Problems with connection to Oracle
Simone MapGuide
simone.mapguide at gmail.com
Tue Dec 19 06:41:05 EST 2006
Hello
I did the download the Autodesk Mapguide Studio trial version, but I can't
add Data Connection. It opens a window called Connect to Data and it asks to
select a feature provider, but it doesn't show anything provider installed.
I am connected with the Mapguide Open Source Server and I installed the
provider FDO for Oracle and provider FDO for ODBC, but I can't create a
connection to Oracle. Is this a limitation of Trial version? How Can I solve
this problem to create a Oracle connection? I have to do the download of the
Autodesk FDO Provider for Oracle?
If I use the Mapguide Web Studio Open Source, it doesn't show how I have to
create connection with Oracle, it allows that I create only SDF or SHP data,
but I need to connect with a extern database. How do I this in the Mapguide
Web Studio Open Source?
Regards,
Simone.
URL: http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20061219/8d3bc6fc/attachment.html
More information about the Mapguide-internals
