[mapguide-internals] tile edge effects using gdal provider in
tiled mode
Frank Warmerdam
warmerdam at pobox.com
Tue Feb 20 11:22:57 EST 2007
Paul Spencer wrote:
> I've got a client using the GDAL provider to render an ECW file. He's
> set up the map/viewer to use tiles rather than straight map draws and he
> is getting some edge effects (white lines in this case) in his tiles.
> I've attached a small screengrab of part of the problem.
> Any ideas? Could this be a problem with the provider or is it more
> likely a problem elsewhere? Note that the edge effects do not appear on
> every tile, nor on every edge of every tile, so perhaps it is a rounding
> issue in tile generation somewhere? Or in the provider?
Paul,
I suspect this is a big in the GDAL provider. I would appreciate it if you
could file a bug in the FDO trac against the GDAL provider:
http://trac.osgeo.org/fdo/
Login with your OSGeo userid (ie. mapguide svn userid).
I'll make an attempt to reproduce the problem at the fdo level. If that proves
difficult I may need to work with you to isolate the problem.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
More information about the mapguide-internals
