[Mapguide_dev] Provider for Oracle
Simone MapGuide simone.mapguide at gmail.com
Fri Jan 12 06:34:34 EST 2007
Hello
I am using the Autodesk Mapguide Studio 2007 with King.FDO Oracle provider
for MapGuide Open Source. I am using Mapguide Open Source Web Server
1.1.0RC1. I get the connection with database normally, but when I try
to create a
new layer with this FeatureSource I get the following below. Can you help
me? What's the problem?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Net.WebException: The remote server returned an error: (559)
MgUnclassifiedException.
   at Autodesk.MapGuide.Studio.Site .Comm.RequestManager.CreateSess ion()
   at Autodesk.MapGuide.Studio.Site.Comm.RequestManager.RefreshSession()
   at
Autodesk.MapGuide.Studio.Site.Comm.RequestManager.ExecutePendingMultipartPostRequest(Operation
operation)
   at Autodesk.MapGuide.Studio.Site.ResourceInfo.SaveResourceDocument(Stream
stream)
   at Autodesk.MapGuide.Studio.Site.WebLayoutInfo.Save(Stream
resourceDocument)
   at Autodesk.MapGuide.Studio.UI.HtmlViewer.GetTempWebLayout(String
siteUrl, String mapResourceId, Point2D center, Double scale, Boolean
showLegend)
   at Autodesk.MapGuide.Studio.UI.HtmlViewer.SetMap(String siteUrl, String
mapResourceId, Point2D center, Double scale, Boolean showLegend)
   at Autodesk.MapGuide.Studio.UI.Viewer.SetMap(String siteUrl, String
   at Autodesk.MapGuide.Studio.UI.MapEditor.MapPreview.ReloadPreview()
   at Autodesk.MapGuide.Studio.UI.LayerEditor.LayerPreview.ReloadPreview()
   at
Autodesk.MapGuide.Studio.UI.LayerEditor.LayerEditorPreview.backgroundColorBox_ColorChanged(Object
sender, EventArgs e)
   at
Autodesk.MapGuide.Studio.UI.ColorComboBox.comboBox_SelectedIndexChanged(Object
   at System.Windows.Forms.ComboBox.OnSelectedIndexChanged(EventArgs e)
   at System.Windows.Forms.ComboBox.WmReflectCommand(Message& m)
   at System.Windows.Forms.ComboBox.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg,
IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.42 (RTM.050727-4200)
    CodeBase:
file:///C:/WINNT/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
Studio
    Assembly Version: 1.0.0.17864
    Win32 Version: 1.0.0.17864
    CodeBase:
file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Studio.exe
    CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase:
file:///C:/WINNT/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase:
file:///C:/WINNT/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Autodesk.MapGuide.Studio.Locale
    CodeBase:
file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.Locale.DLL
msvcm80
    Assembly Version: 8.0.50608.0
    Win32 Version: 8.00.50727.42
    CodeBase: file:///C:/WINNT/system32/msvcm80.dll
    CodeBase:
file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.UI.DLL
Autodesk.Gis.DwfToolkit
    CodeBase:
file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Autodesk.Gis.DwfToolkit.DLL
Autodesk.MapGuide.Studio.Feature
    CodeBase:
file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.Feature.DLL
Autodesk.MapGuide.Studio.FdoLoader
    CodeBase:
file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.FdoLoader.DLL
Autodesk.MapGuide.Forms
    CodeBase:
file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Forms.DLL
Autodesk.MapGuide.Studio.Site.UI
    CodeBase:
file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.Site.UI.DLL
    Assembly Version: 1.1.0.0
    Win32 Version: 1.1.0.0
    CodeBase: file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.Site.DLL
Autodesk.MapGuide.Studio.MdfModel
    CodeBase:
file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.MdfModel.DLL
Autodesk.MapGuide.Studio.ImageEngine
    CodeBase: file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.ImageEngine.DLL
Autodesk.MapGuide.Studio.Load
    CodeBase: file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.Load.DLL
Autodesk.MapGuide.Studio.Load.Serializer
    CodeBase: file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.Load.Serializer.DLL
Autodesk.MapGuide.Studio.Dwg.Load
    CodeBase:
file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.Dwg.Load.DLL
System.Xml
    CodeBase:
file:///C:/WINNT/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Autodesk.MapGuide.Studio.StylePreview
    CodeBase: file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.StylePreview.DLL
System.Configuration
    CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
11ykwil_
    CodeBase:
System.Web
    Win32 Version: 2.0.50727.210 (QFE.050727-2100)
    CodeBase:
file:///C:/WINNT/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
j6hsy_r0
    CodeBase:
ety8haar
    CodeBase:
vajktdd0
    CodeBase:
ka2agk90
    CodeBase:
pyw5onit
    CodeBase:
tm-7fwl-
    CodeBase:
qlqxskt0
    CodeBase:
bzqlyclj
    CodeBase:
System.Data
    CodeBase:
file:///C:/WINNT/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
Autodesk.Gis.CoordinateSystems
    CodeBase: file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Autodesk.Gis.CoordinateSystems.DLL
Microsoft.mshtml
    Assembly Version: 7.0.3300.0
    Win32 Version: 7.0.3300.0
    CodeBase:
file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Microsoft.mshtml.DLL
    CodeBase:
file:///C:/Arquivos%20de%20programas/Autodesk/MapGuideStudio2007/Autodesk.MapGuide.Studio.Fdo.DLL
_rvuz0jq
    CodeBase:
Accessibility
    CodeBase:
file:///C:/WINNT/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
regards,
Simone.
URL: http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20070112/6b0034ce/attachment.html
More information about the mapguide-internals mailing list
