[mapguide-commits] r10222 - in branches/4.0/MgDev: . Oem/LinuxApt
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Oct 21 15:30:54 PDT 2026
Author: jng
Date: 2026-10-21 15:30:53 -0700 (Wed, 21 Oct 2026)
New Revision: 10222
Added:
   branches/4.0/MgDev/Oem/LinuxApt/apache-tomcat-9.0.123.tar.gz
   branches/4.0/MgDev/Oem/LinuxApt/apr-util-1.6.5.tar.bz2
   branches/4.0/MgDev/Oem/LinuxApt/httpd-2.4.69.tar.bz2
   branches/4.0/MgDev/Oem/LinuxApt/php-8.3.36.tar.bz2
Removed:
   branches/4.0/MgDev/Oem/LinuxApt/apache-tomcat-9.0.110.tar.gz
   branches/4.0/MgDev/Oem/LinuxApt/apr-util-1.6.3.tar.bz2
   branches/4.0/MgDev/Oem/LinuxApt/httpd-2.4.65.tar.bz2
   branches/4.0/MgDev/Oem/LinuxApt/php-8.3.26.tar.bz2
   branches/4.0/MgDev/Oem/LinuxApt/CMakeLists.txt
   branches/4.0/MgDev/UPDATING_WEBTIER_COMPONENTS.md
   branches/4.0/MgDev/cmake_linuxapt.sh
   branches/4.0/MgDev/prepare_webtier_components.bat
MapGuide Web Tier component updates
- PHP 8.3.26 -> 8.3.36 (includes php2shell fix)
- HTTPD 2.4.65 -> 2.4.69
- Tomcat 9.0.110 -> 9.0.123
- APR util 1.6.3 -> 1.6.5
Modified: branches/4.0/MgDev/Oem/LinuxApt/CMakeLists.txt
--- branches/4.0/MgDev/Oem/LinuxApt/CMakeLists.txt	2026-10-21 22:24:19 UTC (rev 10221)
+++ branches/4.0/MgDev/Oem/LinuxApt/CMakeLists.txt	2026-10-21 22:30:53 UTC (rev 10222)
@@ -20,7 +20,7 @@
     file(MAKE_DIRECTORY ${CMAKE_CURRENT_BINARY_DIR}/tomcat)
     # TODO: Offload tomcat version to top-level var
-    execute_process(COMMAND tar -zxf ${CMAKE_CURRENT_SOURCE_DIR}/apache-tomcat-9.0.110.tar.gz -C ${CMAKE_CURRENT_BINARY_DIR}/tomcat --strip-components=1)
+    execute_process(COMMAND tar -zxf ${CMAKE_CURRENT_SOURCE_DIR}/apache-tomcat-9.0.123.tar.gz -C ${CMAKE_CURRENT_BINARY_DIR}/tomcat --strip-components=1)
     configure_file(${CMAKE_MODULE_PATH}/../configs/mapguide.xml.in ${CMAKE_CURRENT_BINARY_DIR}/tomcat/conf/Catalina/localhost/mapguide.xml)
     # Don't overwrite startup.sh in the CMAKE_CURRENT_BINARY_DIR as the subseqent install will do the same thing
@@ -31,4 +31,4 @@
     file(GLOB TOMCAT_SCRIPTS "${CMAKE_CURRENT_BINARY_DIR}/tomcat/bin/*.sh")
     install(PROGRAMS ${TOMCAT_SCRIPTS} DESTINATION ${MG_INSTALL_WEB_PREFIX}/tomcat/bin)
     install(PROGRAMS ${CMAKE_CURRENT_BINARY_DIR}/startup.sh DESTINATION ${MG_INSTALL_WEB_PREFIX}/tomcat/bin)
-endif (WITH_JAVA)
\ No newline at end of file
+endif (WITH_JAVA)
Deleted: branches/4.0/MgDev/Oem/LinuxApt/apache-tomcat-9.0.110.tar.gz
(Binary files differ)
Added: branches/4.0/MgDev/Oem/LinuxApt/apache-tomcat-9.0.123.tar.gz
Index: branches/4.0/MgDev/Oem/LinuxApt/apache-tomcat-9.0.123.tar.gz
--- branches/4.0/MgDev/Oem/LinuxApt/apache-tomcat-9.0.123.tar.gz	2026-10-21 22:24:19 UTC (rev 10221)
+++ branches/4.0/MgDev/Oem/LinuxApt/apache-tomcat-9.0.123.tar.gz	2026-10-21 22:30:53 UTC (rev 10222)
Property changes on: branches/4.0/MgDev/Oem/LinuxApt/apache-tomcat-9.0.123.tar.gz
___________________________________________________________________
Added: svn:mime-type
## -0,0 +1 ##
+application/gzip
\ No newline at end of property
Deleted: branches/4.0/MgDev/Oem/LinuxApt/apr-util-1.6.3.tar.bz2
Added: branches/4.0/MgDev/Oem/LinuxApt/apr-util-1.6.5.tar.bz2
Index: branches/4.0/MgDev/Oem/LinuxApt/apr-util-1.6.5.tar.bz2
