[mapguide-commits] r10286 - in trunk/Installer: . Support/Web/x64
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Nov 13 03:00:56 PST 2026
Author: jng
Date: 2026-11-13 03:00:55 -0800 (Fri, 13 Nov 2026)
New Revision: 10286
Added:
   trunk/Installer/Support/Web/x64/httpd-2.4.71-261112-Win64-VS18.zip
Removed:
   trunk/Installer/Support/Web/x64/httpd-2.4.69-261002-Win64-VS18.zip
   trunk/Installer/Support/Web/x64/php-8.3.36-nts-Win32-vs16-x64.zip
   trunk/Installer/build.bat
Installer component updates:
 * httpd 2.4.69 -> 2.4.71
 * php 8.3.36 -> 8.3.36-1 (keeping original filename as it is simpler than trying to get our build scripts to recognise the -1 suffix)
Deleted: trunk/Installer/Support/Web/x64/httpd-2.4.69-261002-Win64-VS18.zip
(Binary files differ)
Added: trunk/Installer/Support/Web/x64/httpd-2.4.71-261112-Win64-VS18.zip
Index: trunk/Installer/Support/Web/x64/httpd-2.4.71-261112-Win64-VS18.zip
--- trunk/Installer/Support/Web/x64/httpd-2.4.71-261112-Win64-VS18.zip	2026-11-13 10:53:23 UTC (rev 10285)
+++ trunk/Installer/Support/Web/x64/httpd-2.4.71-261112-Win64-VS18.zip	2026-11-13 11:00:55 UTC (rev 10286)
Property changes on: trunk/Installer/Support/Web/x64/httpd-2.4.71-261112-Win64-VS18.zip
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+application/octet-stream
\ No newline at end of property
Modified: trunk/Installer/Support/Web/x64/php-8.3.36-nts-Win32-vs16-x64.zip
Modified: trunk/Installer/build.bat
--- trunk/Installer/build.bat	2026-11-13 10:53:23 UTC (rev 10285)
+++ trunk/Installer/build.bat	2026-11-13 11:00:55 UTC (rev 10286)
@@ -81,8 +81,8 @@
 rem ==================================================
 rem Web dependencies
-SET HTTPD_VERSION=2.4.69
-SET HTTPD_BUILD=261002
+SET HTTPD_VERSION=2.4.71
+SET HTTPD_BUILD=261112
 SET HTTPD_VCVER=VS18
 SET PHP_VERSION=8.3.36
 SET TOMCAT_VERSION=9.0.123
More information about the mapguide-commits mailing list
