[mapguide-dev] problems with asp.net c# code
Jason Birch Jason.Birch at nanaimo.ca
Thu Jun 29 12:58:24 EDT 2006
The MapGuide dev list is for developers working on the core MapGuide
code.
This message is copied to the "users" list; please subscribe there if
you haven't already.
Jason
-----Original Message-----
Sent: Thursday, June 29, 2006 09:13
To: dev at mapguide.osgeo.org
Subject: [mapguide-dev] problems with asp.net c# code
I am using this code (I am currently just messing around to get an
understanding of mapguide):
<script runat="server">
</script>
<!-- #Include File="utilityfunctions.aspx" -->
    String mgSessionId = GetParameters()["SESSION"];
    try
        MapGuideApi.InitializeSockets();
        InitializeWebTier();
        MgUserInformation userInfo = new MgUserInformation("xxxx",
"yyyy");
        MgSiteConnection siteConnection = new MgSiteConnection();
        siteConnection.Open(userInfo);
        MgResourceService resourceService =
siteConnection.CreateService(MgServiceType.ResourceService) as
MgResourceService;
        MgMap map = new MgMap();
        map.Open(resourceService, "Sheboygan");
        Response.Write("$" + mgSessionId + "$");
    catch (MgException mge)
        String result = mge.GetMessage() + "<br><br>" +
mge.GetDetails();
        Response.ContentType = "text/html";
        Response.Write(result);
        MapGuideApi.TerminateSockets();
Unfortunately, it throws an exception:
Invalid argument(s): [0] = " " The string cannot be empty.
Invalid argument(s): [0] = " " The string cannot be empty. Exception
occurred in method MgMap.Open at line 483 in file
c:\build_tux_area\mgdev\common\service\maplayer\Map.cpp
Could anyone please be so kind and provide me with some pointers to
overcome this problem? Many thanks.
Christian
More information about the Mapguide-internals mailing list
