[mapguide-dev] Reverse engineering "prototype" from PHP extension?
Trevor Wekel trevor.wekel at autodesk.com
Wed Nov 29 12:49:49 EST 2006
Hi Jason,
The IMake utility in BuildTools/WebTools/Imake is the front end
processor for generating our exported API.  It reads the C++ headers and
generates Swig input files.  With some extra coding, it should be
possible to generate the prototype file as part of the standard build
mechanism.  Zend Studio also has "intellisense" capabilities and it also
requires some sort of input file.  It might be worthwhile to extend
IMake in a more generic fashion so that other developers can add support
for their favourite environment.
Thanks,
Trevor
-----Original Message-----
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Saturday, November 25, 2006 2:06 PM
To: dev at mapguide.osgeo.org
Subject: [mapguide-dev] Reverse engineering "prototype" from PHP
extension?
Hi all,
I'd like to set up "intellisense" for the MapGuide php extension in my
php editor (PHPEd), but in order to do this, I need to make a PHP file
that contains a prototype for all of the classes, methods, properties,
constants, etc available through the MapGuide Web API.  This isn't
something that I really want to tackle by hand :)
Can anyone think of a way that I can automatically generate this kind of
file?
An example of what I need to generate can be found on the PHPEd website:
http://www.nusphere.com/kb/technicalfaq/howto_codecompletion.htm
<http://www.nusphere.com/kb/technicalfaq/howto_codecompletion.htm>
Thanks,
Jason
To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: dev-help at mapguide.osgeo.org
More information about the Mapguide-internals mailing list
