[mapguide-internals] ogr postgis layer problems
Traian Stanev
traian.stanev at autodesk.com
Thu Feb 1 11:54:53 EST 2007
Hi Paul.
I checked on this and to fix selection highlighting, you need to set the
PGSQL_OGR_FID configuration variable to equal the name of the ID column
of your data. This is documented in the OGR Postgres page (see
http://www.gdal.org/ogr/drv_pg.html).
Traian
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Paul
Spencer (External)
Sent: Thursday, February 01, 2007 7:12 AM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] ogr postgis layer problems
Thanks Traian, that fixed the problems. There is one small remaining
issue that is not critical - the selected features (postgis again) don't
seem to highlight in the ajax viewer.
Cheers
Paul
On 31-Jan-07, at 4:49 PM, Traian Stanev wrote:
> Hi again.
> I've fixed both issues in the OGR provider. Selection now works fine,
> including multi-select, when tested on SHP files. There was a problem
> with intersection queries (the problem was they weren't implemented,
> heh). I also fixes the problem of the features disappearing after
> selection -- I had forgotten to reset the filters on the OGRLayer in
> between Selects. I also fixed a small problem in OGR, which was making
> FID filters fail. I'll have Tom post a new Win32 DLL to the provider
> download location.
> FYI, I recompiled against the following versions of the dependent
> libraries: GDAL 1.4.0 (plus my fix), PostgreSQL 8.2.1, Proj 4.5.0,
> Geos 2.2.3, plus unknown versions of Oracle OCI and ODBC.
> Traian
> From: Traian Stanev
> Sent: Wednesday, January 31, 2007 3:33 PM
> To: 'MapGuide Internals Mail List'
> Subject: RE: [mapguide-internals] ogr postgis layer problems
> Hi Paul.
> I tried it against an SHP file and selection is definitely not working
> right. :) To avoid the disappearing map problem, you can disable
> connection pooling for the OGR provider in the serverconfig.ini file.
> This will prevent the map from disappearing (since the connection is
> not reused after it breaks during selection), but it will not make
> selection work. I will see what can be done about fixing this and let
> you know.
> Traian
> Spencer (External)
> Sent: Tuesday, January 30, 2007 9:18 PM
> Subject: [mapguide-internals] ogr postgis layer problems
> Hi all,
> I am looking into an issue regarding postgis layers loaded via the OGR
> provider for a client. The postgis layer is functioning normally when
> the map loads (it is initially off but it can be toggled on/off no
> problem). It can be queried using the select. However, when the
> layer has had features selected on it, the next action causes the
> layer to be turned off and the layer cannot be turned back on without
> restarting the service and web browser.
> Any ideas what might be going on? Bug in the OGR provider? AJAX
> Viewer? Bad data?
> Cheers
> Paul
> |Paul Spencer pspencer at dmsolutions.ca |
> |Chief Technology Officer |
> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
