[mapguide-internals] question about inserting features
Robert Bray
rbray at robertbray.net
Thu Jul 19 17:21:56 EDT 2007
This is all somewhat odd and probably a bug that should be logged.
UpdateFeatures should return the identity property(ies) of the newly
created feature.
Bob
Paul Spencer wrote:
> Hi Traian,
> its an SDF file. I did end up getting contains to work using a negative
> buffer, but I am currently working on a different solution that is
> (hopefully) less error prone than doing a spatial selection to get back
> the feature that I inserted. This is all just a work-around for not
> being able to access the newly inserted features through the result object.
> Cheers
> Paul
> On 18-Jul-07, at 9:52 AM, Traian Stanev wrote:
>> At least some of these should have worked. I am late to the thread, so I
>> may have missed this, but what data source are you inserting the feature
>> into (SDF, SHP, some DB?)
>> Traian
>> -----Original Message-----
>> From: mapguide-internals-bounces at lists.osgeo.org
>> [mailto:mapguide-internals-bounces at lists.osgeo.org] On Behalf Of Paul
>> Spencer (External)
>> Sent: Tuesday, July 17, 2007 10:27 PM
>> To: Paul Spencer (External)
>> Cc: MapGuide Internals Mail List
>> Subject: Re: [mapguide-internals] question about inserting features
>> Another problem (potential problem) has cropped up. I thought that I
>> could provide a mechanism to do this by performing a select after
>> insert and using a spatial filter that had the geom that was inserted
>> and an operation of Equals. Doesn't work. I also tried CoveredBy
>> using a buffered version of the geometry. Doesn't work either.
>> Should any of these strategies work?
>> Paul
>> On 17-Jul-07, at 8:19 AM, Paul Spencer wrote:
>>> Hi Trevor ... nice thought ... GetPropertyType() returns 12,
>>> MgPropertyType::Feature ... This makes sense because the identity
>>> property of a feature source may be composed of several attributes
>>> so there wouldn't necessarily be a single value.
>>> I hadn't checked the property type before, but I did print_r($res-
>>>> GetItem(0)->GetValue()) and it told me it was an
>>> mg_feature_reader_obj (or something like that) and ReadNext() also
>>> did not fail - it is only the calls to get at the properties that
>>> fail with a null reference.
>>> Cheers
>>> Paul
>>> On 16-Jul-07, at 5:54 PM, Trevor Wekel wrote:
>>>> Hi Paul,
>>>> I wonder if UpdateFeatures returns the identity property for the
>>>> inserted property and not an MgFeatureReader. Try calling
>>>> res->GetItem(0)->GetPropertyType() and see what the type is.
>>>> Thanks,
>>>> Trevor
>>>> Spencer (External)
>>>> Sent: Monday, July 16, 2007 3:27 PM
>>>> To: MapGuide Internals Mail List
>>>> Subject: [mapguide-internals] question about inserting features
>>>> Hi all,
>>>> when inserting new features into a feature source, the (php) code
>>>> looks like this:
>>>> $className = $layer->GetFeatureClassName();
>>>> $cmd = new MgInsertFeatures($className, $drawProps);
>>>> $commands = new MgFeatureCommandCollection();
>>>> $commands->Add($cmd);
>>>> $res = $featureService->UpdateFeatures($dataSourceId, $commands,
>>>> false);
>>>> this works great. What I would like to do is access the newly
>>>> created feature. According to the documentation, the result of
>>>> UpdateFeatures is an MgPropertyCollection which should have one
>>>> property, of type MgFeatureProperty whose value is an MgFeatureReader
>>>> that contains the set of properties inserted into the datastore by
>>>> the insert command.
>>>> When I try to get access to the properties, I receive an error
>>>> - MgFeatureReader.GetPropertyCount line 29 file .\Services
>>>> \FeatureReader.cpp
>>>> This happens with the following code:
>>>> $featureReader = $res->GetItem(0)->GetValue();
>>>> while ($featureReader->ReadNext()) {
>>>> $nProps = $featureReader->GetPropertyCount();
>>>> // would do something more here if it didn't crap out
>>>> Is this the right way to access a newly inserted feature? If not,
>>>> then how should I do it? If yes, is the code wrong or is there a bug
>>>> somewhere?
>>>> Cheers
>>>> Paul
>>>> |Paul Spencer pspencer at dmsolutions.ca |
>>>> |Chief Technology Officer |
>>>> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
>>>> _______________________________________________
>>>> mapguide-internals mailing list
>>>> mapguide-internals at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-internals
More information about the mapguide-internals
