[mapguide-internals] RFC required for tile caching changes?
Paul Spencer pspencer at dmsolutions.ca
Wed Jan 24 07:57:15 EST 2007
I support the modifications proposed without requiring an RFC.  I do
agree with Jason about a larger RFC covering enhancements to the tile
cache.
Cheers
Paul
On 24-Jan-07, at 12:01 AM, Jason Birch wrote:
> Being able to specify tile size is very important for setting up
> the global profiles of TMS, but I would much rather see it
> implemented at the "TileGroup" (Andy's idea) level than at the
> server level.  Same goes for the block size.
> I agree that TMS would be easy to implement with a script but was
> hoping for raw http sharing of the tile directory, with a custom
> handler for 404s that generates missing tiles (or sends a 404 if it
> really doesn't exist).  This would give the benefits of the
> webserver without additional load on each request.
> At this point, I would support the alteration of the directory
> structure to fix a defect (as long as there are no changes to the
> API because of it), but the enhancements are running pretty close
> to the line.  As well, there is a fair amount of interest in the
> caching mechanism and it would likely make sense to revisit it as
> part of a larger RFC to make sure that all of the desired
> modifications fit properly with our future direction.
> However I'm willing to go with the group on this if there's
> majority support for the small enhancements without an RFC.
> Jason
> ________________________________
> From: mapguide-internals-bounces at lists.osgeo.org on behalf of Chris
> Claydon
> Sent: Tue 2007-01-23 2:18 PM
> To: MapGuide Internals Mail List
> Subject: RE: [mapguide-internals] RFC required for tile caching
> changes?
> The impact on the AJAX Viewer complicates the issue of dynamic tile
> sizing, and Trevor will be addressing that issue in an RFC.
> I am going to implement the TileBlockSize config parameter (which
> has no impact on the viewer) and Traian's tile-organizing scheme.
> Chris.
> From: mapguide-internals-bounces at lists.osgeo.org [mailto:mapguide-
> internals-bounces at lists.osgeo.org] On Behalf Of Walt Welton-Lair
> Sent: January 23, 2007 2:26 PM
> changes?
> If you make the cached tile size a parameter then this will also
> require some AJAX Viewer work.  IIRC the AJAX code has the current
> tile size hard-coded.  If you make it a parameter then you'll need
> to update ajaxviewer.templ (I think) to let it be set dynamically.
> There may also be other things you need to fix in AJAX.  For
> example, it currently requests tiles for rows / columns which are
> slightly outside your visible extents.  I don't know offhand how
> many extra rows / columns it requests, but it seems this also
> depends on the tile size.  Maybe you'd want to request enough rows/
> columns to give you an additional 25% screen coverage.  So the
> number of extra rows/columns you'll need to request on each side is
> 0.25 * screen width in pixels / tile size.  I don't know if AJAX
> viewer currently has such logic.
> Walt
> 	-----Original Message-----
> Chris Claydon
> 	Sent: Tue 1/23/2007 9:42 PM
> 	Cc:
> changes?
> 	That should be relatively straightforward to achieve. I would add
> a comment into serverconfig.ini indicating that any modifications
> to these settings would:
> 	a)       Only take effect after a server restart.
> 	b)       Invalidate ALL existing cached tiles.
> 	Chris.
> internals-bounces at lists.osgeo.org] On Behalf Of Trevor Wekel
> 	Sent: January 23, 2007 1:34 PM
> changes?
> 	Hi Chris,
> 	As an additional item, can we add serverconfig.ini parameters to
> control the following:
> 	- Size of the cache tile where the tiles assumed to be square
> "TileSize = 300" for 300x300 tiles
> 	- Tile block size, ie. the mod value in the discussion below
> "TileBlockSize = 30"
> 	The first item is good for tuning and is useful if you need to
> match MapGuide tiles against an externally tiled raster source.
> The second item could be used for tuning and eventually to support
> "block rendering" of tiles.
> 	Thanks,
> 	Trevor
> internals-bounces at lists.osgeo.org] On Behalf Of Chris Claydon
> 	Sent: Tuesday, January 23, 2007 1:26 PM
> changes?
> 	We seem to have digressed a little from my original question! I
> have summarized the issues discussed in this thread below. I would
> like to implement the changes as proposed in item 2), and to do so
> without the need for an RFC. Please let me know if this is
> unacceptable for any reason.
> 	Thanks,
> 	Chris.
> 	1)       We cannot conform directly with the Tile Map Service
> Specification, because it does not currently support the concept of
> grouping sets of tiles into individual folders. However, it would
> be very simple to write a simple script or servlet to map from the
> specification's path format directly to the MapGuide format.
> 	2)       Traian suggested a slightly modified folder naming
> convention that provides an easier mapping to the original tile
> index. I like this approach and would be happy to implement it this
> way. His proposal is as follows:
> 	"Another suggestion I have -- name the folder part of the path (30
> * tile index div 30) and then the file part would be (tile index
> mod 30).
