[mapguide-dev] MGOS 1.1.0 Release
Andy Morsell amorsell at spatialgis.com
Mon Dec 18 17:01:40 EST 2006
It sounds like there is another instance of Apache running on port 8008 on
that machine.  If you uninstalled and the Apache folder under MapGuide was
your only Apache instance, have you rebooted between your uninstall and
reinstall?  Either way, you definitely have a port conflict.  On Windows XP,
try using the following command at a command prompt:
netstat -a -b -n
You should then see port 8008 somewhere in the list and whatever the owning
executable and PID is.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
From: Jim O'Leary [mailto:joleary.public at gmail.com]
Sent: Monday, December 18, 2006 1:38 PM
To: dev at mapguide.osgeo.org
Subject: Re: [mapguide-dev] MGOS 1.1.0 Release
I uninstalled 1.0.1 Server and Extensions and installed this release on my
XP machine. The install did not generate and errors and did create required
directories, but Apache did not start. It did not show in the Services, and
when I executed Apache.exe from the command line in Apache2\bin, the error
message said:
C:\Program Files\MapGuideOpenSource\WebServerExtensions\Apache2\bin>apache
(OS 10048)Only one usage of each socket address (protocol/network
address/port)
is normally permitted.  : make_sock: could not bind to address 0.0.0.0:8008
no listening sockets available, shutting down Unable to open logs
I changed http.conf to read:
Listen 8009
and now it works. What is going on? I would like to go back to port 8008.
Thanks
Tom Fukushima wrote:
> Hi,
> Barring any problems we are planning to release MG 1.1.0 this coming
> weekend (Dec 16th).  If there are any issues that you are aware of,
> please reply to this mailing list.
> Thanks
> Tom
View this message in context:
http://www.nabble.com/MGOS-1.1.0-Release-tf2803698.html#a7937071
Sent from the MapGuide Dev mailing list archive at Nabble.com.
To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: dev-help at mapguide.osgeo.org
More information about the Mapguide-internals mailing list
