[mapguide-internals] Fwd: Swithing base MgLayerGroup on/off ...
fails?
Maksim Sestic
max at geoinova.com
Thu Dec 27 04:28:20 EST 2007
I posted a ticket regarding this issue:
http://trac.osgeo.org/mapguide/ticket/377 #377 .NET API: Switching
MgLayerGroup visibility on/off doesn't work .
Maksim Sestic wrote:
> I guess I'm missing something, but this won't switch on/off base layer
> group:
> Dim map As MgMap = ...get runtime Map...
> Dim layerGroup As MgLayerGroup =
> map.GetLayerGroups.GetItem(layerGroupName)
> layerGroup.SetVisible(True)
> map.Save(...ResourceService...)
> and then call JavaScript function parent.parent.Refresh(); from Task Pane,
> base layer group gets switched on only in legend pane, but map
> representation won't change. MgLayerGroup doesn't have ForceRefresh()
> method like MgLayer.
> I'm coding my own Legend TreeView control in AJAX.NET and everything else
> in it works just fine (dynamic layers, etc), except for the base layer
> groups.
> Regards,
> Maksim Sestic
View this message in context: http://www.nabble.com/Fwd%3A-Swithing-base-MgLayerGroup-on-off-...-fails--tp14454152s16610p14511053.html
Sent from the MapGuide Internals mailing list archive at Nabble.com.
More information about the mapguide-internals