> 	So for tile 33,64 the folder would be:
> 	Base Layer Group/30/60/3_4.png
> 	And for tile -33,-64 the folder would be:
> 	Base Layer Group/-30/-60/-3_-4.png
> 	For tile 1,1, the folder would be:
> 	Base Layer Group/0/0/1_1.png
> 	For tile -1,-1 the folder would be:
> 	Base Layer Group/-0/-0/-1_-1.png"
> 	3) Various issues were brought up regarding how tiles are
> generated, and how label placement can be optimized. These are
> beyond the scope of my proposal, and can be addressed separately
> without being affected by the changes I've proposed.
> internals-bounces at lists.osgeo.org] On Behalf Of Robert Bray
> 	Sent: January 17, 2007 9:08 AM
> 	Subject: Re: [mapguide-internals] RFC required for tile caching
> changes?
> 	Hey Paul, I think that is because you explicitly added him, for
> some weird reason this list is already set to reply to list. The
> change in question would not have made a difference in this case...
> 	Bob
> 	Paul Spencer wrote:
> 	Steve's response bounced from the list, but fortunately reply-to-
> all was still actually sending to everyone so I actually got the
> message ... hint, hint ...
> 	Paul
> 	On 16-Jan-07, at 11:18 PM, Steve Lime wrote:
> 	Paul: Er, I spent too much time at the Camp-to-Camp beer tap so my
> 	memory is a bit fuzzy. We talked about several things from pre-
> computing
> 	label positions to what you mention below. You are correct in how
> 	MapServer works. It doesn't have any special "tiled" mode and hence
> 	considers each tile just as any other map. In a single map context,
> 	computing label positions post-clip makes sense.
> 	Computing label positions pre-clip would result in a single,
> consistent
> 	label position for each feature. For points and polygons that's
> 	generally
> 	OK I believe. For linear features the results might not always be
> 	optimal
> 	since the clipping often provides a nice means of segmenting long
> 	features
> 	so that get labeled multiple times. One could work around that at the
> 	data level by segmenting long features ahead of time.
> 	I don't believe it would hard to hack MapServer drawing routine
> 	to do this and someone could test it out. Let me know if interested.
> 	Steve
> 			Paul Spencer <pspencer at dmsolutions.ca>
> <mailto:pspencer at dmsolutions.ca>  01/15/07 7:03 PM >>>
> 	Walt,
> 	I don't believe it got documented.  I spoke with Steve Lime (cc'd)
> 	directly about this during OSGeo.
> 	At the time, I believe Steve suggested label placement would be done
> 	before features are clipped for rendering.  I believe the way
> 	mapserver works, it grabs all features that intersect a given bbox
> 	then clips the features to the bbox then renders them.  Labelling is
> 	currently done post-clip.  If it were done pre-clip, then labels
> 	would be in a fixed position and could overlap tile boundaries
> 	without problems.
> 	I do believe that there were some potential problems with this
> 	approach, but I don't know enough of mapserver internals to remember
> 	what they were.
> 	Steve, perhaps you could jump in and fix my explanation?  Also, do
> 	you think that label rendering changes would be a potential for
> 	version 5?
> 	Cheers
> 	Paul
> 	On 15-Jan-07, at 2:54 PM, Walt Welton-Lair wrote:
> 	"In lieu of fixing this in MapServer (there is actually a proposal
> 	to fix this)..."
> 	Paul - is there per chance a public link to this proposal?  I'd be
> 	interested in looking at it.
> 	Thanks,
> 	Walt
> 	Paul
> 	Spencer (External)
> 	    Sent: Mon 1/15/2007 7:40 PM
> 	    Cc:
> 	changes?
> 	    Trevor,
> 	    I don't think I got my idea across clearly :)  Let me explain a
> 	    little more clearly.
> 	    In ka-Map, the size of a tile is configurable and by default is
> 	    200x200 px.  There is a second concept that I've called a 'meta
> 	    tile'.  A meta tile is some number of tiles wide x high,
> 	typically 10
> 	    x 10.  When a request for a tile comes to the tile server, it
> 	checks
> 	    the cache.
> 	    If the tile exists, the tile (200x200px) is returned.  This
> 	happens
> 	    without invoking any map rendering ... the tile exists as an
> 	image on
> 	    disk.
> 	    If the tile does not exist, then a map render happens.  A map
> 	the
> 	    size of the meta tile is rendered and sliced into tile-sized
> 	chunks
> 	    that are stored on disk in the cache directory structure.  While
> 	the
> 	    tiles are being created, a lock file is used to 'pause' requests
> 	for
> 	    tiles in the same meta-tile directory so that they can all be
> 	served
> 	    from the same map draw when it is finished.
