[mapguide-internals] Final update to MapGuide RFC 14 - Cartographic
Stylization Engine
Walt Welton-Lair
walt.welton-lair at autodesk.com
Tue Feb 27 19:30:35 EST 2007
I've made a few minor changes to the symbolization schema to address the
recent feedback:
1/ Renamed the LineWeightContext element in PathType to
LineWeightScalable, and corrected its documentation.
2/ Added an optional PositioningAlgorithm string element to
SymbolInstanceType. Here's its documentation:
Specifies the algorithm used to generate candidate positions for
the symbol. This must evaluate to one of: Default or EightSurrounding.
Default means generate one position using the feature geometry (used for
normal rendering). EightSurrounding means generate eight positions
surrounding the feature geometry (used when labeling point features).
3/ Improved documentation for a few other elements.
Only the schemas attached to the RFC have been updated, and no changes
to the RFC text were made.
[RFC link is http://trac.osgeo.org/mapguide/wiki/MapGuideRfc14]
Walt
W E @__ __o
A T R @___ _ \<,_
L @_ (*)/ (*)
More information about the mapguide-internals
