[mapguide-internals] MapGuide
RFC 14- CartographicStylizationEngine
(maybe this time I'll get it right)
Robert Bray
rbray at robertbray.net
Sun Feb 4 22:11:01 EST 2007
Guys,
Here is the definition of our existing SymbolLibrary:
<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
elementFormDefault="qualified" attributeFormDefault="unqualified">
<xs:element name="SymbolLibrary" type="SymbolLibraryType"/>
<xs:complexType name="SymbolLibraryType">
<xs:sequence>
<xs:element name="Description" type="xs:string" minOccurs="0"/>
<xs:element name="Symbol" type="SymbolType" minOccurs="0"
maxOccurs="unbounded"/>
</xs:sequence>
</xs:complexType>
<xs:complexType name="SymbolType">
<xs:sequence>
<xs:element name="Name" type="xs:string"/>
<xs:element name="Resource" type="xs:string"/>
</xs:sequence>
</xs:complexType>
</xs:schema>
In looking at this I have two reservations. First is the naming which is
not great for re-purposing it (but I can live with it if everyone else
can). Second we might need to add I type element or attribute to
SymbolType to indicate if the binary data is a DWF, Image, or some other
type of future thing.
Bob
Paul Spencer wrote:
> Carsten,
> I was thinking of just the raster. I agree with each symbol being its
> own resource. I would just like to have a place to put the raster
> images in the repository rather than an external reference, and would
> prefer to have the raster images not be with the symbol so they can be
> potentially shared between symbols.
> Cheers
> Paul
> On 4-Feb-07, at 7:38 PM, Carsten Hess wrote:
>> Bob, Paul,
>> not sure I follow. Do you want to put the symbol plus all
>> depdendencies into the symbol library and hence build a symbol library
>> or do you want to put just the raster into the symbol library?
>> I always thought we could make a directory in the resource repository
>> to be a "symbol library" but each symbol be its own resource. The
>> reason I liked it is that I can put metadata against it and ultimately
>> search for the symbol (if we get around to implementing that).
>> Think for example about the FGDC library, it has several hundred
>> symbols, searching would be useful I think.
>> Cheers,
>> Carsten
>> -----Original Message-----
>> From: mapguide-internals-bounces at lists.osgeo.org on behalf of
>> Robert Bray
>> Sent: Sun 2/4/2007 5:28 PM
>> To: MapGuide Internals Mail List
>> Cc:
>> Subject: Re: [mapguide-internals] MapGuide RFC 14-
>> CartographicStylizationEngine (maybe this time I'll get it right)
>> Carsten,
>> I read your choice (1) as storing it with the SimpleSymbolDefinition
>> using Get/SetResourceData. I think Paul is referring to storing the
>> images in our existing SymbolLibrary resource, which stores a
>> collection
>> of DWF symbols in a single resource.
>> Bob
>> Carsten Hess wrote:
>> > Paul,
>> > that is the same as my choice 1) think. We could do that. Like I
>> said though we have to figure out to have multiple raster in there and
>> how to refer to them as resource id.
>> > Cheers,
>> > Carsten
>> of Paul Spencer (External)
>> > Sent: Sun 2/4/2007 5:03 PM
>> > Cc:
>> > Subject: Re: [mapguide-internals] MapGuide RFC 14 -
>> > Carsten,
>> > Why can you not reference it inside the existing
>> SymbolLibrary object
>> > in the repository? This mechanism is already used for
>> point symbols
>> > and seems to fit semantically for this purpose too. I
>> believe there
>> > is already a way to do this using MarkSymbolType or
>> something like
>> > that (I'm not looking at the schema for layer definition
>> so I may
>> > have that wrong)
>> > Cheers
>> > Paul
>> > On 4-Feb-07, at 3:23 PM, Carsten Hess wrote:
>> > > Hi Paul,
>> > > I think we have four choices for binary raster data:
>> > > 1) We could attach it to the symbol resource as binary data
>> > > (resource data)
>> > > 2) We could make it its own resource
>> > > 3) We could put it somewhere on the file system
>> > > 4) We could embedd it in the XML as base64 encoded stream
>> > > Currently you find 3) only because of our prototype, we
>> actually
>> > > don't want to propose that. We played with some of the
>> XML and use
>> > > it to refer to raster via the file system. That is
>> easier to debug
>> > > then in the resource repository.
>> > > The schema refers to 2) and 4) I think as a possiblity
>> ... I
>> > > personally also like 1) but then we would have to figure
>> out how to
>> > > refer to it and how to put multipl raster in there.
>> > > Cheers
>> > > Carsten
>> on behalf of Paul
>> > > Spencer (External)
>> > > Sent: Sun 2/4/2007 12:22 PM
>> > > Cc:
>> - Cartographic
>> > > I notice that the first example references an
>> image in the Library://
>> > > but the documentation in the proposed schema say
>> its a reference to
>> > > an external image.
>> > > Is the intention to actually reference images on
>> the server in an
>> > > external location on the file system, external via
>> http, or actually
>> > > to allow putting images into the repository?
>> > > I like the idea of being able to put images such
>> as PNGs into the
>> > > repository and referencing them there - but there
>> is no concept of
>> > > this in the proposed schema.
>> > > I guess, thinking about this, it would be best to
>> reference an image
>> > > inside a SymbolLibrary. What would be the
>> implications of this to
>> > > your proposal?
>> > > Cheers
>> > > Paul
>> > > On 2-Feb-07, at 4:29 PM, Robert Bray wrote:
>> > > > THIS TIME SENT AS VERY PLAIN TEXT with FIXED
>> LINK - SORRY FOR THE
>> > > > SPAN ALL
>> > > > All,
>> > > > We would like to submit the following RFC for
>> open discussion and
>> > > > comments:
>> http://www.osgeo.org/trac/mapguide/wiki/MapGuideRfc14
>> > > > - Note this RFC is living on our new Trac based
>> Wiki. The other
>> > > > RFCs will be moving to this location shortly.
>> > > > Please respond to the list with any feedback and
>> we will be happy
>> > > > to respond.
>> > > > Thanks, Walt, Traian, Carsten, Jason (and
>> others like Bob the
>> > > > admin assistant)
>> > > > _______________________________________________
>> > > > mapguide-internals mailing list
>> > > > mapguide-internals at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
>> > > |Paul Spencer
>> pspencer at dmsolutions.ca |
>> > > |Chief Technology
>> Officer |
>> > > |DM Solutions Group Inc
>> http://www.dmsolutions.ca/ |
>> > |Paul Spencer
>> > |Chief Technology
>> Officer |
> |Paul Spencer pspencer at dmsolutions.ca |
> |Chief Technology Officer |
> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
More information about the mapguide-internals
