[mapguide-commits] r10294 - branches/4.0/MgDev/Common/PlatformBase/MapLayer
svn_mapguide at osgeo.org
Wed Nov 18 14:46:02 PST 2026
Author: jng
Date: 2026-11-18 14:45:59 -0800 (Wed, 18 Nov 2026)
New Revision: 10294
branches/4.0/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp
Plug leak from previous change
Modified: branches/4.0/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp
--- branches/4.0/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp 2026-11-18 15:43:39 UTC (rev 10293)
+++ branches/4.0/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp 2026-11-18 22:45:59 UTC (rev 10294)
@@ -44,7 +44,22 @@
m_map = SAFE_ADDREF(map);
m_stream = new MgMemoryStreamHelper();
- FromXml(xmlSelectionString);
+ try
+ FromXml(xmlSelectionString);
+ catch (...)
+ // FromXml rejects a selection string that is not XML by throwing, and a constructor that
+ // throws runs no destructor, so everything this object has taken so far has to go back
+ // here. m_stream is a raw pointer and m_selections owns the lists it holds; m_map is a Ptr,
+ // whose destructor does run while the object unwinds.
+ ClearSelections();
+ delete m_stream;
+ m_stream = NULL;
+ throw;
More information about the mapguide-commits
