[mapguide-internals] MapGuide RFC 42 - Remove Support Servers
Zac Spitzer
zac.spitzer at gmail.com
Thu Dec 6 18:09:33 EST 2007
Ok it makes sense..... we will become more reliant on proxing a bit then.
MGP's don't include the tile cache tho do they? is that do-able? I wish WMS
would set a cache header...
I would be nice to be able to define a master site servers (including
unmanaged folders to be rsync-ed)
and be able to push the config out from one master site server...
should be pretty easy to script... hot back up the repository, rsync the
unmanaged folders & tilecache (would that work?),
shut down the slave site server, restore the hot back up, and bring it back
up.
z
On Dec 7, 2007 4:13 AM, Trevor Wekel <trevor.wekel at autodesk.com> wrote:
> Hi Zac,
> Since the configuration of site and support servers is no longer possible
> through the Site Administrator, this RFC effectively disables support server
> functionality.
> I agree having multiple site repositories makes data management for load
> balanced site servers more complex. Packages (mgp files) can help alleviate
> this problem if a "production" and "dev/test" environment are set up. Only
> the production setup would be load balanced. Mgp's would be created in the
> "dev/test" environment and deployed to the production site servers using an
> mgp load.
> There are a couple of performance advantages to using load balanced site
> servers versus site and support servers:
> 1. All service to service traffic remains in process on the local
> machine.
> A typical rendering service operation talks to the resource service and
> feature service. In a site server / support server setup, all of this
> traffic will have to be serialized, transmitted over the wire, and
> de-serialized. This incurs significant overhead.
> The only way to get good performance on site/support server setup is to
> have all of the services except resource service present on each support
> server. This also means the managed and unmanaged data files (SDF, SHP,
> raster) must also be present on each support server. So you end up
> performing the data replication manually.
> 2. Multiple site servers provide multiple session repositories.
> This is significant for higher user loads because the users are evenly
> balanced over the available site servers. It is similar to using a database
> cluster that does not perform replication.
> Does this help?
> Thanks,
> Trevor
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:
> mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: Wednesday, December 05, 2007 6:24 PM
> To: MapGuide Internals Mail List
> Subject: Re: [mapguide-internals] MapGuide RFC 42 - Remove Support Servers
> "Load balanced site servers provide better scalability and easier
> setup than separate site
> and support servers. Furthermore, the site and support server concept
> is confusing for the user base."
> How will this affect server admin?.... the support server (calling it
> a Render Slave makes a lot more sense) approach
> means you only need to maintain and update one repository.
> Having to maintain 6 site servers instead of 5 support servers and one
> site server sounds like a backward step
> in terms of maintainability.
> Renaming the support servers to something that provides more insight
> into their function would be a good step.
> Also the RFC Title should specify that this is only at the MapGuide
> Site Administrator level
> ie "Remove Support Servers from MapGuide Site Administrator"
> Regards
> Zac
> On Dec 6, 2007 11:40 AM, Trevor Wekel <trevor.wekel at autodesk.com> wrote:
> > I would like to submit "MapGuide RFC 42 - Remove Support Servers" to the
> list for review and comment. Please send your comments/concerns back to the
> list and I will respond.
> > http://trac.osgeo.org/mapguide/wiki/MapGuideRfc42
> > Thanks,
> > Trevor Wekel
> > mapguide-internals mailing list
> > mapguide-internals at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> Zac Spitzer -
> http://zacster.blogspot.com (My Blog)
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
More information about the mapguide-internals
