[mapguide-commits] r10216 - in branches/4.0/MgDev: Common/Renderers Oem/DWFTK/develop/global/src/dwf Oem/DWFTK/develop/global/src/dwf/whiptk Server/src/UnitTesting
svn_mapguide at osgeo.org
Mon Sep 21 05:39:48 PDT 2026
Author: jng
Date: 2026-09-21 05:39:45 -0700 (Mon, 21 Sep 2026)
New Revision: 10216
branches/4.0/MgDev/Common/Renderers/AGGRenderer.cpp
branches/4.0/MgDev/Common/Renderers/AGGRenderer.h
branches/4.0/MgDev/Common/Renderers/DWFRenderer.cpp
branches/4.0/MgDev/Common/Renderers/DWFRenderer.h
branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/CMakeLists.txt
branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/color.cpp
branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/ellipse.cpp
branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/plotinfo.cpp
branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/plotinfo.h
branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/transform.h
branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/typedefs_defines.h
branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/usrhatchpat.cpp
branches/4.0/MgDev/Server/src/UnitTesting/TestDrawingService.cpp
Fix MgDrawingService::EnumerateLayers() returning an empty list on Linux
Like our initial woes porting MapGuide to 64-bit Linux, the issue ultimately was incorrect typedefs on fundamental integral types in DWF Toolkit that caused the reading of DWF content to mis-behave due to these incorrect typedefs.
Our long-disabled test case for this API has been re-activated as proof this API is now working as advertised.
Fixes #2500
Modified: branches/4.0/MgDev/Common/Renderers/AGGRenderer.cpp
--- branches/4.0/MgDev/Common/Renderers/AGGRenderer.cpp 2026-09-13 09:13:38 UTC (rev 10215)
+++ branches/4.0/MgDev/Common/Renderers/AGGRenderer.cpp 2026-09-21 12:39:45 UTC (rev 10216)
@@ -3159,7 +3159,7 @@
// of the destination DWF or be much larger, we need to take that scaling
// into account when carrying over things like line weight, font height,
// etc. This helper function determines and applies that scale.
-double AGGRenderer::ScaleW2DNumber(WT_File& file, WT_Integer32 number)
+double AGGRenderer::ScaleW2DNumber(WT_File& file, int number)
WT_Matrix xform = file.desired_rendition().drawing_info().units().dwf_to_application_adjoint_transform();
Modified: branches/4.0/MgDev/Common/Renderers/AGGRenderer.h
--- branches/4.0/MgDev/Common/Renderers/AGGRenderer.h 2026-09-13 09:13:38 UTC (rev 10215)
+++ branches/4.0/MgDev/Common/Renderers/AGGRenderer.h 2026-09-21 12:39:45 UTC (rev 10216)
@@ -338,7 +338,7 @@
WT_Logical_Point* srcpts,
int numpts,
bool checkInBounds);
- /*Do not export from DLL*/ double ScaleW2DNumber(WT_File& file, long number);
+ /*Do not export from DLL*/ double ScaleW2DNumber(WT_File& file, int number);
private:
void AddW2DContent(RS_InputStream* in, CSysTransformer* xformer, const RS_String& w2dfilter);
Modified: branches/4.0/MgDev/Common/Renderers/DWFRenderer.cpp
--- branches/4.0/MgDev/Common/Renderers/DWFRenderer.cpp 2026-09-13 09:13:38 UTC (rev 10215)
+++ branches/4.0/MgDev/Common/Renderers/DWFRenderer.cpp 2026-09-21 12:39:45 UTC (rev 10216)
@@ -3636,7 +3636,7 @@
//scaling into account when carrying over things like line weight,
//font height, etc. this helper funtion determines and applies
//that scale
-WT_Integer32 DWFRenderer::ScaleW2DNumber(WT_File& file, WT_Integer32 number)
+int DWFRenderer::ScaleW2DNumber(WT_File& file, int number)
@@ -3662,7 +3662,7 @@
dDstSpace *= m_scale;
- return (WT_Integer32)dDstSpace;
+ return (int)dDstSpace;
Modified: branches/4.0/MgDev/Common/Renderers/DWFRenderer.h
--- branches/4.0/MgDev/Common/Renderers/DWFRenderer.h 2026-09-13 09:13:38 UTC (rev 10215)
+++ branches/4.0/MgDev/Common/Renderers/DWFRenderer.h 2026-09-21 12:39:45 UTC (rev 10216)
@@ -384,8 +384,8 @@
int numpts
- /*Do not export from DLL*/ long ScaleW2DNumber(WT_File& file,
- long number);
+ /*Do not export from DLL*/ int ScaleW2DNumber(WT_File& file,
+ int number);
/*Do not export from DLL*/ void UpdateSymbolTrans(WT_File& file, WT_Viewport& viewport);
Modified: branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/CMakeLists.txt
--- branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/CMakeLists.txt 2026-09-13 09:13:38 UTC (rev 10215)
+++ branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/CMakeLists.txt 2026-09-21 12:39:45 UTC (rev 10216)
@@ -1,6 +1,33 @@
include_directories(${CMAKE_CURRENT_SOURCE_DIR}
${CMAKE_CURRENT_SOURCE_DIR}/..)
