[mapguide-internals] Patch submission for MapGuide RFC 8
Rex Szeto (Intern)
Rex.Szeto at autodesk.com
Fri Jan 19 13:14:02 EST 2007
Hi Chris,
Thanks, I appreciate the review and feedback.
I'll make the changes to use the constants.php from mapadmin.
The main.php is used only as the entry point for a user to use this
feature on a browser (http://servername/mapguide/schemareport/main.php).
They can define the specific resource, even pin point it down to a
particular schema or class in that resource. The hard-coded resource is
just a default example input for the user (similar to how mapagent have
the "Library://Test/Sources/..." default values on their Resource ID).
Good luck with debugging the source code.
Thanks,
Rex
_____
From: mapguide-internals-bounces at lists.osgeo.org
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Chris
Claydon
Sent: Friday, January 19, 2007 10:33 AM
To: MapGuide Internals Mail List
Subject: RE: [mapguide-internals] Patch submission for MapGuide RFC 8
Hi Rex,
Overall, this looks great. I had a chance to look at the output earlier,
and it's very impressive. Unfortunately, I'm running into problems with
the latest MapGuide source code (not your code) that I need to track
down before I can test your latest changes. I have a couple of comments:
When you asked me about constants.php before, I mislead you. You can't
rely on the version installed in the mapviewerphp folder, since it will
not be present for web tier installations that use Java or .NET. You
could possibly use the one in the mapadmin folder, since the admin pages
are always installed as PHPs.
Also... what is the function of main.php? It looks like it's just a test
page that uses hard-coded resources and credentials, and I'm not sure it
belongs in the patch file.
Thanks,
Chris.
_____
[mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Rex
Szeto (Intern)
Sent: January 18, 2007 2:46 PM
Subject: [mapguide-internals] Patch submission for MapGuide RFC 8
Hi everyone,
I would like to submit this patch.
It contains changes for the MapGuide RFC 8.
http://wiki.osgeo.org/index.php/MapGuide_RFC_8_-_PHP_pages_for_describin
g_a_feature_source
As a note, the patch should be applied inside the Web/src/ folder.
Thanks,
Rex
URL: http://lists.osgeo.org/pipermail/mapguide-internals/attachments/20070119/4640a89b/attachment.html
More information about the mapguide-internals
