Problems with MapServer
Stefano Casagrande (I&S)
stefano.casagrande at ies.it
Fri Nov 10 03:56:03 EST 2006
Hi!
I have installed MapServer 1.0.2, MapServerWebExtensions 1.0.2 and
everything's ok.
In fact the example application
http://localhost/mapguide/phpviewersample/ajaxtiledviewersample.php
Works. Even if I change the ajaxtiledviewersample.php with a new $webLayout
and $mapDefinition it shows the new map.
But if I develop another application with the same map that works with the
example it tell me:
Failed to retrieve message for "MgFileNotFoundException". Exception occured
in method ByteSourceFileImpl.LoadFile at line 126 in file
c:\build_tux_area\mgdev_opensource\common\service\data\ByteSourceFileImpl.cpp
WebConfig.ini is ok, what should I check ? How should I found what fails ?
URL: http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20061110/91d474ec/attachment.html
More information about the Mapguide-internals
