions/apache2/man/man1/logresolve.1
-webserverextensions/apache2/man/man1/htpasswd.1
 webserverextensions/apache2/man/man8/
+webserverextensions/apache2/man/man8/apachectl.8
 webserverextensions/apache2/man/man8/fcgistarter.8
+webserverextensions/apache2/man/man8/htcacheclean.8
+webserverextensions/apache2/man/man8/httpd.8
+webserverextensions/apache2/man/man8/rotatelogs.8
 webserverextensions/apache2/man/man8/suexec.8
-webserverextensions/apache2/man/man8/rotatelogs.8
-webserverextensions/apache2/man/man8/httpd.8
-webserverextensions/apache2/man/man8/htcacheclean.8
-webserverextensions/apache2/man/man8/apachectl.8
 webserverextensions/apache2/manual/
-webserverextensions/apache2/manual/invoking.html.ja.utf8
-webserverextensions/apache2/manual/license.html.en
-webserverextensions/apache2/manual/stopping.html.ja.utf8
-webserverextensions/apache2/manual/sitemap.html.en
-webserverextensions/apache2/manual/logs.html.ja.utf8
-webserverextensions/apache2/manual/content-negotiation.html.tr.utf8
-webserverextensions/apache2/manual/server-wide.html
-webserverextensions/apache2/manual/platform/
-webserverextensions/apache2/manual/platform/perf-hp.html.ko.euc-kr
-webserverextensions/apache2/manual/platform/windows.html.fr.utf8
-webserverextensions/apache2/manual/platform/netware.html.en
-webserverextensions/apache2/manual/platform/perf-hp.html.en
-webserverextensions/apache2/manual/platform/rpm.html
-webserverextensions/apache2/manual/platform/rpm.html.fr.utf8
-webserverextensions/apache2/manual/platform/ebcdic.html.ko.euc-kr
-webserverextensions/apache2/manual/platform/netware.html.fr.utf8
-webserverextensions/apache2/manual/platform/perf-hp.html.fr.utf8
-webserverextensions/apache2/manual/platform/windows.html.ko.euc-kr
-webserverextensions/apache2/manual/platform/netware.html.ko.euc-kr
-webserverextensions/apache2/manual/platform/ebcdic.html.en
-webserverextensions/apache2/manual/platform/index.html.ko.euc-kr
-webserverextensions/apache2/manual/platform/win_compiling.html.ko.euc-kr
-webserverextensions/apache2/manual/platform/index.html.zh-cn.utf8
-webserverextensions/apache2/manual/platform/windows.html.en
-webserverextensions/apache2/manual/platform/index.html.en
-webserverextensions/apache2/manual/platform/index.html.fr.utf8
-webserverextensions/apache2/manual/platform/rpm.html.en
-webserverextensions/apache2/manual/platform/win_compiling.html.fr.utf8
-webserverextensions/apache2/manual/platform/win_compiling.html.en
-webserverextensions/apache2/manual/invoking.html.es
-webserverextensions/apache2/manual/dso.html.ja.utf8
-webserverextensions/apache2/manual/new_features_2_0.html.fr.utf8
-webserverextensions/apache2/manual/stopping.html.ko.euc-kr
-webserverextensions/apache2/manual/handler.html.en
-webserverextensions/apache2/manual/expr.html
+webserverextensions/apache2/manual/BUILDING
+webserverextensions/apache2/manual/LICENSE
+webserverextensions/apache2/manual/bind.html
+webserverextensions/apache2/manual/bind.html.de
 webserverextensions/apache2/manual/bind.html.en
-webserverextensions/apache2/manual/new_features_2_0.html.de
-webserverextensions/apache2/manual/mpm.html
-webserverextensions/apache2/manual/dso.html.fr.utf8
+webserverextensions/apache2/manual/bind.html.fr.utf8
+webserverextensions/apache2/manual/bind.html.ja.utf8
+webserverextensions/apache2/manual/bind.html.ko.euc-kr
+webserverextensions/apache2/manual/bind.html.pt-br.utf8
+webserverextensions/apache2/manual/bind.html.tr.utf8
+webserverextensions/apache2/manual/caching.html
+webserverextensions/apache2/manual/caching.html.en
+webserverextensions/apache2/manual/caching.html.fr.utf8
+webserverextensions/apache2/manual/caching.html.tr.utf8
+webserverextensions/apache2/manual/configuring.html
+webserverextensions/apache2/manual/configuring.html.de
+webserverextensions/apache2/manual/configuring.html.en
+webserverextensions/apache2/manual/configuring.html.fr.utf8
+webserverextensions/apache2/manual/configuring.html.ja.utf8
+webserverextensions/apache2/manual/configuring.html.ko.euc-kr
+webserverextensions/apache2/manual/configuring.html.tr.utf8
-webserverextensions/apache2/manual/upgrading.html.fr.utf8
-webserverextensions/apache2/manual/filter.html.ja.utf8
-webserverextensions/apache2/manual/install.html.es
-webserverextensions/apache2/manual/server-wide.html.en
-webserverextensions/apache2/manual/dns-caveats.html
-webserverextensions/apache2/manual/BUILDING
-webserverextensions/apache2/manual/sitemap.html.de
-webserverextensions/apache2/manual/stopping.html.de
+webserverextensions/apache2/manual/content-negotiation.html.en
+webserverextensions/apache2/manual/content-negotiation.html.fr.utf8
+webserverextensions/apache2/manual/content-negotiation.html.ja.utf8
+webserverextensions/apache2/manual/content-negotiation.html.ko.euc-kr
+webserverextensions/apache2/manual/content-negotiation.html.tr.utf8
+webserverextensions/apache2/manual/convenience.map
 webserverextensions/apache2/manual/custom-error.html
-webserverextensions/apache2/manual/new_features_2_4.html
-webserverextensions/apache2/manual/configuring.html.tr.utf8
-webserverextensions/apache2/manual/getting-started.html.ru.utf8
-webserverextensions/apache2/manual/suexec.html.en
-webserverextensions/apache2/manual/sitemap.html.ko.euc-kr
-webserverextensions/apache2/manual/stopping.html.es
-webserverextensions/apache2/manual/new_features_2_2.html.fr.utf8
+webserverextensions/apache2/manual/custom-error.html.en
+webserverextensions/apache2/manual/custom-error.html.es
+webserverextensions/apache2/manual/custom-error.html.fr.utf8
+webserverextensions/apache2/manual/custom-error.html.ja.utf8
+webserverextensions/apache2/manual/custom-error.html.ko.euc-kr
+webserverextensions/apache2/manual/custom-error.html.tr.utf8
 webserverextensions/apache2/manual/developer/
-webserverextensions/apache2/manual/developer/request.html
-webserverextensions/apache2/manual/developer/modguide.html.en
-webserverextensions/apache2/manual/developer/modules.html.en
-webserverextensions/apache2/manual/developer/new_api_2_4.html.en
-webserverextensions/apache2/manual/developer/documenting.html
 webserverextensions/apache2/manual/developer/API.html
-webserverextensions/apache2/manual/developer/modules.html.ja.utf8
 webserverextensions/apache2/manual/developer/API.html.en
-webserverextensions/apache2/manual/developer/thread_safety.html
-webserverextensions/apache2/manual/developer/filters.html
 webserverextensions/apache2/manual/developer/debugging.html
-webserverextensions/apache2/manual/developer/thread_safety.html.en
-webserverextensions/apache2/manual/developer/index.html.zh-cn.utf8
-webserverextensions/apache2/manual/developer/index.html.en
 webserverextensions/apache2/manual/developer/debugging.html.en
-webserverextensions/apache2/manual/developer/output-filters.html
+webserverextensions/apache2/manual/developer/documenting.html
+webserverextensions/apache2/manual/developer/documenting.html.en
 webserverextensions/apache2/manual/developer/documenting.html.zh-cn.utf8
-webserverextensions/apache2/manual/developer/output-filters.html.en
-webserverextensions/apache2/manual/developer/documenting.html.en
+webserverextensions/apache2/manual/developer/filters.html
+webserverextensions/apache2/manual/developer/filters.html.en
 webserverextensions/apache2/manual/developer/hooks.html
+webserverextensions/apache2/manual/developer/hooks.html.en
+webserverextensions/apache2/manual/developer/index.html.en
+webserverextensions/apache2/manual/developer/index.html.zh-cn.utf8
+webserverextensions/apache2/manual/developer/mod_example_1.c
+webserverextensions/apache2/manual/developer/mod_example_2.c
+webserverextensions/apache2/manual/developer/modguide.html
+webserverextensions/apache2/manual/developer/modguide.html.en
+webserverextensions/apache2/manual/developer/modules.html
+webserverextensions/apache2/manual/developer/modules.html.en
+webserverextensions/apache2/manual/developer/modules.html.ja.utf8
+webserverextensions/apache2/manual/developer/new_api_2_4.html
+webserverextensions/apache2/manual/developer/new_api_2_4.html.en
+webserverextensions/apache2/manual/developer/output-filters.html
+webserverextensions/apache2/manual/developer/output-filters.html.en
+webserverextensions/apache2/manual/developer/request.html
 webserverextensions/apache2/manual/developer/request.html.en
-webserverextensions/apache2/manual/developer/filters.html.en
-webserverextensions/apache2/manual/developer/hooks.html.en
+webserverextensions/apache2/manual/developer/thread_safety.html
+webserverextensions/apache2/manual/developer/thread_safety.html.en
+webserverextensions/apache2/manual/dns-caveats.html
+webserverextensions/apache2/manual/dns-caveats.html.en
+webserverextensions/apache2/manual/dns-caveats.html.fr.utf8
+webserverextensions/apache2/manual/dns-caveats.html.ja.utf8
+webserverextensions/apache2/manual/dns-caveats.html.ko.euc-kr
+webserverextensions/apache2/manual/dns-caveats.html.tr.utf8
+webserverextensions/apache2/manual/dso.html
+webserverextensions/apache2/manual/dso.html.en
+webserverextensions/apache2/manual/dso.html.fr.utf8
+webserverextensions/apache2/manual/dso.html.ja.utf8
+webserverextensions/apache2/manual/dso.html.ko.euc-kr
+webserverextensions/apache2/manual/dso.html.tr.utf8
+webserverextensions/apache2/manual/env.html
+webserverextensions/apache2/manual/env.html.en
+webserverextensions/apache2/manual/env.html.fr.utf8
+webserverextensions/apache2/manual/env.html.ja.utf8
+webserverextensions/apache2/manual/env.html.ko.euc-kr
+webserverextensions/apache2/manual/env.html.tr.utf8
+webserverextensions/apache2/manual/expr.html
+webserverextensions/apache2/manual/expr.html.en
+webserverextensions/apache2/manual/expr.html.fr.utf8
+webserverextensions/apache2/manual/faq/
+webserverextensions/apache2/manual/faq/index.html
+webserverextensions/apache2/manual/faq/index.html.en
+webserverextensions/apache2/manual/faq/index.html.es
+webserverextensions/apache2/manual/faq/index.html.fr.utf8
+webserverextensions/apache2/manual/faq/index.html.tr.utf8
+webserverextensions/apache2/manual/faq/index.html.zh-cn.utf8
+webserverextensions/apache2/manual/filter.html
+webserverextensions/apache2/manual/filter.html.en
+webserverextensions/apache2/manual/filter.html.es
+webserverextensions/apache2/manual/filter.html.fr.utf8
+webserverextensions/apache2/manual/filter.html.ja.utf8
+webserverextensions/apache2/manual/filter.html.ko.euc-kr
+webserverextensions/apache2/manual/filter.html.pt-br.utf8
+webserverextensions/apache2/manual/filter.html.tr.utf8
+webserverextensions/apache2/manual/getting-started.html
+webserverextensions/apache2/manual/getting-started.html.en
+webserverextensions/apache2/manual/getting-started.html.fr.utf8
+webserverextensions/apache2/manual/getting-started.html.ru.utf8
+webserverextensions/apache2/manual/glossary.html
+webserverextensions/apache2/manual/glossary.html.de
+webserverextensions/apache2/manual/glossary.html.en
+webserverextensions/apache2/manual/glossary.html.es
+webserverextensions/apache2/manual/glossary.html.fr.utf8
+webserverextensions/apache2/manual/glossary.html.ja.utf8
+webserverextensions/apache2/manual/glossary.html.ko.euc-kr
+webserverextensions/apache2/manual/glossary.html.tr.utf8
+webserverextensions/apache2/manual/handler.html
+webserverextensions/apache2/manual/handler.html.en
+webserverextensions/apache2/manual/handler.html.es
+webserverextensions/apache2/manual/handler.html.fr.utf8
+webserverextensions/apache2/manual/handler.html.ja.utf8
+webserverextensions/apache2/manual/handler.html.ko.euc-kr
+webserverextensions/apache2/manual/handler.html.tr.utf8
+webserverextensions/apache2/manual/handler.html.zh-cn.utf8
+webserverextensions/apache2/manual/howto/
+webserverextensions/apache2/manual/howto/access.html
+webserverextensions/apache2/manual/howto/access.html.en
+webserverextensions/apache2/manual/howto/access.html.es
+webserverextensions/apache2/manual/howto/access.html.fr.utf8
+webserverextensions/apache2/manual/howto/auth.html
+webserverextensions/apache2/manual/howto/auth.html.en
+webserverextensions/apache2/manual/howto/auth.html.es
+webserverextensions/apache2/manual/howto/auth.html.fr.utf8
+webserverextensions/apache2/manual/howto/auth.html.ja.utf8
+webserverextensions/apache2/manual/howto/auth.html.ko.euc-kr
+webserverextensions/apache2/manual/howto/auth.html.tr.utf8
+webserverextensions/apache2/manual/howto/cgi.html
+webserverextensions/apache2/manual/howto/cgi.html.en
+webserverextensions/apache2/manual/howto/cgi.html.es
+webserverextensions/apache2/manual/howto/cgi.html.fr.utf8
+webserverextensions/apache2/manual/howto/cgi.html.ja.utf8
+webserverextensions/apache2/manual/howto/cgi.html.ko.euc-kr
+webserverextensions/apache2/manual/howto/htaccess.html
+webserverextensions/apache2/manual/howto/htaccess.html.en
+webserverextensions/apache2/manual/howto/htaccess.html.es
+webserverextensions/apache2/manual/howto/htaccess.html.fr.utf8
+webserverextensions/apache2/manual/howto/htaccess.html.ja.utf8
+webserverextensions/apache2/manual/howto/htaccess.html.ko.euc-kr
+webserverextensions/apache2/manual/howto/htaccess.html.pt-br
+webserverextensions/apache2/manual/howto/htaccess.html.pt-br.utf8
+webserverextensions/apache2/manual/howto/http2.html
+webserverextensions/apache2/manual/howto/http2.html.en
+webserverextensions/apache2/manual/howto/http2.html.es
+webserverextensions/apache2/manual/howto/http2.html.fr.utf8
+webserverextensions/apache2/manual/howto/index.html
+webserverextensions/apache2/manual/howto/index.html.en
+webserverextensions/apache2/manual/howto/index.html.es
+webserverextensions/apache2/manual/howto/index.html.fr.utf8
+webserverextensions/apache2/manual/howto/index.html.ja.utf8
+webserverextensions/apache2/manual/howto/index.html.ko.euc-kr
+webserverextensions/apache2/manual/howto/index.html.zh-cn.utf8
+webserverextensions/apache2/manual/howto/public_html.html
+webserverextensions/apache2/manual/howto/public_html.html.en
+webserverextensions/apache2/manual/howto/public_html.html.es
+webserverextensions/apache2/manual/howto/public_html.html.fr.utf8
+webserverextensions/apache2/manual/howto/public_html.html.ja.utf8
+webserverextensions/apache2/manual/howto/public_html.html.ko.euc-kr
+webserverextensions/apache2/manual/howto/public_html.html.tr.utf8
+webserverextensions/apache2/manual/howto/reverse_proxy.html
+webserverextensions/apache2/manual/howto/reverse_proxy.html.en
+webserverextensions/apache2/manual/howto/reverse_proxy.html.fr.utf8
+webserverextensions/apache2/manual/howto/ssi.html
+webserverextensions/apache2/manual/howto/ssi.html.en
+webserverextensions/apache2/manual/howto/ssi.html.es
+webserverextensions/apache2/manual/howto/ssi.html.fr.utf8
+webserverextensions/apache2/manual/howto/ssi.html.ja.utf8
+webserverextensions/apache2/manual/howto/ssi.html.ko.euc-kr
+webserverextensions/apache2/manual/images/
+webserverextensions/apache2/manual/images/README.md
+webserverextensions/apache2/manual/images/apache_header.gif
+webserverextensions/apache2/manual/images/bal-man-b.png
+webserverextensions/apache2/manual/images/bal-man-w.png
+webserverextensions/apache2/manual/images/bal-man.png
+webserverextensions/apache2/manual/images/build_a_mod_2.png
+webserverextensions/apache2/manual/images/build_a_mod_3.png
+webserverextensions/apache2/manual/images/build_a_mod_4.png
+webserverextensions/apache2/manual/images/caching_fig1.gif
+webserverextensions/apache2/manual/images/caching_fig1.png
+webserverextensions/apache2/manual/images/caching_fig1.tr.png
+webserverextensions/apache2/manual/images/custom_errordocs.png
+webserverextensions/apache2/manual/images/down.gif
+webserverextensions/apache2/manual/images/favicon.ico
+webserverextensions/apache2/manual/images/favicon.png
+webserverextensions/apache2/manual/images/feather.gif
+webserverextensions/apache2/manual/images/feather.png
+webserverextensions/apache2/manual/images/filter_arch.png
+webserverextensions/apache2/manual/images/filter_arch.pt-br.png
+webserverextensions/apache2/manual/images/filter_arch.tr.png
+webserverextensions/apache2/manual/images/home.gif
+webserverextensions/apache2/manual/images/index.gif
+webserverextensions/apache2/manual/images/left.gif
+webserverextensions/apache2/manual/images/mod_filter_new.gif
+webserverextensions/apache2/manual/images/mod_filter_new.png
+webserverextensions/apache2/manual/images/mod_filter_new.pt-br.png
+webserverextensions/apache2/manual/images/mod_filter_new.tr.png
+webserverextensions/apache2/manual/images/mod_filter_old.gif
+webserverextensions/apache2/manual/images/mod_filter_old.png
+webserverextensions/apache2/manual/images/mod_rewrite_fig1.png
+webserverextensions/apache2/manual/images/mod_rewrite_fig1.svg
+webserverextensions/apache2/manual/images/mod_rewrite_fig2.png
+webserverextensions/apache2/manual/images/mod_rewrite_fig2.svg
+webserverextensions/apache2/manual/images/pixel.gif
+webserverextensions/apache2/manual/images/reverse-proxy-arch.png
+webserverextensions/apache2/manual/images/rewrite_backreferences.png
+webserverextensions/apache2/manual/images/rewrite_backreferences.svg
+webserverextensions/apache2/manual/images/rewrite_l_flag_looping.png
+webserverextensions/apache2/manual/images/rewrite_l_flag_looping.svg
+webserverextensions/apache2/manual/images/rewrite_module_order.png
+webserverextensions/apache2/manual/images/rewrite_module_order.svg
+webserverextensions/apache2/manual/images/rewrite_path_stripping.png
+webserverextensions/apache2/manual/images/rewrite_path_stripping.svg
+webserverextensions/apache2/manual/images/rewrite_process_uri.png
+webserverextensions/apache2/manual/images/rewrite_process_uri.svg
+webserverextensions/apache2/manual/images/rewrite_simplified_overview.png
+webserverextensions/apache2/manual/images/rewrite_simplified_overview.svg
+webserverextensions/apache2/manual/images/right.gif
+webserverextensions/apache2/manual/images/ssl_intro_fig1.gif
+webserverextensions/apache2/manual/images/ssl_intro_fig1.png
+webserverextensions/apache2/manual/images/ssl_intro_fig2.gif
+webserverextensions/apache2/manual/images/ssl_intro_fig2.png
+webserverextensions/apache2/manual/images/ssl_intro_fig3.gif
+webserverextensions/apache2/manual/images/ssl_intro_fig3.png
+webserverextensions/apache2/manual/images/sub.gif
+webserverextensions/apache2/manual/images/syntax_rewritecond.png
+webserverextensions/apache2/manual/images/syntax_rewritecond.svg
+webserverextensions/apache2/manual/images/syntax_rewriterule.png
+webserverextensions/apache2/manual/images/syntax_rewriterule.svg
+webserverextensions/apache2/manual/images/up.gif
+webserverextensions/apache2/manual/index.html
+webserverextensions/apache2/manual/index.html.da
+webserverextensions/apache2/manual/index.html.de
+webserverextensions/apache2/manual/index.html.en
+webserverextensions/apache2/manual/index.html.es
+webserverextensions/apache2/manual/index.html.fr.utf8
+webserverextensions/apache2/manual/index.html.ja.utf8
+webserverextensions/apache2/manual/index.html.ko.euc-kr
+webserverextensions/apache2/manual/index.html.pt-br
+webserverextensions/apache2/manual/index.html.pt-br.utf8
+webserverextensions/apache2/manual/index.html.ru.utf8
+webserverextensions/apache2/manual/index.html.tr.utf8
+webserverextensions/apache2/manual/index.html.zh-cn.utf8
+webserverextensions/apache2/manual/install.html
+webserverextensions/apache2/manual/install.html.de
+webserverextensions/apache2/manual/install.html.en
+webserverextensions/apache2/manual/install.html.es
+webserverextensions/apache2/manual/install.html.fr.utf8
+webserverextensions/apache2/manual/install.html.ja.utf8
+webserverextensions/apache2/manual/install.html.ko.euc-kr
+webserverextensions/apache2/manual/install.html.pt-br.utf8
+webserverextensions/apache2/manual/install.html.tr.utf8
+webserverextensions/apache2/manual/invoking.html
+webserverextensions/apache2/manual/invoking.html.de
+webserverextensions/apache2/manual/invoking.html.en
+webserverextensions/apache2/manual/invoking.html.es
+webserverextensions/apache2/manual/invoking.html.fr.utf8
+webserverextensions/apache2/manual/invoking.html.ja.utf8
+webserverextensions/apache2/manual/invoking.html.ko.euc-kr
+webserverextensions/apache2/manual/invoking.html.pt-br.utf8
+webserverextensions/apache2/manual/invoking.html.tr.utf8
+webserverextensions/apache2/manual/license.html
+webserverextensions/apache2/manual/license.html.en
+webserverextensions/apache2/manual/logs.html
 webserverextensions/apache2/manual/logs.html.en
-webserverextensions/apache2/manual/custom-error.html.ja.utf8
-webserverextensions/apache2/manual/filter.html.tr.utf8
-webserverextensions/apache2/manual/rewrite/
-webserverextensions/apache2/manual/rewrite/advanced.html
-webserverextensions/apache2/manual/rewrite/rewritemap.html.en
-webserverextensions/apache2/manual/rewrite/htaccess.html
-webserverextensions/apache2/manual/rewrite/htaccess.html.en
-webserverextensions/apache2/manual/rewrite/tech.html
-webserverextensions/apache2/manual/rewrite/intro.html
-webserverextensions/apache2/manual/rewrite/remapping.html
-webserverextensions/apache2/manual/rewrite/avoid.html
-webserverextensions/apache2/manual/rewrite/avoid.html.en
-webserverextensions/apache2/manual/rewrite/flags.html.en
-webserverextensions/apache2/manual/rewrite/tech.html.fr.utf8
-webserverextensions/apache2/manual/rewrite/remapping.html.fr.utf8
-webserverextensions/apache2/manual/rewrite/rewritemap.html.fr.utf8
-webserverextensions/apache2/manual/rewrite/proxy.html
-webserverextensions/apache2/manual/rewrite/vhosts.html.fr.utf8
-webserverextensions/apache2/manual/rewrite/index.html.tr.utf8
-webserverextensions/apache2/manual/rewrite/index.html.zh-cn.utf8
-webserverextensions/apache2/manual/rewrite/vhosts.html.en
-webserverextensions/apache2/manual/rewrite/index.html.en
-webserverextensions/apache2/manual/rewrite/index.html.fr.utf8
-webserverextensions/apache2/manual/rewrite/tech.html.en
-webserverextensions/apache2/manual/rewrite/intro.html.fr.utf8
-webserverextensions/apache2/manual/rewrite/htaccess.html.fr.utf8
-webserverextensions/apache2/manual/rewrite/remapping.html.en
-webserverextensions/apache2/manual/rewrite/proxy.html.en
-webserverextensions/apache2/manual/rewrite/advanced.html.fr.utf8
-webserverextensions/apache2/manual/rewrite/advanced.html.en
-webserverextensions/apache2/manual/rewrite/access.html
-webserverextensions/apache2/manual/rewrite/avoid.html.fr.utf8
-webserverextensions/apache2/manual/rewrite/access.html.fr.utf8
-webserverextensions/apache2/manual/rewrite/flags.html.fr.utf8
-webserverextensions/apache2/manual/rewrite/proxy.html.fr.utf8
-webserverextensions/apache2/manual/rewrite/access.html.en
-webserverextensions/apache2/manual/rewrite/intro.html.en
-webserverextensions/apache2/manual/style/
-webserverextensions/apache2/manual/style/lang.dtd
-webserverextensions/apache2/manual/style/common.dtd
-webserverextensions/apache2/manual/style/scripts/
-webserverextensions/apache2/manual/style/scripts/MINIFY
-webserverextensions/apache2/manual/style/scripts/prettify.min.js
-webserverextensions/apache2/manual/style/scripts/prettify.js
-webserverextensions/apache2/manual/style/sitemap.dtd
-webserverextensions/apache2/manual/style/modulesynopsis.dtd
-webserverextensions/apache2/manual/style/lang/
-webserverextensions/apache2/manual/style/css/
-webserverextensions/apache2/manual/style/css/manual-chm.css
-webserverextensions/apache2/manual/style/css/manual-print.css
-webserverextensions/apache2/manual/style/css/prettify.css
-webserverextensions/apache2/manual/style/css/manual-loose-100pc.css
-webserverextensions/apache2/manual/style/css/manual.css
-webserverextensions/apache2/manual/style/css/manual-zip.css
-webserverextensions/apache2/manual/style/css/manual-zip-100pc.css
-webserverextensions/apache2/manual/style/faq.dtd
-webserverextensions/apache2/manual/style/latex/
-webserverextensions/apache2/manual/style/latex/atbeginend.sty
-webserverextensions/apache2/manual/style/manualpage.dtd
-webserverextensions/apache2/manual/style/build.properties
-webserverextensions/apache2/manual/style/version.ent
-webserverextensions/apache2/manual/style/xsl/
-webserverextensions/apache2/manual/style/xsl/util/
-webserverextensions/apache2/manual/mpm.html.tr.utf8
-webserverextensions/apache2/manual/new_features_2_2.html.ko.euc-kr
-webserverextensions/apache2/manual/dso.html.en
+webserverextensions/apache2/manual/logs.html.fr.utf8
+webserverextensions/apache2/manual/logs.html.ja.utf8
 webserverextensions/apache2/manual/logs.html.ko.euc-kr
+webserverextensions/apache2/manual/logs.html.tr.utf8
+webserverextensions/apache2/manual/misc/
+webserverextensions/apache2/manual/misc/index.html
+webserverextensions/apache2/manual/misc/index.html.en
+webserverextensions/apache2/manual/misc/index.html.es
+webserverextensions/apache2/manual/misc/index.html.fr.utf8
+webserverextensions/apache2/manual/misc/index.html.ko.euc-kr
+webserverextensions/apache2/manual/misc/index.html.tr.utf8
+webserverextensions/apache2/manual/misc/index.html.zh-cn.utf8
+webserverextensions/apache2/manual/misc/password_encryptions.html
+webserverextensions/apache2/manual/misc/password_encryptions.html.en
+webserverextensions/apache2/manual/misc/password_encryptions.html.fr.utf8
+webserverextensions/apache2/manual/misc/perf-tuning.html
+webserverextensions/apache2/manual/misc/perf-tuning.html.en
+webserverextensions/apache2/manual/misc/perf-tuning.html.fr.utf8
+webserverextensions/apache2/manual/misc/perf-tuning.html.ko.euc-kr
+webserverextensions/apache2/manual/misc/perf-tuning.html.tr.utf8
+webserverextensions/apache2/manual/misc/relevant_standards.html
+webserverextensions/apache2/manual/misc/relevant_standards.html.en
+webserverextensions/apache2/manual/misc/relevant_standards.html.fr.utf8
+webserverextensions/apache2/manual/misc/relevant_standards.html.ko.euc-kr
+webserverextensions/apache2/manual/misc/security_tips.html
+webserverextensions/apache2/manual/misc/security_tips.html.en
+webserverextensions/apache2/manual/misc/security_tips.html.fr.utf8
+webserverextensions/apache2/manual/misc/security_tips.html.ko.euc-kr
+webserverextensions/apache2/manual/misc/security_tips.html.tr.utf8
 webserverextensions/apache2/manual/mod/
-webserverextensions/apache2/manual/mod/mod_log_config.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_so.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_version.html.en
-webserverextensions/apache2/manual/mod/mod_authnz_fcgi.html
-webserverextensions/apache2/manual/mod/mod_access_compat.html.fr.utf8
-webserverextensions/apache2/manual/mod/module-dict.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_socache_shmcb.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_proxy_scgi.html
-webserverextensions/apache2/manual/mod/mod_socache_dc.html
-webserverextensions/apache2/manual/mod/mod_authn_file.html.ja.utf8
-webserverextensions/apache2/manual/mod/directives.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_authz_user.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_filter.html.en
-webserverextensions/apache2/manual/mod/mod_asis.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mpmt_os2.html.en
-webserverextensions/apache2/manual/mod/mod_proxy_http2.html
-webserverextensions/apache2/manual/mod/mod_auth_form.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_ident.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_mime.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_reflector.html.en
-webserverextensions/apache2/manual/mod/mod_speling.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_authnz_ldap.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_ldap.html.en
-webserverextensions/apache2/manual/mod/mpm_winnt.html.de
-webserverextensions/apache2/manual/mod/mod_proxy_fcgi.html.en
-webserverextensions/apache2/manual/mod/prefork.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_proxy_balancer.html.en
-webserverextensions/apache2/manual/mod/mod_dav.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_dir.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_actions.html.de
-webserverextensions/apache2/manual/mod/mod_proxy_hcheck.html.en
-webserverextensions/apache2/manual/mod/mod_cache_disk.html
-webserverextensions/apache2/manual/mod/mod_vhost_alias.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_so.html.en
-webserverextensions/apache2/manual/mod/quickreference.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mpm_netware.html.en
-webserverextensions/apache2/manual/mod/mod_isapi.html.en
-webserverextensions/apache2/manual/mod/mod_proxy_ajp.html.ja.utf8
+webserverextensions/apache2/manual/mod/core.html
 webserverextensions/apache2/manual/mod/core.html.de
-webserverextensions/apache2/manual/mod/worker.html.de
-webserverextensions/apache2/manual/mod/mod_proxy.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_nw_ssl.html
-webserverextensions/apache2/manual/mod/mod_authz_groupfile.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_dumpio.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_dav.html.en
-webserverextensions/apache2/manual/mod/mod_macro.html
-webserverextensions/apache2/manual/mod/mod_log_config.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_unique_id.html
+webserverextensions/apache2/manual/mod/core.html.en
+webserverextensions/apache2/manual/mod/core.html.es
+webserverextensions/apache2/manual/mod/core.html.fr.utf8
 webserverextensions/apache2/manual/mod/core.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_ident.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_auth_digest.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/quickreference.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_lua.html
-webserverextensions/apache2/manual/mod/mod_dir.html.en
-webserverextensions/apache2/manual/mod/mod_authn_file.html.en
-webserverextensions/apache2/manual/mod/mod_auth_basic.html
-webserverextensions/apache2/manual/mod/mod_headers.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_charset_lite.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_proxy_fdpass.html
-webserverextensions/apache2/manual/mod/mod_dbd.html.en
-webserverextensions/apache2/manual/mod/mod_cern_meta.html.en
-webserverextensions/apache2/manual/mod/mod_proxy_fdpass.html.en
-webserverextensions/apache2/manual/mod/mod_so.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_so.html.tr.utf8
-webserverextensions/apache2/manual/mod/mpmt_os2.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_echo.html.en
-webserverextensions/apache2/manual/mod/mod_brotli.html.en
-webserverextensions/apache2/manual/mod/mod_actions.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_lbmethod_byrequests.html
-webserverextensions/apache2/manual/mod/mod_privileges.html.en
+webserverextensions/apache2/manual/mod/core.html.tr.utf8
 webserverextensions/apache2/manual/mod/directive-dict.html
-webserverextensions/apache2/manual/mod/mod_log_forensic.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_deflate.html.fr.utf8
+webserverextensions/apache2/manual/mod/directive-dict.html.en
+webserverextensions/apache2/manual/mod/directive-dict.html.es
+webserverextensions/apache2/manual/mod/directive-dict.html.fr.utf8
+webserverextensions/apache2/manual/mod/directive-dict.html.ja.utf8
+webserverextensions/apache2/manual/mod/directive-dict.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/directive-dict.html.tr.utf8
+webserverextensions/apache2/manual/mod/directives.html
+webserverextensions/apache2/manual/mod/directives.html.de
+webserverextensions/apache2/manual/mod/directives.html.en
+webserverextensions/apache2/manual/mod/directives.html.es
+webserverextensions/apache2/manual/mod/directives.html.fr.utf8
 webserverextensions/apache2/manual/mod/directives.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_authn_socache.html
-webserverextensions/apache2/manual/mod/mod_proxy_connect.html
-webserverextensions/apache2/manual/mod/mod_request.html.en
-webserverextensions/apache2/manual/mod/mod_socache_dc.html.en
-webserverextensions/apache2/manual/mod/mod_authz_owner.html.en
-webserverextensions/apache2/manual/mod/mod_heartbeat.html
-webserverextensions/apache2/manual/mod/mod_speling.html.fr.utf8
-webserverextensions/apache2/manual/mod/mpm_common.html.de
-webserverextensions/apache2/manual/mod/mod_headers.html.fr.utf8
+webserverextensions/apache2/manual/mod/directives.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/directives.html.tr.utf8
+webserverextensions/apache2/manual/mod/directives.html.zh-cn.utf8
+webserverextensions/apache2/manual/mod/event.html
+webserverextensions/apache2/manual/mod/event.html.en
+webserverextensions/apache2/manual/mod/event.html.fr.utf8
+webserverextensions/apache2/manual/mod/index.html
+webserverextensions/apache2/manual/mod/index.html.de
+webserverextensions/apache2/manual/mod/index.html.en
+webserverextensions/apache2/manual/mod/index.html.es
+webserverextensions/apache2/manual/mod/index.html.fr.utf8
+webserverextensions/apache2/manual/mod/index.html.ja.utf8
+webserverextensions/apache2/manual/mod/index.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/index.html.tr.utf8
+webserverextensions/apache2/manual/mod/index.html.zh-cn.utf8
+webserverextensions/apache2/manual/mod/mod_access_compat.html
+webserverextensions/apache2/manual/mod/mod_access_compat.html.en
+webserverextensions/apache2/manual/mod/mod_access_compat.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_access_compat.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_actions.html
+webserverextensions/apache2/manual/mod/mod_actions.html.de
+webserverextensions/apache2/manual/mod/mod_actions.html.en
+webserverextensions/apache2/manual/mod/mod_actions.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_actions.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_actions.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_alias.html
+webserverextensions/apache2/manual/mod/mod_alias.html.en
+webserverextensions/apache2/manual/mod/mod_alias.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_alias.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_alias.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_alias.html.tr.utf8
+webserverextensions/apache2/manual/mod/mod_allowmethods.html
+webserverextensions/apache2/manual/mod/mod_allowmethods.html.en
 webserverextensions/apache2/manual/mod/mod_allowmethods.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_slotmem_shm.html
-webserverextensions/apache2/manual/mod/mod_ext_filter.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_usertrack.html
-webserverextensions/apache2/manual/mod/quickreference.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_socache_dbm.html
-webserverextensions/apache2/manual/mod/mod_lbmethod_bybusyness.html.en
-webserverextensions/apache2/manual/mod/mod_remoteip.html.en
-webserverextensions/apache2/manual/mod/mod_slotmem_shm.html.en
-webserverextensions/apache2/manual/mod/directive-dict.html.es
-webserverextensions/apache2/manual/mod/mod_file_cache.html.en
-webserverextensions/apache2/manual/mod/mod_dav.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_speling.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_proxy_html.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_asis.html
+webserverextensions/apache2/manual/mod/mod_asis.html.en
+webserverextensions/apache2/manual/mod/mod_asis.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_asis.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_asis.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_auth_basic.html
+webserverextensions/apache2/manual/mod/mod_auth_basic.html.en
+webserverextensions/apache2/manual/mod/mod_auth_basic.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_auth_basic.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_auth_basic.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_auth_digest.html
+webserverextensions/apache2/manual/mod/mod_auth_digest.html.en
+webserverextensions/apache2/manual/mod/mod_auth_digest.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_auth_digest.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_auth_form.html
+webserverextensions/apache2/manual/mod/mod_auth_form.html.en
+webserverextensions/apache2/manual/mod/mod_auth_form.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_authn_anon.html
+webserverextensions/apache2/manual/mod/mod_authn_anon.html.en
+webserverextensions/apache2/manual/mod/mod_authn_anon.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_authn_anon.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_authn_anon.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_authn_core.html
+webserverextensions/apache2/manual/mod/mod_authn_core.html.en
 webserverextensions/apache2/manual/mod/mod_authn_core.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_macro.html.en
-webserverextensions/apache2/manual/mod/mod_authz_host.html
-webserverextensions/apache2/manual/mod/mod_mime.html.fr.utf8
-webserverextensions/apache2/manual/mod/event.html.en
-webserverextensions/apache2/manual/mod/mod_log_forensic.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_authn_dbd.html
+webserverextensions/apache2/manual/mod/mod_authn_dbd.html.en
+webserverextensions/apache2/manual/mod/mod_authn_dbd.html.fr.utf8
 webserverextensions/apache2/manual/mod/mod_authn_dbm.html
-webserverextensions/apache2/manual/mod/mod_proxy_uwsgi.html.fr.utf8
-webserverextensions/apache2/manual/mod/core.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_echo.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_cache_socache.html
-webserverextensions/apache2/manual/mod/mod_cache.html
-webserverextensions/apache2/manual/mod/mod_env.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_include.html.en
-webserverextensions/apache2/manual/mod/mod_expires.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_heartmonitor.html.en
+webserverextensions/apache2/manual/mod/mod_authn_dbm.html.en
+webserverextensions/apache2/manual/mod/mod_authn_dbm.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_authn_dbm.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_authn_dbm.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_authn_file.html
+webserverextensions/apache2/manual/mod/mod_authn_file.html.en
+webserverextensions/apache2/manual/mod/mod_authn_file.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_authn_file.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_authn_file.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_authn_socache.html
+webserverextensions/apache2/manual/mod/mod_authn_socache.html.en
+webserverextensions/apache2/manual/mod/mod_authn_socache.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_authnz_fcgi.html
+webserverextensions/apache2/manual/mod/mod_authnz_fcgi.html.en
 webserverextensions/apache2/manual/mod/mod_authnz_fcgi.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_asis.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_autoindex.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_authnz_ldap.html
+webserverextensions/apache2/manual/mod/mod_authnz_ldap.html.en
+webserverextensions/apache2/manual/mod/mod_authnz_ldap.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_authz_core.html
+webserverextensions/apache2/manual/mod/mod_authz_core.html.en
+webserverextensions/apache2/manual/mod/mod_authz_core.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_authz_dbd.html
+webserverextensions/apache2/manual/mod/mod_authz_dbd.html.en
+webserverextensions/apache2/manual/mod/mod_authz_dbd.html.fr.utf8
 webserverextensions/apache2/manual/mod/mod_authz_dbm.html
-webserverextensions/apache2/manual/mod/mod_authz_user.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_cache.html.en
-webserverextensions/apache2/manual/mod/mod_alias.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_headers.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_rewrite.html.en
-webserverextensions/apache2/manual/mod/mod_cern_meta.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_slotmem_plain.html.en
-webserverextensions/apache2/manual/mod/mod_proxy_connect.html.en
-webserverextensions/apache2/manual/mod/mod_reqtimeout.html.en
-webserverextensions/apache2/manual/mod/mod_cern_meta.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_auth_form.html.en
-webserverextensions/apache2/manual/mod/mod_watchdog.html.en
-webserverextensions/apache2/manual/mod/mod_deflate.html.en
-webserverextensions/apache2/manual/mod/mod_userdir.html
-webserverextensions/apache2/manual/mod/module-dict.html.en
-webserverextensions/apache2/manual/mod/mod_logio.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_auth_basic.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_nw_ssl.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_authz_dbm.html.en
 webserverextensions/apache2/manual/mod/mod_authz_dbm.html.fr.utf8
-webserverextensions/apache2/manual/mod/mpm_netware.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_proxy_ajp.html.fr.utf8
-webserverextensions/apache2/manual/mod/worker.html.en
-webserverextensions/apache2/manual/mod/mod_version.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_dav.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_cache_socache.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_log_config.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_substitute.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_mime.html.en
-webserverextensions/apache2/manual/mod/mod_systemd.html
-webserverextensions/apache2/manual/mod/worker.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_proxy.html.en
-webserverextensions/apache2/manual/mod/directives.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_dbd.html.fr.utf8
-webserverextensions/apache2/manual/mod/quickreference.html.zh-cn.utf8
-webserverextensions/apache2/manual/mod/directive-dict.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_access_compat.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_nw_ssl.html.en
-webserverextensions/apache2/manual/mod/mod_suexec.html.ja.utf8
-webserverextensions/apache2/manual/mod/mpm_common.html.en
-webserverextensions/apache2/manual/mod/mod_mime_magic.html
-webserverextensions/apache2/manual/mod/mod_dav_fs.html
-webserverextensions/apache2/manual/mod/mod_rewrite.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_authn_anon.html.en
-webserverextensions/apache2/manual/mod/mod_alias.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_lua.html.en
-webserverextensions/apache2/manual/mod/mod_proxy_http.html
-webserverextensions/apache2/manual/mod/mod_cgid.html.en
-webserverextensions/apache2/manual/mod/mod_proxy_html.html.en
-webserverextensions/apache2/manual/mod/mod_info.html.fr.utf8
-webserverextensions/apache2/manual/mod/overrides.html.en
-webserverextensions/apache2/manual/mod/mod_http2.html
-webserverextensions/apache2/manual/mod/mod_deflate.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_ident.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_authnz_fcgi.html.en
-webserverextensions/apache2/manual/mod/mod_session_dbd.html.en
-webserverextensions/apache2/manual/mod/mod_ssl.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_proxy_ftp.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_example_hooks.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_socache_redis.html.en
-webserverextensions/apache2/manual/mod/mod_proxy_http2.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_systemd.html.en
-webserverextensions/apache2/manual/mod/mod_socache_memcache.html
-webserverextensions/apache2/manual/mod/mod_data.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_dumpio.html.en
-webserverextensions/apache2/manual/mod/mod_session.html.en
-webserverextensions/apache2/manual/mod/worker.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_http2.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_dav_fs.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_proxy_hcheck.html.fr.utf8
-webserverextensions/apache2/manual/mod/mpm_common.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_info.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_authz_dbm.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_authz_groupfile.html
 webserverextensions/apache2/manual/mod/mod_authz_groupfile.html.en
-webserverextensions/apache2/manual/mod/mod_buffer.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_autoindex.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_authn_dbm.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_cache_disk.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_env.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_asis.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_cgid.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_charset_lite.html.en
-webserverextensions/apache2/manual/mod/directives.html.es
-webserverextensions/apache2/manual/mod/mod_usertrack.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_buffer.html.en
-webserverextensions/apache2/manual/mod/mod_proxy_fcgi.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_proxy_connect.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_info.html.en
-webserverextensions/apache2/manual/mod/mod_watchdog.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_authz_user.html.en
-webserverextensions/apache2/manual/mod/index.html.es
-webserverextensions/apache2/manual/mod/mod_allowmethods.html
-webserverextensions/apache2/manual/mod/mod_lbmethod_bytraffic.html
-webserverextensions/apache2/manual/mod/mod_dav_lock.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_dav_lock.html.en
-webserverextensions/apache2/manual/mod/mod_reflector.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_negotiation.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_imagemap.html
-webserverextensions/apache2/manual/mod/mod_dir.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_logio.html.en
+webserverextensions/apache2/manual/mod/mod_authz_groupfile.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_authz_groupfile.html.ja.utf8
 webserverextensions/apache2/manual/mod/mod_authz_groupfile.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_slotmem_shm.html.fr.utf8
-webserverextensions/apache2/manual/mod/mpm_winnt.html.en
-webserverextensions/apache2/manual/mod/mod_alias.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_socache_memcache.html.en
-webserverextensions/apache2/manual/mod/mod_status.html
-webserverextensions/apache2/manual/mod/mod_http2.html.en
+webserverextensions/apache2/manual/mod/mod_authz_host.html
 webserverextensions/apache2/manual/mod/mod_authz_host.html.en
-webserverextensions/apache2/manual/mod/mpm_winnt.html.ja.utf8
-webserverextensions/apache2/manual/mod/prefork.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_imagemap.html.en
-webserverextensions/apache2/manual/mod/mod_privileges.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_auth_basic.html.en
-webserverextensions/apache2/manual/mod/mod_authn_anon.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_filter.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_authz_dbm.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_authz_groupfile.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_autoindex.html.en
 webserverextensions/apache2/manual/mod/mod_authz_host.html.fr.utf8
-webserverextensions/apache2/manual/mod/quickreference.html.en
-webserverextensions/apache2/manual/mod/mod_heartmonitor.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_session_crypto.html
-webserverextensions/apache2/manual/mod/mod_authn_dbm.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_proxy_http2.html.en
-webserverextensions/apache2/manual/mod/index.html.de
-webserverextensions/apache2/manual/mod/mod_proxy_http.html.en
-webserverextensions/apache2/manual/mod/mod_authnz_ldap.html.en
+webserverextensions/apache2/manual/mod/mod_authz_owner.html
+webserverextensions/apache2/manual/mod/mod_authz_owner.html.en
+webserverextensions/apache2/manual/mod/mod_authz_owner.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_authz_owner.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_authz_owner.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_session_cookie.html.en
-webserverextensions/apache2/manual/mod/mod_logio.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_authz_core.html.fr.utf8
-webserverextensions/apache2/manual/mod/quickreference.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_info.html.ja.utf8
-webserverextensions/apache2/manual/mod/index.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_authz_dbd.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_proxy_connect.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_lua.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_unique_id.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_ratelimit.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_cgi.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_status.html.en
-webserverextensions/apache2/manual/mod/mod_lbmethod_bybusyness.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_ident.html.en
+webserverextensions/apache2/manual/mod/mod_authz_user.html.en
+webserverextensions/apache2/manual/mod/mod_authz_user.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_authz_user.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_authz_user.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_autoindex.html
+webserverextensions/apache2/manual/mod/mod_autoindex.html.en
+webserverextensions/apache2/manual/mod/mod_autoindex.html.fr.utf8
 webserverextensions/apache2/manual/mod/mod_autoindex.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_authn_dbd.html.en
-webserverextensions/apache2/manual/mod/mod_authz_dbd.html.en
-webserverextensions/apache2/manual/mod/mod_proxy_scgi.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_proxy.html.fr.utf8
-webserverextensions/apache2/manual/mod/index.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_md.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_socache_dbm.html.fr.utf8
 webserverextensions/apache2/manual/mod/mod_autoindex.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/core.html.es
-webserverextensions/apache2/manual/mod/mod_auth_digest.html.en
+webserverextensions/apache2/manual/mod/mod_autoindex.html.tr.utf8
+webserverextensions/apache2/manual/mod/mod_brotli.html
+webserverextensions/apache2/manual/mod/mod_brotli.html.en
+webserverextensions/apache2/manual/mod/mod_brotli.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_buffer.html
+webserverextensions/apache2/manual/mod/mod_buffer.html.en
+webserverextensions/apache2/manual/mod/mod_buffer.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_cache.html
+webserverextensions/apache2/manual/mod/mod_cache.html.en
+webserverextensions/apache2/manual/mod/mod_cache.html.fr.utf8
 webserverextensions/apache2/manual/mod/mod_cache.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_proxy_http.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_headers.html.en
-webserverextensions/apache2/manual/mod/mod_proxy_express.html.en
-webserverextensions/apache2/manual/mod/mod_md.html.en
-webserverextensions/apache2/manual/mod/mod_proxy_wstunnel.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_authn_anon.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_cache.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_cache_disk.html
+webserverextensions/apache2/manual/mod/mod_cache_disk.html.en
+webserverextensions/apache2/manual/mod/mod_cache_disk.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_cache_disk.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_cache_disk.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_cache_socache.html
+webserverextensions/apache2/manual/mod/mod_cache_socache.html.en
+webserverextensions/apache2/manual/mod/mod_cache_socache.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_cern_meta.html
+webserverextensions/apache2/manual/mod/mod_cern_meta.html.en
+webserverextensions/apache2/manual/mod/mod_cern_meta.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_cern_meta.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_cgi.html
 webserverextensions/apache2/manual/mod/mod_cgi.html.en
-webserverextensions/apache2/manual/mod/mod_socache_memcache.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_logio.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_expires.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_cgi.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_cgi.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_cgi.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_cgid.html
+webserverextensions/apache2/manual/mod/mod_cgid.html.en
+webserverextensions/apache2/manual/mod/mod_cgid.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_cgid.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_cgid.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_charset_lite.html
+webserverextensions/apache2/manual/mod/mod_charset_lite.html.en
+webserverextensions/apache2/manual/mod/mod_charset_lite.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_charset_lite.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_data.html
+webserverextensions/apache2/manual/mod/mod_data.html.en
+webserverextensions/apache2/manual/mod/mod_data.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_dav.html
+webserverextensions/apache2/manual/mod/mod_dav.html.en
+webserverextensions/apache2/manual/mod/mod_dav.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_dav.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_dav.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_dav_fs.html
+webserverextensions/apache2/manual/mod/mod_dav_fs.html.en
+webserverextensions/apache2/manual/mod/mod_dav_fs.html.fr.utf8
 webserverextensions/apache2/manual/mod/mod_dav_fs.html.ja.utf8
-webserverextensions/apache2/manual/mod/index.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_cache_disk.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_cache.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_file_cache.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_unixd.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_dav_fs.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_dav_lock.html
+webserverextensions/apache2/manual/mod/mod_dav_lock.html.en
+webserverextensions/apache2/manual/mod/mod_dav_lock.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_dav_lock.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_dbd.html
+webserverextensions/apache2/manual/mod/mod_dbd.html.en
+webserverextensions/apache2/manual/mod/mod_dbd.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_deflate.html
+webserverextensions/apache2/manual/mod/mod_deflate.html.en
+webserverextensions/apache2/manual/mod/mod_deflate.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_deflate.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_deflate.html.ko.euc-kr
 webserverextensions/apache2/manual/mod/mod_dialup.html
-webserverextensions/apache2/manual/mod/mod_lbmethod_heartbeat.html.en
+webserverextensions/apache2/manual/mod/mod_dialup.html.en
+webserverextensions/apache2/manual/mod/mod_dialup.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_dir.html
+webserverextensions/apache2/manual/mod/mod_dir.html.en
+webserverextensions/apache2/manual/mod/mod_dir.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_dir.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_dir.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_dir.html.tr.utf8
+webserverextensions/apache2/manual/mod/mod_dumpio.html
+webserverextensions/apache2/manual/mod/mod_dumpio.html.en
+webserverextensions/apache2/manual/mod/mod_dumpio.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_dumpio.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_echo.html
+webserverextensions/apache2/manual/mod/mod_echo.html.en
+webserverextensions/apache2/manual/mod/mod_echo.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_echo.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_echo.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_env.html
+webserverextensions/apache2/manual/mod/mod_env.html.en
+webserverextensions/apache2/manual/mod/mod_env.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_env.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_env.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_env.html.tr.utf8
+webserverextensions/apache2/manual/mod/mod_example_hooks.html
+webserverextensions/apache2/manual/mod/mod_example_hooks.html.en
+webserverextensions/apache2/manual/mod/mod_example_hooks.html.fr.utf8
 webserverextensions/apache2/manual/mod/mod_example_hooks.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/index.html.zh-cn.utf8
-webserverextensions/apache2/manual/mod/mod_userdir.html.en
-webserverextensions/apache2/manual/mod/mod_unixd.html.en
-webserverextensions/apache2/manual/mod/mod_macro.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_proxy_uwsgi.html.en
-webserverextensions/apache2/manual/mod/mod_authz_owner.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_expires.html
+webserverextensions/apache2/manual/mod/mod_expires.html.en
+webserverextensions/apache2/manual/mod/mod_expires.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_expires.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_expires.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_ext_filter.html
+webserverextensions/apache2/manual/mod/mod_ext_filter.html.en
+webserverextensions/apache2/manual/mod/mod_ext_filter.html.fr.utf8
 webserverextensions/apache2/manual/mod/mod_ext_filter.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_dialup.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_dialup.html.en
-webserverextensions/apache2/manual/mod/mod_ldap.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_authn_anon.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_ext_filter.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_file_cache.html
+webserverextensions/apache2/manual/mod/mod_file_cache.html.en
+webserverextensions/apache2/manual/mod/mod_file_cache.html.fr.utf8
 webserverextensions/apache2/manual/mod/mod_file_cache.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/index.html.en
-webserverextensions/apache2/manual/mod/mod_session_dbd.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_cache.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_filter.html
+webserverextensions/apache2/manual/mod/mod_filter.html.en
+webserverextensions/apache2/manual/mod/mod_filter.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_headers.html
+webserverextensions/apache2/manual/mod/mod_headers.html.en
+webserverextensions/apache2/manual/mod/mod_headers.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_headers.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_headers.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_heartbeat.html
+webserverextensions/apache2/manual/mod/mod_heartbeat.html.en
+webserverextensions/apache2/manual/mod/mod_heartbeat.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_heartmonitor.html
+webserverextensions/apache2/manual/mod/mod_heartmonitor.html.en
+webserverextensions/apache2/manual/mod/mod_heartmonitor.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_http2.html
+webserverextensions/apache2/manual/mod/mod_http2.html.en
+webserverextensions/apache2/manual/mod/mod_http2.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_ident.html
+webserverextensions/apache2/manual/mod/mod_ident.html.en
+webserverextensions/apache2/manual/mod/mod_ident.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_ident.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_ident.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_imagemap.html
+webserverextensions/apache2/manual/mod/mod_imagemap.html.en
+webserverextensions/apache2/manual/mod/mod_imagemap.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_imagemap.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_include.html
+webserverextensions/apache2/manual/mod/mod_include.html.en
+webserverextensions/apache2/manual/mod/mod_include.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_include.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_info.html
+webserverextensions/apache2/manual/mod/mod_info.html.en
+webserverextensions/apache2/manual/mod/mod_info.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_info.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_info.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_isapi.html
+webserverextensions/apache2/manual/mod/mod_isapi.html.en
 webserverextensions/apache2/manual/mod/mod_isapi.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_dir.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/prefork.html.de
-webserverextensions/apache2/manual/mod/mpm_common.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_xml2enc.html.en
-webserverextensions/apache2/manual/mod/index.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_setenvif.html
-webserverextensions/apache2/manual/mod/mod_imagemap.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_suexec.html.tr.utf8
+webserverextensions/apache2/manual/mod/mod_isapi.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_lbmethod_bybusyness.html
+webserverextensions/apache2/manual/mod/mod_lbmethod_bybusyness.html.en
+webserverextensions/apache2/manual/mod/mod_lbmethod_bybusyness.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_lbmethod_byrequests.html
+webserverextensions/apache2/manual/mod/mod_lbmethod_byrequests.html.en
+webserverextensions/apache2/manual/mod/mod_lbmethod_byrequests.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_lbmethod_bytraffic.html
+webserverextensions/apache2/manual/mod/mod_lbmethod_bytraffic.html.en
+webserverextensions/apache2/manual/mod/mod_lbmethod_bytraffic.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_lbmethod_heartbeat.html
+webserverextensions/apache2/manual/mod/mod_lbmethod_heartbeat.html.en
+webserverextensions/apache2/manual/mod/mod_lbmethod_heartbeat.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_ldap.html
+webserverextensions/apache2/manual/mod/mod_ldap.html.en
+webserverextensions/apache2/manual/mod/mod_ldap.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_log_config.html
 webserverextensions/apache2/manual/mod/mod_log_config.html.en
-webserverextensions/apache2/manual/mod/mod_asis.html.en
-webserverextensions/apache2/manual/mod/mod_proxy_ajp.html.en
-webserverextensions/apache2/manual/mod/mod_heartbeat.html.en
-webserverextensions/apache2/manual/mod/mod_socache_shmcb.html.en
-webserverextensions/apache2/manual/mod/mod_suexec.html.en
-webserverextensions/apache2/manual/mod/mod_proxy_balancer.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_ssl.html.en
-webserverextensions/apache2/manual/mod/mod_access_compat.html.en
-webserverextensions/apache2/manual/mod/mod_dav_fs.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_allowmethods.html.en
-webserverextensions/apache2/manual/mod/mod_authn_socache.html.en
-webserverextensions/apache2/manual/mod/mod_vhost_alias.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_status.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_auth_basic.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_expires.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_lbmethod_bytraffic.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_suexec.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_setenvif.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_sed.html
-webserverextensions/apache2/manual/mod/mod_actions.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/directive-dict.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_setenvif.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_log_config.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_log_config.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_log_config.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_log_config.html.tr.utf8
+webserverextensions/apache2/manual/mod/mod_log_debug.html
+webserverextensions/apache2/manual/mod/mod_log_debug.html.en
 webserverextensions/apache2/manual/mod/mod_log_debug.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_session_cookie.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_log_forensic.html
+webserverextensions/apache2/manual/mod/mod_log_forensic.html.en
+webserverextensions/apache2/manual/mod/mod_log_forensic.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_log_forensic.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_log_forensic.html.tr.utf8
+webserverextensions/apache2/manual/mod/mod_logio.html
+webserverextensions/apache2/manual/mod/mod_logio.html.en
+webserverextensions/apache2/manual/mod/mod_logio.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_logio.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_logio.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_logio.html.tr.utf8
+webserverextensions/apache2/manual/mod/mod_lua.html
+webserverextensions/apache2/manual/mod/mod_lua.html.en
+webserverextensions/apache2/manual/mod/mod_lua.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_macro.html
+webserverextensions/apache2/manual/mod/mod_macro.html.en
+webserverextensions/apache2/manual/mod/mod_macro.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_md.html
+webserverextensions/apache2/manual/mod/mod_md.html.en
+webserverextensions/apache2/manual/mod/mod_md.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_mime.html
+webserverextensions/apache2/manual/mod/mod_mime.html.en
+webserverextensions/apache2/manual/mod/mod_mime.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_mime.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_mime_magic.html
+webserverextensions/apache2/manual/mod/mod_mime_magic.html.en
+webserverextensions/apache2/manual/mod/mod_mime_magic.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_logio.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_dav_lock.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_status.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_speling.html.en
-webserverextensions/apache2/manual/mod/mod_echo.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_version.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/module-dict.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mpm_winnt.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_sed.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_include.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_log_debug.html.en
-webserverextensions/apache2/manual/mod/mod_vhost_alias.html.en
-webserverextensions/apache2/manual/mod/event.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_actions.html.en
-webserverextensions/apache2/manual/mod/mpm_common.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_isapi.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_reqtimeout.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_cgi.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_env.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_session.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_authn_socache.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_unixd.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_data.html.en
 webserverextensions/apache2/manual/mod/mod_negotiation.html.en
-webserverextensions/apache2/manual/mod/mod_mime_magic.html.en
-webserverextensions/apache2/manual/mod/mod_cache_disk.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_negotiation.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_negotiation.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_nw_ssl.html
+webserverextensions/apache2/manual/mod/mod_nw_ssl.html.en
+webserverextensions/apache2/manual/mod/mod_nw_ssl.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_privileges.html
+webserverextensions/apache2/manual/mod/mod_privileges.html.en
+webserverextensions/apache2/manual/mod/mod_privileges.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_proxy.html
+webserverextensions/apache2/manual/mod/mod_proxy.html.en
+webserverextensions/apache2/manual/mod/mod_proxy.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_proxy.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_proxy_ajp.html
+webserverextensions/apache2/manual/mod/mod_proxy_ajp.html.en
+webserverextensions/apache2/manual/mod/mod_proxy_ajp.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_proxy_ajp.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_proxy_balancer.html
+webserverextensions/apache2/manual/mod/mod_proxy_balancer.html.en
+webserverextensions/apache2/manual/mod/mod_proxy_balancer.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_proxy_balancer.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_proxy_connect.html
+webserverextensions/apache2/manual/mod/mod_proxy_connect.html.en
+webserverextensions/apache2/manual/mod/mod_proxy_connect.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_proxy_connect.html.ja.utf8
-webserverextensions/apache2/manual/mod/directives.html.en
-webserverextensions/apache2/manual/mod/mod_expires.html.en
-webserverextensions/apache2/manual/mod/mod_socache_dbm.html.en
-webserverextensions/apache2/manual/mod/directives.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/quickreference.html.de
-webserverextensions/apache2/manual/mod/mod_log_forensic.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_unique_id.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_authn_dbm.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_alias.html.en
-webserverextensions/apache2/manual/mod/mod_authn_core.html
-webserverextensions/apache2/manual/mod/mod_socache_redis.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_charset_lite.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_systemd.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_lbmethod_heartbeat.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_authn_dbm.html.en
-webserverextensions/apache2/manual/mod/mod_authz_owner.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_proxy_balancer.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_slotmem_plain.html.fr.utf8
-webserverextensions/apache2/manual/mod/directive-dict.html.en
-webserverextensions/apache2/manual/mod/prefork.html.en
-webserverextensions/apache2/manual/mod/mod_authn_core.html.en
-webserverextensions/apache2/manual/mod/mod_dav_fs.html.en
+webserverextensions/apache2/manual/mod/mod_proxy_express.html.en
+webserverextensions/apache2/manual/mod/mod_proxy_express.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_proxy_fcgi.html
+webserverextensions/apache2/manual/mod/mod_proxy_fcgi.html.en
+webserverextensions/apache2/manual/mod/mod_proxy_fcgi.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_proxy_fdpass.html
+webserverextensions/apache2/manual/mod/mod_proxy_fdpass.html.en
+webserverextensions/apache2/manual/mod/mod_proxy_fdpass.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_proxy_ftp.html
+webserverextensions/apache2/manual/mod/mod_proxy_ftp.html.en
+webserverextensions/apache2/manual/mod/mod_proxy_ftp.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_proxy_hcheck.html
+webserverextensions/apache2/manual/mod/mod_proxy_hcheck.html.en
+webserverextensions/apache2/manual/mod/mod_proxy_hcheck.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_imagemap.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_userdir.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/module-dict.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_so.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_lbmethod_byrequests.html.fr.utf8
-webserverextensions/apache2/manual/mod/core.html.en
+webserverextensions/apache2/manual/mod/mod_proxy_html.html.en
+webserverextensions/apache2/manual/mod/mod_proxy_html.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_proxy_http.html
+webserverextensions/apache2/manual/mod/mod_proxy_http.html.en
+webserverextensions/apache2/manual/mod/mod_proxy_http.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_proxy_http2.html
+webserverextensions/apache2/manual/mod/mod_proxy_http2.html.en
+webserverextensions/apache2/manual/mod/mod_proxy_http2.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_proxy_scgi.html
 webserverextensions/apache2/manual/mod/mod_proxy_scgi.html.en
-webserverextensions/apache2/manual/mod/mod_setenvif.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_userdir.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_auth_basic.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_actions.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_cgid.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_heartbeat.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_proxy_scgi.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_proxy_uwsgi.html
+webserverextensions/apache2/manual/mod/mod_proxy_uwsgi.html.en
+webserverextensions/apache2/manual/mod/mod_proxy_uwsgi.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_proxy_wstunnel.html
+webserverextensions/apache2/manual/mod/mod_proxy_wstunnel.html.en
+webserverextensions/apache2/manual/mod/mod_proxy_wstunnel.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_ratelimit.html
 webserverextensions/apache2/manual/mod/mod_ratelimit.html.en
-webserverextensions/apache2/manual/mod/mod_cgi.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_ratelimit.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_reflector.html
+webserverextensions/apache2/manual/mod/mod_reflector.html.en
+webserverextensions/apache2/manual/mod/mod_reflector.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_remoteip.html
+webserverextensions/apache2/manual/mod/mod_remoteip.html.en
+webserverextensions/apache2/manual/mod/mod_remoteip.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_reqtimeout.html
+webserverextensions/apache2/manual/mod/mod_reqtimeout.html.en
+webserverextensions/apache2/manual/mod/mod_reqtimeout.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_request.html
+webserverextensions/apache2/manual/mod/mod_request.html.en
+webserverextensions/apache2/manual/mod/mod_request.html.fr.utf8
 webserverextensions/apache2/manual/mod/mod_request.html.tr.utf8
+webserverextensions/apache2/manual/mod/mod_rewrite.html
+webserverextensions/apache2/manual/mod/mod_rewrite.html.en
+webserverextensions/apache2/manual/mod/mod_rewrite.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_sed.html
+webserverextensions/apache2/manual/mod/mod_sed.html.en
+webserverextensions/apache2/manual/mod/mod_sed.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_session.html
+webserverextensions/apache2/manual/mod/mod_session.html.en
+webserverextensions/apache2/manual/mod/mod_session.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_session_cookie.html
+webserverextensions/apache2/manual/mod/mod_session_cookie.html.en
+webserverextensions/apache2/manual/mod/mod_session_cookie.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_session_crypto.html
+webserverextensions/apache2/manual/mod/mod_session_crypto.html.en
+webserverextensions/apache2/manual/mod/mod_session_crypto.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_session_dbd.html
+webserverextensions/apache2/manual/mod/mod_session_dbd.html.en
+webserverextensions/apache2/manual/mod/mod_session_dbd.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_setenvif.html
 webserverextensions/apache2/manual/mod/mod_setenvif.html.en
-webserverextensions/apache2/manual/mod/core.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_deflate.html.ja.utf8
-webserverextensions/apache2/manual/mod/module-dict.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_alias.html.tr.utf8
-webserverextensions/apache2/manual/mod/mod_brotli.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_sed.html.en
+webserverextensions/apache2/manual/mod/mod_setenvif.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_setenvif.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_setenvif.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_setenvif.html.tr.utf8
+webserverextensions/apache2/manual/mod/mod_slotmem_plain.html
+webserverextensions/apache2/manual/mod/mod_slotmem_plain.html.en
+webserverextensions/apache2/manual/mod/mod_slotmem_plain.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_slotmem_shm.html
+webserverextensions/apache2/manual/mod/mod_slotmem_shm.html.en
+webserverextensions/apache2/manual/mod/mod_slotmem_shm.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_so.html
+webserverextensions/apache2/manual/mod/mod_so.html.en
+webserverextensions/apache2/manual/mod/mod_so.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_so.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_so.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_so.html.tr.utf8
+webserverextensions/apache2/manual/mod/mod_socache_dbm.html
+webserverextensions/apache2/manual/mod/mod_socache_dbm.html.en
+webserverextensions/apache2/manual/mod/mod_socache_dbm.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_socache_dc.html
+webserverextensions/apache2/manual/mod/mod_socache_dc.html.en
+webserverextensions/apache2/manual/mod/mod_socache_dc.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_socache_memcache.html
+webserverextensions/apache2/manual/mod/mod_socache_memcache.html.en
+webserverextensions/apache2/manual/mod/mod_socache_memcache.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_socache_redis.html
+webserverextensions/apache2/manual/mod/mod_socache_redis.html.en
+webserverextensions/apache2/manual/mod/mod_socache_redis.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_socache_shmcb.html
+webserverextensions/apache2/manual/mod/mod_socache_shmcb.html.en
+webserverextensions/apache2/manual/mod/mod_socache_shmcb.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_speling.html
+webserverextensions/apache2/manual/mod/mod_speling.html.en
+webserverextensions/apache2/manual/mod/mod_speling.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_speling.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_speling.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_ssl.html
+webserverextensions/apache2/manual/mod/mod_ssl.html.en
+webserverextensions/apache2/manual/mod/mod_ssl.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_status.html
+webserverextensions/apache2/manual/mod/mod_status.html.en
+webserverextensions/apache2/manual/mod/mod_status.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_status.html.ja.utf8
 webserverextensions/apache2/manual/mod/mod_status.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_session_crypto.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_authn_file.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_lbmethod_byrequests.html.en
-webserverextensions/apache2/manual/mod/mod_log_config.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_xml2enc.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_auth_digest.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_proxy_express.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_proxy_ftp.html.en
-webserverextensions/apache2/manual/mod/mod_session_crypto.html.en
-webserverextensions/apache2/manual/mod/mod_echo.html.ja.utf8
-webserverextensions/apache2/manual/mod/directive-dict.html.ja.utf8
-webserverextensions/apache2/manual/mod/directives.html.de
-webserverextensions/apache2/manual/mod/mod_dir.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_status.html.tr.utf8
+webserverextensions/apache2/manual/mod/mod_substitute.html
+webserverextensions/apache2/manual/mod/mod_substitute.html.en
+webserverextensions/apache2/manual/mod/mod_substitute.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_suexec.html
+webserverextensions/apache2/manual/mod/mod_suexec.html.en
 webserverextensions/apache2/manual/mod/mod_suexec.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_cache_disk.html.en
-webserverextensions/apache2/manual/mod/mod_setenvif.html.ja.utf8
-webserverextensions/apache2/manual/mod/directive-dict.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_userdir.html.fr.utf8
-webserverextensions/apache2/manual/mod/prefork.html.fr.utf8
-webserverextensions/apache2/manual/mod/quickreference.html.es
-webserverextensions/apache2/manual/mod/mod_authz_user.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_log_forensic.html.en
+webserverextensions/apache2/manual/mod/mod_suexec.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_suexec.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_suexec.html.tr.utf8
+webserverextensions/apache2/manual/mod/mod_systemd.html
+webserverextensions/apache2/manual/mod/mod_systemd.html.en
+webserverextensions/apache2/manual/mod/mod_systemd.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_unique_id.html
