[mapguide-dev] mg version stamp
Walt Welton-Lair
walt.welton-lair at autodesk.com
Thu Oct 26 04:18:13 EDT 2006
That's a test URL to verify MapGuide is set up correctly. The error is
the correct response. Give it the name of an existing WebLayout and you
will get your map.
-----Original Message-----
From: a.penitente at gepaspa.com [mailto:a.penitente at gepaspa.com]
Sent: Thursday, October 26, 2006 9:01 AM
To: dev at mapguide.osgeo.org
Subject: [mapguide-dev] mg version stamp
Hi Haris
I have build MG 1.0.2 on windows XP platform.
But when I digit on browser
http://localhost:8008/mapguide/mapviewerajax/ajaxviewer.php?
WEBLAYOUT=Library://ATest.WebLayout
I have the error:
Resource was not found: Library://ATest.WebLayout
Resource was not found: Library://ATest.WebLayout Exception
occurred in method MgResourceDefinitionManager.GetDocument
at line 476 in file
c:\build_tux_area\mgdev_opensource\server\src\services\resource\Resource
DefinitionManager.cpp
Do you know because?
Can you send your file httpd.conf?
thank
Alba
Haris
To unsubscribe, e-mail: dev-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: dev-help at mapguide.osgeo.org
More information about the Mapguide-internals
