[mapguide-internals] Summer of Code Projects
Jason Birch
Jason.Birch at nanaimo.ca
Fri Feb 23 14:33:58 EST 2007
If you haven't committed to SVN since the change in servers, then someone will have to set up a new LDAP account for you and grant you the appropriate role for commit access to FDO. This same account is what you will use for the Trac Wiki updates.
The current URL for King.Oracle is:
https://svn.osgeo.org/svn/fdo/trunk/Providers/KingOracle/ <https://svn.osgeo.org/svn/fdo/trunk/Providers/KingOracle/>
Tortoise SVN should work just fine once you get an account set up.
The FDO folks should be able to answer any other questions you might have.
Bob, Greg, I'd really appreciate it if this account could be set up as quickly as possible and Haris given whatever info he needs to upload his current code. Mateusz could really benefit from using this as a template for some of the stuff he's doing with the PostGIS provider, and he gets a lot of work done on weekends :)
Thanks,
Jason
From: mapguide-internals-bounces at lists.osgeo.org on behalf of Haris Kurtagic
Sent: Fri 2007-02-23 11:34 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Summer of Code Projects
I couldn't log with any credentials I usually use.
I wanted to test to login to svn but I can't find a login to svn on fdo
site ( it used to be there on previous www).
Couple months ago I setup Tortoise client and I was able to commit
King.Oracle, but now I don't know how to find address and also it seems
like I save my credentials into tortoise and it works, but I don't how
to get credentials out (I successfully forgot how I did it since then )
I want to upload newer version of King>oarcel provider, in which
branches it should go ?
I am unfamiliar with svn,trac,... so I would appreciate any help.
Basic instructions where svn is now and how to login and what to use
(Tortoise or ? ) would be very helpful to me.
Thank you,
Haris
-----Original Message-----
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Robert
Bray
Sent: 23. februar 2007 15:20
Subject: Re: [mapguide-internals] Summer of Code Projects
Hi Haris,
You should be able to use the same user name and password you use to
commit code to the FDO SVN repository. If that does not work, please let
me know.
Bob
Haris Kurtagic wrote:
> Hi Bob,
> How do I edit this page? Need to login? I am not able to login, which
> credentials?
> Thank you,
> Haris
Robert
> Bray
> Sent: 23. februar 2007 2:58
> Subject: [mapguide-internals] Summer of Code Projects
> I have added a page to list potential projects for the Google Summer
of
> Code effort. You can find it here:
> http://trac.osgeo.org/mapguide/wiki/GoogleSoC2007
> Feel free to add your favorite pet projects, elaborate, etc. Keep in
> mind these projects are aimed for a single student to complete in a
> period of three months.
> Bob
> mapguide-internals mailing list
> mapguide-internals at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