+# Sanity-check the whiptk fundamental type sizes at configure time.
+# The W2D binary parser reads and writes 32-bit fields using WT_Integer32 /
+# WT_Unsigned_Integer32. If those are not exactly 4 bytes the parser silently
+# desynchronizes (e.g. `long` is 8 bytes on 64-bit Linux), producing empty or
+# corrupted drawing results. Fail the build early rather than at runtime.
+include(CheckCXXSourceCompiles)
+set(CMAKE_REQUIRED_INCLUDES
+ ${CMAKE_CURRENT_SOURCE_DIR}
+ ${CMAKE_CURRENT_SOURCE_DIR}/..)
+check_cxx_source_compiles(
+ "#include \"whiptk/typedefs_defines.h\"
+ typedef char DWFTK_WT_INT32_MUST_BE_4_BYTES[(sizeof(WT_Integer32) == 4) ? 1 : -1];
+ typedef char DWFTK_WT_UINT32_MUST_BE_4_BYTES[(sizeof(WT_Unsigned_Integer32) == 4) ? 1 : -1];
+ typedef char DWFTK_WT_INT16_MUST_BE_2_BYTES[(sizeof(WT_Integer16) == 2) ? 1 : -1];
+ typedef char DWFTK_WT_UINT16_MUST_BE_2_BYTES[(sizeof(WT_Unsigned_Integer16) == 2) ? 1 : -1];
+ typedef char DWFTK_WT_BYTE_MUST_BE_1_BYTE[(sizeof(WT_Byte) == 1) ? 1 : -1];
+ int main() { return 0; }"
+ DWFTK_WT_TYPES_HAVE_EXPECTED_SIZES)
+unset(CMAKE_REQUIRED_INCLUDES)
+if(NOT DWFTK_WT_TYPES_HAVE_EXPECTED_SIZES)
+ message(FATAL_ERROR "DWFTK whiptk fundamental types have unexpected sizes. WT_Integer32/WT_Unsigned_Integer32 must be exactly 4 bytes; see whiptk/typedefs_defines.h")
+endif()
set (dwftk_SRCS
Toolkit.cpp
#dwfx
Modified: branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/color.cpp
--- branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/color.cpp 2026-09-13 09:13:38 UTC (rev 10215)
+++ branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/color.cpp 2026-09-21 12:39:45 UTC (rev 10216)
@@ -43,7 +43,7 @@
// calc heidi color
// cube index
- long lr,lg,lb;
+ WT_Integer32 lr,lg,lb;
short sr,sg,sb;
lr = ( rgba.m_rgb.r * 6 ) << 8;
lg = ( rgba.m_rgb.g * 6 ) << 8;
Modified: branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/ellipse.cpp
--- branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/ellipse.cpp 2026-09-13 09:13:38 UTC (rev 10215)
+++ branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/ellipse.cpp 2026-09-21 12:39:45 UTC (rev 10216)
@@ -214,8 +214,8 @@
else
// merge any ellipse tilt into the circle angles
- long start = ((long)m_start + (long)m_tilt) & 0x0000FFFF;
- long end = ((long)m_end + (long)m_tilt) & 0x0000FFFF;
+ WT_Integer32 start = ((WT_Integer32)m_start + (WT_Integer32)m_tilt) & 0x0000FFFF;
+ WT_Integer32 end = ((WT_Integer32)m_end + (WT_Integer32)m_tilt) & 0x0000FFFF;
// Output a circle in ASCII
if (start != end)
Modified: branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/plotinfo.cpp
--- branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/plotinfo.cpp 2026-09-13 09:13:38 UTC (rev 10215)
+++ branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/plotinfo.cpp 2026-09-21 12:39:45 UTC (rev 10216)
@@ -132,7 +132,7 @@
else
WD_CHECK( file.read_ascii(m_rotation) );
- m_rotation = ((long)((m_rotation / 90.0) + 0.5)) * 90; // Only allow 90 degree rotations in this release
+ m_rotation = ((WT_Integer32)((m_rotation / 90.0) + 0.5)) * 90; // Only allow 90 degree rotations in this release
m_stage = Getting_Units_String;
Modified: branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/plotinfo.h
--- branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/plotinfo.h 2026-09-13 09:13:38 UTC (rev 10215)
+++ branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/plotinfo.h 2026-09-21 12:39:45 UTC (rev 10216)
@@ -59,7 +59,7 @@
WT_Paper_Units m_units;
WT_Boolean m_show;
WT_String m_temp_string;
- long m_rotation;
+ WT_Integer32 m_rotation;
enum WT_Materialize_Stage
{ Eating_Initial_Whitespace,
@@ -117,9 +117,9 @@
/// Returns the paper width (in paper units.)
inline const double& paper_width() const { return m_width; }
/// Returns a writable accessor to the rotation angle (in degrees, one of 0, 90, 180, 270.)
- inline const long& rotation() const { return m_rotation; }
+ inline const WT_Integer32& rotation() const { return m_rotation; }
/// Returns a the pre-applied rotation angle (in degrees, one of 0, 90, 180, 270, typically portrait==0 or landscape==90.)