 webserverextensions/apache2/manual/mod/mod_unique_id.html.en
-webserverextensions/apache2/manual/mod/mod_ext_filter.html.ko.euc-kr
 webserverextensions/apache2/manual/mod/mod_unique_id.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_dumpio.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_authz_dbm.html.en
+webserverextensions/apache2/manual/mod/mod_unique_id.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_unique_id.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_unixd.html
+webserverextensions/apache2/manual/mod/mod_unixd.html.en
+webserverextensions/apache2/manual/mod/mod_unixd.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_unixd.html.tr.utf8
+webserverextensions/apache2/manual/mod/mod_userdir.html
+webserverextensions/apache2/manual/mod/mod_userdir.html.en
+webserverextensions/apache2/manual/mod/mod_userdir.html.fr.utf8
 webserverextensions/apache2/manual/mod/mod_userdir.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_authz_core.html.en
-webserverextensions/apache2/manual/mod/mod_cgid.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_substitute.html.en
-webserverextensions/apache2/manual/mod/mod_negotiation.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_example_hooks.html.en
-webserverextensions/apache2/manual/mod/mod_proxy_wstunnel.html.en
-webserverextensions/apache2/manual/mod/mod_socache_dc.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_proxy_fdpass.html.fr.utf8
-webserverextensions/apache2/manual/mod/worker.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_userdir.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_userdir.html.tr.utf8
+webserverextensions/apache2/manual/mod/mod_usertrack.html
+webserverextensions/apache2/manual/mod/mod_usertrack.html.en
+webserverextensions/apache2/manual/mod/mod_usertrack.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_version.html
+webserverextensions/apache2/manual/mod/mod_version.html.en
 webserverextensions/apache2/manual/mod/mod_version.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_status.html.ja.utf8
-webserverextensions/apache2/manual/mod/mod_mime_magic.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_lbmethod_bytraffic.html.en
-webserverextensions/apache2/manual/mod/mod_remoteip.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_usertrack.html.en
-webserverextensions/apache2/manual/mod/mod_request.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_authz_owner.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_ext_filter.html.en
-webserverextensions/apache2/manual/mod/mod_env.html.en
-webserverextensions/apache2/manual/mod/mod_authn_dbd.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_authn_file.html.ko.euc-kr
-webserverextensions/apache2/manual/mod/mod_cache_socache.html.en
-webserverextensions/apache2/manual/mod/mod_env.html.fr.utf8
-webserverextensions/apache2/manual/mod/mod_include.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_version.html.ja.utf8
+webserverextensions/apache2/manual/mod/mod_version.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/mod_vhost_alias.html
+webserverextensions/apache2/manual/mod/mod_vhost_alias.html.en
+webserverextensions/apache2/manual/mod/mod_vhost_alias.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_vhost_alias.html.tr.utf8
+webserverextensions/apache2/manual/mod/mod_watchdog.html
+webserverextensions/apache2/manual/mod/mod_watchdog.html.en
+webserverextensions/apache2/manual/mod/mod_watchdog.html.fr.utf8
+webserverextensions/apache2/manual/mod/mod_xml2enc.html
+webserverextensions/apache2/manual/mod/mod_xml2enc.html.en
+webserverextensions/apache2/manual/mod/mod_xml2enc.html.fr.utf8
+webserverextensions/apache2/manual/mod/module-dict.html
+webserverextensions/apache2/manual/mod/module-dict.html.en
+webserverextensions/apache2/manual/mod/module-dict.html.fr.utf8
+webserverextensions/apache2/manual/mod/module-dict.html.ja.utf8
+webserverextensions/apache2/manual/mod/module-dict.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/module-dict.html.tr.utf8
+webserverextensions/apache2/manual/mod/mpm_common.html
+webserverextensions/apache2/manual/mod/mpm_common.html.de
+webserverextensions/apache2/manual/mod/mpm_common.html.en
+webserverextensions/apache2/manual/mod/mpm_common.html.fr.utf8
+webserverextensions/apache2/manual/mod/mpm_common.html.ja.utf8
+webserverextensions/apache2/manual/mod/mpm_common.html.tr.utf8
+webserverextensions/apache2/manual/mod/mpm_netware.html
+webserverextensions/apache2/manual/mod/mpm_netware.html.en
+webserverextensions/apache2/manual/mod/mpm_netware.html.fr.utf8
+webserverextensions/apache2/manual/mod/mpm_winnt.html
+webserverextensions/apache2/manual/mod/mpm_winnt.html.de
+webserverextensions/apache2/manual/mod/mpm_winnt.html.en
+webserverextensions/apache2/manual/mod/mpm_winnt.html.fr.utf8
+webserverextensions/apache2/manual/mod/mpm_winnt.html.ja.utf8
+webserverextensions/apache2/manual/mod/mpmt_os2.html
+webserverextensions/apache2/manual/mod/mpmt_os2.html.en
+webserverextensions/apache2/manual/mod/mpmt_os2.html.fr.utf8
+webserverextensions/apache2/manual/mod/overrides.html
+webserverextensions/apache2/manual/mod/overrides.html.en
 webserverextensions/apache2/manual/mod/overrides.html.fr.utf8
-webserverextensions/apache2/manual/mod/directives.html.zh-cn.utf8
-webserverextensions/apache2/manual/socache.html
-webserverextensions/apache2/manual/stopping.html.en
-webserverextensions/apache2/manual/invoking.html.fr.utf8
-webserverextensions/apache2/manual/LICENSE
-webserverextensions/apache2/manual/socache.html.fr.utf8
-webserverextensions/apache2/manual/new_features_2_4.html.fr.utf8
-webserverextensions/apache2/manual/handler.html
-webserverextensions/apache2/manual/glossary.html.en
-webserverextensions/apache2/manual/glossary.html.ja.utf8
-webserverextensions/apache2/manual/new_features_2_2.html.tr.utf8
-webserverextensions/apache2/manual/dso.html.tr.utf8
-webserverextensions/apache2/manual/configuring.html.ko.euc-kr
-webserverextensions/apache2/manual/expr.html.en
-webserverextensions/apache2/manual/handler.html.ko.euc-kr
-webserverextensions/apache2/manual/bind.html.ko.euc-kr
-webserverextensions/apache2/manual/install.html
-webserverextensions/apache2/manual/convenience.map
-webserverextensions/apache2/manual/stopping.html.tr.utf8
-webserverextensions/apache2/manual/invoking.html.ko.euc-kr
-webserverextensions/apache2/manual/index.html.ru.utf8
-webserverextensions/apache2/manual/suexec.html.ko.euc-kr
-webserverextensions/apache2/manual/socache.html.en
-webserverextensions/apache2/manual/glossary.html.de
-webserverextensions/apache2/manual/urlmapping.html.fr.utf8
-webserverextensions/apache2/manual/caching.html.fr.utf8
-webserverextensions/apache2/manual/suexec.html.ja.utf8
-webserverextensions/apache2/manual/server-wide.html.ko.euc-kr
-webserverextensions/apache2/manual/custom-error.html.en
-webserverextensions/apache2/manual/custom-error.html.fr.utf8
-webserverextensions/apache2/manual/dns-caveats.html.tr.utf8
-webserverextensions/apache2/manual/filter.html.en
-webserverextensions/apache2/manual/index.html.es
-webserverextensions/apache2/manual/env.html.fr.utf8
-webserverextensions/apache2/manual/install.html.ko.euc-kr
-webserverextensions/apache2/manual/howto/
-webserverextensions/apache2/manual/howto/public_html.html.fr.utf8
-webserverextensions/apache2/manual/howto/reverse_proxy.html
-webserverextensions/apache2/manual/howto/htaccess.html.ja.utf8
-webserverextensions/apache2/manual/howto/public_html.html.ko.euc-kr
-webserverextensions/apache2/manual/howto/http2.html.en
-webserverextensions/apache2/manual/howto/public_html.html.tr.utf8
-webserverextensions/apache2/manual/howto/auth.html.ja.utf8
-webserverextensions/apache2/manual/howto/auth.html.en
-webserverextensions/apache2/manual/howto/cgi.html
-webserverextensions/apache2/manual/howto/cgi.html.en
-webserverextensions/apache2/manual/howto/htaccess.html.en
-webserverextensions/apache2/manual/howto/public_html.html.es
-webserverextensions/apache2/manual/howto/cgi.html.es
-webserverextensions/apache2/manual/howto/index.html.es
-webserverextensions/apache2/manual/howto/auth.html.tr.utf8
-webserverextensions/apache2/manual/howto/cgi.html.ko.euc-kr
-webserverextensions/apache2/manual/howto/ssi.html.fr.utf8
-webserverextensions/apache2/manual/howto/http2.html.fr.utf8
-webserverextensions/apache2/manual/howto/public_html.html.en
-webserverextensions/apache2/manual/howto/auth.html.es
-webserverextensions/apache2/manual/howto/ssi.html.ko.euc-kr
-webserverextensions/apache2/manual/howto/public_html.html.ja.utf8
-webserverextensions/apache2/manual/howto/index.html.ko.euc-kr
-webserverextensions/apache2/manual/howto/reverse_proxy.html.fr.utf8
-webserverextensions/apache2/manual/howto/index.html.ja.utf8
-webserverextensions/apache2/manual/howto/cgi.html.fr.utf8
-webserverextensions/apache2/manual/howto/cgi.html.ja.utf8
-webserverextensions/apache2/manual/howto/htaccess.html.pt-br
-webserverextensions/apache2/manual/howto/index.html.zh-cn.utf8
-webserverextensions/apache2/manual/howto/index.html.en
-webserverextensions/apache2/manual/howto/index.html.fr.utf8
-webserverextensions/apache2/manual/howto/auth.html.ko.euc-kr
-webserverextensions/apache2/manual/howto/htaccess.html.es
-webserverextensions/apache2/manual/howto/htaccess.html.fr.utf8
-webserverextensions/apache2/manual/howto/reverse_proxy.html.en
-webserverextensions/apache2/manual/howto/access.html.es
-webserverextensions/apache2/manual/howto/ssi.html.es
-webserverextensions/apache2/manual/howto/http2.html.es
-webserverextensions/apache2/manual/howto/auth.html.fr.utf8
-webserverextensions/apache2/manual/howto/ssi.html.ja.utf8
-webserverextensions/apache2/manual/howto/access.html.fr.utf8
-webserverextensions/apache2/manual/howto/htaccess.html.ko.euc-kr
-webserverextensions/apache2/manual/howto/access.html.en
-webserverextensions/apache2/manual/howto/ssi.html.en
-webserverextensions/apache2/manual/sitemap.html.ja.utf8
-webserverextensions/apache2/manual/stopping.html.fr.utf8
-webserverextensions/apache2/manual/logs.html.tr.utf8
-webserverextensions/apache2/manual/custom-error.html.tr.utf8
-webserverextensions/apache2/manual/glossary.html.tr.utf8
+webserverextensions/apache2/manual/mod/prefork.html
+webserverextensions/apache2/manual/mod/prefork.html.de
+webserverextensions/apache2/manual/mod/prefork.html.en
+webserverextensions/apache2/manual/mod/prefork.html.fr.utf8
+webserverextensions/apache2/manual/mod/prefork.html.ja.utf8
+webserverextensions/apache2/manual/mod/prefork.html.tr.utf8
+webserverextensions/apache2/manual/mod/quickreference.html
+webserverextensions/apache2/manual/mod/quickreference.html.de
+webserverextensions/apache2/manual/mod/quickreference.html.en
+webserverextensions/apache2/manual/mod/quickreference.html.es
+webserverextensions/apache2/manual/mod/quickreference.html.fr.utf8
+webserverextensions/apache2/manual/mod/quickreference.html.ja.utf8
+webserverextensions/apache2/manual/mod/quickreference.html.ko.euc-kr
+webserverextensions/apache2/manual/mod/quickreference.html.tr.utf8
+webserverextensions/apache2/manual/mod/quickreference.html.zh-cn.utf8
+webserverextensions/apache2/manual/mod/worker.html
+webserverextensions/apache2/manual/mod/worker.html.de
+webserverextensions/apache2/manual/mod/worker.html.en
+webserverextensions/apache2/manual/mod/worker.html.fr.utf8
+webserverextensions/apache2/manual/mod/worker.html.ja.utf8
+webserverextensions/apache2/manual/mod/worker.html.tr.utf8
+webserverextensions/apache2/manual/mpm.html
+webserverextensions/apache2/manual/mpm.html.de
+webserverextensions/apache2/manual/mpm.html.en
+webserverextensions/apache2/manual/mpm.html.es
+webserverextensions/apache2/manual/mpm.html.fr.utf8
+webserverextensions/apache2/manual/mpm.html.ja.utf8
+webserverextensions/apache2/manual/mpm.html.ko.euc-kr
+webserverextensions/apache2/manual/mpm.html.tr.utf8
+webserverextensions/apache2/manual/mpm.html.zh-cn.utf8
 webserverextensions/apache2/manual/new_features_2_0.html
-webserverextensions/apache2/manual/upgrading.html.en
-webserverextensions/apache2/manual/mpm.html.zh-cn.utf8
-webserverextensions/apache2/manual/index.html.de
-webserverextensions/apache2/manual/sitemap.html.zh-cn.utf8
+webserverextensions/apache2/manual/new_features_2_0.html.de
+webserverextensions/apache2/manual/new_features_2_0.html.en
+webserverextensions/apache2/manual/new_features_2_0.html.fr.utf8
+webserverextensions/apache2/manual/new_features_2_0.html.ja.utf8
+webserverextensions/apache2/manual/new_features_2_0.html.ko.euc-kr
+webserverextensions/apache2/manual/new_features_2_0.html.pt-br
+webserverextensions/apache2/manual/new_features_2_0.html.pt-br.utf8
 webserverextensions/apache2/manual/new_features_2_0.html.tr.utf8
-webserverextensions/apache2/manual/sections.html.ko.euc-kr
-webserverextensions/apache2/manual/server-wide.html.tr.utf8
+webserverextensions/apache2/manual/new_features_2_2.html
 webserverextensions/apache2/manual/new_features_2_2.html.en
-webserverextensions/apache2/manual/handler.html.es
-webserverextensions/apache2/manual/index.html.ko.euc-kr
-webserverextensions/apache2/manual/install.html.fr.utf8
-webserverextensions/apache2/manual/content-negotiation.html.ko.euc-kr
-webserverextensions/apache2/manual/dns-caveats.html.fr.utf8
-webserverextensions/apache2/manual/custom-error.html.es
-webserverextensions/apache2/manual/configuring.html.de
-webserverextensions/apache2/manual/index.html.ja.utf8
-webserverextensions/apache2/manual/bind.html.fr.utf8
-webserverextensions/apache2/manual/mpm.html.ko.euc-kr
-webserverextensions/apache2/manual/configuring.html.en
-webserverextensions/apache2/manual/sections.html.ja.utf8
-webserverextensions/apache2/manual/handler.html.fr.utf8
-webserverextensions/apache2/manual/sitemap.html.fr.utf8
-webserverextensions/apache2/manual/server-wide.html.ja.utf8
-webserverextensions/apache2/manual/invoking.html.tr.utf8
-webserverextensions/apache2/manual/index.html.tr.utf8
-webserverextensions/apache2/manual/install.html.en
-webserverextensions/apache2/manual/sections.html.fr.utf8
-webserverextensions/apache2/manual/content-negotiation.html.fr.utf8
-webserverextensions/apache2/manual/mpm.html.fr.utf8
-webserverextensions/apache2/manual/index.html.zh-cn.utf8
-webserverextensions/apache2/manual/getting-started.html.fr.utf8
-webserverextensions/apache2/manual/index.html.en
-webserverextensions/apache2/manual/invoking.html.de
-webserverextensions/apache2/manual/index.html.fr.utf8
-webserverextensions/apache2/manual/urlmapping.html.ja.utf8
-webserverextensions/apache2/manual/content-negotiation.html.ja.utf8
-webserverextensions/apache2/manual/install.html.de
-webserverextensions/apache2/manual/handler.html.zh-cn.utf8
-webserverextensions/apache2/manual/install.html.ja.utf8
-webserverextensions/apache2/manual/env.html.ja.utf8
-webserverextensions/apache2/manual/suexec.html.tr.utf8
-webserverextensions/apache2/manual/ssl/
-webserverextensions/apache2/manual/ssl/ssl_intro.html.ja.utf8
-webserverextensions/apache2/manual/ssl/ssl_compat.html.en
-webserverextensions/apache2/manual/ssl/ssl_faq.html.en
-webserverextensions/apache2/manual/ssl/ssl_howto.html.en
-webserverextensions/apache2/manual/ssl/ssl_howto.html.fr.utf8
-webserverextensions/apache2/manual/ssl/index.html.ja.utf8
-webserverextensions/apache2/manual/ssl/index.html.tr.utf8
-webserverextensions/apache2/manual/ssl/index.html.zh-cn.utf8
-webserverextensions/apache2/manual/ssl/index.html.en
-webserverextensions/apache2/manual/ssl/index.html.fr.utf8
-webserverextensions/apache2/manual/ssl/ssl_intro.html.fr.utf8
-webserverextensions/apache2/manual/ssl/ssl_compat.html.fr.utf8
-webserverextensions/apache2/manual/ssl/ssl_faq.html.fr.utf8
-webserverextensions/apache2/manual/ssl/ssl_intro.html.en
-webserverextensions/apache2/manual/bind.html.tr.utf8
-webserverextensions/apache2/manual/new_features_2_0.html.en
-webserverextensions/apache2/manual/urlmapping.html.en
-webserverextensions/apache2/manual/new_features_2_0.html.ko.euc-kr
+webserverextensions/apache2/manual/new_features_2_2.html.fr.utf8
+webserverextensions/apache2/manual/new_features_2_2.html.ko.euc-kr
 webserverextensions/apache2/manual/new_features_2_2.html.pt-br
-webserverextensions/apache2/manual/env.html.en
-webserverextensions/apache2/manual/sitemap.html.es
-webserverextensions/apache2/manual/index.html.pt-br
-webserverextensions/apache2/manual/configuring.html.ja.utf8
-webserverextensions/apache2/manual/glossary.html.fr.utf8
+webserverextensions/apache2/manual/new_features_2_2.html.pt-br.utf8
+webserverextensions/apache2/manual/new_features_2_2.html.tr.utf8
+webserverextensions/apache2/manual/new_features_2_4.html
 webserverextensions/apache2/manual/new_features_2_4.html.en
-webserverextensions/apache2/manual/sections.html.en
-webserverextensions/apache2/manual/mpm.html.en
-webserverextensions/apache2/manual/sections.html.tr.utf8
-webserverextensions/apache2/manual/env.html.ko.euc-kr
-webserverextensions/apache2/manual/content-negotiation.html.en
-webserverextensions/apache2/manual/configuring.html.fr.utf8
-webserverextensions/apache2/manual/invoking.html.en
-webserverextensions/apache2/manual/env.html.tr.utf8
-webserverextensions/apache2/manual/index.html.da
-webserverextensions/apache2/manual/caching.html.tr.utf8
-webserverextensions/apache2/manual/bind.html.ja.utf8
-webserverextensions/apache2/manual/mpm.html.es
-webserverextensions/apache2/manual/suexec.html.fr.utf8
-webserverextensions/apache2/manual/glossary.html.ko.euc-kr
-webserverextensions/apache2/manual/new_features_2_0.html.pt-br
-webserverextensions/apache2/manual/dns-caveats.html.ja.utf8
-webserverextensions/apache2/manual/urlmapping.html.tr.utf8
-webserverextensions/apache2/manual/handler.html.ja.utf8
-webserverextensions/apache2/manual/caching.html.en
-webserverextensions/apache2/manual/getting-started.html.en
-webserverextensions/apache2/manual/handler.html.tr.utf8
+webserverextensions/apache2/manual/new_features_2_4.html.fr.utf8
+webserverextensions/apache2/manual/new_features_2_4.html.pt-br.utf8
+webserverextensions/apache2/manual/new_features_2_4.html.tr.utf8
+webserverextensions/apache2/manual/platform/
+webserverextensions/apache2/manual/platform/ebcdic.html
+webserverextensions/apache2/manual/platform/ebcdic.html.en
+webserverextensions/apache2/manual/platform/ebcdic.html.ko.euc-kr
+webserverextensions/apache2/manual/platform/index.html
+webserverextensions/apache2/manual/platform/index.html.en
+webserverextensions/apache2/manual/platform/index.html.fr.utf8
+webserverextensions/apache2/manual/platform/index.html.ko.euc-kr
+webserverextensions/apache2/manual/platform/index.html.zh-cn.utf8
+webserverextensions/apache2/manual/platform/netware.html
+webserverextensions/apache2/manual/platform/netware.html.en
+webserverextensions/apache2/manual/platform/netware.html.fr.utf8
+webserverextensions/apache2/manual/platform/netware.html.ko.euc-kr
+webserverextensions/apache2/manual/platform/rpm.html
+webserverextensions/apache2/manual/platform/rpm.html.en
+webserverextensions/apache2/manual/platform/rpm.html.fr.utf8
+webserverextensions/apache2/manual/platform/win_compiling.html
+webserverextensions/apache2/manual/platform/win_compiling.html.en
+webserverextensions/apache2/manual/platform/win_compiling.html.fr.utf8
+webserverextensions/apache2/manual/platform/win_compiling.html.ko.euc-kr
+webserverextensions/apache2/manual/platform/windows.html
+webserverextensions/apache2/manual/platform/windows.html.en
+webserverextensions/apache2/manual/platform/windows.html.fr.utf8
+webserverextensions/apache2/manual/platform/windows.html.ko.euc-kr
 webserverextensions/apache2/manual/programs/
+webserverextensions/apache2/manual/programs/ab.html
+webserverextensions/apache2/manual/programs/ab.html.en
+webserverextensions/apache2/manual/programs/ab.html.fr.utf8
+webserverextensions/apache2/manual/programs/ab.html.ko.euc-kr
+webserverextensions/apache2/manual/programs/ab.html.tr.utf8
+webserverextensions/apache2/manual/programs/apachectl.html
 webserverextensions/apache2/manual/programs/apachectl.html.en
-webserverextensions/apache2/manual/programs/dbmmanage.html
-webserverextensions/apache2/manual/programs/htpasswd.html.en
-webserverextensions/apache2/manual/programs/httpd.html.ko.euc-kr
-webserverextensions/apache2/manual/programs/htcacheclean.html.ko.euc-kr
+webserverextensions/apache2/manual/programs/apachectl.html.fr.utf8
+webserverextensions/apache2/manual/programs/apachectl.html.ko.euc-kr
+webserverextensions/apache2/manual/programs/apachectl.html.tr.utf8
 webserverextensions/apache2/manual/programs/apxs.html
-webserverextensions/apache2/manual/programs/htdigest.html
+webserverextensions/apache2/manual/programs/apxs.html.en
+webserverextensions/apache2/manual/programs/apxs.html.fr.utf8
+webserverextensions/apache2/manual/programs/apxs.html.ko.euc-kr
+webserverextensions/apache2/manual/programs/apxs.html.tr.utf8
+webserverextensions/apache2/manual/programs/configure.html
+webserverextensions/apache2/manual/programs/configure.html.en
+webserverextensions/apache2/manual/programs/configure.html.fr.utf8
 webserverextensions/apache2/manual/programs/configure.html.ko.euc-kr
-webserverextensions/apache2/manual/programs/rotatelogs.html
-webserverextensions/apache2/manual/programs/configure.html.fr.utf8
-webserverextensions/apache2/manual/programs/ab.html.tr.utf8
+webserverextensions/apache2/manual/programs/configure.html.tr.utf8
+webserverextensions/apache2/manual/programs/dbmmanage.html
 webserverextensions/apache2/manual/programs/dbmmanage.html.en
-webserverextensions/apache2/manual/programs/suexec.html.en
-webserverextensions/apache2/manual/programs/split-logfile.html
-webserverextensions/apache2/manual/programs/log_server_status.html.en
-webserverextensions/apache2/manual/programs/rotatelogs.html.en
-webserverextensions/apache2/manual/programs/httpd.html.tr.utf8
-webserverextensions/apache2/manual/programs/configure.html.tr.utf8
-webserverextensions/apache2/manual/programs/apxs.html.ko.euc-kr
 webserverextensions/apache2/manual/programs/dbmmanage.html.fr.utf8
+webserverextensions/apache2/manual/programs/dbmmanage.html.ko.euc-kr
+webserverextensions/apache2/manual/programs/dbmmanage.html.tr.utf8
+webserverextensions/apache2/manual/programs/fcgistarter.html
+webserverextensions/apache2/manual/programs/fcgistarter.html.en
+webserverextensions/apache2/manual/programs/fcgistarter.html.fr.utf8
+webserverextensions/apache2/manual/programs/fcgistarter.html.tr.utf8
+webserverextensions/apache2/manual/programs/htcacheclean.html
+webserverextensions/apache2/manual/programs/htcacheclean.html.en
+webserverextensions/apache2/manual/programs/htcacheclean.html.fr.utf8
+webserverextensions/apache2/manual/programs/htcacheclean.html.ko.euc-kr
 webserverextensions/apache2/manual/programs/htcacheclean.html.tr.utf8
+webserverextensions/apache2/manual/programs/htdbm.html
+webserverextensions/apache2/manual/programs/htdbm.html.en
+webserverextensions/apache2/manual/programs/htdbm.html.fr.utf8
+webserverextensions/apache2/manual/programs/htdbm.html.tr.utf8
+webserverextensions/apache2/manual/programs/htdigest.html
+webserverextensions/apache2/manual/programs/htdigest.html.en
+webserverextensions/apache2/manual/programs/htdigest.html.fr.utf8
+webserverextensions/apache2/manual/programs/htdigest.html.ko.euc-kr
 webserverextensions/apache2/manual/programs/htdigest.html.tr.utf8
-webserverextensions/apache2/manual/programs/logresolve.html.fr.utf8
-webserverextensions/apache2/manual/programs/rotatelogs.html.ko.euc-kr
-webserverextensions/apache2/manual/programs/rotatelogs.html.tr.utf8
-webserverextensions/apache2/manual/programs/suexec.html.ko.euc-kr
-webserverextensions/apache2/manual/programs/log_server_status.html.fr.utf8
-webserverextensions/apache2/manual/programs/ab.html.ko.euc-kr
+webserverextensions/apache2/manual/programs/htpasswd.html
+webserverextensions/apache2/manual/programs/htpasswd.html.en
+webserverextensions/apache2/manual/programs/htpasswd.html.fr.utf8
 webserverextensions/apache2/manual/programs/htpasswd.html.ko.euc-kr
-webserverextensions/apache2/manual/programs/ab.html.fr.utf8
-webserverextensions/apache2/manual/programs/index.html.es
-webserverextensions/apache2/manual/programs/htcacheclean.html.fr.utf8
+webserverextensions/apache2/manual/programs/htpasswd.html.tr.utf8
+webserverextensions/apache2/manual/programs/httpd.html
+webserverextensions/apache2/manual/programs/httpd.html.en
 webserverextensions/apache2/manual/programs/httpd.html.fr.utf8
-webserverextensions/apache2/manual/programs/split-logfile.html.en
+webserverextensions/apache2/manual/programs/httpd.html.ko.euc-kr
+webserverextensions/apache2/manual/programs/httpd.html.tr.utf8
+webserverextensions/apache2/manual/programs/httxt2dbm.html
+webserverextensions/apache2/manual/programs/httxt2dbm.html.en
+webserverextensions/apache2/manual/programs/httxt2dbm.html.fr.utf8
 webserverextensions/apache2/manual/programs/httxt2dbm.html.tr.utf8
+webserverextensions/apache2/manual/programs/index.html
+webserverextensions/apache2/manual/programs/index.html.en
+webserverextensions/apache2/manual/programs/index.html.es
+webserverextensions/apache2/manual/programs/index.html.fr.utf8
 webserverextensions/apache2/manual/programs/index.html.ko.euc-kr
-webserverextensions/apache2/manual/programs/fcgistarter.html.tr.utf8
-webserverextensions/apache2/manual/programs/dbmmanage.html.tr.utf8
-webserverextensions/apache2/manual/programs/other.html.tr.utf8
-webserverextensions/apache2/manual/programs/logresolve.html.tr.utf8
-webserverextensions/apache2/manual/programs/htdbm.html.tr.utf8
-webserverextensions/apache2/manual/programs/ab.html.en
-webserverextensions/apache2/manual/programs/htpasswd.html.tr.utf8
 webserverextensions/apache2/manual/programs/index.html.tr.utf8
 webserverextensions/apache2/manual/programs/index.html.zh-cn.utf8
-webserverextensions/apache2/manual/programs/apachectl.html
-webserverextensions/apache2/manual/programs/htdbm.html.fr.utf8
-webserverextensions/apache2/manual/programs/httxt2dbm.html.en
-webserverextensions/apache2/manual/programs/index.html.en
+webserverextensions/apache2/manual/programs/log_server_status.html
+webserverextensions/apache2/manual/programs/log_server_status.html.en
+webserverextensions/apache2/manual/programs/log_server_status.html.fr.utf8
+webserverextensions/apache2/manual/programs/logresolve.html
+webserverextensions/apache2/manual/programs/logresolve.html.en
+webserverextensions/apache2/manual/programs/logresolve.html.fr.utf8
+webserverextensions/apache2/manual/programs/logresolve.html.ko.euc-kr
+webserverextensions/apache2/manual/programs/logresolve.html.tr.utf8
+webserverextensions/apache2/manual/programs/other.html
 webserverextensions/apache2/manual/programs/other.html.en
-webserverextensions/apache2/manual/programs/index.html.fr.utf8
+webserverextensions/apache2/manual/programs/other.html.fr.utf8
 webserverextensions/apache2/manual/programs/other.html.ko.euc-kr
-webserverextensions/apache2/manual/programs/suexec.html.tr.utf8
+webserverextensions/apache2/manual/programs/other.html.tr.utf8
+webserverextensions/apache2/manual/programs/rotatelogs.html
+webserverextensions/apache2/manual/programs/rotatelogs.html.en
+webserverextensions/apache2/manual/programs/rotatelogs.html.fr.utf8
+webserverextensions/apache2/manual/programs/rotatelogs.html.ko.euc-kr
+webserverextensions/apache2/manual/programs/rotatelogs.html.tr.utf8
+webserverextensions/apache2/manual/programs/split-logfile.html
+webserverextensions/apache2/manual/programs/split-logfile.html.en
 webserverextensions/apache2/manual/programs/split-logfile.html.fr.utf8
-webserverextensions/apache2/manual/programs/htdigest.html.en
-webserverextensions/apache2/manual/programs/apachectl.html.fr.utf8
-webserverextensions/apache2/manual/programs/configure.html.en
-webserverextensions/apache2/manual/programs/apachectl.html.ko.euc-kr
+webserverextensions/apache2/manual/programs/suexec.html
+webserverextensions/apache2/manual/programs/suexec.html.en
 webserverextensions/apache2/manual/programs/suexec.html.fr.utf8
-webserverextensions/apache2/manual/programs/rotatelogs.html.fr.utf8
-webserverextensions/apache2/manual/programs/other.html.fr.utf8
-webserverextensions/apache2/manual/programs/htpasswd.html.fr.utf8
-webserverextensions/apache2/manual/programs/httxt2dbm.html.fr.utf8
-webserverextensions/apache2/manual/programs/logresolve.html.ko.euc-kr
-webserverextensions/apache2/manual/programs/htdigest.html.fr.utf8
-webserverextensions/apache2/manual/programs/logresolve.html.en
-webserverextensions/apache2/manual/programs/apachectl.html.tr.utf8
-webserverextensions/apache2/manual/programs/httpd.html.en
-webserverextensions/apache2/manual/programs/htdigest.html.ko.euc-kr
-webserverextensions/apache2/manual/programs/dbmmanage.html.ko.euc-kr
-webserverextensions/apache2/manual/programs/apxs.html.en
-webserverextensions/apache2/manual/programs/htcacheclean.html.en
-webserverextensions/apache2/manual/programs/fcgistarter.html.en
-webserverextensions/apache2/manual/programs/apxs.html.fr.utf8
-webserverextensions/apache2/manual/programs/apxs.html.tr.utf8
-webserverextensions/apache2/manual/programs/fcgistarter.html.fr.utf8
-webserverextensions/apache2/manual/programs/htdbm.html.en
+webserverextensions/apache2/manual/programs/suexec.html.ko.euc-kr
+webserverextensions/apache2/manual/programs/suexec.html.tr.utf8
+webserverextensions/apache2/manual/rewrite/
+webserverextensions/apache2/manual/rewrite/access.html
+webserverextensions/apache2/manual/rewrite/access.html.en
+webserverextensions/apache2/manual/rewrite/access.html.fr.utf8
+webserverextensions/apache2/manual/rewrite/advanced.html
+webserverextensions/apache2/manual/rewrite/advanced.html.en
+webserverextensions/apache2/manual/rewrite/advanced.html.fr.utf8
+webserverextensions/apache2/manual/rewrite/avoid.html
+webserverextensions/apache2/manual/rewrite/avoid.html.en
+webserverextensions/apache2/manual/rewrite/avoid.html.fr.utf8
+webserverextensions/apache2/manual/rewrite/flags.html
+webserverextensions/apache2/manual/rewrite/flags.html.en
+webserverextensions/apache2/manual/rewrite/flags.html.fr.utf8
+webserverextensions/apache2/manual/rewrite/htaccess.html
+webserverextensions/apache2/manual/rewrite/htaccess.html.en
+webserverextensions/apache2/manual/rewrite/htaccess.html.fr.utf8
+webserverextensions/apache2/manual/rewrite/index.html
+webserverextensions/apache2/manual/rewrite/index.html.en
+webserverextensions/apache2/manual/rewrite/index.html.fr.utf8
+webserverextensions/apache2/manual/rewrite/index.html.tr.utf8
+webserverextensions/apache2/manual/rewrite/index.html.zh-cn.utf8
+webserverextensions/apache2/manual/rewrite/intro.html
+webserverextensions/apache2/manual/rewrite/intro.html.en
+webserverextensions/apache2/manual/rewrite/intro.html.fr.utf8
+webserverextensions/apache2/manual/rewrite/proxy.html
+webserverextensions/apache2/manual/rewrite/proxy.html.en
+webserverextensions/apache2/manual/rewrite/proxy.html.fr.utf8
+webserverextensions/apache2/manual/rewrite/remapping.html
+webserverextensions/apache2/manual/rewrite/remapping.html.en
+webserverextensions/apache2/manual/rewrite/remapping.html.fr.utf8
+webserverextensions/apache2/manual/rewrite/rewritemap.html
+webserverextensions/apache2/manual/rewrite/rewritemap.html.en
+webserverextensions/apache2/manual/rewrite/rewritemap.html.fr.utf8
+webserverextensions/apache2/manual/rewrite/tech.html
+webserverextensions/apache2/manual/rewrite/tech.html.en
+webserverextensions/apache2/manual/rewrite/tech.html.fr.utf8
+webserverextensions/apache2/manual/rewrite/vhosts.html
+webserverextensions/apache2/manual/rewrite/vhosts.html.en
+webserverextensions/apache2/manual/rewrite/vhosts.html.fr.utf8
+webserverextensions/apache2/manual/sections.html
+webserverextensions/apache2/manual/sections.html.en
+webserverextensions/apache2/manual/sections.html.fr.utf8
+webserverextensions/apache2/manual/sections.html.ja.utf8
+webserverextensions/apache2/manual/sections.html.ko.euc-kr
+webserverextensions/apache2/manual/sections.html.tr.utf8
+webserverextensions/apache2/manual/server-wide.html
+webserverextensions/apache2/manual/server-wide.html.en
+webserverextensions/apache2/manual/server-wide.html.fr.utf8
+webserverextensions/apache2/manual/server-wide.html.ja.utf8
+webserverextensions/apache2/manual/server-wide.html.ko.euc-kr
+webserverextensions/apache2/manual/server-wide.html.tr.utf8
+webserverextensions/apache2/manual/sitemap.html
+webserverextensions/apache2/manual/sitemap.html.de
+webserverextensions/apache2/manual/sitemap.html.en
+webserverextensions/apache2/manual/sitemap.html.es
+webserverextensions/apache2/manual/sitemap.html.fr.utf8
+webserverextensions/apache2/manual/sitemap.html.ja.utf8
+webserverextensions/apache2/manual/sitemap.html.ko.euc-kr
+webserverextensions/apache2/manual/sitemap.html.tr.utf8
+webserverextensions/apache2/manual/sitemap.html.zh-cn.utf8
+webserverextensions/apache2/manual/socache.html
+webserverextensions/apache2/manual/socache.html.en
+webserverextensions/apache2/manual/socache.html.fr.utf8
+webserverextensions/apache2/manual/ssl/
+webserverextensions/apache2/manual/ssl/index.html
+webserverextensions/apache2/manual/ssl/index.html.en
+webserverextensions/apache2/manual/ssl/index.html.fr.utf8
+webserverextensions/apache2/manual/ssl/index.html.ja.utf8
+webserverextensions/apache2/manual/ssl/index.html.tr.utf8
+webserverextensions/apache2/manual/ssl/index.html.zh-cn.utf8
+webserverextensions/apache2/manual/ssl/ssl_compat.html
+webserverextensions/apache2/manual/ssl/ssl_compat.html.en
+webserverextensions/apache2/manual/ssl/ssl_compat.html.fr.utf8
+webserverextensions/apache2/manual/ssl/ssl_faq.html
+webserverextensions/apache2/manual/ssl/ssl_faq.html.en
+webserverextensions/apache2/manual/ssl/ssl_faq.html.fr.utf8
+webserverextensions/apache2/manual/ssl/ssl_howto.html
+webserverextensions/apache2/manual/ssl/ssl_howto.html.en
+webserverextensions/apache2/manual/ssl/ssl_howto.html.fr.utf8
+webserverextensions/apache2/manual/ssl/ssl_intro.html
+webserverextensions/apache2/manual/ssl/ssl_intro.html.en
+webserverextensions/apache2/manual/ssl/ssl_intro.html.fr.utf8
+webserverextensions/apache2/manual/ssl/ssl_intro.html.ja.utf8
+webserverextensions/apache2/manual/stopping.html
+webserverextensions/apache2/manual/stopping.html.de
+webserverextensions/apache2/manual/stopping.html.en
+webserverextensions/apache2/manual/stopping.html.es
+webserverextensions/apache2/manual/stopping.html.fr.utf8
+webserverextensions/apache2/manual/stopping.html.ja.utf8
+webserverextensions/apache2/manual/stopping.html.ko.euc-kr
+webserverextensions/apache2/manual/stopping.html.tr.utf8
+webserverextensions/apache2/manual/style/
+webserverextensions/apache2/manual/style/build.properties
+webserverextensions/apache2/manual/style/common.dtd
+webserverextensions/apache2/manual/style/css/
+webserverextensions/apache2/manual/style/css/manual-chm.css
+webserverextensions/apache2/manual/style/css/manual-loose-100pc.css
+webserverextensions/apache2/manual/style/css/manual-print.css
+webserverextensions/apache2/manual/style/css/manual-zip-100pc.css
+webserverextensions/apache2/manual/style/css/manual-zip.css
+webserverextensions/apache2/manual/style/css/manual.css
+webserverextensions/apache2/manual/style/css/prettify.css
+webserverextensions/apache2/manual/style/faq.dtd
+webserverextensions/apache2/manual/style/lang.dtd
+webserverextensions/apache2/manual/style/lang/
+webserverextensions/apache2/manual/style/latex/
+webserverextensions/apache2/manual/style/latex/atbeginend.sty
+webserverextensions/apache2/manual/style/manualpage.dtd
+webserverextensions/apache2/manual/style/modulesynopsis.dtd
+webserverextensions/apache2/manual/style/scripts/
+webserverextensions/apache2/manual/style/scripts/MINIFY
+webserverextensions/apache2/manual/style/scripts/prettify.js
+webserverextensions/apache2/manual/style/scripts/prettify.min.js
+webserverextensions/apache2/manual/style/sitemap.dtd
+webserverextensions/apache2/manual/style/version.ent
+webserverextensions/apache2/manual/style/xsl/
+webserverextensions/apache2/manual/style/xsl/util/
+webserverextensions/apache2/manual/suexec.html
+webserverextensions/apache2/manual/suexec.html.en
+webserverextensions/apache2/manual/suexec.html.fr.utf8
+webserverextensions/apache2/manual/suexec.html.ja.utf8
+webserverextensions/apache2/manual/suexec.html.ko.euc-kr
+webserverextensions/apache2/manual/suexec.html.tr.utf8
+webserverextensions/apache2/manual/upgrading.html
+webserverextensions/apache2/manual/upgrading.html.en
+webserverextensions/apache2/manual/upgrading.html.fr.utf8
+webserverextensions/apache2/manual/upgrading.html.pt-br.utf8
+webserverextensions/apache2/manual/urlmapping.html
+webserverextensions/apache2/manual/urlmapping.html.en
+webserverextensions/apache2/manual/urlmapping.html.fr.utf8
+webserverextensions/apache2/manual/urlmapping.html.ja.utf8
+webserverextensions/apache2/manual/urlmapping.html.ko.euc-kr
+webserverextensions/apache2/manual/urlmapping.html.tr.utf8
 webserverextensions/apache2/manual/vhosts/
-webserverextensions/apache2/manual/vhosts/name-based.html.ko.euc-kr
-webserverextensions/apache2/manual/vhosts/mass.html.ko.euc-kr
-webserverextensions/apache2/manual/vhosts/name-based.html.en
-webserverextensions/apache2/manual/vhosts/ip-based.html.fr.utf8
+webserverextensions/apache2/manual/vhosts/details.html
+webserverextensions/apache2/manual/vhosts/details.html.en
+webserverextensions/apache2/manual/vhosts/details.html.fr.utf8
 webserverextensions/apache2/manual/vhosts/details.html.ko.euc-kr
-webserverextensions/apache2/manual/vhosts/ip-based.html.ko.euc-kr
-webserverextensions/apache2/manual/vhosts/fd-limits.html.tr.utf8
+webserverextensions/apache2/manual/vhosts/details.html.tr.utf8
 webserverextensions/apache2/manual/vhosts/examples.html
-webserverextensions/apache2/manual/vhosts/name-based.html.de
-webserverextensions/apache2/manual/vhosts/mass.html.fr.utf8
-webserverextensions/apache2/manual/vhosts/name-based.html.tr.utf8
+webserverextensions/apache2/manual/vhosts/examples.html.en
+webserverextensions/apache2/manual/vhosts/examples.html.fr.utf8
+webserverextensions/apache2/manual/vhosts/examples.html.ja.utf8
+webserverextensions/apache2/manual/vhosts/examples.html.ko.euc-kr
+webserverextensions/apache2/manual/vhosts/examples.html.tr.utf8
+webserverextensions/apache2/manual/vhosts/fd-limits.html
 webserverextensions/apache2/manual/vhosts/fd-limits.html.en
-webserverextensions/apache2/manual/vhosts/details.html.tr.utf8
-webserverextensions/apache2/manual/vhosts/details.html.en
-webserverextensions/apache2/manual/vhosts/mass.html.en
-webserverextensions/apache2/manual/vhosts/ip-based.html.tr.utf8
+webserverextensions/apache2/manual/vhosts/fd-limits.html.fr.utf8
+webserverextensions/apache2/manual/vhosts/fd-limits.html.ja.utf8
 webserverextensions/apache2/manual/vhosts/fd-limits.html.ko.euc-kr
-webserverextensions/apache2/manual/vhosts/examples.html.ko.euc-kr
-webserverextensions/apache2/manual/vhosts/name-based.html.ja.utf8
+webserverextensions/apache2/manual/vhosts/fd-limits.html.tr.utf8
+webserverextensions/apache2/manual/vhosts/index.html
 webserverextensions/apache2/manual/vhosts/index.html.de
+webserverextensions/apache2/manual/vhosts/index.html.en
+webserverextensions/apache2/manual/vhosts/index.html.fr.utf8
+webserverextensions/apache2/manual/vhosts/index.html.ja.utf8
 webserverextensions/apache2/manual/vhosts/index.html.ko.euc-kr
-webserverextensions/apache2/manual/vhosts/index.html.ja.utf8
-webserverextensions/apache2/manual/vhosts/ip-based.html.ja.utf8
 webserverextensions/apache2/manual/vhosts/index.html.tr.utf8
 webserverextensions/apache2/manual/vhosts/index.html.zh-cn.utf8
-webserverextensions/apache2/manual/vhosts/index.html.en
-webserverextensions/apache2/manual/vhosts/index.html.fr.utf8
-webserverextensions/apache2/manual/vhosts/mass.html.tr.utf8
-webserverextensions/apache2/manual/vhosts/examples.html.tr.utf8
-webserverextensions/apache2/manual/vhosts/fd-limits.html.fr.utf8
-webserverextensions/apache2/manual/vhosts/fd-limits.html.ja.utf8
 webserverextensions/apache2/manual/vhosts/ip-based.html.en
+webserverextensions/apache2/manual/vhosts/ip-based.html.fr.utf8
+webserverextensions/apache2/manual/vhosts/ip-based.html.ja.utf8
+webserverextensions/apache2/manual/vhosts/ip-based.html.ko.euc-kr
+webserverextensions/apache2/manual/vhosts/ip-based.html.tr.utf8
+webserverextensions/apache2/manual/vhosts/mass.html
+webserverextensions/apache2/manual/vhosts/mass.html.en
+webserverextensions/apache2/manual/vhosts/mass.html.fr.utf8
+webserverextensions/apache2/manual/vhosts/mass.html.ko.euc-kr
+webserverextensions/apache2/manual/vhosts/mass.html.tr.utf8
+webserverextensions/apache2/manual/vhosts/name-based.html
+webserverextensions/apache2/manual/vhosts/name-based.html.de
+webserverextensions/apache2/manual/vhosts/name-based.html.en
 webserverextensions/apache2/manual/vhosts/name-based.html.fr.utf8
-webserverextensions/apache2/manual/vhosts/examples.html.ja.utf8
-webserverextensions/apache2/manual/vhosts/examples.html.fr.utf8
-webserverextensions/apache2/manual/vhosts/details.html.fr.utf8
-webserverextensions/apache2/manual/vhosts/examples.html.en
-webserverextensions/apache2/manual/custom-error.html.ko.euc-kr
-webserverextensions/apache2/manual/expr.html.fr.utf8
-webserverextensions/apache2/manual/dso.html.ko.euc-kr
-webserverextensions/apache2/manual/images/
-webserverextensions/apache2/manual/images/custom_errordocs.png
-webserverextensions/apache2/manual/images/ssl_intro_fig3.png
-webserverextensions/apache2/manual/images/mod_rewrite_fig1.gif
-webserverextensions/apache2/manual/images/feather.png
-webserverextensions/apache2/manual/images/bal-man-w.png
-webserverextensions/apache2/manual/images/ssl_intro_fig1.png
-webserverextensions/apache2/manual/images/mod_filter_new.gif
-webserverextensions/apache2/manual/images/ssl_intro_fig3.gif
-webserverextensions/apache2/manual/images/build_a_mod_3.png
-webserverextensions/apache2/manual/images/sub.gif
-webserverextensions/apache2/manual/images/mod_filter_new.png
-webserverextensions/apache2/manual/images/rewrite_process_uri.png
-webserverextensions/apache2/manual/images/home.gif
-webserverextensions/apache2/manual/images/up.gif
-webserverextensions/apache2/manual/images/bal-man.png
-webserverextensions/apache2/manual/images/filter_arch.tr.png
-webserverextensions/apache2/manual/images/down.gif
-webserverextensions/apache2/manual/images/pixel.gif
-webserverextensions/apache2/manual/images/apache_header.gif
-webserverextensions/apache2/manual/images/syntax_rewriterule.png
-webserverextensions/apache2/manual/images/index.gif
-webserverextensions/apache2/manual/images/ssl_intro_fig2.png
-webserverextensions/apache2/manual/images/rewrite_backreferences.png
-webserverextensions/apache2/manual/images/mod_filter_new.tr.png
-webserverextensions/apache2/manual/images/mod_rewrite_fig2.gif
-webserverextensions/apache2/manual/images/rewrite_rule_flow.png
-webserverextensions/apache2/manual/images/mod_filter_old.gif
-webserverextensions/apache2/manual/images/favicon.ico
-webserverextensions/apache2/manual/images/left.gif
-webserverextensions/apache2/manual/images/ssl_intro_fig2.gif
-webserverextensions/apache2/manual/images/build_a_mod_2.png
-webserverextensions/apache2/manual/images/bal-man-b.png
-webserverextensions/apache2/manual/images/feather.gif
-webserverextensions/apache2/manual/images/reverse-proxy-arch.png
-webserverextensions/apache2/manual/images/right.gif
-webserverextensions/apache2/manual/images/caching_fig1.tr.png
-webserverextensions/apache2/manual/images/mod_rewrite_fig1.png
-webserverextensions/apache2/manual/images/filter_arch.png
-webserverextensions/apache2/manual/images/mod_rewrite_fig2.png
-webserverextensions/apache2/manual/images/mod_filter_old.png
-webserverextensions/apache2/manual/images/ssl_intro_fig1.gif
-webserverextensions/apache2/manual/images/syntax_rewritecond.png
-webserverextensions/apache2/manual/images/caching_fig1.png
-webserverextensions/apache2/manual/images/build_a_mod_4.png
-webserverextensions/apache2/manual/images/caching_fig1.gif
-webserverextensions/apache2/manual/new_features_2_4.html.tr.utf8
-webserverextensions/apache2/manual/logs.html.fr.utf8
-webserverextensions/apache2/manual/dns-caveats.html.ko.euc-kr
-webserverextensions/apache2/manual/new_features_2_0.html.ja.utf8
-webserverextensions/apache2/manual/sitemap.html.tr.utf8
-webserverextensions/apache2/manual/filter.html.es
-webserverextensions/apache2/manual/faq/
-webserverextensions/apache2/manual/faq/index.html.es
-webserverextensions/apache2/manual/faq/index.html.tr.utf8
-webserverextensions/apache2/manual/faq/index.html.zh-cn.utf8
-webserverextensions/apache2/manual/faq/index.html.en
-webserverextensions/apache2/manual/faq/index.html.fr.utf8
-webserverextensions/apache2/manual/dns-caveats.html.en
-webserverextensions/apache2/manual/license.html
-webserverextensions/apache2/manual/server-wide.html.fr.utf8
-webserverextensions/apache2/manual/misc/
-webserverextensions/apache2/manual/misc/perf-tuning.html.fr.utf8
-webserverextensions/apache2/manual/misc/security_tips.html.tr.utf8
-webserverextensions/apache2/manual/misc/relevant_standards.html.ko.euc-kr
-webserverextensions/apache2/manual/misc/security_tips.html.ko.euc-kr
-webserverextensions/apache2/manual/misc/password_encryptions.html.en
-webserverextensions/apache2/manual/misc/password_encryptions.html.fr.utf8
-webserverextensions/apache2/manual/misc/index.html.es
-webserverextensions/apache2/manual/misc/perf-tuning.html.tr.utf8
-webserverextensions/apache2/manual/misc/perf-tuning.html.en
-webserverextensions/apache2/manual/misc/index.html.ko.euc-kr
-webserverextensions/apache2/manual/misc/index.html.tr.utf8
-webserverextensions/apache2/manual/misc/relevant_standards.html.en
-webserverextensions/apache2/manual/misc/index.html.zh-cn.utf8
-webserverextensions/apache2/manual/misc/index.html.en
-webserverextensions/apache2/manual/misc/index.html.fr.utf8
-webserverextensions/apache2/manual/misc/relevant_standards.html.fr.utf8
-webserverextensions/apache2/manual/misc/perf-tuning.html.ko.euc-kr
-webserverextensions/apache2/manual/misc/security_tips.html.fr.utf8
-webserverextensions/apache2/manual/misc/security_tips.html.en
-webserverextensions/apache2/manual/urlmapping.html.ko.euc-kr
-webserverextensions/apache2/manual/glossary.html.es
-webserverextensions/apache2/manual/install.html.tr.utf8
-webserverextensions/apache2/manual/mpm.html.de
-webserverextensions/apache2/manual/bind.html.de
-webserverextensions/apache2/manual/filter.html.fr.utf8
-webserverextensions/apache2/manual/filter.html.ko.euc-kr
-webserverextensions/apache2/manual/mpm.html.ja.utf8
-webserverextensions/apache2/conf/
-webserverextensions/apache2/conf/httpd.conf
-webserverextensions/apache2/conf/httpd.conf.bak
-webserverextensions/apache2/conf/mime.types
-webserverextensions/apache2/conf/magic
-webserverextensions/apache2/conf/mapguide/
-webserverextensions/apache2/conf/mapguide/workers.properties
-webserverextensions/apache2/conf/mapguide/tomcat.conf
-webserverextensions/apache2/conf/mapguide/mapguide.conf
-webserverextensions/apache2/conf/extra/
-webserverextensions/apache2/conf/extra/httpd-dav.conf
-webserverextensions/apache2/conf/extra/httpd-ssl.conf
-webserverextensions/apache2/conf/extra/httpd-info.conf
-webserverextensions/apache2/conf/extra/proxy-html.conf
-webserverextensions/apache2/conf/extra/httpd-languages.conf
-webserverextensions/apache2/conf/extra/httpd-userdir.conf
-webserverextensions/apache2/conf/extra/httpd-vhosts.conf
-webserverextensions/apache2/conf/extra/httpd-autoindex.conf
-webserverextensions/apache2/conf/extra/httpd-manual.conf
-webserverextensions/apache2/conf/extra/httpd-default.conf
-webserverextensions/apache2/conf/extra/httpd-multilang-errordoc.conf
-webserverextensions/apache2/conf/extra/httpd-mpm.conf
-webserverextensions/apache2/conf/original/
-webserverextensions/apache2/conf/original/httpd.conf
-webserverextensions/apache2/conf/original/extra/
-webserverextensions/apache2/conf/original/extra/httpd-dav.conf
-webserverextensions/apache2/conf/original/extra/httpd-ssl.conf
-webserverextensions/apache2/conf/original/extra/httpd-info.conf
-webserverextensions/apache2/conf/original/extra/proxy-html.conf
-webserverextensions/apache2/conf/original/extra/httpd-languages.conf
-webserverextensions/apache2/conf/original/extra/httpd-userdir.conf
-webserverextensions/apache2/conf/original/extra/httpd-vhosts.conf
-webserverextensions/apache2/conf/original/extra/httpd-autoindex.conf
-webserverextensions/apache2/conf/original/extra/httpd-manual.conf
-webserverextensions/apache2/conf/original/extra/httpd-default.conf
-webserverextensions/apache2/conf/original/extra/httpd-multilang-errordoc.conf
-webserverextensions/apache2/conf/original/extra/httpd-mpm.conf
-webserverextensions/apache2/lib/
-webserverextensions/apache2/lib/libaprutil-1.la
-webserverextensions/apache2/lib/pkgconfig/
-webserverextensions/apache2/lib/pkgconfig/apr-util-1.pc
-webserverextensions/apache2/lib/pkgconfig/apr-1.pc
-webserverextensions/apache2/lib/libaprutil-1.so.0
-webserverextensions/apache2/lib/apr.exp
-webserverextensions/apache2/lib/libapr-1.so
-webserverextensions/apache2/lib/libaprutil-1.a
-webserverextensions/apache2/lib/libapr-1.a
-webserverextensions/apache2/lib/libapr-1.la
-webserverextensions/apache2/lib/libapr-1.so.0
-webserverextensions/apache2/lib/aprutil.exp
-webserverextensions/apache2/lib/libaprutil-1.so.0.6.3
-webserverextensions/apache2/lib/libapr-1.so.0.7.6
-webserverextensions/apache2/icons/
-webserverextensions/apache2/icons/patch.gif
-webserverextensions/apache2/icons/odf6oti.png
-webserverextensions/apache2/icons/pie2.png
-webserverextensions/apache2/icons/dvi.gif
-webserverextensions/apache2/icons/transfer.png
-webserverextensions/apache2/icons/pie1.gif
-webserverextensions/apache2/icons/odf6odp.png
-webserverextensions/apache2/icons/small/
-webserverextensions/apache2/icons/small/patch.gif
-webserverextensions/apache2/icons/small/transfer.png
-webserverextensions/apache2/icons/small/patch.png
-webserverextensions/apache2/icons/small/generic3.png
-webserverextensions/apache2/icons/small/generic.gif
-webserverextensions/apache2/icons/small/generic.png
-webserverextensions/apache2/icons/small/text.gif
-webserverextensions/apache2/icons/small/sound2.png
-webserverextensions/apache2/icons/small/compressed.png
-webserverextensions/apache2/icons/small/transfer.gif
-webserverextensions/apache2/icons/small/compressed.gif
-webserverextensions/apache2/icons/small/sound2.gif
-webserverextensions/apache2/icons/small/binhex.gif
-webserverextensions/apache2/icons/small/sound.png
-webserverextensions/apache2/icons/small/index.png
-webserverextensions/apache2/icons/small/uu.gif
-webserverextensions/apache2/icons/small/broken.png
-webserverextensions/apache2/icons/small/broken.gif
-webserverextensions/apache2/icons/small/forward.png
-webserverextensions/apache2/icons/small/forward.gif
-webserverextensions/apache2/icons/small/back.gif
-webserverextensions/apache2/icons/small/folder.png
-webserverextensions/apache2/icons/small/tar.png
-webserverextensions/apache2/icons/small/blank.gif
-webserverextensions/apache2/icons/small/uu.png
-webserverextensions/apache2/icons/small/index.gif
-webserverextensions/apache2/icons/small/image.png
-webserverextensions/apache2/icons/small/ps.png
-webserverextensions/apache2/icons/small/generic3.gif
-webserverextensions/apache2/icons/small/doc.gif
-webserverextensions/apache2/icons/small/back.png
-webserverextensions/apache2/icons/small/comp2.gif
-webserverextensions/apache2/icons/small/image2.gif
-webserverextensions/apache2/icons/small/burst.gif
-webserverextensions/apache2/icons/small/doc.png
-webserverextensions/apache2/icons/small/continued.png
-webserverextensions/apache2/icons/small/folder2.png
-webserverextensions/apache2/icons/small/blank.png
-webserverextensions/apache2/icons/small/rainbow.png
-webserverextensions/apache2/icons/small/key.png
-webserverextensions/apache2/icons/small/key.gif
-webserverextensions/apache2/icons/small/movie.gif
-webserverextensions/apache2/icons/small/comp1.gif
-webserverextensions/apache2/icons/small/binary.gif
-webserverextensions/apache2/icons/small/generic2.png
-webserverextensions/apache2/icons/small/unknown.png
-webserverextensions/apache2/icons/small/folder2.gif
-webserverextensions/apache2/icons/small/text.png
-webserverextensions/apache2/icons/small/sound.gif
-webserverextensions/apache2/icons/small/ps.gif
-webserverextensions/apache2/icons/small/binary.png
-webserverextensions/apache2/icons/small/unknown.gif
-webserverextensions/apache2/icons/small/continued.gif
-webserverextensions/apache2/icons/small/comp2.png
-webserverextensions/apache2/icons/small/folder.gif
-webserverextensions/apache2/icons/small/tar.gif
-webserverextensions/apache2/icons/small/movie.png
-webserverextensions/apache2/icons/small/binhex.png
-webserverextensions/apache2/icons/small/comp1.png
-webserverextensions/apache2/icons/small/burst.png
-webserverextensions/apache2/icons/small/image.gif
-webserverextensions/apache2/icons/small/rainbow.gif
-webserverextensions/apache2/icons/small/generic2.gif
-webserverextensions/apache2/icons/small/image2.png
-webserverextensions/apache2/icons/alert.red.png
-webserverextensions/apache2/icons/hand.right.gif
-webserverextensions/apache2/icons/hand.up.gif
-webserverextensions/apache2/icons/patch.png
-webserverextensions/apache2/icons/apache_pb.gif
-webserverextensions/apache2/icons/folder.open.gif
-webserverextensions/apache2/icons/icon.sheet.png
-webserverextensions/apache2/icons/generic.gif
-webserverextensions/apache2/icons/sphere1.png
-webserverextensions/apache2/icons/generic.png
-webserverextensions/apache2/icons/folder.sec.gif
-webserverextensions/apache2/icons/folder.open.png
-webserverextensions/apache2/icons/pie5.png
-webserverextensions/apache2/icons/odf6ots.png
-webserverextensions/apache2/icons/world2.gif
-webserverextensions/apache2/icons/text.gif
-webserverextensions/apache2/icons/sound2.png
-webserverextensions/apache2/icons/compressed.png
-webserverextensions/apache2/icons/box2.png
-webserverextensions/apache2/icons/world2.png
-webserverextensions/apache2/icons/generic.red.gif
-webserverextensions/apache2/icons/transfer.gif
-webserverextensions/apache2/icons/compressed.gif
-webserverextensions/apache2/icons/sound2.gif
-webserverextensions/apache2/icons/link.png
-webserverextensions/apache2/icons/binhex.gif
-webserverextensions/apache2/icons/screw2.gif
-webserverextensions/apache2/icons/right.png
-webserverextensions/apache2/icons/alert.black.png
-webserverextensions/apache2/icons/folder.sec.png
-webserverextensions/apache2/icons/p.gif
-webserverextensions/apache2/icons/generic.red.png
-webserverextensions/apache2/icons/index.png
-webserverextensions/apache2/icons/uu.gif
-webserverextensions/apache2/icons/dir.png
-webserverextensions/apache2/icons/p.png
-webserverextensions/apache2/icons/box1.gif
-webserverextensions/apache2/icons/odf6otg.png
-webserverextensions/apache2/icons/broken.png
-webserverextensions/apache2/icons/broken.gif
-webserverextensions/apache2/icons/bomb.png
-webserverextensions/apache2/icons/odf6otc.png
-webserverextensions/apache2/icons/odf6odi.png
-webserverextensions/apache2/icons/forward.png
-webserverextensions/apache2/icons/pdf.png
-webserverextensions/apache2/icons/forward.gif
-webserverextensions/apache2/icons/sphere1.gif
-webserverextensions/apache2/icons/apache_pb.png
-webserverextensions/apache2/icons/odf6odg.png
-webserverextensions/apache2/icons/back.gif
-webserverextensions/apache2/icons/f.png
-webserverextensions/apache2/icons/box2.gif
-webserverextensions/apache2/icons/odf6ott.png
-webserverextensions/apache2/icons/up.gif
-webserverextensions/apache2/icons/pie3.png
-webserverextensions/apache2/icons/image1.png
-webserverextensions/apache2/icons/world1.png
-webserverextensions/apache2/icons/screw1.gif
-webserverextensions/apache2/icons/tex.gif
-webserverextensions/apache2/icons/down.gif
-webserverextensions/apache2/icons/odf6ods.png
-webserverextensions/apache2/icons/folder.png
-webserverextensions/apache2/icons/alert.black.gif
-webserverextensions/apache2/icons/pdf.gif
-webserverextensions/apache2/icons/down.png
-webserverextensions/apache2/icons/ball.gray.png
-webserverextensions/apache2/icons/quill.gif
-webserverextensions/apache2/icons/diskimg.png
-webserverextensions/apache2/icons/comp.gray.png
-webserverextensions/apache2/icons/tar.png
-webserverextensions/apache2/icons/generic.sec.gif
-webserverextensions/apache2/icons/sound1.gif
-webserverextensions/apache2/icons/blank.gif
-webserverextensions/apache2/icons/uu.png
-webserverextensions/apache2/icons/svg.png
-webserverextensions/apache2/icons/index.gif
-webserverextensions/apache2/icons/screw1.png
-webserverextensions/apache2/icons/ps.png
-webserverextensions/apache2/icons/comp.blue.gif
-webserverextensions/apache2/icons/odf6odt.png
-webserverextensions/apache2/icons/pie0.png
-webserverextensions/apache2/icons/pie8.png
-webserverextensions/apache2/icons/pie7.gif
-webserverextensions/apache2/icons/back.png
-webserverextensions/apache2/icons/bomb.gif
-webserverextensions/apache2/icons/image2.gif
-webserverextensions/apache2/icons/c.gif
-webserverextensions/apache2/icons/burst.gif
-webserverextensions/apache2/icons/hand.up.png
-webserverextensions/apache2/icons/f.gif
-webserverextensions/apache2/icons/left.png
-webserverextensions/apache2/icons/odf6otf.png
-webserverextensions/apache2/icons/sphere2.png
-webserverextensions/apache2/icons/screw2.png
-webserverextensions/apache2/icons/continued.png
-webserverextensions/apache2/icons/pie5.gif
-webserverextensions/apache2/icons/blank.png
-webserverextensions/apache2/icons/image3.gif
-webserverextensions/apache2/icons/ball.red.gif
-webserverextensions/apache2/icons/sound1.png
-webserverextensions/apache2/icons/portal.png
-webserverextensions/apache2/icons/pie4.gif
-webserverextensions/apache2/icons/odf6odc.png
-webserverextensions/apache2/icons/pie6.png
-webserverextensions/apache2/icons/odf6odb.png
-webserverextensions/apache2/icons/script.gif
-webserverextensions/apache2/icons/left.gif
-webserverextensions/apache2/icons/a.png
-webserverextensions/apache2/icons/xml.png
-webserverextensions/apache2/icons/movie.gif
-webserverextensions/apache2/icons/apache_pb2.png
-webserverextensions/apache2/icons/icon.sheet.gif
-webserverextensions/apache2/icons/binary.gif
-webserverextensions/apache2/icons/tex.png
-webserverextensions/apache2/icons/odf6oth.png
-webserverextensions/apache2/icons/unknown.png
-webserverextensions/apache2/icons/pie7.png
-webserverextensions/apache2/icons/odf6odf.png
-webserverextensions/apache2/icons/a.gif
-webserverextensions/apache2/icons/layout.png
-webserverextensions/apache2/icons/script.png
-webserverextensions/apache2/icons/odf6odm.png
-webserverextensions/apache2/icons/uuencoded.png
-webserverextensions/apache2/icons/text.png
-webserverextensions/apache2/icons/portal.gif
-webserverextensions/apache2/icons/ball.gray.gif
-webserverextensions/apache2/icons/up.png
-webserverextensions/apache2/icons/link.gif
-webserverextensions/apache2/icons/ps.gif
-webserverextensions/apache2/icons/image1.gif
-webserverextensions/apache2/icons/binary.png
-webserverextensions/apache2/icons/unknown.gif
-webserverextensions/apache2/icons/diskimg.gif
-webserverextensions/apache2/icons/alert.red.gif
-webserverextensions/apache2/icons/continued.gif
-webserverextensions/apache2/icons/right.gif
-webserverextensions/apache2/icons/dir.gif
-webserverextensions/apache2/icons/c.png
-webserverextensions/apache2/icons/pie4.png
-webserverextensions/apache2/icons/comp.blue.png
-webserverextensions/apache2/icons/uuencoded.gif
-webserverextensions/apache2/icons/ball.red.png
-webserverextensions/apache2/icons/folder.gif
-webserverextensions/apache2/icons/image3.png
-webserverextensions/apache2/icons/tar.gif
-webserverextensions/apache2/icons/pie0.gif
-webserverextensions/apache2/icons/sphere2.gif
-webserverextensions/apache2/icons/world1.gif
-webserverextensions/apache2/icons/comp.gray.gif
-webserverextensions/apache2/icons/README.html
-webserverextensions/apache2/icons/quill.png
-webserverextensions/apache2/icons/movie.png
-webserverextensions/apache2/icons/apache_pb2.gif
-webserverextensions/apache2/icons/layout.gif
-webserverextensions/apache2/icons/pie3.gif
-webserverextensions/apache2/icons/odf6otp.png
-webserverextensions/apache2/icons/binhex.png
-webserverextensions/apache2/icons/burst.png
-webserverextensions/apache2/icons/apache_pb.svg
-webserverextensions/apache2/icons/box1.png
-webserverextensions/apache2/icons/hand.right.png
-webserverextensions/apache2/icons/pie6.gif
-webserverextensions/apache2/icons/generic.sec.png
-webserverextensions/apache2/icons/image2.png
-webserverextensions/apache2/icons/pie8.gif
-webserverextensions/apache2/icons/pie2.gif
-webserverextensions/apache2/icons/pie1.png
-webserverextensions/apache2/icons/dvi.png
-webserverextensions/apache2/htdocs/
-webserverextensions/apache2/htdocs/index.html
-webserverextensions/apache2/build/
-webserverextensions/apache2/build/program.mk
-webserverextensions/apache2/build/config_vars.mk
-webserverextensions/apache2/build/library.mk
-webserverextensions/apache2/build/ltlib.mk
-webserverextensions/apache2/build/make_var_export.awk
-webserverextensions/apache2/build/special.mk
-webserverextensions/apache2/build/make_exports.awk
-webserverextensions/apache2/build/config.nice
-webserverextensions/apache2/build/rules.mk
-webserverextensions/apache2/build/libtool
-webserverextensions/apache2/build/mkdir.sh
-webserverextensions/apache2/build/instdso.sh
-webserverextensions/apache2/build/apr_rules.mk
-webserverextensions/apache2/bin/
-webserverextensions/apache2/bin/htpasswd
-webserverextensions/apache2/bin/httxt2dbm
-webserverextensions/apache2/bin/htcacheclean
-webserverextensions/apache2/bin/apachectl
-webserverextensions/apache2/bin/envvars
-webserverextensions/apache2/bin/apxs
-webserverextensions/apache2/bin/apr-1-config
-webserverextensions/apache2/bin/rotatelogs
-webserverextensions/apache2/bin/logresolve
-webserverextensions/apache2/bin/htdbm
-webserverextensions/apache2/bin/checkgid
-webserverextensions/apache2/bin/htdigest
-webserverextensions/apache2/bin/fcgistarter
-webserverextensions/apache2/bin/ab
-webserverextensions/apache2/bin/httpd
-webserverextensions/apache2/bin/envvars-std
-webserverextensions/apache2/bin/dbmmanage
-webserverextensions/apache2/bin/apu-1-config
-webserverextensions/apache2/error/
-webserverextensions/apache2/error/HTTP_NOT_FOUND.html.var
-webserverextensions/apache2/error/HTTP_REQUEST_URI_TOO_LARGE.html.var
-webserverextensions/apache2/error/include/
-webserverextensions/apache2/error/include/spacer.html
-webserverextensions/apache2/error/include/bottom.html
-webserverextensions/apache2/error/include/top.html
-webserverextensions/apache2/error/HTTP_SERVICE_UNAVAILABLE.html.var
-webserverextensions/apache2/error/HTTP_BAD_REQUEST.html.var
-webserverextensions/apache2/error/HTTP_VARIANT_ALSO_VARIES.html.var
-webserverextensions/apache2/error/HTTP_UNAUTHORIZED.html.var
-webserverextensions/apache2/error/HTTP_LENGTH_REQUIRED.html.var
-webserverextensions/apache2/error/HTTP_INTERNAL_SERVER_ERROR.html.var
-webserverextensions/apache2/error/HTTP_GONE.html.var
-webserverextensions/apache2/error/HTTP_PRECONDITION_FAILED.html.var
-webserverextensions/apache2/error/HTTP_FORBIDDEN.html.var
-webserverextensions/apache2/error/HTTP_REQUEST_ENTITY_TOO_LARGE.html.var
-webserverextensions/apache2/error/HTTP_NOT_IMPLEMENTED.html.var
-webserverextensions/apache2/error/HTTP_UNSUPPORTED_MEDIA_TYPE.html.var
-webserverextensions/apache2/error/HTTP_REQUEST_TIME_OUT.html.var
-webserverextensions/apache2/error/HTTP_BAD_GATEWAY.html.var
-webserverextensions/apache2/error/HTTP_METHOD_NOT_ALLOWED.html.var
-webserverextensions/apache2/error/contact.html.var
-webserverextensions/apache2/error/README
+webserverextensions/apache2/manual/vhosts/name-based.html.ja.utf8
+webserverextensions/apache2/manual/vhosts/name-based.html.ko.euc-kr
+webserverextensions/apache2/manual/vhosts/name-based.html.tr.utf8
 webserverextensions/apache2/modules/
-webserverextensions/apache2/modules/mod_proxy_fdpass.so
-webserverextensions/apache2/modules/mod_lbmethod_byrequests.so
+webserverextensions/apache2/modules/httpd.exp
+webserverextensions/apache2/modules/libphp.so
+webserverextensions/apache2/modules/mod_access_compat.so
+webserverextensions/apache2/modules/mod_actions.so
+webserverextensions/apache2/modules/mod_alias.so
+webserverextensions/apache2/modules/mod_allowmethods.so
+webserverextensions/apache2/modules/mod_auth_basic.so
 webserverextensions/apache2/modules/mod_auth_digest.so
+webserverextensions/apache2/modules/mod_auth_form.so
+webserverextensions/apache2/modules/mod_authn_anon.so
+webserverextensions/apache2/modules/mod_authn_core.so
+webserverextensions/apache2/modules/mod_authn_dbd.so
+webserverextensions/apache2/modules/mod_authn_dbm.so
+webserverextensions/apache2/modules/mod_authn_file.so
 webserverextensions/apache2/modules/mod_authn_socache.so
-webserverextensions/apache2/modules/mod_substitute.so
+webserverextensions/apache2/modules/mod_authz_core.so
+webserverextensions/apache2/modules/mod_authz_dbd.so
+webserverextensions/apache2/modules/mod_authz_dbm.so
+webserverextensions/apache2/modules/mod_authz_groupfile.so
+webserverextensions/apache2/modules/mod_authz_host.so
+webserverextensions/apache2/modules/mod_authz_owner.so
+webserverextensions/apache2/modules/mod_authz_user.so
+webserverextensions/apache2/modules/mod_autoindex.so
+webserverextensions/apache2/modules/mod_buffer.so
+webserverextensions/apache2/modules/mod_cache.so
+webserverextensions/apache2/modules/mod_cache_disk.so
+webserverextensions/apache2/modules/mod_cache_socache.so
+webserverextensions/apache2/modules/mod_cgid.so
+webserverextensions/apache2/modules/mod_dav.so
+webserverextensions/apache2/modules/mod_dav_fs.so
+webserverextensions/apache2/modules/mod_dbd.so
+webserverextensions/apache2/modules/mod_deflate.so
+webserverextensions/apache2/modules/mod_dir.so
+webserverextensions/apache2/modules/mod_dumpio.so
+webserverextensions/apache2/modules/mod_env.so
+webserverextensions/apache2/modules/mod_expires.so
+webserverextensions/apache2/modules/mod_ext_filter.so
+webserverextensions/apache2/modules/mod_file_cache.so
+webserverextensions/apache2/modules/mod_filter.so
+webserverextensions/apache2/modules/mod_headers.so
 webserverextensions/apache2/modules/mod_include.so
-webserverextensions/apache2/modules/mod_alias.so
 webserverextensions/apache2/modules/mod_info.so
-webserverextensions/apache2/modules/mod_remoteip.so
-webserverextensions/apache2/modules/mod_auth_basic.so
-webserverextensions/apache2/modules/mod_setenvif.so
-webserverextensions/apache2/modules/mod_proxy_scgi.so
-webserverextensions/apache2/modules/mod_negotiation.so
-webserverextensions/apache2/modules/mod_proxy_http.so
-webserverextensions/apache2/modules/mod_proxy_ajp.so
-webserverextensions/apache2/modules/mod_dumpio.so
-webserverextensions/apache2/modules/mod_unique_id.so
-webserverextensions/apache2/modules/mod_authn_dbd.so
-webserverextensions/apache2/modules/mod_version.so
+webserverextensions/apache2/modules/mod_jk.so
+webserverextensions/apache2/modules/mod_lbmethod_bybusyness.so
+webserverextensions/apache2/modules/mod_lbmethod_byrequests.so
+webserverextensions/apache2/modules/mod_lbmethod_bytraffic.so
+webserverextensions/apache2/modules/mod_lbmethod_heartbeat.so
+webserverextensions/apache2/modules/mod_log_config.so
 webserverextensions/apache2/modules/mod_log_debug.so
-webserverextensions/apache2/modules/mod_sed.so
-webserverextensions/apache2/modules/mod_filter.so
-webserverextensions/apache2/modules/mod_userdir.so
-webserverextensions/apache2/modules/mod_proxy.so
-webserverextensions/apache2/modules/mod_session_dbd.so
-webserverextensions/apache2/modules/mod_proxy_hcheck.so
-webserverextensions/apache2/modules/mod_authz_groupfile.so
-webserverextensions/apache2/modules/mod_unixd.so
-webserverextensions/apache2/modules/libphp.so
-webserverextensions/apache2/modules/mod_ext_filter.so
 webserverextensions/apache2/modules/mod_logio.so
-webserverextensions/apache2/modules/mod_mime.so
-webserverextensions/apache2/modules/mod_lbmethod_heartbeat.so
-webserverextensions/apache2/modules/mod_authz_core.so
 webserverextensions/apache2/modules/mod_macro.so
-webserverextensions/apache2/modules/mod_lbmethod_bybusyness.so
-webserverextensions/apache2/modules/mod_allowmethods.so
-webserverextensions/apache2/modules/mod_cache_disk.so
-webserverextensions/apache2/modules/mod_actions.so
-webserverextensions/apache2/modules/mod_expires.so
 webserverextensions/apache2/modules/mod_mgmapagent.so
-webserverextensions/apache2/modules/mod_authz_host.so
+webserverextensions/apache2/modules/mod_mime.so
+webserverextensions/apache2/modules/mod_negotiation.so
+webserverextensions/apache2/modules/mod_proxy.so
+webserverextensions/apache2/modules/mod_proxy_ajp.so
+webserverextensions/apache2/modules/mod_proxy_balancer.so
 webserverextensions/apache2/modules/mod_proxy_connect.so
-webserverextensions/apache2/modules/mod_dbd.so
-webserverextensions/apache2/modules/mod_socache_dbm.so
-webserverextensions/apache2/modules/mod_file_cache.so
-webserverextensions/apache2/modules/mod_env.so
-webserverextensions/apache2/modules/mod_authz_user.so
-webserverextensions/apache2/modules/mod_headers.so
+webserverextensions/apache2/modules/mod_proxy_express.so
 webserverextensions/apache2/modules/mod_proxy_fcgi.so
-webserverextensions/apache2/modules/mod_dav_fs.so
-webserverextensions/apache2/modules/mod_cache_socache.so
-webserverextensions/apache2/modules/mod_watchdog.so
-webserverextensions/apache2/modules/mod_auth_form.so
-webserverextensions/apache2/modules/httpd.exp
+webserverextensions/apache2/modules/mod_proxy_fdpass.so
 webserverextensions/apache2/modules/mod_proxy_ftp.so
-webserverextensions/apache2/modules/mod_lbmethod_bytraffic.so
+webserverextensions/apache2/modules/mod_proxy_hcheck.so
+webserverextensions/apache2/modules/mod_proxy_http.so
+webserverextensions/apache2/modules/mod_proxy_scgi.so
+webserverextensions/apache2/modules/mod_proxy_uwsgi.so
+webserverextensions/apache2/modules/mod_proxy_wstunnel.so
 webserverextensions/apache2/modules/mod_ratelimit.so
-webserverextensions/apache2/modules/mod_proxy_uwsgi.so
+webserverextensions/apache2/modules/mod_remoteip.so
+webserverextensions/apache2/modules/mod_reqtimeout.so
 webserverextensions/apache2/modules/mod_request.so
-webserverextensions/apache2/modules/mod_dir.so
+webserverextensions/apache2/modules/mod_rewrite.so
+webserverextensions/apache2/modules/mod_sed.so
 webserverextensions/apache2/modules/mod_session.so
-webserverextensions/apache2/modules/mod_reqtimeout.so
+webserverextensions/apache2/modules/mod_session_cookie.so
+webserverextensions/apache2/modules/mod_session_dbd.so
+webserverextensions/apache2/modules/mod_setenvif.so
+webserverextensions/apache2/modules/mod_slotmem_shm.so
+webserverextensions/apache2/modules/mod_socache_dbm.so
+webserverextensions/apache2/modules/mod_socache_memcache.so
+webserverextensions/apache2/modules/mod_socache_redis.so
+webserverextensions/apache2/modules/mod_socache_shmcb.so
 webserverextensions/apache2/modules/mod_speling.so
-webserverextensions/apache2/modules/mod_socache_memcache.so
-webserverextensions/apache2/modules/mod_authz_owner.so
-webserverextensions/apache2/modules/mod_authn_file.so
-webserverextensions/apache2/modules/mod_authn_dbm.so
-webserverextensions/apache2/modules/mod_autoindex.so
-webserverextensions/apache2/modules/mod_dav.so
-webserverextensions/apache2/modules/mod_access_compat.so
-webserverextensions/apache2/modules/mod_proxy_wstunnel.so
 webserverextensions/apache2/modules/mod_status.so
-webserverextensions/apache2/modules/mod_slotmem_shm.so
-webserverextensions/apache2/modules/mod_socache_shmcb.so
-webserverextensions/apache2/modules/mod_socache_redis.so
-webserverextensions/apache2/modules/mod_proxy_balancer.so
-webserverextensions/apache2/modules/mod_rewrite.so
-webserverextensions/apache2/modules/mod_authz_dbm.so
-webserverextensions/apache2/modules/mod_proxy_express.so
-webserverextensions/apache2/modules/mod_authz_dbd.so
-webserverextensions/apache2/modules/mod_cache.so
-webserverextensions/apache2/modules/mod_buffer.so
+webserverextensions/apache2/modules/mod_substitute.so
+webserverextensions/apache2/modules/mod_unique_id.so
+webserverextensions/apache2/modules/mod_unixd.so
+webserverextensions/apache2/modules/mod_userdir.so
+webserverextensions/apache2/modules/mod_version.so
 webserverextensions/apache2/modules/mod_vhost_alias.so
-webserverextensions/apache2/modules/mod_session_cookie.so
-webserverextensions/apache2/modules/mod_jk.so
-webserverextensions/apache2/modules/mod_authn_anon.so
-webserverextensions/apache2/modules/mod_cgid.so
-webserverextensions/apache2/modules/mod_deflate.so
-webserverextensions/apache2/modules/mod_authn_core.so
-webserverextensions/apache2/modules/mod_log_config.so
-webserverextensions/apache2/logs/
+webserverextensions/apache2/modules/mod_watchdog.so
+webserverextensions/bin/
+webserverextensions/bin/mgdevhttpserver
+webserverextensions/bin/mgdevhttpserver.sh
 webserverextensions/lib64/
-webserverextensions/lib64/libMgWebApp.so
-webserverextensions/lib64/libMgWebSupport-4.0.0.so
-webserverextensions/lib64/libphp_MapGuideApi-4.0.0.so
-webserverextensions/lib64/libMgHttpHandler-4.0.0.so
-webserverextensions/lib64/libphp_MapGuideApi.so
-webserverextensions/lib64/liblib_json.so
+webserverextensions/lib64/libMapGuideJavaApi-4.0.1.so
 webserverextensions/lib64/libMapGuideJavaApi.so
-webserverextensions/lib64/mod_mgmapagent-4.0.0.so
-webserverextensions/lib64/libMgWebApp-4.0.0.so
+webserverextensions/lib64/libMgHttpHandler-4.0.1.so
 webserverextensions/lib64/libMgHttpHandler.so
+webserverextensions/lib64/libMgWebApp-4.0.1.so
+webserverextensions/lib64/libMgWebApp.so
+webserverextensions/lib64/libMgWebSupport-4.0.1.so
 webserverextensions/lib64/libMgWebSupport.so
-webserverextensions/lib64/libMapGuideJavaApi-4.0.0.so
+webserverextensions/lib64/liblib_json.so
+webserverextensions/lib64/mod_mgmapagent-4.0.1.so
+webserverextensions/php/
+webserverextensions/php/bin/
+webserverextensions/php/bin/phar
+webserverextensions/php/bin/phar.phar
+webserverextensions/php/bin/php
+webserverextensions/php/bin/php-cgi
+webserverextensions/php/bin/php-config
+webserverextensions/php/bin/phpdbg
+webserverextensions/php/bin/phpize
+webserverextensions/php/include/
+webserverextensions/php/include/php/
+webserverextensions/php/include/php/TSRM/
+webserverextensions/php/include/php/TSRM/TSRM.h
+webserverextensions/php/include/php/TSRM/tsrm_win32.h
+webserverextensions/php/include/php/Zend/
+webserverextensions/php/include/php/Zend/Optimizer/
+webserverextensions/php/include/php/Zend/Optimizer/zend_call_graph.h
+webserverextensions/php/include/php/Zend/Optimizer/zend_cfg.h
+webserverextensions/php/include/php/Zend/Optimizer/zend_dfg.h
+webserverextensions/php/include/php/Zend/Optimizer/zend_dump.h
+webserverextensions/php/include/php/Zend/Optimizer/zend_func_info.h
+webserverextensions/php/include/php/Zend/Optimizer/zend_inference.h
+webserverextensions/php/include/php/Zend/Optimizer/zend_optimizer.h
+webserverextensions/php/include/php/Zend/Optimizer/zend_ssa.h
+webserverextensions/php/include/php/Zend/zend.h
+webserverextensions/php/include/php/Zend/zend_API.h
+webserverextensions/php/include/php/Zend/zend_alloc.h
+webserverextensions/php/include/php/Zend/zend_alloc_sizes.h
+webserverextensions/php/include/php/Zend/zend_arena.h
+webserverextensions/php/include/php/Zend/zend_ast.h
+webserverextensions/php/include/php/Zend/zend_atomic.h
+webserverextensions/php/include/php/Zend/zend_attributes.h
+webserverextensions/php/include/php/Zend/zend_attributes_arginfo.h
+webserverextensions/php/include/php/Zend/zend_bitset.h
+webserverextensions/php/include/php/Zend/zend_build.h
+webserverextensions/php/include/php/Zend/zend_builtin_functions.h
+webserverextensions/php/include/php/Zend/zend_builtin_functions_arginfo.h
+webserverextensions/php/include/php/Zend/zend_call_stack.h
+webserverextensions/php/include/php/Zend/zend_closures.h
+webserverextensions/php/include/php/Zend/zend_closures_arginfo.h
+webserverextensions/php/include/php/Zend/zend_compile.h
+webserverextensions/php/include/php/Zend/zend_config.h
+webserverextensions/php/include/php/Zend/zend_config.w32.h
+webserverextensions/php/include/php/Zend/zend_constants.h
+webserverextensions/php/include/php/Zend/zend_constants_arginfo.h
+webserverextensions/php/include/php/Zend/zend_cpuinfo.h
+webserverextensions/php/include/php/Zend/zend_dtrace.h
+webserverextensions/php/include/php/Zend/zend_enum.h
+webserverextensions/php/include/php/Zend/zend_enum_arginfo.h
+webserverextensions/php/include/php/Zend/zend_errors.h
+webserverextensions/php/include/php/Zend/zend_exceptions.h
+webserverextensions/php/include/php/Zend/zend_exceptions_arginfo.h
+webserverextensions/php/include/php/Zend/zend_execute.h
+webserverextensions/php/include/php/Zend/zend_extensions.h
+webserverextensions/php/include/php/Zend/zend_fibers.h
+webserverextensions/php/include/php/Zend/zend_fibers_arginfo.h
+webserverextensions/php/include/php/Zend/zend_float.h
+webserverextensions/php/include/php/Zend/zend_gc.h
+webserverextensions/php/include/php/Zend/zend_gdb.h
+webserverextensions/php/include/php/Zend/zend_generators.h
+webserverextensions/php/include/php/Zend/zend_generators_arginfo.h
+webserverextensions/php/include/php/Zend/zend_globals.h
+webserverextensions/php/include/php/Zend/zend_globals_macros.h
+webserverextensions/php/include/php/Zend/zend_hash.h
+webserverextensions/php/include/php/Zend/zend_highlight.h
+webserverextensions/php/include/php/Zend/zend_hrtime.h
+webserverextensions/php/include/php/Zend/zend_inheritance.h
+webserverextensions/php/include/php/Zend/zend_ini.h
+webserverextensions/php/include/php/Zend/zend_ini_parser.h
+webserverextensions/php/include/php/Zend/zend_ini_scanner.h
+webserverextensions/php/include/php/Zend/zend_ini_scanner_defs.h
+webserverextensions/php/include/php/Zend/zend_interfaces.h
+webserverextensions/php/include/php/Zend/zend_interfaces_arginfo.h
+webserverextensions/php/include/php/Zend/zend_istdiostream.h
+webserverextensions/php/include/php/Zend/zend_iterators.h
+webserverextensions/php/include/php/Zend/zend_language_parser.h
+webserverextensions/php/include/php/Zend/zend_language_scanner.h
+webserverextensions/php/include/php/Zend/zend_language_scanner_defs.h
+webserverextensions/php/include/php/Zend/zend_list.h
+webserverextensions/php/include/php/Zend/zend_llist.h
+webserverextensions/php/include/php/Zend/zend_long.h
+webserverextensions/php/include/php/Zend/zend_map_ptr.h
+webserverextensions/php/include/php/Zend/zend_max_execution_timer.h
+webserverextensions/php/include/php/Zend/zend_mmap.h
+webserverextensions/php/include/php/Zend/zend_modules.h
+webserverextensions/php/include/php/Zend/zend_multibyte.h
+webserverextensions/php/include/php/Zend/zend_multiply.h
+webserverextensions/php/include/php/Zend/zend_object_handlers.h
+webserverextensions/php/include/php/Zend/zend_objects.h
+webserverextensions/php/include/php/Zend/zend_objects_API.h
+webserverextensions/php/include/php/Zend/zend_observer.h
+webserverextensions/php/include/php/Zend/zend_operators.h
+webserverextensions/php/include/php/Zend/zend_portability.h
+webserverextensions/php/include/php/Zend/zend_ptr_stack.h
+webserverextensions/php/include/php/Zend/zend_range_check.h
+webserverextensions/php/include/php/Zend/zend_signal.h
+webserverextensions/php/include/php/Zend/zend_smart_str.h
+webserverextensions/php/include/php/Zend/zend_smart_str_public.h
+webserverextensions/php/include/php/Zend/zend_smart_string.h
+webserverextensions/php/include/php/Zend/zend_smart_string_public.h
+webserverextensions/php/include/php/Zend/zend_sort.h
+webserverextensions/php/include/php/Zend/zend_stack.h
+webserverextensions/php/include/php/Zend/zend_stream.h
+webserverextensions/php/include/php/Zend/zend_string.h
+webserverextensions/php/include/php/Zend/zend_strtod.h
+webserverextensions/php/include/php/Zend/zend_strtod_int.h