> 	    We chose this approach for several reasons.  First, MapServer
> 	suffers
> 	    from edge effects when rendering map images.  This is normally
> 	not
> 	    noticeable, but when you put several map draws together in a
> 	tiled
> 	    client, it becomes horribly obvious.  The solution was to render
> 	a
> 	    slightly larger map image (about 10 pixels in fact) and clip out
> 	the
> 	    center as the tile.  Second, MapServer labelling only considers
> 	the
> 	    current map draw.  Depending on the size of the rendered label,
> 	it
> 	    may not fit into a single tile.  Depending on the size of a
> 	feature,
> 	    the label may appear on several adjacent tiles.  In lieu of
> 	fixing
> 	    this in MapServer (there is actually a proposal to fix this),
> 	    rendering a much larger map and slicing it into smaller tiles
> 	    produces a reasonable effect.  Finally, it is relatively
> 	expensive to
> 	    parse the map file and find/read the data compared to rendering
> 	so
> 	    rendering a single large image and slicing it is cheaper than
> 	    rendering each smaller tile (with diminishing returns).
> 	    I don't know how you actually render the tiles in MapGuide, but
> 	I
> 	    don't think you suffer from the same edge and label issues.
> 	    The ka-Map directory structure looks something like this:
> 	    <map>/<layer-group>/<scale>/<row-of-metatile>/<col-of-
> metatile>/<row-
> 	    of-tile><col-of-tile>.<ext>
> 	    ... which is similar to Chris' suggestion :)  I don't get the
> 	    impression that you render the entire contents of the metatile
> 	    directory in one go though.  Because I do, I only have to check
> 	if
> 	    the meta-tile directory exists to know if any tile in the
> 	directory
> 	    exists, which is a small optimizatin.
> 	    One difference between Chris' proposal and the way ka-Map works
> 	is
> 	    that the scale and layer group are reversed.  This makes it
> 	    theoretically possible to share the <layer-group> cache
> 	directory
> 	    between different maps simply by creating symlinks or by
> 	allowing a
> 	    per-layer-group setting that indicates the root directory to
> 	keep the
> 	    tile cache in.
> 	    Cheers
> 	    Paul
> 	    On 15-Jan-07, at 11:49 AM, Trevor Wekel wrote:
> 	    > Hi everyone,
> 	    > I did some analysis on file systems a little while ago in
> 	support
> 	    > of the
> 	    > directory structure change.  Here are some approximate numbers
> 	for
> 	    > directory entry and file system entries that I pulled from an
> 	internet
> 	    > search:
> 	    > Linux ext3  - each file or directory is approx 8 bytes +
> 	length of
> 	    > file
> 	    > or directory name
> 	    > Linux Reiserfs  - each file or directory is 18 bytes + length
> 	of
> 	    > file or
> 	    > directory name
> 	then
> 	    > each
> 	    > file entry will require 26 bytes under ext3 and 34 bytes under
> 	    > ReiserFS.
> 	    > To facilitate fast directory access, tiles which are close to
> 	each
> 	    > other
> 	    > should like in the same directory.  This reduces the directory
> 	entry
> 	    > reads for each tile request.  If we also assume that the read
> 	block
> 	    > size
> 	    > for the file system is 32kbytes (32/64k is often used in RAID
> 	arrays)
> 	    > then a directory with 900 entries (30x30 block) will get read
> 	in a
> 	    > single IOP (900*34 = 30600).  And since the tiles are blocked
> 	    > together,
> 	    > it is very likely that adjacent tiles will fall within the
> 	same
> 	    > directory.  Since the directory was just read, it will be
> 	cached
> 	and
> 	    > there will be no disk access required.
> 	    > If we increase the size of the directories to more than 900
> 	entries
> 	    > then
> 	    > we will incur more than IOP to read the bottom-most directory
> 	    > structure.
> 	    > I also think Traian's suggestion of Base Layer Group/
> 	30/60/3_4.png is
> 	    > reasonable.  It is more readable than the original mod scheme.
> 	    >> From a rendering perspective, dealing with 2000x2000 pixel
> 	blocks
> 	    >> may be
> 	    > more efficient but cutting the tiles up from these larger
> 	images
> 	will
> 	    > require some computational effort.  Rendering the tiles in the
> 	same
> 	    > size
> 	    > as requested from the client reduces server load because the
> 	HTTP
> 	    > request ends up being simply a file serving operation.
> 	    > With some of the latest optimizations I have been working on,
> 	MapGuide
> 	    > tile serving speeds using "client-sized" tiles are quite
> 	respectable.
> 	    > On a machine with a single 3GHz CPU, MapGuide can service more
> 	than
> 	    > 100
> 	    > tiles per second assuming the tiles are being served from
> 	memory,
> 	    > ie. no
> 	    > disk access.  The additional computational effort required to
> 	generate
> 	    > "client" tiles from larger pixel blocks will significantly
> 	impact
> 	    > performance.