--- branches/4.0/MgDev/Oem/LinuxApt/apr-util-1.6.5.tar.bz2	2026-10-21 22:24:19 UTC (rev 10221)
+++ branches/4.0/MgDev/Oem/LinuxApt/apr-util-1.6.5.tar.bz2	2026-10-21 22:30:53 UTC (rev 10222)
Property changes on: branches/4.0/MgDev/Oem/LinuxApt/apr-util-1.6.5.tar.bz2
## -0,0 +1 ##
+application/x-bzip2
Deleted: branches/4.0/MgDev/Oem/LinuxApt/httpd-2.4.65.tar.bz2
Added: branches/4.0/MgDev/Oem/LinuxApt/httpd-2.4.69.tar.bz2
Index: branches/4.0/MgDev/Oem/LinuxApt/httpd-2.4.69.tar.bz2
--- branches/4.0/MgDev/Oem/LinuxApt/httpd-2.4.69.tar.bz2	2026-10-21 22:24:19 UTC (rev 10221)
+++ branches/4.0/MgDev/Oem/LinuxApt/httpd-2.4.69.tar.bz2	2026-10-21 22:30:53 UTC (rev 10222)
Property changes on: branches/4.0/MgDev/Oem/LinuxApt/httpd-2.4.69.tar.bz2
## -0,0 +1 ##
Deleted: branches/4.0/MgDev/Oem/LinuxApt/php-8.3.26.tar.bz2
Added: branches/4.0/MgDev/Oem/LinuxApt/php-8.3.36.tar.bz2
Index: branches/4.0/MgDev/Oem/LinuxApt/php-8.3.36.tar.bz2
--- branches/4.0/MgDev/Oem/LinuxApt/php-8.3.36.tar.bz2	2026-10-21 22:24:19 UTC (rev 10221)
+++ branches/4.0/MgDev/Oem/LinuxApt/php-8.3.36.tar.bz2	2026-10-21 22:30:53 UTC (rev 10222)
Property changes on: branches/4.0/MgDev/Oem/LinuxApt/php-8.3.36.tar.bz2
## -0,0 +1 ##
Modified: branches/4.0/MgDev/UPDATING_WEBTIER_COMPONENTS.md
--- branches/4.0/MgDev/UPDATING_WEBTIER_COMPONENTS.md	2026-10-21 22:24:19 UTC (rev 10221)
+++ branches/4.0/MgDev/UPDATING_WEBTIER_COMPONENTS.md	2026-10-21 22:30:53 UTC (rev 10222)
@@ -39,7 +39,7 @@
  * For `tomcat`, `httpd` and `php`, only update to the latest release in that series. Do not update to a new major version unless that is planned for (ie. The current major version has entered EOL). As of writing this document, the current major release versions are:
    * `apache-tomcat` - `9.0.x`
    * `httpd` - `2.4.x`
-   * `php` - `8.1.x`
+   * `php` - `8.3.x`
  * Update `CMakeLists.txt`
    * Update referenced tomcat version number
@@ -121,4 +121,4 @@
   * apr-util [old version] -> [new version]
   * tomcat [old version] -> [new version]
   * tomcat-connectors [old version] -> [new version]
Modified: branches/4.0/MgDev/cmake_linuxapt.sh
--- branches/4.0/MgDev/cmake_linuxapt.sh	2026-10-21 22:24:19 UTC (rev 10221)
+++ branches/4.0/MgDev/cmake_linuxapt.sh	2026-10-21 22:30:53 UTC (rev 10222)
@@ -130,11 +130,11 @@
     echo "Created LinuxApt working dir at: $LINUXAPT_WORK_DIR"
 fi
-PHP_VER=8.3.26
-HTTPD_VER=2.4.65
+PHP_VER=8.3.36
+HTTPD_VER=2.4.69
 TC_VER=1.2.50
 APR_VER=1.7.6
-APR_UTIL_VER=1.6.3
+APR_UTIL_VER=1.6.5
 HTTPD_PORT=8008
 TOMCAT_PORT=8009
@@ -299,4 +299,4 @@
 fi
 echo "$OEM_WORK_DIR/env_vars.sh updated"
-echo "Make sure to run cmake_build.sh with --oem-working-dir set to: $OEM_WORK_DIR"
+echo "Make sure to run cmake_build.sh with --oem-working-dir set to: $OEM_WORK_DIR"
Modified: branches/4.0/MgDev/prepare_webtier_components.bat
--- branches/4.0/MgDev/prepare_webtier_components.bat	2026-10-21 22:24:19 UTC (rev 10221)
+++ branches/4.0/MgDev/prepare_webtier_components.bat	2026-10-21 22:30:53 UTC (rev 10222)
@@ -1,6 +1,6 @@
 @echo off
 SET SEVENZ=%CD%\BuildTools\WebTools\7-zip\7z.exe
-SET HTTPD_VER=2.4.65
+SET HTTPD_VER=2.4.69
 pushd Oem\LinuxApt
 :check_httpd
 if not exist httpd-%HTTPD_VER% goto unpack_httpd
More information about the mapguide-commits mailing list