+webserverextensions/php/include/php/Zend/zend_system_id.h
+webserverextensions/php/include/php/Zend/zend_type_info.h
+webserverextensions/php/include/php/Zend/zend_types.h
+webserverextensions/php/include/php/Zend/zend_variables.h
+webserverextensions/php/include/php/Zend/zend_virtual_cwd.h
+webserverextensions/php/include/php/Zend/zend_vm.h
+webserverextensions/php/include/php/Zend/zend_vm_def.h
+webserverextensions/php/include/php/Zend/zend_vm_execute.h
+webserverextensions/php/include/php/Zend/zend_vm_handlers.h
+webserverextensions/php/include/php/Zend/zend_vm_opcodes.h
+webserverextensions/php/include/php/Zend/zend_vm_trace_handlers.h
+webserverextensions/php/include/php/Zend/zend_vm_trace_lines.h
+webserverextensions/php/include/php/Zend/zend_vm_trace_map.h
+webserverextensions/php/include/php/Zend/zend_weakrefs.h
+webserverextensions/php/include/php/Zend/zend_weakrefs_arginfo.h
+webserverextensions/php/include/php/ext/
+webserverextensions/php/include/php/ext/date/
+webserverextensions/php/include/php/ext/date/lib/
+webserverextensions/php/include/php/ext/date/lib/timelib.h
+webserverextensions/php/include/php/ext/date/lib/timelib_config.h
+webserverextensions/php/include/php/ext/date/php_date.h
+webserverextensions/php/include/php/ext/dom/
+webserverextensions/php/include/php/ext/dom/xml_common.h
+webserverextensions/php/include/php/ext/filter/
+webserverextensions/php/include/php/ext/filter/php_filter.h
+webserverextensions/php/include/php/ext/gd/
+webserverextensions/php/include/php/ext/gd/gd_arginfo.h
+webserverextensions/php/include/php/ext/gd/gd_compat.h
+webserverextensions/php/include/php/ext/gd/libgd/
+webserverextensions/php/include/php/ext/gd/libgd/bmp.h
+webserverextensions/php/include/php/ext/gd/libgd/gd.h
+webserverextensions/php/include/php/ext/gd/libgd/gd_errors.h
+webserverextensions/php/include/php/ext/gd/libgd/gd_intern.h
+webserverextensions/php/include/php/ext/gd/libgd/gd_io.h
+webserverextensions/php/include/php/ext/gd/libgd/gd_tga.h
+webserverextensions/php/include/php/ext/gd/libgd/gdcache.h
+webserverextensions/php/include/php/ext/gd/libgd/gdfontg.h
+webserverextensions/php/include/php/ext/gd/libgd/gdfontl.h
+webserverextensions/php/include/php/ext/gd/libgd/gdfontmb.h
+webserverextensions/php/include/php/ext/gd/libgd/gdfonts.h
+webserverextensions/php/include/php/ext/gd/libgd/gdfontt.h
+webserverextensions/php/include/php/ext/gd/libgd/gdhelpers.h
+webserverextensions/php/include/php/ext/gd/libgd/jisx0208.h
+webserverextensions/php/include/php/ext/gd/libgd/wbmp.h
+webserverextensions/php/include/php/ext/gd/php_gd.h
+webserverextensions/php/include/php/ext/hash/
+webserverextensions/php/include/php/ext/hash/php_hash.h
+webserverextensions/php/include/php/ext/hash/php_hash_adler32.h
+webserverextensions/php/include/php/ext/hash/php_hash_crc32.h
+webserverextensions/php/include/php/ext/hash/php_hash_fnv.h
+webserverextensions/php/include/php/ext/hash/php_hash_gost.h
+webserverextensions/php/include/php/ext/hash/php_hash_haval.h
+webserverextensions/php/include/php/ext/hash/php_hash_joaat.h
+webserverextensions/php/include/php/ext/hash/php_hash_md.h
+webserverextensions/php/include/php/ext/hash/php_hash_murmur.h
+webserverextensions/php/include/php/ext/hash/php_hash_ripemd.h
+webserverextensions/php/include/php/ext/hash/php_hash_sha.h
+webserverextensions/php/include/php/ext/hash/php_hash_sha3.h
+webserverextensions/php/include/php/ext/hash/php_hash_snefru.h
+webserverextensions/php/include/php/ext/hash/php_hash_tiger.h
+webserverextensions/php/include/php/ext/hash/php_hash_whirlpool.h
+webserverextensions/php/include/php/ext/hash/php_hash_xxhash.h
+webserverextensions/php/include/php/ext/iconv/
+webserverextensions/php/include/php/ext/iconv/iconv_arginfo.h
+webserverextensions/php/include/php/ext/iconv/php_iconv.h
+webserverextensions/php/include/php/ext/json/
+webserverextensions/php/include/php/ext/json/php_json.h
+webserverextensions/php/include/php/ext/json/php_json_parser.h
+webserverextensions/php/include/php/ext/json/php_json_scanner.h
+webserverextensions/php/include/php/ext/libxml/
+webserverextensions/php/include/php/ext/libxml/php_libxml.h
+webserverextensions/php/include/php/ext/mbstring/
+webserverextensions/php/include/php/ext/mbstring/libmbfl/
+webserverextensions/php/include/php/ext/mbstring/libmbfl/config.h
+webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/
+webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/eaw_table.h
+webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfilter.h
+webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfilter_8bit.h
+webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfilter_pass.h
+webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfilter_wchar.h
+webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfl_consts.h
+webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfl_convert.h
+webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfl_defs.h
+webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfl_encoding.h
+webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfl_filter_output.h
+webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfl_language.h
+webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfl_memory_device.h
+webserverextensions/php/include/php/ext/mbstring/libmbfl/mbfl/mbfl_string.h
+webserverextensions/php/include/php/ext/mbstring/mbstring.h
+webserverextensions/php/include/php/ext/mbstring/php_mbregex.h
+webserverextensions/php/include/php/ext/mbstring/php_onig_compat.h
+webserverextensions/php/include/php/ext/pcre/
+webserverextensions/php/include/php/ext/pcre/pcre2lib/
+webserverextensions/php/include/php/ext/pcre/pcre2lib/config.h
+webserverextensions/php/include/php/ext/pcre/pcre2lib/pcre2.h
+webserverextensions/php/include/php/ext/pcre/pcre2lib/pcre2_internal.h
+webserverextensions/php/include/php/ext/pcre/pcre2lib/pcre2_intmodedep.h
+webserverextensions/php/include/php/ext/pcre/pcre2lib/pcre2_jit_neon_inc.h
+webserverextensions/php/include/php/ext/pcre/pcre2lib/pcre2_jit_simd_inc.h
+webserverextensions/php/include/php/ext/pcre/pcre2lib/pcre2_ucp.h
+webserverextensions/php/include/php/ext/pcre/php_pcre.h
+webserverextensions/php/include/php/ext/pdo/
+webserverextensions/php/include/php/ext/pdo/php_pdo.h
+webserverextensions/php/include/php/ext/pdo/php_pdo_driver.h
+webserverextensions/php/include/php/ext/pdo/php_pdo_error.h
+webserverextensions/php/include/php/ext/phar/
+webserverextensions/php/include/php/ext/phar/php_phar.h
+webserverextensions/php/include/php/ext/random/
+webserverextensions/php/include/php/ext/random/php_random.h
+webserverextensions/php/include/php/ext/session/
+webserverextensions/php/include/php/ext/session/mod_files.h
+webserverextensions/php/include/php/ext/session/mod_user.h
+webserverextensions/php/include/php/ext/session/php_session.h
+webserverextensions/php/include/php/ext/simplexml/
+webserverextensions/php/include/php/ext/simplexml/php_simplexml.h
+webserverextensions/php/include/php/ext/simplexml/php_simplexml_exports.h
+webserverextensions/php/include/php/ext/spl/
+webserverextensions/php/include/php/ext/spl/php_spl.h
+webserverextensions/php/include/php/ext/spl/spl_array.h
+webserverextensions/php/include/php/ext/spl/spl_directory.h
+webserverextensions/php/include/php/ext/spl/spl_dllist.h
+webserverextensions/php/include/php/ext/spl/spl_engine.h
+webserverextensions/php/include/php/ext/spl/spl_exceptions.h
+webserverextensions/php/include/php/ext/spl/spl_fixedarray.h
+webserverextensions/php/include/php/ext/spl/spl_functions.h
+webserverextensions/php/include/php/ext/spl/spl_heap.h
+webserverextensions/php/include/php/ext/spl/spl_iterators.h
+webserverextensions/php/include/php/ext/spl/spl_observer.h
+webserverextensions/php/include/php/ext/standard/
+webserverextensions/php/include/php/ext/standard/base64.h
+webserverextensions/php/include/php/ext/standard/basic_functions.h
+webserverextensions/php/include/php/ext/standard/basic_functions_arginfo.h
+webserverextensions/php/include/php/ext/standard/crc32.h
+webserverextensions/php/include/php/ext/standard/crc32_x86.h
+webserverextensions/php/include/php/ext/standard/credits.h
+webserverextensions/php/include/php/ext/standard/credits_ext.h
+webserverextensions/php/include/php/ext/standard/credits_sapi.h
+webserverextensions/php/include/php/ext/standard/crypt_blowfish.h
+webserverextensions/php/include/php/ext/standard/crypt_freesec.h
+webserverextensions/php/include/php/ext/standard/css.h
+webserverextensions/php/include/php/ext/standard/datetime.h
+webserverextensions/php/include/php/ext/standard/dir_arginfo.h
+webserverextensions/php/include/php/ext/standard/dl.h
+webserverextensions/php/include/php/ext/standard/dl_arginfo.h
+webserverextensions/php/include/php/ext/standard/exec.h
+webserverextensions/php/include/php/ext/standard/file.h
+webserverextensions/php/include/php/ext/standard/file_arginfo.h
+webserverextensions/php/include/php/ext/standard/flock_compat.h
+webserverextensions/php/include/php/ext/standard/fsock.h
+webserverextensions/php/include/php/ext/standard/head.h
+webserverextensions/php/include/php/ext/standard/html.h
+webserverextensions/php/include/php/ext/standard/html_tables.h
+webserverextensions/php/include/php/ext/standard/info.h
+webserverextensions/php/include/php/ext/standard/md5.h
+webserverextensions/php/include/php/ext/standard/pack.h
+webserverextensions/php/include/php/ext/standard/pageinfo.h
+webserverextensions/php/include/php/ext/standard/php_array.h
+webserverextensions/php/include/php/ext/standard/php_assert.h
+webserverextensions/php/include/php/ext/standard/php_browscap.h
+webserverextensions/php/include/php/ext/standard/php_crypt.h
+webserverextensions/php/include/php/ext/standard/php_crypt_r.h
+webserverextensions/php/include/php/ext/standard/php_dir.h
+webserverextensions/php/include/php/ext/standard/php_dns.h
+webserverextensions/php/include/php/ext/standard/php_ext_syslog.h
+webserverextensions/php/include/php/ext/standard/php_filestat.h
+webserverextensions/php/include/php/ext/standard/php_fopen_wrappers.h
+webserverextensions/php/include/php/ext/standard/php_http.h
+webserverextensions/php/include/php/ext/standard/php_image.h
+webserverextensions/php/include/php/ext/standard/php_incomplete_class.h
+webserverextensions/php/include/php/ext/standard/php_lcg.h
+webserverextensions/php/include/php/ext/standard/php_mail.h
+webserverextensions/php/include/php/ext/standard/php_math.h
+webserverextensions/php/include/php/ext/standard/php_mt_rand.h
+webserverextensions/php/include/php/ext/standard/php_net.h
+webserverextensions/php/include/php/ext/standard/php_password.h
+webserverextensions/php/include/php/ext/standard/php_rand.h
+webserverextensions/php/include/php/ext/standard/php_random.h
+webserverextensions/php/include/php/ext/standard/php_smart_string.h
+webserverextensions/php/include/php/ext/standard/php_smart_string_public.h
+webserverextensions/php/include/php/ext/standard/php_standard.h
+webserverextensions/php/include/php/ext/standard/php_string.h
+webserverextensions/php/include/php/ext/standard/php_uuencode.h
+webserverextensions/php/include/php/ext/standard/php_var.h
+webserverextensions/php/include/php/ext/standard/php_versioning.h
+webserverextensions/php/include/php/ext/standard/proc_open.h
+webserverextensions/php/include/php/ext/standard/quot_print.h
+webserverextensions/php/include/php/ext/standard/scanf.h
+webserverextensions/php/include/php/ext/standard/sha1.h
+webserverextensions/php/include/php/ext/standard/streamsfuncs.h
+webserverextensions/php/include/php/ext/standard/url.h
+webserverextensions/php/include/php/ext/standard/url_scanner_ex.h
+webserverextensions/php/include/php/ext/standard/user_filters_arginfo.h
+webserverextensions/php/include/php/ext/standard/winver.h
+webserverextensions/php/include/php/ext/xml/
+webserverextensions/php/include/php/ext/xml/expat_compat.h
+webserverextensions/php/include/php/ext/xml/php_xml.h
+webserverextensions/php/include/php/ext/xml/xml_arginfo.h
+webserverextensions/php/include/php/include/
+webserverextensions/php/include/php/main/
+webserverextensions/php/include/php/main/SAPI.h
+webserverextensions/php/include/php/main/build-defs.h
+webserverextensions/php/include/php/main/fastcgi.h
+webserverextensions/php/include/php/main/fopen_wrappers.h
+webserverextensions/php/include/php/main/http_status_codes.h
+webserverextensions/php/include/php/main/main_arginfo.h
+webserverextensions/php/include/php/main/php.h
+webserverextensions/php/include/php/main/php_compat.h
+webserverextensions/php/include/php/main/php_config.h
+webserverextensions/php/include/php/main/php_content_types.h
+webserverextensions/php/include/php/main/php_getopt.h
+webserverextensions/php/include/php/main/php_globals.h
+webserverextensions/php/include/php/main/php_ini.h
+webserverextensions/php/include/php/main/php_ini_builder.h
+webserverextensions/php/include/php/main/php_main.h
+webserverextensions/php/include/php/main/php_memory_streams.h
+webserverextensions/php/include/php/main/php_network.h
+webserverextensions/php/include/php/main/php_odbc_utils.h
+webserverextensions/php/include/php/main/php_open_temporary_file.h
+webserverextensions/php/include/php/main/php_output.h
+webserverextensions/php/include/php/main/php_reentrancy.h
+webserverextensions/php/include/php/main/php_scandir.h
+webserverextensions/php/include/php/main/php_streams.h
+webserverextensions/php/include/php/main/php_syslog.h
+webserverextensions/php/include/php/main/php_ticks.h
+webserverextensions/php/include/php/main/php_variables.h
+webserverextensions/php/include/php/main/php_version.h
+webserverextensions/php/include/php/main/rfc1867.h
+webserverextensions/php/include/php/main/snprintf.h
+webserverextensions/php/include/php/main/spprintf.h
+webserverextensions/php/include/php/main/streams/
+webserverextensions/php/include/php/main/streams/php_stream_context.h
+webserverextensions/php/include/php/main/streams/php_stream_filter_api.h
+webserverextensions/php/include/php/main/streams/php_stream_glob_wrapper.h
+webserverextensions/php/include/php/main/streams/php_stream_mmap.h
+webserverextensions/php/include/php/main/streams/php_stream_plain_wrapper.h
+webserverextensions/php/include/php/main/streams/php_stream_transport.h
+webserverextensions/php/include/php/main/streams/php_stream_userspace.h
+webserverextensions/php/include/php/main/streams/php_streams_int.h
+webserverextensions/php/include/php/main/streams/userspace_arginfo.h
+webserverextensions/php/include/php/sapi/
+webserverextensions/php/include/php/sapi/cli/
+webserverextensions/php/include/php/sapi/cli/cli.h
+webserverextensions/php/lib/
+webserverextensions/php/lib/php.ini
+webserverextensions/php/lib/php/
+webserverextensions/php/lib/php/build/
+webserverextensions/php/lib/php/build/Makefile.global
+webserverextensions/php/lib/php/build/ax_check_compile_flag.m4
+webserverextensions/php/lib/php/build/ax_gcc_func_attribute.m4
+webserverextensions/php/lib/php/build/config.guess
+webserverextensions/php/lib/php/build/config.sub
+webserverextensions/php/lib/php/build/gen_stub.php
+webserverextensions/php/lib/php/build/libtool.m4
+webserverextensions/php/lib/php/build/ltmain.sh
+webserverextensions/php/lib/php/build/php.m4
+webserverextensions/php/lib/php/build/php_cxx_compile_stdcxx.m4
+webserverextensions/php/lib/php/build/phpize.m4
+webserverextensions/php/lib/php/build/pkg.m4
+webserverextensions/php/lib/php/build/run-tests.php
+webserverextensions/php/lib/php/build/shtool
+webserverextensions/php/lib/php/extensions/
+webserverextensions/php/lib/php/extensions/no-debug-zts-20230831/
+webserverextensions/php/lib/php/extensions/no-debug-zts-20230831/libphp_MapGuideApi-4.0.1.so
+webserverextensions/php/lib/php/extensions/no-debug-zts-20230831/libphp_MapGuideApi.so
+webserverextensions/php/lib/php/extensions/no-debug-zts-20230831/mbstring.so
+webserverextensions/php/lib/php/extensions/no-debug-zts-20230831/opcache.so
+webserverextensions/php/php/
+webserverextensions/php/php/man/
+webserverextensions/php/php/man/man1/
+webserverextensions/php/php/man/man1/phar.1
+webserverextensions/php/php/man/man1/phar.phar.1
+webserverextensions/php/php/man/man1/php-cgi.1
+webserverextensions/php/php/man/man1/php-config.1
+webserverextensions/php/php/man/man1/php.1
+webserverextensions/php/php/man/man1/phpdbg.1
+webserverextensions/php/php/man/man1/phpize.1
+webserverextensions/php/var/
+webserverextensions/php/var/log/
+webserverextensions/php/var/run/
+webserverextensions/tomcat/
+webserverextensions/tomcat/BUILDING.txt
+webserverextensions/tomcat/CONTRIBUTING.md
+webserverextensions/tomcat/LICENSE
+webserverextensions/tomcat/NOTICE
+webserverextensions/tomcat/README.md
+webserverextensions/tomcat/RELEASE-NOTES
+webserverextensions/tomcat/RUNNING.txt
+webserverextensions/tomcat/bin/
+webserverextensions/tomcat/bin/bootstrap.jar
+webserverextensions/tomcat/bin/catalina-tasks.xml
+webserverextensions/tomcat/bin/catalina.bat
+webserverextensions/tomcat/bin/catalina.sh
+webserverextensions/tomcat/bin/ciphers.bat
+webserverextensions/tomcat/bin/ciphers.sh
+webserverextensions/tomcat/bin/commons-daemon-native.tar.gz
+webserverextensions/tomcat/bin/commons-daemon.jar
+webserverextensions/tomcat/bin/configtest.bat
+webserverextensions/tomcat/bin/configtest.sh
+webserverextensions/tomcat/bin/daemon.sh
+webserverextensions/tomcat/bin/digest.bat
+webserverextensions/tomcat/bin/digest.sh
+webserverextensions/tomcat/bin/makebase.bat
+webserverextensions/tomcat/bin/makebase.sh
+webserverextensions/tomcat/bin/setclasspath.bat
+webserverextensions/tomcat/bin/setclasspath.sh
+webserverextensions/tomcat/bin/shutdown.bat
+webserverextensions/tomcat/bin/shutdown.sh
+webserverextensions/tomcat/bin/startup.bat
+webserverextensions/tomcat/bin/startup.sh
+webserverextensions/tomcat/bin/tomcat-juli.jar
+webserverextensions/tomcat/bin/tomcat-native.tar.gz
+webserverextensions/tomcat/bin/tool-wrapper.bat
+webserverextensions/tomcat/bin/tool-wrapper.sh
+webserverextensions/tomcat/bin/version.bat
+webserverextensions/tomcat/bin/version.sh
+webserverextensions/tomcat/conf/
+webserverextensions/tomcat/conf/Catalina/
+webserverextensions/tomcat/conf/Catalina/localhost/
+webserverextensions/tomcat/conf/Catalina/localhost/mapguide.xml
+webserverextensions/tomcat/conf/catalina.policy
+webserverextensions/tomcat/conf/catalina.properties
+webserverextensions/tomcat/conf/context.xml
+webserverextensions/tomcat/conf/jaspic-providers.xml
+webserverextensions/tomcat/conf/jaspic-providers.xsd
+webserverextensions/tomcat/conf/logging.properties
+webserverextensions/tomcat/conf/server.xml
+webserverextensions/tomcat/conf/tomcat-users.xml
+webserverextensions/tomcat/conf/tomcat-users.xsd
+webserverextensions/tomcat/conf/web.xml
+webserverextensions/tomcat/lib/
+webserverextensions/tomcat/lib/annotations-api.jar
+webserverextensions/tomcat/lib/catalina-ant.jar
+webserverextensions/tomcat/lib/catalina-ha.jar
+webserverextensions/tomcat/lib/catalina-ssi.jar
+webserverextensions/tomcat/lib/catalina-storeconfig.jar
+webserverextensions/tomcat/lib/catalina-tribes.jar
+webserverextensions/tomcat/lib/catalina.jar
+webserverextensions/tomcat/lib/ecj-4.20.jar
+webserverextensions/tomcat/lib/el-api.jar
+webserverextensions/tomcat/lib/jasper-el.jar
+webserverextensions/tomcat/lib/jasper.jar
+webserverextensions/tomcat/lib/jaspic-api.jar
+webserverextensions/tomcat/lib/jsp-api.jar
+webserverextensions/tomcat/lib/servlet-api.jar
+webserverextensions/tomcat/lib/tomcat-api.jar
+webserverextensions/tomcat/lib/tomcat-coyote-ffm.jar
+webserverextensions/tomcat/lib/tomcat-coyote.jar
+webserverextensions/tomcat/lib/tomcat-dbcp.jar
+webserverextensions/tomcat/lib/tomcat-i18n-cs.jar
+webserverextensions/tomcat/lib/tomcat-i18n-de.jar
+webserverextensions/tomcat/lib/tomcat-i18n-es.jar
+webserverextensions/tomcat/lib/tomcat-i18n-fr.jar
+webserverextensions/tomcat/lib/tomcat-i18n-ja.jar
+webserverextensions/tomcat/lib/tomcat-i18n-ko.jar
+webserverextensions/tomcat/lib/tomcat-i18n-pt-BR.jar
+webserverextensions/tomcat/lib/tomcat-i18n-ru.jar
+webserverextensions/tomcat/lib/tomcat-i18n-zh-CN.jar
+webserverextensions/tomcat/lib/tomcat-jdbc.jar
+webserverextensions/tomcat/lib/tomcat-jni.jar
+webserverextensions/tomcat/lib/tomcat-util-scan.jar
+webserverextensions/tomcat/lib/tomcat-util.jar
+webserverextensions/tomcat/lib/tomcat-websocket.jar
+webserverextensions/tomcat/lib/websocket-api.jar
+webserverextensions/tomcat/logs/
+webserverextensions/tomcat/temp/
+webserverextensions/tomcat/temp/safeToDelete.tmp
+webserverextensions/tomcat/webapps/
+webserverextensions/tomcat/webapps/ROOT/
+webserverextensions/tomcat/webapps/ROOT/RELEASE-NOTES.txt
+webserverextensions/tomcat/webapps/ROOT/WEB-INF/
+webserverextensions/tomcat/webapps/ROOT/WEB-INF/web.xml
+webserverextensions/tomcat/webapps/ROOT/asf-logo-wide.svg
+webserverextensions/tomcat/webapps/ROOT/bg-button.png
+webserverextensions/tomcat/webapps/ROOT/bg-middle.png
+webserverextensions/tomcat/webapps/ROOT/bg-nav.png
+webserverextensions/tomcat/webapps/ROOT/bg-upper.png
+webserverextensions/tomcat/webapps/ROOT/favicon.ico
+webserverextensions/tomcat/webapps/ROOT/index.jsp
+webserverextensions/tomcat/webapps/ROOT/tomcat.css
+webserverextensions/tomcat/webapps/ROOT/tomcat.svg
+webserverextensions/tomcat/webapps/docs/
+webserverextensions/tomcat/webapps/docs/BUILDING.txt
+webserverextensions/tomcat/webapps/docs/META-INF/
+webserverextensions/tomcat/webapps/docs/META-INF/context.xml
+webserverextensions/tomcat/webapps/docs/RELEASE-NOTES.txt
+webserverextensions/tomcat/webapps/docs/RUNNING.txt
+webserverextensions/tomcat/webapps/docs/WEB-INF/
+webserverextensions/tomcat/webapps/docs/WEB-INF/jsp/
+webserverextensions/tomcat/webapps/docs/WEB-INF/jsp/403.jsp
+webserverextensions/tomcat/webapps/docs/WEB-INF/web.xml
+webserverextensions/tomcat/webapps/docs/aio.html
+webserverextensions/tomcat/webapps/docs/annotationapi/
+webserverextensions/tomcat/webapps/docs/annotationapi/index.html
+webserverextensions/tomcat/webapps/docs/api/
+webserverextensions/tomcat/webapps/docs/api/index.html
+webserverextensions/tomcat/webapps/docs/appdev/
+webserverextensions/tomcat/webapps/docs/appdev/build.xml.txt
+webserverextensions/tomcat/webapps/docs/appdev/deployment.html
+webserverextensions/tomcat/webapps/docs/appdev/index.html
+webserverextensions/tomcat/webapps/docs/appdev/installation.html
+webserverextensions/tomcat/webapps/docs/appdev/introduction.html
+webserverextensions/tomcat/webapps/docs/appdev/processes.html
+webserverextensions/tomcat/webapps/docs/appdev/sample/
+webserverextensions/tomcat/webapps/docs/appdev/sample/build.xml
+webserverextensions/tomcat/webapps/docs/appdev/sample/docs/
+webserverextensions/tomcat/webapps/docs/appdev/sample/docs/README.txt
+webserverextensions/tomcat/webapps/docs/appdev/sample/index.html
+webserverextensions/tomcat/webapps/docs/appdev/sample/sample.war
+webserverextensions/tomcat/webapps/docs/appdev/sample/src/
+webserverextensions/tomcat/webapps/docs/appdev/sample/src/mypackage/
+webserverextensions/tomcat/webapps/docs/appdev/sample/src/mypackage/Hello.java
+webserverextensions/tomcat/webapps/docs/appdev/sample/web/
+webserverextensions/tomcat/webapps/docs/appdev/sample/web/WEB-INF/
+webserverextensions/tomcat/webapps/docs/appdev/sample/web/WEB-INF/web.xml
+webserverextensions/tomcat/webapps/docs/appdev/sample/web/hello.jsp
+webserverextensions/tomcat/webapps/docs/appdev/sample/web/images/
+webserverextensions/tomcat/webapps/docs/appdev/sample/web/images/tomcat.gif
+webserverextensions/tomcat/webapps/docs/appdev/sample/web/index.html
+webserverextensions/tomcat/webapps/docs/appdev/source.html
+webserverextensions/tomcat/webapps/docs/appdev/web.xml.txt
+webserverextensions/tomcat/webapps/docs/apr.html
+webserverextensions/tomcat/webapps/docs/architecture/
+webserverextensions/tomcat/webapps/docs/architecture/index.html
+webserverextensions/tomcat/webapps/docs/architecture/overview.html
+webserverextensions/tomcat/webapps/docs/architecture/requestProcess.html
+webserverextensions/tomcat/webapps/docs/architecture/requestProcess/
+webserverextensions/tomcat/webapps/docs/architecture/requestProcess/11_nio.plantuml
+webserverextensions/tomcat/webapps/docs/architecture/requestProcess/11_nio.png
+webserverextensions/tomcat/webapps/docs/architecture/requestProcess/21_http11.plantuml
+webserverextensions/tomcat/webapps/docs/architecture/requestProcess/21_http11.png
+webserverextensions/tomcat/webapps/docs/architecture/requestProcess/31_synchronous.plantuml
+webserverextensions/tomcat/webapps/docs/architecture/requestProcess/31_synchronous.png
+webserverextensions/tomcat/webapps/docs/architecture/requestProcess/41_basic.plantuml
+webserverextensions/tomcat/webapps/docs/architecture/requestProcess/41_basic.png
+webserverextensions/tomcat/webapps/docs/architecture/startup.html
+webserverextensions/tomcat/webapps/docs/architecture/startup/
+webserverextensions/tomcat/webapps/docs/architecture/startup/1_overview.plantuml
+webserverextensions/tomcat/webapps/docs/architecture/startup/1_overview.png
+webserverextensions/tomcat/webapps/docs/architecture/startup/2_catalina_init.plantuml
+webserverextensions/tomcat/webapps/docs/architecture/startup/2_catalina_init.png
+webserverextensions/tomcat/webapps/docs/architecture/startup/3_catalina_start_1.plantuml
+webserverextensions/tomcat/webapps/docs/architecture/startup/3_catalina_start_1.png
+webserverextensions/tomcat/webapps/docs/architecture/startup/4_catalina_start_2.plantuml
+webserverextensions/tomcat/webapps/docs/architecture/startup/4_catalina_start_2.png
+webserverextensions/tomcat/webapps/docs/architecture/startup/5_catalina_start_3.plantuml
+webserverextensions/tomcat/webapps/docs/architecture/startup/5_catalina_start_3.png
+webserverextensions/tomcat/webapps/docs/architecture/startup/6_catalina_host_config.plantuml
+webserverextensions/tomcat/webapps/docs/architecture/startup/6_catalina_host_config.png
+webserverextensions/tomcat/webapps/docs/architecture/startup/7_catalina_context_config.plantuml
+webserverextensions/tomcat/webapps/docs/architecture/startup/7_catalina_context_config.png
+webserverextensions/tomcat/webapps/docs/architecture/startup/serverStartup.txt
+webserverextensions/tomcat/webapps/docs/balancer-howto.html
+webserverextensions/tomcat/webapps/docs/building.html
+webserverextensions/tomcat/webapps/docs/cdi.html
+webserverextensions/tomcat/webapps/docs/cgi-howto.html
+webserverextensions/tomcat/webapps/docs/changelog.html
+webserverextensions/tomcat/webapps/docs/class-loader-howto.html
+webserverextensions/tomcat/webapps/docs/cluster-howto.html
+webserverextensions/tomcat/webapps/docs/comments.html
+webserverextensions/tomcat/webapps/docs/config/
+webserverextensions/tomcat/webapps/docs/config/ajp.html
+webserverextensions/tomcat/webapps/docs/config/automatic-deployment.html
+webserverextensions/tomcat/webapps/docs/config/cluster-channel.html
+webserverextensions/tomcat/webapps/docs/config/cluster-deployer.html
+webserverextensions/tomcat/webapps/docs/config/cluster-interceptor.html
+webserverextensions/tomcat/webapps/docs/config/cluster-listener.html
+webserverextensions/tomcat/webapps/docs/config/cluster-manager.html
+webserverextensions/tomcat/webapps/docs/config/cluster-membership.html
+webserverextensions/tomcat/webapps/docs/config/cluster-receiver.html
+webserverextensions/tomcat/webapps/docs/config/cluster-sender.html
+webserverextensions/tomcat/webapps/docs/config/cluster-valve.html
+webserverextensions/tomcat/webapps/docs/config/cluster.html
+webserverextensions/tomcat/webapps/docs/config/context.html
+webserverextensions/tomcat/webapps/docs/config/cookie-processor.html
+webserverextensions/tomcat/webapps/docs/config/credentialhandler.html
+webserverextensions/tomcat/webapps/docs/config/engine.html
+webserverextensions/tomcat/webapps/docs/config/executor.html
+webserverextensions/tomcat/webapps/docs/config/filter.html
+webserverextensions/tomcat/webapps/docs/config/globalresources.html
+webserverextensions/tomcat/webapps/docs/config/host.html
+webserverextensions/tomcat/webapps/docs/config/http.html
+webserverextensions/tomcat/webapps/docs/config/http2.html
+webserverextensions/tomcat/webapps/docs/config/index.html
+webserverextensions/tomcat/webapps/docs/config/jar-scan-filter.html
+webserverextensions/tomcat/webapps/docs/config/jar-scanner.html
+webserverextensions/tomcat/webapps/docs/config/jaspic.html
+webserverextensions/tomcat/webapps/docs/config/listeners.html
+webserverextensions/tomcat/webapps/docs/config/loader.html
+webserverextensions/tomcat/webapps/docs/config/manager.html
+webserverextensions/tomcat/webapps/docs/config/realm.html
+webserverextensions/tomcat/webapps/docs/config/resources.html
+webserverextensions/tomcat/webapps/docs/config/runtime-attributes.html
+webserverextensions/tomcat/webapps/docs/config/server.html
+webserverextensions/tomcat/webapps/docs/config/service.html
+webserverextensions/tomcat/webapps/docs/config/sessionidgenerator.html
+webserverextensions/tomcat/webapps/docs/config/systemprops.html
+webserverextensions/tomcat/webapps/docs/config/valve.html
+webserverextensions/tomcat/webapps/docs/connectors.html
+webserverextensions/tomcat/webapps/docs/default-servlet.html
+webserverextensions/tomcat/webapps/docs/deployer-howto.html
+webserverextensions/tomcat/webapps/docs/developers.html
+webserverextensions/tomcat/webapps/docs/elapi/
+webserverextensions/tomcat/webapps/docs/elapi/index.html
+webserverextensions/tomcat/webapps/docs/graal.html
+webserverextensions/tomcat/webapps/docs/host-manager-howto.html
+webserverextensions/tomcat/webapps/docs/html-host-manager-howto.html
+webserverextensions/tomcat/webapps/docs/html-manager-howto.html
+webserverextensions/tomcat/webapps/docs/images/
+webserverextensions/tomcat/webapps/docs/images/add.gif
+webserverextensions/tomcat/webapps/docs/images/asf-logo.svg
+webserverextensions/tomcat/webapps/docs/images/code.gif
+webserverextensions/tomcat/webapps/docs/images/cors-flowchart.png
+webserverextensions/tomcat/webapps/docs/images/design.gif
+webserverextensions/tomcat/webapps/docs/images/docs-stylesheet.css
+webserverextensions/tomcat/webapps/docs/images/docs.gif
+webserverextensions/tomcat/webapps/docs/images/fix.gif
+webserverextensions/tomcat/webapps/docs/images/fonts/
+webserverextensions/tomcat/webapps/docs/images/fonts/OpenSans400.woff
+webserverextensions/tomcat/webapps/docs/images/fonts/OpenSans400italic.woff
+webserverextensions/tomcat/webapps/docs/images/fonts/OpenSans600.woff
+webserverextensions/tomcat/webapps/docs/images/fonts/OpenSans600italic.woff
+webserverextensions/tomcat/webapps/docs/images/fonts/OpenSans700.woff
+webserverextensions/tomcat/webapps/docs/images/fonts/OpenSans700italic.woff
+webserverextensions/tomcat/webapps/docs/images/fonts/fonts.css
+webserverextensions/tomcat/webapps/docs/images/tomcat.gif
+webserverextensions/tomcat/webapps/docs/images/tomcat.png
+webserverextensions/tomcat/webapps/docs/images/update.gif
+webserverextensions/tomcat/webapps/docs/images/void.gif
+webserverextensions/tomcat/webapps/docs/index.html
+webserverextensions/tomcat/webapps/docs/introduction.html
+webserverextensions/tomcat/webapps/docs/jasper-howto.html
+webserverextensions/tomcat/webapps/docs/jaspicapi/
+webserverextensions/tomcat/webapps/docs/jaspicapi/index.html
+webserverextensions/tomcat/webapps/docs/jdbc-pool.html
+webserverextensions/tomcat/webapps/docs/jndi-datasource-examples-howto.html
+webserverextensions/tomcat/webapps/docs/jndi-resources-howto.html
+webserverextensions/tomcat/webapps/docs/jspapi/
+webserverextensions/tomcat/webapps/docs/jspapi/index.html
+webserverextensions/tomcat/webapps/docs/logging.html
+webserverextensions/tomcat/webapps/docs/manager-howto.html
+webserverextensions/tomcat/webapps/docs/maven-jars.html
+webserverextensions/tomcat/webapps/docs/mbeans-descriptors-howto.html
+webserverextensions/tomcat/webapps/docs/mbeans-descriptors.dtd
+webserverextensions/tomcat/webapps/docs/monitoring.html
+webserverextensions/tomcat/webapps/docs/proxy-howto.html
+webserverextensions/tomcat/webapps/docs/realm-howto.html
+webserverextensions/tomcat/webapps/docs/rewrite.html
+webserverextensions/tomcat/webapps/docs/security-howto.html
+webserverextensions/tomcat/webapps/docs/security-manager-howto.html
+webserverextensions/tomcat/webapps/docs/servletapi/
+webserverextensions/tomcat/webapps/docs/servletapi/index.html
+webserverextensions/tomcat/webapps/docs/setup.html
+webserverextensions/tomcat/webapps/docs/ssi-howto.html
+webserverextensions/tomcat/webapps/docs/ssl-howto.html
+webserverextensions/tomcat/webapps/docs/tribes/
+webserverextensions/tomcat/webapps/docs/tribes/developers.html
+webserverextensions/tomcat/webapps/docs/tribes/faq.html
+webserverextensions/tomcat/webapps/docs/tribes/interceptors.html
+webserverextensions/tomcat/webapps/docs/tribes/introduction.html
+webserverextensions/tomcat/webapps/docs/tribes/membership.html
+webserverextensions/tomcat/webapps/docs/tribes/setup.html
+webserverextensions/tomcat/webapps/docs/tribes/status.html
+webserverextensions/tomcat/webapps/docs/tribes/transport.html
+webserverextensions/tomcat/webapps/docs/virtual-hosting-howto.html
+webserverextensions/tomcat/webapps/docs/web-socket-howto.html
+webserverextensions/tomcat/webapps/docs/websocketapi/
+webserverextensions/tomcat/webapps/docs/websocketapi/index.html
+webserverextensions/tomcat/webapps/docs/windows-auth-howto.html
+webserverextensions/tomcat/webapps/docs/windows-service-howto.html
+webserverextensions/tomcat/webapps/examples/
+webserverextensions/tomcat/webapps/examples/META-INF/
+webserverextensions/tomcat/webapps/examples/META-INF/context.xml
+webserverextensions/tomcat/webapps/examples/WEB-INF/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/CookieExample.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/CookieExample.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/HelloWorldExample.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/HelloWorldExample.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings.properties
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_cs.properties
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_de.properties
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_es.properties
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_fr.properties
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_ja.properties
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_ko.properties
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_pt.properties
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_pt_BR.properties
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_ru.properties
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/LocalStrings_zh_CN.properties
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/RequestHeaderExample.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/RequestHeaderExample.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/RequestInfoExample.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/RequestInfoExample.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/RequestParamExample.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/RequestParamExample.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/ServletToJsp.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/ServletToJsp.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/SessionExample.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/SessionExample.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async0$1.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async0.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async0.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async1$1.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async1.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async1.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async2$1.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async2.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async2.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async3.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Async3.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/AsyncStockContextListener.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/AsyncStockContextListener.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/AsyncStockServlet.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/AsyncStockServlet.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Stockticker$Stock.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Stockticker$TickListener.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Stockticker.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/async/Stockticker.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/checkbox/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/checkbox/CheckTest.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/checkbox/CheckTest.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/colors/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/colors/ColorGameBean.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/colors/ColorGameBean.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/CompressionFilter.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/CompressionFilter.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/CompressionFilterTestServlet.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/CompressionFilterTestServlet.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/CompressionResponseStream.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/CompressionResponseStream.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/CompressionServletResponseWrapper.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/compressionFilters/CompressionServletResponseWrapper.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/dates/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/dates/JspCalendar.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/dates/JspCalendar.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/error/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/error/Smart.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/error/Smart.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/ExampleTagBase.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/ExampleTagBase.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/FooTag.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/FooTag.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/FooTagExtraInfo.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/FooTagExtraInfo.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/LogTag.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/LogTag.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/ValuesTag.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/examples/ValuesTag.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/filters/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/filters/ExampleFilter.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/filters/ExampleFilter.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/http2/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/http2/SimpleImagePush.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/http2/SimpleImagePush.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/BookBean.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/BookBean.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/FooBean.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/FooBean.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/ValuesBean.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/ValuesBean.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/el/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/el/Functions.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/el/Functions.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/EchoAttributesTag.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/EchoAttributesTag.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/FindBookSimpleTag.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/FindBookSimpleTag.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/HelloWorldSimpleTag.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/HelloWorldSimpleTag.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/RepeatSimpleTag.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/RepeatSimpleTag.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/ShuffleSimpleTag.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/ShuffleSimpleTag.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/TileSimpleTag.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/jsp2/examples/simpletag/TileSimpleTag.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/listeners/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/listeners/ContextListener.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/listeners/ContextListener.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/listeners/SessionListener.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/listeners/SessionListener.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/ByteCounter$1.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/ByteCounter$CounterListener.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/ByteCounter.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/ByteCounter.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/NumberWriter$1.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/NumberWriter$NumberWriterListener.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/NumberWriter.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/nonblocking/NumberWriter.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/num/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/num/NumberGuessBean.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/num/NumberGuessBean.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/sessions/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/sessions/DummyCart.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/sessions/DummyCart.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/sessions/Item.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/sessions/Item.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/trailers/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/trailers/ResponseTrailers$1.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/trailers/ResponseTrailers$TrailerFieldSupplier.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/trailers/ResponseTrailers.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/trailers/ResponseTrailers.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/util/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/util/CookieFilter.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/util/CookieFilter.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/util/HTMLFilter.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/util/HTMLFilter.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/validators/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/validators/DebugValidator.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/validators/DebugValidator.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/ExamplesConfig.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/ExamplesConfig.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/chat/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/chat/ChatAnnotation.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/chat/ChatAnnotation.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Client$1.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Client.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Client.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawMessage$ParseException.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawMessage.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawMessage.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawboardContextListener.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawboardContextListener.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawboardEndpoint$1.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawboardEndpoint$2.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawboardEndpoint$3$1.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawboardEndpoint$3.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawboardEndpoint.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/DrawboardEndpoint.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Room$1$1.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Room$1.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Room$2.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Room$MessageType.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Room$Player.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Room.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/Room.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/AbstractWebsocketMessage.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/AbstractWebsocketMessage.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/BinaryWebsocketMessage.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/BinaryWebsocketMessage.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/CloseWebsocketMessage.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/CloseWebsocketMessage.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/StringWebsocketMessage.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/drawboard/wsmessages/StringWebsocketMessage.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoAnnotation.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoAnnotation.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoAsyncAnnotation$1.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoAsyncAnnotation$CompletedFuture.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoAsyncAnnotation.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoAsyncAnnotation.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoEndpoint$1.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoEndpoint$EchoMessageHandlerBinary.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoEndpoint$EchoMessageHandlerText.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoEndpoint.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoEndpoint.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoStreamAnnotation.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/EchoStreamAnnotation.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/echo/servers.json
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/Direction.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/Direction.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/Location$1.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/Location.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/Location.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/Snake.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/Snake.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/SnakeAnnotation.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/SnakeAnnotation.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/SnakeTimer$1.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/SnakeTimer.class
+webserverextensions/tomcat/webapps/examples/WEB-INF/classes/websocket/snake/SnakeTimer.java
+webserverextensions/tomcat/webapps/examples/WEB-INF/jsp/
+webserverextensions/tomcat/webapps/examples/WEB-INF/jsp/403.jsp
+webserverextensions/tomcat/webapps/examples/WEB-INF/jsp/403.jsp.html
+webserverextensions/tomcat/webapps/examples/WEB-INF/jsp/debug-taglib.tld
+webserverextensions/tomcat/webapps/examples/WEB-INF/jsp/example-taglib.tld
+webserverextensions/tomcat/webapps/examples/WEB-INF/jsp/jsp2-example-taglib.tld
+webserverextensions/tomcat/webapps/examples/WEB-INF/lib/
+webserverextensions/tomcat/webapps/examples/WEB-INF/lib/taglibs-standard-impl-1.2.5.jar
+webserverextensions/tomcat/webapps/examples/WEB-INF/lib/taglibs-standard-spec-1.2.5.jar
+webserverextensions/tomcat/webapps/examples/WEB-INF/tags/
+webserverextensions/tomcat/webapps/examples/WEB-INF/tags/displayProducts.tag
+webserverextensions/tomcat/webapps/examples/WEB-INF/tags/helloWorld.tag
+webserverextensions/tomcat/webapps/examples/WEB-INF/tags/panel.tag
+webserverextensions/tomcat/webapps/examples/WEB-INF/web.xml
+webserverextensions/tomcat/webapps/examples/index.html
+webserverextensions/tomcat/webapps/examples/jsp/
+webserverextensions/tomcat/webapps/examples/jsp/async/
+webserverextensions/tomcat/webapps/examples/jsp/async/async1.jsp
+webserverextensions/tomcat/webapps/examples/jsp/async/async1.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/async/async3.jsp
+webserverextensions/tomcat/webapps/examples/jsp/async/async3.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/async/index.jsp
+webserverextensions/tomcat/webapps/examples/jsp/async/index.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/checkbox/
+webserverextensions/tomcat/webapps/examples/jsp/checkbox/CheckTest.html
+webserverextensions/tomcat/webapps/examples/jsp/checkbox/check.html
+webserverextensions/tomcat/webapps/examples/jsp/checkbox/checkresult.jsp
+webserverextensions/tomcat/webapps/examples/jsp/checkbox/checkresult.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/checkbox/cresult.html
+webserverextensions/tomcat/webapps/examples/jsp/colors/
+webserverextensions/tomcat/webapps/examples/jsp/colors/ColorGameBean.html
+webserverextensions/tomcat/webapps/examples/jsp/colors/clr.html
+webserverextensions/tomcat/webapps/examples/jsp/colors/colors.html
+webserverextensions/tomcat/webapps/examples/jsp/colors/colrs.jsp
+webserverextensions/tomcat/webapps/examples/jsp/colors/colrs.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/dates/
+webserverextensions/tomcat/webapps/examples/jsp/dates/date.html
+webserverextensions/tomcat/webapps/examples/jsp/dates/date.jsp
+webserverextensions/tomcat/webapps/examples/jsp/dates/date.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/error/
+webserverextensions/tomcat/webapps/examples/jsp/error/er.html
+webserverextensions/tomcat/webapps/examples/jsp/error/err.jsp
+webserverextensions/tomcat/webapps/examples/jsp/error/err.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/error/error.html
+webserverextensions/tomcat/webapps/examples/jsp/error/errorpge.jsp
+webserverextensions/tomcat/webapps/examples/jsp/error/errorpge.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/forward/
+webserverextensions/tomcat/webapps/examples/jsp/forward/forward.jsp
+webserverextensions/tomcat/webapps/examples/jsp/forward/forward.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/forward/fwd.html
+webserverextensions/tomcat/webapps/examples/jsp/forward/one.jsp
+webserverextensions/tomcat/webapps/examples/jsp/forward/one.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/forward/two.html
+webserverextensions/tomcat/webapps/examples/jsp/images/
+webserverextensions/tomcat/webapps/examples/jsp/images/code.gif
+webserverextensions/tomcat/webapps/examples/jsp/images/execute.gif
+webserverextensions/tomcat/webapps/examples/jsp/images/return.gif
+webserverextensions/tomcat/webapps/examples/jsp/include/
+webserverextensions/tomcat/webapps/examples/jsp/include/foo.html
+webserverextensions/tomcat/webapps/examples/jsp/include/foo.jsp
+webserverextensions/tomcat/webapps/examples/jsp/include/foo.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/include/inc.html
+webserverextensions/tomcat/webapps/examples/jsp/include/include.jsp
+webserverextensions/tomcat/webapps/examples/jsp/include/include.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/index.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/Functions.java.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/ValuesBean.java.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/ValuesTag.java.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/basic-arithmetic.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/basic-arithmetic.jsp
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/basic-arithmetic.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/basic-comparisons.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/basic-comparisons.jsp
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/basic-comparisons.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/composite.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/composite.jsp
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/composite.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/functions.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/functions.jsp
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/functions.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/implicit-objects.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/implicit-objects.jsp
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/el/implicit-objects.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/FooBean.java.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/HelloWorldSimpleTag.java.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/ShuffleSimpleTag.java.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/TileSimpleTag.java.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/jspattribute.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/jspattribute.jsp
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/jspattribute.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/shuffle.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/shuffle.jsp
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspattribute/shuffle.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/basic.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/basic.jspx
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/basic.jspx.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/svgexample.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/textRotate.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/textRotate.jpg
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/textRotate.jspx
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/jspx/textRotate.jspx.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/EchoAttributesTag.java.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/coda.jspf
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/coda.jspf.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/config.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/config.jsp
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/config.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/dynamicattrs.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/dynamicattrs.jsp
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/dynamicattrs.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/prelude.jspf
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/misc/prelude.jspf.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/BookBean.java.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/FindBookSimpleTag.java.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/Functions.java.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/HelloWorldSimpleTag.java.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/RepeatSimpleTag.java.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/book.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/book.jsp
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/book.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/hello.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/hello.jsp
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/hello.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/repeat.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/repeat.jsp
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/simpletag/repeat.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/displayProducts.tag.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/hello.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/hello.jsp
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/hello.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/helloWorld.tag.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/panel.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/panel.jsp
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/panel.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/panel.tag.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/products.html
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/products.jsp
+webserverextensions/tomcat/webapps/examples/jsp/jsp2/tagfiles/products.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/jsptoserv/
+webserverextensions/tomcat/webapps/examples/jsp/jsptoserv/ServletToJsp.java.html
+webserverextensions/tomcat/webapps/examples/jsp/jsptoserv/hello.jsp
+webserverextensions/tomcat/webapps/examples/jsp/jsptoserv/hello.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/jsptoserv/jsptoservlet.jsp
+webserverextensions/tomcat/webapps/examples/jsp/jsptoserv/jsptoservlet.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/jsptoserv/jts.html
+webserverextensions/tomcat/webapps/examples/jsp/num/
+webserverextensions/tomcat/webapps/examples/jsp/num/numguess.html
+webserverextensions/tomcat/webapps/examples/jsp/num/numguess.jsp
+webserverextensions/tomcat/webapps/examples/jsp/num/numguess.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/security/
+webserverextensions/tomcat/webapps/examples/jsp/security/protected/
+webserverextensions/tomcat/webapps/examples/jsp/security/protected/error.jsp
+webserverextensions/tomcat/webapps/examples/jsp/security/protected/error.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/security/protected/index.jsp
+webserverextensions/tomcat/webapps/examples/jsp/security/protected/index.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/security/protected/login.jsp
+webserverextensions/tomcat/webapps/examples/jsp/security/protected/login.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/sessions/
+webserverextensions/tomcat/webapps/examples/jsp/sessions/DummyCart.html
+webserverextensions/tomcat/webapps/examples/jsp/sessions/carts.jsp
+webserverextensions/tomcat/webapps/examples/jsp/sessions/carts.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/sessions/crt.html
+webserverextensions/tomcat/webapps/examples/jsp/sessions/shopping.jsp
+webserverextensions/tomcat/webapps/examples/jsp/sessions/shopping.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/simpletag/
+webserverextensions/tomcat/webapps/examples/jsp/simpletag/foo.html
+webserverextensions/tomcat/webapps/examples/jsp/simpletag/foo.jsp
+webserverextensions/tomcat/webapps/examples/jsp/simpletag/foo.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/snp/
+webserverextensions/tomcat/webapps/examples/jsp/snp/snoop.html
+webserverextensions/tomcat/webapps/examples/jsp/snp/snoop.jsp
+webserverextensions/tomcat/webapps/examples/jsp/snp/snoop.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/tagplugin/
+webserverextensions/tomcat/webapps/examples/jsp/tagplugin/choose.html
+webserverextensions/tomcat/webapps/examples/jsp/tagplugin/choose.jsp
+webserverextensions/tomcat/webapps/examples/jsp/tagplugin/choose.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/tagplugin/foreach.html
+webserverextensions/tomcat/webapps/examples/jsp/tagplugin/foreach.jsp
+webserverextensions/tomcat/webapps/examples/jsp/tagplugin/foreach.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/tagplugin/howto.html
+webserverextensions/tomcat/webapps/examples/jsp/tagplugin/if.html
+webserverextensions/tomcat/webapps/examples/jsp/tagplugin/if.jsp
+webserverextensions/tomcat/webapps/examples/jsp/tagplugin/if.jsp.html
+webserverextensions/tomcat/webapps/examples/jsp/tagplugin/notes.html
+webserverextensions/tomcat/webapps/examples/jsp/xml/
+webserverextensions/tomcat/webapps/examples/jsp/xml/xml.html
+webserverextensions/tomcat/webapps/examples/jsp/xml/xml.jsp
+webserverextensions/tomcat/webapps/examples/jsp/xml/xml.jsp.html
+webserverextensions/tomcat/webapps/examples/servlets/
+webserverextensions/tomcat/webapps/examples/servlets/cookies.html
+webserverextensions/tomcat/webapps/examples/servlets/helloworld.html
+webserverextensions/tomcat/webapps/examples/servlets/images/
+webserverextensions/tomcat/webapps/examples/servlets/images/code.gif
+webserverextensions/tomcat/webapps/examples/servlets/images/execute.gif
+webserverextensions/tomcat/webapps/examples/servlets/images/return.gif
+webserverextensions/tomcat/webapps/examples/servlets/index.html
+webserverextensions/tomcat/webapps/examples/servlets/nonblocking/
+webserverextensions/tomcat/webapps/examples/servlets/nonblocking/bytecounter.html
+webserverextensions/tomcat/webapps/examples/servlets/reqheaders.html
+webserverextensions/tomcat/webapps/examples/servlets/reqinfo.html
+webserverextensions/tomcat/webapps/examples/servlets/reqparams.html
+webserverextensions/tomcat/webapps/examples/servlets/sessions.html
+webserverextensions/tomcat/webapps/examples/websocket/
+webserverextensions/tomcat/webapps/examples/websocket/chat.xhtml
+webserverextensions/tomcat/webapps/examples/websocket/drawboard.xhtml
+webserverextensions/tomcat/webapps/examples/websocket/echo.xhtml
+webserverextensions/tomcat/webapps/examples/websocket/index.xhtml
+webserverextensions/tomcat/webapps/examples/websocket/snake.xhtml
+webserverextensions/tomcat/webapps/host-manager/
+webserverextensions/tomcat/webapps/host-manager/META-INF/
+webserverextensions/tomcat/webapps/host-manager/META-INF/context.xml
+webserverextensions/tomcat/webapps/host-manager/WEB-INF/
+webserverextensions/tomcat/webapps/host-manager/WEB-INF/jsp/
+webserverextensions/tomcat/webapps/host-manager/WEB-INF/jsp/401.jsp
+webserverextensions/tomcat/webapps/host-manager/WEB-INF/jsp/403.jsp
+webserverextensions/tomcat/webapps/host-manager/WEB-INF/jsp/404.jsp
+webserverextensions/tomcat/webapps/host-manager/WEB-INF/manager.xml
+webserverextensions/tomcat/webapps/host-manager/WEB-INF/web.xml
+webserverextensions/tomcat/webapps/host-manager/css/
+webserverextensions/tomcat/webapps/host-manager/css/manager.css
+webserverextensions/tomcat/webapps/host-manager/images/
+webserverextensions/tomcat/webapps/host-manager/images/asf-logo.svg
+webserverextensions/tomcat/webapps/host-manager/images/favicon.ico
+webserverextensions/tomcat/webapps/host-manager/images/tomcat.svg
+webserverextensions/tomcat/webapps/host-manager/index.jsp
+webserverextensions/tomcat/webapps/manager/
+webserverextensions/tomcat/webapps/manager/META-INF/
+webserverextensions/tomcat/webapps/manager/META-INF/context.xml
+webserverextensions/tomcat/webapps/manager/WEB-INF/
+webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/
+webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/401.jsp
+webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/403.jsp
+webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/404.jsp
+webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/connectorCerts.jsp
+webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/connectorCiphers.jsp
+webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/connectorTrustedCerts.jsp
+webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/sessionDetail.jsp
+webserverextensions/tomcat/webapps/manager/WEB-INF/jsp/sessionsList.jsp
+webserverextensions/tomcat/webapps/manager/WEB-INF/web.xml
+webserverextensions/tomcat/webapps/manager/css/
+webserverextensions/tomcat/webapps/manager/css/manager.css
+webserverextensions/tomcat/webapps/manager/images/
+webserverextensions/tomcat/webapps/manager/images/asf-logo.svg
+webserverextensions/tomcat/webapps/manager/images/favicon.ico
+webserverextensions/tomcat/webapps/manager/images/tomcat.svg
+webserverextensions/tomcat/webapps/manager/index.jsp
+webserverextensions/tomcat/webapps/manager/status.xsd
+webserverextensions/tomcat/webapps/manager/xform.xsl
+webserverextensions/tomcat/work/
 webserverextensions/www/
-webserverextensions/www/phpviewersample/
-webserverextensions/www/phpviewersample/dwfviewersample.php
-webserverextensions/www/phpviewersample/composer.json
-webserverextensions/www/phpviewersample/findaddress/
-webserverextensions/www/phpviewersample/findaddress/findaddress.php
-webserverextensions/www/phpviewersample/findaddress/templates/
-webserverextensions/www/phpviewersample/findaddress/templates/addressmarker.xml
-webserverextensions/www/phpviewersample/findaddress/gotopoint.php
-webserverextensions/www/phpviewersample/findaddress/clearaddressresults.php
-webserverextensions/www/phpviewersample/findaddress/findaddressmain.php
-webserverextensions/www/phpviewersample/findaddress/findaddressfunctions.php
-webserverextensions/www/phpviewersample/styles/
-webserverextensions/www/phpviewersample/styles/gt.css
-webserverextensions/www/phpviewersample/query/
-webserverextensions/www/phpviewersample/query/classes/
-webserverextensions/www/phpviewersample/query/classes/query.php
-webserverextensions/www/phpviewersample/query/classes/property.php
-webserverextensions/www/phpviewersample/query/classes/feature.php
-webserverextensions/www/phpviewersample/query/templates/
-webserverextensions/www/phpviewersample/query/templates/filterlayerdefinition.xml
-webserverextensions/www/phpviewersample/query/querycontroller.php
-webserverextensions/www/phpviewersample/query/querymain.php
-webserverextensions/www/phpviewersample/ajaxviewersample.php
-webserverextensions/www/phpviewersample/ajaxtiledviewersample.php
-webserverextensions/www/phpviewersample/JSON.php
-webserverextensions/www/phpviewersample/theme/
-webserverextensions/www/phpviewersample/theme/classes/
-webserverextensions/www/phpviewersample/theme/classes/theme.php
-webserverextensions/www/phpviewersample/theme/classes/layerinfo.php
-webserverextensions/www/phpviewersample/theme/classes/property.php
-webserverextensions/www/phpviewersample/theme/templates/
-webserverextensions/www/phpviewersample/theme/templates/arearuletemplate.xml
-webserverextensions/www/phpviewersample/theme/themecontroller.php
-webserverextensions/www/phpviewersample/theme/thememain.php
-webserverextensions/www/phpviewersample/plot/
-webserverextensions/www/phpviewersample/plot/plot.php
-webserverextensions/www/phpviewersample/plot/plotmain.php
-webserverextensions/www/phpviewersample/title.html
-webserverextensions/www/phpviewersample/utilityfunctions.php
-webserverextensions/www/phpviewersample/images/
-webserverextensions/www/phpviewersample/images/loader_inactive.gif
-webserverextensions/www/phpviewersample/images/pushpin.jpg
-webserverextensions/www/phpviewersample/images/pushpinblue.jpg
-webserverextensions/www/phpviewersample/images/loader_pulse.gif
-webserverextensions/www/phpviewersample/images/Thumbs.db
-webserverextensions/www/phpviewersample/json.js
-webserverextensions/www/phpviewersample/overview/
-webserverextensions/www/phpviewersample/overview/overviewmain.php
-webserverextensions/www/phpviewersample/vendor/
-webserverextensions/www/phpviewersample/vendor/autoload.php
-webserverextensions/www/phpviewersample/vendor/composer/
-webserverextensions/www/phpviewersample/vendor/composer/autoload_real.php
-webserverextensions/www/phpviewersample/vendor/composer/autoload_classmap.php
-webserverextensions/www/phpviewersample/vendor/composer/installed.json
-webserverextensions/www/phpviewersample/vendor/composer/ClassLoader.php
-webserverextensions/www/phpviewersample/vendor/composer/autoload_psr4.php
-webserverextensions/www/phpviewersample/vendor/composer/autoload_namespaces.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/build.xml
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Client.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/ClientInterface.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Value/
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Value/Base64Interface.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Value/Base64.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Parser/
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Parser/ParserInterface.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Parser/XmlReaderParser.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Parser/NativeParser.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/AbstractDecorator.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/ExtensionSupportInterface.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/GuzzleBridge.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/BuzzBrowserBridge.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/HttpTransportInterface.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/StreamSocketTransport.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/AbstractHttpTransport.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/TransportInterface.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/ZendFrameworkOneHttpClientBridge.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/ZendFrameworkTwoHttpClientBridge.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/CurlTransport.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Timing/
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Timing/ZendFrameworkTwoTimerBridge.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Timing/TimingDecorator.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Timing/ZendFrameworkOneTimerBridge.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Timing/AbstractTimerBridge.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Timing/Psr3TimerBridge.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Timing/MonologTimerBridge.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Timing/TimerInterface.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Proxy.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Multicall.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/CodeGenerator/
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/CodeGenerator/XmlReaderParserBitmaskGenerator.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/HttpException.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/ResponseException.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/SerializationException.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/MissingExtensionException.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/TcpException.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/TransportException.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/RuntimeException.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/InvalidArgumentException.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/ExceptionInterface.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Serializer/
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Serializer/XmlWriterSerializer.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Serializer/SerializerInterface.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Serializer/NativeSerializer.php
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/composer.json
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/.gitignore
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/phpunit.xml.dist
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/package.json
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/README.md
-webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/.travis.yml
-webserverextensions/www/stdicons/
-webserverextensions/www/stdicons/lc_collapse.gif
-webserverextensions/www/stdicons/lc_dwf.gif
-webserverextensions/www/stdicons/cp_arr.gif
-webserverextensions/www/stdicons/icon_zoomprev.gif
-webserverextensions/www/stdicons/pan.cur
-webserverextensions/www/stdicons/lc_unchecked_grayed_16.gif
-webserverextensions/www/stdicons/slider.png
-webserverextensions/www/stdicons/icon_print_disabled.gif
-webserverextensions/www/stdicons/lc_noexpand.gif
-webserverextensions/www/stdicons/icon_refreshmap.gif
-webserverextensions/www/stdicons/mn_scrollup_disabled.gif
-webserverextensions/www/stdicons/nav_band_expand.gif
-webserverextensions/www/stdicons/selectRadius.cur
-webserverextensions/www/stdicons/lc_sym.gif
-webserverextensions/www/stdicons/cp_arr_dis.gif
-webserverextensions/www/stdicons/icon_copy.gif
-webserverextensions/www/stdicons/mn_scrolldown_disabled.gif
-webserverextensions/www/stdicons/progress_indicator.gif
-webserverextensions/www/stdicons/mn_scrolldown.gif
-webserverextensions/www/stdicons/icon_zoomnext_disabled.gif
-webserverextensions/www/stdicons/icon_panleft_disabled.gif
-webserverextensions/www/stdicons/measure.cur
-webserverextensions/www/stdicons/icon_forward.gif
-webserverextensions/www/stdicons/mn_scrollup.gif
-webserverextensions/www/stdicons/icon_home.gif
-webserverextensions/www/stdicons/digitizePolygon.cur
-webserverextensions/www/stdicons/lc_broken.gif
-webserverextensions/www/stdicons/icon_pandown_disabled.gif
-webserverextensions/www/stdicons/zoomout.cur
-webserverextensions/www/stdicons/icon_fitwindow.gif
-webserverextensions/www/stdicons/icon_menuarrow.gif
-webserverextensions/www/stdicons/lc_select.gif
-webserverextensions/www/stdicons/icon_buffer_disabled.gif
-webserverextensions/www/stdicons/zoomin.cur
-webserverextensions/www/stdicons/icon_invokescript.gif
-webserverextensions/www/stdicons/icon_help.gif
-webserverextensions/www/stdicons/icon_selectradius.gif
-webserverextensions/www/stdicons/icon_zoomrect.gif
-webserverextensions/www/stdicons/icon_viewoptions.gif
-webserverextensions/www/stdicons/icon_clearselect.gif
-webserverextensions/www/stdicons/pixel.gif
-webserverextensions/www/stdicons/icon_selectwithin.gif
-webserverextensions/www/stdicons/icon_home_disabled.gif
-webserverextensions/www/stdicons/icon_zoomrect_disabled.gif
-webserverextensions/www/stdicons/icon_popupscrollup.gif
-webserverextensions/www/stdicons/sliderscale.png
-webserverextensions/www/stdicons/lc_checked.gif
-webserverextensions/www/stdicons/pr_north.gif
-webserverextensions/www/stdicons/lc_style.gif
-webserverextensions/www/stdicons/icon_menuarrowup_disabled.gif
-webserverextensions/www/stdicons/icon_search_disabled.gif
-webserverextensions/www/stdicons/icon_panright.gif
-webserverextensions/www/stdicons/icon_measure.gif
-webserverextensions/www/stdicons/lc_unselect.gif
-webserverextensions/www/stdicons/icon_zoomselect.gif
-webserverextensions/www/stdicons/icon_help_disabled.gif
-webserverextensions/www/stdicons/digitizeLine.cur
-webserverextensions/www/stdicons/icon_menuarrow_disabled.gif
-webserverextensions/www/stdicons/selectPolygon.cur
-webserverextensions/www/stdicons/icon_measure_disabled.gif
-webserverextensions/www/stdicons/icon_error.gif
-webserverextensions/www/stdicons/icon_null.gif
-webserverextensions/www/stdicons/lc_checked_16.gif
-webserverextensions/www/stdicons/icon_pan.gif
-webserverextensions/www/stdicons/icon_panup.gif
-webserverextensions/www/stdicons/icon_tasks.gif
-webserverextensions/www/stdicons/icon_copy_disabled.gif
-webserverextensions/www/stdicons/icon_popupscrollup_disabled.gif
-webserverextensions/www/stdicons/icon_print.gif
-webserverextensions/www/stdicons/icon_select.gif
-webserverextensions/www/stdicons/icon_zoom_disabled.gif
-webserverextensions/www/stdicons/icon_back.gif
-webserverextensions/www/stdicons/lc_checked_grayed_16.gif
-webserverextensions/www/stdicons/icon_select_disabled.gif
-webserverextensions/www/stdicons/lc_checked_grayed.gif
-webserverextensions/www/stdicons/icon_buffer.gif
-webserverextensions/www/stdicons/lc_theme.gif
-webserverextensions/www/stdicons/icon_search.gif
-webserverextensions/www/stdicons/digitizeRectangle.cur
-webserverextensions/www/stdicons/icon_warning.gif
-webserverextensions/www/stdicons/icon_selectwithin_disabled.gif
-webserverextensions/www/stdicons/icon_maptip_disabled.gif
-webserverextensions/www/stdicons/icon_forward_disabled.gif
-webserverextensions/www/stdicons/icon_popupscrolldown_disabled.gif
-webserverextensions/www/stdicons/lc_expand_16.gif
-webserverextensions/www/stdicons/icon_panleft.gif
-webserverextensions/www/stdicons/icon_selectradius_disabled.gif
-webserverextensions/www/stdicons/icon_restorecenter_disabled.gif
-webserverextensions/www/stdicons/lc_unchecked.gif
-webserverextensions/www/stdicons/icon_fitwindow_disabled.gif
-webserverextensions/www/stdicons/icon_printablepage.gif
-webserverextensions/www/stdicons/icon_viewoptions_disabled.gif
-webserverextensions/www/stdicons/zoomrect.cur
-webserverextensions/www/stdicons/lc_unchecked_grayed.gif
-webserverextensions/www/stdicons/lc_raster.gif
-webserverextensions/www/stdicons/nav_band_contract.gif
-webserverextensions/www/stdicons/lc_collapse_16.gif
-webserverextensions/www/stdicons/icon_zoom.gif
-webserverextensions/www/stdicons/icon_zoomin_disabled.gif
-webserverextensions/www/stdicons/icon_ctxarrow.gif
-webserverextensions/www/stdicons/lc_group.gif
-webserverextensions/www/stdicons/icon_zoomnext.gif
-webserverextensions/www/stdicons/icon_zoomselect_disabled.gif
-webserverextensions/www/stdicons/digitizePoint.cur
-webserverextensions/www/stdicons/openButton.gif
-webserverextensions/www/stdicons/lc_unchecked_16.gif
-webserverextensions/www/stdicons/rotate.cur
-webserverextensions/www/stdicons/mn_check.gif
-webserverextensions/www/stdicons/icon_invokeurl.gif
-webserverextensions/www/stdicons/icon_printablepage_disabled.gif
-webserverextensions/www/stdicons/icon_zoomout.gif
-webserverextensions/www/stdicons/closeButton.gif
-webserverextensions/www/stdicons/icon_plotdwf_disabled.gif
-webserverextensions/www/stdicons/icon_tasks_disabled.gif
-webserverextensions/www/stdicons/icon_pandown.gif
-webserverextensions/www/stdicons/transparentpixel.gif
-webserverextensions/www/stdicons/icon_maptip.gif
-webserverextensions/www/stdicons/icon_zoomin.gif
-webserverextensions/www/stdicons/icon_popupscrolldown.gif
-webserverextensions/www/stdicons/icon_zoomout_disabled.gif
-webserverextensions/www/stdicons/icon_back_disabled.gif
-webserverextensions/www/stdicons/icon_loading.gif
-webserverextensions/www/stdicons/digitizeCircle.cur
-webserverextensions/www/stdicons/digitizeLineString.cur
-webserverextensions/www/stdicons/icon_clearselect_disabled.gif
-webserverextensions/www/stdicons/icon_refreshmap_disabled.gif
-webserverextensions/www/stdicons/icon_selectpolygon.gif
-webserverextensions/www/stdicons/icon_zoomprev_disabled.gif
-webserverextensions/www/stdicons/icon_restorecenter.gif
-webserverextensions/www/stdicons/icon_invokeurl_disabled.gif
-webserverextensions/www/stdicons/icon_menuarrowup.gif
-webserverextensions/www/stdicons/icon_invokescript_disabled.gif
-webserverextensions/www/stdicons/lc_expand.gif
-webserverextensions/www/stdicons/icon_panright_disabled.gif
-webserverextensions/www/stdicons/icon_pan_disabled.gif
-webserverextensions/www/stdicons/icon_plotdwf.gif
-webserverextensions/www/stdicons/icon_info.gif
-webserverextensions/www/stdicons/icon_panup_disabled.gif
-webserverextensions/www/stdicons/icon_selectpolygon_disabled.gif
-webserverextensions/www/samples.php
-webserverextensions/www/mapviewerjava/
-webserverextensions/www/mapviewerjava/product.jsp
-webserverextensions/www/mapviewerjava/selectwithin.jsp
-webserverextensions/www/mapviewerjava/legendctrl.jsp
-webserverextensions/www/mapviewerjava/quickplotpreviewinner.jsp
-webserverextensions/www/mapviewerjava/gettingstarted.jsp
-webserverextensions/www/mapviewerjava/mapframe.jsp
-webserverextensions/www/mapviewerjava/bufferui.jsp
-webserverextensions/www/mapviewerjava/index.jsp
-webserverextensions/www/mapviewerjava/selectwithinui.jsp
-webserverextensions/www/mapviewerjava/ajaxviewerabout.jsp
-webserverextensions/www/mapviewerjava/toolbar.jsp
-webserverextensions/www/mapviewerjava/formframe.jsp
-webserverextensions/www/mapviewerjava/legendui.jsp
-webserverextensions/www/mapviewerjava/taskpane.jsp
-webserverextensions/www/mapviewerjava/searchprompt.jsp
-webserverextensions/www/mapviewerjava/statusbar.jsp
-webserverextensions/www/mapviewerjava/search.jsp
-webserverextensions/www/mapviewerjava/measure.jsp
-webserverextensions/www/mapviewerjava/measureui.jsp
-webserverextensions/www/mapviewerjava/viewoptions.jsp
-webserverextensions/www/mapviewerjava/tasklist.jsp
-webserverextensions/www/mapviewerjava/colorpicker.jsp
-webserverextensions/www/mapviewerjava/legend.jsp
