[mapguide-internals] changing mapguide's image type
Trevor Wekel trevor.wekel at autodesk.com
Tue Feb 6 14:37:00 EST 2007
Hi Walt,
Yes. I agree.  Using a lossy image format for tiles could introduce a
number of undesirable effects.  For tiles of vector-only data, I suspect
JPG will introduce a speckling effect against the hard boudaries of the
various features.
For raster based hybrid tiles, ie. Raster imagery with some overlaid
vector data, a JPG may be appropriate.  The base raster image could
provide enough consistency to reduce edge effects.
Thanks,
Trevor
-----Original Message-----
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Walt
Welton-Lair
Sent: Tuesday, February 06, 2007 12:08 PM
To: MapGuide Internals Mail List
Subject: RIF: [mapguide-internals] changing mapguide's image type
Think carefully about using any lossy image format for tiles.  To look
correct adjacent tiles need to match at their borders...
Walt
	-----Messaggio originale-----
	Da: mapguide-internals-bounces at lists.osgeo.org per conto di
Trevor Wekel
	Inviato: lun 2/5/2007 7:21
	A: MapGuide Internals Mail List
	Cc:
	Oggetto: RE: [mapguide-internals] changing mapguide's image type
	Yes.  I think so.  The tiles and the overlay are two separate
HTTP
	requests.  Tiles could be JPG and overlay could be PNG.  If
you're using
	tiles, then the overlay should be PNG so transparency can be
used to
	show the tiles underneath.
	I'm not sure this has been tested though.  It would be
interesting to
	see if the various browsers can deal with overlaying a
transparent PNG
	image over a non-transparent JPG.
	And I agree that image type and image size should ideally be set
per
	base layer group.  However, that's a fair bit more work to
implement
	(map definition, Web Studio, Studio, viewers) than adding
configuration
	parameters for default behaviours.
	Thanks,
	Trevor
Paul
	Spencer (External)
	Sent: Monday, February 05, 2007 10:57 AM
	Subject: Re: [mapguide-internals] changing mapguide's image type
	Ideally the image type would be set per base layer group.
	Paul
	On 5-Feb-07, at 12:43 PM, Jason Birch wrote:
	> So, if the tiling service image type could be specified, would
that
	> allow Paul to use JPG for the tiles, and the interface would
still use
	> PNG for the overlays?
	> Jason
Of
	> Trevor Wekel
	> Sent: Monday, February 05, 2007 09:40
	> Subject: RE: [mapguide-internals] changing mapguide's image
type
	> Yes.  Andy is right.  If you're not using tiles then the image
type
	> can be specified.  However, tile generation is currently
hardcoded as
	> PNG.
	> Thanks,
	> Trevor
	> mapguide-internals mailing list
	> mapguide-internals at lists.osgeo.org
	> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
	|Paul Spencer                          pspencer at dmsolutions.ca
	|Chief Technology Officer
	|DM Solutions Group Inc
http://www.dmsolutions.ca/ |
More information about the mapguide-internals mailing list
