[mapguide-internals] Please test MGOS 1.2.0 with
updatedFDOlibraries
Greg Boone
greg.boone at autodesk.com
Thu Aug 23 10:41:13 EDT 2007
The GDAL DLL was built using the build settings currently established in
https://svn.osgeo.org/fdocore/branches/3.2.3/Thirdparty/GDAL1.3/src/Gdal
1.3.vcproj
nmake /f "makefile.vc" /NOLOGO
LIBDIR=..\windows\lib\VC8\release BINDIR=..\windows\bin\VC8\release
clean
devinstallonly
If these setting are not sufficient for the MG 1.2 release, please
advise on the appropriate procedure required to re-generate the DLL.
Greg
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jason
Birch
Sent: Thursday, August 23, 2007 2:10 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Please test MGOS 1.2.0 with
updatedFDOlibraries
I don't think that the gdal13.dll file that is distributed with the
installer was generated from the 3.2.x trunk. It's missing the function
which is required to work with the MrSID plugin.
It appears to be working fine with ECW files so far... more testing to
follow.
I'll see if I can find time to re-compile the GDAL dll tomorrow at work
and test again, but I'm a bit tight on time tomorrow.
Jason
From: mapguide-internals-bounces at lists.osgeo.org on behalf of Tom
Fukushima
Sent: Wed 2007-08-22 12:53 PM
Subject: [mapguide-internals] Please test MGOS 1.2.0 with updated
FDOlibraries
I have posted the Windows installer for MGOS 1.2.0 server with the FDO
libraries that contain the GDAL changes. The GDAL changes were the only
changes; that is, we did not rebuild the MGOS server, we only updated
the installed to use the new FDO DLLs.
This is intended to become our MGOS 1.2.0 release. Please test it out
and send me your findings. If all goes well, I hope to motion this for
release when I have received feedback from at least Jason.
The installer is available at:
http://download.osgeo.org/mapguide/releases/1.2.0-rc2/MgServerSetup-1.2.
0RC2.G066.exe.
Thanks
Tom
mapguide-internals mailing list
mapguide-internals at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