-webserverextensions/www/mapviewerjava/taskframe.jsp
-webserverextensions/www/mapviewerjava/quickplotgeneratepicture.jsp
-webserverextensions/www/mapviewerjava/quickplotpanel.jsp
-webserverextensions/www/mapviewerjava/init.jsp
-webserverextensions/www/mapviewerjava/ajaxviewer.jsp
-webserverextensions/www/mapviewerjava/mainframe.jsp
-webserverextensions/www/mapviewerjava/serveradminhelper.jsp
-webserverextensions/www/mapviewerjava/propertyctrl.jsp
-webserverextensions/www/mapviewerjava/taskbar.jsp
-webserverextensions/www/mapviewerjava/buffer.jsp
-webserverextensions/www/mapviewerjava/common.jsp
+webserverextensions/www/Resources/
+webserverextensions/www/Resources/mapguide_en.res
+webserverextensions/www/TempDir/
+webserverextensions/www/WEB-INF/
+webserverextensions/www/WEB-INF/lib/
+webserverextensions/www/WEB-INF/lib/MapGuideApi-sources.jar
+webserverextensions/www/WEB-INF/lib/MapGuideApi.jar
+webserverextensions/www/WEB-INF/lib/commons-codec-1.3.jar
+webserverextensions/www/WEB-INF/lib/commons-fileupload-1.0.jar
+webserverextensions/www/WEB-INF/web.xml
+webserverextensions/www/clientsamples/
+webserverextensions/www/clientsamples/assets/
+webserverextensions/www/clientsamples/assets/OpenLayers.js
+webserverextensions/www/clientsamples/assets/jquery-1.10.2.min.js
+webserverextensions/www/clientsamples/assets/legend.js
+webserverextensions/www/clientsamples/assets/legend_ol.js
+webserverextensions/www/clientsamples/assets/theme/
+webserverextensions/www/clientsamples/assets/theme/default/
+webserverextensions/www/clientsamples/assets/theme/default/google.css
+webserverextensions/www/clientsamples/assets/theme/default/google.tidy.css
+webserverextensions/www/clientsamples/assets/theme/default/ie6-style.css
+webserverextensions/www/clientsamples/assets/theme/default/ie6-style.tidy.css
+webserverextensions/www/clientsamples/assets/theme/default/img/
+webserverextensions/www/clientsamples/assets/theme/default/img/add_point_off.png
+webserverextensions/www/clientsamples/assets/theme/default/img/add_point_on.png
+webserverextensions/www/clientsamples/assets/theme/default/img/blank.gif
+webserverextensions/www/clientsamples/assets/theme/default/img/close.gif
+webserverextensions/www/clientsamples/assets/theme/default/img/drag-rectangle-off.png
+webserverextensions/www/clientsamples/assets/theme/default/img/drag-rectangle-on.png
+webserverextensions/www/clientsamples/assets/theme/default/img/draw_line_off.png
+webserverextensions/www/clientsamples/assets/theme/default/img/draw_line_on.png
+webserverextensions/www/clientsamples/assets/theme/default/img/draw_point_off.png
+webserverextensions/www/clientsamples/assets/theme/default/img/draw_point_on.png
+webserverextensions/www/clientsamples/assets/theme/default/img/draw_polygon_off.png
+webserverextensions/www/clientsamples/assets/theme/default/img/draw_polygon_on.png
+webserverextensions/www/clientsamples/assets/theme/default/img/editing_tool_bar.png
+webserverextensions/www/clientsamples/assets/theme/default/img/move_feature_off.png
+webserverextensions/www/clientsamples/assets/theme/default/img/move_feature_on.png
+webserverextensions/www/clientsamples/assets/theme/default/img/navigation_history.png
+webserverextensions/www/clientsamples/assets/theme/default/img/overview_replacement.gif
+webserverextensions/www/clientsamples/assets/theme/default/img/pan-panel-NOALPHA.png
+webserverextensions/www/clientsamples/assets/theme/default/img/pan-panel.png
+webserverextensions/www/clientsamples/assets/theme/default/img/pan_off.png
+webserverextensions/www/clientsamples/assets/theme/default/img/pan_on.png
+webserverextensions/www/clientsamples/assets/theme/default/img/panning-hand-off.png
+webserverextensions/www/clientsamples/assets/theme/default/img/panning-hand-on.png
+webserverextensions/www/clientsamples/assets/theme/default/img/remove_point_off.png
+webserverextensions/www/clientsamples/assets/theme/default/img/remove_point_on.png
+webserverextensions/www/clientsamples/assets/theme/default/img/ruler.png
+webserverextensions/www/clientsamples/assets/theme/default/img/save_features_off.png
+webserverextensions/www/clientsamples/assets/theme/default/img/save_features_on.png
+webserverextensions/www/clientsamples/assets/theme/default/img/view_next_off.png
+webserverextensions/www/clientsamples/assets/theme/default/img/view_next_on.png
+webserverextensions/www/clientsamples/assets/theme/default/img/view_previous_off.png
+webserverextensions/www/clientsamples/assets/theme/default/img/view_previous_on.png
+webserverextensions/www/clientsamples/assets/theme/default/img/zoom-panel-NOALPHA.png
+webserverextensions/www/clientsamples/assets/theme/default/img/zoom-panel.png
+webserverextensions/www/clientsamples/assets/theme/default/style.css
+webserverextensions/www/clientsamples/assets/theme/default/style.mobile.css
+webserverextensions/www/clientsamples/assets/theme/default/style.mobile.tidy.css
+webserverextensions/www/clientsamples/assets/theme/default/style.tidy.css
+webserverextensions/www/clientsamples/data/
+webserverextensions/www/clientsamples/data/SheboyganCommercial.MapDefinition.xml
+webserverextensions/www/clientsamples/data/SheboyganMixed.MapDefinition.xml
+webserverextensions/www/clientsamples/data/load.php
+webserverextensions/www/clientsamples/external/
+webserverextensions/www/clientsamples/external/index.html
+webserverextensions/www/clientsamples/geoprocessing/
+webserverextensions/www/clientsamples/geoprocessing/index_ol.html
+webserverextensions/www/clientsamples/hybrid/
+webserverextensions/www/clientsamples/hybrid/index.html
+webserverextensions/www/clientsamples/mixed/
+webserverextensions/www/clientsamples/mixed/index.html
+webserverextensions/www/clientsamples/mixed/index_ol.html
+webserverextensions/www/clientsamples/retina/
+webserverextensions/www/clientsamples/retina/index_ol.html
+webserverextensions/www/clientsamples/selection/
+webserverextensions/www/clientsamples/selection/index.html
+webserverextensions/www/clientsamples/tiled/
+webserverextensions/www/clientsamples/tiled/index.html
+webserverextensions/www/clientsamples/untiled/
+webserverextensions/www/clientsamples/untiled/index.html
+webserverextensions/www/clientsamples/utfgrid/
+webserverextensions/www/clientsamples/utfgrid/index.html
+webserverextensions/www/clientsamples/wms/
+webserverextensions/www/clientsamples/wms/index.html
+webserverextensions/www/clientsamples/xyz/
+webserverextensions/www/clientsamples/xyz/index.html
+webserverextensions/www/clientsamples/xyz/index_ol.html
 webserverextensions/www/fusion/
-webserverextensions/www/fusion/ext/
-webserverextensions/www/fusion/ext/README.TXT
+webserverextensions/www/fusion/common/
+webserverextensions/www/fusion/common/browserdetect.js
+webserverextensions/www/fusion/common/images/
+webserverextensions/www/fusion/common/images/loader_inactive.gif
+webserverextensions/www/fusion/common/images/loader_pulse.gif
+webserverextensions/www/fusion/common/json.js
+webserverextensions/www/fusion/common/mgsamples.css
+webserverextensions/www/fusion/common/php/
+webserverextensions/www/fusion/common/php/GetLocale.php
+webserverextensions/www/fusion/common/php/Utilities.php
+webserverextensions/www/fusion/common/php/Xml2JSON.php
+webserverextensions/www/fusion/config.json
+webserverextensions/www/fusion/configHeader.json
 webserverextensions/www/fusion/containerinfo/
-webserverextensions/www/fusion/containerinfo/toolbar.xml
+webserverextensions/www/fusion/containerinfo/contextmenu.xml
 webserverextensions/www/fusion/containerinfo/menu.png
 webserverextensions/www/fusion/containerinfo/splitterbar.png
-webserverextensions/www/fusion/containerinfo/contextmenu.xml
+webserverextensions/www/fusion/containerinfo/splitterbar.xml
 webserverextensions/www/fusion/containerinfo/toolbar.png
-webserverextensions/www/fusion/containerinfo/splitterbar.xml
-webserverextensions/www/fusion/widgets/
-webserverextensions/www/fusion/widgets/SelectionInfo/
-webserverextensions/www/fusion/widgets/SelectionInfo/SelectionInfo.css
-webserverextensions/www/fusion/widgets/Legend.js
-webserverextensions/www/fusion/widgets/SelectRadiusValue.js
-webserverextensions/www/fusion/widgets/SelectionPanel/
-webserverextensions/www/fusion/widgets/SelectionPanel/SelectionPanel.css
-webserverextensions/www/fusion/widgets/Print/
-webserverextensions/www/fusion/widgets/Print/Print.css
-webserverextensions/www/fusion/widgets/Print/pr_north.gif
-webserverextensions/www/fusion/widgets/Print/printablepage.templ
-webserverextensions/www/fusion/widgets/Print/printablepage.php
-webserverextensions/www/fusion/widgets/GetFeatureInfo.js
-webserverextensions/www/fusion/widgets/Measure/
-webserverextensions/www/fusion/widgets/Measure/Measure.css
-webserverextensions/www/fusion/widgets/Measure/MeasurePending.gif
-webserverextensions/www/fusion/widgets/Measure/Measure.php
-webserverextensions/www/fusion/widgets/Zoom.js
-webserverextensions/www/fusion/widgets/Legend/
-webserverextensions/www/fusion/widgets/Legend/Legend.css
-webserverextensions/www/fusion/widgets/FeatureInfo.js
-webserverextensions/www/fusion/widgets/Theme.js
-webserverextensions/www/fusion/widgets/QuickPlot.js
-webserverextensions/www/fusion/widgets/ClearSelection.js
-webserverextensions/www/fusion/widgets/SelectWithin.js
-webserverextensions/www/fusion/widgets/ViewSize/
-webserverextensions/www/fusion/widgets/ViewSize/ViewSize.css
-webserverextensions/www/fusion/widgets/SaveSession.js
-webserverextensions/www/fusion/widgets/ScalebarDual.js
-webserverextensions/www/fusion/widgets/Redline.js
-webserverextensions/www/fusion/widgets/Geolocation.js
-webserverextensions/www/fusion/widgets/CoordinateTracker/
-webserverextensions/www/fusion/widgets/CoordinateTracker/CoordinateTracker.css
-webserverextensions/www/fusion/widgets/CoordinateTracker/CoordinateTracker.php
-webserverextensions/www/fusion/widgets/AddWMSLayer/
-webserverextensions/www/fusion/widgets/AddWMSLayer/wms-parser.php
-webserverextensions/www/fusion/widgets/AddWMSLayer/AddWMSLayer.php
-webserverextensions/www/fusion/widgets/AddWMSLayer/AddWMSLayer.css
-webserverextensions/www/fusion/widgets/AddWMSLayer/AddWMSLayer.html
-webserverextensions/www/fusion/widgets/Buffer.js
-webserverextensions/www/fusion/widgets/ZoomToSelection.js
-webserverextensions/www/fusion/widgets/SaveMapImage.js
-webserverextensions/www/fusion/widgets/Redline/
-webserverextensions/www/fusion/widgets/Redline/uploadmarkup.php
-webserverextensions/www/fusion/widgets/Redline/editmarkupstyle.php
-webserverextensions/www/fusion/widgets/Redline/newmarkup.php
-webserverextensions/www/fusion/widgets/Redline/classes/
-webserverextensions/www/fusion/widgets/Redline/classes/markupeditor.php
-webserverextensions/www/fusion/widgets/Redline/classes/markupmanager.php
-webserverextensions/www/fusion/widgets/Redline/classes/editcommand.php
-webserverextensions/www/fusion/widgets/Redline/classes/markupschemafactory.php
-webserverextensions/www/fusion/widgets/Redline/classes/defaultstyle.php
-webserverextensions/www/fusion/widgets/Redline/classes/markupcommand.php
-webserverextensions/www/fusion/widgets/Redline/templates/
-webserverextensions/www/fusion/widgets/Redline/templates/area_line_90.templ
-webserverextensions/www/fusion/widgets/Redline/templates/markuplayerdefinition_advanced.xml
-webserverextensions/www/fusion/widgets/Redline/templates/area_hex.templ
-webserverextensions/www/fusion/widgets/Redline/templates/area_line.templ
-webserverextensions/www/fusion/widgets/Redline/templates/line_dash.templ
-webserverextensions/www/fusion/widgets/Redline/templates/area_sacncr.templ
-webserverextensions/www/fusion/widgets/Redline/templates/line_dashdotdot.templ
-webserverextensions/www/fusion/widgets/Redline/templates/line_fenceline1.templ
-webserverextensions/www/fusion/widgets/Redline/templates/area_dash.templ
-webserverextensions/www/fusion/widgets/Redline/templates/line_dashdot.templ
-webserverextensions/www/fusion/widgets/Redline/templates/line_rail.templ
-webserverextensions/www/fusion/widgets/Redline/templates/line_border.templ
-webserverextensions/www/fusion/widgets/Redline/templates/area_net.templ
-webserverextensions/www/fusion/widgets/Redline/templates/markuplayerdefinition.xml
-webserverextensions/www/fusion/widgets/Redline/templates/area_line_135.templ
-webserverextensions/www/fusion/widgets/Redline/templates/area_dolmit.templ
-webserverextensions/www/fusion/widgets/Redline/templates/line_dot.templ
-webserverextensions/www/fusion/widgets/Redline/templates/line_solid.templ
-webserverextensions/www/fusion/widgets/Redline/templates/area_box.templ
-webserverextensions/www/fusion/widgets/Redline/templates/area_cross.templ
-webserverextensions/www/fusion/widgets/Redline/templates/line_divide.templ
-webserverextensions/www/fusion/widgets/Redline/templates/area_square.templ
-webserverextensions/www/fusion/widgets/Redline/templates/area_solid.templ
-webserverextensions/www/fusion/widgets/Redline/templates/area_line_45.templ
-webserverextensions/www/fusion/widgets/Redline/templates/markupfeaturesource.xml
-webserverextensions/www/fusion/widgets/Redline/templates/area_steel.templ
-webserverextensions/www/fusion/widgets/Redline/styles/
-webserverextensions/www/fusion/widgets/Redline/getselectionxml.php
-webserverextensions/www/fusion/widgets/Redline/editmarkup.php
-webserverextensions/www/fusion/widgets/Redline/Redline.css
-webserverextensions/www/fusion/widgets/Redline/markupmain.php
-webserverextensions/www/fusion/widgets/LayerManager/
-webserverextensions/www/fusion/widgets/LayerManager/LayerManager.css
-webserverextensions/www/fusion/widgets/Select.js
-webserverextensions/www/fusion/widgets/scalebar/
-webserverextensions/www/fusion/widgets/scalebar/scalebar-fancy.css
-webserverextensions/www/fusion/widgets/scalebar/license.txt
-webserverextensions/www/fusion/widgets/scalebar/scalebar-fat.css
-webserverextensions/www/fusion/widgets/scalebar/scalebartool.js
-webserverextensions/www/fusion/widgets/scalebar/fancy-bar.gif
-webserverextensions/www/fusion/widgets/scalebar/fancy-bar-alt.gif
-webserverextensions/www/fusion/widgets/scalebar/scalebar-thinner.css
-webserverextensions/www/fusion/widgets/scalebar/scalebar-thin.css
-webserverextensions/www/fusion/widgets/MapMetadata.js
-webserverextensions/www/fusion/widgets/BufferPanel/
-webserverextensions/www/fusion/widgets/BufferPanel/cp_arr.gif
-webserverextensions/www/fusion/widgets/BufferPanel/cp_arr_dis.gif
-webserverextensions/www/fusion/widgets/BufferPanel/BufferPanel.php
-webserverextensions/www/fusion/widgets/BufferPanel/AreaLayerDef.templ
-webserverextensions/www/fusion/widgets/BufferPanel/BufferReport.templ
-webserverextensions/www/fusion/widgets/BufferPanel/ColorPicker.php
-webserverextensions/www/fusion/widgets/BufferPanel/ErrorPage.templ
-webserverextensions/www/fusion/widgets/BufferPanel/Viewer.css
-webserverextensions/www/fusion/widgets/BufferPanel/ColorPicker.templ
-webserverextensions/www/fusion/widgets/BufferPanel/Buffer.php
-webserverextensions/www/fusion/widgets/BufferPanel/BufferPanel.templ
-webserverextensions/www/fusion/widgets/Maptip.js
-webserverextensions/www/fusion/widgets/Maptip/
-webserverextensions/www/fusion/widgets/Maptip/Maptip.css
-webserverextensions/www/fusion/widgets/EditableScale.js
-webserverextensions/www/fusion/widgets/MapMenu.js
-webserverextensions/www/fusion/widgets/widgetinfo/
-webserverextensions/www/fusion/widgets/widgetinfo/refreshmap.xml
-webserverextensions/www/fusion/widgets/widgetinfo/scalebar.xml
-webserverextensions/www/fusion/widgets/widgetinfo/zoomonclick.xml
-webserverextensions/www/fusion/widgets/widgetinfo/invokescript.xml
-webserverextensions/www/fusion/widgets/widgetinfo/print.xml
-webserverextensions/www/fusion/widgets/widgetinfo/invokeurl.xml
-webserverextensions/www/fusion/widgets/widgetinfo/selectwithin.xml
-webserverextensions/www/fusion/widgets/widgetinfo/redline.xml
-webserverextensions/www/fusion/widgets/widgetinfo/measure.xml
-webserverextensions/www/fusion/widgets/widgetinfo/scalebardual.xml
-webserverextensions/www/fusion/widgets/widgetinfo/quickplot.xml
-webserverextensions/www/fusion/widgets/widgetinfo/bufferpanel.xml
-webserverextensions/www/fusion/widgets/widgetinfo/GoogleStreetViewer.xml
-webserverextensions/www/fusion/widgets/widgetinfo/extenthistory.xml
-webserverextensions/www/fusion/widgets/widgetinfo/navigator.xml
-webserverextensions/www/fusion/widgets/widgetinfo/selectpolygon.xml
-webserverextensions/www/fusion/widgets/widgetinfo/viewsize.xml
-webserverextensions/www/fusion/widgets/widgetinfo/cursorposition.xml
-webserverextensions/www/fusion/widgets/widgetinfo/viewoptions.xml
-webserverextensions/www/fusion/widgets/widgetinfo/clearselection.xml
-webserverextensions/www/fusion/widgets/widgetinfo/buffer.xml
-webserverextensions/www/fusion/widgets/widgetinfo/legend.xml
-webserverextensions/www/fusion/widgets/widgetinfo/featureinfo.xml
-webserverextensions/www/fusion/widgets/widgetinfo/panonclick.xml
-webserverextensions/www/fusion/widgets/widgetinfo/help.xml
-webserverextensions/www/fusion/widgets/widgetinfo/maptip.xml
-webserverextensions/www/fusion/widgets/widgetinfo/zoom.xml
-webserverextensions/www/fusion/widgets/widgetinfo/selectioninfo.xml
-webserverextensions/www/fusion/widgets/widgetinfo/mapmenu.xml
-webserverextensions/www/fusion/widgets/widgetinfo/selectionpanel.xml
-webserverextensions/www/fusion/widgets/widgetinfo/basemapswitcher.xml
-webserverextensions/www/fusion/widgets/widgetinfo/zoomtoselection.xml
-webserverextensions/www/fusion/widgets/widgetinfo/colorpicker.xml
-webserverextensions/www/fusion/widgets/widgetinfo/coordinatetracker.xml
-webserverextensions/www/fusion/widgets/widgetinfo/geolocation.xml
-webserverextensions/www/fusion/widgets/widgetinfo/about.xml
-webserverextensions/www/fusion/widgets/widgetinfo/selectradiusvalue.xml
-webserverextensions/www/fusion/widgets/widgetinfo/search.xml
-webserverextensions/www/fusion/widgets/widgetinfo/select.xml
-webserverextensions/www/fusion/widgets/widgetinfo/WidgetInfoTemplate.xml
-webserverextensions/www/fusion/widgets/widgetinfo/pan.xml
-webserverextensions/www/fusion/widgets/widgetinfo/panquery.xml
-webserverextensions/www/fusion/widgets/widgetinfo/centerselection.xml
-webserverextensions/www/fusion/widgets/widgetinfo/activityindicator.xml
-webserverextensions/www/fusion/widgets/widgetinfo/linktoview.xml
-webserverextensions/www/fusion/widgets/widgetinfo/savemap.xml
-webserverextensions/www/fusion/widgets/widgetinfo/initialmapview.xml
-webserverextensions/www/fusion/widgets/widgetinfo/selectradius.xml
-webserverextensions/www/fusion/widgets/widgetinfo/theme.xml
-webserverextensions/www/fusion/widgets/widgetinfo/taskpane.xml
-webserverextensions/www/fusion/widgets/widgetinfo/overviewmap.xml
-webserverextensions/www/fusion/widgets/widgetinfo/editablescale.xml
-webserverextensions/www/fusion/widgets/widgetinfo/query.xml
-webserverextensions/www/fusion/widgets/ZoomOnClick.js
-webserverextensions/www/fusion/widgets/InvokeURL.js
-webserverextensions/www/fusion/widgets/GoogleStreetViewer/
-webserverextensions/www/fusion/widgets/GoogleStreetViewer/GoogleStreetView.templ
-webserverextensions/www/fusion/widgets/GoogleStreetViewer/navigator.png
-webserverextensions/www/fusion/widgets/GoogleStreetViewer/GoogleStreetView.png
-webserverextensions/www/fusion/widgets/GoogleStreetViewer/GoogleStreetView.php
-webserverextensions/www/fusion/widgets/InitialMapView.js
-webserverextensions/www/fusion/widgets/BasemapSwitcher.js
-webserverextensions/www/fusion/widgets/MapWidget/
-webserverextensions/www/fusion/widgets/MapWidget/MapWidget.css
-webserverextensions/www/fusion/widgets/SelectionInfo.js
-webserverextensions/www/fusion/widgets/ExtentHistory.js
-webserverextensions/www/fusion/widgets/Search.js
-webserverextensions/www/fusion/widgets/SelectRadius.js
-webserverextensions/www/fusion/widgets/Search/
-webserverextensions/www/fusion/widgets/Search/Search.php
-webserverextensions/www/fusion/widgets/Search/Search.templ
-webserverextensions/www/fusion/widgets/Search/SearchPrompt.php
-webserverextensions/www/fusion/widgets/Search/SearchPrompt.templ
-webserverextensions/www/fusion/widgets/Search/ErrorPage.templ
-webserverextensions/www/fusion/widgets/Search/Viewer.css
-webserverextensions/www/fusion/widgets/EditableScale/
-webserverextensions/www/fusion/widgets/EditableScale/EditableScale.css
-webserverextensions/www/fusion/widgets/CoordinateTracker.js
-webserverextensions/www/fusion/widgets/About.js
-webserverextensions/www/fusion/widgets/ColorPicker.js
-webserverextensions/www/fusion/widgets/Theme/
-webserverextensions/www/fusion/widgets/Theme/classes/
-webserverextensions/www/fusion/widgets/Theme/classes/theme.php
-webserverextensions/www/fusion/widgets/Theme/classes/layerinfo.php
-webserverextensions/www/fusion/widgets/Theme/classes/property.php
-webserverextensions/www/fusion/widgets/Theme/templates/
-webserverextensions/www/fusion/widgets/Theme/templates/arearuletemplate-1.3.0.xml
-webserverextensions/www/fusion/widgets/Theme/templates/arearuletemplate-2.4.0.xml
-webserverextensions/www/fusion/widgets/Theme/templates/arearuletemplate-1.1.0.xml
-webserverextensions/www/fusion/widgets/Theme/templates/arearuletemplate-1.0.0.xml
-webserverextensions/www/fusion/widgets/Theme/templates/arearuletemplate-2.3.0-Enhanced.xml
-webserverextensions/www/fusion/widgets/Theme/templates/arearuletemplate-1.2.0.xml
-webserverextensions/www/fusion/widgets/Theme/templates/arearuletemplate-2.3.0.xml
-webserverextensions/www/fusion/widgets/Theme/templates/arearuletemplate-2.4.0-Enhanced.xml
-webserverextensions/www/fusion/widgets/Theme/themecontroller.php
-webserverextensions/www/fusion/widgets/Theme/thememain.php
-webserverextensions/www/fusion/widgets/Print.js
-webserverextensions/www/fusion/widgets/OverviewMap.js
-webserverextensions/www/fusion/widgets/SelectWithin/
-webserverextensions/www/fusion/widgets/SelectWithin/SelectWithin.php
-webserverextensions/www/fusion/widgets/SelectWithin/SelectWithinPanel.php
-webserverextensions/www/fusion/widgets/SelectWithin/SelectWithinPanel.templ
-webserverextensions/www/fusion/widgets/SelectWithin/Viewer.css
-webserverextensions/www/fusion/widgets/About/
-webserverextensions/www/fusion/widgets/About/About.html
-webserverextensions/www/fusion/widgets/PanOnClick.js
-webserverextensions/www/fusion/widgets/SelectAttribute.js
-webserverextensions/www/fusion/widgets/ViewSize.js
-webserverextensions/www/fusion/widgets/LinkToView.js
-webserverextensions/www/fusion/widgets/Navigator/
-webserverextensions/www/fusion/widgets/Navigator/slider.png
-webserverextensions/www/fusion/widgets/Navigator/sliderscale.png
-webserverextensions/www/fusion/widgets/Navigator/spinner.gif
-webserverextensions/www/fusion/widgets/SaveMap.js
-webserverextensions/www/fusion/widgets/Measure.js
-webserverextensions/www/fusion/widgets/InvokeScript.js
-webserverextensions/www/fusion/widgets/TaskPane.js
-webserverextensions/www/fusion/widgets/ActivityIndicator.js
-webserverextensions/www/fusion/widgets/Help/
-webserverextensions/www/fusion/widgets/Help/Help.html
-webserverextensions/www/fusion/widgets/Navigator.js
-webserverextensions/www/fusion/widgets/TaskPane/
-webserverextensions/www/fusion/widgets/TaskPane/taskpane.png
-webserverextensions/www/fusion/widgets/TaskPane/TaskPane.css
-webserverextensions/www/fusion/widgets/TaskPane/TaskPane.html
-webserverextensions/www/fusion/widgets/ViewOptions.js
-webserverextensions/www/fusion/widgets/CenterSelection.js
-webserverextensions/www/fusion/widgets/FeatureInfo/
-webserverextensions/www/fusion/widgets/FeatureInfo/classes/
-webserverextensions/www/fusion/widgets/FeatureInfo/classes/featureinfo.php
-webserverextensions/www/fusion/widgets/FeatureInfo/classes/property.php
-webserverextensions/www/fusion/widgets/FeatureInfo/classes/feature.php
-webserverextensions/www/fusion/widgets/FeatureInfo/featureinfocontroller.php
-webserverextensions/www/fusion/widgets/FeatureInfo/featureinfomain.php
-webserverextensions/www/fusion/widgets/Help.js
-webserverextensions/www/fusion/widgets/GoogleStreetViewer.js
-webserverextensions/www/fusion/widgets/QuickPlot/
-webserverextensions/www/fusion/widgets/QuickPlot/GeneratePicture.php
-webserverextensions/www/fusion/widgets/QuickPlot/north_arrow.png
-webserverextensions/www/fusion/widgets/QuickPlot/legend-raster.png
-webserverextensions/www/fusion/widgets/QuickPlot/PlotAsPDF.php
-webserverextensions/www/fusion/widgets/QuickPlot/pixel.gif
-webserverextensions/www/fusion/widgets/QuickPlot/legend-DWF.png
-webserverextensions/www/fusion/widgets/QuickPlot/QuickPlotPanel.php
-webserverextensions/www/fusion/widgets/QuickPlot/lc_group.gif
-webserverextensions/www/fusion/widgets/QuickPlot/QuickPlotPanel.js
-webserverextensions/www/fusion/widgets/QuickPlot/legend-theme.png
-webserverextensions/www/fusion/widgets/QuickPlot/rotate.cur
-webserverextensions/www/fusion/widgets/QuickPlot/GenerateLegend.php
-webserverextensions/www/fusion/widgets/QuickPlot/MapCapturer.js
-webserverextensions/www/fusion/widgets/QuickPlot/QuickPlotPanel.templ
-webserverextensions/www/fusion/widgets/Scalebar.js
-webserverextensions/www/fusion/widgets/PanQuery.js
-webserverextensions/www/fusion/widgets/BufferPanel.js
-webserverextensions/www/fusion/widgets/LayerManager.js
-webserverextensions/www/fusion/widgets/AddWMSLayer.js
-webserverextensions/www/fusion/widgets/OverviewMap/
-webserverextensions/www/fusion/widgets/OverviewMap/blank.gif
-webserverextensions/www/fusion/widgets/OverviewMap/OverviewMap.css
-webserverextensions/www/fusion/widgets/Query.js
-webserverextensions/www/fusion/widgets/ScalebarDual/
-webserverextensions/www/fusion/widgets/ScalebarDual/ScalebarDual.css
-webserverextensions/www/fusion/widgets/RefreshMap.js
-webserverextensions/www/fusion/widgets/Query/
-webserverextensions/www/fusion/widgets/Query/classes/
-webserverextensions/www/fusion/widgets/Query/classes/query.php
-webserverextensions/www/fusion/widgets/Query/classes/property.php
-webserverextensions/www/fusion/widgets/Query/classes/feature.php
-webserverextensions/www/fusion/widgets/Query/templates/
-webserverextensions/www/fusion/widgets/Query/templates/filterlayerdefinition.xml
-webserverextensions/www/fusion/widgets/Query/querycontroller.php
-webserverextensions/www/fusion/widgets/Query/querymain.php
-webserverextensions/www/fusion/widgets/CursorPosition/
-webserverextensions/www/fusion/widgets/CursorPosition/CursorPosition.css
-webserverextensions/www/fusion/widgets/CursorPosition.js
-webserverextensions/www/fusion/widgets/LinkToView/
-webserverextensions/www/fusion/widgets/LinkToView/LinkToView.css
-webserverextensions/www/fusion/widgets/Pan.js
-webserverextensions/www/fusion/widgets/SelectionPanel.js
-webserverextensions/www/fusion/widgets/SelectPolygon.js
-webserverextensions/www/fusion/text/
-webserverextensions/www/fusion/text/en.json
-webserverextensions/www/fusion/text/fr.json
-webserverextensions/www/fusion/configHeader.json
+webserverextensions/www/fusion/containerinfo/toolbar.xml
+webserverextensions/www/fusion/docs/
+webserverextensions/www/fusion/docs/ApplicationDefinition-1.0.0.xsd
+webserverextensions/www/fusion/docs/ApplicationDefinition.xml
+webserverextensions/www/fusion/docs/index.html
+webserverextensions/www/fusion/docs/installation.html
+webserverextensions/www/fusion/docs/tutorial/
+webserverextensions/www/fusion/docs/tutorial/Fusion_Tutorial.odt
+webserverextensions/www/fusion/docs/tutorial/fullPage/
+webserverextensions/www/fusion/docs/tutorial/fullPage/ApplicationDefinition.xml
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/ie6.css
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/ie7.css
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/a_pixel.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/button.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/button_combo.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/button_multi.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/button_multi_disclose.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/dialog_chrome.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/dialog_resize.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/emblems.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/flyout_chrome.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/grid.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/loading.gif
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/menu_hover.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/menu_icon_active.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/panel_controls.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/panelbar.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tab_bottom.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tab_close.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tab_left.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tab_right.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tab_top.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tabbar.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tabbar_bottom.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tabbar_left.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tabbar_right.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/table_col.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/table_row.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/toolbar.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/toolbar_separator_h.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/toolbar_separator_v.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tree.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tree_hover.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tree_vert_line.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/jxtheme.css
+webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/jxtheme.uncompressed.css
+webserverextensions/www/fusion/docs/tutorial/fullPage/icons.css
+webserverextensions/www/fusion/docs/tutorial/fullPage/images/
+webserverextensions/www/fusion/docs/tutorial/fullPage/images/a_pixel.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/images/icon_home.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/images/icons.png
+webserverextensions/www/fusion/docs/tutorial/fullPage/index.html
+webserverextensions/www/fusion/docs/tutorial/fullPage/index1.html
+webserverextensions/www/fusion/docs/tutorial/fullPage/index2.html
+webserverextensions/www/fusion/docs/tutorial/fullPage/index3.html
+webserverextensions/www/fusion/docs/tutorial/fullPage/index4.html
+webserverextensions/www/fusion/docs/tutorial/fullPage/index5.html
+webserverextensions/www/fusion/docs/tutorial/simple/
+webserverextensions/www/fusion/docs/tutorial/simple/ApplicationDefinition.xml
+webserverextensions/www/fusion/docs/tutorial/simple/Sheboygan News _ Sheboygan Life.htm
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/6.jpg
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/6_002.jpg
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/6_003.jpg
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/6_004.jpg
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/ads.htm
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/ads_002.htm
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/ads_003.htm
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/ads_data_002/
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/ads_data_002/abg-en-100c-000000.png
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/counter.js
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/expansion_embed.js
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/images/
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/images/skyline.jpg
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/imghover.htm
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/ipkfile.png
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/show_ads.js
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/style.css
+webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/test_domain.js
+webserverextensions/www/fusion/docs/tutorial/simple/index.html
+webserverextensions/www/fusion/docs/tutorial/simple/index.xml
+webserverextensions/www/fusion/docs/tutorial/simple/index2.html
+webserverextensions/www/fusion/docs/tutorial/simple/simple.gif
+webserverextensions/www/fusion/ext/
+webserverextensions/www/fusion/ext/README.TXT
 webserverextensions/www/fusion/layers/
 webserverextensions/www/fusion/layers/Generic/
+webserverextensions/www/fusion/layers/Generic/Generic.js
 webserverextensions/www/fusion/layers/Generic/php/
 webserverextensions/www/fusion/layers/Generic/php/save.php
-webserverextensions/www/fusion/layers/Generic/Generic.js
 webserverextensions/www/fusion/layers/Layers.js
 webserverextensions/www/fusion/layers/MapGuide/
+webserverextensions/www/fusion/layers/MapGuide/MapGuide.js
+webserverextensions/www/fusion/layers/MapGuide/MapGuideViewerApi.js
 webserverextensions/www/fusion/layers/MapGuide/php/
-webserverextensions/www/fusion/layers/MapGuide/php/Print.php
-webserverextensions/www/fusion/layers/MapGuide/php/cp_arr.gif
+webserverextensions/www/fusion/layers/MapGuide/php/Buffer.php
+webserverextensions/www/fusion/layers/MapGuide/php/ClearSelection.php
+webserverextensions/www/fusion/layers/MapGuide/php/ColorPicker.php
+webserverextensions/www/fusion/layers/MapGuide/php/ColorPicker.templ
+webserverextensions/www/fusion/layers/MapGuide/php/Common.php
+webserverextensions/www/fusion/layers/MapGuide/php/Constants.php
+webserverextensions/www/fusion/layers/MapGuide/php/CreateSession.php
 webserverextensions/www/fusion/layers/MapGuide/php/CsMap2Proj.php
-webserverextensions/www/fusion/layers/MapGuide/php/cp_arr_dis.gif
-webserverextensions/www/fusion/layers/MapGuide/php/Common.php
 webserverextensions/www/fusion/layers/MapGuide/php/GetSelectionProperties.php
-webserverextensions/www/fusion/layers/MapGuide/php/SaveSelection.php
+webserverextensions/www/fusion/layers/MapGuide/php/JSON.php
+webserverextensions/www/fusion/layers/MapGuide/php/LayerInfo.php
+webserverextensions/www/fusion/layers/MapGuide/php/Legend.php
+webserverextensions/www/fusion/layers/MapGuide/php/LoadMap.php
 webserverextensions/www/fusion/layers/MapGuide/php/LoadScaleRanges.php
-webserverextensions/www/fusion/layers/MapGuide/php/SetLayers.php
+webserverextensions/www/fusion/layers/MapGuide/php/MapMenu.php
+webserverextensions/www/fusion/layers/MapGuide/php/Measure.php
+webserverextensions/www/fusion/layers/MapGuide/php/Print.php
+webserverextensions/www/fusion/layers/MapGuide/php/Query.php
 webserverextensions/www/fusion/layers/MapGuide/php/SaveMap.php
-webserverextensions/www/fusion/layers/MapGuide/php/JSON.php
-webserverextensions/www/fusion/layers/MapGuide/php/Measure.php
 webserverextensions/www/fusion/layers/MapGuide/php/SaveMapFrame.php
-webserverextensions/www/fusion/layers/MapGuide/php/Query.php
+webserverextensions/www/fusion/layers/MapGuide/php/SaveSelection.php
+webserverextensions/www/fusion/layers/MapGuide/php/Selection.php
+webserverextensions/www/fusion/layers/MapGuide/php/SetLayers.php
+webserverextensions/www/fusion/layers/MapGuide/php/UserManager.php
+webserverextensions/www/fusion/layers/MapGuide/php/Utilities.php
+webserverextensions/www/fusion/layers/MapGuide/php/cp_arr.gif
+webserverextensions/www/fusion/layers/MapGuide/php/cp_arr_dis.gif
 webserverextensions/www/fusion/layers/MapGuide/php/csmap2proj4.js
-webserverextensions/www/fusion/layers/MapGuide/php/ColorPicker.php
-webserverextensions/www/fusion/layers/MapGuide/php/Constants.php
-webserverextensions/www/fusion/layers/MapGuide/php/Legend.php
-webserverextensions/www/fusion/layers/MapGuide/php/Utilities.php
-webserverextensions/www/fusion/layers/MapGuide/php/ClearSelection.php
-webserverextensions/www/fusion/layers/MapGuide/php/UserManager.php
-webserverextensions/www/fusion/layers/MapGuide/php/LayerInfo.php
-webserverextensions/www/fusion/layers/MapGuide/php/Selection.php
-webserverextensions/www/fusion/layers/MapGuide/php/CreateSession.php
-webserverextensions/www/fusion/layers/MapGuide/php/MapMenu.php
-webserverextensions/www/fusion/layers/MapGuide/php/LoadMap.php
-webserverextensions/www/fusion/layers/MapGuide/php/ColorPicker.templ
-webserverextensions/www/fusion/layers/MapGuide/php/Buffer.php
-webserverextensions/www/fusion/layers/MapGuide/MapGuide.js
-webserverextensions/www/fusion/layers/MapGuide/MapGuideViewerApi.js
 webserverextensions/www/fusion/layers/MapServer/
 webserverextensions/www/fusion/layers/MapServer/MapServer.js
 webserverextensions/www/fusion/layers/MapServer/php/
-webserverextensions/www/fusion/layers/MapServer/php/Session.php
+webserverextensions/www/fusion/layers/MapServer/php/Common.php
+webserverextensions/www/fusion/layers/MapServer/php/CreateSession.php
+webserverextensions/www/fusion/layers/MapServer/php/GetAttributes.php
 webserverextensions/www/fusion/layers/MapServer/php/LegendIcon.php
-webserverextensions/www/fusion/layers/MapServer/php/updateSessionMapFile.php
-webserverextensions/www/fusion/layers/MapServer/php/Common.php
-webserverextensions/www/fusion/layers/MapServer/php/RestoreState.php
+webserverextensions/www/fusion/layers/MapServer/php/LoadMap.php
 webserverextensions/www/fusion/layers/MapServer/php/LoadScaleRanges.php
-webserverextensions/www/fusion/layers/MapServer/php/SetLayers.php
-webserverextensions/www/fusion/layers/MapServer/php/SelectionCSV.php
+webserverextensions/www/fusion/layers/MapServer/php/Maptip.php
 webserverextensions/www/fusion/layers/MapServer/php/Measure.php
 webserverextensions/www/fusion/layers/MapServer/php/Query.php
-webserverextensions/www/fusion/layers/MapServer/php/GetAttributes.php
-webserverextensions/www/fusion/layers/MapServer/php/Utilities.php
+webserverextensions/www/fusion/layers/MapServer/php/RestoreState.php
 webserverextensions/www/fusion/layers/MapServer/php/SaveSession.php
-webserverextensions/www/fusion/layers/MapServer/php/Maptip.php
 webserverextensions/www/fusion/layers/MapServer/php/Selection.php
-webserverextensions/www/fusion/layers/MapServer/php/CreateSession.php
-webserverextensions/www/fusion/layers/MapServer/php/LoadMap.php
+webserverextensions/www/fusion/layers/MapServer/php/SelectionCSV.php
+webserverextensions/www/fusion/layers/MapServer/php/Session.php
+webserverextensions/www/fusion/layers/MapServer/php/SetLayers.php
+webserverextensions/www/fusion/layers/MapServer/php/Utilities.php
+webserverextensions/www/fusion/layers/MapServer/php/updateSessionMapFile.php
+webserverextensions/www/fusion/lib/
+webserverextensions/www/fusion/lib/ApplicationDefinition.js
+webserverextensions/www/fusion/lib/Error.js
+webserverextensions/www/fusion/lib/EventMgr.js
+webserverextensions/www/fusion/lib/MGBroker.js
+webserverextensions/www/fusion/lib/Map.js
+webserverextensions/www/fusion/lib/MapMessage.js
+webserverextensions/www/fusion/lib/OLpatch.js
+webserverextensions/www/fusion/lib/OpenLayers/
+webserverextensions/www/fusion/lib/OpenLayers/Lang/
+webserverextensions/www/fusion/lib/OpenLayers/Lang/ar.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/be-tarask.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/bg.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/br.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/ca.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/cs-CZ.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/da-DK.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/de.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/el.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/en-CA.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/en.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/es.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/fi.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/fr.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/fur.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/gl.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/gsw.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/hr.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/hsb.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/hu.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/ia.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/id.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/io.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/is.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/it.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/ja.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/km.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/ksh.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/lt.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/nb.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/nds.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/nl.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/nn.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/oc.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/pl.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/pt-BR.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/pt.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/ro.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/ru.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/sk.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/sv-SE.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/te.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/vi.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/zh-CN.js
+webserverextensions/www/fusion/lib/OpenLayers/Lang/zh-TW.js
+webserverextensions/www/fusion/lib/OpenLayers/OpenLayers.js
+webserverextensions/www/fusion/lib/OpenLayers/ext/
+webserverextensions/www/fusion/lib/OpenLayers/ext/OpenLayers/
+webserverextensions/www/fusion/lib/OpenLayers/ext/OpenLayers/Layer/
+webserverextensions/www/fusion/lib/OpenLayers/ext/OpenLayers/Layer/Google/
+webserverextensions/www/fusion/lib/OpenLayers/ext/OpenLayers/Layer/Google/v3.js
+webserverextensions/www/fusion/lib/OpenLayers/ext/OpenLayers/Map.js
+webserverextensions/www/fusion/lib/OpenLayers/ext/readme.txt
+webserverextensions/www/fusion/lib/OpenLayers/img/
+webserverextensions/www/fusion/lib/OpenLayers/img/blank.gif
+webserverextensions/www/fusion/lib/OpenLayers/img/cloud-popup-relative.png
+webserverextensions/www/fusion/lib/OpenLayers/img/drag-rectangle-off.png
+webserverextensions/www/fusion/lib/OpenLayers/img/drag-rectangle-on.png
+webserverextensions/www/fusion/lib/OpenLayers/img/east-mini.png
+webserverextensions/www/fusion/lib/OpenLayers/img/layer-switcher-maximize.png
+webserverextensions/www/fusion/lib/OpenLayers/img/layer-switcher-minimize.png
+webserverextensions/www/fusion/lib/OpenLayers/img/marker-blue.png
+webserverextensions/www/fusion/lib/OpenLayers/img/marker-gold.png
+webserverextensions/www/fusion/lib/OpenLayers/img/marker-green.png
+webserverextensions/www/fusion/lib/OpenLayers/img/marker.png
+webserverextensions/www/fusion/lib/OpenLayers/img/measuring-stick-off.png
+webserverextensions/www/fusion/lib/OpenLayers/img/measuring-stick-on.png
+webserverextensions/www/fusion/lib/OpenLayers/img/north-mini.png
+webserverextensions/www/fusion/lib/OpenLayers/img/panning-hand-off.png
+webserverextensions/www/fusion/lib/OpenLayers/img/panning-hand-on.png
+webserverextensions/www/fusion/lib/OpenLayers/img/slider.png
+webserverextensions/www/fusion/lib/OpenLayers/img/south-mini.png
+webserverextensions/www/fusion/lib/OpenLayers/img/west-mini.png
+webserverextensions/www/fusion/lib/OpenLayers/img/zoom-minus-mini.png
+webserverextensions/www/fusion/lib/OpenLayers/img/zoom-plus-mini.png
+webserverextensions/www/fusion/lib/OpenLayers/img/zoom-world-mini.png
+webserverextensions/www/fusion/lib/OpenLayers/img/zoombar.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/google.css
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/google.tidy.css
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/ie6-style.css
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/ie6-style.tidy.css
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/add_point_off.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/add_point_on.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/blank.gif
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/close.gif
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/drag-rectangle-off.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/drag-rectangle-on.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/draw_line_off.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/draw_line_on.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/draw_point_off.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/draw_point_on.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/draw_polygon_off.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/draw_polygon_on.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/editing_tool_bar.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/move_feature_off.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/move_feature_on.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/navigation_history.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/overview_replacement.gif
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/pan-panel-NOALPHA.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/pan-panel.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/pan_off.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/pan_on.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/panning-hand-off.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/panning-hand-on.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/remove_point_off.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/remove_point_on.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/ruler.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/save_features_off.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/save_features_on.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/view_next_off.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/view_next_on.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/view_previous_off.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/view_previous_on.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/zoom-panel-NOALPHA.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/zoom-panel.png
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/style.css
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/style.mobile.css
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/style.mobile.tidy.css
+webserverextensions/www/fusion/lib/OpenLayers/theme/default/style.tidy.css
+webserverextensions/www/fusion/lib/Proj4js/
+webserverextensions/www/fusion/lib/Proj4js/proj4js-combined.js
+webserverextensions/www/fusion/lib/RectTool.js
+webserverextensions/www/fusion/lib/Search.js
+webserverextensions/www/fusion/lib/SingleFile.js
+webserverextensions/www/fusion/lib/SymbolLayer.js
+webserverextensions/www/fusion/lib/TraceKit/
+webserverextensions/www/fusion/lib/TraceKit/TraceKit.js
+webserverextensions/www/fusion/lib/Widget.js
+webserverextensions/www/fusion/lib/a_pixel.png
+webserverextensions/www/fusion/lib/excanvas/
+webserverextensions/www/fusion/lib/excanvas/AUTHORS
+webserverextensions/www/fusion/lib/excanvas/COPYING
+webserverextensions/www/fusion/lib/excanvas/README
+webserverextensions/www/fusion/lib/excanvas/excanvas-compressed.js
+webserverextensions/www/fusion/lib/excanvas/excanvas.js
+webserverextensions/www/fusion/lib/fusion.js
+webserverextensions/www/fusion/lib/fusionSF-compressed.js
+webserverextensions/www/fusion/lib/fusionSF-compressed.js.map
+webserverextensions/www/fusion/lib/fusionSF.js
+webserverextensions/www/fusion/lib/jxLib/
+webserverextensions/www/fusion/lib/jxLib/jxlib.uncompressed.js
+webserverextensions/www/fusion/lib/jxLib/themes/
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/ie6.css
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/ie7.css
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/a_pixel.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/button.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/button_combo.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/button_multi.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/button_multi_disclose.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/dialog_chrome.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/dialog_resize.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/emblems.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/flyout_chrome.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/grid.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/icons.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/listitem.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/loading.gif
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/menuitem.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/notice.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/notice_error.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/notice_success.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/notice_warning.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/panel_controls.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/panelbar.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/progressbar.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/spinner_16.gif
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/spinner_24.gif
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tab_bottom.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tab_close.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tab_left.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tab_right.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tab_top.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tabbar.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tabbar_bottom.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tabbar_left.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tabbar_right.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/table_col.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/table_row.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/toolbar.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/toolbar_separator_h.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/toolbar_separator_v.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tree.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tree_hover.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tree_vert_line.png
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/jxtheme.css
+webserverextensions/www/fusion/lib/jxLib/themes/crispin/jxtheme.uncompressed.css
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/ie6.css
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/ie7.css
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/a_pixel.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/button.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/button_combo.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/button_multi.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/button_multi_disclose.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/dialog_chrome.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/dialog_resize.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/emblems.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/flyout_chrome.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/grid.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/icons.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/listitem.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/loading.gif
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/menuitem.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/notice.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/notice_error.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/notice_success.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/notice_warning.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/panel_controls.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/panelbar.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/progressbar.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/spinner_16.gif
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/spinner_24.gif
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tab_bottom.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tab_close.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tab_left.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tab_right.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tab_top.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tabbar.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tabbar_bottom.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tabbar_left.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tabbar_right.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/table_col.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/table_row.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/toolbar.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/toolbar_separator_h.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/toolbar_separator_v.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tree.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tree_hover.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tree_vert_line.png
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/jxtheme.css
+webserverextensions/www/fusion/lib/jxLib/themes/delicious/jxtheme.uncompressed.css
+webserverextensions/www/fusion/lib/tcpdf/
+webserverextensions/www/fusion/lib/tcpdf/2dbarcodes.php
+webserverextensions/www/fusion/lib/tcpdf/LICENSE.TXT
+webserverextensions/www/fusion/lib/tcpdf/barcodes.php
+webserverextensions/www/fusion/lib/tcpdf/cache/
+webserverextensions/www/fusion/lib/tcpdf/cache/chapter_demo_1.txt
+webserverextensions/www/fusion/lib/tcpdf/cache/chapter_demo_2.txt
+webserverextensions/www/fusion/lib/tcpdf/cache/table_data_demo.txt
+webserverextensions/www/fusion/lib/tcpdf/cache/utf8test.txt
+webserverextensions/www/fusion/lib/tcpdf/config/
+webserverextensions/www/fusion/lib/tcpdf/config/lang/
+webserverextensions/www/fusion/lib/tcpdf/config/lang/afr.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/ara.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/aze.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/bel.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/bra.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/cat.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/ces.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/chi.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/cym.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/dan.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/eng.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/est.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/eus.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/far.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/fra.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/ger.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/gle.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/glg.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/hat.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/heb.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/hrv.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/hun.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/hye.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/ind.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/ita.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/jpn.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/kat.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/kor.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/mkd.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/mlt.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/msa.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/nld.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/nob.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/pol.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/por.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/ron.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/rus.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/slv.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/spa.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/sqi.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/srp.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/swa.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/swe.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/urd.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/yid.php
+webserverextensions/www/fusion/lib/tcpdf/config/lang/zho.php
+webserverextensions/www/fusion/lib/tcpdf/config/tcpdf_config.php
+webserverextensions/www/fusion/lib/tcpdf/config/tcpdf_config_alt.php
+webserverextensions/www/fusion/lib/tcpdf/datamatrix.php
+webserverextensions/www/fusion/lib/tcpdf/encodings_maps.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/
+webserverextensions/www/fusion/lib/tcpdf/fonts/aealarabiya.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/aealarabiya.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/aealarabiya.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/aefurat.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/aefurat.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/aefurat.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/cid0cs.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/cid0ct.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/cid0jp.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/cid0kr.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/courier.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/courierb.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/courierbi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/courieri.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/AUTHORS
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/BUGS
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/LICENSE
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/NEWS
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/README
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/langcover.txt
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/status.txt
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/unicover.txt
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusans.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusans.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusans.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansb.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansb.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansb.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansbi.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansbi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansbi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensed.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensed.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensed.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedb.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedb.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedb.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedbi.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedbi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedbi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedi.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansextralight.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansextralight.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansextralight.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansi.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmono.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmono.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmono.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonob.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonob.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonob.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonobi.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonobi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonobi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonoi.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonoi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonoi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserif.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserif.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserif.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifb.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifb.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifb.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifbi.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifbi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifbi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensed.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensed.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensed.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedb.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedb.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedb.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedbi.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedbi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedbi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedi.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifi.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freefont-20100919/
+webserverextensions/www/fusion/lib/tcpdf/fonts/freefont-20100919/AUTHORS
+webserverextensions/www/fusion/lib/tcpdf/fonts/freefont-20100919/COPYING
+webserverextensions/www/fusion/lib/tcpdf/fonts/freefont-20100919/CREDITS
+webserverextensions/www/fusion/lib/tcpdf/fonts/freefont-20100919/ChangeLog
+webserverextensions/www/fusion/lib/tcpdf/fonts/freefont-20100919/INSTALL
+webserverextensions/www/fusion/lib/tcpdf/fonts/freefont-20100919/README
+webserverextensions/www/fusion/lib/tcpdf/fonts/freemono.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freemono.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/freemono.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freemonob.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freemonob.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/freemonob.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freemonobi.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freemonobi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/freemonobi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freemonoi.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freemonoi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/freemonoi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freesans.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freesans.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/freesans.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freesansb.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freesansb.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/freesansb.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freesansbi.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freesansbi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/freesansbi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freesansi.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freesansi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/freesansi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freeserif.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freeserif.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/freeserif.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifb.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifb.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifb.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifbi.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifbi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifbi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifi.ctg.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/helvetica.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/helveticab.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/helveticabi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/helveticai.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/hysmyeongjostdmedium.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/kozgopromedium.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/kozminproregular.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/msungstdlight.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfacourier.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfacourier.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfacourierb.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfacourierb.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfacourierbi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfacourierbi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfacourieri.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfacourieri.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfahelvetica.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfahelvetica.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfahelveticab.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfahelveticab.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfahelveticabi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfahelveticabi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfahelveticai.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfahelveticai.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfasymbol.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfasymbol.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfatimes.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfatimes.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfatimesb.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfatimesb.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfatimesbi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfatimesbi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfatimesi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfatimesi.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfazapfdingbats.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/pdfazapfdingbats.z
+webserverextensions/www/fusion/lib/tcpdf/fonts/stsongstdlight.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/symbol.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/times.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/timesb.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/timesbi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/timesi.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/uni2cid_ac15.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/uni2cid_ag15.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/uni2cid_aj16.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/uni2cid_ak12.php
+webserverextensions/www/fusion/lib/tcpdf/fonts/zapfdingbats.php
+webserverextensions/www/fusion/lib/tcpdf/htmlcolors.php
+webserverextensions/www/fusion/lib/tcpdf/images/
+webserverextensions/www/fusion/lib/tcpdf/images/_blank.png
+webserverextensions/www/fusion/lib/tcpdf/images/alpha.png
+webserverextensions/www/fusion/lib/tcpdf/images/bug.eps
+webserverextensions/www/fusion/lib/tcpdf/images/image_demo.jpg
+webserverextensions/www/fusion/lib/tcpdf/images/image_with_alpha.png
+webserverextensions/www/fusion/lib/tcpdf/images/img.png
+webserverextensions/www/fusion/lib/tcpdf/images/logo_example.gif
+webserverextensions/www/fusion/lib/tcpdf/images/logo_example.jpg
+webserverextensions/www/fusion/lib/tcpdf/images/logo_example.png
+webserverextensions/www/fusion/lib/tcpdf/images/pelican.ai
+webserverextensions/www/fusion/lib/tcpdf/images/tcpdf_cell.png
+webserverextensions/www/fusion/lib/tcpdf/images/tcpdf_logo.jpg
+webserverextensions/www/fusion/lib/tcpdf/images/tcpdf_signature.png
+webserverextensions/www/fusion/lib/tcpdf/images/testsvg.svg
+webserverextensions/www/fusion/lib/tcpdf/images/tiger.ai
+webserverextensions/www/fusion/lib/tcpdf/images/tux.svg
+webserverextensions/www/fusion/lib/tcpdf/pdf417.php
+webserverextensions/www/fusion/lib/tcpdf/qrcode.php
+webserverextensions/www/fusion/lib/tcpdf/sRGB.icc
+webserverextensions/www/fusion/lib/tcpdf/spotcolors.php
+webserverextensions/www/fusion/lib/tcpdf/tcpdf.crt
+webserverextensions/www/fusion/lib/tcpdf/tcpdf.fdf
+webserverextensions/www/fusion/lib/tcpdf/tcpdf.p12
+webserverextensions/www/fusion/lib/tcpdf/tcpdf.php
+webserverextensions/www/fusion/lib/tcpdf/tcpdf_filters.php
+webserverextensions/www/fusion/lib/tcpdf/tcpdf_parser.php
+webserverextensions/www/fusion/lib/tcpdf/unicode_data.php
 webserverextensions/www/fusion/templates/
 webserverextensions/www/fusion/templates/mapguide/
-webserverextensions/www/fusion/templates/mapguide/slate.xml
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/ApplicationDefinition.xml
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/turquoiseyellow.css
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/turquoiseyellow.uncompressed.css
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/preview.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/icons.css
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/ie6.css
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/index.templ
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/ie7.css
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/pbmg.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/palleteTile.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_glow_t.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tabSetBackground.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/taskTabSD_Left.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_glow_br.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/iconCollapseClosed.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tabbar_bottom.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/sidebarCollapseBottom.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_glow_b.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolListBackground.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/statusBarBackground.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbar_separator_h2.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/iconCollapse.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/iconFileMenuRightArrow.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tab_right.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/mapBackground.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icon_forward.gif
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/jxPanelBarLeft.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tabbar_left.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbarRight.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/moduleBackground.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/backgroundTile.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/fileMenuBackgroundOver.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/zoomout.cur
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/ToolbarBackground.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/iconNavigator.gif
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbarLeft.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/zoomin.cur
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tabbar.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/overviewMap.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/maximize.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/fileMenuBackground.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/seperator.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/panel_controls.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbarSubBackground.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/filemenuHover.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/grab.cur
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/fileMenuBDLeft.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icon_close.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_resize.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/select-radius.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/query.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/edit-cut.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/invoke-script.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/edit-duplicate.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/zoom-in.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/print.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/initial-center.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/edit-paste.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/view-back.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/select-features.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/invoke-url.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/select-zoom.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/feature-info.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/search.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/zoom-out-fixed.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/legend-raster.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/out-of-range.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/view-refresh.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/preview.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/pan.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/geolocation.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/zoom-dynamic.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/zoom-full.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/select.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/pan-east.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/warning.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/file-print.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/maptip.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/legend-DWF.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/info.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/pan-west.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/options.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/pan-south.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/legend-layer.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/overview-map.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/error.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/coordinate-tracker.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/edit-copy.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/legend-theme.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/redline.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/edit-xml.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/legend-map.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/select-polygon.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/measure.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/help.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/select-centre.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/buffer.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/file-save.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/pan-north.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/select-clear.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/zoom-in-fixed.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/view-forward.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/iconNavigator.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/about.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/maptip.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tab_close.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/overviewMapTmp.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_chrome.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tree_vert_line.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/panelBackground.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/sidebarCollapseTop.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tab_top.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbarSubLeft.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/statusbar.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/button_combo.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/jxPanelBackround.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tab_bottom.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/emblems_alt.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/flyout_chrome.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolListBDLeft.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/sidebarCloseButton.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icon_back.gif
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_glow_tr.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/seperator_v.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/button_multi_disclose.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/loading.gif
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/panelbar.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_glow_tl.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/palleteIconMaximize.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbarSubRight.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/coordinate-tracker.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/button_multi.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_controls.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/fileMenuButton.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbar_separator_v.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/iconCollapseOpen.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_glow_r.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/moduleBorder.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/button.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/sidebarCollapseButton.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/overview_map.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/iconFileMenuDownArrow.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_glow_l.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/fileMenuBDRight.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbarButton.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/table_col.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/grid.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/fileMenuRight.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbar.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/menu_hover.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/overviewMapButtonClose.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/menu_icon_active.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbar_separator_h.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/moduleTaskToolbarBackground.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/verticalMenuBar.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/taskTabSD_Right.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/fileMenuLeft.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tabbar_right.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbarHover.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icon_quickhelp.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/sidebarOpenButton.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/table_row.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/jxPanelBarBackground.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/sidebarCollapseBackground.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/grabbing.cur
