[mapguide-internals] tile edge effects using gdal provider in tiled
mode
Paul Spencer
pspencer at dmsolutions.ca
Tue Feb 20 11:11:14 EST 2007
I've got a client using the GDAL provider to render an ECW file.
He's set up the map/viewer to use tiles rather than straight map
draws and he is getting some edge effects (white lines in this case)
in his tiles. I've attached a small screengrab of part of the problem.
Any ideas? Could this be a problem with the provider or is it more
likely a problem elsewhere? Note that the edge effects do not appear
on every tile, nor on every edge of every tile, so perhaps it is a
rounding issue in tile generation somewhere? Or in the provider?
Paul
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
Type: image/jpeg
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20070220/95eaf0d9/tile_lines-0001.jpg
More information about the mapguide-internals
