[mapguide-dev] Fw: Autodesk MapGuide Studio and WebStudio?
Paul Spencer
pspencer at dmsolutions.ca
Tue Nov 7 06:22:37 EST 2006
Albina,
you follow the steps in the Getting Started tab:
1) Find Data (and load it into MapGuide) ... there are two links in
this section depending on the type of data you have (file or rdbms)
2) Build Layers - when you load data in step 1), layers are normally
created for you
3) Make a Map
4) Place the Map on the Internet
The user's guide is hidden away in the Help menu - Autodesk MapGuide
Studio Help (F1). A curious person might have looked there ... ;)
WebStudio works in more-or-less the same way but without the
documentation and you can't do the last step (4 above) with WebStudio
yet.
There is also a sample data set you can load, available from the
https://mapguide.osgeo.org/ site.
Cheers
Paul
On 7-Nov-06, at 4:38 AM, Albina Penitente wrote:
> Hi all,
> There is someone that can explain to me like beginning to use
> Autodesk Studio?
> If click start/programmi/Autodesk/Autodesk MapGuide Studio:
> <001901c70250$7899e7e0$a700a8c0>
> How to manage and to construct the maps?
> If open the bowser Explorer and digit : http://localhost:8008/
> mapguide/webstudio/
> Exists a manual?
> thanks Alba
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the Mapguide-internals