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tree_hover.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbarVerticalBackground.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/jxPanelBottom.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/emblems.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tree.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/logo.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbar_separator_v2.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/a_pixel.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_glow_bl.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/overviewMapButtonClose2.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/adsk_logo.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/background.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tab_left.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/moduleTitleBackground.png
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/index.html
-webserverextensions/www/fusion/templates/mapguide/maroon.xml
-webserverextensions/www/fusion/templates/mapguide/turquoiseyellow.xml
-webserverextensions/www/fusion/templates/mapguide/limegold.xml
-webserverextensions/www/fusion/templates/mapguide/standard/
-webserverextensions/www/fusion/templates/mapguide/standard/ApplicationDefinition.xml
-webserverextensions/www/fusion/templates/mapguide/standard/icons.css
-webserverextensions/www/fusion/templates/mapguide/standard/images/
-webserverextensions/www/fusion/templates/mapguide/standard/images/icon_forward.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/grab.cur
-webserverextensions/www/fusion/templates/mapguide/standard/images/icon_invokeurl_disabled.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icon_tasks.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icon_back.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-radius.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/edit-cut.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/edit-duplicate.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/zoom-in.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/edit-paste.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/navigator.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/west.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/view-back.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-features.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-zoom.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/search.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/zoom-out-fixed.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/legend-raster.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/out-of-range.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/view-refresh.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/move-up.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/pan.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/zoom-full.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-query.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/pan-east.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/warning.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/file-print.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/zoom-out.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/pan-south.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/legend-layer.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-attribute.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/edit-undo.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/edit-copy.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/legend-theme.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/move-down.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-rectangle.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/legend-map.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/file-open.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-polygon.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/measure.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/help.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-centre.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/buffer.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/file-save.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/pan-north.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-clear.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/zoom-in-fixed.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/view-forward.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons/edit-redo.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/maptip.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icon_home.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/icons.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/grabbing.cur
-webserverextensions/www/fusion/templates/mapguide/standard/images/icon_invokeurl.png
-webserverextensions/www/fusion/templates/mapguide/standard/images/a_pixel.png
-webserverextensions/www/fusion/templates/mapguide/standard/index.html
 webserverextensions/www/fusion/templates/mapguide/aqua.xml
-webserverextensions/www/fusion/templates/mapguide/slate/
-webserverextensions/www/fusion/templates/mapguide/slate/ApplicationDefinition.xml
-webserverextensions/www/fusion/templates/mapguide/slate/slate.css
-webserverextensions/www/fusion/templates/mapguide/slate/preview.png
-webserverextensions/www/fusion/templates/mapguide/slate/icons.css
-webserverextensions/www/fusion/templates/mapguide/slate/ie6.css
-webserverextensions/www/fusion/templates/mapguide/slate/index.templ
-webserverextensions/www/fusion/templates/mapguide/slate/ie7.css
-webserverextensions/www/fusion/templates/mapguide/slate/images/
-webserverextensions/www/fusion/templates/mapguide/slate/images/pbmg.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/tabbar_bottom.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/sidebarCollapseBottom.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/statusBarBackground.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/tab_right.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/mapBackground.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icon_forward.gif
-webserverextensions/www/fusion/templates/mapguide/slate/images/tabbar_left.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/toolbarRight.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/backgroundTile.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/fileMenuHover.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/zoomout.cur
-webserverextensions/www/fusion/templates/mapguide/slate/images/iconNavigator.gif
-webserverextensions/www/fusion/templates/mapguide/slate/images/toolbarLeft.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/zoomin.cur
-webserverextensions/www/fusion/templates/mapguide/slate/images/tabbar.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/fileMenuBackground.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/seperator.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/panel_controls.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/toolbarSubBackground.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/panelBarLeft.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/grab.cur
-webserverextensions/www/fusion/templates/mapguide/slate/images/dialog_resize.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/nav_base_60trans.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/select-radius.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/query.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/edit-cut.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/invoke-script.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/edit-duplicate.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/zoom-in.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/print.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/initial-center.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/edit-paste.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/view-back.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/theme.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/select-features.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/invoke-url.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/select-zoom.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/feature-info.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/search.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/zoom-out-fixed.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/legend-raster.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/out-of-range.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/view-refresh.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/preview.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/pan.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/geolocation.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/zoom-dynamic.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/zoom-full.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/select.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/pan-east.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/warning.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/file-print.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/maptip.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/legend-DWF.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/info.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/pan-west.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/options.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/pan-south.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/legend-layer.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/overview-map.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/error.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/coordinate-tracker.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/edit-copy.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/legend-theme.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/redline.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/edit-xml.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/legend-map.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/select-polygon.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/measure.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/help.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/select-centre.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/buffer.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/file-save.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/pan-north.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/select-clear.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/zoom-in-fixed.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/view-forward.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/iconNavigator.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons/about.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/maptip.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/tab_close.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/panelBottom.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/dialog_chrome.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/tree_vert_line.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/panelBackground.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/sidebarCollapseTop.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/tab_top.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/toolbarSubLeft.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/button_combo.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/tab_bottom.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/emblems_alt.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/flyout_chrome.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/sidebarCloseButton.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icon_back.gif
-webserverextensions/www/fusion/templates/mapguide/slate/images/seperator_v.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/button_multi_disclose.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/loading.gif
-webserverextensions/www/fusion/templates/mapguide/slate/images/panelbar.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/toolbarSubRight.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/coordinate-tracker.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/button_multi.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/dialog_controls.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/fileMenuButton.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/toolbar_separator_v.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/button.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/icons.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/toolbarButton.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/table_col.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/grid.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/fileMenuRight.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/toolbar.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/menu_hover.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/menu_icon_active.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/toolbar_separator_h.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/nav_slider_60trans.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/fileMenuLeft.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/tabbar_right.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/sidebarOpenButton.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/table_row.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/sidebarCollapseBackground.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/grabbing.cur
-webserverextensions/www/fusion/templates/mapguide/slate/images/tree_hover.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/emblems.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/tree.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/logo.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/a_pixel.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/toolbarBackground.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/toolbarSubButton.png
-webserverextensions/www/fusion/templates/mapguide/slate/images/tab_left.png
-webserverextensions/www/fusion/templates/mapguide/slate/index.html
-webserverextensions/www/fusion/templates/mapguide/slate/slate.uncompressed.css
 webserverextensions/www/fusion/templates/mapguide/aqua/
+webserverextensions/www/fusion/templates/mapguide/aqua/ApplicationDefinition.xml
 webserverextensions/www/fusion/templates/mapguide/aqua/aqua.css
-webserverextensions/www/fusion/templates/mapguide/aqua/ApplicationDefinition.xml
 webserverextensions/www/fusion/templates/mapguide/aqua/aqua.uncompressed.css
-webserverextensions/www/fusion/templates/mapguide/aqua/preview.png
 webserverextensions/www/fusion/templates/mapguide/aqua/icons.css
 webserverextensions/www/fusion/templates/mapguide/aqua/ie6.css
-webserverextensions/www/fusion/templates/mapguide/aqua/index.templ
 webserverextensions/www/fusion/templates/mapguide/aqua/ie7.css
 webserverextensions/www/fusion/templates/mapguide/aqua/images/
-webserverextensions/www/fusion/templates/mapguide/aqua/images/pbmg.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/palleteTile.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_glow_t.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/jxPanelBottom.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_glow_br.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/iconCollapseClosed.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/tabbar_bottom.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/seperator.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/sidebarCollapseBottom.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/20070914_Mapguide_activity_indicator.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/FileMenuBackground.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/FileMenuLeft.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/FileMenuRight.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/Logo.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/ToolbarBackground.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/ToolbarLeft.gif
 webserverextensions/www/fusion/templates/mapguide/aqua/images/ToolbarRight.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/ToolbarSubBackground.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/ToolbarSubLeft.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/ToolbarSubRight.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/ToolbarVerticalBackground.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/a_pixel.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/backgroundTile.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/backgroundTile.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/button.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/button_combo.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/button_multi.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/button_multi_disclose.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/coordinate-tracker.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_chrome.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_controls.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_glow_b.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/backgroundTile.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/statusBarBackground.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/mapBackground.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_glow_bl.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_glow_br.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_glow_l.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_glow_r.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_glow_t.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_glow_tl.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_glow_tr.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_resize.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/emblems.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/emblems_alt.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/fileMenuBackground.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/fileMenuLeft.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/fileMenuRight.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/filemenuButton.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/filemenuHover.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/filemenuHover.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/flyout_chrome.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/grab.cur
+webserverextensions/www/fusion/templates/mapguide/aqua/images/grabbing.cur
+webserverextensions/www/fusion/templates/mapguide/aqua/images/grid.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/iconCollapse.gif
 webserverextensions/www/fusion/templates/mapguide/aqua/images/iconCollapse.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/iconCollapseClosed.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/iconCollapseClosed.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/iconCollapseOpen.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/iconCollapseOpen.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/iconFileMenuDownArrow.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/iconFileMenuDownArrow.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/iconFileMenuRightArrow.gif
 webserverextensions/www/fusion/templates/mapguide/aqua/images/iconFileMenuRightArrow.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/tab_right.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/ToolbarSubBackground.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/mapBackground.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/iconNavigator.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/iconNavigator.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_back.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_back.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_close.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_forward.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_forward.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_home.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/jxPanelBarLeft.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/overviewMapButtonClose.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/tabbar_left.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarRight.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/backgroundTile.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/zoomout.cur
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_forward.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/iconNavigator.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarLeft.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/zoomin.cur
-webserverextensions/www/fusion/templates/mapguide/aqua/images/tabbar.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/fileMenuBackground.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/seperator.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/jxPanelBarBackground.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarVerticalButton.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/20070914_Mapguide_activity_indicator.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/FileMenuRight.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/panel_controls.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarSubBackground.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/filemenuHover.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/filemenuHover.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/grab.cur
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_home.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_invokeurl.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_invokeurl_disabled.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_quickhelp.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_tasks.gif
 webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_tasks.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_close.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_resize.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/nav_base_60trans.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_back.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/statusBarBackground.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarHover.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/select-radius.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/query.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/about.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/buffer.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/coordinate-tracker.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/edit-copy.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/edit-cut.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/invoke-script.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/edit-duplicate.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/zoom-in.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/print.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/edit-paste.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/edit-xml.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/error.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/feature-info.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/file-print.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/file-save.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/geolocation.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/help.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/iconNavigator.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/info.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/initial-center.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/edit-paste.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/view-back.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/select-features.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/invoke-script.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/invoke-url.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/select-zoom.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/feature-info.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/search.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/zoom-out-fixed.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/legend-DWF.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/legend-layer.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/legend-map.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/legend-raster.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/legend-theme.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/maptip.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/measure.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/options.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/out-of-range.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/view-refresh.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/preview.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/pan.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/geolocation.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/zoom-dynamic.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/zoom-full.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/select.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/overview-map.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/pan-east.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/warning.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/file-print.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/maptip.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/legend-DWF.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/info.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/pan-north.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/pan-south.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/pan-west.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/options.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/pan-south.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/legend-layer.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/overview-map.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/error.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/coordinate-tracker.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/edit-copy.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/legend-theme.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/pan.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/preview.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/print.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/query.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/redline.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/edit-xml.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/legend-map.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/select-polygon.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/measure.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/help.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/search.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/select-centre.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/buffer.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/file-save.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/pan-north.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/select-clear.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/select-features.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/select-polygon.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/select-radius.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/select-zoom.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/select.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/view-back.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/view-forward.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/view-refresh.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/warning.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/zoom-dynamic.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/zoom-full.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/zoom-in-fixed.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/view-forward.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/iconNavigator.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/about.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/zoom-in.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/icons/zoom-out-fixed.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/jxPanelBackround.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/jxPanelBackround.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/jxPanelBarBackground.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/jxPanelBarBackground.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/jxPanelBarLeft.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/jxPanelBarLeft.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/jxPanelBottom.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/jxPanelBottom.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/loading.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/logo.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/mapBackground.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/mapBackground.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/maptip.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/tab_close.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarContainer.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/ToolbarLeft.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_chrome.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/tree_vert_line.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/iconCollapse.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/menu_hover.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/menu_icon_active.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/nav_base_60trans.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/nav_slider_60trans.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/overviewMapButtonClose.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/overviewMapButtonClose.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/overviewMapButtonClose2.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/overview_map.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/palleteIconMaximize.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/palleteIconMaximize.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/palleteTile.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/panelBackground.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/sidebarCollapseTop.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/tab_top.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarSubLeft.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/button_combo.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/jxPanelBackround.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/tab_bottom.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/emblems_alt.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/sidebarCollapseButton.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/flyout_chrome.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_tasks.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/ToolbarSubLeft.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_back.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_glow_tr.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/seperator_v.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/FileMenuBackground.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/button_multi_disclose.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/loading.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/panel_controls.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/panelbar.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_glow_tl.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/palleteIconMaximize.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarSubRight.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/coordinate-tracker.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/button_multi.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_controls.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/jxPanelBarLeft.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbar_separator_v.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarVerticalContainer.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/iconCollapseOpen.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_home.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_glow_r.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/Logo.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/button.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/ToolbarVerticalBackground.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/sidebarCollapseButton.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/overview_map.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/iconFileMenuDownArrow.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_glow_l.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icons.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarButton.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/pbmg.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/pbmg.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/seperator.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/seperator.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/seperator_v.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/table_col.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/iconCollapseClosed.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/seperator_v.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/sidebarCollapseBackground.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/sidebarCollapseBackground.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/sidebarCollapseBottom.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/grid.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/fileMenuRight.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbar.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/menu_hover.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/ToolbarBackground.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/sidebarCollapseBackground.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/jxPanelBackround.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/overviewMapButtonClose.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/menu_icon_active.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbar_separator_h.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/nav_slider_60trans.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/sidebarCollapseBottom.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/sidebarCollapseButton.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/sidebarCollapseButton.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/sidebarCollapseTop.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/fileMenuLeft.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/iconFileMenuRightArrow.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/sidebarCollapseTop.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/statusBarBackground.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/statusBarBackground.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/tab_bottom.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/tab_close.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/tab_left.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/tab_right.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/tab_top.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/tabbar.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/tabbar_bottom.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/tabbar_left.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/tabbar_right.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/table_col.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/table_row.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbar.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarBackground.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarButton.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarContainer.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarHover.gif
 webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarHover.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_invokeurl.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_quickhelp.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/FileMenuLeft.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/palleteIconMaximize.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/table_row.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/jxPanelBarBackground.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/sidebarCollapseBackground.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/grabbing.cur
-webserverextensions/www/fusion/templates/mapguide/aqua/images/tree_hover.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarLeft.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarRight.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarSubBackground.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarSubLeft.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarSubRight.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarVerticalBackground.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/pbmg.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/jxPanelBottom.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/emblems.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/ToolbarSubRight.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/filemenuButton.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/iconNavigator.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/icon_invokeurl_disabled.gif
+webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarVerticalButton.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarVerticalContainer.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbar_separator_h.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbar_separator_v.png
 webserverextensions/www/fusion/templates/mapguide/aqua/images/tree.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/logo.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/a_pixel.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/dialog_glow_bl.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/iconFileMenuDownArrow.gif
-webserverextensions/www/fusion/templates/mapguide/aqua/images/toolbarBackground.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/overviewMapButtonClose2.png
-webserverextensions/www/fusion/templates/mapguide/aqua/images/tab_left.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/tree_hover.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/tree_vert_line.png
+webserverextensions/www/fusion/templates/mapguide/aqua/images/zoomin.cur
+webserverextensions/www/fusion/templates/mapguide/aqua/images/zoomout.cur
 webserverextensions/www/fusion/templates/mapguide/aqua/index.html
+webserverextensions/www/fusion/templates/mapguide/aqua/index.templ
+webserverextensions/www/fusion/templates/mapguide/aqua/preview.png
+webserverextensions/www/fusion/templates/mapguide/images/
+webserverextensions/www/fusion/templates/mapguide/images/a_pixel.png
+webserverextensions/www/fusion/templates/mapguide/images/backgroundTile.png
+webserverextensions/www/fusion/templates/mapguide/images/button.png
+webserverextensions/www/fusion/templates/mapguide/images/button_combo.png
+webserverextensions/www/fusion/templates/mapguide/images/button_multi.png
+webserverextensions/www/fusion/templates/mapguide/images/button_multi_disclose.png
+webserverextensions/www/fusion/templates/mapguide/images/coordinate-tracker.png
+webserverextensions/www/fusion/templates/mapguide/images/dialog_chrome.png
+webserverextensions/www/fusion/templates/mapguide/images/dialog_controls.png
+webserverextensions/www/fusion/templates/mapguide/images/dialog_resize.png
+webserverextensions/www/fusion/templates/mapguide/images/emblems.png
+webserverextensions/www/fusion/templates/mapguide/images/emblems_alt.png
+webserverextensions/www/fusion/templates/mapguide/images/fileMenuBackground.png
+webserverextensions/www/fusion/templates/mapguide/images/fileMenuButton.png
+webserverextensions/www/fusion/templates/mapguide/images/fileMenuHover.png
+webserverextensions/www/fusion/templates/mapguide/images/fileMenuLeft.png
+webserverextensions/www/fusion/templates/mapguide/images/fileMenuRight.png
+webserverextensions/www/fusion/templates/mapguide/images/flyout_chrome.png
+webserverextensions/www/fusion/templates/mapguide/images/grab.cur
+webserverextensions/www/fusion/templates/mapguide/images/grabbing.cur
+webserverextensions/www/fusion/templates/mapguide/images/grid.png
+webserverextensions/www/fusion/templates/mapguide/images/iconNavigator.gif
+webserverextensions/www/fusion/templates/mapguide/images/icon_back.gif
+webserverextensions/www/fusion/templates/mapguide/images/icon_forward.gif
+webserverextensions/www/fusion/templates/mapguide/images/icons.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/
+webserverextensions/www/fusion/templates/mapguide/images/icons/about.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/buffer.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/coordinate-tracker.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/edit-copy.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/edit-cut.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/edit-duplicate.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/edit-paste.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/edit-xml.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/error.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/feature-info.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/file-print.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/file-save.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/geolocation.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/help.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/iconNavigator.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/info.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/initial-center.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/invoke-script.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/invoke-url.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/legend-DWF.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/legend-layer.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/legend-map.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/legend-raster.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/legend-theme.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/maptip.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/measure.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/options.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/out-of-range.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/overview-map.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/pan-east.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/pan-north.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/pan-south.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/pan-west.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/pan.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/preview.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/print.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/query.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/redline.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/search.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/select-centre.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/select-clear.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/select-features.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/select-polygon.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/select-radius.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/select-zoom.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/select.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/theme.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/view-back.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/view-forward.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/view-refresh.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/warning.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/zoom-dynamic.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/zoom-full.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/zoom-in-fixed.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/zoom-in.png
+webserverextensions/www/fusion/templates/mapguide/images/icons/zoom-out-fixed.png
+webserverextensions/www/fusion/templates/mapguide/images/loading.gif
+webserverextensions/www/fusion/templates/mapguide/images/logo.png
+webserverextensions/www/fusion/templates/mapguide/images/mapBackground.png
+webserverextensions/www/fusion/templates/mapguide/images/maptip.png
+webserverextensions/www/fusion/templates/mapguide/images/menu_hover.png
+webserverextensions/www/fusion/templates/mapguide/images/menu_icon_active.png
+webserverextensions/www/fusion/templates/mapguide/images/nav_base_60trans.png
+webserverextensions/www/fusion/templates/mapguide/images/nav_slider_60trans.png
+webserverextensions/www/fusion/templates/mapguide/images/panelBackground.png
+webserverextensions/www/fusion/templates/mapguide/images/panelBarLeft.png
+webserverextensions/www/fusion/templates/mapguide/images/panelBottom.png
+webserverextensions/www/fusion/templates/mapguide/images/panel_controls.png
+webserverextensions/www/fusion/templates/mapguide/images/panelbar.png
+webserverextensions/www/fusion/templates/mapguide/images/pbmg.png
+webserverextensions/www/fusion/templates/mapguide/images/seperator.png
+webserverextensions/www/fusion/templates/mapguide/images/seperator_v.png
+webserverextensions/www/fusion/templates/mapguide/images/sidebarCloseButton.png
+webserverextensions/www/fusion/templates/mapguide/images/sidebarCollapseBackground.png
+webserverextensions/www/fusion/templates/mapguide/images/sidebarCollapseBottom.png
+webserverextensions/www/fusion/templates/mapguide/images/sidebarCollapseTop.png
+webserverextensions/www/fusion/templates/mapguide/images/sidebarOpenButton.png
+webserverextensions/www/fusion/templates/mapguide/images/statusBarBackground.png
+webserverextensions/www/fusion/templates/mapguide/images/tab_bottom.png
+webserverextensions/www/fusion/templates/mapguide/images/tab_close.png
+webserverextensions/www/fusion/templates/mapguide/images/tab_left.png
+webserverextensions/www/fusion/templates/mapguide/images/tab_right.png
+webserverextensions/www/fusion/templates/mapguide/images/tab_top.png
+webserverextensions/www/fusion/templates/mapguide/images/tabbar.png
+webserverextensions/www/fusion/templates/mapguide/images/tabbar_bottom.png
+webserverextensions/www/fusion/templates/mapguide/images/tabbar_left.png
+webserverextensions/www/fusion/templates/mapguide/images/tabbar_right.png
+webserverextensions/www/fusion/templates/mapguide/images/table_col.png
+webserverextensions/www/fusion/templates/mapguide/images/table_row.png
+webserverextensions/www/fusion/templates/mapguide/images/toolbar.png
+webserverextensions/www/fusion/templates/mapguide/images/toolbarBackground.png
+webserverextensions/www/fusion/templates/mapguide/images/toolbarButton.png
+webserverextensions/www/fusion/templates/mapguide/images/toolbarLeft.png
+webserverextensions/www/fusion/templates/mapguide/images/toolbarRight.png
+webserverextensions/www/fusion/templates/mapguide/images/toolbarSubBackground.png
+webserverextensions/www/fusion/templates/mapguide/images/toolbarSubButton.png
+webserverextensions/www/fusion/templates/mapguide/images/toolbarSubLeft.png
+webserverextensions/www/fusion/templates/mapguide/images/toolbarSubRight.png
+webserverextensions/www/fusion/templates/mapguide/images/toolbar_separator_h.png
+webserverextensions/www/fusion/templates/mapguide/images/toolbar_separator_v.png
+webserverextensions/www/fusion/templates/mapguide/images/tree.png
+webserverextensions/www/fusion/templates/mapguide/images/tree_hover.png
+webserverextensions/www/fusion/templates/mapguide/images/tree_vert_line.png
+webserverextensions/www/fusion/templates/mapguide/images/zoomin.cur
+webserverextensions/www/fusion/templates/mapguide/images/zoomout.cur
+webserverextensions/www/fusion/templates/mapguide/index.php
+webserverextensions/www/fusion/templates/mapguide/limegold.xml
+webserverextensions/www/fusion/templates/mapguide/limegold/
+webserverextensions/www/fusion/templates/mapguide/limegold/ApplicationDefinition.xml
+webserverextensions/www/fusion/templates/mapguide/limegold/icons.css
+webserverextensions/www/fusion/templates/mapguide/limegold/ie6.css
+webserverextensions/www/fusion/templates/mapguide/limegold/ie7.css
+webserverextensions/www/fusion/templates/mapguide/limegold/images/
+webserverextensions/www/fusion/templates/mapguide/limegold/images/20070914_Mapguide_activity_indicator.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/FileMenuBackground.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/FileMenuLeft.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/FileMenuRight.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/Logo.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/ToolbarBackground.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/ToolbarLeft.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/ToolbarRight.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/ToolbarSubBackground.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/ToolbarSubLeft.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/ToolbarSubRight.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/a_pixel.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/backgroundTile.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/backgroundTile.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/button.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/button_combo.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/button_multi.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/button_multi_disclose.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/coordinate-tracker.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/dialog_chrome.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/dialog_controls.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/dialog_resize.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/emblems.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/fileMenuBackground.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/fileMenuButton.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/fileMenuLeft.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/fileMenuRight.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/filemenuHover.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/filemenuHover.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/flyout_chrome.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/grab.cur
+webserverextensions/www/fusion/templates/mapguide/limegold/images/grabbing.cur
+webserverextensions/www/fusion/templates/mapguide/limegold/images/grid.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/iconCollapse.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/iconCollapse.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/iconCollapseClosed.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/iconCollapseClosed.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/iconCollapseOpen.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/iconCollapseOpen.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/iconFileMenuDownArrow.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/iconFileMenuDownArrow.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/iconFileMenuRightArrow.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/iconFileMenuRightArrow.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/iconNavigator.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_back.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_back.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_close.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_forward.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_forward.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_home.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_home.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_invokeurl.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_invokeurl_disabled.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_quickhelp.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_tasks.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_tasks.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/about.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/buffer.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/coordinate-tracker.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/edit-copy.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/edit-cut.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/edit-duplicate.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/edit-paste.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/edit-xml.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/error.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/feature-info.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/file-print.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/file-save.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/geolocation.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/help.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/iconNavigator.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/info.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/initial-center.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/invoke-script.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/invoke-url.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/legend-DWF.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/legend-layer.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/legend-map.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/legend-raster.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/legend-theme.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/maptip.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/measure.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/options.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/out-of-range.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/overview-map.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/pan-east.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/pan-north.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/pan-south.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/pan-west.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/pan.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/preview.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/print.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/query.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/redline.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/search.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/select-centre.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/select-clear.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/select-features.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/select-polygon.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/select-radius.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/select-zoom.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/select.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/view-back.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/view-forward.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/view-refresh.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/warning.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/zoom-dynamic.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/zoom-full.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/zoom-in-fixed.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/zoom-in.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/zoom-out-fixed.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/jxPanelBackround.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/jxPanelBackround.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/jxPanelBarBackground.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/jxPanelBarBackground.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/jxPanelBarLeft.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/jxPanelBarLeft.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/jxPanelBottom.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/jxPanelBottom.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/loading.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/logo.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/mapBackground.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/mapBackground.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/maptip.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/menu_hover.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/menu_icon_active.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/nav_base_60trans.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/nav_slider_60trans.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/overviewMapButtonClose.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/overviewMapButtonClose.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/overviewMapButtonClose2.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/overview_map.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/panelBackground.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/panel_controls.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/panelbar.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/pbmg.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/pbmg.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/seperator_h.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/seperator_h.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarCloseButton.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarCloseButton.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarCollapseBackground.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarCollapseBackground.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarCollapseBottom.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarCollapseBottom.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarCollapseTop.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarCollapseTop.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarOpenButton.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarOpenButton.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/statusBarBackground.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/statusBarBackground.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/tabSetBackground.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/tabSetBackground.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/tab_bottom.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/tab_close.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/tab_left.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/tab_right.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/tab_top.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/tabbar.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/tabbar_bottom.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/tabbar_left.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/tabbar_right.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/table_col.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/table_row.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/taskTabSD_Left.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/taskTabSD_Left.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/taskTabSD_Right.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/taskTabSD_Right.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/taskTab_Left.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/taskTab_Left.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/taskTab_Right.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/taskTab_Right.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/tmpMap.jpg
+webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbar.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarBackground.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarButton.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarHover.gif
+webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarHover.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarLeft.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarRight.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarSubBackground.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarSubButton.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarSubLeft.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarSubRight.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbar_separator_h.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbar_separator_v.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/tree.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/tree_hover.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/tree_vert_line.png
+webserverextensions/www/fusion/templates/mapguide/limegold/images/zoomin.cur
+webserverextensions/www/fusion/templates/mapguide/limegold/images/zoomout.cur
+webserverextensions/www/fusion/templates/mapguide/limegold/index.html
+webserverextensions/www/fusion/templates/mapguide/limegold/index.templ
+webserverextensions/www/fusion/templates/mapguide/limegold/limegold.css
+webserverextensions/www/fusion/templates/mapguide/limegold/limegold.uncompressed.css
+webserverextensions/www/fusion/templates/mapguide/limegold/preview.png
+webserverextensions/www/fusion/templates/mapguide/maroon.xml
 webserverextensions/www/fusion/templates/mapguide/maroon/
 webserverextensions/www/fusion/templates/mapguide/maroon/ApplicationDefinition.xml
-webserverextensions/www/fusion/templates/mapguide/maroon/preview.png
 webserverextensions/www/fusion/templates/mapguide/maroon/icons.css
 webserverextensions/www/fusion/templates/mapguide/maroon/ie6.css
-webserverextensions/www/fusion/templates/mapguide/maroon/maroon.uncompressed.css
-webserverextensions/www/fusion/templates/mapguide/maroon/index.templ
 webserverextensions/www/fusion/templates/mapguide/maroon/ie7.css
 webserverextensions/www/fusion/templates/mapguide/maroon/images/
-webserverextensions/www/fusion/templates/mapguide/maroon/images/pbmg.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/a_pixel.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/adsk_logo.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/background.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/button.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/button_combo.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/button_multi.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/button_multi_disclose.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/coordinate-tracker.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/dialog_chrome.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/dialog_resize.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/emblems.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/emblems_alt.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/fileMenuBDLeft.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/fileMenuBackground.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/fileMenuBackgroundOver.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/fileMenuButton.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/flyout_chrome.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/grab.cur
+webserverextensions/www/fusion/templates/mapguide/maroon/images/grabbing.cur
+webserverextensions/www/fusion/templates/mapguide/maroon/images/grid.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/iconButtonMenuDownArrow.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/iconButtonMenuRightArrow.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/iconCollapse.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/iconCollapseClosed.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/tabbar_bottom.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/sidebarCollapseBottom.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/toolListBackground.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/iconCollapse.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/iconButtonMenuRightArrow.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/iconCollapseOpen.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/iconFileMenuDownArrow.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/iconFileMenuRightArrow.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/tab_right.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icon_forward.gif
-webserverextensions/www/fusion/templates/mapguide/maroon/images/tabbar_left.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/moduleBackground.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/fileMenuBackgroundOver.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/iconNavigator.gif
-webserverextensions/www/fusion/templates/mapguide/maroon/images/tabbar.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/maximize.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/fileMenuBackground.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/panel_controls.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/grab.cur
-webserverextensions/www/fusion/templates/mapguide/maroon/images/fileMenuBDLeft.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icon_back.gif
 webserverextensions/www/fusion/templates/mapguide/maroon/images/icon_close.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/dialog_resize.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/nav_base_60trans.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icon_forward.gif
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icon_quickhelp.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/select-radius.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/query.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/about.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/buffer.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/coordinate-tracker.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/edit-copy.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/edit-cut.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/invoke-script.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/edit-duplicate.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/zoom-in.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/print.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/edit-paste.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/edit-xml.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/error.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/feature-info.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/file-print.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/file-save.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/geolocation.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/help.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/iconNavigator.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/info.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/initial-center.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/edit-paste.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/view-back.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/select-features.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/invoke-script.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/invoke-url.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/select-zoom.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/feature-info.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/search.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/zoom-out-fixed.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/legend-DWF.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/legend-layer.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/legend-map.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/legend-raster.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/legend-theme.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/maptip.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/measure.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/options.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/out-of-range.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/view-refresh.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/preview.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/pan.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/geolocation.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/zoom-dynamic.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/zoom-full.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/select.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/overview-map.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/pan-east.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/warning.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/file-print.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/maptip.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/legend-DWF.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/info.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/pan-north.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/pan-south.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/pan-west.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/options.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/pan-south.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/legend-layer.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/overview-map.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/error.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/coordinate-tracker.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/edit-copy.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/legend-theme.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/pan.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/preview.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/print.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/query.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/redline.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/edit-xml.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/legend-map.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/select-polygon.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/measure.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/help.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/search.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/select-centre.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/buffer.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/file-save.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/pan-north.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/select-clear.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/select-features.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/select-polygon.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/select-radius.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/select-zoom.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/select.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/view-back.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/view-forward.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/view-refresh.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/warning.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/zoom-dynamic.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/zoom-full.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/zoom-in-fixed.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/view-forward.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/iconNavigator.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/about.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/zoom-in.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/icons/zoom-out-fixed.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/loading.gif
+webserverextensions/www/fusion/templates/mapguide/maroon/images/logo.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/maptip.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/tab_close.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/dialog_chrome.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/tree_vert_line.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/maximize.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/menu_hover.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/menu_icon_active.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/moduleBackground.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/moduleBorder.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/moduleTitleBackground.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/nav_base_60trans.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/nav_slider_60trans.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/panelBackground.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/panel_controls.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/panelbar.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/pbmg.gif
+webserverextensions/www/fusion/templates/mapguide/maroon/images/pbmg.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/seperator_h.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/seperator_v.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/sidebarCloseButton.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/sidebarCollapseBackground.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/sidebarCollapseBottom.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/sidebarCollapseTop.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/sidebarOpenButton.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/statusbar.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/statusbarBackground.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/tab_bottom.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/tab_close.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/tab_left.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/tab_right.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/tab_top.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/statusbar.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/button_combo.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/tab_bottom.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/emblems_alt.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/flyout_chrome.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/tabbar.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/tabbar_bottom.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/tabbar_left.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/tabbar_right.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/table_col.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/table_row.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/toolListBDLeft.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/sidebarCloseButton.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icon_back.gif
-webserverextensions/www/fusion/templates/mapguide/maroon/images/seperator_v.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/button_multi_disclose.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/loading.gif
-webserverextensions/www/fusion/templates/mapguide/maroon/images/panelbar.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/coordinate-tracker.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/button_multi.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/fileMenuButton.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/toolbar_separator_v.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/iconCollapseOpen.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/moduleBorder.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/button.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/iconFileMenuDownArrow.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icons.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/toolListBackground.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/toolbar.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/toolbarBackground.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/toolbarButton.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/table_col.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/grid.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/toolbar.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/menu_hover.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/iconButtonMenuDownArrow.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/menu_icon_active.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/toolbar_separator_h.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/nav_slider_60trans.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/tabbar_right.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/icon_quickhelp.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/sidebarOpenButton.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/table_row.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/sidebarCollapseBackground.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/grabbing.cur
+webserverextensions/www/fusion/templates/mapguide/maroon/images/toolbar_separator_v.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/tree.png
 webserverextensions/www/fusion/templates/mapguide/maroon/images/tree_hover.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/pbmg.gif
-webserverextensions/www/fusion/templates/mapguide/maroon/images/seperator_h.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/emblems.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/tree.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/logo.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/a_pixel.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/toolbarBackground.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/adsk_logo.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/background.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/tab_left.png
-webserverextensions/www/fusion/templates/mapguide/maroon/images/moduleTitleBackground.png
+webserverextensions/www/fusion/templates/mapguide/maroon/images/tree_vert_line.png
 webserverextensions/www/fusion/templates/mapguide/maroon/index.html
