[mapguide-commits] r10214 - in sandbox/jng/installer_wix6: . Libraries/MapGuide Server Libraries/MapGuide Web Extensions Support
svn_mapguide at osgeo.org
Fri Sep 11 07:35:47 PDT 2026
Author: jng
Date: 2026-09-11 07:35:46 -0700 (Fri, 11 Sep 2026)
New Revision: 10214
Removed:
sandbox/jng/installer_wix6/Features.xml
sandbox/jng/installer_wix6/Paraffin.exe
sandbox/jng/installer_wix6/Support/Paraffin/
sandbox/jng/installer_wix6/Libraries/MapGuide Server/InstallService.wxs
sandbox/jng/installer_wix6/Libraries/MapGuide Web Extensions/Apache.wxs
Remove all traces of paraffin
Deleted: sandbox/jng/installer_wix6/Features.xml
--- sandbox/jng/installer_wix6/Features.xml 2026-09-11 09:04:17 UTC (rev 10213)
+++ sandbox/jng/installer_wix6/Features.xml 2026-09-11 14:35:46 UTC (rev 10214)
@@ -1,13 +0,0 @@
-<?xml version="1.0" encoding="utf-8" ?>
-<FeatureMap>
- <FeaturePattern Pattern="www\\mapagent\\(.*\.html|.*\.php|.*\.js)" Feature="WebExtMapAgentTestPagesFeature" />
- <FeaturePattern Pattern="www\\mapviewernet\\serveradminhelper.aspx" Feature="WebExtMapAgentTestPagesFeature" />
- <FeaturePattern Pattern="www\\mapviewerphp\\serveradminhelper.php" Feature="WebExtMapAgentTestPagesFeature" />
- <FeaturePattern Pattern="www\\mapviewerjava\\serveradminhelper.jsp" Feature="WebExtMapAgentTestPagesFeature" />
- <IdentifierOverride Pattern="Server\bin\mgserver.exe" Identifier="MGSERVER_EXE" />
- <IdentifierOverride Pattern="Apache24\bin\httpd.exe" Identifier="HTTPD_EXE" />
- <IdentifierOverride Pattern="Tomcat\bin\service.bat" Identifier="TOMCAT_SERVICE_BAT" />
- <IdentifierOverride Pattern="Tomcat\bin\tomcat7.exe" Identifier="TOMCAT_EXE" />
- <IdentifierOverride Pattern="DevHttpServer\MgDevHttpServer.exe" Identifier="DEV_HTTP_SERVER_EXE" />
- <IdentifierOverride Pattern="www\webconfig.ini" Identifier="WEB_CONFIG_INI" />
-</FeatureMap>
\ No newline at end of file
Modified: sandbox/jng/installer_wix6/Libraries/MapGuide Server/InstallService.wxs
--- sandbox/jng/installer_wix6/Libraries/MapGuide Server/InstallService.wxs 2026-09-11 09:04:17 UTC (rev 10213)
+++ sandbox/jng/installer_wix6/Libraries/MapGuide Server/InstallService.wxs 2026-09-11 14:35:46 UTC (rev 10214)
@@ -1,7 +1,6 @@
<Wix xmlns="http://wixtoolset.org/schemas/v4/wxs">
- MGSERVER_EXE is a special identifiers assigned by Paraffin using
- settings defined in Features.xml
+ MGSERVER_EXE is a special identifier defined in HarvestFiles.wxs
<Fragment>
Modified: sandbox/jng/installer_wix6/Libraries/MapGuide Web Extensions/Apache.wxs
--- sandbox/jng/installer_wix6/Libraries/MapGuide Web Extensions/Apache.wxs 2026-09-11 09:04:17 UTC (rev 10213)
+++ sandbox/jng/installer_wix6/Libraries/MapGuide Web Extensions/Apache.wxs 2026-09-11 14:35:46 UTC (rev 10214)
@@ -1,7 +1,6 @@
- HTTPD_EXE, TOMCAT_EXE and TOMCAT_SERVICE_BAT are special identifiers assigned by Paraffin using
+ HTTPD_EXE, TOMCAT_EXE and TOMCAT_SERVICE_BAT are special identifiers defined in HarvestFiles.wxs
<?if "$(var.MgPlatform)" = "x64" ?>
<!-- apache_actions.dll path -->
Deleted: sandbox/jng/installer_wix6/Paraffin.exe
(Binary files differ)
More information about the mapguide-commits
