[mapguide-internals] Session-MapName-Map
Jason Birch Jason.Birch at nanaimo.ca
Fri Aug 31 16:27:28 EDT 2007
I like that, if the second part is implemented.  It gets away from the
runtime map name being associated with the source map altogether.
Am I right that it would still breaking the existing code (because
you're returning a string rather than a void), but it doesn't affect the
MapAgent at all because the name is automatically set to the UUID?
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Trevor
Wekel
Sent: Friday, August 31, 2007 13:11
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Session-MapName-Map
Auto generating a UUID for the map name would be less of an API impact.
If you are willing to generate the UUID yourself, you can use the
existing API.
$uuid = uniqid("map",true);  // not really a GUID, just a unique ID
$map1 = new MgMap($siteConnection);
$map1->Create($resourceId, $uuid);
$map1->Save();
$map2 = new MgMap($siteConnection);
$map2->Open($uuid);
We may also be able to generate a unique id internally on the Save() if
a map name is not passed into the Create()
$map1->Create($resourceId);
$mapid = $map1->Save();  // generates a UUID internally
Much less API change this way...
Thanks,
Trevor
More information about the mapguide-internals mailing list