+webserverextensions/www/fusion/templates/mapguide/maroon/index.templ
 webserverextensions/www/fusion/templates/mapguide/maroon/maroon.css
+webserverextensions/www/fusion/templates/mapguide/maroon/maroon.uncompressed.css
+webserverextensions/www/fusion/templates/mapguide/maroon/preview.png
 webserverextensions/www/fusion/templates/mapguide/preview/
-webserverextensions/www/fusion/templates/mapguide/preview/preview.css
 webserverextensions/www/fusion/templates/mapguide/preview/ApplicationDefinition.xml
-webserverextensions/www/fusion/templates/mapguide/preview/preview.png
 webserverextensions/www/fusion/templates/mapguide/preview/icons.css
-webserverextensions/www/fusion/templates/mapguide/preview/preview.uncompressed.css
-webserverextensions/www/fusion/templates/mapguide/preview/indexNoLegend.html
 webserverextensions/www/fusion/templates/mapguide/preview/ie6.css
 webserverextensions/www/fusion/templates/mapguide/preview/ie7.css
 webserverextensions/www/fusion/templates/mapguide/preview/images/
-webserverextensions/www/fusion/templates/mapguide/preview/images/tabbar_bottom.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/tab_right.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/PoweredBy_en.gif
+webserverextensions/www/fusion/templates/mapguide/preview/images/a_pixel.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/button.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/button_combo.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/button_multi.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/button_multi_disclose.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/dialog_chrome.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/dialog_resize.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/emblems.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/flyout_chrome.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/grab.cur
+webserverextensions/www/fusion/templates/mapguide/preview/images/grabbing.cur
+webserverextensions/www/fusion/templates/mapguide/preview/images/grid.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icon_back.gif
+webserverextensions/www/fusion/templates/mapguide/preview/images/icon_back.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/icon_forward.gif
+webserverextensions/www/fusion/templates/mapguide/preview/images/icon_forward.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/icon_home.gif
-webserverextensions/www/fusion/templates/mapguide/preview/images/tabbar_left.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/zoomout.cur
-webserverextensions/www/fusion/templates/mapguide/preview/images/icon_forward.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/zoomin.cur
-webserverextensions/www/fusion/templates/mapguide/preview/images/tabbar.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/panel_controls.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/grab.cur
+webserverextensions/www/fusion/templates/mapguide/preview/images/icon_home.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icon_invokeurl.gif
+webserverextensions/www/fusion/templates/mapguide/preview/images/icon_invokeurl_disabled.gif
+webserverextensions/www/fusion/templates/mapguide/preview/images/icon_loading.gif
+webserverextensions/www/fusion/templates/mapguide/preview/images/icon_tasks.gif
 webserverextensions/www/fusion/templates/mapguide/preview/images/icon_tasks.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/dialog_resize.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icon_back.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/icons/
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/select-radius.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/query.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/about.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/buffer.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/coordinate-tracker.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/edit-copy.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/icons/edit-cut.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/invoke-script.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/icons/edit-duplicate.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/zoom-in.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/print.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/edit-paste.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/edit-xml.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/error.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/feature-info.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/file-print.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/file-save.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/geolocation.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/help.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/iconNavigator.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/info.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/icons/initial-center.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/edit-paste.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/view-back.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/select-features.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/invoke-script.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/icons/invoke-url.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/select-zoom.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/feature-info.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/search.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/zoom-out-fixed.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/legend-DWF.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/legend-layer.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/legend-map.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/icons/legend-raster.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/legend-theme.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/maptip.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/measure.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/options.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/icons/out-of-range.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/view-refresh.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/preview.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/pan.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/geolocation.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/zoom-dynamic.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/zoom-full.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/select.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/overview-map.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/icons/pan-east.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/warning.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/file-print.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/maptip.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/legend-DWF.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/info.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/pan-north.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/pan-south.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/icons/pan-west.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/options.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/pan-south.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/legend-layer.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/overview-map.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/error.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/coordinate-tracker.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/edit-copy.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/legend-theme.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/pan.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/preview.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/print.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/query.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/icons/redline.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/edit-xml.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/legend-map.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/select-polygon.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/measure.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/help.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/search.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/icons/select-centre.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/buffer.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/file-save.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/pan-north.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/icons/select-clear.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/select-features.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/select-polygon.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/select-radius.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/select-zoom.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/select.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/view-back.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/view-forward.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/view-refresh.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/warning.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/zoom-dynamic.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/zoom-full.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/icons/zoom-in-fixed.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/view-forward.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/iconNavigator.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons/about.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/zoom-in.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/icons/zoom-out-fixed.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/loading.gif
 webserverextensions/www/fusion/templates/mapguide/preview/images/maptip.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/menu_hover.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/menu_icon_active.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/panelBackground.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/panel_controls.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/panelbar.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/tab_bottom.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/tab_close.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/dialog_chrome.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/tree_vert_line.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/panelBackground.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/tab_left.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/tab_right.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/tab_top.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/button_combo.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/tab_bottom.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/flyout_chrome.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icon_tasks.gif
-webserverextensions/www/fusion/templates/mapguide/preview/images/icon_back.gif
-webserverextensions/www/fusion/templates/mapguide/preview/images/button_multi_disclose.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/loading.gif
-webserverextensions/www/fusion/templates/mapguide/preview/images/panelbar.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/button_multi.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/toolbar_separator_v.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icon_home.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/button.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/PoweredBy_en.gif
-webserverextensions/www/fusion/templates/mapguide/preview/images/icons.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/tabbar.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/tabbar_bottom.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/tabbar_left.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/tabbar_right.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/table_col.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/grid.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/table_row.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/toolbar.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/menu_hover.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/menu_icon_active.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/toolbar_separator_h.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/tabbar_right.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icon_invokeurl.gif
-webserverextensions/www/fusion/templates/mapguide/preview/images/table_row.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/grabbing.cur
+webserverextensions/www/fusion/templates/mapguide/preview/images/toolbar_separator_v.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/tree.png
 webserverextensions/www/fusion/templates/mapguide/preview/images/tree_hover.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icon_loading.gif
-webserverextensions/www/fusion/templates/mapguide/preview/images/emblems.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/icon_invokeurl_disabled.gif
-webserverextensions/www/fusion/templates/mapguide/preview/images/tree.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/a_pixel.png
-webserverextensions/www/fusion/templates/mapguide/preview/images/tab_left.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/tree_vert_line.png
+webserverextensions/www/fusion/templates/mapguide/preview/images/zoomin.cur
+webserverextensions/www/fusion/templates/mapguide/preview/images/zoomout.cur
 webserverextensions/www/fusion/templates/mapguide/preview/index.html
-webserverextensions/www/fusion/templates/mapguide/limegold/
-webserverextensions/www/fusion/templates/mapguide/limegold/ApplicationDefinition.xml
-webserverextensions/www/fusion/templates/mapguide/limegold/preview.png
-webserverextensions/www/fusion/templates/mapguide/limegold/limegold.css
-webserverextensions/www/fusion/templates/mapguide/limegold/icons.css
-webserverextensions/www/fusion/templates/mapguide/limegold/limegold.uncompressed.css
-webserverextensions/www/fusion/templates/mapguide/limegold/ie6.css
-webserverextensions/www/fusion/templates/mapguide/limegold/index.templ
-webserverextensions/www/fusion/templates/mapguide/limegold/ie7.css
-webserverextensions/www/fusion/templates/mapguide/limegold/images/
-webserverextensions/www/fusion/templates/mapguide/limegold/images/pbmg.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/tabSetBackground.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/jxPanelBottom.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/taskTabSD_Left.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/iconCollapseClosed.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/tabbar_bottom.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarCollapseBottom.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/ToolbarRight.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/taskTab_Left.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/backgroundTile.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/taskTab_Right.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/statusBarBackground.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/mapBackground.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/iconCollapse.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarOpenButton.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/iconCollapseOpen.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/iconFileMenuRightArrow.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/tab_right.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/ToolbarSubBackground.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/mapBackground.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_forward.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_home.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/jxPanelBarLeft.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/taskTabSD_Right.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/seperator_h.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/overviewMapButtonClose.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/tabbar_left.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarRight.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/backgroundTile.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/zoomout.cur
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_forward.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/iconNavigator.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/taskTab_Right.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarLeft.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/zoomin.cur
-webserverextensions/www/fusion/templates/mapguide/limegold/images/tabbar.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/fileMenuBackground.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/jxPanelBarBackground.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/20070914_Mapguide_activity_indicator.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/FileMenuRight.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/panel_controls.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarSubBackground.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/filemenuHover.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/filemenuHover.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/grab.cur
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_tasks.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_close.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/dialog_resize.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/nav_base_60trans.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_back.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/statusBarBackground.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarHover.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/select-radius.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/query.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/edit-cut.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/invoke-script.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/edit-duplicate.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/zoom-in.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/print.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/initial-center.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/edit-paste.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/view-back.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/select-features.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/invoke-url.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/select-zoom.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/feature-info.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/search.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/zoom-out-fixed.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/legend-raster.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/out-of-range.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/view-refresh.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/preview.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/pan.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/geolocation.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/zoom-dynamic.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/zoom-full.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/select.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/pan-east.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/warning.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/file-print.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/maptip.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/legend-DWF.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/info.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/pan-west.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/options.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/pan-south.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/legend-layer.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/overview-map.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/error.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/coordinate-tracker.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/edit-copy.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/legend-theme.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/redline.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/edit-xml.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/legend-map.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/select-polygon.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/measure.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/help.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/select-centre.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/buffer.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/file-save.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/pan-north.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/select-clear.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/zoom-in-fixed.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/view-forward.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/iconNavigator.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons/about.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/maptip.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/tab_close.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/ToolbarLeft.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/dialog_chrome.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/tree_vert_line.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/iconCollapse.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/panelBackground.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarCollapseTop.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/tab_top.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarSubLeft.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/button_combo.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/jxPanelBackround.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/tab_bottom.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/flyout_chrome.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_tasks.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarCloseButton.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/ToolbarSubLeft.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_back.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/FileMenuBackground.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/button_multi_disclose.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/loading.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/panelbar.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarSubRight.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/coordinate-tracker.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/button_multi.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/dialog_controls.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/jxPanelBarLeft.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/fileMenuButton.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbar_separator_v.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/iconCollapseOpen.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_home.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/Logo.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/button.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/taskTab_Left.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/overview_map.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/iconFileMenuDownArrow.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icons.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarButton.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarCloseButton.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/table_col.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/iconCollapseClosed.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/tabSetBackground.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarCollapseBottom.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/grid.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/fileMenuRight.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbar.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/menu_hover.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/ToolbarBackground.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarCollapseBackground.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/jxPanelBackround.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/overviewMapButtonClose.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/menu_icon_active.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbar_separator_h.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/tmpMap.jpg
-webserverextensions/www/fusion/templates/mapguide/limegold/images/nav_slider_60trans.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/taskTabSD_Right.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarCollapseTop.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/fileMenuLeft.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/iconFileMenuRightArrow.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/tabbar_right.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarHover.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_invokeurl.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_quickhelp.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/FileMenuLeft.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarOpenButton.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/table_row.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/jxPanelBarBackground.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/sidebarCollapseBackground.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/grabbing.cur
-webserverextensions/www/fusion/templates/mapguide/limegold/images/tree_hover.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/pbmg.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/jxPanelBottom.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/seperator_h.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/emblems.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/ToolbarSubRight.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/icon_invokeurl_disabled.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/tree.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/logo.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/a_pixel.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/taskTabSD_Left.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/iconFileMenuDownArrow.gif
-webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarBackground.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/overviewMapButtonClose2.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/toolbarSubButton.png
-webserverextensions/www/fusion/templates/mapguide/limegold/images/tab_left.png
-webserverextensions/www/fusion/templates/mapguide/limegold/index.html
-webserverextensions/www/fusion/templates/mapguide/images/
-webserverextensions/www/fusion/templates/mapguide/images/pbmg.png
-webserverextensions/www/fusion/templates/mapguide/images/tabbar_bottom.png
-webserverextensions/www/fusion/templates/mapguide/images/sidebarCollapseBottom.png
-webserverextensions/www/fusion/templates/mapguide/images/statusBarBackground.png
-webserverextensions/www/fusion/templates/mapguide/images/tab_right.png
-webserverextensions/www/fusion/templates/mapguide/images/mapBackground.png
-webserverextensions/www/fusion/templates/mapguide/images/icon_forward.gif
-webserverextensions/www/fusion/templates/mapguide/images/tabbar_left.png
-webserverextensions/www/fusion/templates/mapguide/images/toolbarRight.png
-webserverextensions/www/fusion/templates/mapguide/images/backgroundTile.png
-webserverextensions/www/fusion/templates/mapguide/images/fileMenuHover.png
-webserverextensions/www/fusion/templates/mapguide/images/zoomout.cur
-webserverextensions/www/fusion/templates/mapguide/images/iconNavigator.gif
-webserverextensions/www/fusion/templates/mapguide/images/toolbarLeft.png
-webserverextensions/www/fusion/templates/mapguide/images/zoomin.cur
-webserverextensions/www/fusion/templates/mapguide/images/tabbar.png
-webserverextensions/www/fusion/templates/mapguide/images/fileMenuBackground.png
-webserverextensions/www/fusion/templates/mapguide/images/seperator.png
-webserverextensions/www/fusion/templates/mapguide/images/panel_controls.png
-webserverextensions/www/fusion/templates/mapguide/images/toolbarSubBackground.png
-webserverextensions/www/fusion/templates/mapguide/images/panelBarLeft.png
-webserverextensions/www/fusion/templates/mapguide/images/grab.cur
-webserverextensions/www/fusion/templates/mapguide/images/dialog_resize.png
-webserverextensions/www/fusion/templates/mapguide/images/nav_base_60trans.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/
-webserverextensions/www/fusion/templates/mapguide/images/icons/select-radius.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/query.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/edit-cut.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/invoke-script.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/edit-duplicate.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/zoom-in.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/print.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/initial-center.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/edit-paste.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/view-back.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/theme.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/select-features.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/invoke-url.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/select-zoom.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/feature-info.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/search.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/zoom-out-fixed.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/legend-raster.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/out-of-range.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/view-refresh.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/preview.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/pan.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/geolocation.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/zoom-dynamic.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/zoom-full.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/select.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/pan-east.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/warning.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/file-print.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/maptip.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/legend-DWF.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/info.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/pan-west.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/options.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/pan-south.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/legend-layer.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/overview-map.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/error.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/coordinate-tracker.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/edit-copy.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/legend-theme.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/redline.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/edit-xml.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/legend-map.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/select-polygon.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/measure.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/help.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/select-centre.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/buffer.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/file-save.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/pan-north.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/select-clear.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/zoom-in-fixed.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/view-forward.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/iconNavigator.png
-webserverextensions/www/fusion/templates/mapguide/images/icons/about.png
-webserverextensions/www/fusion/templates/mapguide/images/maptip.png
-webserverextensions/www/fusion/templates/mapguide/images/tab_close.png
-webserverextensions/www/fusion/templates/mapguide/images/panelBottom.png
-webserverextensions/www/fusion/templates/mapguide/images/dialog_chrome.png
-webserverextensions/www/fusion/templates/mapguide/images/tree_vert_line.png
-webserverextensions/www/fusion/templates/mapguide/images/panelBackground.png
-webserverextensions/www/fusion/templates/mapguide/images/sidebarCollapseTop.png
-webserverextensions/www/fusion/templates/mapguide/images/tab_top.png
-webserverextensions/www/fusion/templates/mapguide/images/toolbarSubLeft.png
-webserverextensions/www/fusion/templates/mapguide/images/button_combo.png
-webserverextensions/www/fusion/templates/mapguide/images/tab_bottom.png
-webserverextensions/www/fusion/templates/mapguide/images/emblems_alt.png
-webserverextensions/www/fusion/templates/mapguide/images/flyout_chrome.png
-webserverextensions/www/fusion/templates/mapguide/images/sidebarCloseButton.png
-webserverextensions/www/fusion/templates/mapguide/images/icon_back.gif
-webserverextensions/www/fusion/templates/mapguide/images/seperator_v.png
-webserverextensions/www/fusion/templates/mapguide/images/button_multi_disclose.png
-webserverextensions/www/fusion/templates/mapguide/images/loading.gif
-webserverextensions/www/fusion/templates/mapguide/images/panelbar.png
-webserverextensions/www/fusion/templates/mapguide/images/toolbarSubRight.png
-webserverextensions/www/fusion/templates/mapguide/images/coordinate-tracker.png
-webserverextensions/www/fusion/templates/mapguide/images/button_multi.png
-webserverextensions/www/fusion/templates/mapguide/images/dialog_controls.png
-webserverextensions/www/fusion/templates/mapguide/images/fileMenuButton.png
-webserverextensions/www/fusion/templates/mapguide/images/toolbar_separator_v.png
-webserverextensions/www/fusion/templates/mapguide/images/button.png
-webserverextensions/www/fusion/templates/mapguide/images/icons.png
-webserverextensions/www/fusion/templates/mapguide/images/toolbarButton.png
-webserverextensions/www/fusion/templates/mapguide/images/table_col.png
-webserverextensions/www/fusion/templates/mapguide/images/grid.png
-webserverextensions/www/fusion/templates/mapguide/images/fileMenuRight.png
-webserverextensions/www/fusion/templates/mapguide/images/toolbar.png
-webserverextensions/www/fusion/templates/mapguide/images/menu_hover.png
-webserverextensions/www/fusion/templates/mapguide/images/menu_icon_active.png
-webserverextensions/www/fusion/templates/mapguide/images/toolbar_separator_h.png
-webserverextensions/www/fusion/templates/mapguide/images/nav_slider_60trans.png
-webserverextensions/www/fusion/templates/mapguide/images/fileMenuLeft.png
-webserverextensions/www/fusion/templates/mapguide/images/tabbar_right.png
-webserverextensions/www/fusion/templates/mapguide/images/sidebarOpenButton.png
-webserverextensions/www/fusion/templates/mapguide/images/table_row.png
-webserverextensions/www/fusion/templates/mapguide/images/sidebarCollapseBackground.png
-webserverextensions/www/fusion/templates/mapguide/images/grabbing.cur
-webserverextensions/www/fusion/templates/mapguide/images/tree_hover.png
-webserverextensions/www/fusion/templates/mapguide/images/emblems.png
-webserverextensions/www/fusion/templates/mapguide/images/tree.png
-webserverextensions/www/fusion/templates/mapguide/images/logo.png
-webserverextensions/www/fusion/templates/mapguide/images/a_pixel.png
-webserverextensions/www/fusion/templates/mapguide/images/toolbarBackground.png
-webserverextensions/www/fusion/templates/mapguide/images/toolbarSubButton.png
-webserverextensions/www/fusion/templates/mapguide/images/tab_left.png
-webserverextensions/www/fusion/templates/mapguide/index.php
+webserverextensions/www/fusion/templates/mapguide/preview/indexNoLegend.html
+webserverextensions/www/fusion/templates/mapguide/preview/preview.css
+webserverextensions/www/fusion/templates/mapguide/preview/preview.png
+webserverextensions/www/fusion/templates/mapguide/preview/preview.uncompressed.css
+webserverextensions/www/fusion/templates/mapguide/slate.xml
+webserverextensions/www/fusion/templates/mapguide/slate/
+webserverextensions/www/fusion/templates/mapguide/slate/ApplicationDefinition.xml
+webserverextensions/www/fusion/templates/mapguide/slate/icons.css
+webserverextensions/www/fusion/templates/mapguide/slate/ie6.css
+webserverextensions/www/fusion/templates/mapguide/slate/ie7.css
+webserverextensions/www/fusion/templates/mapguide/slate/images/
+webserverextensions/www/fusion/templates/mapguide/slate/images/a_pixel.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/backgroundTile.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/button.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/button_combo.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/button_multi.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/button_multi_disclose.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/coordinate-tracker.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/dialog_chrome.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/dialog_controls.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/dialog_resize.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/emblems.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/emblems_alt.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/fileMenuBackground.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/fileMenuButton.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/fileMenuHover.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/fileMenuLeft.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/fileMenuRight.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/flyout_chrome.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/grab.cur
+webserverextensions/www/fusion/templates/mapguide/slate/images/grabbing.cur
+webserverextensions/www/fusion/templates/mapguide/slate/images/grid.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/iconNavigator.gif
+webserverextensions/www/fusion/templates/mapguide/slate/images/icon_back.gif
+webserverextensions/www/fusion/templates/mapguide/slate/images/icon_forward.gif
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/about.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/buffer.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/coordinate-tracker.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/edit-copy.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/edit-cut.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/edit-duplicate.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/edit-paste.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/edit-xml.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/error.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/feature-info.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/file-print.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/file-save.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/geolocation.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/help.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/iconNavigator.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/info.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/initial-center.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/invoke-script.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/invoke-url.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/legend-DWF.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/legend-layer.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/legend-map.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/legend-raster.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/legend-theme.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/maptip.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/measure.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/options.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/out-of-range.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/overview-map.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/pan-east.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/pan-north.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/pan-south.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/pan-west.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/pan.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/preview.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/print.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/query.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/redline.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/search.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/select-centre.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/select-clear.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/select-features.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/select-polygon.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/select-radius.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/select-zoom.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/select.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/theme.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/view-back.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/view-forward.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/view-refresh.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/warning.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/zoom-dynamic.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/zoom-full.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/zoom-in-fixed.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/zoom-in.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/icons/zoom-out-fixed.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/loading.gif
+webserverextensions/www/fusion/templates/mapguide/slate/images/logo.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/mapBackground.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/maptip.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/menu_hover.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/menu_icon_active.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/nav_base_60trans.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/nav_slider_60trans.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/panelBackground.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/panelBarLeft.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/panelBottom.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/panel_controls.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/panelbar.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/pbmg.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/seperator.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/seperator_v.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/sidebarCloseButton.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/sidebarCollapseBackground.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/sidebarCollapseBottom.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/sidebarCollapseTop.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/sidebarOpenButton.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/statusBarBackground.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/tab_bottom.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/tab_close.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/tab_left.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/tab_right.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/tab_top.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/tabbar.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/tabbar_bottom.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/tabbar_left.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/tabbar_right.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/table_col.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/table_row.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/toolbar.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/toolbarBackground.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/toolbarButton.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/toolbarLeft.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/toolbarRight.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/toolbarSubBackground.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/toolbarSubButton.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/toolbarSubLeft.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/toolbarSubRight.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/toolbar_separator_h.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/toolbar_separator_v.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/tree.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/tree_hover.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/tree_vert_line.png
+webserverextensions/www/fusion/templates/mapguide/slate/images/zoomin.cur
+webserverextensions/www/fusion/templates/mapguide/slate/images/zoomout.cur
+webserverextensions/www/fusion/templates/mapguide/slate/index.html
+webserverextensions/www/fusion/templates/mapguide/slate/index.templ
+webserverextensions/www/fusion/templates/mapguide/slate/preview.png
+webserverextensions/www/fusion/templates/mapguide/slate/slate.css
+webserverextensions/www/fusion/templates/mapguide/slate/slate.uncompressed.css
+webserverextensions/www/fusion/templates/mapguide/standard/
+webserverextensions/www/fusion/templates/mapguide/standard/ApplicationDefinition.xml
+webserverextensions/www/fusion/templates/mapguide/standard/icons.css
+webserverextensions/www/fusion/templates/mapguide/standard/images/
+webserverextensions/www/fusion/templates/mapguide/standard/images/a_pixel.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/grab.cur
+webserverextensions/www/fusion/templates/mapguide/standard/images/grabbing.cur
+webserverextensions/www/fusion/templates/mapguide/standard/images/icon_back.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icon_forward.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icon_home.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icon_invokeurl.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icon_invokeurl_disabled.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icon_tasks.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/buffer.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/edit-copy.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/edit-cut.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/edit-duplicate.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/edit-paste.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/edit-redo.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/edit-undo.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/file-open.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/file-print.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/file-save.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/help.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/legend-layer.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/legend-map.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/legend-raster.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/legend-theme.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/measure.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/move-down.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/move-up.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/navigator.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/out-of-range.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/pan-east.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/pan-north.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/pan-south.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/pan.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/search.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-attribute.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-centre.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-clear.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-features.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-polygon.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-query.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-radius.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-rectangle.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select-zoom.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/select.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/view-back.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/view-forward.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/view-refresh.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/warning.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/west.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/zoom-full.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/zoom-in-fixed.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/zoom-in.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/zoom-out-fixed.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/icons/zoom-out.png
+webserverextensions/www/fusion/templates/mapguide/standard/images/maptip.png
+webserverextensions/www/fusion/templates/mapguide/standard/index.html
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow.xml
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/ApplicationDefinition.xml
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/icons.css
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/ie6.css
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/ie7.css
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/ToolbarBackground.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/a_pixel.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/adsk_logo.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/background.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/backgroundTile.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/button.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/button_combo.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/button_multi.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/button_multi_disclose.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/coordinate-tracker.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_chrome.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_controls.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_glow_b.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_glow_bl.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_glow_br.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_glow_l.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_glow_r.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_glow_t.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_glow_tl.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_glow_tr.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/dialog_resize.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/emblems.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/emblems_alt.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/fileMenuBDLeft.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/fileMenuBDRight.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/fileMenuBackground.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/fileMenuBackgroundOver.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/fileMenuButton.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/fileMenuLeft.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/fileMenuRight.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/filemenuHover.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/flyout_chrome.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/grab.cur
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/grabbing.cur
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/grid.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/iconCollapse.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/iconCollapseClosed.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/iconCollapseOpen.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/iconFileMenuDownArrow.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/iconFileMenuRightArrow.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/iconNavigator.gif
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icon_back.gif
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icon_close.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icon_forward.gif
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icon_quickhelp.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/about.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/buffer.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/coordinate-tracker.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/edit-copy.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/edit-cut.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/edit-duplicate.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/edit-paste.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/edit-xml.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/error.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/feature-info.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/file-print.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/file-save.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/geolocation.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/help.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/iconNavigator.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/info.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/initial-center.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/invoke-script.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/invoke-url.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/legend-DWF.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/legend-layer.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/legend-map.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/legend-raster.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/legend-theme.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/maptip.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/measure.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/options.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/out-of-range.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/overview-map.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/pan-east.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/pan-north.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/pan-south.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/pan-west.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/pan.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/preview.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/print.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/query.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/redline.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/search.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/select-centre.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/select-clear.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/select-features.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/select-polygon.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/select-radius.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/select-zoom.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/select.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/view-back.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/view-forward.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/view-refresh.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/warning.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/zoom-dynamic.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/zoom-full.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/zoom-in-fixed.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/zoom-in.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/icons/zoom-out-fixed.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/jxPanelBackround.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/jxPanelBarBackground.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/jxPanelBarLeft.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/jxPanelBottom.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/loading.gif
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/logo.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/mapBackground.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/maptip.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/maximize.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/menu_hover.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/menu_icon_active.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/moduleBackground.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/moduleBorder.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/moduleTaskToolbarBackground.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/moduleTitleBackground.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/overviewMap.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/overviewMapButtonClose.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/overviewMapButtonClose2.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/overviewMapTmp.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/overview_map.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/palleteIconMaximize.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/palleteTile.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/panelBackground.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/panel_controls.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/panelbar.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/pbmg.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/seperator.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/seperator_v.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/sidebarCloseButton.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/sidebarCollapseBackground.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/sidebarCollapseBottom.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/sidebarCollapseButton.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/sidebarCollapseTop.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/sidebarOpenButton.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/statusBarBackground.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/statusbar.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tabSetBackground.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tab_bottom.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tab_close.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tab_left.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tab_right.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tab_top.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tabbar.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tabbar_bottom.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tabbar_left.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tabbar_right.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/table_col.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/table_row.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/taskTabSD_Left.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/taskTabSD_Right.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolListBDLeft.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolListBackground.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbar.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbarButton.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbarHover.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbarLeft.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbarRight.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbarSubBackground.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbarSubLeft.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbarSubRight.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbarVerticalBackground.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbar_separator_h.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbar_separator_h2.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbar_separator_v.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/toolbar_separator_v2.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tree.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tree_hover.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/tree_vert_line.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/verticalMenuBar.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/zoomin.cur
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/images/zoomout.cur
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/index.html
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/index.templ
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/preview.png
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/turquoiseyellow.css
+webserverextensions/www/fusion/templates/mapguide/turquoiseyellow/turquoiseyellow.uncompressed.css
 webserverextensions/www/fusion/templates/mapserver/
 webserverextensions/www/fusion/templates/mapserver/standard/
 webserverextensions/www/fusion/templates/mapserver/standard/ApplicationDefinition.xml
@@ -5190,1366 +5364,1258 @@
 webserverextensions/www/fusion/templates/mapserver/standard/EPSG42304.js
 webserverextensions/www/fusion/templates/mapserver/standard/icons.css
 webserverextensions/www/fusion/templates/mapserver/standard/images/
-webserverextensions/www/fusion/templates/mapserver/standard/images/zoomout.cur
-webserverextensions/www/fusion/templates/mapserver/standard/images/zoomin.cur
+webserverextensions/www/fusion/templates/mapserver/standard/images/PoweredBy_en.gif
+webserverextensions/www/fusion/templates/mapserver/standard/images/Thumbs.db
+webserverextensions/www/fusion/templates/mapserver/standard/images/a_pixel.png
 webserverextensions/www/fusion/templates/mapserver/standard/images/grab.cur
+webserverextensions/www/fusion/templates/mapserver/standard/images/grabbing.cur
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons.png
 webserverextensions/www/fusion/templates/mapserver/standard/images/icons/
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/select-radius.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/Thumbs.db
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/buffer.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/edit-copy.png
 webserverextensions/www/fusion/templates/mapserver/standard/images/icons/edit-cut.png
 webserverextensions/www/fusion/templates/mapserver/standard/images/icons/edit-duplicate.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/zoom-in.png
 webserverextensions/www/fusion/templates/mapserver/standard/images/icons/edit-paste.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/navigator.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/west.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/view-back.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/select-features.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/edit-redo.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/edit-undo.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/file-open.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/file-print.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/file-save.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/help.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/icon_back.png
 webserverextensions/www/fusion/templates/mapserver/standard/images/icons/icon_forward.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/select-zoom.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/search.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/zoom-out-fixed.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/icon_home.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/icon_invokeurl.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/icon_loading.gif
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/icon_tasks.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/legend-layer.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/legend-map.png
 webserverextensions/www/fusion/templates/mapserver/standard/images/icons/legend-raster.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/view-refresh.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/legend-theme.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/measure.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/move-down.png
 webserverextensions/www/fusion/templates/mapserver/standard/images/icons/move-up.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/pan.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/icon_tasks.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/zoom-full.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/select-query.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/icon_back.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/select.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/navigator.png
 webserverextensions/www/fusion/templates/mapserver/standard/images/icons/pan-east.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/warning.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/file-print.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/zoom-out.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/pan-north.png
 webserverextensions/www/fusion/templates/mapserver/standard/images/icons/pan-south.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/legend-layer.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/pan.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/search.png
 webserverextensions/www/fusion/templates/mapserver/standard/images/icons/select-attribute.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/icon_home.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/edit-undo.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/edit-copy.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/legend-theme.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/move-down.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/select-rectangle.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/legend-map.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/file-open.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/select-polygon.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/measure.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/Thumbs.db
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/help.png
 webserverextensions/www/fusion/templates/mapserver/standard/images/icons/select-centre.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/buffer.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/file-save.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/pan-north.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/icon_invokeurl.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/icon_loading.gif
 webserverextensions/www/fusion/templates/mapserver/standard/images/icons/select-clear.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/select-features.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/select-polygon.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/select-query.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/select-radius.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/select-rectangle.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/select-zoom.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/select.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/view-back.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/view-forward.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/view-refresh.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/warning.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/west.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/zoom-full.png
 webserverextensions/www/fusion/templates/mapserver/standard/images/icons/zoom-in-fixed.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/view-forward.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons/edit-redo.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/PoweredBy_en.gif
-webserverextensions/www/fusion/templates/mapserver/standard/images/icons.png
-webserverextensions/www/fusion/templates/mapserver/standard/images/Thumbs.db
-webserverextensions/www/fusion/templates/mapserver/standard/images/grabbing.cur
-webserverextensions/www/fusion/templates/mapserver/standard/images/a_pixel.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/zoom-in.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/zoom-out-fixed.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/icons/zoom-out.png
+webserverextensions/www/fusion/templates/mapserver/standard/images/zoomin.cur
+webserverextensions/www/fusion/templates/mapserver/standard/images/zoomout.cur
 webserverextensions/www/fusion/templates/mapserver/standard/index.html
-webserverextensions/www/fusion/docs/
-webserverextensions/www/fusion/docs/ApplicationDefinition.xml
-webserverextensions/www/fusion/docs/tutorial/
-webserverextensions/www/fusion/docs/tutorial/Fusion_Tutorial.odt
-webserverextensions/www/fusion/docs/tutorial/simple/
-webserverextensions/www/fusion/docs/tutorial/simple/ApplicationDefinition.xml
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/expansion_embed.js
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/test_domain.js
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/6_002.jpg
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/ads.htm
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/counter.js
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/ads_002.htm
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/ipkfile.png
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/ads_003.htm
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/6_004.jpg
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/ads_data_002/
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/ads_data_002/abg-en-100c-000000.png
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/6.jpg
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/style.css
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/show_ads.js
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/imghover.htm
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/6_003.jpg
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/images/
-webserverextensions/www/fusion/docs/tutorial/simple/SheboyganLife_files/images/skyline.jpg
-webserverextensions/www/fusion/docs/tutorial/simple/index2.html
-webserverextensions/www/fusion/docs/tutorial/simple/simple.gif
-webserverextensions/www/fusion/docs/tutorial/simple/Sheboygan News _ Sheboygan Life.htm
-webserverextensions/www/fusion/docs/tutorial/simple/index.html
-webserverextensions/www/fusion/docs/tutorial/simple/index.xml
-webserverextensions/www/fusion/docs/tutorial/fullPage/
-webserverextensions/www/fusion/docs/tutorial/fullPage/ApplicationDefinition.xml
-webserverextensions/www/fusion/docs/tutorial/fullPage/index2.html
-webserverextensions/www/fusion/docs/tutorial/fullPage/index1.html
-webserverextensions/www/fusion/docs/tutorial/fullPage/icons.css
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/ie6.css
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/ie7.css
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/jxtheme.css
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tabbar_bottom.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tab_right.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tabbar_left.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tabbar.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/panel_controls.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/dialog_resize.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tab_close.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/dialog_chrome.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tree_vert_line.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tab_top.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/button_combo.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tab_bottom.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/flyout_chrome.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/button_multi_disclose.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/loading.gif
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/panelbar.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/button_multi.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/toolbar_separator_v.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/button.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/table_col.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/grid.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/toolbar.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/menu_hover.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/menu_icon_active.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/toolbar_separator_h.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tabbar_right.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/table_row.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tree_hover.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/emblems.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tree.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/a_pixel.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/images/tab_left.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/crispin/jxtheme.uncompressed.css
-webserverextensions/www/fusion/docs/tutorial/fullPage/index5.html
-webserverextensions/www/fusion/docs/tutorial/fullPage/images/
-webserverextensions/www/fusion/docs/tutorial/fullPage/images/icon_home.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/images/icons.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/images/a_pixel.png
-webserverextensions/www/fusion/docs/tutorial/fullPage/index4.html
-webserverextensions/www/fusion/docs/tutorial/fullPage/index.html
-webserverextensions/www/fusion/docs/tutorial/fullPage/index3.html
-webserverextensions/www/fusion/docs/ApplicationDefinition-1.0.0.xsd
-webserverextensions/www/fusion/docs/installation.html
-webserverextensions/www/fusion/docs/index.html
-webserverextensions/www/fusion/lib/
-webserverextensions/www/fusion/lib/Widget.js
-webserverextensions/www/fusion/lib/Error.js
-webserverextensions/www/fusion/lib/OpenLayers/
-webserverextensions/www/fusion/lib/OpenLayers/ext/
-webserverextensions/www/fusion/lib/OpenLayers/ext/OpenLayers/
-webserverextensions/www/fusion/lib/OpenLayers/ext/OpenLayers/Map.js
-webserverextensions/www/fusion/lib/OpenLayers/ext/OpenLayers/Layer/
-webserverextensions/www/fusion/lib/OpenLayers/ext/OpenLayers/Layer/Google/
-webserverextensions/www/fusion/lib/OpenLayers/ext/OpenLayers/Layer/Google/v3.js
-webserverextensions/www/fusion/lib/OpenLayers/ext/readme.txt
-webserverextensions/www/fusion/lib/OpenLayers/OpenLayers.js
-webserverextensions/www/fusion/lib/OpenLayers/theme/
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/ie6-style.tidy.css
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/ie6-style.css
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/google.css
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/style.tidy.css
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/style.mobile.tidy.css
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/style.css
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/view_previous_off.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/editing_tool_bar.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/draw_line_on.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/panning-hand-off.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/draw_polygon_on.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/zoom-panel-NOALPHA.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/drag-rectangle-on.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/pan_off.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/move_feature_off.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/save_features_on.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/draw_polygon_off.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/pan-panel-NOALPHA.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/view_previous_on.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/blank.gif
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/view_next_on.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/remove_point_off.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/draw_point_on.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/close.gif
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/drag-rectangle-off.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/remove_point_on.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/ruler.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/draw_point_off.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/panning-hand-on.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/pan-panel.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/save_features_off.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/move_feature_on.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/overview_replacement.gif
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/add_point_off.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/pan_on.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/zoom-panel.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/draw_line_off.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/add_point_on.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/view_next_off.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/img/navigation_history.png
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/google.tidy.css
-webserverextensions/www/fusion/lib/OpenLayers/theme/default/style.mobile.css
-webserverextensions/www/fusion/lib/OpenLayers/Lang/
