[mapguide-dev] Fw: Start Autodesk mapguide studio
    Paul Spencer
    pspencer at dmsolutions.ca
    Fri Nov  3 10:54:34 EST 2006
If you are running Studio on the same machine that you installed
MapGuide on, the login information would be:
http://localhost:8008/mapguide
user: Administrator
pass: admin
If you changed the port during install, you will have to change this
appropriately
If you changed the password for the Administrator user, again you
will have to change it here
If you installed Studio on a different machine than MapGuide,
substitute the ip address or name of the server for 'localhost'
Cheers
Paul
On 3-Nov-06, at 10:42 AM, Albina Penitente wrote:
> On the choice Site is not sites
> How do the first login?
> thanks Alba
> ----- Original Message ----- From: "Paul Spencer"
> <pspencer at dmsolutions.ca>
> To: <dev at mapguide.osgeo.org>
> Sent: Friday, November 03, 2006 1:27 PM
> Subject: Re: [mapguide-dev] Fw: Start Autodesk mapguide studio
>> What error message?  There is an empty site authentication dialog
>> and  an empty studio window.  You need to login first!
>> Paul
>>> From: Albina Penitente
>>> To: users at mapguide.osgeo.org
>>> Sent: Friday, November 03, 2006 11:59 AM
>>> Subject: Start Autodesk mapguide studio
>>> Hi all,
>>> S.O.: window 2003 server
>>> I install mapguide server
>>> I install mapguide extensions with default setting (Apache, Php)
>>> Test Map Agent ok
>>> Test Site Administrator ok
>>> After I look the manual 'Installing Sample Data and Viewer
>>> Sample  Application'
>>> when I exec the instruction of page 3 I have the error attached
>>> <006401c6ff42$f919f470$a700a8c0>
>>> <006501c6ff42$f919f470$a700a8c0>
>>> someone knows to say to me because?
>>> thank
>>> Alba
>> |Paul Spencer                          pspencer at dmsolutions.ca    |
>> |Chief Technology Officer                                         |
>> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
>> To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
>> For additional commands, e-mail: dev-help at mapguide.osgeo.org
More information about the Mapguide-internals
