[mapguide-internals] tile edge effects using gdal provider
intiledmode
Paul Spencer
pspencer at dmsolutions.ca
Tue Feb 20 11:29:18 EST 2007
Has anyone seen this with MGE and the ADSK raster provider? I'll
file a bug (as suggested by Frank) but I would like to be sure that
the code that requests the tile is doing the right thing before
asking Frank to look further into the GDAL provider. If it works in
MGE then it seems likely that the problem resides in the GDAL
provider, if not then it would seem likely that the problem is in the
code requesting the image instead.
Cheers
Paul
On 20-Feb-07, at 11:24 AM, Walt Welton-Lair wrote:
> It seems this problem only occurs when rendering raster data into
> tiles.
> Vector data seems ok, right? If that's the case, then it probably
> just
> a rounding error in the code which draws the raster image.
> Walt
> -----Original Message-----
> From: mapguide-internals-bounces at lists.osgeo.org
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Andy
> Morsell
> Sent: Tuesday, February 20, 2007 5:19 PM
> To: 'MapGuide Internals Mail List'
> Subject: RE: [mapguide-internals] tile edge effects using gdal
> provider
> intiledmode
> Hi Paul,
> This is not an artifact of the GDAL provider but rather of using base
> layers
> (tiles) in your map definitions. I ran into this same issue last week
> with
> a client and on my demo server with 1.1.0. I posted a message to this
> group
> last week with several "I have that problem too" responses but nothing
> from
> the developers. I remember this issue from awhile back and was due to
> the
> whit lines being a hidden SDF tile index that was drawing. I
> thought it
> was
> slated to be fixed, but I am unsure if an issue in Issue Tracker was
> ever
> entered.
> Andy
> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Paul
> Spencer
> Sent: Tuesday, February 20, 2007 8:11 AM
> To: MapGuide Internals Mail List
> Subject: [mapguide-internals] tile edge effects using gdal provider in
> tiledmode
> I've got a client using the GDAL provider to render an ECW file.
> He's set up the map/viewer to use tiles rather than straight map draws
> and
> he is getting some edge effects (white lines in this case) in his
> tiles.
> I've attached a small screengrab of part of the problem.
> Any ideas? Could this be a problem with the provider or is it more
> likely a
> problem elsewhere? Note that the edge effects do not appear on every
> tile,
> nor on every edge of every tile, so perhaps it is a rounding issue in
> tile
> generation somewhere? Or in the provider?
> Paul
> |Paul Spencer pspencer at dmsolutions.ca |
> |Chief Technology Officer |
> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
