[mapguide-commits] r10211 - branches/4.0/MgDev/Server/src/Services/Mapping
svn_mapguide at osgeo.org
Thu Sep 10 03:17:52 PDT 2026
Author: jng
Date: 2026-09-10 03:17:52 -0700 (Thu, 10 Sep 2026)
New Revision: 10211
branches/4.0/MgDev/Server/src/Services/Mapping/RSMgFeatureReader.cpp
Fix regression in selection rendering around NULL value handling.
Fixes #2889
Modified: branches/4.0/MgDev/Server/src/Services/Mapping/RSMgFeatureReader.cpp
--- branches/4.0/MgDev/Server/src/Services/Mapping/RSMgFeatureReader.cpp 2026-09-09 14:29:44 UTC (rev 10210)
+++ branches/4.0/MgDev/Server/src/Services/Mapping/RSMgFeatureReader.cpp 2026-09-10 10:17:52 UTC (rev 10211)
@@ -464,6 +464,16 @@
static const size_t MAX_STRING = 64;
+ // A null property value cannot be converted to a string. Return an empty
+ // string instead of letting MgNullPropertyValueException escape, since the
+ // RSFR_TRY/RSFR_CATCH macros no longer translate MgException to FdoException
+ // (see changeset 10158).
+ if (IsNull(propertyName))
+ m_cachePropValue = L"";
+ return m_cachePropValue.c_str();
try
switch (GetPropertyType(propertyName))
@@ -553,7 +563,15 @@
//to put into DWF
+ catch (MgException* e)
+ e->Release();
+ //value is likely null in the provider, so just use empty string
+ //to put into DWF
More information about the mapguide-commits
