[mapguide-internals] FW: [mapguide-users] patch for Mouse Wheel
Zoom, set scale and image on loading map in Ajax.
Jason Birch
Jason.Birch at nanaimo.ca
Mon Apr 2 17:21:37 EDT 2007
How invasive are these changes? Is it something that we could add to 1.2 during the beta stages? :)
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of José Manuel Cerrejón González
Sent: Friday, March 30, 2007 04:36
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] patch for Mouse Wheel Zoom, set scale and image on loading map in Ajax.
I've try to post the code in the internal list, but I don't how to register. Anyway here the code. I've applied the changes on the 1.0.2, but in the last version works fine.
Somebody who know how to do it, please e-mail me.
This patch use javascript to zoom with the wheel mouse, like in AutoCAD.
Another patch is to input in the scale bar, a scale manually.
You can see an icon in the toolbar when the map is loading.
All these changes in action here <http://wms.diphuelva.es/mapguide/phpviewersample/index.php> . Click on the help icon to see more features.
E-mail me with any problem.
Thank you.
[toolbar.templ]
In css:
div.cssRefresh
position: absolute;
right:10px;
top:4px;
The body seems like this. Rotating_arrow.gif is the image. You can design it or use the attached:
<body class="Toolbar" onload="InitDocument()" leftmargin=10 topmargin=0 rightmargin=0 bottommargin=0 marginwidth=0>
<div id="divRefresh" name="divRefresh" class="cssRefresh"><img alt="loading" src="../phpviewersample/images/common/rotating_arrow.gif"></div>
<span id="ToolbarContent"><td></td></span>
<div class="TextMetricsDiv" id="TextMetricsDiv"><span class="TextMetrics" id="Metrics"></span></div>
</body>
[ajaxmappane.templ]
About line 1350:
if(requestObj.responseXML)
var resp = ParseEnvelope(requestObj.responseXML.documentElement);
if(resp == null)
RequestFailed("Invalid XML response");
else
var frmParent = parent.frames ["tbFrame"];
var objDivRefresh = frmParent.document.getElementById("divRefresh");
if(objDivRefresh!=null){ objDivRefresh.style.display='block'; }
panX1 = extX1 = resp.lowerLeft.X;
Line 1463 after the changes:
if(safari)
curimg = (curimg == "mapImage1"? "mapImage2": "mapImage1");
if(objDivRefresh!=null){ objDivRefresh.style.display='none'; }
return false;
Jose Manuel Cerrejon Gonzalez
jose.cerrejon at mapas-sll.com | gis at mapas-sll.com
I+D
MAPAS SLL <http://mapas-sll.com>
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
More information about the mapguide-internals