-webserverextensions/www/fusion/lib/OpenLayers/Lang/es.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/nb.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/nl.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/da-DK.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/ja.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/te.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/sv-SE.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/hr.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/io.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/pt.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/fi.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/ca.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/bg.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/is.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/cs-CZ.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/it.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/id.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/oc.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/zh-CN.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/ksh.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/sk.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/de.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/be-tarask.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/ar.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/br.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/gl.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/ia.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/nds.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/hsb.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/vi.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/km.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/fr.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/hu.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/ro.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/gsw.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/pl.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/pt-BR.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/ru.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/en-CA.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/en.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/el.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/lt.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/fur.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/zh-TW.js
-webserverextensions/www/fusion/lib/OpenLayers/Lang/nn.js
-webserverextensions/www/fusion/lib/OpenLayers/img/
-webserverextensions/www/fusion/lib/OpenLayers/img/south-mini.png
-webserverextensions/www/fusion/lib/OpenLayers/img/zoom-plus-mini.png
-webserverextensions/www/fusion/lib/OpenLayers/img/zoom-minus-mini.png
-webserverextensions/www/fusion/lib/OpenLayers/img/slider.png
-webserverextensions/www/fusion/lib/OpenLayers/img/panning-hand-off.png
-webserverextensions/www/fusion/lib/OpenLayers/img/marker-gold.png
-webserverextensions/www/fusion/lib/OpenLayers/img/marker-blue.png
-webserverextensions/www/fusion/lib/OpenLayers/img/drag-rectangle-on.png
-webserverextensions/www/fusion/lib/OpenLayers/img/layer-switcher-maximize.png
-webserverextensions/www/fusion/lib/OpenLayers/img/north-mini.png
-webserverextensions/www/fusion/lib/OpenLayers/img/marker-green.png
-webserverextensions/www/fusion/lib/OpenLayers/img/west-mini.png
-webserverextensions/www/fusion/lib/OpenLayers/img/blank.gif
-webserverextensions/www/fusion/lib/OpenLayers/img/layer-switcher-minimize.png
-webserverextensions/www/fusion/lib/OpenLayers/img/east-mini.png
-webserverextensions/www/fusion/lib/OpenLayers/img/measuring-stick-off.png
-webserverextensions/www/fusion/lib/OpenLayers/img/drag-rectangle-off.png
-webserverextensions/www/fusion/lib/OpenLayers/img/cloud-popup-relative.png
-webserverextensions/www/fusion/lib/OpenLayers/img/panning-hand-on.png
-webserverextensions/www/fusion/lib/OpenLayers/img/measuring-stick-on.png
-webserverextensions/www/fusion/lib/OpenLayers/img/zoombar.png
-webserverextensions/www/fusion/lib/OpenLayers/img/zoom-world-mini.png
-webserverextensions/www/fusion/lib/OpenLayers/img/marker.png
-webserverextensions/www/fusion/lib/RectTool.js
-webserverextensions/www/fusion/lib/fusionSF-compressed.js
-webserverextensions/www/fusion/lib/fusion.js
-webserverextensions/www/fusion/lib/TraceKit/
-webserverextensions/www/fusion/lib/TraceKit/TraceKit.js
-webserverextensions/www/fusion/lib/OLpatch.js
-webserverextensions/www/fusion/lib/MGBroker.js
-webserverextensions/www/fusion/lib/fusionSF.js
-webserverextensions/www/fusion/lib/tcpdf/
-webserverextensions/www/fusion/lib/tcpdf/tcpdf.php
-webserverextensions/www/fusion/lib/tcpdf/tcpdf.fdf
-webserverextensions/www/fusion/lib/tcpdf/htmlcolors.php
-webserverextensions/www/fusion/lib/tcpdf/2dbarcodes.php
-webserverextensions/www/fusion/lib/tcpdf/tcpdf.p12
-webserverextensions/www/fusion/lib/tcpdf/sRGB.icc
-webserverextensions/www/fusion/lib/tcpdf/LICENSE.TXT
-webserverextensions/www/fusion/lib/tcpdf/encodings_maps.php
-webserverextensions/www/fusion/lib/tcpdf/tcpdf_parser.php
-webserverextensions/www/fusion/lib/tcpdf/unicode_data.php
-webserverextensions/www/fusion/lib/tcpdf/spotcolors.php
-webserverextensions/www/fusion/lib/tcpdf/config/
-webserverextensions/www/fusion/lib/tcpdf/config/tcpdf_config.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/
-webserverextensions/www/fusion/lib/tcpdf/config/lang/far.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/swa.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/ara.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/fra.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/srp.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/hye.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/jpn.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/pol.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/glg.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/mkd.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/aze.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/hat.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/kat.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/ita.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/kor.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/urd.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/eng.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/ind.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/ron.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/hrv.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/heb.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/nld.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/cym.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/eus.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/bra.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/mlt.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/dan.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/bel.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/ces.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/zho.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/sqi.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/afr.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/chi.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/spa.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/gle.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/hun.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/yid.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/por.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/slv.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/est.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/msa.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/rus.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/swe.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/nob.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/ger.php
-webserverextensions/www/fusion/lib/tcpdf/config/lang/cat.php
-webserverextensions/www/fusion/lib/tcpdf/config/tcpdf_config_alt.php
-webserverextensions/www/fusion/lib/tcpdf/cache/
-webserverextensions/www/fusion/lib/tcpdf/cache/chapter_demo_1.txt
-webserverextensions/www/fusion/lib/tcpdf/cache/table_data_demo.txt
-webserverextensions/www/fusion/lib/tcpdf/cache/chapter_demo_2.txt
-webserverextensions/www/fusion/lib/tcpdf/cache/utf8test.txt
-webserverextensions/www/fusion/lib/tcpdf/qrcode.php
-webserverextensions/www/fusion/lib/tcpdf/datamatrix.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/
-webserverextensions/www/fusion/lib/tcpdf/fonts/freesansb.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensed.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfahelvetica.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/freesans.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfahelveticab.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/uni2cid_ac15.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/aealarabiya.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserif.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserif.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/helveticabi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/freemonoi.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freesansbi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/uni2cid_ag15.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfazapfdingbats.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonob.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfatimes.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansextralight.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/courier.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifb.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusans.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfacourierbi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensed.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusans.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfacourieri.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifb.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freemono.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfahelveticabi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/aealarabiya.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freesans.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifi.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansb.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/courierbi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/helveticab.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/courieri.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/kozminproregular.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfacourier.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedb.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/zapfdingbats.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/cid0kr.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmono.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonobi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfasymbol.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/freesansi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/freesansi.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedi.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonobi.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freemonoi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freeserif.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freemonobi.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensed.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansbi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/aefurat.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserif.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freesans.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifbi.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/cid0jp.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifi.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freemonob.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedb.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonoi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfatimesb.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedb.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/helvetica.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedb.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfacourierbi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifbi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensed.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/uni2cid_ak12.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/timesb.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/timesbi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/freesansb.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/freemono.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfatimesbi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/cid0cs.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/freemono.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfasymbol.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfacourierb.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/hysmyeongjostdmedium.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/freemonobi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/freefont-20100919/
-webserverextensions/www/fusion/lib/tcpdf/fonts/freefont-20100919/AUTHORS
-webserverextensions/www/fusion/lib/tcpdf/fonts/freefont-20100919/ChangeLog
-webserverextensions/www/fusion/lib/tcpdf/fonts/freefont-20100919/CREDITS
-webserverextensions/www/fusion/lib/tcpdf/fonts/freefont-20100919/INSTALL
-webserverextensions/www/fusion/lib/tcpdf/fonts/freefont-20100919/COPYING
-webserverextensions/www/fusion/lib/tcpdf/fonts/freefont-20100919/README
-webserverextensions/www/fusion/lib/tcpdf/fonts/msungstdlight.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/stsongstdlight.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/aefurat.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfahelveticai.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfacourierb.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonoi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedbi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansextralight.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansextralight.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedbi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedi.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonob.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/aefurat.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/timesi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifbi.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansbi.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansi.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifb.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/uni2cid_aj16.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifbi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/freesansbi.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedb.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freemonoi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/NEWS
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/unicover.txt
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/LICENSE
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/AUTHORS
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/status.txt
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/langcover.txt
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/BUGS
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavu-fonts-ttf-2.33/README
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmono.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfacourieri.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/freesansbi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfahelveticab.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freeserif.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/cid0ct.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonobi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfahelveticai.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/times.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifbi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/kozgopromedium.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedbi.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifb.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusans.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifb.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfatimesbi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/courierb.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedbi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfazapfdingbats.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmono.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfahelveticabi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonoi.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifbi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensed.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/aealarabiya.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfacourier.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/freemonobi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/helveticai.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/freesansb.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfatimesb.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freemonob.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansb.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/symbol.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansbi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedbi.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensedb.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifb.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfatimesi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansmonob.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusanscondensed.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfahelvetica.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfatimes.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/pdfatimesi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavusansb.ctg.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freemonob.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/dejavuserifcondensedbi.php
-webserverextensions/www/fusion/lib/tcpdf/fonts/freeserif.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freesansi.z
-webserverextensions/www/fusion/lib/tcpdf/fonts/freeserifi.z
-webserverextensions/www/fusion/lib/tcpdf/barcodes.php
-webserverextensions/www/fusion/lib/tcpdf/tcpdf_filters.php
-webserverextensions/www/fusion/lib/tcpdf/pdf417.php
-webserverextensions/www/fusion/lib/tcpdf/images/
-webserverextensions/www/fusion/lib/tcpdf/images/image_with_alpha.png
-webserverextensions/www/fusion/lib/tcpdf/images/tcpdf_signature.png
-webserverextensions/www/fusion/lib/tcpdf/images/logo_example.gif
-webserverextensions/www/fusion/lib/tcpdf/images/bug.eps
-webserverextensions/www/fusion/lib/tcpdf/images/image_demo.jpg
-webserverextensions/www/fusion/lib/tcpdf/images/testsvg.svg
-webserverextensions/www/fusion/lib/tcpdf/images/tux.svg
-webserverextensions/www/fusion/lib/tcpdf/images/pelican.ai
-webserverextensions/www/fusion/lib/tcpdf/images/logo_example.jpg
-webserverextensions/www/fusion/lib/tcpdf/images/tiger.ai
-webserverextensions/www/fusion/lib/tcpdf/images/img.png
-webserverextensions/www/fusion/lib/tcpdf/images/tcpdf_logo.jpg
-webserverextensions/www/fusion/lib/tcpdf/images/alpha.png
-webserverextensions/www/fusion/lib/tcpdf/images/tcpdf_cell.png
-webserverextensions/www/fusion/lib/tcpdf/images/logo_example.png
-webserverextensions/www/fusion/lib/tcpdf/images/_blank.png
-webserverextensions/www/fusion/lib/tcpdf/tcpdf.crt
-webserverextensions/www/fusion/lib/Map.js
-webserverextensions/www/fusion/lib/jxLib/
-webserverextensions/www/fusion/lib/jxLib/themes/
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/ie6.css
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/ie7.css
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/jxtheme.css
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tabbar_bottom.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/notice_warning.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tab_right.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/spinner_16.gif
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tabbar_left.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/notice_success.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/notice_error.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tabbar.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/panel_controls.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/dialog_resize.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tab_close.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/dialog_chrome.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tree_vert_line.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tab_top.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/spinner_24.gif
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/button_combo.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tab_bottom.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/flyout_chrome.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/button_multi_disclose.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/loading.gif
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/panelbar.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/button_multi.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/toolbar_separator_v.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/button.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/notice.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/icons.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/table_col.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/grid.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/toolbar.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/toolbar_separator_h.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/listitem.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/menuitem.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tabbar_right.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/table_row.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tree_hover.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/emblems.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tree.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/a_pixel.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/progressbar.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/images/tab_left.png
-webserverextensions/www/fusion/lib/jxLib/themes/delicious/jxtheme.uncompressed.css
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/ie6.css
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/ie7.css
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/jxtheme.css
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tabbar_bottom.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/notice_warning.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tab_right.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/spinner_16.gif
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tabbar_left.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/notice_success.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/notice_error.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tabbar.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/panel_controls.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/dialog_resize.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tab_close.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/dialog_chrome.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tree_vert_line.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tab_top.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/spinner_24.gif
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/button_combo.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tab_bottom.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/flyout_chrome.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/button_multi_disclose.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/loading.gif
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/panelbar.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/button_multi.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/toolbar_separator_v.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/button.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/notice.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/icons.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/table_col.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/grid.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/toolbar.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/toolbar_separator_h.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/listitem.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/menuitem.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tabbar_right.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/table_row.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tree_hover.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/emblems.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tree.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/a_pixel.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/progressbar.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/images/tab_left.png
-webserverextensions/www/fusion/lib/jxLib/themes/crispin/jxtheme.uncompressed.css
-webserverextensions/www/fusion/lib/jxLib/jxlib.uncompressed.js
-webserverextensions/www/fusion/lib/Search.js
-webserverextensions/www/fusion/lib/SymbolLayer.js
-webserverextensions/www/fusion/lib/MapMessage.js
-webserverextensions/www/fusion/lib/fusionSF-compressed.js.map
-webserverextensions/www/fusion/lib/Proj4js/
-webserverextensions/www/fusion/lib/Proj4js/proj4js-combined.js
-webserverextensions/www/fusion/lib/ApplicationDefinition.js
-webserverextensions/www/fusion/lib/excanvas/
-webserverextensions/www/fusion/lib/excanvas/excanvas-compressed.js
-webserverextensions/www/fusion/lib/excanvas/AUTHORS
-webserverextensions/www/fusion/lib/excanvas/excanvas.js
-webserverextensions/www/fusion/lib/excanvas/COPYING
-webserverextensions/www/fusion/lib/excanvas/README
-webserverextensions/www/fusion/lib/SingleFile.js
-webserverextensions/www/fusion/lib/EventMgr.js
-webserverextensions/www/fusion/lib/a_pixel.png
-webserverextensions/www/fusion/config.json
-webserverextensions/www/fusion/common/
-webserverextensions/www/fusion/common/php/
-webserverextensions/www/fusion/common/php/GetLocale.php
-webserverextensions/www/fusion/common/php/Utilities.php
-webserverextensions/www/fusion/common/php/Xml2JSON.php
-webserverextensions/www/fusion/common/browserdetect.js
-webserverextensions/www/fusion/common/mgsamples.css
-webserverextensions/www/fusion/common/images/
-webserverextensions/www/fusion/common/images/loader_inactive.gif
-webserverextensions/www/fusion/common/images/loader_pulse.gif
-webserverextensions/www/fusion/common/json.js
-webserverextensions/www/WEB-INF/
-webserverextensions/www/WEB-INF/lib/
-webserverextensions/www/WEB-INF/lib/commons-fileupload-1.0.jar
-webserverextensions/www/WEB-INF/lib/commons-codec-1.3.jar
-webserverextensions/www/WEB-INF/lib/MapGuideApi.jar
-webserverextensions/www/WEB-INF/lib/MapGuideApi-sources.jar
-webserverextensions/www/WEB-INF/web.xml
-webserverextensions/www/phpsamples/
-webserverextensions/www/phpsamples/hello_map/
-webserverextensions/www/phpsamples/hello_map/task_pane.php
-webserverextensions/www/phpsamples/hello_map/display_spatial_reference.php
-webserverextensions/www/phpsamples/modifying_maps_and_layers/
-webserverextensions/www/phpsamples/modifying_maps_and_layers/create_new_line_layer_definition.php
-webserverextensions/www/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php
-webserverextensions/www/phpsamples/modifying_maps_and_layers/RecentlyBuilt.LayerDefinition
-webserverextensions/www/phpsamples/modifying_maps_and_layers/layer_functions.php
-webserverextensions/www/phpsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.php
-webserverextensions/www/phpsamples/modifying_maps_and_layers/task_pane.php
-webserverextensions/www/phpsamples/modifying_maps_and_layers/maindwf.php
-webserverextensions/www/phpsamples/modifying_maps_and_layers/create_new_point_layer_definition.php
-webserverextensions/www/phpsamples/styles/
-webserverextensions/www/phpsamples/styles/globalStyles.css
-webserverextensions/www/phpsamples/styles/otherStyles.css
-webserverextensions/www/phpsamples/WebLayout.xml
-webserverextensions/www/phpsamples/main.php
-webserverextensions/www/phpsamples/analyzing_features/
-webserverextensions/www/phpsamples/analyzing_features/bufferlayerdefinition.xml
-webserverextensions/www/phpsamples/analyzing_features/bufferfunctions.php
-webserverextensions/www/phpsamples/analyzing_features/task_pane.php
-webserverextensions/www/phpsamples/analyzing_features/selectfeaturesinbuffer.php
-webserverextensions/www/phpsamples/analyzing_features/parcelmarker.xml
-webserverextensions/www/phpsamples/analyzing_features/createbuffer.php
-webserverextensions/www/phpsamples/custom_output/
-webserverextensions/www/phpsamples/custom_output/eplot.php
-webserverextensions/www/phpsamples/custom_output/createmapimage.php
-webserverextensions/www/phpsamples/custom_output/multiplot.php
-webserverextensions/www/phpsamples/custom_output/property_report.php
-webserverextensions/www/phpsamples/custom_output/task_pane.php
-webserverextensions/www/phpsamples/interacting_with_layers/
-webserverextensions/www/phpsamples/interacting_with_layers/task_pane.php
-webserverextensions/www/phpsamples/interacting_with_layers/toggle_roads_label.php
-webserverextensions/www/phpsamples/interacting_with_layers/layer_visibility.php
-webserverextensions/www/phpsamples/readme.txt
-webserverextensions/www/phpsamples/common/
-webserverextensions/www/phpsamples/common/viewsource.php
-webserverextensions/www/phpsamples/common/layerdefinitionfactory.php
-webserverextensions/www/phpsamples/common/title.php
-webserverextensions/www/phpsamples/common/common.php
-webserverextensions/www/phpsamples/common/pageLoadFunctions.js
-webserverextensions/www/phpsamples/common/SymbolDefinition-1.1.0.xsd
-webserverextensions/www/phpsamples/common/LayerDefinition-1.3.0.xsd
-webserverextensions/www/phpsamples/common/PlatformCommon-1.0.0.xsd
-webserverextensions/www/phpsamples/viewerfiles/
-webserverextensions/www/phpsamples/viewerfiles/marksymbol.templ
-webserverextensions/www/phpsamples/viewerfiles/layerdefinition.templ
-webserverextensions/www/phpsamples/viewerfiles/linerule.templ
-webserverextensions/www/phpsamples/viewerfiles/pointrule.templ
-webserverextensions/www/phpsamples/viewerfiles/arearule.templ
-webserverextensions/www/phpsamples/viewerfiles/linetypestyle.templ
-webserverextensions/www/phpsamples/viewerfiles/textsymbol.templ
-webserverextensions/www/phpsamples/viewerfiles/areatypestyle.templ
-webserverextensions/www/phpsamples/viewerfiles/pointtypestyle.templ
-webserverextensions/www/phpsamples/viewerfiles/scalerange.templ
-webserverextensions/www/phpsamples/digitizing_features/
-webserverextensions/www/phpsamples/digitizing_features/draw_line.php
-webserverextensions/www/phpsamples/digitizing_features/clear_lines.php
-webserverextensions/www/phpsamples/digitizing_features/task_pane_redlining.php
-webserverextensions/www/phpsamples/digitizing_features/task_pane.php
-webserverextensions/www/phpsamples/digitizing_features/task_pane_digitizing.php
-webserverextensions/www/phpsamples/hello_viewer/
-webserverextensions/www/phpsamples/hello_viewer/gotopoint.php
-webserverextensions/www/phpsamples/hello_viewer/task_pane.php
-webserverextensions/www/phpsamples/images/
-webserverextensions/www/phpsamples/images/banner.jpg
-webserverextensions/www/phpsamples/index.php
-webserverextensions/www/phpsamples/working_with_feature_data/
-webserverextensions/www/phpsamples/working_with_feature_data/selectfeatures.php
-webserverextensions/www/phpsamples/working_with_feature_data/queryfeatures.php
-webserverextensions/www/phpsamples/working_with_feature_data/listselection.php
-webserverextensions/www/phpsamples/working_with_feature_data/task_pane.php
-webserverextensions/www/TempDir/
-webserverextensions/www/mapviewerphp/
-webserverextensions/www/mapviewerphp/ajaxviewer.php
-webserverextensions/www/mapviewerphp/taskbar.php
-webserverextensions/www/mapviewerphp/buffer.php
-webserverextensions/www/mapviewerphp/mapagentcapture.php
-webserverextensions/www/mapviewerphp/propertyctrl.php
-webserverextensions/www/mapviewerphp/gettingstarted.php
-webserverextensions/www/mapviewerphp/bufferui.php
-webserverextensions/www/mapviewerphp/mainframe.php
-webserverextensions/www/mapviewerphp/taskframe.php
-webserverextensions/www/mapviewerphp/debugconsole.php
-webserverextensions/www/mapviewerphp/templates/
-webserverextensions/www/mapviewerphp/templates/regress.xml
-webserverextensions/www/mapviewerphp/templates/1.0.0.xml
-webserverextensions/www/mapviewerphp/templates/1.1.1.xml
-webserverextensions/www/mapviewerphp/templates/1.1.0.xml
-webserverextensions/www/mapviewerphp/layerdefinitionfactory.php
-webserverextensions/www/mapviewerphp/viewoptions.php
-webserverextensions/www/mapviewerphp/search.php
-webserverextensions/www/mapviewerphp/ajaxviewerabout.php
-webserverextensions/www/mapviewerphp/colorpicker.php
-webserverextensions/www/mapviewerphp/capturerequest.php
-webserverextensions/www/mapviewerphp/common.php
-webserverextensions/www/mapviewerphp/toolbar.php
-webserverextensions/www/mapviewerphp/selectwithin.php
-webserverextensions/www/mapviewerphp/selectwithinui.php
-webserverextensions/www/mapviewerphp/quickplotpreviewinner.php
-webserverextensions/www/mapviewerphp/mapframe.php
-webserverextensions/www/mapviewerphp/formframe.php
-webserverextensions/www/mapviewerphp/measureui.php
-webserverextensions/www/mapviewerphp/serveradminhelper.php
-webserverextensions/www/mapviewerphp/legend.php
-webserverextensions/www/mapviewerphp/legendui.php
-webserverextensions/www/mapviewerphp/createlayer.php
-webserverextensions/www/mapviewerphp/statusbar.php
-webserverextensions/www/mapviewerphp/searchprompt.php
-webserverextensions/www/mapviewerphp/measure.php
-webserverextensions/www/mapviewerphp/tasklist.php
-webserverextensions/www/mapviewerphp/product.php
-webserverextensions/www/mapviewerphp/legendctrl.php
-webserverextensions/www/mapviewerphp/quickplotpanel.php
-webserverextensions/www/mapviewerphp/quickplotgeneratepicture.php
-webserverextensions/www/schemareport/
-webserverextensions/www/schemareport/showgeom.php
-webserverextensions/www/schemareport/displayschema.xsl
-webserverextensions/www/schemareport/weblayoutfactory.php
-webserverextensions/www/schemareport/layerdefinitionfactory.php
-webserverextensions/www/schemareport/templatefiles/
-webserverextensions/www/schemareport/templatefiles/layerdefinition.templ
-webserverextensions/www/schemareport/templatefiles/linerule.templ
-webserverextensions/www/schemareport/templatefiles/pointrule.templ
-webserverextensions/www/schemareport/templatefiles/mapdefinition.templ
-webserverextensions/www/schemareport/templatefiles/arearule.templ
-webserverextensions/www/schemareport/templatefiles/linetypestyle.templ
-webserverextensions/www/schemareport/templatefiles/areatypestyle.templ
-webserverextensions/www/schemareport/templatefiles/weblayout.templ
-webserverextensions/www/schemareport/templatefiles/textwatermark.templ
-webserverextensions/www/schemareport/templatefiles/extents.templ
-webserverextensions/www/schemareport/templatefiles/flexweblayout.templ
-webserverextensions/www/schemareport/templatefiles/maplayergroup.templ
-webserverextensions/www/schemareport/templatefiles/pointtypestyle.templ
-webserverextensions/www/schemareport/templatefiles/maplayer.templ
-webserverextensions/www/schemareport/templatefiles/scalerange.templ
-webserverextensions/www/schemareport/main.php
-webserverextensions/www/schemareport/displayschemafunctions.php
-webserverextensions/www/schemareport/blank.php
-webserverextensions/www/schemareport/displayschema.php
-webserverextensions/www/schemareport/mapdefinitionfactory.php
-webserverextensions/www/schemareport/describeschema.php
-webserverextensions/www/schemareport/displayschema.css
-webserverextensions/www/schemareport/images/
-webserverextensions/www/schemareport/images/expand_pane.png
-webserverextensions/www/schemareport/images/collapse_pane.png
-webserverextensions/www/schemareport/stringconstants.php
-webserverextensions/www/schemareport/showclass.php
+webserverextensions/www/fusion/text/
+webserverextensions/www/fusion/text/en
+webserverextensions/www/fusion/text/en.json
+webserverextensions/www/fusion/text/fr
+webserverextensions/www/fusion/text/fr.json
+webserverextensions/www/fusion/widgets/
+webserverextensions/www/fusion/widgets/About.js
+webserverextensions/www/fusion/widgets/About/
+webserverextensions/www/fusion/widgets/About/About.html
+webserverextensions/www/fusion/widgets/ActivityIndicator.js
+webserverextensions/www/fusion/widgets/AddWMSLayer.js
+webserverextensions/www/fusion/widgets/AddWMSLayer/
+webserverextensions/www/fusion/widgets/AddWMSLayer/AddWMSLayer.css
+webserverextensions/www/fusion/widgets/AddWMSLayer/AddWMSLayer.html
+webserverextensions/www/fusion/widgets/AddWMSLayer/AddWMSLayer.php
+webserverextensions/www/fusion/widgets/AddWMSLayer/wms-parser.php
+webserverextensions/www/fusion/widgets/BasemapSwitcher.js
+webserverextensions/www/fusion/widgets/Buffer.js
+webserverextensions/www/fusion/widgets/BufferPanel.js
+webserverextensions/www/fusion/widgets/BufferPanel/
+webserverextensions/www/fusion/widgets/BufferPanel/AreaLayerDef.templ
+webserverextensions/www/fusion/widgets/BufferPanel/Buffer.php
+webserverextensions/www/fusion/widgets/BufferPanel/BufferPanel.php
+webserverextensions/www/fusion/widgets/BufferPanel/BufferPanel.templ
+webserverextensions/www/fusion/widgets/BufferPanel/BufferReport.templ
+webserverextensions/www/fusion/widgets/BufferPanel/ColorPicker.php
+webserverextensions/www/fusion/widgets/BufferPanel/ColorPicker.templ
+webserverextensions/www/fusion/widgets/BufferPanel/ErrorPage.templ
+webserverextensions/www/fusion/widgets/BufferPanel/Viewer.css
+webserverextensions/www/fusion/widgets/BufferPanel/cp_arr.gif
+webserverextensions/www/fusion/widgets/BufferPanel/cp_arr_dis.gif
+webserverextensions/www/fusion/widgets/CenterSelection.js
+webserverextensions/www/fusion/widgets/ClearSelection.js
+webserverextensions/www/fusion/widgets/ColorPicker.js
+webserverextensions/www/fusion/widgets/CoordinateTracker.js
+webserverextensions/www/fusion/widgets/CoordinateTracker/
+webserverextensions/www/fusion/widgets/CoordinateTracker/CoordinateTracker.css
+webserverextensions/www/fusion/widgets/CoordinateTracker/CoordinateTracker.php
+webserverextensions/www/fusion/widgets/CursorPosition.js
+webserverextensions/www/fusion/widgets/CursorPosition/
+webserverextensions/www/fusion/widgets/CursorPosition/CursorPosition.css
+webserverextensions/www/fusion/widgets/EditableScale.js
+webserverextensions/www/fusion/widgets/EditableScale/
+webserverextensions/www/fusion/widgets/EditableScale/EditableScale.css
+webserverextensions/www/fusion/widgets/ExtentHistory.js
+webserverextensions/www/fusion/widgets/FeatureInfo.js
+webserverextensions/www/fusion/widgets/FeatureInfo/
+webserverextensions/www/fusion/widgets/FeatureInfo/classes/
+webserverextensions/www/fusion/widgets/FeatureInfo/classes/feature.php
+webserverextensions/www/fusion/widgets/FeatureInfo/classes/featureinfo.php
+webserverextensions/www/fusion/widgets/FeatureInfo/classes/property.php
+webserverextensions/www/fusion/widgets/FeatureInfo/featureinfocontroller.php
+webserverextensions/www/fusion/widgets/FeatureInfo/featureinfomain.php
+webserverextensions/www/fusion/widgets/Geolocation.js
+webserverextensions/www/fusion/widgets/GetFeatureInfo.js
+webserverextensions/www/fusion/widgets/GoogleStreetViewer.js
+webserverextensions/www/fusion/widgets/GoogleStreetViewer/
+webserverextensions/www/fusion/widgets/GoogleStreetViewer/GoogleStreetView.php
+webserverextensions/www/fusion/widgets/GoogleStreetViewer/GoogleStreetView.png
+webserverextensions/www/fusion/widgets/GoogleStreetViewer/GoogleStreetView.templ
+webserverextensions/www/fusion/widgets/GoogleStreetViewer/navigator.png
+webserverextensions/www/fusion/widgets/Help.js
+webserverextensions/www/fusion/widgets/Help/
+webserverextensions/www/fusion/widgets/Help/Help.html
+webserverextensions/www/fusion/widgets/InitialMapView.js
+webserverextensions/www/fusion/widgets/InvokeScript.js
+webserverextensions/www/fusion/widgets/InvokeURL.js
+webserverextensions/www/fusion/widgets/LayerManager.js
+webserverextensions/www/fusion/widgets/LayerManager/
+webserverextensions/www/fusion/widgets/LayerManager/LayerManager.css
+webserverextensions/www/fusion/widgets/Legend.js
+webserverextensions/www/fusion/widgets/Legend/
+webserverextensions/www/fusion/widgets/Legend/Legend.css
+webserverextensions/www/fusion/widgets/LinkToView.js
+webserverextensions/www/fusion/widgets/LinkToView/
+webserverextensions/www/fusion/widgets/LinkToView/LinkToView.css
+webserverextensions/www/fusion/widgets/MapMenu.js
+webserverextensions/www/fusion/widgets/MapMetadata.js
+webserverextensions/www/fusion/widgets/MapWidget/
+webserverextensions/www/fusion/widgets/MapWidget/MapWidget.css
+webserverextensions/www/fusion/widgets/Maptip.js
+webserverextensions/www/fusion/widgets/Maptip/
+webserverextensions/www/fusion/widgets/Maptip/Maptip.css
+webserverextensions/www/fusion/widgets/Measure.js
+webserverextensions/www/fusion/widgets/Measure/
+webserverextensions/www/fusion/widgets/Measure/Measure.css
+webserverextensions/www/fusion/widgets/Measure/Measure.php
+webserverextensions/www/fusion/widgets/Measure/MeasurePending.gif
+webserverextensions/www/fusion/widgets/Navigator.js
+webserverextensions/www/fusion/widgets/Navigator/
+webserverextensions/www/fusion/widgets/Navigator/slider.png
+webserverextensions/www/fusion/widgets/Navigator/sliderscale.png
+webserverextensions/www/fusion/widgets/Navigator/spinner.gif
+webserverextensions/www/fusion/widgets/OverviewMap.js
+webserverextensions/www/fusion/widgets/OverviewMap/
+webserverextensions/www/fusion/widgets/OverviewMap/OverviewMap.css
+webserverextensions/www/fusion/widgets/OverviewMap/blank.gif
+webserverextensions/www/fusion/widgets/Pan.js
+webserverextensions/www/fusion/widgets/PanOnClick.js
+webserverextensions/www/fusion/widgets/PanQuery.js
+webserverextensions/www/fusion/widgets/Print.js
+webserverextensions/www/fusion/widgets/Print/
+webserverextensions/www/fusion/widgets/Print/Print.css
+webserverextensions/www/fusion/widgets/Print/pr_north.gif
+webserverextensions/www/fusion/widgets/Print/printablepage.php
+webserverextensions/www/fusion/widgets/Print/printablepage.templ
+webserverextensions/www/fusion/widgets/Query.js
+webserverextensions/www/fusion/widgets/Query/
+webserverextensions/www/fusion/widgets/Query/classes/
+webserverextensions/www/fusion/widgets/Query/classes/feature.php
+webserverextensions/www/fusion/widgets/Query/classes/property.php
+webserverextensions/www/fusion/widgets/Query/classes/query.php
+webserverextensions/www/fusion/widgets/Query/querycontroller.php
+webserverextensions/www/fusion/widgets/Query/querymain.php
+webserverextensions/www/fusion/widgets/Query/templates/
+webserverextensions/www/fusion/widgets/Query/templates/filterlayerdefinition.xml
+webserverextensions/www/fusion/widgets/QuickPlot.js
+webserverextensions/www/fusion/widgets/QuickPlot/
+webserverextensions/www/fusion/widgets/QuickPlot/GenerateLegend.php
+webserverextensions/www/fusion/widgets/QuickPlot/GeneratePicture.php
+webserverextensions/www/fusion/widgets/QuickPlot/MapCapturer.js
+webserverextensions/www/fusion/widgets/QuickPlot/PlotAsPDF.php
+webserverextensions/www/fusion/widgets/QuickPlot/QuickPlotPanel.js
+webserverextensions/www/fusion/widgets/QuickPlot/QuickPlotPanel.php
+webserverextensions/www/fusion/widgets/QuickPlot/QuickPlotPanel.templ
+webserverextensions/www/fusion/widgets/QuickPlot/lc_group.gif
+webserverextensions/www/fusion/widgets/QuickPlot/legend-DWF.png
+webserverextensions/www/fusion/widgets/QuickPlot/legend-raster.png
+webserverextensions/www/fusion/widgets/QuickPlot/legend-theme.png
+webserverextensions/www/fusion/widgets/QuickPlot/north_arrow.png
+webserverextensions/www/fusion/widgets/QuickPlot/pixel.gif
+webserverextensions/www/fusion/widgets/QuickPlot/rotate.cur
+webserverextensions/www/fusion/widgets/Redline.js
+webserverextensions/www/fusion/widgets/Redline/
+webserverextensions/www/fusion/widgets/Redline/Redline.css
+webserverextensions/www/fusion/widgets/Redline/classes/
+webserverextensions/www/fusion/widgets/Redline/classes/defaultstyle.php
+webserverextensions/www/fusion/widgets/Redline/classes/editcommand.php
+webserverextensions/www/fusion/widgets/Redline/classes/markupcommand.php
+webserverextensions/www/fusion/widgets/Redline/classes/markupeditor.php
+webserverextensions/www/fusion/widgets/Redline/classes/markupmanager.php
+webserverextensions/www/fusion/widgets/Redline/classes/markupschemafactory.php
+webserverextensions/www/fusion/widgets/Redline/editmarkup.php
+webserverextensions/www/fusion/widgets/Redline/editmarkupstyle.php
+webserverextensions/www/fusion/widgets/Redline/getselectionxml.php
+webserverextensions/www/fusion/widgets/Redline/markupmain.php
+webserverextensions/www/fusion/widgets/Redline/newmarkup.php
+webserverextensions/www/fusion/widgets/Redline/styles/
+webserverextensions/www/fusion/widgets/Redline/templates/
+webserverextensions/www/fusion/widgets/Redline/templates/area_box.templ
+webserverextensions/www/fusion/widgets/Redline/templates/area_cross.templ
+webserverextensions/www/fusion/widgets/Redline/templates/area_dash.templ
+webserverextensions/www/fusion/widgets/Redline/templates/area_dolmit.templ
+webserverextensions/www/fusion/widgets/Redline/templates/area_hex.templ
+webserverextensions/www/fusion/widgets/Redline/templates/area_line.templ
+webserverextensions/www/fusion/widgets/Redline/templates/area_line_135.templ
+webserverextensions/www/fusion/widgets/Redline/templates/area_line_45.templ
+webserverextensions/www/fusion/widgets/Redline/templates/area_line_90.templ
+webserverextensions/www/fusion/widgets/Redline/templates/area_net.templ
+webserverextensions/www/fusion/widgets/Redline/templates/area_sacncr.templ
+webserverextensions/www/fusion/widgets/Redline/templates/area_solid.templ
+webserverextensions/www/fusion/widgets/Redline/templates/area_square.templ
+webserverextensions/www/fusion/widgets/Redline/templates/area_steel.templ
+webserverextensions/www/fusion/widgets/Redline/templates/line_border.templ
+webserverextensions/www/fusion/widgets/Redline/templates/line_dash.templ
+webserverextensions/www/fusion/widgets/Redline/templates/line_dashdot.templ
+webserverextensions/www/fusion/widgets/Redline/templates/line_dashdotdot.templ
+webserverextensions/www/fusion/widgets/Redline/templates/line_divide.templ
+webserverextensions/www/fusion/widgets/Redline/templates/line_dot.templ
+webserverextensions/www/fusion/widgets/Redline/templates/line_fenceline1.templ
+webserverextensions/www/fusion/widgets/Redline/templates/line_rail.templ
+webserverextensions/www/fusion/widgets/Redline/templates/line_solid.templ
+webserverextensions/www/fusion/widgets/Redline/templates/markupfeaturesource.xml
+webserverextensions/www/fusion/widgets/Redline/templates/markuplayerdefinition.xml
+webserverextensions/www/fusion/widgets/Redline/templates/markuplayerdefinition_advanced.xml
+webserverextensions/www/fusion/widgets/Redline/uploadmarkup.php
+webserverextensions/www/fusion/widgets/RefreshMap.js
+webserverextensions/www/fusion/widgets/SaveMap.js
+webserverextensions/www/fusion/widgets/SaveMapImage.js
+webserverextensions/www/fusion/widgets/SaveSession.js
+webserverextensions/www/fusion/widgets/Scalebar.js
+webserverextensions/www/fusion/widgets/ScalebarDual.js
+webserverextensions/www/fusion/widgets/ScalebarDual/
+webserverextensions/www/fusion/widgets/ScalebarDual/ScalebarDual.css
+webserverextensions/www/fusion/widgets/Search.js
+webserverextensions/www/fusion/widgets/Search/
+webserverextensions/www/fusion/widgets/Search/ErrorPage.templ
+webserverextensions/www/fusion/widgets/Search/Search.php
+webserverextensions/www/fusion/widgets/Search/Search.templ
+webserverextensions/www/fusion/widgets/Search/SearchPrompt.php
+webserverextensions/www/fusion/widgets/Search/SearchPrompt.templ
+webserverextensions/www/fusion/widgets/Search/Viewer.css
+webserverextensions/www/fusion/widgets/Select.js
+webserverextensions/www/fusion/widgets/SelectAttribute.js
+webserverextensions/www/fusion/widgets/SelectPolygon.js
+webserverextensions/www/fusion/widgets/SelectRadius.js
+webserverextensions/www/fusion/widgets/SelectRadiusValue.js
+webserverextensions/www/fusion/widgets/SelectWithin.js
+webserverextensions/www/fusion/widgets/SelectWithin/
+webserverextensions/www/fusion/widgets/SelectWithin/SelectWithin.php
+webserverextensions/www/fusion/widgets/SelectWithin/SelectWithinPanel.php
+webserverextensions/www/fusion/widgets/SelectWithin/SelectWithinPanel.templ
+webserverextensions/www/fusion/widgets/SelectWithin/Viewer.css
+webserverextensions/www/fusion/widgets/SelectionInfo.js
+webserverextensions/www/fusion/widgets/SelectionInfo/
+webserverextensions/www/fusion/widgets/SelectionInfo/SelectionInfo.css
+webserverextensions/www/fusion/widgets/SelectionPanel.js
+webserverextensions/www/fusion/widgets/SelectionPanel/
+webserverextensions/www/fusion/widgets/SelectionPanel/SelectionPanel.css
+webserverextensions/www/fusion/widgets/TaskPane.js
+webserverextensions/www/fusion/widgets/TaskPane/
+webserverextensions/www/fusion/widgets/TaskPane/TaskPane.css
+webserverextensions/www/fusion/widgets/TaskPane/TaskPane.html
+webserverextensions/www/fusion/widgets/TaskPane/taskpane.png
+webserverextensions/www/fusion/widgets/Theme.js
+webserverextensions/www/fusion/widgets/Theme/
+webserverextensions/www/fusion/widgets/Theme/classes/
+webserverextensions/www/fusion/widgets/Theme/classes/layerinfo.php
+webserverextensions/www/fusion/widgets/Theme/classes/property.php
+webserverextensions/www/fusion/widgets/Theme/classes/theme.php
+webserverextensions/www/fusion/widgets/Theme/templates/
+webserverextensions/www/fusion/widgets/Theme/templates/arearuletemplate-1.0.0.xml
+webserverextensions/www/fusion/widgets/Theme/templates/arearuletemplate-1.1.0.xml
+webserverextensions/www/fusion/widgets/Theme/templates/arearuletemplate-1.2.0.xml
+webserverextensions/www/fusion/widgets/Theme/templates/arearuletemplate-1.3.0.xml
+webserverextensions/www/fusion/widgets/Theme/templates/arearuletemplate-2.3.0-Enhanced.xml
+webserverextensions/www/fusion/widgets/Theme/templates/arearuletemplate-2.3.0.xml
+webserverextensions/www/fusion/widgets/Theme/templates/arearuletemplate-2.4.0-Enhanced.xml
+webserverextensions/www/fusion/widgets/Theme/templates/arearuletemplate-2.4.0.xml
+webserverextensions/www/fusion/widgets/Theme/themecontroller.php
+webserverextensions/www/fusion/widgets/Theme/thememain.php
+webserverextensions/www/fusion/widgets/ViewOptions.js
+webserverextensions/www/fusion/widgets/ViewSize.js
+webserverextensions/www/fusion/widgets/ViewSize/
+webserverextensions/www/fusion/widgets/ViewSize/ViewSize.css
+webserverextensions/www/fusion/widgets/Zoom.js
+webserverextensions/www/fusion/widgets/ZoomOnClick.js
+webserverextensions/www/fusion/widgets/ZoomToSelection.js
+webserverextensions/www/fusion/widgets/scalebar/
+webserverextensions/www/fusion/widgets/scalebar/fancy-bar-alt.gif
+webserverextensions/www/fusion/widgets/scalebar/fancy-bar.gif
+webserverextensions/www/fusion/widgets/scalebar/license.txt
+webserverextensions/www/fusion/widgets/scalebar/scalebar-fancy.css
+webserverextensions/www/fusion/widgets/scalebar/scalebar-fat.css
+webserverextensions/www/fusion/widgets/scalebar/scalebar-thin.css
+webserverextensions/www/fusion/widgets/scalebar/scalebar-thinner.css
+webserverextensions/www/fusion/widgets/scalebar/scalebartool.js
+webserverextensions/www/fusion/widgets/widgetinfo/
+webserverextensions/www/fusion/widgets/widgetinfo/GoogleStreetViewer.xml
+webserverextensions/www/fusion/widgets/widgetinfo/WidgetInfoTemplate.xml
+webserverextensions/www/fusion/widgets/widgetinfo/about.xml
+webserverextensions/www/fusion/widgets/widgetinfo/activityindicator.xml
+webserverextensions/www/fusion/widgets/widgetinfo/basemapswitcher.xml
+webserverextensions/www/fusion/widgets/widgetinfo/buffer.xml
+webserverextensions/www/fusion/widgets/widgetinfo/bufferpanel.xml
+webserverextensions/www/fusion/widgets/widgetinfo/centerselection.xml
+webserverextensions/www/fusion/widgets/widgetinfo/clearselection.xml
+webserverextensions/www/fusion/widgets/widgetinfo/colorpicker.xml
+webserverextensions/www/fusion/widgets/widgetinfo/coordinatetracker.xml
+webserverextensions/www/fusion/widgets/widgetinfo/cursorposition.xml
+webserverextensions/www/fusion/widgets/widgetinfo/editablescale.xml
+webserverextensions/www/fusion/widgets/widgetinfo/extenthistory.xml
+webserverextensions/www/fusion/widgets/widgetinfo/featureinfo.xml
+webserverextensions/www/fusion/widgets/widgetinfo/geolocation.xml
+webserverextensions/www/fusion/widgets/widgetinfo/help.xml
+webserverextensions/www/fusion/widgets/widgetinfo/initialmapview.xml
+webserverextensions/www/fusion/widgets/widgetinfo/invokescript.xml
+webserverextensions/www/fusion/widgets/widgetinfo/invokeurl.xml
+webserverextensions/www/fusion/widgets/widgetinfo/legend.xml
+webserverextensions/www/fusion/widgets/widgetinfo/linktoview.xml
+webserverextensions/www/fusion/widgets/widgetinfo/mapmenu.xml
+webserverextensions/www/fusion/widgets/widgetinfo/maptip.xml
+webserverextensions/www/fusion/widgets/widgetinfo/measure.xml
+webserverextensions/www/fusion/widgets/widgetinfo/navigator.xml
+webserverextensions/www/fusion/widgets/widgetinfo/overviewmap.xml
+webserverextensions/www/fusion/widgets/widgetinfo/pan.xml
+webserverextensions/www/fusion/widgets/widgetinfo/panonclick.xml
+webserverextensions/www/fusion/widgets/widgetinfo/panquery.xml
+webserverextensions/www/fusion/widgets/widgetinfo/print.xml
+webserverextensions/www/fusion/widgets/widgetinfo/query.xml
+webserverextensions/www/fusion/widgets/widgetinfo/quickplot.xml
+webserverextensions/www/fusion/widgets/widgetinfo/redline.xml
+webserverextensions/www/fusion/widgets/widgetinfo/refreshmap.xml
+webserverextensions/www/fusion/widgets/widgetinfo/savemap.xml
+webserverextensions/www/fusion/widgets/widgetinfo/scalebar.xml
+webserverextensions/www/fusion/widgets/widgetinfo/scalebardual.xml
+webserverextensions/www/fusion/widgets/widgetinfo/search.xml
+webserverextensions/www/fusion/widgets/widgetinfo/select.xml
+webserverextensions/www/fusion/widgets/widgetinfo/selectioninfo.xml
+webserverextensions/www/fusion/widgets/widgetinfo/selectionpanel.xml
+webserverextensions/www/fusion/widgets/widgetinfo/selectpolygon.xml
+webserverextensions/www/fusion/widgets/widgetinfo/selectradius.xml
+webserverextensions/www/fusion/widgets/widgetinfo/selectradiusvalue.xml
+webserverextensions/www/fusion/widgets/widgetinfo/selectwithin.xml
+webserverextensions/www/fusion/widgets/widgetinfo/taskpane.xml
+webserverextensions/www/fusion/widgets/widgetinfo/theme.xml
+webserverextensions/www/fusion/widgets/widgetinfo/viewoptions.xml
+webserverextensions/www/fusion/widgets/widgetinfo/viewsize.xml
+webserverextensions/www/fusion/widgets/widgetinfo/zoom.xml
+webserverextensions/www/fusion/widgets/widgetinfo/zoomonclick.xml
+webserverextensions/www/fusion/widgets/widgetinfo/zoomtoselection.xml
+webserverextensions/www/javasamples/
+webserverextensions/www/javasamples/WebLayout.xml
+webserverextensions/www/javasamples/common/
+webserverextensions/www/javasamples/common/common.jsp
+webserverextensions/www/javasamples/common/pageLoadFunctions.js
+webserverextensions/www/javasamples/common/title.jsp
+webserverextensions/www/javasamples/common/viewsource.php
+webserverextensions/www/javasamples/hello_map/
+webserverextensions/www/javasamples/hello_map/display_spatial_reference.jsp
+webserverextensions/www/javasamples/hello_map/task_pane.jsp
+webserverextensions/www/javasamples/hello_viewer/
+webserverextensions/www/javasamples/hello_viewer/gotopoint.jsp
+webserverextensions/www/javasamples/hello_viewer/task_pane.jsp
+webserverextensions/www/javasamples/images/
+webserverextensions/www/javasamples/images/banner.jpg
+webserverextensions/www/javasamples/index.jsp
+webserverextensions/www/javasamples/interacting_with_layers/
+webserverextensions/www/javasamples/interacting_with_layers/layer_visibility.jsp
+webserverextensions/www/javasamples/interacting_with_layers/task_pane.jsp
+webserverextensions/www/javasamples/interacting_with_layers/toggle_roads_label.jsp
+webserverextensions/www/javasamples/main.jsp
+webserverextensions/www/javasamples/readme.txt
+webserverextensions/www/javasamples/styles/
+webserverextensions/www/javasamples/styles/globalStyles.css
+webserverextensions/www/javasamples/styles/otherStyles.css
+webserverextensions/www/javaviewersample/
+webserverextensions/www/javaviewersample/ReadMe.txt
+webserverextensions/www/javaviewersample/ajaxtiledviewersample.jsp
+webserverextensions/www/javaviewersample/ajaxviewersample.jsp
+webserverextensions/www/javaviewersample/dwfviewersample.jsp
+webserverextensions/www/javaviewersample/findaddress/
+webserverextensions/www/javaviewersample/findaddress/clearaddressresults.jsp
+webserverextensions/www/javaviewersample/findaddress/findaddress.jsp
+webserverextensions/www/javaviewersample/findaddress/findaddressfunctions.jsp
+webserverextensions/www/javaviewersample/findaddress/findaddressmain.jsp
+webserverextensions/www/javaviewersample/findaddress/gotopoint.jsp
+webserverextensions/www/javaviewersample/findaddress/templates/
+webserverextensions/www/javaviewersample/findaddress/templates/addressmarker.xml
+webserverextensions/www/javaviewersample/images/
+webserverextensions/www/javaviewersample/images/Thumbs.db
+webserverextensions/www/javaviewersample/images/loader_inactive.gif
+webserverextensions/www/javaviewersample/images/loader_pulse.gif
+webserverextensions/www/javaviewersample/images/pushpin.jpg
+webserverextensions/www/javaviewersample/images/pushpinblue.jpg
+webserverextensions/www/javaviewersample/json.jar
+webserverextensions/www/javaviewersample/json.js
+webserverextensions/www/javaviewersample/overview/
+webserverextensions/www/javaviewersample/overview/overviewmain.jsp
+webserverextensions/www/javaviewersample/plot/
+webserverextensions/www/javaviewersample/plot/plot.jsp
+webserverextensions/www/javaviewersample/plot/plotmain.jsp
+webserverextensions/www/javaviewersample/query/
+webserverextensions/www/javaviewersample/query/classes/
+webserverextensions/www/javaviewersample/query/classes/command.jsp
+webserverextensions/www/javaviewersample/query/classes/feature.jsp
+webserverextensions/www/javaviewersample/query/classes/property.jsp
+webserverextensions/www/javaviewersample/query/classes/query.jsp
+webserverextensions/www/javaviewersample/query/querycontroller.jsp
+webserverextensions/www/javaviewersample/query/querymain.jsp
+webserverextensions/www/javaviewersample/query/templates/
+webserverextensions/www/javaviewersample/query/templates/filterlayerdefinition.xml
+webserverextensions/www/javaviewersample/styles/
+webserverextensions/www/javaviewersample/styles/gt.css
+webserverextensions/www/javaviewersample/theme/
+webserverextensions/www/javaviewersample/theme/classes/
+webserverextensions/www/javaviewersample/theme/classes/command.jsp
+webserverextensions/www/javaviewersample/theme/classes/layerinfo.jsp
+webserverextensions/www/javaviewersample/theme/classes/property.jsp
+webserverextensions/www/javaviewersample/theme/classes/theme.jsp
+webserverextensions/www/javaviewersample/theme/templates/
+webserverextensions/www/javaviewersample/theme/templates/arearuletemplate.xml
+webserverextensions/www/javaviewersample/theme/themecontroller.jsp
+webserverextensions/www/javaviewersample/theme/thememain.jsp
+webserverextensions/www/javaviewersample/title.html
+webserverextensions/www/javaviewersample/utilityfunctions.jsp
 webserverextensions/www/localized/
+webserverextensions/www/localized/PoweredBy_en.gif
 webserverextensions/www/localized/en
-webserverextensions/www/localized/license_en.htm
 webserverextensions/www/localized/fr
-webserverextensions/www/localized/PoweredBy_en.gif
 webserverextensions/www/localized/help/
 webserverextensions/www/localized/help/en/
+webserverextensions/www/localized/help/en/WS1a9193826455f5ff9110c71085341391d-2b8b.htm
 webserverextensions/www/localized/help/en/WS1a9193826455f5ff9110c71085341391d-2df8.htm
-webserverextensions/www/localized/help/en/WS1a9193826455f5ff9110c71085341391d-2e07.htm
+webserverextensions/www/localized/help/en/WS1a9193826455f5ff9110c71085341391d-2dff.htm
+webserverextensions/www/localized/help/en/WS1a9193826455f5ff9110c71085341391d-2e02.htm
+webserverextensions/www/localized/help/en/WS1a9193826455f5ff9110c71085341391d-2e03.htm
 webserverextensions/www/localized/help/en/WS1a9193826455f5ff9110c71085341391d-2e05.htm
 webserverextensions/www/localized/help/en/WS1a9193826455f5ff9110c71085341391d-2e06.htm
-webserverextensions/www/localized/help/en/style/
-webserverextensions/www/localized/help/en/style/comments-disabled.css
-webserverextensions/www/localized/help/en/style/isd.css
-webserverextensions/www/localized/help/en/style/cpm-gbu.css
-webserverextensions/www/localized/help/en/style/cpm.css
-webserverextensions/www/localized/help/en/style/adsk.cpm.css
-webserverextensions/www/localized/help/en/WSfacf1429558a55def7b6851052968aa39-7848.htm
-webserverextensions/www/localized/help/en/WS1a9193826455f5ff9110c71085341391d-2e02.htm
-webserverextensions/www/localized/help/en/WS1a9193826455f5ff9110c71085341391d-2e03.htm
+webserverextensions/www/localized/help/en/WS1a9193826455f5ff9110c71085341391d-2e07.htm
+webserverextensions/www/localized/help/en/WS1a9193826455f5ff9110c71085341391d-2e28.htm
 webserverextensions/www/localized/help/en/WS1a9193826455f5ff9110c71085341391d-39ab.htm
-webserverextensions/www/localized/help/en/WS1a9193826455f5ff9110c71085341391d-2b8b.htm
-webserverextensions/www/localized/help/en/WSfacf1429558a55def7b6851052968aa39-7847.htm
 webserverextensions/www/localized/help/en/WS1a9193826455f5ff9110c71085341391d-39b4.htm
-webserverextensions/www/localized/help/en/WS1a9193826455f5ff9110c71085341391d-2e28.htm
-webserverextensions/www/localized/help/en/WS1a9193826455f5ff9110c71085341391d-2dff.htm
-webserverextensions/www/localized/help/en/mapguide_viewer_command_list.htm
+webserverextensions/www/localized/help/en/WS73099cc142f487551e5a0cb10850d4cd7c-689b.htm
+webserverextensions/www/localized/help/en/WSfacf1429558a55de2ab0a1008e4bf960-7ff4.htm
 webserverextensions/www/localized/help/en/WSfacf1429558a55def7b6851052968aa39-7843.htm
-webserverextensions/www/localized/help/en/index.htm
+webserverextensions/www/localized/help/en/WSfacf1429558a55def7b6851052968aa39-7847.htm
+webserverextensions/www/localized/help/en/WSfacf1429558a55def7b6851052968aa39-7848.htm
 webserverextensions/www/localized/help/en/WSfacf1429558a55def7b6851052968aa39-7ac3.htm
-webserverextensions/www/localized/help/en/WSfacf1429558a55de2ab0a1008e4bf960-7ff4.htm
 webserverextensions/www/localized/help/en/images/
+webserverextensions/www/localized/help/en/images/ac.down.gif
 webserverextensions/www/localized/help/en/images/ac.right.gif
+webserverextensions/www/localized/help/en/images/head_graphic.gif
 webserverextensions/www/localized/help/en/images/product_name.gif
-webserverextensions/www/localized/help/en/images/ac.down.gif
-webserverextensions/www/localized/help/en/images/head_graphic.gif
-webserverextensions/www/localized/help/en/WS73099cc142f487551e5a0cb10850d4cd7c-689b.htm
-webserverextensions/www/webconfig.ini
-webserverextensions/www/javasamples/
-webserverextensions/www/javasamples/hello_map/
-webserverextensions/www/javasamples/hello_map/display_spatial_reference.jsp
-webserverextensions/www/javasamples/hello_map/task_pane.jsp
-webserverextensions/www/javasamples/index.jsp
-webserverextensions/www/javasamples/styles/
-webserverextensions/www/javasamples/styles/globalStyles.css
-webserverextensions/www/javasamples/styles/otherStyles.css
-webserverextensions/www/javasamples/main.jsp
-webserverextensions/www/javasamples/WebLayout.xml
-webserverextensions/www/javasamples/interacting_with_layers/
-webserverextensions/www/javasamples/interacting_with_layers/layer_visibility.jsp
-webserverextensions/www/javasamples/interacting_with_layers/toggle_roads_label.jsp
-webserverextensions/www/javasamples/interacting_with_layers/task_pane.jsp
-webserverextensions/www/javasamples/readme.txt
-webserverextensions/www/javasamples/common/
-webserverextensions/www/javasamples/common/viewsource.php
-webserverextensions/www/javasamples/common/pageLoadFunctions.js
-webserverextensions/www/javasamples/common/title.jsp
-webserverextensions/www/javasamples/common/common.jsp
-webserverextensions/www/javasamples/hello_viewer/
-webserverextensions/www/javasamples/hello_viewer/gotopoint.jsp
-webserverextensions/www/javasamples/hello_viewer/task_pane.jsp
-webserverextensions/www/javasamples/images/
-webserverextensions/www/javasamples/images/banner.jpg
-webserverextensions/www/mapagent/
-webserverextensions/www/mapagent/describedrawingform.html
-webserverextensions/www/mapagent/getlayerkmlform.html
-webserverextensions/www/mapagent/featureserviceapi.html
-webserverextensions/www/mapagent/wkttoepsgcodeform.html
-webserverextensions/www/mapagent/boundaryform.html
-webserverextensions/www/mapagent/getrepositoryheaderform.html
-webserverextensions/www/mapagent/getclassdefinitionform.html
-webserverextensions/www/mapagent/convexhullform.html
-webserverextensions/www/mapagent/tessellateform.html
-webserverextensions/www/mapagent/getfeaturesetenvelopeform.html
-webserverextensions/www/mapagent/getsiteinfoform.html
-webserverextensions/www/mapagent/getcapabilitiesform.html
-webserverextensions/www/mapagent/deleterepositoryform.html
-webserverextensions/www/mapagent/enumeratewidgetsform.html
-webserverextensions/www/mapagent/dwfviewerform.html
-webserverextensions/www/mapagent/gettileimageform.html
-webserverextensions/www/mapagent/coordinatesystemapi.html
-webserverextensions/www/mapagent/geometryinfoform.html
-webserverextensions/www/mapagent/getmapwmsform.html
-webserverextensions/www/mapagent/setdwfactiontarget.js
-webserverextensions/www/mapagent/enumeratecoordinatesystemsform.html
-webserverextensions/www/mapagent/enumeratetemplatesform.html
-webserverextensions/www/mapagent/selectfeaturesform.html
-webserverextensions/www/mapagent/updaterepositoryform.html
-webserverextensions/www/mapagent/getdrawingsection.html
-webserverextensions/www/mapagent/csepsgcodetowktform.html
-webserverextensions/www/mapagent/setresourceform.html
-webserverextensions/www/mapagent/getcapabilitieswfsform.html
-webserverextensions/www/mapagent/epsgcodetowktform.html
-webserverextensions/www/mapagent/csgetbaselibraryform.html
-webserverextensions/www/mapagent/csenumeratecoordinatesystemsform.html
-webserverextensions/www/mapagent/getlongtransactionsform.html
-webserverextensions/www/mapagent/serveradminserviceapi.html
-webserverextensions/www/mapagent/deleteresourceform.html
-webserverextensions/www/mapagent/createsessionform.html
-webserverextensions/www/mapagent/enumerateresourcereferencesform.html
-webserverextensions/www/mapagent/enumeratedatastoresform.html
-webserverextensions/www/mapagent/getschemasform.html
-webserverextensions/www/mapagent/enumeraterepositoriesform.html
-webserverextensions/www/mapagent/wfsserviceapi.html
-webserverextensions/www/mapagent/checkwktform.html
-webserverextensions/www/mapagent/getresourcedataform.html
-webserverextensions/www/mapagent/getplotform.html
-webserverextensions/www/mapagent/getresourceheaderform.html
-webserverextensions/www/mapagent/getdrawingsectionresource.html
-webserverextensions/www/mapagent/isvalidform.html
-webserverextensions/www/mapagent/siteserviceapi.html
-webserverextensions/www/mapagent/getrepositorycontentform.html
-webserverextensions/www/mapagent/getcapabilitieswmsform.html
-webserverextensions/www/mapagent/codetowktform.html
-webserverextensions/www/mapagent/createrepositoryform.html
-webserverextensions/www/mapagent/getfeatureskmlform.html
-webserverextensions/www/mapagent/testconnectionform.html
-webserverextensions/www/mapagent/getschemamappingform.html
-webserverextensions/www/mapagent/getfdocacheinfoform.html
-webserverextensions/www/mapagent/csenumeratecategoriesform.html
-webserverextensions/www/mapagent/setajaxactiontarget.js
-webserverextensions/www/mapagent/enumeratecontainersform.html
-webserverextensions/www/mapagent/enumeratedrawingsectionresources.html
-webserverextensions/www/mapagent/drawingserviceapi.html
-webserverextensions/www/mapagent/getclassesform.html
-webserverextensions/www/mapagent/getfeatureprovidersform.html
-webserverextensions/www/mapagent/cstransformcoordinatesform.html
-webserverextensions/www/mapagent/describeschemaform.html
-webserverextensions/www/mapagent/mapagent.fcgi
-webserverextensions/www/mapagent/selectaggregatesform.html
-webserverextensions/www/mapagent/enumeratedrawinglayers.html
-webserverextensions/www/mapagent/getdrawingcoordinatespaceform.html
-webserverextensions/www/mapagent/resourceserviceapi.html
-webserverextensions/www/mapagent/geoprocessingapi.html
-webserverextensions/www/mapagent/wkttocodeform.html
-webserverextensions/www/mapagent/enumeratedrawingsections.html
-webserverextensions/www/mapagent/getsessiontimeoutform.html
-webserverextensions/www/mapagent/executesqlqueryform.html
-webserverextensions/www/mapagent/menu.html
-webserverextensions/www/mapagent/enumerateusersform.html
-webserverextensions/www/mapagent/getfeaturewfsform.html
-webserverextensions/www/mapagent/getmapimageform.html
-webserverextensions/www/mapagent/renderingserviceapi.html
-webserverextensions/www/mapagent/enumerateunmanageddataform.html
-webserverextensions/www/mapagent/getmapkmlform.html
-webserverextensions/www/mapagent/webapplicationserviceapi.html
-webserverextensions/www/mapagent/getsitestatusform.html
-webserverextensions/www/mapagent/resourceexistsform.html
-webserverextensions/www/mapagent/getdrawingform.html
-webserverextensions/www/mapagent/bufferform.html
-webserverextensions/www/mapagent/distanceform.html
-webserverextensions/www/mapagent/deleteresourcedataform.html
-webserverextensions/www/mapagent/enumerateresourcesform.html
-webserverextensions/www/mapagent/tileserviceapi.html
-webserverextensions/www/mapagent/setresourcedataform.html
-webserverextensions/www/mapagent/spatialpredicateform.html
-webserverextensions/www/mapagent/gettileimageform2.html
-webserverextensions/www/mapagent/copyresourceform.html
-webserverextensions/www/mapagent/getvisiblemapextentform.html
-webserverextensions/www/mapagent/getconnectpropertyvaluesform.html
-webserverextensions/www/mapagent/kmlserviceapi.html
-webserverextensions/www/mapagent/wmsserviceapi.html
-webserverextensions/www/mapagent/getdefaulttilesizexform.html
-webserverextensions/www/mapagent/mappingserviceapi.html
-webserverextensions/www/mapagent/getdynamicmapoverlayimageform.html
-webserverextensions/www/mapagent/describefeaturetypewfsform.html
-webserverextensions/www/mapagent/gettileprovidersform.html
-webserverextensions/www/mapagent/getfeatureinfowmsform.html
-webserverextensions/www/mapagent/cswkttoepsgcodeform.html
-webserverextensions/www/mapagent/setactiontarget.js
-webserverextensions/www/mapagent/changeresourceownerform.html
-webserverextensions/www/mapagent/enumerateresourcedataform.html
-webserverextensions/www/mapagent/simplifyform.html
-webserverextensions/www/mapagent/getdefaulttilesizeyform.html
-webserverextensions/www/mapagent/renameresourcedataform.html
-webserverextensions/www/mapagent/binaryoperationform.html
-webserverextensions/www/mapagent/ajaxviewerform.html
-webserverextensions/www/mapagent/cleartilecacheform.html
-webserverextensions/www/mapagent/csisvalidform.html
-webserverextensions/www/mapagent/enumerategroupsform.html
-webserverextensions/www/mapagent/getsiteversionform.html
-webserverextensions/www/mapagent/index.html
-webserverextensions/www/mapagent/getidentitypropertiesform.html
-webserverextensions/www/mapagent/services.html
-webserverextensions/www/mapagent/moveresourceform.html
-webserverextensions/www/mapagent/cswkttocodeform.html
-webserverextensions/www/mapagent/applyresourcepackageform.html
-webserverextensions/www/mapagent/getresourcecontentform.html
-webserverextensions/www/mapagent/getdrawinglayerform.html
-webserverextensions/www/mapagent/inheritpermissionsfromform.html
-webserverextensions/www/mapagent/getspatialcontextsform.html
-webserverextensions/www/mapagent/otherapi.html
-webserverextensions/www/mapagent/cscodetowktform.html
+webserverextensions/www/localized/help/en/index.htm
+webserverextensions/www/localized/help/en/mapguide_viewer_command_list.htm
+webserverextensions/www/localized/help/en/style/
+webserverextensions/www/localized/help/en/style/adsk.cpm.css
+webserverextensions/www/localized/help/en/style/comments-disabled.css
+webserverextensions/www/localized/help/en/style/cpm-gbu.css
+webserverextensions/www/localized/help/en/style/cpm.css
+webserverextensions/www/localized/help/en/style/isd.css
+webserverextensions/www/localized/license_en.htm
 webserverextensions/www/mapadmin/
 webserverextensions/www/mapadmin/HelpDocs/
-webserverextensions/www/mapadmin/HelpDocs/configuring_external_files.htm
-webserverextensions/www/mapadmin/HelpDocs/performance_report.htm
-webserverextensions/www/mapadmin/HelpDocs/managing_servers.htm
-webserverextensions/www/mapadmin/HelpDocs/Templates/
-webserverextensions/www/mapadmin/HelpDocs/Templates/ServerAdminHelp with autodesk logo.dwt
-webserverextensions/www/mapadmin/HelpDocs/Templates/serveradminhelp.dwt
-webserverextensions/www/mapadmin/HelpDocs/about_packages.htm
-webserverextensions/www/mapadmin/HelpDocs/adding_users_to_groups.htm
-webserverextensions/www/mapadmin/HelpDocs/about_WFS_WMS.htm
-webserverextensions/www/mapadmin/HelpDocs/managing_groups.htm
-webserverextensions/www/mapadmin/HelpDocs/configuring_services.htm
-webserverextensions/www/mapadmin/HelpDocs/about_services.htm
-webserverextensions/www/mapadmin/HelpDocs/about_users_groups_and_roles.htm
-webserverextensions/www/mapadmin/HelpDocs/about_external_files.htm
-webserverextensions/www/mapadmin/HelpDocs/about_log_files.htm
-webserverextensions/www/mapadmin/HelpDocs/adding_and_deleting_users.htm
-webserverextensions/www/mapadmin/HelpDocs/managing_users.htm
-webserverextensions/www/mapadmin/HelpDocs/configuring_servers.htm
-webserverextensions/www/mapadmin/HelpDocs/monitor_server_status.htm
-webserverextensions/www/mapadmin/HelpDocs/assigning_roles.htm
 webserverextensions/www/mapadmin/HelpDocs/Images/
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_roles_group.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_start.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_users_about.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_status.png
+webserverextensions/www/mapadmin/HelpDocs/Images/banner.jpg
+webserverextensions/www/mapadmin/HelpDocs/Images/logo.gif
+webserverextensions/www/mapadmin/HelpDocs/Images/mapserverenterpriselogo.gif
+webserverextensions/www/mapadmin/HelpDocs/Images/performance_resutls.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_add.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_external_files.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_external_files_config.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_group_user_add.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_groups.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_groups_add.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_groups_remove.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_logs.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_logs_view.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_offline.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_package_about.png
 webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_packages.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_groups_add.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_select_user.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_user_add.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_web_advanced2.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_groups.png
 webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_packages_make.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_support.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_users.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_services_config.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_site_about.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_web.png
 webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_roles.png
-webserverextensions/www/mapadmin/HelpDocs/Images/performance_resutls.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_roles_click.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_roles_group.png
 webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_roles_user.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_user_group.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_groups_remove.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_logs_view.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_select_group.png
 webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_select_server.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_select_user.png
 webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_services.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_select_group.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_logs.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_external_files.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_group_user_add.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_services_config.png
 webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_services_enabl.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_offline.png
 webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_services_enable.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_package_about.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_add.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_site_about.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_start.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_status.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_support.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_user_add.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_user_group.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_users.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_users_about.png
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_web.png
 webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_web_advanced1.png
-webserverextensions/www/mapadmin/HelpDocs/Images/logo.gif
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_roles_click.png
-webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_external_files_config.png
-webserverextensions/www/mapadmin/HelpDocs/Images/banner.jpg
-webserverextensions/www/mapadmin/HelpDocs/Images/mapserverenterpriselogo.gif
-webserverextensions/www/mapadmin/HelpDocs/managing_roles.htm
+webserverextensions/www/mapadmin/HelpDocs/Images/server_admin_web_advanced2.png
+webserverextensions/www/mapadmin/HelpDocs/Templates/
+webserverextensions/www/mapadmin/HelpDocs/Templates/ServerAdminHelp with autodesk logo.dwt
+webserverextensions/www/mapadmin/HelpDocs/Templates/serveradminhelp.dwt
+webserverextensions/www/mapadmin/HelpDocs/about_WFS_WMS.htm
+webserverextensions/www/mapadmin/HelpDocs/about_external_files.htm
