[mapguide-dev] area calculation conversion to meters
Daniel Morissette
dmorissette at mapgears.com
Mon Dec 4 11:18:05 EST 2006
Paul Spencer wrote:
> Sweet, thanks Daniel. Can you confirm something for me please? In the
> sprintf, there is a zoneStr variable that appears to have no value and
> perhaps shouldn't be there? As far as I can see, there are only two
> substitution points in the string and zoneStr shouldn't go in either one :)
I think you're right, you should probably ignore zoneStr.
BTW, here is the same definition in PROJ.4 format, from MapServer's
implementation of the WMS AUTO projections (function
_msProcessAutoProjection() in mapfile.c):
case 42001: /** WGS 84 / Auto UTM **/
nZone = (int) floor( (dLon0 + 180.0) / 6.0 ) + 1;
sprintf( szProjBuf,
"+proj=tmerc+lat_0=0+lon_0=%.16g+k=0.999600+x_0=500000"
"+y_0=%.16g+ellps=WGS84+datum=WGS84+units=%s",
-183.0 + nZone * 6.0,
(dLat0 >= 0.0) ? 0.0 : 10000000.0,
pszUnits);
Daniel
Daniel Morissette
http://www.mapgears.com/
More information about the Mapguide-internals
