[mapguide-dev] sources docs
"Antonio Lucas Rodríguez (sr&tec)"
alucas at srtec.com
Wed Apr 19 11:22:05 EDT 2006
Traian Stanev wrote:
>What do you mean by the "maps server" component. Do you mean the code
>that generates images for maps for requests like GETMAPIMAGE and the
>AJAX viewer and DWFs for the DWF viewer?
>Traian
>-----Original Message-----
>From: alucas at srtec.com [mailto:alucas at srtec.com]
>Sent: Monday, April 17, 2006 7:45 PM
>To: dev at mapguide.osgeo.org
>Subject: [mapguide-dev] sources docs
>Hello list,
>I've a question. I've downloaded mapguide 1.0.0 source code for try to
>understand it. It's very difficult to understand internal
>functionalities
>without any documentation or software engineering docs. I'd like to
>study
>all his compoments in detail, but between the getting started guide and
>the source code there are not documents about the internal architecture
>for understand all components and their relations. For example, if I'd
>like to analyze the maps server component, I open with VS 2005 the
>server
>solution and it has several projects with several classes. Without any
>documentation, I will spend long time to understand this code.
>I've looked for in mapguide.osgeo.org but there is nothing (there are
>some
>api guides for viewer and installation).
>So, the question is, there is any documentation about this?
>Thanks.
>Antonio Lucas
>Software Engineer
>SER&TEC S.L
>Phone: +34 96 395 95 13
>www.srtec.com
>Valencia (Spain)
>To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
>For additional commands, e-mail: dev-help at mapguide.osgeo.org
Hi Traian,
For me, is the engine for serving maps. For example, in sources the
Visual Studio solution "server.sln" includes all projects like services
(drawing, rendering ...), coordinate systems etc. There are doc about this?
Thanks.
Antonio Lucas
Software Engineer
alucas at srtec.com <mailto:alucas at srtec.com> www.srtec.com
<http://www.srtec.com>
963·959·513
Fax 963·731·756
SER&TEC
avda. Ausias March 79 - 1
46013 Valencia
Skipped content of type multipart/related
More information about the Mapguide-internals