+webserverextensions/www/mapadmin/HelpDocs/about_log_files.htm
+webserverextensions/www/mapadmin/HelpDocs/about_packages.htm
+webserverextensions/www/mapadmin/HelpDocs/about_services.htm
+webserverextensions/www/mapadmin/HelpDocs/about_sites_and_servers.htm
+webserverextensions/www/mapadmin/HelpDocs/about_users_groups_and_roles.htm
+webserverextensions/www/mapadmin/HelpDocs/ad_mh.css
+webserverextensions/www/mapadmin/HelpDocs/adding_and_deleting_groups.htm
+webserverextensions/www/mapadmin/HelpDocs/adding_and_deleting_users.htm
+webserverextensions/www/mapadmin/HelpDocs/adding_users_to_groups.htm
+webserverextensions/www/mapadmin/HelpDocs/assigning_roles.htm
 webserverextensions/www/mapadmin/HelpDocs/configuring_and_viewing_logs.htm
-webserverextensions/www/mapadmin/HelpDocs/ad_mh.css
+webserverextensions/www/mapadmin/HelpDocs/configuring_external_files.htm
+webserverextensions/www/mapadmin/HelpDocs/configuring_servers.htm
+webserverextensions/www/mapadmin/HelpDocs/configuring_services.htm
+webserverextensions/www/mapadmin/HelpDocs/configuring_web_services.htm
+webserverextensions/www/mapadmin/HelpDocs/managing_groups.htm
 webserverextensions/www/mapadmin/HelpDocs/managing_packages.htm
-webserverextensions/www/mapadmin/HelpDocs/configuring_web_services.htm
-webserverextensions/www/mapadmin/HelpDocs/adding_and_deleting_groups.htm
+webserverextensions/www/mapadmin/HelpDocs/managing_roles.htm
+webserverextensions/www/mapadmin/HelpDocs/managing_servers.htm
+webserverextensions/www/mapadmin/HelpDocs/managing_users.htm
+webserverextensions/www/mapadmin/HelpDocs/monitor_server_status.htm
+webserverextensions/www/mapadmin/HelpDocs/performance_report.htm
 webserverextensions/www/mapadmin/HelpDocs/tablestyles.css
-webserverextensions/www/mapadmin/HelpDocs/about_sites_and_servers.htm
-webserverextensions/www/mapadmin/groupmanagement.php
+webserverextensions/www/mapadmin/about.php
+webserverextensions/www/mapadmin/addgroup.php
 webserverextensions/www/mapadmin/addunmanageddata.php
-webserverextensions/www/mapadmin/addgroup.php
-webserverextensions/www/mapadmin/serverproperties.php
 webserverextensions/www/mapadmin/adduser.php
-webserverextensions/www/mapadmin/servicesproperties.php
-webserverextensions/www/mapadmin/logproperties.php
-webserverextensions/www/mapadmin/license.htm
-webserverextensions/www/mapadmin/viewserverstatustop.php
-webserverextensions/www/mapadmin/resizablepagecomponents.php
-webserverextensions/www/mapadmin/logmanagement.php
-webserverextensions/www/mapadmin/performanceReport.php
-webserverextensions/www/mapadmin/makepackage.php
-webserverextensions/www/mapadmin/about.php
-webserverextensions/www/mapadmin/wfsproperties.php
-webserverextensions/www/mapadmin/usermanagement.php
-webserverextensions/www/mapadmin/login.php
-webserverextensions/www/mapadmin/xmlparser.php
-webserverextensions/www/mapadmin/resizableadmin.php
+webserverextensions/www/mapadmin/assignroles.php
+webserverextensions/www/mapadmin/css/
+webserverextensions/www/mapadmin/css/resizablestyles.css
 webserverextensions/www/mapadmin/displaypackagelog.php
-webserverextensions/www/mapadmin/msgs.php
-webserverextensions/www/mapadmin/performanceReport_GetResult.php
+webserverextensions/www/mapadmin/downloadlogfile.php
+webserverextensions/www/mapadmin/editgroup.php
 webserverextensions/www/mapadmin/editunmanageddata.php
-webserverextensions/www/mapadmin/loadpackage.php
-webserverextensions/www/mapadmin/profilingmapxml/
-webserverextensions/www/mapadmin/profilingmapxml/MapViewerTemplate.xml
-webserverextensions/www/mapadmin/servermanagement.php
+webserverextensions/www/mapadmin/edituser.php
+webserverextensions/www/mapadmin/groupmanagement.php
 webserverextensions/www/mapadmin/grouprolemanagement.php
-webserverextensions/www/mapadmin/viewcurrentlogtop.php
-webserverextensions/www/mapadmin/performanceReport_Export.php
-webserverextensions/www/mapadmin/viewcurrentlogbottom.php
-webserverextensions/www/mapadmin/css/
-webserverextensions/www/mapadmin/css/resizablestyles.css
-webserverextensions/www/mapadmin/viewserverstatus.php
-webserverextensions/www/mapadmin/userrolemanagement.php
 webserverextensions/www/mapadmin/help.php
-webserverextensions/www/mapadmin/unmanageddatamanagement.php
-webserverextensions/www/mapadmin/edituser.php
-webserverextensions/www/mapadmin/wmsproperties.php
-webserverextensions/www/mapadmin/js/
-webserverextensions/www/mapadmin/js/scripts.js
-webserverextensions/www/mapadmin/sessionvars.php
-webserverextensions/www/mapadmin/performanceReport_MapViewer.php
-webserverextensions/www/mapadmin/assignroles.php
-webserverextensions/www/mapadmin/editgroup.php
 webserverextensions/www/mapadmin/images/
-webserverextensions/www/mapadmin/images/view_log.gif
-webserverextensions/www/mapadmin/images/help.gif
-webserverextensions/www/mapadmin/images/mapDefinitionNameInfo.png
-webserverextensions/www/mapadmin/images/startautorefresh.gif
-webserverextensions/www/mapadmin/images/save.gif
 webserverextensions/www/mapadmin/images/ajax_loading.gif
-webserverextensions/www/mapadmin/images/refresh_disabled.gif
-webserverextensions/www/mapadmin/images/stop.gif
-webserverextensions/www/mapadmin/images/logs.gif
-webserverextensions/www/mapadmin/images/warning.png
+webserverextensions/www/mapadmin/images/arrow_down.png
+webserverextensions/www/mapadmin/images/arrow_left.png
+webserverextensions/www/mapadmin/images/arrow_up.png
+webserverextensions/www/mapadmin/images/close.png
 webserverextensions/www/mapadmin/images/configure.gif
+webserverextensions/www/mapadmin/images/delete.gif
 webserverextensions/www/mapadmin/images/edit.gif
+webserverextensions/www/mapadmin/images/help.gif
+webserverextensions/www/mapadmin/images/load_package.gif
+webserverextensions/www/mapadmin/images/logs.gif
+webserverextensions/www/mapadmin/images/mapDefinitionNameInfo.png
 webserverextensions/www/mapadmin/images/monitor_status.gif
-webserverextensions/www/mapadmin/images/sort_ascending.gif
 webserverextensions/www/mapadmin/images/new.gif
-webserverextensions/www/mapadmin/images/load_package.gif
-webserverextensions/www/mapadmin/images/save_disabled.gif
 webserverextensions/www/mapadmin/images/null.gif
-webserverextensions/www/mapadmin/images/arrow_down.png
-webserverextensions/www/mapadmin/images/arrow_up.png
 webserverextensions/www/mapadmin/images/refresh.gif
-webserverextensions/www/mapadmin/images/arrow_left.png
-webserverextensions/www/mapadmin/images/delete.gif
-webserverextensions/www/mapadmin/images/close.png
+webserverextensions/www/mapadmin/images/refresh_disabled.gif
+webserverextensions/www/mapadmin/images/save.gif
+webserverextensions/www/mapadmin/images/save_disabled.gif
+webserverextensions/www/mapadmin/images/sort_ascending.gif
 webserverextensions/www/mapadmin/images/sort_descending.gif
-webserverextensions/www/mapadmin/viewcurrentlog.php
+webserverextensions/www/mapadmin/images/startautorefresh.gif
+webserverextensions/www/mapadmin/images/stop.gif
+webserverextensions/www/mapadmin/images/view_log.gif
+webserverextensions/www/mapadmin/images/warning.png
 webserverextensions/www/mapadmin/index.html
+webserverextensions/www/mapadmin/js/
+webserverextensions/www/mapadmin/js/scripts.js
+webserverextensions/www/mapadmin/license.htm
+webserverextensions/www/mapadmin/loadpackage.php
+webserverextensions/www/mapadmin/login.php
+webserverextensions/www/mapadmin/logmanagement.php
+webserverextensions/www/mapadmin/logproperties.php
+webserverextensions/www/mapadmin/makepackage.php
+webserverextensions/www/mapadmin/msgs.php
+webserverextensions/www/mapadmin/packagemanagement.php
+webserverextensions/www/mapadmin/performanceReport.php
+webserverextensions/www/mapadmin/performanceReport_Export.php
+webserverextensions/www/mapadmin/performanceReport_GetResult.php
+webserverextensions/www/mapadmin/performanceReport_MapViewer.php
+webserverextensions/www/mapadmin/profilingmapxml/
+webserverextensions/www/mapadmin/profilingmapxml/MapViewerTemplate.xml
+webserverextensions/www/mapadmin/resizableadmin.php
+webserverextensions/www/mapadmin/resizablepagecomponents.php
 webserverextensions/www/mapadmin/serverdatafunctions.php
-webserverextensions/www/mapadmin/downloadlogfile.php
+webserverextensions/www/mapadmin/servermanagement.php
+webserverextensions/www/mapadmin/serverproperties.php
+webserverextensions/www/mapadmin/servicesproperties.php
+webserverextensions/www/mapadmin/sessionvars.php
+webserverextensions/www/mapadmin/unmanageddatamanagement.php
+webserverextensions/www/mapadmin/usermanagement.php
+webserverextensions/www/mapadmin/userrolemanagement.php
+webserverextensions/www/mapadmin/viewcurrentlog.php
+webserverextensions/www/mapadmin/viewcurrentlogbottom.php
+webserverextensions/www/mapadmin/viewcurrentlogtop.php
+webserverextensions/www/mapadmin/viewserverstatus.php
 webserverextensions/www/mapadmin/viewserverstatusbottom.php
-webserverextensions/www/mapadmin/packagemanagement.php
-webserverextensions/www/clientsamples/
-webserverextensions/www/clientsamples/hybrid/
-webserverextensions/www/clientsamples/hybrid/index.html
-webserverextensions/www/clientsamples/data/
-webserverextensions/www/clientsamples/data/SheboyganMixed.MapDefinition.xml
-webserverextensions/www/clientsamples/data/load.php
-webserverextensions/www/clientsamples/data/SheboyganCommercial.MapDefinition.xml
-webserverextensions/www/clientsamples/retina/
-webserverextensions/www/clientsamples/retina/index_ol.html
-webserverextensions/www/clientsamples/untiled/
-webserverextensions/www/clientsamples/untiled/index.html
-webserverextensions/www/clientsamples/assets/
-webserverextensions/www/clientsamples/assets/legend.js
-webserverextensions/www/clientsamples/assets/OpenLayers.js
-webserverextensions/www/clientsamples/assets/jquery-1.10.2.min.js
-webserverextensions/www/clientsamples/assets/theme/
-webserverextensions/www/clientsamples/assets/theme/default/
-webserverextensions/www/clientsamples/assets/theme/default/ie6-style.tidy.css
-webserverextensions/www/clientsamples/assets/theme/default/ie6-style.css
-webserverextensions/www/clientsamples/assets/theme/default/google.css
-webserverextensions/www/clientsamples/assets/theme/default/style.tidy.css
-webserverextensions/www/clientsamples/assets/theme/default/style.mobile.tidy.css
-webserverextensions/www/clientsamples/assets/theme/default/style.css
-webserverextensions/www/clientsamples/assets/theme/default/img/
-webserverextensions/www/clientsamples/assets/theme/default/img/view_previous_off.png
-webserverextensions/www/clientsamples/assets/theme/default/img/editing_tool_bar.png
-webserverextensions/www/clientsamples/assets/theme/default/img/draw_line_on.png
-webserverextensions/www/clientsamples/assets/theme/default/img/panning-hand-off.png
-webserverextensions/www/clientsamples/assets/theme/default/img/draw_polygon_on.png
-webserverextensions/www/clientsamples/assets/theme/default/img/zoom-panel-NOALPHA.png
-webserverextensions/www/clientsamples/assets/theme/default/img/drag-rectangle-on.png
-webserverextensions/www/clientsamples/assets/theme/default/img/pan_off.png
-webserverextensions/www/clientsamples/assets/theme/default/img/move_feature_off.png
-webserverextensions/www/clientsamples/assets/theme/default/img/save_features_on.png
-webserverextensions/www/clientsamples/assets/theme/default/img/draw_polygon_off.png
-webserverextensions/www/clientsamples/assets/theme/default/img/pan-panel-NOALPHA.png
-webserverextensions/www/clientsamples/assets/theme/default/img/view_previous_on.png
-webserverextensions/www/clientsamples/assets/theme/default/img/blank.gif
-webserverextensions/www/clientsamples/assets/theme/default/img/view_next_on.png
-webserverextensions/www/clientsamples/assets/theme/default/img/remove_point_off.png
-webserverextensions/www/clientsamples/assets/theme/default/img/draw_point_on.png
-webserverextensions/www/clientsamples/assets/theme/default/img/close.gif
-webserverextensions/www/clientsamples/assets/theme/default/img/drag-rectangle-off.png
-webserverextensions/www/clientsamples/assets/theme/default/img/remove_point_on.png
-webserverextensions/www/clientsamples/assets/theme/default/img/ruler.png
-webserverextensions/www/clientsamples/assets/theme/default/img/draw_point_off.png
-webserverextensions/www/clientsamples/assets/theme/default/img/panning-hand-on.png
-webserverextensions/www/clientsamples/assets/theme/default/img/pan-panel.png
-webserverextensions/www/clientsamples/assets/theme/default/img/save_features_off.png
-webserverextensions/www/clientsamples/assets/theme/default/img/move_feature_on.png
-webserverextensions/www/clientsamples/assets/theme/default/img/overview_replacement.gif
-webserverextensions/www/clientsamples/assets/theme/default/img/add_point_off.png
-webserverextensions/www/clientsamples/assets/theme/default/img/pan_on.png
-webserverextensions/www/clientsamples/assets/theme/default/img/zoom-panel.png
-webserverextensions/www/clientsamples/assets/theme/default/img/draw_line_off.png
-webserverextensions/www/clientsamples/assets/theme/default/img/add_point_on.png
-webserverextensions/www/clientsamples/assets/theme/default/img/view_next_off.png
-webserverextensions/www/clientsamples/assets/theme/default/img/navigation_history.png
-webserverextensions/www/clientsamples/assets/theme/default/google.tidy.css
-webserverextensions/www/clientsamples/assets/theme/default/style.mobile.css
-webserverextensions/www/clientsamples/assets/legend_ol.js
-webserverextensions/www/clientsamples/utfgrid/
-webserverextensions/www/clientsamples/utfgrid/index.html
-webserverextensions/www/clientsamples/selection/
-webserverextensions/www/clientsamples/selection/index.html
-webserverextensions/www/clientsamples/geoprocessing/
-webserverextensions/www/clientsamples/geoprocessing/index_ol.html
-webserverextensions/www/clientsamples/wms/
-webserverextensions/www/clientsamples/wms/index.html
-webserverextensions/www/clientsamples/mixed/
-webserverextensions/www/clientsamples/mixed/index.html
-webserverextensions/www/clientsamples/mixed/index_ol.html
-webserverextensions/www/clientsamples/xyz/
-webserverextensions/www/clientsamples/xyz/index.html
-webserverextensions/www/clientsamples/xyz/index_ol.html
-webserverextensions/www/clientsamples/external/
-webserverextensions/www/clientsamples/external/index.html
-webserverextensions/www/clientsamples/tiled/
-webserverextensions/www/clientsamples/tiled/index.html
+webserverextensions/www/mapadmin/viewserverstatustop.php
+webserverextensions/www/mapadmin/wfsproperties.php
+webserverextensions/www/mapadmin/wmsproperties.php
+webserverextensions/www/mapadmin/xmlparser.php
+webserverextensions/www/mapagent/
+webserverextensions/www/mapagent/ajaxviewerform.html
+webserverextensions/www/mapagent/applyresourcepackageform.html
+webserverextensions/www/mapagent/binaryoperationform.html
+webserverextensions/www/mapagent/boundaryform.html
+webserverextensions/www/mapagent/bufferform.html
+webserverextensions/www/mapagent/changeresourceownerform.html
+webserverextensions/www/mapagent/checkwktform.html
+webserverextensions/www/mapagent/cleartilecacheform.html
+webserverextensions/www/mapagent/codetowktform.html
+webserverextensions/www/mapagent/convexhullform.html
+webserverextensions/www/mapagent/coordinatesystemapi.html
+webserverextensions/www/mapagent/copyresourceform.html
+webserverextensions/www/mapagent/createrepositoryform.html
+webserverextensions/www/mapagent/createsessionform.html
+webserverextensions/www/mapagent/cscodetowktform.html
+webserverextensions/www/mapagent/csenumeratecategoriesform.html
+webserverextensions/www/mapagent/csenumeratecoordinatesystemsform.html
+webserverextensions/www/mapagent/csepsgcodetowktform.html
+webserverextensions/www/mapagent/csgetbaselibraryform.html
+webserverextensions/www/mapagent/csisvalidform.html
+webserverextensions/www/mapagent/cstransformcoordinatesform.html
+webserverextensions/www/mapagent/cswkttocodeform.html
+webserverextensions/www/mapagent/cswkttoepsgcodeform.html
+webserverextensions/www/mapagent/deleterepositoryform.html
+webserverextensions/www/mapagent/deleteresourcedataform.html
+webserverextensions/www/mapagent/deleteresourceform.html
+webserverextensions/www/mapagent/describedrawingform.html
+webserverextensions/www/mapagent/describefeaturetypewfsform.html
+webserverextensions/www/mapagent/describeschemaform.html
+webserverextensions/www/mapagent/distanceform.html
+webserverextensions/www/mapagent/drawingserviceapi.html
+webserverextensions/www/mapagent/dwfviewerform.html
+webserverextensions/www/mapagent/enumeratecontainersform.html
+webserverextensions/www/mapagent/enumeratecoordinatesystemsform.html
+webserverextensions/www/mapagent/enumeratedatastoresform.html
+webserverextensions/www/mapagent/enumeratedrawinglayers.html
+webserverextensions/www/mapagent/enumeratedrawingsectionresources.html
+webserverextensions/www/mapagent/enumeratedrawingsections.html
+webserverextensions/www/mapagent/enumerategroupsform.html
+webserverextensions/www/mapagent/enumeraterepositoriesform.html
+webserverextensions/www/mapagent/enumerateresourcedataform.html
+webserverextensions/www/mapagent/enumerateresourcereferencesform.html
+webserverextensions/www/mapagent/enumerateresourcesform.html
+webserverextensions/www/mapagent/enumeratetemplatesform.html
+webserverextensions/www/mapagent/enumerateunmanageddataform.html
+webserverextensions/www/mapagent/enumerateusersform.html
+webserverextensions/www/mapagent/enumeratewidgetsform.html
+webserverextensions/www/mapagent/epsgcodetowktform.html
+webserverextensions/www/mapagent/featureserviceapi.html
+webserverextensions/www/mapagent/geometryinfoform.html
+webserverextensions/www/mapagent/geoprocessingapi.html
+webserverextensions/www/mapagent/getcapabilitiesform.html
+webserverextensions/www/mapagent/getcapabilitieswfsform.html
+webserverextensions/www/mapagent/getcapabilitieswmsform.html
+webserverextensions/www/mapagent/getclassdefinitionform.html
+webserverextensions/www/mapagent/getclassesform.html
+webserverextensions/www/mapagent/getconnectpropertyvaluesform.html
+webserverextensions/www/mapagent/getdefaulttilesizexform.html
+webserverextensions/www/mapagent/getdefaulttilesizeyform.html
+webserverextensions/www/mapagent/getdrawingcoordinatespaceform.html
+webserverextensions/www/mapagent/getdrawingform.html
+webserverextensions/www/mapagent/getdrawinglayerform.html
+webserverextensions/www/mapagent/getdrawingsection.html
+webserverextensions/www/mapagent/getdrawingsectionresource.html
+webserverextensions/www/mapagent/getdynamicmapoverlayimageform.html
+webserverextensions/www/mapagent/getfdocacheinfoform.html
+webserverextensions/www/mapagent/getfeatureinfowmsform.html
+webserverextensions/www/mapagent/getfeatureprovidersform.html
+webserverextensions/www/mapagent/getfeaturesetenvelopeform.html
+webserverextensions/www/mapagent/getfeatureskmlform.html
+webserverextensions/www/mapagent/getfeaturewfsform.html
+webserverextensions/www/mapagent/getidentitypropertiesform.html
+webserverextensions/www/mapagent/getlayerkmlform.html
+webserverextensions/www/mapagent/getlongtransactionsform.html
+webserverextensions/www/mapagent/getmapimageform.html
+webserverextensions/www/mapagent/getmapkmlform.html
+webserverextensions/www/mapagent/getmapwmsform.html
+webserverextensions/www/mapagent/getplotform.html
+webserverextensions/www/mapagent/getrepositorycontentform.html
+webserverextensions/www/mapagent/getrepositoryheaderform.html
+webserverextensions/www/mapagent/getresourcecontentform.html
+webserverextensions/www/mapagent/getresourcedataform.html
+webserverextensions/www/mapagent/getresourceheaderform.html
+webserverextensions/www/mapagent/getschemamappingform.html
+webserverextensions/www/mapagent/getschemasform.html
+webserverextensions/www/mapagent/getsessiontimeoutform.html
+webserverextensions/www/mapagent/getsiteinfoform.html
+webserverextensions/www/mapagent/getsitestatusform.html
+webserverextensions/www/mapagent/getsiteversionform.html
+webserverextensions/www/mapagent/getspatialcontextsform.html
+webserverextensions/www/mapagent/gettileimageform.html
+webserverextensions/www/mapagent/gettileimageform2.html
+webserverextensions/www/mapagent/gettileprovidersform.html
+webserverextensions/www/mapagent/getvisiblemapextentform.html
+webserverextensions/www/mapagent/index.html
+webserverextensions/www/mapagent/inheritpermissionsfromform.html
+webserverextensions/www/mapagent/isvalidform.html
+webserverextensions/www/mapagent/kmlserviceapi.html
+webserverextensions/www/mapagent/mapagent.fcgi
+webserverextensions/www/mapagent/mappingserviceapi.html
+webserverextensions/www/mapagent/menu.html
+webserverextensions/www/mapagent/moveresourceform.html
+webserverextensions/www/mapagent/otherapi.html
+webserverextensions/www/mapagent/renameresourcedataform.html
+webserverextensions/www/mapagent/renderingserviceapi.html
+webserverextensions/www/mapagent/resourceexistsform.html
+webserverextensions/www/mapagent/resourceserviceapi.html
+webserverextensions/www/mapagent/selectaggregatesform.html
+webserverextensions/www/mapagent/selectfeaturesform.html
+webserverextensions/www/mapagent/serveradminserviceapi.html
+webserverextensions/www/mapagent/services.html
+webserverextensions/www/mapagent/setactiontarget.js
+webserverextensions/www/mapagent/setajaxactiontarget.js
+webserverextensions/www/mapagent/setdwfactiontarget.js
+webserverextensions/www/mapagent/setresourcedataform.html
+webserverextensions/www/mapagent/setresourceform.html
+webserverextensions/www/mapagent/simplifyform.html
+webserverextensions/www/mapagent/siteserviceapi.html
+webserverextensions/www/mapagent/spatialpredicateform.html
+webserverextensions/www/mapagent/tessellateform.html
+webserverextensions/www/mapagent/testconnectionform.html
+webserverextensions/www/mapagent/tileserviceapi.html
+webserverextensions/www/mapagent/updaterepositoryform.html
+webserverextensions/www/mapagent/webapplicationserviceapi.html
+webserverextensions/www/mapagent/wfsserviceapi.html
+webserverextensions/www/mapagent/wkttocodeform.html
+webserverextensions/www/mapagent/wkttoepsgcodeform.html
+webserverextensions/www/mapagent/wmsserviceapi.html
+webserverextensions/www/mapviewerjava/
+webserverextensions/www/mapviewerjava/ajaxviewer.jsp
+webserverextensions/www/mapviewerjava/ajaxviewerabout.jsp
+webserverextensions/www/mapviewerjava/buffer.jsp
+webserverextensions/www/mapviewerjava/bufferui.jsp
+webserverextensions/www/mapviewerjava/colorpicker.jsp
+webserverextensions/www/mapviewerjava/common.jsp
+webserverextensions/www/mapviewerjava/formframe.jsp
+webserverextensions/www/mapviewerjava/gettingstarted.jsp
+webserverextensions/www/mapviewerjava/index.jsp
+webserverextensions/www/mapviewerjava/init.jsp
+webserverextensions/www/mapviewerjava/legend.jsp
+webserverextensions/www/mapviewerjava/legendctrl.jsp
+webserverextensions/www/mapviewerjava/legendui.jsp
+webserverextensions/www/mapviewerjava/mainframe.jsp
+webserverextensions/www/mapviewerjava/mapframe.jsp
+webserverextensions/www/mapviewerjava/measure.jsp
+webserverextensions/www/mapviewerjava/measureui.jsp
+webserverextensions/www/mapviewerjava/product.jsp
+webserverextensions/www/mapviewerjava/propertyctrl.jsp
+webserverextensions/www/mapviewerjava/quickplotgeneratepicture.jsp
+webserverextensions/www/mapviewerjava/quickplotpanel.jsp
+webserverextensions/www/mapviewerjava/quickplotpreviewinner.jsp
+webserverextensions/www/mapviewerjava/search.jsp
+webserverextensions/www/mapviewerjava/searchprompt.jsp
+webserverextensions/www/mapviewerjava/selectwithin.jsp
+webserverextensions/www/mapviewerjava/selectwithinui.jsp
+webserverextensions/www/mapviewerjava/serveradminhelper.jsp
+webserverextensions/www/mapviewerjava/statusbar.jsp
+webserverextensions/www/mapviewerjava/taskbar.jsp
+webserverextensions/www/mapviewerjava/taskframe.jsp
+webserverextensions/www/mapviewerjava/tasklist.jsp
+webserverextensions/www/mapviewerjava/taskpane.jsp
+webserverextensions/www/mapviewerjava/toolbar.jsp
+webserverextensions/www/mapviewerjava/viewoptions.jsp
+webserverextensions/www/mapviewerphp/
+webserverextensions/www/mapviewerphp/ajaxviewer.php
+webserverextensions/www/mapviewerphp/ajaxviewerabout.php
+webserverextensions/www/mapviewerphp/buffer.php
+webserverextensions/www/mapviewerphp/bufferui.php
+webserverextensions/www/mapviewerphp/capturerequest.php
+webserverextensions/www/mapviewerphp/colorpicker.php
+webserverextensions/www/mapviewerphp/common.php
+webserverextensions/www/mapviewerphp/createlayer.php
+webserverextensions/www/mapviewerphp/debugconsole.php
+webserverextensions/www/mapviewerphp/formframe.php
+webserverextensions/www/mapviewerphp/gettingstarted.php
+webserverextensions/www/mapviewerphp/layerdefinitionfactory.php
+webserverextensions/www/mapviewerphp/legend.php
+webserverextensions/www/mapviewerphp/legendctrl.php
+webserverextensions/www/mapviewerphp/legendui.php
+webserverextensions/www/mapviewerphp/mainframe.php
+webserverextensions/www/mapviewerphp/mapagentcapture.php
+webserverextensions/www/mapviewerphp/mapframe.php
+webserverextensions/www/mapviewerphp/measure.php
+webserverextensions/www/mapviewerphp/measureui.php
+webserverextensions/www/mapviewerphp/product.php
+webserverextensions/www/mapviewerphp/propertyctrl.php
+webserverextensions/www/mapviewerphp/quickplotgeneratepicture.php
+webserverextensions/www/mapviewerphp/quickplotpanel.php
+webserverextensions/www/mapviewerphp/quickplotpreviewinner.php
+webserverextensions/www/mapviewerphp/search.php
+webserverextensions/www/mapviewerphp/searchprompt.php
+webserverextensions/www/mapviewerphp/selectwithin.php
+webserverextensions/www/mapviewerphp/selectwithinui.php
+webserverextensions/www/mapviewerphp/serveradminhelper.php
+webserverextensions/www/mapviewerphp/statusbar.php
+webserverextensions/www/mapviewerphp/taskbar.php
+webserverextensions/www/mapviewerphp/taskframe.php
+webserverextensions/www/mapviewerphp/tasklist.php
+webserverextensions/www/mapviewerphp/templates/
+webserverextensions/www/mapviewerphp/templates/1.0.0.xml
+webserverextensions/www/mapviewerphp/templates/1.1.0.xml
+webserverextensions/www/mapviewerphp/templates/1.1.1.xml
+webserverextensions/www/mapviewerphp/templates/regress.xml
+webserverextensions/www/mapviewerphp/toolbar.php
+webserverextensions/www/mapviewerphp/viewoptions.php
+webserverextensions/www/openapi/
+webserverextensions/www/openapi/openapi.yaml
+webserverextensions/www/openapi/swagger.html
+webserverextensions/www/phpsamples/
+webserverextensions/www/phpsamples/WebLayout.xml
+webserverextensions/www/phpsamples/analyzing_features/
+webserverextensions/www/phpsamples/analyzing_features/bufferfunctions.php
+webserverextensions/www/phpsamples/analyzing_features/bufferlayerdefinition.xml
+webserverextensions/www/phpsamples/analyzing_features/createbuffer.php
+webserverextensions/www/phpsamples/analyzing_features/parcelmarker.xml
+webserverextensions/www/phpsamples/analyzing_features/selectfeaturesinbuffer.php
+webserverextensions/www/phpsamples/analyzing_features/task_pane.php
+webserverextensions/www/phpsamples/common/
+webserverextensions/www/phpsamples/common/LayerDefinition-1.3.0.xsd
+webserverextensions/www/phpsamples/common/PlatformCommon-1.0.0.xsd
+webserverextensions/www/phpsamples/common/SymbolDefinition-1.1.0.xsd
+webserverextensions/www/phpsamples/common/common.php
+webserverextensions/www/phpsamples/common/layerdefinitionfactory.php
+webserverextensions/www/phpsamples/common/pageLoadFunctions.js
+webserverextensions/www/phpsamples/common/title.php
+webserverextensions/www/phpsamples/common/viewsource.php
+webserverextensions/www/phpsamples/custom_output/
+webserverextensions/www/phpsamples/custom_output/createmapimage.php
+webserverextensions/www/phpsamples/custom_output/eplot.php
+webserverextensions/www/phpsamples/custom_output/multiplot.php
+webserverextensions/www/phpsamples/custom_output/property_report.php
+webserverextensions/www/phpsamples/custom_output/task_pane.php
+webserverextensions/www/phpsamples/digitizing_features/
+webserverextensions/www/phpsamples/digitizing_features/clear_lines.php
+webserverextensions/www/phpsamples/digitizing_features/draw_line.php
+webserverextensions/www/phpsamples/digitizing_features/task_pane.php
+webserverextensions/www/phpsamples/digitizing_features/task_pane_digitizing.php
+webserverextensions/www/phpsamples/digitizing_features/task_pane_redlining.php
+webserverextensions/www/phpsamples/hello_map/
+webserverextensions/www/phpsamples/hello_map/display_spatial_reference.php
+webserverextensions/www/phpsamples/hello_map/task_pane.php
+webserverextensions/www/phpsamples/hello_viewer/
+webserverextensions/www/phpsamples/hello_viewer/gotopoint.php
+webserverextensions/www/phpsamples/hello_viewer/task_pane.php
+webserverextensions/www/phpsamples/images/
+webserverextensions/www/phpsamples/images/banner.jpg
+webserverextensions/www/phpsamples/index.php
+webserverextensions/www/phpsamples/interacting_with_layers/
+webserverextensions/www/phpsamples/interacting_with_layers/layer_visibility.php
+webserverextensions/www/phpsamples/interacting_with_layers/task_pane.php
+webserverextensions/www/phpsamples/interacting_with_layers/toggle_roads_label.php
+webserverextensions/www/phpsamples/main.php
+webserverextensions/www/phpsamples/modifying_maps_and_layers/
+webserverextensions/www/phpsamples/modifying_maps_and_layers/RecentlyBuilt.LayerDefinition
+webserverextensions/www/phpsamples/modifying_maps_and_layers/change_layers_via_dom.php
+webserverextensions/www/phpsamples/modifying_maps_and_layers/create_new_line_layer_definition.php
+webserverextensions/www/phpsamples/modifying_maps_and_layers/create_new_point_layer_definition.php
+webserverextensions/www/phpsamples/modifying_maps_and_layers/create_new_squarefootage_layer_definition.php
+webserverextensions/www/phpsamples/modifying_maps_and_layers/layer_functions.php
+webserverextensions/www/phpsamples/modifying_maps_and_layers/maindwf.php
+webserverextensions/www/phpsamples/modifying_maps_and_layers/task_pane.php
+webserverextensions/www/phpsamples/readme.txt
+webserverextensions/www/phpsamples/styles/
+webserverextensions/www/phpsamples/styles/globalStyles.css
+webserverextensions/www/phpsamples/styles/otherStyles.css
+webserverextensions/www/phpsamples/viewerfiles/
+webserverextensions/www/phpsamples/viewerfiles/arearule.templ
+webserverextensions/www/phpsamples/viewerfiles/areatypestyle.templ
+webserverextensions/www/phpsamples/viewerfiles/layerdefinition.templ
+webserverextensions/www/phpsamples/viewerfiles/linerule.templ
+webserverextensions/www/phpsamples/viewerfiles/linetypestyle.templ
+webserverextensions/www/phpsamples/viewerfiles/marksymbol.templ
+webserverextensions/www/phpsamples/viewerfiles/pointrule.templ
+webserverextensions/www/phpsamples/viewerfiles/pointtypestyle.templ
+webserverextensions/www/phpsamples/viewerfiles/scalerange.templ
+webserverextensions/www/phpsamples/viewerfiles/textsymbol.templ
+webserverextensions/www/phpsamples/working_with_feature_data/
+webserverextensions/www/phpsamples/working_with_feature_data/listselection.php
+webserverextensions/www/phpsamples/working_with_feature_data/queryfeatures.php
+webserverextensions/www/phpsamples/working_with_feature_data/selectfeatures.php
+webserverextensions/www/phpsamples/working_with_feature_data/task_pane.php
+webserverextensions/www/phpviewersample/
+webserverextensions/www/phpviewersample/JSON.php
+webserverextensions/www/phpviewersample/ajaxtiledviewersample.php
+webserverextensions/www/phpviewersample/ajaxviewersample.php
+webserverextensions/www/phpviewersample/composer.json
+webserverextensions/www/phpviewersample/dwfviewersample.php
+webserverextensions/www/phpviewersample/findaddress/
+webserverextensions/www/phpviewersample/findaddress/clearaddressresults.php
+webserverextensions/www/phpviewersample/findaddress/findaddress.php
+webserverextensions/www/phpviewersample/findaddress/findaddressfunctions.php
+webserverextensions/www/phpviewersample/findaddress/findaddressmain.php
+webserverextensions/www/phpviewersample/findaddress/gotopoint.php
+webserverextensions/www/phpviewersample/findaddress/templates/
+webserverextensions/www/phpviewersample/findaddress/templates/addressmarker.xml
+webserverextensions/www/phpviewersample/images/
+webserverextensions/www/phpviewersample/images/Thumbs.db
+webserverextensions/www/phpviewersample/images/loader_inactive.gif
+webserverextensions/www/phpviewersample/images/loader_pulse.gif
+webserverextensions/www/phpviewersample/images/pushpin.jpg
+webserverextensions/www/phpviewersample/images/pushpinblue.jpg
+webserverextensions/www/phpviewersample/json.js
+webserverextensions/www/phpviewersample/overview/
+webserverextensions/www/phpviewersample/overview/overviewmain.php
+webserverextensions/www/phpviewersample/plot/
+webserverextensions/www/phpviewersample/plot/plot.php
+webserverextensions/www/phpviewersample/plot/plotmain.php
+webserverextensions/www/phpviewersample/query/
+webserverextensions/www/phpviewersample/query/classes/
+webserverextensions/www/phpviewersample/query/classes/feature.php
+webserverextensions/www/phpviewersample/query/classes/property.php
+webserverextensions/www/phpviewersample/query/classes/query.php
+webserverextensions/www/phpviewersample/query/querycontroller.php
+webserverextensions/www/phpviewersample/query/querymain.php
+webserverextensions/www/phpviewersample/query/templates/
+webserverextensions/www/phpviewersample/query/templates/filterlayerdefinition.xml
+webserverextensions/www/phpviewersample/styles/
+webserverextensions/www/phpviewersample/styles/gt.css
+webserverextensions/www/phpviewersample/theme/
+webserverextensions/www/phpviewersample/theme/classes/
+webserverextensions/www/phpviewersample/theme/classes/layerinfo.php
+webserverextensions/www/phpviewersample/theme/classes/property.php
+webserverextensions/www/phpviewersample/theme/classes/theme.php
+webserverextensions/www/phpviewersample/theme/templates/
+webserverextensions/www/phpviewersample/theme/templates/arearuletemplate.xml
+webserverextensions/www/phpviewersample/theme/themecontroller.php
+webserverextensions/www/phpviewersample/theme/thememain.php
+webserverextensions/www/phpviewersample/title.html
+webserverextensions/www/phpviewersample/utilityfunctions.php
+webserverextensions/www/phpviewersample/vendor/
+webserverextensions/www/phpviewersample/vendor/autoload.php
+webserverextensions/www/phpviewersample/vendor/composer/
+webserverextensions/www/phpviewersample/vendor/composer/ClassLoader.php
+webserverextensions/www/phpviewersample/vendor/composer/autoload_classmap.php
+webserverextensions/www/phpviewersample/vendor/composer/autoload_namespaces.php
+webserverextensions/www/phpviewersample/vendor/composer/autoload_psr4.php
+webserverextensions/www/phpviewersample/vendor/composer/autoload_real.php
+webserverextensions/www/phpviewersample/vendor/composer/installed.json
+webserverextensions/www/phpviewersample/vendor/lstrojny/
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/.gitignore
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/.travis.yml
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/README.md
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/build.xml
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/composer.json
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/package.json
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/phpunit.xml.dist
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/AbstractDecorator.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Client.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/ClientInterface.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/CodeGenerator/
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/CodeGenerator/XmlReaderParserBitmaskGenerator.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/ExceptionInterface.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/HttpException.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/InvalidArgumentException.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/MissingExtensionException.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/ResponseException.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/RuntimeException.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/SerializationException.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/TcpException.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Exception/TransportException.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/ExtensionSupportInterface.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Multicall.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Parser/
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Parser/NativeParser.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Parser/ParserInterface.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Parser/XmlReaderParser.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Proxy.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Serializer/
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Serializer/NativeSerializer.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Serializer/SerializerInterface.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Serializer/XmlWriterSerializer.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Timing/
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Timing/AbstractTimerBridge.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Timing/MonologTimerBridge.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Timing/Psr3TimerBridge.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Timing/TimerInterface.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Timing/TimingDecorator.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Timing/ZendFrameworkOneTimerBridge.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Timing/ZendFrameworkTwoTimerBridge.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/AbstractHttpTransport.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/BuzzBrowserBridge.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/CurlTransport.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/GuzzleBridge.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/HttpTransportInterface.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/StreamSocketTransport.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/TransportInterface.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/ZendFrameworkOneHttpClientBridge.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Transport/ZendFrameworkTwoHttpClientBridge.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Value/
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Value/Base64.php
+webserverextensions/www/phpviewersample/vendor/lstrojny/fxmlrpc/src/fXmlRpc/Value/Base64Interface.php
+webserverextensions/www/samples.php
+webserverextensions/www/schemareport/
+webserverextensions/www/schemareport/blank.php
+webserverextensions/www/schemareport/describeschema.php
+webserverextensions/www/schemareport/displayschema.css
+webserverextensions/www/schemareport/displayschema.php
+webserverextensions/www/schemareport/displayschema.xsl
+webserverextensions/www/schemareport/displayschemafunctions.php
+webserverextensions/www/schemareport/images/
+webserverextensions/www/schemareport/images/collapse_pane.png
+webserverextensions/www/schemareport/images/expand_pane.png
+webserverextensions/www/schemareport/layerdefinitionfactory.php
+webserverextensions/www/schemareport/main.php
+webserverextensions/www/schemareport/mapdefinitionfactory.php
+webserverextensions/www/schemareport/showclass.php
+webserverextensions/www/schemareport/showgeom.php
+webserverextensions/www/schemareport/stringconstants.php
+webserverextensions/www/schemareport/templatefiles/
+webserverextensions/www/schemareport/templatefiles/arearule.templ
+webserverextensions/www/schemareport/templatefiles/areatypestyle.templ
+webserverextensions/www/schemareport/templatefiles/extents.templ
+webserverextensions/www/schemareport/templatefiles/flexweblayout.templ
+webserverextensions/www/schemareport/templatefiles/layerdefinition.templ
+webserverextensions/www/schemareport/templatefiles/linerule.templ
+webserverextensions/www/schemareport/templatefiles/linetypestyle.templ
+webserverextensions/www/schemareport/templatefiles/mapdefinition.templ
+webserverextensions/www/schemareport/templatefiles/maplayer.templ
+webserverextensions/www/schemareport/templatefiles/maplayergroup.templ
+webserverextensions/www/schemareport/templatefiles/pointrule.templ
+webserverextensions/www/schemareport/templatefiles/pointtypestyle.templ
+webserverextensions/www/schemareport/templatefiles/scalerange.templ
+webserverextensions/www/schemareport/templatefiles/textwatermark.templ
+webserverextensions/www/schemareport/templatefiles/weblayout.templ
+webserverextensions/www/schemareport/weblayoutfactory.php
+webserverextensions/www/stdicons/
+webserverextensions/www/stdicons/closeButton.gif
+webserverextensions/www/stdicons/cp_arr.gif
+webserverextensions/www/stdicons/cp_arr_dis.gif
+webserverextensions/www/stdicons/digitizeCircle.cur
+webserverextensions/www/stdicons/digitizeLine.cur
+webserverextensions/www/stdicons/digitizeLineString.cur
+webserverextensions/www/stdicons/digitizePoint.cur
+webserverextensions/www/stdicons/digitizePolygon.cur
+webserverextensions/www/stdicons/digitizeRectangle.cur
+webserverextensions/www/stdicons/icon_back.gif
+webserverextensions/www/stdicons/icon_back_disabled.gif
+webserverextensions/www/stdicons/icon_buffer.gif
+webserverextensions/www/stdicons/icon_buffer_disabled.gif
+webserverextensions/www/stdicons/icon_clearselect.gif
+webserverextensions/www/stdicons/icon_clearselect_disabled.gif
+webserverextensions/www/stdicons/icon_copy.gif
+webserverextensions/www/stdicons/icon_copy_disabled.gif
+webserverextensions/www/stdicons/icon_ctxarrow.gif
+webserverextensions/www/stdicons/icon_error.gif
+webserverextensions/www/stdicons/icon_fitwindow.gif
+webserverextensions/www/stdicons/icon_fitwindow_disabled.gif
+webserverextensions/www/stdicons/icon_forward.gif
+webserverextensions/www/stdicons/icon_forward_disabled.gif
+webserverextensions/www/stdicons/icon_help.gif
+webserverextensions/www/stdicons/icon_help_disabled.gif
+webserverextensions/www/stdicons/icon_home.gif
+webserverextensions/www/stdicons/icon_home_disabled.gif
+webserverextensions/www/stdicons/icon_info.gif
+webserverextensions/www/stdicons/icon_invokescript.gif
+webserverextensions/www/stdicons/icon_invokescript_disabled.gif
+webserverextensions/www/stdicons/icon_invokeurl.gif
+webserverextensions/www/stdicons/icon_invokeurl_disabled.gif
+webserverextensions/www/stdicons/icon_loading.gif
+webserverextensions/www/stdicons/icon_maptip.gif
+webserverextensions/www/stdicons/icon_maptip_disabled.gif
+webserverextensions/www/stdicons/icon_measure.gif
+webserverextensions/www/stdicons/icon_measure_disabled.gif
+webserverextensions/www/stdicons/icon_menuarrow.gif
+webserverextensions/www/stdicons/icon_menuarrow_disabled.gif
+webserverextensions/www/stdicons/icon_menuarrowup.gif
+webserverextensions/www/stdicons/icon_menuarrowup_disabled.gif
+webserverextensions/www/stdicons/icon_null.gif
+webserverextensions/www/stdicons/icon_pan.gif
+webserverextensions/www/stdicons/icon_pan_disabled.gif
+webserverextensions/www/stdicons/icon_pandown.gif
+webserverextensions/www/stdicons/icon_pandown_disabled.gif
+webserverextensions/www/stdicons/icon_panleft.gif
+webserverextensions/www/stdicons/icon_panleft_disabled.gif
+webserverextensions/www/stdicons/icon_panright.gif
+webserverextensions/www/stdicons/icon_panright_disabled.gif
+webserverextensions/www/stdicons/icon_panup.gif
+webserverextensions/www/stdicons/icon_panup_disabled.gif
+webserverextensions/www/stdicons/icon_plotdwf.gif
+webserverextensions/www/stdicons/icon_plotdwf_disabled.gif
+webserverextensions/www/stdicons/icon_popupscrolldown.gif
+webserverextensions/www/stdicons/icon_popupscrolldown_disabled.gif
+webserverextensions/www/stdicons/icon_popupscrollup.gif
+webserverextensions/www/stdicons/icon_popupscrollup_disabled.gif
+webserverextensions/www/stdicons/icon_print.gif
+webserverextensions/www/stdicons/icon_print_disabled.gif
+webserverextensions/www/stdicons/icon_printablepage.gif
+webserverextensions/www/stdicons/icon_printablepage_disabled.gif
+webserverextensions/www/stdicons/icon_refreshmap.gif
+webserverextensions/www/stdicons/icon_refreshmap_disabled.gif
+webserverextensions/www/stdicons/icon_restorecenter.gif
+webserverextensions/www/stdicons/icon_restorecenter_disabled.gif
+webserverextensions/www/stdicons/icon_search.gif
+webserverextensions/www/stdicons/icon_search_disabled.gif
+webserverextensions/www/stdicons/icon_select.gif
+webserverextensions/www/stdicons/icon_select_disabled.gif
+webserverextensions/www/stdicons/icon_selectpolygon.gif
+webserverextensions/www/stdicons/icon_selectpolygon_disabled.gif
+webserverextensions/www/stdicons/icon_selectradius.gif
+webserverextensions/www/stdicons/icon_selectradius_disabled.gif
+webserverextensions/www/stdicons/icon_selectwithin.gif
+webserverextensions/www/stdicons/icon_selectwithin_disabled.gif
+webserverextensions/www/stdicons/icon_tasks.gif
+webserverextensions/www/stdicons/icon_tasks_disabled.gif
+webserverextensions/www/stdicons/icon_viewoptions.gif
+webserverextensions/www/stdicons/icon_viewoptions_disabled.gif
+webserverextensions/www/stdicons/icon_warning.gif
+webserverextensions/www/stdicons/icon_zoom.gif
+webserverextensions/www/stdicons/icon_zoom_disabled.gif
+webserverextensions/www/stdicons/icon_zoomin.gif
+webserverextensions/www/stdicons/icon_zoomin_disabled.gif
+webserverextensions/www/stdicons/icon_zoomnext.gif
+webserverextensions/www/stdicons/icon_zoomnext_disabled.gif
+webserverextensions/www/stdicons/icon_zoomout.gif
+webserverextensions/www/stdicons/icon_zoomout_disabled.gif
+webserverextensions/www/stdicons/icon_zoomprev.gif
+webserverextensions/www/stdicons/icon_zoomprev_disabled.gif
+webserverextensions/www/stdicons/icon_zoomrect.gif
+webserverextensions/www/stdicons/icon_zoomrect_disabled.gif
+webserverextensions/www/stdicons/icon_zoomselect.gif
+webserverextensions/www/stdicons/icon_zoomselect_disabled.gif
+webserverextensions/www/stdicons/lc_broken.gif
+webserverextensions/www/stdicons/lc_checked.gif
+webserverextensions/www/stdicons/lc_checked_16.gif
+webserverextensions/www/stdicons/lc_checked_grayed.gif
+webserverextensions/www/stdicons/lc_checked_grayed_16.gif
+webserverextensions/www/stdicons/lc_collapse.gif
+webserverextensions/www/stdicons/lc_collapse_16.gif
+webserverextensions/www/stdicons/lc_dwf.gif
+webserverextensions/www/stdicons/lc_expand.gif
+webserverextensions/www/stdicons/lc_expand_16.gif
+webserverextensions/www/stdicons/lc_group.gif
+webserverextensions/www/stdicons/lc_noexpand.gif
+webserverextensions/www/stdicons/lc_raster.gif
+webserverextensions/www/stdicons/lc_select.gif
+webserverextensions/www/stdicons/lc_style.gif
+webserverextensions/www/stdicons/lc_sym.gif
+webserverextensions/www/stdicons/lc_theme.gif
+webserverextensions/www/stdicons/lc_unchecked.gif
+webserverextensions/www/stdicons/lc_unchecked_16.gif
+webserverextensions/www/stdicons/lc_unchecked_grayed.gif
+webserverextensions/www/stdicons/lc_unchecked_grayed_16.gif
+webserverextensions/www/stdicons/lc_unselect.gif
+webserverextensions/www/stdicons/measure.cur
+webserverextensions/www/stdicons/mn_check.gif
+webserverextensions/www/stdicons/mn_scrolldown.gif
+webserverextensions/www/stdicons/mn_scrolldown_disabled.gif
+webserverextensions/www/stdicons/mn_scrollup.gif
+webserverextensions/www/stdicons/mn_scrollup_disabled.gif
+webserverextensions/www/stdicons/nav_band_contract.gif
+webserverextensions/www/stdicons/nav_band_expand.gif
+webserverextensions/www/stdicons/openButton.gif
+webserverextensions/www/stdicons/pan.cur
+webserverextensions/www/stdicons/pixel.gif
+webserverextensions/www/stdicons/pr_north.gif
+webserverextensions/www/stdicons/progress_indicator.gif
+webserverextensions/www/stdicons/rotate.cur
+webserverextensions/www/stdicons/selectPolygon.cur
+webserverextensions/www/stdicons/selectRadius.cur
+webserverextensions/www/stdicons/slider.png
+webserverextensions/www/stdicons/sliderscale.png
+webserverextensions/www/stdicons/transparentpixel.gif
+webserverextensions/www/stdicons/zoomin.cur
+webserverextensions/www/stdicons/zoomout.cur
+webserverextensions/www/stdicons/zoomrect.cur
 webserverextensions/www/viewerfiles/
-webserverextensions/www/viewerfiles/quickplot.js
+webserverextensions/www/viewerfiles/COPYRIGHT
+webserverextensions/www/viewerfiles/ajaxmappane.templ
+webserverextensions/www/viewerfiles/ajaxviewerabout.templ
+webserverextensions/www/viewerfiles/arealayerdef.templ
+webserverextensions/www/viewerfiles/arearule.templ
+webserverextensions/www/viewerfiles/areatypestyle.templ
 webserverextensions/www/viewerfiles/blank.html
+webserverextensions/www/viewerfiles/browserdetect.js
 webserverextensions/www/viewerfiles/bufferreport.templ
-webserverextensions/www/viewerfiles/selectwithinui.templ
-webserverextensions/www/viewerfiles/viewoptions.templ
-webserverextensions/www/viewerfiles/measureui.templ
-webserverextensions/www/viewerfiles/marksymbol.templ
-webserverextensions/www/viewerfiles/quickplotnortharrow.png
-webserverextensions/www/viewerfiles/sarissa.js
-webserverextensions/www/viewerfiles/layerdefinition.templ
+webserverextensions/www/viewerfiles/bufferui.templ
+webserverextensions/www/viewerfiles/colorpicker.templ
+webserverextensions/www/viewerfiles/contextmenu.js
+webserverextensions/www/viewerfiles/digitize.js
 webserverextensions/www/viewerfiles/errorpage.templ
-webserverextensions/www/viewerfiles/searchprompt.templ
-webserverextensions/www/viewerfiles/ajaxmappane.templ
-webserverextensions/www/viewerfiles/numfmt.js
-webserverextensions/www/viewerfiles/linerule.templ
-webserverextensions/www/viewerfiles/pngfix_map.js
-webserverextensions/www/viewerfiles/arealayerdef.templ
+webserverextensions/www/viewerfiles/floatingmessage.js
+webserverextensions/www/viewerfiles/formframe.templ
+webserverextensions/www/viewerfiles/framesetnotaskbar.templ
+webserverextensions/www/viewerfiles/framesettaskbar.templ
 webserverextensions/www/viewerfiles/hashtable.js
+webserverextensions/www/viewerfiles/jxlib.js
+webserverextensions/www/viewerfiles/jxtheme.css
+webserverextensions/www/viewerfiles/layerdefinition.templ
+webserverextensions/www/viewerfiles/legend.js
 webserverextensions/www/viewerfiles/legendctrl.templ
-webserverextensions/www/viewerfiles/floatingmessage.js
-webserverextensions/www/viewerfiles/toolbar.templ
-webserverextensions/www/viewerfiles/legend.js
-webserverextensions/www/viewerfiles/pointrule.templ
-webserverextensions/www/viewerfiles/arearule.templ
+webserverextensions/www/viewerfiles/legendui.templ
+webserverextensions/www/viewerfiles/legendupdate.templ
+webserverextensions/www/viewerfiles/linelayerdef.templ
+webserverextensions/www/viewerfiles/linerule.templ
 webserverextensions/www/viewerfiles/linetypestyle.templ
-webserverextensions/www/viewerfiles/linelayerdef.templ
+webserverextensions/www/viewerfiles/mainframe.templ
+webserverextensions/www/viewerfiles/marksymbol.templ
+webserverextensions/www/viewerfiles/measureui.templ
+webserverextensions/www/viewerfiles/numfmt.js
+webserverextensions/www/viewerfiles/ol.css
 webserverextensions/www/viewerfiles/ol.js
-webserverextensions/www/viewerfiles/taskframe.templ
-webserverextensions/www/viewerfiles/COPYRIGHT
+webserverextensions/www/viewerfiles/ol.js.map
+webserverextensions/www/viewerfiles/pngfix_map.js
+webserverextensions/www/viewerfiles/pointrule.templ
+webserverextensions/www/viewerfiles/pointtypestyle.templ
+webserverextensions/www/viewerfiles/propertyctrl.templ
+webserverextensions/www/viewerfiles/quickplot.js
+webserverextensions/www/viewerfiles/quickplotnortharrow.png
+webserverextensions/www/viewerfiles/quickplotpanel.js
 webserverextensions/www/viewerfiles/quickplotpanel.templ
-webserverextensions/www/viewerfiles/textsymbol.templ
-webserverextensions/www/viewerfiles/jxlib.js
+webserverextensions/www/viewerfiles/quickplotpreview.js
+webserverextensions/www/viewerfiles/quickplotpreviewinner.templ
+webserverextensions/www/viewerfiles/sarissa.js
+webserverextensions/www/viewerfiles/scalerange.templ
 webserverextensions/www/viewerfiles/search.templ
-webserverextensions/www/viewerfiles/propertyctrl.templ
-webserverextensions/www/viewerfiles/areatypestyle.templ
+webserverextensions/www/viewerfiles/searchprompt.templ
+webserverextensions/www/viewerfiles/selectwithinui.templ
 webserverextensions/www/viewerfiles/statusbar.templ
-webserverextensions/www/viewerfiles/formframe.templ
+webserverextensions/www/viewerfiles/taskbar.templ
+webserverextensions/www/viewerfiles/taskframe.templ
 webserverextensions/www/viewerfiles/tasklist.templ
-webserverextensions/www/viewerfiles/ol.css
-webserverextensions/www/viewerfiles/bufferui.templ
-webserverextensions/www/viewerfiles/framesetnotaskbar.templ
-webserverextensions/www/viewerfiles/mainframe.templ
-webserverextensions/www/viewerfiles/framesettaskbar.templ
+webserverextensions/www/viewerfiles/textsymbol.templ
+webserverextensions/www/viewerfiles/toolbar.templ
+webserverextensions/www/viewerfiles/util.js
+webserverextensions/www/viewerfiles/viewer.css
+webserverextensions/www/viewerfiles/viewoptions.templ
 webserverextensions/www/viewerfiles/wz_jsgraphics.js
-webserverextensions/www/viewerfiles/pointtypestyle.templ
-webserverextensions/www/viewerfiles/taskbar.templ
-webserverextensions/www/viewerfiles/legendui.templ
-webserverextensions/www/viewerfiles/colorpicker.templ
-webserverextensions/www/viewerfiles/viewer.css
-webserverextensions/www/viewerfiles/ajaxviewerabout.templ
-webserverextensions/www/viewerfiles/browserdetect.js
-webserverextensions/www/viewerfiles/jxtheme.css
-webserverextensions/www/viewerfiles/util.js
-webserverextensions/www/viewerfiles/contextmenu.js
-webserverextensions/www/viewerfiles/quickplotpanel.js
-webserverextensions/www/viewerfiles/legendupdate.templ
-webserverextensions/www/viewerfiles/quickplotpreviewinner.templ
-webserverextensions/www/viewerfiles/quickplotpreview.js
-webserverextensions/www/viewerfiles/digitize.js
-webserverextensions/www/viewerfiles/scalerange.templ
-webserverextensions/www/viewerfiles/ol.js.map
-webserverextensions/www/Resources/
-webserverextensions/www/Resources/mapguide_en.res
-webserverextensions/www/javaviewersample/
-webserverextensions/www/javaviewersample/ajaxtiledviewersample.jsp
-webserverextensions/www/javaviewersample/ReadMe.txt
-webserverextensions/www/javaviewersample/findaddress/
-webserverextensions/www/javaviewersample/findaddress/gotopoint.jsp
-webserverextensions/www/javaviewersample/findaddress/clearaddressresults.jsp
-webserverextensions/www/javaviewersample/findaddress/findaddressfunctions.jsp
-webserverextensions/www/javaviewersample/findaddress/findaddressmain.jsp
-webserverextensions/www/javaviewersample/findaddress/templates/
-webserverextensions/www/javaviewersample/findaddress/templates/addressmarker.xml
-webserverextensions/www/javaviewersample/findaddress/findaddress.jsp
-webserverextensions/www/javaviewersample/ajaxviewersample.jsp
-webserverextensions/www/javaviewersample/styles/
-webserverextensions/www/javaviewersample/styles/gt.css
-webserverextensions/www/javaviewersample/query/
-webserverextensions/www/javaviewersample/query/classes/
-webserverextensions/www/javaviewersample/query/classes/feature.jsp
-webserverextensions/www/javaviewersample/query/classes/query.jsp
-webserverextensions/www/javaviewersample/query/classes/property.jsp
-webserverextensions/www/javaviewersample/query/classes/command.jsp
-webserverextensions/www/javaviewersample/query/templates/
-webserverextensions/www/javaviewersample/query/templates/filterlayerdefinition.xml
-webserverextensions/www/javaviewersample/query/querymain.jsp
-webserverextensions/www/javaviewersample/query/querycontroller.jsp
-webserverextensions/www/javaviewersample/utilityfunctions.jsp
-webserverextensions/www/javaviewersample/theme/
-webserverextensions/www/javaviewersample/theme/classes/
-webserverextensions/www/javaviewersample/theme/classes/property.jsp
-webserverextensions/www/javaviewersample/theme/classes/layerinfo.jsp
-webserverextensions/www/javaviewersample/theme/classes/theme.jsp
-webserverextensions/www/javaviewersample/theme/classes/command.jsp
-webserverextensions/www/javaviewersample/theme/thememain.jsp
-webserverextensions/www/javaviewersample/theme/templates/
-webserverextensions/www/javaviewersample/theme/templates/arearuletemplate.xml
-webserverextensions/www/javaviewersample/theme/themecontroller.jsp
-webserverextensions/www/javaviewersample/plot/
-webserverextensions/www/javaviewersample/plot/plotmain.jsp
-webserverextensions/www/javaviewersample/plot/plot.jsp
-webserverextensions/www/javaviewersample/title.html
-webserverextensions/www/javaviewersample/dwfviewersample.jsp
-webserverextensions/www/javaviewersample/json.jar
-webserverextensions/www/javaviewersample/images/
-webserverextensions/www/javaviewersample/images/loader_inactive.gif
-webserverextensions/www/javaviewersample/images/pushpin.jpg
-webserverextensions/www/javaviewersample/images/pushpinblue.jpg
-webserverextensions/www/javaviewersample/images/loader_pulse.gif
-webserverextensions/www/javaviewersample/images/Thumbs.db
-webserverextensions/www/javaviewersample/json.js
-webserverextensions/www/javaviewersample/overview/
-webserverextensions/www/javaviewersample/overview/overviewmain.jsp
-webserverextensions/bin/
-webserverextensions/bin/mgdevhttpserver
-webserverextensions/bin/mgdevhttpserver.sh
+webserverextensions/www/webconfig.ini
Modified: branches/4.0/MgDev/Bindings/src/ApiDump/filelist.linux.ubuntu.txt
--- branches/4.0/MgDev/Bindings/src/ApiDump/filelist.linux.ubuntu.txt	2026-11-10 07:15:37 UTC (rev 10282)
+++ branches/4.0/MgDev/Bindings/src/ApiDump/filelist.linux.ubuntu.txt	2026-11-11 12:20:53 UTC (rev 10283)
@@ -1,5198 +1,5372 @@
 lib64/
-lib64/libMgPlatformBase.so
+lib64/libMgFoundation-4.0.1.so
+lib64/libMgFoundation.so
+lib64/libMgGeometry-4.0.1.so
 lib64/libMgGeometry.so
-lib64/libMgMdfParser-4.0.0.so
-lib64/libMgGeometry-4.0.0.so
+lib64/libMgGwsCommon-4.0.1.so
+lib64/libMgGwsCommon.so
+lib64/libMgGwsQueryEngine-4.0.1.so
 lib64/libMgGwsQueryEngine.so
-lib64/libMgMdfModel-4.0.0.so
-lib64/libMgMapGuideCommon-4.0.0.so
-lib64/libMgFoundation-4.0.0.so
-lib64/libMgGwsQueryEngine-4.0.0.so
-lib64/libMgGwsResource-4.0.0.so
-lib64/libMgStylization.so
-lib64/libMgPlatformBase-4.0.0.so
+lib64/libMgGwsResource-4.0.1.so
 lib64/libMgGwsResource.so
-lib64/libMgFoundation.so
-lib64/libMgStylization-4.0.0.so
+lib64/libMgMapGuideCommon-4.0.1.so
 lib64/libMgMapGuideCommon.so
-lib64/libMgRenderers-4.0.0.so
+lib64/libMgMdfModel-4.0.1.so
+lib64/libMgMdfModel.so
+lib64/libMgMdfParser-4.0.1.so
+lib64/libMgMdfParser.so
+lib64/libMgPlatformBase-4.0.1.so
+lib64/libMgPlatformBase.so
+lib64/libMgRenderers-4.0.1.so
 lib64/libMgRenderers.so
-lib64/libMgGwsCommon.so
-lib64/libMgMdfParser.so
-lib64/libMgGwsCommon-4.0.0.so
-lib64/libMgMdfModel.so
+lib64/libMgStylization-4.0.1.so
+lib64/libMgStylization.so
 server/
 server/Logs/
+server/Packages/
+server/Repositories/
+server/RepositoryAdmin/
+server/RepositoryAdmin/BackUpOfflineRepositories.sh
+server/RepositoryAdmin/BackUpOnlineRepositories.sh
+server/RepositoryAdmin/COPYRIGHT
+server/RepositoryAdmin/DotMake.CommandLine.dll
+server/RepositoryAdmin/MapGuide.RepositoryAdmin
+server/RepositoryAdmin/MapGuide.RepositoryAdmin.deps.json
+server/RepositoryAdmin/MapGuide.RepositoryAdmin.dll
+server/RepositoryAdmin/MapGuide.RepositoryAdmin.runtimeconfig.json
+server/RepositoryAdmin/README.txt
+server/RepositoryAdmin/RecoverRepositories.sh
+server/RepositoryAdmin/RestoreColdBackupRepositories.sh
+server/RepositoryAdmin/RestoreHotBackupRepositories.sh
+server/RepositoryAdmin/SetupRepositoryIndices.sh
+server/RepositoryAdmin/System.Collections.Concurrent.dll
+server/RepositoryAdmin/System.Collections.Immutable.dll
+server/RepositoryAdmin/System.Collections.NonGeneric.dll
+server/RepositoryAdmin/System.Collections.dll
+server/RepositoryAdmin/System.CommandLine.dll
+server/RepositoryAdmin/System.ComponentModel.Primitives.dll
+server/RepositoryAdmin/System.ComponentModel.TypeConverter.dll
+server/RepositoryAdmin/System.Console.dll
+server/RepositoryAdmin/System.Diagnostics.Process.dll
+server/RepositoryAdmin/System.Diagnostics.StackTrace.dll
+server/RepositoryAdmin/System.IO.Compression.dll
+server/RepositoryAdmin/System.IO.MemoryMappedFiles.dll
+server/RepositoryAdmin/System.IO.Pipes.dll
+server/RepositoryAdmin/System.Linq.dll
+server/RepositoryAdmin/System.Net.Primitives.dll
+server/RepositoryAdmin/System.Net.Sockets.dll
+server/RepositoryAdmin/System.ObjectModel.dll
+server/RepositoryAdmin/System.Private.CoreLib.dll
+server/RepositoryAdmin/System.Private.Uri.dll
+server/RepositoryAdmin/System.Reflection.Metadata.dll
+server/RepositoryAdmin/System.Text.RegularExpressions.dll
+server/RepositoryAdmin/System.dll
+server/RepositoryAdmin/UpgradeRepositories.sh
+server/RepositoryAdmin/createdump
+server/RepositoryAdmin/libSystem.Globalization.Native.so
+server/RepositoryAdmin/libSystem.IO.Compression.Native.so
+server/RepositoryAdmin/libSystem.Native.so
+server/RepositoryAdmin/libSystem.Net.Security.Native.so
+server/RepositoryAdmin/libSystem.Security.Cryptography.Native.OpenSsl.so
+server/RepositoryAdmin/libclrgc.so
+server/RepositoryAdmin/libclrjit.so
+server/RepositoryAdmin/libcoreclr.so
+server/RepositoryAdmin/libcoreclrtraceptprovider.so
+server/RepositoryAdmin/libhostfxr.so
+server/RepositoryAdmin/libhostpolicy.so
+server/RepositoryAdmin/libmscordaccore.so
+server/RepositoryAdmin/libmscordbi.so
+server/Resources/
+server/Resources/mapguide_en.res
 server/Schema/
-server/Schema/ResourceDocumentHeader-1.0.0.xsd
-server/Schema/WatermarkDefinition-2.4.0.xsd
-server/Schema/DrawingSource-1.0.0.xsd
-server/Schema/RepositoryList-1.0.0.xsd
-server/Schema/LayerDefinition-1.2.0.xsd
-server/Schema/Role-1.0.0.xsd
-server/Schema/FdoProviderCapabilities-1.1.0.xsd
-server/Schema/PrintLayout-1.0.0.xsd
-server/Schema/FeatureSet-1.0.0.xsd
-server/Schema/LayerDefinition-2.3.0.xsd
-server/Schema/Server-1.0.0.xsd
-server/Schema/SqlSelect-1.0.0.xsd
-server/Schema/WebLayout-2.4.0.xsd
-server/Schema/RuntimeMap-3.0.0.xsd
-server/Schema/UnitOfMeasure-4.0.0.xsd
-server/Schema/WebLayout-2.6.0.xsd
-server/Schema/SymbolDefinition-1.0.0.xsd
-server/Schema/ResourceFolderHeader-1.0.0.xsd
-server/Schema/SiteInformation-2.2.0.xsd
+server/Schema/ApplicationDefinition-1.0.0.xsd
+server/Schema/ApplicationDefinitionInfo-1.0.0.xsd
 server/Schema/BatchPropertyCollection-1.0.0.xsd
-server/Schema/SelectAggregate-1.0.0.xsd
-server/Schema/LayerDefinition-1.1.0.xsd
-server/Schema/TileProviderList-3.0.0.xsd
-server/Schema/ResourceDataList-1.0.0.xsd
-server/Schema/MapDefinition-2.4.0.xsd
-server/Schema/SiteStatus-2.2.0.xsd
-server/Schema/FdoSpatialContextList-1.0.0.xsd
 server/Schema/ClassDefinition-4.0.0.xsd
-server/Schema/WatermarkDefinition-2.3.0.xsd
-server/Schema/FeatureSource-1.0.0.xsd
 server/Schema/DataStoreList-1.0.0.xsd
+server/Schema/DrawingSectionList-1.0.0.xsd
+server/Schema/DrawingSectionResourceList-1.0.0.xsd
+server/Schema/DrawingSource-1.0.0.xsd
 server/Schema/Envelope-1.0.0.xsd
-server/Schema/MapDefinition-1.0.0.xsd
+server/Schema/FdoLongTransactionList-1.0.0.xsd
 server/Schema/FdoProviderCapabilities-1.0.0.xsd
-server/Schema/TileSetDefinition-3.0.0.xsd
-server/Schema/ProfileResult-2.4.0.xsd
-server/Schema/User-1.0.0.xsd
-server/Schema/UnmanagedDataList-1.0.0.xsd
-server/Schema/SymbolDefinition-2.4.0.xsd
-server/Schema/LoadProcedure-1.0.0.xsd
-server/Schema/SymbolLibrary-1.0.0.xsd
+server/Schema/FdoProviderCapabilities-1.1.0.xsd
+server/Schema/FdoSpatialContextList-1.0.0.xsd
 server/Schema/FeatureProviderRegistry-1.0.0.xsd
-server/Schema/WebLayout-1.1.0.xsd
 server/Schema/FeatureSchemaCollection-4.0.0.xsd
+server/Schema/FeatureSet-1.0.0.xsd
+server/Schema/FeatureSource-1.0.0.xsd
+server/Schema/GeometryInfo-4.0.0.xsd
+server/Schema/Group-1.0.0.xsd
+server/Schema/GroupList-1.0.0.xsd
+server/Schema/LayerDefinition-1.0.0.xsd
+server/Schema/LayerDefinition-1.1.0.xsd
+server/Schema/LayerDefinition-1.2.0.xsd
+server/Schema/LayerDefinition-1.3.0.xsd
+server/Schema/LayerDefinition-2.3.0.xsd
 server/Schema/LayerDefinition-2.4.0.xsd
-server/Schema/SiteVersion-1.0.0.xsd
-server/Schema/WebLayout-1.0.0.xsd
+server/Schema/LayerDefinition-4.0.0.xsd
+server/Schema/LoadProcedure-1.0.0.xsd
+server/Schema/LoadProcedure-1.1.0.xsd
+server/Schema/LoadProcedure-2.2.0.xsd
+server/Schema/MapDefinition-1.0.0.xsd
+server/Schema/MapDefinition-2.3.0.xsd
+server/Schema/MapDefinition-2.4.0.xsd
+server/Schema/MapDefinition-3.0.0.xsd
+server/Schema/PlatformCommon-1.0.0.xsd
+server/Schema/PrintLayout-1.0.0.xsd
+server/Schema/ProfileResult-2.4.0.xsd
 server/Schema/RepositoryContent-1.0.0.xsd
-server/Schema/Group-1.0.0.xsd
-server/Schema/GeometryInfo-4.0.0.xsd
+server/Schema/RepositoryList-1.0.0.xsd
+server/Schema/ResourceDataList-1.0.0.xsd
+server/Schema/ResourceDocumentHeader-1.0.0.xsd
+server/Schema/ResourceFolderHeader-1.0.0.xsd
+server/Schema/ResourceList-1.0.0.xsd
+server/Schema/ResourcePackageManifest-1.0.0.xsd
+server/Schema/ResourceReferenceList-1.0.0.xsd
+server/Schema/ResourceSecurity-1.0.0.xsd
+server/Schema/Role-1.0.0.xsd
+server/Schema/RuntimeMap-2.6.0.xsd
+server/Schema/RuntimeMap-3.0.0.xsd
 server/Schema/RuntimeMap-4.0.0.xsd
+server/Schema/SelectAggregate-1.0.0.xsd
+server/Schema/Server-1.0.0.xsd
 server/Schema/ServerList-1.0.0.xsd
 server/Schema/SiteInformation-1.0.0.xsd
+server/Schema/SiteInformation-2.2.0.xsd
+server/Schema/SiteStatus-2.2.0.xsd
+server/Schema/SiteVersion-1.0.0.xsd
+server/Schema/SiteVersion-2.2.0.xsd
+server/Schema/SqlSelect-1.0.0.xsd
 server/Schema/StringCollection-1.0.0.xsd
-server/Schema/DrawingSectionResourceList-1.0.0.xsd
-server/Schema/ResourcePackageManifest-1.0.0.xsd
-server/Schema/MapDefinition-2.3.0.xsd
-server/Schema/LoadProcedure-1.1.0.xsd
-server/Schema/FdoLongTransactionList-1.0.0.xsd
+server/Schema/SymbolDefinition-1.0.0.xsd
+server/Schema/SymbolDefinition-1.1.0.xsd
+server/Schema/SymbolDefinition-2.4.0.xsd
+server/Schema/SymbolLibrary-1.0.0.xsd
+server/Schema/TileProviderList-3.0.0.xsd
+server/Schema/TileSetDefinition-3.0.0.xsd
+server/Schema/TransformedCoordinateCollection-4.0.0.xsd
 server/Schema/Types-1.0.0.xsd
-server/Schema/DrawingSectionList-1.0.0.xsd
-server/Schema/ApplicationDefinitionInfo-1.0.0.xsd
-server/Schema/ResourceReferenceList-1.0.0.xsd
-server/Schema/LayerDefinition-4.0.0.xsd
+server/Schema/UnitOfMeasure-4.0.0.xsd
+server/Schema/UnmanagedDataList-1.0.0.xsd
+server/Schema/User-1.0.0.xsd
 server/Schema/UserList-1.0.0.xsd
-server/Schema/SymbolDefinition-1.1.0.xsd
-server/Schema/ApplicationDefinition-1.0.0.xsd
-server/Schema/LoadProcedure-2.2.0.xsd
-server/Schema/GroupList-1.0.0.xsd
-server/Schema/LayerDefinition-1.0.0.xsd
-server/Schema/SiteVersion-2.2.0.xsd
-server/Schema/ResourceList-1.0.0.xsd
-server/Schema/RuntimeMap-2.6.0.xsd
-server/Schema/MapDefinition-3.0.0.xsd
-server/Schema/TransformedCoordinateCollection-4.0.0.xsd
-server/Schema/LayerDefinition-1.3.0.xsd
-server/Schema/ResourceSecurity-1.0.0.xsd
-server/Schema/PlatformCommon-1.0.0.xsd
-server/RepositoryAdmin/
-server/RepositoryAdmin/UpgradeRepositories.sh
-server/RepositoryAdmin/MapGuide.RepositoryAdmin
-server/RepositoryAdmin/COPYRIGHT
-server/RepositoryAdmin/README.txt
-server/RepositoryAdmin/BackUpOfflineRepositories.sh
-server/RepositoryAdmin/BackUpOnlineRepositories.sh
-server/RepositoryAdmin/SetupRepositoryIndices.sh
-server/RepositoryAdmin/RestoreColdBackupRepositories.sh
-server/RepositoryAdmin/RestoreHotBackupRepositories.sh
-server/RepositoryAdmin/RecoverRepositories.sh
-server/Packages/
+server/Schema/WatermarkDefinition-2.3.0.xsd
+server/Schema/WatermarkDefinition-2.4.0.xsd
+server/Schema/WebLayout-1.0.0.xsd
+server/Schema/WebLayout-1.1.0.xsd
+server/Schema/WebLayout-2.4.0.xsd
+server/Schema/WebLayout-2.6.0.xsd
 server/Temp/
+server/Trash/
+server/Wfs/
+server/Wfs/1.0.0.xml.awd
+server/Wfs/1.1.0.xml.awd
+server/Wfs/OgcWfsService.config.awd
 server/Wms/
-server/Wms/REGRESS.xml.awd
-server/Wms/1.3.0.xml.awd
-server/Wms/1.1.1.xml.awd
 server/Wms/1.0.0.xml.awd
 server/Wms/1.1.0.xml.awd
+server/Wms/1.1.1.xml.awd
+server/Wms/1.3.0.xml.awd
 server/Wms/OgcWmsService.config.awd
-server/Wfs/
-server/Wfs/OgcWfsService.config.awd
-server/Wfs/1.0.0.xml.awd
-server/Wfs/1.1.0.xml.awd
+server/Wms/REGRESS.xml.awd
+server/bin/
+server/bin/db_archive
+server/bin/db_checkpoint
+server/bin/db_dump
+server/bin/db_hotbackup
+server/bin/db_load
+server/bin/db_recover
+server/bin/db_upgrade
+server/bin/db_verify
+server/bin/dbxml
+server/bin/dbxml_dump
+server/bin/dbxml_load
+server/bin/mapguidectl
+server/bin/mgserver
+server/bin/mgserver.sh
+server/bin/mgserver_test.sh
+server/bin/mgserverd.sh
+server/bin/serverconfig.ini
 server/lib64/
-server/lib64/libMgServerFeatureService-4.0.0.so
-server/lib64/libdb_cxx.so
-server/lib64/libdbxml-2.5.so
-server/lib64/libMgServerRenderingService-4.0.0.so
-server/lib64/libMgServerResourceService-4.0.0.so
-server/lib64/libdb-4.8.so
-server/lib64/libMgServerMappingService-4.0.0.so
-server/lib64/libMgServerBase-4.0.0.so
+server/lib64/libMgServerAdminService-4.0.1.so
 server/lib64/libMgServerAdminService.so
+server/lib64/libMgServerBase-4.0.1.so
+server/lib64/libMgServerBase.so
+server/lib64/libMgServerCache-4.0.1.so
+server/lib64/libMgServerCache.so
+server/lib64/libMgServerDrawingService-4.0.1.so
+server/lib64/libMgServerDrawingService.so
+server/lib64/libMgServerFeatureService-4.0.1.so
+server/lib64/libMgServerFeatureService.so
+server/lib64/libMgServerKmlService-4.0.1.so
+server/lib64/libMgServerKmlService.so
+server/lib64/libMgServerManager-4.0.1.so
+server/lib64/libMgServerManager.so
+server/lib64/libMgServerMappingService-4.0.1.so
+server/lib64/libMgServerMappingService.so
+server/lib64/libMgServerProfilingService-4.0.1.so
+server/lib64/libMgServerProfilingService.so
+server/lib64/libMgServerRenderingService-4.0.1.so
+server/lib64/libMgServerRenderingService.so
+server/lib64/libMgServerResourceService-4.0.1.so
+server/lib64/libMgServerResourceService.so
+server/lib64/libMgServerSiteService-4.0.1.so
+server/lib64/libMgServerSiteService.so
+server/lib64/libMgServerThread-4.0.1.so
+server/lib64/libMgServerThread.so
+server/lib64/libMgServerTileService-4.0.1.so
 server/lib64/libMgServerTileService.so
-server/lib64/libMgServerSiteService-4.0.0.so
-server/lib64/libMgServerProfilingService-4.0.0.so
-server/lib64/libxqilla.so.5
+server/lib64/libMgUnitTesting.so
+server/lib64/libdb-4.8.so
 server/lib64/libdb-4.so
-server/lib64/libMgServerSiteService.so
-server/lib64/libMgServerManager-4.0.0.so
-server/lib64/libMgServerBase.so
 server/lib64/libdb.so
-server/lib64/libMgServerRenderingService.so
 server/lib64/libdb_cxx-4.8.so
-server/lib64/libMgServerThread-4.0.0.so
-server/lib64/libMgServerDrawingService.so
-server/lib64/libMgServerDrawingService-4.0.0.so
-server/lib64/libMgServerManager.so
-server/lib64/libMgServerFeatureService.so
-server/lib64/libMgUnitTesting.so
-server/lib64/libMgServerThread.so
-server/lib64/libMgServerKmlService-4.0.0.so
-server/lib64/libMgServerKmlService.so
 server/lib64/libdb_cxx-4.so
+server/lib64/libdb_cxx.so
+server/lib64/libdbxml-2.5.so
 server/lib64/libdbxml.so
-server/lib64/libMgServerTileService-4.0.0.so
-server/lib64/libMgServerCache-4.0.0.so
-server/lib64/libMgServerResourceService.so
-server/lib64/libMgServerAdminService-4.0.0.so
+server/lib64/libxqilla.so
+server/lib64/libxqilla.so.5
 server/lib64/libxqilla.so.5.0.4
-server/lib64/libMgServerMappingService.so
-server/lib64/libMgServerProfilingService.so
-server/lib64/libMgServerCache.so
-server/bin/
-server/bin/db_recover
-server/bin/db_checkpoint
-server/bin/dbxml_dump
-server/bin/dbxml
-server/bin/db_load
-server/bin/db_upgrade
-server/bin/db_archive
-server/bin/dbxml_load
-server/bin/db_dump
-server/bin/db_verify
-server/bin/serverconfig.ini
-server/bin/mgserver_test.sh
-server/bin/mapguidectl
-server/bin/mgserverd.sh
-server/bin/mgserver.sh
-server/bin/db_hotbackup
-server/Repositories/
-server/Trash/
-server/Resources/
-server/Resources/mapguide_en.res
 share/
 share/gis/
 share/gis/coordsys/
-share/gis/coordsys/NameMapper.csv
+share/gis/coordsys/Australia/
+share/gis/coordsys/Australia/Agd66/
+share/gis/coordsys/Australia/Agd66/A66National(13.09.01).gsb
+share/gis/coordsys/Australia/Agd84/
+share/gis/coordsys/Australia/Agd84/National84(02.07.01).gsb
+share/gis/coordsys/Australia/Gda94/
+share/gis/coordsys/Brazil/
+share/gis/coordsys/Brazil/CA61_003.GSB
+share/gis/coordsys/Brazil/CA7072_003.GSB
+share/gis/coordsys/CS-MAP.GID
+share/gis/coordsys/CS_Comp
+share/gis/coordsys/CS_DictDiff
+share/gis/coordsys/Canada/
+share/gis/coordsys/Canada/ReadMe.txt
+share/gis/coordsys/Category.CSD
+share/gis/coordsys/Coordsys.CSD
+share/gis/coordsys/Datums.CSD
+share/gis/coordsys/Elipsoid.CSD
+share/gis/coordsys/France/
+share/gis/coordsys/France/gr3df97a.txt
+share/gis/coordsys/GeodeticPath.CSD
+share/gis/coordsys/GeodeticPath.asc
+share/gis/coordsys/GeodeticTransform.CSD
+share/gis/coordsys/GeodeticTransformation.asc
+share/gis/coordsys/GeoidHeight.gdc
 share/gis/coordsys/Germany/
 share/gis/coordsys/Germany/BETA2007.gsb
+share/gis/coordsys/Japan/
+share/gis/coordsys/Japan/ReadMe.txt
+share/gis/coordsys/Japan/TKY2JGD._par
+share/gis/coordsys/Japan/TKY2JGD.par
+share/gis/coordsys/NameMapper.csv
+share/gis/coordsys/NewZealand/
+share/gis/coordsys/NewZealand/nzgd2kgrid0005.gsb
+share/gis/coordsys/OSGM91.TXT
+share/gis/coordsys/OSTN02._02
+share/gis/coordsys/OSTN02.txt
+share/gis/coordsys/OSTN97.TXT
 share/gis/coordsys/OSTN97._nt
-share/gis/coordsys/France/
-share/gis/coordsys/France/gr3df97a.txt
-share/gis/coordsys/Vertcon.gdc
-share/gis/coordsys/license.txt
-share/gis/coordsys/CS_DictDiff
-share/gis/coordsys/Canada/
-share/gis/coordsys/Canada/ReadMe.txt
+share/gis/coordsys/Portugal/
+share/gis/coordsys/Portugal/D73_ETRS89_geo.gsb
+share/gis/coordsys/Portugal/DLX_ETRS89_geo.gsb
+share/gis/coordsys/Portugal/pt73_e89.gsb
+share/gis/coordsys/Portugal/ptED_e89.gsb
+share/gis/coordsys/Portugal/ptLB_e89.gsb
+share/gis/coordsys/Portugal/ptLX_e89.gsb
+share/gis/coordsys/Spain/
+share/gis/coordsys/Spain/copyright_and_disclaimer.txt
+share/gis/coordsys/Spain/sped2et-2005.gsb
+share/gis/coordsys/Switzerland/
+share/gis/coordsys/Switzerland/CHENYX06.gsb
+share/gis/coordsys/UK/
+share/gis/coordsys/UK/HS2TN02_NTv2.gsb
+share/gis/coordsys/UK/HS2TN15_NTv2.gsb
+share/gis/coordsys/UK/OSTN15_NTv2_OSGBtoETRS.gsb
+share/gis/coordsys/UK/OSTN15_OSGM15_GB.txt
+share/gis/coordsys/UK/TN15-ETRS89-to-EWR2-IRF.gsb
+share/gis/coordsys/UK/ostn02.gsb
 share/gis/coordsys/Usa/
-share/gis/coordsys/Usa/Nadcon/
-share/gis/coordsys/Usa/Nadcon/stlrnc.los
-share/gis/coordsys/Usa/Nadcon/hawaii.las
-share/gis/coordsys/Usa/Nadcon/prvi.las
-share/gis/coordsys/Usa/Nadcon/stgeorge.las
-share/gis/coordsys/Usa/Nadcon/conus.los
-share/gis/coordsys/Usa/Nadcon/conus.las
-share/gis/coordsys/Usa/Nadcon/hawaii.los
-share/gis/coordsys/Usa/Nadcon/alaska.los
-share/gis/coordsys/Usa/Nadcon/stpaul.los
-share/gis/coordsys/Usa/Nadcon/stgeorge.los
-share/gis/coordsys/Usa/Nadcon/alaska.las
-share/gis/coordsys/Usa/Nadcon/prvi.los
-share/gis/coordsys/Usa/Nadcon/stpaul.las
-share/gis/coordsys/Usa/Nadcon/stlrnc.las
 share/gis/coordsys/Usa/Harn/
-share/gis/coordsys/Usa/Harn/nchpgn.las
-share/gis/coordsys/Usa/Harn/kshpgn.las
-share/gis/coordsys/Usa/Harn/nmhpgn.las
-share/gis/coordsys/Usa/Harn/uthpgn.los
-share/gis/coordsys/Usa/Harn/nbhpgn.los
-share/gis/coordsys/Usa/Harn/wohpgn.los
-share/gis/coordsys/Usa/Harn/nbhpgn.las
-share/gis/coordsys/Usa/Harn/wihpgn.los
-share/gis/coordsys/Usa/Harn/mohpgn.los
-share/gis/coordsys/Usa/Harn/mshpgn.los
+share/gis/coordsys/Usa/Harn/48hpgn.las
+share/gis/coordsys/Usa/Harn/48hpgn.los
+share/gis/coordsys/Usa/Harn/alhpgn.las
+share/gis/coordsys/Usa/Harn/alhpgn.los
+share/gis/coordsys/Usa/Harn/arhpgn.las
 share/gis/coordsys/Usa/Harn/arhpgn.los
+share/gis/coordsys/Usa/Harn/azhpgn.las
+share/gis/coordsys/Usa/Harn/azhpgn.los
+share/gis/coordsys/Usa/Harn/cahpgn.las
+share/gis/coordsys/Usa/Harn/cahpgn.los
+share/gis/coordsys/Usa/Harn/cnhpgn.las
+share/gis/coordsys/Usa/Harn/cnhpgn.los
+share/gis/coordsys/Usa/Harn/cohpgn.las
+share/gis/coordsys/Usa/Harn/cohpgn.los
+share/gis/coordsys/Usa/Harn/cshpgn.las
 share/gis/coordsys/Usa/Harn/cshpgn.los
-share/gis/coordsys/Usa/Harn/wihpgn.las
-share/gis/coordsys/Usa/Harn/nvhpgn.las
-share/gis/coordsys/Usa/Harn/okhpgn.los
-share/gis/coordsys/Usa/Harn/okhpgn.las
-share/gis/coordsys/Usa/Harn/48hpgn.las
 share/gis/coordsys/Usa/Harn/emhpgn.las
-share/gis/coordsys/Usa/Harn/wshpgn.las
-share/gis/coordsys/Usa/Harn/ohhpgn.los
-share/gis/coordsys/Usa/Harn/sdhpgn.las
-share/gis/coordsys/Usa/Harn/sdhpgn.los
-share/gis/coordsys/Usa/Harn/pahpgn.las
+share/gis/coordsys/Usa/Harn/emhpgn.los
+share/gis/coordsys/Usa/Harn/eshpgn.las
+share/gis/coordsys/Usa/Harn/eshpgn.los
+share/gis/coordsys/Usa/Harn/ethpgn.las
+share/gis/coordsys/Usa/Harn/ethpgn.los
+share/gis/coordsys/Usa/Harn/flhpgn.las
+share/gis/coordsys/Usa/Harn/flhpgn.los
+share/gis/coordsys/Usa/Harn/gahpgn.las
+share/gis/coordsys/Usa/Harn/gahpgn.los
+share/gis/coordsys/Usa/Harn/guhpgn.las
+share/gis/coordsys/Usa/Harn/guhpgn.los
+share/gis/coordsys/Usa/Harn/hihpgn.las
+share/gis/coordsys/Usa/Harn/hihpgn.los
+share/gis/coordsys/Usa/Harn/iahpgn.las
+share/gis/coordsys/Usa/Harn/iahpgn.los
+share/gis/coordsys/Usa/Harn/ilhpgn.las
+share/gis/coordsys/Usa/Harn/ilhpgn.los
+share/gis/coordsys/Usa/Harn/inhpgn.las
+share/gis/coordsys/Usa/Harn/inhpgn.los
+share/gis/coordsys/Usa/Harn/kshpgn.las
+share/gis/coordsys/Usa/Harn/kshpgn.los
 share/gis/coordsys/Usa/Harn/kyhpgn.las
-share/gis/coordsys/Usa/Harn/cshpgn.las
-share/gis/coordsys/Usa/Harn/wohpgn.las
-share/gis/coordsys/Usa/Harn/hihpgn.las
-share/gis/coordsys/Usa/Harn/ethpgn.las
-share/gis/coordsys/Usa/Harn/cahpgn.las
-share/gis/coordsys/Usa/Harn/alhpgn.las
-share/gis/coordsys/Usa/Harn/nehpgn.los
-share/gis/coordsys/Usa/Harn/njhpgn.las
-share/gis/coordsys/Usa/Harn/wyhpgn.las
-share/gis/coordsys/Usa/Harn/alhpgn.los
+share/gis/coordsys/Usa/Harn/kyhpgn.los
+share/gis/coordsys/Usa/Harn/lahpgn.las
+share/gis/coordsys/Usa/Harn/lahpgn.los
+share/gis/coordsys/Usa/Harn/mdhpgn.las
+share/gis/coordsys/Usa/Harn/mdhpgn.los
+share/gis/coordsys/Usa/Harn/mehpgn.las
+share/gis/coordsys/Usa/Harn/mehpgn.los
+share/gis/coordsys/Usa/Harn/mihpgn.las
 share/gis/coordsys/Usa/Harn/mihpgn.los
-share/gis/coordsys/Usa/Harn/iahpgn.los
-share/gis/coordsys/Usa/Harn/eshpgn.los
-share/gis/coordsys/Usa/Harn/wvhpgn.las
-share/gis/coordsys/Usa/Harn/schpgn.las
-share/gis/coordsys/Usa/Harn/hihpgn.los
+share/gis/coordsys/Usa/Harn/mnhpgn.las
+share/gis/coordsys/Usa/Harn/mnhpgn.los
+share/gis/coordsys/Usa/Harn/mohpgn.las
+share/gis/coordsys/Usa/Harn/mohpgn.los
+share/gis/coordsys/Usa/Harn/mshpgn.las
+share/gis/coordsys/Usa/Harn/mshpgn.los
+share/gis/coordsys/Usa/Harn/nbhpgn.las
+share/gis/coordsys/Usa/Harn/nbhpgn.los
+share/gis/coordsys/Usa/Harn/nchpgn.las
+share/gis/coordsys/Usa/Harn/nchpgn.los
 share/gis/coordsys/Usa/Harn/ndhpgn.las
-share/gis/coordsys/Usa/Harn/vahpgn.los
-share/gis/coordsys/Usa/Harn/emhpgn.los
 share/gis/coordsys/Usa/Harn/ndhpgn.los
-share/gis/coordsys/Usa/Harn/mihpgn.las
-share/gis/coordsys/Usa/Harn/kshpgn.los
-share/gis/coordsys/Usa/Harn/azhpgn.los
-share/gis/coordsys/Usa/Harn/ilhpgn.las
-share/gis/coordsys/Usa/Harn/wthpgn.las
-share/gis/coordsys/Usa/Harn/wthpgn.los
+share/gis/coordsys/Usa/Harn/nehpgn.las
+share/gis/coordsys/Usa/Harn/nehpgn.los
+share/gis/coordsys/Usa/Harn/njhpgn.las
+share/gis/coordsys/Usa/Harn/njhpgn.los
+share/gis/coordsys/Usa/Harn/nmhpgn.las
 share/gis/coordsys/Usa/Harn/nmhpgn.los
-share/gis/coordsys/Usa/Harn/lahpgn.los
+share/gis/coordsys/Usa/Harn/nvhpgn.las
 share/gis/coordsys/Usa/Harn/nvhpgn.los
+share/gis/coordsys/Usa/Harn/nyhpgn.las
+share/gis/coordsys/Usa/Harn/nyhpgn.los
+share/gis/coordsys/Usa/Harn/ohhpgn.las
+share/gis/coordsys/Usa/Harn/ohhpgn.los
+share/gis/coordsys/Usa/Harn/okhpgn.las
+share/gis/coordsys/Usa/Harn/okhpgn.los
+share/gis/coordsys/Usa/Harn/pahpgn.las
 share/gis/coordsys/Usa/Harn/pahpgn.los
+share/gis/coordsys/Usa/Harn/pvhpgn.las
+share/gis/coordsys/Usa/Harn/pvhpgn.los