> 	    > Thanks,
> 	    > Trevor
> 	    > [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf
> 	Of
> 	Paul
> 	    > Spencer (External)
> 	    > Sent: Sunday, January 14, 2007 11:59 AM
> 	caching
> 	    > changes?
> 	    > FWIW, Traian's suggestion for naming folders based on a mod of
> 	r/
> 	c is
> 	    > essentially the same approach I took with ka-Map (for the same
> 	reason
> 	    > that Chris brought this up) and it seems to work very well.
> 	In ka-
> 	    > Map,
> 	    > tiles are rendered in blocks of about 2000x2000 pixels (tile
> 	size is
> 	    > configurable but you might get 10 x 10 tiles in a typical
> 	    > configuration) and they would go in one of these sub-
> 	directories.  I
> 	    > think I figured out that this would be enough directories to
> 	decently
> 	    > cache a pretty large area (say, all of the US) without running
> 	into
> 	    > file
> 	    > system limits for most scales.
> 	    > It would be interesting to know the limits on:
> 	    > * files per directory
> 	    > * directories per directory
> 	    > * total number of directories
> 	    > * total number of files
> 	    > * minimum block(?) size in the file system compared to typical
> 	size
> 	    > of a
> 	    > tile (wasted space per tile).
> 	    > for various operating systems/file system combinations.  I
> 	know
> 	we use
> 	    > ReiserFS because it handles lots of small files better than
> 	ext3
> 	for
> 	    > instance.  Knowing some of this might help make the caching
> 	system
> 	    > more
> 	    > tunable in different environments.
> 	    > Paul
> 	    > On 13-Jan-07, at 11:09 AM, Traian Stanev wrote:
> 	    >> Can you also give an example for tiles with negative indices?
> 	    >> For example if in the current scheme the tile is -33, -64,
> 	what
> 	would
> 	    >> be the resulting directory path?
> 	    >> R-2/C-3/-3_-4
> 	    >> What about tile -1,-1
> 	(30 *
> 	index mod
> 	    >> 30).
> 	    >> It's a little weird around 0, but it allows for arbitrary
> 	    >> groupings of
> 	    >> tiles in folders (they don't have to be 30x30) since the tile
> 	index
> 	    >> can be computed directly from the file path, by adding the
> 	folder
> 	    >> term
> 	    >> to the file path term.
> 	    >> Also, can you tell us what the problem is with having too
> 	many
> 	images
> 	    >> in one directory? Is it a file system issue? And how many
> 	tiles is
> 	    >> the
> 	    >> limit, i.e. why is 30x30 the preferred grouping and not
> 	1000x1000 for
> 	    >> example?
> 	    >> Traian
> 	Jason
> 	    >> Birch
> 	    >> Sent: Fri 1/12/2007 8:57 PM
> 	    >> Cc:
> 	caching
> 	    >> changes?
> 	    >> Can I forward this to the "tiling" list for comment?
> 	Chris
> 	    >> Claydon
> 	    >> Sent: Fri 2007-01-12 12:24 PM
> 	caching
> 	    >> changes?
> 	    >> A sample tile location would be as follows:
> 	Repositories\TileCache\Samples_Sheboygan_Maps_Sheboygan\7
> 	    >> \Base
> 	    >> The R and C indices correspond to rows and columns where each
> 	row
> 	    >> contains 30 tiles vertically and each column contains 30
> 	tiles
> 	    >> horizontally.
> 	    >> This indicates that:
> 	    >> 1)       We're at zoom level 7
> 	    >> 2)       We're in grouped row 2
> 	    >> 3)       We're in grouped column 3
> 	    >> 4)       The tile location within this grouped row/column
> 	    >> combination is (3,4).
> 	    >> The R and C indices never take a zero value (to avoid issues
> 	with
> 	    >> negative values around the origin), so this tile corresponds
> 	to a
> 	    >> location of (33, 64) in the old scheme.
> 	    >> I took a quick look at the Tile Map Service Specification,
> 	but it
> 	    >> doesn't appear to support the concept of grouping blocks of
> 	tiles
> 	    >> into subfolders in its current form. Can you provide more
> 	    >> information on whether this is possible?
> 	    >> Chris.
> 	    >> _______________________________________________
> 	    >> mapguide-internals mailing list
> 	    >> mapguide-internals at lists.osgeo.org
> 	    >> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
> 	    > |Chief Technology Officer
> 	    > |DM Solutions Group Inc
> 	http://www.dmsolutions.ca/ |
> 	<winmail.dat>
> 	|Paul Spencer                          pspencer at dmsolutions.ca    |
> 	|Chief Technology Officer                                         |
> 	|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
> <winmail.dat>
More information about the mapguide-internals mailing list
