[mapguide-dev] area calculation conversion to meters
Paul Spencer
pspencer at dmsolutions.ca
Sat Dec 2 12:04:29 EST 2006
Trevor,
That would work for GetLength() but I wonder if you need to adjust
for latitude as well ... and it doesn't work for area. I pondered
doing this for the square root of the area and then squaring the
result ... I think that would work, but again it would have to be
adjusted for the latitude ... or am I over-engineering this?
Paul
On 1-Dec-06, at 4:10 PM, Trevor Wekel wrote:
> Hi Paul,
> For the most general case, I think you're on the right track. Most of
> the geometry classes support the Transform() operation. The
> MgCoordinateSystemTransform allows transformation from one coordinate
> system to another. I'm not a coordinate system expert but from what I
> understand most coordinate systems projections have an accurate sweet
> spot in the center and become more inaccurate around the edges. I
> wonder if there is a programmatic way to determine the appropriateness
> of the target system? Possibly based on center point of the
> projection?
> But if your target system is in decimal degrees, doesn't that imply a
> direct mapping to the world space? Isn't a decimal degree some number
> of meters? Could you just use
> MgCoordinateSystem::ConvertCoordinateSystemUnitsToMeters(double units)
> as the conversion factor? I suspect this may also work in the sweet
> spot of projected systems as well.
> Thanks,
> Trevor
> -----Original Message-----
> From: Paul Spencer (External)
> Sent: Thursday, November 30, 2006 3:03 PM
> To: dev at mapguide.osgeo.org
> Subject: [mapguide-dev] area calculation conversion to meters
> Hi all,
> I'm measuring the area and length of features using
> MgGeometricEntity::GetArea() and GetLength() in the Sheboygan data.
> This returns values in the units of the projection, which happens
> to be
> decimal degrees. Not so useful. I'd like the result to be in meters.
> Since this code needs to be generic, I've implemented some stuff to
> transform the geometry into a coordinate system that supports meters.
> This is not too accurate since I arbitrarily picked a World LCC
> projection wkt :)
> What is the recommended way of doing this calculation?
> Cheers
> Paul
> |Paul Spencer pspencer at dmsolutions.ca |
> |Chief Technology Officer |
> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
> To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: dev-help at mapguide.osgeo.org
More information about the Mapguide-internals
