[mapguide-internals] Session-MapName-Map
Paul Spencer
pspencer at dmsolutions.ca
Fri Aug 31 17:33:03 EDT 2007
works for me :)
On 31-Aug-07, at 5:23 PM, Trevor Wekel wrote:
> Yes. This would work and would not break existing scripts. The other
> alternative I suggested below is more invasive and would break API.
> You don't actually need to create the UUID until you Save() the MgMap.
> That's why I put the return value on the Save() instead of the
> Create().
> The Save() would return the name regardless of whether it was
> auto-generated or not. Either would be ok but you may not want to
> generate the UUID if you are passing the MgMap to a GeneratePlot API.
> Thanks,
> Trevor
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Paul
> Spencer (External)
> Sent: Friday, August 31, 2007 2:40 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] Session-MapName-Map
> I would hope it wouldn't break existing code at all. The way I see
> it, if you call Create without a second parameter, a uuid is
> automatically created (and perhaps it should be returned from Create
> instead of Save). Having a return value where once it was void
> should be ignored in all scripting languages - the return value is
> just discarded. This is fine for existing code that already creates
> a name and passes it in, because they don't need the return value to
> find out the name that was assigned.
> Trevor, would it work to support:
> $map->Create($resourceId, $name);
> $name = $map->Create($resourceId);
> where both cases return $name, but in the second case a uuid is
> automatically created by the server?
> This would still result in the map being saved in
> Session:...//name.Map
> and the existing mapagent calls would work as is?
> This seems like a fairly trivial change, actually.
> Paul
> On 31-Aug-07, at 4:27 PM, Jason Birch wrote:
>> I like that, if the second part is implemented. It gets away from
>> the
>> runtime map name being associated with the source map altogether.
>> Am I right that it would still breaking the existing code (because
>> you're returning a string rather than a void), but it doesn't
>> affect the
>> MapAgent at all because the name is automatically set to the UUID?
>> Trevor
>> Wekel
>> Sent: Friday, August 31, 2007 13:11
>> Subject: RE: [mapguide-internals] Session-MapName-Map
>> Auto generating a UUID for the map name would be less of an API
>> impact.
>> If you are willing to generate the UUID yourself, you can use the
>> existing API.
>> $uuid = uniqid("map",true); // not really a GUID, just a unique ID
>> $map1 = new MgMap($siteConnection);
>> $map1->Create($resourceId, $uuid);
>> $map1->Save();
>> $map2 = new MgMap($siteConnection);
>> $map2->Open($uuid);
>> We may also be able to generate a unique id internally on the Save
>> () if
>> a map name is not passed into the Create()
>> $map1->Create($resourceId);
>> $mapid = $map1->Save(); // generates a UUID internally
>> Much less API change this way...
>> Thanks,
>> Trevor
>> mapguide-internals mailing list
>> mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> |Paul Spencer pspencer at dmsolutions.ca |
> |Chief Technology Officer |
> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the mapguide-internals
