[mapguide-internals] Joining to Development Team
Bruce Dechant
bruce.dechant at autodesk.com
Mon Feb 5 15:41:44 EST 2007
Jorge,
The MapGuide open source community would welcome you localizing MapGuide
into Spanish.
I have added some information below on what needs to be done in order to
do this.
MapGuide resource information:
The latest "Trunk" version of MapGuide (upcoming v1.2) now has only a
single resource file that is used by either the server or web tier. This
should make it easier to localize then the previous 2 files. The
MapGuide resource file is located in the source tree here:
..\Common\MapGuideCommon\Resources\mapguide_en.res
The file naming convention used by MapGuide is as follows:
mapguide_en.res
The filename uses the ISO 639-1 naming convention for the locale. "en"
for English in the above example.
You can find a list of ISO 639-1 names here:
http://en.wikipedia.org/wiki/List_of_ISO_639-1_codes
In your case for Spanish the filename would be: mapguide_es_res
If you are testing your new resource file you will need to copy your
resource file to the following locations:
server - Resources folder in the same folder as the mgserver.exe
web - ..\WebServerExtensions\www\mapagent\Resources folder
Also, you will need to pass the locale of your client, "es" in your
case, in order for the server to know that it is talking to a Spanish
client instead of an English one.
Thanks,
Bruce
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Jorge
Rubio
Sent: February 5, 2007 1:15 PM
To: MapGuide Internals Mail List
Subject: Re: [mapguide-internals] Joining to Development Team
I have dowloaded the contributor agreement pdf file and I will sign and
send
it as soon as possible.
I'll be waiting for Tom info.
2007/2/5, Jason Birch <Jason.Birch at nanaimo.ca>:
> Currently there is no localisation project. We're still really
getting
> underway as a PSC and this question had not come up yet. It's very
> exciting though.
> The submission process for patches has not been formalised. Some
> projects just ask them to be sent to the -internals list, but I'm not
> sure how I feel about it. My preference would be for you to post to
> this list that they are available, then one of the developers with
> check-in rights would arrange to receive and review the files, and
> upload them if they pass code review.
> I think that we may need to get a contributor agreement from you as
> well?
> Does anyone else have any thoughts on this?
> Once this is under way, we should put up a web page listing the
> translations and the person who is maintaining them, so they can be
> notified when a new string needs to be added to the resource file,
etc.
> Jason
> Rubio
> Sent: Monday, February 05, 2007 11:41
> Hi Jason
> *****Have you read this page: http://mapguide.osgeo.org/developer.html
> Yes I have and I joined the mailing list, but I still do not
understand
> what I have to do!
> *****You don't really need anything to get started as a Contributor
> other than the ability to check out from SVN anonymously, and generate
> patch files from your work
> Ok I can check SVN because you have sent the address to me. But should
I
> be able to upload files?
> Who leads the localization project?
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
Lic. Jorge Rubio
More information about the mapguide-internals
