[mapguide-commits] r10224 - in branches/4.0/MgDev: Common/Foundation/Data Server/src/UnitTesting
svn_mapguide at osgeo.org
Wed Oct 21 15:45:33 PDT 2026
Author: jng
Date: 2026-10-21 15:45:33 -0700 (Wed, 21 Oct 2026)
New Revision: 10224
branches/4.0/MgDev/Common/Foundation/Data/NamedCollection.cpp
branches/4.0/MgDev/Server/src/UnitTesting/TestMisc.cpp
Guard against stale refs (by name) in MgNamedCollection
Fixes #1268
Modified: branches/4.0/MgDev/Common/Foundation/Data/NamedCollection.cpp
--- branches/4.0/MgDev/Common/Foundation/Data/NamedCollection.cpp 2026-10-21 22:40:44 UTC (rev 10223)
+++ branches/4.0/MgDev/Common/Foundation/Data/NamedCollection.cpp 2026-10-21 22:45:33 UTC (rev 10224)
@@ -159,8 +159,12 @@
// the requested object.
if (Compare(obj->GetName(), name) != 0)
- // The names do not match so we need to do a linear search
- // to find it because the collection and the map don't match.
+ // The names do not match, so the object was renamed after it
+ // was added to the map and the entry is keyed by a name it no
+ // longer has. Drop it, and do a linear search to find the
+ // requested object because the collection and the map don't
+ // match.
+ RemoveMap(obj);
obj = NULL;
@@ -184,6 +188,13 @@
+ // The object was not indexed under its current name, so index it now.
+ if (m_pNameMap && obj != NULL)
+ RemoveMap(obj);
+ InsertMap(obj);
return obj.Detach();
@@ -332,9 +343,12 @@
if (m_pNameMap)
- // If map is built, use it since it is faster.
+ // If map is built, use it since it is faster. Its entry for a name can
+ // be stale though, because an element's name can be changed after it
+ // was added, so only a hit for the element itself is conclusive.
Ptr<MgNamedSerializable> item = GetMap( ((MgNamedSerializable*)value)->GetName() );
- return(item != NULL );
+ if (item.p == value)
+ return true;
// otherwise, linear search
@@ -551,11 +565,16 @@
// Remove the given element from the map.
void MgNamedCollection::RemoveMap(const MgNamedSerializable* value)
- // handle the current case sensitivity of the element name.
- if (m_bCaseSensitive)
- m_pNameMap->erase( ((MgNamedSerializable*)value)->GetName() );
- else
- m_pNameMap->erase( Lower(((MgNamedSerializable*)value)->GetName()) );
+ // The element's name may have changed since it was added to the map, so its
+ // entries have to be located by element rather than by name.
+ std::map<STRING, MgNamedSerializable* >::iterator iter = m_pNameMap->begin();
+ while (iter != m_pNameMap->end())
+ if (iter->second == value)
+ m_pNameMap->erase(iter++);
+ else
+ ++iter;
Modified: branches/4.0/MgDev/Server/src/UnitTesting/TestMisc.cpp
--- branches/4.0/MgDev/Server/src/UnitTesting/TestMisc.cpp 2026-10-21 22:40:44 UTC (rev 10223)
+++ branches/4.0/MgDev/Server/src/UnitTesting/TestMisc.cpp 2026-10-21 22:45:33 UTC (rev 10224)
@@ -1017,6 +1017,76 @@
+TEST_CASE("TracTicket1268", "[Misc]")
+ try
+ // MgNamedCollection indexes its elements by name once the collection
+ // outgrows COLL_MAP_THRESHOLD. An element can be renamed after that,
+ // and removal used to erase the map entry by the element's current
+ // name, so the entry keyed by the old name survived and kept pointing
+ // at the removed element.
+ Ptr<MgNamedCollection> coll = new MgNamedCollection(false);
+ Ptr<MgFeatureSchema> renamed;
+ for (INT32 i = 0; i < COLL_MAP_THRESHOLD + 2; i++)
+ STRING suffix;
+ MgUtil::Int32ToString(i, suffix);
+ STRING name = L"Schema" + suffix;
+ Ptr<MgFeatureSchema> schema = new MgFeatureSchema(name, L"");
+ coll->Add(schema);
+ if (i == 0)
+ renamed = schema;
+ // ========================== Begin Test ======================== //
+ // Renaming an element does not take it out of the collection.
+ renamed->SetName(L"RenamedSchema");
+ CHECK(coll->Contains(renamed));
+ Ptr<MgNamedSerializable> found = coll->FindItem(L"RenamedSchema");
+ CHECK(found.p == renamed.p);
+ // Removing the element must remove it completely: neither of the names
+ // it has had may resolve to it afterwards.
+ REQUIRE(coll->Remove(renamed));
+ CHECK(coll->FindItem(L"RenamedSchema") == nullptr);
+ CHECK(coll->FindItem(L"Schema0") == nullptr);
+ // An element that merely carries the vacated name is not in the
+ // collection until it is added.
+ Ptr<MgFeatureSchema> replacement = new MgFeatureSchema(L"Schema0", L"");
+ CHECK(!coll->Contains(replacement));
+ // Drop the last reference to the removed element. A lookup by the name
+ // it used to have must not reach the freed object.
+ found = NULL;
+ renamed = NULL;
+ // The vacated name is free to be used again.
+ coll->Add(replacement);
+ found = coll->FindItem(L"Schema0");
+ REQUIRE(found.p == replacement.p);
+ CHECK(coll->Contains(replacement));
+ catch (MgException* e)
+ STRING message = e->GetDetails(TestServiceFactory::TEST_LOCALE);
+ SAFE_RELEASE(e);
+ FAIL(MG_WCHAR_TO_CHAR(message.c_str()));
+ catch (...)
+ throw;
TEST_CASE("TracTicket1304", "[Misc]")
try
More information about the mapguide-commits
