[mapguide-dev] How to call the load procedure from program???
Rasel Md. Anawer TMN Technical
rasel.anawer at grameenphone.com
Mon Jul 10 23:39:17 EDT 2006
Hi Bill,
Thanks for your reply.
I have tried that and found error.
My Code
LoadProcedureInfo lpi =
sc.NewLoadProcedureInfo("Library://hiT/Loaders/hiTDataLoader");
SdfLoadProcedure sdfldpr = (SdfLoadProcedure)SdfSerializer.Open(lpi);
sdfldpr.SdfKeyTreatment = SdfKeyTreatment.AutogenerateAll;
sdfldpr.Generalization = 100;
sdfldpr.Execute(sc);
Exception
The specified module could not be found. (Exception from HRESULT:
0x8007007E)
at
Autodesk.MapGuide.Studio.Load.SdfLoadProcedure.ProcessSourceFile(Package
Writer package, String filePath, SiteConnection connection)
at Autodesk.MapGuide.Studio.Load.LoadProcedure.Execute(String
packageFilePath, SiteConnection connection)
at Autodesk.MapGuide.Studio.Load.LoadProcedure.Execute(SiteConnection
connection)
at SDFLoader.Program.Main(String[] args) in C:\Documents and
Settings\Administrator\My Documents\Visual Studio
2005\Projects\SDFLoader\SDFLoader\Program.cs:line 40
Desc
I have a load procedure at - "Library://hiT/Loaders/hiTDataLoader". No
problem about that.
My variables - lpi, sdfldpr is initiated successfully. No problem about
that.
Please help. ...
MD. RASEL ANAWER
System Engineer, TMN, TD,
GrameenPhone Ltd.
Mobile : +8801711506316
E-mail: rasel.anawer at grameenphone.com
Date: Mon, 10 Jul 2006 13:04:02 -0400
From: Bill Dhimitri <bill.dhimitri at autodesk.com>
Subject: [mapguide-dev] How to call the load procedure from program???
Hi Rasel,
MapGuide Studio provides an API that allows you to programmatically load
an SDF file. Go to the Studio API Help, and look up (in the index) the
SdfLoadProcedure class.
Bill
_____
[mailto:rasel.anawer at grameenphone.com]
Sent: Monday, July 10, 2006 7:49 AM
To: dev at mapguide.osgeo.org
I have a load procedure which loads a SDF file and generate Data and
Layer only.
Please help and thanks in advance...
MD. RASEL ANAWER
GrameenPhone Ltd.
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to which they are addressed. It may also be legally privileged. If you are not the named addressee, you should not copy, forward, disclose or use any part of it. If you have received this message in error, please delete it and all copies from your system and notify the sender immediately by return e-mail. Internet communications cannot be guaranteed to be timely, secure, error or virus-free. The sender does not accept liability for any errors or omissions.
URL: http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20060711/6c5a0622/attachment.html
More information about the Mapguide-internals