- inline long& rotation() { return m_rotation; }
+ inline WT_Integer32& rotation() { return m_rotation; }
/// Returns a writable accessor to the 3x3 matrix which facilitates transforming DWF coordinate space to paper coordinate space.
inline WT_Matrix2D& to_paper() { return m_dwf2paper; }
/// Returns the 3x3 matrix which facilitates transforming DWF coordinate space to paper coordinate space.
Modified: branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/transform.h
--- branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/transform.h 2026-09-13 09:13:38 UTC (rev 10215)
+++ branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/transform.h 2026-09-21 12:39:45 UTC (rev 10216)
@@ -32,7 +32,7 @@
WT_Logical_Point m_translate; /**< \brief Translation vector. */
double m_x_scale; /**< \brief X scale factor. */
double m_y_scale; /**< \brief Y scale factor. */
- long m_rotation; /**< \brief Rotation (in degrees, one of 0, 90, 180, 270). */
+ WT_Integer32 m_rotation; /**< \brief Rotation (in degrees, one of 0, 90, 180, 270). */
/// Constructs a WT_Transform object.
WT_Transform()
@@ -66,13 +66,13 @@
double rotation /**< Rotation (in degrees, one of 0, 90, 180, 270). */
- switch ((long)rotation)
+ switch ((WT_Integer32)rotation)
case 0:
case 90:
case 180:
case 270:
- m_rotation = (long)rotation;
+ m_rotation = (WT_Integer32)rotation;
break;
default:
m_rotation = 0;
@@ -81,7 +81,7 @@
/// Returns the rotation value (in degrees, one of 0, 90, 180, 270).
- long rotation() const
+ WT_Integer32 rotation() const
Modified: branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/typedefs_defines.h
--- branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/typedefs_defines.h 2026-09-13 09:13:38 UTC (rev 10215)
+++ branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/typedefs_defines.h 2026-09-21 12:39:45 UTC (rev 10216)
@@ -29,19 +29,33 @@
/// \brief Simple boolean.
typedef char WT_Boolean;
+// The W2D binary format stores 32-bit integers as exactly 4 bytes.
+// On Windows `long` is 4 bytes, but on 64-bit Linux (LP64) `long` is
+// 8 bytes, which silently desynchronizes the W2D parser. Keep the
+// original Windows typedefs and use fixed 4-byte types elsewhere.
+#if defined(_WIN32)
/// \typedef typedef long WT_Integer32
/// \brief 32-bit signed integer.
typedef long WT_Integer32;
-/// \typedef typedef long WT_Integer16
-/// \brief 16-bit signed integer.
-typedef short WT_Integer16;
/// \typedef typedef unsigned long WT_Unsigned_Integer32
/// \brief 32-bit unsigned integer.
typedef unsigned long WT_Unsigned_Integer32;
+#else
+/// \typedef typedef int WT_Integer32
+/// \brief 32-bit signed integer.
+typedef int WT_Integer32;
-/// \typedef typedef unsigned long WT_Unsigned_Integer16
+/// \typedef typedef unsigned int WT_Unsigned_Integer32
+/// \brief 32-bit unsigned integer.
+typedef unsigned int WT_Unsigned_Integer32;
+#endif
+/// \typedef typedef short WT_Integer16
+/// \brief 16-bit signed integer.
+typedef short WT_Integer16;
+/// \typedef typedef unsigned short WT_Unsigned_Integer16
/// \brief 16-bit unsigned integer.
typedef unsigned short WT_Unsigned_Integer16;
Modified: branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/usrhatchpat.cpp
--- branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/usrhatchpat.cpp 2026-09-13 09:13:38 UTC (rev 10215)
+++ branches/4.0/MgDev/Oem/DWFTK/develop/global/src/dwf/whiptk/usrhatchpat.cpp 2026-09-21 12:39:45 UTC (rev 10216)
@@ -18,7 +18,7 @@
#include "whiptk/pch.h"
-#define DOUBLE_TO_LONG_BIT_SHIFT_16(x) (long) ((float)x * 65536)
+#define DOUBLE_TO_LONG_BIT_SHIFT_16(x) (WT_Integer32) ((float)x * 65536)
#define LONG_TO_DOUBLE_BIT_SHIFT_16(x) (double) ((double)x * 0.0000152587890625)
WT_User_Hatch_Pattern::WT_User_Hatch_Pattern(WT_User_Hatch_Pattern const & pattern)
Modified: branches/4.0/MgDev/Server/src/UnitTesting/TestDrawingService.cpp
--- branches/4.0/MgDev/Server/src/UnitTesting/TestDrawingService.cpp 2026-09-13 09:13:38 UTC (rev 10215)
+++ branches/4.0/MgDev/Server/src/UnitTesting/TestDrawingService.cpp 2026-09-21 12:39:45 UTC (rev 10216)
@@ -109,11 +109,7 @@
-#ifdef _WIN32
TEST_CASE("EnumerateLayers", "[DrawingService]")
-#else
-TEST_CASE("EnumerateLayers", "[Broken]")
-#endif
try
More information about the mapguide-commits
